Beginning from Commvault Platform Release 2024, version 1 indexing for Unix file system is no longer supported.
For comprehensive information about deprecated features, see End-of-Life, Deprecated and Extended Support - Features.
The following table lists the features that are supported by this Agent.
Feature |
Sub-Feature |
Support |
Comments |
Advanced Backup/Archive Options |
Data tab - Verify Synthetic Full |
Job Retry tab |
Media tab - Allow other Schedule to use Media Set |
Media tab - Mark Media Full on Success |
Media tab - Reserve Resources Before Scan |
Media tab - Start New Media |
Startup tab |
Vault Tracking tab |
Comments |
Additional option in the Data tab: |
Advanced File System Agent Options |
Automatic File System Multi-Streaming |
On-Demand Data Protection Operation |
Restore by Jobs |
Restore Data Using a Map File |
Comments |
Global Alerts |
Job-Based Alerts |
Comments |
Block-Level Backup |
Differential Backup |
Full Backup |
Incremental Backup |
Synthetic Full Backup |
Comments |
Browse from Copy Precedence |
Browse the Latest Data |
Browse Using Filters |
Exclude Data Before |
Find |
Full Backup Transparent Browse |
Image Browse |
No Image Browse |
Page Size |
Specify Browse Path |
Specify Browse Time |
Subclient Browse |
Use MediaAgent |
View All Versions |
Comments |
Netware cluster |
Unix Cluster |
Windows - Microsoft Cluster (MSCS) |
Windows - Non-Microsoft Cluster |
Comments |
AIX, HP-UX, Linux and Solaris support VERITAS Cluster |
Command Line Interface |
Comments |
CommCell Migration |
Comments |
CommCell Migration is also supported with Virtualize Me and 1-Touch restores. |
Offline Content Indexing |
Comments |
Basic Retention Rules |
Deleting a Job |
Extended Retention Rules |
Retaining a Job |
Unique Data Aging Rules |
Comments |
Client Compression |
Hardware Compression |
MediaAgent Compression |
Comments |
Data Encryption |
Third-party Command Line Encryption Support |
Comments |
Multiplexing |
Comments |
MediaAgent-Side Deduplication |
Source-Side Deduplication |
Comments |
To maintain the deduplication ratio and prevent DDB issues, you can exclude the SQL dump files using the sDedupeExcludeExtensions additional setting. |
Delete Data Using CommCell Console |
Delete Data Using Web Console |
Comments |
File System Backup Quota |
Comments |
Global Filters |
Comments |
GRC |
Comments |
GRC is supported with Virtualize Me and 1-Touch Restore. |
Installing 32-bit Components on a Microsoft Windows x64 Platform |
Install 32-bit On x64 |
Comments |
Not Restartable |
Restarts from the Beginning |
Restarts from the Beginning of the Database |
Restarts from the Point-of-Failure |
Comments |
Not Restartable |
Comments |
List Media Associated with a Specific Backup Set or Instance |
List Media Associated with Index |
List Media Associated with Specific Files and/or Folders |
List Media Associated with Specific Jobs |
Comments |
Replication |
Failover |
Failback |
Validation |
Multi-Instance Installations |
Comments |
Optimized Scan |
Comments |
Pre/Post Process with Data Protection and Recovery |
Comments |
Cross-Application Restores (Different Application version) |
Cross-Platform Restores - Different Operating System |
Cross-Platform Restores - Same Operating System - Different Version |
In-place Restore - Same path/ destination - Same Client |
Out-of-place Restore - Different path/ destination |
Out-of-place Restore - Same path/ destination - Different Client |
Point-in-Time Restore |
Restore to Network Drive /NFS-Mounted File System |
Table-Level Restore |
Comments |
Automatic Detection of Regular Expressions |
Filter Data From Recover Operations |
Rename/ Redirect Files on Restore |
Restore Data Using Wildcard Expressions |
Restore Data with Pre/Post Processes |
Restore from Copies |
Skip Errors and Continue |
Use Exact Index |
Use MediaAgent |
Comments |
Restore/Recover/Retrieve Overwrite Options |
Overwrite Files |
Overwrite if file in backup is newer |
Restore only if target exists |
Unconditional Overwrite |
Unconditionally overwrite only if target is a DataArchiver stub |
Comments |
Agent Specific Data Protection Schedule Policy |
All Agent Types Schedule Policy |
Comments |
Incremental Storage Policy |
Standard Storage Policies |
Comments |
Subclient Policy |
Comments |
Not supported with block-level backups |
Backup Set/Archive Set |
Instance |
Subclient |
Comments |
Web Console Interface |
Comments |
For supported operations, see My Computers. |
