The following cloud storage products are supported by the Commvault software.
Cloud Storage Product |
Details |
Deduplication Support |
Micro Pruning Support |
Air Gap Protect |
Alibaba Cloud Object Storage Service |
http://intl.aliyun.com/?spm=a3c0i.6010108.66002.1.1WSEoG The following storage classes are supported:
Combined Storage tiers and Archive not supported. |
Amazon Glacier (Direct) |
Amazon S3 |
The following Amazon S3 storage classes are supported for Commvault Cloud Storage libraries:
The following combined Storage options are available for the Glacier Flexible Retrieval and Glacier Deep Archive storage classes:
Note If you use the Intelligent Tiering storage class for long term retention, you must disable micro pruning and enable seal deduplication database (DDB) options.
Combined Storage tier, Glacier Flexible, and Glacier Deep Archive not supported.
Commvault Cloud supports the following server-side encryptions:
The following AWS Snow Family devices are supported:
AT&T Synaptic Storage
CCL Vault v2
https://concepts.co.nz/capabilities/hybrid-multi-cloud-solutions/
Ceph Object Gateway (S3-compatible)
China Mobile oNest
Cloudian HyperStore
DataCore Swarm
DDN WOS
http://www.ddn.com/products/object-storage-web-object-scaler-wos/
Dell DX Object Storage Platform
http://www.dell.com/us/business/p/powervault-dx6012s/pd http://content.dell.com/us/en/enterprise/cloud-computing.aspx
Dell EMC ECS (S3-Compatible)
EMC Atmos
Fujitsu Storage ETERNUS CD 1000
https://www.fujitsu.com/us/products/computing/storage/eternus-cd/s1/
Google Cloud Storage
https://cloud.google.com/storage/ You can create Google storage classes from the Google site. The following storage classes are supported:
Google Transfer Appliance supported. See Migrating or Seeding Data to Google Cloud Using Google Transfer Appliance.
Hitachi Content Platform (REST API) Hitachi Content Platform (HS3) Hitachi Content Platform for Cloud Scale (S3)
https://www.hitachivantara.com/en-us/products/storage/object-storage/content-platform.html
Huawei Object Storage
IBM Cloud Object Storage
IBM Cloud Object Storage (S3-compatible)
Inspur Cloud Object Storage
http://en.inspur.com/inspur/2228467/2228735/2228817/index.html
Iron Mountain Iron Cloud
https://www.ironmountain.com/services/iron-cloud-data-management
Iron Mountain Iron Cloud Secure Offline Storage (SOS)
https://www.ironmountain.com/resources/solution-guides/i/iron-cloud-secure-offline-storage
Kingsoft Standard Storage Service
http://www.kingsoftstore.com/support-for-android-office/2832-how-to-do-setup-cloud-storage.html
Microsoft Azure Storage
Azure Stack Hub storage https://docs.microsoft.com/en-us/azure-stack/user/azure-stack-storage-overview?view=azs-2002 https://docs.microsoft.com/en-us/azure-stack/user/azure-stack-acs-differences?view=azs-2002
Immutable Storage feature of Azure Blob Storage (WORM state) https://docs.microsoft.com/en-us/azure/storage/blobs/storage-blob-immutable-storage The following storage classes are supported:
Note Commvault supports only version-level immutability.
Azure Data Box supported.
Microsoft OneDrive
NetApp StorageGRID
https://www.netapp.com/us/products/data-management-software/object-storage-grid-sds.aspx
Nutanix Objects
OpenStack® Object Storage
Oracle Cloud Infrastructure Archive Storage
Oracle Cloud Infrastructure Archive Storage Classic
Oracle Cloud Infrastructure Object Storage
Oracle Cloud Infrastructure Object Storage (S3 Compatible)
Oracle Cloud Infrastructure Object Storage Classic
Pure Storage FlashBlade
Quantum ActiveScale
https://www.quantum.com/en/products/object-storage/ The following storage classes are supported:
Rackspace Cloud Files
S3 Compatible Storage
Supported Cloud Storage - S3 Compatible Object Storage Vendors
Scality RING
Telefonica Open Cloud Object Storage
VAST Data Platform
Verizon Cloud Storage
https://www.verizonwireless.com/support/verizon-cloud/cloud-website/
VMware vCloud Air Object Storage
Wasabi Hot Cloud Storage
If a cloud storage product is not listed in this list, but a product is compatible with any one of the vendors listed below, you can verify its compatibility with Commvault software. For more information, see Verifying Cloud Storage Product Compatibility with Commvault.
Yes
No
