You can launch the netx.jar file from the command line interface. Use the netx.jar file to access the CommCell Console remotely from any computer where the netx.jar file exists.
- The minimum JRE version on the computer must be the same major version that Commvault deploys (or a newer minor/patch level).
On the command line, go to software_installation_directory/GUI, and then type the following command:
where:java –jar netx.jar [-options] -
\-basedir dir: Directory where the cache is kept. -
\-commservehostname: Sets the default CommServe to connect -
\-jnlp location: Location of JNLP file to launch (url or file). -
\-reconfigure: Deletes the directory where the cache is kept and asks user to enter directory details again. -
\-force: Always download the jars. -
\-arg arg: Adds an application argument before launching. -
\-param name=value: Adds an applet parameter before launching. -
\-property name=value: Sets a system property before launching. -
\-update seconds: Update check if seconds since last checked. -
\-license: Display the GPL license and exit. -
\-verbose: Enable verbose output. -
\-about: Streamed from the internet. -
\-nosecurity: Disables the secure runtime environment. -
\-noupdate: Disables checking for updates. -
\-headless: Disables download window, other UIs. -
\-strict: Enables strict checking of JNLP file format. -
\-help: Print this message and exit.
