Verify that your environment meets the system requirements for the Solaris file system.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system |
Processor architecture |
Solaris 11.x |
Solaris 10.x (Flying Zones supported) For Solaris 10 and previous releases, you must install the SUNWcry package. |
UltraSPARC-II or more recent recommended |
Solaris 10 Update 11 or equivalent For Solaris 10 Update 11 or equivalent, you must install the SUNWcsl and SUNWcry packages. |
Hard Drive
Component |
Space required |
Software |
Job results folder |
To calculate the space required for the job results folder, see Job Results Directory Disk Space Calculation. |
Log folder By default, /var/log is the log directory. |
500 MB |
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Memory (RAM)
2 GB or more
An additional 1.5 GB for every 500,000 folders in the backup data
File Systems
Unix File System (UFS)
Oracle ASM Cluster File System (Oracle ACFS)
VERITAS File System (VxFS)
VERITAS Cluster File System (VxCFS)
Zettabyte File System (ZFS)
Extended attributes in the VxFS, UFS, and ZFS file systems
Schedule Jobs Using a Client Computer's Time Zone
The client computer has to be in one of the standard time zones recognized by the CommServe server. Otherwise, the CommServe server is not updated with the client computer's time zone and the jobs scheduled using the client computer's time zone might not run.
Volume Managers
Veritas Volume Manager (VxVM) 5.0 or a more recent version
Solaris Volume Manager (SVM)
DISCLAIMER
