There are restrictions and known issues for protecting Kubernetes with Commvault. Workarounds, if available, are included.
Restrictions
Supportability
Protection of etcd is not supported for managed Kubernetes services like on Amazon EKS, Azure AKS, Google GKE, etc.
Use of the Rancher management endpoint is not supported.
As a workaround, add Rancher clusters using the control plane endpoint for the Kubernetes cluster. For more information, see Adding a Kubernetes Cluster.
Data You Cannot Back Up
KubeVirt.io-managed virtual machines
Windows containers in Kubernetes
Data You Cannot Restore
- System namespaces (kube-system, kube-node-lease, kube-public) that have the overwrite option enabled
Kubernetes resources that have an owner reference to a parent resource are not restored. The parent is restored, and then the parent creates the child resource. For example, for a Pod that is created by a Deployment, Commvault restores the Deployment (but not the Pod), and then the Deployment creates the Pod.
Known Issues
Guided Setup
When you complete the Kubernetes guided setup, add a Kubernetes cluster, or create a Kubernetes application group, you can create a Windows x86 64-bit access node, but you cannot create a Linux access node. To add a Linux access node, see Adding an Access Node for Kubernetes.
When you complete the Kubernetes guided setup or add a Kubernetes cluster, on the Add Cluster page, if you click the Previous button to review the server plan or access node, the cluster is not added and the cluster information is not retained.
Adding a Cluster
- Commvault does not support creating a volume-based protection application group with both file-mode and block-mode volumes included. Please select the entire namespace to protect applications with both file-mode and block-mode volumes.
Adding a Cluster: Authentication
Commvault supports authentication and authorization with the default cluster-admin role or a custom ClusterRole created from the cvrolescript.sh. Commvault does not support the creation or usage of restricted ClusterRoles that have limited access to specific namespaces, applications, and/or API resources.
Commvault supports service account tokens for authentication exclusively.
Application Groups
When an application group uses application-centric protection to protect individual applications or content detected using label selectors, related API resources/objects are intelligently inferred based on the application manifest and/or helm chart. If an API resource/object exists in the application namespace, but is not directly referenced, the resource/object is not protected.
To protect all API resources/objects in a namespace, use namespace-centric protection. For more information, see Namespace-Centric and Application-Centric Protection for Kubernetes.
Backups of applications and/or application group with full or partial failure do not identify the source host, but instead indicate that the problem occurred on host[].
Application or application group failures indicate that the access node (referred to as proxy) might not be able to communicate with the host. The destination host is not identified in the failure reason.
Clicking a failed or partially failed last backup on the Application group tab refers to failed entities as VMs instead of as Kubernetes applications.
As a workaround, re-run the application group backup from the application group properties page.
Exclusion filters operate at the level of an application, namespace, or volume. Exclusion of specific API resources (for example, excluding specific secrets via wildcard) is not supported.
When you specify exclusions, the effect of both including and excluding an object depends on the type of the object. If you both add and exclude the same application, the application is not backed up. If you both add and exclude the same namespace, the namespace is backed up.
Clusters Page
Commvault tags attached to a cluster resource are not displayed on the Clusters page.
As a workaround, click the cluster to view the cluster properties page, and then go to the Configuration tab.
The Content section of the application group properties page does not show Kubernetes-native icons for included content rules. This known issue does not affect protection of these resources.
Commvault tags that are attached to an application group are not displayed on the Application groups page.
As a workaround, click the application group, then go to the Configuration tab to view the tags.
Applications Page
When you select the etcd (system generated) application on the Application page, and then clicking Restore, the Application manifests and Full application options are presented. Only the Application files restore type can be used.
As a workaround, go to the etcd (system generated) application group properties page, and then click the Restore button.
Commvault tags attached to an application are not displayed in the Applications page.
As a workaround, click the application, and then go to the Configuration tab to view the tags.
Cleanup of Temporary Resources
If a backup or restore operation fails, the Commvault software might not remove temporary volume snapshots, volumes, and Commvault worker pods. The software removes such entities when a subsequent backup operation is initiated. In case of restore operation, a cleanup process runs automatically to remove the entities. These resources will continue to consume CPU, memory, and diskspace on your cluster until manually removed. Additionally, when multiple access nodes are used to perform data management, if a subsequent data management job is scheduled on another access node, that access node will not be aware of previously created temporary resources for cleanup.
As a workaround, you can identify and manually remove leftover temporary resources.
Command to list temporary resources:
kubectl get pods,pvc,volumesnapshot -l cv-backup-admin= --all-namespaces
If necessary, you can delete the temporary resources
kubectl delete <pod|pvc|volumesnapshot> resource_name -n namespace
Backups
Backups might fail when the Kubernetes API server is behind either a load balancer or Ingress. The following error appears in logs:
15784 f18'a0'a0 08/04 16:04:39 130730 VSBkpWorker::BackupVMFileCollection() - Failed to backup file collection accessnode-certsandlogs due to 0xFFFFFFE2:{CK8sFSVolume::readNodeContentBlock(263)/ErrNo.-30.(Unknown error)-file collection data read failed. error Truncated tar archive.} 'a0If you encounter this problem, try adding the cluster in the Command Center without a load balancer or Ingress.
Commvault protects control plane SSL certificates from the node that runs the etcd POD (at time of backup). To capture all SSL certificates, from all control plane nodes, see Configuration for Kubernetes SSL Certificates.
Commvault protects SSL certificates in controlplane-node: /etc/kubernetes/pki/etcd. Certificates in the /etc/kubernetes/pki folder are not collected. To capture all SSL certificates from all control plane nodes, see Configuration for Kubernetes SSL Certificates.
Backups might behave incorrectly if the Job Results directory path for a Windows access node is greater than 256 characters.
As a workaround, move the Job Results directory to a shorter path. For instructions, see Changing the Path of the Job Results Directory.
When you view backup job details, some descriptions (such as "VM Admin Job(Backup)" and "Virtual Machine Count") refer to "virtual machine" or "VM" instead of "application".
Commvault creates the worker Pods without any restrictions on CPU or memory. If necessary, you can apply CPU and memory restrictions. For information, see Modifying the Resource Limits for Commvault Temporary Pods for Kubernetes.
Restores
Commvault cannot restore etcd snapshots to the original pod or an alternate running etcd pod. Instead, restore the snapshot to a Commvault access node file system, and then transfer the snapshot to the intended control plane node. For instructions, see Restoring a Kubernetes etcd Snapshot to a File System.
Commvault cannot restore control plane SSL certificates to the original or alternate running etcd POD. Restore to a Commvault access node file system, and then transfer to intended control plane node. For information, see Configuration for Kubernetes SSL Certificates.
Commvault cannot perform application restores or migration between different releases of Kubernetes. Commvault requires that the same major revision is running on both the source cluster and the destination cluster for application migration to succeed.
Commvault does not perform API resource transformation when restoring objects cross cluster. If you are restoring networking resources with references to the source cluster (for example, endpoints, endpointslices, routes), restore the manifest, update networking information to reference the destination cluster, and then manually schedule on the cluster using kubectl utility.
When you perform a restore for a stateless application or namespace the Restore options page shows a Storage class mapping section. There is no ability to assign a StorageClass during a restore without PersistentVolumeClaims.
This input can be safely ignored.
When you perform an etcd SSL certificate or etcd snapshot recovery to an access node file system, the Restore options page shows a Volume destination by default. Restoring to an existing PersistentVolumeClaim (PVC) or Volume is not supported.
As a workaround, select the File system destination tab when you perform an etcd SSL certificate or etcd snapshot recovery.
When you perform an etcd SSL certificate or etcd snapshot recovery to a file system destination, the Path setting does not allow an existing or new path to be directly typed into the input box.
As a workaround, click the Browse button, and then select an existing folder or create a new folder.
When you perform an etcd SSL certificate or etcd snapshot recovery to a file system destination, the software incorrectly shows access node groups in the Destination client list. For the restore to complete successfully, you must select an individual access node, not a group.
Live browse operations are not supported for Kubernetes.
Operations: Job Monitor and Log Files
Within Kubernetes protection log files (vsbkp.log, vsrst.log), containerized applications might be referred to as "Virtual Machines" or "VMs". This known issue does not affect protection activity.
Within Kubernetes protection jobs, errors might refer to the Kubernetes access node as a "proxy". The "proxy" and "access node" terms are used interchangeably for servers that run the Virtual Server package. This known issue does not affect protection activity.
