The following requirements are for the NDMP Agent.
File Server Operating System
The following table lists the supported file server versions for each vendor:
Vendor |
Supported File Server |
Dell Compellent FS |
5.0 to 7.0 |
Dell EMC Isilon/PowerScale |
7.0 through 9.8 The Dell EMC Isilon/PowerScale Backup Accelerator is supported for NDMP backups. |
Dell PowerStore |
1.0, 2.0, 3.0, 3.5.0.1, 3.6, 4.0 |
Dell EMC Unity |
4.1 to 4.5, 5.0.3, 5.1.2.0.5.007, 5.2.0, 5.3.1, 5.4 |
Dell EMC VNX / Celerra |
DART 5.5, 5.6, 6.0 |
Dell EMC VNX and Dell EMC VNX2 |
7.0, 7.1, 8.1, 8.2 |
Dell EMC VNXe |
2.0 |
FUJITSU Storage ETERNUS AC/AX/HX Series |
ONTAP versions
Hitachi NAS (VSP One File) |
Up to 15.1 |
Huawei OceanStor V3 Converged Storage |
1.0 |
Huawei OceanStor V5 Converged Storage |
1.0 |
Huawei OceanStor 9000 Storage |
1.0 |
IBM N-Series |
Lenovo DM Series |
ONTAP versions
NetApp |
NexentaStor |
Version 5.0 |
Nexsan |
UNITY 1.1 |
Oracle ZFS Storage Appliance |
ak-2009.09.01.* 2010.02.09.* 2010.08.17.* 2011.04.24 2013.06.05.* *The dump-pathnode setting must be set to yes. dump-pathnode is required so that restores from incremental backups have the necessary information to complete. Consult Oracle documentation for instructions about enabling this setting. |
Stratus |
3.0 |
**The Active IQ Unified Manager (AIQUM) 9.14 and 9.13P1 are not supported. If you are using AIQUM-based replication, Commvault recommends verifying support from NetApp Interoperability Matrix for ONTAP 9.14.1, 9.15.1, and 9.16.1 with AIQUM 9.13 or older. For information on why certain AIQUM versions are not supported, see the NetApp KB articles CAIQUM-5577 and CAIQUM-6267.
The AIQUM 9.13 version is supported only with specific NetApp patches. For information on the AIQUM version, see the NetApp article and contact NetApp.
Hard Disk
No minimum disk space requirement for installing the software. All required components are installed automatically with the MediaAgent software. There is no separate software to install for NAS Clients. See System Requirements - MediaAgent for information on install information specific to the MediaAgent.
2% of the backup size in free disk space is required for the job results directory. For example, if the backup is 40 GB, then you must have 0.8 GB of free space for the job results directory.
256 MB of free disk space is required for log directory.
MediaAgent Operating System
Only MediaAgents with the following operating systems can be used when performing data protection operations with NDMP agent data:
AIX
HP-UX
Linux (except Itanium varieties)
Solaris
Windows
See System Requirements - MediaAgent for information on specific versions supported with these operating systems.
Miscellaneous
File Server
If media changers and/or tape drives are attached to the file server, all hardware (including the SAN networking hardware) must be of a type supported by the file server.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Microsoft Windows 10 and Microsoft Windows Server 2016, because these versions have the Universal C Runtime already installed.
KB2919355
KB2939087
KB2975061
KB2999226
DISCLAIMER
