Running a Data Aging Job
You can run a data aging job at the CommServe level.
  1. From the CommCell Console, right click the CommServe node, click All Tasks > Data Aging.
  2. In the Data Aging Options dialog box, in the Job Initiation area, define whether the data aging job runs immediately or if it will be scheduled.
  3. Click OK.
    • If you chose to run the job immediately, the data aging job starts now.
    • If you chose to run the job according to a schedule, the data aging runs according to the schedule that you defined.
After data aging job is run, the data will be pruned from the storage.
