You can stop and restart a single node in a HyperScale cluster when required. To maintain data integrity and prevent data loss, always follow the shutdown and startup procedures outlined on this page when stopping or starting a node. Use these steps to safely shut down and restart a single node for maintenance purposes.
- If more than one node must be shut down, shut down the entire cluster using the procedure described in Stopping and Starting the Cluster. Improperly shutting down multiple nodes individually can result in data integrity issues, data loss, and restore failures.
- Before stopping a node, verify the cluster status by running the following command to confirm that all services are fully online on the remaining nodes:
After starting a node, it may take up to one hour for all services to come online. Do not stop the next node until you confirm the services are fully operational. Stopping another node prematurely may result in two nodes being offline simultaneously, which can compromise data integrity./usr/local/hedvig/scripts/showmembers.exp
If you have setup a Primary and Standby CommServe server, verify whether the CommServe server is currently active on the node that you want to stop. Use the following steps to identify the currently active and passive nodes:
Login to the Command Center. For more information on logging in to the Command Center, see Accessing the Command Center.
From the navigation pane, expand Administration > System, and then click CommServe LiveSync.
The CommServe LiveSync page appears.
Under Nodes, verify the Node Information which displays the currently active and passive nodes.
If the CommServe server is currently active on the node that you want to stop, failover the CommServe server to the standby node. For more information on failover over a node, see Planned Failovers.
Stopping a Node
Stop or suspend all running jobs that are associated with the MediaAgent installed in the node that you plan to shut-down. For more information, see Controlling Jobs.
Set the MediaAgent on maintenance mode. For more information, see Setting the MediaAgent on Maintenance Mode.
Stop the Commvault services, and verify that the Commvault File System (CVFS) vdisk is unmounted on the node: :
Using an SSH client program, like PuTTy on Windows, login to any one of the nodes using the
rootcredentials. -
Stop the services using the following command:
# commvault stop -
To verify that the vdisk is unmounted successfully, run the following command:
The output should not appear like below:# df -h127.0.0.1:/exports/CVLTBackupSMC43002153 269T -1.5T 271T 0% /ws/hedvig/CVLTBackupSMC43002153 127.0.0.1:/exports/CVLTBackupSMC43002153 269T -1.5T 271T 0% /ws/hedvig/CVLTBackupSMC43002153-r
Stop the nodes using the following commands:
On nodes with HyperScale 2.x installations, before you stop the nodes, switch to the admin user using the command,
# su - admin.# export HV_PUBKEY=1 # /opt/hedvig/bin/hv_deploy --show_all_clustersThis will display the cluster name, as shown in the following sample output:
Cluster name: HV13102021054000 - owner: unowned - version: v-4.5.0.0.2.3597.00320e0ba9:06aca75bc4db06170a13ef14cbfe8446Use the cluster name to stop the node using the following command:
# /opt/hedvig/bin/hv_deploy --stop_node fqdn hostname --cluster_name ClusternameFor example:
# /opt/hedvig/bin/hv_deploy --stop_node hs2300m5.company.com --cluster_name HV13102021054000 ... provisioning as a hsx cluster. details: ApplianceType HS2300 ... logged into commvault cluster Ensuring password-less SSH connections have been added for all cluster machines. RUNNING: stop_node ************************************************************* RUNNING PLAY 1 [stop hedvig hblock] ******************************************** RUNNING PLAY 2 [stop hedvig pages] ********************************************* RUNNING PLAY 3 [stop hedvig hpod] ********************************************** COMPLETED PLAY 3 *************************************************************** ACTION RECAP: ****************************************************************** hs2300m5.company.com : ok=9 changed=0 unreachable=0 failed=0
Starting a Node After a Reboot
Reboot the node using the following command:
# rebootAfter a reboot all the services will be automatically restarted and the CVFS vdisk will be mounted.
Disable the maintenance mode for the MediaAgent to bring it online. For more information, see Setting the MediaAgent on Maintenance Mode.
Starting a Node Manually
Using an SSH client program, like PuTTy on Windows, login to a node using the
rootcredentials. -
Start the nodes using the following commands:
Cluster name: HV13102021054000 - owner: unowned - version: v-4.5.0.0.2.3597.00320e0ba9:06aca75bc4db06170a13ef14cbfe8446Use the cluster name to start the node using the following command:
# /opt/hedvig/bin/hv_deploy --start_node fqdn hostname --cluster_name ClusternameFor example:
# /opt/hedvig/bin/hv_deploy --start_node hs2300m5.company.com --cluster_name HV13102021054000 ... provisioning as a hsx cluster. details: ApplianceType HS2300 ... logged into commvault cluster Ensuring password-less SSH connections have been added for all cluster machines. RUNNING: start_node ************************************************************ RUNNING PLAY 1 [collect deploy server facts] *********************************** RUNNING PLAY 2 [start node] **************************************************** COMPLETED PLAY 2 *************************************************************** ACTION RECAP: ****************************************************************** hs2300m5-1a.company.com : ok=16 changed=10 unreachable=0 failed=0 localhost : ok=2 changed=0 unreachable=0 failed=0 -
Start the Commvault services. (This will also mount the CVFS vdisk.)
# commvault start -
