Job Management
The direct management of CommCell jobs is performed using the Job Controller. To begin using the Job Controller, see Getting Started with the Job Controller.
There are additional CommCell job management functions you can configure.
Job management functions
Activity Control
Enable or disable jobs from all levels of the hierarchy in the CommCell.
Activity Monitoring
Monitor CommCell activity in the CommCell Console. See CommCell Console - Advanced.
Customize Calendars and Blackouts Windows
Define calendars for schedules, data aging and auxiliary copy operations, and restrict activity types to certain times of the day. See Custom Calendars Overview and Blackout Window.
Error Conditions
Define rules to control and update the status of jobs. See Customizing Completed with Errors Condition - Overview.
Events
View events and status information for jobs. See Event Viewer Overview.
Job History
View detailed, historical information about a job. See Job History Overview.
Job Priority
Define which job has precedence over other competing jobs. See Overview of Job Priorities and Priority Precedence.
Job Restartability
Configure job types for restartability, maximum number of restart attempts, the interval, and other options. See Overview of Job Restartability.
Job Results Location
Define where job results files are stored. See Job Results Directory Overview.
Job Schedules
Schedule jobs to perform CommCell operations on a regular basis without user intervention. See Scheduling.
Job Throttling
Limit the number of data and log backup jobs that run simultaneously. See Throttling Backup Jobs.
Blackout Window
Prevent operations from running during certain time periods of the day. See Blackout Window.
Schedule Policies
Create a schedule policy as a template when multiple clients or tasks require similar operations to be scheduled. See Overview of Schedule Policy.
CommCell Access
