Library and Drive Configuration
File System Restore iDataAgent
MS Exchange Restore iDataAgent
Alert Comment Messages
| Code | Description |
| 83:1 | IIS Server Name changed from [<String>] to [<String>]. |
| 83:2 | IIS Server Install Location changed from [<String>] to [<String>]. |
| 83:3 | IIS Server Books Online Alias changed from [<String>] to [<String>]. |
| 83:4 | Use alternate IIS Server option was Deselected. |
| 83:5 | Use alternate IIS Server option was Selected. |
| 83:6 | IIS Server User Name changed from [<String>] to [<String>] |
| 83:7 | IIS Server User Password was changed. |
| 83:8 | Maintenance Advantage User Name changed from [<String>] to [<String>] |
| 83:9 | Maintenance Advantage User Password was changed. |
| 83:10 | KB Link for JPR User Name changed from [<String>] to [<String>] |
| 83:11 | KB Link for JPR User Password was changed. |
| 83:12 | Job Controller Job Retention Time changed from [<Number>] to [<Number>]. |
| 83:13 | Scheduler has been enabled. |
| 83:14 | Scheduler has been disabled. |
| 83:15 | SNMP Traps Support has been enabled and is set to [<Number>]. |
| 83:16 | SNMP Traps Support has been disabled. |
| 83:17 | Audit Trail Recording Level has been enabled and is set to [<Number>]. |
| 83:18 | Audit Trail Recording has been disabled. |
| 83:19 | Audit Trail Recording Level changed from [<Number>] to [<Number>]. |
| 83:20 | Audit Trail retention time changed from [<Number>] to [<Number>] days. |
| 83:21 | Jobs Complete Past Operational Window Option changed from [<String>] to [<String>]. |
| 83:22 | Jobs Complete If Activity Disabled Option changed from [<String>] to [<String>]. |
| 83:23 | Queued Jobs if activity is disabled was [<String>]. |
| 83:24 | Queue Jobs If Other Jobs Running Option changed from [<String>] to [<String>]. |
| 83:25 | Disable Software Update Reboot Option changed from [<String>] to [<String>]. |
| 83:26 | ER Storage Policy changed to [<String>]. |
| 83:27 | Express Recovery user name changed from [<String>] to [<String>]. |
| 83:28 | Mail Server changed from [<String>] to [<String>]. |
| 83:29 | Sender's Address changed from [<String>] to [<String>]. |
| 83:30 | SMTP Port number changed from [<Number>] to [<Number>]. |
| 83:31 | SMTP Max Message Size changed from [<Number>]KB to [<Number>]KB. |
| 83:32 | Express Recovery User name and password deleted. |
| 83:33 | Express Recovery user password was changed. |
| 83:34 | Maximum Events in event log changed from [<Number>] to [<Number>]. |
| 83:35 | GUI Timeout changed from [<Number>] to [<Number>]. |
| 83:36 | GUI Timeout after [<Number>] minutes idle has been turned on. |
| 83:37 | GUI Timeout has been turned off. |
| 83:38 | GUI Timeout changed from [<Number>] to [<Number>] minutes idle. |
| 83:39 | Job Alive Retry changed from [<Number>] to [<Number>]. |
| 83:40 | Job Alive check interval changed from [<Number>] to [<Number>]. |
| 83:41 | Job high watermark changed from [<Number>] to [<Number>]. |
| 83:42 | Job low watermark changed from [<Number>] to [<Number>]. |
| 83:43 | Job Priority Precedence Changed |
| 83:44 | Queue Scheduled Jobs Option has been <String>. |
| 83:45 | Backup preemption of other backups has been <String>. |
| 83:46 | Restore preemption of other jobs has been <String>. |
| 83:47 | Auxiliary Copy preemption of other jobs has been <String>. |
| 83:48 | Backup preemption of Auxiliary Copy and Synthetic Fulls has been <String>. |
| 83:49 | [<String>] priority changed from [<Number>] to [<Number>]. |
| 83:50 | Express Recovery Destination Directory changed to [<String>]. |
| 83:51 | Disaster Recovery Number of Fulls changed from [<Number>] to [<Number>]. |
| 83:52 | Database Space Check Interval changed from [<Number> hour(s) <Number> minute(s)] to [<Number> hour(s) <Number> minute(s)]. |
| 83:53 | Database Space Check Informational Percent Free changed from [<Number>] to [<Number>]. |
| 83:54 | Database Space Check Minor Percent Free changed from [<Number>] to [<Number>]. |
| 83:55 | Database Space Check Major Percent Free changed from [<Number>] to [<Number>]. |
| 83:56 | Database Space Check Critical Percent Free changed from [<Number>] to [<Number>]. |
| 83:57 | Data Replicator Update Interval changed from [<Number>] to [<Number>]. |
| 83:58 | Data Classification Update Interval changed from [<Number>] to [<Number>]. |
| 83:59 | Visibility Checking has been <String>. |
| 83:60 | Use exact index for restore has been <String>. |
| 83:61 | PreScan Command for DR changed from [<String>] to [<String>]. |
| 83:62 | PostScan Command for DR changed from [<String>] to [<String>]. |
| 83:63 | PreBackup Command for DR changed from [<String>] to [<String>]. |
| 83:64 | PostBackup Command for DR changed from [<String>] to [<String>]. |
| 83:65 | Pre/Post User changed for DR Backup . |
| 83:66 | 'Use Pre/Post user' option for DR Backup changed to [<String>]. |
| 83:67 | Pre/Post Password changed doe DR Backup. |
| 83:68 | Attempt to modify <String> denied <String>. |
| 83:69 | <String> operations on this CommCell have been <String>. |
| 83:70 | Volume Creation |
| 83:71 | Data Protection |
| 83:72 | Volume Recovery |
| 83:73 | Data Recovery |
| 83:74 | Auxiliary Copy |
| 83:75 | CommServe ER Backup |
| 83:76 | Data Aging |
| 83:77 | Media Recycling |
| 83:78 | Synthetic Full |
| 83:79 | All |
| 83:80 | Schedule Export |
| 83:81 | Media Inventory |
| 83:82 | Reporting |
| 83:83 | Scheduling |
| 83:84 | Online Content Indexing |
| 83:85 | Offline Content Indexing |
| 83:86 | Unknown |
| 83:87 | enabled |
| 83:88 | disabled |
| 83:89 | yes |
| 83:90 | no |
| 83:91 | Content Changed. |
| 83:92 | Auto Suppress Web Restores Option changed from [<String>] to [<String>]. |
| 83:93 | Network Error Retry Option changed to [<String>]. |
| 83:94 | Network Error Retry Frequency changed from [<Number>] to [<Number>]. |
| 83:95 | Network Error Retry Count changed from [<Number>] to [<Number>]. |
| 83:96 | Secure Agent install has been [<String>]. |
| 83:97 | CSVDE filtering option changed from [<String>] to [<String>]. |
| 83:98 | Client Encryption Restore Access is [<String>], changed from [<String>]. |
| 83:99 | Client Encryption DRTool Access is [<String>], changed from [<String>]. |
| 83:100 | Client Encryption Enable Synthetic Full is changed to [<String>] from [<String>]. |
| 83:101 | Client Encryption Cipher is [<String>], changed from [<String>]. |
| 83:102 | Client Encryption Key Length is [<Number>], changed from [<Number>]. |
| 83:103 | Replication Set [<String>] added. |
| 83:104 | Destination Host changed from [<String>] to [<String>]. |
| 83:105 | Common Base Folder changed from [<String>] to [<String>]. |
| 83:106 | Use Common Folder changed to [<String>]. |
| 83:107 | PreBackup Command changed from [<String>] to [<String>]. |
| 83:108 | PostBackup Command changed from [<String>] to [<String>]. |
| 83:109 | Pre/Post User changed. |
| 83:110 | 'Use Pre/Post user' option changed to [<String>]. |
| 83:111 | Pre/Post Password changed. |
| 83:112 | Initial File Transfer changed to [<String>]. |
| 83:113 | Replicate Data in Remote Storage changed to [<String>]. |
| 83:114 | Compression changed to [<String>]. |
| 83:115 | Encryption changed to [<String>]. |
| 83:116 | Follow Mountpoints changed to [<String>]. |
| 83:117 | Include ACLs changed to [<String>]. |
| 83:118 | Allow Consistency Points changed to [<String>]. |
| 83:119 | Auto Mount Snapshot changed to [<String>]. |
| 83:120 | Snap Engine for Recovery Point Creation changed to QSnap. |
| 83:121 | Snap Engine for Recovery Point Creation changed to VSS. |
| 83:122 | Automatic Resync changed to [<String>]. |
| 83:123 | Orphan Handling changed to [<String>]. |
| 83:124 | Log file name changed to [<String>]. |
| 83:125 | Delete Orphans changed to [<String>]. |
| 83:126 | Maximum Consistency Points changed from [<Number>] to [<Number>]. |
| 83:127 | User changed. |
| 83:128 | Password changed. |
| 83:129 | Filters changed. |
| 83:130 | Base Mount Path changed from [<String>] to [<String>]. |
| 83:131 | CIFS Share changed from [<String>] to [<String>]. |
| 83:132 | Storage Policy for Consistency Points Backups changed. |
| 83:133 | Attempt to modify Global Filters denied. |
| 83:134 | Global Filters modified. |
| 83:135 | [<String>] CommCell Operation Windows Rules at [<String>] Level. |
| 83:136 | Blackout Window added. |
| 83:137 | Blackout Window modified. |
| 83:138 | Blackout Window deleted. |
| 83:139 | FTP Site changed from [<String>] to [<String>]. |
| 83:140 | User Name for FTP Site changed from [<String>] to [<String>]. |
| 83:141 | Password for FTP Site changed. |
| 83:142 | Whether to use HTTP proxy changed from [<Number>] to [<Number>]. |
| 83:143 | HTTP Proxy server was set from [<String>:<Number>] to [<String>:<Number>]. |
| 83:144 | HTTP Proxy username was set from [<String>] to [<String>]. |
| 83:145 | HTTP Proxy password was changed. |
| 83:146 | CommServe Update Location changed from [<String>] to [<String>]. |
| 83:147 | User Name for CommServe Update Location changed from [<String>] to [<String>]. |
| 83:148 | Password for CommServe Update Location Changed. |
| 83:149 | UNIX Update Location changed from [<String>] to [<String>]. |
| 83:150 | User Name for UNIX Update Location changed from [<String>] to [<String>]. |
| 83:151 | UNIX Client for UNIX Update Location changed from [<Number>] to [<Number>]. |
| 83:152 | UNIX Download changed from [<String>] to [<String>]. |
| 83:153 | Snap Volume Unit [<String>] added. |
| 83:154 | Snap Volume Unit [<String>] name changed to [<String>]. |
| 83:155 | Snap Volume Unit [<String>] modified. |
| 83:156 | Snap Volume Unit [<String>] deleted. |
| 83:157 | Workflow [<String>] added for Snap Volume Unit [<String>]. |
| 83:158 | Workflow [<String>] name changed to [<String>]. |
| 83:159 | Workflow [<String>] modified in Snap Volume Unit [<String>]. |
| 83:160 | Workflow [<String>] deleted. |
| 83:161 | Subclient Policy Name is [<String>], changed from [<String>]. |
| 83:162 | Filer User Name changed from [<String>] to [<String>]. |
| 83:163 | Site Account User changed from [<String>] to [<String>]. |
| 83:164 | Filer User Password changed. |
| 83:165 | Site Account User Password changed. |
| 83:166 | Windows Account with SQL Admin Role was changed from [<String>] to [<String>]. |
| 83:167 | Password for Windows Account with SQL Admin Role was changed. |
| 83:168 | Added Filter [<String>] for User [<String>]. |
| 83:169 | Modified Filter [<String>] for User [<String>]. |
| 83:170 | Deleted Filter [<String>] for User [<String>]. |
| 83:171 | Calendar [<String>] deleted. |
| 83:172 | Calendar [<String>] added. |
| 83:173 | Calendar [<String>] modified. |
| 83:174 | Changed name of Calendar from [<String>] to [<String>]. |
| 83:175 | Changed to default calendar |
| 83:176 | Changed start date. |
| 83:177 | Client [<String>] Domain name changed from [<String>] to [<String>]. |
| 83:178 | Client [<String>] CommServe host name changed from [<String>] to [<String>]. |
| 83:179 | [<String>] |
| 83:180 | [n<String>n] |
| 83:181 | Default Undo File Path was changed from [<String>] to [<String>]. |
| 83:182 | Windows Account with SQL Admin Role was changed from [<String>] to [<String>]. |
| 83:183 | Password for Windows Account with SQL Admin Role was changed. |
| 83:184 | User Name for Pre/Post Commands changed from [<String>] to [<String>]. |
| 83:185 | User Impersonation for Pre/Post Commands enabled. |
| 83:186 | User Impersonation for Pre/Post Commands disabled. |
| 83:187 | Password for Pre/Post Commands Changed. |
| 83:188 | Time Zone for operational window and this application has changed from [<String>] to [<String>]. |
| 83:189 | Windows Account with SQL Admin Role was changed from [<String>] to [<String>]. |
| 83:190 | Password for Windows Account with SQL Admin Role was changed. |
| 83:191 | Content Indexing [<String>]. |
| 83:192 | Description changed from [<String>] to [<String>]. |
| 83:193 | Resource Filename changed from [<String>] to [<String>]. |
| 83:194 | Client Job priority changed from [<Number>] to [<Number>]. |
| 83:195 | Store Updates Locally is changed from [<String>] to [<String>]. |
| 83:196 | [<String>] has been changed to [<String>]. |
| 83:197 | Proxy Client For Content Search is [<String>], changed from [<String>]. |
| 83:198 | Prune job results when disk capacity percentage reaches [<Number>] percent, changed from [<Number>] percent. |
| 83:199 | Prune job results after [<Number>] days, changed from [<Number>] days. |
| 83:200 | Default Network Interface changed from [<String>] to [<String>]. |
| 83:201 | Client alternate cache partition changed from [<String>] to [<String>]. |
| 83:202 | ContinuousDataReplicator Log file Location changed from [<String>] to [<String>]. |
| 83:203 | client host name changed from [<String>] to [<String>]. |
| 83:204 | client name changed from [<String>] to [<String>]. |
| 83:205 | client CommServe host name changed from [<String>] to [<String>]. |
| 83:206 | Time Zone for operational window and this application has changed from [<String>] to [<String>]. |
| 83:207 | User Name for Pre/Post Commands changed from [<String>] to [<String>]. |
| 83:208 | User Impersonation for Pre/Post Commands changed from [<String>] to [<String>]. |
| 83:209 | Password for Pre/Post Commands Changed. |
| 83:210 | Priority for this Application changed from [<Number>] to [<Number>]. |
| 83:211 | Maximum Simultaneous Stub Recoveries for this Application changed from [<Number>] to [<String>]. |
| 83:212 | Maximum Simultaneous Stub Recoveries for this Application changed from [<String>] to [<Number>]. |
| 83:213 | Maximum Simultaneous Stub Recoveries for this Application changed from [<Number>] to [<Number>]. |
| 83:214 | Throttle when Destination Volume Space changed from [<Number>] to [<Number>]. |
| 83:215 | Stop when Destination Volume Space changed from [<Number>] to [<Number>]. |
| 83:216 | Abort when Source Volume Space changed from [<Number>] to [<Number>]. |
| 83:217 | OS Priority for New Replications changed from [<Number>] to [<Number>]. |
| 83:218 | Logfile No I/O Flush minutes changed from [<Number>] to [<Number>]. |
| 83:219 | Pipeline throttle value changed from [<Number>] to [<Number>]. |
| 83:220 | Bandwidth Throttling Windows changed. |
| 83:221 | Meta Data Location changed from [<String>] to [<String>]. |
| 83:222 | Data Classification has been [<String>]. |
| 83:223 | Data Classification OS Priority changed from [<Number>] to [<Number>]. |
| 83:224 | Data Classification CommServe Update Interval changed from [<Number>] to [<Number>]. |
| 83:225 | Data Classification Inactivity Timeout changed from [<Number>] to [<Number>]. |
| 83:226 | AD User name changed from [<String>] to [<String>]. |
| 83:227 | File Archiver User Password Changed. |
| 83:228 | Time Between Recalls for this Application changed from [<Number>] to [<Number>]. |
| 83:229 | Auto Discovery has been [<String>]. |
| 83:230 | Filer User Name changed from [<String>] to [<String>]. |
| 83:231 | Site Account User changed from [<String>] to [<String>]. |
| 83:232 | Filer User Password changed. |
| 83:233 | Site Account User Password changed. |
| 83:234 | Filer Name changed from [<String>] to [<String>]. |
| 83:235 | Server name changed from [<String>] to [<String>]. |
| 83:236 | Stubs Location changed from [<String>] to [<String>]. |
| 83:237 | Force Lock Release changed to [<String>]. |
| 83:238 | Index Backup/Restore Path changed from [<String>] to [<String>]. |
| 83:239 | SQL Database Hosted Remotely changed to [<String>]. |
| 83:240 | Profile changed from [<String>] to [<String>]. |
| 83:241 | Mailbox name changed from [<String>] to [<String>]. |
| 83:242 | Backup Deleted Item Retention changed from [<Number>] to [<Number>]. |
| 83:243 | Journal Mailbox Threshold changed from [<Number>] to [<Number>]. |
| 83:244 | Backup Hidden Mailbox changed from [<Number>] to [<Number>]. |
| 83:245 | Snapshot Writer changed from [<Number>] to [<Number>]. |
| 83:246 | Backup Set Level changed from [<Number>] to [<Number>]. |
| 83:247 | Create new index on full is <String> set. |
| 83:248 | Create new index on Fail is <String> set. |
| 83:249 | User name changed from [<String>] to [<String>]. |
| 83:250 | Restore in Progress Message for Disk Library Exchange Archiver changed from [<String>] to [<String>]. |
| 83:251 | Restore in Progress Message for Tape Library Exchange Archiver changed from [<String>] to [<String>]. |
| 83:252 | Restore in Progress for Offline Media Message for Exchange Archiver changed from [<String>] to [<String>]. |
| 83:253 | Force Recalls Outlook Add-In user changed from [<Number>] to [<Number>]. |
| 83:254 | Force Recalls OWA user changed from [<Number>] to [<Number>]. |
| 83:255 | Proxy File Expiration changed from [<Number>] to [<Number>]. |
| 83:256 | Proxy Prune Interval changed from [<Number>] to [<Number>]. |
| 83:257 | Network File Share Archiver for EMC has been <String> |
| 83:258 | AD Server Name changed from [<String>] to [<String>]. |
| 83:259 | AD User name changed from [<String>] to [<String>]. |
| 83:260 | AD User Password Changed. |
| 83:261 | Data Classification Tags changed. |
| 83:262 | Snap Engine Type changed from [<String>] to [<String>]. |
| 83:263 | AD Server List changed. |
| 83:264 | QSnap Maximum Cache size for this application has changed from [<Number>] to [<Number>]. |
| 83:265 | QSnap Minimum Cache size for this application has changed from [<Number>] to [<Number>]. |
| 83:266 | Online Context Indexing Location ShareName changed. |
| 83:267 | User Name for Job Results Directory changed from [<String>] to [<String>]. |
| 83:268 | Password for Job Results Directory Changed. |
| 83:269 | Job Results Path changed from [<String>] to [<String>]. |
| 83:270 | [<String>] on this Subclient has been [<String>] |
| 83:271 | Storage Policy changed. |
| 83:272 | PreCommand changed. |
| 83:273 | PostCommand changed. |
| 83:274 | MediaAgent successfully deleted. |
| 83:275 | iDataAgent successfully deleted. |
| 83:276 | Client successfully deleted. |
| 83:277 | Attempt to run emergency uninstall denied.n<String> |
| 83:278 | User [<String>], Forced Deconfigure for [<String>] failed.n<String> |
| 83:279 | User [<String>], Reconfigure for [<String>] failed.n<String> |
| 83:280 | Attempt to modify <String> denied.n<String> |
| 83:281 | Attempt to delete <String> denied.n<String> |
| 83:282 | Unauthorized attempt to modify properties at pair Level.n<String> |
| 83:283 | Unauthorized attempt to modify properties at replication set Level.n<String> |
| 83:284 | Unauthorized attempt to modify properties at subclient Level.n<String> |
| 83:285 | Unauthorized attempt to create/modify subclient.n<String> |
| 83:286 | Client Encryption Setting is [<String>], changed from [<String>]. |
| 83:287 | Throttling Parameter changed from [<Number>] to [<Number>] |
| 83:288 | FTP Operation Type changed from [<String>] to [<String>]. |
| 83:289 | FTP Use Passive FTP Option changed from [<String>] to [<String>]. |
| 83:290 | FTP Proxy Use Passive FTP Changed From [<String>] to [<String>]. |
| 83:291 | FTP Proxy server was set from [<String>:<Number>] to [<String>:<Number>]. |
| 83:292 | FTP Proxy username was set from [<String>] to [<String>]. |
| 83:293 | FTP Proxy password was changed. |
| 83:294 | FTP Proxy Location was set from [<String>] to [<String>]. |
| 83:295 | SQL authentication mode set to [<String>]. |
| 83:296 | SQL authentication username changed from [<String>] to [<String>]. |
| 83:297 | SQL authentication password changed. |
| 83:298 | Override SQL authentication at higher level had been [%s]. |
| 83:299 | Update Cache Agent ID changed from [<Number>] to [<Number>]. |
| 83:300 | FPolicy is now enabled for this Instance. |
| 83:301 | FPolicy is now disabled for this Instance. |
| 83:302 | Time between recalls changed from [<Number>] to [<Number>] seconds. |
| 83:303 | Time to wait after maximum successive recall limit is reached changed from [<Number>] to [<Number>] seconds. |
| 83:304 | Maximum Simultaneous Stub Recoveries changed from [<Number>] to [<Number>]. |
| 83:305 | Windows authentication |
| 83:306 | Username and password authentication |
| 83:307 | Virtual Center |
| 83:308 | ESX Server |
| 83:309 | Virtual Server |
| 83:310 | Unknown Server Type |
| 83:311 | Instance type for Virtual Server changed from [<String>] to [<String>]. |
| 83:312 | Virtual Server Username now set as [<String>]. |
| 83:313 | Virtual Server Password has been changed. |
| 83:314 | ESX Auto Discovery has been enabled. |
| 83:315 | ESX Auto Discovery has been disabled. |
| 83:316 | Auto Discover Set to ESX Affinity. |
| 83:317 | Auto Discover Set to Wildcard Affinity. |
| 83:318 | Auto Discover Set to Unknown Affinity [<Number>]. |
| 83:319 | Content of ESX Subclients changed for this Backup Set. |
| 83:320 | Wildcards used in Auto Discovery of VM-s as Subclient content changed. |
| 83:321 | Content of Virtual Guest Hosts Changed for this Backup Set. |
| 83:322 | Backup View has changed from [<String>] to [<String>]. |
| 83:323 | File View |
| 83:324 | Volume View |
| 83:325 | Disk View |
| 83:326 | Unauthorized attempt to Enable/Disable [<String>] for this application on this client.nn [<String>] |
| 83:327 | [<String>] for this application on this client has been enabled.n |
| 83:328 | Group(s) [<String>] is/are now associated with this <String>.n |
| 83:329 | Group(s) [<String>] is/are no longer associated with this <String>.n t |
| 83:330 | [<String>] for this application on this client has been disabled.n |
| 83:331 | Unauthorized attempt to Enable/Disable [<String>] at Client Level.nn%sn |
| 83:332 | Cannot fetch old group affiliation data. Assuming groups may have been deleted.n |
| 83:333 | Unauthorized attempt to modify group associations.nn [<String>] |
| 83:334 | Unauthorized attempt to create Replication Set from Policy. |
| 83:335 | Subclient : [<String>] tOld Storage Policy Name : [<String>] tNew Storage Policy Name : [<String>] |
| 83:336 | Minimum file size for Hash computation changed from [<Number>] to [<Number>]. |
| 83:337 | Hash Block Size changed from [<Number>] to [<Number>]. |
| 83:338 | Exchange Mining Tool Path changed from [<String>] to [<String>]. |
| 83:339 | Snap Backups [<String>]. |
| 83:340 | Unauthorized attempt to create Backup Set for OSSV Backup to Tape. |
| 83:341 | Context Indexing OWA URL changed. |
| 83:342 | Association changed for group [<String>].n |
| 83:343 | Group is now associated to these entities.n |
| 83:344 | tCommServe : [<String>]n |
| 83:345 | tClient(s): [<String>]n |
| 83:346 | tMediaAgent(s): [<String>]n |
| 83:347 | tLibraries : [<String>]n |
| 83:348 | tServer group(s): [<String>]n |
| 83:349 | tStorage policies : [<String>]n |
| 83:350 | Password check on login to the CommServe has been [<String>]. |
| 83:351 | Collect Delegate Info has been [<String>]. |
| 83:352 | Do not de-duplicate email [<String>]. |
| 83:353 | Attempt to delete user [<String>] was denied.nn |
| 83:354 | Attempt to add a new user was denied.nn |
| 83:355 | Attempt to modify properties for user [<String>] was denied.nn |
| 83:356 | User does not have permission to delete self.nn |
| 83:357 | User attempted to modify group associations for which he/she does not have permission.nn |
| 83:358 | User cannot modify his/her own login name.nn |
| 83:359 | User cannot modify his/her own password aging criteria.nn |
| 83:360 | <String> [<String>] has been added. n |
| 83:361 | <String> [<String>] has been deleted. n |
| 83:362 | <String> [<String>] has been updated. n |
| 83:363 | Description has been changed. |
| 83:364 | Full name was changed from [<String>] to [<String>]. |
| 83:365 | Login name was changed from [<String>] to [<String>]. |
| 83:366 | Password was changed. |
| 83:367 | Email Address was changed from [<String>] to [<String>]. |
| 83:368 | Pager Address was changed from [<String>] to [<String>]. |
| 83:369 | User has been <String>. |
| 83:370 | Password expiration date has been changed. |
| 83:371 | The user is no longer a member of <String> <String>. |
| 83:372 | The user is now a member of <String> <String>. |
| 83:373 | Group [<String>] changes: nn |
| 83:374 | Group has been <String>. |
| 83:375 | "All capabilities" has been <String>. |
| 83:376 | "All Associations" has been <String>. |
| 83:377 | "Self Association" has been <String>. |
| 83:378 | Group name has been changed from [<String>] to [<String>]. |
| 83:379 | Group has been deleted. |
| 83:380 | User |
| 83:381 | Users |
| 83:382 | Group |
| 83:383 | Groups |
| 83:384 | Capability |
| 83:385 | Capabilities |
| 83:386 | has |
| 83:387 | have |
| 83:388 | selected |
| 83:389 | deselected |
| 83:390 | add |
| 83:391 | delete |
| 83:392 | modify |
| 83:393 | <String> <String> <String> been deleted from the group. |
| 83:394 | <String> <String> <String> been added to the group. |
| 83:395 | Unauthorized attempt to Enable/Disable <String> on this CommCell.nn<String> |
| 83:396 | Unauthorized attempt to Enable/Disable <String> on this client.nn<String> |
| 83:397 | Unauthorized attempt to Enable/Disable <String> on client group [^2%%s].nn<String> |
| 83:398 | <String> on Server group [<String>] has been <String>. |
| 83:399 | <String> on this client has been <String>. |
| 83:400 | Scratch Pool [<String>] added to Library.n |
| 83:401 | Added Mount Path [<String>]n |
| 83:402 | Deleted Mount Path [<String>]n |
| 83:403 | Deleted Deconfigured Library [<String>]n |
| 83:404 | Unlimited |
| 83:405 | Store Updates Locally |
| 83:406 | Get Updates From Share |
| 83:407 | Engage Active Directory VSS writer [<String>] |
| 83:408 | Disk Keep Snaps now Enabled |
| 83:409 | Disk Keep Snaps now Disabled |
| 83:410 | Deprecated message |
| 83:411 | Deprecated message |
| 83:412 | No Snapshot for Discrete Replication [<String>].n |
| 83:413 | Auto Discovery of SQL instances Enabled. |
| 83:414 | Auto Discovery of SQL instances Disabled. |
| 83:415 | End user erase Enabled. |
| 83:416 | End user erase Disabled. |
| 83:417 | Use alternate URL for IIS Server Enabled. |
| 83:418 | Use alternate URL for IIS Server Disabled. |
| 83:419 | Alternate IIS Server Name changed from [<String>] to [<String>]. |
| 83:420 | Run post recovery Point command enabled. |
| 83:421 | Run post recovery point command disabled. |
| 83:422 | Description modified. |
| 83:423 | Unauthorized attempt to update network settings for client. |
| 83:424 | nWindows Global Filters : [<String>]. |
| 83:425 | nUnix Global Filters : [<String>]. |
| 83:426 | nNetware Global Filters :[<String>]. |
| 83:427 | nExchange Mailbox Global Filters : [<String>]. |
| 83:428 | nOnline Content Indexing for Exchange Global Filters : [<String>]. |
| 83:429 | nExchange Compliance Archiver Filters : [<String>]. |
| 83:430 | nExchange Mailbox Archiver Global Filters : [<String>]. |
| 83:431 | nWindows File Archiver Global Filters : [<String>]. |
| 83:432 | nVirtual Server Global Filters : [<String>]. |
| 83:433 | Use Global filters on All Subclients Selected.n |
| 83:434 | Use Global filters on All Subclients Deselected.n |
| 83:435 | Use Master Global Filters Selected.n |
| 83:436 | Use Master Global Filters Deselected.n |
| 83:437 | Storage Policy has been changed for Subclients [%s].n |
| 83:438 | Storage Policy has been changed for Instances [%s].n |
| 83:439 | Data Management |
| 83:440 | Desktop GUI configuration modified. |
| 83:441 | Instance Name changed from [<String>] to [<String>]. |
| 83:442 | nWorkstation Backup Agent Global Filters : [<String>]. |
| 83:443 | Virtual Center hostname now set to [<String>]. |
| 83:444 | Handle unassociated Guest Hosts has been enabled. |
| 83:445 | Handle unassociated Guest Hosts has been disabled. |
| 83:446 | Proxy File System Client is [<String>], changed from [<String>]. |
| 83:447 | Rule based discovery has been enabled. |
| 83:448 | Rule based discovery has been disabled. |
| 83:449 | Update Cache Agent changed from [<String>] to [<String>]. |
| 83:450 | Collect Delegate Information Enabled. |
| 83:451 | Collect Delegate Information Disabled. |
| 83:452 | Do not Single Instance Email Messages Enabled. |
| 83:453 | Do not Single Instance Email Messages Disabled. |
| 83:454 | URL for Compliance Search changed from [<String>] to [<String>]. |
| 83:455 | URL for end user search changed from [<String>] to [<String>]. |
| 83:456 | URL for Administrator changed from [<String>] to [<String>]. |
| 83:457 | Check Archive Bit during backup is Enabled. |
| 83:458 | Check Archive Bit during backup is Disabled. |
| 83:459 | Backup set Marked as My Backup set. |
| 83:460 | Backup set is not My Backup set anymore. |
| 83:461 | Preserve File access time Enabled. |
| 83:462 | Preserve File access time Disabled. |
| 83:463 | Use Change Journal Enabled. |
| 83:464 | Use Change Journal Disabled. |
| 83:465 | Use Data Classification for Backup Enabled. |
| 83:466 | Use Data Classification for Backup Disabled. |
| 83:467 | Auto Discovery Enabled. |
| 83:468 | Auto Discovery Disabled. |
| 83:469 | Decompress Data before Backup Enabled. |
| 83:470 | Decompress Data before Backup Disabled. |
| 83:471 | Catalog Partition number changed from [<Number>] to [<Number>]. |
| 83:472 | SQL connect User Name changed from [<String>] to [<String>]. |
| 83:473 | SQL connect Password changed. |
| 83:474 | Use SQL Connect Enabled. |
| 83:475 | Use SQL Connect Disabled. |
| 83:476 | Backup set Name changed from [<String>] to [<String>]. |
| 83:477 | Backup set has been marked as the default backup set. |
| 83:478 | Use Storage Group Affinity for Mailbox discovery enabled. |
| 83:479 | Use Storage Group Affinity for Mailbox discovery disabled. |
| 83:480 | Use Active Directory Group Affinity for Mailbox discovery enabled. |
| 83:481 | Use Active Directory Group Affinity for Mailbox discovery disabled. |
| 83:482 | Use Wild Card for Mailbox discovery enabled. |
| 83:483 | Use Wild Card for Mailbox discovery disabled. |
| 83:484 | Default Index Storage Policy changed from [<String>] to [<String>]. |
| 83:485 | Snapshot Maximum Cache size changed from [<Number>] to [<Number>]. |
| 83:486 | Create index on Full enabled. |
| 83:487 | Create index on Full disabled. |
| 83:488 | Create index when job fails Enabled. |
| 83:489 | Create index when job fails Disabled. |
| 83:490 | Centera Resource File Name changed from [<String>] to [<String>]. |
| 83:491 | Centera Client Name changed from [<String>] to [<String>]. |
| 83:492 | Continue from replica after Failover Enabled. |
| 83:493 | Continue from replica after Failover Disabled. |
| 83:494 | Content Indexing enabled. |
| 83:495 | Content Indexing disabled. |
| 83:496 | Snap Backup enabled. |
| 83:497 | Snap Backup disabled. |
| 83:498 | Client is now associated with Server groups [<String>]. |
| 83:499 | Client is no longer associated with Server groups [<String>]. |
| 83:500 | %s has been enabled. |
| 83:501 | VDI timeout was changed from [<Number>] to [<Number>]. |
| 83:502 | Override Global settings for Authentication Enabled |
| 83:503 | Override Global settings for Authentication Disabled |
| 83:504 | SQL Version changed from [<String>] to [<String>] |
| 83:505 | Use VSS enabled |
| 83:506 | Use VSS disabled |
| 83:507 | Log Storage policy changed to [<String>] |
| 83:508 | Default View Names Added [<String>] |
| 83:509 | Profile Document Names Added [<String>] |
| 83:510 | Network file share archiver for EMC has been Enabled |
| 83:511 | Network file share archiver for EMC has been Disabled. |
| 83:512 | Filer Name changed from [<String>] to [<String>] |
| 83:513 | Filer User Name changed from [<String>] to [<String>] |
| 83:514 | Password changed. |
| 83:515 | Informix User is [<String>]. |
| 83:516 | Informix Command Policy changed. |
| 83:517 | Informix Log Policy changed. |
| 83:518 | Informix On-Config File changed from [<String>] to [<String>]. |
| 83:519 | Informix Dir changed from [<String>] to [<String>]. |
| 83:520 | Version changed from [<String>] to [<String>]. |
| 83:521 | Encryption setting changed. |
| 83:522 | SAP data home changed from [<String>] to [<String>]. |
| 83:523 | Number of Log Backup Streams changed from [<Number>] to [<Number>]. |
| 83:524 | Override Data Paths for command line storage policy Enabled. |
| 83:525 | Override Data Paths for command line storage policy Disabled. |
| 83:526 | Override Data Paths for log storage policy Enabled. |
| 83:527 | Override Data Paths for log storage policy Disabled. |
| 83:528 | Data Paths for command line storage policy changed. |
| 83:529 | Data Paths for log storage policy changed. |
| 83:530 | SAP Exe Folder changed from [<String>] to [<String>]. |
| 83:531 | SAP Library location changed from [<String>] to [<String>]. |
| 83:532 | SBT Library Name changed from [<String>] to [<String>]. |
| 83:533 | Oracle Home changed from [<String>] to [<String>]. |
| 83:534 | SAP Exe Folder changed from [<String>] to [<String>]. |
| 83:535 | Use Catalog Connect enabled. |
| 83:536 | Use Catalog Connect disabled. |
| 83:537 | Catalog Connect username changed from [<String>] to [<String>]. |
| 83:538 | Catalog Connect Password Changed. |
| 83:539 | Catalog Connect SID changed from [<String>] to [<String>]. |
| 83:540 | SQL Connect username changed from [<String>] to [<String>]. |
| 83:541 | SQL Connect Password Changed. |
| 83:542 | SQL Connect SID changed from [<String>] to [<String>]. |
| 83:543 | TNS Admin path changed from [<String>] to [<String>]. |
| 83:544 | Startup Pfile changed from [<String>] to [<String>]. |
| 83:545 | Oracle Proxy copy changed from [<String>] to [<String>]. |
| 83:546 | Delete Expired enabled. |
| 83:547 | Delete Expired disabled. |
| 83:548 | Auto Backup Control File enabled. |
| 83:549 | Auto Backup Control File disabled. |
| 83:550 | Oracle Database Role changed from [<String>] to [<String>]. |
| 83:551 | Block size changed from [<Number>] to [<Number>]. |
| 83:552 | Oracle user changed from [<Number>] to [<Number>]. |
| 83:553 | Oracle host password changed |
| 83:554 | Use source on missing proxy enabled |
| 83:555 | Use source on missing proxy disabled |
| 83:556 | Proxy for snap backup changed from [<String>] to [<String>] |
| 83:557 | Snapshot Engine changed |
| 83:558 | Snap backup enabled |
| 83:559 | Snap backup disabled |
| 83:560 | Data path 1 changed to [<String>] from [<String>] |
| 83:561 | Data path 2 changed to [<String>] from [<String>] |
| 83:562 | Data path 3 changed to [<String>] from [<String>] |
| 83:563 | Data path 4 changed to [<String>] from [<String>] |
| 83:564 | Data path 5 changed to [<String>] from [<String>] |
| 83:565 | Single instancing enabled |
| 83:566 | Single instancing disabled |
| 83:567 | RMAN cross check disabled |
| 83:568 | RMAN cross check enabled |
| 83:569 | Auto Detect new and deleted Partitions Enabled |
| 83:570 | Auto Detect new and deleted Partitions Disabled |
| 83:571 | Word width changed from [<Number>] to [<Number>] |
| 83:572 | SA user name changed from [<String>] to [<String>] |
| 83:573 | SA password changed |
| 83:574 | Sybase Home changed from [<String>] to [<String>]. |
| 83:575 | Sybase ASE changed from [<String>] to [<String>]. |
| 83:576 | Sybase OCS changed from [<String>] to [<String>]. |
| 83:577 | Sybase Configuration file path changed from [<String>] to [<String>]. |
| 83:578 | Sybase shared memory directory changed from [<String>] to [<String>]. |
| 83:579 | Sybase OCS changed from [<String>] to [<String>]. |
| 83:580 | Sybase backup server changed from [<String>] to [<String>]. |
| 83:581 | MySQL Home changed from [<String>] to [<String>]. |
| 83:582 | MySQL Version changed from [<String>] to [<String>]. |
| 83:583 | MySQL binary file path changed from [<String>] to [<String>]. |
| 83:584 | MySQL Configuration file path changed from [<String>] to [<String>]. |
| 83:585 | MySQL data file path changed from [<String>] to [<String>]. |
| 83:586 | MySQL Archive Log index file path changed from [<String>] to [<String>]. |
| 83:587 | MySQL Socket file changed from [<String>] to [<String>]. |
| 83:588 | Data Storage policy changed from [<String>] to [<String>]. |
| 83:589 | Log Storage policy changed from [<String>] to [<String>]. |
| 83:590 | Command Line Storage policy changed from [<String>] to [<String>]. |
| 83:591 | Host user name changed from [<String>] to [<String>]. |
| 83:592 | Host password changed |
| 83:593 | Host user domain name changed from [<String>] to [<String>]. |
| 83:594 | Storage policy changed from [<String>] to [<String>]. |
| 83:595 | Create Snap Command changed from [<String>] to [<String>]. |
| 83:596 | Generic recovery script changed from [<String>] to [<String>]. |
| 83:597 | Default Import host changed from [<String>] to [<String>]. |
| 83:598 | Delete Snap Command changed from [<String>] to [<String>]. |
| 83:599 | Snap username changed from [<String>] to [<String>]. |
| 83:600 | Number of streams changed from [<Number>] to [<Number>]. |
| 83:601 | Number of streams for data backup changed from [<Number>] to [<Number>]. |
| 83:602 | Number of streams for log backup changed from [<Number>] to [<Number>]. |
| 83:603 | PreScan process changed from [<Number>] to [<Number>]. |
| 83:604 | PostScan process changed from [<Number>] to [<Number>]. |
| 83:605 | PreBackup process changed from [<Number>] to [<Number>]. |
| 83:606 | PostBackup process changed from [<Number>] to [<Number>]. |
| 83:607 | PreSnap process changed from [<Number>] to [<Number>]. |
| 83:608 | PostSnap process changed from [<Number>] to [<Number>]. |
| 83:609 | Subclient name changed from [<Number>] to [<Number>]. |
| 83:610 | Subclient Backup level changed from [<Number>] to [<Number>]. |
| 83:611 | Subclient was marked default. |
| 83:612 | System state backup disabled on this subclient. |
| 83:613 | System state backup enabled on this subclient. |
| 83:614 | Exclude Quota trees disabled on this subclient. |
| 83:615 | Exclude Quota trees enabled on this subclient. |
| 83:616 | Oracle backup device changed from [<String>] to [<String>]. |
| 83:617 | Oracle backup device changed from [<String>] to [<String>]. |
| 83:618 | Backup Archive log enabled |
| 83:619 | Backup Archive log disabled |
| 83:620 | Number of Archive files per bfs changed from [<Number>] to [<Number>] |
| 83:621 | Delete Archive log enabled |
| 83:622 | Delete Archive log disabled |
| 83:623 | Resync catalog enabled |
| 83:624 | Resync catalog disabled |
| 83:625 | Use startup file is enabled. |
| 83:626 | Use startup file has been disabled |
| 83:627 | Startup Pfile changed from [<String>] to [<String>] |
| 83:628 | Light out script enabled |
| 83:629 | Light out script disabled |
| 83:630 | Backup control files enabled |
| 83:631 | Backup control files disabled |
| 83:632 | Backup SP files enabled |
| 83:633 | Backup SP files disabled |
| 83:634 | Validate backup enabled |
| 83:635 | Validate backup disabled |
| 83:636 | Protect backup recovery area enabled |
| 83:637 | Protect backup recovery area disabled |
| 83:638 | Maximum number of open files changed from [<Number>] to [<Number>] |
| 83:639 | Maximum backup set size changed from [<Number>] to [<Number>] |
| 83:640 | Light out script Maximum delay time changed from [<Number>] to [<Number>] |
| 83:641 | Light out script Maximum sleep time(minutes) changed from [<Number>] to [<Number>] |
| 83:642 | Light out script Maximum sleep time(seconds) changed from [<Number>] to [<Number>] |
| 83:643 | Light out script Maximum retries changed from [<Number>] to [<Number>] |
| 83:644 | Light out script backup warning changed from [<Number>] to [<Number>] |
| 83:645 | Light out script Maximum retries changed from [<Number>] to [<Number>] |
| 83:646 | Backup level changed from [<Number>] to [<Number>] |
| 83:647 | Cumulative : yes |
| 83:648 | Cumulative : no |
| 83:649 | Oracle Tag changed from [<String>] to [<String>] |
| 83:650 | Get Data FPS enabled |
| 83:651 | Get Data FPS disabled |
| 83:652 | Skip read-only enabled |
| 83:653 | Skip read-only, disabled |
| 83:654 | Oracle Tag changed from [<String>] to [<String>] |
| 83:655 | Skip offline items Enabled |
| 83:656 | Skip offline items Disabled |
| 83:657 | Skip items in access Enabled |
| 83:658 | Skip items in access Disabled |
| 83:659 | Table browse Enabled |
| 83:660 | Table browse Disabled |
| 83:661 | Backup Office Communication Server Enabled |
| 83:662 | Backup Office Communication Server Disabled |
| 83:663 | OCS username changed from [<String>] to [<String>] |
| 83:664 | OCS password changed |
| 83:665 | Use Global Filter changed from [<String>] to [<String>] |
| 83:666 | Backup Mode changed from [<String>] to [<String>] |
| 83:667 | Backfill cutoff date changed |
| 83:668 | Single Instance Enabled |
| 83:669 | Single Instance Disabled |
| 83:670 | Proxy port number changed from [<String>] to [<String>]. |
| 83:671 | Proxy Address changed from [<String>] to [<String>]. |
| 83:672 | Proxy Path changed from [<String>] to [<String>] |
| 83:673 | Proxy Enabled |
| 83:674 | Proxy Disabled |
| 83:675 | Check Last Event time changed. |
| 83:676 | Check Last Event Enabled |
| 83:677 | Check Last Event Disabled |
| 83:678 | Number of buffers changed from [<Number>] to [<Number>]. |
| 83:679 | Backup buffer size changed from [<Number>] to [<Number>]. |
| 83:680 | Backup logs only Enabled |
| 83:681 | Backup logs only Disabled |
| 83:682 | Backup data Enabled |
| 83:683 | Backup data Disabled |
| 83:684 | Backup type changed |
| 83:685 | Data stream threshold changed from [<Number>] to [<Number>]. |
| 83:686 | Do not single instance e-mail has been enabled. |
| 83:687 | Do not single instance e-mail, disabled. |
| 83:688 | Snap failure action changed from [<String>] to [<String>]. |
| 83:689 | Search Engine changed from [<String>] to [<String>]. |
| 83:690 | Change Deduplication Setting |
| 83:691 | Document type changed from [<String>] to [<String>]. |
| 83:692 | Site group changed from [<String>] to [<String>]. |
| 83:693 | Owner changed from [<String>] to [<String>]. |
| 83:694 | Number of Versions changed from [<Number>] to [<Number>]. |
| 83:695 | Content Indexing word count changed from [<Number>] to [<Number>]. |
| 83:696 | Incremental level changed from [<Number>] to [<Number>]. |
| 83:697 | Backup IXBAR boot file enabled. |
| 83:698 | Backup IXBAR boot file disabled. |
| 83:699 | Pre/Post username changed from [<String>] to [<String>]. |
| 83:700 | Username for UNC path changed from [<String>] to [<String>]. |
| 83:701 | UNC path user password changed |
| 83:702 | Use pre post user Enabled |
| 83:703 | Use pre post user Disabled |
| 83:704 | Pre/Post user password changed |
| 83:705 | Filer user Password changed. |
| 83:706 | Begin scan for file selection for free volume changed from [<Number>] to [<Number>] percentage. |
| 83:707 | End scan if volume is freed to changed from [<Number>] to [<Number>] percentage. |
| 83:708 | Low mailbox size watermark changed from [<Number>] to [<Number>] percentage. |
| 83:709 | High mailbox size watermark changed from [<Number>] to [<Number>] percentage. |
| 83:710 | Archive files access time is changed from [<Number>] to [<Number>] days. |
| 83:711 | Archive files modified time is changed from [<Number>] to [<Number>] days. |
| 83:712 | Archive files with block size changed from [<Number>] to [<Number>] KB. |
| 83:713 | Stub retention time changed from [<String>] to [<String>]. |
| 83:714 | PST file location changed from [<String>] to [<String>]. |
| 83:715 | PST file username changed from [<String>] to [<String>]. |
| 83:716 | PST file user password changed |
| 83:717 | Create index interval changed from [<Number>] to [<Number>] |
| 83:718 | Hot spot enabled |
| 83:719 | Hot spot disabled |
| 83:720 | Use SQL connect enabled |
| 83:721 | Use SQL connect disabled |
| 83:722 | Use subclient policy filters enabled |
| 83:723 | Use subclient policy filters disabled |
| 83:724 | Allow multiple streams within drive or mount point Enabled |
| 83:725 | Allow multiple streams within drive or mount point Disabled |
| 83:726 | Failover to storage policy data paths for full backup Enabled |
| 83:727 | Failover to storage policy data paths for full backup Disabled |
| 83:728 | Failover to storage policy data paths for non-full backup Enabled |
| 83:729 | Failover to storage policy data paths for non-full backup Disabled |
| 83:730 | Apple double support enabled. |
| 83:731 | Apple double support disabled. |
| 83:732 | Use SharePoint alternate access enabled. |
| 83:733 | Use SharePoint alternate access disabled. |
| 83:734 | Do not allow incremental backup Enabled. |
| 83:735 | Do not allow incremental backup Disabled. |
| 83:736 | Delete Archived Messages enabled. |
| 83:737 | Delete Archived Messages disabled. |
| 83:738 | Use disk space watermarks Enabled |
| 83:739 | Use disk space watermarks Disabled |
| 83:740 | Use mailbox size watermarks Enabled |
| 83:741 | Use mailbox size watermarks Disabled |
| 83:742 | Do not migrate unread messages Enabled |
| 83:743 | Do not migrate unread messages Disabled |
| 83:744 | Leave body with stub enabled |
| 83:745 | Leave body with stub disabled |
| 83:746 | Local host backup Enabled |
| 83:747 | Local host backup Disabled |
| 83:748 | Collect user identity Enabled |
| 83:749 | Collect user identity Disabled |
| 83:750 | Use VSS enabled |
| 83:751 | Use VSS disabled |
| 83:752 | Use VSS for system state enabled |
| 83:753 | Use VSS for system state disabled |
| 83:754 | Use Qsnap enabled |
| 83:755 | Use Qsnap disabled |
| 83:756 | Ignore Archive log destination Enabled |
| 83:757 | Ignore Archive log destination Disabled |
| 83:758 | Subclient marked as Selective Online Full. |
| 83:759 | Subclient is not Selective Online Full anymore. |
| 83:760 | Software Compression changed from [<String>] to [<String>]. |
| 83:761 | Software Compression on MediaAgent |
| 83:762 | Software Compression Off |
| 83:763 | Throttle network bandwidth changed from [<Number>] to [<String>] |
| 83:764 | Number of network agents from [<Number>] to [<String>] |
| 83:765 | Software Encryption changed from [<String>] to [<String>] |
| 83:766 | None |
| 83:767 | On Network Only |
| 83:768 | On Media Only |
| 83:769 | On Network and Media |
| 83:770 | Deduplication changed from [<String>] to [<String>] |
| 83:771 | On Client |
| 83:772 | On MediaAgent |
| 83:773 | No Deduplication |
| 83:774 | Content removed : [<String>] |
| 83:775 | Content added : [<String>] |
| 83:776 | Content changed from [<String>] to [<String>] |
| 83:777 | Use backup conversion rules enabled |
| 83:778 | Use backup conversion rules disabled |
| 83:779 | Preserve Stubs until media has been pruned |
| 83:780 | Prune stubs for given days |
| 83:781 | Archive files only, do not create stubs. |
| 83:782 | Prune stubs after [<Number>] days |
| 83:783 | Proxy for Exchange changed from [<String>] to [<String>] |
| 83:784 | Network Error Retry Option Enabled |
| 83:785 | Network Error Retry Option Disabled |
| 83:786 | Backup Type changed from [<String>] to [<String>]. |
| 83:787 | Use VSS Enabled |
| 83:788 | Use VSS Disabled |
| 83:789 | End user erase folder list changed from [<String>] to [<String>] |
| 83:790 | Fail the job |
| 83:791 | Continue and reset access time |
| 83:792 | Continue and do not reset access time |
| 83:793 | On |
| 83:794 | Off |
| 83:795 | Use Cell level policy |
| 83:796 | Online |
| 83:797 | Offline |
| 83:798 | Online Subset |
| 83:799 | Archive according to Archiving Rules |
| 83:800 | Operate as Backup Agent |
| 83:801 | Operate as backfill |
| 83:802 | Context Indexing OWA URL changed from [<String>] to [<String>] |
| 83:803 | Online Context Indexing Location Share Name changed from [<String>] to [<String>] |
| 83:804 | Generate Activity Log Enabled |
| 83:805 | Generate Activity Log Disabled |
| 83:806 | Log location from [<String>] to [%2%s] |
| 83:807 | Change Journal User changed from [<String>] to [<String>] |
| 83:808 | Change Journal User password changed |
| 83:809 | Use local System Account for Authentication Enabled |
| 83:810 | Use local System Account for Authentication Disabled |
| 83:811 | nContent Indexing global filters : [<String>]. |
| 83:812 | Oracle Backup disable switch is set to true |
| 83:813 | Oracle Backup disable switch is set to false |
| 83:814 | Backup type has changed from [<String>] to [<String>] |
| 83:815 | Use journaling for Discrete Replication [<String>]n |
| 83:816 | PostgreSQL |
| 83:817 | [<Message>] Port changed from [<String>] to [<String>] |
| 83:818 | [<Message>] Binary Directory path changed from [<String>] to [<String>] |
| 83:819 | [<Message>] Configuration file path changed from [<String>] to [<String>] |
| 83:820 | [<Message>] Data Directory changed from [<String>] to [<String>] |
| 83:821 | [<Message>] Archive Log Directory changed from [<String>] to [<String>] |
| 83:822 | [<Message>] Socket file changed from [<String>] to [<String>] |
| 83:823 | SybaseIQ |
| 83:824 | [<Message>] Home changed from [<String>] to [<String>] |
| 83:825 | [<Message>] ASE changed from [<String>] to [<String>] |
| 83:826 | [<Message>] Sybase OCS changed from [<String>] to [<String>] |
| 83:827 | [<Message>] server changed from [<String>] to [<String>] |
| 83:828 | [<Message>] catalog database space path changed from [<String>] to [<String>] |
| 83:829 | [<Message>] main store path changed from [<String>] to [<String>] |
| 83:830 | [<Message>] Catalog dump path Changed from [<String>] to [<String>] |
| 83:831 | Net application Image File backup changed from [<String>] to [<String>] |
| 83:832 | Xen Server |
| 83:833 | Xen Center |
| 83:834 | Allow multiple streams within drive or mount point Enabled for Snap Backup |
| 83:835 | Allow multiple streams within drive or mount point Disabled for Snap Backup |
| 83:836 | Number of streams changed for Snap Backup from [<Number>] to [<Number>] |
| 83:837 | Auto Discover Set to Resource Pool Affinity. |
| 83:838 | Auto Discover Set to Data Store Affinity. |
| 83:839 | Follow Symbolic link enabled. |
| 83:840 | Follow Symbolic link disabled. |
| 83:841 | Restore to Recovered Items folder enabled. |
| 83:842 | Restore to Recovered Items folder disabled. |
| 83:843 | Copy Backup enabled. |
| 83:844 | Copy Backup disabled. |
| 83:845 | Online Content Indexing enabled. |
| 83:846 | Online Content Indexing disabled. |
| 83:847 | Sharepoint Online Content Indexing Web Server changed from [<String>] to [<String>]. |
| 83:848 | Sharepoint Online Content Indexing username changed from [<String>] to [<String>]. |
| 83:849 | Sharepoint Online Content Indexing password modified. |
| 83:850 | Skip Metafile Creation changed from [<String>] to [<String>]. |
| 83:851 | Backup Staging directory changed from [<String>] to [<String>] |
| 83:852 | Use MSSQL Compression Enabled |
| 83:853 | Use MSSQL Compression Disabled |
| 83:854 | Use MSSQL Encryption Enabled |
| 83:855 | Use MSSQL Encryption Disabled |
| 83:856 | Backup staging directory password changed. |
| 83:857 | Global Zone Host Name changed from [<String>] to [<String>] |
| 83:858 | Enabled WildCard Content for backup set [<String>]. |
| 83:859 | EDC NBU Instance - |
| 83:860 | [<Message>] [<String>] Master Server Name changed from [<String>] to [<String>]. |
| 83:861 | [<Message>] [<String>] Staging Path changed from [<String>] to [<String>]. |
| 83:862 | [<String>] User name changed from [<String>] to [<String>]. |
| 83:863 | [<String>] Password Changed. |
| 83:864 | System Server group [<String>] created. |
| 83:865 | Server group - [<String>] deleted. |
| 83:866 | EDC Clients [<String>] belonging to Server group - [<String>] are deleted. |
| 83:867 | Discover criteria of subclient [<String>] set to discover by client name pattern. |
| 83:868 | Discover criteria of subclient [<String>] set to discover by agents. |
| 83:869 | Updated the discover criteria. |
| 83:870 | Server group associated changed from [<String>] to [<String>]. |
| 83:871 | Optimized Data For Search enabled. |
| 83:872 | Optimized Data For Search disabled. |
| 83:873 | File level analytics license Enabled for client [<String>] |
| 83:874 | File level analytics license Disabled for client [<String>] |
| 83:875 | Deprecated message [<String>]. |
| 83:876 | Deprecated message [<String>]. |
| 83:877 | NetBIOS Name changed from [<String>] to [<String>]. |
| 83:878 | SNMP Common Name changed from [<String>] to [<String>]. |
| 83:879 | UID changed from [<Number>] to [<Number>]. |
| 83:880 | GID changed from [<Number>] to [<Number>]. |
| 83:881 | Filer NET Password has been changed. |
| 83:882 | Filer NET username changed from [<String>] to [<String>]. |
| 83:883 | Deprecated message. |
| 83:884 | Deprecated message. |
| 83:885 | PST Specific Folder changed from [<String>] to [<String>]. |
| 83:886 | Web Search Server Changed from [<String>] to [<String>]. |
| 83:887 | Web Service URL changed from [<String>] to [<String>]. |
| 83:888 | DAG SubClient[<String>] selection type changed. |
| 83:889 | Backup to Active copy Enabled in subclient[<String>]. |
| 83:890 | Enabled Backup to Passive Copy if Active copy is not available in subclient[<String>]. |
| 83:891 | Snap Proxy Mount changed from [<String>] to [<String>]. |
| 83:892 | Deprecated message |
| 83:893 | Deprecated message |
| 83:894 | Catalog data full system restore changed to [<String>] |
| 83:895 | Create PST Specific folder Enabled. |
| 83:896 | Create PST Specific folder Disabled. |
| 83:897 | Changed mining client from [<String>] to [<String>] for subclient [<String>]. |
| 83:898 | Changed mining backup set from [<String>] to [<String>] for subclient [<String>]. |
| 83:899 | Changed mining subclient from [<String>] to [<String>] for subclient [<String>]. |
| 83:900 | Changed mining proxy client from [<String>] to [<String>] for subclient [<String>]. |
| 83:901 | Mining is enabled for subclient [<String>]. |
| 83:902 | Mining is disabled for subclient [<String>]. |
| 83:903 | Mine proxy client enabled for subclient [<String>]. |
| 83:904 | Mine proxy client disabled for subclient [<String>]. |
| 83:905 | Updated the list of WBA Owners for client[<String>]. |
| 83:906 | Deprecated message. |
| 83:907 | Deprecated message. |
| 83:908 | Deprecated message. |
| 83:909 | Use either Age or Size rule enabled. |
| 83:910 | Use either Age or Size rule disabled. |
| 83:911 | Use Sent or Received time for Age rule enabled. |
| 83:912 | Use Sent or Received time for Age rule disabled. |
| 83:913 | Disable all rules is enabled. |
| 83:914 | Disable all rules is disabled. |
| 83:915 | Do not create stub enabled. |
| 83:916 | Do not create stub disabled. |
| 83:917 | Archive messages with attachment only enabled. |
| 83:918 | Archive messages with attachment only disabled. |
| 83:919 | Override index cycles enabled. |
| 83:920 | Override index cycles disabled. |
| 83:921 | Preserve stubs until media has been pruned. |
| 83:922 | Manage PST Stubs enabled. |
| 83:923 | Manage PST Stubs disabled. |
| 83:924 | Manage PST changed from [<String>] to [<String>]. |
| 83:925 | Copy PST stubs to mailbox. |
| 83:926 | Move PST stubs to mailbox. |
| 83:927 | Local PST location enabled. |
| 83:928 | Local PST location disabled. |
| 83:929 | Include attachment filter changed from [<String>] to [<String>]. |
| 83:930 | Exclude attachment filter changed from [<String>] to [<String>]. |
| 83:931 | Manual Retention enabled. |
| 83:932 | Manual Retention disabled. |
| 83:933 | Support Offline Archiving enabled. |
| 83:934 | Support Offline Archiving disabled. |
| 83:935 | Use file modified time to determine age enabled. |
| 83:936 | Use file modified time to determine age disabled. |
| 83:937 | File Archive Enabled for File system. |
| 83:938 | File Archive Disabled for File system. |
| 83:939 | Changed ESX server name from [<String>] to [<String>] for subclient [<String>]. |
| 83:940 | Express Recovery wild card for client log backup changed from [<String>] to [<String>]. |
| 83:941 | Changed Number of minutes between removing catalogued objects from [<Number>] to [<Number>]. |
| 83:942 | Software Share changed from [<String>] to [<String>]. |
| 83:943 | [<String>] Storage PolicyId changed from [<Number>] to [<Number>]. |
| 83:944 | [<String>] Storage Policy Name changed from [<String>] to [<String>]. |
| 83:945 | Changed mining sqlInstance Name from [<String>] to [<String>] for subclient [<String>]. |
| 83:946 | Changed mining userPassword from [<String>] to [<String>] for subclient [<String>]. |
| 83:947 | Changed mining userName from [<String>] to [<String>] for subclient [<String>]. |
| 83:948 | Generate Data Verification is enabled for subclient [<String>]. |
| 83:949 | Generate Data Verification is disabled for subclient [<String>]. |
| 83:950 | EDC NetApp SnapManager for Oracle Instance - |
| 83:951 | EDC NetApp SnapManager for SAP/Oracle Instance - |
| 83:952 | [<Message>] [<String>] SAP Data Home changed from [<String>] to [<String>]. |
| 83:953 | [<Message>] [<String>] SAP EXE Location changed from [<String>] to [<String>]. |
| 83:954 | Catalog Data Full System Restore changed from [<String>] to [<String>]. |
| 83:955 | Backup system state option is [<String>]n |
| 83:956 | Auto Discover Set to OS Group Affinity |
| 83:957 | Instance has been selected as a Secondary policy Server. |
| 83:958 | Instance has been de-selected as a Secondary Fpolicy Server. |
| 83:959 | Backup Set Deduplication property changed from [<String>] to [<String>]. |
| 83:960 | [<Message>] Version changed from [<String>] to [<String>]. |
| 83:961 | Recall link body enabled for subclient [<String>]. |
| 83:962 | Recall link body disabled for subclient [<String>]. |
| 83:963 | Changed OWA Server Name from [<String>] to [<String>] for subclient [<String>]. |
| 83:964 | Use Disable AutoDiscovery option enabled. |
| 83:965 | Use Disable AutoDiscovery option disabled. |
| 83:966 | Use Disable LogConsistency option enabled. |
| 83:967 | Use Disable LogConsistency option disabled. |
| 83:968 | Tunable block size changed from [<Number>] to [<Number>]. |
| 83:969 | Tunable buffer count changed from [<Number>] to [<Number>]. |
| 83:970 | Archive files with max size changed from [<Number>] to [<Number>] KB. |
| 83:971 | Migrate Read Only file Enabled. |
| 83:972 | Migrate Read Only file Disabled. |
| 83:973 | Transport Mode has changed from [<Number>] to [<Number>] for subclient [<Number>]. |
| 83:974 | Use SharePoint Direct access enabled. |
| 83:975 | Use SharePoint alternate access disabled. |
| 83:976 | Oracle Archive second copy enabled. |
| 83:977 | Oracle Archive second copy disabled. |
| 83:978 | Archive delete enabled at [<Message>] Instance [<String>]. |
| 83:979 | Archive delete disabled at [<Message>] Instance [<String>]. |
| 83:980 | Multiplexing for Oracle has been <String>. |
| 83:981 | Use HardWare Snapshot. |
| 83:982 | Backup of Workstation Deleted files has been [<String>]. |
| 83:983 | Backup set has been marked as the fan-in backup set. |
| 83:984 | Changed ESX User name from [<String>] to [<String>] for subclient [<String>]. |
| 83:985 | Changed ESX Password for subclient [<String>]. |
| 83:986 | Tunable maximum transfer size changed from [<Number>] to [<Number>]. |
| 83:987 | Changed ESX Hostname from [<String>] to [<String>] for subclient [<String>]. |
| 83:988 | SMTP username changed from [<String>] to [<String>]. |
| 83:989 | SMTP displayname changed from [<String>] to [<String>]. |
| 83:990 | SMTP SSL/TLS flag changed. |
| 83:991 | SMTP authentication flag changed. |
| 83:992 | SMTP password has been changed. |
| 83:993 | Exchange version changed from [<String>] to [<String>] |
| 83:994 | DB2 backup compression flag has been changed from [<Number>] to [<Number>]. |
| 83:995 | DB2 backup parallelism value has been changed from [<Number>] to [<Number>]. |
| 83:996 | mtime is enabled. |
| 83:997 | mtime is disabled. |
| 83:998 | Changed hash minimum file size changed from [<Number>] to [<Number>]. |
| 83:999 | Changed hash block size changed from [<Number>] to [<Number>]. |
| 83:1000 | Changed FLR verification before sync. |
| 83:1001 | Changed FLR generate data verification. |
| 83:1002 | Prune archive items flag changed. |
| 83:1003 | Prune archive items changed from [<Number>] to [<Number>] days. |
| 83:1004 | Changed Celerra control station from [<String>] to [<String>]. |
| 83:1005 | Changed Celerra user name from [<String>] to [<String>]. |
| 83:1006 | Celerra password changed. |
| 83:1007 | ctime is enabled. |
| 83:1008 | ctime is disabled. |
| 83:1009 | Enable Stubbing is enabled. |
| 83:1010 | Enable Stubbing is disabled. |
| 83:1011 | Enable LVM/cxbf snapshot to preserve file access time. |
| 83:1012 | Disable LVM/cxbf snapshot to preserve file access time. |
| 83:1013 | postgresql collect object list enabled. |
| 83:1014 | postgresql collect object list disabled. |
| 83:1015 | Collect VSS MetaData enabled. |
| 83:1016 | Collect VSS MetaData disabled. |
| 83:1017 | Truncate SQL Logs enabled. |
| 83:1018 | Truncate SQL Logs disabled. |
| 83:1019 | Truncate EXDB Logs enabled. |
| 83:1020 | Truncate EXDB Logs enabled. |
| 83:1021 | Can not create the policy due to error in data. |
| 83:1022 | Can not modify the policy due to error in data. |
| 83:1023 | Can not find the required policy. |
| 83:1024 | Cannot create the target as another target with the same name exists. |
| 83:1025 | Subclient [<String>] is being used for Dedup database backup. |
| 83:1026 | Subclient [<String>] is not being used for Dedup database backup. |
| 83:1027 | Deprecated message. [<String>] [<String>]. |
| 83:1028 | Archive files created time is changed from [<Number>] to [<Number>] days. |
| 83:1029 | File Created Time Rule Enabled. |
| 83:1030 | File Created Time Rule Disabled. |
| 83:1031 | Virtual Machine Archive Rules has changed from [<String>] to [<String>]. |
| 83:1032 | Client is archived. |
| 83:1033 | Client is not Archived. |
| 83:1034 | Server group does not exist |
| 83:1035 | Backup Archive Mailbox enabled for subclient [<String>]. |
| 83:1036 | Backup Archive Mailbox disabled for subclient [<String>]. |
| 83:1037 | Archive Everything enabled for subclient [<String>]. |
| 83:1038 | Archive Everything disabled for subclient [<String>]. |
| 83:1039 | Archive Source Online enabled for subclient [<String>]. |
| 83:1040 | Archive Source Online disabled for subclient [<String>]. |
| 83:1041 | Archive Source Archive enabled for subclient [<String>]. |
| 83:1042 | Archive Source Archive disabled for subclient [<String>]. |
| 83:1043 | Archive Source PST enabled for subclient [<String>]. |
| 83:1044 | Archive Source PST disabled for subclient [<String>]. |
| 83:1045 | Backup Only Files qualified for archiving enabled for subclient [<String>]. |
| 83:1046 | Backup Only Files qualified for archiving disabled for subclient [<String>]. |
| 83:1047 | Fpolicy Primary Client changed to [<String>]. |
| 83:1048 | Fpolicy Secondary Client changed to [<String>]. |
| 83:1049 | NAS HTTP Port changed to [<Number>]. |
| 83:1050 | CIFS Path changed to [<String>]. |
| 83:1051 | Amazon Center |
| 83:1052 | Amazon Center Access Key has been changed. |
| 83:1053 | Amazon Center Secret Key has been changed. |
| 83:1054 | Amazon Center URL now set as [<String>]. |
| 83:1055 | Amazon Center Email now set as [<String>]. |
| 83:1056 | Use Classic Scan Enabled. |
| 83:1057 | Use Classic Scan Disabled. |
| 83:1058 | Oracle Merge Incrementals Image Copy enabled. |
| 83:1059 | Oracle Merge Incrementals Image Copy disabled. |
| 83:1060 | Username for [<String>] changed from [<String>] to [<String>]. |
| 83:1061 | User Password for [<String>] was changed. |
| 83:1062 | DB2 SQL Connect username changed from [<String>] to [<String>]. |
| 83:1063 | DB2 SQL Connect User Password was changed. |
| 83:1064 | FLR Lock Data username changed from [<String>] to [<String>]. |
| 83:1065 | FLR Lock Data User Password was changed. |
| 83:1066 | Informix username changed from [<String>] to [<String>]. |
| 83:1067 | Informix User Password was changed. |
| 83:1068 | Oracle username changed from [<String>] to [<String>]. |
| 83:1069 | Oracle User Password was changed. |
| 83:1070 | Disaster Recovery User Name changed from [<String>] to [<String>]. |
| 83:1071 | Disaster Recovery Password changed. |
| 83:1072 | System state backup on full backup only disabled on this subclient. |
| 83:1073 | System state backup on full backup only enabled on this subclient. |
| 83:1074 | Oracle use Rman for log backup is enabled. |
| 83:1075 | Oracle use Rman for log backup is disabled. |
| 83:1076 | Number Of Synth Full Versions changed from [<Number>] to [<Number>]. |
| 83:1077 | Explorer Based End User Recall has been Disabled. |
| 83:1078 | Explorer Based End User Recall has been Enabled. |
| 83:1079 | DB2 Backup disable switch is set to true |
| 83:1080 | DB2 Backup disable switch is set to false |
| 83:1081 | Alert Run Command(s) User Name changed from [<String>] to [<String>]. |
| 83:1082 | Alert Run Command(s) Password changed. |
| 83:1083 | MediaAgent Access Path User Name changed from [<String>] to [<String>]. |
| 83:1084 | MediaAgent Access Path Password changed. |
| 83:1085 | MediaAgent Device Controller User Name changed from [<String>] to [<String>]. |
| 83:1086 | MediaAgent Device Controller Password changed. |
| 83:1087 | MediaAgent Data Recovery run information User Name changed from [<String>] to [<String>]. |
| 83:1088 | MediaAgent Data Recovery run information Password changed. |
| 83:1089 | MediaAgent Host User Name changed from [<String>] to [<String>]. |
| 83:1090 | MediaAgent Host Password changed. |
| 83:1091 | MediaAgent Mount Path User Name changed from [<String>] to [<String>]. |
| 83:1092 | MediaAgent Mount Path Password changed. |
| 83:1093 | MediaAgent DMP Host Info User Name changed from [<String>] to [<String>]. |
| 83:1094 | MediaAgent DMP Host Info Password changed. |
| 83:1095 | MediaAgent SANS switch proxy User Name changed from [<String>] to [<String>]. |
| 83:1096 | MediaAgent SANS switch proxy Password changed. |
| 83:1097 | MediaAgent Array Management User Name changed from [<String>] to [<String>]. |
| 83:1098 | MediaAgent Array Management Password changed. |
| 83:1099 | MediaAgent Control Host User Name changed from [<String>] to [<String>]. |
| 83:1100 | MediaAgent Control Host Password changed. |
| 83:1101 | Commvault Quiesce has been enabled. |
| 83:1102 | Commvault Quiesce has been disabled. |
| 83:1103 | VMWare Quiesce has been enabled. |
| 83:1104 | VMWare Quiesce has been disabled. |
| 83:1105 | Auto Discovery based on folder pattern(s) enabled. |
| 83:1106 | Auto Discovery based on folder pattern(s) disabled. |
| 83:1107 | Folder pattern for auto discovery set |
| 83:1108 | MySql Backup from proxy has been Enabled. |
| 83:1109 | MySql Backup from proxy has been Disabled. |
| 83:1110 | MySql use SSL for backup from proxy has been Enabled. |
| 83:1111 | MySql use SSL for backup from proxy has been Disabled. |
| 83:1112 | MySql Backup from proxy has been Enabled. |
| 83:1113 | MySql Backup from proxy has been Disabled. |
| 83:1114 | MySql fail over backup on production has been Enabled. |
| 83:1115 | MySql fail over backup has been Disabled. |
| 83:1116 | Virtual Machine Dynamic Content has changed for Subclient : [<Number>]. |
| 83:1117 | Delete snapshot after backup has been Enabled. |
| 83:1118 | Delete snapshot after backup has been Disabled. |
| 83:1119 | Block level backup has been Enabled. |
| 83:1120 | Block level backup has been Disabled. |
| 83:1121 | Pst with no owner information should be assigned to this mailbox changed from [<String>] to [<String>]. |
| 83:1122 | Reference Copy enabled for subclient [<String>]. |
| 83:1123 | Reference Copy disabled for subclient [<String>]. |
| 83:1124 | PST Archiving enabled for subclient [<String>]. |
| 83:1125 | PST Archiving disabled for subclient [<String>]. |
| 83:1126 | Merge into mailbox hierarchy enabled for subclient [<String>]. |
| 83:1127 | Merge into mailbox hierarchy disabled for subclient [<String>].======= |
| 83:1128 | MSSQL Integrity Server Name Changed. |
| 83:1129 | Archive Time Enabled. |
| 83:1130 | Receive Time Enabled. |
| 83:1131 | Backup only emails that qualify for archiving Enabled. |
| 83:1132 | Backup only emails that qualify for archiving Disabled. |
| 83:1133 | Virtual Machine Filters has changed for Subclient : [<Number>]. |
| 83:1134 | Virtual Machine Disk Filters has changed for Subclient : [<Number>]. |
| 83:1135 | MySql run log backups on proxy has been Enabled. |
| 83:1136 | MySql run log backups on proxy has been Disabled. |
| 83:1137 | For Open Files Only has been enabled. |
| 83:1138 | For Open Files Only has been disabled. |
| 83:1139 | Sybase block size changed from [<Number>] to [<Number>]. |
| 83:1140 | Delete PST file only is enabled for subclient [<String>]. |
| 83:1141 | Delete PST file only is disabled for subclient [<String>]. |
| 83:1142 | Use Proxy for SQL integrity check enabled for subclient : [<Number>]. |
| 83:1143 | Use Proxy for SQL integrity check disabled for subclient : [<Number>]. |
| 83:1144 | Credentials for SQL integrity check enabled for subclient : [<Number>]. |
| 83:1145 | Credentials for SQL integrity check disabled for subclient : [<Number>]. |
| 83:1146 | User Name is changed for Proxy SQL Server Integrity Check for subclient : [<Number>]. |
| 83:1147 | Password is changed for Proxy SQL Server Integrity Check for subclient : [<Number>]. |
| 83:1148 | Retain Indefinitely |
| 83:1149 | Use storage policy copy retention after [<Number>] days. |
| 83:1150 | Prune archived items changed from [<String>] to [<String>]. |
| 83:1151 | Off Line Mining Active Directory user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1152 | Off Line Mining Active Directory user password changed for schedule [<String>] |
| 83:1153 | Impersonate user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1154 | Impersonate user password changed for schedule [<String>] |
| 83:1155 | NT Impersonate user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1156 | NT Impersonate user password changed for schedule [<String>] |
| 83:1157 | Share point Doc user information user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1158 | Share point Doc user information user password changed for schedule [<String>] |
| 83:1159 | Search user information user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1160 | Search user information user password changed for schedule [<String>] |
| 83:1161 | SyBase IQ user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1162 | SyBase IQ user password changed for schedule [<String>] |
| 83:1163 | Domino user information user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1164 | Domino user information user password changed for schedule [<String>] |
| 83:1165 | Virtual server disk level user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1166 | Virtual server disk level user password changed for schedule [<String>] |
| 83:1167 | Virtual server user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1168 | Virtual server user password changed for schedule [<String>] |
| 83:1169 | SQL server user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1170 | SQL server user password changed for schedule [<String>] |
| 83:1171 | Oracle catalog user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1172 | Oracle catalog user password changed for schedule [<String>] |
| 83:1173 | Report saved to user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1174 | Report saved to user password changed for schedule [<String>] |
| 83:1175 | SQL install account user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1176 | SQL install account user password changed for schedule [<String>] |
| 83:1177 | Client install account user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1178 | Client install account user password changed for schedule [<String>] |
| 83:1179 | Client install job user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1180 | Client install job user password changed for schedule [<String>] |
| 83:1181 | Download update user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1182 | Download update job user password changed for schedule [<String>] |
| 83:1183 | CommCell Migration user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1184 | CommCell Migration password changed for schedule [<String>] |
| 83:1185 | CommCell Migration SQL linked server user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1186 | CommCell Migration SQL linked server user password changed for schedule [<String>] |
| 83:1187 | CommCell Migration remote DB path user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1188 | CommCell Migration remote DB path password changed for schedule [<String>] |
| 83:1189 | CommCell Migration account user name changed from [<String>] to [<String>] for schedule [<String>]. |
| 83:1190 | CommCell Migration account password changed for schedule [<String>] |
| 83:1191 | Pre/Post user name |
| 83:1192 | Pre/Post user password |
| 83:1193 | Username for UNC path |
| 83:1194 | UNC path user password |
| 83:1195 | Mining sqlInstance Name |
| 83:1196 | Mining user password |
| 83:1197 | PST file user name |
| 83:1198 | PST file user password |
| 83:1199 | Snap user name |
| 83:1200 | OCS user name |
| 83:1201 | OCS password |
| 83:1202 | SQL connect user name |
| 83:1203 | SQL connect Password |
| 83:1204 | Host password |
| 83:1205 | Host user domain name |
| 83:1206 | Site Account User |
| 83:1207 | Site Account user password |
| 83:1208 | Windows Account with SQL Admin Role |
| 83:1209 | Password for Windows Account with SQL Admin Role |
| 83:1210 | User name for Job Results Directory |
| 83:1211 | Password for Job Results Directory |
| 83:1212 | User name for [<String>] |
| 83:1213 | User password for [<String>] |
| 83:1214 | Off Line Mining Active Directory user name |
| 83:1215 | Off Line Mining Active Directory user password |
| 83:1216 | Impersonate user name |
| 83:1217 | Impersonate user password |
| 83:1218 | NT Impersonate user name |
| 83:1219 | NT Impersonate user password |
| 83:1220 | Share point Doc user information user name |
| 83:1221 | Share point Doc user information user password |
| 83:1222 | Search user information user name |
| 83:1223 | Search user information user password |
| 83:1224 | SyBase IQ user name |
| 83:1225 | SyBase IQ user password |
| 83:1226 | Domino user information user name |
| 83:1227 | Domino user information user password |
| 83:1228 | Virtual server disk level user name |
| 83:1229 | Virtual server disk level user password |
| 83:1230 | Virtual server user name |
| 83:1231 | Virtual server user password |
| 83:1232 | SQL server user name |
| 83:1233 | SQL server user password |
| 83:1234 | Oracle catalog user name |
| 83:1235 | Oracle catalog user password |
| 83:1236 | Report saved to user name |
| 83:1237 | Report saved to user password |
| 83:1238 | SQL install account user name |
| 83:1239 | SQL install account user password |
| 83:1240 | Client install account user name |
| 83:1241 | Client install account user password |
| 83:1242 | Client install job user name |
| 83:1243 | Client install job user password |
| 83:1244 | Download update user name |
| 83:1245 | Download update job user password |
| 83:1246 | Commcell Migration user name |
| 83:1247 | Commcell Migration password |
| 83:1248 | Commcell Migration SQL linked server user name |
| 83:1249 | Commcell Migration SQL linked server user password |
| 83:1250 | Commcell Migration remote DB path user name |
| 83:1251 | Commcell Migration remote DB path password |
| 83:1252 | Commcell Migration account user name |
| 83:1253 | Commcell Migration account password |
| 83:1254 | DB2 SQL Connect user name |
| 83:1255 | DB2 SQL Connect user password |
| 83:1256 | FLR Lock Data user name |
| 83:1257 | FLR Lock Data user password |
| 83:1258 | Informix user name |
| 83:1259 | Informix user password |
| 83:1260 | Oracle user name |
| 83:1261 | Oracle user password |
| 83:1262 | Disaster Recovery user name |
| 83:1263 | Disaster Recovery Password |
| 83:1264 | Alert Run Command(s) user name |
| 83:1265 | Alert Run Command(s) Password |
| 83:1266 | MediaAgent Access Path user name |
| 83:1267 | MediaAgent Access Path Password |
| 83:1268 | MediaAgent Device Controller user name |
| 83:1269 | MediaAgent Device Controller Password |
| 83:1270 | MediaAgent Data Recovery run information user name |
| 83:1271 | MediaAgent Data Recovery run information Password |
| 83:1272 | MediaAgent Host user name |
| 83:1273 | MediaAgent Host Password |
| 83:1274 | MediaAgent Mount Path user name |
| 83:1275 | MediaAgent Mount Path Password |
| 83:1276 | MediaAgent DMP Host Info user name |
| 83:1277 | MediaAgent DMP Host Info Password |
| 83:1278 | MediaAgent SANS switch proxy user name |
| 83:1279 | MediaAgent SANS switch proxy Password |
| 83:1280 | MediaAgent Array Management user name |
| 83:1281 | MediaAgent Array Management Password |
| 83:1282 | MediaAgent Control Host user name |
| 83:1283 | MediaAgent Control Host Password |
| 83:1284 | SMTP user name |
| 83:1285 | SMTP password |
| 83:1286 | IIS Server user name |
| 83:1287 | IIS Server user password |
| 83:1288 | User name for FTP Site |
| 83:1289 | Password for FTP Site |
| 83:1290 | HTTP Proxy user name |
| 83:1291 | HTTP Proxy password |
| 83:1292 | User name for CommServe Update Location |
| 83:1293 | Password for CommServe Update Location |
| 83:1294 | FTP Proxy user name |
| 83:1295 | FTP Proxy password |
| 83:1296 | SQL authentication user name |
| 83:1297 | SQL authentication password |
| 83:1298 | and user password |
| 83:1299 | Import comcell user name |
| 83:1300 | Import comcell user password |
| 83:1301 | Export comcell user name |
| 83:1302 | Export comcell user password |
| 83:1303 | Use VSS for all files enabled |
| 83:1304 | Use VSS for all files disabled |
| 83:1305 | Fail the job if VSS Snap fails enabled |
| 83:1306 | Fail the job if VSS Snap fails disabled |
| 83:1307 | Continue and reset access time if VSS Snap fails enabled |
| 83:1308 | Continue and reset access time if VSS Snap fails disabled |
| 83:1309 | Continue and do not reset access time if VSS Snap fails enabled |
| 83:1310 | Continue and do not reset access time if VSS Snap fails disabled |
| 83:1311 | Backup from Live volume enabled |
| 83:1312 | Backup from Live volume disabled |
| 83:1313 | Backup Disabled Mailbox is enabled for subclient [<String>]. |
| 83:1314 | Backup Disabled Mailbox is disabled for subclient [<String>]. |
| 83:1315 | Virtual Server Quiesce User Name has changed from [<String>] to [<String>] for Subclient : [<Number>]. |
| 83:1316 | Virtual Server Quiesce User Password has changed for Subclient : [<Number>]. |
| 83:1317 | Virtual Machine Perform Datastore Freespace check has changed for Subclient : [<Number>]. |
| 83:1318 | Virtual Machine Datastore Freespace Required has changed from [<String>] to [<String>] for Subclient : [<Number>]. |
| 83:1319 | Remove Old Stubs is enabled. |
| 83:1320 | Remove Old Stubs is disabled |
| 83:1321 | Remove Old Messages is enabled. |
| 83:1322 | Remove Old Messages is disabled |
| 83:1323 | Do Not Archive Items Before changed from [<String>] to [<String>]. |
| 83:1324 | Do Not Archive Items After changed from [<String>] to [<String>]. |
| 83:1325 | Disabled |
| 83:1326 | Use pre post user Enabled for FTI |
| 83:1327 | Use pre post user Enabled for SA |
| 83:1328 | Use pre post user Enabled for DB |
| 83:1329 | Use pre post user Disabled for FTI |
| 83:1330 | Use pre post user Disabled for SA |
| 83:1331 | Use pre post user Disabled for DB |
| 83:1332 | FTI pre post Backup process impersonate user name changed from [<String>] to [<String>] |
| 83:1333 | DB pre post Backup process impersonate user name changed from [<String>] to [<String>] |
| 83:1334 | SA pre post Backup process impersonate user name changed from [<String>] to [<String>] |
| 83:1335 | Retention for files deleted by archiving job changed from [<String>] to [<String>]. |
| 83:1336 | Forever |
| 83:1337 | Catalog ACL option has been enabled |
| 83:1338 | Catalog ACL option has been disabled |
| 83:1339 | Catalog Additional File And System Attributes option has been enabled |
| 83:1340 | Catalog Additional File And System Attributes option has been disabled |
| 83:1341 | Proxy for SQL Integrity check changed from [<String>] to [<String>] |
| 83:1342 | Use Proxy for SQL integrity check is enabled |
| 83:1343 | Use Proxy for SQL integrity check is disabled |
| 83:1344 | Credentials for SQL integrity check is enabled |
| 83:1345 | Credentials for SQL integrity check is disabled |
| 83:1346 | User Name for Proxy SQL Server for SQL Integrity Check is changed from [<String>] to [<String>] |
| 83:1347 | Password for Proxy SQL Server for SQL Integrity Check is changed |
| 83:1348 | Prune archive items type changed from [<Number>] to [<Number>]. |
| 83:1349 | Enable Two-Factor Authentication changed from [<Number>] to [<Number>]. |
| 83:1350 | Use PST Name is enabled for subclient [<String>]. |
| 83:1351 | Use PST Name is disabled for subclient [<String>]. |
| 83:1352 | Section size changed from [<Number>] to [<Number>] |
| 83:1353 | [<String>] is enabled |
| 83:1354 | [<String>] is disabled |
| 83:1355 | Enable Metadata Collection has been Enabled. |
| 83:1356 | Enable Metadata Collection has been Disabled. |
| 83:1357 | Use PST Name to create folder option is enabled for subclient [<String>]. |
| 83:1358 | Merge folders from all PSTs under the parent folder is enabled for subclient [<String>]. |
| 83:1359 | Determine PST Ownership based on ACLs is selected for subclient [<String>]. |
| 83:1360 | Determine PST Ownership based on Folder Hierarchy is selected for subclient [<String>]. |
| 83:1361 | Determine PST Ownership based on Laptop owner, If ACLs not found is enabled for subclient [<String>]. |
| 83:1362 | Determine PST Ownership based on Laptop owner, If ACLs not found is disabled for subclient [<String>]. |
| 83:1363 | Changed PST Starting Folder Path from [<String>] to [<String>] for subclient [<String>]. |
| 83:1364 | Changed PST AD Property from [<String>] to [<String>] for subclient [<String>]. |
| 83:1365 | Sharepoint Archiver Tier 1 Archiving option is enabled |
| 83:1366 | Sharepoint Archiver Tier 1 Archiving option is disabled |
| 83:1367 | Sharepoint Archiver Tier 2 Archiving option is enabled |
| 83:1368 | Sharepoint Archiver Tier 2 Archiving option is disabled |
| 83:1369 | Only backup files created or modified on and after enabled. |
| 83:1370 | Only backup files created or modified on and after disabled. |
| 83:1371 | Only backup files created or modified on and after changed from [<Number>] to [<Number>]. |
| 83:1372 | Use NAS Catalog enabled. |
| 83:1373 | Use NAS Catalog disabled. |
| 83:1374 | Use incremental changed from [<Number>] to [<Number>]. |
| 83:1375 | Backup file time zone changed from [<String>] to [<String>]. |
| 83:1376 | Is Turbo Subclient property is set. |
| 83:1377 | Is Turbo Subclient property is unset. |
| 83:1378 | SharePoint version changed from [<String>] to [<String>]. |
| 83:1379 | Mailbox Quota Based On Disk Usage is enabled for subclient [<String>]. |
| 83:1380 | Mailbox Quota Based On Disk Usage is disabled for subclient [<String>]. |
| 83:1381 | Mailbox Quota Based On Disk Usage Size is changed from [<Number>] to [<Number>]. |
| 83:1382 | Honor archiver agent retention changed from [<Number>] to [<Number>]. |
| 83:1383 | Virtual Machine Filters has changed from: [<String>] to [<String>]. |
| 83:1384 | Virtual Machine Filters pattern has changed from: [<String>] to [<String>]. |
| 83:1385 | Virtual Machine Filters device node has changed from: [<String>] to [<String>]. |
| 83:1386 | Virtual Machine Filters data store has changed from: [<String>] to [<String>]. |
| 83:1387 | Virtual Machine Filters label has changed from: [<String>] to [<String>]. |
| 83:1388 | Change block tracking enabled. |
| 83:1389 | Change block tracking disabled. |
| 83:1390 | Successfully enabled the alert |
| 83:1391 | Successfully disabled the alert |
| 83:1392 | Azure Center |
| 83:1393 | Azure |
| 83:1394 | Azure Username now set as [<String>]. |
| 83:1395 | Azure Password has been changed. |
| 83:1396 | Warning subject for Mailbox size near quota size has been changed |
| 83:1397 | Warning Message for Mailbox size near quota size has been changed |
| 83:1398 | Warning subject for Mailbox size over quota size has been changed |
| 83:1399 | Warning Message for Mailbox size over quota size has been changed |
| 83:1400 | Exchange Online Backup Enabled. |
| 83:1401 | Exchange Online Backup Disabled. |
| 83:1402 | Exchange Online Account Username Changed. |
| 83:1403 | Exchange Online Account Password Changed. |
| 83:1404 | Exchange Online Profile changed from [<String>] to [<String>]. |
| 83:1405 | Prune Messages/Stubs which users erase from media is enabled. |
| 83:1406 | Prune Messages/Stubs which users erase from media is disabled |
| 83:1407 | Dear <String> |
| 83:1408 | Data Protection Job Alert: Client exceeded quota limit |
| 83:1409 | Data protection job <String> did not start on client computer <String>. You have used <String> out of quota of <String>. Please erase unnecessary data by logging into web console at <String>. |
| 83:1410 | Data Protection Job Alert: Client nearing quota limit |
| 83:1411 | Data protection job <String> signaled warning for client computer <String>. You have used <String> out of quota of <String>. Please erase unnecessary data by logging into web console at <String>. |
| 83:1412 | Retain File Copy Based on Storage Policy Day's Retention has been Enabled. |
| 83:1413 | Retain File Copy Based on Storage Policy Day's Retention has been Disabled. |
| 83:1414 | Retention for stubs deleted by user changed from [<String>] to [<String>]. |
| 83:1415 | Customized content in iSeries has been enabled. |
| 83:1416 | Customized content in iSeries has been disabled. |
| 83:1417 | Content selection in iSeries changed from [<String>] to [<String>]. |
| 83:1418 | Synchronize libraries for backup flag in iSeries has been enabled. |
| 83:1419 | Synchronize libraries for backup flag in iSeries has been disabled. |
| 83:1420 | Target release for backup data in iSeries changed from [<String>] to [<String>]. |
| 83:1421 | Save active wait time setting in iSeries changed from [<String>] to [<String>]. |
| 83:1422 | Backup library objects SAVFDATA flag in iSeries has been enabled. |
| 83:1423 | Backup library objects SAVFDATA flag in iSeries has been disabled. |
| 83:1424 | Backup library objects SPLFDTA flag in iSeries has been enabled. |
| 83:1425 | Backup library objects SPLFDTA flag in iSeries has been disabled. |
| 83:1426 | Backup library objects QDTA flag in iSeries has been enabled. |
| 83:1427 | Backup library objects QDTA flag in iSeries has been disabled. |
| 83:1428 | Backup library objects PVTAUT flag in iSeries has been enabled. |
| 83:1429 | Backup library objects PVTAUT flag in iSeries has been disabled. |
| 83:1430 | Synchronization Queue setting in iSeries changed from [<String>] to [<String>]. |
| 83:1431 | Program to run after libraries are synchronized setting in iSeries changed from [<String>] to [<String>]. |
| 83:1432 | Data Collection Option has been changed from Discovery to Discovery and Analysis |
| 83:1433 | Data Collection Option has been changed from Discovery and Analysis to Discovery |
| 83:1434 | DB2 Use Dedupe Device flag has been changed from [<Number>] to [<Number>]. |
| 83:1435 | DB2 Instance Home changed from [<String>] to [<String>]. |
| 83:1436 | Changed VSS Copy On Write destination from [<String>] to [<String>] for subclient [<String>]. |
| 83:1437 | Sybase Snap Dump based backup copy is enabled |
| 83:1438 | Sybase Snap Dump based backup copy is Disabled |
| 83:1439 | Sybase Snap Dump based backup copy use sybase instance is enabled |
| 83:1440 | Sybase Snap Dump based backup copy use sybase instance is Disabled |
| 83:1441 | Sybase Snap Dump based backup copy create Auxiliary server is enabled |
| 83:1442 | Sybase Snap Dump based backup copy create Auxiliary server is Disabled |
| 83:1443 | [<Message>] Home Path of Auxilary server changed from [<String>] to [<String>] |
| 83:1444 | [<Message>] ASE of Auxilary server changed from [<String>] to [<String>] |
| 83:1445 | [<Message>] Sybase OCS of Auxilary server changed from [<String>] to [<String>] |
| 83:1446 | [<Message>] User name of Auxilary server changed from [<String>] to [<String>] |
| 83:1447 | [<Message>] The Sybase Snap Configured Instance name changed from [<String>] to [<String>] |
| 83:1448 | [<Message>] The Sybase Snap Configured Instance Id changed from [<Number>] to [<Number>] |
| 83:1449 | [<Message>] The Sybase Snap Configured Client Id changed from [<Number>] to [<Number>] |
| 83:1450 | [<Message>] User password of Auxilary server changed from [<String>] to [<String>] |
| 83:1451 | tLocations : [<String>]n |
| 83:1452 | tContainers : [<String>]n |
| 83:1453 | tMedia Repositories : [<String>]n |
| 83:1454 | Informix Sql HostFile Entry changed from [<String>] to [<String>]. |
| 83:1455 | SQL Special Subclient type changed from [<String>] to [<String>] . |
| 83:1456 | Allow metadata for Exchange Db subclient is Enabled |
| 83:1457 | Allow metadata for Exchange Db subclient is Disabled |
| 83:1458 | Number of streams for Exchange changed from [<Number>] to [<Number>]. |
| 83:1459 | Archive and delete site collection is enabled. |
| 83:1460 | Archive and delete site collection is disabled. |
| 83:1461 | DB2 Skip logs in backup flag has been changed from [<Number>] to [<Number>]. |
| 83:1462 | Exclude From SLA Enabled. |
| 83:1463 | Exclude From SLA Disabled. |
| 83:1464 | Delete Archive log all enabled |
| 83:1465 | Delete Archive log all disabled |
| 83:1466 | Oracle Wallet Authentication Enabled |
| 83:1467 | Oracle Wallet Authentication Disabled |
| 83:1468 | Number of job messages to be protected changed from [<Number>] to [<Number>]. |
| 83:1469 | Number of job hours has been changed from [<Number>] to [<Number>]. |
| 83:1470 | MAPI network error is enabled. |
| 83:1471 | MAPI network error is disabled. |
| 83:1472 | Home Path of Auxiliary server changed from [<String>] to [<String>] |
| 83:1473 | ASE of Auxiliary server changed from [<String>] to [<String>] |
| 83:1474 | Sybase OCS of Auxiliary server changed from [<String>] to [<String>] |
| 83:1475 | User name of Auxiliary server changed from [<String>] to [<String>] |
| 83:1476 | The Sybase Snap Configured Instance name changed from [<String>] to [<String>] |
| 83:1477 | The Sybase Snap Configured Instance Id changed from [<Number>] to [<Number>] |
| 83:1478 | The Sybase Snap Configured Client Id changed from [<Number>] to [<Number>] |
| 83:1479 | User password of Auxiliary server changed from [<String>] to [<String>] |
| 83:1480 | Reference copy with deletion and stubbed filter enabled for subclient [<String>]. |
| 83:1481 | Reference copy with deletion and stubbed filter disabled for subclient [<String>] |
| 83:1482 | Alert Save to disk notification: User Name changed from [<String>] to [<String>]. |
| 83:1483 | Alert Save to disk notification: Password changed. |
| 83:1484 | Alert Save to disk notification user name |
| 83:1485 | Alert Save to disk notification password |
| 83:1486 | Trash Can retention changed from [<Number>] days to [<Number>] days. |
| 83:1487 | Grace period for versions changed from [<Number>] days to [<Number>] days. |
| 83:1488 | Virtual Server Snap info has changed for Subclient : [<Number>]. |
| 83:1489 | Transport Mode has changed from [<Number>] to [<Number>] for subclient [<String>]. |
| 83:1490 | Virtual Machine Dynamic Content has changed for Subclient : [<String>]. |
| 83:1491 | Virtual Machine Filters has changed for Subclient : [<String>]. |
| 83:1492 | Virtual Machine Disk Filters has changed for Subclient : [<String>]. |
| 83:1493 | Virtual Server Quiesce User Name has changed from [<String>] to [<String>] for Subclient : [<String>]. |
| 83:1494 | Virtual Server Quiesce User Password has changed for Subclient : [<String>]. |
| 83:1495 | Virtual Machine Perform Datastore Freespace check has changed for Subclient : [<String>]. |
| 83:1496 | Virtual Machine Datastore Freespace Required has changed from [<String>] to [<String>] for Subclient : [<String>]. |
| 83:1497 | Schedule Holiday Changes: <String> |
| 83:1498 | Use VSS Enabled for DR subclient changed from [<Number>] to [<Number>] |
| 83:1499 | Use ACS Interface [<String>] |
| 83:1500 | nNAS Agent Global Filters : [<String>]. |
| 83:1501 | PostgreSQL Instacne UNC Username changed from [<String>] to [<String>] |
| 83:1502 | PostgreSQL Instacne UNC Password changed |
| 83:1503 | SPOS Block Level option changed from [<Number>] to [<Number>]. |
| 83:1504 | SPOS Block Level client reboot option changed from [<Number>] to [<Number>]. |
| 83:1505 | Download protocol has been changed from [<String>] to [<String>]. |
| 83:1506 | Block-Level Backup optimize option changed from [<Number>] to [<Number>]. |
| 83:1507 | Oracle Data Export enabled |
| 83:1508 | Oracle Data Export disabled |
| 83:1509 | Use CVAccounts URL for SSO Redirections Enabled. |
| 83:1510 | Use CVAccounts URL for SSO Redirections Disabled. |
| 83:1511 | CVAccounts URL for SSO Redirections changed from [<String>] to [<String>]. |
| 83:1512 | Recall Link will be added to Stub body |
| 83:1513 | Recall Link will not be added to Stub body |
| 83:1514 | Stub Recall is enabled on Subclient |
| 83:1515 | Stub Recall is disabled on Subclient |
| 83:1516 | Windows global filter changed from [<String>] to [<String>]. |
| 83:1517 | Windows file archiver global filter changed from [<String>] to [<String>]. |
| 83:1518 | IBM I global filter changed from [<String>] to [<String>]. |
| 83:1519 | Unix global filter changed from [<String>] to [<String>]. |
| 83:1520 | Netware global filter changed from [<String>] to [<String>]. |
| 83:1521 | Exchange mailbox global filter changed from [<String>] to [<String>]. |
| 83:1522 | Exchange compliance archiver global filter changed from [<String>] to [<String>]. |
| 83:1523 | Content indexing global filter changed from [<String>] to [<String>]. |
| 83:1524 | NAS agent global filter changed from [<String>] to [<String>]. |
| 83:1525 | Server group is now associated with client [<String>]. |
| 83:1526 | Server group is no longer associated with client [<String>]. |
| 83:1527 | Disable switch current log is set to true |
| 83:1528 | Disable switch current log is set to false |
| 83:1529 | Image Copy Dir changed from [<String>] to [<String>]. |
| 83:1530 | Snap Image Copy is set to false |
| 83:1531 | Snap Image Copy is set to true |
| 83:1532 | Use Backup set Virtual Machine Disk Filter disabled. |
| 83:1533 | Use Backup set Virtual Machine Disk Filter enabled. |
| 83:1534 | HTTP Site location has been changed from [<String>] to [<String>]. |
| 83:1535 | Patch Config URL Prefix has been changed from [<String>] to [<String>]. |
| 83:1536 | Use token has been changed from [<String>] to [<String>]. |
| 83:1537 | Run true up for FS after number of days changed from [<String>] to [<String>]. |
| 83:1538 | True up for FS option has been disabled |
| 83:1539 | True up for FS option has been enabled |
| 83:1540 | Backup device changed from [<String>] to [<String>]. |
| 83:1541 | PostLog process changed from [<Number>] to [<Number>]. |
| 83:1542 | PreLog process changed from [<Number>] to [<Number>]. |
| 83:1543 | Operation Performed : Delete Software Cache |
| 83:1544 | Operation Performed : Sync Software Cache |
| 83:1545 | Operation Performed : Commit Software cache |
| 83:1546 | Operation Performed : Test Software Cache |
| 83:1547 | Virtual Machine Include Independent Disks option has changed from [<Number>] to [<Number>] for Subclient : [<String>]. |
| 83:1548 | Virtual Machine Include Raw Device Maps options has changed [<Number>] to [<Number>] for Subclient : [<String>]. |
| 83:1549 | [<Message>] Standby Backup has been disabled. |
| 83:1550 | [<Message>] Standby Backup has been enabled. |
| 83:1551 | [<Message>] Standby Instance has been changed from [<Number>] to [<Number>]. |
| 83:1552 | [<Message>] Standby Option : Use master if standby is unavailable has been disabled. |
| 83:1553 | [<Message>] Standby Option : Use master if standby is unavailable has been enabled. |
| 83:1554 | [<Message>] Standby Option : Use Master for Log Backup has been disabled. |
| 83:1555 | [<Message>] Standby Option : Use Master for Log Backup has been enabled. |
| 83:1556 | Data Verification |
| 83:1557 | DDB |
| 83:1558 | Google Cloud Private key's password has been changed. |
| 83:1559 | Google Cloud Username - private key file path now set as [<String>]. |
| 83:1560 | Ignore Strikes Before option has been changed. |
| 83:1561 | Alibaba Cloud secret key has been changed. |
| 83:1562 | Oracle Cloud Infrastructure finger print has been changed. |
| 83:1563 | Oracle Cloud Infrastructure private key file path has been changed. |
| 83:1564 | Credential Manager User Password for [<String>] was changed. |
| 83:1565 | Credential Manager User password for [<String>]. |
| 83:1566 | Credential Manager Username for [<String>] changed from [<String>] to [<String>]. |
| 83:1567 | Credential Manager User name for [<String>]. |
| 83:1568 | Block-Level Backup optimize option changed from [<String>] to [<String>]. |
| 83:1569 | SPOS Block Level option changed from [<String>] to [<String>]. |
| 83:1570 | Passive node [<String>] is not reachable. |
| 83:1571 | Passive node [<String>] is reachable. |
| 83:1572 | Production failover to node [<String>] failed. Please check log files for details. |
| 83:1573 | Production failover to node [<String>] failed and rollback to node [<String>] was done successfully. Please check log files for details. |
| 83:1574 | Production failover started from node [<String>] to [<String>]. |
| 83:1575 | Production failover to node [<String>] was successful. |
| 83:1576 | Production maintenance failover to node [<String>] failed. Please check log files for details. |
| 83:1577 | Production maintenance failover started from node [<String>] to [<String>]. |
| 83:1578 | Production maintenance failover to node [<String>] was successful. |
| 83:1579 | Production node [<String>] is not running. Some or all the services could be down. |
| 83:1580 | Production node [<String>] is running |
| 83:1581 | Production node [<String>] is not reachable from the node [<String>] |
| 83:1582 | Test failback to node [<String>] failed. Please check log files for details. |
| 83:1583 | Test failback started from node [<String>] to [<String>]. |
| 83:1584 | Test failback to node [<String>] was successful. |
| 83:1585 | Test failover to node [<String>] failed. Please check log files for details. |
| 83:1586 | Test failover started from node [<String>] to [<String>]. |
| 83:1587 | Test failover to node [<String>] was successful. |
| 83:1588 | MySQL Xtrabackup binary path changed from [<String>] to [<String>]. |
| 83:1589 | MySQL Xtrabackup flag changed from [<String>] to [<String>]. |
| 83:1590 | Password history count changed from [<Number>] to [<Number>]. |
| 83:1591 | RPO Minutes has been changed. |
| 83:1592 | RTO Minutes has been changed. |
| 83:1593 | The system detected events that are unusual in occurrence or frequency. |
| 83:1594 | The system detected jobs that are running longer than usual time. |
| 83:1595 | The system detected an unusually large number of jobs failed. Current failed jobs are <Number> against an expected value of less than <Number>. |
| 83:1596 | The system detected an unusually large number of jobs pending. Current pending jobs are <Number> against an expected value of less than <Number>. |
| 83:1597 | The system detected an unusually less number of jobs succeeded. Number of jobs succeeded is <Number>. |
| 83:1598 | Diagnostic Information: |
| 83:1599 | Number of failed jobs: <Number> |
| 83:1600 | Number of jobs |
| 83:1601 | Number of queued jobs: <Number> |
| 83:1602 | The system detected an unusually <b> less number of jobs succeeded between <String> to <String> on <String> </b>. Number of jobs succeeded is <Number>. |
| 83:1603 | Top job failure reason |
| 83:1604 | Top job queue reason |
| 83:1605 | Top job waiting reason |
| 83:1606 | Number of waiting jobs: <Number> |
| 83:1607 | The job did not run from <String> to <String> as the backup activity was disabled. |
| 83:1608 | The job did not run from <String> to <String> due to the operation window. |
| 83:1609 | There is an increase in the backup size by <Number> percent. |
| 83:1610 | The subclient's content has changed after the last successful backup. Check audit trail for more details. |
| 83:1611 | The job was suspended at <String> and later resumed at <String>. |
| 83:1612 | Last <Number> jobs have not completed in this subclient. |
| 83:1613 | Consider running a deduplication database (DDB) backup for SIDB store <String> from <String> to <String>, during the periods of low activity. |
| 83:1614 | Deduplication database (DDB) is being backed up (job ID <Number>) for SIDB substore [<String>]. |
| 83:1615 | Deduplication database (DDB) backup job (job ID <Number>) was running for substore <String> from <String> to <String>. |
| 83:1616 | Phase <String> has failed <Number> times. Phase failure message: (<String>) |
| 83:1617 | There is an unusual performance drop detected in pruning for deduplication database [<String>] due to the increase in [<String>] |
| 83:1618 | Failed to restore database [<String>]. Please attempt manual restore of the database. |
| 83:1619 | The backup size has increased from <String> to <String> |
| 83:1620 | The system detected events that are unusual in occurrence or frequency in <String>. |
| 83:1621 | The system detected jobs that are running longer than usual time in <String>. |
| 83:1622 | The system detected an unusually large number of jobs failed in <String>. Current failed jobs are <Number> against an expected value of less than <Number>. |
| 83:1623 | The system detected an unusually large number of jobs pending in <String>. Current pending jobs are <Number> against an expected value of less than <Number>. |
| 83:1624 | The system detected an unusually <b> less number of jobs succeeded between <String> to <String> on <String> </b> in <String>. The number of jobs succeeded is <Number>. |
| 83:1625 | Media Agent <String> is soft state disabled due to an abnormal increase in the count of long-running or pending jobs in it. |
| 83:1626 | Number of long running jobs: <Number> |
| 83:1627 | The system detected an unusual number of long-running/pending/waiting/failed jobs through MediaAgent <String> at <String> on <String> in <String>. The MediaAgent is soft state disabled and the jobs will be routed through other MediaAgent. |
| 83:1628 | Media Agent <String> is soft state enabled by KPI based Media Agent state management. |
| 83:1629 | Media Agent <String> is restarted by KPI based Media Agent state management due to an increase in pending or long-running jobs. |
| 83:1630 | Top job delay reason |
| 83:1631 | The system detected an unusual drop in the pruning performance for the following databases in commcell <String> |
| 83:1632 | The job state is changed by KPI based Media Agent state management. |
| 83:1633 | The system detected an unusual number of long-running/pending/waiting/failed jobs through MediaAgent <String> at <String> on <String> in <String>. The services in the MediaAgent are restarted. |
| 83:1634 | The scheduled job is expected to run beyond the SLA period. |
| 83:1635 | The client does not have any backup jobs scheduled. |
| 83:1636 | The client does not have any backup jobs scheduled to run before the SLA period. |
| 83:1637 | Last <Number> jobs have not succeeded in the client |
| 83:1638 | The job in progress is expected to run beyond the SLA period. |
| 83:1639 | The client has missed SLA. |
| 83:1640 | System detected that the following clients have missed SLA in <String>. |
| 83:1641 | There is a history of jobs failing in the client. |
| 83:1642 | The subclient has missed SLA as jobs have not completed for the past <String> days in the subclient. |
| 83:1643 | The subclient has missed SLA as jobs never completed in the subclient. |
| 83:1644 | The job in progress is expected to run beyond the SLA period as it will be delayed by <String> due to overlapping operation window. |
| 83:1645 | The scheduled job is expected to run beyond the SLA period as it will be delayed by <String> due to overlapping operation window. |
| 83:1646 | Archive logs will be deleted after [<Number>] hours. |
| 83:1647 | User does not have Administrative Management capability at commcell level to delete recovery target |
| 83:1648 | Replication group [<String>] is using this recovery target. Please delete recovery group before deleting recovery target |
| 83:1649 | There is a history of jobs failing in the subclient. A job must complete before <String> |
| 83:1650 | Scheduled job is expected to run beyond the SLA period. A job must complete before <String>. |
| 83:1651 | No backup jobs scheduled. Please run backup before <String>. |
| 83:1652 | No backup jobs scheduled before the SLA period. Please run backup before <String>. |
| 83:1653 | The job is expected to run beyond the SLA period. It has to be completed before <String>. |
| 83:1654 | The job is running beyond the runtime threshold. It has to be completed before <String>. |
| 83:1655 | The job is running longer than the forecasted runtime. It has to be completed before <String>. |
| 83:1656 | The job is expected to run beyond the SLA period as it will be delayed by <String> due to overlapping blackout window. It has to be completed before <String>. |
| 83:1657 | Scheduled job is expected to run beyond the SLA period as it will be delayed by <String> due to overlapping blackout window. A job must complete before <String>. |
| 83:1658 | AutoScale option disabled |
| 83:1659 | AutoScale option enabled |
| 83:1660 | Job <String> is expected to run beyond the SLA period. It must complete before <String> |
| 83:1661 | Job <String> is running beyond the runtime threshold. It must complete before <String> |
| 83:1662 | Job <String> is running longer than the forecasted runtime. It must complete before <String> |
| 83:1663 | Job <String> is expected to run beyond the SLA period as it will be delayed by <String> due to overlapping blackout window. It must complete before <String> |
| 83:1664 | MySQL full instance XtraBackup is disabled. |
| 83:1665 | MySQL full instance XtraBackup is enabled. |
| 83:1666 | SQL authentication MSSQL Credential Association changed from [<Number>] to [<Number>]. |
| 83:1667 | System detected anomaly during backup job [<String>] for the Salesforce organization [<String>]. |
| 83:1668 | System detected that there may be a fall in SLA in the following clients in <String>. |
| 83:1669 | Cannot edit the target as another target with the same name exists. |
| 83:1670 | MySQL cluster backup is disabled. |
| 83:1671 | MySQL cluster backup is enabled. |
| 83:1672 | System detected that the following nodes are overloaded in <String>. |
| 83:1673 | Blackout Window[<String>] added. |
| 83:1674 | Blackout Window[<String>] deleted. |
| 83:1675 | Blackout Window[<String>] modified. |
| 83:1676 | Catalog dump path Changed from [<String>] to [<String>] |
| 83:1677 | To view and access your downloads, click [<String>]. |
| 83:1678 | The system detected an anomaly in the audit pattern of <String>. |
| 83:1679 | Recovery group(s) [<String>] is/are using this cleanroom target. Please delete the recovery group(s) before deleting this target |
| 83:1680 | User does not have [<String>] capability at hypervisor level to delete recovery target |
Alert Messages
| Code | Description |
| 74:1 | <SUBJECT END> |
| 74:2 | <SUBJECT BEGIN> |
| 74:3 | <COMMCELL ID> |
| 74:4 | <COMMCELL NAME> |
| 74:5 | <CATEGORY> |
| 74:6 | <ALERT CATEGORY - ALERT TYPE> |
| 74:7 | <TIME> |
| 74:8 | <UTC_TIME> |
| 74:9 | <OWNER LOGIN> |
| 74:10 | <OWNER NAME> |
| 74:11 | <OWNER EMAIL> |
| 74:12 | <ALERT ID> |
| 74:13 | <ALERT NAME> |
| 74:14 | <DETECTED CRITERIA> |
| 74:15 | <NOTIFICATION TRIGGER> |
| 74:16 | <ACTUAL THRESHOLD> |
| 74:17 | <ACTUAL TIME> |
| 74:18 | <CRITERIA THRESHOLD> |
| 74:19 | <CRITERIA TYPE> |
| 74:20 | <UNIT> |
| 74:21 | <IF PERCENT> |
| 74:22 | <IS ESCALATED?> |
| 74:23 | <STATUS> |
| 74:24 | <MEDIAAGENT LIST> |
| 74:25 | <LIBRARY LIST> |
| 74:26 | <DRIVE LIST> |
| 74:27 | <CLIENT LIST> |
| 74:28 | <SUB-CLIENT LIST> |
| 74:29 | <COMMCELL LIST> |
| 74:30 | <JOB LIST> |
| 74:31 | <DB_DETAIL> |
| 74:32 | <ATTACHMENT> |
| 74:33 | <DESCRIPTION> |
| 74:34 | <BIG DATA> |
| 74:35 | <JOB ID> |
| 74:36 | <START TIME> |
| 74:37 | <END TIME> |
| 74:38 | <SCHEDULE TIME> |
| 74:39 | <FAILURE REASON> |
| 74:40 | <SP NAME> |
| 74:41 | <COPY NAME> |
| 74:42 | <CLIENT NAME> |
| 74:43 | <AGENT TYPE NAME> |
| 74:44 | <INSTANCE NAME> |
| 74:45 | <BACKUPSET NAME> |
| 74:46 | <SUBCLIENT NAME> |
| 74:47 | <LEVEL> |
| 74:48 | <PROTECTED COUNT> |
| 74:49 | <FAILED COUNT> |
| 74:50 | <RECOVERED COUNT> |
| 74:51 | <SKIPPED COUNT> |
| 74:52 | <PROTECTED OBJECTS> |
| 74:53 | <FAILED OBJECTS> |
| 74:54 | <RECOVERED OBJECTS> |
| 74:55 | <SKIPPED OBJECTS> |
| 74:56 | <MEDIA LABEL> |
| 74:57 | <LIBRARY NAME> |
| 74:58 | <CONTAINER> |
| 74:59 | <EXPORT LOCATION> |
| 74:60 | <MEDIA LIST> |
| 74:61 | <MEDIA SUCCEEDED> |
| 74:62 | <MEDIA FAILED> |
| 74:63 | <COMMENT> |
| 74:64 | <DISC SPACE LOW Y/N> |
| 74:65 | <FREE SPACE> |
| 74:66 | <FORCE DECONFIG Y/N> |
| 74:67 | <HOLIDAY CHANGES Y/N> |
| 74:68 | <MEDIAAGENT NAME> |
| 74:69 | <SCHEDULE/SCHEDULE POLICY NAME> |
| 74:70 | <SPAREPOOL/MOUNTPATH NAME> |
| 74:71 | <MEDIA SPACE LEFT> |
| 74:72 | <THRESHOLD> |
| 74:73 | <OTHER LIBRARY> |
| 74:74 | <DRIVEPOOL NAME> |
| 74:75 | <DRIVE NAME> |
| 74:76 | <INITIATER> |
| 74:77 | <SOURCE LOCATION> |
| 74:78 | <TRANSIT LOCATION> |
| 74:79 | <SP LIST> |
| 74:80 | <DESTINATION LOCATION> |
| 74:81 | <BARCODE CURRENT LOCATION> |
| 74:82 | Job Management |
| 74:83 | Configuration |
| 74:84 | Media Management |
| 74:85 | Software Updates |
| 74:86 | Library Operations |
| 74:87 | Data Aging |
| 74:88 | Auxiliary Copy |
| 74:89 | Data Protection |
| 74:90 | Data Recovery |
| 74:91 | Disaster Recovery Backup |
| 74:92 | Data Verification |
| 74:93 | Media Inventory |
| 74:94 | Scheduled Export |
| 74:95 | Media Erase |
| 74:96 | Clients |
| 74:97 | Agents |
| 74:98 | CommCell |
| 74:99 | MediaAgents |
| 74:100 | Schedules |
| 74:101 | Storage Policy |
| 74:102 | Library |
| 74:103 | Library Management |
| 74:104 | VaultTracker |
| 74:105 | Download Software |
| 74:106 | Install Updates |
| 74:107 | Erase Data |
| 74:108 | Job Succeeded |
| 74:109 | Job Failed |
| 74:110 | Job Skipped |
| 74:111 | Delayed by <2,5,1,1,-1> Hrs |
| 74:112 | List Media |
| 74:113 | Job Initiated |
| 74:114 | Rolled Back |
| 74:115 | Media Needs Import |
| 74:116 | Media Handling Required |
| 74:117 | Media Picked up |
| 74:118 | Media Reached Destination |
| 74:119 | Media Returned to Source |
| 74:120 | Job Activity |
| 74:121 | ASR Backup Occurred |
| 74:122 | Properties Modified |
| 74:123 | Alert Modified |
| 74:124 | Disk Space Low |
| 74:125 | Force Deconfigured |
| 74:126 | Library went Offline |
| 74:127 | Scheduler Changes |
| 74:128 | Insufficient Storage |
| 74:129 | Media Handling Errors |
| 74:130 | Media Handling Required |
| 74:131 | Media Mount and Usage Errors |
| 74:132 | Maintenance Required |
| 74:133 | Maintenance Occurred |
| 74:134 | User Overwrite of Media |
| 74:135 | Alert every <1,3,2,1,-1> attempts (Phase failures) |
| 74:136 | Drive went Offline |
| 74:137 | MediaAgent went Offline |
| 74:138 | Mount Path went Offline |
| 74:139 | Alert every <1,3,2,1,-1> attempts (Network failures) |
| 74:140 | XML message initialization failed |
| 74:141 | Failed to create alert |
| 74:142 | XML message unserialization failed |
| 74:143 | Alert notification not found |
| 74:144 | |
| 74:145 | |
| 74:146 | All |
| 74:147 | CommServe |
| 74:148 | Clients |
| 74:149 | Libraries |
| 74:150 | MediaAgents |
| 74:151 | Users |
| 74:152 | User Groups |
| 74:153 | Storage Policies |
| 74:154 | All Actions |
| 74:155 | Tracking policies |
| 74:156 | VaultTracker Via Jobs |
| 74:157 | Data protection |
| 74:158 | Auxiliary Copy |
| 74:159 | Alert with same name already exist |
| 74:160 | Successfully created the alert |
| 74:161 | Device Status |
| 74:162 | <MEDIA REQUIRED Y/N> |
| 74:163 | <FORCED DECONFIGURED Y/N> |
| 74:164 | <DISK SPACE LOW Y/N> |
| 74:165 | Not Applicable |
| 74:166 | See attachment |
| 74:167 | <PROPERTY MODIFIED Y/N> |
| 74:168 | <MOUNTPATH NAME> |
| 74:169 | Successfully deleted the alert |
| 74:170 | Failed to delete the alert |
| 74:171 | Successfully modified the alert |
| 74:172 | Failed to modify the alert |
| 74:173 | User does not have required [Alert Management] capability for this CommCell and this operation. |
| 74:174 | Error controlling alert system for CommCell. |
| 74:175 | <SUCCESSFUL CLIENT LIST> |
| 74:176 | <FAILED CLIENT LIST> |
| 74:177 | <UNKNOWN CLIENT LIST> |
| 74:178 | <UP-TO-DATE CLIENT LIST> |
| 74:179 | <ALL CLIENT LIST> |
| 74:180 | <MEDIA REQUIRE LIST> |
| 74:181 | <MEDIA LOCATION LIST> |
| 74:182 | <CONDITION CLEARED Y/N> |
| 74:183 | <USER NAME> |
| 74:184 | <AGENT TYPE ID> |
| 74:185 | <RESOURCE WAIT TIME> |
| 74:186 | Application Management |
| 74:187 | Exchange |
| 74:188 | Update Availability |
| 74:189 | Journal Mailbox Threshold Exceeded |
| 74:190 | Low Space Condition |
| 74:191 | Index Cache Folder Space Low |
| 74:192 | Feature Release Required |
| 74:193 | Release Upgrade Required |
| 74:194 | Updates Available to Download |
| 74:195 | <MESSAGE COUNT> |
| 74:196 | <SPACE THRESHOLD> |
| 74:197 | <MAILBOX NAME> |
| 74:198 | <ELAPSED TIME> |
| 74:199 | <CONTENTS> |
| 74:200 | <CONTENTS DOWNLOADED> |
| 74:201 | <TOTAL FILES AVAILABLE> |
| 74:202 | <FILES DOWNLOADED> |
| 74:203 | <DOWNLOAD SIZE (MB)> |
| 74:204 | <HIGHEST FEATURE RELEASE> |
| 74:205 | <CLIENT STATUS LIST> |
| 74:206 | <JOBS RUNNING CLIENT LIST> |
| 74:207 | <LOW CACHE CLIENT LIST> |
| 74:208 | <UNREACHABLE CLIENT LIST> |
| 74:209 | <SERVER RELEASE> |
| 74:210 | <CLIENT RELEASE LIST> |
| 74:211 | Escalated |
| 74:212 | Alert: |
| 74:213 | Type: |
| 74:214 | Detected Criteria: |
| 74:215 | Detected Time: |
| 74:216 | User: |
| 74:217 | Job ID: |
| 74:218 | Status: |
| 74:219 | Start Time: |
| 74:220 | Scheduled Time: |
| 74:221 | End Time: |
| 74:222 | Failure Reason: |
| 74:223 | Storage Policy Name: |
| 74:224 | Copy Name: |
| 74:225 | Client: |
| 74:226 | Agent Type: |
| 74:227 | Instance: |
| 74:228 | Backup Set: |
| 74:229 | Subclient: |
| 74:230 | Backup Level: |
| 74:231 | Failed Counts: |
| 74:232 | Protected Counts: |
| 74:233 | Skipped Counts: |
| 74:234 | Recovered Counts: |
| 74:235 | Level: |
| 74:236 | Media List: |
| 74:237 | Succeeded Media: |
| 74:238 | Failed Media: |
| 74:239 | Comments: |
| 74:240 | Property/Alert Modifications: |
| 74:241 | Disk Space Low: |
| 74:242 | Free Space Available: |
| 74:243 | Force Deconfigured: |
| 74:244 | MediaAgent Name: |
| 74:245 | Condition Cleared: |
| 74:246 | Schedule Details: |
| 74:247 | Schedule/Schedule Policy Name: |
| 74:248 | Holiday Changes: |
| 74:249 | Library Name: |
| 74:250 | SparePool/Mount Path: |
| 74:251 | Drivepool: |
| 74:252 | Drive: |
| 74:253 | Media label: |
| 74:254 | Media/Space left: |
| 74:255 | Other library: |
| 74:256 | Mount Path: |
| 74:257 | Initiator: |
| 74:258 | Storage Policy List: |
| 74:259 | Source location: |
| 74:260 | Transit location: |
| 74:261 | Destination location: |
| 74:262 | All Client List: |
| 74:263 | Succeeded Client List: |
| 74:264 | Failed Client List: |
| 74:265 | Unknown Status Client List: |
| 74:266 | UP-TO-DATE Client List: |
| 74:267 | Mailbox Name: |
| 74:268 | Message Count: |
| 74:269 | Property Modifications: |
| 74:270 | Folder: [<String>], threshold: [<Number>] , free space:[<Number>] . |
| 74:271 | <DISK SPACE INFO> |
| 74:272 | Media Ready in Mail Slot |
| 74:273 | Log file reached high watermark |
| 74:274 | Log file volume reached low watermark |
| 74:275 | No log play activity |
| 74:276 | No transfer activity |
| 74:277 | ContinuousDataReplicator |
| 74:278 | <LOG FILE NAME> |
| 74:279 | <LAST ACTIVITY TIME> |
| 74:280 | Actual Value: |
| 74:281 | Configured Value: |
| 74:282 | <MORE MEDIA Y/N> |
| 74:283 | <LOG FILE SIZE> |
| 74:284 | <VOLUME NAME> |
| 74:285 | Machines |
| 74:286 | No Data Protection |
| 74:287 | <RD JOB Y/N> |
| 74:288 | <SNAPSHOT VOLUME UNIT> |
| 74:289 | <WORKFLOW> |
| 74:290 | Download Size (MB): |
| 74:291 | Files Downloaded: |
| 74:292 | Contents: |
| 74:293 | More Media to Export: |
| 74:294 | Media List in the Mail Slots: |
| 74:295 | Clients Requiring Update: |
| 74:296 | Clients Requiring Upgrade: |
| 74:297 | Version Mismatch |
| 74:298 | Threshold: |
| 74:299 | Volume Name: |
| 74:300 | NO ACTION |
| 74:301 | Succeeded |
| 74:302 | Completed w/ one or more errors |
| 74:303 | Failed |
| 74:304 | Failed to Start |
| 74:305 | Enabled/Disabled |
| 74:306 | Properties Modified |
| 74:307 | Security Modified |
| 74:308 | Modified |
| 74:309 | Deleted |
| 74:310 | Added |
| 74:311 | Alert Modified |
| 74:312 | Unauthorized Attempt to modify Alerted Users |
| 74:313 | Backup Set(s) Pruned |
| 74:314 | Switched Online/Offline |
| 74:315 | Mount Error |
| 74:316 | Unmount Error |
| 74:317 | Killed by User |
| 74:318 | Resumed by User |
| 74:319 | Suspended by User |
| 74:320 | Job Interrupted |
| 74:321 | Job Restarted |
| 74:322 | Job Aborted |
| 74:323 | No Spare Media |
| 74:324 | Media is not in Library |
| 74:325 | Data Protection activity Enabled/Disabled |
| 74:326 | Data Recovery activity Enabled/Disabled |
| 74:327 | Unauthorized Attempt to alter properties |
| 74:328 | Duplicate Barcode/Label |
| 74:329 | Below Low Media Threshold |
| 74:330 | Skipped Scheduled Jobs |
| 74:331 | Scheduled Job Ran |
| 74:332 | Failed to Schedule Job |
| 74:333 | CommCell Database Disk Space Low |
| 74:334 | New Content Added |
| 74:335 | Holidays Modified |
| 74:336 | Skipped due to Holiday |
| 74:337 | Disk Library Out of Space |
| 74:338 | Forced De-configure |
| 74:339 | Threshold Exceeded |
| 74:340 | No Storage Policy Defined |
| 74:341 | ASR Backup Successful |
| 74:342 | Media from different Library |
| 74:343 | Media Marked Read Only/Bad/Deprecated |
| 74:344 | Drive Requires Cleaning |
| 74:345 | Media Inventory Job Succeeded |
| 74:346 | Media Inventory Job Failed |
| 74:347 | Media Inventory Job Failed to Start |
| 74:348 | Media Inventory Job Killed by User |
| 74:349 | Scheduled Export Job Succeeded/Partially Succeeded |
| 74:350 | Scheduled Export Job Failed |
| 74:351 | Scheduled Export Job Failed to Start |
| 74:352 | Scheduled Export Job Killed by User |
| 74:353 | Media in drive needs changing |
| 74:354 | Media Required |
| 74:355 | Drive Cleaning Succeeded |
| 74:356 | Drive Cleaning Failed |
| 74:357 | Schedule Export Starts |
| 74:358 | Library Switched Online/Offline |
| 74:359 | Drive Switched Online/Offline |
| 74:360 | Mount Path Switched Online/Offline |
| 74:361 | CommCell Disk Space Low |
| 74:362 | Pending Media Movement is Created |
| 74:363 | Pending Media Movement Completed Successfully |
| 74:364 | Pending Media Movement Failed/Aborted |
| 74:365 | Media Needs Import |
| 74:366 | Media is Exported |
| 74:367 | Media is Moved to Virtual Mail Slots |
| 74:368 | Media is Picked Up |
| 74:369 | Media has Reached Destination |
| 74:370 | Media is Returned to Source |
| 74:371 | Media Movement is Rolled Back |
| 74:372 | Initiated |
| 74:373 | Overwrite Media Option Selected |
| 74:374 | Media Overwritten (User Selected) |
| 74:375 | Data Classification |
| 74:376 | Alert |
| 74:377 | CommCell: <String> |
| 74:378 | Client:tt<String> |
| 74:379 | Backup set:t<String> |
| 74:380 | Subclient:t<String> |
| 74:381 | Application:t<String> |
| 74:382 | Instance:tt<String> |
| 74:383 | MediaAgent:t<String> |
| 74:384 | Storage Policy:t<String> |
| 74:385 | Library:tt<String> |
| 74:386 | User:tt<String> |
| 74:387 | Description:t<String> |
| 74:388 | CommCell: |
| 74:389 | Classification Failed |
| 74:390 | Disk Space Low |
| 74:391 | Inactive Pair Detect |
| 74:392 | <FLR_SRC_PATH> |
| 74:393 | <FLR_DEST_PATH> |
| 74:394 | <DEST CLIENT> |
| 74:395 | <REPSET NAME> |
| 74:396 | <OPERATION TYPE> |
| 74:397 | Continuous Data Replication |
| 74:398 | Operation Type: |
| 74:399 | Replication Set: |
| 74:400 | Source Directory: |
| 74:401 | Destination Directory: |
| 74:402 | Destination Client: |
| 74:403 | <BACKUP SIZE (Compressed)> |
| 74:404 | <BACKUP SIZE (Uncompressed)> |
| 74:405 | Failed Replication |
| 74:406 | Disk Space Available: |
| 74:407 | Offline Content Indexing |
| 74:408 | <CS UPGR TIME> |
| 74:409 | <XFER BYTES> |
| 74:410 | <XFER SECS> |
| 74:411 | <XFER GB PER HOUR> |
| 74:412 | <ERR CODE> |
| 74:413 | Error Code: |
| 74:414 | SharePoint |
| 74:415 | New Virtual Servers Found. Restart IIS. |
| 74:416 | Sharepoint Version Upgraded. Restart IIS. |
| 74:417 | Server groups |
| 74:418 | Media Recalled |
| 74:419 | <RECALL REASON> |
| 74:420 | <RECALL EXPIRE TIME> |
| 74:421 | <RECALL DESTINATION> |
| 74:422 | Recall Reason: |
| 74:423 | Recall Expiration Time: |
| 74:424 | Recall Destination: |
| 74:425 | Deprecated message. |
| 74:426 | Windows File System |
| 74:427 | Unix File System |
| 74:428 | Oracle |
| 74:429 | SQL Server |
| 74:430 | NAS |
| 74:431 | Exchange |
| 74:432 | SharePoint |
| 74:433 | NetWare |
| 74:434 | Cost Analysis |
| 74:435 | Snap to Tape |
| 74:436 | Send Report |
| 74:437 | <Report ID> |
| 74:438 | <Report Hist ID> |
| 74:439 | <Report URL> |
| 74:440 | Report ID: |
| 74:441 | Report Location: |
| 74:442 | Increase in Data size by <1,2,10,1,-1> percent |
| 74:443 | Decrease in Data size by <1,2,10,1,-1> percent |
| 74:444 | <CURRENT BACKUP SIZE> |
| 74:445 | Current Backup Size: |
| 74:446 | <PREVIOUS BACKUP SIZE> |
| 74:447 | Previous Backup Size: |
| 74:448 | <PREVIOUS JOBID> |
| 74:449 | Previous Job ID: |
| 74:450 | <PERCENTAGE CHANGE> |
| 74:451 | Percentage Change: |
| 74:452 | <PRUNED MEDIA BARCODE LIST> |
| 74:453 | Pruned Media Barcode List: |
| 74:454 | <PRUNED JOBS COUNT> |
| 74:455 | Pruned Jobs Count: |
| 74:456 | Job Started |
| 74:457 | <RESTORE USER NAME> |
| 74:458 | <NUMBER OF ITEMS> |
| 74:459 | <SIZE> |
| 74:460 | Alert every <1,3,3,1,-1> failed login attempts |
| 74:461 | Failed Login Attempts Count: |
| 74:462 | <FAILED ATTEMPTS COUNT> |
| 74:463 | GUI Client Name: |
| 74:464 | <GUI Client Name> |
| 74:465 | User Names List: |
| 74:466 | <USER NAME LIST> |
| 74:467 | Failed Login Attempts Time List: |
| 74:468 | <FAILED ATTEMPT TIME LIST> |
| 74:469 | Clients Requiring Update/Upgrade: |
| 74:470 | Storage Policies Used: |
| 74:471 | Job Type: |
| 74:472 | <STORAGE POLICIES USED> |
| 74:473 | Deprecated message. |
| 74:474 | Deprecated message |
| 74:475 | <Source RDN> |
| 74:476 | <Msg Parameters> |
| 74:477 | Failure of Exchange Server clustered resources |
| 74:478 | Disk space limited for Exchange Server |
| 74:479 | Excessive CPU utilization of Exchange Server |
| 74:480 | Failing monitoring services of Exchange Server |
| 74:481 | Low memory for Exchange Server |
| 74:482 | Windows Automatic Updates are disabled |
| 74:483 | Anti-virus software might not be installed |
| 74:484 | Disk is not used |
| 74:485 | Group exceeded storage space hard limit |
| 74:486 | Group exceeded storage space soft limit |
| 74:487 | File system quotas not enabled. |
| 74:488 | Software Firewall might not be installed |
| 74:489 | User exceeded storage space hard limit |
| 74:490 | User exceeded storage space soft limit |
| 74:491 | Volume is full |
| 74:492 | NAS aggregate is full |
| 74:493 | NAS aggregate is overcommitted |
| 74:494 | NAS aggregate is unavailable |
| 74:495 | NAS Celerra automatic extension is disabled for Storage Pool |
| 74:496 | NAS Celerra CIFS share: CIFS server is unavailable |
| 74:497 | NAS Celerra CIFS share: Data Mover is unavailable |
| 74:498 | NAS Celerra CIFS share: Storage Pool is full |
| 74:499 | NAS Celerra Data Mover is not available |
| 74:500 | NAS storage quota for group exceeded Celerra maximum limit |
| 74:501 | NAS Celerra checkpoint name has invalid extension |
| 74:502 | NAS Celerra maximum number of nested mount points under NMFS root |
| 74:503 | NAS Celerra NFS Share: Data Mover is unavailable |
| 74:504 | NAS Celerra NFS Share: Storage Pool is full |
| 74:505 | NAS Celerra disk volumes cannot be added to Storage Pool |
| 74:506 | NAS Celerra is not reachable |
| 74:507 | NAS Celerra primary Data Mover has no standby |
| 74:508 | NAS storage quota on quota tree exceeded Celerra maximum limit |
| 74:509 | NAS Celerra Storage Pool is overcommitted |
| 74:510 | NAS Celerra Storage Pool is full |
| 74:511 | NAS Celerra Meta Volume has no client volume or file system |
| 74:512 | NAS Celerra slice volume is not in Storage Pool/Meta Volume |
| 74:513 | NAS Celerra stripe volume is not in Storage Pool/Meta Volume |
| 74:514 | NAS storage quota for user exceeded Celerra maximum limit |
| 74:515 | NAS Celerra VDM is not replicated |
| 74:516 | NAS Celerra quota policy is wrong for CIFS |
| 74:517 | NAS CIFS share: file system is unavailable |
| 74:518 | NAS CIFS share: file system is full |
| 74:519 | NAS file system hosting iSCSI LUNs is exported via CIFS share |
| 74:520 | NAS CIFS share: logical volume is full |
| 74:521 | NAS CIFS share: logical volume is unavailable |
| 74:522 | NAS filer is not reachable |
| 74:523 | NAS file system is full |
| 74:524 | NAS file system is mounted but not shared |
| 74:525 | NAS logical volume is full |
| 74:526 | NAS logical volume is unavailable |
| 74:527 | NAS file system is not mounted |
| 74:528 | NAS file system hosting iSCSI LUNs is exported via NFS share |
| 74:529 | NAS NFS Share: file system is full |
| 74:530 | NAS NFS share: logical volume is full |
| 74:531 | NAS NFS share: logical volume is unavailable |
| 74:532 | NAS vFiler is not available |
| 74:533 | Pool is full |
| 74:534 | User is close to storage space quota |
| 74:535 | Database has dictionary managed tablespaces |
| 74:536 | Database has guessable passwords |
| 74:537 | Database has no SPFILE. |
| 74:538 | Database public has execute privileges |
| 74:539 | Database public account has system privileges |
| 74:540 | Database has too few control files |
| 74:541 | Database has users with unlimited login attempts |
| 74:542 | Instance has average waits that are too long |
| 74:543 | Instance does not have archive log mode |
| 74:544 | Instance does not have ASSM. |
| 74:545 | Instance does not have auto undo |
| 74:546 | Instance does not have enough redo space |
| 74:547 | Segment has too many extents |
| 74:548 | System tablespace has rollback |
| 74:549 | Table has many chained rows |
| 74:550 | Tablespace has both rollback and data |
| 74:551 | Tablespace has little free space |
| 74:552 | Tablespace has unlimited extension |
| 74:553 | System tablespace has user data |
| 74:554 | Table has too many indexes |
| 74:555 | User has the system tablespace as default |
| 74:556 | User has a temporary tablespace as permanent |
| 74:557 | Content Database site warning. |
| 74:558 | The current server configuration is invalid. |
| 74:559 | Site Collection has no usage quota assigned. |
| 74:560 | Site Collection quota size exceeded. |
| 74:561 | Site Database is not online. |
| 74:562 | Usage Analysis Processing is not enabled. |
| 74:563 | Usage Logging is not enabled. |
| 74:564 | Virtual Server has RecycleBinCleanUp Disabled. |
| 74:565 | Virtual Server has RecycleBin Disabled. |
| 74:566 | Autoclose is enabled |
| 74:567 | Auto create statistics is disabled |
| 74:568 | Autoshrink is enabled |
| 74:569 | Auto update statistics is disabled |
| 74:570 | Database in single user mode |
| 74:571 | Database log not backed up |
| 74:572 | Database not backed up |
| 74:573 | Extent scan fragmentation for Index exceeds limit |
| 74:574 | Logical scan fragmentation for Index exceeds limit |
| 74:575 | Simple recovery mode of production database |
| 74:576 | Torn pages detected |
| 74:577 | Group exceeded block hard limit quota |
| 74:578 | Group exceeded block soft limit quota |
| 74:579 | Group exceeded file count hard limit quota |
| 74:580 | Group exceeded file count soft limit quota |
| 74:581 | Logical Volume is almost full |
| 74:582 | Logical Volume offline |
| 74:583 | Partition is almost full |
| 74:584 | Unused disk space |
| 74:585 | User exceeded block hard limit quota |
| 74:586 | User exceeded block soft limit quota |
| 74:587 | User exceeded file count hard limit quota |
| 74:588 | User exceeded file count soft limit quota |
| 74:589 | Volume Group offline |
| 74:590 | Cluster failure of [{0}] on [{1}]. Administer cluster. |
| 74:591 | Insufficient disk space for [{0}] on [{1}]. Free up unused disk space or add disk storage. |
| 74:592 | Excessive CPU Utilization for [{0}] on [{1}]. Terminate unneeded applications or upgrade system. |
| 74:593 | Monitoring services of [{0}] Exchange Server are failing. Administer Exchange Server. |
| 74:594 | Low memory for [{0}] on [{1}]. Terminate unneeded applications or extend memory. |
| 74:595 | Windows Automatic Updates are disabled. |
| 74:596 | Anti-virus software might not be installed. |
| 74:597 | Part of disk space ({0}%) of disk [{1}] is not allocated to partitions. Use Volume Manager to allocate remaining space to existing or new partitions. |
| 74:598 | Group [{0}] exceeded storage space hard limit [{1}] on file system [{2}]. |
| 74:599 | Group [{0}] exceeded storage space soft limit [{1}] on file system [{2}]. |
| 74:600 | Quotas are not enabled on file system [{0}]. |
| 74:601 | Software Firewall might not be installed. |
| 74:602 | User [{0}] exceeded storage space hard limit [{1}] on file system [{2}]. |
| 74:603 | User [{0}] exceeded storage space soft limit [{1}] on file system [{2}]. |
| 74:604 | Volume [{0}] is {1}% full. Use Volume Manager to allocate additional storage. |
| 74:605 | Aggregate volume [{0}] on filer [{1}] is {2}% full. |
| 74:606 | Aggregate volume [{0}] on filer [{1}] is overcommitted. |
| 74:607 | Aggregate volume [{0}] on filer [{1}] is unavailable. |
| 74:608 | Automatic extension is disabled for system defined Storage Pool [{0}] of Celerra [{1}]. |
| 74:609 | CIFS server [{0}] of CIFS share [{1}] on Celerra [{2}] is unavailable. |
| 74:610 | Data Mover [{0}] of CIFS share [{1}] on Celerra [{2}] is unavailable. |
| 74:611 | Storage Pool [{0}] of CIFS share [{1}] on Celerra [{2}] is {3}% full. |
| 74:612 | Data Mover [{0}] of Celerra [{1}] is not available. |
| 74:613 | Storage quota on group [{0}] in file system [{1}] on Celerra [{2}] exceeded {3} TB. Set quota limit to a lower value. |
| 74:614 | Checkpoint [{0}] of file system [{1}] on Celerra [{2}] has invalid extension [{3}]. Rename the checkpoint. |
| 74:615 | Created maximum number of nested mount points under root directory [{0}] of NMFS file system [{1}] on Celerra [{2}]. |
| 74:616 | Data Mover [{0}] of NFS share [{1}] on Celerra [{2}] is unavailable. |
| 74:617 | Storage Pool [{0}] of NFS share [{1}] on Celerra [{2}] is {3}% full. |
| 74:618 | No more disk volumes are available for system defined Storage Pool [{0}] of Celerra [{1}]. |
| 74:619 | Celerra [{0}] is not reachable. |
| 74:620 | Primary Data Mover [{0}] of Celerra [{1}] has no standby. |
| 74:621 | Storage quota on quota tree [{0}] in file system [{1}] on Celerra [{2}] exceeded {3} TB. Set quota limit to a lower value. |
| 74:622 | Storage Pool [{0}] on Celerra [{1}] is overcommitted. |
| 74:623 | Storage Pool [{0}] of Celerra [{1}] is {2}% full. |
| 74:624 | Meta Volume [{0}] of Celerra [{1}] has no client volume or file system. |
| 74:625 | Slice volume [{0}] of Celerra [{1}] does not belong to any Storage Pool or Meta Volume. |
| 74:626 | Stripe volume [{0}] of Celerra [{1}] does not belong to any Storage Pool or Meta Volume. |
| 74:627 | Storage quota on user [{0}] in file system [{1}] on Celerra [{2}] exceeded {3} TB. Set quota limit to a lower value. |
| 74:628 | VDM [{0}] of Celerra [{1}] is not involved in replication. |
| 74:629 | File system [{0}] on Celerra [{1}] uses wrong quota policy [{2}]. Use filesize quota policy for CIFS environment. |
| 74:630 | File system [{0}] of CIFS share [{1}] on file server [{2}] is unavailable. |
| 74:631 | File system [{0}] of CIFS share [{1}] on Celerra [{2}] is {3}% full. |
| 74:632 | File system [{0}] on Celerra [{1}] hosting iSCSI LUNs is exported through CIFS share [{2}]. A file system with iSCSI LUNs should be dedicated to iSCSI and not used for other purposes. |
| 74:633 | Logical volume [{0}] of CIFS share [{1}] on filer [{2}] is {3}% full. |
| 74:634 | Logical volume [{0}] of CIFS share [{1}] on filer [{2}] is unavailable. |
| 74:635 | Filer [{0}] is not reachable. |
| 74:636 | File system [{0}] of file server [{1}] is {2}% full. |
| 74:637 | Mounted file system [{0}] of file server [{1}] is not shared. |
| 74:638 | Logical volume [{0}] on filer [{1}] is {2}% full. |
| 74:639 | Logical volume [{0}] on filer [{1}] is unavailable. Use administrative tool to bring volume online. |
| 74:640 | File system [{0}] on file server [{1}] is not mounted. |
| 74:641 | File system [{0}] on Celerra [{1}] hosting iSCSI LUNs is exported through NFS share [{2}]. A file system with iSCSI LUNs should be dedicated to iSCSI and not used for other purposes. |
| 74:642 | File system [{0}] of NFS share [{1}] on Celerra [{2}] is {3}% full. |
| 74:643 | Logical volume [{0}] of NFS share [{1}] on filer [{2}] is {3}% full. |
| 74:644 | Logical volume [{0}] of NFS share [{1}] on filer [{2}] is unavailable. |
| 74:645 | vFiler [{0}] of filer [{1}] is not available. |
| 74:646 | The pool [{0}] on server [{1}] is {2}% full. |
| 74:647 | The user [{0}] is using {1}% of the quota limit. |
| 74:648 | In database [{0}], there are Dictionary Managed Tablespaces (other than SYSTEM and SYSAUX). Locally Managed Tablespaces may be a better choice. |
| 74:649 | In database [{0}], the accounts [{1}] have default passwords. Please change the passwords. |
| 74:650 | Database [{0}] is not using an SPFILE. Using an SPFILE is an Oracle Configuration Best Practice. |
| 74:651 | In database [{0}], PUBLIC has been granted execute any privileges. Please remove this privilege. |
| 74:652 | In database [{0}], SYSTEM privileges have been granted to PUBLIC. Please disable these privileges. |
| 74:653 | In database [{0}], the number of control files should be increased from [{1}] to at least 3. |
| 74:654 | In database [{0}], the profiles [{1}] have unlimited login attempts. These should be eliminated. |
| 74:655 | In database [{0}], instance [{1}], average wait for event [{2}] is [{3}]. This will affect performance. Try to decrease it by shifting resources to a faster disk. |
| 74:656 | In database [{0}], consider using archive log mode to enable online backups and point in time recovery. |
| 74:657 | In database [{0}], consider using automatic segment space management. |
| 74:658 | In database [{0}], consider using automatic undo management. |
| 74:659 | In database [{0}], instance [{1}], REDO logs are less than 1 MB in size. Undersized log files increase checkpoint activity and reduce performance. Consider increasing the size of your REDO logs. |
| 74:660 | In database [{0}], tablespace [{1}] Segment [{2}] partition [{3}] has [{4}] extents. This can result in poor performance. Consider reconfiguring with a larger extent size. |
| 74:661 | In database [{0}], there are rollback segments in the SYSTEM tablespace. |
| 74:662 | In database [{0}], table [{1}] for user [{2}] has [{3}] chained rows. Consider reinserting the chained rows (General Management of Schema Objects) |
| 74:663 | In database [{0}], tablespace [{1}] contains both Rollback and Data Segments. |
| 74:664 | In database [{0}], tablespace [{1}] has < 10% free space remaining. |
| 74:665 | In database [{0}], tablespace [{1}] has at least one data file whose size is unlimited. |
| 74:666 | In database [{0}], data segments owned by [{1}] are in tablespaces SYSTEM or SYSAUX. |
| 74:667 | In database [{0}], table [{1}] for user [{2}] has [{3}] indexes for only [{4}] segments. This results in slow performance for inserts and changes. Consider removing some indexes. |
| 74:668 | In database [{0}], user [{1}] is using a system tablespace as the default tablespace. |
| 74:669 | In database [{0}], user [{1}] is using a temporary tablespace as a permanent tablespace. |
| 74:670 | Content Database [{0}] has [{1}] sites; warning level is [{2}] and maximum level is [{3}] sites. |
| 74:671 | The current server configuration is invalid for Farm [{0}]. |
| 74:672 | No Usage Quota applied to Site Collection [{0}]. Quota assignment is recommended to flag excess usage. |
| 74:673 | Quota Size for Site Collection [{0}] exceeded: Usage:[{1}]; Warning:[{2}]; Maximum:[{3}] Bytes. |
| 74:674 | Site Database [{0}] of Virtual Server [{1}] not online. |
| 74:675 | Usage Analysis Processing is not enabled on the Farm [{0}]. |
| 74:676 | Usage Logging is not enabled on the Farm [{0}]. |
| 74:677 | Virtual Server [{0}] on server [{1}] has RecycleBinCleanUp Disabled. |
| 74:678 | Virtual Server [{0}] on server [{1}] has RecycleBin Disabled. |
| 74:679 | Autoclose is enabled for database [{0}] of SQL Instance [{1}]; This may impact performance. |
| 74:680 | Auto create statistics is disabled for database [{0}] of SQL Instance [{1}]; This may adversely impact query performance. |
| 74:681 | Autoshrink is enabled for database [{0}] of SQL Instance [{1}]; This may impact performance. |
| 74:682 | Auto update statistics is disabled for database [{0}] of SQL Instance [{1}]; This may adversely impact query performance. |
| 74:683 | Database [{0}] of SQL Instance [{1}] is in single user mode. |
| 74:684 | Log of database [{0}] of SQL Instance [{1}] has not been backed up in the last {2} day(s). |
| 74:685 | Database [{0}] of SQL Instance [{1}] has not been backed up in the last [{2}] day(s). |
| 74:686 | Extent scan fragmentation for index [{0}] of database [{1}] table [{2}] of SQL Instance [{3}] exceeds {4}%; recommend rebuilding the index. |
| 74:687 | Logical scan fragmentation for index [{0}] of database [{1}] table [{2}] of SQL Instance [{3}] exceeds {4}%; recommend rebuilding the index. |
| 74:688 | SIMPLE recovery model is not recommended for production database [{0}] of SQL Instance [{1}]. |
| 74:689 | Torn pages were detected for database [{0}] of SQL Instance [{1}]; SQL data integrity may be compromised. Recommend restoring from the backups. |
| 74:690 | Group {0} exceeded block hard limit quota {1} on file system {2}. |
| 74:691 | Group {0} exceeded block soft limit quota {1} on file system {2}. |
| 74:692 | Group {0} exceeded file count hard limit quota {1} on file system {2}. |
| 74:693 | Group {0} exceeded file count soft limit quota {1} on file system {2}. |
| 74:694 | File System {0} on logical volume {1} of volume group {2} on hostname {3} is more than 90% full. |
| 74:695 | Logical Volume {0} of Volume Group {1} of hostname {2} is offline. |
| 74:696 | File System {0} on partition {1} of disk {2} of hostname {3} is more than 90% full. |
| 74:697 | {0}% of space of disk {1} of hostname {2} is not used. |
| 74:698 | User {0} exceeded block hard limit quota {1} on file system {2}. |
| 74:699 | User {0} exceeded block soft limit quota {1} on file system {2}. |
| 74:700 | User {0} exceeded file count hard limit quota {1} on file system {2}. |
| 74:701 | User {0} exceeded file count soft limit quota {1} on file system {2}. |
| 74:702 | Volume Group {0} of hostname {1} is offline. |
| 74:703 | Auxiliary Copy fallen behind alert |
| 74:704 | Size of Data to be Copied: |
| 74:705 | <SIZE OF DATA TOBE COPIED> |
| 74:706 | Number of Media to be Copied: |
| 74:707 | <MEDIA TOBE COPIED COUNT> |
| 74:708 | Number of Jobs to be Copied: |
| 74:709 | <JOBS TOBE COPIED> |
| 74:710 | Oldest Job End Date: |
| 74:711 | <OLDEST JOB ENDDATE> |
| 74:712 | Media that got copied: |
| 74:713 | <COPIED MEDIA LIST> |
| 74:714 | Copied data size: |
| 74:715 | <COPIED DATA SIZE> |
| 74:716 | Report |
| 74:717 | Report Name: |
| 74:718 | <REPORT NAME> |
| 74:719 | Started |
| 74:720 | Information Management |
| 74:721 | Automated Content Classification Policy Name: |
| 74:722 | <AUTOMATED_CONTENT_CLASSIFICATION_POLICY_NAME> |
| 74:723 | Phases in Job: |
| 74:724 | <PHASES_IN_JOB> |
| 74:725 | Tagging |
| 74:726 | ERM Connector |
| 74:727 | Restore to a Review Set |
| 74:728 | Legal Hold |
| 74:729 | Restore |
| 74:730 | Status of Search Phase: |
| 74:731 | <STATUS OF SEARCH PHASE> |
| 74:732 | Status of Tagging Phase: |
| 74:733 | <STATUS OF TAGGING PHASE> |
| 74:734 | Status of ERM Connector Phase: |
| 74:735 | <STATUS OF ERM CONNECTOR PHASE> |
| 74:736 | Status of Restore to a Review Set Phase: |
| 74:737 | <STATUS OF RESTORE TO REVIEW SET PHASE> |
| 74:738 | Status of Legal Hold Backup Phase: |
| 74:739 | <STATUS OF LEGAL HOLD BACKUP PHASE> |
| 74:740 | Status of Legal Hold Restore Phase: |
| 74:741 | <STATUS OF LEGAL HOLD RESTORE PHASE> |
| 74:742 | Search Phase Selected to Run: |
| 74:743 | <SEARCH PHASE SELETED Y/N> |
| 74:744 | Tagging Phase Selected to Run: |
| 74:745 | <TAGGING PHASE SELECTED Y/N> |
| 74:746 | ERM Connector Phase Selected to Run: |
| 74:747 | <ERM CONNECTOR PHASE SELECTED Y/N> |
| 74:748 | Restore to Review Set Phase Selected to Run: |
| 74:749 | <RESTORE TO REVIEW SET PHASE SELECTED Y/N> |
| 74:750 | Legal Hold Backup Phase Selected to Run: |
| 74:751 | <LEGAL HOLD BACKUP PHASE SELECTED Y/N> |
| 74:752 | Legal Hold Restore Phase Selected to Run: |
| 74:753 | <LEGAL HOLD RESTORE PHASE SELECTED Y/N> |
| 74:754 | Number of Items Selected for Tagging: |
| 74:755 | <NO. OF ITEMS SELECTED FOR TAGGING> |
| 74:756 | Number of Items Tagged Successfully: |
| 74:757 | <NO. OF ITEMS TAGGED SUCCESSFULLY> |
| 74:758 | Number of Items Failed to Tag: |
| 74:759 | <NO. OF ITEMS FAILED TO TAG> |
| 74:760 | Number of Items Selected for ERM Connector: |
| 74:761 | <NO. OF ITEMS SELECTED FOR ERM CONNECTOR> |
| 74:762 | Number of Items Succeeded in ERM Connector Phase: |
| 74:763 | <NO. OF ITEMS SUCCEEDED IN ERM CONNECTOR PHASE> |
| 74:764 | Number of Items Failed in ERM Connector Phase: |
| 74:765 | <NO. OF ITEMS FAILED IN ERM CONNECTOR PHASE> |
| 74:766 | Number of Items Selected to Restore to Review Set: |
| 74:767 | <NO. OF ITEMS SELECTED TO RESTORE TO REVIEW SET> |
| 74:768 | Number of Items Succeeded in Restore to Review Set Phase: |
| 74:769 | <NO. OF ITEMS SUCCEEDED IN RESTORE TO REVIEW SET PHASE> |
| 74:770 | Number of Items Failed in Restore to Review Set Phase: |
| 74:771 | <NO. OF ITEMS FAILED IN RESTORE TO REVIEW SET PHASE> |
| 74:772 | Number of Items Selected for Legal Hold Backup: |
| 74:773 | <NO. OF ITEMS SELECTED FOR LEGAL HOLD BACKUP> |
| 74:774 | Number of Items Succeeded in Legal Hold Backup Phase: |
| 74:775 | <NO. OF ITEMS SUCCEEDED IN LEGAL HOLD BACKUP PHASE> |
| 74:776 | Number of Items Failed In Legal Hold Backup Phase: |
| 74:777 | <NO. OF ITEMS FAILED IN LEGAL HOLD BACKUP PHASE> |
| 74:778 | Number of Items Selected for Legal Hold Restore: |
| 74:779 | <NO. OF ITEMS SELECTED FOR LEGAL HOLD RESTORE> |
| 74:780 | Number of Items Succeeded in Legal Hold Restore Phase: |
| 74:781 | <NO. OF ITEMS SUCCEEDED IN LEGAL HOLD RESTORE PHASE> |
| 74:782 | Number of Items Failed In Legal Hold Restore Phase: |
| 74:783 | <NO. OF ITEMS FAILED IN LEGAL HOLD RESTORE PHASE> |
| 74:784 | Number of Items Selected to Search: |
| 74:785 | <NO. OF ITEMS SELECTED TO SEARCH> |
| 74:786 | Number of Items Searched Successfully: |
| 74:787 | <NO. OF ITEMS SEARCHED SUCCESSFULLY> |
| 74:788 | Number of Items Failed to Search: |
| 74:789 | <NO. OF ITEMS FAILED TO SEARCH> |
| 74:790 | <Virtual Machine NAME> |
| 74:791 | Failed to create alert: <String> |
| 74:792 | Successfully created the alert: <String> |
| 74:793 | Job Succeeded with Errors |
| 74:794 | <String> GB |
| 74:795 | <String> Bytes |
| 74:796 | <String> KB |
| 74:797 | <String> MB |
| 74:798 | <String> TB |
| 74:799 | Deprecated message. |
| 74:800 | Deprecated message. |
| 74:801 | <XFER SIZE> |
| 74:802 | Exchange Mailbox Store dismounted |
| 74:803 | Exchange Public Folder Store dismounted |
| 74:804 | Exchange MailBox Store [{0}] is dismounted. |
| 74:805 | Exchange Public Folder Store [{0}] is dismounted. |
| 74:806 | Extended Retention Job |
| 74:807 | <EXTENDED RET. CANDIDATE Y/N> |
| 74:808 | <RETAIN UNTIL> |
| 74:809 | Alert CommServe License Expires Within <7,15,30,0,-1> Days |
| 74:810 | License Expired: |
| 74:811 | <LICENSE EXPIRED> |
| 74:812 | Number Of Days Left For License Expiration: |
| 74:813 | <NO. OF DAYS LEFT FOR LICENSE EXPIRY> |
| 74:814 | Overlapping Partitions Condition Exists |
| 74:815 | Partition {0} and partition {1} are overlapping. |
| 74:816 | Attachment File Location |
| 74:817 | <XFER TIME> |
| 74:818 | <Number> Hour(s), <Number> Minute(s), <Number> Second(s) |
| 74:819 | Media Refresh |
| 74:820 | Test Alert |
| 74:821 | Client Configuration Policy Modified |
| 74:822 | <Task ID> |
| 74:823 | Task ID: |
| 74:824 | <OBJ STORE CACHE> |
| 74:825 | DeDup DB Reconstruction |
| 74:826 | Report |
| 74:827 | Deprecated message. |
| 74:828 | Deprecated message. |
| 74:829 | Deprecated message. |
| 74:830 | Deprecated message. |
| 74:831 | Servers/Server groups: |
| 74:832 | Max Rows: |
| 74:833 | Adhoc Query: |
| 74:834 | Chart Report Options: |
| 74:835 | <CSV Output File> |
| 74:836 | <FileList> |
| 74:837 | Generated Time: |
| 74:838 | Alert when Licenses Consumed reaches <1,2,80,1,100> Percent |
| 74:839 | License Percent Consumed: |
| 74:840 | <LICENSE PERCENT CONSUMED> |
| 74:841 | No Backup for last <2,5,3,1,-1> Days |
| 74:842 | Last Successful Backup ran at |
| 74:843 | <TIME OF LAST SUCCESSFUL JOB> |
| 74:844 | <DATE OF LAST SUCCESSFUL JOB> |
| 74:845 | <NO SUCCESSFUL JOB SINCE> |
| 74:846 | [<Number>] month(s) |
| 74:847 | [<Number>] day(s) |
| 74:848 | Not backed up since: |
| 74:849 | Date of last recorded backup: |
| 74:850 | Time of last recorded backup: |
| 74:851 | Job exceeded running time of <2,5,60,1,-1> Minutes |
| 74:852 | Number of failed files is more than <1,3,100,0,-1> |
| 74:853 | Total number of objects: |
| 74:854 | <TOTAL OBJECTS> |
| 74:855 | Percentage of failed files is more than <1,2,10,1,100> |
| 74:856 | Operation |
| 74:857 | Custom Alert |
| 74:858 | DDB Store got corrupted |
| 74:859 | <DDB NAME> |
| 74:860 | DDB Store Name: |
| 74:861 | Offline Since: |
| 74:862 | <OFFLINE SINCE> |
| 74:863 | [<Number>] Hrs |
| 74:864 | Backup Copy Workflow |
| 74:865 | Backup for subclient failed consecutively for <1,3,3,1,-1> attempts |
| 74:866 | Backup job [<Number>] with job status [<String>] started at [<String>] and completed at [<String>] with failure message [<String>]. |
| 74:867 | Failed Job Info: |
| 74:868 | <FAILED JOB INFO> |
| 74:869 | Alert when jobs in pending state exceed <1,2,30,1,100> percent or count of <1,3,15,0,-1> |
| 74:870 | <TOTAL JOBS> |
| 74:871 | <PENDING JOBS COUNT> |
| 74:872 | <TOP PENDING ERRORS LIST> |
| 74:873 | <TOP WAITING ERRORS LIST> |
| 74:874 | DDB disk space low |
| 74:875 | Total number of running jobs : |
| 74:876 | Number of pending jobs: |
| 74:877 | Top pending errors list: |
| 74:878 | Top waiting errors list: |
| 74:879 | Error Code: [<String>] Failure Reason : [<String>] |
| 74:880 | Message12 |
| 74:881 | Message13 |
| 74:882 | Message14 |
| 74:883 | Message15 |
| 74:884 | Message16 |
| 74:885 | Message17 |
| 74:886 | Message18 |
| 74:887 | Message19 |
| 74:888 | Message20 |
| 74:889 | Message21 |
| 74:890 | Message22 |
| 74:891 | Message23 |
| 74:892 | Message24 |
| 74:893 | Message25 |
| 74:894 | Not restored since: |
| 74:895 | Date of last recorded restore: |
| 74:896 | Time of last recorded restore: |
| 74:897 | <SUCCESSFUL MESSAGE> |
| 74:898 | <STATUS MESSAGE> |
| 74:899 | <ERR CODE MESSAGE> |
| 74:900 | <FAILURE REASON MESSAGE> |
| 74:901 | Failure Reason is [<String>] |
| 74:902 | Error Code is <String> |
| 74:903 | Successfully |
| 74:904 | <CHECK LOGS MESSAGE> |
| 74:905 | Please check the logs for more details. |
| 74:906 | Below Warning Threshold |
| 74:907 | Alert when client certificate Expires Within <7,15,7,1,-1> Days |
| 74:908 | Certificate for client [<String>] created on [<String>] expires on [<String>] |
| 74:909 | License |
| 74:910 | Log Monitoring |
| 74:911 | Matched log monitor data |
| 74:912 | Log Monitoring Criteria |
| 74:913 | <MONITORING POLICY NAME> |
| 74:914 | <MONITORING CRITERIA STRING> |
| 74:915 | <MATCHED LINE> |
| 74:916 | Log Monitoring Policy Name: |
| 74:917 | Monitoring Criteria: |
| 74:918 | Line Matched: |
| 74:919 | <MATCHED LINE NUMBER> |
| 74:920 | Line Number |
| 74:921 | Event Viewer Events |
| 74:922 | Event Viewer Events |
| 74:923 | <EVENT SEVERITY> |
| 74:924 | <EVENT DATE> |
| 74:925 | <EVENT PROGRAM> |
| 74:926 | Severity: |
| 74:927 | Program: |
| 74:928 | Event Date: |
| 74:929 | File Name: |
| 74:930 | <MATCHED LOG FILE> |
| 74:931 | Lines above matched line: |
| 74:932 | <LINES ABOVE MATCHED LINE> |
| 74:933 | Lines below matched line: |
| 74:934 | <LINES BELOW MATCHED LINE> |
| 74:935 | Description: |
| 74:936 | <EVENT ID> |
| 74:937 | Event ID: |
| 74:938 | Non-encrypted media exported |
| 74:939 | Content Indexing fallen behind alert |
| 74:940 | Operation: |
| 74:941 | Alert is marked permanent and may not be deleted. |
| 74:942 | Laptop Alerts have been enabled. |
| 74:943 | Laptop Alerts have been disabled. |
| 74:944 | <PARTIALLY SUCCESSFUL CLIENT LIST> |
| 74:945 | Partially Successful Client List: |
| 74:946 | Size: |
| 74:947 | <CLIENT GROUP NAME> |
| 74:948 | Server group |
| 74:949 | Server group: |
| 74:950 | <VARIABLE BODY> |
| 74:951 | MediaAgent [<String>] came online at [<String>] |
| 74:952 | Matched String |
| 74:953 | <VARIABLE END> |
| 74:954 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] SubClient : [<String>] |
| 74:955 | <ENTITY> |
| 74:956 | Windows Event Log Monitoring |
| 74:957 | Source |
| 74:958 | Level |
| 74:959 | Date and Time |
| 74:960 | Event ID |
| 74:961 | Task Category |
| 74:962 | Description |
| 74:963 | Computer |
| 74:964 | <TASK CATEGORY> |
| 74:965 | <COMPUTER> |
| 74:966 | <TIME> |
| 74:967 | <DATA COPIED> |
| 74:968 | <String> was copied and <String> is waiting to be copied(<String> of what was copied in the last <String> days). |
| 74:969 | Info: |
| 74:970 | Workflow |
| 74:971 | Workflows |
| 74:972 | Workflow Name: |
| 74:973 | Virtualize ME |
| 74:974 | vCenter: |
| 74:975 | <VCENTER> |
| 74:976 | ESX: |
| 74:977 | <ESX> |
| 74:978 | Data store: |
| 74:979 | <DATASTORE> |
| 74:980 | New Virtual Machine Name: |
| 74:981 | New Virtual Machine Host Name: |
| 74:982 | <VMHOSTNAME> |
| 74:983 | New Virtual Machine IP: |
| 74:984 | <IPADDRESS> |
| 74:985 | Clone Client Name: |
| 74:986 | <CLONECLIENTNAME> |
| 74:987 | Clone Host Name: |
| 74:988 | <CLONEHOSTNAME> |
| 74:989 | Estimated Time Needed For Copying: |
| 74:990 | <Number> Hour(s) |
| 74:991 | <COPY HOURS> |
| 74:992 | Number of SubClients: |
| 74:993 | <NUMBER OF SUBCLIENTS> |
| 74:994 | Custom Query |
| 74:995 | Data backed up exceeds <1,3, 5, 1, -1> GB |
| 74:996 | Substore location: |
| 74:997 | <SUBSTORE LOCATION> |
| 74:998 | Alert Reason: |
| 74:999 | <ALERT REASON> |
| 74:1000 | <INDEX 0> |
| 74:1001 | <INDEX 1> |
| 74:1002 | <INDEX 2> |
| 74:1003 | <INDEX 3> |
| 74:1004 | <INDEX 4> |
| 74:1005 | <INDEX 5> |
| 74:1006 | <INDEX 6> |
| 74:1007 | <INDEX 7> |
| 74:1008 | <INDEX 8> |
| 74:1009 | <INDEX 9> |
| 74:1010 | <INDEX 10> |
| 74:1011 | <INDEX 11> |
| 74:1012 | <INDEX 12> |
| 74:1013 | <INDEX 13> |
| 74:1014 | <INDEX 14> |
| 74:1015 | <INDEX 15> |
| 74:1016 | <INDEX 16> |
| 74:1017 | <INDEX 17> |
| 74:1018 | <INDEX 18> |
| 74:1019 | <INDEX 19> |
| 74:1020 | <INDEX 20> |
| 74:1021 | <INDEX 21> |
| 74:1022 | <INDEX 22> |
| 74:1023 | <INDEX 23> |
| 74:1024 | <INDEX 24> |
| 74:1025 | <INDEX 25> |
| 74:1026 | <INDEX 26> |
| 74:1027 | <INDEX 27> |
| 74:1028 | <INDEX 28> |
| 74:1029 | <INDEX 29> |
| 74:1030 | <INDEX 30> |
| 74:1031 | <INDEX 31> |
| 74:1032 | <INDEX 32> |
| 74:1033 | <INDEX 33> |
| 74:1034 | <INDEX 34> |
| 74:1035 | <INDEX 35> |
| 74:1036 | <INDEX 36> |
| 74:1037 | <INDEX 37> |
| 74:1038 | <INDEX 38> |
| 74:1039 | <INDEX 39> |
| 74:1040 | <INDEX 40> |
| 74:1041 | <INDEX 41> |
| 74:1042 | <INDEX 42> |
| 74:1043 | <INDEX 43> |
| 74:1044 | <INDEX 44> |
| 74:1045 | <INDEX 45> |
| 74:1046 | <INDEX 46> |
| 74:1047 | <INDEX 47> |
| 74:1048 | <INDEX 48> |
| 74:1049 | <INDEX 49> |
| 74:1050 | <INDEX 50> |
| 74:1051 | <INDEX 51> |
| 74:1052 | <INDEX 52> |
| 74:1053 | <INDEX 53> |
| 74:1054 | <INDEX 54> |
| 74:1055 | <INDEX 55> |
| 74:1056 | <INDEX 56> |
| 74:1057 | <INDEX 57> |
| 74:1058 | <INDEX 58> |
| 74:1059 | <INDEX 59> |
| 74:1060 | <INDEX 60> |
| 74:1061 | <INDEX 61> |
| 74:1062 | <INDEX 62> |
| 74:1063 | <INDEX 63> |
| 74:1064 | <INDEX 64> |
| 74:1065 | <INDEX 65> |
| 74:1066 | <INDEX 66> |
| 74:1067 | <INDEX 67> |
| 74:1068 | <INDEX 68> |
| 74:1069 | <INDEX 69> |
| 74:1070 | <INDEX 70> |
| 74:1071 | <INDEX 71> |
| 74:1072 | <INDEX 72> |
| 74:1073 | <INDEX 73> |
| 74:1074 | <INDEX 74> |
| 74:1075 | <INDEX 75> |
| 74:1076 | <INDEX 76> |
| 74:1077 | <INDEX 77> |
| 74:1078 | <INDEX 78> |
| 74:1079 | <INDEX 79> |
| 74:1080 | <INDEX 80> |
| 74:1081 | <INDEX 81> |
| 74:1082 | <INDEX 82> |
| 74:1083 | <INDEX 83> |
| 74:1084 | <INDEX 84> |
| 74:1085 | <INDEX 85> |
| 74:1086 | <INDEX 86> |
| 74:1087 | <INDEX 87> |
| 74:1088 | <INDEX 88> |
| 74:1089 | <INDEX 89> |
| 74:1090 | <INDEX 90> |
| 74:1091 | <INDEX 91> |
| 74:1092 | <INDEX 92> |
| 74:1093 | <INDEX 93> |
| 74:1094 | <INDEX 94> |
| 74:1095 | <INDEX 95> |
| 74:1096 | <INDEX 96> |
| 74:1097 | <INDEX 97> |
| 74:1098 | <INDEX 98> |
| 74:1099 | <INDEX 99> |
| 74:1100 | <INDEX 100> |
| 74:1101 | Alert Rule Name |
| 74:1102 | <QUERY NAME> |
| 74:1103 | <VARIABLE TOKENS> |
| 74:1104 | Custom Rules |
| 74:1105 | Size of Data to be Content Indexed: |
| 74:1106 | <SIZE OF DATA TOBE CONTENT INDEXED> |
| 74:1107 | Number of Jobs to be Content Indexed: |
| 74:1108 | <JOBS TOBE CONTENT INDEXED> |
| 74:1109 | <REPORT DISPLAY NAME> |
| 74:1110 | <REPORT PARAM NAME> |
| 74:1111 | <REPORT NAME> |
| 74:1112 | <REPORT CRITERIA> |
| 74:1113 | Disk Space low for Index Cache |
| 74:1114 | Disk space low for Job results directory |
| 74:1115 | Disk Space low for System temp directory |
| 74:1116 | Disk space low for software install directory |
| 74:1117 | Disk space low for library server Database |
| 74:1118 | Disk space low for /var directory |
| 74:1119 | Disk space low for iDataAgent dierctory |
| 74:1120 | Disk space low for software install base directory |
| 74:1121 | Disk space low for software install temp directory |
| 74:1122 | Disk space low for home directory |
| 74:1123 | Commcells |
| 74:1124 | <VM FAILURE REASON> |
| 74:1125 | <VM STATUS> |
| 74:1126 | Virtual Machine Backup Status: |
| 74:1127 | Failure reason for Virtual Machine Backup: |
| 74:1128 | <VIRTUAL MACHINE NAME> |
| 74:1129 | Virtual Machine Name: |
| 74:1130 | Virtual Machine Host Name: |
| 74:1131 | <VIRTUAL MACHINE HOST NAME> |
| 74:1132 | Validation Failed : Given criteria is not supported for this alert Type. |
| 74:1133 | Validation Failed : AlertType is not given , and unable to find a unique alertType for given criteria. |
| 74:1134 | Validation Failed : Notification types [<String>] are not supported. Please use commcell console for this. |
| 74:1135 | Validation Failed : Invalid param list for criteria.Please verify all parameters are provided for given criteria. |
| 74:1136 | Validation Failed : This operation will cause this alert rule not associated to any entities. If you are trying to dissociate some entities from this alert rule , please don't dissociate all entities. |
| 74:1137 | Validation Failed : Users [<String>] are not valid. Please specify valid users. |
| 74:1138 | Validation Failed : UserGroups [<String>] are not valid. Please specify valid UserGroups. |
| 74:1139 | Permission denied : No permission to associate following entities you are trying to associate with this alert [<String>]. |
| 74:1140 | Validation Failed : Alert name is empty , Please sepecify a valid alert name. |
| 74:1141 | Validation Failed : Alert criteria modification is not supported. |
| 74:1142 | <TABLE DATA> |
| 74:1143 | <INPUT DATA> |
| 74:1144 | Permission denied : User dont have enough permission to edit this alert. |
| 74:1145 | Validation Failed : This operation will cause this alert rule not associated to any user . If you are trying to dissociate some users from this alert rule ,please don't dissociate all users . |
| 74:1146 | Validation Failed : This operation will cause this alert rule not associated to any notification type. If you are trying to dissociate some notification types please don't dissociate all notification Types. |
| 74:1147 | Unknown Server Error : occured while processing. Please see the logs for more details. |
| 74:1148 | Validation Failed : Alert rule with the name [<String>] already exists. Please try this operation with different alert rule name. |
| 74:1149 | Match [<String>] times within [<String>] minutes |
| 74:1150 | <SEARCH QUERY STRING> |
| 74:1151 | <SEARCH CRITERIA> |
| 74:1152 | <SEARCH URL INFO> |
| 74:1153 | <SEARCH CRITERA MATCHED LINES> |
| 74:1154 | <JOB OPERATION> |
| 74:1155 | <PENDING CLIENT LIST> |
| 74:1156 | Pending Client List: |
| 74:1157 | <WARNING> |
| 74:1158 | Warning: |
| 74:1159 | Subclient association to this storage policy will be blocked if any of the fallen behind alert parameters exceeds three times the value specified in the Auxiliary Copy Fallen Behind Alert criteria. |
| 74:1160 | Please enable filter on Event Code to select Reporting options for event viewer alerts. |
| 74:1161 | Data analytics |
| 74:1162 | Metrics Alert |
| 74:1163 | <LEGAL HOLD NAME> |
| 74:1164 | Legal Hold Name: |
| 74:1165 | <REPORT URL> |
| 74:1166 | <REPORT MANAGE URL> |
| 74:1167 | The potential filegroup growth on drive <String>: is below the <Number> percent free space threshold ([<String>]growth/[<String>]free). |
| 74:1168 | Job Committed |
| 74:1169 | Job Committed |
| 74:1170 | <ADDITIONAL VM INFO> |
| 74:1171 | Virtual Machine backup end time |
| 74:1172 | Virtual Machine guest size |
| 74:1173 | Virtual Machine used space |
| 74:1174 | Virtual Machine powered off |
| 74:1175 | Is Virtual Machine guest size valid |
| 74:1176 | Virtual Machine Agent |
| 74:1177 | Virtual Machine size |
| 74:1178 | Virtual Machine Operating System |
| 74:1179 | Virtual Machine CBT Status |
| 74:1180 | Virtual Machine backup start time |
| 74:1181 | Virtual Machine hardware Version |
| 74:1182 | Virtual Machine backup Type |
| 74:1183 | Virtual Machine transport Mode |
| 74:1184 | Additional Information : |
| 74:1185 | <TABLE DATA XML> |
| 74:1186 | <AUDIT INFO> |
| 74:1187 | <TOTAL METRICS RESULT COUNT> |
| 74:1188 | All Entities |
| 74:1189 | <TREND DATA> |
| 74:1190 | Invalid appTypeFilter [<Number>] |
| 74:1191 | Invalid appGroupFilter [<Number>] |
| 74:1192 | Invalid Filter Operation Type |
| 74:1193 | Invalid EntityType provided [<Number>] |
| 74:1194 | Alert Modified Partially! All modifications are not applied.<BR><BR>User [<String>] requires [Edit Alert, Edit Alert Associations, Add/Remove Recipients] permission to edit [<String>] alert.<BR>Currently, user [<String>] has only [<String>] permission(s). |
| 74:1195 | Permission denied : User [<String>] does not have permission to associate/remove the user(s) [<String>] as recipient(s). |
| 74:1196 | Permission denied : User [<String>] does not have permission to associate/remove the user group(s) [<String>] as recipient(s). |
| 74:1197 | Permission denied : User [<String>] do not have [Alert Management] capability on following entities [<String>] to associate/remove them from the alert. |
| 74:1198 | Backup Job Succeeded |
| 74:1199 | Backup Job Failed |
| 74:1200 | Backup Job Skipped |
| 74:1201 | Backup Delayed by <2,5,1,1,-1> Hrs |
| 74:1202 | Backup Job completed with Errors |
| 74:1203 | Backup Job Started |
| 74:1204 | Backup Job Activity |
| 74:1205 | Increase in Data size by <1,2,10,1,-1> percent for backup job |
| 74:1206 | Decrease in Data size by <1,2,10,1,-1> percent for backup job |
| 74:1207 | Restore Job Succeeded |
| 74:1208 | Restore Job Failed |
| 74:1209 | Restore Job Skipped |
| 74:1210 | Restore Job completed with Errors |
| 74:1211 | Restore Job Started |
| 74:1212 | Restore Job Activity |
| 74:1213 | Disk space low on client |
| 74:1214 | VM Backup succeeded |
| 74:1215 | VM Backup failed |
| 74:1216 | VM Backup succeeded with errors |
| 74:1217 | Validation Failed : Option processDiscoveredVMs in alertStatus can be selected only for Job Management->data protection alerts. |
| 74:1218 | Description:t |
| 74:1219 | Validation Failed : Entity List is not valid. Please specify valid Entities. |
| 74:1220 | User does not have sufficient permission to subscribe to alert [<String>]. |
| 74:1221 | <CLIENT HOST NAME> |
| 74:1222 | Disk space low on Commserv Database |
| 74:1223 | Disk space low for Job results directory |
| 74:1224 | Disk Space low for Index Cache |
| 74:1225 | Disk space low for software install directory |
| 74:1226 | User specified condition got cleared. |
| 74:1227 | Some Solr Indexing engines are down or not reachable, Please check client[<String>] logs for more details. |
| 74:1228 | <ALARM HEADER> |
| 74:1229 | <JOB DESCRIPTION> |
| 74:1230 | Install Software |
| 74:1231 | UnInstall Software |
| 74:1232 | Upgrade Client |
| 74:1233 | Users |
| 74:1234 | Quota Exceeded |
| 74:1235 | Quota exceeding threshold |
| 74:1236 | Quota validation failed |
| 74:1237 | Object size : |
| 74:1238 | Quota Limit : |
| 74:1239 | Space consumed : |
| 74:1240 | <OBJECT SIZE> |
| 74:1241 | <QUOTA LIMIT> |
| 74:1242 | <SPACE CONSUMED> |
| 74:1243 | <USER ID> |
| 74:1244 | Cannot perform operation on alert when alert type is disabled. Please enable alert type and retry the operation |
| 74:1245 | User Group |
| 74:1246 | Operation Performed By: |
| 74:1247 | User Group: |
| 74:1248 | <OPERATION PERFORMED BY USER> |
| 74:1249 | <USER GROUP NAME> |
| 74:1250 | Please erase unnecessary data by logging into web console at <String>. |
| 74:1251 | <CLEANUP DATA TEXT> |
| 74:1252 | <CLIENT_OS_NAME> |
| 74:1253 | <CLIENT_OS_PLATFORM> |
| 74:1254 | <CLIENT_OS_SUBTYPE> |
| 74:1255 | <CLIENT_OS_TYPE> |
| 74:1256 | <CLIENT_OS_VERSION> |
| 74:1257 | Read error on extent file [<String>] inside NFS object store cache. |
| 74:1258 | File size read error on extent file [<String>] inside NFS object store cache. |
| 74:1259 | Extent [<String>] is missing from NFS object store cache. |
| 74:1260 | <Number> Seconds |
| 74:1261 | Edge drive/Share operations |
| 74:1262 | Edge drive/Share operations |
| 74:1263 | <ENTITY NAME> |
| 74:1264 | <ENTITY TYPE> |
| 74:1265 | <OPERATION DATA> |
| 74:1266 | DDB went Offline |
| 74:1267 | Offline Reason: |
| 74:1268 | <OFFLINE REASON> |
| 74:1269 | $ADMIN URL$ |
| 74:1270 | <BROWSE URL> |
| 74:1271 | Job is in waiting state |
| 74:1272 | <DESTINATION CLIENT> |
| 74:1273 | <SOURCE CLIENT> |
| 74:1274 | <CLIENT DESCRIPTION> |
| 74:1275 | <DATA WRITTEN> |
| 74:1276 | Increase in object count by <1,2,10,1,-1> percent |
| 74:1277 | Current Object Count: |
| 74:1278 | Percentage Increase in Object Count: |
| 74:1279 | Previous Object Count: |
| 74:1280 | <PERCENTAGE INCREASE IN OBJECT COUNT> |
| 74:1281 | <PREVIOUS JOB OBJECT COUNT> |
| 74:1282 | To view the shared <String>, click <a href="<String>" style="color: #3366ff"><String></a> |
| 74:1283 | <SHARE ENTITY INFO> |
| 74:1284 | Validation Failed : Subscription based alert cannot be created for this alert type since it isnt suppoprted. |
| 74:1285 | Shares |
| 74:1286 | Edge Drive/Share Digest notification |
| 74:1287 | <h4>Below are the list of activities on your share [<String>]</h4> |
| 74:1288 | Activity Name: |
| 74:1289 | Is file activity: |
| 74:1290 | File/Folder Name: |
| 74:1291 | File/Folder Old Name: |
| 74:1292 | Share Name: |
| 74:1293 | <ACTIVITY ID> |
| 74:1294 | <ACTIVITY NAME> |
| 74:1295 | <DIGEST INFO> |
| 74:1296 | <ENTITY GUID> |
| 74:1297 | <IS FILE ACTIVITY> |
| 74:1298 | <FILE NAME> |
| 74:1299 | <OLD FILE NAME> |
| 74:1300 | <OPERATION DATA BODY> |
| 74:1301 | <SHARE NAME> |
| 74:1302 | Media/Space left (excluding reserve space): |
| 74:1303 | <SHARE ID> |
| 74:1304 | $SHARE NOTIFICATION WIDTH$ |
| 74:1305 | <MAIL ID> |
| 74:1306 | Failed to fetch Current NFS Cache Configuration details while attempting to change [<String>]. [<String>] value reverted to original. Please check MA logs for more details. |
| 74:1307 | Attempt to migrate NFS Cache to new Cache Directory Failed. NFS Cache Directory location is unchanged. Please check MA logs for more details. |
| 74:1308 | Request to migrate NFS cache to new location failed since previous NFS Cache Migration request is already in progress. |
| 74:1309 | Failed to update NFS Cache status on CommServe. This will prevent from changing Cache Directory for Cache Migration. Another attempt to update will be done when 3dnfs service restarts on MA. |
| 74:1310 | Failed to [<String>] SMB Share for Object Store. Please check MA Logs for more details. |
| 74:1311 | <SEVERITY> |
| 74:1312 | <SEVERITY INT> |
| 74:1313 | Administrative job |
| 74:1314 | <CLIENT GROUP LIST> |
| 74:1315 | <ORGANIZATION NAME> |
| 74:1316 | CommServe LiveSync |
| 74:1317 | Production Commserve is not reachable |
| 74:1318 | Failover activity |
| 74:1319 | Failover completed |
| 74:1320 | Failover failed |
| 74:1321 | Failover started |
| 74:1322 | Failover Commserve: |
| 74:1323 | Failover initiated from: |
| 74:1324 | <FAILOVER COMMSERVE> |
| 74:1325 | <FAILOVER INITIATED FROM> |
| 74:1326 | Production Commserve is not running |
| 74:1327 | Passive node is not reachable |
| 74:1328 | Cannot delete disk cache directory [<String>] for deleted share [<String>]. The directory can be manually removed to reclaim space. |
| 74:1329 | <DIRECTORY WITH LOW SPACE> |
| 74:1330 | <THRESHOLD FOR LOW SPACE> |
| 74:1331 | Collection: |
| 74:1332 | Virtual Server: |
| 74:1333 | <EXCLUDED FROM SLA> |
| 74:1334 | Generated At: |
| 74:1335 | <FAILED MAILBOXES> |
| 74:1336 | <SKIPPED MAILBOXES> |
| 74:1337 | <SUCCESSFUL MAILBOXES> |
| 74:1338 | Admin Alert |
| 74:1339 | Anomaly in events |
| 74:1340 | Anomaly in number of failed jobs |
| 74:1341 | Anomaly in number of pending jobs |
| 74:1342 | Runtime anomaly in jobs |
| 74:1343 | Anomaly threshold |
| 74:1344 | Anomaly type |
| 74:1345 | Delay reason |
| 74:1346 | Event |
| 74:1347 | Event time |
| 74:1348 | Forecasted |
| 74:1349 | Job ID |
| 74:1350 | Occurrence |
| 74:1351 | Percentage complete |
| 74:1352 | Running time |
| 74:1353 | Subclient Name |
| 74:1354 | Frequency |
| 74:1355 | Occurrence and frequency |
| 74:1356 | Threshold for failed jobs: |
| 74:1357 | Threshold for pending jobs: |
| 74:1358 | Number of failed jobs: |
| 74:1359 | <FAILED JOBS THRESHOLD> |
| 74:1360 | <PENDING JOBS THRESHOLD> |
| 74:1361 | <FAILED JOBS COUNT> |
| 74:1362 | Server |
| 74:1363 | for more details. |
| 74:1364 | here |
| 74:1365 | Please click |
| 74:1366 | File system Quota Exceeded |
| 74:1367 | File system Quota exceeding threshold |
| 74:1368 | File system Quota validation failed |
| 74:1369 | Deleting cache directory [<String>] for Network Share [<String>] failed. Reclaim the space manually. |
| 74:1370 | Failed to get time on CommServer during [<String>] of Network Share [<String>], Network Server time is used instead. Browse results might get impacted in subsequent file listing. |
| 74:1371 | Automatic Refresh on backup for Network Share [<String>] failed. [<String>] |
| 74:1372 | Subclient time zone changed from [<String>] to [<String>]. |
| 74:1373 | Job activity anomaly |
| 74:1374 | <SUBCLIENT DESCRIPTION> |
| 74:1375 | Anomaly in number of succeeded jobs |
| 74:1376 | <SUCCEEDED JOBS THRESHOLD> |
| 74:1377 | <SUCCEEDED JOBS COUNT> |
| 74:1378 | [<String>] operation completed successfully on 3dfs Network Share [<String>] |
| 74:1379 | Alert when client is offline for <1,3, 15, 1, -1> Minutes |
| 74:1380 | <DESCRIPTION HTML> |
| 74:1381 | <TIME EPOCH> |
| 74:1382 | <VERSION GUID> |
| 74:1383 | UnReachable Client List: |
| 74:1384 | <CLIENT DISPLAY NAME> |
| 74:1385 | DataServer-IP on [<String>] is not ready |
| 74:1386 | Clients with low disk space: |
| 74:1387 | Clients which need reboot: |
| 74:1388 | <NEED REBOOT CLIENT LIST> |
| 74:1389 | Anomaly in DDB Pruning |
| 74:1390 | Storage Policy |
| 74:1391 | Storage Policy Copy |
| 74:1392 | Agent type |
| 74:1393 | KPI based Media Agent state management |
| 74:1394 | Deduplication Database |
| 74:1395 | Reason |
| 74:1396 | No mount path is available for subclient ID [<Number>] |
| 74:1397 | Job succeeded with warnings |
| 74:1398 | Disk space low for SMTP cache directory |
| 74:1399 | May miss SLA |
| 74:1400 | Client |
| 74:1401 | Disk space low for LogFiles directory |
| 74:1402 | Created point-in-time 3dfs network share [<String>] instead of Refresh on Backup share, since Refresh on Backup share already exist for a given subclient/backupset. |
| 74:1403 | <ALERT TIME> |
| 74:1404 | <VIRTUAL MACHINE INSTANCE UUID> |
| 74:1405 | Company |
| 74:1406 | Backup size: |
| 74:1407 | Cleanup comment: |
| 74:1408 | Is escalated: |
| 74:1409 | <CLIENT VERSION> |
| 74:1410 | <JOB STARTED FROM> |
| 74:1411 | <USER LOGIN NAME> |
| 74:1412 | <TEXT DATA> |
| 74:1413 | <QUERY GENERATED HTML CONTENT> |
| 74:1414 | Salesforce object backup anomaly |
| 74:1415 | Object |
| 74:1416 | Operation |
| 74:1417 | Record count |
| 74:1418 | <FAILED VMS> |
| 74:1419 | <PARTIALSUCCESS VMS> |
| 74:1420 | Replication |
| 74:1421 | No Replication in last <2,5,3,1,-1> Days |
| 74:1422 | Replication Delayed by <2,5,1,1,-1> Hrs |
| 74:1423 | Failback Complete |
| 74:1424 | Failback Failed |
| 74:1425 | Failover Complete |
| 74:1426 | Failover Failed |
| 74:1427 | Undo Failover Complete |
| 74:1428 | Undo Failover Failed |
| 74:1429 | In Sync |
| 74:1430 | Sync Failed |
| 74:1431 | Sync Paused |
| 74:1432 | Sync Pending |
| 74:1433 | Replication Pairs |
| 74:1434 | Destination: |
| 74:1435 | Failover Group: |
| 74:1436 | Failover Status: |
| 74:1437 | Date of last successful Replication: |
| 74:1438 | Time of last successful Replication: |
| 74:1439 | Replication Group: |
| 74:1440 | Replication Status: |
| 74:1441 | Source: |
| 74:1442 | <FAILOVER GROUP> |
| 74:1443 | <FAILOVER STATUS> |
| 74:1444 | <DATE OF LAST REPLICATION JOB> |
| 74:1445 | <TIME OF LAST REPLICATION JOB> |
| 74:1446 | <REPLICATION GROUP> |
| 74:1447 | <REPLICATION STATUS> |
| 74:1448 | 3dfs cache directory [<String>] is out of disk space on MediaAgent [<String>]. Consider expanding the disk or delete some of the 3dfs share. |
| 74:1449 | Missed SLA |
| 74:1450 | Failed to access the mount path [<String>] on the media agent [<String>]. |
| 74:1451 | Continuous |
| 74:1452 | Periodic |
| 74:1453 | Synchronization Status: |
| 74:1454 | <Synchronization Status> |
| 74:1455 | Event Code: |
| 74:1456 | <EVENT CODE> |
| 74:1457 | <TIME ZONE> |
| 74:1458 | <UTC_TIMESTAMP> |
| 74:1459 | <ALERT LINK> |
| 74:1460 | <CUSTOMER ID> |
| 74:1461 | Backup job exceeded running time of <2,5,60,1,-1> Minutes |
| 74:1462 | Resource overload |
| 74:1463 | <VIRTUAL MACHINE CLIENT NAME> |
| 74:1464 | <DOWNLOAD JOB MESSAGE> |
| 74:1465 | Condition Cleared |
| 74:1466 | Input |
| 74:1467 | <ALERT EVENT ID> |
| 74:1468 | DDB Space Reclamation |
| 74:1469 | <WORKLOAD> |
| 74:1470 | Disk space low on media agent |
| 74:1471 | <QUERY GENERATED TEXT CONTENT> |
| 74:1472 | Anomaly in audit |
| 74:1473 | Audit operation |
| 74:1474 | Period |
| 74:1475 | User |
| 74:1476 | Time zone: |
| 74:1477 | <COMMAND CENTER URL> |
| 74:1478 | Staged data will be available for guest file restore for the next 72 hours. |
| 74:1479 | Alert criteria within the same alert definition cannot have different values for delay time seconds |
| 74:1480 | Alert criteria within the same alert definition cannot have different values for persist time seconds |
| 74:1481 | Alert criteria within the same alert definition cannot have different values for reporting options |
| 74:1482 | Backup copy fallen behind |
Archive Manager Messages
| Code | Description |
| 81:1 | If the issue persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 81:2 | Please check log file <String> for details. |
| 81:3 | Please check subclient's Storage Policy setting. |
| 81:4 | Please check if the backup job is available in the Storage Policy Copy. |
| 81:5 | Please check following:n1. Check your AWS account credentials.n2. Check AWS KMS endpoint for the given region is reachable from CommServe.n3. Check user has required permissions.n4. Key is deleted or rolled over. |
| 81:6 | Please check following:n1. Check connectivity to KMIP server.n2. Key is deleted or rolled over. |
| 81:7 | Please check following:n1. Check connectivity to client(s) from CommServe.n2. Check passphrase file is accessible on the client(s). |
| 81:8 | Please check following:n1. Check provided passphrase is correct.n2. Exported passphrase on client(s) is intact and check connectivity to client(s) from CommServe.n3. See logs for more details. |
| 81:9 | Please check following:n1. Check connectivity to SafeNet server.n2. Key is deleted or rolled over. |
| 81:10 | Please check following:n1. Check connectivity to KMIP server.n2. if there is any passphrase set for SSL certificate then check if same is set in key provider properties on CommServe.n3. Check key IDs in bring your own keys list are valid if bring your own key option is used for KMS. |
| 81:11 | Please check following:n1. Check connectivity to KMIP server.n2. If dealy is expected then change value of the setting [Timeout in seconds to expire request sent to KMIP Server] in Media Manager configuration. |
| 81:12 | Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
Archive Manager Errors
| 80:1 | Data |
| 80:2 | Index |
| 80:3 | Content Indexing |
| 80:4 | Transaction Log |
| 80:5 | Filter |
| 80:6 | Undefined software error occurred. |
| 80:7 | A generic error occurred. |
| 80:8 | An error occurred in the session layer. |
| 80:9 | A timeout occurred in the session layer. |
| 80:10 | An error occurred in the data pipe layer. |
| 80:11 | There are no more chunks. |
| 80:12 | Not enough drives are available. |
| 80:13 | A socket timeout occurred. |
| 80:14 | A socket select call failed. |
| 80:15 | A socket receive call failed. |
| 80:16 | Memory allocation failed. |
| 80:17 | No qualified archive file was found. |
| 80:18 | A database query error occurred. Please check log files in CommServe for details. |
| 80:19 | Invalid Storage Policy ID. Application may not yet point to a valid Storage Policy. |
| 80:20 | Invalid incremental Storage Policy. |
| 80:21 | Invalid full Storage Policy. |
| 80:22 | Duplicate Storage Policy name. |
| 80:23 | Unable to delete storage policy due to a database error. |
| 80:24 | Storage Policy does not have a secondary copy. |
| 80:25 | Invalid Storage Policy copy ID. |
| 80:26 | Storage Policy copies are not synchronized. |
| 80:27 | Storage Policy copy is not active. |
| 80:28 | Backup On and After date of the Storage Policy copy is in future. |
| 80:29 | Storage Policy copy is not active or its Backup On and After date is in the future. |
| 80:30 | Auxiliary Copy cannot be initiated automatically for a selective copy which copy most recent full when Auxiliary Copy job starts. |
| 80:31 | The primary Storage Policy copy is invalid for this operation. |
| 80:32 | The storage policy copy is invalid for this operation because it is the source copy of a secondary copy. |
| 80:33 | Failed to get application information. |
| 80:34 | Failed to get job information. |
| 80:35 | Failed to get data pipe interface pair. |
| 80:36 | No more allocated streams are available. |
| 80:37 | Failed to create a Media Group. |
| 80:38 | Failed to get Media Groups for a Drive Pool. |
| 80:39 | Failed to get the Drive Pool for a Media Group. |
| 80:40 | There are running jobs for this application. |
| 80:41 | There are running jobs for this Storage Policy. |
| 80:42 | There are running jobs for this Storage Policy copy. |
| 80:43 | The Backup On and After date for the Storage Policy copy is invalid. |
| 80:44 | The Drive Pool does not exist in CommServe database. |
| 80:45 | The media are residing in a library where there are no compatible drives to read. |
| 80:46 | The archive file has no data. |
| 80:47 | No data needs to be copied. |
| 80:48 | There is no month definition for the calendar. |
| 80:49 | Failed to get network host name. |
| 80:50 | Invalid archive file ID. |
| 80:51 | Failed to get encryption key of the archive file. |
| 80:52 | Unable to find archive file with invalid parameters. |
| 80:53 | Invalid task ID for Auxiliary Copy. |
| 80:54 | Storage Policy and Copy information were not found for an Auxiliary Copy task. |
| 80:55 | Failed to create an archive file entry in CommServe database. |
| 80:56 | No valid backup for the given subclient. |
| 80:57 | No valid backup for the given backup set. |
| 80:58 | No valid data of a given type for the given subclient. |
| 80:59 | No valid backup for the given subclient before the given time. |
| 80:60 | No valid backup for the given subclient after the given time. |
| 80:61 | No non-aged valid backup for the given subclient before the given time. |
| 80:62 | No valid backup for the subclient in the given Storage Policy Copy before the given time. |
| 80:63 | Unable to find out the reason for getting no backup with the given parameters. |
| 80:64 | The archive file ID does not exist in CommServe database. |
| 80:65 | The given archive file name does not exist in CommServe database. |
| 80:66 | There is no valid archive file for the given archive file name and Storage Policy Copy. |
| 80:67 | The archive file for the storage policy copy may be aged or not copied. |
| 80:68 | There is no valid data for the archive file in any Storage Policy Copy. |
| 80:69 | The backup on a Storage Policy Copy is aged. You need to select the global option for using aged data. |
| 80:70 | The backup is aged. You need to select the global option for using aged data. |
| 80:71 | For a Deduplication copy, encryption which requires passphrase for restore is not supported. |
| 80:72 | Invalid copy precedence. Please check copy precedence setting for the Storage Policy. |
| 80:73 | Unable to delete a Storage Policy or Copy because some Filter files are still needed by other Storage Policy or Copy. |
| 80:74 | Offline Content Indexing is not configured for the Storage Policy. |
| 80:75 | Offline Content Indexing is not enabled for the Storage Policy. |
| 80:76 | The effective date of Offline Content Indexing for the Storage Policy is in future. |
| 80:77 | Offline Content Indexing is not enabled for any client associated to the Storage Policy. |
| 80:78 | No client associated to the Storage Policy has a valid license for Offline Content Indexing. |
| 80:79 | No backup data in the Storage Policy are eligible for Offline Content Indexing. |
| 80:80 | Subclients associated to a secondary copy must also be associated to its source copy. |
| 80:81 | Auxiliary Copy cannot write Multiplexed Data on to Deduplication copy as this operation is not supported. |
| 80:82 | This operation is invalid because this Storage Policy is the incremental Storage Policy of another Storage Policy. |
| 80:83 | Unable to delete this Storage Policy because it is still associated by applications. |
| 80:84 | This operation is only supported with Windows MediaAgent. |
| 80:85 | Circular source copy dependence is detected for the Storage Policy Copy and its Source Copy. |
| 80:86 | Deduplication is not enabled for this Storage Policy Copy. |
| 80:87 | Backup Silo is not enabled for this Storage Policy Copy. |
| 80:88 | Backup Silo is not configured correctly for this Storage Policy Copy. |
| 80:89 | Backup data encrypted with 7.0 or a later release version cannot be restored to a client with older version. |
| 80:90 | No valid backup for the given instance. |
| 80:91 | No valid backup for the given instance and copy. |
| 80:92 | Storage Policy does not have a snap copy. |
| 80:93 | Some snap jobs are not picked for moving to media. Possible reasons: (1) the earlier snap jobs are not picked for moving to media; (2) the later snap jobs have been moved to media. |
| 80:94 | Resources are not reserved. |
| 80:95 | BCD Index |
| 80:96 | Component Index |
| 80:97 | DB Index |
| 80:98 | N/A |
| 80:99 | Storage policy [<String>] is already existing |
| 80:100 | Storage policy Copy [<String>] is already existing |
| 80:101 | Library [<String>] is not Existing |
| 80:102 | Deduplication Can not be Enabled For Tape Library Type |
| 80:103 | Hardware cannot be compressed for Magnetic Library |
| 80:104 | The copy creation failed. Reason: <Message> |
| 80:105 | Dedupe Database Sync job will not start because the Dedupe Database is not for the active store. |
| 80:106 | Dedupe Database Sync job will not start because the Dedupe Database for the active store is not corrupted. |
| 80:107 | Dedupe Database Sync job will not start because the Dedupe Database for the active store is not reconstructable. |
| 80:108 | The Global Deduplication host copy does not exist. |
| 80:109 | Copies of the same storage policy can not use the same Global Deduplication policy. |
| 80:110 | Selected storage pool DDB block size is different than source copy storage pool block size. Block size mismatch will cause performance issues ADVICE: Use a new storage pool to create backup destination. For more details visit https://documentation.commvault.com/2023e/expert/12411_deduplication_building_block_guide.html#b12422_block_size |
| 80:111 | There is no data for Content Indexing. These clients have no valid license for Offline Content Indexing: <String>. |
| 80:112 | Unable to create dataset. Error [<String>]. |
| 80:113 | Wait for being assigned to run. |
| 80:114 | Store not found. |
| 80:115 | No active subclient found for the given SIDB store. |
| 80:116 | No valid backup found on the given store. |
| 80:117 | The Global Secondary Copy Policy host copy does not exist. |
| 80:118 | Copies of the same storage policy can not use the same Global Secondary Copy Policy. |
| 80:119 | A Global Secondary Copy Policy can not be used across different CommCells. |
| 80:120 | Some encrypted archive files will not be fully copied because source data are encrypted with different keys. Please enable Re-encryption. |
| 80:121 | No client associated to the Storage Policy has Content Indexing enabled. |
| 80:122 | Some snap jobs are not picked for catalog. Possible reasons: (1) the earlier snap jobs are not picked for catalog; (2) the later snap jobs have been cataloged. |
| 80:123 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as the job is not picked. |
| 80:124 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as the job is not available in source copy and also not marked for auxiliary copy. |
| 80:125 | Snap Job [<Number>], Storage Policy [<String>] is skipped for the backup copy operation. The job specified is non-full backup and will be processed once the corresponding full job has been copied to the backup copy destination. |
| 80:126 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy. Option not enabled on storage policy. |
| 80:127 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as the backup level of job is non-full but the previous jobs in the cycle are not yet copied to backup copy destination. |
| 80:128 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as a newer snap job is already backup copied for this subclient. |
| 80:129 | Backup copy validation for Snap Job [<Number>], Storage Policy [<String>] failed. A database query error occurred. Please check log files in CommServe for details. |
| 80:130 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as the job is not picked. |
| 80:131 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as the job is not available in source copy and also not marked for auxiliary copy. |
| 80:132 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as the backup level of job is non-full but the full job of the cycle does not have catalog in source copy. |
| 80:133 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog. Option not enabled on storage policy. |
| 80:134 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as the backup level of job is non-full but the previous jobs in the cycle are not yet cataloged. |
| 80:135 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as a newer backup job is already cataloged for this subclient. |
| 80:136 | Deferred catalog validation for Snap Job [<Number>], Storage Policy [<String>] failed. A database query error occurred. Please check log files in CommServe for details. |
| 80:137 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as a backup copy job is already running. |
| 80:138 | DDB Backups are still associated with this Storage Policy. Deleting this Storage Policy would result in inability to reconstruct the DDB.nPlease run a new DDB backup after re-associating the DDB subclients with different storage policy. |
| 80:139 | Some snap jobs are not picked for backup copy as they are non-full and corresponding full job of the cycle is not available for backup copy. |
| 80:140 | Some snap jobs are not picked for deferred catalog as they are non-full, no previous job in the same cycle was cataloged and corresponding full job of the cycle is not available. |
| 80:141 | Some snap jobs are not picked for backup copy as they are prevented in source copy. |
| 80:142 | Some snap jobs are not picked for deferred catalog as they are not available in source copy. |
| 80:143 | Some snap jobs are not picked for backup copy as they are migrated from a different CommCell. |
| 80:144 | Some snap jobs are not picked for deferred catalog as they are migrated from a different CommCell. |
| 80:145 | Job is deleted on the media. |
| 80:146 | Job exists in magnetic media |
| 80:147 | Job is invalid (failed/killed) |
| 80:148 | Data to Storage Policy [<String>] Copy [<String>] may not be copied now as destination MediaAgent(s) has not closed the streams allocated, will be retried soon. |
| 80:149 | Failed to commit chunk as some or all the sub stores are corrupted. |
| 80:150 | No backup data in the Storage Policy are eligible for Data Analytics. |
| 80:151 | Analytics option is not enabled for MediaAgent [<String>] |
| 80:152 | The storage policy has significant amount of pending data to copy. Please review the documentation on "Resolving the Auxiliary Copy Fallen Behind Alert Issues" or temporarily disable the Auxiliary Copy Fallen Behind Alert on copy properties to continue. |
| 80:153 | Data to Storage Policy [<String>] Copy [<String>] may not be copied as chunk replicate status update failed, will be retried soon. |
| 80:154 | Data to Storage Policy [<String>] Copy [<String>] may not be copied as source or destination copy is none dedupe copy. |
| 80:155 | All media agents hosting the libraries are below the required feature release level to run DDB based Data Verification or DDB Space Reclamation job. Please install the latest feature release and restart the job. |
| 80:156 | All media agents hosting the deduplication engines are below the required feature release level to run DDB based Data Verification or DDB Space Reclamation job. Please install the latest feature release and restart the job. |
| 80:157 | All media agents hosting the deduplication engines and libraries are below the required feature release level to run DDB based Data Verification job. Please install the latest feature release and restart the job. |
| 80:158 | Cannot unpick snapshot job when backup copy job is already running for the snap. |
| 80:159 | Can not promote copy[<String>] to primary as this is the only destination copy for spool copy[<String>]. |
| 80:160 | Analytics engine is not configured for MediaAgent [<String>] |
| 80:161 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as the subclient is deconfigured. |
| 80:162 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as the subclient is deconfigured. |
| 80:163 | Invalid Job Token. |
| 80:164 | Invalid client version for performing compression after deduplication. |
| 80:165 | Unable to create an array replica copy. Array Replica Copy is already present. |
| 80:166 | Unable to create an array replica copy. Array Replica Copy is already present. |
| 80:167 | Invalid client[<String>] version for performing compression after deduplication. |
| 80:168 | Unable to toggle SILO option as the store has already initialized. |
| 80:169 | The storage policy [<String>] has significant amount of pending data to copy. Please review the documentation on "Resolving the Auxiliary Copy Fallen Behind Alert Issues" or temporarily disable the Auxiliary Copy Fallen Behind Alert on copy properties to continue. |
| 80:170 | Job has different encryption in source copy. ADVICE: Mark job for re-copy and then try un-age. |
| 80:171 | There are media refresh jobs running for storage policy copy. If a copy is pointing to Global Secondary copy, verify that media refresh jobs are not running for Global Secondary copy. |
| 80:172 | Data to Storage Policy [<String>] Copy [<String>] may not be copied as we failed to get array controller Media Agent, make sure to set an array controller Media Agent for source Array, will be retried soon. |
| 80:173 | One or more media agents hosting the deduplication engines and libraries are below the required feature release level to run Defragment Data on MountPath(s) for Deduplication Database. Please install the latest feature release and restart the job. |
| 80:174 | Failed to run defragment job because data exist on cloud library for Deduplication Database. |
| 80:175 | SubClient reassociation is not allowed for current storage policy. |
| 80:176 | Subclient cannot be reassociated to new storage policy because the Dataset from subclient's previous storage policy association is marked for aging. |
| 80:177 | Storage policy association is not allowed because there are pending snap jobs for current subclient which need to be cataloged. |
| 80:178 | There are pending snap jobs for current subclient which need to be backup copied. Run backup copy workflow job on storage policy otherwise old jobs will not be backup copied. |
| 80:179 | Failed to associate applications for storage policy. |
| 80:180 | Failed to release cached resources. |
| 80:181 | Invalid task ID for Dedupe Database Data Verification. |
| 80:182 | There are running jobs for this Dedupe Database. |
| 80:183 | No data needs to be verified. |
| 80:184 | Invalid key provider [<String>]. |
| 80:185 | Failed to generate RSA key pair. |
| 80:186 | Failed to get master key. |
| 80:187 | Failed to rotate master key. See logs for details. |
| 80:188 | Failed to encrypt key using master key. See logs for details. |
| 80:189 | Failed to decrypt key using master key. See logs for details. |
| 80:190 | Failed to scramble keys. See logs for details. |
| 80:191 | Failed to set RSA key pair for copy [<String>] Storage Policy [<String>]. |
| 80:192 | A key provider by this name [<String>] already exists. |
| 80:193 | Unable to delete key provider [<String>] because following Storage Policy/Copy associated with it.n<String> |
| 80:194 | Changing key provider for Storage Policy Copy requires authentication code. Contact your software vendor for authentication code. |
| 80:195 | Failed to decrypt RSA private key for Storage Policy / copy [<String> / <String>]. See logs for details. |
| 80:196 | Unable to get default master key for Storage Policy / copy [<String> / <String>]. See logs for details. |
| 80:197 | Unable to get master key for Storage Policy / copy [<String> / <String>] from KMIP provider [<String>]. Please check following:n1. Check connectivity to KMIP server.n2. Key is deleted or rolled over. |
| 80:198 | No new backup data to analyze. |
| 80:199 | Failed to revoke old key. See logs for details. |
| 80:200 | Key operation request sent to KMIP provider [<String>] failed for Storage Policy / Copy [<String> / <String>]. Please check following:n1. Check connectivity to KMIP server.n2. if there is any passphrase set for SSL certificate then check if same is set in key provider properites on CommServe. |
| 80:201 | Key operation request sent to KMIP provider [<String>] timed out for Storage Policy / Copy [<String> / <String>]. Please check following:n1. Check connectivity to KMIP server.n2. If dealy is expected then change value of the setting Timeout in seconds to expire request sent to KMIP Server in Media Manager configuration. |
| 80:202 | Operation successful. However, the storage policy [<String>] has significant amount of pending data to copy. Please review documentation on "Resolving the Auxiliary Copy Fallen Behind Issues" for more info. |
| 80:203 | Operation successful. However, the storage policy has significant amount of pending data to copy. Please review documentation on "Resolving the Auxiliary Copy Fallen Behind Issues" for more info. |
| 80:204 | Invalid or missing configuration. Please specify KMIP server host name, port, certificate file path, key file path and CA certificate file path. |
| 80:205 | Invalid or missing encryption key length. |
| 80:206 | Invalid or missing encryption type. |
| 80:207 | Invalid or missing key provider type. |
| 80:208 | Key provider name is missing or empty. |
| 80:209 | Invalid Parameters |
| 80:210 | Failed to create Storage Policy Copy [<String>] because all backups are selected and source Copy either has jobs older than [<Number>] days or more than [<Number>] TB of data. |
| 80:211 | XML Message serialization failed. |
| 80:212 | XML Message unserialization failed. |
| 80:213 | Unable to get master key for Storage Policy / copy [<String> / <String>] from AWS provider [<String>]. Please check following:n1. Check your AWS Secret Access Key.n2. Check AWS KMS endpoint for the given region is reachable from CommServe.n3. Check user has required permissions.n4. Key is deleted or rolled over. |
| 80:214 | Unable to get master key for Storage Policy / copy [<String> / <String>] from SafeNet provider [<String>]. Please check following:n1. Check connectivity to SafeNet server.n2. Key is deleted or rolled over. |
| 80:215 | Invalid or missing AWS user account credentials.nADVICE: Using credential file: 1. Check if environment variable AWS_SHARED_CREDENTIALS_FILE is set with credential file path.n2. Credential file has valid access key info.n3. Restarted services after setting environment variable. nUsing access info: 1. Check if you entered all the required access credentials. |
| 80:216 | The Global Storage Policy host copy does not exist. |
| 80:217 | Invalid file/folder [<String>].nAdvice: Check file/folder path is correct and able to access. |
| 80:218 | Unable to get master key from AWS provider [<String>]. Please check following:n1. Check your AWS Access Keys.n2. Check AWS KMS endpoint for the given region is reachable from CommServe.n3. Check user has required permissions.n4. Key is deleted or rolled over. |
| 80:219 | Unable to get default master key. See logs for details. |
| 80:220 | Unable to get master key from KMIP provider [<String>]. Please check following:n1. Check connectivity to KMIP server.n2. Key is deleted or rolled over. |
| 80:221 | Unable to get master key from SafeNet provider [<String>]. Please check following:n1. Check connectivity to SafeNet server.n2. Key is deleted or rolled over. |
| 80:222 | Key operation request sent to KMIP provider [<String>] failed. Please check following:n1. Check connectivity to KMIP server.n2. if there is any passphrase set for SSL certificate then check if same is set in key provider properites on CommServe. |
| 80:223 | Invalid operation. See logs for details. |
| 80:224 | Key operation request sent to KMIP provider [<String>] timed out. Please check following:n1. Check connectivity to KMIP server.n2. If dealy is expected then change value of the setting Timeout in seconds to expire request sent to KMIP Server in Media Manager configuration. |
| 80:225 | Some snap jobs are not picked for backup copy as the subclients for these jobs are missing |
| 80:226 | Some snap jobs are not picked for deferred catalog as the subclients for these jobs are missing |
| 80:227 | Key provider [<String>] is in use |
| 80:228 | Missing passphrase file path. Specify a directory to create a file with passphrase. |
| 80:229 | Failed to export passphrase to client(s) for provider [<String>] with error [<String>]. |
| 80:230 | Unable to get passphrase from client(s) for PASSPHRASE provider [<String>]. Please check following:n1. Check connectivity to client(s).n2. Check passphrase file is accessible. |
| 80:231 | Unable to get master key for Storage Policy / copy [<String> / <String>] from PASSPHRASE provider [<String>]. Please check following:n1. Check provided passphrase is correct.n2. See logs for more details. |
| 80:232 | Unable to get master key from PASSPHRASE provider [<String>]. Please check following:n1. Check provided passphrase is correct.n2. See logs for more details. |
| 80:233 | Deletion of default mirror copy is not allowed. Promote another mirror copy as the default mirror copy and then delete the current copy. |
| 80:234 | Deletion of default replica/vault copy is not allowed. Promote another replica/vault copy as the default replica/vault copy and then delete the current copy. |
| 80:235 | Failed to decrypt RSA private key. |
| 80:236 | KMS [<String>] EntityType [<Message>] EntityName [<String>]nError: <Message>nADVICE: <Message> |
| 80:237 | Unable to get passphrase from client(s). |
| 80:238 | Key operation request sent to KMIP server failed. |
| 80:239 | Key operation request sent to KMIP server timed out. |
| 80:240 | Enabling Key Management Server at company level requires all servers and MediaAgents should be at version 11 SP12 or higher. |
| 80:241 | Unable to decrypt key encryption key(KEK) of Storage Policy / copy [<String> / <String>] using master key from Azure provider [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:242 | Unable to decrypt key using master key from Azure provider [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:243 | Unable to encrypt key encryption key(KEK) of Storage Policy / copy [<String> / <String>] using master key from Azure provider [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:244 | Unable to encrypt key using master key from Azure provider [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:245 | Unable to get master key for Storage Policy / copy [<String> / <String>] from Azure provider [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:246 | Unable to get master key from Azure provider [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:247 | Unable to decrypt key encryption key(KEK) using master key. |
| 80:248 | Unable to encrypt key encryption key(KEK) using master key. |
| 80:249 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as there are active backup copy jobs, reaching the maximum number of backup copy jobs that can run on the storage policy. Please try again later. |
| 80:250 | Duplicate export locations are not allowed, please specify unique locations. |
| 80:251 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as there are older jobs on subclient pending for backup copy. Please try again later. |
| 80:252 | Snap Job [<Number>], Storage Policy [<String>] is skipped for deferred catalog as there are older jobs on subclient pending for catalog. Please try again later. |
| 80:253 | Client [<String>] is older than SP14 and cannot be used for infiniStore Enabled Subclient [<Number>] |
| 80:254 | DDB Backups are still associated with this storage policy copy. Deleting this storage policy copy would result in inability to reconstruct the DDB. Please run a new DDB backup after re-associating the DDB subclients with different storage policy copy. |
| 80:255 | Subclient to DDB mapping is missing. |
| 80:256 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy, as the parent VSA job of the application aware job either has not been backup copied or has not processed the VM successfully for backup copy. |
| 80:257 | Failed to set copy [<String>] to primary. User does not have Create Storage Policy permission on global policy to promote secondary copy to primary copy. |
| 80:258 | Failed to set copy [<String>] to primary. User does not have Create Storage Policy Copy permission on global policy to de-promote primary copy to secondary copy. |
| 80:259 | MediaAgent reached maximum DDBs limit. ADVICE: Provision new MediaAgent. |
| 80:260 | Reached maximum allowed Space Reclamation jobs limit per schedule or schedule policy |
| 80:261 | Last Space Reclamation job ran within the maximum configured allowed interval on this Dedupe database. |
| 80:262 | Mountpaths associated with this Dedupe database are either support drill holes or free space is not below low watermark. |
| 80:263 | Invalid Plan/Storage Policy. Please verify Client[<String>], Agent[<String>], Instance[<String>], Backupset[<String>], Subclient[<String>] is associated to a valid Plan/Storage Policy. |
| 80:264 | Some backup jobs are skipped because some media are outside the library. |
| 80:265 | Changes to encryption settings are prevented by Administrator. |
| 80:266 | Unsupported MediaAgent version. Client is at higher version than MediaAgent.nADVICE: Upgrade MediaAgent to the same or higher version than client. |
| 80:267 | Unsupported MediaAgent version. Client [<String>] is at higher version than MediaAgent [<String>].nADVICE: Upgrade MediaAgent to the same or higher version than client. |
| 80:268 | Selected source media agent does not have access to mount paths to run DDB based Data Verification job. Please select the correct media agent. |
| 80:269 | DDB Backups [<String>] are still associated with this storage policy copy. Deleting this would result in inability to reconstruct the DDB. Please run a new DDB backup after re-associating the subclients with different storage policy copy. |
| 80:270 | DDB Backups [<String>] are still associated with this Storage Policy. Deleting this Storage Policy would result in inability to reconstruct the DDB.nPlease run a new DDB backup after re-associating the subclients with different storage policy. |
| 80:271 | Jobs cannot be un-aged. Media is reserved by new copy. |
| 80:272 | All media agents hosting the libraries are below the required service pack level to run DDB based Data Verification job with Use Scalable Resource Option selected. Please install the latest service pack and restart the job. |
| 80:273 | Pruner media agent not found to run Defrag phase on DDB, Please configure pruner media agent. |
| 80:274 | MediaAgents below 11.20 version will not be used for the current DDB based Data Verification job. Please upgrade all Media agents that are below version 11.20. |
| 80:275 | Selected Source MediaAgent is below 11.20 version and cannot be used for the current DDB based Data Verification job. Please upgrade all Media agents that are below version 11.20 and restart the job. |
| 80:276 | MediaAgents below 11.20 version will not be used for the current DDB based Data Verification job. Please upgrade all Media agents that are below version 11.20. |
| 80:277 | Selected Source MediaAgent is below 11.20 version and cannot be used for the current DDB based Data Verification job. Please upgrade all Media agents that are below version 11.20 and restart the job. |
| 80:278 | Micro pruning is not enabled on some/all of the mount path(s) to run Defrag phase on DDB, Please enable using mount path properties. |
| 80:279 | Selected source media agent is not a Pruner media agent to run Defrag phase on DDB, Please configure pruner media agent. |
| 80:280 | Snap Job [<Number>], Storage Policy [<String>] is skipped for the backup copy operation. The job specified is non-full backup and will not be processed for backup copy as the corresponding full job is not available on the backup copy destination. |
| 80:281 | MediaAgent [<String>] is below 11.25 version and cannot be used for the current DDB Space Reclamation job. Please upgrade this Media agent to version 11.25 or higher and restart the job. |
| 80:282 | All media agents or selected source media agent hosting the libraries does not have write access to run DDB Space Reclamation job. Please give write access to media agents. |
| 80:283 | MediaAgents below 11.25 version will not be used for the current Quick DDB Verification or DDB Space Reclamation job. Please upgrade all Media agents that are below version 11.25. |
| 80:284 | Selected Source MediaAgent is below 11.25 version and cannot be used for the current Quick DDB Verification or DDB Space Reclamation job. Please upgrade all Media agents that are below version 11.25 and restart the job. |
| 80:285 | Data for Job [<Number>] is aged. Select the global option for using aged data. |
| 80:286 | Data for Job [<Number>] is aged on Storage Policy [<String>] Copy [<String>]. Select the global option for using aged data. |
| 80:287 | Data for job [<Number>] is not available in any Storage Policy Copy. |
| 80:288 | Data for Job [<Number>] is not available on Storage Policy [<String>] Copy [<String>]. Please run auxiliary copy to copy the job to selected copy. |
| 80:289 | No MediaAgent has access to the mount path to run DDB based Data Verification job. Please check the job option for MediaAgent selection. |
| 80:290 | Invalid storage pool passed for secondary copy. Please use regular Disk, Cloud or HSX storage pool for secondary copy. |
| 80:291 | Another snapshot copy cannot be added to the 'Database Dev/Test' plan or storage policy |
| 80:292 | Failed to do post operation for 'Database Dev/Test' plan or storage policy. |
| 80:293 | Some snap jobs are not picked for backup copy. Possible reason could be backup copy not supported for subclient. |
| 80:294 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as backup activity is disabled for VSA parent subclient. |
| 80:295 | Snap Job [<Number>], Storage Policy [<String>] is skipped for backup copy as VSA parent subclient is deleted and backup activity is disabled. |
| 80:296 | Unsupported MediaAgent version. Client [<String>] is at higher version than MediaAgent [<String>]. Update job [<Number>] is already running for the MediaAgent. |
| 80:297 | Unsupported MediaAgent version. Client [<String>] is at higher version than MediaAgent [<String>]. Failed to start workflow job for updating MediaAgent. |
| 80:298 | Unsupported MediaAgent version. Client [<String>] is at higher version than MediaAgent [<String>]. Started workflow job [<Number>] for updating MediaAgent. |
| 80:299 | Unable to run space reclamation job on the DDB, as WORM storage lock is enabled on the library or copy. |
| 80:300 | Archive file and encryption key is mismatching. |
| 80:301 | Invalid Encryption Key |
| 80:302 | Unable to decrypt key encryption key(KEK) of Storage Policy / copy [<String> / <String>] using master key from GCP KMS [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:303 | Unable to decrypt key using master key from GCP KMS [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:304 | Unable to decrypt key encryption key(KEK) using master key. |
| 80:305 | Unable to encrypt key encryption key(KEK) of Storage Policy / copy [<String> / <String>] using master key from GCP KMS [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:306 | Unable to encrypt key using master key from GCP KMS [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:307 | Unable to encrypt key encryption key(KEK) using master key. |
| 80:308 | Unable to get master key for Storage Policy / copy [<String> / <String>] from GCP KMS [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:309 | Unable to get master key from GCP KMS [<String>]. Please check following:n1. Check application has required permissions.n2. Key is deleted or rolled over. |
| 80:310 | Failed during validation of credentials. Check if credentials provided are correct and have the necessary permissions. |
| 80:311 | Invalid or missing GCP user account credentials. |
| 80:312 | Cannot promote Airgap copy [<String>] to primary copy |
| 80:313 | Airgap copy should be synchronous or selective, cannot create primary copy using Airgap storage [<String>] |
| 80:314 | Cannot use Airgap copy [<String>] as a source for another copy |
CommCell Migration
| 106:1 | CCM Export Job has started |
| 106:2 | CCM Import Job has started |
| 106:3 | CCM Job phase has failed. Please Check CCMManager.log for more details. |
| 106:4 | Answers needed for import to proceed. |
| 106:5 | One or more User info for the imported Alert [<String>] is not found on destination CommServe. Adding CCM user [<String>]. |
| 106:6 | Error in initializing CommCell Migration |
| 106:7 | Failed to get restart string from Job manager |
| 106:8 | Failed to initialize CCM Options |
| 106:9 | Failed to send restart string to Job Manager |
| 106:10 | License Failure |
| 106:11 | User Impersonation failed |
| 106:12 | Invalid Dump Location |
| 106:13 | Access to Dump Path denied, please restore access and retry |
| 106:14 | Active connections to Database, Drop connections and resume the job |
| 106:15 | getPruningUpperLimit of dumpset failed. |
| 106:16 | Pruning of dumpsets failed. |
| 106:17 | Generation of Common Question File failed |
| 106:18 | Removal of Progress Files Failed. |
| 106:19 | Failed to get the supported subclients |
| 106:20 | Export of unsupported subclients requested. |
| 106:21 | Job specific directory already exists. Delete and resume the export |
| 106:22 | list.txt already exists for a fresh export request. Delete it and resume the job |
| 106:23 | common.dmp already exists. Please delete and resume the job |
| 106:24 | Restore of Commserv_Capture.dmp for common.dmp failed. Please check the following: 1)Verify if the job results directory of the CommServe client is valid and accessible. 2)Make sure that compression is not enabled on the disk having the installation base directory. 3)Verify if the file CommServ_Capture.dmp is present in the installation base directory. |
| 106:25 | Generation of Output files failed. |
| 106:26 | ccmCaptureCommCellXML failed. |
| 106:27 | Restore of Commserv_Capture.dmp for export dump failed. Please check the following: 1)Verify if the job results directory of the CommServe client is valid and accessible. 2)Make sure that compression is not enabled on the disk having the installation base directory. 3)Verify if the file CommServ_Capture.dmp is present in the installation base directory. |
| 106:28 | CCM Export Initialization failed. |
| 106:29 | Export of subclient failed. |
| 106:30 | Export of unknown entity requested. |
| 106:31 | Export Request failed. |
| 106:32 | Update of CCMCaptureEntities Table Failed. |
| 106:33 | Generation of job-specific question file failed. |
| 106:34 | Failed to get CommCell number |
| 106:35 | Error in database restore during import. Please check the following: 1)Make sure that the SQL server of source CommCell is of equal or lower version when compared to the SQL server of destination CommCell. 2)Verify if the job results directory of the CommServe client is valid and accessible. 3)Verify if any path mentioned as staging path in import options is valid and accessible. 4)Make sure that compression is not enabled on the disk having the dump files to import. 5)Verify if the path having the exported dump files is accessible and the dump files are present. |
| 106:36 | List file could not be opened for import |
| 106:37 | Insert of a row in CCMMERGEDUMPFILES failed. |
| 106:38 | Creation of progress file failed. |
| 106:39 | Read Questions failed for subclient entity. |
| 106:40 | Import failed to restore DB for subclient entity. Please check the following: 1)Make sure that the SQL server of source CommCell is of equal or lower version when compared to the SQL server of destination CommCell. 2)Verify if the job results directory of the CommServe client is valid and accessible. 3)Verify if any path mentioned as staging path in import options is valid and accessible. 4)Make sure that compression is not enabled on the disk having the dump files to import. 5)Verify if the path having the exported dump files is accessible and the dump files are present. |
| 106:41 | Import request failed for subclient entity. |
| 106:42 | Activate License failed after Import for subclient entity. |
| 106:43 | Read Questions failed for client entity. |
| 106:44 | Import failed to restore DB for client entity. Please check the following: 1)Make sure that the SQL server of source CommCell is of equal or lower version when compared to the SQL server of destination CommCell. 2)Verify if the job results directory of the CommServe client is valid and accessible. 3)Verify if any path mentioned as staging path in import options is valid and accessible. 4)Make sure that compression is not enabled on the disk having the dump files to import. 5)Verify if the path having the exported dump files is accessible and the dump files are present. |
| 106:45 | Import request failed for client entity. |
| 106:46 | Activate License failed after import for client entity. |
| 106:47 | Read Questions failed for MediaAgent entity. |
| 106:48 | Import failed to restore DB for MediaAgent entity. Please check the following: 1)Make sure that the SQL server of source CommCell is of equal or lower version when compared to the SQL server of destination CommCell. 2)Verify if the job results directory of the CommServe client is valid and accessible. 3)Verify if any path mentioned as staging path in import options is valid and accessible. 4)Make sure that compression is not enabled on the disk having the dump files to import. 5)Verify if the path having the exported dump files is accessible and the dump files are present. |
| 106:49 | Import request failed for MediaAgent entity. |
| 106:50 | Read Questions failed for Subclient Policies. |
| 106:51 | Import failed to restore DB for subclient policies. Please check the following: 1)Make sure that the SQL server of source CommCell is of equal or lower version when compared to the SQL server of destination CommCell. 2)Verify if the job results directory of the CommServe client is valid and accessible. 3)Verify if any path mentioned as staging path in import options is valid and accessible. 4)Make sure that compression is not enabled on the disk having the dump files to import. 5)Verify if the path having the exported dump files is accessible and the dump files are present. |
| 106:52 | Import request failed for Subclient Policies. |
| 106:53 | Import failed to restore DB for Media Locations. Please check the following: 1)Make sure that the SQL server of source CommCell is of equal or lower version when compared to the SQL server of destination CommCell. 2)Verify if the job results directory of the CommServe client is valid and accessible. 3)Verify if any path mentioned as staging path in import options is valid and accessible. 4)Make sure that compression is not enabled on the disk having the dump files to import. 5)Verify if the path having the exported dump files is accessible and the dump files are present. |
| 106:54 | Import request failed for Media Locations. |
| 106:55 | Import of unknown entity requested. |
| 106:56 | Schedule Policy [<String>] with Custom Calendar has been mapped to Standard Calendar during Import. |
| 106:57 | Number of clients limit violated. |
| 106:58 | Enough licenses not available to consume |
| 106:59 | Entity to import already exists on the destination. Failing Import Job. |
| 106:60 | Schedule Policy [<String>] from source already exists in destination CommCell as [<String>]. |
| 106:61 | Alert [<String>] from source already exists in destination CommCell as [<String>]. |
| 106:62 | Server group [<String>] from source already exists in destination CommCell as [<String>]. |
| 106:63 | Creation of Database Synonyms for Export Source DB Failed |
| 106:64 | Export of common dump file Failed |
| 106:65 | No Free Space available on [<String>] |
| 106:66 | No Free Disk Space available. Please Check CCMManager.log for Details. |
| 106:67 | Generation Of Dump File List For Export Failed |
| 106:68 | Validation of dump directory failed |
| 106:69 | Creation of Job Specific Export Directory Failed |
| 106:70 | Validation for cross-version export failed |
| 106:71 | Failed to check if client version supported for cross-version export |
| 106:72 | Cross-version export failed |
| 106:73 | Custom Calendar [<String>] from source already exists in destination CommCell as [<String>]. |
| 106:74 | The custom calendar of one or more imported schedule is not found on destination CommServe. Using the default calendar [<String>]. |
| 106:75 | Another CCM Job is already running |
| 106:76 | User [<String>] has been assigned as the owner for Server group [<String>] since the original owner was not found. |
| 106:77 | One or more User group info for the imported Alert [<String>] is not found on destination CommServe and is dropped. |
| 106:78 | One or more external group info for the imported Alert [<String>] is not found on destination CommServe and is dropped. |
| 106:79 | Name change of client [<String>] to [<String>] on remote commcell [<String>]*[<String>] success. |
| 106:80 | CONFLICT: There is already a client named [<String>] with Commcell [<String>]*[<String>]. Click Yes if you still want to proceed with the name change. |
| 106:81 | CONFLICT: There is already a client with GUID [<String>] with Commcell [<String>]*[<String>]. Click Yes if you still want to proceed with the name change. |
| 106:82 | Error in name change operation in source commcell. Please check CCMManager.log for more details. |
| 106:83 | Remote commcell id=[<Number>] [<String>]*[<String>] is not reachable. Please check if Commvault services are up. If they are already up, please check CVD.log, CCMManager.log in remote commcell. |
| 106:84 | Failed to communicate with CCMManager service. Please check [<String>].log, CCMManager.log for more details. |
| 106:85 | Error in remote commcell [<String>]*[<String>] in name change operation for client [^3%ls]. Please check CCMManager.log in remote commcell. |
| 106:86 | [<String>] |
| 106:87 | ICCS operation success: [<String>] |
| 106:88 | Failed to query CommServe DB. Please check [<String>].log |
| 106:89 | Error in ICCS operation [<String>]. Please check [<String>].log |
| 106:90 | Failed to query CommServe DB on remote CommServe. Please check CCMManager.log on CommServe [<String>]*[<String>] |
| 106:91 | Error in ICCS operation [<String>] on remote CommServe. Please check CCMManager.log on CommServe [<String>]*[<String>] |
| 106:92 | [<String>] |
| 106:93 | [<String>] |
| 106:94 | Failed to share MediaAgent [<String>] with CommServe [<String>].n |
| 106:95 | Failed to apply SSL certificate on MediaAgent [<String>], MediaAgent may be offline. |
| 106:96 | Remote commcell [<String>] is not reachable.nPlease check if Commvault services are up. If they are already up, please check CVD.log, CCMManager.log in remote commcell. |
| 106:97 | Failed to update CommServe DB after MediaAgent[<String>] is shared with CommServe[<String>]. nAny client/host name change for this MediaAgent will not be sync-ed with remote CommServe. |
| 106:98 | Failed to share client [<String>] with CommServe [<String>].n |
| 106:99 | Failed to apply SSL certificate on client [<String>], client may be offline. |
| 106:100 | Failed to update CommServe DB after client[<String>] was shared with CommServe[<String>]. nAny client/host name change for this client will not be sync-ed with remote CommServe. |
| 106:101 | [<String>] failed on POD. Please check status of job [<Number>] on remote commcell [<String>]. |
| 106:102 | Remote [<String>] incomplete on POD. Please check status of job [<Number>] on remote commcell [<String>]. |
| 106:103 | Handler missing for ICCS message id [<Number>] |
| 106:104 | Failed to copy exported dumps to remote location. |
| 106:105 | Failed to notify GRC on job completion |
| 106:106 | Waiting for remote [<String>] to complete on commcell [<String>]. Job Id [<Number>] |
| 106:107 | Pushback phase incomplete. Please check CCMManager.log. |
| 106:108 | Encountered unexpected incoming route configuration for remote CommCell. Please clear incoming route settings for this client and perform CommCell Registration again. |
| 106:109 | No new exported dumps available to import. |
| 106:110 | Failed to upload exported dumps to cloud. |
| 106:111 | Failed to download exported dumps from cloud. |
| 106:112 | Failed to upload state file to cloud. |
| 106:113 | Failed to copy state file to remote MediaAgent [<String>]. |
| 106:114 | Failed to upload state file to PodCell [<String>]. |
| 106:115 | CommCell GUIDs in state file doesn't match with the GUIDs from DataBase. |
| 106:116 | There was no successful import reported from several days hence stopping export job. |
| 106:117 | Commcell Migration feature is disabled on POD cell, please contact your software provider to get authorization code to enable the feature. |
| 106:118 | Failed to connect to the cloud storage. See logs for details. |
| 106:119 | Failed to connect to cloud storage. Please verify cloud storage is accessible from CommServe and specified cloud account credentials are valid. |
| 106:120 | Missing cloud storage account information. Please specify cloud storage account information. |
| 106:121 | [<String>] is suspended on POD. Please resume the Job [<Number>] on the remote commcell [<String>]. |
Common Event Messages
| 72:1 | Failed to get result from CreateIndex on MediaAgent. Please check if there is a network problem and that the services on the MediaAgent are running. |
| 72:2 | CreateIndex on MediaAgent returned an error. Please check the CreateIndex.log on MediaAgent for possible causes. |
| 72:3 | Cannot read acknowledgment from CreateIndex on MediaAgent. Please check the network connectivity and for possible problems with the CreateIndex process problem on the MediaAgent. |
| 72:4 | Error opening or reading the index file <String>, error code = <Number>. Please check the network connectivity and for possible problems with the CreateIndex process problem on the MediaAgent. |
| 72:5 | There is an error during launching CreateIndex. Possible causes: a) CreateIndex failure; please check CreateIndex.log file on MediaAgent [<String>]. b) Network problem between this machine and the MediaAgent. |
| 72:6 | CreateIndex on the MediaAgent timed out. Please check the network connectivity and ensure that the services on the MediaAgent are running. |
| 72:7 | The file [<String>] could not be created because of error code [<Number>]. Please check what the error code means and the folder permission and ensure that there is enough disk space. |
| 72:8 | Unable to retrieve subclient content information from the CommServe. Please check network connectivity and ensure that the product's services are running on both client and CommServe. |
| 72:9 | Error obtaining the client host name. Please check the TCP/IP settings. If these are OK, check this product's registry keys - the reason may be a possibly corrupted installation. |
| 72:10 | Error obtaining CommServe name. Possibly corrupted install. |
| 72:11 | Cannot open registry key SOFTWARE\CommVault Systems\Galaxy\Platform Information\...\iDataAgent on client <String>. |
| 72:12 | Could not open file <String> for reading, error=<Number> |
| 72:13 | Could not open file <String> for writing, error=<Number> |
| 72:14 | Error writing to the file [<String>], perhaps insufficient disk space? |
| 72:15 | Error reading from file [<String>]. |
| 72:16 | Send index to MediaAgent failed. Check the network connectivity and CreateIndex logs on MediaAgent. |
| 72:17 | A problem occurred while trying to access, or inconsistent data was returned from the CommServe database. Please make sure that all the product's services are running, the iDataAgent properties are set up correctly, and the name resolution and network connectivity are working correctly. If the problem persists, please call the support hotline. |
| 72:18 | An error occurred. Please see the log files for more information. |
| 72:19 | An exception occurred. Please call the support hotline. |
| 72:20 | Failed to open directory [<String>]. Possible reasons: nonexistent path/file or hardware problems. |
| 72:21 | Process cannot continue as there is insufficient memory to continue the execution. |
| 72:22 | Backup will be executed with legacy APIs. |
| 72:23 | Pipeline is down. Cannot allocate buffer. Check MediaAgent and pipeline. |
| 72:24 | Unable to retrieve the iDataAgent properties. Please check if the product's services on the CommServe and on the CommClient are up. Restart all the services and try again. |
| 72:25 | User or CommServe Job Manager stopped the backup job. |
| 72:26 | Backup initialization failed. Check pipeline and MediaAgent. |
| 72:27 | Unable to login using user [<String>\<String>]. Error code returned was [<Number>]. Please make sure that the user credentials are correct. |
| 72:28 | Received an unexpected message from the CommServe. Please make sure that all services are running. |
| 72:29 | The receive message operation has failed with the error [0x<HexNumber>]. The connection has been aborted! |
| 72:30 | Sending either the message header or the message itself failed. Please check if all services are up and that the network connection is working. |
| 72:31 | Error opening data source. |
| 72:32 | Restore was aborted. |
| 72:33 | Backup was aborted. |
| 72:34 | Error initializing the COM library. |
| 72:35 | Cannot get subclient configuration from server. |
| 72:36 | Cannot get working directory. |
| 72:37 | Out of disk space. |
| 72:38 | Cannot open registry key <String> on client [<String>]. |
| 72:39 | MediaAgent network connectivity problem to iDataAgent. |
| 72:40 | Failed to open Archive File. The connectivity between client and MediaAgent may be broken OR an invalid copy precedence may have been specified. |
| 72:41 | Archive file cannot be opened. Possible causes: services down on CommServe, lost network connectivity to CommServe. |
| 72:42 | Unknown status. |
| 72:43 | Directory [<String>] is in use. |
| 72:44 | Could not create directory [<String>]. |
| 72:45 | CommServe was unable to connect over the network to MediaAgent [<String>] - the problem may be either with network connectivity or that this product's services are down. |
| 72:46 | Could not determine full path for [<String>]. |
| 72:47 | Error impersonating user. Please verify that the username and password are correct. |
| 72:48 | Failed to get destination client host name. |
| 72:49 | Failed to set up connection to destination client [<String>]. |
| 72:50 | Quit Message received from Job Manager. |
| 72:51 | Error notifying Job Manager of successful completion. |
| 72:52 | Error notifying Job Manager of failure. |
| 72:53 | Not enough space on the disk at [<String>] ; available [<Number>] MB, required [<Number>] MB. |
| 72:54 | <String> |
| 72:55 | [<String>] exceeds threshold of [<Number>] MB. The space usage is [<Number>] MB. |
| 72:56 | [<String>] does not have the required minimum space of [<Number>] MB and exceeded the threshold of [<Number>] MB. Space available: [<Number>] MB. Space usage: [<Number>] MB. |
| 72:57 | [<String>] does not have required minimum space of [<Number>] MB. The space available is [<Number>] MB. |
| 72:58 | Unable to commit database transaction. Please try again, and if the problem persists, please contact your software vendor. |
| 72:59 | The operation could not be completed as obsoleted code was encountered during the execution. Please contact your software vendor. |
| 72:60 | NAS updates : |
| 72:61 | NDMP updates : |
| 72:62 | WA Driver updates : |
| 72:63 | Copy Manager updates : |
| 72:64 | Base updates : |
| 72:65 | iDataAgent updates : |
| 72:66 | Informix iDataAgent updates : |
| 72:67 | Oracle iDataAgent updates : |
| 72:68 | SAP for Oracle updates : |
| 72:69 | Quick Recovery Agent updates : |
| 72:70 | Serverless Data Manager updates : |
| 72:71 | File Archiver updates : |
| 72:72 | Lotus Notes Database updates : |
| 72:73 | DB2 updates : |
| 72:74 | Sybase updates : |
| 72:75 | UNIX Image Level updates : |
| 72:76 | 1-Touch updates : |
| 72:77 | Service Pack : |
| 72:78 | Additional updates : |
| 72:79 | Missing updates : |
| 72:80 | No updates |
| 72:81 | None |
| 72:82 | Apple Macintosh updates : |
| 72:83 | FreeBSD updates : |
| 72:84 | HP-UX File System updates : |
| 72:85 | Linux File System updates : |
| 72:86 | Tru64 File System updates : |
| 72:87 | SGI File System updates : |
| 72:88 | Solaris File System updates : |
| 72:89 | Data Classification volumes are running at [<Number>] percent of capacity. Data classification will not function when the volume runs out of space. |
| 72:90 | The QR Snap Cache [<String>] is running at [<Number>] percent of the volume space. Quick Recovery will stop functioning when this volume runs out of space. |
| 72:91 | Overwritten |
| 72:92 | Restored |
| 72:93 | Older |
| 72:94 | Failed |
| 72:95 | Filtered by map |
| 72:96 | Appended |
| 72:97 | Skipped |
| 72:98 | Not mapped |
| 72:99 | Pending |
| 72:100 | Bad media |
| 72:101 | Some volumes on this machine are running at [<Number>] percent of capacity. Recovery points that have been saved on this machine could be compromised or its behavior could become unpredictable. |
| 72:102 | The index location [<String>] used by the Content Indexing server is reaching [<Number>] percent of the disk capacity. |
| 72:103 | The disk used to store the index on the Content Indexing server is running at [<Number>] percent of capacity. Please add more disk space to prevent failures during Content Indexing operations. |
| 72:104 | The index location [<String>] used by the Content Indexing server does not have required minimum space of [<Number>] GB. Space available is [<Number>] MB. |
| 72:105 | The disk used to store the index on the Content Indexing server does not have required minimum space of [<Number>] GB. Please add more disk space to prevent failures during search or indexing operations. |
| 72:106 | <String> |
| 72:107 | Locked |
| 72:108 | Needs reboot |
| 72:109 | Failed to set the ACLs. ACL support is not available on destination machine/filesystem or incompatible with backup data. |
| 72:110 | The cache location [<String>] used by the Content Store is reaching [<Number>] percent of the disk capacity. |
| 72:111 | The cache location [<String>] used by the Content Store does not have required minimum space of [<Number>] GB. Space available is [<Number>] MB. |
| 72:112 | The disk used to store the cached files on the Content Store is running at [<Number>] percent of capacity. Please add more disk space to prevent failures during Content Store operations. |
| 72:113 | The disk used to store the cached files on the Content Store does not have required minimum space of [<Number>] GB. Please add more disk space to prevent failures during Content Store operations. |
| 72:114 | Failed to initialize External data connector. |
| 72:115 | Failed to run job phase through External data connector layer. |
| 72:116 | Failed to fetch the resource list from External data connector layer. |
| 72:117 | Failed to find log file resources in External data connector's resource list. |
| 72:118 | Failed to extract information of MIME data in External data connector layer. |
| 72:119 | Failed to fetch handshake data from External data connector. |
| 72:120 | Failed to back up using 'mining database'. |
| 72:121 | User exceeded allowed Virtual machine Quota using this Allocation policy <String>. Use another Allocation Policy or contact the Administrator. |
| 72:122 | Disk space requested exceeds maximum disk space allowed by the Allocation policy [<String>]. |
| 72:123 | Total disks requested exceeds maximum disks allowed by the Allocation policy [<String>]. |
| 72:124 | Total NICS requested exceeds maximum NICS allowed by the Allocation policy [<String>]. |
| 72:125 | Total memory requested exceeds maximum memory allowed by the Allocation policy [<String>]. |
| 72:126 | None of the Host servers configured in the Allocation policy [<String>] can be selected for creating virtual machine. Verify that there is enough disk space available on the Data stores connected to the hosts. |
| 72:127 | Database Error [<String>] occurred while selecting best ESX Server and Datastore from the Allocation Policy [<String>]. |
| 72:128 | User is not a member of the Allocation Policy [<String>]. Use another Allocation Policy. |
| 72:129 | Phase 1: Provisioning of Virtual Machine [<String>] is successful, Phase 2: 1-Touch Recovery started |
| 72:130 | User has exceeded allowed Virtual Machine Quota. |
| 72:131 | Maximum allowed length of virtual machine name is 15 characters. Use a smaller name. |
| 72:132 | Failed to open directory [<String>]. Unable to log in using user [<String>\<String>]. Please make sure the user credentials are correct. |
| 72:133 | User exceeded allowed number of snapshots for this Virtual Machine using this Allocation Policy. Please use another Allocation Policy with higher limits. |
| 72:134 | Failed to access path [<String>]. No logon servers are available. Check network connectivity to the device and health of any domain controller. |
| 72:135 | Verified |
| 72:136 | Requested disk size exceeds available space on storage |
| 72:137 | Conflict |
| 72:138 | A VM with same name already exists. Please retry with a different name. |
| 72:139 | The number of CPU(s) requested exceeds maximum allowed by the Allocation policy [<String>]. |
| 72:140 | None of the Host servers configured in the Allocation policy [<String>] can be selected for creating virtual machine. Verify that there is enough memory available on the hosts. |
| 72:141 | Commserve failed to connect to Enterprise Metrics Reporting Server to download scripts.Access the download URL from the explorer and verify. |
| 72:142 | Commserve failed to process Enterprise Metrics Reporting Server scripts. |
| 72:143 | Commserve failed to upload data to Enterprise Metrics Reporting Server.In case HTTP Proxy is configured, Update HTTP Proxy details in Control Panel -> E-Mail & Web Server Configuration -> Internet Gateway. |
| 72:144 | Commserve failed to connect to Cloud Reporting Server to download scripts.Access the download URL from the explorer and verify. |
| 72:145 | Commserve failed to process Cloud Metrics Reporting Server scripts. |
| 72:146 | Commserve failed to upload data to Cloud Metrics Reporting Server. In case HTTP Proxy is configured, Update HTTP Proxy details in Control Panel -> Internet Options-> HTTP Proxy. |
| 72:147 | Commserve failed to download the proactive support request configuration from the Cloud Metrics Reporting Server. |
| 72:148 | Commserve failed to submit sendlogs job for the remote troubleshooting request. |
| 72:149 | Submitted sendlogs job id[<Number>] for remote troubleshooting request id [<Number>]. |
| 72:150 | Request exceeds maximum limit configured in Live Mount policy. |
| 72:151 | Error :[<String>] |
| 72:152 | The index location [<String>] used by the Analytics Engine is reaching [<Number>] percent of the disk capacity. |
| 72:153 | The disk used to store the index on the Analytics Engine is running at [<Number>] percent of capacity. Please add more disk space to prevent failures during Analytics operations. |
| 72:154 | The index location [<String>] used by the Analytics Engine does not have required minimum space of [<Number>] GB. Space available is [<Number>] MB. |
| 72:155 | The disk used to store the index on the Analytics Engine does not have required minimum space of [<Number>] GB. Please add more disk space to prevent failures during indexing operations. |
| 72:156 | Deleted |
| 72:157 | Skipped.Operation Not Supported |
| 72:158 | User has exceeded allowed Virtual Lab Quota. |
| 72:159 | User has exceeded allowed Virtual Machine Memory Quota. |
| 72:160 | User has exceeded allowed Virtual Machine CPU Quota. |
| 72:161 | Commserve failed to download the license server update from the Cloud Metrics Reporting Server. |
| 72:162 | Commserve failed to process license server update. |
| 72:163 | [<String>] is down or unreachable as URL [<String>] is not reachable. Please make sure [<String>] is running and reachable. |
| 72:164 | [<String>] is up and running. |
| 72:165 | [<String>] is up and running as URL [<String>] is accessible. |
| 72:166 | Approval denied for DR Operation. |
| 72:167 | Operation [<String>] failed with error [<String>] for client [<String>]. |
| 72:168 | Failure reported by API call [<String>] (<Number>). |
| 72:169 | Invalid input specified. |
| 72:170 | User [<String>] is not an owner of the lab. |
| 72:171 | Virtual Lab with the given name [<String>] already exists. Please retry with a different name. |
| 72:172 | Virtual Lab does not exist. |
| 72:173 | <String> is down or unreachable |
| 72:174 | <String> is down or unreachable, Error Code : <Number> |
| 72:175 | Index Server ran out of disk |
| 72:176 | [<String>] with URL [<String>] is not responsive. Reason [<String>]. Please make sure [<String>] is running and reachable. |
| 72:177 | VM group is not configured for application validation. |
| 72:178 | The disk used to store the Content Store Mailbox Cache is running at [<Number>] percent of capacity. Please add more disk space to prevent failures during Content Store Mailbox Caching operations. |
| 72:179 | The disk used to store the Content Store Mailbox Cache does not have the required minimum space of [<Number>] GB. Please add more disk space to prevent failures during Content Store Mailbox Caching operations. |
| 72:180 | The Content Store Mailbox Cache location [<String>] does not have the required minimum space of [<Number>] GB. Space available is [<Number>] MB. |
| 72:181 | The Content Store Mailbox Cache location [<String>] is reaching [<Number>] percent of the disk capacity. |
| 72:182 | Total [<String>] files failed to be recalled in last [<String>] minutes ending on [<String>]. Please check RecalledItems.log and ClMgrS.log for details. |
| 72:183 | Automatic Heal has taken a dump of [<String>]. It is saved in the logs folder. Contact support. |
| 72:184 | [<String>] server architecture not supported for backups using PLAN with OptimizeForInstantClone. |
| 72:185 | [<String>] Linux distribution not supported for backups using PLAN with OptimizeForInstantClone. |
| 72:186 | FS [<String>] on this system has max size is [<Number>]TB but requested size is [<Number>]TB |
| 72:187 | FS [<String>] extend command failed.Error [<String>]. |
| 72:188 | Mounting backup volume [<String>] failed. Error [<String>]. |
| 72:189 | mkfs.xfs and mkfs.ext4 commands not detected on this system. |
| 72:190 | Platform not supported for backups using PLAN with OptimizeForInstantClone. |
| 72:191 | Automatic TempDb Healing has detected High TempDb usage by certain SPIDs. <String>. Please contact the Customer Support Team. |
| 72:192 | Process Dump(s) of [<String>] is saved in the Logs folder with names [<String>] respectively, along with the Log Files [<String>]. |
| 72:193 | The processes [<String>] have been restarted. |
| 72:194 | These SPIDs have been killed. |
| 72:195 | Subclient content is empty or invalid. |
| 72:196 | Recovery Target Policy ID is not set. |
| 72:197 | Alibaba Cloud: Authentication or Access Error: Make sure the credentials provided are correct and active, the Alibaba Cloud resource exists. Also validate privileges. Error [<String>]. |
| 72:198 | Alibaba Cloud: Incorrect Access or Secret Key: Make sure Secret Key is correct and active. Also verify privileges. Error[<String>]. |
| 72:199 | Alibaba Cloud: Invalid Access Key: Make sure Access Key [<String>] is active and has the permissions to access this resource. |
| 72:200 | Alibaba Cloud: Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:201 | Azure: Authentication failed: Make sure the AD application has sufficient privileges. Check the Role associated with this application. Error[<String>]. |
| 72:202 | Azure: Authentication failed: Wrong password or expired SAS token or insufficient privileges. Password may have changed or rotated. Error[<String>]. |
| 72:203 | Azure: Authentication or Access Error: Make sure the credentials provided are correct and active, the Azure resource exists. Also validate privileges and Roles. Error [<String>]. |
| 72:204 | Azure: Authentication failed: Wrong password or SAS token or insufficient privileges. Error[<String>]. |
| 72:205 | Azure: Name resolution error: Check if the account name [<String>] is correct. Also check the proxy, firewall and DNS configuration. |
| 72:206 | Azure: Authentication failed: Make sure the VM has storage account access. Error[<String>]. |
| 72:207 | Azure: Authentication failed: Incorrect Application Id or Secret value. Error[<String>]. |
| 72:208 | Azure: Authentication failed: Looks like Key based authentication is disabled for this account. Error[<String>]. |
| 72:209 | Azure: Name resolution error: Check if the Url[<String>] and account name [<String>] are correct. Also check the proxy, firewall and DNS configuration. |
| 72:210 | Google Cloud: Authentication or Access Error: Make sure the credentials provided are correct and active, the Google Cloud resource exists. Also validate privileges. Error [<String>]. |
| 72:211 | Google Cloud: Incorrect Access or Secret Key: Make sure Secret Key is correct and active. Also verify privileges. Error[<String>]. |
| 72:212 | Google Cloud: Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:213 | IBM Cloud: Authentication or Access Error: Make sure the credentials provided are correct and active, the IBM Cloud resource exists. Also validate privileges. Error [<String>]. |
| 72:214 | IBM Cloud: Incorrect Access or Secret Key: Make sure Secret Key is correct and active. Also verify privileges. Error[<String>]. |
| 72:215 | IBM Cloud: Invalid Access Key: Make sure Access Key [<String>] is active and has the permissions to access this resource. |
| 72:216 | IBM Cloud: Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:217 | Open Stack: Authentication or Access Error: Make sure the credentials provided are correct and active, the Open Stack resource exists. Also validate privileges. Error [<String>]. |
| 72:218 | Open Stack: Incorrect Access or Secret Key: Make sure Secret Key is correct and active. Also verify privileges. Error[<String>]. |
| 72:219 | Open Stack: Invalid Access Key: Make sure Access Key [<String>] is active and has the permissions to access this resource. |
| 72:220 | Open Stack: Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:221 | ORACLE Cloud: Authentication or Access Error: Make sure the credentials provided are correct and active, the ORACLE Cloud resource exists. Also validate privileges. Error [<String>]. |
| 72:222 | ORACLE Cloud: Incorrect Access or Secret Key: Make sure Secret Key is correct and active. Also verify privileges. Error[<String>]. |
| 72:223 | ORACLE Cloud: Invalid Access Key: Make sure Access Key [<String>] is active and has the permissions to access this resource. |
| 72:224 | ORACLE Cloud: Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:225 | S3: Access Denied: Make sure the S3 resource is accessible with the given level of Privileges. Error[<String>]. |
| 72:226 | S3: Authentication or Access Error: Make sure the credentials provided are correct and active, the S3 resource exists. Also validate privileges. Error [<String>]. |
| 72:227 | Authentication Error: Wrong password or insufficient privileges. Password may have changed or rotated. Privileges revoked or token expired. Error[<String>]. |
| 72:228 | Invalid Access Key: Access Key [<String>] is invalid. Error[<String>]. |
| 72:229 | Failed to connect: Url [<String>] is not reachable. If the URL is correct, check the proxy and firewall configuration. |
| 72:230 | Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:231 | S3: Failed to connect: Url [<String>] is not reachable. Check the proxy and firewall configuration. |
| 72:232 | Name resolution error: Server IP address for this Url [<String>] could not be found. If the URL is correct, check the proxy, firewall and DNS configuration. |
| 72:233 | S3: Access Denied: Make sure the IAM role has access to the S3 resource. Error[<String>]. |
| 72:234 | S3: IAM role not found: Make sure the IAM role exists and has access to the S3 resource. Error[<String>]. |
| 72:235 | S3: Incorrect Secret Key: Make sure Secret Key is correct and active. Also verify privileges. Error[<String>]. |
| 72:236 | S3: Access Denied: Validate access Privileges. Review Bucket Policy. Error[<String>]. |
| 72:237 | S3: Access Denied: Validate access Privileges. Review Bucket Policy. Error[<String>]. |
| 72:238 | S3: Invalid Access Key: Make sure Access Key [<String>] is active and has the permissions to access this resource. |
| 72:239 | S3: Invalid Operation: Check the object's storage class. Error[<String>]. |
| 72:240 | S3: Access Denied: Make sure user is authorized to Assume role on the S3 resource. Error[<String>]. |
| 72:241 | S3: Failed to connect: Configured Url [<String>] is not reachable. If the URL is correct, check the proxy and firewall configuration. |
| 72:242 | Name resolution error: If the configured URL[<String>] is correct, check the proxy, firewall and DNS configuration. |
| 72:243 | Successfully created the provider. Preparing LDAP Gateway for first time use in clients : <String> |
| 72:244 | There are no files that need to be backed up. |
| 72:245 | Access nodes used for this job - [ <String> ] |
| 72:246 | Object storage backup job started on node [ <String> ] |
| 72:247 | Backup failed for all files, job will not be marked as completed successfully |
| 72:248 | This client is installed with secure permissions, so impersonation feature can't be used. Please remove secure permissions and try again. |
| 72:249 | Unable to access Cloud. Possible causes: Wrong credentials or url, Lack of permissions, Network issue, Wrong system time on proxy |
| 72:250 | The index location [<String>] used by the Analytics Engine has reached [<Number>] percent of the disk capacity. The minimum required disk space is [<Number>] GB. The available disk space is [<Number>] GB. |
| 72:251 | The disk used for storing index on the Analytics Engine has reached [<Number>] percent of the capacity. The available disk space is less than the [<Number>] GB minimum. Please add more disk space to prevent failures during Analytics operations. |
| 72:252 | Waiting for the DRApproval job with job ID [<Number>] to complete |
| 72:253 | Failed to create commit collect file. Forcing reference time to 0 for this backup to behave as FULL. |
| 72:254 | Couldn't connect to cloud for cleanup phase. Error[<String>] |
| 72:255 | Failed to cleanup the staging path [<String>] for spanner. Please check CvCloudBkp.log on the proxy. |
| 72:256 | Couldn't get the staging path for cleanup |
| 72:257 | Got Invalid path for cleanup |
| 72:258 | Failed to scan part of the subclient content |
| 72:259 | Size of data [<Number>] to be backed up exceeds the configured Value [<Number>] |
| 72:260 | <String> must belong to the same region as [<String>] to ensure best performance and eliminate inter-region data transfer charges. |
| 72:261 | JobResults folder for the previous job is missing. To overcome this error : Browse and Restore the troubleshooting items from the last successful job. Please check the logs for more details. |
| 72:262 | Pipeline failure occurred during backup. Check Media Agent and connectivity. |
| 72:263 | Storage accounts which matches the rules are already protected. No new instances will be created |
| 72:264 | Successfully created instances for the storage accounts: [<String>] |
| 72:265 | Discovery will be skipped for the following storage accounts as they're already protected: [<String>] |
| 72:266 | Failed to create instance for storage account[<String>] with error[<String>] |
| 72:267 | No storage accounts matching the configured rules were found |
| 72:268 | Rules are not configured for instance [<String>] with cloud account [<String>] |
| 72:269 | Error encountered while parsing rules during discovery |
| 72:270 | To perform optimized scan, it is expected that all paths of the content group belong to the same region [<String>]. Path [<String>] belongs to region [<String>]. |
| 72:271 | No bucket backups found for given bucket, time range and copy values. Bucket Clone creation request cannot be processed. |
| 72:272 | Bucket clone creation failed with internal error, please review JobManager.log file on CommServer. Error [<String>]. |
| 72:273 | <String> is supported only for multi-node or distributed backups |
| 72:274 | <String> could not be used for this job as [<String>] |
| 72:275 | For <String> : Staging path is needed |
| 72:276 | <String> could not be used for some paths in this job as [<String>] |
| 72:277 | <String> : <String> is missing |
| 72:278 | Failure reason [<String>] |
| 72:279 | The log dump to disk cache was unsuccessful. Client: [<String>], Instance: [<String>], Error: [<String>] |
| 72:280 | The log dump to the disk cache was unsuccessful. Client: [<String>], Instance: [<String>], Affected Database: [<String>], Error: [<String>] |
| 72:281 | The log dump to disk cache was unsuccessful. Client: [<String>], Affected database(s): [<String>]. More details can be found in the events. |
| 72:282 | The log dump to disk cache was unsuccessful. Client: [<String>]. More details can be found in the events. |
CommServe License Manager
| Code | Description |
| 1:1 | Invalid arguments. |
| 1:2 | An application is still in use by another client. |
| 1:3 | An invalid application type have been detected. |
| 1:4 | An invalid number of clients has been detected. |
| 1:5 | An invalid platform type has been detected. |
| 1:6 | The CommServe has an invalid license key. |
| 1:7 | The CommServe has an out-of-date license key. |
| 1:8 | A database connection error has occurred. |
| 1:9 | A database update error has occurred. |
| 1:10 | A database read error has occurred. |
| 1:11 | A memory allocation error has occurred. |
| 1:12 | The CommServe license key is corrupted. |
| 1:13 | An invalid operation code has been detected. |
| 1:14 | An invalid data type has been detected. |
| 1:15 | An invalid product release has been detected. |
| 1:16 | There is no application data present. |
| 1:17 | There is no license key information present. |
| 1:18 | There is no library control program application present. |
| 1:19 | There is no MediaAgent present in the license. |
| 1:20 | Failed to encrypt the data. Please contact your software provider. |
| 1:21 | An invalid CommServe identification number has been detected. |
| 1:22 | An invalid CommCell identification number has been detected. |
| 1:23 | An application that cannot be an evaluation copy has been detected. |
| 1:24 | The CommServe license decoder failed. |
| 1:25 | An invalid license type has been detected. |
| 1:26 | An invalid license type operation has been detected. |
| 1:27 | There is no Archive Server Application present. |
| 1:28 | A CRC error has occurred. |
| 1:29 | An expired CommServe license key has been detected. |
| 1:30 | An invalid License File has been detected. |
| 1:31 | Server applications not allowed in license add type. |
| 1:32 | Evaluation CommServe is not allowed for the license type. |
| 1:33 | Application data is not allowed for the license type. |
| 1:34 | The creation of the release configuration file failed. |
| 1:35 | The reading of the release configuration file failed. |
| 1:36 | A CommServe license structure is required. |
| 1:37 | There are no licenses available for this application. |
| 1:38 | The application license update failed. |
| 1:39 | The application license evaluation date has expired. |
| 1:40 | The CommServe license evaluation date has expired. |
| 1:41 | The evaluation day argument cannot be NULL. |
| 1:42 | Invalid application data has been detected. |
| 1:43 | An invalid activation key code has been detected. |
| 1:44 | License administrator invoked. |
| 1:45 | License administrator failed. |
| 1:46 | License administrator succeeded. |
| 1:47 | CommCell name found but with different CommCell ID in CommCell table. |
| 1:48 | Warning: CommCell ID found but with a different CommCell name in CommCell table. |
| 1:49 | CommCell ID not found in CommCell table. |
| 1:50 | CommCell ID not found in CommCell table. |
| 1:51 | CommServe client ID not found in Client table. |
| 1:52 | CommServe client not found in Platform table. |
| 1:53 | Unknown license application [<Number>]. |
| 1:54 | License application type not found. |
| 1:55 | CommServe license validated! |
| 1:56 | MediaAgent license validated! |
| 1:57 | Either unable to contact CommServe for License Validation or MediaAgent license has expired! |
| 1:58 | Application Name: <String> |
| 1:59 | The new license contains more MediaAgents than LCPs |
| 1:60 | Duplicate CommServe Storage Manager license key! |
| 1:61 | Success! |
| 1:62 | A memory allocation error has occurred. |
| 1:63 | nUsage: <String> -A T:NOC [-A T:NOC] -P OS -I Machid [-O OEMName -o OEMLicenseType] -C CSid -L Lictype -R Relnum [-E T:NOC [-E T:NOC] -e -F LicFile]nn |
| 1:64 | Invalid license parameter.n |
| 1:65 | Invalid platform parameter.n |
| 1:66 | Invalid release parameter.n |
| 1:67 | Invalid application parameter.n |
| 1:68 | Invalid application type.n |
| 1:69 | Invalid OEM Id.n |
| 1:70 | A server application cannot be an evaluation copy.n |
| 1:71 | An invalid number of applications clients.n |
| 1:72 | An invalid machine ID parameter.n |
| 1:73 | An invalid CommCell ID parameter.n |
| 1:74 | An invalid OEM license type parameter.n |
| 1:75 | A missing argument.n |
| 1:76 | A required argument missing.n |
| 1:77 | An invalid option.n |
| 1:78 | nError: |
| 1:79 | nnnLicense Key valid on <String>n |
| 1:80 | License key expires if not used by <String>n |
| 1:81 | tCommServe Storage Manager Evaluation Configurationnn |
| 1:82 | ttCommServe Storage Manager Configurationnn |
| 1:83 | CommServe ID = <HexNumber>n |
| 1:84 | nOEM ID = <Number>n |
| 1:85 | nOEM License Type = <Number>n |
| 1:86 | nCommCell ID = <HexNumber>n |
| 1:87 | nPlatform Type = <String>n |
| 1:88 | nCommServe Release = <Number>.xn |
| 1:89 | nLicense Type = <String>n |
| 1:90 | Application name |
| 1:91 | Number of clients |
| 1:92 | CommServe Storage Manager Install |
| 1:93 | iDataAgent upgrade |
| 1:94 | iDataAgent Addition |
| 1:95 | CommServe Storage Manager Release Upgrade |
| 1:96 | CommServe Storage Manager OEM Upgrade |
| 1:97 | iDataAgent Deletion |
| 1:98 | Sun Solaris |
| 1:99 | Hewlett Packard HP-UX |
| 1:100 | Microsoft Windows |
| 1:101 | Evaluation |
| 1:102 | nActivation Key = <HexNumber>n |
| 1:103 | +###################### WARNING ####################### |
| 1:104 | An evaluation CommServe upgrade license may ben |
| 1:105 | rejected during activation if the installed CommServen |
| 1:106 | is NOT an evaluation copy.nn |
| 1:107 | IF THIS IS AN ERROR, PLEASE RE-GENERATE THIS LICENSE KEY! |
| 1:108 | nUsage: <String> -L Lic |
| 1:109 | nPlease write down the activation key code ===>[<HexNumber>]<=== maybe required by technical support n |
| 1:110 | License activator invoked. |
| 1:111 | License activator failed. |
| 1:112 | License activator succeeded. |
| 1:113 | nUsage: <String> -R CVRel -L Lic |
| 1:114 | -F and -L options are incompatible.n |
| 1:115 | Incompatible product and license releases.n |
| 1:116 | License installer invoked. |
| 1:117 | License installer failed. |
| 1:118 | License installer succeeded. |
| 1:119 | nApplication: <String>n Max [<Number>] tConfigured [<Number>] |
| 1:120 | tALERTn |
| 1:121 | Evaluation expiration date: <String>n |
| 1:122 | CommServe expiration date: <String>n |
| 1:123 | Number applications: <Number>n |
| 1:124 | nLicense: <String>n |
| 1:125 | CommServe Release: <String>n |
| 1:126 | License install date: <String>n |
| 1:127 | CommServe ID: 0x<HexNumber>n |
| 1:128 | OEM ID: <Number>n |
| 1:129 | OEM License Type: <Number>n |
| 1:130 | CommCell ID: 0x<HexNumber>n |
| 1:131 | License reader invoked. |
| 1:132 | License reader failed. |
| 1:133 | License reader succeeded. |
| 1:134 | Failed to set CommCell ID. |
| 1:135 | Failed to set up activity control data. |
| 1:136 | Activation Key: <HexNumber>n |
| 1:137 | CommServe Storage Manager License Only Update |
| 1:138 | Invalid OEM information. |
| 1:139 | Duplicate application data in license key. |
| 1:140 | CommServe Storage Manager Id Change |
| 1:141 | nNew CommServe ID = <HexNumber>n |
| 1:142 | CommServe License Release does NOT match the installed release! |
| 1:143 | An attempt was made to delete more licenses than exist for an application |
| 1:144 | You do not have a license to perform data encryption. |
| 1:145 | Unable to verify data encryption license. |
| 1:146 | You are using an evaluation encryption license with only <Number> days left. |
| 1:147 | You do not have a license to perform CommCell Migration. |
| 1:148 | Unable to verify CommCell Migration license. |
| 1:149 | You are using an evaluation CommCell Migration license with only <Number> days left. |
| 1:150 | You cannot convert a permanent license to an evaluation license. |
| 1:151 | The first license to use should always be a license of type NEW and cannot be Replace or anything else. |
| 1:152 | Once a CommServe is activated with a license, a license of type New cannot be used again. |
| 1:153 | A CommCell level license de-configure failed. |
| 1:154 | License activation failed. |
| 1:155 | License activation failed. <String> The number of licenses given for a License type should be at least equal <String> to the number of licenses used in the CommServe. |
| 1:156 | The following Agents do not have enough licenses given. |
| 1:157 | [<String>] Permanent Licenses: Issued [<Number>] Consumed [<Number>] |
| 1:158 | License activation failed.<String> Invalid machine ID detected in the license. |
| 1:159 | The license being activated is for CommServe with IP address [<String>] <String> and the CommServe is of IP address [<String>]. |
| 1:160 | License activation failed.<String> Invalid CommCell ID detected in the license. |
| 1:161 | The license being activated is for CommCell ID [<Number>] and the current CommServe is of CommCell ID [<Number>]. |
| 1:162 | License activation failed.<String> Invalid CommServe release detected in the license. |
| 1:163 | Release number in license file is not valid for this CommCell. The license file you selected is for release [<String>], but the current CommCell license is for release [<String>]. |
| 1:164 | License activation failed.<String> The license file [<String>] is not a valid license file or could not be read. |
| 1:165 | License activation failed.<String> Could not get the version from registry or the version is invalid. |
| 1:166 | Failed to update the counter table. |
| 1:167 | Server File System |
| 1:168 | Laptop and Desktop |
| 1:169 | Application Class 1 |
| 1:170 | iDataAgent for Domino Database on MS Windows |
| 1:171 | iDataAgent for Domino Document on Unix |
| 1:172 | Application Class 1 |
| 1:173 | Application Class 1 |
| 1:174 | iDataAgent for Exchange Mailbox |
| 1:175 | Application Class 1 |
| 1:176 | Library Control Module |
| 1:177 | MediaAgent |
| 1:178 | MediaAgent |
| 1:179 | MediaAgent |
| 1:180 | MediaAgent |
| 1:181 | MediaAgent |
| 1:182 | Application Class 3 |
| 1:183 | Application Class 2 |
| 1:184 | Application Class 1 |
| 1:185 | Application Class 2 |
| 1:186 | iDataAgent for Sun Solaris File System on Intel |
| 1:187 | Server File System |
| 1:188 | Server File System |
| 1:189 | Server File System |
| 1:190 | Application Class 1 |
| 1:191 | NDMP |
| 1:192 | Shared Storage License |
| 1:193 | iDataAgent for Hewlett Packard HP-UX 64bit File System |
| 1:194 | iDataAgent for Sun Solaris 64bit File System |
| 1:195 | Server File System |
| 1:196 | Server File System |
| 1:197 | Application Class 2 |
| 1:198 | Application Class 1 |
| 1:199 | NAS Client |
| 1:200 | iDataAgent for EMC IP4700 NAS |
| 1:201 | NAS Client |
| 1:202 | MediaAgent for Unix |
| 1:203 | iDataAgent for ProxyHost on MS Windows |
| 1:204 | iDataAgent for Fastrax Exchange Database |
| 1:205 | iDataAgent for EMC Fastrax Exchange Mailbox |
| 1:206 | iDataAgent for Fastrax Exchange 2000 Database |
| 1:207 | iDataAgent for EMC Fastrax Exchange 2000 Mailbox |
| 1:208 | iDataAgent for EMC Fastrax Windows 2000 File System |
| 1:209 | iDataAgent for MS SharePoint Database v1 |
| 1:210 | iDataAgent for Serverless Data Manager on MS Windows |
| 1:211 | Server File System |
| 1:212 | iDataAgent for MS Exchange Public Folder/Web Folder |
| 1:213 | NAS Client |
| 1:214 | NRS Client |
| 1:215 | iDataAgent for ProxyHost on Unix |
| 1:216 | Application Class 1 |
| 1:217 | Software Copy Manager |
| 1:218 | EZ Browse |
| 1:219 | MediaAgent |
| 1:220 | Application Class 3 |
| 1:221 | iDataAgent for MS SharePoint Document v1 |
| 1:222 | Quick Recovery Agent for MS Windows |
| 1:223 | Quick Recovery Agent for Unix |
| 1:224 | iDataAgent for IMAN |
| 1:225 | NRS Client |
| 1:226 | QSnap on MS Windows |
| 1:227 | iDataAgent for Serverless Data Manager on Unix |
| 1:228 | Application Class 2 |
| 1:229 | File System Archiving |
| 1:230 | Application Class 3 |
| 1:231 | iDataAgent for NAS Restore Enabler |
| 1:232 | QR Enabler for ISSG |
| 1:233 | QR Enabler for SnapView |
| 1:234 | QR Enabler for Windows Volume Shadow Service |
| 1:235 | CommCell SNMP Enabler |
| 1:236 | QSnap on Unix |
| 1:237 | Centera Mount Path |
| 1:238 | MediaAgent |
| 1:239 | Application Class 1 |
| 1:240 | CommCell Explorer |
| 1:241 | Hardware Copy Manager |
| 1:242 | Server File System |
| 1:243 | Server File System |
| 1:244 | iDataAgent for Image Level on Windows |
| 1:245 | Application Class 3 |
| 1:246 | Offline Content Indexing Connector |
| 1:247 | QR Enabler for Echo View |
| 1:248 | VaultTracker Enterprise |
| 1:249 | File System Archiving |
| 1:250 | Disk Library Connector (DDO) |
| 1:251 | Data Encryption |
| 1:252 | Data Verification |
| 1:253 | Data Multiplexing |
| 1:254 | CommCell Migration |
| 1:255 | Application Class 3 |
| 1:256 | WORM Media Support |
| 1:257 | GridStore |
| 1:258 | Application Class 1 |
| 1:259 | Application Class 1 |
| 1:260 | iDataAgent for Recovery Directory |
| 1:261 | File System Archiving |
| 1:262 | QR Enabler for OSSV |
| 1:263 | Server File System |
| 1:264 | iDataAgent for Image Level on Unix |
| 1:265 | iDataAgent for ProxyHost for Image Level on Windows |
| 1:266 | iDataAgent for ProxyHost for Image Level on Unix |
| 1:267 | QR Enabler for ONTAP |
| 1:268 | CommClient Base |
| 1:269 | CommServe Storage Manager |
| 1:270 | MediaAgent |
| 1:271 | NAS MediaAgent Client Software |
| 1:272 | License activation failed.<String> Duplicate license key detected. |
| 1:273 | The license you are trying to apply is of type [<String>]. When installing a fresh CommServe, only a license of type NEW can be used. |
| 1:274 | Cannot change the OEM type of the CommServe from [<String>] to [<String>]. Only OEM upgrades are allowed. |
| 1:275 | Once a CommServe is installed, a license of type New cannot be used again. |
| 1:276 | Invalid operation. Cannot convert a permanent CommServe to an Evaluation CommServe. |
| 1:277 | The platform type in the license has to be 'Evaluation' since this is an Evaluation CommServe. |
| 1:278 | The platform type in the license should not be 'Evaluation' since this is a permanent CommServe. |
| 1:279 | License activation failed.<String> OEM Upgrade license type can only be applied to an Evaluation CommServe. |
| 1:280 | License activation failed with DB error [<String>]; failed to update the license table. |
| 1:281 | License activation failed.<String> There is no license of type [<String>] in the database currently to be deleted. |
| 1:282 | License activation failed.<String> There is a license of type [<String>] already present in the database and cannot be added again. |
| 1:283 | License activation failed.<String> This license of type [<String>] in the database is not 'evaluation' and cannot be made evaluation now. |
| 1:284 | DB error; failed to update the license list table. |
| 1:285 | License activation failed with DB error [<String>]; failed to update the license list table. |
| 1:286 | License activation failed with DB error [<String>]; failed to delete the license list table. |
| 1:287 | License activation failed.<String> DB Error. Could not get the CommCell information. |
| 1:288 | DB Error. Could not get the client table information. |
| 1:289 | DB Error; failed to insert into license key table. |
| 1:290 | DB Error. Failed to update the CommCell table. |
| 1:291 | DB Error. Failed to insert into CommCell table. |
| 1:292 | DB Error. Failed to insert into client table. |
| 1:293 | DB Error. Failed to insert into platform table. |
| 1:294 | DB Error. Failed to insert into simclientapplication table. |
| 1:295 | DB Error. Failed to get the CommCell ID from the registry. |
| 1:296 | Failed to configure one of the CommCell level licenses in the database. |
| 1:297 | App manager error: Failed to create the appId. Error : [<String>] |
| 1:298 | App manager error: Failed to get the network hostname for the CommServe. Error : [<String>] |
| 1:299 | Job manager error: Failed to populate the activity control tables. |
| 1:300 | License activation failed.<String> Failed to log on the user with the supplied credentials. |
| 1:301 | License activation failed.<String> Failed to impersonate the logged on user. |
| 1:302 | Failed to get the product's install directory from the registry. |
| 1:303 | The old IP address in the license [<String>] does not match the IP address of the earlier CommServe [<String>]. |
| 1:304 | License activation failed.<String> The OEM type in the license [<String>] does not match the OEM type [<String>] in the database.<String> OEM types can be changed only by activating a OEM Upgrade license and not [<String>] license. |
| 1:305 | Failed to copy the HTML files during the OEM Upgrade/New install. |
| 1:306 | Failed to set the OEM-specific properties in the database. |
| 1:307 | DB Error. Failed to get the CommCell operating mode info from the CommCell table. |
| 1:308 | DB Error; failed to get the license key record from the database. |
| 1:309 | DB Error. Failed to update a record in the CommServe database. |
| 1:310 | Disaster Recovery Machine ID not present in the CommServe license key. |
| 1:311 | 1-Touch Server For Unix |
| 1:312 | Application Class 3 |
| 1:313 | Application Class 3 |
| 1:314 | Content Addressed Storage |
| 1:315 | Optical Media Support |
| 1:316 | Optical Media Support |
| 1:317 | CommCell Readiness Check |
| 1:318 | Advanced File System iDA Options |
| 1:319 | 1-Touch Server for MS Windows |
| 1:320 | Erase Data |
| 1:321 | Client Groups |
| 1:322 | Disk Mount Path Sharing |
| 1:323 | iDataAgent for Linux File System on s390 Mainframe |
| 1:324 | iDataAgent for Linux File System on Itanium |
| 1:325 | Advanced Copy Features |
| 1:326 | Advanced Media Management Features |
| 1:327 | iDataAgent for MS SharePoint Document |
| 1:328 | NAS Client |
| 1:329 | License activation successful. |
| 1:330 | Failed to get the IP list. |
| 1:331 | This license key has already been applied on this CommServe. The same license file cannot be applied again. |
| 1:332 | The IP Address in the database <String> does not match the IP address(es) of CommServe <String>. |
| 1:333 | Failed to open the license file [<String>] for reading. An invalid License File has been detected. |
| 1:334 | The word [KEY:] was not found in the license file [<String>]. An invalid License File has been detected. |
| 1:335 | The word [Commvault License END:] was not found in the license file [<String>]. An invalid License File has been detected. |
| 1:336 | Failed to read product release version from the CommServe registry. |
| 1:337 | The CommServe registry does not contain a valid tag. |
| 1:338 | The CommServe registry contains an invalid release number in it. |
| 1:339 | The platform type of the CommServe [<Number>] does not match the platform type in the license key [<Number>]. |
| 1:340 | The IP address in the license file [<String>] does not match any of the IP addresses of this CommServe [<String>]. Please obtain an IP Address Change license from your software provider. |
| 1:341 | Failed to read the registry for client name and client host names. |
| 1:342 | Failed to get the simsystem OS ID from the database for the CommServe. |
| 1:343 | DB Error. Failed to update the CommCell operating mode information in the CommCell table. |
| 1:344 | The directory [<String>] does not exist. Failed to copy the HTML files during the OEM Upgrade/New install. |
| 1:345 | No Default_.htm files found under the directory [<String>]. |
| 1:346 | Failed to copy [<String>] to [<String>]. Reason: [<String>]. |
| 1:347 | Failed to find the next default_.htm file. Reason: [<String>]. |
| 1:348 | The parameter passed in release [<String>] is not valid. Invalid release parameter detected. |
| 1:349 | iDataAgent for EMC Centera NAS |
| 1:350 | iDataAgent for Oracle RAC |
| 1:351 | DataArchiver for MS Exchange Public Folder |
| 1:352 | File System Archiving |
| 1:353 | ContinuousDataReplicator for MS Windows |
| 1:354 | Data Classification Enabler |
| 1:355 | VaultTracker |
| 1:356 | Libraries |
| 1:357 | Drives |
| 1:358 | Slots |
| 1:359 | The license type [<Number>] is not a valid license type. An invalid application type has been detected. |
| 1:360 | There are no free licenses available for [<String>]. Please obtain a new license file with additional licenses from your software provider. |
| 1:361 | The application license evaluation date has expired for [<String>]. |
| 1:362 | Database Error. Failed to update the license list table for license type [<Number>]. |
| 1:363 | Database error; failed to get the license type for ClientId [<Number>] and Apptype [<Number>]. |
| 1:364 | This license [<String>] is not a CommCell level license. Call a different function for this verification. |
| 1:365 | Commvault |
| 1:366 | HP_NAS |
| 1:367 | HP-UX_EXCH_NAS |
| 1:368 | HP-UX |
| 1:369 | Sun Microsystems |
| 1:370 | Dell ContentStore Server |
| 1:371 | Dell ContentStore Server Pro |
| 1:372 | Dell - Data Center |
| 1:373 | DELL ContentStore Enterprise |
| 1:374 | StorageTek |
| 1:375 | StoneFly Backup Express |
| 1:376 | NEI |
| 1:377 | Hitachi Data Protection Suite |
| 1:378 | Failed to find a particular character in the license key. |
| 1:379 | Failed to find an entry in the client table for the CommServe. The host name of the client does not match. |
| 1:380 | This license is not available. |
| 1:381 | CommCell ID in the license key [<Number>] does not match the CommCell ID [<Number>] found in the CommCell table for CommCell [<String>]. |
| 1:382 | Failed to find an entry in the CommCell table for the CommCell name [<String>]. Please contact your software provider. |
| 1:383 | De-Configuring the CommCell level feature [<String>] failed. |
| 1:384 | Failed to encode the license type [<Number>]. |
| 1:385 | Database error; failed to insert a record into license list table. |
| 1:386 | Database error; failed to insert a record into license list table for license type [<Number>]. |
| 1:387 | Database error; failed to update a record in license list table. |
| 1:388 | Database error; failed to update a record in license list table for license type [<Number>]. |
| 1:389 | Database error; failed to delete a record from license list table. |
| 1:390 | Database error; failed to delete a record from license list table for license type [<Number>]. |
| 1:391 | DB Error. Inserting default entries in client, CommCell, platform and simclientapps due to failed CommServe installation. |
| 1:392 | Failed to consume the CommCell level license [<String>] on the CommServe. Please contact your software provider. |
| 1:393 | Failed to get license information from the passed in license file/key. |
| 1:394 | The license is not available. |
| 1:395 | The license [<String>] has expired. Expiration date is [<String>]. |
| 1:396 | The license [<String>] is not in the installed state on client [<String>]. |
| 1:397 | No record found in Lic_Usage table for license type [<Number>] and client ID [<Number>]. |
| 1:398 | No record found in license key table for CommServe. |
| 1:399 | There are not enough free tokens to continue the install for license [<String>] on this CommServe. |
| 1:400 | There are not enough free tokens available on this CommServe. Tokens needed : [<Number>] and Tokens free : [<Number>] |
| 1:401 | There are not enough free tokens available on this CommServe. |
| 1:402 | No record found in the database. |
| 1:403 | No record found in license type and apptype map table for license type [<Number>]. |
| 1:404 | No record found in license type and apptype map table. |
| 1:405 | More than one application type found for license type [<Number>] in license type and apptype map table; number of application types found = [<Number>] |
| 1:406 | More than one application type found for a license type in license type and apptype map table. |
| 1:407 | Failed to get the OEM ID of the CommServe. |
| 1:408 | There are already [<Number>] licenses of type [<Number>] installed on this CommServe with OEM ID[<Number>]. No more installs of this license type [<Number>] allowed. |
| 1:409 | This CommServe has reached the maximum number of clients that can be protected. Please contact Customer Support. |
| 1:410 | The configuration ID passed represents that no configuration ID check is needed. |
| 1:411 | License upgrade from prior scheme to new licensing scheme failed. |
| 1:412 | Failed to generate a license. |
| 1:413 | The install date is in the future. This is not allowed. |
| 1:414 | The installation date for license [<String>] on client [<String>] is a future date [<String>]. Today's date is [<String>]. This is not allowed. |
| 1:415 | Failed to check for free tokens available on the CommServe. |
| 1:416 | Database Error: Failed to get the drive pool info from drive pool ID. |
| 1:417 | Database Error: Failed to get the drive pool info from drive pool ID[<Number>]. |
| 1:418 | Database Error: Failed to get the library name from library ID. |
| 1:419 | Database Error: Failed to get the library name from library ID [<Number>]. |
| 1:420 | Database Error: Failed to insert row into table [<String>]. |
| 1:421 | Database Error: Failed to insert row into User Preference table. |
| 1:422 | Invalid License Key Error: Invalid product ID detected. |
| 1:423 | Invalid License Key Error: Invalid OEM ID detected in the 25-character license key. |
| 1:424 | Failed to convert evaluation licenses to permanent. There are no free permanent licenses to convert. |
| 1:425 | Database Error: Failed to get the license usage counts from the CommServe database. |
| 1:426 | Failed to convert the token number to base 35 string(5 character string). |
| 1:427 | Failed to generate an IP address change license. |
| 1:428 | You cannot update a license that was generated prior to the license that is already applied on this CommServe. |
| 1:429 | The current license being applied was generated on [<String>] but the license already applied on this CommServe was generated on [<String>]. Only licenses generated later than all licenses applied can be updated. |
| 1:430 | Database error; failed to update a record in Notification Rule table. |
| 1:431 | Cluster Group |
| 1:432 | Recovery Points |
| 1:433 | Database Error. Failed to get the Expiry Date information of the evaluation installations from the CommServe database. |
| 1:434 | File System Configuration |
| 1:435 | SQL Server Configuration |
| 1:436 | Exchange Configuration |
| 1:437 | Domino Configuration |
| 1:438 | SharePoint Configuration |
| 1:439 | Oracle Configuration |
| 1:440 | [<String>] Evaluation Licenses: Issued [<Number>] Consumed [<Number>]. At least # of permanent licenses issued should be equal to consumed evaluation licenses. |
| 1:441 | Failed to extend the evaluation period for all evaluation license installs. |
| 1:442 | OEM Upgrade cannot continue. The issued license file does not have all the licenses issued to accommodate all the licenses installed. |
| 1:443 | No record found in database for client id [<Number>] and license type [<Number>]. |
| 1:444 | No record found in database table for client id [<Number>] and application type [<Number>]. |
| 1:445 | The license issued has [<Number>] permanent tokens. But tokens consumed is [<Number>]. Permanent tokens issued should be at least equal to consumed tokens. |
| 1:446 | Permanent tokens issued is less than consumed. Cannot continue the license update. |
| 1:447 | The license count cannot be fixed. Either there are no more licenses to free or all licenses are consumed. |
| 1:448 | Version of the server (for the license key that is being applied) does not support one or more currently configured license types. Either uninstall these license types or contact your account representative to obtain appropriate license key |
| 1:449 | Version of the server (for the license key that is being applied) does not support one or more currently configured license types. Either uninstall these license types or contact your account representative to obtain appropriate license key |
| 1:450 | Version of the server (for the license key that is being applied) does not support one or more currently configured license types, config [<String>]. Either uninstall these license types or contact your account representative to obtain appropriate license key |
| 1:451 | Version of the server (for the license key that is being applied) does not support one or more currently configured license types, config [<String>]. Either uninstall these license types or contact your account representative to obtain appropriate license key |
| 1:452 | Replication Configuration |
| 1:453 | License is in un-installed state. Check license logs. |
| 1:454 | The required license has expired. |
| 1:455 | DataArchiver for MS SharePoint |
| 1:456 | Application Class 3 |
| 1:457 | Application Class 1 |
| 1:458 | De-Duplication SIS Enabler |
| 1:459 | ContinuousDataReplicator for Unix |
| 1:460 | Content Indexing Node |
| 1:461 | Content Indexing Client |
| 1:462 | NetApp Express |
| 1:463 | Commvault Express |
| 1:464 | NetApp Snapshot Enabler |
| 1:465 | Web Search Server |
| 1:466 | Directory Service Integration |
| 1:467 | BULL Data Protection Suite |
| 1:468 | Auxiliary Copy Encryption |
| 1:469 | SQL BackTrack OBSI |
| 1:470 | Compliance Search |
| 1:471 | SharePoint Search Connector |
| 1:472 | Virtual Server |
| 1:473 | MS Outlook Web Access Proxy |
| 1:474 | Legal Hold |
| 1:475 | Deprecated message. |
| 1:476 | Deprecated message. |
| 1:477 | Deprecated message. |
| 1:478 | Deprecated message. |
| 1:479 | Deprecated message. |
| 1:480 | Deprecated message. |
| 1:481 | Deprecated message. |
| 1:482 | Deprecated message. |
| 1:483 | Deprecated message. |
| 1:484 | Failed to update the database. |
| 1:485 | DB2 DPF |
| 1:486 | Online Content Indexing Connector |
| 1:487 | Application Class 1 |
| 1:488 | Workstation Backup |
| 1:489 | Exchange Offline DB Mining Administrative Tool |
| 1:490 | Offline Mining Enabler |
| 1:491 | Virtual Server |
| 1:492 | Offline Mining Enabler |
| 1:493 | Application Class 1 |
| 1:494 | Hardware Snapshot Enabler |
| 1:495 | Automated content classification |
| 1:496 | Data Tagging |
| 1:497 | ERM Connector |
| 1:498 | Offline Mining Enabler |
| 1:499 | An evaluation extension license OEM should match the OEM type of the CommServe |
| 1:500 | De-Duplication Block Level |
| 1:501 | De-Duplication to Tape |
| 1:502 | Free License |
| 1:503 | The license file contains non-express Cell Licenses [%s] for Express CommServe. |
| 1:504 | Metrics Reporting Server |
| 1:505 | Monitored Ops Clients |
| 1:506 | Deprecated message. |
| 1:507 | Developer License |
| 1:508 | Deprecated message. |
| 1:509 | DataArchiver for Domino Document for UNIX |
| 1:510 | Index Cache Server |
| 1:511 | Application Class 1 |
| 1:512 | Object Link |
| 1:513 | Sybase IQ |
| 1:514 | Foreign Data Discovery Agent |
| 1:515 | Deprecated message. |
| 1:516 | Deprecated message. |
| 1:517 | Application Class 1 |
| 1:518 | External Data Connector |
| 1:519 | Deprecated message. |
| 1:520 | Sharepoint Online Search Connector |
| 1:521 | Library Sharing Across CommCells |
| 1:522 | Object Store |
| 1:523 | Cloud Storage |
| 1:524 | SAP ArchiveLink |
| 1:525 | Deprecated message. |
| 1:526 | Documentum for UNIX |
| 1:527 | Subscription Based Cloud Storage |
| 1:528 | Available license check failed. |
| 1:529 | This license [<String>] is not available at this time. |
| 1:530 | The <String> license [<String>] is not available. |
| 1:531 | Data Protection Core infrastructure |
| 1:532 | Backup |
| 1:533 | Data Archive Core infrastructure |
| 1:534 | Archive |
| 1:535 | Eval capacity license [<String>] cannot be added when permanent once already exists. |
| 1:536 | NetApp Snap Management |
| 1:537 | NetApp Cloud |
| 1:538 | Remote Operation Management Service |
| 1:539 | Search Server |
| 1:540 | Advanced document |
| 1:541 | Linguistic |
| 1:542 | Dell Snap Management |
| 1:543 | Virtual Machines |
| 1:544 | Protected Mailboxes |
| 1:545 | Archived Mailboxes |
| 1:546 | Content indexed Mailboxes |
| 1:547 | Disk Library Space (TB) |
| 1:548 | Deduplication Active Store Capacity |
| 1:549 | Content Indexing Advanced Linguistic Support |
| 1:550 | NetApp Disk Library |
| 1:551 | Content Indexed Objects (In Millions) |
| 1:552 | Failed to read the existing license type [<String>] from the CommServe. Please contact your software provider. |
| 1:553 | Failed to decrypt license key from the license file. Please contact your software provider. |
| 1:554 | The active licensed IP address [<String>] does not match any of the IP addresses of this CommServe [<String>]. Please obtain an IP Address Change license from your software provider. |
| 1:555 | The active licensed IP address [<String>] does not match any of the IP addresses of this CommServe [<String>]. Please obtain an IP Address Change license from your software provider. |
| 1:556 | The original licensed IP address [<String>] does not match any of the IP addresses of this CommServe [<String>]. |
| 1:557 | The number of new permanent licenses of license type [<String>] is [<String>], which is less than the number currently in use [<String>]. Please obtain a sufficient number of new licenses. |
| 1:558 | The number of new evaluation licenses of license type [<String>] is [<String>], which is less than the number currently in use [<String>]. Please obtain a sufficient number of new licenses. |
| 1:559 | You cannot mix evaluation and permanent Capacity Or Usage based licenses. |
| 1:560 | Content Indexed Objects |
| 1:561 | The CommCell ID in the License file does not match this CommServe. Please obtain a license with the correct CommCell ID [<String>] from your software provider |
| 1:562 | Existing feature license cannot be released because feature is in use. Please contact your software provider. |
| 1:563 | Snapshot |
| 1:564 | Replication |
| 1:565 | <String> capacity license is required to run jobs. |
| 1:566 | <String> license has been expired. |
| 1:567 | The usage for <String> has exceeded the licensed capacity. Please purchase additional capacity licenses. Until the new license is applied, click on the RESET button in control panel license administration window to temporarily allow jobs. |
| 1:568 | Failed to get the license status for <String>. |
| 1:569 | The amount of data to be protected [<String>] exceeds the limit of [<String>] for the [<String>] Capacity license. |
| 1:570 | VM Sockets |
| 1:571 | Protected Virtual Machines |
| 1:572 | Virtual Machine Provisioning |
| 1:573 | Virtual Machine Archiving |
| 1:574 | Virtual Machine Snapshot |
| 1:575 | CPU Socket Based Virtual Machine Snapshot |
| 1:576 | End point users |
| 1:577 | End point sharing users |
| 1:578 | End point E-discovery users |
| 1:579 | Permanent |
| 1:580 | License activation failed because of missing GUID in the new license key. Please obtain a new license file with GUID [<String>]. |
| 1:581 | GUID [<String>] in the license file does not match this CommServe. Please obtain a license with the correct GUID [<String>] from your software provider. |
| 1:582 | License [<String>] and [<String>] are mutually exclusive. Please obtain a license with only one of the licenses included. |
| 1:583 | Application Class Virtual |
| 1:584 | Serial No [<String>] and Registration Code [<String>] in the license file do not match this CommServe. Please obtain a license with the correct Serial No [<String>] and Registration Code [<String>] from your software provider. |
| 1:585 | Mailbox archive solution |
| 1:586 | Failed to apply the license file because it contains both finite and unlimited quantities for capacity licenses. |
| 1:587 | Existing feature license [<String>] cannot be released because feature is in use. Please contact your software provider. |
| 1:588 | Could not connect to License Server. Please ensure the Private Metrics URLs are set. |
| 1:589 | The license file cannot be applied because it expired on [<String>]. Contact your software provider for assistance. |
| 1:590 | Appliance Store Usage |
| 1:591 | Application Server |
| 1:592 | File System Only Server |
| 1:593 | CIFN Enabler |
| 1:594 | Office 365 Sharepoint |
| 1:595 | Commvault Complete Enabler |
| 1:596 | Operating Instances |
| 1:597 | Virtual Operating Instances |
| 1:598 | Activate E-Discovery For Email/Cloud Apps |
| 1:599 | Activate E-Discovery For Files |
| 1:600 | Activate Sensitive Data For Email/Cloud Apps |
| 1:601 | Activate Sensitive Data For Files |
| 1:602 | Activate Suite |
| 1:603 | File Storage Optimization |
| 1:604 | Auto Recovery |
| 1:605 | The amount of data to be protected [<String>] exceeds the limit of [<String>] for the [<String>] license. |
| 1:606 | Metallic Recovery Reserve |
| 1:607 | Metallic Recovery Reserve user agreement is not accepted. |
| 1:608 | Metallic Recovery Reserve T10 |
| 1:609 | Metallic Recovery Reserve T2 |
| 1:610 | Metallic Recovery Reserve T3 |
| 1:611 | Metallic Recovery Reserve T4 |
| 1:612 | Metallic Recovery Reserve T5 |
| 1:613 | Metallic Recovery Reserve T6 |
| 1:614 | Metallic Recovery Reserve T7 |
| 1:615 | Metallic Recovery Reserve T8 |
| 1:616 | Metallic Recovery Reserve T9 |
| 1:617 | Commvault Backup & Recovery for Unstructured data |
| 1:618 | HyperScale Storage |
| 1:619 | Metallic Cloud Storage Service T11 |
| 1:620 | Metallic Cloud Storage Service T12 |
| 1:621 | Metallic Cloud Storage Service T13 |
| 1:622 | Metallic Cloud Storage Service T14 |
| 1:623 | Metallic Cloud Storage Service T15 |
| 1:624 | Metallic Cloud Storage Service T16 |
| 1:625 | Metallic Cloud Storage Service T17 |
| 1:626 | Metallic Cloud Storage Service T18 |
| 1:627 | Metallic Cloud Storage Service T19 |
| 1:628 | Metallic Cloud Storage Service T20 |
| 1:629 | Activate Data Governance For Endpoints |
| 1:630 | Activate Data Governance For Virtual Machines |
| 1:631 | Activate E-Discovery For Endpoints |
| 1:632 | Activate E-Discovery For Virtual Machines |
| 1:633 | File Storage Optimization for Endpoints |
| 1:634 | File Storage Optimization for Virtual Machines |
| 1:635 | Risk Analysis Enabler |
| 1:636 | Risk Analysis For VMs |
| 1:637 | Threat Scan For Files |
| 1:638 | Threat Scan For VMs |
| 1:639 | License is not consumed by agent [<String>] on client [<String>]. Try Release/Reconfigure agent [<String>] license on client [<String>] and then run the job again. |
| 1:640 | SaaS Ring |
| 1:641 | Recovery Groups |
| 1:642 | Kubernetes VOI Enabler |
| 1:643 | Active Directory - Enterprise |
| 1:644 | Active Directory - Standard |
Data Set Manager
| 13:1 | Data Aging forecast has started. |
| 13:2 | Data Aging has started. |
| 13:3 | Failure to retrieve CommServe name. |
| 13:4 | Failure to initialize job object. |
| 13:5 | Failure to initialize job control object. |
| 13:6 | Exiting with errors - some files may not have been pruned. |
| 13:7 | Data Aging completed successfully. |
| 13:8 | <String> job for storage policy [<String>] starts. Total amount of data: <Number> <String>. |
| 13:9 | Received job interrupt - exiting. |
| 13:10 | Data Aging successful. |
| 13:11 | Failed to retrieve Storage Policy list. |
| 13:12 | Failed to retrieve Storage Policy copy list. |
| 13:13 | Failed to retrieve Application IDs. |
| 13:14 | Failed to retrieve Storage Policy properties. |
| 13:15 | Failed to retrieve properties of Auxiliary Copy [<String>] Storage Policy [<String>]. -- Copy skipped. |
| 13:16 | Error retrieving Storage Policy [<String>] properties: [<String>] -- Continuing with next Storage Policy. |
| 13:17 | Job completed and failed to verify some chunks. |
| 13:18 | Attached to source MediaAgent [<String>]. |
| 13:19 | Failed to attach to source MediaAgent [<String>]. |
| 13:20 | Failed to read chunk [<Number>] in media [<String>] for storage policy [<String>] copy [<String>]: <String>. |
| 13:21 | Failed to read from chunk [<Number>]. <String> |
| 13:22 | Failed to initialize connection to Media Manager - exiting. |
| 13:23 | Out of memory. |
| 13:24 | No <String> Copy with precedence [<Number>] available for Storage Policy [<String>]. |
| 13:25 | There are applications associated with Storage Policy [<String>] which require more streams than will remain after decrementing the number of streams. |
| 13:26 | Failed to retrieve subclients associated with Storage Policy [<String>] CommCell [<Number>]. Please call the support hotline. |
| 13:27 | Invalid installation. Please call the support hotline of your software vendor. |
| 13:28 | CommServe internal error [<String>]. Please call the support hotline. |
| 13:29 | Unable to communicate with CommServe on host [<String>]. Please check the network connectivity between the Client and CommServe, and verify this product's Communication Service is running on the CommServe. |
| 13:30 | Unable to communicate with MediaAgent on host [<String>]. Please check the network connectivity between the Client and MediaAgent, and verify this product's Communication Service is running on the MediaAgent. |
| 13:31 | Unable to determine MediaAgent name. Make sure that Storage Policy settings are accurate. |
| 13:32 | Unable to determine data pipe configuration. Make sure that Storage Policy settings are accurate. |
| 13:33 | Failed to retrieve uncopied jobs for Storage Policy [<String>] Copy [<String>]. |
| 13:34 | Failed to retrieve uncopied archive files of backup job [<Number>] for Auxiliary Copy [<String>] from Default Copy [<String>] Stream [<Number>]. |
| 13:35 | Failed to mark job [<Number>] copied for Storage Policy [<String>] Copy [<String>]. |
| 13:36 | <String> Copy is not supported by <String> iDataAgent. No data will be copied for this iDataAgent. |
| 13:37 | Duplicate archPipeConfig records of app [<Number>] were found. Operation will continue. Please call the support hotline. |
| 13:38 | No archPipeConfig record of app [<Number>] CommCell [<Number>] was found. Use default values. Please check the Subclient Properties - Software Compression. |
| 13:39 | Failed to gather information for Storage Policy [<String>] when retrieving storage policy list. |
| 13:40 | Failover for copy [<String>] in storage policy [<String>] is performed for job [<Number>], the MediaAgent has been failed over from [<String>] to [<String>], the Drive Pool has been switched from [<String>] to [<String>]. |
| 13:41 | Skipping pruning of OSSV volumes as there are OSSV jobs running. |
| 13:42 | Failed to check for running OSSV jobs. No OSSV volumes will be pruned. Error: [<String>] |
| 13:43 | Invalid pass-phrase specified. Please check the spelling and try again. |
| 13:44 | A valid passphrase is required to restore this client encrypted data. |
| 13:45 | Unable to unlock data encryption key for archive file [<Number>]. The private key for client [<String>] was not found in memory. User probably did not specify a passphrase. If this is a Synthetic Full backup, please make sure that [Enable Synthetic Full] button is checked in the client properties. |
| 13:46 | Datapipe error: detected some data that was not uncompressed in the pipeline. |
| 13:47 | Datapipe error: detected some data that was not decrypted in the pipeline. |
| 13:48 | Data is partially pruned due to database problem. |
| 13:49 | Failed to prune data due to database problem. |
| 13:50 | Data is not fully pruned because job was killed. |
| 13:51 | Failed to delete from ArchDB2Log table due to database problem. |
| 13:52 | Failed to prune job history due to database problem. |
| 13:53 | Failed to prune non-backup job history due to database problem. |
| 13:54 | Failed to prune unused subclient properties due to database problem. |
| 13:55 | Failed to prune CommCell history due to database problem. |
| 13:56 | Failed to prune Audit Trail records due to database problem. |
| 13:57 | Failed to prune SQL backup set from SQL clients. |
| 13:58 | Failed to cross-check Oracle clients. |
| 13:59 | Failed to prune OSSV volumes. |
| 13:60 | Multiple Data Aging errors occurred. Please see related events and have a look at the log file. |
| 13:61 | No data path for storage policy [<String>] |
| 13:62 | Unable to communicate with Auxiliary Copy process on MediaAgent [<String>]. |
| 13:63 | A CommServe database query failed. See logs on CommServe for details. |
| 13:64 | Failed to parse job's restart string. Job cannot start. |
| 13:65 | Job's task ID is invalid. Job cannot start. |
| 13:66 | Failed to get media ID for data verification. Job cannot start. |
| 13:67 | Media ID is not in CommServe database. Job cannot start. |
| 13:68 | Job's GUI sequence number is invalid. Job cannot start. |
| 13:69 | This storage policy has no active secondary copies. |
| 13:70 | Job is for one storage policy copy but its start time is in the future. |
| 13:71 | Job is for one storage policy copy but this copy no longer exists. |
| 13:72 | Failed to retrieve storage policy ID and copy ID. Job cannot start. |
| 13:73 | No copy exists for the storage policy. |
| 13:74 | No secondary copy exists for the storage policy. |
| 13:75 | No auto copy exists for the storage policy. |
| 13:76 | Job is for all copies of a storage policy but their start times are in the future. |
| 13:77 | Failed to get type of drive pool. |
| 13:78 | No data needs to be copied, the to-be-copied jobs are deferred or the source copy doesn't have the required job. |
| 13:79 | No data needs to be verified. |
| 13:80 | Insufficient resources allocated for job. Job will go pending and resume. |
| 13:81 | Auxiliary Copy will not run for a deferred copy. There is no valid license for advanced copy. |
| 13:82 | Data multiplexing is currently enabled for one or more storage policy copies. |
| 13:83 | Advanced copy features such as inline copy and deferred copy are currently enabled for one or more storage policy copies. Please uncheck the Inline and Deferred-Copy options from those storage policies. |
| 13:84 | Failed to prune selective deletion jobs due to a database problem. |
| 13:85 | A time-out has occurred while initializing data transfer with MediaAgent [<String>]. Please check the following n If this is a LAN Data Transfer, check network connectivity between the Client and MediaAgent. n For Network Free Data Transfer verify that there are no issues with the secondary storage device on the MediaAgent. |
| 13:86 | The MediaAgent [<String>] failed to connect back to the Client [<String>]. Please check the network connectivity between the Client and MediaAgent, and verify that the MediaAgent's name resolution for the Client's host name. |
| 13:87 | Some archive files are copied but not marked as valid. Please see related events and have a look at log files. |
| 13:88 | Some backup jobs completed or some backup jobs were selected after this job started or next batch of jobs are selected. Start copying/verifying more data. |
| 13:89 | A thread of Auxiliary Copy process on MediaAgent is hanging. Please check resources and see if it sticks on any hardware. |
| 13:90 | Failed to clean aged disk chunks from database. |
| 13:91 | Failed to prune to-be-pruned extended jobs from database. |
| 13:92 | Failed to reset reference time for iDataAgents. |
| 13:93 | Failed to clean up database after Oracle cross-check due to database problem. |
| 13:94 | Oracle Cross-Check failed for some instances. |
| 13:95 | Unable to set primary copy. See logs for details. |
| 13:96 | Unable to set primary copy. There are running backup or Auxiliary Copy jobs for the storage policy. |
| 13:97 | Unable to change the effective date of a storage policy copy to a past date. |
| 13:98 | Unable to prune or disable the last full cycle of a subclient in primary copy. There are running jobs for this subclient. |
| 13:99 | Auxiliary Copy to the same library is disabled. No Auxiliary Copy for destination copy [<String>] library [<String>]. |
| 13:100 | Unable to get source MediaAgent. <Message> |
| 13:101 | Auxiliary Copy for multiplexed data to a Deduplication enabled library is not supported. No Auxiliary Copy for destination copy [<String>] library [<String>]. |
| 13:102 | MediaAgent [<String>] version is too low to restore data to this client. Please upgrade the MediaAgent. |
| 13:103 | Unable to get pipeline information from CommServe. |
| 13:104 | Failed to reset manual retention of jobs after the expiration date reached. |
| 13:105 | Database error. Please see related events and have a look at the log file. |
| 13:106 | Failed to delete job history without matching archiver file. |
| 13:107 | Database error. Please see related events and have a look at the log file. |
| 13:108 | Content Indexing start time is in the future for storage policy [<String>]. Job cannot start. |
| 13:109 | Content Indexing is not enabled for storage policy [<String>]. Job cannot start. |
| 13:110 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Subclient [<String>]. |
| 13:111 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>]. |
| 13:112 | No valid <Message> data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Subclient [<String>]. |
| 13:113 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Subclient [<String>] before [<String>]. |
| 13:114 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Subclient [<String>] after [<String>]. |
| 13:115 | No non-aged valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Subclient [<String>] before [<String>]. |
| 13:116 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Subclient [<String>] in Storage Policy [<String>] Copy [<String>] before [<String>]. |
| 13:117 | Auxiliary Copy will not run for a snapshot copy. |
| 13:118 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Instance [<String>] before [<String>]. |
| 13:119 | No valid backup data for Client [<String>] iDataAgent [<String>] Backup Set [<String>] Instance [<String>] before [<String>] with Copy Precedence [<Number>] Include Aged Data [<Number>]. |
| 13:120 | No valid backup data for Client [<String>] iDataAgent [<String>] Instance [<String>] before [<String>]. |
| 13:121 | No valid backup data for Client [<String>] iDataAgent [<String>] Instance [<String>] before [<String>] with Copy Precedence [<Number>] Include Aged Data [<Number>]. |
| 13:122 | Media Refresh is not enabled for the Storage Policy copy. |
| 13:123 | Media Refresh is not enabled for any copy of the Storage Policy. |
| 13:124 | Deduplication Database Sync is not enabled for the Storage Policy copy. |
| 13:125 | No data was found for Deduplication Database Sync. |
| 13:126 | No media to refresh. |
| 13:127 | Error occurred while processing chunk [<Number>] in media [<String>] for storage policy [<String>] copy [<String>]: <String>. |
| 13:128 | System has reached within <String> percent limit of [<String>] usage. |
| 13:129 | System has reached within <String> percent limit of [<String>] usage. System may start to disable options soon. |
| 13:130 | System has reached over <String> percent of the limit for [<String>] usage. Jobs may not run. |
| 13:131 | Number of 'Reset' attempts have exceeded the limit. Backup or Archiver jobs would not run. |
| 13:132 | For [<String>], Available Capacity: <Number> TB, Used Capacity: <Number>, Percentage of capacity used <Number>. |
| 13:133 | A few jobs have been skipped on copy [<String>/<String>] since they are multiplexed jobs. Please check JobManager logs for more details on which jobs have been skipped. Enable Media Management Aux Copy Configuration parameter [Allow multiplexed data to be copied to deduplication enabled storage policy copy] to copy them. |
| 13:134 | Following jobs [<String>] have been skipped on copy [<String>/<String>] since they are multiplexed jobs. Enable Media Management Aux Copy Configuration parameter [Allow multiplexed data to be copied to deduplication enabled storage policy copy] to copy them. |
| 13:135 | A few archive files have been skipped on copy [<String>/<String>] since old chunks from these archive files have not been fully deleted. |
| 13:136 | Job [<Number>] on copy [<String>/<String>] has been marked bad as one of its chunks on media is bad. |
| 13:137 | Disabled backup job [<Number>] on copy [<String>/<String>] since source copy encountered corrupt chunk error. |
| 13:138 | Error occurred while processing chunk [<Number>] in media [<String>], at the time of error in library [<String>] and mount path [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:139 | Error occurred while processing chunk [<Number>] in media [<String>], at the time of error in library [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:140 | Copy [<String>/<String>] was promoted as primary copy. As a result of this operation data path and media configurations on copies [<String>/<String>] and [<String>/<String>] may have been modified. |
| 13:141 | <String> |
| 13:142 | Cannot query CommServe database for information needed to restore corrupted DDB Store [<String>]. |
| 13:143 | Cannot connect to SIDB Engine [<String>]. Reason [<String>]. |
| 13:144 | Waiting for restore job(s) [<String>] to complete restoring DDB Store [<String>] at location(s) [<String>]. |
| 13:145 | Error restoring DDB Store files. Restore job(s) [<String>] encountered one or more errors. |
| 13:146 | Content Indexing process is waiting for pruning existing items to finish. Job will automatically resume after deletion is finished. |
| 13:147 | Job [<Number>] on copy [<String>/<String>] has been marked bad since data on its source copy was reported as bad. |
| 13:148 | Job was resumed but there is no data to copy. Perhaps some data that was to be copied was found to be corrupt in the last iteration of this job and was prevented from being copied. |
| 13:149 | No stream activity for [<Number>] hour(s) from source MediaAgent(s) [<String>]. |
| 13:150 | No stream activity for [<Number>] hour(s). |
| 13:151 | System has reached over <String> percent of the limit for [<String>] usage. Jobs may not run. Purchased quantity [<Number>]: consumed quantity [<Number>]. |
| 13:152 | License [<String>] has expired. Jobs may not run. |
| 13:153 | [<String>] license will get expired in [<Number>] days. Please call the support hotline of your software vendor. |
| 13:154 | Some jobs have encountered MediaAgent side failures during content indexing. These will be retried in the job's next attempt. |
| 13:155 | Some archive files have been skipped on copy [<String>/<String>] since old chunks from these archive files have not been fully pruned. |
| 13:156 | Some archive files from jobs [<String>] have been skipped on copy [<String>/<String>] since old chunks from these archive files have not been fully pruned. |
| 13:157 | Due to a running DDB backup job some archive files have been skipped on copy [<String>/<String>]. |
| 13:158 | Due to a running DDB backup job some archive files from jobs [<String>] have been skipped on copy [<String>/<String>]. |
| 13:159 | Some archive files have been skipped due to content indexing pruning failure. Please check AuxCopyMgr logs for more deails. |
| 13:160 | System has reached over <String> percent of the limit for [<String>] usage. Content Indexing job may not run. Purchased quantity [<Number>]: consumed quantity [<Number>]. |
| 13:161 | Jobs [<String>] from CommCell [<Number>] have been skipped on copy [<String>/<String>]. |
| 13:162 | Some jobs have been skipped on copy [<String>/<String>] since there is CCM data on the source copy. Please check events for more details. |
| 13:163 | Auxcopy job has been skipped on copy [<String>/<String>] since there is data from multiple commcells [<String>]. It is advised to copy jobs from one commcell to a new copy. |
| 13:164 | To Be Copied Data Exceeded |
| 13:165 | Old Jobs Not Copied |
| 13:166 | Need More Time To Copy Data |
| 13:167 | AuxCopyFallenBehind Alert To Be Copied Data Criteria is changed from GB to TB, please reconfigure the alert for the copy[<String>/<String>] if necessary. |
| 13:168 | No VM activity for [<Number>] hour(s). |
| 13:169 | Unable to communicate with CVCIAnalytics process on MediaAgent [<String>]. |
| 13:170 | SafeNet KeySecure returned invalid key. |
| 13:171 | Unable to unlock data encryption key for archive file [<Number>]. The private key for Storage Policy / copy [<String> / <String>] was not found in memory. |
| 13:172 | Jobs picked for content indexing are encrypted by pass phrase, and can not be content indexed. Please prevent content indexing on jobs which are encrypted by pass phrase. |
| 13:173 | Job [<Number>] on copy [<String>/<String>] has been marked bad by user. |
| 13:174 | Job [<Number>] on secondary copy [<String>/<String>] is disabled. |
| 13:175 | Job [<Number>] available on copy [<String>/<String>] has been prevented from Auxiliary Copy. |
| 13:176 | Job [<Number>] on copy [<String>/<String>] marked as Do Not copy. |
| 13:177 | Some backup jobs are skipped because they are aged on destination copy. |
| 13:178 | Global Dedupe Storage Policy is not associated with any Storage Policy Copies. |
| 13:179 | Unable to get job information. See logs for details. |
| 13:180 | Unable to get reservation response from JM. |
| 13:181 | Failed to process chunk [<Number>] in media [<String>] for storage policy [<String>] copy [<String>]: <String>. |
| 13:182 | Failed to process chunk [<Number>] in media [<String>], at the time of error in library [<String>] and mount path [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:183 | Failed to process chunk [<Number>] in media [<String>], at the time of error in library [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:184 | Storage policy copy [<String>/<String>] is having <String> data to copy and <Number> days oldest backup job in to be copied state. |
| 13:185 | Auxiliary Copy Fallen Behind alert is generated for the storage policy copy [<String>/<String>] which is having <String> data to copy. |
| 13:186 | Some backup jobs are skipped because they are aged on destination copy or marked do not copy or backup jobs are not available on source copy. |
| 13:187 | Some backup jobs are skipped because they are aged on destination copy or marked do not copy |
| 13:188 | Media [<String>] refreshed during the media refresh job. |
| 13:189 | Unable to communicate with onCommand Server. |
| 13:190 | Unable to validate SafeNet key for Storage Policy / copy [<String> / <String>].Please check following:n1. Check connectivity to SafeNet server.n2. Key is deleted or rolled over. |
| 13:191 | Unable to get SafeNet key for Storage Policy / copy [<String> / <String>].Please check following:n1. Check connectivity to SafeNet server.n2. Key is deleted or rolled over. |
| 13:192 | Some jobs [<String>] have been skipped on copy [<String>/<String>] since data verification failed on these jobs on source copy. |
| 13:193 | Incremental data verification job is converted to full. |
| 13:194 | Auxiliary copy job cannot run on Primary copy. |
| 13:195 | Failed to fetch correct restore encryption key.Error[<String>]. |
| 13:196 | Unable to reserve required resources. |
| 13:197 | No data in Deduplication database needs to be verified. |
| 13:198 | The size of archFile [<Number>] on destination copy [<Number>] is bigger than that on source copy. |
| 13:199 | Controller initialization failed on MediaAgent [<String>]. |
| 13:200 | Failed to start controller on MediaAgent [<String>]. |
| 13:201 | Failed to process chunk [<Number>] referred chunk [<Number>] in media [<String>], at the time of error in library [<String>] and mount path [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:202 | Error occurred while processing chunk [<Number>] referred chunk [<Number>] in media [<String>], at the time of error in library [<String>] and mount path [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:203 | Failed to get CVPassword V5 encryption key from CommServe. See logs on CommServe for details. |
| 13:204 | Some jobs have been skipped on copy [<String>/<String>] since data verification failed on these jobs on source copy. |
| 13:205 | Failed due to error in population of chunks to copy |
| 13:206 | Licensing information is over 24 hours old. Last successful update from License Server was at [<String>]. Please check connection to Metrics Server URL [<String>]. If connection issues are not resolved, backups will stop after [<String>]. Please check documentation for troubleshooting information [<String>]. |
| 13:207 | Some jobs [<String>] have been skipped on copy [<String>/<String>] since maximum device streams configured on storage policy is one. |
| 13:208 | Some jobs have been skipped on copy [<String>/<String>] since maximum device streams configured on storage policy is one. |
| 13:209 | Unable to unlock data encryption key. The private key for client's company was not found in memory. |
| 13:210 | Copy [<String>] belonging to Storage Policy [<String>] has <String> data yet to be copied. Fallen behind reason : ' <String> ' |
| 13:211 | The destination copy has multiple Deduplication Databases, Only Scalable Resources AuxCopy Jobs are supported for copies with multiple Active Deduplication Databases. |
| 13:212 | Unable to set primary copy. There are running backup or Auxiliary Copy jobs for the storage policy. Running jobs [<String>]. |
| 13:213 | Aux Copy is not supported for a Storage Policy configured with Commvault IBM i VTL. |
| 13:214 | Data Verification job with current selected options is not allowed to run on some configurations. Please contact your vendor's customer support. |
| 13:215 | DDB Verification job will be slower on Deduplication databases using cloud mouthpaths or created for HyperScale Storage Pool. |
| 13:216 | Restoring backup job [<Number>], Storage Policy[<String>], Copy [<String>], Backup time[<String>], Subclient [<String>] |
| 13:217 | Unable to set primary copy. User[<String>] does not have [<String>] permission on Global Storage Policy [<String>]. |
| 13:218 | Encrypted backups are mandated on this client. Encryption has been turned off or has not been set to encrypt on the Client. |
| 13:219 | Jobs of client(s) [<String>] have been skipped on copy [<String>/<String>] since force encryption is enabled on client(s) but copy encryption setting is store plain text. nADVICE: Review the copy's encryption settings. |
| 13:220 | Jobs of some clients have been skipped on copy [<String>/<String>] since force encryption is enabled on client(s) but copy encryption setting is store plain text. nADVICE: Review the copy's encryption settings. |
| 13:221 | Some jobs [<String>] have been skipped on copy [<String>/<String>] since Auxiliary copy to Snap Copy of VSA V2 jobs using OCUM (7-Mode) Replication are not supported, nADVICE: Please create separate Storage Policy without any secondary Snap Copies or remove the subclient association from Copy Properties. |
| 13:222 | Some jobs have been skipped on copy [<String>/<String>] since Auxiliary copy to Snap Copy of VSA V2 jobs using OCUM (7-Mode) Replication are not supported, nADVICE: Please create separate Storage Policy without any secondary Snap Copies or remove the subclient association from Copy Properties. |
| 13:223 | Some jobs [<String>] have been skipped on copy [<String>/<String>] since Auxiliary copy to Snap Copy of VSA V2 using OCUM Replication (C-Mode) jobs are not supported when data path media agent is below version 11.22, nADVICE: Please upgrade the data path media agents to version 11.22. |
| 13:224 | Some jobs have been skipped on copy [<String>/<String>] since Auxiliary copy to Snap Copy of VSA V2 jobs using OCUM Replication (C-Mode) are not supported when data path media agent is below version 11.22, nADVICE: Please upgrade the data path media agents to version 11.22. |
| 13:225 | The VM replication pair(s) has been configured. DR VM license is required to continue the operation. The VM replication jobs will stop after [<Number>] days of grace period without this license. Please call the support hotline of your software vendor. |
| 13:226 | Error occurred while replicating snaps [<String>], for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:227 | Unactivated license has been reapplied successfully. |
| 13:228 | Failed to reapply unactivated license with error [<String>]. |
| 13:229 | Failed to get compactable chunks count from SIDB Engine [<String>] in DV2 job. Reason [<String>]. |
| 13:230 | Unable to get configuration information for SIDB Engine [<String>]. Reason [<String>]. |
| 13:231 | Failed to get max chunk id verified by SIDB Engine [<String>] in DV2 job. Reason [<String>]. |
| 13:232 | No data to run full Dedupe DB Reconstruction job, if there is no data on store please seal it. |
| 13:233 | Cannot continue with the job as the Deduplication store has data on archive storage [<String>]. |
| 13:234 | Space reclamation job cannot be started as one of the mount paths associated to the store is being moved. |
| 13:235 | Disabled Snap Job [<Number>] on copy [<String>/<String>] as the snapshot is not available as per update from Job Manager. |
| 13:236 | Snap Job [<Number>] on copy [<String>/<String>] has been marked bad as the snapshot is not available as per update from Job Manager. |
| 13:237 | Space Reclamation job is not allowed as there is some data in a metallic cloud library |
| 13:238 | Some jobs [<String>] have been skipped on copy [<String>/<String>] as only cataloged NDMP backup are supported on cloud copy. |
| 13:239 | Error occurred [<String>] MediaAgent [<String>] mount path [<String>] |
| 13:240 | Error occurred [<String>] MediaAgent [<String>] |
| 13:241 | Deduplication local-cache-operation failure [^1s] |
| 13:242 | [<Message>] |
| 13:243 | [<Message>] [<Message>] |
| 13:244 | [<Message>] [<Message>] [<Message>] |
| 13:245 | [<Message>] [<Message>] [<Message>] [<Message>] |
| 13:246 | [<Message>] [<Message>] [<Message>] [<Message>] [<Message>] |
| 13:247 | [<Message>] [<Message>] [<Message>] [<Message>] [<Message>] [<Message>] |
| 13:248 | Data reader - internal error |
| 13:249 | Data writer - internal error |
| 13:250 | Deduplication failure |
| 13:251 | Cloud media |
| 13:252 | Dedupe cloud media |
| 13:253 | Disk media |
| 13:254 | Dedupe disk media |
| 13:255 | HP-StoreOnce media |
| 13:256 | NAS media |
| 13:257 | Centera media |
| 13:258 | Centera-V2 media |
| 13:259 | Server less media |
| 13:260 | Web-storage media |
| 13:261 | in media (<String>) , Path (<String>) |
| 13:262 | Media read operation failure |
| 13:263 | Media write operation failure |
| 13:264 | Advice: Please make sure that your device supports hardware encryption and it's functioning correctly. |
| 13:265 | Advice: To resume the job, please make sure that the mount path is online. |
| 13:266 | Advice: Please contact customer support for further assistance. |
| 13:267 | Advice: Please contact customer support for further assistance if the issue persists. |
| 13:268 | Advice: Please check CommServer connectivity. And contact customer support for further assistance if the issue persists. |
| 13:269 | Advice: Please check media accessibility. Contact customer support if issue persists. |
| 13:270 | Advice: Please verify with your hardware vendor. If device does not support hardware encryption, turn off the hardware encryption feature from GUI Console and retry the operation. |
| 13:271 | Advice: Run Data-verification operation. |
| 13:272 | Multiplexing deduplication data on same stream is not expected. |
| 13:273 | . |
| 13:274 | Fail to get metadata information from comm-server. Operation will be resumed automatically. |
| 13:275 | Failed to enable hardware encryption on the hardware device. |
| 13:276 | Invalid metadata information. |
| 13:277 | Insufficient memory. Operation will be resumed. |
| 13:278 | Operation will be resumed automatically. |
| 13:279 | Interruption of data transfer due to network problems. Operation will be resumed automatically. |
| 13:280 | Hardware device does not support Hardware Encryption. |
| 13:281 | Fail to read data from the media. |
| 13:282 | Fail to read Meta-data from the media. |
| 13:283 | Fail to write/update data on the media. |
| 13:284 | Use scalable resource allocation is disabled because the MediaAgents[1^%s] are below V11.28 |
| 13:285 | Error occurred while processing data at the time of error in the library [<String>] for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:286 | Failed to process data at the time of error in the library [<String>] for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:287 | Error occurred while processing data at the time of error in the library [<String>] and mount path [<String>] for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:288 | Failed to process data at the time of error in the library [<String>] and mount path [<String>] for storage policy [<String>] copy [<String>] MediaAgent [<String>]: <String>. |
| 13:289 | Error occurred while processing data for storage policy [<String>] copy [<String>]: <String>. |
| 13:290 | Failed to process data for storage policy [<String>] copy [<String>]: <String>. |
| 13:291 | DataDomain Boost Media |
| 13:292 | Hardware Dedupe Media |
| 13:293 | Copy [<String>] contains a Metallic Recovery Reserve storage which is not eligible for Data Verification |
| 13:294 | Metallic Recovery Reserve storage is not eligible for Data Verification |
| 13:295 | Metallic Recovery Reserve storage is not eligible for space reclamation. |
| 13:296 | Some jobs [<String>] have been skipped on copy [<String>/<String>] since subclient, copy and DDB Engine association information not found. We will retry again on the next auxiliary copy job. If the issue persists, please contact your vendor's support hotline. |
| 13:297 | Some jobs have been skipped on copy [<String>/<String>] since subclient, copy and DDB Engine association information not found. We will retry again on the next auxiliary copy job. If the issue persists, please contact your vendor's support hotline. |
| 13:298 | A message for this job was dropped to avoid message overflow. Please increase the maximum queue size or reduce the active number of AuxCopy, Data/DDB verification and Space Reclamation jobs. |
| 13:299 | Failed to fetch readers for the job, if the job went into pending state then it should be retried after the restart interval set for the job. If the Issue persists, please contact the customer helpline. |
| 13:300 | Failed to get Job Status, the current auxCopy job status might be incorrect. If the issue persists, please contact the customer helpline. |
| 13:301 | Failed to launch coordinator process, if the job went into pending state then it should be retried after the restart interval set for the job. If the Issue persists, please contact the customer helpline. |
| 13:302 | Failed to update AuxCopy status for the backup jobs, if there are backup jobs that are not getting marked as completed on destination copy despite having it's data copied then please contact the customer helpline. |
| 13:303 | Interruption of data transfer, unable to read the source data. Backup will be retried. |
| 13:304 | Interruption of data transfer, unable to read the data. |
| 13:305 | Kubernetes workloads now use Capacity license. Your capacity license usage will go up and Virtual Operation Instance usage will go down. This change will be enforced in [<Number>] days. Talk to your account team for help or questions. |
Content Indexing
| Code | Description |
| 69:1 | The amount of available memory was insufficient to complete the operation. |
| 69:2 | App Type [<Number>] is not recognized for Content Indexing. |
| 69:3 | Unable to determine App Type for App ID [<Number>]. |
| 69:4 | Unable to look up the MediaAgent for Content Indexing. |
| 69:5 | Failed to look up the Content Indexing Server. |
| 69:6 | Unable to look up the pipeline pair for Content Indexing. |
| 69:7 | Unable to set up Content Indexing pipeline. |
| 69:8 | Content Indexing will utilize [<String>] as a proxy. |
| 69:9 | Failed to initialize Content Indexing map API. |
| 69:10 | Failed to open Content Indexing map API. |
| 69:11 | Failed to initialize Content Indexing cache API. |
| 69:12 | Failed to open Content Indexing cache for a new backup. |
| 69:13 | Failed to rename Content Indexing cache directory. |
| 69:14 | Failed to populate the Content Indexing collect file for archiving. |
| 69:15 | Failed to initialize Content Indexing directory. |
| 69:16 | Failed to initialize spooling of Content Indexing data. |
| 69:17 | Failed to commit spooled records to the Content Indexing database. |
| 69:18 | [<Number>] of [<Number>] files were indexed for content. [<Number>] files were skipped. [<Number>] files failed. |
| 69:19 | Failed to reserve [<Number>] bytes in the Content Indexing cache. |
| 69:20 | Failed to open the collect file generated by the file system backup. |
| 69:21 | Failed to get the subclient directory. |
| 69:22 | Failed to seek to the restart offset in the file system collect file. |
| 69:23 | The Content Indexing database is empty and cannot be archived. |
| 69:24 | Failed to find the collection for the content indexing server. |
| 69:25 | Search engine has not been initialized. |
| 69:26 | Content indexing services may be down. Please check content indexing services. |
| 69:27 | Content indexing operation failed. Please check the log. |
| 69:28 | Failed to get configuration information in Search engine initialization. |
| 69:29 | Failed to update Content Indexing results to CommServe database. |
| 69:30 | Failed to extract application data while reading the archive. |
| 69:31 | SSN |
| 69:32 | Driving License Number |
| 69:33 | American CC |
| 69:34 | VISA CC |
| 69:35 | MasterCard CC |
| 69:36 | Discover CC |
| 69:37 | Routing Number |
| 69:38 | Location |
| 69:39 | US Phone number |
| 69:40 | Fail to process the Documents. |
| 69:41 | Fail to submit batch. Please check content indexing services. |
| 69:42 | Batches are timing out. Please check content indexing services. |
| 69:43 | Merge is running. Job will wait for it to finish. |
| 69:44 | There are no Batch Slots available. Need to wait till it becomes free. |
| 69:45 | There is not enough Heap available to Process Batch. Job will wait for it to become free |
| 69:46 | Failed to commit the documents pushed. Please check content indexing services. |
| 69:47 | The free space on Index Directory Volume [<String>] is less than minimum required [<String>] on Search Engine Node[<String>]. Please increase the disk space and resume the job again. |
| 69:48 | Failed to locate Index Directory location in registry on Search Engine node[<String>]. Please make sure Search Engine installation is completed. |
| 69:49 | Can not determine free space of index directory volume [<String>] Error [<Number>] on Search Engine node[<String>]. |
| 69:50 | <Number> |
| 69:51 | Threat-Analysis package is not installed in [<String>] |
| 69:52 | Possible threat found on client [<String>] [count - <Number>]. Check Unusual File Activity report for more detail. |
| 69:53 | Client, [<String>], could not participate in this job as they do not have [IndexGateway, ContentExtractor] packages installed. |
| 69:54 | Following nodes, [<String>], could not participate in this job as they do not have [IndexGateway, ContentExtractor] packages installed. |
| 69:55 | No node, [<String>], could not participate in this job as they do not have [IndexGateway, ContentExtractor] packages installed. |
| 69:56 | Following tape libraries, [^%1], are outside. Please put them back to continue with the content indexing of items from above tape libraries. |
| 69:57 | Failed to update policy associations for policy id [<Number>] |
| 69:58 | No subclients are configured for the policy / plan. |
| 69:59 | <html>Possible threat found on client [<String>] [count - <Number>]. Check Unusual File Activity report for more detail.<span style="display: none"><String></span></html> |
| 69:60 | <html>Possible suspicious files found on client [<String>] [count - <Number>]. Check Unusual File Activity report for more detail.<span style="display: none"><String></span></html> |
| 69:61 | One or more backup jobs belonging to subclients [<String>] have failed to content index. Possible reasons include 1. Media Agent is not reachable, 2. Subclient does not have a valid copy on the given storage pool, 3. Aux-Copy for these files has not yet been completed to the selected storage pool |
| 69:62 | Threat Analysis Virus Definition Update Status=[<String>], Client: [<String>], Time: [<String>] |
DataPipe
| 10:1 | The amount of available memory was insufficient to complete the operation. |
| 10:2 | Unable to communicate with the remote machine [<String>] to start the Data Pipe. Please check the network connectivity between the local machine and the remote machine and verify this product's Communications Service is running on the remote machine. |
| 10:3 | Unable to send data to the remote machine [<String>], <String>. Please check the network connectivity between the local machine and the remote machine and verify this product's Communications Service is running on the remote machine. |
| 10:4 | Unable to receive data from the remote machine [<String>], <String>. Please check the network connectivity between the local machine and the remote machine and verify that the Communications Service is running on the remote machine. |
| 10:5 | Not enough space in the pipeline buffer to perform encryption. At least one 64KB buffer was left unencrypted. If this job restores data that was backed up with a pre-5.0 release of this product, this is normal. If this is a Synthetic Full that uses a pre-5.0 backup, a new full backup is recommended. |
| 10:6 | Data transfer was interrupted by a network send failure. Please check the network connectivity and verify this product's Communications Service is running. |
| 10:7 | Data transfer was interrupted by a network receive failure. Please check the network connectivity and verify this product's Communications Service is running. |
| 10:8 | DataMover could not be brought down gracefully. Please check your hardware. |
| 10:9 | Shared memory and or semaphores have not been adequately set up as per the operational guidelines on the MediaAgent machine |
| 10:10 | Shared memory and or semaphores have not been adequately set up as per the operational guidelines on the client machine |
| 10:11 | Problem with Decryption of Data; need to provide Correct Pass Phrase. |
| 10:12 | Network reader unable to connect back to the network writer. Please check the name resolution on the client and the MediaAgent. |
| 10:13 | Unable to resolve host name [<String>]. Please make sure that the DNS settings are appropriate. |
| 10:14 | The remote machine [<String>] did not respond to start the Data Pipe. Please check the network connectivity between the local machine and the remote machine and verify this product's Communications Service is running on the remote machine. |
| 10:15 | [Cache Database error at source side.] |
| 10:16 | [Low disk space on the client side disk cache used by Client Side DeDuplication. Please increase the available space on the job results directory of the client.] |
| 10:17 | [Client encountered an error while communicating SIDB Engine.] |
| 10:18 | [Failed to open Deduplication Database (DDB) on the MediaAgent[<String>], please check network connectivity between [<String>] and DDB MediaAgent [<String>].] |
| 10:19 | [Client encountered an error while sending message to SIDB Engine.] |
| 10:20 | [Client encountered an error while receiving message from SIDB Engine.] |
| 10:21 | [Deduplication module encountered error at source side.] |
| 10:22 | [The Deduplication store[<String>] does not support Client side deduplication for the stores created in older releases. Need to seal the store.] |
| 10:23 | [Source Side Deduplication encountered error (<String>)] |
| 10:24 | Could not connect to the DeDuplication Database engine process for Store Id [<String>]. |
| 10:25 | Could not connect to the CVD on remote host to launch the DeDuplication Database engine process for Store Id [<String>]. |
| 10:26 | Failed to start the DeDuplication Database engine for Store Id [<String>]. |
| 10:27 | Not connected to DeDuplication Database engine for Store Id [<String>]. |
| 10:28 | The network module failed to send / recv data (DeDuplication Database with Store Id [<String>]). |
| 10:29 | Timeout while waiting for a reply from DeDuplication Database engine for Store Id [<String>]. |
| 10:30 | The DeDuplication Database engine is going down for Store Id [<String>]. |
| 10:31 | The wrong DeDuplication Database engine is being contacted using Store Id [<String>]. |
| 10:32 | Incorrect signature type was passed to the DeDuplication Database engine for Store Id [<String>]. |
| 10:33 | The DeDuplication Database engine has failed to insert an entry into the database with Store Id [<String>]. |
| 10:34 | Low disk space on the path for DeDuplication Database with Store Id [<String>]. |
| 10:35 | CommServe and the DeDuplication Database are out of sync for Store Id [<String>]. |
| 10:36 | Wrong version for DeDuplication Database with Store Id [<String>]. |
| 10:37 | Could not connect to the CacheDB process. |
| 10:38 | Could not connect to the CVD on remote host to launch the CacheDB engine. |
| 10:39 | Failed to start the CacheDB engine. |
| 10:40 | Not connected to CacheDB engine. |
| 10:41 | The network module failed to send / recv data (CacheDB). |
| 10:42 | Timeout while waiting for a reply from CacheDB engine. |
| 10:43 | The CacheDB engine is going down. |
| 10:44 | The wrong CacheDB engine is being contacted. |
| 10:45 | Incorrect signature type was passed to the CacheDB engine. |
| 10:46 | The CacheDB engine has failed to insert an entry into the SIDB tables. |
| 10:47 | Low disk space on the client side disk cache used by Client Side DeDuplication. Please increase the available space on the job results directory of the client. |
| 10:48 | Cannot allocate Pipeline Buffer. |
| 10:49 | DeDuplication Database Engine encountered failure in communicating CommServe for Store Id [<String>]. |
| 10:50 | DeDuplication Database has been suspended for Store Id [<String>]. |
| 10:51 | DeDuplication Database Initialization has failed for Store Id [<String>]. |
| 10:52 | DeDuplication Database Encountered failure for Store Id [<String>]. |
| 10:53 | Failed to open DeDuplication Database with Store Id [<String>]. |
| 10:54 | DeDuplication Database is in incorrect State for Store Id [<String>]. |
| 10:55 | DeDuplication Database is in suspended state for Store Id [<String>]. |
| 10:56 | All DeDuplication Database partitions are found offline for Store Id [<String>]. |
| 10:57 | DeDuplication Database suspend request has been failed for Store Id [<String>]. |
| 10:58 | DeDuplication Database path is inaccessible for Store Id [<String>]. |
| 10:59 | DeDuplication Database encountered failure for Store Id [<String>]. |
| 10:60 | DeDuplication Database partition is found offline for Store Id [<String>]. |
| 10:61 | DeDuplication Database move is in progress for Store Id [<String>]. |
| 10:62 | Other end <String> encountered failure in receiving data [<String>] |
| 10:63 | Unable to find device mounted for DeDuplication Database Path for Store Id [<String>]. |
| 10:64 | Unable to communicate with the remote machine [<String>] to start the Data Pipe. Please check following:n1. Network connectivity exists between client and remote machine.n2. Product's services are running on remote machine.n3. Firewall is setup properly between client and remote machine.n4. Error [<String>]. |
| 3:1 | Communications Service started successfully. |
| 3:2 | Communications Service stopped successfully. |
| 3:3 | Communications Service for [<String>] failed to start: [<String>]. |
| 3:4 | Communications Service for [<String>] started successfully. |
| 3:5 | Communications Service for [<String>] stopped successfully. |
| 3:6 | The CommServe license for [<String>] has expired. |
| 3:7 | The MediaAgent license for [<String>] has expired. |
| 3:8 | Communications Service failed to start: [<String>]. |
| 3:9 | This computer will require a manual reboot to replace system files that were in use during update installation. |
| 3:10 | Cannot produce complete firewall configuration for client [<String>]. It references client [<String>] for which firewall configuration was not established yet. |
| 3:11 | Processing of Network Route configuration for client [<Number>] failed due to database lookup error. |
| 3:12 | Could not find Network Route or Data Interface Pair configuration for client [<String>], its current active node or any other Virtual Machine on that node. |
| 3:13 | Failed to retrieve CommCell Firewall certificates from the DB. |
| 3:14 | Failed to push Network Route configuration to client [<String>] because of communication errors. |
| 3:15 | Failed to query client's name or ID. |
| 3:16 | Client [<String>] which is [<String>] is not a part of this CommServe's client list. Try stopping services or uninstalling instance on this client. |
| 3:17 | Could not retrieve physical machine client name from registry. |
| 3:18 | Could not apply 8.0 Firewall Config files to CommServe DB. Unknown error. |
| 3:19 | Could not find and load 8.0 Firewall configuration files. |
| 3:20 | Not connected to A/C power. |
| 3:21 | CPU utilization is too high. |
| 3:22 | No connectivity with CommServe. |
| 3:23 | Sufficient amount of free disk space is still available |
| 3:24 | Not in the right subnet |
| 3:25 | All conditions are satisfied, the jobs will run shortly |
| 3:26 | Minimum time interval between jobs |
| 3:27 | Some previously scheduled jobs are still running |
| 3:28 | Communication errors. |
| 3:29 | There are existing suspended jobs |
| 3:30 | There are existing pending jobs |
| 3:31 | There are install update jobs running |
| 3:32 | Expired CommServe SRM license |
| 3:33 | Job failed to start |
| 3:34 | Operational window |
| 3:35 | Backup activities are disabled on the CommServe |
| 3:36 | Job was killed |
| 3:37 | Job failed |
| 3:38 | Insufficient network bandwidth |
| 3:39 | Not on a wired network |
| 3:40 | Not on a wireless network |
| 3:41 | No changed files |
| 3:42 | Job failed to start because backup quota exceeded for user [<String>] |
| 3:43 | On a metered network |
| 3:44 | Not on the allowed backup infrastructure list |
| 3:45 | [%s] database has incorrect release [%s], Please make sure that database upgrade is completed successfully. |
| 3:46 | [<String>] database on this machine is partially upgrade, Please make sure that database upgrade is completed successfully. |
| 3:47 | AWS API error, please check cvd.log for more details. |
| 3:48 | Invalid license identified - installed license may only be used on AWS Marketplace Product 'Commvault Backup & Recovery' (productcode). To troubleshoot your license configuration, see https://ma.commvault.com. |
Remote Exec Client
| 58:1 | Could not complete function:[<String>] - missing parameter:[<String>] |
| 58:2 | Communication with host:[<String>] failed. Please check this product's services on host:[<String>]. |
| 58:3 | Could not send message to host:[<String>], received session error:[<String>=<String>]. Please check this product's services on host:[<String>]. |
| 58:4 | Could not free message type:[<String>], received session error:[<String>=<String>] |
| 58:5 | Could not receive message:[<String>] from host:[<String>], received session error:[<String>=<String>]. Please check this product's services on host:[<String>]. |
| 58:6 | Could not receive message from host:[<String>], received session error:[<String>=<String>]. Please check this product's services on host:[<String>]. |
| 58:7 | Failed to create socket on host:[<String>], error code = [<String>]. |
| 58:8 | Failed to resolve host name:[<String>], error code = [<String>]. |
| 58:9 | Failed to bind port [<String>] on host:[<String>], error code = [<String>]. |
| 58:10 | Failed to get socket name on host:[<String>], error code = [<String>]. |
| 58:11 | Failed to listen socket on host:[<String>], error code = [<String>]. |
| 58:12 | Failed to accept connection on host:[<String>], error code = [<String>]. |
| 58:13 | Failed to send message on host:[<String>], error code = [<String>]. |
| 58:14 | Failed to receive message on host:[<String>], error code = [<String>]. |
| 58:15 | Failed to verify message on host:[<String>], error code = [<String>]. |
| 58:16 | Failed to connect to host:[<String>] on host:[<String>], error code = [<String>]. |
| 58:17 | Failed to make the connection before timeout [<String> seconds] on host:[<String>]. |
| 58:18 | Unknown Error on host:[<String>]. |
| 58:19 | Failed to bind port [<String>] on host:[<String>]. Another application may be using this port or the port is not released from the previous connection yet. Please retry after waiting for a few minutes. |
| 58:20 | Failed to connect service [<String>] on host:[<String>] from host:[<String>]. Received session error:[<String>=<String>]. Please check that this product's services on host [<String>] are up. |
| 58:21 | Failed to connect service [<String>] on host:[<String>] from host:[<String>]. |
| 58:22 | Unknown event! |
| 58:23 | Unknown message! |
Install Manager
| 29:1 | The first message. |
Library and Drive Configuration
| 36:1 | Configuration of MediaAgent Library, Drives, and default Storage Policy completed successfully. |
| 36:2 | Memory allocation error displaying configuration. |
| 36:3 | Memory allocation error creating interface to Communications Service. |
| 36:4 | Memory allocation error creating Drive group. |
| 36:5 | Memory allocation error creating host information. |
| 36:6 | Memory allocation error. |
| 36:7 | Could not reassign Drive - received error [<String>]. |
| 36:8 | Could not share DrivePool - received error [<String>]. |
| 36:9 | Could not drop Master DrivePool - received error [<String>]. |
| 36:10 | Failed attaching to Communications Service on CommServe [<String>] with error: [<String>]. |
| 36:11 | Failed attaching to Communications Service on CommServe [<String>] - the service is not running. Please start this service. |
| 36:12 | Could not connect to Media Manager on CommServe: [<String>]. |
| 36:13 | [<String>] failed. MediaAgent platform type is not valid. |
| 36:14 | [<String>] failed getting hostnames. Could not find MediaAgent or CommServe hostname in the platform information. |
| 36:15 | [<String>] failed. No host found. |
| 36:16 | Read configuration failed with error: [<String>]. |
| 36:17 | Auto detect HOST:[<String>] failed with error: [<String>]. |
| 36:18 | Auto detect HOST:[<String>] completed successfully. Libraries:[<String>], Drives:[<String>]. |
| 36:19 | Starting services failed with error: [<String>]. |
| 36:20 | Starting service for Library [<String>] failed with error: [<String>]. |
| 36:21 | Starting service for Drive [<String>] failed with error: [<String>]. |
| 36:22 | Stopping services failed with error: [<String>]. |
| 36:23 | Stopping service for Library [<String>] failed with error: [<String>]. |
| 36:24 | Stopping service for Drive [<String>] failed with error: [<String>]. |
| 36:25 | Configuring host [<String>] failed. <String> |
| 36:26 | Configuring Library [<String>] failed. <String> |
| 36:27 | Configuring Drive [<String>] failed. <String> |
| 36:28 | Getting unique ID for Library [<String>] failed with error: [<String>]. |
| 36:29 | Getting unique ID for Drive [<String>] failed with error: [<String>]. |
| 36:30 | Getting unique ID for Master DrivePool [<String>] failed with error: [<String>]. |
| 36:31 | Getting unique ID for DrivePool [<String>] failed with error: [<String>]. |
| 36:32 | Internal error. Could not find Drive [<String>] in Library [<String>]. |
| 36:33 | Initialization of data for host [<String>] failed with error [<String>]. |
| 36:34 | Deconfiguring host [<String>] failed. <String> |
| 36:35 | Deconfiguring Drive [<String>] failed. <String> |
| 36:36 | Deconfiguring Library [<String>] failed. <String> |
| 36:37 | Discover Media is only valid on libraries. |
| 36:38 | Discover New Media only valid when Library has been configured. |
| 36:39 | Discover Media on Library [<String>] failed determining valid media types. |
| 36:40 | Discover Media on Library [<String>] failed determining spare media group list. |
| 36:41 | Discover Media on Library [<String>] failed with error [<String>]. |
| 36:42 | Completed Discover New Media - no new media found in Library [<String>]. |
| 36:43 | Discover Media on Library [<String>] failed. Media Manager process returned an error. |
| 36:44 | Unable to discover Media on Library [<String>]. Library is not in a ready state - it may be offline or an inventory may be in progress. |
| 36:45 | Discover Media on Library [<String>] failed. Error determining if the Library is in a ready state [<String>]. |
| 36:46 | Library [<String>] must be configured before Drive [<String>]. |
| 36:47 | At least one detected Library seems to have no Drives. Drivers for the Drives may not have been loaded. Please load the Drivers and run CVMMINST again. |
| 36:48 | At least one detected Library has a vendor : model [<String> : <String>], which has not been supported. Please call your vendor's support hotline. |
| 36:49 | At least one detected Drive has a vendor : model [<String> : <String>], which has not been supported. Please call your vendor's support hotline. |
| 36:50 | Drive [<String>] cannot be moved until it has been deconfigured. |
| 36:51 | Unable to get volume list for Library [<String>]. Error returned [<String>=<String>]. |
| 36:52 | Unable to validate Drive configuration. No volumes were found in Library [<String>]. Please Discover Media and try again. |
| 36:53 | Error validating Drive [<String>] on Library [<String>]. Error returned [<String>]. |
| 36:54 | Validate Drive on Library [<String>] failed. Library is not in a ready state - it may be doing an inventory. |
| 36:55 | Validate Drive on Library [<String>] failed. Error determining if the Library is in a ready state [<String>]. |
| 36:56 | Could not move Drive [<String>]. All Drives in Library [<String>] from [<String>] through [<String>] must be deconfigured to complete the move. |
| 36:57 | Unmounting medium from Drive [<String>] failed with error [<String>=<String>]. |
| 36:58 | Library [<String>] must be configured before DrivePool [<String>]. |
| 36:59 | Library [<String>] must be configured before Master DrivePool [<String>]. |
| 36:60 | Configuring DrivePool [<String>] failed. <String> |
| 36:61 | Configuring Master DrivePool [<String>] failed. <String> |
| 36:62 | Deconfiguring DrivePool [<String>] failed. <String> |
| 36:63 | Deconfiguring Master DrivePool [<String>] failed. <String> |
| 36:64 | Failed reading the current configuration from CommServe [<String>] - received error [<String>]. |
| 36:65 | Operation failed on Drive [<String>]. Not enough information to perform action. |
| 36:66 | Operation failed on Library [<String>]. Not enough information to perform action. |
| 36:67 | Operation failed on DrivePool [<String>]. Not enough information to perform action. |
| 36:68 | Failed initialization - unable to read the platform type from the registry. |
| 36:69 | Failed reading the local platform information - received error [<String>]. |
| 36:70 | Unable to add NDMP Drive to Library [<String>] and HOST [<String>]. Error returned [<String>=<String>]. |
| 36:71 | Only Network browse is available for remote MediaAgents. Please enter Connect As and Password to browse the Network. To browse the local disks, run CVMMINST on MediaAgent - [<String>] |
| 36:72 | Please enter Connect As Username and Password to browse the Network. |
| 36:73 | Error impersonating user. Please verify that the username and password are correct. |
| 36:74 | Sharing Violation. The process cannot access the file because it is being used by another process. |
| 36:75 | A mount path already exists at the given location. Please enter a different mount path. |
| 36:76 | Access is denied. |
| 36:77 | The system cannot find the path specified. |
| 36:78 | Disk Libraries [<String>] are not configured. Backups to libraries [<String>] will fail until a mount path is added to them. Verify the mountpath is write enabled. |
| 36:79 | Disk Library [<String>] is not configured. Backups to Library [<String>] will fail until a mount path is added to it. If mount path is already configured, make sure it is write enabled. |
| 36:80 | Unable to create NDMP Drive. 'NDMP Server Password' is different from 'NDMP Server Confirm Password'. |
| 36:81 | The access path for Drive [<String>] has changed - Drives have been added to or removed from HOST [<String>], or Drives are not being detected properly. Please configure this drive again or correct the detection problem. |
| 36:82 | Cannot detect Library [<String>] - SCSI adapters have been added to or removed from HOST [<String>], or libraries are not being detected properly. Please go to Properties Page to select the right SCSI address or correct the detection problem. |
| 36:83 | Cannot detect Drive [<String>] - SCSI adapters have been added to or removed from HOST [<String>], or drives are not being detected properly. Please go to Properties Page to select the right SCSI address or correct the detection problem. |
| 36:84 | Update SCSI bus failed for Library [<String>] failed. <String> |
| 36:85 | Update SCSI bus failed for Drive [<String>] failed. <String> |
| 36:86 | Could not find host [<String>]. Please check this host name. |
| 36:87 | Incorrect vendor for host [<String>]. The correct vendor is [<String>]. Please select the correct vendor. |
| 36:88 | Could not open an NDMP connection to host [<String>]. Please verify the NDMP server is running on that host. |
| 36:89 | Failed authenticating NDMP connection to host [<String>]. Please check the login and password. |
| 36:90 | Failed to get the OS type from host [<String>]. NDMP request failed. Please verify the firmware revision of the host. |
| 36:91 | Host [<String>] returned an unsupported OS type. Please verify the filer OS. |
| 36:92 | Unexpected error attempting to verify NDMP login to host [<String>]. |
| 36:93 | A database error was encountered on the MMS2NDMPHostInfo table. Please check the Media Manager log for more information. |
| 36:94 | Cannot create mount path, Media Mount Manager may be offline! |
| 36:95 | Validation failed. Error returned [<String>]. |
| 36:96 | Field [<String>] is empty. |
| 36:97 | Failed to get the OS version from host [<String>]. NDMP request failed. Please verify the firmware revision of the host. |
| 36:98 | Invalid Password. |
| 36:99 | Failed to delete NDMP information for host [<String>]. The NDMP information is still in use by a client. |
| 36:100 | NDMP Remote Server information cannot be deleted. To remove this entry, please uninstall the NDMP Remote Server. |
| 36:101 | Would you like to configure all the drives for Library [<String>]? |
| 36:102 | Are you sure you want to configure host [<String>] and all of its libraries and drives? |
| 36:103 | Are you sure you want to configure Library [<String>]? |
| 36:104 | Are you sure you want to configure Drive [<String>]? |
| 36:105 | Delete any storage policy or any storage policy copies associated with all libraries on this host. Deleting a storage policy copy will delete all backup data associated with the copy. Are you sure you want to deconfigure Host [<String>] and all of its libraries and drives? |
| 36:106 | Delete any storage policy or any storage policy copies associated with this Library. Deleting a storage policy copy will delete all backup data associated with the copy. Are you sure you want to deconfigure Library [<String>]? |
| 36:107 | Are you sure you want to deconfigure Drive [<String>]? |
| 36:108 | Drives must be deconfigured before their library. Would you like to deconfigure the drives for Library [<String>]? |
| 36:109 | Detection has already been completed. Detect again? |
| 36:110 | DMS Service for Drive [<String>] has just been started. LMS Service for Library [<String>] must be stopped and restarted to recognize the drive. Would you like to stop and restart this Library service now? |
| 36:111 | Validating a Library will mount a medium in each drive and can take several minutes per drive. Are you sure you want to validate Drives in Library [<String>]? |
| 36:112 | Validating a Drive will mount a medium in the Drive and can take several minutes. Are you sure you want to validate Drive [<String>]? |
| 36:113 | Are you sure you want to configure DrivePool [<String>]? |
| 36:114 | Are you sure you want to configure Master DrivePool [<String>]? |
| 36:115 | Would you like to configure all the Drives for Master DrivePool [<String>]? |
| 36:116 | Would you like to configure all the Drives for DrivePool [<String>]? |
| 36:117 | Are you sure you want to deconfigure DrivePool [<String>]? |
| 36:118 | Are you sure you want to deconfigure Master DrivePool [<String>]? |
| 36:119 | Drives must be deconfigured before their DrivePool. Would you like to deconfigure the Drives for DrivePool [<String>]? |
| 36:120 | DrivePools must be deconfigured before their Master DrivePool. Would you like to deconfigure the DrivePools for Master DrivePool [<String>]? |
| 36:121 | Validating a DrivePool will mount a medium in each Drive and can take several minutes per Drive. Are you sure you want to validate Drives in DrivePool [<String>]? |
| 36:122 | Validating a Master DrivePool will mount a medium in each Drive and can take several minutes per Drive. Are you sure you want to validate Drives in Master DrivePool [<String>]? |
| 36:123 | DrivePools must be deconfigured before their Library. Would you like to deconfigure the DrivePools for Library [<String>]? |
| 36:124 | Master DrivePools must be deconfigured before their Library. Would you like to deconfigure the Master DrivePools for Library [<String>]? |
| 36:125 | Are you sure you want to delete Library [<String>]? |
| 36:126 | Are you sure you want to delete DrivePool [<String>]? |
| 36:127 | Are you sure you want to delete Master DrivePool [<String>]? |
| 36:128 | Are you sure you want to delete Drive [<String>]? |
| 36:129 | The access path entered is an invalid format. Valid format is '\. ape#' where '#' is a positive number. Do you want to discard these changes and continue? |
| 36:130 | Are you sure you want to change SCSI address? |
| 36:131 | Dragging and dropping a DrivePool to a Master DrivePool will create a shared SAN DrivePool. Do you want to continue? |
| 36:132 | Does this Library [<String> <String>] have a barcode reader? |
| 36:133 | There is a configured Library [<String>] on MediaAgent [<String>] with the same or empty serial number; it could be the same library in SAN. Configuring the same library twice may make the library unusable in this product. Are you sure you want to configure this library? |
| 36:134 | For changing the options to take effect, you need to restart the program. Do you want to restart the program now? |
| 36:135 | Are you sure you want to change access path? |
| 36:136 | Are you sure you want to reset Library? |
| 36:137 | Are you sure you want to reset Drive? |
| 36:138 | Are you sure you want to change login/password? |
| 36:139 | Are you sure you want to delete the mount path[<String>]? |
| 36:140 | Are you sure you want to change the device name? |
| 36:141 | <String> Are you sure you want to continue anyway? |
| 36:142 | Make sure you have the privilege to create services on the passive nodes. |
| 36:143 | Remote configuration for Library and Drive is not allowed currently. Please try it on the local MediaAgent. |
| 36:144 | Are you sure you want to abort the exhaustive detection? |
| 36:145 | If you want to use this product instead of RSM for this library, please go to Device Manager and disable the Medium Changer driver for this library and detect the devices again. Are you sure you want to use RSM to control this Library? |
| 36:146 | Changing the Mount Path may cause the loss of all previous backup data. Are you sure you want to change the Mount Path? |
| 36:147 | Ready to configure. |
| 36:148 | Configuring host... |
| 36:149 | Deconfiguring host... |
| 36:150 | Error during host configuration. |
| 36:151 | Error during host deconfiguration. |
| 36:152 | Error during Library configuration. |
| 36:153 | Error during Library deconfiguration. |
| 36:154 | Error during Drive configuration. |
| 36:155 | Error during Drive deconfiguration. |
| 36:156 | Configuration of Library/Drives Completed Successfully. |
| 36:157 | Deconfiguration of Library/Drives Completed Successfully. |
| 36:158 | Auto Detection of Libraries/Drives Started on client [<String>].... |
| 36:159 | Please select Detect to start Detection of Storage Libraries/Drives |
| 36:160 | Error attaching to CommServe. |
| 36:161 | Testing connection to Media Manager. |
| 36:162 | Media Manager connection successful. |
| 36:163 | Media Manager connection failed. |
| 36:164 | Could not determine CommServe or Local hostname. |
| 36:165 | Errors during AutoDetect. |
| 36:166 | Errors during AutoDetect NULL Host. |
| 36:167 | Errors During AutoDetect. Invalid platform type. |
| 36:168 | Starting MediaAgent LMSs and DMSs... |
| 36:169 | Errors during start LMSs and DMSs NULL Host. |
| 36:170 | Errors during start LMSs and DMSs. |
| 36:171 | LMS and DMS Services Started. |
| 36:172 | Stopping MediaAgent LMSs and DMSs... |
| 36:173 | Errors during stop LMSs and DMSs NULL Host. |
| 36:174 | Error stopping LMS and DMS Services. |
| 36:175 | LMS and DMS services stopped successfully. |
| 36:176 | Configuring Library [<String>]... |
| 36:177 | Configuring Drive [<String>]... |
| 36:178 | Deconfiguring Library [<String>]... |
| 36:179 | Deconfiguring Drive [<String>]... |
| 36:180 | Getting unique ID for Library [<String>]... |
| 36:181 | Getting unique ID for Drive [<String>]... |
| 36:182 | Starting service for Library [<String>]... |
| 36:183 | Stopping service for Library [<String>]... |
| 36:184 | Error stopping service for Library [<String>]. |
| 36:185 | Starting service for Drive [<String>]... |
| 36:186 | Stopping service for Drive [<String>]... |
| 36:187 | Error starting Drive service. |
| 36:188 | Error stopping service for Drive [<String>]. |
| 36:189 | Configuration of Library [<String>] completed successfully. |
| 36:190 | Deconfiguration of Library [<String>] completed successfully. |
| 36:191 | Deconfiguration of Library [<String>] canceled. |
| 36:192 | Configuration of Drive [<String>] completed successfully. |
| 36:193 | Deconfiguration of Drive [<String>] completed successfully. |
| 36:194 | Initializing host data. |
| 36:195 | Error initializing host data. |
| 36:196 | Completed Configuration - no items selected. |
| 36:197 | Completed Configuration - blank item selected. |
| 36:198 | Completed Deconfiguration - no items selected. |
| 36:199 | Completed Deconfiguration - blank item selected. |
| 36:200 | Trying to deconfigure <String> Libraries and <String> Drives... |
| 36:201 | Failed to attach to Communications Service. |
| 36:202 | Please Select Configure to start MediaAgent Configuration |
| 36:203 | Completed Discover New Media - no item selected. |
| 36:204 | Completed Discover New Media - invalid item selected. |
| 36:205 | Completed Discover New Media - could not get media type list. |
| 36:206 | Completed Discover New Media - could not spare media group list. |
| 36:207 | Discover New Media canceled. |
| 36:208 | Discovering new media on Library [<String>]... |
| 36:209 | Completed Discover New Media - no new media found. |
| 36:210 | Completed Discover New Media - error finding new media. |
| 36:211 | Discover New Media successful. |
| 36:212 | Validating Drive [<String>]... |
| 36:213 | Validating Library [<String>]... |
| 36:214 | Library [<String>] configuration validation successful. |
| 36:215 | Library [<String>] configuration validation failed. |
| 36:216 | Drive [<String>] configuration validation successful. |
| 36:217 | Drive [<String>] configuration validation failed. |
| 36:218 | DrivePool [<String>] configuration validation successful. |
| 36:219 | Unmounting a medium in Drive [<String>]... |
| 36:220 | Error Unmounting medium from Drive [<String>]. |
| 36:221 | Error Mounting medium in Drive [<String>]. |
| 36:222 | Configuring DrivePool [<String>]... |
| 36:223 | Error during DrivePool configuration. |
| 36:224 | Configuration of DrivePool [<String>] completed successfully. |
| 36:225 | Deconfiguring DrivePool [<String>]... |
| 36:226 | Deconfiguration of DrivePool [<String>] canceled. |
| 36:227 | Error during DrivePool deconfiguration. |
| 36:228 | Deconfiguration of DrivePool [<String>] completed successfully. |
| 36:229 | Configuring Master DrivePool [<String>]... |
| 36:230 | Error during Master DrivePool configuration. |
| 36:231 | Configuration of Master DrivePool [<String>] completed successfully. |
| 36:232 | Deconfiguring Master DrivePool [<String>]... |
| 36:233 | Deconfiguration of Master DrivePool [<String>] canceled. |
| 36:234 | Error during Master DrivePool deconfiguration. |
| 36:235 | Deconfiguration of Master DrivePool [<String>] completed successfully. |
| 36:236 | Validating DrivePool [<String>]... |
| 36:237 | Validating Master DrivePool [<String>]... |
| 36:238 | Initializing configuration data structures... Please wait. |
| 36:239 | Initialization failed. |
| 36:240 | Ready |
| 36:241 | Reading current configuration... Please wait. |
| 36:242 | Error reading the current configuration. |
| 36:243 | Install Disk Library... |
| 36:244 | Install Disk Library...Successful. |
| 36:245 | Install Disk Library...Failed. |
| 36:246 | Deconfigure Disk Library... |
| 36:247 | Deconfigure Disk Library...Successful. |
| 36:248 | Deconfigure Disk Library...Failed. |
| 36:249 | Add Mount Path for Disk Library... |
| 36:250 | Add Mount Path for Disk Library...Successful. |
| 36:251 | Add Mount Path for Disk Library...Failed. |
| 36:252 | Delete Mount Path from Disk Library... |
| 36:253 | Delete Mount Path from Disk Library...Successful. |
| 36:254 | Delete Mount Path from Disk Library...Failed. |
| 36:255 | Completed delete - no items selected. |
| 36:256 | Completed delete - blank item selected. |
| 36:257 | Cannot delete item - must be deconfigured before delete. |
| 36:258 | Unable to add NDMP Drive to Library [<String>] and HOST [<String>]. |
| 36:259 | Update Library [<String>] SCSI address failed! |
| 36:260 | Update Drive [<String>] SCSI address failed! |
| 36:261 | Resetting Library [<String>]... |
| 36:262 | Resetting Drive [<String>]... |
| 36:263 | Reset Library [<String>] successful. |
| 36:264 | Reset Library [<String>] failed. [<String>] |
| 36:265 | Reset Drive [<String>] successful. |
| 36:266 | Reset Drive [<String>] failed. [<String>] |
| 36:267 | Master DrivePool [<String>] configuration validation successful. |
| 36:268 | Expert Storage Configuration |
| 36:269 | Local Host |
| 36:270 | CommServe Host |
| 36:271 | Exit |
| 36:272 | OK |
| 36:273 | Cancel |
| 36:274 | Detect Devices |
| 36:275 | Add Disk Library |
| 36:276 | Configure |
| 36:277 | Deconfigure |
| 36:278 | Discover Media |
| 36:279 | Validate |
| 36:280 | Properties |
| 36:281 | Delete |
| 36:282 | Add Mount Path |
| 36:283 | Uninstall Library |
| 36:284 | Delete Mount Path |
| 36:285 | Detect Devices Options |
| 36:286 | Available MediaAgents: |
| 36:287 | Discover New Media |
| 36:288 | Select New Media Type: |
| 36:289 | Select Destination Scratch Pool: |
| 36:290 | Library Properties |
| 36:291 | Drive Properties |
| 36:292 | DrivePool Properties |
| 36:293 | Master DrivePool Properties |
| 36:294 | MediaAgent: |
| 36:295 | Drive Name: |
| 36:296 | Library Name: |
| 36:297 | Master DrivePool Name: |
| 36:298 | DrivePool Name: |
| 36:299 | Unique ID: |
| 36:300 | Manufacturer: |
| 36:301 | Model: |
| 36:302 | Description: |
| 36:303 | Firmware: |
| 36:304 | Serial Number: |
| 36:305 | WWN: |
| 36:306 | SCSI Address: |
| 36:307 | Access Path: |
| 36:308 | Base Address: |
| 36:309 | Drive Count: |
| 36:310 | Door Check (sec): |
| 36:311 | Disable RSM |
| 36:312 | Alias: |
| 36:313 | Unassigned |
| 36:314 | Device Name: |
| 36:315 | Service Status: |
| 36:316 | Could not communicate with the Media & Library Manager on CommServe [<String>]. Please verify this service has been started on the CommServe. |
| 36:317 | A database error was encountered when operating on the DrivePool table on CommServe [<String>]. Check the Media Manager log for more information. There may be jobs that have reserved drives in this Library - please kill these jobs and try again. |
| 36:318 | A database error was encountered when operating on the MediaGroupSpare table on CommServe [<String>]. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:319 | The Media & Library Manager on CommServe [<String>] reported a database error. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:320 | Storage Policy operations could not communicate with the Media & Library Manager on CommServe [<String>]. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:321 | Storage Policy operations reported a database error on CommServe [<String>]. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:322 | A Storage Policy could not be deleted on CommServe [<String>] because it is in use. Please check the Storage Policy assignments. |
| 36:323 | Storage Policy operations reported a database error when using the MediaGroup table on CommServe [<String>]. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:324 | Media & Library Manager on CommServe [<String>] cannot complete action because the Library has a volume in use. Allow the backup or restore to complete. |
| 36:325 | Media & Library Manager on CommServe [<String>] cannot complete action because the Library has a volume in an unknown state. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:326 | Media & Library Manager on CommServe [<String>] timed out waiting for a volume to mount or unmount. Check the Media & Library Manager log (MediaManager.log) for more information. |
| 36:327 | Spare Media Group could not be deleted on CommServe [<String>]. Check to see if the storage policy copies for this Library were properly deleted. |
| 36:328 | DrivePool could not be deleted on CommServe [<String>]. Check to see if the storage policy copies for this Library were properly deleted. |
| 36:329 | Could not allocate a license for library on CommServe [<String>]. Please check if there are licenses available. |
| 36:330 | Could not update the information on CommServe [<String>], the name may already be used by the other. |
| 36:331 | Could not update the information on CommServe, the name may already be used by the other. |
| 36:332 | Failed to unmount the medium from [<String>]. |
| 36:333 | Failed to rename the node [<String>]. <String> |
| 36:334 | Configuring Copy Manager [<String>]... |
| 36:335 | Error during Copy Manager configuration. |
| 36:336 | Configuration of Copy Manager [<String>] completed successfully. |
| 36:337 | Deconfiguring Copy Manager [<String>]... |
| 36:338 | Error during Copy Manager deconfiguration. |
| 36:339 | Deconfiguration of Copy Manager [<String>] completed successfully. |
| 36:340 | Configuring Copy Manager [<String>] failed. <String> |
| 36:341 | Deconfiguring Copy Manager [<String>] failed. <String> |
| 36:342 | Would you like to configure Copy Manager [<String>] for all MediaAgents? |
| 36:343 | Are you sure you want to deconfigure Copy Manager [<String>]? |
| 36:344 | Are you sure you want to deconfigure Copy Manager [<String>] for all MediaAgents? |
| 36:345 | Are you sure you want to change Drive ID? |
| 36:346 | The SCSI addresses of some Libraries and Drives with serial numbers on MediaAgent[<String>] have been automatically updated in the database. |
| 36:347 | The mount path will be created under the root directory. The system will become inoperable if the root directory becomes full. Are you sure you want to create the mount path under the root directory? |
| 36:348 | You have detected devices without using Exhaustive Detection; this may result in the wrong library and drives association. Do you still want to configure devices without the Exhaustive Detection option? |
| 36:349 | Are you sure you want to create a standalone library for the selected drive? |
| 36:350 | Do you want to configure the standalone library now? |
| 36:351 | Are you sure you want to move the item to <String>? |
| 36:352 | Exhaustive detection may unload some drives on the selected MediaAgents. This may interfere with currently running backups/restores. Are you sure that you want to proceed? |
| 36:353 | Exhaustive detection will unload all drives on all the selected MediaAgents. This may interfere with currently running backups/restores. Are you sure that you want to proceed? |
| 36:354 | Do you want to configure the library now? |
| 36:355 | Are you sure you want to abort the storage validation? |
| 36:356 | Exhaustive detection has <updated/verified> the configuration. Do you want to configure Library [<String>] now? |
| 36:357 | Library only |
| 36:358 | Library and all drives |
| 36:359 | MasterDrivePool only |
| 36:360 | MasterDrivePool and all drives |
| 36:361 | DrivePool only |
| 36:362 | DrivePool and all drives |
| 36:363 | At least one library is not configured after running Exhaustive Detection. Do you still want to exit the program? |
| 36:364 | At least one library is not configured after running Exhaustive Detection. Do you still want to restart the program? |
| 36:365 | Exhaustive detection has verified <String> drives in Library [<String>]. Do you want to configure the library and the verified drives only now? |
| 36:366 | Exhaustive detection cannot verify any new drive in Library [<String>]. Please view log for details. |
| 36:367 | Host Name: |
| 36:368 | NDMP detection will require stopping library services of configured devices on the selected NDMP servers. Services will be restarted after detection. Are you sure you want to proceed? |
| 36:369 | Drive Slot Count: |
| 36:370 | Configured Drive Count: |
| 36:371 | Work Pool Number: |
| 36:372 | Please select MediaAgents first! |
| 36:373 | Select MediaAgents |
| 36:374 | A library with this name already exists. Please enter a different library name. |
| 36:375 | No devices were detected. |
| 36:376 | No new devices were detected. |
| 36:377 | Right-click a particular device to continue its configuration. |
| 36:378 | Please configure storage devices on the new MediaAgents. <String> - For SCSI devices, select Detect/Configure Devices. <String> - For other devices, select Add from the Start Menu. |
| 36:379 | Select an empty drive slot as the target |
| 36:380 | Select an empty drive slot as the target |
| 36:381 | Select the destination Master Drive Pool |
| 36:382 | No empty slots available to move this drive! |
| 36:383 | No other Master DrivePool available to create DDS DrivePool! |
| 36:384 | Please enter Connect As Username and Password to create the Mount Path from the remote MediaAgent. |
| 36:385 | Dragging and dropping a Library to another Library will create the failover Library Controllers. Do you want to continue? |
| 36:386 | Are you sure you want to delete Library Controller [<String>] on MediaAgent [<String>]? |
| 36:387 | Select the destination library |
| 36:388 | No Library available to create Failover Controller! |
| 36:389 | Library Controller Properties |
| 36:390 | This is a shared device, so changing the device properties may affect the properties (i.e., SCSI address, Access Path) of the shared device on other MediaAgents. Please detect the devices on those MediaAgents to correct any incorrect device property. |
| 36:391 | Configuring Device [<String>] failed. <String> |
| 36:392 | To discover media for Library [<String>] without the barcode reader, please enable Auto-discover Media feature for this library. |
| 36:393 | Failed to set the default media type for Library [<String>]. <String> |
| 36:394 | A full inventory of the library without barcode reader is required to identify the media. This operation will take several minutes. You can also perform a full inventory from the CommCell Console later. Click Yes to start the inventory in five minutes. |
| 36:395 | Failed to schedule the inventory for Library [<String>]. <String> |
| 36:396 | The selected Library Controller node will now move to the corresponding Library [<String>] node; please right-click the Library Controller to continue its configuration. |
| 36:397 | Generic |
| 36:398 | Copy Manager |
| 36:399 | To use RSM-enabled libraries, you also have to back up the RSM database as a separate subclient. Otherwise, any RSM database corruption may cause complete loss of data. Please see the user manual for more details. |
| 36:400 | Error while loading NDMP host info |
| 36:401 | Scanning NDMP devices. Please wait... |
| 36:402 | Are you sure you want to reset the MediaAgent [<String>]? |
| 36:403 | Are you sure you want to reset all MediaAgents? |
| 36:404 | Failed to reset MediaAgent [<String>]. <String> |
| 36:405 | This program is only used for the configuration of the Disk libraries and the SCSI/SAN devices. For other types of libraries, use the CommCell Console for Java GUI -> Tools -> Library & Drive Configuration to configure the libraries. Do you want to continue? |
| 36:406 | Do you want to detect the SCSI devices now? |
| 36:407 | No Service! |
| 36:408 | No Service Needed |
| 36:409 | Service Stopped! |
| 36:410 | Service Running... |
| 36:411 | Unknown! |
| 36:412 | No NDMP devices detected |
| 36:413 | Please detect devices first! |
| 36:414 | Please enter all necessary information! |
| 36:415 | Please enter Import/Export Area information! |
| 36:416 | Please enter the Device Name. |
| 36:417 | Unable to open connection to NDMP library device. |
| 36:418 | Unable to determine number of drives and their base address. |
| 36:419 | Unable to determine library vendor and model. |
| 36:420 | Please select a MediaAgent from the list. |
| 36:421 | Disk Library Properties |
| 36:422 | Mount Path Properties |
| 36:423 | Available NDMP Hosts: |
| 36:424 | Selected NDMP Hosts: |
| 36:425 | Are you sure you want to do the replacement for <String> and <String>? |
| 36:426 | Please select one device. |
| 36:427 | After discovery, move any cleaning tape that may have been discovered from the scratch pool [<String>] to the cleaning media scratch pool. |
| 36:428 | Are you sure you want to deconfigure Library Controller [<String>]? |
| 36:429 | Shared Library |
| 36:430 | Move |
| 36:431 | DDS Drive Pool |
| 36:432 | Library Controller |
| 36:433 | Deconfiguring Library [<String>] failed. <String> Do you want to force-deconfigure this library? |
| 36:434 | Please enter the name! |
| 36:435 | Please add at least one access node! |
| 36:436 | Please select an access node and the MediaAgent to detect and get the information for the cluster! |
| 36:437 | Are you sure you want to remove this access node? |
| 36:438 | Are you sure you want to remove this Centera cluster? |
| 36:439 | Adding access node [<String>] failed. <String> |
| 36:440 | Removing access node [<String>] failed. <String> |
| 36:441 | Adding Centera cluster [<String>] failed. <String> |
| 36:442 | Removing Centera cluster [<String>] failed. <String> |
| 36:443 | Regular Mount Path |
| 36:444 | Centera Mount Path |
| 36:445 | Configuring Disk Device [<String>]... |
| 36:446 | Error during Disk Device configuration. |
| 36:447 | Configuration of Disk Device [<String>] completed successfully. |
| 36:448 | Deconfiguring Disk Device [<String>]... |
| 36:449 | Error during Disk Device deconfiguration. |
| 36:450 | Deconfiguration of Disk Device [<String>] completed successfully. |
| 36:451 | Would you like to configure Disk Device [<String>] for all MediaAgents? |
| 36:452 | Are you sure you want to deconfigure DiskDevice [<String>]? |
| 36:453 | Are you sure you want to deconfigure DiskDevice [<String>] for all MediaAgents? |
| 36:454 | Shared Disk Device |
| 36:455 | Configuring Disk Device [<String>] failed. <String> |
| 36:456 | Configuring Disk Volume [<String>] failed. <String> |
| 36:457 | Deconfiguring Disk Device [<String>] failed. <String> |
| 36:458 | Deconfiguring Disk Volume [<String>] failed. <String> |
| 36:459 | Unknown |
| 36:460 | Fibre Channel - WWN |
| 36:461 | ISCSI - WWUI |
| 36:462 | GSS ID |
| 36:463 | ATAPI/IDE ID |
| 36:464 | A Centera Cluster already exists with the same Cluster ID. |
| 36:465 | Please enter the base folder name. |
| 36:466 | Please enter a mount path. |
| 36:467 | Please enter a valid mount path. |
| 36:468 | Cannot decrypt the password. |
| 36:469 | The password entries did not match, please enter password again! |
| 36:470 | The Cluster ID cannot change after the Centera Cluster is configured. |
| 36:471 | Using Access Node [<String>] detects different Cluster ID [<String>] from current Cluster ID [<String>]; please remove this Access Node from the list. |
| 36:472 | Failed to delete MountPath[<String>]. [Error: <String>] Do you want to remove the entry from the database? Removing the entries from the database will not delete the data from the physical disk. |
| 36:473 | Failed to deconfigure Disk Library[<String>]. <String> Do you want to deconfigure it anyway? |
| 36:474 | Are you sure you want to create the mount path on the same drive of the CommServe? |
| 36:475 | Network Sharing Folder |
| 36:476 | Automatically Create Failover Library Controllers and DDS DrivePools |
| 36:477 | MS Shadow Copy |
| 36:478 | Snap View |
| 36:479 | HP/Compaq ISSG |
| 36:480 | Echo View |
| 36:481 | Fake |
| 36:482 | Sistina GFS |
| 36:483 | Are you sure you want to create the mount path on the same drive of the CommServe and DB folder? |
| 36:484 | Are you sure you want to create the mount path on the same drive of the CommServe DB folder? |
| 36:485 | Are you sure you want to create the mount path on the same drive of the MediaAgent Installation folder? |
| 36:486 | Select Drive IDs |
| 36:487 | Available Drive IDs: |
| 36:488 | Selected Drive IDs: |
| 36:489 | Failed to get the list of drive IDs for the library. |
| 36:490 | Are you sure you want to abort the device detection? |
| 36:491 | Updated Host successfully. Please detect devices on the new MediaAgent to update the device information. |
| 36:492 | Updated Host successfully. Please detect devices on the new MediaAgent to update the device information and reselect the Copy Manager for the Drive Pool. |
| 36:493 | Library [<String>] does not support drive identifiers; please run Exhaustive Detection or drag and drop the proper drives into the library before configuring the library. |
| 36:494 | Are you sure you want to deconfigure Library [<String>]? |
| 36:495 | Failed to start Expert Storage Configuration. <String> |
| 36:496 | User can use Expert Storage Configuration. |
| 36:497 | Another instance of 'Expert Storage Configuration' is being used by User [<String>]. |
| 36:498 | Invalid user to unlock Expert Storage Configuration. |
| 36:499 | All information required to process this request is not received. |
| 36:500 | Failed to update NDMP Server. <String> |
| 36:501 | Failed to add NAS Client. <String> |
| 36:502 | Failed to remove NAS Client. <String> |
| 36:503 | Failed to undelete NAS Client. <String> |
| 36:504 | Add NDMP Server |
| 36:505 | NDMP Server Properties |
| 36:506 | Enter Drive Data: |
| 36:507 | Enter Drive Pool Data - select drive pool or fill in fields: |
| 36:508 | Enter Library Data - leave blank for new standalone library: |
| 36:509 | Drive Description: |
| 36:510 | Drive Number: |
| 36:511 | Drive Serial Number: |
| 36:512 | Library: |
| 36:513 | MediaAgent: |
| 36:514 | NDMP Server Drive Path: |
| 36:515 | NDMP Server Host Name: |
| 36:516 | Populate Serial Number and Model |
| 36:517 | Update NDMP Server List |
| 36:518 | Cancel |
| 36:519 | OK |
| 36:520 | DNS |
| 36:521 | IPC |
| 36:522 | Port: |
| 36:523 | Access Node |
| 36:524 | Centera Cluster |
| 36:525 | Add... |
| 36:526 | Remove |
| 36:527 | Detect |
| 36:528 | Name: |
| 36:529 | Unique ID: |
| 36:530 | Access Nodes |
| 36:531 | Cluster Name: |
| 36:532 | Cluster ID: |
| 36:533 | Capacity |
| 36:534 | Version: |
| 36:535 | Detect Information From MediaAgent: |
| 36:536 | Centera Cluster List |
| 36:537 | New Cluster... |
| 36:538 | Remove Cluster |
| 36:539 | Properties... |
| 36:540 | Done |
| 36:541 | Centera Mount Path |
| 36:542 | Library Name: |
| 36:543 | Library ID: |
| 36:544 | Center Cluster: |
| 36:545 | Password |
| 36:546 | Please enter old remote server password (for this product): |
| 36:547 | Shared Mount Path |
| 36:548 | Disk Device: |
| 36:549 | Base Folder: |
| 36:550 | Add Library |
| 36:551 | MediaAgent: |
| 36:552 | IP Library Data: |
| 36:553 | MediaAgent: |
| 36:554 | Library Type: |
| 36:555 | Library Host Name: |
| 36:556 | Create Default Work Pool |
| 36:557 | Work Pool Number: |
| 36:558 | Vendor: |
| 36:559 | Model: |
| 36:560 | Description: |
| 36:561 | Drive Count: |
| 36:562 | NDMP Library Data: |
| 36:563 | NDMP Server Device Name: |
| 36:564 | Base Address: |
| 36:565 | Detect Library Data |
| 36:566 | Add Disk Library |
| 36:567 | Library Name: |
| 36:568 | Alias: |
| 36:569 | Unique ID: |
| 36:570 | Low Watermark (MB): |
| 36:571 | Automatically create storage policy for new data paths |
| 36:572 | Add NDMP Drive |
| 36:573 | DrivePool: |
| 36:574 | Drive Vendor / Model: |
| 36:575 | Selected MediaAgents: |
| 36:576 | Add >> |
| 36:577 | << Remove |
| 36:578 | Add All >>> |
| 36:579 | <<< Remove All |
| 36:580 | Discover Media Options |
| 36:581 | Yes |
| 36:582 | No |
| 36:583 | Should the media be discovered automatically for you? |
| 36:584 | Select Default Media Type: |
| 36:585 | Configuration |
| 36:586 | Configure |
| 36:587 | Device Confirmation |
| 36:588 | is an additional new device |
| 36:589 | Device: |
| 36:590 | replacement: |
| 36:591 | Device Configuration |
| 36:592 | It is strongly recommended that exhaustive detection be done prior to configuration to avoid errors. This may take several minutes. |
| 36:593 | Do Exhaustive Detection Now |
| 36:594 | Configure Devices without Exhaustive Detection |
| 36:595 | Copy Manager Controller Properties |
| 36:596 | Device Name: |
| 36:597 | Controller ID: |
| 36:598 | MediaAgent: |
| 36:599 | Manufacturer: |
| 36:600 | Model: |
| 36:601 | Firmware: |
| 36:602 | Serial Number: |
| 36:603 | WWN: |
| 36:604 | SCSI Address: |
| 36:605 | Access Path: |
| 36:606 | Concurrency Limit: |
| 36:607 | Copy Manager Device Properties |
| 36:608 | Disk Device Properties |
| 36:609 | ID Type: |
| 36:610 | ID: |
| 36:611 | LUN: |
| 36:612 | LB Offset: |
| 36:613 | Block Count: |
| 36:614 | Block Size: |
| 36:615 | Disk Volume Properties |
| 36:616 | Volume: |
| 36:617 | Mount Points: |
| 36:618 | Drive ID: |
| 36:619 | Modify... |
| 36:620 | Copy Manager: |
| 36:621 | NDMP Server Hostname: |
| 36:622 | NDMP Host List |
| 36:623 | Add New NDMP Host |
| 36:624 | Remove NDMP Host |
| 36:625 | Update NDMP Host |
| 36:626 | Add / Update |
| 36:627 | Cancel |
| 36:628 | NDMP Server Hostname: |
| 36:629 | NDMP Login: |
| 36:630 | NDMP Password |
| 36:631 | Confirm NDMP Password: |
| 36:632 | Vendor: |
| 36:633 | Firmware Revision: |
| 36:634 | Listen Port: |
| 36:635 | Device Selection |
| 36:636 | Start |
| 36:637 | Select Libraries: |
| 36:638 | Select Drives: |
| 36:639 | Auto-Configuration for New Device: |
| 36:640 | Barcode Reader Installed |
| 36:641 | Failover Library Controller |
| 36:642 | DDS DrivePool |
| 36:643 | Log |
| 36:644 | Close |
| 36:645 | Add Mount Path |
| 36:646 | Use Network Share |
| 36:647 | Connect As: |
| 36:648 | Password: |
| 36:649 | Verify Password: |
| 36:650 | Mount Path: |
| 36:651 | Media in the Free Media Pool: |
| 36:652 | Media to be discovered for this product: |
| 36:653 | Selected MediaAgents |
| 36:654 | Failed to deconfigure Libraries/Drives. |
| 36:655 | Please enter a valid Mount Path (directory path).nA valid mount path can be:nA directory path on any local hard drive.nexample: C:\Temp\MountPathnORnA Universal Naming Coded (UNC) path.nexample: \\server\sharenORnA Unix-based path (if the library belongsnto a Unix MediaAgent)nexample: /usr/mount path 1 |
| 36:656 | Add NDMP Device |
| 36:657 | Device Type |
| 36:658 | NDMP Library |
| 36:659 | NDMP Drive |
| 36:660 | Processing... |
| 36:661 | Abort |
| 36:662 | View log... |
| 36:663 | Aborting... |
| 36:664 | Elapsed Time: |
| 36:665 | Select MediaAgent |
| 36:666 | Detect/Configure Devices |
| 36:667 | Device Type |
| 36:668 | SCSI/SAN Devices |
| 36:669 | Detect on Selected MediaAgents in Parallel |
| 36:670 | Automatically Create DDS DrivePools |
| 36:671 | NDMP Devices |
| 36:672 | Exhaustive Detection (Only for Libraries without Drive ID Support) |
| 36:673 | SAN Switch Login |
| 36:674 | Please provide the login information on the SAN switch: |
| 36:675 | Switch IP: |
| 36:676 | User Name: |
| 36:677 | Password: |
| 36:678 | Move to... |
| 36:679 | Select the destination: |
| 36:680 | Detect Vendor |
| 36:681 | Change Password |
| 36:682 | Are you sure you want to remove the NDMP server [<String>] from the list? |
| 36:683 | Unable to determine platform type. |
| 36:684 | Failed to encrypt the password! |
| 36:685 | Drive Access Path is empty |
| 36:686 | Browse for Mount Path... |
| 36:687 | Could not get Vendor/Model information. |
| 36:688 | Could not get tape drive serial number information. |
| 36:689 | Server NDMP version does not support Serial Number and Vendor name detection. |
| 36:690 | No more memory available. |
| 36:691 | Unable to obtain Serial Number and Vendor information. |
| 36:692 | Unable to obtain Filer type. |
| 36:693 | NDMP Server Drive Path field is empty. |
| 36:694 | No NDMP server has been added. |
| 36:695 | No NDMP server has been selected from NDMP Server Host Name list. |
| 36:696 | Unable to obtain serial number and drive type. |
| 36:697 | Serial Number is not available. Please enter Serial Number manually. |
| 36:698 | Drive is not in the list of supported drives. |
| 36:699 | Empty Drive Slot <String> (empty or undetected drive) |
| 36:700 | Unknown Device |
| 36:701 | Failed to encrypt password |
| 36:702 | Failed to decrypt password |
| 36:703 | Please select the number of media between <Number> and <Number> (number of media in Free Media Pool). |
| 36:704 | Invalid Mount Path |
| 36:705 | Add |
| 36:706 | NDMP |
| 36:707 | Centera |
| 36:708 | Exhaustive Detection |
| 36:709 | Configure |
| 36:710 | Deconfigure |
| 36:711 | Add Master Drive Pool |
| 36:712 | Discover Media... |
| 36:713 | Validate |
| 36:714 | Reset Library |
| 36:715 | Delete |
| 36:716 | Properties... |
| 36:717 | Create DDS DrivePool... |
| 36:718 | SAN Path Report... |
| 36:719 | Reset Drive |
| 36:720 | Move to... |
| 36:721 | Move to Shared Library... |
| 36:722 | Create Standalone Library |
| 36:723 | Add Mount Path |
| 36:724 | Add Shared Mount Path |
| 36:725 | Add Centera Mount Path |
| 36:726 | Add Drive Pool... |
| 36:727 | Delete Mount Path |
| 36:728 | Select MediaAgents... |
| 36:729 | Detect/Configure Devices... |
| 36:730 | Disk Library... |
| 36:731 | Shared Disk Library... |
| 36:732 | IP Library... |
| 36:733 | Servers... |
| 36:734 | Add Library... |
| 36:735 | Add Drive... |
| 36:736 | Cluster... |
| 36:737 | Add Library... |
| 36:738 | Exit |
| 36:739 | Reset |
| 36:740 | Reset All MediaAgents |
| 36:741 | Create Failover Library Controller... |
| 36:742 | Volume Range: |
| 36:743 | Deconfigure on all MediaAgents |
| 36:744 | Are you sure you want to deconfigure Drive [<String>] on all MediaAgents? |
| 36:745 | Client information cannot be deleted. To remove this entry, please deconfigure the client from the Client Computers list. |
| 36:746 | Error updating Centera information in the database. Please check the Event Manager Service log for more details. |
| 36:747 | Error adding client [<String>]: already exist. |
| 36:748 | NAS Primary |
| 36:749 | NAS Secondary |
| 36:750 | NAS Snapshot |
| 36:751 | Generic Enabler |
| 36:752 | Shared Disk |
| 36:753 | Library Controller |
| 36:754 | Adding DRU Host[<String>] failed. <String> |
| 36:755 | Removing DRU Host [<String>] failed. <String> |
| 36:756 | Updating DRU Host [<String>] failed. <String> |
| 36:757 | None |
| 36:758 | CBRM cannot be deleted because it is in use by Centera clients. To remove this entry, please make sure no Centera clients are assigned to storage policies using this MediaAgent. |
| 36:759 | Libraries |
| 36:760 | Data Paths |
| 36:761 | Another instance of 'Expert Storage Configuration' is being used by User [<String>]. Do you want to close it and start a new instance? |
| 36:762 | This instance of 'Expert Storage Configuration' is being closed by User [<String>]. |
| 36:763 | Could not open an NDMP connection to host [<String>]. The NDMP version running on that host is not supported. |
| 36:764 | Configuring Disk Library [<String>] ... |
| 36:765 | Configuring Disk Library [<String>] succeeded. |
| 36:766 | Configuring Disk Library [<String>] failed. |
| 36:767 | Deconfiguring Disk Library [<String>]... |
| 36:768 | Deconfiguring Disk Library [<String>] succeeded. |
| 36:769 | Deconfiguring Disk Library [<String>] failed. |
| 36:770 | Adding Mount Path [<String>] for Disk Library [<String>]... |
| 36:771 | Adding Mount Path [<String>] for Disk Library [<String>] succeeded. |
| 36:772 | Adding Mount Path [<String>] for Disk Library [<String>] failed. |
| 36:773 | Deleting Mount Path [<String>] from Disk Library [<String>]... |
| 36:774 | Deleting Mount Path [<String>] from Disk Library [<String>] succeeded. |
| 36:775 | Deleting Mount Path [<String>] from Disk Library [<String>] failed. |
| 36:776 | Creating LUN with size [<String>] GB for Disk Library [<String>]... |
| 36:777 | Created LUN for Disk Library [<String>]. |
| 36:778 | Added Mount Path [<String>] for Disk Library [<String>]. |
| 36:779 | Automatic Disk Group Configuration |
| 36:780 | Please select one of the following options: |
| 36:781 | Change physical disks and retry |
| 36:782 | Continue with automatic disk group configuration |
| 36:783 | Change to manual mode for disk group configuration |
| 36:784 | Cancel disk group configuration |
| 36:785 | OK |
| 36:786 | Found unconfigured physical disks available for automatic disk group configuration. |
| 36:787 | Warning: The unconfigured physical disks are not all the same size. Storage capacity will be lost in disk group configuration. |
| 36:788 | Warning: No hot spare is available to protect the disk group after configuration. |
| 36:789 | Warning: SAS physical disks are not supported for automatic disk group configuration. |
| 36:790 | Selecting manual mode will disable automatic disk group configuration. Are you sure you want to select this option? |
| 36:791 | Confirm Manual Configuration |
| 36:792 | Failed to set the registry key! |
| 36:793 | <String> |
| 36:794 | Disk group configuration cannot be performed in manual mode. Please change the mode or configure the disk group manually. |
| 36:795 | No new disk group available to configure. |
| 36:796 | Warning: No hot spare is available to protect some disk groups after configuration. |
| 36:797 | Warning: The size of hot spare may be too small to protect some disk groups after configuration. |
| 36:798 | Warning: There are unknown type physical disks that are not supported for automatic disk group configuration. |
| 36:799 | Warning: Found a global hot spare disk that is not in slot 0. |
| 36:800 | Warning: Found one or more LUNs that do not meet standard configuration. |
| 36:801 | Warning: Found unsupported RAID type LUNs in disk array. |
| 36:802 | Remote Host Storage |
| 36:803 | Amazon S3 |
| 36:804 | Microsoft Azure Storage |
| 36:805 | Nirvanix MFS |
| 36:806 | Rackspace Cloud Files |
| 36:807 | Iron Mountain ASP |
| 36:808 | Sun Cloud Storage |
| 36:809 | i365 Cloud Storage |
| 36:810 | EMC Atmos |
| 36:811 | Network Files |
| 36:812 | Warning: Found a global hot spare disk that is not in the desired slot. |
| 36:813 | Warning: Found one or more disks in the array with a different disk type compared to the specification provided for Disk Configuration. |
| 36:814 | Warning: The total number of enclosures exceeds the number in the specification provided for Disk Configuration. |
| 36:815 | Warning: Found disks in foreign state, please use Dell OpenManage Server Administrator to import or clear the foreign disk. |
| 36:816 | Failed to add user with MediaAgent management rights to library [<String>]. |
| 36:817 | Warning: Found an unsupported disk array enclosure connected to the host. |
| 36:818 | Found unconfigured physical disk(s) available to configure as global hot spare disk(s). |
| 36:819 | CV Object Server |
| 36:820 | Hitachi Content Platform (REST API) |
| 36:821 | Mezeo Cloud Storage |
| 36:822 | Caringo CAStor |
| 36:823 | AT&T Synaptic Storage |
| 36:824 | Warning: SAS drives are not supported in the disk array. |
| 36:825 | Warning: SATA drives are not supported in the disk array. |
| 36:826 | Dell DX Object Storage Platform |
| 36:827 | OpenStack Object Storage |
| 36:828 | Quantum ActiveScale |
| 36:829 | Library [<String>] already exists. Please enter unique library name. |
| 36:830 | In order to force deconfigure the mountpath, please use Library & Drive Configuration tool. |
| 36:831 | DDN WOS |
| 36:832 | China Mobile oNest |
| 36:833 | Verizon Cloud Storage |
| 36:834 | Google Cloud Storage |
| 36:835 | Preferred |
| 36:836 | Read/Write |
| 36:837 | Read |
| 36:838 | Unable to update Device Controller properties. |
| 36:839 | VMware vCloud Air Object Storage |
| 36:840 | Oracle Cloud Infrastructure Object Storage Classic |
| 36:841 | Storage Array |
| 36:842 | Status: |
| 36:843 | Tray: |
| 36:844 | Drive Type: |
| 36:845 | Free Pool Space (GB): |
| 36:846 | Used Pool Space (GB): |
| 36:847 | Controller A (DNS/Network name, IP): |
| 36:848 | Controller B (DNS/Network name, IP): |
| 36:849 | Oracle Cloud Infrastructure Archive Storage Classic |
| 36:850 | Alibaba Cloud Object Storage Service |
| 36:851 | Amazon Glacier |
| 36:852 | The mount path should have atleast one local path before sharing using DataServer IP |
| 36:853 | Cannot delete the only local device access path when the mount path contains a DataServer IP device path |
| 36:854 | MediaAgent older than 11.0 release cannot be used as DataServer IP |
| 36:855 | Only Linux and Windows MediaAgents can be used as DataServer IP |
| 36:856 | Huawei Object Storage |
| 36:857 | Oracle Cloud Infrastructure Object Storage |
| 36:858 | Oracle Cloud Infrastructure Object Storage (S3 Compatibility) |
| 36:859 | Telefonica Open Cloud Object Storage |
| 36:860 | Oracle Cloud Infrastructure Archive Storage |
| 36:861 | Inspur Cloud Object Storage |
| 36:862 | IBM Cloud Object Storage |
| 36:863 | HPE Catalyst |
| 36:864 | Kingsoft Standard Storage Service |
| 36:865 | Iron Mountain Iron Cloud |
| 36:866 | Microsoft OneDrive |
| 36:867 | S3 Compatible Storage |
| 36:868 | Ceph Object Gateway (S3-compatible) |
| 36:869 | Cloudian HyperStore |
| 36:870 | Dell EMC ECS (S3-compatible) |
| 36:871 | Fujitsu Storage ETERNUS CD10000 |
| 36:872 | Hitachi Content Platform (HS3) |
| 36:873 | IBM Cloud Object Storage (S3-compatible) |
| 36:874 | NetApp StorageGRID |
| 36:875 | CCL Vault v2 |
| 36:876 | Scality RING |
| 36:877 | Wasabi Hot Cloud Storage |
| 36:878 | Nutanix Objects |
| 36:879 | Metallic Recovery Reserve |
| 36:880 | Hitachi Content Platform for Cloud Scale (S3) |
| 36:881 | Metallic Recovery Reserve Azure Bundled |
| 36:882 | Metallic Recovery Reserve Azure Cool |
| 36:883 | Metallic Recovery Reserve Azure Hot |
| 36:884 | Metallic Recovery Reserve OCI IA |
| 36:885 | Metallic Recovery Reserve OCI Standard |
| 36:886 | Metallic Recovery Reserve - Azure AD |
| 36:887 | Metallic Recovery Reserve - Azure MAAS |
| 36:888 | Metallic Recovery Reserve - D365 |
| 36:889 | Metallic Recovery Reserve - Endpoint |
| 36:890 | Metallic Recovery Reserve - O365 |
| 36:891 | Metallic Recovery Reserve - Salesforce |
| 36:892 | Pure Storage FlashBlade |
| 36:893 | VAST Data Universal Storage |
Media Management Service
| Code | Description |
| 25:1 | Failed to create directory <String>. |
| 25:2 | Failed to create directory <String>, code <Number>. |
| 25:3 | Failed to delete file <String>. |
| 25:4 | Failed to delete file <String>, Error: <Number>. Please correct the problem and delete the file manually. |
| 25:5 | Failed to delete subtree <String>. |
| 25:6 | Failed to delete subtree <String>, code <Number>. |
| 25:7 | Failed to delete directory <String>. |
| 25:8 | Failed to delete directory <String>, Error: <Number>. Please correct the problem and delete the directory manually. |
| 25:9 | Failed to get free space for <String>. |
| 25:10 | Failed to get free space for <String>, code <Number>. |
| 25:11 | [<String>]: Invalid drive ID specified. |
| 25:12 | Problem Impersonating user [<String>] in [<String>]. Error <Number>. |
| 25:13 | Problem Logging in user [<String>] in [<String>]. Error <Number>. |
| 25:14 | Problem decrypting password for user [<String>] in [<String>]. |
| 25:15 | [<String>]: Path not found. |
| 25:16 | <String><String> |
| 25:17 | Controller for [<String>] did not connect after several retries. Please check if the target is working properly and the connections are okay. |
| 25:18 | Drive [<String>] in library [<String>] does not unload after several retries. Please check if the library or drive is working properly. |
| 25:19 | <String> |
| 25:20 | Auto re-synchronization with Media Manager service started. Please wait until the MediaAgent is online. |
| 25:21 | The parent directory [<String>] is not found. Creating the entire directory structure [<String>]. |
| 25:22 | Media Mount Manager Service failed to start: [<String>]. |
| 25:23 | Library Control Service failed to start: [<String>]. |
| 25:24 | Failed to move media [<String>] in Library [<String>] to RSM Free Media Pool. Please move the media to RSM Free Media Pool using RSM Console. |
| 25:25 | Please provide the location and identifier for the median with Unique ID [<String>] used by JobID [<Number>]n in Standalone library [<String>] drive [<String>].n |
| 25:26 | [<String>]nn Please provide the location and identifier for the median with Unique ID [<String>] used by Job ID [<Number>]n in Standalone library [<String>] drive [<String>].n |
| 25:27 | Please insert the active media or a new media into the library [<String>] drive [<String>] for Job ID [<Number>] |
| 25:28 | [<String>]nn Please insert a new media into the library [<String>] drive [<String>] for Job ID [<Number>] |
| 25:29 | A CRC error was encountered when trying to read the tape forn Job ID [<Number>] in the Standalone Library [<String>] Drive [<String>]. This could be due to:nn 1. The tape was written with a higher recording format,n 2. Drive needs cleaning,n 3. Media imperfections.nnPlease take appropriate action and re-run the job. |
| 25:30 | Failed to Stamp Media. A CRC error was encountered when trying to read then tape in the Standalone Library [<String>] Drive [<String>]. This could be due to:nn 1. The tape was written with a higher recording format,n 2. Drive needs cleaning,n 3. Media imperfections.nnPlease take appropriate action and re-run the operation. |
| 25:31 | A read error occurred for Job ID [<Number>] for the tape in Library [<String>] Drive [<String>].n Tape volume block size encountered is different from this product's standard.nn Please insert a new tape or erase the data on this tape and re-run the job. |
| 25:32 | The media in the library [<String>] drive [<String>] for JobID [<Number>] is not correct. nnPlease insert the media <Message> <Message> <Message> <Message> |
| 25:33 | <String> |
| 25:34 | with barcode [<String>] |
| 25:35 | from the location [<String>] |
| 25:36 | with last write-time=[<String>]. |
| 25:37 | <String> |
| 25:38 | The media in the drive is already in use by this product or it could be a cleaning media. Please eject this media nThen insert the required media [<String>] for JobID [<Number>] <Message> <Message> <Message> <Message> |
| 25:39 | Please insert the required media [<String>] for Job ID [<Number>] <Message> <Message> <Message> <Message> |
| 25:40 | with identifier [<String>]n |
| 25:41 | OR a new media |
| 25:42 | into the library [<String>] drive [<String>]. |
| 25:43 | Media ID of the OML does not match. Expected [<String>] Got [<String>]. |
| 25:44 | While accessing a drive the Serial Number obtained [<String>] is different from expected Serial Number [<String>]. |
| 25:45 | Failed to flush the contents of the volume to the disk during an I/O operation on MediaAgent [<String>]. Please stop all applications accessing the disks on this machine including Windows Explorer. |
| 25:46 | Cleaning Media is loaded in the drive on [<String>] for Job ID [<Number>]. Please unload the cleaning media. |
| 25:47 | [<Message>]nn Please insert a new media into the library [<String>] drive [<String>] for Job ID [<Number>] |
| 25:48 | The tape drive [<String>] is no longer accessible from the MediaAgent [<String>]. This drive controller is marked as inaccessible. Please check if the drive is working properly and the host to drive connection is okay. |
| 25:49 | The tape drive [<String>] has lost accessibility from the MediaAgent [<String>] and further scans on the SCSI Bus will be stopped for discovering this drive. Please reset this drive manually when the communication issues between this MediaAgent and drive are resolved. |
| 25:50 | The tape drive [<String>], which had lost access from the host, is automatically detected on the MediaAgent [<String>]. This drive controller is marked as accessible. |
| 25:51 | The drive serial number obtained [<String>] is different from the expected SCSI Identifier [<String>] known by the Library medium changer. |
| 25:52 | System Compatibility check failed. All disk libraries using Dell disk arrays will be marked offline. |
| 25:53 | System Compatibility check failed with a critical error. All disk libraries using Dell disk arrays will be marked offline. |
| 25:54 | System Compatibility check completed with warning. |
| 25:55 | MOUNTPATH_LABEL file is missing on mountpath [<String>]. Pruning will be skipped for this mount path. |
| 25:56 | Cannot submit edge drive pruning request to web server at MediaAgent [<String>]. |
| 25:57 | Cannot submit edge drive pruning request to web server for subclient [<String>] at MediaAgent [<String>]. |
| 25:58 | Cannot submit NFS object store pruning request to web server for subclient [<String>] at MediaAgent [<String>]. |
Network Module
| 9:1 | <String>Remote system [<String>]. Protocol version is invalid. |
| 9:2 | <String>Remote system [<String>]. Internal negotiation error - negotiation flag set, but the message type is not a connection [<HexNumber>=<String>]. |
| 9:3 | <String>Remote system [<String>]. Value for an argument [<String>] was invalid. |
| 9:4 | <String>Remote system [<String>]. Message type is not PM_CONNECT and protocol has not been negotiated [<HexNumber>=<String>]. |
| 9:5 | <String>Remote system [<String>]. Max data value is invalid or has not been negotiated. |
| 9:6 | <String>Remote system (unknown). Could not find CvSession object on the command line. |
| 9:7 | <String>Remote system (unknown). Could not map view of CvSession object from shared memory - received error: [<Number>=<String>]. |
| 9:8 | <String>Remote system (unknown). Could not receive Communications Service Application msg. Incoming size [<Number>] is greater than max size [<Number>]. |
| 9:9 | <String>Remote system (not applicable). XDR Network byte order routine returned error - message data is invalid. |
| 9:10 | <String>Remote system [<String>]. XDR Network byte order routine returned error - message data is invalid [<HexNumber>=<String>]. |
| 9:11 | <String>Remote system [<String>]. XDR Network byte order routine returned error - not enough space for converted data [<HexNumber>=<String>]. |
| 9:12 | <String>Remote system [<String>]. Data length [<Number>] is too big. Protocol max is [<Number>]. Data max is [<Number>]. |
| 9:13 | <String>Remote system [<String>]. Required parameter missing [<String>]. |
| 9:14 | <String>Remote system [<String>]. Socket is currently in an open state - cannot perform desired action. |
| 9:15 | <String>Remote system [<String>]. The socket open failed. Error returned [<String>]. |
| 9:16 | <String>Remote machine [<String>]. The socket connect failed. Error returned [<Number>=<String>]. Check Network Connectivity. |
| 9:17 | <String>Remote machine [<String>]. The network connection failed - the remote process is not listening. Error returned [<Number>=<String>]. Check Network Connectivity and ensure that services are running on the remote machine. |
| 9:18 | <String>Remote system [<String>]. The socket send failed. Error returned [<Number>=<String>]. |
| 9:19 | <String>Remote system [<String>]. The socket receive failed. Error returned [<String>]. |
| 9:20 | <String>Remote system [<String>]. The socket function was interrupted by signal. Error returned [<Number>=<String>]. |
| 9:21 | <String>Remote system [<String>]. The socket accept failed. Error returned [<Number>=<String>]. |
| 9:22 | <String>Remote system [<String>]. The socket select failed. Error returned [<Number>=<String>]. |
| 9:23 | <String>Remote system [<String>]. The socket receive was successful but no data was received. Error returned [<Number>=<String>]. |
| 9:24 | <String>Could not translate the name/address of machine [<String>] into an address/name. Error returned [<String>]. Check DNS or Host Files. |
| 9:25 | <String>Remote system (not applicable). The socket bind to address failed. Error returned [<Number>=<String>]. |
| 9:26 | <String>Remote system (not applicable). The socket getsockname failed. Error returned [<Number>=<String>]. |
| 9:27 | <String>Remote system (not applicable). The socket listen failed. Error returned [<String>]. |
| 9:28 | <String>Remote system (not applicable). The service name [<String>] could not be found. |
| 9:29 | <String>Remote system [<String>]. Unexpected message type. Received message type [<HexNumber>=<String>], Expected message type [<HexNumber>=<String>]. |
| 9:30 | <String>Remote system [<String>]. The socket is in an invalid state [<String>] for desired action. |
| 9:31 | <String>Remote system [<String>]. Receive timed out waiting for message. |
| 9:32 | <String>Remote system [<String>]. The abort operation was successful. |
| 9:33 | <String>Remote system [<String>]. The service [<String>] could not be found. |
| 9:34 | <String>Remote machine [<String>]. The socket connection was lost unexpectedly. MyIoctl returned 0 bytes waiting. Check Network Connectivity. |
| 9:35 | <String>Remote system [<String>]. Authentication failed. Could not get the client name from platform information for platform type [<String>]. |
| 9:36 | <String>Remote system [<String>]. Could not get the password from platform information or the database - authentication failed. |
| 9:37 | <String>Remote system [<String>]. Could not find the client password in the database - authentication failed. |
| 9:38 | <String>Remote system [<String>]. Failed authentication returned from server. |
| 9:39 | <String>Remote system [<String>]. Failed authentication returned from client. |
| 9:40 | <String>Remote system [<String>]. Unexpected message type received [<HexNumber>=<String>] - authentication failed. |
| 9:41 | <String>Remote system [<String>]. Could not encrypt challenge string when connecting - authentication failed. |
| 9:42 | <String>Remote system [<String>]. Password received from client did not match the database password for that client - authentication failed. |
| 9:43 | <String>Remote system [<String>]. Communications Service returned error when initiating post message processing. Pmtype=[<Number>]. |
| 9:44 | <String>Remote system [<String>]. Communications Service returned error when executing remote library [<String>] function [<String>]. |
| 9:45 | <String>Remote system [<String>]. Communications Service returned error when executing remote command [<String>] arguments [<String>]. |
| 9:46 | <String>Remote system [<String>]. The local file [<String>] could not be found during file transfer. |
| 9:47 | <String>Remote system [<String>]. The remote file [<String>] could not be found during file transfer. |
| 9:48 | <String>Remote system [<String>]. The remote system returned no-space when transferring file [<String>]. |
| 9:49 | <String>Remote system [<String>]. The remote system returned write error when transferring file [<String>]. |
| 9:50 | <String>Remote system [<String>]. Local write error when transferring file [<String>]. |
| 9:51 | <String>Remote system [<String>]. The remote system returned error indicating the file exists when transferring file [<String>]. |
| 9:52 | <String>Remote system [<String>]. Local file already existed when transferring file [<String>]. |
| 9:53 | <String>Remote system [<String>]. The remote system returned unknown error when transferring file [<String>]. |
| 9:54 | <String>Remote system [<String>]. Local unexpected error when transferring file [<String>]. |
| 9:55 | <String>Remote system [<String>]. The remote system returned read error when transferring file [<String>]. |
| 9:56 | <String>Remote system [<String>]. Local read error when transferring file [<String>]. |
| 9:57 | <String>Remote system [<String>]. The remote system returned open error when transferring file [<String>]. |
| 9:58 | <String>Remote system [<String>]. Local file could not be opened when transferring file [<String>]. |
| 9:59 | <String>Remote system [<String>]. Receive return error when transferring file [<String>]. |
| 9:60 | <String>Remote system [<String>]. Could not determine platform type. |
| 9:61 | <String>Remote system [<String>]. Remote execute request returned error: [<String>]. |
| 9:62 | <String>Remote system [<String>]. Invalid platform type: [<String>]. |
| 9:63 | Internal Error: Function [<String>] Argument [<String>]: Invalid or missing argument! |
| 9:64 | Internal Error: Function [<String>]: Operation only allowed on CommServe! |
| 9:65 | Internal Error: CVNetMessage class not initialized properly! |
| 9:66 | Internal Error: Function [<String>]: CVNetMessage does not support connection type requested! |
| 9:67 | Internal error: pre-install connection is only allowed to the CommServe. |
| 9:68 | Internal Error: CVNetMessage requires the request, response, subsystem identifiers to be initialized! |
| 9:69 | Internal Error: CVNetMessage requires the loadable DLL Name and Entry point to be initialized! |
| 9:70 | Internal Error: CVNetMessage requires the remote hostname to be initialized! |
| 9:71 | Internal Error: Could not allocate space for buffers. |
| 9:72 | Failed to establish connection to remote client hostname [<String>]! |
| 9:73 | Deprecated message. |
| 9:74 | <String> XML Convert: Could not convert XML message [<String>]. Error [<String>]. |
| 9:75 | Failed to resolve host name [<String>]. Please make sure that the DNS settings are appropriate. Ensure hostname is resolvable and the port is open. |
| 9:76 | The current version of the computer [<String>] does not support executing a process by impersonating a user. |
| 9:77 | Deprecated message. [<String>]. |
| 9:78 | <String>Failed to initialize Windows COM subsystem. |
| 9:79 | <String>Failed to initialize Server SecureSocket COM object. |
| 9:80 | <String>Failed to initialize Client SecureSocket COM object. |
| 9:81 | <String>Failed to get Session Key from Security object. |
| 9:82 | <String>Failed to get Public Key from Security object. |
| 9:83 | <String>Failed to get System Time from Security object. |
| 9:84 | <String>Failed to encode [<String>]. |
| 9:85 | <String>Failed to decode [<String>]. |
| 9:86 | Internal Error [<Number>] in CVSession while communicating with remote host [<String>]. [<String>] |
| 9:87 | Internal Error [<Number>] in CVSession. [<String>] |
| 9:88 | The network connection was lost unexpectedly. Check Network Connectivity. |
| 9:89 | Authentication failed for host [<String>]. Could not find the client entry in database. |
| 9:90 | Authentication failed for host [<String>]. Network password does not match. |
| 9:91 | CVSession Authentication failed for host [<String>]. Password is not available on the host. |
| 9:92 | Timed out waiting for a response. |
| 9:93 | Machine [<String>] is Blacklisted. It is not allowed to connect. |
| 9:94 | Unable to connect to remote machine [<String>]. Please check Network Connectivity. |
| 9:95 | Connection to remote machine [<String>] refused. Please check that the services are running on the remote machine. |
| 9:96 | Unable to resolve host name [<String>]. Please make sure that the DNS settings are appropriate. |
| 9:97 | Unable to execute command [<String>] on remote machine [<String>]. Please ensure that the latest feature release is installed on the remote machine. If the problem persists contact your software provider. |
| 9:98 | SSL authentication with [<String>] has failed: [<String>]. Check if the client has a valid certificate. |
| 9:99 | Client [<String>] is not allowed to connect with built-in certificates. If you are reinstalling, please revoke all the client's outstanding certificates in the Certificate Administration applet of Control Panel in the GUI. |
| 9:100 | <String>Remote system [<String>]. The remote system returned error during move when transferring file [<String>]. |
| 9:101 | Can't generate new certificate for client [<String>] because there are too many of them already: [<Number>]. Try revoking some first. |
| 9:102 | Peer [<String>] didn't accept any of our CAs |
| 9:103 | Offline Replication failure: [<String>]. |
| 9:104 | There is no incoming network connection from remote machine [<String>]. Please check if the remote machine is able to connect to the current machine using cvping tool on tunnel port |
| 9:105 | The network connection to [<String>] timed out. Please check if there is any firewall between the machines. Ensure that the port is open. Error returned [<Number>=<String>]. |
| 9:106 | <String>Please verify is system time is correct on source machine and destination machine [<String>]. |
| 9:107 | Can not communicate with the remote machine [<String>]. Please make sure both the machines belong to the same company. |
| 9:108 | Unable to execute command [<String>] on remote machine [<String>] as the <String>. |
Connection Manager
| 21:1 | [<String>]:No errors. |
| 21:2 | [<String>]:Select timed out. |
| 21:3 | [<String>]:Received exit return code from callback. |
| 21:4 | [<String>]:Could not allocate memory to add node to list of sessions. |
| 21:5 | [<String>]:Could not open session for listening. |
| 21:6 | [<String>]:Could not set port to [<Number>]. |
| 21:7 | [<String>]:Could not set service [<String>] during initialization. |
| 21:8 | [<String>]:Could not complete attaching to session from [<String>] to [<String>] at port <Number>. Please check the following n 1. Network connectivity between machines. n 2. If there is a firewall configured, make sure that the firewall configuration in the software is correct. n 3. Check for services on the Machine [<String>]. |
| 21:9 | [<String>]:Could not find socket [<Number>] in list. |
| 21:10 | [<String>]:Socket error when selecting data from socket list [<Number>=<String>]. |
| 21:11 | [<String>]:Socket error when accepting incoming socket [<Number>=<String>]. |
| 21:12 | [<String>]:Could not allocate buffer space for incoming message on socket [<Number>]. |
| 21:13 | [<String>]:Error when receiving message on socket [<Number>]. |
| 21:14 | [<String>]:Error when freeing session buffers for message [<HexNumber>=<String>]. |
| 21:15 | [<String>]:Cannot change listen port parameters after listening has started. |
| 21:16 | [<String>]:Session server state is not listening, cannot wait for messages. |
| 21:17 | [<String>]:Could not register port for service name [<String>] in platform information. |
| 21:18 | [<String>]:Could not create mutex. Error returned [<Number>=<String>]. |
| 21:19 | [<String>]:Session error. Error returned [<Number>=<String>]. |
| 21:20 | [<String>]:Session could not be added - it is in an invalid state. |
| 21:21 | [<String>]:Could not begin thread. Error returned [<Number>=<String>]. |
| 21:22 | [<String>]:Could not determine a list of sockets to listen on. |
SAN Volume Configuration
| 47:1 | Could not complete function:[<String>] - missing parameter:[<String>]. |
| 47:2 | Could not send message to host:[<String>], received session error:[<String>=<String>]. |
| 47:3 | Could not attach session to host:[<String>], received session error:[<String>=<String>]. |
| 47:4 | Could not free message type:[<String>], received session error:[<String>=<String>]. |
| 47:5 | Could not receive message:[<String>] from host:[<String>], received session error:[<String>=<String>]. |
| 47:6 | Could not receive message from host:[<String>], received session error:[<String>=<String>]. |
| 47:7 | Configure SAN Volume... |
| 47:8 | Configure SAN Volume...Successful. |
| 47:9 | Configure SAN Volume...Failed. |
| 47:10 | Deconfigure SAN Volume... |
| 47:11 | Deconfigure SAN Volume...Successful. |
| 47:12 | Deconfigure SAN Volume...Failed. |
| 47:13 | Detect SAN Volume... |
| 47:14 | Detect Host:[<String>] completed successfully. SAN Volume:[<String>]. |
| 47:15 | Detect SAN Volume...Failed. |
| 47:16 | Detect Host:[<String>] failed. Error: <String> |
| 47:17 | Ready |
| 47:18 | Reading current configuration... Please wait. |
| 47:19 | Error reading the current configuration. |
| 47:20 | Could not delete the configured object [<String>]. |
| 47:21 | Could not read the platform information. |
| 47:22 | Unknown event! |
| 47:23 | Unknown message! |
Meta-Data Database
| 22:1 | No rows were affected or no data was returned from the operation. |
| 22:2 | Where clause was required for the previous operation. |
| 22:3 | No values were specified for the previous operation. |
| 22:4 | RDBMS specific library has not been substituted for the stub library. |
| 22:5 | Expecting one row, received many. |
| 22:6 | Already connected to database. |
| 22:7 | No (expected) previous connection to reestablish. |
| 22:8 | No (expected) transaction in progress. |
| 22:9 | Can't lock table. No referenced transaction object. |
| 22:10 | No database server in environment set. |
| 22:11 | Timed out waiting for locks to clear. |
| 22:12 | Statement timed out before completion. |
| 22:13 | Method is not supported by this object. |
| 22:14 | Connection refused by data source. |
| 22:15 | Constraint violation (foreign or primary key). |
| 22:16 | Application bound with conflicting version of database object. |
| 22:17 | Open cursor was attempted and cursor was still open. |
| 22:18 | Fetch was attempted and cursor was closed. |
| 22:19 | Previous statement handle for this object is still open. |
| 22:20 | Error code [<Number>] returned for previous operation. Please call your vendor's support hotline if the problem persists. |
| 22:21 | Attempt to run a command on an already busy connection. |
| 22:22 | Conflict between dll and database object revisions. |
| 22:23 | Database Space Check Alert: Problem fetching global parameter [<String>], error = [<Number>]. Default value of [<Number>] will be used. |
| 22:24 | Database Space Check Alert: Problem opening table containing list of files in the database. Error [<Number>] returned. |
| 22:25 | Database Space Check Alert: Problem fetching rows from table containing list of files in the database. Error [<Number>] returned. |
| 22:26 | Database Space Check Alert: The filegroup [<String>][id=<Number>] may not have sufficient room to grow. The free space is less than <Number> percent on all drives. |
| 22:27 | Database Space Check Alert: The potential filegroup growth on drive <String>: is below the <Number> percent free space threshold (<Number> KB growth/<Number> KB free). |
| 22:28 | Database Space Check Alert: filegroup [<String>][id=<Number>] cannot grow past fixed file size set. |
| 22:29 | Transaction started at [<String>] exceeded current lock timeout period of [<Number>] seconds by [<Number>] seconds. |
| 22:30 | Could not establish connection to [<String>] on attempt [<Number>]. |
| 22:31 | Established connection to [<String>] on attempt [<Number>]. |
| 22:32 | DBclass Internal Buffer Overrun. |
| 22:33 | Operation requires that the table have a primary key. |
| 22:34 | Error for operation [<String>] on table [<String>]. |
| 22:35 | Cannot set [where] clause for object of this subclass (Cursor or Stored Procedure). |
| 22:36 | Cannot set [order by] clause for object of this subclass (Cursor or Stored Procedure). |
| 22:37 | Drive [<String>:] has less than <Number> percent free disk space remaining. There is [<Number>] of [<Number>] KB free. |
Data Classifier Client
| 78:1 | Exiting because event initialization failed. |
| 78:2 | Error notifying Job Manager of successful completion. |
| 78:3 | Error notifying Job Manager of failure. |
| 78:4 | Started. |
| 78:5 | Exiting... |
| 78:6 | Failed to Initialize Global Data. |
| 78:7 | Initial file transfer successful, src: [<String>] dest: [<String>] desthost: [<String>]. |
| 78:8 | Failed to synch files for src: [<String>] dest: [<String>] desthost: [<String>]. |
| 78:9 | Failed to start pipeline for src: [<String>] dest: [<String>] desthost: [<String>]. |
| 78:10 | Failed to get LOG object in configuration for src: [<String>] dest: [<String>] desthost: [<String>]. |
| 78:11 | Failed to Open Collect File. |
| 78:12 | Failed to Write into Collect File. |
| 78:13 | Failed to Read from Collect File. |
| 78:14 | Failed to Seek into Collect File. |
| 78:15 | Failed to Create Collect File. |
| 78:16 | Failed to Restart Job, Invalid restart string. |
| 78:17 | New Path Added to Repset: [<Number>] SubClient: [<Number>] from [<String>] to [<String>]. |
| 78:18 | Path Repset: [<Number>] SubClient: [<Number>] Removed. |
| 78:19 | Path Started Repset: [<Number>] SubClient: [<Number>]. |
| 78:20 | Path Aborted Repset: [<Number>] SubClient: [<Number>]. |
| 78:21 | Path Paused Repset: [<Number>] SubClient: [<Number>]. |
| 78:22 | Path Resume Repset: [<Number>] SubClient: [<Number>] successful. |
| 78:23 | Could not Add Path, Repset: [<Number>] SubClient: [<Number>]. |
| 78:24 | Could not Remove Path, Repset: [<Number>] SubClient: [<Number>]. |
| 78:25 | Could not Start Path, Repset: [<Number>] SubClient: [<Number>]. |
| 78:26 | Could not Abort Path, Repset: [<Number>] SubClient: [<Number>]. |
| 78:27 | Could not Pause Path, Repset: [<Number>] SubClient: [<Number>]. |
| 78:28 | Could not Resume Path, Repset: [<Number>] SubClient: [<Number>]. |
| 78:29 | Configuration Missing. |
| 78:30 | Configuration File Missing. |
| 78:31 | Configuration Corrupted. |
| 78:32 | FRN configuration missing. |
| 78:33 | Failed to update FRN configuration. |
| 78:34 | Initiated Log Transfer for RepSet: [<Number>] SubClient:[<Number>]. |
| 78:35 | Deleting log file [<String>]. |
| 78:36 | This machine has 'Delete Log Configuration' Set! |
| 78:37 | Consistency Point successfully marked for the replication set [<Number>]. |
| 78:38 | Consistency Point cannot be marked for the repset [<Number>]. |
| 78:39 | Snapshot is successfully taken for the volume [<String>]. |
| 78:40 | Snapshot cannot be taken for the volume [<String>]. |
| 78:41 | Successfully made database entries for CP JobID [<Number>]. |
| 78:42 | Cannot make database entries for CP JobID [<Number>]. |
| 78:43 | Database needed to be rebuilt on volume [<String>]. |
| 78:44 | Failed to open Database. Failure may be due to lack of drive space. Check drive space; Db Path [<String>]; ErrorMsg [<String>]; Misc-ID [<String> - <String>] |
| 78:45 | Failed to execute Database command; command [<String>]; ErrorMsg [<String>]; Misc-ID [<String> - <String>]. Check drive space. |
| 78:46 | Received Database error message; ErrorID [<String>]; Misc-ID [<String> - <String>]. Check drive space. |
| 78:47 | Failed Active Directory search using group [<String>]; Misc-ID [<String> - <String>]. Check valid group name and/or credentials. |
| 78:48 | Failed Active Directory connection for domain [<String>]; Misc-ID [<String> - <String>]. Check valid domain name and/or credentials. |
| 78:49 | Free space on volume [<String>] is approaching 1 GB. |
| 78:50 | Loading DC driver succeeded. |
| 78:51 | Failed to load DC driver. [<String>]. |
| 78:52 | DC Monitor request sent for the following volumes. [<String>] |
| 78:53 | DC Stop Monitor request sent for the following volumes. [<String>] |
Documentum iDataAgent
| 96:1 | Failed to initialize Documentum client agent. |
| 96:2 | Failed to generate Collect Files for Full Text Index Backup. Please make sure the Path [<String>] specified for Full Text Index is valid. |
| 96:3 | Error during Backup of Full Text Index [<String>]. |
| 96:4 | Failed to communicate to client [<String>] for generating Collect Files. Please make sure this product's Services are running on this client. |
| 96:5 | Failed to communicate to Full Text Index client [<String>] for Full Text Index Backup. Please make this product's Services are running on this client. |
| 96:6 | Failed to generate Collect files for Storage Area [<String>]. Please make sure to associate the Storage Area with correct client. |
| 96:7 | Failed to generate Collect Files. |
| 96:8 | Failed to update Job Manager for progress. |
| 96:9 | Failed to notify Job Manager of Job Completion. |
| 96:10 | Failed to communicate with client [<String>] for Storage Area Backup. Please make sure this product's Services are running. |
| 96:11 | Failed to receive message from Storage Area Client. Make sure this product's Services are running on all Storage Area hosts. |
| 96:12 | Failed to create index for Storage Area Backups. |
| 96:13 | Failed to finalize the index for Storage Area Backups. |
| 96:14 | Storage Area Backup has failed on all nodes. |
| 96:15 | Documentum Discovery Request has failed with error [<String>] |
| 96:16 | Encountered error during Documentum Response parsing. |
| 96:17 | Full Text Index Quiesce Script is not specified in the subclient properties. |
| 96:18 | Full Text Index Unquiesce Script is not specified in the subclient properties. |
| 96:19 | Full Text Index Quiesce Script [<String>] execution failed. Please check the logs and verify the Quiesce Script execution. |
| 96:20 | Full Text Index Unquiesce Script [<String>] execution has failed. Please check the logs and verify the UnQuiesce Script execution and restart Index Server and Agent. |
| 96:21 | No new documents have been added since the last FULL Backup. |
| 96:22 | No new documents have been added since the last FULL Backup on client [<String>]. Skipping Incremental Backup on this client. |
| 96:23 | No documents to include in the FULL Backup for Storage Area client [<String>]. Skipping Storage Area Backup on this client. |
| 96:24 | Streams are not reserved for Storage Area Client [<String>]. Skipping Backup on this client. |
| 96:25 | Failed to generate Collect Files for Storage Area Backup. error message [<String>]. |
Datamover
| 40:1 | Out of Memory. |
| 40:2 | Failed to log on as user [<String>], domain [<String>] for writing to disk: |
| 40:3 | Failed to impersonate user [<String>], domain [<String>] for writing to disk: |
| 40:4 | Failed to decrypt password for user impersonation: |
| 40:5 | Media with barcode [<String>] in library [<String>] is write-protected. |
| 40:6 | Error occurred in Library [<String>], Drive Name [<String>], Barcode [<String>], Path [<String>] [<String>]. For more help, please call your vendor's support hotline. |
| 40:7 | Error occurred in Disk Media, Path [<String>] [<String>]. For more help, please call your vendor's support hotline. |
| 40:8 | The required media with barcode [<String>] needed for <String> job is not inside the library [<String>]. |
| 40:9 | There is no spare media which the job can use to continue. Please import a spare media. |
| 40:10 | Failed to initialize client restore process. Please check that all services are running, that there is sufficient memory and that there is not a network problem. |
| 40:11 | Failed to set restore parameters. Please check that all services are running, that there is sufficient memory and that there is not a network problem. |
| 40:12 | Failed to receive source path from the CommServe. Please check that all services are running, that there is sufficient memory and that there is not a network problem. |
| 40:13 | Failed to receive destination path from the CommServe. Please check that all services are running, that there is sufficient memory and that there is not a network problem. |
| 40:14 | Failed to get the archiving rules from the CommServe. Please check that all the services are running. If the problem persists, please call your vendor's support hotline. |
| 40:15 | Cannot initialize stubbing. Please check if MAPI profile, message list file, etc. are correct. |
| 40:16 | Failed to initialize the MediaAgent modules as one of the parameters is invalid. |
| 40:17 | Failed to initialize the MediaAgent modules as the platform is invalid. |
| 40:18 | Failed to get the host name of the MediaAgent. |
| 40:19 | Failed to allocate memory to initialize the MediaAgent modules. |
| 40:20 | Failed to establish connection with the Media Manager Service. |
| 40:21 | Wrong sequence of operations encountered during the job. |
| 40:22 | Failed to create archive file on media as the MediaAgent modules have not yet been initialized. |
| 40:23 | Failed to get the information of the archive file that was created from the archive manager on the CommServe. |
| 40:24 | The media have not been initialized to continue the job. |
| 40:25 | Failed to determine the size of the chunk for the archive file. |
| 40:26 | Failed to determine the version of the CommServe. |
| 40:27 | Failed to get the unique ID of the chunk from the archive manager on the CommServe. |
| 40:28 | Interruption of data transfer due to network problems. |
| 40:29 | Data received on the MediaAgent has invalid data size. |
| 40:30 | During a backup, MediaAgent received data from a client which was not selected for the current backup operation. |
| 40:31 | Failed to position on the correct location on the media to start reading the data. |
| 40:32 | Data from the media is unreadable. |
| 40:33 | Failed to create a new chunk for the archive file. |
| 40:34 | Failed to determine the last write position on the media to continue the backup. |
| 40:35 | Failed to allocate required memory. |
| 40:36 | Failed to get the chunk information for the archive files from the archive manager on the CommServe. |
| 40:37 | Failed to get the media needed for restoring the data. |
| 40:38 | Failed to parse the metadata that was read from the media. |
| 40:39 | Failed to update the chunk information to the archive manager on the CommServe. |
| 40:40 | Failed to inform the archive manager that the archive file is closed on the media. |
| 40:41 | Invalid information sent to the archive manager while closing the chunk on the media. |
| 40:42 | Unable to determine the type of media. |
| 40:43 | Failed to determine the block size that will be used to write or read from the media. |
| 40:44 | The backup media has not been initialized properly. |
| 40:45 | Failed to update the CommServe Database with the number of file markers written on the tape. |
| 40:46 | The medium was never initialized to perform the backup. |
| 40:47 | Archive file of unknown type has been requested for creation. |
| 40:48 | The NetWare volume name is invalid or is not specified in the correct format. |
| 40:49 | Failed to get free disk space on the disk volume. |
| 40:50 | Failed to connect or create a remote disk mount path. |
| 40:51 | Failed to update CommServe Database with metadata information. |
| 40:52 | Failed to contact CommServe Services from the MediaAgent[<String>] during the start of the Data Transfer operation. Please check the network connectivity from this MediaAgent to the CommServe and make sure services are running on the CommServe. |
| 40:53 | Failed to initialize the data writer. |
| 40:54 | MediaAgent module is unable to communicate with the CommServe Services even after several retries. |
| 40:55 | Found an Active MediaAgent resource which is not being used by any running jobs. Job might be failed or stopped/killed by the user. |
| 40:56 | Failed to start the modules that monitor the MediaAgent resource that is being used. |
| 40:57 | Erase Migration Data failed, could be related to querying directory or MAPI logon. |
| 40:58 | Failed to erase some of migration data, could be stubs from previous releases or archive file lookup error. |
| 40:59 | Retrieving index from Media. |
| 40:60 | Data Writer for the current multiplexing stream is in an Invalid state. |
| 40:61 | Auxiliary Copy cannot write Multiplexed Data on to a Deduplication enabled library as this operation is not supported. |
| 40:62 | Failed to retrieve Archive metadata for this job from the CommServe Database. Please contact your vendor's customer support. |
| 40:63 | Failed to impersonate user [<String>] for writing to disk path [<String>]. |
| 40:64 | Error occurred in Library [<String>], Drive Name [<String>], Barcode [<String>], Path [<String>] [<Message>]. For more help, please call your vendor's support hotline. |
| 40:65 | Error occurred in Disk Media, Path [<String>] [<Message>]. For more help, please call your vendor's support hotline. |
| 40:66 | Unable to communicate with the device [<String>]. Please check whether the correct version of drivers has been installed for this device. Please check whether the devices have been configured properly. |
| 40:67 | The device is busy or not yet initialized. Please check whether the device is initialized and working properly. |
| 40:68 | Check whether the path [<String>] is accessible. |
| 40:69 | Backup file does not exist on the path [<String>]. Check whether the path [<String>] is accessible and the backup file exists at that location. |
| 40:70 | Backup file already exists on the path [<String>]. This could be due to an error in previous deconfiguration of mount path [<String>]. |
| 40:71 | Unable to communicate with the device [<String>]. Please check whether the correct version of drivers has been installed for this device. |
| 40:72 | Error occurred while writing to the drive [<String>]. Check whether the drive is online and connected properly. Please check whether the correct version of drivers has been installed for this device. |
| 40:73 | Drive did not respond to commands properly. There may be too many drives on the SCSI Bus operating at the same time. Try reducing the number of drives on the SCSI Bus. Try reducing the synchronous transfer rate on the SCSI Controller. Or two controlling programs may be accessing the library concurrently. For more details, please check to see a corresponding Operating System event for this device. |
| 40:74 | Please check whether the correct version of drivers has been installed for this device. Please check whether the SCSI Bus is terminated properly. |
| 40:75 | Error occurred while reading from the drive [<String>]. See if the drive is online and connected properly. Please check whether the correct version of drivers has been installed for this device. |
| 40:76 | Device did not respond to commands properly. The SCSI Controller reset the SCSI Bus. For more details, please check to see a corresponding Operating System event for this device. |
| 40:77 | The mount path [<String>] is full. Add a new mount path to a different disk so that the job can resume. |
| 40:78 | The end of data marker was reached during an operation. |
| 40:79 | The block size is incorrect on the tape. Please format the tape using TapeTest.exe application and try again. For more help, call Customer Support. |
| 40:80 | The tape that was in the drive has been replaced or removed. Please make sure that the intended tape is in the drive. |
| 40:81 | The indicated device requires reinitialization due to hardware errors. Please check whether the correct version of drivers has been installed for this device. |
| 40:82 | The drive requires cleaning. Please retry after cleaning the drive. |
| 40:83 | The operation failed since the library door is opened. Retry the job after completing the operations with library. |
| 40:84 | Unable to communicate with the device [<String>]. Please check whether the correct version of drivers has been installed for this device. |
| 40:85 | No media found in drive. Please make sure that the media in the drive is not accessed by any other applications. |
| 40:86 | The medium is write protected. Please change the write-protect settings on the tape and retry the job. |
| 40:87 | The drive is being used by another application or by another job. Please wait and retry the job later. |
| 40:88 | The drive reported a CRC error. This could be because the drive needs cleaning or the tape used is old. Please retry the operation after cleaning the drive and use a different tape. |
| 40:89 | The drive reported a CRC error. This could be due to a bad block on the disk. Please run disk utilities to correct this problem. |
| 40:90 | The Physical End of Tape Reached. This could be because Early Warning for Logical End of Tape (LEOT) has not received from the Tape Drive. |
| 40:91 | Failed to Copy or verify Chunk [<Number>] in media [<String>], Storage Policy [<String>], Copy [<String>], Host [<String>], Path [<String>], File Number [<Number>], Backup Jobs [<String>]. n<Message> <Message> |
| 40:92 | During a backup, MediaAgent received invalid data sequence from the client. Please run diagnostics on the Network for the data integrity of the data transferred between the client and MediaAgent. |
| 40:93 | During a backup, MediaAgent received invalid data sequence from the client [<String>]. Please run diagnostics on the Network for the data integrity of the data transferred between the client and MediaAgent. |
| 40:94 | No Files were archived as No Rules were selected. |
| 40:95 | No Files matched archival criteria. |
| 40:96 | No Files were migrated as Rules were disabled. |
| 40:97 | Hardware device does not support Hardware Encryption. Please verify with your hardware vendor. If device does not support hardware encryption, turn off the hardware encryption feature from GUI Console and retry the operation. |
| 40:98 | Failed to enable hardware encryption on the hardware device. Please make sure that your device supports hardware encryption and it's functioning correctly. |
| 40:99 | Failed to disable hardware encryption on the hardware device. Please make sure that your device supports hardware encryption and it's functioning correctly. |
| 40:100 | Failed to retrieve Mount Path information using mount path ID [<Number>]. Please make sure that Mount Path is configured correctly. |
| 40:101 | Current backup is Deduplicated and is attempting to use the same writer resource used for a different job/stream. This may happen because of a network disconnect issue or a network call being stuck. This job will proceed on the next resume. |
| 40:102 | Waiting for Silo retrieval job [<Number>] to complete retrieval of volume [<Number>]. |
| 40:103 | Dependent Silo retrieval job [<Number>] failed while retrieving volume [<Number>]. |
| 40:104 | Starting conversion of DMAPI stubs to the new format. |
| 40:105 | Failed to convert DMAPI stubs to the new format. Please check the client logs for more details. |
| 40:106 | Successfully converted DMAPI stubs to the new format. |
| 40:107 | Waiting for Silo retrieval job [<Number>] to complete retrieval of data at path [<String>]. |
| 40:108 | Dependent Silo retrieval job [<Number>] failed while retrieving data at path [<String>]. |
| 40:109 | Error occurred in Cloud Storage Library Path [<String>] [<Message>]. For more help, please call your vendor's support hotline. |
| 40:110 | Client-side deduplication enabled job found Cache-Database and Deduplication-Database are out of sync. Job will be proceeded by next resume. |
| 40:111 | Failed to open Deduplication Database (DDB) on the MediaAgent[<String>], please check network connectivity between [<String>] and DDB MediaAgent [<String>]. |
| 40:112 | Starting conversion of CXFS stubs to the new format. |
| 40:113 | Failed to convert CXFS stubs to the new format. Please check the client logs for more details. |
| 40:114 | Successfully converted CXFS stubs to the new format. |
| 40:115 | Unable to mount active media. [<String>]. |
| 40:116 | <String> |
| 40:117 | Failed to get media during write. |
| 40:118 | Failed to open deduplication database on one or more of the following MediaAgents [<String>]. Please check the network connectivity between [<String>] and the DDB MediaAgents. |
| 40:119 | Check if the specified network path is accessible from MediaAgent [<String>]. |
| 40:120 | SIDB is in incorrect State. Failed to open deduplication database on one or more of the following MediaAgents [<String>]. |
| 40:121 | SIDB process has been failed on one or more of the following MediaAgents [<String>]. |
| 40:122 | Cache-DB process has been failed. |
| 40:123 | Permission denied error while accessing the path [<String>]. Check whether the path is accessible. |
| 40:124 | Job manager detected job token mismatch between client process and job manager. Livelyness check may have failed due to commserve services restart or intermittent network connection failure. |
| 40:125 | Failed to restore data due to unreadable chunk. |
| 40:126 | Unable to find device mounted for DDB Path. Failed to open deduplication database on one or more of the following MediaAgents [<String>] |
| 40:127 | Device [<String>] reported error. Try cleaning the drive. Try resetting the drive and/or library. Contact CommVault Support. |
CommServe Disaster Recovery
| 34:1 | CommServeDR: Usage: <String> |
| 34:2 | CommServeDR: Full backup started for set [<Number>]. |
| 34:3 | CommServeDR: Differential backup started for set [<Number>]. |
| 34:4 | CommServeDR: Full backup completed <String>. |
| 34:5 | CommServeDR: Differential backup completed <String>. |
| 34:6 | CommServeDR: Full backup failed. |
| 34:7 | CommServeDR: Differential backup failed. |
| 34:8 | CommServeDR: does not support restore (yet). |
| 34:9 | CommServeDR: Coinit fails: Error = 0x<HexNumber>. |
| 34:10 | CommServeDR: Could not create component: Error = 0x<HexNumber>. |
| 34:11 | CommServeDR: VDS::Create fails: Error = 0x<HexNumber>. |
| 34:12 | CommServeDR: VDS::GetCFG Timed out. Check the VDI.log in the MSSQL directory for details. |
| 34:13 | CommServeDR: execSQL failed for backup. |
| 34:14 | CommServeDR: VDS::Getconfig fails: Error = 0x<HexNumber>. |
| 34:15 | CommServeDR: SQL Command for Backup Timed out. |
| 34:16 | CommServeDR: VDS::Open Device fails: Error = 0x<HexNumber>. |
| 34:17 | CommServeDR: Error Performing Transfer: Error = 0x<HexNumber>. |
| 34:18 | CommServeDR: cwait failed: error = <Number> |
| 34:19 | CommServeDR: Could not launch process for sqlcmd.exe, error = <Number>. |
| 34:20 | CommServeDR: Could not open backup file [<String>], error = <Number>. |
| 34:21 | CommServeDR: Completion Failed: error = 0x<HexNumber>. |
| 34:22 | CommServeDR: Successfully completed data transfer. |
| 34:23 | CommServeDR: VDS: Unexpected termination: Error = 0x<HexNumber>. |
| 34:24 | CommServeDR: Cannot insert row, error: <String>. |
| 34:25 | CommServeDR: Cannot update row, error: <String>. |
| 34:26 | CommServeDR: Differential backup: Cannot obtain information on previous full, error = <String>. |
| 34:27 | CommServeDR(prune): Cannot start database transaction. <String> |
| 34:28 | CommServeDR(prune): Cannot get row count for table. Error=<String>. |
| 34:29 | CommServeDR(prune): No sets to purge. |
| 34:30 | CommServeDR(prune): Cannot open database table [<String>]. |
| 34:31 | CommServeDR(prune): Cannot read directory entries for [<String>]. |
| 34:32 | CommServeDR(prune): Could not remove [<String>], Error: <String> |
| 34:33 | CommServeDR: Duplicate or conflicting command line option [<String>] |
| 34:34 | CommServeDR: Error. More than one command specified. |
| 34:35 | CommServeDR: Insufficient arguments. |
| 34:36 | CommServeDR: Failed to initialize Event Messages. |
| 34:37 | CommServeDR(prune): Deleting ER Set [<Number>]. |
| 34:38 | CommServeDR: Error getting hostname. |
| 34:39 | CommServeDR: Error initializing Job Manager Object. |
| 34:40 | CommServeDR: Error initializing Job Control Object. |
| 34:41 | CommServeDR: Error notifying Job Manager of Completion. |
| 34:42 | CommServeDR: Quit Message received from Job Manager. |
| 34:43 | CommServeDR: Could not retrieve default Disaster Recovery target directory from global parameters. Error = [<Number>]. |
| 34:44 | CommServeDR: Could not retrieve list of SmartMedia files to backup. Error = [<String>] |
| 34:45 | CommServeDR: Could not flush SmartMedia files to disk, Error = [<Number>]. |
| 34:46 | CommServeDR: Could not copy SmartMedia file [<String>] to directory [<String>], Error = [<String>] |
| 34:47 | CommServeDR: Could not open SmartMedia Target file [<String>] for writing, Error = [<String>] |
| 34:48 | CommServeDR: File Compression Error [<String>] |
| 34:49 | CommServeDR: Failure: [<String>] |
| 34:50 | CommServeDR: Problems encountered backing up SmartMedia files. |
| 34:51 | CommServeDR: Problems encountered backing up NT registry. |
| 34:52 | CommServeDR: Problems encountered backing up SQL metadata. |
| 34:53 | CommServeDR: Destination Directory [<String>] does not exist or is inaccessible |
| 34:54 | CommServeDR: Command [<String>] failed. System Error [<String>] |
| 34:55 | CommServeDR: Problem Impersonating User [<String>] in [<String>]. Error = [<Number>] |
| 34:56 | CommServeDR: Problem writing file for [<String>]. Destination may be full. |
| 34:57 | CommServeDR: Restarting Backup as Full. Last Full completed with Errors. |
| 34:58 | CommServeDR: Destination directory has changed from [<String>] to [<String>]. Backup converted from differential to a full. |
| 34:59 | CommServeDR: Path [<String>] cannot be accessed. It may not exist. Otherwise, please check Share and Security settings. |
| 34:60 | CommServeDR: Could not delete file [<String>]. Error = [<String>]. |
| 34:61 | CommServeDR: Cannot fetch row from table [<String>]. Error = [<String>]. |
| 34:62 | CommServeDR: The database is still in use by another process and cannot be restored. |
| 34:63 | CommServeDR: The server the restore was attempted on is not compatible with the server the database originated from. |
| 34:64 | CommServeDR: One or more files needed for the restore already exists and the restore cannot continue. |
| 34:65 | CommServeDR: Error: [<String>]. |
| 34:66 | CommServeDR: Device activation error. A physical file name may be incorrect. Consult the log file for more details. |
| 34:67 | CommServeDR: A directory specified for a log file may be invalid. Consult the CommServeDR log file for more details. |
| 34:68 | Insufficient space for one of the restore files. Consult the CommServeDR log file for more details. |
| 34:69 | Could not create temporary directory. Retry by starting CommServeDR in a local temporary directory. |
| 34:70 | The restore file specified [<String>] is not a regular file! |
| 34:71 | CommServeDR: Database may have been corrupted. All server activities are disabled. |
| 34:72 | CommServeDR: Operation was terminated abnormally. Consult CommServeDR log file for details. |
| 34:73 | CommServeDR: DBCC CHECKDB command failed to execute. Please run DBCC CHECKDB command manually to detect database corruption. This command may fail if database is located on FAT drive. Please move database to a non-FAT drive to prevent this problem. |
| 34:74 | CommServeDR: rskeymgmt.bkp is not copied to staging directory. It may not be generated for SRM. |
| 34:75 | CommServeDR: Unknown backup option. Please check the version of Microsoft SQL Server for latest support. |
| 34:76 | CommServeDR: There is insufficient system memory. Consult the CommServeDR log file for more details. |
| 34:77 | A nonrecoverable I/O error occurred. Please check space available for database backup. |
| 34:78 | CommServeDR: Destination directory has changed from [<String>] to [<String>]. Backup converted from LOG to a FULL. |
| 34:79 | CommServeDR: Log backup started for set [<Number>]. |
| 34:80 | CommServeDR: Log backup failed. |
| 34:81 | CommServeDR: Restore failed. |
| 34:82 | CommServeDR: Log backup completed <String>. |
| 34:83 | CommServeDR: Backup is converted to full. |
| 34:84 | CommServeDR: Upload to Commvault cloud failed. File: [<String>]. Error message: [<String>]. |
| 34:85 | CommServeDR: Error Performing Transfer: Error : [<String>]. |
| 34:86 | CommServeDR: Skipping upload to Commvault Cloud as CommCell is on evaluation license. |
| 34:87 | Mongo DR Backup failed. |
| 34:88 | MongoDR Backup Success. |
| 34:89 | MongoDR: Could not retrieve default Disaster Recovery target directory from global parameters. Error = [<Number>]. |
| 34:90 | MongoDR: Upload to Commvault cloud failed. File: [<String>]. Error message: [<String>]. |
| 34:91 | MongoDR: Cannot fetch row from table [<String>]. Error = [<String>]. |
| 34:92 | MongoDR: Problem writing file for [<String>]. Destination may be full. |
| 34:93 | MongoDR: Duplicate or conflicting command line option [<String>] |
| 34:94 | MongoDR: Skipping upload to Commvault Cloud as CommCell is on evaluation license. |
| 34:95 | MongoDR: Full backup started for set [<Number>]. |
| 34:96 | MongoDR: Problem Impersonating User [<String>] in [<String>]. Error = [<Number>] |
| 34:97 | MongoDR: Insufficient arguments. |
| 34:98 | MongoDR: There is insufficient system memory. Consult the CVMongoDR log file for more details. |
| 34:99 | MongoDR: Error initializing Job Manager Object. |
| 34:100 | MongoDR: Error notifying Job Manager of Completion. |
| 34:101 | MongoDR: Quit Message received from Job Manager. |
| 34:102 | MongoDR: Error initializing Job Control Object. |
| 34:103 | MongoDR: Destination Directory [<String>] does not exist or is inaccessible. |
| 34:104 | MongoDR(prune): Could not remove [<String>], Error: <String> |
| 34:105 | MongoDR: Path [<String>] cannot be accessed. It may not exist. Otherwise, please check Share and Security settings. |
| 34:106 | MongoDR: Could not delete file [<String>]. Error = [<String>]. |
| 34:107 | MongoDR: Backup failed for service [<String>]. |
| 34:108 | MongoDR: Problems encountered backing up SQL metadata. |
| 34:109 | MongoDR: Command [<String>] failed. System Error [<String>] |
| 34:110 | MongoDR: Error Performing Transfer: Error = 0x<HexNumber>. |
| 34:111 | MongoDR: Error Performing Transfer: Error : [<String>]. |
| 34:112 | Write on [<String>] failed. Please ensure that the disk has enough free space for the database backup. Error [<String>]. |
| 34:113 | DR uploads to Commvault cloud have been enabled, providing enhanced resilience to cyber threats. Please refer to the documentation for further instructions on configuration of DR backups to Commvault cloud. |
External Data Connector
| 141:1 | NBDB login and/or password is invalid. |
| 141:2 | Discovery job succeeded. Refresh CommCell Console to see new entities. |
| 141:3 | Failed to access cached information at [<String>] on [<String>]. If this persists, rerun discovery job with Full sync option enabled. |
| 141:4 | Job status code [<String>]. |
| 141:5 | Job finished with code [<String>]-[<String>]. |
| 141:6 | The network connection with remote client was lost unexpectedly. Check Network Connectivity. |
| 141:7 | NetBackup services are not running. |
| 141:8 | Unknown error. |
| 141:9 | No Array Credentials found for Filer [<String>]. |
| 141:10 | Unable to reach remote client. Discover job could not be run. |
| 141:11 | Nothing to merge. No data discovered. |
| 141:12 | No data returned by NetApp Powershell. SnapDrive and SnapManager Services may not be running correctly or there are no SnapManager backup jobs to discover. |
| 141:13 | No data returned by NetApp Powershell for instance [<String>]. SnapDrive and SnapManager Services may not be running correctly or there are no SnapManager backup jobs to discover for this instance. |
| 141:14 | Multiple CCM merge execution is not allowed. Waiting for other job to finish merge. |
| 141:15 | EMC NetWorker Services are not running |
| 141:16 | Discovery failed. Please check EDCDiscovery.log for details. |
| 141:17 | TSM login and/or password is invalid |
EvArchive Manager
| 65:1 | Out of Memory. |
| 65:2 | Has received an unprocessed element type [<Number>-<String>]. |
| 65:3 | <String> threw an exception. |
| 65:4 | Browser session ID [<Number>] has been closed. |
| 65:5 | Attempt to re-associate Storage Policy [<String>] properties denied.nn <String> n |
| 65:6 | Failed to initialize with the Job Manager. |
| 65:7 | Unable to re-associate the subclients: Jobs are running for this Storage Policy. |
| 65:8 | DBTran::startTran() failed error [<Number>/<String>] |
| 65:9 | Failed to associate applications for Storage Policy [<String>]. |
| 65:10 | Failed to get the archive group name. |
| 65:11 | Failed to log audit trail. |
| 65:12 | Too many streams. |
| 65:13 | Archive Manager error: [<String>]. |
| 65:14 | Update Storage Policy failed for [<String>] |
| 65:15 | Set next backup to be full failed. |
| 65:16 | Finish updating Storage Policy [<String>]. |
| 65:17 | Could not determine original values for Storage Policy [<String>]:n |
| 65:18 | Storage Policy name may have changed.n |
| 65:19 | Number of Streams may have been changed to [<Number>]nn |
| 65:20 | Number of Streams changed from [<Number>] to [<Number>]n |
| 65:21 | Storage Policy [<String>]: Number of Streams changed from [<Number>] to [<Number>]n |
| 65:22 | Storage Policy Name Changed from [<String>] to [<String>]n |
| 65:23 | Incremental Storage Policy is changed from [<String>] to [<String>]n |
| 65:24 | Deletion of Storage Policy [<String>] deniednn<String>n |
| 65:25 | There are applications associated with Archive Group [<Number>-<String>] |
| 65:26 | Get application for Archive Group failed |
| 65:27 | Unable to init with Job Manager for delete Storage Policy <String> |
| 65:28 | Unable to delete Storage Policy <String> because jobs are running |
| 65:29 | Failed to set ER storage policy to default |
| 65:30 | Failed to get information for Storage Policy <String> |
| 65:31 | An Incremental Storage Policy is configured for this Storage Policy |
| 65:32 | This Storage Policy is an active Incremental Storage Policy for another Storage Policy |
| 65:33 | Delete Archive Group failed |
| 65:34 | Deleted Storage Policy [<String>] but failed to remove backup history |
| 65:35 | Has rolled back transaction due to errors |
| 65:36 | Unsupported operation type specified |
| 65:37 | Has received an unprocessed element type [<Number>-<String>] |
| 65:38 | No copy header specified |
| 65:39 | No drive pool specified |
| 65:40 | No spare media group specified |
| 65:41 | No library specified |
| 65:42 | Operation [<String>] for Storage Policy Copy [<String>] denied nn <String> n |
| 65:43 | Failed to get type and sub-type for library <Number> n |
| 65:44 | Get Desired Media Type failed n |
| 65:45 | Get Media Group Recording Formats failed n |
| 65:46 | Getting list of drive pools for disk library <Number> failed n |
| 65:47 | Copy creation failed - Errors returned from Database Operation |
| 65:48 | Copy creation failed - Errors returned from Media Manager |
| 65:49 | Copy creation failed - Memory allocation problems |
| 65:50 | Copy creation failed - A copy with the same name already exists |
| 65:51 | Copy creation failed - Too many streams |
| 65:52 | Copy creation failed - Effective time of the copy cannot be in the past |
| 65:53 | Copy creation failed - Effective time of the copy cannot be in the past |
| 65:54 | Set copy <Number> <String> failed |
| 65:55 | Failed to get Application ID [<String>] Error [<String>] |
| 65:56 | Failed to get the client from Application ID [<String>] |
| 65:57 | Failed to get client ID for Application ID [<String>] Error [<String>] |
| 65:58 | Failed to get client Name for Application ID [<String>] Error [<String>] |
| 65:59 | Failed to get AppType for Application ID [<String>] Error [<String>] |
| 65:60 | Failed to get the instance from Application ID [<String>] |
| 65:61 | Failed to get instance Name for Application ID [<String>] Error [<String>] |
| 65:62 | Unable to get media list for Archive Group <Number> |
| 65:63 | Get Archive Group [<Number>] Copy list failed |
| 65:64 | Unable to get copies for Archive Group <Number> |
| 65:65 | Get Uncopied Media for Copy <Number> failed |
| 65:66 | Lookup aging rule failed |
| 65:67 | Invalid name or source policy ID. |
| 65:68 | Cloning the Storage Policy on the Policy ID [<Number>] has failed. |
| 65:69 | Failed to get Content Indexing properties for Storage Policy ID [<Number>] |
| 65:70 | Failed to get Content Indexing applications for Storage Policy ID [<Number>] |
| 65:71 | Failed to create Content Indexing properties for Storage Policy ID [<Number>] |
| 65:72 | Failed to update Content Indexing properties for Storage Policy ID [<Number>] |
| 65:73 | Failed to create Archive Group Copy and Subclient Association for Content Indexing Properties |
| 65:74 | Failed to add Deduplication access path [<String>] due to errors: [<String>] |
| 65:75 | Failed to delete Deduplication access path [<String>] due to errors: [<String>] |
| 65:76 | Failed to update Deduplication access path [<String>] due to errors: [<String>] |
| 65:77 | Failed to release Auxiliary Copy Encryption license for Storage Policy [<String>] |
| 65:78 | Failed to release Deduplication license for Storage Policy [<String>] |
| 65:79 | Failed to delete Content Indexing properties for Storage Policy ID [<Number>] |
| 65:80 | Failed to associate applications for Storage Policy [<String>] n because Auxiliary Copy Encryption option cannot be used for Subclient [%s] prior to 7.0. |
| 65:81 | Storage Policy has been cloned successful. But new Access Path for Deduplication is disabled.n Please manually change Access Path location, then enable it. |
| 65:82 | Unable to set incremental storage policy. Jobs are running for storage policy. |
| 65:83 | Failed to get properties of Storage Policy ID [<Number>] for moving snapshot to backup media |
| 65:84 | Failed to set properties of Storage Policy ID [<Number>] for moving snapshot to backup media |
| 65:85 | Failed to release Tape Deduplication license for Storage Policy [<String>] |
| 65:86 | Failed to get properties of Storage Policy for mining snapshot |
| 65:87 | Failed to set properties of Storage Policy for mining snapshot |
| 65:88 | Unable to associate a Deduplication store to the storage policy copy. The specified Deduplication store is invalid. |
| 65:89 | Unable to associate a Deduplication store to the storage policy copy. Copies in the same storage policy cannot share Deduplication stores. |
| 65:90 | Unable to associate a Deduplication store to the storage policy copy. Storage Policies with different block sizes cannot share Deduplication stores. |
| 65:91 | Unable to get Global Deduplication host policies due to a database error |
| 65:92 | Unable to use the given Global Deduplication host policy due to a database error |
| 65:93 | Unable to get Global Secondary Copy host policies due to a database error |
| 65:94 | Unable to use the given Global Secondary Copy host policy due to a database error |
| 65:95 | Unable to get Global Secondary Copy Policy dependent copies due to error. |
| 65:96 | Offline Content Indexing Jobs are running for the SP. Hence failed to update Content Indexing Properties. |
| 65:97 | Change of block size not allowed since copies dependent on Global Dedup Storage Policy exists. |
| 65:98 | No Default Interface |
| 65:99 | Failed to set properties of Storage Policy Id [<Number>] for NAS Snapshot catalog |
| 65:100 | Failed to get properties of Storage Policy ID [<Number>] for NAS Snapshot catalog |
| 65:101 | Failed to configure entity extraction. <String>. |
| 65:102 | Failed to deconfigure entity extraction. <String>. |
| 65:103 | Entity Store Engine is not associated. Please associate Entity Store Eninge from Search engine Properties and try again. |
| 65:104 | Preserve encryption mode as in source |
| 65:105 | Re-encrypt data using selected cipher |
| 65:106 | Store plain text |
| 65:107 | Encrypt on network using selected cipher |
| 65:108 | Unable to get Global Storage Policy dependent copies due to error |
| 65:109 | Unable to get Global Storage Policy host policies due to a database error |
| 65:110 | Unable to use the given Global Storage Policy host policy due to a database error |
| 65:111 | Failed to delete Storage Policy Copy [<String>] due to active job(s) [<String>] |
| 65:112 | Failed to delete Storage Policy [<String>] due to active job(s) [<String>] |
| 65:113 | Change of block size not allowed since backups have been run to the GDSP or the Storage Policy has dependent copies. |
| 65:114 | Operation [<String>] for Storage Policy [<String>] denied. n <String> |
| 65:115 | This Storage Policy is an active Log Storage Policy for another Storage Policy. |
| 65:116 | Unable to set Log storage policy. Jobs are running for storage policy. |
EvLibrary Controller
| Code | Description |
| 67:1 | Out of Memory |
EvMedia Manager
| 66:1 | Out of Memory |
| 66:2 | Total Number of Mount and Unmount Errors |
| 66:3 | Number of Mount and Unmount Errors after Last Clean |
| 66:4 | Total Number of Hours Used |
| 66:5 | Number of Hours Used after Last Clean |
| 66:6 | Total Number of read, write Errors |
| 66:7 | Number of read, write Errors After Last Clean |
| 66:8 | Drive Controller is not alive, MediaAgent is offline |
| 66:9 | Has received an unprocessed element type [<Number>-<String>] |
| 66:10 | Unsupported operation type [<Number>] specified |
| 66:11 | Could not start transaction. Export media not scheduled. Error [<String>] |
| 66:12 | Security Credentials Check Failed. The error returned is : <String> |
| 66:13 | Unable to add immediate schedule entry |
| 66:14 | Error committing transaction [<String>]. Media Export not scheduled |
| 66:15 | Could not commit schedule |
| 66:16 | Could not add task |
| 66:17 | Invalid Library ID for the operation Discover Media |
| 66:18 | Problems rolling back transaction. Some data may need to be cleaned up. Error [<String>] |
| 66:19 | Could not Set Schedule for the Full Inventory |
| 66:20 | Quick Inventory can be performed only for Blind Libraries. |
| 66:21 | Error retrieving Library info for Library <Number>, error = <String> |
| 66:22 | Library name [<String>] was changed to [<String>]n |
| 66:23 | Default Scratch Pool was changed from [<String>] to [<String>].n |
| 66:24 | 'Auto Clean On Sense Code' option was turned on for the library [<String>].n |
| 66:25 | 'Auto Clean On Sense Code' option was turned off for the library [<String>].n |
| 66:26 | 'Auto Discover' option was turned on for the library [<String>].n |
| 66:27 | 'Auto Discover' option was turned off for the library [<String>].n |
| 66:28 | Mount timeout was changed from [<Number>] minutes to [<Number>] minutes.n |
| 66:29 | Unmount timeout was changed from [<Number>] minutes to [<Number>] minutes.n |
| 66:30 | Scratch Pool [<String>] added to Library.n |
| 66:31 | Library [<String>] Low Watermark was changed from <Number> percent to <Number> percent. |
| 66:32 | Library [<String>] Low Watermark was changed to <Number> percent from <Number> percent. |
| 66:33 | No default data pipe interface. |
| 66:34 | No default data pipe interface OR exception <String> |
| 66:35 | No default data pipe interface OR unknown exception |
| 66:36 | Looking up Operating System failed. |
| 66:37 | Looking up Operating System by client failed. |
| 66:38 | Unable to initialize the registry query on the CommServe [<String>]. |
| 66:39 | Looking up Operating System by client failed. |
| 66:40 | Problem encountered changing Index retention time from [<Number>] to [<Number>] days.n |
| 66:41 | Index retention time changed from [<Number>] to [<Number>] days.n |
| 66:42 | Scratch Pool [<String>] deleted. |
| 66:43 | Scratch Pool [<String>] has been renamed to [<String>].n |
| 66:44 | Scratch Pool [<String>] Low Watermark has been changed from [<Number>] to [<Number>].n |
| 66:45 | Problems rolling back transaction. Some data may need to be cleaned up. Error [<String>] |
| 66:46 | Unable to add immediate schedule entry |
| 66:47 | No default data pipe interface OR exception |
| 66:48 | Has received an unprocessed element type [<Number>-<String>] |
| 66:49 | Media Expiration for media type [<String>]: Changed read, write error threshold from [<Number>] to [<Number>].n |
| 66:50 | Media with identifier [<String>], Unique ID [<String>] created at time [<String>] belongs to the CommCell [<String>]. |
| 66:51 | The SCSI2 reservation for the selected drive cannot be released while there are reservations for the selected drive's library from jobs. Please stop all corresponding jobs and try again. |
| 66:52 | The SCSI2 reservation release was attempted, but it failed. |
| 66:53 | 'Mark Media Appendable' option was turned on for the library [<String>].n |
| 66:54 | 'Mark Media Appendable' option was turned off for the library [<String>].n |
| 66:55 | 'Use Appendable Media' option was turned on within [<Number>] days for the library [<String>].n |
| 66:56 | 'Use Appendable Media' option was turned off for the library [<String>].n |
| 66:57 | 'Overwritten Media When Content Verification Fail' option was turned on for the library [<String>].n |
| 66:58 | 'Overwritten Media When Content Verification Fail' option was turned off for the library [<String>].n |
| 66:59 | 'Overwritten Media When From Different CommCell' option was turned on for the library [<String>].n |
| 66:60 | 'Overwritten Media When From Different CommCell' option was turned off for the library [<String>].n |
| 66:61 | 'Start New Media When Required Media Exported' option was turned on for the library [<String>].n |
| 66:62 | 'Start New Media When Required Media Exported' option was turned off for the library [<String>].n |
| 66:63 | 'Start New Media When Required Media Stuck' option was turned on for the library [<String>].n |
| 66:64 | 'Start New Media When Required Media Stuck' option was turned off for the library [<String>].n |
| 66:65 | Failed to retrieve existing pipeline interface pairs. |
| 66:66 | Failed to add new pipeline interface pairs. |
| 66:67 | Failed to delete pipeline interface pairs. |
| 66:68 | Failed to update pipeline interface pairs. |
| 66:69 | <String> option was turned on for the library [<String>].n |
| 66:70 | <String> option was turned off for the library [<String>].n |
| 66:71 | 'Mark Library/Drive broken when error thresholds exceeded' |
| 66:72 | 'Verify access path using Serial Number for Drive' |
| 66:73 | 'Check for cleaning media loaded in Drive' |
| 66:74 | 'Check for Tape Alerts' |
| 66:75 | 'Drive needs cleaning due to Cyclic Redundancy Check(CRC) errors.' |
| 66:76 | SCSI Reservation options changed for the library [<String>].n |
| 66:77 | 'Auto clean drive when Cleaning Thresholds exceed' |
| 66:78 | 'Continue using drive even if it needs cleaning' |
| 66:79 | Library Extended Attributes were changed for the library [<String>].n |
| 66:80 | Drive clean interval was changed for the library [<String>].n |
| 66:81 | Library [<String>] Warning Watermark was changed from <Number> percent to <Number> percent. |
| 66:82 | Library [<String>] Warning Watermark was changed to <Number> percent from <Number> percent. |
| 66:83 | Failed to check for any store in the target path [<String>], for details see [EvMgrs.log]. |
| 66:84 | Failed to get DDB reconstruction job presence, for details see [EvMgrs.log]. |
| 66:85 | Failed to get DDB backup job presence, for details see [EvMgrs.log]. |
| 66:86 | Failed to get backup job presence, for details see [EvMgrs.log]. |
| 66:87 | Cannot start DDB move partition job as a DDB reconstruction job is currently running. |
| 66:88 | Cannot start DDB move partition job as a DDB backup job is currently running. |
| 66:89 | Cannot start DDB move partition job as there is an existing partition at the specified target path [<String>]. |
| 66:90 | Cannot start DDB move partition job as a job is running to the Storage policy [<String>]. Please suspend the jobs running to this Storage Policy and retry the operation. |
| 66:91 | Cannot seal the store because DDB move partition job is running on this store. |
| 66:92 | Cannot start DDB reconstruction job as a DDB move partition job is currently running. |
| 66:93 | Cannot start DDB backup job as a DDB move partition job is currently running. |
| 66:94 | Failed to fetch store information for storeId [<Number>]. Please try again. |
| 66:95 | Library [<String>] Out Of Space Alert In Days was changed from <Number> days to <Number> days.n |
| 66:96 | Failed to update Deduplication Store Properties for Store : [<String>]" " |
| 66:97 | Cannot start DDB move partition job because the SIDB Store [<Number>], Partition [<Number>] does not have any data. Please select Config Only move. |
| 66:98 | Cannot start DDB move partition job because SIDB Store [<Number>] is currently under maintenance. |
| 66:99 | DDB move partition job initialization failed for the SIDB Store [<Number>]. |
| 66:100 | A DDB move partition job is already running on Partition [<Number>]. |
| 66:101 | Failed to fetch host information from [<String>] table for host id [<Number>]. |
| 66:102 | Cannot start ConfigOnly DDB move partition job. Source MediaAgent [<Number>] or Target MediaAgent [<Number>] are not offline for ConfigOnly move. |
| 66:103 | Cannot start DDB move partition job Source MediaAgent [<Number>] or Target MediaAgent [<Number>] are offline. |
| 66:104 | Failed to update store information for storeId [<Number>]. Please try again. |
| 66:105 | Failed to fetch partition information for SubStoreId [<Number>]. Please try again. |
| 66:106 | Unable to create new IDX Cache and Pool entries for the partition [<Number>]. |
| 66:107 | Failed to set Index [<String>] for the Id [<Number>]. |
| 66:108 | Failed to add accesspath to index cache for cacheID [<Number>], target MA [<Number>]. |
| 66:109 | Failed to Allocate [<String>] dedupe license for media agent [<Number>]. |
| 66:110 | Failed to Release [<String>] dedupe license for media agent [<Number>]. |
| 66:111 | Failed to fetch information from [<String>] for <String> [<Number>]. |
| 66:112 | Failed to update <String> to [<String>] for <String> [<Number>]. |
| 66:113 | Cannot start DDB move partition job because sourcePath mismatch on GUI [<String>, <String>] and DB [<String>, <String>].Please refresh GUI. |
| 66:114 | Unable to Stop SIDB Engines with store id [<Number>]. |
| 66:115 | Failed to fetch subStore list for StoreId [<Number>] and commcellId [<Number>]. |
| 66:116 | Jobs are running to the Storage Policy [<String>]. Suspend the job(s) [<String>] and retry. Check the Event Viewer for more details. |
| 66:117 | DDB Config only move completed successfully for SIDB Store [<Number>], Partition [<Number>], Storage Policy [<String>] and Copy [<String>]. |
| 66:118 | DDB Config only move failed for SIDB Store [<Number>], Partition [<Number>], Storage Policy [<String>] and Copy [<String>]. |
| 66:119 | Max number of archive files per secondary files is configured for this store[<Number>]. The destination MA[<String>] should at least be at 11.0 . |
| 66:120 | DDB move partition is not allowed from this higher feature release[<Number>] MediaAgent[<String>] to lower feature release[<Number>] MediaAgent[<String>] when In-memory deduplication database option is disabled. |
| 66:121 | Configuration parameter to allow DDB expansion is off. |
| 66:122 | Mount path [<String>] is already reserved by job(s) [<String>]. |
| 66:123 | Failed to start Move Mount Path[<String>] job. Internal error occured. |
| 66:124 | Failed to start DDB move partition job because the SIDB Store [<String>] does not have any data. Please select Config Only move. |
| 66:125 | Failed to start Move Mount Path job because the mountpath[<String>] does not have any data. |
| 66:126 | Policy |
| 66:127 | Failed to start Move Mount Path job because the MountPath[<String>] is already shared with the selected destination MediaAgent[<String>]. Please select a destination MediaAgent which is not already shared by the MountPath. |
| 66:128 | Jobs are running to the Storage Policy [<String>]. Suspend the job(s) [<String>] and retry the Move partition job. |
| 66:129 | Failed to suspend running jobs to the Storage Policy [<String>]. Suspend the jobs and retry the Move partition job. Check the Event Viewer for more details. |
| 66:130 | Failed to suspend running jobs to the Storage Policy [<String>]. Suspend the job(s) [<String>] and retry the Move partition job. |
| 66:131 | The Running Job(s) [<String>] to the storage policy[<String>] are suspended by Move partition job. |
| 66:132 | Failed to move partition of the storage policy/copy [<String> / <String>] because SIDB store [<Number>] is currently under maintenance. Reason [<String>]. |
| 66:133 | SystemCreatedSP |
| 66:134 | Failed to update Deduplication Store Properties for Store : [<String>] because [Add Record] phase of Deduplication Database Reconstruction job [<Number>] is running. |
| 66:135 | Some partitions are not compact. All partitions need to be compacted before enabling garbage collection and pruning logs for reconstruction options. |
| 66:136 | Failed to move DDB disk as source MediaAgent [<String>] and path [<String>] is same as target MediaAgent [<String>] and path [<String>] |
| 66:137 | Cannot start move partition job as target path [<String>] on MediaAgent [<String>] does not have enough usable free space |
| 66:138 | Airgap initialization for storage pool [<String>] is partially completed, please check logs and retry after resolving errors |
| 66:139 | Cannot enable Airgap as Storage [<String>] has dependent copies |
| 66:140 | High Watermark should be greater than the Low Watermark |
| 66:141 | 'Prevent use of tapes from a different backup vendor' option was turned [<String>] for the library [<String>].n |
Event Manager Client
| 16:1 | Event Manager Client started successfully. |
| 16:2 | Event Manager Client stopped successfully. |
| 16:3 | [<String>] on computer [<String>] failed to start; Failed to get local host name. |
| 16:4 | [<String>] on computer [<String>] failed to start. Network subsystem on the computer is down. |
| 16:5 | [<String>] on computer [<String>] failed to start. Host Name for this computer may not be configured properly. |
| 16:6 | [<String>] on computer [<String>] failed to start. Name resolution failed for the interface[<String>]. |
| 16:7 | [<String>] on computer [<String>] failed to start. Could not get the port number from services file. |
| 16:8 | [<String>] on computer [<String>] failed to start. Failed to determine if the computer is a cluster. Registry may be corrupt. |
| 16:9 | [<String>] on computer [<String>] failed to start. Port [<Number>] may be busy. |
| 16:10 | [<String>] on computer [<String>] failed to start. Could not get information for disk group [<String>] on machine [<String>]. |
| 16:11 | [<String>] on computer [<String>] failed to start. Could not bind to the specified port on any address. |
| 16:12 | Failed to resolve host name [<String>]. Please make sure that the DNS settings are appropriate. |
| 16:13 | The current version of the computer [<String>] does not support executing a process by impersonating a user. |
| 16:14 | Calendar [<String>] definition will expire in [<String>] months. |
| 16:15 | Calendar [<String>] definition is expired. |
| 16:16 | Client [<String>] has inconsistent set of updates because additional packages were installed. Apply feature release [<String>] patch [<String>] for proper operation. |
| 16:17 | Failed to get the Search URL. |
| 16:18 | The current version of the computer [<String>] does not support browsing agent files. |
| 16:19 | Client [<String>] has inconsistent set of updates because additional packages were installed. Please apply update(s) [<String>] and/or most recent Service Pack for proper operation. |
Event Manager Server
| 15:1 | Event Manager Server started successfully. |
| 15:2 | Event Manager Server stopped successfully. |
Restore iDataAgent
| 23:1 | Winsock initialization error. |
| 23:2 | Socket from MediaAgent closed prematurely. |
| 23:3 | Write error on socket to MediaAgent. |
| 23:4 | Read error on socket from MediaAgent. |
| 23:5 | Get platform information failed for section [<String>], field [<String>]. |
| 23:6 | Open archive [<Number>], [<Number>], [<Number>] failed. |
| 23:7 | Seek archive [<Number>], [<Number>], [<Number>] to offset [<Number>] failed. |
| 23:8 | Read archive [<Number>], [<Number>], [<Number>] starting at offset [<Number>] failed |
| 23:9 | Could not send restore status of a path name to the GUI Server. |
| 23:10 | Error while reading pipeline buffer from MediaAgent [<String>]. |
| 23:11 | Memory allocation error. |
| 23:12 | Error occurred in pipeline data transfer. |
| 23:13 | Error while setting up pipeline. |
| 23:14 | Unrecognized message [<HexNumber>] |
| 23:15 | Invalid mode [<Number>] for file [<String>]. |
| 23:16 | UTF8 to Unicode conversion error: destination buffer too small. |
| 23:17 | Get File Attributes error [<Number>] |
| 23:18 | Error [<Number>] while writing to [<String>]. |
| 23:19 | Error [<Number>] while issuing final BackupWrite for [<String>]. |
| 23:20 | Error [<Number>] while closing [<String>]. |
| 23:21 | Error [<Number>] while setting attributes [<HexNumber>] on [<String>]. |
| 23:22 | Could not open [<String>]. Restoring to [<String>]. |
| 23:23 | Error [<Number>] while opening [<String>]. |
| 23:24 | Error [<Number>] while marking [<String>] to be moved on reboot to [<String>]. |
| 23:25 | Error [<Number>] while marking registry hive [<String>] to be moved on reboot to [<String>]. |
| 23:26 | Error [<Number>] while obtaining the process' access token. |
| 23:27 | Error [<Number>] while looking up the process' backup privilege. |
| 23:28 | Error [<Number>] while looking up the process' restore privilege. |
| 23:29 | Error [<Number>] while looking up the process' security privilege. |
| 23:30 | Error [<Number>] while looking up the process' take-ownership privilege. |
| 23:31 | Error [<Number>] while enabling the process' privileges. |
| 23:32 | Registry file [<String>] is not recognized as a Hive. |
| 23:33 | RegSaveKey failed |
| 23:34 | Client initialization error. |
| 23:35 | Error [<Number>] while opening registry key [<String>]. |
| 23:36 | [<String>] key not found in registry. Using default hive list... |
| 23:37 | Restore of [<Number>] files on client [<String>] subclient [<String>] started. |
| 23:38 | Timeout [<Number>] seconds expired while waiting for message from MediaAgent [<String>]. |
| 23:39 | Restore on client [<String>] subclient [<String>] completed. |
| 23:40 | Error [<Number>] while creating semaphore. |
| 23:41 | Protocol error: received message type [<HexNumber>] instead of [<HexNumber>]. |
| 23:42 | Error [<Number>] while spawning a thread. |
| 23:43 | File Statistics: Total [<Number>], Succeeded [<Number>], Failed [<Number>] |
| 23:44 | Byte Statistics: Total [<Number>], Succeeded [<Number>], Failed [<Number>] |
| 23:45 | Path name translation error for not-in-place restore. |
| 23:46 | Could not find a prefix for [<String>] in the source paths list. |
| 23:47 | Error [<Number>] while updating file times for [<String>]. |
| 23:48 | Error [<Number>] while setting compression attribute on [<String>]. |
| 23:49 | Unable to obtain controlling CommServe's name. |
| 23:50 | Unable to obtain the local host's name. |
| 23:51 | Unable to obtain CommClient platform information. |
| 23:52 | Unable to obtain event log directory name. |
| 23:53 | Could not initialize restart functionality. |
| 23:54 | Unable to obtain File System Agent directory name. |
| 23:55 | Reboot [<String>] to complete restoration of locked files. |
| 23:56 | Unable to create a file backed list. |
| 23:57 | Could not strip [<Number>] levels off path [<String>]. |
| 23:58 | Logon of <String>/<String> failed with error <Number>. Check the user's password and privileges. |
| 23:59 | Impersonation of logged on user failed with error <Number>. |
| 23:60 | Logged on as <String>/<String> |
| 23:61 | Could not open file for restore results. |
| 23:62 | FAILED |
| 23:63 | RESTORED |
| 23:64 | OLDER |
| 23:65 | Error while creating archive. |
| 23:66 | Error while closing archive. |
| 23:67 | Error while closing pipeline. |
| 23:68 | Could not allocate pipeline buffer. |
| 23:69 | Unable to write Datapipe buffer. |
| 23:70 | There is not enough space on the disk. Failed while restoring [<String>] on machine [<String>]. |
| 23:71 | Access to destination directory <String> is denied on machine [<String>]. |
| 23:72 | Program Operating System Mismatch [<String>]. |
| 23:73 | Please check the Windows Server service. Windows share permissions will not be backed up or restored. [<String>] |
| 23:74 | Failed to create share. Name:[<String>] Path:[<String>] Cause:[<String>] |
| 23:75 | Failed to update share. Name:[<String>] Path:[<String>] Cause:[<String>] |
| 23:76 | TEXT BUSY HENCE FAILED |
| 23:77 | Successfully rebooted client [<String>]. |
| 23:78 | Source Volume does not fit into Destination Volume, Size Mismatch. |
| 23:79 | The path to restore [<String>] not found on machine [<String>]. |
| 23:80 | The restore cannot complete as the restore path [<String>] is an invalid drive on machine [<String>]. |
| 23:81 | The restore cannot complete, as the restore is being attempted to a removable storage (e.g., CD drive, floppy drive) and the device is not ready[<String>] on machine[<String>]. |
| 23:82 | The restore cannot complete as the path is write-protected[<String>] on machine [<String>]. |
| 23:83 | Job client initialization failure. Possible causes: Services down on Client and/or CommServe, lost network connectivity to CommServe, Out of process memory, handles or corrupted install. |
| 23:84 | Restore: Wrong parameters for the job. Possibly mismatched version with CommServe or corrupted install. |
| 23:85 | Archive index failed on MediaAgent - index files are missing, possibly due to a failover. |
| 23:86 | Archive index failed on MediaAgent - unable to modify index before backup. |
| 23:87 | Archive index failed on MediaAgent - unable to modify index after backup. |
| 23:88 | Unable to access index cache directory. Please make sure the folder is specified correctly and that the permissions are set up correctly. |
| 23:89 | Synthetic full stopped or interrupted. |
| 23:90 | Failed to open or read at least one item needed for the Synthetic Full operation. Please ensure the source Library is online and available. |
| 23:91 | NOT_MAPPED |
| 23:92 | FILTERED_BY_MAP |
| 23:93 | Either the map file was not found, could not be used, or the map file does not contain any valid entry. Users' choice allows only map-based restore. Nothing to restore. |
| 23:94 | Bad Media |
| 23:95 | ACL support is not available on this machine or incompatible with backup data. |
| 23:96 | Failing to set security attributes for one or more files. Please see clRestore.log for more details. |
| 23:97 | Create Index failed to connect back from MediaAgent. |
| 23:98 | Error while media read/seek operation at MediaAgent during restore. |
| 23:99 | Restore of critical system state component [<String>] failed. |
| 23:100 | Restore of system state component [<String>] failed. |
| 23:101 | Skipped restore since file does not exist |
| 23:102 | In-place system state restore not allowed for index-free restore |
| 23:103 | File would not be restored if labels do not match on trusted Solaris |
| 23:104 | Needs reboot |
| 23:105 | Failed to load the library ObjSrvIDA. |
| 23:106 | Failed to get the function address from the dynamically loaded library ObjSrvIDA. |
| 23:107 | Failed to prepare for receiving restore messages. |
| 23:108 | ArchiveIndex failed on MediaAgent [<String>] - Index files are missing. Job could have earlier run on a different MediaAgent possibly due to a failover. |
| 23:109 | Buffer too small to save ACL or extended attributes. |
| 23:110 | Mandatory lock exists on file [<String>]. |
| 23:111 | Restore failed because the option to perform an out-of-place restore was selected but a destination folder was not entered. Please run the out of place restore again making sure that a destination folder is entered. |
| 23:112 | Reason: |
| 23:113 | CONFLICT |
| 23:114 | Restore of stubs failed because extended attribute is not supported in mountpoint(s) <String>. |
| 23:115 | Impersonation of user [<String>] failed. Please check if the user exists |
| 23:116 | Failed to restore even a single file |
| 23:117 | Snap shot is not available for revert restore. |
| 23:118 | SKIPPPED |
| 23:119 | DELETED |
| 23:120 | User doesn't have [Overwrite on restore] permission. Destination directory <String> is not empty on machine [<String>]. Please provide a different destination folder. |
| 23:121 | Failed to load library for <String>. |
| 23:122 | Resource reservation request failed. |
| 23:123 | GreenPlum Backup/Restore/Configuration error [<String>]. |
| 23:124 | Skipping incremental for newly added database [<String>]. |
| 23:125 | Directory path [<String>] for a virtual DVD images must be reside on IFS. |
| 23:126 | Directory path [<String>] for a virtual DVD images is not valid. Please provide path with at least 2 levels. |
| 23:127 | Multi streamed restore is not supported for System State restore.Please select single stream for System State restore. |
| 23:128 | Cleanup failed on a client with communication error. Check the sr.log on a Proxy and CVD.LOG on a Client for more details. |
| 23:129 | Cleanup failed on a client. [<String>] |
| 23:130 | System scan failed on a client. [<String>] |
| 23:131 | CVD job hasn't started on the client. Verify if the client machine is in running state and CVD job has started. Check cvd.log and spooled files for CVDRBKP2 job on the client for more details. |
| 23:132 | System didn't get into restricted stated. Check the CVD.LOG and spooled files for CVDRBKP2 job on a client for more details. |
| 23:133 | Unable contact CVD process on client [<String>]. Check if CVD process running on a client. |
| 23:134 | Client didn't confirmed job request for DR backup. Check client's CVD.LOG for errors. |
| 23:135 | Failed to verify user authority. <String> |
| 23:136 | *IOSYSCFG special authority is required to run DR backup. <String> |
| 23:137 | Failed to submit DR backup job on a client. <String> |
| 23:138 | Cloud Connection error |
| 23:139 | Hadoop Connection error |
| 23:140 | Skipped because of Do not overwrite option |
| 23:141 | User profile archive CVLIBOBJ/ALLUSRPRF not found. Resubmit DR data restore using workflow 'IBM i DR Data Restore'. If the problem persists, contact support. |
| 23:142 | Host name property is not set for IBM i client [<String>]. |
| 23:143 | Proxy is not set for IBM i client [<String>]. |
| 23:144 | TIMESTAMP FAILED |
| 23:145 | Some files failed to pass the validation. Please check Restore Items for more details. |
| 23:146 | Reparse points failed to be restored as this is an out-of-place restore. Please check the restore result for more details. |
| 23:147 | Could not access destination directory [<String>]. Error [<String>]. |
| 23:148 | Validation not supported |
| 23:149 | Failed to setup a listener queue for <Number> connections. |
| 23:150 | Failed to load collect files. See client log file for more details. |
| 23:151 | Failed to create a Message Queue (<String>) on client. |
| 23:152 | Failed to start SAVSYNC. |
| 23:153 | Failed to start driver program (<String>) on client. |
| 23:154 | Too many (<Number>) libraries to backup using *SYNCLIB option. Maximum of 32 libraries are allowed. |
| 23:155 | Failed to add tape (<String>) to the library (<String>). |
| 23:156 | Detected bad tape. See client logs for more details. |
| 23:157 | Tape (<String>) cannot be used on the client system because the owner is set to system (<String>). |
| 23:158 | Failed to identify tape library based on drive (<String>) and tape (<String>). |
| 23:159 | Failed to set category *SHARE400 for tape (<String>) in the library (<String>). |
| 23:160 | Failed to find media type from tape's barcode (<String>) in the library (<String>). |
| 23:161 | Failed to initialize tape (<String>) in the library (<String>). |
| 23:162 | Failed to find a location of tape (<String>) in the library (<String>). |
| 23:163 | Failed to obtain status for tape (<String>) in the library (<String>). |
| 23:164 | Tape [<String>] provided for backup is FULL. |
| 23:165 | Client failed to VARYON tape [<String>] in library [<String>]. Library reset may be required. |
| 23:166 | Found tape [<String>] in drive [<String>] while it is expected to be in [<String>]. |
| 23:167 | Skipped restore since file didn't meet ACL Passthrough condition |
| 23:168 | Failed to connect to Hadoop cluster, Error : [<String>] |
| 23:169 | File extent restore failed during updating progress report. Failed to flush the File Extent records. |
| 23:170 | Failed to set file times on HDFS, please check if configuration parameter dfs.namenode.accesstime.precision is set |
| 23:171 | Failed to initialize Hadoop Library. Error : [<String>] |
| 23:172 | Failed to initialize RemoteFile instance. Error : [<String>] |
| 23:173 | Skipped restore since impersonated user didn't have read permission |
| 23:174 | Finish restore in the restricted state: RSTUSRPRF DEV(<String>) VOL(<String>) SEQNBR(<Number>) ENDOPT(*LEAVE) |
| 23:175 | Backup job failed due to *SAVSYNC timeout. |
| 23:176 | Invalid destination path [<String>] |
| 23:177 | Skipped since file is backed up as extents |
| 23:178 | 1-Touch Disaster Recovery Backup is not supported with Commvault IBM i VTL. |
| 23:179 | Hadoop concatenate failed |
| 23:180 | One or more items failed to be restored due to invalid owner error, owner of these items might no longer be a valid user. Please refer to restore logs for the list of failed items. "Restore Data Only" option can be used to restore these items. |
| 23:181 | Failed to create Automount Manager [<String>] |
| 23:182 | Failed to mount share [<String>] [<String>] |
| 23:183 | Failed to mount shares [<String>] |
| 23:184 | Failed in initializing Backup Handler. |
| 23:185 | Backup failed for Tables:[<String>] |
| 23:186 | Failed to apply timestamp for some of the folders. Check log files for more details. |
| 23:187 | Failed to apply timestamp for some of the folders in task [<Number>]. Check log files for more details. |
| 23:188 | COMMVAULT_PROTECTED |
| 23:189 | DR backup job failed. Check JOBLOG for CVBKPDR2 job on the IBM i client [<String>]. |
| 23:190 | Unable to backup subclient content. |
| 23:191 | Failed to determine Indexing version. Job will be automatically resumed as single stream restore. |
| 23:192 | Multi streamed restore is not supported for indexing V1 data. Job will be automatically resumed as single stream restore. |
| 23:193 | Multi streamed restore is not supported for System State restore. Job will be automatically resumed as single stream restore. |
| 23:194 | Volume Level Restore from Backup Copy is not supported in multi-stream framework. Job will be automatically resumed as single stream restore. |
| 23:195 | Multiple drives concurrent backup option not supported with '%^1s' command. |
| 23:196 | The 'Disk Space Report' not found. Please schedule IBM i 'Disk Space Report' to run a day before IBM i DR backup job. |
| 23:197 | The 'Disk Space Report' is too old. Please schedule 'Disk Space Report' to run a day before DR backup job is scheduled. |
| 23:198 | Unable to estimate DVD size. Please schedule IBM i 'Disk Space Report' to run a day before IBM i DR backup job. |
| 23:199 | Unable to estimate DVD size. Check cvd.log on IBM i client for more details. |
| 23:200 | The free disk space on client [<String>] is <Number> GB. The disk space needed to perform IBM i DR backup is <Number> GB. |
| 23:201 | Failed to get Hadoop Instance |
| 23:202 | Failed to get HBase Instance |
| 23:203 | Failed to detect HDFS keytab location. Set Additional Setting - sHdfsKeytabLocation with keytab location as value. |
| 23:204 | Failed to get HBase DB |
| 23:205 | Failed to detect HBase keytab location. Set Additional Setting - sHBaseKeytabLocation with keytab location as value |
| 23:206 | Failed to get HBase Root Directory |
| 23:207 | Found Non-HBase node as Master node. Change Master node to a HBase node. |
| 23:208 | Unable to restart client services on '<String>'. Other client processes are running. |
| 23:209 | Failed to get <String>:%<Number> properties. Run readiness check and try operation again once issue is resolved. |
| 23:210 | Invalid format for client base folder (<String>). Expected drive:[dir1[.dir2[]]] |
| 23:211 | Backup operation failed on the [<String>] database with errors on the following hosts: [<String>]. Check GPlogs in the Commvault log directory on the respective host(s) for more details. |
| 23:212 | Restore operation failed on the [<String>] database with errors on the following hosts: [<String>]. Check GPlogs in the Commvault log directory on the respective host(s) for more details. |
| 23:213 | Valid Greenplum version not found |
| 23:214 | Destination Impala Table already exists. |
| 23:215 | Destination Kudu Table already exists. |
| 23:216 | Failed to detect Kudu keytab location. Set Additional Setting - sKuduKeytabLocation with keytab location as value. |
| 23:217 | Failed to detect Impala keytab location. Set Additional Setting - sImpalaKeytabLocation with keytab location as value. |
| 23:218 | [<String>] not a Impala Node. Mapping of Kudu Table in Impala will not be done. |
| 23:219 | Table [<String>] is successfully restored as [<String>] |
| 23:220 | Failed to detect Hive keytab location. Set Additional Setting - sHiveKeytabLocation with keytab location as value. |
| 23:221 | Either Kudu service is not installed on [<String>] or the Kudu service is stopped. |
| 23:222 | Destination [<String>] already exists |
| 23:223 | Skipped by restore head |
| 23:224 | Incremental Backup for Table [<String>] is converted to Full Backup |
| 23:225 | Restore will be retried on next node in client list. |
| 23:226 | CCSID 37 not found on IBM i client [%s]. Please follow the documentation to configure English Language and try again. |
| 23:227 | IBM i client [<String>] does not have configured English language. Please follow the documentation to configure English Language and try again. |
| 23:228 | ArchiveIndex failed on MediaAgent [<String>] - IndexCache is offline. |
| 23:229 | Failed to Start Hadoop Java Utility. Please upgrade your Java version to Java 8 or later. |
| 23:230 | Failed to create restore vector. Reason: [<String>]. |
| 23:231 | Web server cache is full while restoring to [<String>]. |
| 23:232 | Failed to authenticate to Kerberos via kinit, please check keytab file or try kinit manually for exact error |
| 23:233 | Backup Failed for Table [<String>] . Reason : [<String>] |
| 23:234 | Backup Failed for the Table [<String>] . |
| 23:235 | Backup of Table [<String>] is successfully completed. |
Firewall Port Reservations
| 46:1 | WARNING - All network ports suitable for traffic across the firewall are in use on machine <<String>>. You may want to increase the number of ports available through the firewall. |
| 46:2 | CRITICAL - All network ports suitable for traffic across the firewall are in use on machine <<String>>. You should open more ports on the firewall, modify the FW config files, and restart the product's services. |
| 46:3 | CRITICAL - Couldn't save the network configuration under <<String>>, as the tunnel port <<Number>> is already being used by <<String>>. Make sure there are no port conflicts under all instances on this machine. |
File Replication Messages
| 76:1 | Exiting because event initialization failed. |
| 76:2 | Error notifying Job Manager of successful completion. |
| 76:3 | Error notifying Job Manager of failure. |
| 76:4 | Started. |
| 76:5 | Exiting. |
| 76:6 | Failed to Initialize Global Data. |
| 76:7 | Initial File Transfer Successful Source: [<String>] Destination: [<String>] Destination Host: [<String>]. |
| 76:8 | Failed to sync files for Source: [<String>] Destination: [<String>] Destination Host: [<String>]. |
| 76:9 | Failed to start pipeline for Source: [<String>] Destination: [<String>] Destination Host[<String>]. |
| 76:10 | Failed to get LOG object in configuration for Source: [<String>] Destination: [<String>] Destination Host[<String>]. |
| 76:11 | Failed to Open Collect File. |
| 76:12 | Failed to Write into Collect File. |
| 76:13 | Failed to Read from Collect File. |
| 76:14 | Failed to Seek into Collect File. |
| 76:15 | Failed to Create Collect File. |
| 76:16 | Failed to Restart Job: Invalid restart string. |
| 76:17 | New Path Added to Replication set: [<Number>] SubClient: [<Number>] from [<String>] to [<String>]. |
| 76:18 | Path Replication set: [<Number>] SubClient: [<Number>] Removed. |
| 76:19 | Replication Started for Source Path: [<String>] Destination Path: [<String>] Destination Host: [<String>]. |
| 76:20 | Replication Aborted for Source Path: [<String>] Destination Path: [<String>] Destination Host: [<String>]. |
| 76:21 | Replication Paused for Source Path: [<String>] Destination Path: [<String>] Destination Host: [<String>]. |
| 76:22 | Replication Resumed for Source Path: [<String>] Destination Path: [<String>] Destination Host: [<String>]. |
| 76:23 | Could not Add Path, Replication set: [<Number>] SubClient: [<Number>]. |
| 76:24 | Could not Remove Path, Replication set: [<Number>] SubClient: [<Number>]. |
| 76:25 | Could not Start Path, Replication set: [<Number>] SubClient: [<Number>]. |
| 76:26 | Could not Abort Path, Replication set: [<Number>] SubClient: [<Number>]. |
| 76:27 | Could not Pause Path, Replication set: [<Number>] SubClient: [<Number>]. |
| 76:28 | Could not Resume Path, Replication set: [<Number>] SubClient: [<Number>]. |
| 76:29 | Configuration Missing. |
| 76:30 | Configuration File Missing. |
| 76:31 | Configuration Corrupted. |
| 76:32 | FRN Configuration Missing. |
| 76:33 | Failed to Update FRN Configuration. |
| 76:34 | Initiated Log Transfer for Source: [<String>] Destination:[<String>]. |
| 76:35 | Deleting Log File [<String>]. |
| 76:36 | This machine has 'Delete Log Configuration' Set! |
| 76:37 | Recovery Point successfully marked for the Replication set [<String>]. |
| 76:38 | Recovery Point cannot be marked for the Replication set [<String>]. |
| 76:39 | Snapshot is successfully taken for the volume [<String>]. |
| 76:40 | Snapshot cannot be taken for the volume [<String>]. Please verify that enough physical extents are available or a Volume Group cache area is available. Check client logs for more details. |
| 76:41 | Successfully made database entries for Recovery Point Job ID [<Number>]. |
| 76:42 | Cannot make database entries for Recovery Point Job ID [<Number>]. |
| 76:43 | Disk Space low for Log Volume on [<String>], slowing down the log transfer, where this client is the destination. |
| 76:44 | Disk Space critically low for Log Volume on [<String>], stopping log transfer, where this client is the destination. |
| 76:45 | Disk Space critically low for Log Volume on [<String>], aborting all pairs, where this client is the source. |
| 76:46 | Recovered some disk Space for Log Volume on [<String>], starting slow log transfer, where this client is the destination. |
| 76:47 | Disk Space normal for Log Volume on [<String>], starting regular log transfer, where this client is the destination. |
| 76:48 | Failed to connect with the destination [<String>] from source [<String>] - aborting replication. Possible causes: lost network connection, destination host down or services on destination host down. |
| 76:49 | Failed to create the collect File. Look into log for more details. |
| 76:50 | Failed to send the File. Look into log for more details. |
| 76:51 | Pipeline Error. Look into log for more details. |
| 76:52 | Write failed on destination: Please check the disk space on destination. Refer to log for more details. |
| 76:53 | Failed to mount the snapshot. Please verify that the snapshot exists. |
| 76:54 | An error occurred while doing copyback. Look into log for more details. |
| 76:55 | A replication job failed due to [<Message>]. |
| 76:56 | Replication resynch started for destination path: [<String>] Destination Path: [<String>] Destination Host: [<String>] Reason [<Message>]. |
| 76:57 | System aborted replication for destination path: [<String>] Destination Path: [<String>] Destination Host: [<String>] Reason [<Message>]. |
| 76:58 | Could not connect to destination (pipeline Error). |
| 76:59 | Could not connect to CommServe. |
| 76:60 | Could not find replication job information in database. |
| 76:61 | Cannot create snapshot of replicating set [<String>]: Not in the replicating state. |
| 76:62 | Could not create consistency point of replication set [<String>]: Got invalid job ID in the data stream. |
| 76:63 | Waiting for all pairs in replication set [<String>] to complete initial synchronization before creating recovery point. |
| 76:64 | Waiting for all pairs in replication set [<String>] to complete initial synchronization before creating consistent recovery point. |
| 76:65 | Timed out while waiting for a consistency snapshot mark to come from the source machine. |
| 76:66 | Cannot create recovery point for replicating set [<String>]: Set contains no pairs. |
| 76:67 | Failed to delete snapshot [<String>]. |
| 76:68 | Successfully deleted snapshot [<String>]. |
| 76:69 | Cannot remove snapshot [<String>] now because it's either busy or is not the oldest one. Will retry later. |
| 76:70 | Could not find journal entry [<Number>] in the cache. Switching replicating set [<String>] back to mirroring. |
| 76:71 | Starting mirroring of source folder [<String>] to folder [<String>] of [<String>] (repset [<String>]). |
| 76:72 | Starting mirroring of source folder [<String>] to folder [<String>] of [<String>] (repset [<String>]): [<Message>]. |
| 76:73 | Mirroring of source folder [<String>] to folder [<String>] of [<String>] (repset [<String>]) completed successfully. |
| 76:74 | Mirroring of source folder [<String>] to folder [<String>] of [<String>] (repset [<String>]) failed. |
| 76:75 | Starting replication of source folder [<String>] to folder [<String>] of [<String>] (repset [<String>]). |
| 76:76 | Connection to destination machine [<String>] has been lost. |
| 76:77 | ContinuousDataReplicator Driver reported that it encountered an unrecoverable error. All ContinuousDataReplicator pairs will now be aborted. |
| 76:78 | All ContinuousDataReplicator Replication Sets and Pairs originating on machine [<String>] are being aborted now. |
| 76:79 | ContinuousDataReplicator Service on machine [<String>] is going down. |
| 76:80 | Shutdown of ContinuousDataReplicator Service on machine [<String>] completed successfully. |
| 76:81 | Replication of source folder [<String>] to folder [<String>] on [<String>] (repset [<String>]) aborted successfully. |
| 76:82 | Database layer in ContinuousDataReplicator Service has encountered an unrecoverable error. All ContinuousDataReplicator pairs will now be aborted. |
| 76:83 | Performing smart resynchronization for all pairs starting on host [<String>]: [<Message>]. |
| 76:84 | Performing smart resynchronization for all pairs starting on host [<String>]. |
| 76:85 | Performing smart resynchronization of source folder [<String>] to [<String>] (repset [<String>]): [<Message>]. |
| 76:86 | Performing smart resynchronization of source folder [<String>] to [<String>] (repset [<String>]): [<Message>]. |
| 76:87 | ContinuousDataReplicator Database is corrupt. |
| 76:88 | Move-in detected. |
| 76:89 | ContinuousDataReplicator Cache on the source machine overflowed. |
| 76:90 | Cannot enable replication of source folder [<String>]: It belongs to the root file system. |
| 76:91 | ContinuousDataReplicator filters were changed. |
| 76:92 | Partial move-out detected. |
| 76:93 | Raw Buffer Failure. |
| 76:94 | Rolling Cache Failure. |
| 76:95 | System will auto restart this pair when there is enough disk space. |
| 76:96 | System will auto restart this pair. |
| 76:97 | Failure starting data transfer pipe, Network Error. |
| 76:98 | Please check the network connection and abort the pair and restart. |
| 76:99 | User Interrupted. |
| 76:100 | Manual Start required. |
| 76:101 | Please Abort the Pair and restart. |
| 76:102 | Configuration file is corrupt. |
| 76:103 | Failed to allocate Memory. |
| 76:104 | Failed to send internal message. |
| 76:105 | Please check the destination service, and abort the pair and restart. |
| 76:106 | Failed to monitor changes. |
| 76:107 | Failed to perform Checksum processing with retry. |
| 76:108 | Failure to perform Scan. |
| 76:109 | User Aborted. |
| 76:110 | Driver detected Error. |
| 76:111 | Could not connect to CommServe. |
| 76:112 | Could not connect to destination. |
| 76:113 | Disk is full. Cannot write logs to disk. |
| 76:114 | Machine rebooted. Will perform smart synchronization. |
| 76:115 | Pair Level File filters changed. Full resynchronization is needed. |
| 76:116 | Could not take a source snapshot for second level synchronization. |
| 76:117 | Throttling. Source Log Volume is running out of disk space. |
| 76:118 | Folder or File is moved in to the monitored folder (Cut/Paste). |
| 76:119 | Cluster Group of which this pair is part of, failed over to other server. |
| 76:120 | Replay reported internal error. |
| 76:121 | Reason: [<Message>] Corrective Action: [<Message>] |
| 76:122 | Pair is in inconsistent state. |
| 76:123 | Could not take snapshot due to high I/O volume. Will continue to retry. If the issue continues, consider aborting the pair and restarting it after some time. |
| 76:124 | Snapshot of source volume successfully taken. |
| 76:125 | Could not create resynchronization file. |
| 76:126 | Journal Id in smart synchronization phase does not match. |
| 76:127 | Could not initiate checksum processing. |
| 76:128 | Not continuing with orphan processing on source as destination cannot be reached. |
| 76:129 | Aborting all pairs from source to destination as log cannot be opened on destination. |
| 76:130 | Aborting all pairs from source to destination as log file size could not be determined on destination. |
| 76:131 | Aborting all pairs from source to destination as memory could not be allocated on destination. |
| 76:132 | Aborting pair to destination on request. |
| 76:133 | Aborting all pairs to destination on request. |
| 76:134 | Aborting pair because source could not ask destination to start log replay. |
| 76:135 | Please check destination logs and if necessary take appropriate action and restart pair. |
| 76:136 | Request for recovery point creation failed. Possible reasons could be that replication set has all pairs aborted and destination service was recently recycled and does not yet have configuration information. |
| 76:137 | Please verify that the replication set does not have all pairs in aborted state. If they are not, please wait for some time and retry recovery point creation operation. |
| 76:138 | Invalid source path [<String>] passed for copyback. |
| 76:139 | Can't find mount point for [<String>]. Copyback will be performed from live FS. |
| 76:140 | Inconsistent OS mount table. Path [<String>] is said to be on the FS mounted under [<String>], but in fact it's not. Copyback will be performed from live FS. |
| 76:141 | No snapshot found for [<String>]: copyback will be performed from live FS. |
| 76:142 | Auto mounting snapshot [<String>] under [<String>] for copyback purposes. |
| 76:143 | [<String>] is not a CXBF device. Please use Volume Explorer or run CDR/cdr_config_cxbf script from the install folder on the client machine in order to create a new CXBF device on top of [<String>] or disable CXBF snapshots altogether. |
| 76:144 | [<String>] belongs to [<String>], which is not a CXBF device. Please use Volume Explorer or run CDR/cdr_config_cxbf script from the install folder on the client machine in order to create a new CXBF device on top of [<String>] or disable CXBF snapshots altogether. |
| 76:145 | Failed to replicate ACL or extended attributes of file [<String>] on the destination. File system does not support them. |
| 76:146 | Folder monitoring could not start due to high I/O volume. Will continue to retry. If the issue continues, consider aborting the pair and restarting it. |
| 76:147 | Could not take snapshot of source folder. |
| 76:148 | Please check log file for details and take appropriate action. |
| 76:149 | Destination volume is full. Aborting pair on request from destination. |
| 76:150 | Please ensure destination volume has enough free space and restart pair. |
| 76:151 | Snapshot is not valid anymore. |
| 76:152 | Replication of folder [<String>] from machine [<String>] to folder [<String>] of machine [<String>] has been aborted due to the lack of space. |
| 76:153 | Source did not receive response from destination for smart sync update. |
| 76:154 | The oldest snapshot is in use and cannot be pruned. Continuing without pruning... |
| 76:155 | Attempt to prune snapshot failed. New snapshot will not be created. |
| 76:156 | Snapshot [<String>] could not be mounted. |
| 76:157 | Failed to change snapshot engine type on the client: Unknown error. |
| 76:158 | The specified snapshot engine type is not supported on this platform. |
| 76:159 | Invalid snapshot engine type. |
| 76:160 | Cannot activate QSnap Engine: QSnap Driver is either uninstalled or not loaded. |
| 76:161 | The new snapshot engine type has been accepted on the client, but there are still some CXBF devices configured. Please de-configure them using either Volume Explorer or CDR/cdr_config_cxbf script in the install folder on the client machine. |
| 76:162 | The new snapshot engine type has been accepted on the client, but you still need to configure CXBF devices on top of regular block devices either using Volume Explorer or by running CDR/cdr_config_cxbf script in the install folder on the client machine. |
| 76:163 | We were unable to inject our driver in the I/O path of the FS containing [<String>]. Consider recompiling the file system code as a module. |
| 76:164 | Not enough space on destination. |
| 76:165 | Source failed replication for pair upon request by destination. If destination path is a UNC path, please check impersonation settings and try starting pair again. |
| 76:166 | CDR Service is not initialized completely. Please try again after some time. |
| 76:167 | CDR Service encountered error while processing request. |
| 76:168 | Network call is not implemented. |
| 76:169 | Failed to add replication pair to internal data structures. Please check client logs for more details. |
| 76:170 | Failed to start replication pair. Please check client logs for more details. |
| 76:171 | Failed to remove replication pair from internal data structures. Please check client logs for more details. |
| 76:172 | Failed to abort replication pair. Please check client logs for more details. |
| 76:173 | Failed to mark replication pair dirty. Please check client logs for more details. |
| 76:174 | Failed to forget replication pair. Please check client logs for more details. |
| 76:175 | Failed to suspend replication pair. Please check client logs for more details. |
| 76:176 | Failed to start replication set. Please check client logs for more details. |
| 76:177 | Some replications pairs in the set failed to start. Please check client logs for more details. |
| 76:178 | Failed to abort replication set. Please check client logs for more details. |
| 76:179 | Some replications pairs in the set could not be aborted. Please check client logs for more details. |
| 76:180 | Failed to suspend replication set. Please check client logs for more details. |
| 76:181 | Some replications pairs in the set could not be suspended. Please check client logs for more details. |
| 76:182 | Failed to apply changes on the client machine. Please check client logs for more details. |
| 76:183 | Failed to inject snapshot mark into the journal stream. Please check client logs for more details. |
| 76:184 | Failed to initiate CRP creation process. Please check client logs for more details. |
| 76:185 | Failed to delete snapshots on the client machine. Please check client logs for more details. |
| 76:186 | Failed to mount snapshots on the client machine. Please check client logs for more details. |
| 76:187 | Failed to unmount snapshots on the client machine. Please check client logs for more details. |
| 76:188 | Cannot monitor file system that the replication pair belongs to. The file system is not supported. |
| 76:189 | Failed to replicate EXT2 extended attributes of file [<String>] on the destination. Destination file system does not support them. |
| 76:190 | Connection to destination machine [<String>] has been broken, and we are still not able to reestablish it. Replication set [<String>] is not transferring any data! |
| 76:191 | Connection to destination machine [<String>] has been reestablish. |
| 76:192 | Specified source path doesn't exist. |
| 76:193 | Recreate the replication pair with new source. |
| 76:194 | Required Library is missing for performing database recovery. |
| 76:195 | Failed to perform database recovery. |
| 76:196 | Journal ID for Backup or Pairs does not match. Please restart JOB with Full sync. |
| 76:197 | Cannot create a new snapshot of [<String>] because there are already snapshots of this volume present that have not been created by us. |
| 76:198 | Backend initialization failed. Please refer to client logs for details. |
| 76:199 | Could not get pair configuration for the provided browse time. Either Pairs are not configured for the time specified or system failed to get pair information. |
| 76:200 | No Recovery point available for the specified time. |
| 76:201 | No pairs are configured for the Replication set. |
| 76:202 | Snapshot cannot be taken for the volume [<String>]. Please verify that enough physical extents are available or a Volume Group cache area is available. Check client logs for more details. |
| 76:203 | Failed to perform incremental backup because one or more expected items were missing from system log files. |
| 76:204 | Next backup will be a full backup job. |
| 76:205 | User disabled backup activity. No backup will be done |
| 76:206 | Tick Mark Enable Backup Activity checkbox on WBA console to enable backup. |
| 76:207 | Failed to stage libraries. |
| 76:208 | Failed to identify paths to databases. |
| 76:209 | Failed to create snapshot. |
| 76:210 | Failed to revert files modified on original volume from snapshot. |
| 76:211 | Replication set is empty. Please configure the pairs or subclient to back up and retry. |
| 76:212 | Client computer has a new update which requires a reboot before jobs can run. Please reboot the client computer and resume backup jobs. |
| 76:213 | Update is being installed on this machine. Cannot run backup now. |
| 76:214 | Pair is already running. |
| 76:215 | Failed to translate received source path to destination browse path. |
| 76:216 | Destination browse path is invalid. |
| 76:217 | Suspending currently running backup job because sufficient network bandwidth is not available. |
| 76:218 | Resuming currently suspended backup job because sufficient network bandwidth is available. |
| 76:219 | Killing stale backup job because it did not complete in allocated time. |
| 76:220 | Scheduled backup job started. |
| 76:221 | Invalid source path |
| 76:222 | Failed to create destination directory. |
| 76:223 | Verify that the destination volume exists and that the directory can be created. |
| 76:224 | Destination volume GUID mismatch. |
| 76:225 | There were log replay errors for folder [<String>] to [<String>]. We are going to attempt a full synchronization for this folder now. |
| 76:226 | Applications on source were quiesced for consistent recovery point. |
| 76:227 | The consistent recovery point creation in progress. |
| 76:228 | Consistent recovery point processed successfully on source. |
| 76:229 | Applications on source were unquiesced after snapshot. |
| 76:230 | Waiting for logs to reach the destination. |
| 76:231 | The recovery point creation is in progress on destination. |
| 76:232 | The recovery point was created successfully. |
| 76:233 | The old recovery point removed successfully. |
| 76:234 | The pair Information is invalid. |
| 76:235 | Change Journal could not be enabled. |
| 76:236 | File System Journal creation failed. |
| 76:237 | Generic CDR Error. |
| 76:238 | Please refer to CDR logs for more information about this error. |
| 76:239 | Successfully mounted snapshot of volume [<String>] to [<String>]. |
| 76:240 | Failed to mount snapshot of volume [<String>] to [<String>]. |
| 76:241 | Commvault VSS Provider not found. Will use legacy methods to quiesce the applications, if any. |
| 76:242 | Mismatch between the current source volume GUID and the GUID when the pair was created. |
| 76:243 | Delete and recreate a new pair. |
| 76:244 | CDR Control process is lost. Moving the pair to PAUSED state. |
| 76:245 | The Commvault VSS software provider is not installed or not found. |
| 76:246 | Failed to convert name [<String>] from UTF-8 to local encoding. Please make sure that system locale is correctly set. |
| 76:247 | Failed to convert name [<String>] from local encoding to UTF-8. Please make sure that system locale is correctly set. |
| 76:248 | The Recovery Point associated with Job [<Number>] was pruned because one of its snapshots got deleted. Please check that there is enough space on the shadow storage. |
| 76:249 | Snapshot for volume [<String>] is not mounted or shared. Please contact your system administrator to mount recovery point to allow browse, restore. |
| 76:250 | Unable to create temporary ONTAP share or LUN mount. |
| 76:251 | Unable to create network share on file server [<String>]. Error returned [<String>]. |
| 76:252 | Unable to mount LUN from snapshot on file server [<String>]. Error returned [<String>]. |
| 76:253 | Monitored volume [<String>] is dismounted. Aborting all pairs on this volume. |
| 76:254 | Replication log volume [<String>] is dismounted. Aborting all pairs on the client. |
| 76:255 | Volume is dismounted. Aborting all pairs on this volume or client. |
| 76:256 | Offline recovery CRP request is posted on machine where QSnap is not installed or running. Please install QSnap on the target machine and retry. |
| 76:257 | Interrupting replication of pair [<Number>] because its source folder [<Number>] is being renamed. |
| 76:258 | Aborting pair [<Number>] because its source folder [<Number>] is absent. |
| 76:259 | Successfully configured corresponding DDR pairs for subclient [<String>]. |
| 76:260 | Failed to configure corresponding DDR pairs for subclient [<String>]. |
| 76:261 | Starting to replicate snapshots for subclient [<String>] using DDR. |
| 76:262 | Failed to replicate snapshots for subclient [<String>] using DDR. |
| 76:263 | Creating and registering snapshots on the destination for subclient [<String>]. |
| 76:264 | Failed to reserve archive files on destination for job [<Number>]. |
| 76:265 | Failed to prepare volume [<String>] for snapshot operation at destination. Additional information [<String>] |
| 76:266 | Failed to create snapshots at destination for volume [<String>]. Additional Information [<String>] |
| 76:267 | Failed to set up a pair for incremental replication. Please check source logs for more details. |
| 76:268 | CDR service is down. Failing this job/phase. |
| 76:269 | CDR service is down. Failing this pair. |
| 76:270 | Start CDR service to resume. |
| 76:271 | Disk Space critically low for volume [<String>] of destination machine [<String>]. An estimated [<Number>] bytes is required and the destination reports [<Number>] bytes are available. Failing this pair. |
| 76:272 | Snapshot mounted at [<String>] is shared and cannot be unmounted. |
| 76:273 | Auto mount for new RP Job [<Number>] failed because previous RP is shared and cannot be unmounted. Please manually mount the new RP. |
| 76:274 | CRP failed as there are more than one Storage Groups present in the repset. |
| 76:275 | Not continuing with orphan processing for pair [<Number>] on source as destination machine [<String>] cannot be reached. |
| 76:276 | Destination CDR service is either down or is not installed. |
| 76:277 | Failed to populate failed file items from DDR replication engine |
| 76:278 | Destination CDR service is not installed. |
| 76:279 | USN for the volume is invalid. Please check source logs for more details. |
| 76:280 | Failed to get destination client ID. |
| 76:281 | Failed to get pair information. |
| 76:282 | No valid pairs available for browse. |
| 76:283 | Failed to get Recovery Points. |
| 76:284 | Cannot create Recovery Point of Replication Set [<String>]: pair [<Number>] is not in the replicating state. |
| 76:285 | Failed to initiate scan of data on source for pair [<Number>]. Please check log file for details. |
| 76:286 | Failed to create event [<String>] on source. |
| 76:287 | Failed to send verification request to destination [<String>] for pair [<Number>]. |
| 76:288 | Destination [<String>] is processing another verification request for pair [<Number>]. |
| 76:289 | Scan of data on source failed for pair [<Number>]. |
| 76:290 | Failed to load verification file received for pair [<Number>]. |
| 76:291 | Failed to compare source and destination data for pair [<Number>]. |
| 76:292 | Failed to import data into verification database for pair [<Number>]. |
| 76:293 | Failed to get list of pairs in repset [<Number>]. |
| 76:294 | Repset [<Number>] has no pairs. |
| 76:295 | Failed to initialize thread pool. |
| 76:296 | Successfully configured corresponding LREP pairs for subclient [<String>]. |
| 76:297 | Failed to configure corresponding LREP pairs for subclient [<String>]. |
| 76:298 | Starting to replicate snapshots for subclient [<String>] using LREP. |
| 76:299 | Failed to replicate snapshots for subclient [<String>] using LREP. |
| 76:300 | Creating and registering snapshots on the destination for subclient [<String>]. |
| 76:301 | Failed to reserve archive files on destination for job [<Number>]. |
| 76:302 | Failed to prepare volume [<String>] for snapshot operation at destination. Additional information [<String>] |
| 76:303 | Failed to create snapshots at destination for volume [<String>]. Additional Information [<String>] |
| 76:304 | Failed to populate failed file items from LREP replication engine |
| 76:305 | Can't initialize replication when the source cache [<String>] is on a monitored file system. |
Backup iDataAgent
| Code | Description |
| 6:1 | Initialization Pending: Failure due to insufficient arguments: Attempting to reinitialize. If the problem persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 6:2 | Initialization pending: failed to resolve CommServe name. Please check the following: 1. CommServe connectivity 2. DNS or host files entries 3. Services are running on client and CommServe [<String>]. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:3 | Initialization pending: failed to resolve CommServe name. Please check the following: 1. CommServe connectivity 2. DNS or host files entries 3. Services are running on client and CommServe [<String>]. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:4 | Initialization pending: failed to resolve CommServe name. Please check the following: 1. CommServe connectivity 2. DNS or host files entries 3. Services are running on client and CommServe. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:5 | Initialization pending: failed Job Object initialization. Please check the following: 1. CommServe connectivity 2. Sufficient process memory 3. Services are running on client and CommServe. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:6 | Initialization pending: failed Job Control initialization. Please check the following: 1. CommServe connectivity 2. Sufficient process memory 3. Services are running on client and CommServe. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:7 | Initialization pending: failed to connect with the CommServe; error [<HexNumber>]. Please check the following: 1. CommServe connectivity 2. Services are running on client and the CommServe. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:8 | Initialization pending: failed to connect with the MediaAgent. Please check the following: 1. MediaAgent connectivity 2. Services are running on client and the MediaAgent. Attempting to reinitialize; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:9 | Backup pending: failed to Create Metadata file. Please check the following: 1. CommServe and MediaAgent connectivity 2. Services are running on client, CommServe and the MediaAgent. Attempting to restart; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:10 | Backup job marked pending due to missing configuration files for CommCell [<Number>] and AppId [<Number>]. Please check the following: 1. CommServe connectivity 2. Services are running on client and the CommServe. 3. The account that File System agent uses, has permissions to the product's install directory. After attempting to restart, if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:11 | Backup pending: failed to open collect file [<String>] error number [<Number>, <String>]. Please check the following: the account that File System agent uses, has permissions to the product's install directory. Attempting to restart; if the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:12 | Job Status notification failed. Please check the following: 1. CommServe connectivity 2. Services are running on client and the CommServe. Attempt to restart. |
| 6:13 | Usage : clBackup -t <Backup Type (1=full, 2=incr)> -a <appId:commCellId> -j <jobId>. |
| 6:14 | Restarting backup at offset [<Number>], but filename found [<String>] does not match restart filename [<String>]. |
| 6:15 | Problem using the supplied restart information for one file. Could not seek to [<Number>] for restart. Continuing the backup from start. If the problem persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 6:16 | Problem using the supplied restart information for one file. Could not read from [<Number>] for restart. Continuing the backup from start. If the problem persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 6:17 | Job Update notification failed. Please check the following: 1. CommServe connectivity 2. Services are running on client and the CommServe. Attempting to restart. |
| 6:18 | Could not open the failures file [<String>]; error [<Number>, <String>]. The backup will continue but this would affect the ability to do the failed file backup during the next incremental backup. A full backup is recommended to back up all files. Please check the following: 1. The account that the File System agent uses, has permissions to the product's install directory. 2. Sufficient disk space is available for the Job Results directory. If the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:19 | Could not open the backup results file for job [<Number>]. The backup will continue but this would affect the ability to view the list of failed files for this job. Please check the following: 1. The account that the File System agent uses, has permissions to the product's install directory. 2. Sufficient disk space is available for the Job Results directory. If the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:20 | Could not back up [<Number>] folders and [<Number>] files. |
| 6:21 | Backup Pending: Failure due to unexpected object state: Attempting to restart. If the problem persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 6:22 | Backup pending: failed to close Metadata file for error [<Number>]. Please check the following: 1. CommServe and MediaAgent connectivity 2. Services are running on client, CommServe and the MediaAgent. Attempting to restart. |
| 6:23 | LAST file has been sent. |
| 6:24 | Exiting. |
| 6:25 | Exiting due to failure. |
| 6:26 | Initialization pending: error [<Number>] when fetching the Operating System ID from CommServe. Please check the CommServe connectivity and that the services are running. |
| 6:27 | Exiting due to datapipe failure. |
| 6:28 | Error during BackupRead on [<String>], error [<Number>]. |
| 6:29 | Failed to get status for [<String>]. |
| 6:30 | Failed to open file [<String>]. |
| 6:31 | Failed to get file size for [<String>] error [<Number>]. |
| 6:32 | DeviceIoControl() failed on getting compression attribute on [<String>], error [<Number>]. |
| 6:33 | No access to registry file [<String>]. |
| 6:34 | Failed to turn off archive attribute after back up [<String>]. |
| 6:35 | Sending Bad File Indicator. |
| 6:36 | Path length exceeds 260 characters. Windows API FindFirstFile limitation reached; cannot process directory [<String>]. |
| 6:37 | Program Operating System Mismatch [<String>]. |
| 6:38 | VSS snapshot will not be used because [<String>]. Locked files will fail to back up. |
| 6:39 | Locked files will fail to back up, QSnap creation failed because [<String>]. |
| 6:40 | Backup Pending: Failure due to unexpected state generally caused by a corrupted install: Attempting to restart. If the problem persists, please reinstall the software with the latest feature release. |
| 6:41 | Backup pending: current user has insufficient privileges to perform the backup. Please check the following: The account, which the file system agent uses, has sufficient privileges. |
| 6:42 | Backup failed: the job has exceeded the maximum allowed failures of [<Number>] files. n Please check the following: 1. The account that the File System agent uses has sufficient privileges to back up files. n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible. n 3. A third-party product is not locking the files. 4. There is no corruption of the data on the disk.n If the problem persists, please upload the log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the Job ID of the failed job. |
| 6:43 | Backup failed: unable to open or read a file. Configured to fail on any error.n Please check the following:n 1. The account that the File System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so that the backups can complete. |
| 6:44 | Backup failed: unable to open or read a file. Configured to fail on any error for proxy host.n Please check the following:n 1. The account that the File System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so the backups can complete. |
| 6:45 | Backup failed: unable to set header flags. Configured to fail on any error.n Please check the following:n 1. The account that the file System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so the backups can complete. |
| 6:46 | Backup failed: one or more files failed to be backed up. Configured to fail on any error.n Please check the following:n 1. The account that the File System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so the backups can complete. |
| 6:47 | Backup failed: unable to populate header. Configured to fail on any error.n Please check the following:n 1. The account that the File System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so the backups can complete. |
| 6:48 | Backup failed: unable to send header. Configured to fail on any error.n Please check the following:n 1. The account that the File System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so the backups can complete. |
| 6:49 | Backup failed: unable to open directory. Configured to fail on any error.n Please check the following:n 1. The account that the File System agent uses has sufficient privileges to back up files.n 2. The data being backed up can be accessed and is not on a path that is unmounted or is inaccessible.n 3. A third-party product is not locking the files.n 4. There is no corruption of the data on the disk.n 5. If some failures are expected, please change the current setting so the backups can complete. |
| 6:50 | Failed to open restart map file [<String>] error number [<Number>, <String>]. |
| 6:51 | Failed to collect metadata for volume [<String>]. File level restore will not be possible for this volume. |
| 6:52 | Backup Pending. Failed to update metadata information on the CommServe. Please check the following: n1. CommServe and MediaAgent connectivity n 2. All services are running on client, CommServe and the MediaAgent. nThe job will be retried again. If the problem persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 6:53 | Backup Pending. Failed due to wrong version of backup program installed on this system. Please install the correct version of the backup program. |
| 6:54 | Could not create a VSS snapshot. Please check the client log for details of the failure. The backup will continue but may not be able to back up open files. |
| 6:55 | Could not create Online Content Indexing [<Number>] folders and [<Number>] files. |
| 6:56 | Snapshot engine initialization failed. |
| 6:57 | (Not used) File System SNAP failed. Please see log file for more information. |
| 6:58 | File System snapshot initialization failed. [<String>] |
| 6:59 | File System snapshot failed. [<String>] |
| 6:60 | File System snapshot Catalog failed. [<String>] |
| 6:61 | Engine type is not set. |
| 6:62 | Mount is failing for snapshot. [<String>] |
| 6:63 | EMC Snapshot operation is still in progress. |
| 6:64 | System state backup of component [<String>] failed. |
| 6:65 | Recursive symbolic link [<String>] found in the content which is referring to the parent path [<String>]. |
| 6:66 | System state backup of component [<String>] failed [<Message>]. |
| 6:67 | OneTouch Error: Failed to get adapter information. |
| 6:68 | OneTouch Error: Failed to get disk information |
| 6:69 | OneTouch Error: Failed to back up 1-Touch file |
| 6:70 | OneTouch Error: Failed to back up boot.ini file |
| 6:71 | OneTouch Error: Failed to back up 1-Touch information |
| 6:72 | OneTouch Error: Failed to get operating system SKU number |
| 6:73 | OneTouch Error: Failed to set a focus |
| 6:74 | OneTouch Error: Failed to get a software directory |
| 6:75 | OneTouch error: failed to create onetouchinfo.cvf file |
| 6:76 | OneTouch error: failed to get software information |
| 6:77 | Failed to create the VSS interface for the open file manager snapshot. The backup will continue, however, open files will not be backed up. |
| 6:78 | VSS snapshot creation timed-out when creating the VSS open file manager snapshot. The backup will continue, however, open files will not be backed up. |
| 6:79 | One or more volumes are ineligible and could not be added to the VSS open file manager snapshot. The backup will continue, however, open files will not be backed up. |
| 6:80 | Failed to create the VSS open file manager snapshot because another VSS snapshot operation is already in progress. The backup will continue, however, open files will not be backed up. |
| 6:81 | Failed to create the VSS open file manager snapshot due to insufficient storage on the cache volume. The backup will continue, however, open files will not be backed up. |
| 6:82 | Failed to create the VSS open file manager snapshot due to a VSS provider veto. The backup will continue, however, open files will not be backed up. |
| 6:83 | Failed to create the VSS open file manager snapshot due to an unexpected VSS provider error. The backup will continue, however, open files will not be backed up. |
| 6:84 | Failed to create the VSS open file manager snapshot due to an unexpected VSS writer error. The backup will continue, however, open files will not be backed up. |
| 6:85 | One or more collect files are missing. |
| 6:86 | Backup in Progress |
| 6:87 | h |
| 6:88 | Virtual Machine |
| 6:89 | Display help for this program |
| 6:90 | Specify instance |
| 6:91 | Backup &Monitor |
| 6:92 | &Settings |
| 6:93 | &Enable Animation |
| 6:94 | &Disable Animation |
| 6:95 | E&xit |
| 6:96 | Success |
| 6:97 | Failed |
| 6:98 | %s Backup Monitor |
| 6:99 | No job information currently available |
| 6:100 | No applications configured on this computer |
| 6:101 | Failed to launch web console |
| 6:102 | Last backup run |
| 6:103 | No backup running |
| 6:104 | Current backup running |
| 6:105 | Open Web Console |
| 6:106 | Close |
| 6:107 | Time |
| 6:108 | Successful Objects |
| 6:109 | Failed Objects |
| 6:110 | Phase |
| 6:111 | Elapsed Time |
| 6:112 | None |
| 6:113 | Enumerating files for backup |
| 6:114 | Transferring |
| 6:115 | Throughput |
| 6:116 | /Hr |
| 6:117 | Data Transferred |
| 6:118 | Files Transferred |
| 6:119 | KB |
| 6:120 | MB |
| 6:121 | GB |
| 6:122 | TB |
| 6:123 | PB |
| 6:124 | Day(s) |
| 6:125 | of |
| 6:126 | Status |
| 6:127 | Help |
| 6:128 | &Documentation |
| 6:129 | Documentation Website |
| 6:130 | Nothing New to back up |
| 6:131 | Bytes |
| 6:132 | Reason |
| 6:133 | Install Updates |
| 6:134 | Updates Pending |
| 6:135 | There are no pending updates to be installed. |
| 6:136 | Successfully submitted request for installing updates. |
| 6:137 | Unable to install updates now. Please try again after sometime. |
| 6:138 | Last Successful Backup : |
| 6:139 | No Backup Running |
| 6:140 | Backup Now |
| 6:141 | Stop |
| 6:142 | Complete |
| 6:143 | Backup in progress on Server... |
| 6:144 | Next Attempt: <String> |
| 6:145 | Error. The last backup job failed. |
| 6:146 | Job Delayed: <String> |
| 6:147 | The backup job has been paused. |
| 6:148 | Subclient : |
| 6:149 | Successfully submitted backup request. |
| 6:150 | Starting... |
| 6:151 | Stopping... |
| 6:152 | Cannot communicate to Server. |
| 6:153 | Unable to process request. |
| 6:154 | No privileges to control backup. |
| 6:155 | No connection to the Server. |
| 6:156 | Checking Connectivity to Server... |
| 6:157 | Processing Request... |
| 6:158 | Subclient content was not found on the source machine. |
| 6:159 | Subclient content [<String>] was not found on the source machine. |
| 6:160 | Client software is not installed on [<String>]. |
| 6:161 | Client software need update on [<String>]. |
| 6:162 | Installation package not found on the proxy client. |
| 6:163 | Can't start launch daemon on the remote client. |
| 6:164 | Can't remove old file on the remote client. |
| 6:165 | Can't copy file to the remote client. |
| 6:166 | Can't stop launch daemon on the remote client. |
| 6:167 | Message send attempted on nonexistent connection. |
| 6:168 | Failed to serialize message. |
| 6:169 | Failed to send message. |
| 6:170 | Failed to peek at message header. |
| 6:171 | Failed to receive message. |
| 6:172 | Failed allocate memory. |
| 6:173 | Failed to deserialize message. |
| 6:174 | Received kill message. |
| 6:175 | Can't start client process. |
| 6:176 | Failed to get client information [<String>] for Application ID [<String>] Error [<Number>] |
| 6:177 | Client information is not configured. |
| 6:178 | View Backup Jobs Report |
| 6:179 | View Backup Jobs &Report |
| 6:180 | Restore |
| 6:181 | Name |
| 6:182 | Type |
| 6:183 | Size |
| 6:184 | Date Modified |
| 6:185 | Backup Time |
| 6:186 | My Vault |
| 6:187 | Latest |
| 6:188 | Last Week |
| 6:189 | View All Versions |
| 6:190 | Open |
| 6:191 | All Versions of |
| 6:192 | Version |
| 6:193 | Two Weeks Ago |
| 6:194 | Last Month |
| 6:195 | Last Year |
| 6:196 | Restore job (<Number>) submitted. |
| 6:197 | Restore selected item(s) to original location?nVersion as of |
| 6:198 | Select Folder for Restore |
| 6:199 | Restore |
| 6:200 | Restore job cannot be submitted. |
| 6:201 | Enable |
| 6:202 | Disable |
| 6:203 | Edge |
| 6:204 | Refresh Local Cache |
| 6:205 | Refresh Archive requires connectivity to CommServe and MediaAgent. Do you want to proceed. |
| 6:206 | Recall Stub |
| 6:207 | Recall Data |
| 6:208 | Recall Data Recursively |
| 6:209 | Failed to create the VSS interface for the open file manager snapshot. |
| 6:210 | VSS snapshot creation timed out when creating the VSS open file manager snapshot. |
| 6:211 | One or more volumes are ineligible and could not be added to the VSS open file manager snapshot. |
| 6:212 | Failed to create the VSS open file manager snapshot because another VSS snapshot operation is already in progress. |
| 6:213 | Failed to create the VSS open file manager snapshot due to insufficient storage on the cache volume. |
| 6:214 | Failed to create the VSS open file manager snapshot due to a VSS provider veto. |
| 6:215 | Failed to create the VSS open file manager snapshot due to an unexpected VSS provider error. |
| 6:216 | Failed to create the VSS open file manager snapshot due to an unexpected VSS writer error. |
| 6:217 | Could not create a VSS snapshot. Check the client log for details of the failure. |
| 6:218 | Create Custom Archive |
| 6:219 | Archive Name |
| 6:220 | Latest Backup |
| 6:221 | Time Range |
| 6:222 | Absolute Time |
| 6:223 | Start Time |
| 6:224 | End Time |
| 6:225 | Relative Time |
| 6:226 | Last |
| 6:227 | Starting Path |
| 6:228 | Filter Criteria |
| 6:229 | File Name |
| 6:230 | Modified Date |
| 6:231 | File Size |
| 6:232 | Stubbed Object |
| 6:233 | Failed Object |
| 6:234 | Folder Size |
| 6:235 | File name Filter is empty. |
| 6:236 | Archive Name is empty. |
| 6:237 | Start Time must be earlier than End Time. |
| 6:238 | Starting Path is empty. |
| 6:239 | Archive Name already exists.Please give another name. |
| 6:240 | No Web Search Server found installed in the commcell. |
| 6:241 | Failures encountered for all associated subclients. |
| 6:242 | &Register |
| 6:243 | No Association found on the subclient. |
| 6:244 | Nothing matched the filter criteria. |
| 6:245 | No Filters found on the subclient. |
| 6:246 | &Feedback |
| 6:247 | Backup State: |
| 6:248 | Backup Time: |
| 6:249 | Size: |
| 6:250 | Up-to-date |
| 6:251 | File modified after last backup |
| 6:252 | Not backed up |
| 6:253 | File Versions: |
| 6:254 | Edge |
| 6:255 | New Archive |
| 6:256 | Sync |
| 6:257 | Two-Way Sync |
| 6:258 | One-Way Sync to other computers |
| 6:259 | One-Way Sync from other computers |
| 6:260 | Synchronize contents between this folder and other computers |
| 6:261 | Update the latest contents from this folder to other computers |
| 6:262 | Update the latest contents for this folder from other computers |
| 6:263 | No connection to server. This request cannot be processed. |
| 6:264 | Pause Sync |
| 6:265 | Resume Sync |
| 6:266 | Check if local Edge services are down. Bring up services and try again. |
| 6:267 | Refresh |
| 6:268 | Sync folder is already configured on this client at |
| 6:269 | Properties |
| 6:270 | Edge Sync options are disabled because [<String>] doesn't have capabilities. Log onto webconsole to map windows user [<String>] to Commvault user with sync capabilities. |
| 6:271 | Today |
| 6:272 | Yesterday |
| 6:273 | This Week |
| 6:274 | This Month |
| 6:275 | This Year |
| 6:276 | Less Than |
| 6:277 | Less Than Or Equal |
| 6:278 | Greater Than |
| 6:279 | Greater Than Or Equal |
| 6:280 | Edge Preferences |
| 6:281 | Preferences |
| 6:282 | User |
| 6:283 | Global |
| 6:284 | Windows Explorer Plugin |
| 6:285 | Special Characters (\ / : * ? " < > |
| 6:286 | Include |
| 6:287 | Show Only |
| 6:288 | Edit Archive |
| 6:289 | Windows Explorer needs to be restarted to continue.nSelect Restart Explorer to proceed.nnIf Restart later is selected, you will be required to reboot Windows or logoff to complete uninstallation of explorer plugin. |
| 6:290 | The Following applications need to be closed to proceed |
| 6:291 | Please close these applications and click OK, or click Cancel to leave the process running.nIf you select Cancel, you will be required to reboot Windows or logoff to complete uninstallation of explorer plugin. |
| 6:292 | Restart Explorer |
| 6:293 | Restart Later |
| 6:294 | Edge Sync options are disabled because commcell user needs to be associated with minimum of 2 licensed laptop computers. |
| 6:295 | Edge Sync options are disabled because commcell user can be associated to maximum of 3 licensed laptop computers. |
| 6:296 | Data Loss Prevention |
| 6:297 | Personal Data Loss Prevention Pass-key |
| 6:298 | Old Pass-key |
| 6:299 | New Pass-key |
| 6:300 | Repeat Pass-key |
| 6:301 | Pass-key should be at least 8 characters long and contain one uppercase letter and one number.nnThe current DLP configuration allows the backup server to unlock protected documents automatically during backups or by your request when this computer is online.nnIn order to be able to access the documents when the server is not available or after copying the documents to another computer, please set up your personal DLP pass-key now. |
| 6:302 | Specified old Pass-key is incorrect. |
| 6:303 | Pass-keys entered do not match. |
| 6:304 | At least one of the fields is empty. |
| 6:305 | Error in setting new Pass-key. |
| 6:306 | Lock |
| 6:307 | Unlock |
| 6:308 | Error occurred while locking following document/s |
| 6:309 | Error occurred while unlocking document/s |
| 6:310 | Please enter user Pass-key below. |
| 6:311 | Enter User Pass-key |
| 6:312 | Authorized Users |
| 6:313 | Remove |
| 6:314 | Do you want to revoke unlock capability for following user? |
| 6:315 | No Pass-key entered. |
| 6:316 | Pass-key should be at least 8 characters long and contain one uppercase letter and one number.nnNote that in accordance with the current DLP configuration the backup server will not be able to unlock protected documents under any circumstances, and your pass-key is the only way to recover them. |
| 6:317 | Unlock document |
| 6:318 | This document can only be unlocked with a personal Pass-key. Please enter it below. |
| 6:319 | The backup server is currently offline. Please enter your personal pass-key below. |
| 6:320 | The backup server could not automatically unlock this document. Please enter your personal pass-key below. |
| 6:321 | This document can only be unlocked by backup server and it's currently offline. |
| 6:322 | This document can only be unlocked by backup server and unlock has failed. |
| 6:323 | Incorrect Pass-key. Please try again. |
| 6:324 | Cannot lock the document because no pass-key has been configured yet. Please use DLP menu in the Edge Monitor to set up your personal pass-key. |
| 6:325 | Pass-key: |
| 6:326 | File: |
| 6:327 | Error in fetching user capabilities. Check for connectivity to server. |
| 6:328 | User doesn't have capabilities to restore. Ensure user has both In-Place Recover and Out-of-Place Recover capabilities. |
| 6:329 | Go to WebConsole for additional configuration |
| 6:330 | This document can only be unlocked with a personal Pass-key but it's not configured. |
| 6:331 | This document is either corrupted or not locked. It cannot be unlocked. |
| 6:332 | This document cannot be unlocked due to insufficient permissions. |
| 6:333 | Error occurred while refreshing page cache on client. Please check logs. |
| 6:334 | Refresh Page Cache is only supported for Laptop Installs. |
| 6:335 | Explorer Plugin Page Cache refreshed successfully. |
| 6:336 | No Backup ran since last refresh. Page Cache is up-to-date. |
| 6:337 | Error occurred while refreshing page cache on client. Check if Local Edge Services are running. |
| 6:338 | Error occurred while refreshing page cache on client. Check if CommServe and MediaAgent services are running. Check Logs for more details. |
| 6:339 | Pass-key does not meet requirements. Pass-key should be at least 8 characters long and contain one uppercase letter and one number. |
| 6:340 | Windows Explorer needs to be restarted to display My Data,Edge Drive and Shares virtual drives correctly.nSelect Restart Explorer to proceed.nnIf you choose to restart later, then please manually restart explorer if My Data,Edge Drive or Shares virtual drives don't show up. |
| 6:341 | Data Loss Prevention makes a file or folder locked and its data is unreadable. Auto unlocking protected documents feature enables to automatically unlock the file when a locked file is being opened. |
| 6:342 | You can specify the process name below that needs to be included or excluded from auto unlocking the protected documents. |
| 6:343 | Add |
| 6:344 | Process Filter |
| 6:345 | Process Exclusion List |
| 6:346 | This process is already included in the list |
| 6:347 | Include |
| 6:348 | Exclude |
| 6:349 | Process Name: |
| 6:350 | OK |
| 6:351 | Cancel |
| 6:352 | Data Loss Prevention |
| 6:353 | Please restart your computer for Driverless method to take effect completely |
| 6:354 | Reached the threshold on number of items for this subclient. |
| 6:355 | Installing update on client [<String>]. |
| 6:356 | Failed to update client [<String>]. |
| 6:357 | Successfully installed update on client [<String>]. |
| 6:358 | My VMs |
| 6:359 | Remote Desktop |
| 6:360 | Full VM Restore |
| 6:361 | VM Name |
| 6:362 | Power On Virtual Machine after restore |
| 6:363 | Unconditionally overwrite VM with same name |
| 6:364 | VM Name is empty |
| 6:365 | Refresh My Data |
| 6:366 | VM File Level Restore |
| 6:367 | Destination |
| 6:368 | Folder Path |
| 6:369 | Folder Path is empty |
| 6:370 | Credentials |
| 6:371 | User Name |
| 6:372 | Password |
| 6:373 | User Name or Password is empty |
| 6:374 | Browse |
| 6:375 | Local Machine |
| 6:376 | Please provide logon credentials in order to browse into this VM. |
| 6:377 | Power On |
| 6:378 | Shutdown |
| 6:379 | Restart |
| 6:380 | Create Snapshot |
| 6:381 | VM Provisioning Task |
| 6:382 | <String> operation for Virtual Machine <String> failed. |
| 6:383 | <String> operation for Virtual Machine <String> successful. |
| 6:384 | Name |
| 6:385 | Description |
| 6:386 | Snapshot name or description is empty |
| 6:387 | VM Management job (<String>) submitted to create snapshot. |
| 6:388 | Create VM |
| 6:389 | Create New Virtual Machine |
| 6:390 | Select Virtual Machine Pool |
| 6:391 | Pattern |
| 6:392 | Expiration |
| 6:393 | VMs to create |
| 6:394 | Confirm Password |
| 6:395 | Memory |
| 6:396 | Number of CPUs |
| 6:397 | Number of NICs |
| 6:398 | Max Disk Size |
| 6:399 | Disk One (GB) |
| 6:400 | Disk Two (GB) |
| 6:401 | Operating System |
| 6:402 | Virtual Machine Pool |
| 6:403 | Details |
| 6:404 | Template |
| 6:405 | Configuration |
| 6:406 | User Details |
| 6:407 | Summary |
| 6:408 | Vm Name does not match pattern. |
| 6:409 | Passwords entered do not match. |
| 6:410 | Enter VM Name and Expiration |
| 6:411 | Select Template |
| 6:412 | Enter User Details |
| 6:413 | Please provide password for administrator user for this virtual machine |
| 6:414 | User (<String>) doesn't have capabilities to browse. |
| 6:415 | VM Management job (<String>) submitted to create VM. |
| 6:416 | User (<String>) doesn't have capabilities to do live browse. |
| 6:417 | Client software need update on [<String>]. Update install blocked by client property. |
| 6:418 | VM Backup Size |
| 6:419 | Error in downloading file |
| 6:420 | Unable to contact server.Check if web console details are configured in registry. |
| 6:421 | Last Backup Time |
| 6:422 | User (<String>) does not have required capabilities to control client operations. |
| 6:423 | PseudoMount cache is running out of Space or Inodes |
| 6:424 | Downloading File |
| 6:425 | My Computers |
| 6:426 | Download File |
| 6:427 | &Activate Edge Drive |
| 6:428 | Ed&ge Drive |
| 6:429 | Edge Drive Preference&s |
| 6:430 | Preference&s |
| 6:431 | Pa&use Edge Drive |
| 6:432 | Pa&use |
| 6:433 | Res&ume Edge Drive |
| 6:434 | Res&ume |
| 6:435 | Sync unavailable |
| 6:436 | Sync complete |
| 6:437 | Sync paused |
| 6:438 | S&yncing [<Number>] files |
| 6:439 | &Advanced setup |
| 6:440 | &File Name: |
| 6:441 | &Modified: |
| 6:442 | &Only sync some folders to this computer: |
| 6:443 | &Start sync |
| 6:444 | < &Back |
| 6:445 | Account |
| 6:446 | Activating Edge Drive |
| 6:447 | An Edge Drive folder will be created on your computer.nnFiles in your Edge Drive folder are available on all your devices. |
| 6:448 | Check the Edge Drive path |
| 6:449 | days ago. |
| 6:450 | Do you want to unlink your account?nnAfter you unlink, your files will remain on your computer. |
| 6:451 | Unlinking Edge Drive |
| 6:452 | Edge Drive configuration |
| 6:453 | Edge Drive folder |
| 6:454 | Edge Drive is not set up for this user on this computer. Please contact your administrator. |
| 6:455 | Edge Drive is not set up |
| 6:456 | Edge Drive is now set up! |
| 6:457 | Edge Drive pause failed |
| 6:458 | Edge Drive preferences failed |
| 6:459 | Edge Drive preferences is unable to continue. Please contact your administrator. |
| 6:460 | Edge Drive preferences |
| 6:461 | Edge Drive resume failed |
| 6:462 | Edge Drive setup failed |
| 6:463 | Edge Drive setup failed. Please contact your administrator. |
| 6:464 | Edge Drive successfully set up on this computer. |
| 6:465 | Edge Drive successfully unlinked. |
| 6:466 | Edge Drive unlink failed |
| 6:467 | Edge Drive unlinked! |
| 6:468 | Edge Drive was previously configured and unlinked from this computer. Would you like to reuse the previous settings? |
| 6:469 | Edge Drive |
| 6:470 | Enter name or wild card (Example: *.doc). |
| 6:471 | File Si&ze: |
| 6:472 | Files in Edge Drive that are not in a folder will always sync. |
| 6:473 | Folder(s): |
| 6:474 | Greater than or Equal to |
| 6:475 | Greater than |
| 6:476 | How it works |
| 6:477 | Invalid file name |
| 6:478 | Invalid file size |
| 6:479 | Invalid modified duration |
| 6:480 | Leaving advanced setup |
| 6:481 | Less than or Equal to |
| 6:482 | Less than |
| 6:483 | months ago. |
| 6:484 | NOTE: Only content matching the above selected preferences will be synced. This will only affect the content getting synced going forward. |
| 6:485 | One-Way Sync from Edge Drive |
| 6:486 | One-Way Sync to Edge Drive |
| 6:487 | Please enter a valid file name. |
| 6:488 | Please enter a valid number for file size. |
| 6:489 | Please enter a valid number for modified duration. |
| 6:490 | Select Edge Drive folder... |
| 6:491 | Sync mode |
| 6:492 | Sync options |
| 6:493 | Sync preferences |
| 6:494 | This will discard any changes made to advanced setup. Continue? |
| 6:495 | Two-Way Sync |
| 6:496 | Unable to create a new folder for Edge Drive. Please specify a valid path. |
| 6:497 | Unable to pause Edge Drive. Please contact your administrator. |
| 6:498 | Unable to resume Edge Drive. Please contact your administrator. |
| 6:499 | Unable to save Edge Drive preferences. Please check if the services are up or contact your administrator. |
| 6:500 | Unable to set up Edge Drive. Please check if the services are up or contact your administrator. |
| 6:501 | Unable to unlink Edge Drive. Please try again or contact your administrator. |
| 6:502 | Unlink account... |
| 6:503 | User: |
| 6:504 | weeks ago. |
| 6:505 | Welcome to Edge Drive! |
| 6:506 | years ago. |
| 6:507 | Path: |
| 6:508 | Sign in |
| 6:509 | Password: |
| 6:510 | The user name or password you entered is incorrect. |
| 6:511 | Sign in to your Edge Drive account that you want to link to this computer.nAn Edge Drive folder will be created on your computer.nFiles in your Edge Drive folder are available on all your devices. |
| 6:512 | Error - Edge Drive folder is missing |
| 6:513 | Files in your Edge Drive folder are available on all your devices. |
| 6:514 | Ope&n Edge Drive folder |
| 6:515 | Please Enter Edge User Credentials |
| 6:516 | Save Credentials |
| 6:517 | Edge User Credentials |
| 6:518 | User Name or Password is empty. |
| 6:519 | Invalid Credentials. Please try again. |
| 6:520 | Backup Size |
| 6:521 | Not honoring Verify SynthFull for this job as Backup Only Files Qualified For Archiving is enabled. |
| 6:522 | Unable to set up Edge Drive. Please ensure that the Edge Drive user is an owner of this computer or contact your administrator. |
| 6:523 | Un&link Edge Drive |
| 6:524 | Failed to back up Edge drive content. |
| 6:525 | Username |
| 6:526 | Password |
| 6:527 | Where |
| 6:528 | Please wait... |
| 6:529 | Secure Delete |
| 6:530 | Error occurred while securely deleting following document/s |
| 6:531 | Unable to set up Edge Drive as this computer is not configured for Laptop or Desktop backup. |
| 6:532 | Syncing <Number> files |
| 6:533 | Syncing 1 file |
| 6:534 | My Data |
| 6:535 | Refreshing My Data... |
| 6:536 | The document cannot be unlocked since this device is marked lost. |
| 6:537 | Please set up your personal Data Loss Prevention(DLP) Pass-key below. |
| 6:538 | I understand that if I lose my pass-key and the backup server is not configured to unlock protected documents automatically, I will not be able to retrieve my files. |
| 6:539 | Shares |
| 6:540 | Shared By Me |
| 6:541 | Shared With Me |
| 6:542 | Share |
| 6:543 | Share Files/Folders |
| 6:544 | Invite People |
| 6:545 | Invited People |
| 6:546 | Can View |
| 6:547 | Can Edit |
| 6:548 | owner |
| 6:549 | Add |
| 6:550 | Remove |
| 6:551 | Make this a public folder |
| 6:552 | Anyone on the internet can view this folder. No sign-in required. A public link to share will appear once this share folder is saved. |
| 6:553 | Anyone on the internet can view this folder. No sign-in required. |
| 6:554 | Notify people via email |
| 6:555 | Include a personal message.(Optional) |
| 6:556 | Un-Share |
| 6:557 | Update |
| 6:558 | Leave Share |
| 6:559 | Are you sure you wish to un-share this shared folder? |
| 6:560 | Are you sure you wish to leave this shared folder? |
| 6:561 | Enter Username, Email Address or Group Name. |
| 6:562 | The user/group is already present in the invite list. |
| 6:563 | User |
| 6:564 | Group |
| 6:565 | |
| 6:566 | Public Share Link |
| 6:567 | Copy and send the link to anyone you want to share with. No sign-in required. |
| 6:568 | Updates are pending. |
| 6:569 | Machine needs to be rebooted to complete installation of updates. |
| 6:570 | Migration Assistant |
| 6:571 | Introduction |
| 6:572 | SignIn |
| 6:573 | Select |
| 6:574 | Summary |
| 6:575 | Progress |
| 6:576 | Attempting SSO... |
| 6:577 | Usage: MigrationAssistant.exe -inst instancename -cn clientname |
| 6:578 | Use the Migration Assistant to transfer data from one Microsoft windows computer to another. |
| 6:579 | Completed |
| 6:580 | Migration Completed |
| 6:581 | Migration Failed |
| 6:582 | Migration Failed. Please check the log files. |
| 6:583 | Migration is in Progress |
| 6:584 | Client : |
| 6:585 | Select the Client |
| 6:586 | No Data Selected For Migration. |
| 6:587 | Select User Folders For Migration |
| 6:588 | No User Folders were backed up. |
| 6:589 | Select the client and the data you want to migrate |
| 6:590 | Enter your Commcell logon credentials to allow Migration Assistant to make changes to the destination computer. |
| 6:591 | CommServe Host Name : |
| 6:592 | CommServe Host Name is empty. |
| 6:593 | User Name is empty. |
| 6:594 | Invalid Credentials.Please check the log files. |
| 6:595 | Client list is empty. |
| 6:596 | Password |
| 6:597 | Username |
| 6:598 | Current user does not have the required capabilities to perform migration.Please enter the comcell credentials |
| 6:599 | You are about to perform the following operation: |
| 6:600 | To begin the transfer of data, Click Finish |
| 6:601 | Description |
| 6:602 | Destination Client : |
| 6:603 | Source Client : |
| 6:604 | Migration Folders : |
| 6:605 | Failed to perform migration.Please the check the log file. |
| 6:606 | Migration is in pending or waiting state. |
| 6:607 | Migration job is killed. |
| 6:608 | Migration job is suspended. |
| 6:609 | Migration job is queued. |
| 6:610 | Operation In Progress |
| 6:611 | Submitting request to create snapshot |
| 6:612 | Submitting request to create Virtual Machine |
| 6:613 | Virtual Machine Name cannot exceed 15 characters. |
| 6:614 | Overwrite Existing Files/Folders |
| 6:615 | Your account does not have access to Edge Drive. Please contact your administrator to enable Edge Drive access. |
| 6:616 | Communication Error. Please check if services are running. |
| 6:617 | Please check if the services are running or try again later. |
| 6:618 | Edge Drive loading... |
| 6:619 | Syncing... |
| 6:620 | Preparing to sync... |
| 6:621 | Sync pending |
| 6:622 | Syncing... [<Number> files remaining] |
| 6:623 | Syncing... [1 file remaining] |
| 6:624 | Sync pending [<Number> files remaining] |
| 6:625 | Sync pending [1 file remaining] |
| 6:626 | Visit Edge Drive on the web |
| 6:627 | Snooze sync |
| 6:628 | Sync snoozed |
| 6:629 | Sync snoozed [<String> to resume] |
| 6:630 | Sync snoozed [resuming shortly...] |
| 6:631 | Resume sync now |
| 6:632 | Pause Backup |
| 6:633 | Resume Backup |
| 6:634 | Start Backup |
| 6:635 | View Backup Data on Device |
| 6:636 | Enable Explorer Plugin |
| 6:637 | Disable Explorer Plugin |
| 6:638 | Windows Explorer needs to be restarted. Do you want to restart the explorer now? |
| 6:639 | Windows Explorer Plugin could not be enabled. Please enable explorer plugin from process manager. |
| 6:640 | Windows Explorer Plugin successfully enabled. |
| 6:641 | Windows Explorer Plugin successfully disabled. |
| 6:642 | Windows explorer needs to be restarted. |
| 6:643 | 1 Hour |
| 6:644 | 2 Hours |
| 6:645 | 4 Hours |
| 6:646 | Indefinitely |
| 6:647 | Please set up your personal Data Loss Prevention (DLP) Pass-key below.nnAfter you change your passkey, you will still need to remember your old passkey to unlock any files that are currently locked on your computer. To assign your new passkey to these files after you change your passkey, unlock your files with your old passkey and then lock them again. |
| 6:648 | Click here for Job Status |
| 6:649 | Share Owner |
| 6:650 | Shared With |
| 6:651 | Do you want to upload these files? |
| 6:652 | Upload Files |
| 6:653 | Uploading |
| 6:654 | Upload completed successfully for following file/s. |
| 6:655 | Upload failed for following file/s. |
| 6:656 | Upload of Folders is not supported. |
| 6:657 | Change Permission |
| 6:658 | Share no longer exists. |
| 6:659 | Edge Drive |
| 6:660 | Do you want to permanently delete the following files/folders? |
| 6:661 | System needs to be rebooted for explorer plugin to be enabled. |
| 6:662 | System needs to be rebooted for explorer plugin to be disabled completely. |
| 6:663 | Reboot Now |
| 6:664 | Reboot Later |
| 6:665 | Restore Failed for following file/s. |
| 6:666 | Restoring |
| 6:667 | Restoring %d Files/Folders |
| 6:668 | Restoring VM |
| 6:669 | Restore Failed for VM |
| 6:670 | Powering On VM |
| 6:671 | Shutting down VM |
| 6:672 | Restarting VM |
| 6:673 | Creating snapshot for VM |
| 6:674 | Creating VM |
| 6:675 | Creating snapshot for VM failed |
| 6:676 | Creating VM failed |
| 6:677 | Created snapshot [<String>] successfully. |
| 6:678 | Created VM successfully. |
| 6:679 | Remote Connect |
| 6:680 | Unable to log on. Please check if the services are up or contact your administrator. |
| 6:681 | Log On |
| 6:682 | Log Off |
| 6:683 | Remote Connect is On |
| 6:684 | Remote Connect is Off |
| 6:685 | Session token expired. Enter credentials to refresh. |
| 6:686 | Refresh Token |
| 6:687 | Select Edge Drive Mode |
| 6:688 | Change Edge Drive Mode |
| 6:689 | Edge Drive Mode |
| 6:690 | Cloud |
| 6:691 | Offline |
| 6:692 | Disable Edge Drive |
| 6:693 | Edge Drive mode is configured to Cloud. Edge drive operations can be performed from a virtual drive.nnTo change edge drive mode select one of the options below. |
| 6:694 | Edge Drive mode is configured to offline. Edge drive operations can be performed from user configured edge drive folder.nnTo change edge drive mode select one of the options below. |
| 6:695 | Select one of the Edge Drive modes below. |
| 6:696 | Windows Explorer needs to be restarted to enable cloud edge drive. Do you want to restart explorer now? |
| 6:697 | Windows Explorer Plugin could not be enabled. Please enable explorer plugin from process manager. |
| 6:698 | Error in changing Edge Drive Mode. Please verify that edge services are up. |
| 6:699 | Edge Drive mode is set to cloud. Edge drive operations can be performed from a virtual drive.There is no offline access. |
| 6:700 | Edge Drive mode is set to cloud. Windows explorer needs to be restarted to enable the virtual drive to perfom Edge Drive operations. |
| 6:701 | Edge Drive is disabled. To enable it back select Edge Drive context menu from Edge Monitor. |
| 6:702 | For cloud mode the virtual drive will be removed. For offline mode the edge drive folder will be unlinked.n Do you want to disable Edge Drive? |
| 6:703 | Edge drive operations can be performed from a virtual drive. There is no offline access. |
| 6:704 | Edge drive operations can be performed from user configured edge drive folder and include offline access. |
| 6:705 | Activate |
| 6:706 | Activating Offline Edge Drive |
| 6:707 | Activating Cloud Edge Drive |
| 6:708 | Error in activating Cloud Edge Drive |
| 6:709 | Select Drive Letter |
| 6:710 | Edge Drive mode is set to cloud. Machine needs to be rebooted to complete configuration and enable virtual drive to perfom Edge Drive operations. |
| 6:711 | Confirmation |
| 6:712 | Do you want to exit Edge Drive configuration? |
| 6:713 | Download |
| 6:714 | Retrieving Versions... |
| 6:715 | Error in retrieving versions for |
| 6:716 | File downloaded successfully at |
| 6:717 | Error in downloading file |
| 6:718 | VPN Log On |
| 6:719 | VPN Log Off |
| 6:720 | Enable VPN Plugin from Process Manager and try again. |
| 6:721 | Activate VPN |
| 6:722 | Activate User |
| 6:723 | Deactivate User |
| 6:724 | User Laptop Registration |
| 6:725 | Unable to register user. Please try again after sometime. |
| 6:726 | Registering laptop for User... |
| 6:727 | Laptop Registered Successfully. |
| 6:728 | New Activation |
| 6:729 | You have other laptops registered with the credentials you entered.nnTo back up the data on this laptop, select New Activation.nnTo stop backing up data on a registered laptop and start backing up data on this laptop, select a registered laptop from the list.nAfter you click Activate, you have the option to transfer data from the registered laptop to this laptop. |
| 6:730 | Enter your credentials to register your laptop and start backing up your data. |
| 6:731 | Do you want to unregister this laptop? |
| 6:732 | Laptop unregistered successfully for user |
| 6:733 | Error in unregistering Laptop. |
| 6:734 | Server |
| 6:735 | The Server is empty. |
| 6:736 | The path [<String>] is already configured for user [<String>]. Do you want to still use the same path to configure your edge drive? |
| 6:737 | When does it expire? |
| 6:738 | Never |
| 6:739 | Expire the link in |
| 6:740 | days |
| 6:741 | Get Link |
| 6:742 | Public Share Link |
| 6:743 | Who can access? |
| 6:744 | Anyone with this link |
| 6:745 | Only people with a password |
| 6:746 | Add comma separated emails |
| 6:747 | Done |
| 6:748 | Do you want to sign out of your Edge Drive?nThis will remove the virtual drive from your computer. The Files in your Edge Drive will not be removed. |
| 6:749 | Go to Drive |
| 6:750 | You are signed out successfully. To sign back in select Sign in from Cloud Edge Drive tray utility. |
| 6:751 | Sign Out |
| 6:752 | The server,user name or password you entered is incorrect. |
| 6:753 | Public Links |
| 6:754 | Expired. Set new expiry. |
| 6:755 | Error in creating Share. |
| 6:756 | Error in updating Share. |
| 6:757 | Opening File |
| 6:758 | Error in opening file |
| 6:759 | Open |
| 6:760 | Please wait while operation is being canceled... |
| 6:761 | Windows Explorer needs to be restarted to show Cloud Edge Drive.nSelect Restart Explorer to proceed.nnIf you choose to restart later, then please manually restart explorer if Cloud Edge drive doesn't show up. |
| 6:762 | Windows Explorer needs to be restarted to continue.nSelect Restart Explorer to proceed.nnIf Restart later is selected, you will be required to reboot Windows or logoff to complete uninstallation of Cloud Edge Drive. |
| 6:763 | Edge Drive Shared By Me |
| 6:764 | Edge Drive Public Links |
| 6:765 | Edge Drive Shared With Me |
| 6:766 | Check if client and commserve services are running. |
| 6:767 | %s Edge Monitor |
| 6:768 | Share has expired. Please set new expiry. |
| 6:769 | User (<String>) does not have required capabilities to control jobs. |
| 6:770 | Backup and Edge Drive options disabled. Check if services are up. |
| 6:771 | Explorer Plugin is already registered on this machine. Do you want to unregister and register this instance? |
| 6:772 | This computer is not activated. Please activate it from the Edge Monitor. |
| 6:773 | VPN - No network connectivity |
| 6:774 | VPN is successfully activated. |
| 6:775 | Please enter Share Name. |
| 6:776 | Collaborative Shares |
| 6:777 | Edge Drive Collaborative Shares |
| 6:778 | Contact Us |
| 6:779 | Client Display Name |
| 6:780 | Please enter valid Name for the laptop. |
| 6:781 | Unable to register client. Please contact your administrator. |
| 6:782 | Backup Server |
| 6:783 | Backup Server is empty. |
| 6:784 | Enter a name for this laptop |
| 6:785 | An expired share cannot be updated. Please set a new expiry date. |
| 6:786 | Failover Monitor |
| 6:787 | Status |
| 6:788 | Display Status |
| 6:789 | Exit |
| 6:790 | Quit this program |
| 6:791 | About |
| 6:792 | Show about dialog |
| 6:793 | File |
| 6:794 | Help |
| 6:795 | Configuration File does not exists. Run ConfigGUI first. |
| 6:796 | Status |
| 6:797 | Failover Configuration |
| 6:798 | Up |
| 6:799 | Down |
| 6:800 | Nodes |
| 6:801 | Witness Servers |
| 6:802 | Current Active Node |
| 6:803 | Action |
| 6:804 | Failover |
| 6:805 | Test Failover |
| 6:806 | Test Failback |
| 6:807 | Enable Maintainance Mode |
| 6:808 | Disable Maintainance Mode |
| 6:809 | Test Failover in Progress |
| 6:810 | Critical Failover in Progress |
| 6:811 | Yes |
| 6:812 | No |
| 6:813 | Are you sure, you want to start a Critical Failover? |
| 6:814 | Are you sure you want to start a Test Failover? |
| 6:815 | Failover process successfully started. Check CvFailover.log for progress. |
| 6:816 | Configuration |
| 6:817 | Reconnect Timeout Minutes |
| 6:818 | Disable Automatic Failover |
| 6:819 | Max Failed Starts |
| 6:820 | DNS Operations |
| 6:821 | Enable Synchronization of Nodes |
| 6:822 | Time Interval for Sync Operation (in minutes) |
| 6:823 | Test Failover Group Name |
| 6:824 | Pre Start Script |
| 6:825 | Post Start Script |
| 6:826 | Pre Stop Script |
| 6:827 | Post Stop Script |
| 6:828 | Select a file |
| 6:829 | Update Configuration |
| 6:830 | Specify non zero for Reconnect Timeout Minutes |
| 6:831 | Specify non zero Time Interval for Sync Operation |
| 6:832 | Specify Test Failover Group Name |
| 6:833 | Configuration File Updated Successfully |
| 6:834 | CommServer Failover Configuration |
| 6:835 | Configuration wizard cancelled. |
| 6:836 | Node Info |
| 6:837 | Witness Servers |
| 6:838 | Additional Details |
| 6:839 | Node |
| 6:840 | DB Instance Name |
| 6:841 | Subclient |
| 6:842 | Please enter all details to proceed |
| 6:843 | Select unique SQLiDA clients |
| 6:844 | Witness Server |
| 6:845 | Listener Port |
| 6:846 | Data Port |
| 6:847 | Election Port |
| 6:848 | Specify unique ports for Witness Server |
| 6:849 | Specify non zero ports for Witness Server |
| 6:850 | Additional Settings |
| 6:851 | CS Instance on Node 2 |
| 6:852 | Specify CSInstance for Failover |
| 6:853 | Remove errors from current tab before closing this window |
| 6:854 | Physical Hostname |
| 6:855 | SQLiDA Client Name |
| 6:856 | Log Shipping |
| 6:857 | Storage Policy |
| 6:858 | Use a DNS server for failover |
| 6:859 | (If DNS is not selected, failover operations may take longer time to complete.) |
| 6:860 | Select a storage policy for Log Shipping |
| 6:861 | Error reading currentOEMId from registry. Setting default SQL Instance as COMMVAULT |
| 6:862 | Floating CommServer Host Name |
| 6:863 | Type of DNS Configuration |
| 6:864 | Automatically Handle DNS Entries |
| 6:865 | DNS Controller Name/IP |
| 6:866 | Domain Name |
| 6:867 | Use Pre Script to handle DNS |
| 6:868 | Domain Admin Credentials |
| 6:869 | Domain Admin Username |
| 6:870 | Password |
| 6:871 | Confirm Password |
| 6:872 | Password does not match the confirm password |
| 6:873 | Password fields is/are empty |
| 6:874 | Specify Username |
| 6:875 | Select a Script |
| 6:876 | Specify Domain Name |
| 6:877 | Specify DNS Controller IP |
| 6:878 | Specify a Script Path |
| 6:879 | Specify a Script Path |
| 6:880 | Specify FQDN for cluster name |
| 6:881 | Specify Cluster Hostname |
| 6:882 | You can enter 3 or 5 witness servers depending on the availability of hardware |
| 6:883 | (Witness servers allow you to automate the processes of Failover. They monitor both the nodes, synchronize the databases automatically without creating explicit handling of the same, carry out the failover automatically when the current active node goes down and send email alerts. Incase no witness servers are configured you will have to manually do the failover using the command provided or GUI. Also there will be no monitoring of nodes and hence no notifications. You can have 3 or 5 witness servers depending on availability of hardware) |
| 6:884 | Select unique witness servers |
| 6:885 | Specify either both witness server 4 and 5 or none |
| 6:886 | Specify Witness Server |
| 6:887 | Email Alerts |
| 6:888 | Enable Email Alerts |
| 6:889 | (Email notification will be sent when there is a status change or other monitoring issues.) |
| 6:890 | SMTP Server Hostname |
| 6:891 | From |
| 6:892 | To (Comma Separated) |
| 6:893 | CC (Comma Separated) |
| 6:894 | Specify To |
| 6:895 | Specify From |
| 6:896 | Specify SMTP Server Hostname |
| 6:897 | Summary |
| 6:898 | Server |
| 6:899 | Advanced |
| 6:900 | Script Location |
| 6:901 | No storage policy found. Please create a storage policy to proceed configuring CvFailover |
| 6:902 | Minimum 2 SQLiDA Clients are to be installed to run this setup. Configuration will fail |
| 6:903 | We see that CvFailover Package is not installed on minimum 3 machine needed for automatic monitoring.nDo you wish to continue to proceed without automatic monitoring of this cluster? |
| 6:904 | Please install CvFailover package on minimum 3 machines and try again |
| 6:905 | Unable to create subclients : |
| 6:906 | Connection failed to Node |
| 6:907 | Copy file failed: |
| 6:908 | Connection failed to Witness Server |
| 6:909 | Copy file failed to Witness Server |
| 6:910 | Connection timed out with : |
| 6:911 | Unable to connect to CVD of host : |
| 6:912 | Failed to send XML Message : |
| 6:913 | Failed to execute remote process on node |
| 6:914 | Unable to set user permission for NT AUTHORITY\SYSTEM or put Databases in recovery mode on Client : |
| 6:915 | Failed to start cvfailovercommserv.exe on |
| 6:916 | Configuration wizard finished. |
| 6:917 | Can this be reshared? |
| 6:918 | Yes |
| 6:919 | No |
| 6:920 | Reshare |
| 6:921 | Reshares Exist |
| 6:922 | This share has been further reshared by users. Do you want to keep these existing reshares or delete them? |
| 6:923 | Keep |
| 6:924 | Delete |
| 6:925 | Test Failover Group is not configured. Specify Test Failover Group using Failover Configuration tab. |
| 6:926 | Select SQLiDA Client |
| 6:927 | Select Storage Policy |
| 6:928 | Cancel |
| 6:929 | Select unique Physical host names |
| 6:930 | View Only |
| 6:931 | Edit |
| 6:932 | Email View Link? |
| 6:933 | Email Edit Link? |
| 6:934 | Pending Invitations |
| 6:935 | Invitations for share |
| 6:936 | Name |
| 6:937 | Permission |
| 6:938 | Action |
| 6:939 | Allow |
| 6:940 | Deny |
| 6:941 | No More Pending Invites |
| 6:942 | Unable to update pending invite. Please contact administrator. |
| 6:943 | Share Details |
| 6:944 | Owner |
| 6:945 | Expiry |
| 6:946 | Expired |
| 6:947 | Please set password to access Public Link. |
| 6:948 | Shared Laptop User Activation |
| 6:949 | user could not be activated. Please activate manually from Edge Monitor. |
| 6:950 | Select "Activate User" to register your laptop and start backing up your data. |
| 6:951 | &Restore Files |
| 6:952 | Select new Drive Letter |
| 6:953 | Settings |
| 6:954 | Decryption failed, please retry again |
| 6:955 | Encryption failed, please retry again |
| 6:956 | Time Interval for Full Backups (in days) |
| 6:957 | Computer Name |
| 6:958 | Computer Name is empty. |
| 6:959 | User Name or Email Address |
| 6:960 | Select Test-Failover Group |
| 6:961 | Change Commserve name on all clients |
| 6:962 | Sync Now |
| 6:963 | (If Change Commserve name on all clients is selected, failover operations may take longer time to complete) |
| 6:964 | Starting synchronization please check email for alerts. |
| 6:965 | Can't connect to the remote client using host name '<String>' and port '<Number>'. Services down or network error. |
| 6:966 | System state backup failed : [<String>] |
| 6:967 | Add Network |
| 6:968 | A new network was detected [<String>]. Add [<String>] to the allowed backup infrastructure network list? |
| 6:969 | Choose a network to run the laptop backup on. |
| 6:970 | Ignore |
| 6:971 | Attempt to backup failed files off VSS snapshot failed. This could be due to temporary issues like network interruption, but if seen to be occurring frequently, please check if VSS is in a stable state. |
| 6:972 | Registration is in progress by installer. Please check later. |
| 6:973 | Agent [<String>] is not participating in this job |
| 6:974 | All the Data Access Nodes are either down or not reachable |
| 6:975 | Not found any node with the latest job results, restarting the job from scan phase |
| 6:976 | Edge Drive Options |
| 6:977 | Backup task [<Number>] failed on node [<String>]. |
| 6:978 | Backup on node [<String>] failed as the collect file details were not received. |
| 6:979 | Priam API [<String>] failed. Error: [<String>]. |
| 6:980 | Failed to start Priam service. Error: [<String>]. |
| 6:981 | Disable |
| 6:982 | Enable |
| 6:983 | There are files in the Cassandra backup directory that could not be deleted. Delete them manually. Check the file [<String>] to get the list of files to be deleted. |
| 6:984 | Converting job to FULL for the keyspaces [<String>] as the keyspaces are either new or have failed to backup in the last backup job. |
| 6:985 | Converting job to FULL for this node as there is no last backup job status found for this node. |
| 6:986 | No content to back up under this default subclient. Completing the job. |
| 6:987 | Skipping node [<String>]. Reason: [<String>]. |
| 6:988 | Login with Edge Drive User |
| 6:989 | Validating Credentials |
| 6:990 | Selective Sync |
| 6:991 | Please select at least one folder to Sync. |
| 6:992 | Authorization Code for Installs |
| 6:993 | <<<Go Back<<< |
| 6:994 | Or use Auth Code |
| 6:995 | Backup |
| 6:996 | User Laptop Activation |
| 6:997 | Or use authorization code for installs |
| 6:998 | Or use user credentials |
| 6:999 | Incremental backup is not enabled on the Cassandra node. |
| 6:1000 | Refreshed Edge Drive folders successfully. |
| 6:1001 | Location of Edge Drive folder is changed, refreshing folders. |
| 6:1002 | <String> operation was running from a fewer Data Access Nodes than configured. This could result in slower <String>. The following Data Access Nodes were not in use: <String>. Please check to see backup services on this node is up. |
| 6:1003 | <String> operation is running from a fewer Data Access Nodes than configured. This could result in a slower <String>. The following Data Access Nodes are currently not in use: <String>. Please check if backup services are running on these Data Access Nodes. |
| 6:1004 | Cassandra Commit log archiving has been configured. Restart Cassandra service to enable the archiving. |
| 6:1005 | Failed to determine if Cassandra is restarted on node [<String>]. Please check Cassandra system logs. |
| 6:1006 | Activation failed. Please try again later. |
| 6:1007 | Registration failed. Please try again later. |
| 6:1008 | Skipping Node [<String>]. The Hardlink feature is not supported on this node's platform. |
| 6:1009 | User password doesn't follow minimum complexity requirements. Minimum password length has to be 8 characters and it should have at least 1 lowercase letter, 1 uppercase letter, 1 number, 1 special character. |
| 6:1010 | Failed to create Cassandra [<String>] with schema [<String>]. Error: [<String>]. |
| 6:1011 | Enter an authorization code to register your laptop. |
| 6:1012 | Attempting SSO Login... |
| 6:1013 | Laptop is ready for activation. |
| 6:1014 | Laptop registration is successful. nPlease wait while laptop nprepares for activation. |
| 6:1015 | Laptop registration is successful. nLaptop is ready for activation. |
| 6:1016 | Activation is in progress... |
| 6:1017 | Laptop activation is successful. |
| 6:1018 | Initializing software...nThis may take a few minutes... |
| 6:1019 | Preparing software for first time use...nThis may take a few minutes... |
| 6:1020 | Redirecting to SAML IDP... |
| 6:1021 | Registration is in progress... |
| 6:1022 | Sign in to start backing up your data |
| 6:1023 | Registration is successful |
| 6:1024 | Please wait while your software is prepared for activation. |
| 6:1025 | Unable to Process Request |
| 6:1026 | Backup |
| 6:1027 | Cancel |
| 6:1028 | OK |
| 6:1029 | Activate |
| 6:1030 | Sign in to your Edge account |
| 6:1031 | Pause Backup |
| 6:1032 | Start Backup |
| 6:1033 | Drive Letter |
| 6:1034 | Sign in to your Cloud Edge account |
| 6:1035 | Edge drive operation can be performed from a virtual drive. There is no offline access. |
| 6:1036 | Your computer is backed up |
| 6:1037 | DLP |
| 6:1038 | New Pass-Key |
| 6:1039 | Old Pass-Key |
| 6:1040 | Retype New Pass-Key |
| 6:1041 | Personal Data Loss Prevention Pass-Key |
| 6:1042 | After you change your passkey, you will still need to remember your old passkey to unlock any files that are currently locked on your computer. To assign your new passkey to these files after you change your passkey, unlock your files with your old passkey and then lock them again. |
| 6:1043 | Please setup your personal Data Loss Prevention(DLP) Pass-Key below. |
| 6:1044 | I understand that if I lose my pass-key and the backup server is not configured to unlock protected documents automatically, I will not be able to retrieve my files. |
| 6:1045 | Drive |
| 6:1046 | Pause |
| 6:1047 | Edge Monitor |
| 6:1048 | Welcome to Edge Monitor |
| 6:1049 | Explorer plugin is Disabled |
| 6:1050 | Explorer plugin is Enabled |
| 6:1051 | Explorer Plugin |
| 6:1052 | Contact Us |
| 6:1053 | Disable Edge Drive |
| 6:1054 | Open Edge Drive Folder |
| 6:1055 | Visit Edge Drive on Web |
| 6:1056 | Pause Edge Drive |
| 6:1057 | Selective Sync |
| 6:1058 | Disable Explorer Plugin |
| 6:1059 | Enable Explorer Plugin |
| 6:1060 | View Backup Data on Device |
| 6:1061 | Feedback |
| 6:1062 | Help |
| 6:1063 | Preferences |
| 6:1064 | Quit |
| 6:1065 | Restore Files |
| 6:1066 | Start Backup |
| 6:1067 | Sync Paused |
| 6:1068 | VPN Log On |
| 6:1069 | VPN Log Out |
| 6:1070 | VPN No Connection |
| 6:1071 | Last backup |
| 6:1072 | Next backup |
| 6:1073 | Sign in to your Offline Edge account |
| 6:1074 | Edge drive operation can be performed from user configured edge drive folder and includes offline access. |
| 6:1075 | Edge Drive Offline Mode |
| 6:1076 | Edge Drive Online Mode |
| 6:1077 | Password |
| 6:1078 | Path |
| 6:1079 | Please Wait |
| 6:1080 | Select a folder |
| 6:1081 | Selective Sync - Choose Folders to Sync |
| 6:1082 | Name |
| 6:1083 | Sync All Folders |
| 6:1084 | Data Transferred |
| 6:1085 | File Name |
| 6:1086 | File Transferred |
| 6:1087 | Details |
| 6:1088 | Throughput |
| 6:1089 | Time Elapsed |
| 6:1090 | You have other laptops registered with the credentials you entered. |
| 6:1091 | To back up the data on this laptop, select New Activation. |
| 6:1092 | Please select 'New Activation' to configure this laptop as new or choose existing to takeover |
| 6:1093 | After you click Activate, you have the option to transfer data from the registered laptop to this laptop. |
| 6:1094 | Username |
| 6:1095 | VPN |
| 6:1096 | Activate VPN |
| 6:1097 | Log On |
| 6:1098 | 12 Hours |
| 6:1099 | 8 Hours |
| 6:1100 | Delay |
| 6:1101 | Select |
| 6:1102 | Next Backup: <String> |
| 6:1103 | This computer is not activated. Please activate it. |
| 6:1104 | Preparing |
| 6:1105 | Configure |
| 6:1106 | Reset passkey |
| 6:1107 | Personal data loss prevention |
| 6:1108 | Resume |
| 6:1109 | Resume edge drive |
| 6:1110 | Disconnect |
| 6:1111 | Cloud edge drive |
| 6:1112 | Edge drive in cloud mode configured successfully. |
| 6:1113 | Disconnect Edge Drive |
| 6:1114 | Offline edge drive |
| 6:1115 | Edge drive in offline mode configured successfully. |
| 6:1116 | Username or password is empty |
| 6:1117 | Login error |
| 6:1118 | VPN Login |
| 6:1119 | VPN activation error |
| 6:1120 | VPN login successful. |
| 6:1121 | Windows explorer successfully restarted. |
| 6:1122 | Windows explorer |
| 6:1123 | Edge drive is successfully detached. |
| 6:1124 | VPN has successfully been logged out |
| 6:1125 | Backup job cannot be submitted. |
| 6:1126 | Backup job submitted successfully. |
| 6:1127 | Do you want to add it in the allowed backup infrastructure network? |
| 6:1128 | A new network was detected |
| 6:1129 | Cassandra backup job failed. Check the log files for more details. |
| 6:1130 | Error during Cassandra commit log replay. |
| 6:1131 | Failed to replay Cassandra commit logs on at least one node.. |
| 6:1132 | Invalid job. Cassandra Commit Log Backup is not configured at instance level. |
| 6:1133 | Failed to delete the network share after restore. Delete the share with share name [<String>] from the Commvault GUI. |
| 6:1134 | No content to back up under this default subclient. Completing the job. |
| 6:1135 | Failed to read the contents of Cassandra system key file [<String>]. |
| 6:1136 | Failed to delete the mount directory [<String>]. Please delete the directory manually from the client. |
| 6:1137 | Failed to unmount the network share from path [<String>]. Please unmount the share manually from the client. |
| 6:1138 | Failed to reload Cassandra tables during restore. Check the log files for more details. |
| 6:1139 | If Two-Factor Authentication is enabled, then specify the 6-digit PIN after your regular password in the password field. |
| 6:1140 | Failed to mount [<String>] at the directory [<String>] with options [<String>]. |
| 6:1141 | Cassandra Stage Free Restore is supported with Linux and Windows Media Agents only. Select a Linux/Windows Media Agent in the restore options while launching the job. |
| 6:1142 | View Content |
| 6:1143 | Remember me |
| 6:1144 | Incorrect or corrupt [<String>]. |
| 6:1145 | Subclient is not a Cassandra subclient. |
| 6:1146 | Automatic |
| 6:1147 | These volumes are excluded from OneTouch tracking because their disk is on a USB bus [<String>]. |
| 6:1148 | Create/Get project [<String>] for organization [<String>] failed. HTTP error code [<Number>], message [<String>]. |
| 6:1149 | Get project [<String>] details failed. HTTP error code [<Number>], message [<String>]. |
| 6:1150 | Creating repository [<String>] failed. HTTP error code [<Number>], message [<String>]. |
| 6:1151 | Repository [<String>] upload failed. |
| 6:1152 | Get project failed for organization [<String>], HTTP error code [<Number>], message [<String>]. |
| 6:1153 | Get repositories failed for organization [<String>], project [<String>], HTTP error code [<Number>], message [<String>]. |
| 6:1154 | Get repositories failed for organization [<String>], HTTP error code [<Number>], message [<String>]. |
| 6:1155 | Download of Repository [<String>] failed. |
| 6:1156 | VPN is connected |
| 6:1157 | Cassandra operation failed with authentication error. Check that the CQL and JMX authentication is configured correctly. |
| 6:1158 | WMI query timed out while collecting system information for 1Touch. This PowerShell query may be executed to verify the health of WMI service [Get-WmiObject -Query "Select * from Win32_DiskDrive"]. If not found to be in a healthy state, consider recycling WMI service. If that does not help, consider rebooting the client. If the query completes but takes more than 5 minutes, the default timeout, the timeout may be changed using the additional setting https://engweb.commvault.com/additionalsetting/10052 . |
| 6:1159 | Stopping node [<String>], since it does not have package [<String>] installed. |
| 6:1160 | Failed to get repository list. Access token may be expired. |
| 6:1161 | Failed to get repository list. Please verify access token and organization details are correct. |
| 6:1162 | Failed to get repository list. Please verify organization details are correct. |
| 6:1163 | Failed to get repository list. Please check if access token is correct. |
| 6:1164 | Primary node [<String>] does not have [<String>] installed. Please install [<String>] and try again |
| 6:1165 | Failed to change permissions on the staging directory. Command: [<String>] |
| 6:1166 | Job started because maximum backup interval reached. |
| 6:1167 | Job started because file change detected. |
| 6:1168 | Device registered successfully and will be automatically activated upon end user login. |
| 6:1169 | Continue |
| 6:1170 | Critical file [<String>] failed, terminating job. |
| 6:1171 | Activation is in progress. still working, processing may take longer... |
| 6:1172 | Backup infrastructure is currently unavailable. Please try later. |
| 6:1173 | Attempting SSO login, processing is taking longer than usual... |
| 6:1174 | Client Name validation error |
| 6:1175 | Client name cannot have the following characters : |
| 6:1176 | Please enter valid computer name |
| 6:1177 | Some repositories from Project [ <String> ] cannot be backed up because they are either disabled or does not exists: [ <String> ]. |
| 6:1178 | No backups found. [<String>] cannot be performed. |
| 6:1179 | None of the services are selected for Azure DevOps. Please select at-least one service. |
| 6:1180 | Unable to access client host [<String>] using ssh interface. |
| 6:1181 | Some feeds could not be restore to project [<String>] because there are some existing feeds with same name. |
| 6:1182 | Create/Get project [<String>] for organization [<String>] failed. HTTP error code [<Number>], message [<String>]. Make sure access token has required permissions. |
| 6:1183 | No projects are present. Please add some projects. |
| 6:1184 | Failed to get repository list. Please verify access token and organization details are correct and repositories are present. |
| 6:1185 | Some workitems could not be restored to the project [<String>] because they are not supported by project type |
| 6:1186 | Command [<String>] failed with error [<String>] |
| 6:1187 | Node does not have staging path shared |
| 6:1188 | Failed to restore LFS objects because the repository is over its data quota. |
| 6:1189 | API limit reached for <String>, will retry after [<Number>] seconds |
| 6:1190 | Download of Repository [<String>] failed, error=[<String>] |
| 6:1191 | Upload of Repository [<String>] failed, error=[<String>] |
| 6:1192 | Create table [<String>] failed with error [<String>] |
| 6:1193 | Export Table [<String>] failed with error [<String>] |
| 6:1194 | Get Column Families for table [<String>] failed with error [<String>] |
| 6:1195 | Import Table [<String>] failed with error [<String>] |
| 6:1196 | All the tables configured for backup does not exist / are part of other other subclients |
| 6:1197 | Skipping [<String>] table restore as the table is already present and overwrite and merge is turned off |
| 6:1198 | Stopping node [<String>]. [<String>] is not installed or the application services are not running on the machine. |
| 6:1199 | Failed to fetch access key for account [<String>] |
| 6:1200 | Not enough RUs to process the request |
| 6:1201 | Get project failed for organization [<String>] with error [<String>]. |
| 6:1202 | Get project details failed for [<String>] with error [<String>]. |
| 6:1203 | Get repositories failed for organization [<String>], project [<String>] with error [<String>]. |
| 6:1204 | Create project [<String>] for organization [<String>] failed with error [<String>]. |
| 6:1205 | Create project [<String>] for organization [<String>] failed with error [<String>]. Make sure access token has required permissions. |
| 6:1206 | Get repositories failed for organization [<String>] with error [<String>]. |
| 6:1207 | Creating repository [<String>] failed with error [<String>]. |
| 6:1208 | [%1s] is not installed or not configured in any of the Access Nodes. Please take action and try again. |
| 6:1209 | [%1s] is not installed or not configured in any of the Access Nodes. Please take action and try again. |
| 6:1210 | Failed to get organization details, access token may be expired. |
| 6:1211 | Failed to get user or organization details, please check if access token is correct. |
| 6:1212 | Failed to get user or group details, please check if access token is correct. |
| 6:1213 | Backup for one or more services failed. Please check the logs for more details |
| 6:1214 | Backup for one or more services failed. Please check the logs for more details and verify if PAT is correct and have required permissions |
| 6:1215 | Nothing to restore, no repositories found |
| 6:1216 | Error [<String>] while accessing organization or account [<String>] |
| 6:1217 | No repositories found in organization [<String>] |
| 6:1218 | None of the configured <String> exists. |
| 6:1219 | Some of the configured projects or repos does not exist |
| 6:1220 | Truncate table failed for <String> and please check cvPriam.log for more details |
| 6:1221 | Truncate table operation skipped for all the tables |
| 6:1222 | No previous successful backups found, converting the job type from incremental to full. |
| 6:1223 | Cassandra [<String>] path [<String>] does not exist. |
| 6:1224 | Detected a configuration change. Old [<String>], New [<String>]. Disk will be backed up in FULL. |
| 6:1225 | Detected a change in Disk Size. Disk [<String>] size <String> from [<String>] to [<String>]. Disk will be backed up in FULL. |
| 6:1226 | Detected a new disk [<String>] under [<String>]. Disk will be backed up in FULL. |
| 6:1227 | RUs insufficient for table [<String>] |
| 6:1228 | Azure Subscription is invalid |
| 6:1229 | Table [<String>] is skipped as it is not present in cloud |
| 6:1230 | [<String>] |
| 6:1231 | Keyspace [<String>] is skipped as it is not present in cloud |
| 6:1232 | Create Entity failed [<String>] |
| 6:1233 | Delete Entity failed [<String>] |
| 6:1234 | Fetch Subclient Content failed [<String>] |
| 6:1235 | List Entities failed [<String>] |
| 6:1236 | Some entities failed/skipped to restore. Please check the events/logs for more information. |
| 6:1237 | Skipping [<String>] restore as the entity is already present and overwrite and merge is turned off |
| 6:1238 | Skipping [<String>] restore as it is a system entity |
| 6:1239 | Initialization Failed [<String>] |
| 6:1240 | Failed to create group [<String>] with error [<String>] |
| 6:1241 | Abort Task Failed [<String>] |
| 6:1242 | There are no tables under the Cosmos DB account to be backed up |
| 6:1243 | Collect file [<String>] not found on the node and was unable to copy from the node [<String>] |
File System Backup iDataAgent
| Code | Description |
| 7:1 | Exiting because event initialization failed. |
| 7:2 | Error notifying Job Manager of successful completion. |
| 7:3 | Error notifying Job Manager of failure. |
| 7:4 | Started. |
| 7:5 | Exiting... |
| 7:6 | Failed to record actual create time in index files. |
| 7:7 | Failed to change Index Cache directory name to new create time. |
| 7:8 | Unable to open file [<String>], error number [<Number>/<String>]. |
| 7:9 | Error notifying Job Manager of backup reference time. |
| 7:10 | Error updating Job Manager for backup reference time. |
| 7:11 | Usage : archiveIndex -t <Backup Type (1=full, 2=incr)> -d <commCellId> -a <appId> -p <path to collect file> -j <jobId>. |
| 7:12 | Updating backup reference time with Job Manager. |
| 7:13 | dsBackup: Failed to get CommServe name. |
| 7:14 | dsBackup: Failure during backup done. |
| 7:15 | dsBackup: Archive filename is NULL. |
| 7:16 | dsBackup: Error in data mover create. |
| 7:17 | dsBackup: Error during index initialization. |
| 7:18 | dsBackup: Failed to initialize a file ID with indexing. |
| 7:19 | dsBackup: Failed to close archive file. |
| 7:20 | dsBackup: Error archiving data in data mover write. |
| 7:21 | dsBackup: error during data mover initialization; Media Mount failure. |
| 7:22 | Error obtaining CommServe name, error: [<String>]. |
| 7:23 | Could not initialize job object. |
| 7:24 | Usage: startPrePostCmd -a <appId> -j <jobID> -p <prePostId>. |
| 7:25 | Exception error received from Application Manager. |
| 7:26 | Error [<HexNumber>] returned while attempting to execute remote command [<String>]. |
| 7:27 | Exiting due to failure. |
| 7:28 | Could not initialize job control object. |
| 7:29 | New tablespace [<String>] has been added to subclient [<String>] for Oracle instance [<String>]. Be sure to run full backup for subclient [<String>]. |
| 7:30 | New datafile [<String>] in tablespace [<String>] has been added to subclient [<String>] for Oracle instance [<String>]. Be sure to run full backup for subclient [<String>]. |
| 7:31 | The amount of available memory was insufficient; attempted to allocate [<Number>] bytes. [<String>] |
| 7:32 | Failed to mount the media for backup. Please refer to previous events from this job for detailed information about the failure. |
| 7:33 | Failed to create the archive file. |
| 7:34 | Failed to close the archive file. |
| 7:35 | Failed to write the archive file to the media. |
| 7:36 | Unable to initialize indexing, [<String>] |
| 7:37 | Unable to open the index for the archive, [<String>] |
| 7:38 | Unable to close the index for the archive, [<String>] |
| 7:39 | Unable to write an index entry for the archive, [<String>] |
| 7:40 | MediaAgent [<String>] failed to connect back to CommClient [<String>] |
| 7:41 | Datapipe error [<Number>] encountered, [<String>] |
| 7:42 | Unknown buffer type [<Number>] received. |
| 7:43 | Unable to read MediaAgent platform information, [<String>] |
| 7:44 | Failed to connect to CommServe, [<String>] |
| 7:45 | Positioning to file marker to write data. |
| 7:46 | Positioning to file marker to read data. |
| 7:47 | Failed to clean Fastrax [<String>], Drive ID [<Number>]. |
| 7:48 | Drive [<String>] in the library [<String>] is dirty. Please clean the drive. |
| 7:49 | New dbspace [<String>] has been added to subclient [<String>] for the Informix instance [<String>]. Be sure to run a full backup for subclient [<String>]. |
| 7:50 | New datafile [<String>] in dbspace [<String>] has been added to subclient [<String>] for Informix instance [<String>]. Be sure to run full backup for subclient [<String>]. |
| 7:51 | Exiting due to [<String>] failure. [<String>] |
| 7:52 | OPERATION FAILED: Create new folder. |
| 7:53 | OPERATION SUCCEEDED: Create new folder. |
| 7:54 | OPERATION FAILED: Unable to determine size of file. |
| 7:55 | OPERATION FAILED: Cannot view contents of directory. |
| 7:56 | OPERATION FAILED: Unable to open file. |
| 7:57 | OPERATION FAILED: Error reading file. |
| 7:58 | Archive Index failed on MediaAgent - unable to modify index after backup. |
| 7:59 | Failing due to critical error: The registry backup failed. |
| 7:60 | Failing due to critical error: Unable to back up the Active Directory. |
| 7:61 | Failing due to critical error: ASR state files are required for ASR restore. |
| 7:62 | Failing due to every component having failed to be backed up. |
| 7:63 | Unable to determine if user impersonation is supported. |
| 7:64 | Unable to determine the OS type of client. |
| 7:65 | Unable to determine application ID. |
| 7:66 | Unable to retrieve CommCell ID for subclient. |
| 7:67 | Unable to retrieve pre-scan command. |
| 7:68 | Unable to retrieve post-scan command. |
| 7:69 | Unable to retrieve prebackup-scan command. |
| 7:70 | Unable to retrieve prebackup-scan command. |
| 7:71 | Unable to retrieve proxy host name for subclient. |
| 7:72 | <Message> |
| 7:73 | <Message> |
| 7:74 | <Message> |
| 7:75 | <Message> |
| 7:76 | <Message> |
| 7:77 | <Message> |
| 7:78 | <Message> |
| 7:79 | Problem processing arguments from Job Manager. |
| 7:80 | Machine ID not found in subclient configuration. |
| 7:81 | Arguments not found in subclient configuration. |
| 7:82 | Unable to get backup machine hostname and ID. |
| 7:83 | User impersonation selected, but no username and password specified. |
| 7:84 | User selection still set to none. |
| 7:85 | Unable to determine if user impersonation is supported. |
| 7:86 | We have encountered an issue with your [Pre/Post] [Scan/Backup] script. The script [<String>] returned a nonzero code [<Number>] which indicates it did not complete properly. Please ensure the utilized account has sufficient permission and review the script with the script author. |
| 7:87 | Unable to run [<String>] on the client. Possible causes: Services not up, network problems, permissions. |
| 7:88 | The client is out of available memory. |
| 7:89 | An attempt to read data from the client resulted in a fatal error. |
| 7:90 | A failure occurred when creating the archive on the MediaAgent. |
| 7:91 | A failure occurred when the client attempted to create the filter file. |
| 7:92 | A failure occurred when the client attempted to read the filter file. |
| 7:93 | The client was unable to launch the create index process on the MediaAgent. Please check the following: network connectivity between the Client and MediaAgent, MediaAgent's host name can be resolved by the Client, and services are running on the MediaAgent. |
| 7:94 | The create index process on the MediaAgent did not connect back to the client. |
| 7:95 | The create index process on the MediaAgent reported a fatal error during startup. |
| 7:96 | The client was unable to send the dirchange file to the CreateIndex process on the MediaAgent. |
| 7:97 | The create index process on the MediaAgent reported an error during index processing. |
| 7:98 | Index update failed. Please make sure that the index cache directory is accessible, and the indexing MediaAgent services are running. |
| 7:99 | Recall limit has been reached, denying request. |
| 7:100 | Recall privilege is denied for this request. |
| 7:101 | Not migrating volume [<String>]: it has more than [<Number>%] of free space. |
| 7:102 | Unable to run [<String>] on the client. |
| 7:103 | Failed to allocate memory, not snapping volume for backup. |
| 7:104 | Snap on path [<String>] not supported; will use regular path for backup. |
| 7:105 | Failed to find path [<String>] for snapping; will use regular path for backup. |
| 7:106 | Failed to open mount path file; will use regular path for backup. |
| 7:107 | Failed to snap [<String>] due to internal error, will use regular path for backup. |
| 7:108 | Failed to mount snap for volume [<String>]; will use regular path for backup. |
| 7:109 | Failed to unsnap [<String>] due to internal error. |
| 7:110 | Performing regular scan. |
| 7:111 | Unable to run [<String>] on the client. <String> |
| 7:112 | Failed to back up critical system state component; Check client logs for details. |
| 7:113 | Failed to back up critical Office Communication Server component; Check client logs for details. |
| 7:114 | Volume [<String>] not monitored by Data Classification |
| 7:115 | Recall abort due to exported media. AFile-Data = [<String>] |
| 7:116 | Data Archiver Popup |
| 7:117 | Recall File |
| 7:118 | Enable Recall Popup Message |
| 7:119 | NAS Popup Message |
| 7:120 | Maximum Popup Message Display Time |
| 7:121 | Local Archiver MAG Popup Message |
| 7:122 | Local Archiver Tape Popup Message |
| 7:123 | Disable File Recall Message |
| 7:124 | Test NAS Pop-up |
| 7:125 | Test MAG Pop-up |
| 7:126 | Test Tape Pop-up |
| 7:127 | Recall for file [<String>] aborted due to exported media. |
| 7:128 | Delete file [<String>] from the archive? |
| 7:129 | Test Disable |
| 7:130 | Startup |
| 7:131 | Start File Archiver Notification with Windows |
| 7:132 | Failed to back up system state component. Check client logs for details. |
| 7:133 | Offline file could not be recalled. |
| 7:134 | Archive has been erased. The file cannot be restored. |
| 7:135 | There are problems with recalling the file. The file will remain offline at this time. |
| 7:136 | Recall threshold limit reached. |
| 7:137 | Not enough space on volume. User defined minimum space reached. |
| 7:138 | Not enough space on volume. |
| 7:139 | Volume is going offline. |
| 7:140 | File Archiver service is shutting down. |
| 7:141 | Received invalid packet from driver. Invalid magic number. |
| 7:142 | Received invalid packet from driver. File path missing. |
| 7:143 | File path is too long for recall. |
| 7:144 | File path is invalid. |
| 7:145 | Could not read stub file data. |
| 7:146 | Stub file is corrupt. Missing key structure. |
| 7:147 | Stub file is corrupt. Stub file data has been modified. |
| 7:148 | Stub file is corrupt. File name missing in stub data. |
| 7:149 | Could not get file attribute. Check privilege and Antivirus settings. |
| 7:150 | Could not get file time. Check privilege and Antivirus settings. |
| 7:151 | Could not copy stub file. |
| 7:152 | Could not copy stub to the cache (restub folder). Check privilege and Antivirus settings. |
| 7:153 | Stub file has been encrypted. The stub file needs to be decrypted before file can be recalled. Decrypt the file and try again. |
| 7:154 | The media containing the archive has been removed. Tape is exported. |
| 7:155 | Recall was canceled. |
| 7:156 | Root volume is going offline. Possible volume fail-over in progress. |
| 7:157 | OK |
| 7:158 | Recalling File |
| 7:159 | Failed to initialize SnapFSContentMapper instance. |
| 7:160 | Failed to stat file '<String>'(file <String> in <String>) due to error: <String> |
| 7:161 | Unable access failure file '<String>'. <String> |
| 7:162 | Method '<String>' not implemented. |
| 7:163 | OnDemand collect file is not open. |
| 7:164 | Stream or backup item argument are not set. |
| 7:165 | Backup item does not provide implementation. |
| 7:166 | Header of type <Number> is not registered. |
| 7:167 | Unable to delete '<String>'. <String> |
| 7:168 | Failed to create file '<String>': <String> |
| 7:169 | Failed to write to '<String>': <String> |
| 7:170 | Unable to allocate object <String> |
| 7:171 | Unknown scanner type <Number> |
| 7:172 | Failed to prepare subclient content. |
| 7:173 | File list obtained from the CommServe. |
| 7:174 | Unexpected object type. Expected <String>. |
| 7:175 | Resource fork for '<String>' changed during backup. |
| 7:176 | Unable to open configuration file '<String>'. |
| 7:177 | Failed to get AFile list for job <Number> |
| 7:178 | File list is empty for job <Number> |
| 7:179 | MediaAgent hostname is empty for job <Number> |
| 7:180 | Failed to get last AFile in cycle for AFile <Number> |
| 7:181 | Failed to find backup time for job <Number> |
| 7:182 | Invalid argument for GetIndexFiles. |
| 7:183 | Unable receive collect files from MediaAgent. |
| 7:184 | Links Table does not exists or may be corrupt. |
| 7:185 | No collect file was found. |
| 7:186 | The snapshot of the Dedupe database could not be created, the backup will be performed from the live volume. |
| 7:187 | The snapshot of the Dedupe database from the previous attempt of this job is not available and a new one could not be created, as the job cannot continue under this condition, it will fail. |
| 7:188 | Errors detected while quiescing the sub-stores for storage policy [<String>], storage policy copy [<String>]. |
| 7:189 | History |
| 7:190 | Recall Status |
| 7:191 | User Name |
| 7:192 | Recall Time |
| 7:193 | File Name |
| 7:194 | Size |
| 7:195 | Keep history for days: |
| 7:196 | Cancel |
| 7:197 | Apply |
| 7:198 | The snapshot failed to be created and the user has selected the option to fail the job if the snapshot cannot be created. |
| 7:199 | Backup job will go to pending as it is not possible to check the snapshot's creation time in the DDB MediaAgent. When the job restarts, it will create a new snapshot and continue automatically. |
| 7:200 | Backup job will go to pending as it is not possible to check the time that the operating system booted up in the DDB MediaAgent. When the job restarts, it will create a new snapshot and continue automatically. |
| 7:201 | Backup job will go to pending as the DDB MediaAgent was rebooted after the snapshot was created. When the job restarts, it will create a new snapshot and continue automatically. |
| 7:202 | Snap initialization failed with an error:[<String>] |
| 7:203 | Snap operation failed with an error:[<String>] |
| 7:204 | Failure in indexing operation:[<String>] |
| 7:205 | <String> |
| 7:206 | Backup operation initialization failed with an error:[<String>] |
| 7:207 | Invalid Folder Name |
| 7:208 | Cannot find the path specified |
| 7:209 | Folder Already Exists |
| 7:210 | Access is denied |
| 7:211 | Detected file activity anomaly of type [<String>] in last 5 minutes. Number of files Modified [<Number>] Deleted [<Number>] Renamed [<Number>] and Created [<Number>]. Please verify the data on the machine. |
| 7:212 | An irregularity in the amount of file activity was detected on the machine [<String>]. Please alert your administrator. |
| 7:213 | Too many backup failures detected. |
| 7:214 | Failed to find one or more subclient content, marking the job completed with error. |
| 7:215 | Failed file [<String>] matched user defined error control rule [<String>]. Marking Job as Failed |
| 7:216 | Failed file [<String>] matched user defined error control rule [<String>]. Marking phase as completed with errors. |
| 7:217 | Failed file [<String>] matched user defined error control rule [<String>]. Marking phase as success. |
| 7:218 | Incorrect restart information for collect file number [<String>], restarting this collect file from beginning. |
| 7:219 | Backup of some files failed, this job type is not allowed to contiue with failed files, failing the job. |
| 7:220 | DDB Backup failed to create collect files. |
| 7:221 | Failed to set backup time for DDB backups. |
| 7:222 | Snap creation failed on volumes holding DDB paths. |
| 7:223 | Snap not supported on the volumes hosting DDB |
| 7:224 | Some huge extended attributes couldn't be backed up |
| 7:225 | Failed to update indexing information for iPhoto items |
| 7:226 | Failed to accept connection request from client host [<String>] |
| 7:227 | Error in communicating with client host [<String>] |
| 7:228 | Failed to initialize connection to client host [<String>] |
| 7:229 | Failed to start backup process on client host [<String>] |
| 7:230 | Error in receiving data from client |
| 7:231 | Operation timed out while waiting for data from client |
| 7:232 | Failed to read file in DIRECT_IO mode, please try tuning buffer alignment size |
| 7:233 | Failed to enumerate SIDB stores. Failing the job. |
| 7:234 | Failed to quiesce some SIDB stores, backup will continue with rest of the SIDB stores |
| 7:235 | Failed to quiesce all SIDB engines. Failing the job. |
| 7:236 | Index transmitter has aborted. Reason : [<String>] |
| 7:237 | Failed to update reference time with Job Manager |
| 7:238 | Failed to initialize index transmitter. Error : [<String>] |
| 7:239 | Failed to send some items to Index Engine, marking phase as completed with errors. |
| 7:240 | Resetting the file extent backup configuration to FileSize = [<String> MB] , ExtentSize = [<String> MB] , supplied was was FileSize=[<String> MB], ExtentSize=[<String> MB]. |
| 7:241 | Resetting the file extent backup configuration to User supplied FileSize = [<String> MB] , ExtentSize = [<String> MB]. |
| 7:242 | OnePass stubbing will be skipped in this job, Index maintenance may be in progress |
| 7:243 | Total [<String>] files qualify for archiving, [<String>] will be archived based on your Delay stub settings, [<String>] skipped because they are never backed up, they are being backed up as data |
| 7:244 | Failed to expand [<String>] to a valid share volume on file share server [<String>] |
| 7:245 | Failed to find any valid share volume on file share server [<String>] |
| 7:246 | Failed to mount file share volume [<String>] |
| 7:247 | Failed to backup MongoDB oplog dumps. Submit FULL SNAP backup immediately to resync the oplog dumps |
| 7:248 | HBase snap UnQuiesce script [<String>] failed. UnQuiesce script will be run again in next attempt or job. |
| 7:249 | HBase snap UnQuiesce script [<String>] failed. Manually run the UnQuiesce script and resubmit the job |
| 7:250 | Failed to execute post-clone command [<String>]. Error [^2%S]. |
| 7:251 | Post-clone command [<String>] returned failure error code [<Number>]. |
| 7:252 | Instant Clone job failed, no snaps are available to clone. |
| 7:253 | Failed to start the MongoDB servers on the restored clients. To start the MongoDB servers, refer the manual recovery procedure provided in the documentation. Resume the job to restore the required Oplog dumps for point in time. |
| 7:254 | Snapshot created for repset [<String>] on host [<String>], port [<String>], data path [<String>] |
| 7:255 | Failed to replay the oplog dump [<String>] on mongod at port [<String>] for replica set [<String>]. mongorestore return code is [<String>], command output [<String>] |
| 7:256 | Restore validation failed. Found MongoDB process running on restore client [<String>] at port [<String>]. Confirm the restore clients and resubmit the restore operation with Stop MongoDB services option. |
| 7:257 | Failed to retrieve Oplog last entry timestamp on secondary node |
| 7:258 | Failed to unquiesce the databases on secondary node. |
| 7:259 | Failed to get target client from restore request for replica set [<String>]. Please make sure that client is mapped with destination mongodb host before submitting restore. |
| 7:260 | Data files have been successfully restored. But, all the mongodb servers could not be started with the restored data. |
| 7:261 | Existing clones found on destination, and overwrite is OFF. Please re-run job with overwrite existing clone option. |
| 7:262 | An error occurred while restoring [1%s] to [2%s]. A [3%s] with the same name [4%s] already exists. This item will not be restored. To restore this item, submit the job with "Unconditionally overwrite if it already exists" checkbox selected |
| 7:263 | An error occurred while restoring [<String>] to [<String>]. A [<String>] with the same name [<String>] already exists. This item will not be restored. To restore this item, submit the job with "Unconditionally overwrite if it already exists" checkbox selected |
| 7:264 | Snap creation failed on volumes holding DDB paths [<String>]. |
| 7:265 | Snap operations are not supported on the volumes hosting DDB [<String>]. |
| 7:266 | The destination cluster could not be discovered. Please make sure that the destination cluster is running before submitting the restore job. |
| 7:267 | Failed to make a copy of mongodb config file for server at [<String>]. This config file will not be backed up |
| 7:268 | Failed to parse mongodb config file [<String>]. Recovery will be attempted using a generated config file with default values |
| 7:269 | A suspicious file [<String>] is detected on the machine [<String>]. Please alert your administrator. |
| 7:270 | Completed recovery of collection [<String>] |
| 7:271 | Completed recovery of database [<String>] |
| 7:272 | Failed to dump source collection [<String>] from staging instance |
| 7:273 | Failed to dump source database [<String>] from staging instance |
| 7:274 | Failed to identify the destination MongoDB server for replica set [<String>]. Please make sure that the primary for this replica set is running before submitting the job |
| 7:275 | Failed to unmount file share volume [<String>] |
| 7:276 | Failed to start [<String>] on node [<String>] |
| 7:277 | Error occurred while listing the backup nodes. Error [<String>] |
| 7:278 | Unable to find suitable secondary node for replica set [<String>] to perform snapshot of the data mount path. By default, backup uses secondary node that has least MongoDB priority in the replica set. Please check CV documentation for additional settings to select secondary node on other criteria like slaveDelay, least lag, specific node etc. |
| 7:279 | Collection [<String>] will not be sharded. Sharding could not be enabled on the parent database [<String>] as unconditionally overwrite checkbox was not selected while submitting restore |
| 7:280 | Detected oplog rollover on [<String>]. Submit FULL SNAP backup immediately to resync the oplog dumps. To avoid issues with oplog rollover, it is recommended to increase the size of MongoDb Oplog to a higher value or increase the frequency of oplog dumps taken in commvault's backup schedule |
| 7:281 | The destination cluster [<String>] is not discoverable. Resubmit the restore job with option to stop MongoDB services and remove existing data in the destination cluster and the selected restore clients. |
| 7:282 | The destination cluster [<String>] is not discoverable. Restore job is proceeding to stop MongoDB services and remove the existing data.in the destination cluster and the selected restore clients. |
| 7:283 | Unable to stop MongoDB services and remove the existing data on destination cluster [<String>]. Check MongoDB.log on client for further details. Verify the restore options and resubmit the restore job. |
| 7:284 | cvlaunchd process on the system does not have full disk access. |
| 7:285 | Early Stub backup phase failed. |
| 7:286 | Failed to backup files that qualified as extents. |
| 7:287 | Failed to backup some files. |
| 7:288 | Failed to create VSS Snap for file extent eligible volumes |
| 7:289 | Failed to update the subclient property [Files Backed up in extent]. Please check the connectivity between agent and commserver. |
| 7:290 | None of the files got backed up. Please review the backup logs and failed items for details. |
| 7:291 | OnePass stubbing will be skipped in this job because no suitable backups found, may be due to delayed stubbing. |
| 7:292 | Error [<String>] occurred during stubbing phase. Stubbing skipped. |
| 7:293 | <html>Detected file activity anomaly of type [<String>] in last 5 minutes. Number of files Modified [<Number>] Deleted [<Number>] Renamed [<Number>] and Created [<Number>]. Please click <a href="<String>"> here</a> for more details.</html> |
| 7:294 | Ignoring preserve access time option. Reason : [<String>] |
| 7:295 | Cassandra commit log backup/restore is not supported with Scylla. |
| 7:296 | Ignoring preserve access time option for OnePass subclient |
| 7:297 | [<String>] Files skipped stubbing due to delayed stubbing (DR/Redundancy) |
| 7:298 | [<String>] Files skipped stubbing because they were not backed up |
| 7:299 | Delete file without backup job is not allowed for [<String>] |
| 7:300 | Snap backup is not supported in storage layout with symbolic links to index and collection directories present under each database directory. |
| 7:301 | Failed to process spanner state files. Error : <String> |
| 7:302 | Failed to select optimal dataflow job location. Error : <String> |
| 7:303 | Error occurred during spanner job. Error : <String> |
| 7:304 | Unable to proceed with DDB backup. Failing the job. |
| 7:305 | Failed to initialize DDB backup. |
| 7:306 | Failed to create list of volumes/SIDB stores for backup. |
| 7:307 | Failed to get SIDB store information from CommServer. |
| 7:308 | Failed to invalidate archive files of previous runs of this job. |
| 7:309 | Got empty list of volumes/SIDB stores for backup. |
| 7:310 | Failed to Quiesce SIDB stores for creating a snap. |
| 7:311 | Failed to unquiesce SIDB stores after creating a snap. |
| 7:312 | Solr transmitter has aborted. Please verify that the Index Engine is running. |
| 7:313 | Failed to send the DDB Engine id to indexing metadata. |
| 7:314 | The job has failed because the VSS snapshot could not be created. |
| 7:315 | Failed to initialize backup job. Failed to scan and create collect files. |
| 7:316 | Failed to retrieve snapshot path. Check for any snap creation failures. |
| 7:317 | One of the backup state files, [<String>], cannot be deleted. Failing the job in this case as the job cannot be resumed. |
| 7:318 | Skipping node [<String>]. Reason: Could not map Cassandra node to Commvault node. |
| 7:319 | Skipping node [<String>]. Reason: Node is not part of the cluster. |
| 7:320 | Skipping node [<String>]. Reason: Cassandra services are down. |
| 7:321 | Failed to stop MongoDB OpsManager service on [<String>] |
| 7:322 | Skipping share [<String>] from archiving since we have two or more filesystems mounted under [<String>] |
| 7:323 | All the tables under this subscription are already being backed as part of other table groups. |
| 7:324 | Table name [<String>] has invalid characters. Please check the name. |
| 7:325 | Destination table [<String>] already exists and is not being overwritten. |
| 7:326 | Table [<String>], part of the table group content is not found. |
| 7:327 | The provided OS User Name [<String>] is not valid or the user does not exist. Starting MongoDB server as root user. |
| 7:328 | Failed to backup and track items locked by other processes. |
| 7:329 | Snapshot created for MongoDB Atlas cluster [<String>]. |
| 7:330 | Failed to backup even a single repository |
| 7:331 | High amount of data to be processed in FailedFilesRetry phase is observed with bulk of the data coming from big files that can be more efficiently processed by enabling optimized backups via extent level. Review documentation to proceed. |
| 7:332 | High contribution of backup data from locked files is observed. Consider enabling VSS for all files for this subclient for more efficient backups, while monitoring to ensure that the VSS snapshot does not unduly affect the performance of the computer. |
| 7:333 | <html>Detected file activity anomaly of type [<String>] on the machine [<String>] in last 5 minutes. Number of files Modified [<Number>] Deleted [<Number>] Renamed [<Number>] and Created [<Number>]. Please click <a href="<String>"> here</a> for more details.</html> |
| 7:334 | Failed to discover the MongoDB cluster from host [<String>] port [<String>]. Error [<String>]. |
| 7:335 | Index query for archiving candidates failed. Error [1^%s]. |
| 7:336 | Index query for archiving candidates completed partially with errors. Error [<String>]. |
| 7:337 | One or more volumes are not supported for VSS Shadow Copies. n Possible causes: n - Unsupported volume or file system type (eg. FAT, FAT32). n - Unsupported volume size (over 64TB). n - Remote or network volume not accessible. n - Other, check the logs for more details. |
| 7:338 | MongoDB instant clone job started. |
| 7:339 | MongoDB staging server started for replica set [<String>] on client [<String>], port [<Number>] with data Path [<String>]. |
| 7:340 | Mongos staging server started on client [<String>], port [<Number>]. |
| 7:341 | Failed to write to disk hosting job results. Possible reasons include nonexistent path/file, hardware problems or full disk. |
| 7:342 | Could not create network share. See logs for more details. |
| 7:343 | Failed to mount 3dfs share [<String>]. Received the following error [<String>]. |
| 7:344 | Could not authenticate user [<String>] for share [<String>]. See logs for more details. |
| 7:345 | Data and log files have been successfully restored. mongod servers have been started successfully. But, failed to start mongos routing service. User must start it manually on the node. |
| 7:346 | Failed to write to restart map file [<String>]. Possible reasons include insufficient free space on the volume or inaccessible volume or disk. |
| 7:347 | Filesystem Archiving is not supported for non-root user installs. |
| 7:348 | Failed to mount, Automatic Share Mount is not supported for non-root installs. |
| 7:349 | <html>Large number of potential renames detected on client [<String>] for extension(s) [<String>] . Total potential renames: [<Number>]. Please click <a href="<String>"> here</a> for more details.</html> |
| 7:350 | Block Level Backups are not supported for non-root user client installs. |
| 7:351 | The system cannot access the job results directory [<String>]. Please Ensure that the directory resides on a shared cluster drive. Also ensure that Antivirus exclusions are in place for Commvault files and folders and check that the items are not in use by another program. Please check logs for more details. |
| 7:352 | Failed to terminate the old instance of the current process. Check the process with id [<Number>] and kill it manually. |
| 7:353 | Killing FileScan process due to high memory consumption. The job will be reattempted upon resume. |
| 7:354 | The system is running low on memory which can impact the backup jobs. Please check. |
| 7:355 | The extended attribute system.cifs_nstd required to backup CIFS DACL and owner information is currently unavailable. |
| 7:356 | The extended attribute system.cifs_acl required to backup CIFS DACL information is currently unavailable. |
| 7:357 | The extended attribute system.cifs_nstd_full required to backup CIFS SACL information is currently unavailable. |
File System Restore iDataAgent
| 24:1 | A timeout [<Number>] seconds expired while waiting for a message from the client [<String>]. |
| 24:2 | A memory allocation error has occurred. |
| 24:3 | The client [<String>] reported an initialization error. |
| 24:4 | An error [<Number>] occurred while spawning a thread. |
| 24:5 | A restore protocol error has occurred while executing a restore for the client [<String>]. |
| 24:6 | Failed to read from the media during restore. |
| 24:7 | Unable to obtain Base platform information. |
| 24:8 | Unable to obtain event log directory. |
| 24:9 | Critical error notification received from client [<String>]. |
| 24:10 | Unable to obtain the MediaAgent platform information. |
| 24:11 | Unable to obtain the name of the CommServe. |
| 24:12 | Unable to exchange handshake with pipeline tail. |
| 24:13 | Pipeline head started. |
| 24:14 | Pipeline head stopped. |
| 24:15 | Could not allocate pipeline buffer. |
| 24:16 | Data Mover open error. |
| 24:17 | Error [<Number>] while creating semaphore. |
| 24:18 | Shutting down to complete file system restore. |
| 24:19 | Invalid destination path [<String>] |
| 24:20 | <Number> file(s) were not restored. |
| 24:21 | Will impersonate <String> on <String> |
| 24:22 | Exceeded maximum number of errors. |
| 24:23 | Could not find MediaAgent with index for subclient <String> |
| 24:24 | Media read failed since the device is not ready. |
| 24:25 | Data error. CRC failed. Please see if the drive needs cleaning. |
| 24:26 | Media read could not be performed because of an I/O device error. |
| 24:27 | The I/O time-out period has expired. |
| 24:28 | <Number> object(s) were not restored. |
| 24:29 | Program Operating System mismatch [<String>]. |
| 24:30 | Reboot of client [<String>] is required. |
| 24:31 | The amount of available memory was insufficient; attempted to allocate [<Number>] bytes. [<String>] |
| 24:32 | MediaAgent [<String>] failed to connect back to CommServe client [<String>]. |
| 24:33 | Failed to start a new thread, [<Number>], [<String>] |
| 24:34 | Failed to mount the media. |
| 24:35 | Failed to open the archive file. |
| 24:36 | Failed to close the archive file. |
| 24:37 | Failed to read from the media. |
| 24:38 | Failed to seek to an archive file. |
| 24:39 | Failed to mount the media. |
| 24:40 | Too many read errors encountered. Restore failed. |
| 24:41 | Failed to read [<Number>] files during restore. |
| 24:42 | Cannot start restore program on host [<String>] - a network error occurred or the product's services are not running. |
| 24:43 | Positioning to file marker to write data. |
| 24:44 | Positioning to file marker to read data. |
| 24:45 | A network error occurred while communicating with the restore program on host [<String>]. |
| 24:46 | One or more ufsrestore executions failed, leaving behind one or more .ufsdump files. |
| 24:47 | One or more .ufsdump files created since ufsrestore is disabled. |
| 24:48 | One or more .ufsdump files created since ufsrestore is not supported on this platform. |
| 24:49 | One or more .ufsdump files created since ufsrestore is not supported on non-UFS file systems. |
| 24:50 | One or more archive files could not be found. Archive files may have been pruned. The restore results will not be complete. |
| 24:51 | Nothing to restore - wildcard source path(s) do not match any subclient content. |
| 24:52 | Initialization failure. Possible causes: Services down on Client and/or CommServe, lost network connectivity to CommServe, Out of process memory, handles or corrupted install. |
| 24:53 | Unable to access index cache directory. Please check permissions and user impersonation settings. |
| 24:54 | An exception occurred in module [<String>]. Please call your vendor's support hotline. |
| 24:55 | Archive file cannot be opened. Possible causes: services are down on CommServe, lost network connectivity to CommServe. |
| 24:56 | Failing due to critical error. |
| 24:57 | Failing due to critical error: Registry archive failed to restore. |
| 24:58 | Failing due to critical error: The Active Directory services were online during the restore. Please use Active Directory restore mode. |
| 24:59 | Failing due to critical error: Active Directory restore failed. |
| 24:60 | Failing due to critical error: Registry merge failed, System state restore failed. |
| 24:61 | Error setting restore status after restoring all files successfully. |
| 24:62 | Failed to get restore information from CommServe. Please check if job is valid and present in at least one copy. |
| 24:63 | There was nothing to restore - item(s) not found or not backed up. |
| 24:64 | There was nothing to restore - subclient(s) not backed up |
| 24:65 | Failed to receive feedback from the restore client. |
| 24:66 | Failed to get restore task information from Job Manager. |
| 24:67 | Failed to send initialization data to the restore client. |
| 24:68 | Failed to send source path to the restore client. |
| 24:69 | Failed to send destination path to the restore client. |
| 24:70 | Failed to connect to the MediaAgent [<String>] while browsing. |
| 24:71 | Connection to the MediaAgent [<String>] was lost. |
| 24:72 | Failed to generate CAB file. |
| 24:73 | Cannot get download ID. Failing generation of CAB file. |
| 24:74 | Cannot get restore path. Failing generation of CAB file. |
| 24:75 | Cannot get user GUID. Failing generation of CAB file. |
| 24:76 | Cannot create restore path. Failing generation of CAB file. |
| 24:77 | Cannot set CAB file name. Failing generation of CAB file. |
| 24:78 | Cannot get download items. Failing generation of CAB file. |
| 24:79 | Download list empty. Failing generation of CAB file. |
| 24:80 | Cannot initialize CAB file. |
| 24:81 | Error generating CAB file. |
| 24:82 | Failed to update DM2 DB with CAB details. |
| 24:83 | CAB report: Total files in CAB [<Number>], Skipped [<Number>], CAB size [<Number> KB] |
| 24:84 | Index restore failed to initialize the job for CommCell [<Number>], appNumber [<Number>], originated User Id [<Number>]. |
| 24:85 | Index restore was prohibited by Job Manager. Please see the log for details. |
| 24:86 | Index restore failed to initialize job control object. Restore failed. |
| 24:87 | Restore failed to set up session parameters. Please see the MediaAgent log for details. |
| 24:88 | Index restore was stopped. |
| 24:89 | Restore failed. Unable to send READ_ALL message. |
| 24:90 | Index restore failed. Please see the logs for details. |
| 24:91 | Restore failed to restore at least one item. |
| 24:92 | Failed to restore items. Failure Reason:[<String>] |
| 24:93 | Restore job couldn't restore at least one item successfully. Please check log files for more details. |
| 24:94 | Failed to populate archive files into database. Please check log files for more details. |
| 24:95 | Failed to get copy information for archive files. Please check log files for more details. |
| 24:96 | Media agent [<String>] is power managed VM and is powered down.Sending power on request. |
| 24:97 | Failed to power on Media agent [<String>]. |
| 24:98 | VSA proxies [<String>] are power-managed VMs that are currently stopped; a request has been sent to start these VMs. |
| 24:99 | Job results folder is not accessible |
| 24:100 | Job Results volume/folder [<String>] is not found |
| 24:101 | Chunk not found for the seek offset |
| 24:102 | Failed to generate PDF files. |
| 24:103 | Failed to generate PDF files due to content extractor service failure. |
| 24:104 | Failed to post process download items. Failing generation of CAB file. |
| 24:105 | Number of files submitted for Post Processing: [<Number>] n Successful:[<Number>] n Failed:[<Number>] n Skipped:[<Number>] |
| 24:106 | The latest backup archive time [<String>] is less than or equal to the current sync time [<String>], nothing more to restore. |
| 24:107 | Outstanding pending file rename operations found that potentially reside within live sync content being restored. Please check the registry to verify and reboot the destination machine to commit these pending items. Check the logs for exact match details. |
| 24:108 | Failed to process redirect restore options. |
| 24:109 | Failed to initialize Cloud Spanner Instance |
| 24:110 | Couldn't fetch staging path for Spanner, Error Code : [ <Number> ] |
| 24:111 | Container id is missing or empty. Container id is required for legal hold restore jobs. |
| 24:112 | Download id is missing or empty. Download id is required for legal hold restore jobs. |
| 24:113 | Failed to create StoreResults object. Failing restore job. |
| 24:114 | Restore By Job does not support restore of files backed up in file extents. For list of files skipped, please refer to restore.out. To restore these items, use 'Browse and Restore' operation. |
| 24:115 | Failed to flush the FileExtent records. |
| 24:116 | Failed to restore solr DB file [<String>]. |
| 24:117 | Failed to get CAN_OVERWRITE task option. |
| 24:118 | Legal hold bypass registry key cannot be present for a legal hold restore. |
| 24:119 | User id is missing or empty. User id is required for legal hold restore job. |
| 24:120 | Access nodes [<String>] are down or not reachable. [<String>] . |
| 24:121 | Live browse cache is locked by another operation |
| 24:122 | No free space in Live browse cache |
| 24:123 | Index browse operation failed during Live Sync Replication. n Possible causes: n - Index replay or construction is incomplete, try again. n - Commserve or MediaAgent is offline or inaccessible, please check connection status and retry. n - Other, check the logs for more details. |
| 24:124 | Data restore initialization failed. 1) Target mount path should have read write permissions 2) Target volume has enough space for data restore 3) Verify that the target mount path is not a symlink |
General
| 2:1 | An invalid argument was detected. |
| 2:2 | A NULL argument was detected. |
| 2:3 | A system call failed. |
| 2:4 | Failed to start the service [<String>]. |
| 2:5 | Failed to stop the service [<String>]. |
| 2:6 | Services startup terminated for [<String>]. |
| 2:7 | Services shutdown terminated for [<String>]. |
| 2:8 | Unknown Event [<Number>]. |
| 2:9 | A system error, [<String>], has occurred for service [<String>]. |
| 2:10 | Success! |
| 2:11 | The system call gethostname() failed. Check the network connectivity on this computer. |
| 2:12 | The system call gethostbyname() failed. Check the network connectivity on this computer. |
| 2:13 | The system call WSAStartup() failed. Check the network connectivity on this computer. |
GUI Audit Operations
| 84:1 | Dummy Operation - please replace. |
| 84:2 | Login Failed |
| 84:3 | User Logged in |
| 84:4 | User Logged out |
| 84:5 | Create Storage Policy |
| 84:6 | Delete Storage Policy |
| 84:7 | Update Storage Policy Properties |
| 84:8 | Clone Storage Policy |
| 84:9 | Reassociate Individual Subclients |
| 84:10 | Reassociate Subset of Subclients |
| 84:11 | Reassociate Bulk Subclients |
| 84:12 | Create Storage Policy Copy |
| 84:13 | Delete Storage Policy Copy |
| 84:14 | Update Storage Policy Copy Properties |
| 84:15 | Mark Volume Full for Storage Policy Copy |
| 84:16 | Change Default Datapath |
| 84:17 | Change Storage Policy Copy Data Path |
| 84:18 | Change Storage Policy Copy Precedence |
| 84:19 | Job Based Pruning |
| 84:20 | Delete Content Index for Job |
| 84:21 | Disable Backups for Storage Policy Copy |
| 84:22 | Allow Recopy Job |
| 84:23 | Allow Copy Job |
| 84:24 | Retain Job |
| 84:25 | Do Not Retain Job |
| 84:26 | Pick Job for Data Verification |
| 84:27 | Disallow Content Indexing for Jobs |
| 84:28 | Allow Content Indexing for Jobs |
| 84:29 | Create Content Indexing for Storage Policy |
| 84:30 | Update Content Indexing Properties for Storage Policy |
| 84:31 | Delete Content Indexing for Storage Policy |
| 84:32 | Disallow Copy Jobs in Media |
| 84:33 | Allow Copy Jobs in Media |
| 84:34 | Allow Recopy Data in Media |
| 84:35 | Change Threshold for Media Expiration |
| 84:36 | Change Threshold for Drive Maintenance |
| 84:37 | Change Threshold for Library |
| 84:38 | Change SAN Switch |
| 84:39 | Update Media Management Configuration Parameter |
| 84:40 | Add Media Barcode Pattern |
| 84:41 | Delete Media Barcode Pattern |
| 84:42 | Change Media Barcode Pattern |
| 84:43 | Add New Media Container |
| 84:44 | Discover Media |
| 84:45 | Migrate Media |
| 84:46 | Export Media |
| 84:47 | Export Media from Library |
| 84:48 | Export Media from Library through VaultTracker |
| 84:49 | Export Media through VaultTracker |
| 84:50 | Recall Media |
| 84:51 | Delete Media |
| 84:52 | Export and Delete Media |
| 84:53 | Delete Media Contents and Move Media |
| 84:54 | Delete Disk Media Content |
| 84:55 | Update Media Properties |
| 84:56 | Mark Media Full |
| 84:57 | Mark Media Good |
| 84:58 | Mark Media Bad |
| 84:59 | Mark Partial Full |
| 84:60 | Verify Media |
| 84:61 | Add Blind Media |
| 84:62 | Quick Erase Media |
| 84:63 | Full Erase Media |
| 84:64 | Release license for MediaAgent |
| 84:65 | Release license for Agent |
| 84:66 | Release licenses for client |
| 84:67 | Delete Replication Pair |
| 84:68 | Delete Subclient |
| 84:69 | Delete Replication Set |
| 84:70 | Delete Backup Set |
| 84:71 | Hard Delete iDataAgent |
| 84:72 | Hard Delete Client |
| 84:73 | Media Reuse Prevented |
| 84:74 | Media Reuse Allowed |
| 84:75 | Delete User |
| 84:76 | Delete User group |
| 84:77 | Update User |
| 84:78 | Create Schedule |
| 84:79 | Update Schedule |
| 84:80 | Delete Schedule |
| 84:81 | Create Schedule Policy |
| 84:82 | Update Schedule Policy |
| 84:83 | Delete Schedule Policy |
| 84:84 | Enable Schedule Policy |
| 84:85 | Disable Schedule Policy |
| 84:86 | Kill Job |
| 84:87 | Kill All Jobs |
| 84:88 | Erase Backup Data |
| 84:89 | Update Activity Control |
| 84:90 | Delete Search Engine |
| 84:91 | Delete Client from Search Engine |
| 84:92 | Create Subclient |
| 84:93 | Change Subclient Content |
| 84:94 | Change Subclient Pre-Command |
| 84:95 | Change Subclient Post-Command |
| 84:96 | Update Subclient Properties |
| 84:97 | Drive Cleaned |
| 84:98 | Drive Replaced |
| 84:99 | Mark Drive Fixed |
| 84:100 | A SCSI2 reservation was released for a drive, and the reservation release was successful. |
| 84:101 | A SCSI2 reservation release was attempted for a drive but failed. |
| 84:102 | Blind Media Full Inventory |
| 84:103 | Blind Media Quick Inventory |
| 84:104 | Quick Erase Media in Library |
| 84:105 | Full Erase Media in Library |
| 84:106 | Update Library Properties |
| 84:107 | Migrate Disk Library |
| 84:108 | Full Library Scan |
| 84:109 | Quick Library Scan |
| 84:110 | Add a Mount Path |
| 84:111 | Delete a Mount Path |
| 84:112 | Delete a Library |
| 84:113 | Add Spare Group |
| 84:114 | Delete Spare Group |
| 84:115 | Update Deduplication Properties |
| 84:116 | Delete Deduplication for Storage Policy Copy |
| 84:117 | Add a Deduplication Access Path |
| 84:118 | Update Deduplication Access Path |
| 84:119 | Remove Deduplication Access Path |
| 84:120 | Enable Deduplication Access Path |
| 84:121 | Disable Deduplication Access Path |
| 84:122 | Modify MediaAgent properties |
| 84:123 | Change Client Name |
| 84:124 | Change Client Host Name |
| 84:125 | Change Client CommServe Host Name |
| 84:126 | Change Network Password |
| 84:127 | Add Blackout Window |
| 84:128 | Update Blackout Window |
| 84:129 | Delete Blackout Window |
| 84:130 | Add Custom Calendar |
| 84:131 | Update Custom Calendar |
| 84:132 | Delete Custom Calendar |
| 84:133 | Add Snap Volume Unit |
| 84:134 | Rename Snap Volume Unit |
| 84:135 | Update Snap Volume Unit |
| 84:136 | Delete Snap Volume Unit |
| 84:137 | Add Workflow |
| 84:138 | Rename Workflow |
| 84:139 | Update Workflow |
| 84:140 | Delete Workflow |
| 84:141 | Add Subclient Policy |
| 84:142 | Clone Subclient Policy |
| 84:143 | Rename Subclient Policy |
| 84:144 | Update Subclient Policy |
| 84:145 | Delete Subclient Policy |
| 84:146 | Update Client Encryption Properties |
| 84:147 | Reset Client Pass Phrase |
| 84:148 | Export Client Pass Phrase |
| 84:149 | Prevent Export |
| 84:150 | Allow Export |
| 84:151 | Delete VaultTracker Policy |
| 84:152 | Update VaultTracker Policy |
| 84:153 | Add Export Location |
| 84:154 | Update Export Location |
| 84:155 | Delete Export Location |
| 84:156 | Add Media Container |
| 84:157 | Update Media Container |
| 84:158 | Delete Media Container |
| 84:159 | Rollback History of VaultTracker Action |
| 84:160 | Delete History of VaultTracker Action |
| 84:161 | Reach Destination for Media in VaultTracker Action |
| 84:162 | Pick up Media in VaultTracker Action |
| 84:163 | Return Media in VaultTracker Action to Source |
| 84:164 | Abort Media in VaultTracker Action |
| 84:165 | Set Container for Media in VaultTracker Action |
| 84:166 | Suspend Export for Media in VaultTracker Action |
| 84:167 | Resume Export for Media in VaultTracker Action |
| 84:168 | Mark Recall Done for Media in VaultTracker Action |
| 84:169 | Add Iron Mountain Customer ID |
| 84:170 | Update Iron Mountain Customer ID |
| 84:171 | Delete Iron Mountain Customer ID |
| 84:172 | Move All Media to Spare Group |
| 84:173 | Move Number of Media to Spare Group |
| 84:174 | Rename Spare Group |
| 84:175 | Update Spare Group Properties |
| 84:176 | Change Index Cache Retention Days |
| 84:177 | Rename Subclient |
| 84:178 | Mark Media Exported |
| 84:179 | Delete a Server group |
| 84:180 | Move Media between Libraries |
| 84:181 | Configure a Storage Node in Expert Storage Configuration Tool |
| 84:182 | Configure the Whole Storage Node in Expert Storage Configuration Tool |
| 84:183 | Deconfigure a Storage Node in Expert Storage Configuration Tool |
| 84:184 | Change the Host for a Storage Node in Expert Storage Configuration Tool |
| 84:185 | Updated Device Path Properties |
| 84:186 | Mark Media from Foreign CommCell Reusable |
| 84:187 | Pick Job for Moving Snapshots to back up Media |
| 84:188 | Unpick Job for Moving Snapshots to back up Media |
| 84:189 | Change Storage Policy Properties for Moving Snapshots to back up Media. |
| 84:190 | Create Content Director Tag |
| 84:191 | Update Content Director Tag |
| 84:192 | Clone Content Director Tag |
| 84:193 | Delete Content Director Tag |
| 84:194 | Enable Content Director Tag |
| 84:195 | Disable Content Director Tag |
| 84:196 | Create Content Director Record Center |
| 84:197 | Update Content Director Record Center |
| 84:198 | Clone Content Director Record Center |
| 84:199 | Delete Content Director Record Center |
| 84:200 | Enable Content Director Record Center |
| 84:201 | Disable Content Director Record Center |
| 84:202 | Create Content Director Search |
| 84:203 | Update Content Director Search |
| 84:204 | Clone Content Director Search |
| 84:205 | Delete Content Director Search |
| 84:206 | Enable Content Director Search |
| 84:207 | Disable Content Director Search |
| 84:208 | Create Content Director Legal Hold |
| 84:209 | Update Content Director Legal Hold |
| 84:210 | Clone Content Director Legal Hold |
| 84:211 | Delete Content Director Legal Hold |
| 84:212 | Enable Content Director Legal Hold |
| 84:213 | Disable Content Director Legal Hold |
| 84:214 | Create Content Director Policy |
| 84:215 | Update Content Director Policy |
| 84:216 | Clone Content Director Policy |
| 84:217 | Delete Content Director Policy |
| 84:218 | Enable Content Director Policy |
| 84:219 | Disable Content Director Policy |
| 84:220 | Enable Schedule |
| 84:221 | Disable Schedule |
| 84:222 | Oracle RMAN Cross-Check Enabled |
| 84:223 | Oracle RMAN Cross-Check Disabled |
| 84:224 | Compliance Search |
| 84:225 | Delete Replication Policy |
| 84:226 | Change SharePoint Archiver Prune Settings |
| 84:227 | Security Domain Settings |
| 84:228 | Update Backup Set Properties |
| 84:229 | Update Instance Properties |
| 84:230 | Deconfigure Instance |
| 84:231 | Delete Instance |
| 84:232 | Created Filer Management |
| 84:233 | Changed Filer Management |
| 84:234 | Deleted Filer Management |
| 84:235 | Mount Snapshot |
| 84:236 | Unmount Snapshot |
| 84:237 | Delete Snapshot |
| 84:238 | Revert Snapshot |
| 84:239 | Created Schedule Holiday |
| 84:240 | Changed Schedule Holiday |
| 84:241 | Deleted Schedule Holiday |
| 84:242 | Description modified |
| 84:243 | Deprecated message. |
| 84:244 | Deprecated message. |
| 84:245 | Deprecated message. |
| 84:246 | Deprecated message. |
| 84:247 | Deprecated message. |
| 84:248 | Deprecated message. |
| 84:249 | Deprecated message. |
| 84:250 | Deprecated message. |
| 84:251 | Set Exchange Subclient Affinity |
| 84:252 | User group Enable/Disable |
| 84:253 | Execute QScript |
| 84:254 | Change Deduplication Setting |
| 84:255 | Seal Deduplication Store |
| 84:256 | Create ERM Connector |
| 84:257 | Update ERM Connector |
| 84:258 | Clone ERM Connector |
| 84:259 | Delete ERM Connector |
| 84:260 | Enable ERM Connector |
| 84:261 | Disable ERM Connector |
| 84:262 | Deprecated message. |
| 84:263 | Deprecated message. |
| 84:264 | Deprecated message. |
| 84:265 | Deprecated message. |
| 84:266 | Deprecated message. |
| 84:267 | Deprecated message. |
| 84:268 | Deprecated message. |
| 84:269 | Deprecated message. |
| 84:270 | Deprecated message. |
| 84:271 | Deprecated message. |
| 84:272 | Change CommServe Host Name |
| 84:273 | Update Client properties |
| 84:274 | Update Application properties |
| 84:275 | Update Instance properties |
| 84:276 | Update Backup set properties |
| 84:277 | Update Subclient properties |
| 84:278 | Update Client properties - Activity Control |
| 84:279 | Update Client properties - Server group association |
| 84:280 | Update User group association |
| 84:281 | Update Application properties - Activity Control |
| 84:282 | Create New Instance |
| 84:283 | Create New Backup set |
| 84:284 | Create Subclient |
| 84:285 | Create Index Cache profile |
| 84:286 | Delete Index Cache profile |
| 84:287 | Update Index Cache profile |
| 84:288 | Set Index Access Path |
| 84:289 | Mark Job Bad |
| 84:290 | Mark Job Good |
| 84:291 | Pick Media for Refreshing |
| 84:292 | Unpick Media for Refreshing |
| 84:293 | Prevent Media Refresh |
| 84:294 | Allow Media Refresh |
| 84:295 | Move Media |
| 84:296 | Add New User |
| 84:297 | Add New User Group |
| 84:298 | Update User Group properties |
| 84:299 | Client Configuration Policy Modified |
| 84:300 | Deprecated message. |
| 84:301 | Set Mining Properties for Storage Policy |
| 84:302 | Change Mining Properties for Storage Policy |
| 84:303 | FTP Upload |
| 84:304 | Web Service Login |
| 84:305 | Web Service Login Failure |
| 84:306 | Review Set Operation |
| 84:307 | Download process from the end user compliance page. |
| 84:308 | ERM Submission |
| 84:309 | Download Item |
| 84:310 | Annotation |
| 84:311 | Legal Hold Item |
| 84:312 | Tagging |
| 84:313 | Delete Orphaned Job from Volume Reconciliation |
| 84:314 | Consume License |
| 84:315 | Release License |
| 84:316 | Command-line Login |
| 84:317 | Command-line Login Failed |
| 84:318 | Command-line Logout |
| 84:319 | Command-line Logout Failed |
| 84:320 | Command-line Internal Login |
| 84:321 | Command-line Pseudo Login |
| 84:322 | Update CommCell properties |
| 84:323 | Execute QScript |
| 84:324 | Execute QScript |
| 84:325 | Execute QScript |
| 84:326 | Execute QScript |
| 84:327 | Control Services |
| 84:328 | Media Catalog |
| 84:329 | Tape Catalog Merge |
| 84:330 | Erase Media |
| 84:331 | Scheduled job ran |
| 84:332 | Created Virtual Machine Allocation Policy |
| 84:333 | Deleted Virtual Machine Allocation Policy |
| 84:334 | Changed Virtual Machine Allocation Policy |
| 84:335 | Register/Install Client |
| 84:336 | Register/Install Client Failed |
| 84:337 | Update Media Barcodes |
| 84:338 | Global Filer Added |
| 84:339 | Global Filer Deleted |
| 84:340 | Global Filer Modified |
| 84:341 | Modify Drive Properties |
| 84:342 | User Account Management |
| 84:343 | Create Client |
| 84:344 | Execute Quick Run Tool |
| 84:345 | User Disconnect |
| 84:346 | Add Quick Run Tool |
| 84:347 | Modify Quick Run Tool |
| 84:348 | Delete Quick Run Tool |
| 84:349 | Update Server group properties |
| 84:350 | Create New Server group |
| 84:351 | Update Content Index Engine JVM Memory |
| 84:352 | Update Content Index Engine Configuration File |
| 84:353 | Automatic Server group Update |
| 84:354 | Certificate Change |
| 84:355 | Update subclient content groups |
| 84:356 | DDB Move operation |
| 84:357 | Update User group capabilities |
| 84:358 | Change Storage Policy Properties for Deferred Cataloging |
| 84:359 | Deprecated message. |
| 84:360 | Move Partition Success |
| 84:361 | Move Partition Failure |
| 84:362 | Move Partition Access Path Update Success |
| 84:363 | Move Partition Access Path Update Failure |
| 84:364 | Data UnAging |
| 84:365 | Configure library server |
| 84:366 | Update User group Associated Entities |
| 84:367 | Vault Tracker Policy Media Status Change |
| 84:368 | CommCell Readiness Check |
| 84:369 | Update Subclient properties |
| 84:370 | Delete Subclient |
| 84:371 | Reference Copy Association |
| 84:372 | Reference Copy Content |
| 84:373 | Change Troubleshooting Settings |
| 84:374 | Add NAS virtual File Server for Physical Filer/Cluster. |
| 84:375 | Remove NAS virtual File Server for Physical Filer/Cluster. |
| 84:376 | Deconfigure client due to client having permanently migrated to a different CommCell |
| 84:377 | Disable client activity due to client having permanently migrated to a different CommCell |
| 84:378 | Modify alerts subscription preference. |
| 84:379 | Web Console download Operation |
| 84:380 | Sync Folder Operation |
| 84:381 | Create Sync Folder Operation |
| 84:382 | Update Sync Folder Operation |
| 84:383 | Client user profile Operation |
| 84:384 | Configure Index Server |
| 84:385 | Deconfigure Index Server |
| 84:386 | Delete Application Test Clone |
| 84:387 | Renew Application Test Clone |
| 84:388 | Printing |
| 84:389 | Cloud Print Configuration |
| 84:390 | Create VaultTracker Policy |
| 84:391 | Clone VaultTracker Policy |
| 84:392 | Add Custom Query |
| 84:393 | Edit Custom Query |
| 84:394 | Delete Custom Query |
| 84:395 | Enable Custom Query |
| 84:396 | Disable Custom Query |
| 84:397 | Share Folder Operation |
| 84:398 | Create Share Folder Operation |
| 84:399 | Update Share Folder Operation |
| 84:400 | Resynchronize DDBs |
| 84:401 | Create Case |
| 84:402 | Update Case |
| 84:403 | Close Case |
| 84:404 | Delete Case |
| 84:405 | Rename Case |
| 84:406 | Updated Shared Disk Device using Expert Storage Configuration Wizard |
| 84:407 | Update Index Server Roles |
| 84:408 | Enable/Disable Cloud Metrics |
| 84:409 | Enable/Disable Cloud Metrics Feature |
| 84:410 | Cloud Metrics URL Change |
| 84:411 | Cloud Metrics Upload Frequency Change |
| 84:412 | Cloud Metrics Upload Now |
| 84:413 | Cloud Metrics Data Collection Time Change |
| 84:414 | Cloud Metrics Server group Selection |
| 84:415 | Enable/Disable Remote Private Metrics |
| 84:416 | Enable/Disable Enterprise Metrics Feature |
| 84:417 | Enterprise Metrics URL Change |
| 84:418 | Enterprise Metrics Upload Frequency Change |
| 84:419 | Enterprise Metrics Upload Now |
| 84:420 | Enterprise Metrics Data Collection Time Change |
| 84:421 | Enterprise Metrics Server group Selection |
| 84:422 | Enterprise Metrics Forwarding State Change |
| 84:423 | Enterprise Metrics Forwarding URL Change |
| 84:424 | Add Monitoring Policy |
| 84:425 | Edit Monitoring Policy |
| 84:426 | Delete Monitoring Policy |
| 84:427 | Disable higher-level Blackout Window rules |
| 84:428 | Enable higher-level Blackout Window rules |
| 84:429 | Unpicked Job for Data Verification |
| 84:430 | Create Alert |
| 84:431 | Modify Alert |
| 84:432 | Delete Alert |
| 84:433 | Add remote CommCell client(s) |
| 84:434 | Web Report Edit Tag |
| 84:435 | Create Snapshot to tape for Storage Policy |
| 84:436 | Create Snapshot Catalog for Storage Policy |
| 84:437 | Pick Job for Snapshot Catalog |
| 84:438 | Unpick Job for Snapshot Catalog |
| 84:439 | Update Search Engine Core Role |
| 84:440 | Move DM2 Cache Directory |
| 84:441 | Move Search Engine Index Directory |
| 84:442 | Move Analytics Index Directory |
| 84:443 | Delete Events |
| 84:444 | Update Store Properties |
| 84:445 | Preview Cloud Engine Association |
| 84:446 | Client Entity Association |
| 84:447 | Configure Entity Extraction |
| 84:448 | Deconfigure Entity Extraction |
| 84:449 | Configure Data Interface Pair |
| 84:450 | Add Role |
| 84:451 | Edit Role |
| 84:452 | Delete Role |
| 84:453 | Security configuration changed |
| 84:454 | Force Kill Job |
| 84:455 | Suspend Job |
| 84:456 | Suspend All Jobs |
| 84:457 | Force Suspend Job |
| 84:458 | User from SAML token mapped to a local user |
| 84:459 | Enable Workflow |
| 84:460 | Disable Workflow |
| 84:461 | Uninstall Client |
| 84:462 | Uninstall Client Failed |
| 84:463 | Storage Validation(MountPath) |
| 84:464 | Storage Validation(Drive) |
| 84:465 | Disk Library Maintenance |
| 84:466 | Edge Drive Operation |
| 84:467 | Library Operation Performed |
| 84:468 | Master Pool Operation Performed |
| 84:469 | Drive Pool Operation Performed |
| 84:470 | Drive Operation Performed |
| 84:471 | Drive Unloaded |
| 84:472 | Configure/Dock client failed. |
| 84:473 | Configure/Dock client. |
| 84:474 | Update Search Engine Properties |
| 84:475 | Add Virtual Server Proxy |
| 84:476 | Edit Virtual Server Proxy |
| 84:477 | Delete Virtual Server Proxy |
| 84:478 | Audit |
| 84:479 | Add Network Topology |
| 84:480 | Edit Network Topology |
| 84:481 | Delete Network Topology |
| 84:482 | Move Search Engine Index |
| 84:483 | Configure Content Extractor |
| 84:484 | Deconfigure Content Extractor |
| 84:485 | Update Content Extractor Configuration |
| 84:486 | Add Command |
| 84:487 | Delete Command |
| 84:488 | Modify Command |
| 84:489 | Create metrics alert |
| 84:490 | Modify metrics alert |
| 84:491 | Delete metrics alert |
| 84:492 | Enable metrics alert |
| 84:493 | Disable metrics alert |
| 84:494 | Server group CLA Quota |
| 84:495 | Update Storage Pool |
| 84:496 | Table Filter Modified |
| 84:497 | Create Dependent Storage Policy |
| 84:498 | SnapManagementTool Volume Rename |
| 84:499 | SnapManagementTool Snap Rename |
| 84:500 | SnapManagementTool Array Rename |
| 84:501 | SnapManagementTool Array Interface Rename |
| 84:502 | SnapManagementTool NasClient to Array Association |
| 84:503 | SnapManagementTool DB update stats |
| 84:504 | Automatic Snap Copy Creation |
| 84:505 | Force Delete Snapshot |
| 84:506 | Tape to Tape Copy Success |
| 84:507 | Tape to Tape Copy Failure |
| 84:508 | Add Encryption Key Provider |
| 84:509 | Delete Encryption Key Provider |
| 84:510 | Modify Encryption Key Provider |
| 84:511 | Move Mount Path Failure |
| 84:512 | Move Mount Path Success |
| 84:513 | Browse/Search/Recovery Options |
| 84:514 | Replication Settings |
| 84:515 | SCOM |
| 84:516 | Modify Network Route Configuration |
| 84:517 | Modify Client to Plan Association |
| 84:518 | Modify Sub-Client to Plan Association |
| 84:519 | SNMPV3 Configuration |
| 84:520 | Transfer Owner |
| 84:521 | Modify MediaAgent properties |
| 84:522 | Created Storage Policy Copy based on Server group configuration |
| 84:523 | Created Storage Policy Group |
| 84:524 | Reassociated Storage Policy for Individual Subclients based on Server group change |
| 84:525 | Delete Controller for Mount Path |
| 84:526 | Share Mount Path |
| 84:527 | Data Cube Delete Data |
| 84:528 | Data Cube Delete Datasource |
| 84:529 | Data Cube Delete Field |
| 84:530 | Data Cube Delete Handler |
| 84:531 | Data Cube MetaInfo |
| 84:532 | Data Cube Update Datasource |
| 84:533 | Data Cube Update Handler |
| 84:534 | Data Cube Update Schema |
| 84:535 | Delete replication schedule in plan |
| 84:536 | Delete replications |
| 84:537 | Release SCSI reservation. |
| 84:538 | SearchAdmin Add Preference |
| 84:539 | SearchAdmin Delete Preference |
| 84:540 | SearchAdmin Modify Preference |
| 84:541 | Delete Data Interface Pair |
| 84:542 | Edit Data Interface Pair |
| 84:543 | Push Network Configuration |
| 84:544 | Update Audit Trail Properties |
| 84:545 | Update Job Manager Settings |
| 84:546 | Update DR Backup Properties |
| 84:547 | Disable Alert |
| 84:548 | Enable Alert |
| 84:549 | Create dashboard search |
| 84:550 | Create search |
| 84:551 | Delete dashboard search |
| 84:552 | Delete search |
| 84:553 | Modify dashboard search |
| 84:554 | Modify search |
| 84:555 | Delete associations for schedule policies |
| 84:556 | Cloud VM Management |
| 84:557 | Add RServer Host Details |
| 84:558 | Update RServer Host Details |
| 84:559 | Delete RServer Host Details |
| 84:560 | Create Analytics Cloud |
| 84:561 | Delete Analytics Cloud |
| 84:562 | Modify Analytics Cloud |
| 84:563 | Analytics Cloud Operation |
| 84:564 | Analytics Node Operation |
| 84:565 | Analytics Role Operation |
| 84:566 | Company Auth Code Generated |
| 84:567 | Update Password Security Configuration |
| 84:568 | Drive reset operation failed for selected drives. Check EvMgrs log for more details. |
| 84:569 | Drive unload operation failed for selected drives. Check EvMgrs log for more details. |
| 84:570 | SamlToken Generated |
| 84:571 | SamlToken Validated |
| 84:572 | Update HyperScale X Storage Pool Properties |
| 84:573 | Add Monitoring Policy Template |
| 84:574 | Delete Monitoring Policy Template |
| 84:575 | Edit Monitoring Policy Template |
| 84:576 | Alert Disabled |
| 84:577 | Alert Enabled |
| 84:578 | Failed to delete the client. Please delete node [<String>] from Index server [<String>] and retry. |
| 84:579 | Update Commserv Livesync Configuration |
| 84:580 | Report Search Analytic Engine |
| 84:581 | Create a Library |
| 84:582 | Add device app key |
| 84:583 | Add device owner |
| 84:584 | Register device |
| 84:585 | Update device app key |
| 84:586 | Laptop Migration |
| 84:587 | Update Configuration Policy |
| 84:588 | Create Configuration Policy |
| 84:589 | Delete Configuration Policy |
| 84:590 | Create Credentials. |
| 84:591 | Delete Credentials. |
| 84:592 | Update Credentials. |
| 84:593 | EDiscovery Configure |
| 84:594 | EDiscovery Create |
| 84:595 | EDiscovery Delete |
| 84:596 | EDiscovery Update |
| 84:597 | Restore Contents |
| 84:598 | Replace disk operation for Storagepool |
| 84:599 | Delete Backup and Archive Data |
| 84:600 | Update Global Params |
| 84:601 | Index Server cloud Operation |
| 84:602 | Index Server Node Operation |
| 84:603 | Index Server Pool Cloud Operation |
| 84:604 | Index Server Pool Node Operation |
| 84:605 | Index Server Role Operation |
| 84:606 | Index Server Changed |
| 84:607 | Add new plan |
| 84:608 | Delete existing plan |
| 84:609 | Modify existing plan |
| 84:610 | Setting default plan |
| 84:611 | Update Company Properties |
| 84:612 | Change Client Domain Name |
| 84:613 | Create Folder |
| 84:614 | Delete Folder |
| 84:615 | Modify Folder |
| 84:616 | Modify locale for alert notifications |
| 84:617 | Add SNMPV3 Host Configuration |
| 84:618 | Update SNMPV3 Host Configuration |
| 84:619 | Delete SNMPV3 Host Configuration |
| 84:620 | Update SMTP Email Server Configuration |
| 84:621 | Update Encryption Properties |
| 84:622 | Files/Emails deleted |
| 84:623 | Changed CommServe Display Name |
| 84:624 | Pick Jobs for Refreshing |
| 84:625 | Unpick Jobs for Refreshing |
| 84:626 | Clone Subclient |
| 84:627 | Laptop Activation |
| 84:628 | Laptop Activation |
| 84:629 | Laptop Deactivation |
| 84:630 | Laptop Deactivation |
| 84:631 | Client Owner Update |
| 84:632 | HAC Cluster Operation |
| 84:633 | HAC Cluster Node Operation |
| 84:634 | Reconfigure Instance |
| 84:635 | Deactivate a company. |
| 84:636 | Client Owner Update |
| 84:637 | Resource Pool Created |
| 84:638 | Resource Pool Deleted |
| 84:639 | Resource Pool Updated |
| 84:640 | Activate a company. |
| 84:641 | Create 3dfs Network Share |
| 84:642 | Delete 3dfs Network Share |
| 84:643 | Update 3dfs Network Share |
| 84:644 | Update Region Properties |
| 84:645 | Create Region |
| 84:646 | Delete Region |
| 84:647 | Create Case Definition |
| 84:648 | Delete Case Definition |
| 84:649 | Update Case Definition |
| 84:650 | Start Over |
| 84:651 | Modify VPN Configuration |
| 84:652 | HTTP Proxy Change |
| 84:653 | Internet Gateway Change |
| 84:654 | Immediate Job Submitted |
| 84:655 | Delete Workflow |
| 84:656 | Data aging has been automatically re-enabled by the system on affected clients |
| 84:657 | Delete plan association |
| 84:658 | Delete MediaAgent |
| 84:659 | Set Grace Period For Capacity License |
| 84:660 | Set Grace Period For Usage License |
| 84:661 | Configure all VM Backup sets associated with VSA Backup set |
| 84:662 | Configure backedup VM's Backup sets from VSA Backup Set |
| 84:663 | Deconfigure all VM Backup sets associated with VSA Backup set |
| 84:664 | Deconfigure removed or filtered VM's Backup sets from VSA Backup Set |
| 84:665 | Browse/Restore |
| 84:666 | Retire Application |
| 84:667 | Retire Client |
| 84:668 | [<String>] Collect file details |
| 84:669 | [<String>] Collect file details for snap |
| 84:670 | Modify VM to Plan Association |
| 84:671 | Delete Replication Group |
| 84:672 | Create Replication Group |
| 84:673 | Configured VM |
| 84:674 | Deconfigured VM |
| 84:675 | Unprotected VM is marked for deconfigure |
| 84:676 | Compliance lock disabled |
| 84:677 | VPN User Logged in |
| 84:678 | VPN User Logged out |
| 84:679 | Deconfigured client deleted by Data Aging as it had no protected data |
| 84:680 | Create company |
| 84:681 | Created Array Management entry |
| 84:682 | Deleted Array Management entry |
| 84:683 | Edited Array Management entry |
| 84:684 | Delete company |
| 84:685 | Delete company app plans |
| 84:686 | Delete company Server groups |
| 84:687 | Delete company media agents |
| 84:688 | Delete company non data bearing entities |
| 84:689 | Retire company clients |
| 84:690 | Delete company schedule policies |
| 84:691 | Delete company storage policies |
| 84:692 | Delete company storage pools |
| 84:693 | KPI based MediaAgent state management |
| 84:694 | Delete a replication pair. |
| 84:695 | Change company for client(s) |
| 84:696 | Reconfigure agent |
| 84:697 | Reconfigure client |
| 84:698 | Register Distributed Storage |
| 84:699 | Delete Distributed Storage |
| 84:700 | Update Distributed Storage |
| 84:701 | External Pruning Operation |
| 84:702 | Delete Offline Laptop |
| 84:703 | Delete retired client |
| 84:704 | Update resource pool |
| 84:705 | Cloud Service Linking |
| 84:706 | Create VM Clients for all the VMs under Subclient Content |
| 84:707 | Retire Offline Laptops |
| 84:708 | Create Storage Pool |
| 84:709 | Delete Storage Pool |
| 84:710 | User account locked |
| 84:711 | Reset Job Priority |
| 84:712 | Set Job Priority |
| 84:713 | Data sources pruning thread |
| 84:714 | Add webhook |
| 84:715 | Create Plan entity rule |
| 84:716 | Update plan entity rule |
| 84:717 | Add web authenticator |
| 84:718 | Remove web authenticator |
| 84:719 | Delete plan entity rule |
| 84:720 | Export set deleted |
| 84:721 | Cloud Service Unlinking |
| 84:722 | Download center operation |
| 84:723 | Add Device User Mapping |
| 84:724 | Delete Device User Mapping |
| 84:725 | Update Device User Mapping |
| 84:726 | Auto client owner association |
| 84:727 | User has been disconnected |
| 84:728 | User [<String>] is added as owner for client: [<String>] |
| 84:729 | Delete a replication pair. |
| 84:730 | Replication pair: [<String>] is deleted from replication group: [<String>]. |
| 84:731 | Add replication pair |
| 84:732 | Replication pair: [<String>] added to replication group: [<String>]. |
| 84:733 | Update region for entity |
| 84:734 | Browse/Find Operation |
| 84:735 | Update user logon attempt limits |
| 84:736 | Company marked for delete |
| 84:737 | Delete empty client groups |
| 84:738 | Execute laptop owner mapping |
| 84:739 | Owner assignment during activation |
| 84:740 | Update Replication Group |
| 84:741 | Add Content |
| 84:742 | Delete Content |
| 84:743 | Update Content |
| 84:744 | Plan rule execution mode |
| 84:745 | Add SAML |
| 84:746 | Delete SAML |
| 84:747 | Update SAML |
| 84:748 | Edit Syslog configuration |
| 84:749 | Add File Server |
| 84:750 | Add Laptop Admin(s) |
| 84:751 | Remove Laptop Admin(s) |
| 84:752 | Infrastructure Resource creation approval |
| 84:753 | Subclient excluded from plan rules framework |
| 84:754 | Subclient included in plan rules framework |
| 84:755 | Clear all Laptop Admin(s) |
| 84:756 | Update Service Commcell Security Association |
| 84:757 | Delete webhook |
| 84:758 | Modify webhook |
| 84:759 | Create SIEM connector |
| 84:760 | Delete SIEM connector |
| 84:761 | Modify SIEM connector |
| 84:762 | Hard Delete Subclient |
| 84:763 | Update Report Subscriptions |
| 84:764 | Set Company for Client(s) |
| 84:765 | Laptop [<String>] deactivated due to user [<String>] disassociation from plan [<String>]. |
| 84:766 | Exclude client from SLA |
| 84:767 | Update Reseller For Company |
| 84:768 | Compare XML Strings |
| 84:769 | Enterprise Metrics Upload Failed |
| 84:770 | Cloud Metrics Upload Failed |
| 84:771 | Exclude subclient from SLA |
| 84:772 | Create Office365 Custom Category |
| 84:773 | Modify Office365 Custom Category |
| 84:774 | Trying to delete a Storage Policy Copy which has Compliance Lock enabled. |
| 84:775 | Trying to delete a Storage Policy which has Compliance Lock enabled on its Primary Copy. |
| 84:776 | Trying to lower Basic or Extended Retention on a copy which has Compliance Lock enabled. |
| 84:777 | Update local authentication configuration |
| 84:778 | REST API Failure |
| 84:779 | Backup code generated |
| 84:780 | Backup code used |
| 84:781 | Trying to delete a Backup Set which has valid data in worm storage. |
| 84:782 | Trying to delete an Instance which has valid data in worm storage. |
| 84:783 | Trying to delete a Library or a Mount Path which has valid data in worm storage. |
| 84:784 | Trying to retire a Client which has valid data in worm storage. |
| 84:785 | Ransomware protection detected unauthorized access |
| 84:786 | Update user failed |
| 84:787 | User Group Auth Code Generated |
| 84:788 | User Group Auth Code |
| 84:789 | Add DDB disk |
| 84:790 | Delete DDB disk |
| 84:791 | Move DDB disk |
| 84:792 | Enforcement |
| 84:793 | SAML test login attempted |
| 84:794 | Users exclusion as part of migration |
| 84:795 | Associate MediaAgent with StoragePool |
| 84:796 | Dissociate MediaAgent from StoragePool |
| 84:797 | Threatwise Registration code generated |
| 84:798 | Trying to delete a copy with data that has not met the minimum retention configured on the copy. |
| 84:799 | Trying to delete a storage policy with data that has not met the minimum retention configured on the copy. |
| 84:800 | Trying to reduce basic or extended retention on a copy lower than the minimum allowed retention days. |
| 84:801 | Submitted Storage Policy for copy promotion |
| 84:802 | Marked Drive as Clean |
| 84:803 | Pruned Anomalies |
| 84:804 | Mark Media Erasable |
| 84:805 | Share Drive |
| 84:806 | Delete Unused Backupset |
| 84:807 | Delete Unused Instance |
| 84:808 | Retire Unused Application |
| 84:809 | Delete Application Instant Clone |
| 84:810 | Enable Airgap |
| 84:811 | Modify Drive Type Properties |
| 84:812 | Kill V2 laptop backup jobs |
| 84:813 | Delete Unused Subclient |
| 84:814 | Disable Active Management |
| 84:815 | Enable Active Management |
| 84:816 | Configure read replica |
| 84:817 | Delete read replica |
| 84:818 | Disable read replica |
| 84:819 | Edit read replica |
| 84:820 | Enable read replica |
| 84:821 | Recovery Group Created |
| 84:822 | Recovery Entity Created |
| 84:823 | Recovery Entity Deleted |
| 84:824 | Recovery Group Deleted |
| 84:825 | Recovery Entity Updated |
| 84:826 | Recovery Group Updated |
| 84:827 | Snap replication mapping has been created. |
| 84:828 | Snap replication mapping has been removed. |
| 84:829 | Snap replication mapping has been updated. |
GUI Audit Parameters
| Code | Description |
| 85:1 | Dummy Parameter - please replace. |
| 85:2 | Job ID: <Number> |
| 85:3 | Job ID: <String> |
| 85:4 | Job ID: None |
| 85:5 | Media: <String> |
| 85:6 | Slot: <String> |
| 85:7 | Sunday |
| 85:8 | Monday |
| 85:9 | Tuesday |
| 85:10 | Wednesday |
| 85:11 | Thursday |
| 85:12 | Friday |
| 85:13 | Saturday |
| 85:14 | All Backups |
| 85:15 | All Full Backups |
| 85:16 | NONE |
| 85:17 | New Name: [<String>] |
| 85:18 | All Full |
| 85:19 | Weekly Full |
| 85:20 | Monthly Full |
| 85:21 | Quarterly Full |
| 85:22 | Half Yearly Full |
| 85:23 | Yearly Full |
| 85:24 | Login Name: <String> |
| 85:25 | Media Barcode: <String> |
| 85:26 | Storage Policy: <String> |
| 85:27 | Storage Policy Copy: <String> |
| 85:28 | Source Storage Policy: <String> |
| 85:29 | Destination Storage Policy: <String> |
| 85:30 | Deduplication Store: <String> |
| 85:31 | Added new extended retention rules. |
| 85:32 | Removed existing extended retention rules. |
| 85:33 | Modified existing extended retention rules. |
| 85:34 | Number of streams was changed from [<Number>] to [<Number>]. |
| 85:35 | Incremental Storage Policy: [<String>]. |
| 85:36 | Incremental Storage Policy was changed from [<String>] to [<String>]. |
| 85:37 | Deduplication block size was changed from [<Number>] KB to [<Number>] KB. |
| 85:38 | Auxiliary Copy fallen behind alert to be copied data in GB was changed from [<Number>] to [<Number>]. |
| 85:39 | Auxiliary Copy fallen behind alert jobs are not copied in days was changed from [<Number>] to [<Number>]. |
| 85:40 | Drive pool was changed from [<String>] to [<String>]. |
| 85:41 | Description was modified. |
| 85:42 | Enable hardware compression. |
| 85:43 | Disable hardware compression. |
| 85:44 | Copy was marked inactive. |
| 85:45 | Copy was marked active. |
| 85:46 | Promoted to primary with nonsynchronous data. |
| 85:47 | Promoted to primary with data synchronized. |
| 85:48 | Months to expire verification was changed from [<Number>] to [<Number>]. |
| 85:49 | Old basic retention rule: Infinite |
| 85:50 | New basic retention rule: Infinite |
| 85:51 | Old basic retention rule: Spool |
| 85:52 | New basic retention rule: Spool |
| 85:53 | Old basic retention days: <Number> |
| 85:54 | New basic retention days: <Number> |
| 85:55 | Old basic retention cycles: <Number> |
| 85:56 | New basic retention cycles: <Number> |
| 85:57 | For weekly full rule the week start on was changed from [<Message>] to [<Message>]. |
| 85:58 | For monthly full rule the month start on was changed from [<Number>] to [<Number>]. |
| 85:59 | Disable Data Aging. |
| 85:60 | Enable Data Aging. |
| 85:61 | Enable managed disk space for disk data. |
| 85:62 | Disable managed disk space for disk data. |
| 85:63 | Old basic retention days for archiver data: <Number> |
| 85:64 | New basic retention days for archiver data: <Number> |
| 85:65 | Old basic retention rule for archiver data: Infinite |
| 85:66 | New basic retention rule for archiver data: Infinite |
| 85:67 | Auxiliary Copy effective date was changed from [<String>] to [<String>]. |
| 85:68 | Data Verification Backups On or After Date was changed from [<String>] to [<String>]. |
| 85:69 | Spare group was changed from [<String>] of library [<String>] to [<String>] of library [<String>]. |
| 85:70 | Old selective copy schedule: <String> |
| 85:71 | New selective copy schedule: <String> |
| 85:72 | Select first full of time period. |
| 85:73 | Select last full of time period. |
| 85:74 | Source for Auxiliary Copy was changed from [<String>] to [<String>]. |
| 85:75 | Old extended retention rule: <Message> ; Retention: Infinite |
| 85:76 | New extended retention rule: <Message> ; Retention: Infinite |
| 85:77 | Old extended retention rule: <Message> ; Retention days: <Number> |
| 85:78 | New extended retention rule: <Message> ; Retention days: <Number> |
| 85:79 | Copy to subclient association was changed. |
| 85:80 | Days to delay Auxiliary Copy was changed from [<Number>] to [<Number>]. |
| 85:81 | Financial calendar [<Number>] was now used by the copy. |
| 85:82 | Financial calendar was changed from [<Number>] to [<Number>]. |
| 85:83 | Option to create new store was changed from every [<Number>] days to [<Number>] days. |
| 85:84 | Option to create new store when size exceeds [<Number>] GB was changed to [<Number>] GB. |
| 85:85 | SILO - New on-demand backup set was created. |
| 85:86 | Financial calendar [<Number>] was removed from the copy. |
| 85:87 | Multiplexing factor was changed from [<Number>] to [<Number>]. |
| 85:88 | Combine stream flag was turned ON. |
| 85:89 | Combine stream flag was turned OFF. |
| 85:90 | Last full flag for selective Auxiliary Copy was turned ON. |
| 85:91 | Last full flag for selective Auxiliary Copy was turned OFF. |
| 85:92 | Time to use alternate data path when resources are offline was changed from [<Number>] to [<Number>]. |
| 85:93 | Switch data path if offline flag was turned on. |
| 85:94 | Switch data path if offline flag was turned off. |
| 85:95 | Time to use alternate data path where resources are busy was changed from [<Number>] to [<Number>]. |
| 85:96 | Switch data path if busy flag was turned on. |
| 85:97 | Switch data path if busy flag was turned off. |
| 85:98 | Reset selection flag was turned on. |
| 85:99 | Reset selection flag was turned off. |
| 85:100 | Demultiplexing on copy flag was turned on. |
| 85:101 | Demultiplexing on copy flag was turned off. |
| 85:102 | Mark media to be erased after recycling flag was turned on. |
| 85:103 | Mark media to be erased after recycling flag was turned off. |
| 85:104 | Data verification backups option was changed from [<Message>] to [<Message>]. |
| 85:105 | Data Path Configuration: Round-Robin between data paths option was turned on. |
| 85:106 | Data Path Configuration: Round-Robin between data paths option was turned off. |
| 85:107 | Inline Auxiliary Copy flag was turned on. |
| 85:108 | Inline Auxiliary Copy flag was turned off. |
| 85:109 | Auto copy flag was turned on. |
| 85:110 | Auto copy flag was turned off. |
| 85:111 | Last full wait flag was turned on. |
| 85:112 | Last full wait flag was turned off. |
| 85:113 | Auto add data path flag was turned on. |
| 85:114 | Auto add data path flag was turned off. |
| 85:115 | No inline copy to same library flag was turned on. |
| 85:116 | No inline copy to same library flag was turned off. |
| 85:117 | No Auxiliary Copy to same library flag was turned on. |
| 85:118 | No Auxiliary Copy to same library flag was turned off. |
| 85:119 | Store key on media flag was turned on. |
| 85:120 | Store key on media flag was turned off. |
| 85:121 | Deduplication was enabled for copy. |
| 85:122 | Deduplication was disabled for copy. |
| 85:123 | Legal hold flag was turned on. |
| 85:124 | Legal hold flag was turned off. |
| 85:125 | SILO - Option to back up deduplicated data was turned on. |
| 85:126 | SILO - Option to back up deduplicated data was turned off. |
| 85:127 | SILO - Option to keep most recent (active) silo in cache was turned on. |
| 85:128 | SILO - Option to keep most recent (active) silo in cache was turned off. |
| 85:129 | SIDB block level flag was turned on. |
| 85:130 | SIDB block level flag was turned off. |
| 85:131 | Remove data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:132 | Add data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:133 | Enable data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:134 | Disable data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:135 | Set data path default: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:136 | Set data path active: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:137 | Update scratch pool for data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:138 | Update data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>]. |
| 85:139 | Data path chunk size was changed from [<Number>] to [<Number>]. |
| 85:140 | Data path flush block size was changed from [<Number>] to [<Number>]. |
| 85:141 | Enable data path hardware compression. |
| 85:142 | Disable data path hardware compression. |
| 85:143 | Data path hardware encryption was changed from [<Number>] to [<Number>]. |
| 85:144 | Enable Content Indexing. |
| 85:145 | Disable Content Indexing. |
| 85:146 | Change retention days from [<Number>] to [<Number>]. |
| 85:147 | Change type from [<Number>] to [<Number>]. |
| 85:148 | Change flags from [<Number>] to [<Number>]. |
| 85:149 | Change cloudId from [<Number>] to [<Number>]. |
| 85:150 | Change start time from [<Number>] to [<Number>]. |
| 85:151 | Change source copy from [<String>] to [<String>]. |
| 85:152 | Change deferred days from [<Number>] to [<Number>]. |
| 85:153 | Change number of periods from [<Number>] to [<Number>]. |
| 85:154 | Change financial calendar from [<Number>] to [<Number>]. |
| 85:155 | Change day number from [<Number>] to [<Number>]. |
| 85:156 | Change number of readers from [<Number>] to [<Number>]. |
| 85:157 | Change minimum document size from [<Number>] KB to [<Number>] KB. |
| 85:158 | Change maximum document size from [<Number>] KB to [<Number>] KB. |
| 85:159 | Change exclude document type from [<String>] to [<String>]. |
| 85:160 | Change include document type from [<String>] to [<String>]. |
| 85:161 | Number of applications added was [<Number>]. |
| 85:162 | Number of applications deleted was [<Number>]. |
| 85:163 | Media Type: <String> |
| 85:164 | Drive Type: <String> |
| 85:165 | Library Type: <String> |
| 85:166 | Soft error threshold was changed from [<Number>] to [<Number>]. |
| 85:167 | Hard error threshold was changed from [<Number>] to [<Number>]. |
| 85:168 | Reuse threshold was changed from [<Number>] to [<Number>]. |
| 85:169 | Time threshold was changed from [<Number>] to [<Number>]. |
| 85:170 | Number of hours used since last clean threshold was changed from [<Number>] to [<Number>]. |
| 85:171 | Number of lifetime hours used threshold was changed from [<Number>] to [<Number>]. |
| 85:172 | Number of lifetime hard error threshold was changed from [<Number>] to [<Number>]. |
| 85:173 | Number of lifetime soft error threshold was changed from [<Number>] to [<Number>]. |
| 85:174 | Number of hard error since last clean threshold was changed from [<Number>] to [<Number>]. |
| 85:175 | Number of soft error since last clean threshold was changed from [<Number>] to [<Number>]. |
| 85:176 | Drive cleaning duration in second threshold was changed from [<Number>] to [<Number>]. |
| 85:177 | Number of lifetime hard error threshold was changed from [<Number>] to [<Number>]. |
| 85:178 | Number of lifetime soft error threshold was changed from [<Number>] to [<Number>]. |
| 85:179 | Number of hard error since last fix threshold was changed from [<Number>] to [<Number>]. |
| 85:180 | Number of soft error since last fix threshold was changed from [<Number>] to [<Number>]. |
| 85:181 | SAN Switch was deleted. |
| 85:182 | SAN Switch was added. |
| 85:183 | SAN Switch was updated. |
| 85:184 | Parameter [<String>] was changed from [<Number>] to [<Number>]. |
| 85:185 | New pattern: <String> |
| 85:186 | Media barcode pattern: <String> |
| 85:187 | Container: <String> |
| 85:188 | Container Capacity was changed from [<Number>] to [<Number>]. |
| 85:189 | Container Tracking ID was changed from [<String>] to [<String>]. |
| 85:190 | Drive: <String> |
| 85:191 | Library: <String> |
| 85:192 | Destination Library: <String> |
| 85:193 | Spare Group: <String> |
| 85:194 | Destination Spare Group: <String> |
| 85:195 | MediaAgent: <String> |
| 85:196 | Mount Path: <String> |
| 85:197 | New barcode: <String> |
| 85:198 | New location: <String> |
| 85:199 | New container: <String> |
| 85:200 | Prevent Export until: <String> |
| 85:201 | CommCell: <String> |
| 85:202 | Client: <String> |
| 85:203 | Client Name was changed from [<String>] to [<String>]. |
| 85:204 | Client CommServe Host Name was changed from [<String>] to [<String>]. |
| 85:205 | Client Host Name was changed from [<String>] to [<String>]. |
| 85:206 | Application Type: <String> |
| 85:207 | Instance: <String> |
| 85:208 | Backup Set: <String> |
| 85:209 | Replication Set: <String> |
| 85:210 | Replication Pair ID: <Number> |
| 85:211 | Subclient: <String> |
| 85:212 | New Subclient Name: <String> |
| 85:213 | MediaAgent: <String> |
| 85:214 | User Group: <String> |
| 85:215 | Login Name was changed to [<String>]. |
| 85:216 | Password was changed for administrator. |
| 85:217 | Scheduled task description: <String> |
| 85:218 | Schedule policy name: <String> |
| 85:219 | Activity: <String> |
| 85:220 | Status: Enabled |
| 85:221 | Status: Disabled |
| 85:222 | Server group: <String> |
| 85:223 | Search Engine: <String> |
| 85:224 | Legal Hold option was turned on. |
| 85:225 | Legal Hold option was turned off. |
| 85:226 | Allow Erase Data option was turned on. |
| 85:227 | Allow Erase Data option was turned off. |
| 85:228 | Auxiliary Copy Fallen Behind Alert was enabled. |
| 85:229 | Auxiliary Copy Fallen Behind Alert was disabled. |
| 85:230 | Randomize Stream option was turned on. |
| 85:231 | Randomize Stream option was turned off. |
| 85:232 | <String> |
| 85:233 | Library was enabled. |
| 85:234 | Library was disabled. |
| 85:235 | Change default spare group from [<String>] to [<String>]. |
| 85:236 | Media mount timeout was changed from [<Number>] to [<Number>]. |
| 85:237 | Media unmount timeout was changed from [<Number>] to [<Number>]. |
| 85:238 | Library configuration parameters were changed. |
| 85:239 | Option to use appendable media was enabled. |
| 85:240 | Option to use appendable media was disabled. |
| 85:241 | Drive clean interval was changed. |
| 85:242 | Option to use auto clean library was enabled. |
| 85:243 | Option to use auto clean library was disabled. |
| 85:244 | Option to mark drive needs cleaning on CRC error was enabled. |
| 85:245 | Option to mark drive needs cleaning on CRC error was disabled. |
| 85:246 | Auto discover option turned on |
| 85:247 | Auto discover option turned off |
| 85:248 | Option to Overwritten Media When Content Verification Fail was turned on. |
| 85:249 | Option to Overwritten Media When Content Verification Fail was turned off. |
| 85:250 | Ignore media content verification option was turned off (OMLs are checked) |
| 85:251 | Ignore media content verification option was turned on (ignore OML mismatch) |
| 85:252 | Overwrite media from a different CommCell option was enabled. |
| 85:253 | Overwrite media from a different CommCell option was disabled. |
| 85:254 | Automatic recovery of stuck tapes was disabled |
| 85:255 | Automatic recovery of stuck tapes was enabled. |
| 85:256 | Mark media full on export option was enabled. |
| 85:257 | Mark media full on export option was disabled. |
| 85:258 | Mark stuck media full option was enabled. |
| 85:259 | Mark stuck media full option was disabled. |
| 85:260 | Mark media appendable option was enabled. |
| 85:261 | Mark media appendable option was disabled. |
| 85:262 | Library Extended Attributes were changed. |
| 85:263 | Mount path [<String>] was disabled and became offline. |
| 85:264 | Mount path [<String>] was enabled and became ready. |
| 85:265 | Low water mark was change from [<Number>] to [<Number>]. |
| 85:266 | Overwrite media option was turned on. |
| 85:267 | Deduplication - Minimum size of object for Deduplication was changed from [<Number>] KB to [<Number>] KB. |
| 85:268 | Deduplication - Do not deduplicate against objects older than (number) of days option was changed from [<Number>] days to [<Number>] days. |
| 85:269 | Deduplication - Minimum free space option was changed from [<Number>] MB to [<Number>] MB. |
| 85:270 | Deduplication - Free space warning option was changed from [<Number>] MB to [<Number>] MB. |
| 85:271 | Deduplication Access Path: <String> |
| 85:272 | New Deduplication Access Path: <String> |
| 85:273 | Custom Calendar Name: <String> |
| 85:274 | Subclient Policy: <String> |
| 85:275 | Subclient Policy was renamed from [<String>] to [<String>]. |
| 85:276 | Workflow: <String> |
| 85:277 | Workflow was renamed from [<String>] to [<String>]. |
| 85:278 | Snap Volume Unit: <String> |
| 85:279 | Snap Volume Unit was renamed from [<String>] to [<String>]. |
| 85:280 | Encrypt Data: Yes |
| 85:281 | Encrypt Data: No |
| 85:282 | Restore Access: With a Passphrase |
| 85:283 | Restore Access: Regular |
| 85:284 | Direct Media Access: Via Media Password |
| 85:285 | Direct Media Access: Via Passphrase |
| 85:286 | Direct Media Access: No Access |
| 85:287 | Enable Synthetic Full: Yes |
| 85:288 | Enable Synthetic Full: No |
| 85:289 | Key Length was changed from [<Number>] to [<Number>]. |
| 85:290 | Export Location: [<String>] |
| 85:291 | Location Type: Stationary |
| 85:292 | Location Type: Transit |
| 85:293 | VaultTracker Policy: <String> |
| 85:294 | VaultTracker Policy was enabled. |
| 85:295 | VaultTracker Policy was disabled. |
| 85:296 | Auto Acknowledgement was turned on. |
| 85:297 | Auto Acknowledgement was turned off. |
| 85:298 | Use Virtual Mail Slot option was turned on. |
| 85:299 | Use Virtual Mail Slot option was turned off. |
| 85:300 | Use Transit Location option was turned on. |
| 85:301 | Use Transit Location option was turned off. |
| 85:302 | Old Container: [<String>] |
| 85:303 | New Container: [<String>] |
| 85:304 | Old Transit Location: [<String>] |
| 85:305 | New Transit Location: [<String>] |
| 85:306 | Old Container Pattern: [<String>] |
| 85:307 | New Container Pattern: [<String>] |
| 85:308 | Old Container Capacity: [<Number>] |
| 85:309 | New Container Capacity: [<Number>] |
| 85:310 | Export Delay Time in Minutes was changed from [<Number>] to [<Number>]. |
| 85:311 | Export Quit Time in Minutes was changed from [<Number>] to [<Number>]. |
| 85:312 | Old Destination: Library [<String>] |
| 85:313 | Old Destination: Any Library |
| 85:314 | Old Destination: Media Repository [<String>] |
| 85:315 | Old Destination: Export Location [<String>] |
| 85:316 | New Destination: Library [<String>] |
| 85:317 | New Destination: Any Library |
| 85:318 | New Destination: Media Repository [<String>] |
| 85:319 | New Destination: Export Location [<String>] |
| 85:320 | VaultTracker Action: <Number> |
| 85:321 | Iron Mountain ID: <String> |
| 85:322 | Pre-Import was turned off. |
| 85:323 | Pre-Import was turned on. |
| 85:324 | Enable option: Marking drive offline after error. |
| 85:325 | Disable option: Marking drive offline after error. |
| 85:326 | Enable Automatic Cleaning: Continue using drive even if it needs cleaning. |
| 85:327 | Disable Automatic Cleaning: Continue using drive even if it needs cleaning. |
| 85:328 | Enable option: Attempt to remove media from the drive when unload the stuck media fails. |
| 85:329 | Disable option: Attempt to remove media from the drive when unload the stuck media fails. |
| 85:330 | Enable Automatic Cleaning: When thresholds exceed. |
| 85:331 | Disable Automatic Cleaning: When thresholds exceed. |
| 85:332 | Enable option: Overwrite Media. |
| 85:333 | Disable option: Overwrite Media. |
| 85:334 | Enable option: Use exportable media for backups. |
| 85:335 | Disable option: Use exportable media for backups. |
| 85:336 | Enable option: Check for cleaning media loaded in Drive. |
| 85:337 | Disable option: Check for cleaning media loaded in Drive. |
| 85:338 | Enable option: Verify access path using Serial Number for Drive. |
| 85:339 | Disable option: Verify access path using Serial Number for Drive. |
| 85:340 | Enable check for tape alerts. |
| 85:341 | Disable check for tape alerts. |
| 85:342 | Enable option: Eject standalone media. |
| 85:343 | Disable option: Eject standalone media. |
| 85:344 | Enable option: Show CommCell Console popup. |
| 85:345 | Disable option: Show CommCell Console popup. |
| 85:346 | Enable standalone cache mount. |
| 85:347 | Disable standalone cache mount. |
| 85:348 | Enable option: Mark archive files as read only. |
| 85:349 | Disable option: Mark archive files as read only. |
| 85:350 | Enable option: Use SCSI-3 reservation. |
| 85:351 | Disable option: Use SCSI-3 reservation. |
| 85:352 | Library was changed to SN6000 library. |
| 85:353 | Library was changed to non-SN6000 library. |
| 85:354 | Enable option: Check for media change in drive. |
| 85:355 | Disable option: Check for media change in drive. |
| 85:356 | Enabled option: Disks within this library support Hardware Single Instancing. |
| 85:357 | Disabled option: Disks within this library support Hardware Single Instancing. |
| 85:358 | Enable option: Automatically create Storage Policy when data paths are created for library. |
| 85:359 | Disable option: Automatically create Storage Policy when data paths are created for library. |
| 85:360 | Enable retry on read error. |
| 85:361 | Disable retry on read error. |
| 85:362 | Enable option: Automatically adding data paths to storage policy copies when adding new drive pools. |
| 85:363 | Disable option: Automatically adding data paths to storage policy copies when adding new drive pools. |
| 85:364 | Mount path usage option was set to fill and spill. |
| 85:365 | Mount path usage option was set to spill and fill. |
| 85:366 | Enable SCSI 2 reservation. |
| 85:367 | Disable SCSI 2 reservation. |
| 85:368 | Disable option: Use media from a different spare group. |
| 85:369 | Enable option: Use media from a different spare group. |
| 85:370 | Enable barcode automatic update. |
| 85:371 | Disable barcode automatic update. |
| 85:372 | Enable option: Unload media in standalone drive when different media is required. |
| 85:373 | Disable option: Unload media in standalone drive when different media is required. |
| 85:374 | Enable option: Skip unload drive for autoloaders before move command. |
| 85:375 | Disable option: Skip unload drive for autoloaders before move command. |
| 85:376 | Enable option: Detect and update media type when media is loaded into the drive. |
| 85:377 | Disable option: Detect and update media type when media is loaded into the drive. |
| 85:378 | Reset container on assigned media option was enabled. |
| 85:379 | Reset container on assigned media option was disabled. |
| 85:380 | Enable option: Reset export location on assigned media. |
| 85:381 | Disable option: Reset export location on assigned media. |
| 85:382 | Library marked for maintenance. |
| 85:383 | Library taken out of maintenance. |
| 85:384 | Library was set to VTL library. |
| 85:385 | Library was set to non VTL library. |
| 85:386 | Enable option: Use only software spares. |
| 85:387 | Disable option: Use only software spares. |
| 85:388 | Low water mark of spare group has been changed from [<Number>] to [<Number>]. |
| 85:389 | High water mark of spare group has been changed from [<Number>] to [<Number>]. |
| 85:390 | Attributes of spare group has been changed from [<Number>] to [<Number>]. |
| 85:391 | Retention days for Index Cache [<Number>] has been changed from [<Number>] to [<Number>]. |
| 85:392 | Number of Media Moved: [<Number>] |
| 85:393 | Enable option to ignore job dependency check. |
| 85:394 | Disable option to ignore job dependency check. |
| 85:395 | Device name [<String>] (<String>) |
| 85:396 | Host name <String> <String> |
| 85:397 | Enable moving snapshot to back up media. |
| 85:398 | Disable moving snapshot to back up media. |
| 85:399 | Created Tag [<String>]: Category [<String>], Description [<String>], Owner [<String>]. |
| 85:400 | Updated Tag [<String>]: Changed description from [<String>] to [<String>]. |
| 85:401 | Cloned Tag [<String>] using Tag [<String>]. |
| 85:402 | Delete Tag: [<String>]. |
| 85:403 | Disabled Tag: [<String>]. |
| 85:404 | Enabled Tag: [<String>]. |
| 85:405 | Created Record Center [<String>]: URL [<String>], User [<String>], Domain [<String>], Type [<String>], Description [<String>]. |
| 85:406 | Updated Record Center [<String>]: Changed URL from [<String>] to [<String>], description from [<String>] to [<String>]. |
| 85:407 | Cloned Record Center [<String>] with [<String>]. |
| 85:408 | Delete Record Center: [<String>]. |
| 85:409 | Disabled Record Center: [<String>]. |
| 85:410 | Enabled Record Center: [<String>]. |
| 85:411 | Created Legal Hold [<String>]: Storage Policy [<String>], User [<String>], Domain [<String>], Description [<String>], retain until [<String>]. |
| 85:412 | Updated Legal Hold [<String>]: Changed retain until time from [<String>] to [<String>], description from [<String>] to [<String>]. |
| 85:413 | Delete Legal Hold: [<String>]. |
| 85:414 | Disabled Legal Hold: [<String>]. |
| 85:415 | Enabled Legal Hold: [<String>]. |
| 85:416 | Created Compliance Director [<String>]: Storage Policy [<String>], User [<String>], Domain [<String>], Description [<String>], retain until [<String>]. |
| 85:417 | Updated Compliance Director [<String>]: Changed retain until time from [<String>] to [<String>], description from [<String>] to [<String>]. |
| 85:418 | Delete Compliance Director: [<String>]. |
| 85:419 | Disabled Compliance Director: [<String>]. |
| 85:420 | Enabled Compliance Director: [<String>]. |
| 85:421 | Offline threshold for Index Cache [<Number>] has been changed from [<Number>] to [<Number>]. |
| 85:422 | Warning threshold for Index Cache [<Number>] has been changed from [<Number>] to [<Number>]. |
| 85:423 | MediaAgent was enabled. |
| 85:424 | MediaAgent was disabled. |
| 85:425 | Media Password for Storage Policy was changed. |
| 85:426 | Search Criteria: [<String>]. |
| 85:427 | Replication Policy: <String> |
| 85:428 | Client [<String>]: Preserve stubs until media has been pruned. |
| 85:429 | Client [<String>]: Prune stub only after [<Number>] days. |
| 85:430 | Domain [<String>] has been added. |
| 85:431 | Domain [<String>] has been deleted. |
| 85:432 | Domain [<String>] has been disabled. |
| 85:433 | Domain [<String>] has been enabled. |
| 85:434 | SSO on domain [<String>] has been disabled. |
| 85:435 | SSO on domain [<String>] has been enabled. |
| 85:436 | Created Filer Info [<String>]. |
| 85:437 | Updated Filer Info [<String>]:Changed host name from [<String>] to [<String>], User Name from [<String>] to [<String>].. |
| 85:438 | Deleted Filer Info [<String>]. |
| 85:439 | Instance was configured for [<String>]. |
| 85:440 | ESX Server [<String>] Added. |
| 85:441 | ESX Server [<String>] Removed. |
| 85:442 | ESX Server [<String>] Updated. |
| 85:443 | Virtual Server Credentials Updated. |
| 85:444 | Automatic add of new VMs Disabled. |
| 85:445 | Automatic add of new VMs Enabled. |
| 85:446 | Rule-based discovery set to match guest host names by regular expression. |
| 85:447 | Rule-based discovery set to ESX Server Affinity. |
| 85:448 | Regular Expression for rule based discovery changed. |
| 85:449 | Subclient Assignment for Server Affinity changed. |
| 85:450 | Source Client Name : <String>. |
| 85:451 | Source Mount Path : <String>. |
| 85:452 | Destination Client Name : <String>. |
| 85:453 | Mount Path : <String>. |
| 85:454 | Snapshot Timestamp : <String>. |
| 85:455 | Number of snapshots : <Number>. |
| 85:456 | Created Schedule Holiday [<String>]. |
| 85:457 | Updated Schedule Holiday [<String>]. |
| 85:458 | Deleted Schedule Holiday [<String>]. |
| 85:459 | Old Description : <String> |
| 85:460 | New Description : <String> |
| 85:461 | Rule Name : <String> |
| 85:462 | Farm Name : <String> |
| 85:463 | User Group: <String> has been enabled. |
| 85:464 | User Group: <String> has been disabled. |
| 85:465 | Media ID : <Number>. |
| 85:466 | Drive ID : <Number>. |
| 85:467 | Snapshot Name : <String> |
| 85:468 | Script Name: <String> |
| 85:469 | Script Parameters: <String> |
| 85:470 | Primary |
| 85:471 | Synchronous |
| 85:472 | Selective |
| 85:473 | Snap |
| 85:474 | Index |
| 85:475 | Log |
| 85:476 | Storage Policy Copy Type: <Message> |
| 85:477 | Deduplication Store Sealed: <String> |
| 85:478 | Deduplication Store Created: <String> |
| 85:479 | Promoted to primary snap copy. |
| 85:480 | Data Path Configuration: Use preferred data path option was turned on. |
| 85:481 | Data Path Configuration: Use preferred data path option was turned off. |
| 85:482 | Deduplication type is set to object level. |
| 85:483 | Deduplication type is set to block level. |
| 85:484 | SILO - Space management option was enabled. |
| 85:485 | SILO - Space management option was disabled. |
| 85:486 | Change Search Engine from [<String>] to [<String>]. |
| 85:487 | Deduplication - Software compression option was enabled. |
| 85:488 | Deduplication - Software compression option was disabled. |
| 85:489 | Created ERM Connector [<String>]: Record Center [<String>], Description [<String>]. |
| 85:490 | Updated ERM Connector [<String>]: Changed Name to [<String>], Record Center from [<String>] to [<String>], description from [<String>] to [<String>]. |
| 85:491 | Cloned ERM Connector [<String>] with [<String>]. |
| 85:492 | Delete ERM Connector: [<String>]. |
| 85:493 | Disabled ERM Connector: [<String>]. |
| 85:494 | Enabled ERM Connector: [<String>]. |
| 85:495 | Handle Unassociated Guest Hosts has been enabled. |
| 85:496 | Handle Unassociated Guest Hosts has been disabled. |
| 85:497 | Deduplication - Select the number of instances option was changed from [<Number>] to [<Number>]. |
| 85:498 | Rule-Based Discovery Disabled. |
| 85:499 | Rule-Based Discovery Enabled. |
| 85:500 | Data Path Configuration: Use alternate data paths when resources are offline after (number) of hours and minutes were changed from [<Number>] hours and [<Number>] minutes to [<Number>] hours and [<Number>] minutes. |
| 85:501 | Data Path Configuration: Use alternate data paths when resources are offline option was turned on. |
| 85:502 | Data Path Configuration: Use alternate data paths when resources are offline option was turned off. |
| 85:503 | Data Path Configuration: Use alternate data paths when resources are busy after (number) of hours and minutes were changed from [<Number>] hours and [<Number>] minutes to [<Number>] hours and [<Number>] minutes. |
| 85:504 | Data Path Configuration: Use alternate data paths when resources are busy option was turned on. |
| 85:505 | Data Path Configuration: Use alternate data paths when resources are busy option was turned off. |
| 85:506 | Updated Record Center [<String>]: Changed Name to [<String>], URL from [<String>] to [<String>], description from [<String>] to [<String>]. |
| 85:507 | Created Content Director Policy: [<String>]. |
| 85:508 | Updated Content Director Policy: [<String>]. |
| 85:509 | Delete Content Director Policy: [<String>]. |
| 85:510 | Disabled Content Director Policy: [<String>]. |
| 85:511 | Enabled Content Director Policy: [<String>]. |
| 85:512 | Updated Filer Info [<String>]: Changed User Name from [<String>] to [<String>], Snap Engine from [<String>] to [<String>], description from [<String>] to [<String>], Device Group name from [<String>] to [<String>]. |
| 85:513 | Description was modified from [<String>] to [<String>]. |
| 85:514 | Media Name : [<String>] |
| 85:515 | Groups Added : [<String>] |
| 85:516 | Groups Removed : [<String>] |
| 85:517 | Billable Entity ID: <Number> |
| 85:518 | Cost Category ID: <Number> |
| 85:519 | Subclient ID: <Number> |
| 85:520 | Storage Device ID: <Number> |
| 85:521 | Storage Device Type: <Number> |
| 85:522 | Warehousing Interval in Days: <Number> |
| 85:523 | Retention Type: <String> |
| 85:524 | Retention Days: <Number> |
| 85:525 | CommServe Name was changed from [<String>] to [<String>]. |
| 85:526 | CommServe Name was changed from [<String>] to [<String>]. |
| 85:527 | CommServe Name was changed On <String>. |
| 85:528 | Failed to Change CommServe Name On <String>. |
| 85:529 | Time Zone Type was changed from [<Number>] to [<Number>]. |
| 85:530 | Time Zone was changed from [<String>] to [<String>]. |
| 85:531 | Index Access Path Set [<String>] for MediaAgent [<String>]. |
| 85:532 | Index Cache created : [<String>] |
| 85:533 | Index Cache removed : [<String>] |
| 85:534 | Index Cache modified : [<String>] |
| 85:535 | Job ID: All |
| 85:536 | Is SILO Data Path : [<String>] |
| 85:537 | Old MediaAgent : [<String>] |
| 85:538 | Rule-based discovery set to match guest host names by resource pool affinity. |
| 85:539 | Rule-based discovery set to match guest host names by data store affinity. |
| 85:540 | Backup staging directory changed from [<String>] to [<String>] |
| 85:541 | Content Indexing |
| 85:542 | Snap Backup |
| 85:543 | Description |
| 85:544 | Resource File |
| 85:545 | Job Priority |
| 85:546 | Update Agent |
| 85:547 | Store Patch Locally |
| 85:548 | Store Patch Location |
| 85:549 | Proxy Client for Search |
| 85:550 | Proxy Host |
| 85:551 | Prune job results when disk capacity percentage reaches |
| 85:552 | Prune job results after (days) |
| 85:553 | Default Network Interface |
| 85:554 | Client Name |
| 85:555 | Host Name |
| 85:556 | CommServe Host Name |
| 85:557 | Client alternate cache partition |
| 85:558 | URL for Compliance Search |
| 85:559 | URL for end user Search |
| 85:560 | URL for Administrator |
| 85:561 | Proxy client for Exchange |
| 85:562 | Exchange Web server for Search |
| 85:563 | Snapshot engine |
| 85:564 | Exchange mining Tool Path |
| 85:565 | Collect Delegate Information |
| 85:566 | Do not Single Instance email |
| 85:567 | CDR Log Location |
| 85:568 | Encryption |
| 85:569 | RSA public key |
| 85:570 | Synthetic Full |
| 85:571 | Restore Access |
| 85:572 | Direct Media Access |
| 85:573 | Pass Phrase changed |
| 85:574 | Cipher |
| 85:575 | BlowFish |
| 85:576 | 3-DES |
| 85:577 | AES(Rijndael) |
| 85:578 | Serpent |
| 85:579 | TwoFish |
| 85:580 | Key Length |
| 85:581 | Regular |
| 85:582 | With a Passphrase |
| 85:583 | Via Media Password |
| 85:584 | Via Passphrase |
| 85:585 | No Access |
| 85:586 | Global Zone Host Name |
| 85:587 | Policy Name <String> |
| 85:588 | New CCP added. |
| 85:589 | Policy Deleted. |
| 85:590 | Policy Modified. |
| 85:591 | Cloned from %1s. |
| 85:592 | Unknown operation [<Number>] requested. |
| 85:593 | Client <String> added to CCP. |
| 85:594 | Client <String> removed from CCP. |
| 85:595 | Application <String> added to CCP. |
| 85:596 | Application <String> removed from CCP. |
| 85:597 | Operation by user <String> with insufficient credentials denied. |
| 85:598 | Error returned from operation. Code[<Number>], [<String>]. |
| 85:599 | File level Analytics License |
| 85:600 | Deprecated message [<String>]. |
| 85:601 | Deprecated message [<String>]. |
| 85:602 | Deprecated message [<String>] [<String>]. |
| 85:603 | Deprecated message [<String>] [<String>]. |
| 85:604 | Deprecated message [<String>] [<String>]. |
| 85:605 | Enable mining snapshot. |
| 85:606 | Disable mining snapshot. |
| 85:607 | Option to decrypt RMS document during content indexing is enabled |
| 85:608 | Option to decrypt RMS document during content indexing is disabled |
| 85:609 | Decrypt RMS document username changed from [<String>] to [<String>]. |
| 85:610 | Decrypt RMS document password modified. |
| 85:611 | The destination storage policy has been set to NOT ASSIGNED |
| 85:612 | FTP Site was modified from [<String>] to [<String>] |
| 85:613 | FTP User Name was modified from [<String>] to [<String>] |
| 85:614 | Time Zone was set to [<String>]. |
| 85:615 | Old Grace Days [<Number>] |
| 85:616 | New Grace Days [<Number>] |
| 85:617 | Enable option to select jobs from previous tier. |
| 85:618 | Disable option to select jobs from previous tier. |
| 85:619 | Hosted Exchange Property has been [<String>]. |
| 85:620 | FTP Password was changed. |
| 85:621 | Perform DeDuplication Property is enabled on Client [<String>]. |
| 85:622 | Perform DeDuplication Property is disabled on Client [<String>]. |
| 85:623 | Intelligent Block Alignment is enabled on Client [<String>]. |
| 85:624 | Intelligent Block Alignment is disabled on Client [<String>]. |
| 85:625 | Buffer Cache size on client [<String>] is changed from [<Number>] to [<Number>]. |
| 85:626 | <String>: changed from [<String>] to [<String>] |
| 85:627 | Enable option: PnP disk based. |
| 85:628 | Disable option: PnP disk based. |
| 85:629 | Enable option: Only use PnP disk when it is blank. |
| 85:630 | Disable option: Only use PnP disk when it is blank. |
| 85:631 | Enable option: Auto drive replacement. |
| 85:632 | Disable option: Auto drive replacement. |
| 85:633 | Enable option: Submit full scan upon empty barcode. |
| 85:634 | Disable option: Submit full scan upon empty barcode. |
| 85:635 | Enable option: Simple Data Replication. |
| 85:636 | Disable option: Simple Data Replication. |
| 85:637 | Enable option: Use Import/Export bit for Import. |
| 85:638 | Disable option: Use Import/Export bit for Import. |
| 85:639 | Enable option: Prevent accidental deletion. |
| 85:640 | Disable option: Prevent accidental deletion. |
| 85:641 | Enable option: Use unbuffered I/O. |
| 85:642 | Disable option: Use unbuffered I/O. |
| 85:643 | Enable option: Use mount path only for SILO restores. |
| 85:644 | Disable option: Use mount path only for SILO restores. |
| 85:645 | Software Share changed from [<String>] to [<String>] |
| 85:646 | Signature Cache size on client [<String>] is changed from [<Number>] to [<Number>]. |
| 85:647 | Max DB Cache size on client [<String>] is changed from [<Number>] to [<Number>]. |
| 85:648 | Rule-based discovery set to match guest host names by O.S. Group affinity |
| 85:649 | Schedules for user [<String>] have been changed to user [<String>]. |
| 85:650 | [<String>] enabled. |
| 85:651 | [<String>] disabled. |
| 85:652 | Login : UserName [<String>] for site mode [<String>] |
| 85:653 | Login Failure : UserName [<String>] for sitemode [<String>] with Error Code [<String>] |
| 85:654 | Operation [<String>] performed by User [<String>] on container [<String>] with Total Items : [<Number>] |
| 85:655 | Retrieve performed by User [<String>] with total items : [<Number>] |
| 85:656 | <String> restore performed by User [<String>] with total items : [<Number>] |
| 85:657 | User [<String>] submitted [<Number>] items to ERM Connector [<String>] with Record Center URL [<String>] |
| 85:658 | Archived <String> item downloaded by User [<String>] of size [<String>] with item ID [<String>] |
| 85:659 | Offline Result Item download by User [<String>] of size [<String>] with result item ID [<String>] |
| 85:660 | Online Result Item download by User [<String>] with URL [<String>] |
| 85:661 | User [<String>] added comment for the Result Item ID [<String>] on Container [<String>] |
| 85:662 | Performed Legal hold operation. Legal hold Job ID : [<Number>] |
| 85:663 | Operation <String> performed for tags [<String>] for [<Number>] result items |
| 85:664 | Operation <String> performed for tags [<String>] on Container [<String>] |
| 85:665 | Registry key [<String>] is added at [<String>] with value [<String>]. |
| 85:666 | Registry key [<String>] is added at [<String>] with value [<String>] and is disabled. |
| 85:667 | Registry key [<String>] at [<String>] is deleted. |
| 85:668 | Registry key [<String>] at [<String>] is disabled. |
| 85:669 | Registry key [<String>] at [<String>] is enabled. |
| 85:670 | Registry key [<String>] at [<String>] is changed from [<String>] to [<String>]. |
| 85:671 | Registry key [<String>] at [<String>] is changed from [<String>] to [<String>] and is enabled. |
| 85:672 | Registry key [<String>] at [<String>] is changed from [<String>] to [<String>] and is disabled. |
| 85:673 | RMS SMTP Address changed from [<String>] to [<String>] |
| 85:674 | Orphaned Job ID: [<Number>] |
| 85:675 | Volume Reconciliation Job ID: [<Number>] |
| 85:676 | License Type: <String> |
| 85:677 | Change entity IDs from [<String>] to [<String>]. |
| 85:678 | User [<String>] logged in successfully. |
| 85:679 | User logged out successfully. |
| 85:680 | User: [<String>] Reference Count : [<Number>] |
| 85:681 | User log out failed |
| 85:682 | User [<String>] login failed. |
| 85:683 | Managed disk space set to [<Number>] for Library [<String>]. |
| 85:684 | Managed disk space variation set to [<Number>] for Library [<String>]. |
| 85:685 | Billable Entity Name: <String> |
| 85:686 | Cost Category Name: <String> |
| 85:687 | Remove data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>] Library [<String>]. |
| 85:688 | All |
| 85:689 | Data Classification |
| 85:690 | <String> services were restarted for Client : [<String>]. |
| 85:691 | <String> services were stopped for Client : [<String>]. |
| 85:692 | ISS server alternate URL enabled/disabled. |
| 85:693 | IIS web URL changed. |
| 85:694 | IIS server name changed from [<String>] to [<String>]. |
| 85:695 | IIS server port changed from [<Number>] to [<Number>]. |
| 85:696 | IIS server SSL flag changed from [<Number>] to [<Number>]. |
| 85:697 | IIS server HTTP protocol changed from [<Number>] to [<Number>]. |
| 85:698 | IIS server book online alias changed from [<String>] to [<String>]. |
| 85:699 | Use alternate IIS server option changed by user [<String>]. |
| 85:700 | IIS Server Username changed from [<String>] to [<String>]. |
| 85:701 | IIS Server password changed by user [<String>]. |
| 85:702 | Maintenance advantage username changed by user [<String>]. |
| 85:703 | Maintenance advantage password changed by user [<String>]. |
| 85:704 | KB Link for JPR Username changed by user [<String>]. |
| 85:705 | KB Link for JPR password changed by user [<String>]. |
| 85:706 | IIS server install location changed from [<String>] to [<String>]. |
| 85:707 | Job Controller Job Retention Time changed from [<Number>] to [<Number>]. |
| 85:708 | Scheduler has been enabled/disabled. |
| 85:709 | SNMP Traps Support has been enabled and is set to [<Number>]. |
| 85:710 | Secure Agent install has been changed by user [<String>]. |
| 85:711 | Audit Trail retention time changed from [<Number>] to [<Number>] days. |
| 85:712 | Audit Trail retention time changed by user [<String>]. |
| 85:713 | Queue Jobs If Other Jobs Running Option changed by user [<String>]. |
| 85:714 | Queued Jobs if activity is disabled was changed by user [<String>]. |
| 85:715 | Disable Software Update Reboot Option changed by user [<String>]. |
| 85:716 | ER Storage Policy changed to [<String>]. |
| 85:717 | Express Recovery user name changed by user [<String>]. |
| 85:718 | Mail Server changed from [<String>] to [<String>]. |
| 85:719 | Mail Sender's Address changed from [<String>] to [<String>]. |
| 85:720 | SMTP Port number changed from [<Number>] to [<Number>]. |
| 85:721 | SMTP Max Message Size changed from [<Number>]KB to [<Number>]KB. |
| 85:722 | Express Recovery User name and password deleted by user [<String>]. |
| 85:723 | Express Recovery user password was changed by user [<String>]. |
| 85:724 | Maximum Events in event log changed from [<Number>] to [<Number>]. |
| 85:725 | GUI Timeout changed from [<Number>] to [<Number>]. |
| 85:726 | Job Alive Retry changed from [<Number>] to [<Number>]. |
| 85:727 | Job Alive check interval changed from [<Number>] to [<Number>]. |
| 85:728 | Job high watermark changed from [<Number>] to [<Number>]. |
| 85:729 | Job low watermark changed from [<Number>] to [<Number>]. |
| 85:730 | Job Priority Precedence Changed. |
| 85:731 | Show aged data item flag changed. |
| 85:732 | Queue Scheduled Jobs Option has been changed by user [<String>]. |
| 85:733 | Do not start backup on disable clients flag has been changed by user [<String>]. |
| 85:734 | Multiplexing for Oracle has been changed by user [<String>]. |
| 85:735 | Backup preemption of other backups has been changed by user [<String>]. |
| 85:736 | Restore preemption of other jobs has been changed by user [<String>]. |
| 85:737 | Backup preemption of Auxiliary Copy and Synthetic Fulls has been changed by user [<String>]. |
| 85:738 | [<String>] priority changed from [<Number>] to [<Number>]. |
| 85:739 | Express Recovery wild card for client log backup changed from [<String>] to [<String>]. |
| 85:740 | Express Recovery Destination Directory changed to [<String>]. |
| 85:741 | Disaster Recovery Number of Fulls changed from [<Number>] to [<Number>]. |
| 85:742 | Database Space Check Interval changed by user [<String>]. |
| 85:743 | Database Space Check Informational Percent Free changed from [<Number>] to [<Number>]. |
| 85:744 | Database Space Check Minor Percent Free changed from [<Number>] to [<Number>]. |
| 85:745 | Database Space Check Major Percent Free changed from [<Number>] to [<Number>]. |
| 85:746 | Database Space Check Critical Percent Free changed from [<Number>] to [<Number>]. |
| 85:747 | Data Replicator Update Interval changed from [<Number>] to [<Number>]. |
| 85:748 | Data Classification Update Interval changed from [<Number>] to [<Number>]. |
| 85:749 | Auto Suppress Web Restores Option changed by user [<String>]. |
| 85:750 | Visibility Checking flag has been changed by user [<String>]. |
| 85:751 | Use exact index flag for restore has been changed by user [<String>]. |
| 85:752 | Client name changed by user [<String>]. |
| 85:753 | Database updated for client name changed by user [<String>]. |
| 85:754 | DR PreScan Command changed from [<String>] to [<String>]. |
| 85:755 | DR PostScan Command changed from [<String>] to [<String>]. |
| 85:756 | DR PreBackup Command changed from [<String>] to [<String>]. |
| 85:757 | DR PostBackup Command changed from [<String>] to [<String>]. |
| 85:758 | 'Use Pre/Post user' option for DR Backup changed by user [<String>]. |
| 85:759 | DR Backup Pre/Post Password changed by user [<String>]. |
| 85:760 | Disaster Recovery Backup Pre/Post Commands saved by user [<String>]. |
| 85:761 | User description has been changed. |
| 85:762 | SQL authentication mode set to [<String>]. |
| 85:763 | SQL authentication username changed by user [<String>]. |
| 85:764 | SQL authentication password changed by user [<String>]. |
| 85:765 | Network error retry parameters changed by user [<String>]. |
| 85:766 | Password check on login to the CommServe has been [<String>]. |
| 85:767 | SMTP mail SSL/TLS flag changed by user [<String>]. |
| 85:768 | SMTP mail credential flag changed by user [<String>]. |
| 85:769 | SMTP user password changed by user [<String>]. |
| 85:770 | SMTP user name changed from [<String>] to [<String>]. |
| 85:771 | SMTP user display name changed from [<String>] to [<String>]. |
| 85:772 | Add data path: MediaAgent [<String>] Drive Pool [<String>] Scratch Pool [<String>] Library [<String>]. |
| 85:773 | DB: <String> |
| 85:774 | Data collection method changed from [<Number>] to [<Number>]. |
| 85:775 | SQL login database name changed from [<String>] to [<String>]. |
| 85:776 | SQL login instance name changed from [<String>] to [<String>]. |
| 85:777 | SQL login user name changed from [<String>] to [<String>]. |
| 85:778 | SQL login password changed. |
| 85:779 | <String> Combined Priority changed from <Number> to <Number> |
| 85:780 | Deduplication is currently active for the copy. |
| 85:781 | Deduplication is currently inactive for the copy. |
| 85:782 | Enable Deduplication on Clients |
| 85:783 | Disable Deduplication on Clients |
| 85:784 | Operation [<String>] performed by User [<String>] on Review set [<String>]. [<Number>] items were added. [<Number>] items are already present and hence skipped. |
| 85:785 | <String> job ran by schedule: <String> |
| 85:786 | Maximum allowed source job application size is changed from [<Number>] MB to [<Number>] MB. |
| 85:787 | Manage Virtual Machine plug-in registration succeeded on vCenter [<String>]. |
| 85:788 | Manage Virtual Machine plug-in un-registration succeeded on vCenter [<String>]. |
| 85:789 | Old snap retention jobs: <Number> |
| 85:790 | New snap retention jobs: <Number> |
| 85:791 | 'Limit simultaneous running jobs' is enabled on Client [<String>]. |
| 85:792 | 'Limit simultaneous running jobs' is disabled on Client [<String>]. |
| 85:793 | Maximum number of running data jobs on client [<String>] is changed from [<Number>] to [<Number>]. |
| 85:794 | Maximum number of running log jobs on client [<String>] is changed from [<Number>] to [<Number>]. |
| 85:795 | 'Exclude immediate jobs' is enabled on client [<String>]. |
| 85:796 | 'Exclude immediate jobs' is disabled on client [<String>]. |
| 85:797 | Library [<String>] - Barcode [<String>] was replaced with [<String>] |
| 85:798 | Library [<String>] - added suffix [<String>] |
| 85:799 | Library [<String>] - added prefix [<String>] |
| 85:800 | Library [<String>] - removed suffix [<String>] |
| 85:801 | Library [<String>] - removed prefix [<String>] |
| 85:802 | Option to create new store changed from <Number> (<String>) to <Number> (<String>). |
| 85:803 | Days |
| 85:804 | Months |
| 85:805 | Start Date [<String>]. |
| 85:806 | Maintenance advantage username changed by user [<String>] from [<String>] to [<String>]. |
| 85:807 | KB Link for JPR Username changed by user [<String>] from [<String>] to [<String>]. |
| 85:808 | Secure Agent install has been [<String>] by user [<String>]. |
| 85:809 | Use alternate IIS server option selected by user [<String>]. |
| 85:810 | Use alternate IIS server option deselected by user [<String>]. |
| 85:811 | SQL authentication username changed by user [<String>] from [<String>] to [<String>]. |
| 85:812 | IIS server HTTP protocol changed from [<String>] to [<String>]. |
| 85:813 | Express Recovery user name changed by user [<String>] from [<String>] to [<String>]. |
| 85:814 | Filer [<String>]. |
| 85:815 | Credentials Changed. |
| 85:816 | Path changed from [<String>] to [<String>]. |
| 85:817 | Filer name changed from [<String>] to [<String>]. |
| 85:818 | HTTP_CIFS address changed from [<String>] to [<String>]. |
| 85:819 | NAS HTTP port changed from [<String>] to [<String>]. |
| 85:820 | Proxy file Expiration changed from [<String>] to [<String>]. |
| 85:821 | Prune interval changed from [<String>] to [<String>]. |
| 85:822 | Primary client changed from [<String>] to [<String>]. |
| 85:823 | Secondary client changed from [<String>] to [<String>]. |
| 85:824 | Filer [<String>] associated with subClient. |
| 85:825 | Filer [<String>] no longer associated with subClient. |
| 85:826 | Network Throttle was changed from [<Number>] to [<Number>]. |
| 85:827 | Drive Enabled |
| 85:828 | Drive Disabled |
| 85:829 | Drive was marked for maintenance. |
| 85:830 | Drive was un-marked for maintenance. |
| 85:831 | MediaAgent marked for maintenance. |
| 85:832 | MediaAgent taken out of maintenance. |
| 85:833 | <String>: Set to [<String>] |
| 85:834 | <String>: Reverted back to original from [<String>] |
| 85:835 | <String>: Yes |
| 85:836 | <String>: Was Selected |
| 85:837 | <String>: Was not Selected |
| 85:838 | <String>: No |
| 85:839 | Client [<String>] has been set as the Proxy Client for this subClient. |
| 85:840 | Proxy Client for this subClient has been changed from [<String>] to [<String>]. |
| 85:841 | Amazon Center Credentials Updated. |
| 85:842 | <String> |
| 85:843 | Xml Root |
| 85:844 | Deduplication : Changed Dash full Disk Read Optimized from [<String>] to [<String>]. |
| 85:845 | Deduplication : Changed Store Priming from [<String>] to [<String>]. |
| 85:846 | Locale: <String> |
| 85:847 | Tool : <String> |
| 85:848 | Run on : <String> |
| 85:849 | Impersonate User : <String> |
| 85:850 | Tool Alias : <String> |
| 85:851 | Description : <String> |
| 85:852 | Parameters : <String> |
| 85:853 | Deduplication : Changed Dash full Network Optimized from [<String>] to [<String>]. |
| 85:854 | Users [<String>] are disconnected with comment [<String>] |
| 85:855 | Removed pattern: <String> |
| 85:856 | Operation : <String> |
| 85:857 | Machine: <String> |
| 85:858 | Startup Path : <String> |
| 85:859 | Operating System : <String> |
| 85:860 | Associated To : <String> |
| 85:861 | Visibility : <String> |
| 85:862 | Execute Tool |
| 85:863 | Add Tool |
| 85:864 | Modify Tool |
| 85:865 | Delete Tool |
| 85:866 | Undefined Operation |
| 85:867 | Client |
| 85:868 | CommServe |
| 85:869 | CommCell Console |
| 85:870 | Windows |
| 85:871 | Unix |
| 85:872 | Unknown |
| 85:873 | All |
| 85:874 | MediaAgent |
| 85:875 | Client |
| 85:876 | CommServe |
| 85:877 | Public |
| 85:878 | Private |
| 85:879 | Option Not Set |
| 85:880 | Auto update SCSI ID during live operation was turned ON. |
| 85:881 | Auto update SCSI ID during live operation was turned OFF. |
| 85:882 | Use Native device driver for data transfer for tape media was turned ON. |
| 85:883 | Use Native device driver for data transfer for tape media was turned OFF. |
| 85:884 | Optimize for concurrent LAN backups was turned ON. |
| 85:885 | Optimize for concurrent LAN backups was turned OFF. |
| 85:886 | Mark drive inaccessible on error and perform status check was turned ON. |
| 85:887 | Mark drive inaccessible on error and perform status check was turned OFF. |
| 85:888 | Enable Application Level Error Recovery during backups was turned ON. |
| 85:889 | Enable Application Level Error Recovery during backup was turned OFF. |
| 85:890 | Auto detect WORM media was turned ON. |
| 85:891 | Auto detect WORM media was turned OFF. |
| 85:892 | Auto Discover Disk Array was turned ON. |
| 85:893 | Auto Discover Disk Array was turned OFF. |
| 85:894 | Data integrity validation on network was turned ON. |
| 85:895 | Data integrity validation on network was turned OFF. |
| 85:896 | Data integrity validation on media was turned ON. |
| 85:897 | Data integrity validation on media was turned OFF. |
| 85:898 | Send pass thru commands to Atape was turned ON. |
| 85:899 | Send pass thru commands to Atape was turned OFF. |
| 85:900 | Distribute data evenly across destination media set for Auxiliary Copy was turned ON. |
| 85:901 | Distribute data evenly across destination media set for Auxiliary Copy was turned OFF. |
| 85:902 | FileSystem IdaAgent added to client [<String>]. |
| 85:903 | Warning water mark was change from [<Number>] to [<Number>]. |
| 85:904 | Old Every X Hours [<Number>] |
| 85:905 | New Every X Hours [<Number>] |
| 85:906 | For daily full rule the minutes since day starts was changed from [<Number>] to [<Number>]. |
| 85:907 | hourly Full |
| 85:908 | daily Full |
| 85:909 | JVM Max Memory modified from [<Number>] to [<Number>]. |
| 85:910 | JVM Min Memory modified from [<Number>] to [<Number>]. |
| 85:911 | RAM Buffer Size (MB) Configuration modified from [<String>] to [<String>]. |
| 85:912 | No. of Segments Configuration modified from [<String>] to [<String>]. |
| 85:913 | Document Processing Timeout(seconds) Configuration modified from [<String>] to [<String>]. |
| 85:914 | Unzip Size Limit (MB) Configuration modified from [<String>] to [<String>]. |
| 85:915 | Zipped Size Limit (MB) Configuration modified from [<String>] to [<String>]. |
| 85:916 | Sequentially Process Files Greater Than (MB) Configuration modified from [<String>] to [<String>]. |
| 85:917 | Consider Incremental Snap Jobs as Full option changed from [<String>] to [<String>]. To 'Allow all Snap backups for Snap Selection Rules' |
| 85:918 | Consider Incremental Snap Jobs as Full option changed from [<String>] to [<String>]. |
| 85:919 | Web Server Client Name modified from [<String>] to [<String>] on WebClient [<String>]. |
| 85:920 | Web Server Host Name modified from [<String>] to [<String>] on WebClient [<String>]. |
| 85:921 | Added Client [<String>] to Server group [<String>]. |
| 85:922 | Removed Client [<String>] from Server group [<String>]. |
| 85:923 | Multiplexing for database agents(non Oracle/RAC) has been changed by user [<String>]. |
| 85:924 | New content group[<String>] added with contents[<String>]. |
| 85:925 | Content group[<String>] removed. |
| 85:926 | Contents[<String>] added to content group[<String>]. |
| 85:927 | Contents[<String>] removed from content group[<String>]. |
| 85:928 | Deduplication : Changed partition availability from [<Number>] to [<Number>]. |
| 85:929 | Error Code : [<Number>] |
| 85:930 | Error Message : [<String>] |
| 85:931 | Process ID : [<Number>] |
| 85:932 | Output : [<String>] |
| 85:933 | Process Exit Code : [<Number>] |
| 85:934 | Media Refresh flag was turned ON. |
| 85:935 | Media Refresh flag was turned OFF |
| 85:936 | Days after media were written is set to [<Number>]. |
| 85:937 | Days before media is aged is set to [<Number>]. |
| 85:938 | Percentage of media capacity is set to [<Number>]. |
| 85:939 | Media retirement threshold exceeded is set to [<Number>]. |
| 85:940 | Days after media were written was changed from [<Number>] to [<Number>]. |
| 85:941 | Days before media is aged was changed from [<Number>] to [<Number>]. |
| 85:942 | Percentage of media capacity was changed from [<Number>] to [<Number>]. |
| 85:943 | Media retirement threshold exceeded was changed from [<Number>] to [<Number>]. |
| 85:944 | The Move Partition operation on storage policy [<String>] copy [<String>] from MediaAgent [<String>], location [<String>] to MediaAgent [<String>], location [<String>] completed successfully. |
| 85:945 | The Move Partition operation on storage policy [<String>] copy [<String>] from MediaAgent [<String>], location [<String>] to MediaAgent [<String>], location [<String>] failed. |
| 85:946 | View Image Preview for PPT Configuration modified from [<String>] to [<String>]. |
| 85:947 | Deduplication: Store availability option - Allow jobs to run with unavailable partitions modified from [<String>] to [<String>]. |
| 85:948 | Deduplication: Store availability option set to [<String>]. |
| 85:949 | Failover |
| 85:950 | Auto Reconstruction |
| 85:951 | On Demand Reconstruction |
| 85:952 | Client Side Deduplication [<String>]. |
| 85:953 | SILO: Remove DDB [<String>]. |
| 85:954 | Deduplication: Partition on path [<String>] marked for recovery. |
| 85:955 | Combine source data streams was changed from [<Number>] to [<Number>]. |
| 85:956 | User Name: <String> |
| 85:957 | CommServe: <String> |
| 85:958 | The Move Partition operation [Path update only] on storage policy [<String>] copy [<String>] from MediaAgent [<String>],location [<String>] to MediaAgent [<String>],location [<String>] succeeded. |
| 85:959 | The Move Partition operation [Path update only] on storage policy [<String>] copy [<String>] from MediaAgent [<String>],location [<String>] to MediaAgent [<String>],location [<String>] failed. |
| 85:960 | Data UnAging Job Request on Media list [<String>], Retain Until [<String>]. |
| 85:961 | Data UnAging Job Request on StoragePolicy\Copy [<String>], JobList [<String>], Retain Until [<String>]. |
| 85:962 | View Image Preview for PPT modified from [<String>] to [<String>]. |
| 85:963 | System owner capabilities modified |
| 85:964 | MediaAgent [<String>] shared with remote CommCell [<String>]. |
| 85:965 | MediaAgent [<String>] of CommCell [<String>] is shared with local CommCell [<String>]. |
| 85:966 | Device [<String>] for mount path [<String>] enabled. |
| 85:967 | Device [<String>] for mount path [<String>] disabled. |
| 85:968 | Encryption Cipher changed from [<String>] to [<String>]. |
| 85:969 | Enable Deferred catalog. |
| 85:970 | Disable Deferred catalog. |
| 85:971 | Entities Added |
| 85:972 | Entities Removed |
| 85:973 | CommServe : [<String>] |
| 85:974 | Server group(s): [<String>] |
| 85:975 | Client(s): [<String>] |
| 85:976 | Array(s): [<String>] |
| 85:977 | Libraries : [<String>] |
| 85:978 | MediaAgent(s): [<String>] |
| 85:979 | Schedule policies : [<String>] |
| 85:980 | Storage policies : [<String>] |
| 85:981 | VaultTraker policies : [<String>] |
| 85:982 | Cloud Metrics data collection was turned ON. |
| 85:983 | Cloud Metrics data collection was turned OFF. |
| 85:984 | ON |
| 85:985 | OFF |
| 85:986 | Option Full is turned <Message>. |
| 85:987 | Option Apendable is turned <Message>. |
| 85:988 | Option Active is turned <Message>. |
| 85:989 | Option Overwrite Protected is turned <Message>. |
| 85:990 | Option Good and Bad is turned <Message>. |
| 85:991 | Option Retired is turned <Message>. |
| 85:992 | Option Cleaning is turned <Message>. |
| 85:993 | Option New is turned <Message>. |
| 85:994 | Option Aged is turned <Message>. |
| 85:995 | Option Foreign is turned <Message>. |
| 85:996 | Option Catalog is turned <Message>. |
| 85:997 | Option Scratch is turned <Message>. |
| 85:998 | Option Assigned is turned <Message>. |
| 85:999 | Option And Exists in is turned <Message>. |
| 85:1000 | Option All Media Status is turned <Message>. |
| 85:1001 | Option All Media Groups is turned <Message>. |
| 85:1002 | Option Bad Media Only is turned <Message>. |
| 85:1003 | Option Good Media Only is turned <Message>. |
| 85:1004 | For activity type [<String>], enable activity |
| 85:1005 | For activity type [<String>], enable activity after delay in time |
| 85:1006 | Status: Enabled |
| 85:1007 | Status: Disabled |
| 85:1008 | Report server url changed from [<String>] to [<String>]. |
| 85:1009 | Warning: Next backup of all the clients may be converted to full. |
| 85:1010 | For activity type [<String>], time zone for enable activity after delay in time |
| 85:1011 | Distribute data evenly among multiple streams for offline processes for Storage Policy was turned ON. |
| 85:1012 | Distribute data evenly among multiple streams for offline processes for Storage Policy was turned OFF. |
| 85:1013 | Device controller [<String>] of Device [<String>] for MediaAgent [<String>] enabled. |
| 85:1014 | Device controller [<String>] of Device [<String>] for MediaAgent [<String>] disabled. |
| 85:1015 | Change start time from [<String>] to [<String>]. |
| 85:1016 | Log recipient changed from [<String>] to [<String>] |
| 85:1017 | FTP location changed from [<String>] to [<String>] |
| 85:1018 | FTP User changed from [<String>] to [<String>] |
| 85:1019 | FTP password has been modified |
| 85:1020 | HTTP location changed from [<String>] to [<String>] |
| 85:1021 | HTTP User changed from [<String>] to [<String>] |
| 85:1022 | HTTP password has been modified |
| 85:1023 | Network Timeout changed from [<Number>] to [<Number>] |
| 85:1024 | Associated NAS virtual file server[<String>] with Physical Filer/Cluster[<String>]. |
| 85:1025 | NAS virtual file server[<String>] no longer associated with Physical Filer/Cluster[<String>]. |
| 85:1026 | Cloud Metrics data collection was turned ON. |
| 85:1027 | Cloud Metrics data collection was turned OFF. |
| 85:1028 | Client [<String>] of CommCell [<String>] is shared with local CommCell [<String>]. |
| 85:1029 | Enable Two-Factor Authentication changed from [<Number>] to [<Number>]. |
| 85:1030 | Local client subscriptions has been overriden |
| 85:1031 | User has subscribed to alert [<String>] on client [<String>]. |
| 85:1032 | User has not subscribed to alert [<String>] on client [<String>]. |
| 85:1033 | User has subscribed to alert [<String>] globally. |
| 85:1034 | User has not subscribed to alert [<String>] globally. |
| 85:1035 | Downloaded file [<String>] from source client [<String>] to destination [<String>] |
| 85:1036 | Client: [<String>] Backupset: [<String>] Associated |
| 85:1037 | Client: [<String>] Backupset: [<String>] Deassociated |
| 85:1038 | Sync Folder: <String> |
| 85:1039 | Two Way Sync |
| 85:1040 | One Way Sync to other computers |
| 85:1041 | One Way Sync from other computers |
| 85:1042 | Not Synced |
| 85:1043 | Sync client [<String>] path [<String>] sync type [<String>] |
| 85:1044 | Deleted Sync Folder: <String> |
| 85:1045 | Paused Sync Folder [<String>] client [<String>] |
| 85:1046 | Paused Sync Folder: <String> |
| 85:1047 | Resumed Sync Folder [<String>] client [<String>] |
| 85:1048 | Resumed Sync Folder: <String> |
| 85:1049 | Forced Sync for Folder: <String> |
| 85:1050 | Changed folder name from [<String>] to [<String>] |
| 85:1051 | Changed folder path for client [<String>] from [<String>] to [<String>] |
| 85:1052 | Changed folder mode for client [<String>] from [<String>] to [<String>] |
| 85:1053 | Added user profile [<String>] to client [<String>] |
| 85:1054 | Changed user profile from [<String>] to [<String>] for client [<String>] |
| 85:1055 | Job killed as SYNC is deleted |
| 85:1056 | Job killed as SYNC is paused |
| 85:1057 | Index Directory: <String> |
| 85:1058 | Copy properties changed while jobs are running. |
| 85:1059 | Expiration Time : <String>. |
| 85:1060 | Auxiliary copy fallen behind alert enabled |
| 85:1061 | To be copied data is set to [<Number>] TB |
| 85:1062 | Jobs that are over X days old and have not yet been fully copied is set to [<Number>] days |
| 85:1063 | More than X hours required to copy all data is set to [<Number>] hours |
| 85:1064 | Auxiliary copy fallen behind alert disabled |
| 85:1065 | To be copied data is changed from [<Number>] TB to [<Number>] TB |
| 85:1066 | Jobs that are over X days old and have not yet been fully copied .changed from [<Number>] to [<Number>] days |
| 85:1067 | More than X hours required to copy all data is changed from [<Number>] hours to [<Number>] hours |
| 85:1068 | Backend SQL Server is changed from [<String>] to [<String>]. |
| 85:1069 | RBS Store Client is changed from [<String>] to [<String>]. |
| 85:1070 | Enable Archiving on content database enabled. |
| 85:1071 | Enable Archiving on content database disabled. |
| 85:1072 | Enable Archiving on file BLOB Storage enabled. |
| 85:1073 | Enable Archiving on file BLOB Storage disabled. |
| 85:1074 | User [<String>] performs the operation [<String>] on file name [<String>] with printer [<String>]. |
| 85:1075 | Cloud Print is [<String>] successfully on WebServer [<String>] using user [<String>]. |
| 85:1076 | Failed to [<String>] Cloud Print on WebServer [<String>] using user [<String>]. Error [<String>]. |
| 85:1077 | Allow backups to the active DDB until <String>. Number of times extended : <Number> |
| 85:1078 | Registry key [<String>] at [<String>] is changed. |
| 85:1079 | Registry key [<String>] at [<String>] is changed and enabled. |
| 85:1080 | Registry key [<String>] at [<String>] is changed and disabled. |
| 85:1081 | Custom Query: [<String>] |
| 85:1082 | Share Folder: <String> |
| 85:1083 | Private Share |
| 85:1084 | Public Share |
| 85:1085 | Edit rights |
| 85:1086 | View rights |
| 85:1087 | Share client [<String>] path [<String>] mode [<String>] |
| 85:1088 | Deleted Share Folder: <String> |
| 85:1089 | Changed Share Folder name from [<String>] to [<String>] |
| 85:1090 | Added user [<String>] with [<String>] |
| 85:1091 | Removed user [<String>] |
| 85:1092 | Added email [<String>] with [<String>] |
| 85:1093 | Removed email [<String>] |
| 85:1094 | Added user group [<String>] with [<String>] |
| 85:1095 | Removed user group [<String>] |
| 85:1096 | User [<String>] left from Share Folder [<String>] |
| 85:1097 | Changed Share Folder mode from [<String>] to [<String>] |
| 85:1098 | Content Index fallen behind alert enabled |
| 85:1099 | Content Index fallen behind criteria To be content indexed data is set to [<Number>] GB |
| 85:1100 | Content Index fallen behind criteria Jobs that are over X days old and have not yet been fully indexed is set to [<Number>] days |
| 85:1101 | Content Index fallen behind alert disabled |
| 85:1102 | Content Index fallen behind criteria To be content indexed data is changed from [<Number>] GB to [<Number>] GB |
| 85:1103 | Content Index fallen behind criteria Jobs that are over X days old and have not yet been fully indexed is changed from [<Number>] to [<Number>] days |
| 85:1104 | Case [<String>] created by case manager [<String>] |
| 85:1105 | Case [<String>] updated by case manager [<String>] with remarks [<String>] |
| 85:1106 | Case [<String>] closed by case manager [<String>] with remarks [<String>] |
| 85:1107 | Case [<String>] deleted by case manager [<String>] with remarks [<String>] |
| 85:1108 | Case name changed from [<String>] to [<String>] by case manager [<String>] |
| 85:1109 | Storage policy [<String>] copy [<String>] is associated with Global Deduplication Policy [<String>] |
| 85:1110 | Device name [<String>] |
| 85:1111 | Old configuration: Folder(<String>)(<String>) |
| 85:1112 | New configuration: Folder(<String>)(<String>) |
| 85:1113 | Allow Subclient Association to the Storage Policy until <String>. |
| 85:1114 | Analytics Roles changed to [<String>] |
| 85:1115 | Added Analytics Roles [<String>] |
| 85:1116 | Removed Analytics Roles [<String>] |
| 85:1117 | Cloud Metrics |
| 85:1118 | Changed download URL from [<String>] to [<String>] |
| 85:1119 | Changed upload URL from [<String>] to [<String>] |
| 85:1120 | Changed upload frequency from [<Number>] to [<Number>] days |
| 85:1121 | Changed time from [<String>] to [<String>] |
| 85:1122 | Changed Server groups from [<String>] to [<String>] |
| 85:1123 | Forwarding enabled |
| 85:1124 | Forwarding disabled |
| 85:1125 | Changed forwarding URLs from [<String>] to [<String>] |
| 85:1126 | Enabled metrics feature [<String>] |
| 85:1127 | Disabled metrics feature [<String>] |
| 85:1128 | Remote Private Metrics data collection was turned ON. |
| 85:1129 | Remote Private Metrics data collection was turned OFF. |
| 85:1130 | Immediate metrics data collection triggered from GUI |
| 85:1131 | Azure Instance Credentials Updated |
| 85:1132 | ESX server for snap mount changed from [<String>] to [<String>]. |
| 85:1133 | Analytics Roles changed from [<String>] to [<String>] |
| 85:1134 | Low water mark was changed from [<Number>] to [<Number>] |
| 85:1135 | Warning water mark was changed from [<Number>] to [<Number>] |
| 85:1136 | Number of writers was changed from [<Number>] to [<Number>] |
| 85:1137 | Mountpath usage was changed from [<Message>] to [<Message>] |
| 85:1138 | Number of writers was changed from [<Number>] to [<Number>] |
| 85:1139 | Reserve space was changed from [<Number>] to [<Number>] |
| 85:1140 | Spill and Fill |
| 85:1141 | Fill and Spill |
| 85:1142 | SafeNet enabled |
| 85:1143 | SafeNet disabled |
| 85:1144 | Disabled all Data Interface Pairs on client : [<String>] |
| 85:1145 | Enabled all Data Interface Pairs on client : [<String>] |
| 85:1146 | [<String>] user has globally associated following tags with report [<String>]: [<String>] |
| 85:1147 | [<String>] user has privately associated following tags with report [<String>]: [<String>] |
| 85:1148 | [<String>] user has globally removed all tags associated with report [<String>]. |
| 85:1149 | [<String>] user has privately removed all tags associated with report [<String>]. |
| 85:1150 | [<String>] user has renamed a global tag [<String>] to [<String>]. If a private tag exists with the same name, that will also get renamed. |
| 85:1151 | [<String>] user renamed a private tag [<String>] to [<String>]. |
| 85:1152 | [<String>] user renamed a private tag [<String>] to [<String>]. There exist some reports which are associated with the global tag having same name. They will remain be associated with the same old global tag. |
| 85:1153 | Monitoring Policy: [<String>] |
| 85:1154 | Files/Folders/Patterns added to exclusion list :[<String>] |
| 85:1155 | Files/Folders/Patterns removed from exclusion list :[<String>] |
| 85:1156 | Files/Folders/Patterns added to inclusion list :[<String>] |
| 85:1157 | Files/Folders/Patterns removed from inclusion list :[<String>] |
| 85:1158 | Physical Pruning was enabled on the Mount Path [<String>]. |
| 85:1159 | Physical Pruning was disabled on the Mount Path [<String>]. |
| 85:1160 | Library Out Of Space Alert In Days was change from [<Number>] to [<Number>]. |
| 85:1161 | Data Pruning was enabled on the Library. |
| 85:1162 | Data Pruning was disabled on the Library. |
| 85:1163 | Storage policy [<String>] copy [<String>] is associated with Global Secondary Copy Policy [<String>] |
| 85:1164 | Retain Until: <String> |
| 85:1165 | Retain Until: Infinite. |
| 85:1166 | Index role is removed from search engine [<String>] due to [<String>]. |
| 85:1167 | Index role is added on search engine [<String>]. |
| 85:1168 | Mark Refreshed appendable media active was enabled. |
| 85:1169 | Mark Refreshed appendable media active was disabled. |
| 85:1170 | DM2 Cache Directory is moved from [<String>] to [<String>] on Webserver [<String>]. |
| 85:1171 | Search Engine Index Directory is moved from [<String>] to [<String>] on Search Engine [<String>]. |
| 85:1172 | Analtyics Index Directory is moved from [<String>] to [<String>] on Analytics Engine [<String>]. |
| 85:1173 | Admin user deleted events[<String>] form Event Viewer |
| 85:1174 | Data Pruning is enabled on the Store [<String>]. |
| 85:1175 | Data Pruning is disabled on the Store [<String>]. |
| 85:1176 | Micro Pruning is enabled on the MountPath [<String>]. |
| 85:1177 | Micro Pruning is disabled on the MountPath [<String>]. |
| 85:1178 | Preview Engine [<String>] is [<String>] on Search Engine [<String>] |
| 85:1179 | Entity Extraction Engine [<String>] is [<String>] on Search Engine [<String>] |
| 85:1180 | Associated Entities [<String>] and subclients [<String>] on Storage Policy [<String>] |
| 85:1181 | Export Location(s): [<String>] |
| 85:1182 | Media Repositories: [<String>] |
| 85:1183 | Container(s): [<String>] |
| 85:1184 | Configure Data Interface pair for clients: [<String> - <String>] and [<String> - <String>] |
| 85:1185 | Access type was changed form [Read/Write] to [Read]. |
| 85:1186 | Access type was changed form [Read] to [Read/Write]. |
| 85:1187 | Number of writers was changed from [Maximum] to [<Number>]. |
| 85:1188 | Number of writers was changed from [<Number>] to [Maximum]. |
| 85:1189 | User : <String> |
| 85:1190 | Role : <String> |
| 85:1191 | Entity : <String> |
| 85:1192 | Changed query IDs filtered from [<String>] to [<String>] |
| 85:1193 | Changed CommCell IDs removed from file paths from [<String>] to [<String>] |
| 85:1194 | Encryption settings changed from [<String>] to [<String>]. |
| 85:1195 | Access type was changed from [<String>] to [<String>]. |
| 85:1196 | Deduplication : Changed Dash option Source side disk cache from [<String>] to [<String>]. |
| 85:1197 | Deduplication : Changed Dash option Optimize for high latency networks by avoiding remote lookups from [<String>] to [<String>]. |
| 85:1198 | Key Length (<String>) was changed from [<Number>] to [<Number>]. |
| 85:1199 | Throttle jobs Option has been changed by user [<String>]. |
| 85:1200 | Password added |
| 85:1201 | Password removed |
| 85:1202 | Expiration time changed from [<String>] to [<String>] |
| 85:1203 | Share has expired |
| 85:1204 | Analytics Memory changed from [<Number>] MB to [<Number>] MB |
| 85:1205 | <String> <String> (Added) |
| 85:1206 | <String> <String> (Removed) |
| 85:1207 | Alert: <String> |
| 85:1208 | Reshare on |
| 85:1209 | Reshare off |
| 85:1210 | Changed reshare mode from [<String>] to [<String>] |
| 85:1211 | Added user [<String>] with [<String>] and [<String>] |
| 85:1212 | Added email [<String>] with [<String>] and [<String>] |
| 85:1213 | Added user group [<String>] with [<String>] and [<String>] |
| 85:1214 | Password changed for user [<String>] |
| 85:1215 | User [<String>] coming from SAML token issued by CommCell registered with guid [<String>] is mapped to local User Id [<Number>] |
| 85:1216 | Pruning of aged data is enabled. |
| 85:1217 | Pruning of aged data is disabled. |
| 85:1218 | Reserve space for silo restores is enabled. |
| 85:1219 | Reserve space for silo restores is disabled. |
| 85:1220 | Device name changed from [<String>] to [<String>]. |
| 85:1221 | Preventing accidental deletion of data from mount paths is enabled. |
| 85:1222 | Preventing accidental deletion of data from mount paths is disabled. |
| 85:1223 | Start data aging when data occupied on the disk is changed from [<Number>]% to [<Number>]%. |
| 85:1224 | Stop data aging when data occupied on the disk is changed from [<Number>]% to [<Number>]%. |
| 85:1225 | Only use Pnp disk when it is blank enabled. |
| 85:1226 | Only use Pnp disk when it is blank disabled. |
| 85:1227 | Category: [<String>]<String> |
| 85:1228 | Permission: [<String>]<String> |
| 85:1229 | Role: [<String>]<String> |
| 85:1230 | Category: [<String>] Permission : [<String>]<String> |
| 85:1231 | Server group : [<String>]<String> |
| 85:1232 | Server group : [<String>] Client : [<String>]<String> |
| 85:1233 | Client : [<String>]<String> |
| 85:1234 | Client : [<String>] Agent Type : [<String>]<String> |
| 85:1235 | Client : [<String>] Agent Type : [<String>] Instance : [<String>]<String> |
| 85:1236 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>]<String> |
| 85:1237 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] SubClient : [<String>]<String> |
| 85:1238 | Storage Policy : [<String>]<String> |
| 85:1239 | Storage Policy : [<String>] Storage Policy Copy : [<String>]<String> |
| 85:1240 | Blackout Window Rule Name: changed from [<String>] to [<String>] |
| 85:1241 | Operation Type: changed from [<String>] to [<String>] |
| 85:1242 | Days Of Week: changed from [<String>] to [<String>] |
| 85:1243 | Start Date: changed from [<String>] to [<String>] |
| 85:1244 | End Date: changed from [<String>] to [<String>] |
| 85:1245 | Blackout window between [<String>] and [<String>] time interval is added. |
| 85:1246 | Blackout window between [<String>] and [<String>] time interval is removed. |
| 85:1247 | Minimum Index Cache free space for MediaAgent [<String>] is changed from [<Number>] MB to [<Number>] MB. |
| 85:1248 | Index Cache alert free space for MediaAgent [<String>] is changed from [<Number>] MB to [<Number>] MB. |
| 85:1249 | Index Cache retention period for MediaAgent [<String>] is changed from [<Number>] days to [<Number>] days. |
| 85:1250 | Index Cache property [cleanup percent until free space is atleast] for MediaAgent [<String>] is changed from [<Number>] to [<Number>]. |
| 85:1251 | Index Cache path for MediaAgent [<String>] is changed from [<String>] to [<String>]. |
| 85:1252 | Clients added [<String>] |
| 85:1253 | Clients deleted [<String>] |
| 85:1254 | Enable Option:Prefer mount paths with more free space. |
| 85:1255 | Disable Option:Prefer mount paths with more free space. |
| 85:1256 | The Storage(MountPath) validation job succeed for the Path [<String>]. |
| 85:1257 | The Storage(MountPath) validation job failed for the Path [<String>]. |
| 85:1258 | The Storage(Drive) validation job succeed for the Drive [ID - <Number>, DriveName - <String>]. |
| 85:1259 | The Storage(Drive) validation job failed for the Drive [ID - <Number>, DriveName - <String>]. |
| 85:1260 | Disk Library Maintenance job is succeed for the path [<String>]. |
| 85:1261 | Disk Library Maintenance job is failed for the path [<String>]. |
| 85:1262 | The Device Alias name changed from [<String>] to [<String>]. |
| 85:1263 | Minimize Fragmentation by allocation write blocks option is disabled. |
| 85:1264 | Enabled option Minimize Fragmentation by allocation write blocks of [<Number>]MB. |
| 85:1265 | Minimize Fragmentation by allocation write blocks changed from [<Number>]MB to [<Number>]MB. |
| 85:1266 | Enabled space allocation option to not use space more than [<Number>]GB. |
| 85:1267 | Space allocation option changed to not use space more than from [<Number>]GB to [<Number>]GB. |
| 85:1268 | Enabled space allocation option to use free space on the mount path until it reaches reserved space. |
| 85:1269 | MountPath is disabled for new data. |
| 85:1270 | Configured Edge Drive |
| 85:1271 | Configured Edge Drive on client [<String>] |
| 85:1272 | Paused Edge Drive on client [<String>] |
| 85:1273 | Resumed Edge Drive on client [<String>] |
| 85:1274 | Disabled Edge Drive on client [<String>] |
| 85:1275 | Maximum number of parallel connections was changed from [<Number>] to [<Number>]. |
| 85:1276 | Media agent name was changed from [<String>] to [<String>]. |
| 85:1277 | SCSI/SAN device scan interval changed from [<Number>] hours to [<Number>] hours. |
| 85:1278 | Retry on network errors enabled. |
| 85:1279 | Retry on network errors disabled. |
| 85:1280 | Retry frequency changed from [<Number>] seconds to [<Number>] seconds. |
| 85:1281 | Retry count changed from [<Number>] to [<Number>]. |
| 85:1282 | New cleaning media was discovered. |
| 85:1283 | New cleaning media was imported. |
| 85:1284 | New media was imported. |
| 85:1285 | Library was reset. |
| 85:1286 | Library was marked fixed. |
| 85:1287 | Library was marked exported. |
| 85:1288 | Library was marked clean. |
| 85:1289 | Cache mount period changed from [<Number>] to [<Number>]. |
| 85:1290 | Prevent physical inventory was enabled. |
| 85:1291 | Prevent physical inventory was disabled. |
| 85:1292 | Periodic mail slot check for any change in status of library was enabled. |
| 85:1293 | Periodic mail slot check for any change in status of library was disabled. |
| 85:1294 | Prevent auto import of media from mail slot was enabled. |
| 85:1295 | Prevent auto import of media from mail slot was disabled. |
| 85:1296 | Allow medium removal from mail slot was enabled. |
| 85:1297 | Allow medium removal from mail slot was disabled. |
| 85:1298 | Do not import media from I/E port back to the slots was Enabled. |
| 85:1299 | Do not import media from I/E port back to the slots was Disabled. |
| 85:1300 | Drive allocation changed to all drives. |
| 85:1301 | Drive allocation changed from all drives to [<Number>] drives. |
| 85:1302 | Drive allocation changed from [<Number>] drives to [<Number>] drives. |
| 85:1303 | Drive allocation changed to all drives. |
| 85:1304 | Drive allocation changed from all drives to [<Number>] drives. |
| 85:1305 | Drive allocation changed from [<Number>] drives to [<Number>] drives. |
| 85:1306 | Master Pool: [<String>]. |
| 85:1307 | Master Pool was Enabled. |
| 85:1308 | Master Pool was Disabled. |
| 85:1309 | Drive Pool: [<String>]. |
| 85:1310 | Drive pool was enabled. |
| 85:1311 | Drive pool was disabled. |
| 85:1312 | Drive name changed from [<String>] to [<String>]. |
| 85:1313 | Drive was marked read only. |
| 85:1314 | Drive was unmarked read only. |
| 85:1315 | Drive controller: [<String>]. |
| 85:1316 | Failover controller was enabled. |
| 85:1317 | Failover controller was disabled. |
| 85:1318 | Appendable media days: [<Number>]. |
| 85:1319 | Use appendable media was disabled. |
| 85:1320 | Use appendable media days changed from [<Number>] to [<Number>]. |
| 85:1321 | Read retry attempts changed from [<Number>] to [<Number>]. |
| 85:1322 | Read retry interval changed from [<Number>] minutes to [<Number>] minutes. |
| 85:1323 | Virtual Mail Slot for Export was Enabled with a start slot of [<Number>] and a direction of [<String>]. |
| 85:1324 | Virtual Mail Slot for Export was Disabled. |
| 85:1325 | Virtual Mail Slot for Export values changed: Start slot changed from [<Number>] to [<Number>], and direction changed from [<String>] to [<String>]. |
| 85:1326 | Drive pool name changed from [<String>] to [<String>]. |
| 85:1327 | Media Side Name: [<String>]. |
| 85:1328 | Drive clean interval was changed from [<Number>] days to [<Number>] days. |
| 85:1329 | Drive marked as replaced [drive : <String> library : <String>]. |
| 85:1330 | Drive marked as cleaned [drive : <String> library : <String>]. |
| 85:1331 | Drive marked as fixed [drive : <String> library : <String>]. |
| 85:1332 | Mount path reserve space changed from [<Number>] MB to [<Number>] MB. |
| 85:1333 | 'Do not consume more than' value changed from [<Number>] GB to [<Number>] GB. |
| 85:1334 | 'Do not consume more than' value changed from [<Number>] GB to 'Use until free space reaches Reserved Space'. |
| 85:1335 | 'Use until free space reaches Reserved Space' changed to 'Do not consume more than' with value [<Number>] GB. |
| 85:1336 | Device Name [<String>] MediaAgent [<String>] Path [<String>] |
| 85:1337 | Job : [<String>] Old Retention [<String>] |
| 85:1338 | Job : [<String>] Old Retention [Infinite] |
| 85:1339 | Invalid parameter: <String> |
| 85:1340 | AM |
| 85:1341 | PM |
| 85:1342 | Every [<Number>] cycle(s) |
| 85:1343 | Every [<Number>] hour(s), starts at [<String>] |
| 85:1344 | Every [<Number>] day(s), the day starts at [<String>] |
| 85:1345 | Every [<Number>] week(s), the week starts on [<String>] |
| 85:1346 | Every [<Number>] month(s), on day [<Number>] |
| 85:1347 | Do not automatically select jobs |
| 85:1348 | Job selection period was moved [<Number>] hour(s) [<String>] |
| 85:1349 | Job selection period was moved [<Number>] day(s) [<String>] |
| 85:1350 | Job selection period was moved [<Number>] week(s) [<String>] |
| 85:1351 | Job selection period was moved [<Number>] month(s) [<String>] |
| 85:1352 | forward |
| 85:1353 | backward |
| 85:1354 | Search Engine Name is changed from [<String>] to [<String>] |
| 85:1355 | <String><String> |
| 85:1356 | Index Large Files option is Enabled. |
| 85:1357 | Index Large Files option is Disabled. |
| 85:1358 | Deduplication - Enable transactional DDB. |
| 85:1359 | Deduplication - Disable transactional DDB. |
| 85:1360 | Rule group |
| 85:1361 | MB/Folders/Patterns added to exclusion list :[<String>] |
| 85:1362 | MB/Folders/Patterns removed from exclusion list :[<String>] |
| 85:1363 | Folders added to exclusion list :[<String>] |
| 85:1364 | Folders removed from exclusion list :[<String>] |
| 85:1365 | Folders added to inclusion list :[<String>] |
| 85:1366 | Folders removed from inclusion list :[<String>] |
| 85:1367 | [<String>] |
| 85:1368 | Network Topology: [<String>] |
| 85:1369 | User [<String>] coming from SAML token issued by CommCell registered with guid [<String>] is mapped to local User [<String>] |
| 85:1370 | Application Group: [<String>]<String> |
| 85:1371 | Application Type: [<String>]<String> |
| 85:1372 | Search Engine index is moved from [<String>, <String>] to [<String>, <String>] |
| 85:1373 | Failed to move Search Engine index from [<String>, <String>] to [<String>, <String>] |
| 85:1374 | Content Extractor Data Directory: <String> |
| 85:1375 | Content Extractor Java Memory changed from [<Number>] MB to [<Number>] MB |
| 85:1376 | Use Enterprise Metrics as Internet Gateway was turned ON. |
| 85:1377 | Use Enterprise Metrics as Internet Gateway was turned OFF. |
| 85:1378 | Enable Global Policy Retention on copy. |
| 85:1379 | Disable Global Policy Retention on copy. |
| 85:1380 | Copy and Subclient region mapping was modified |
| 85:1381 | NAS client [<String>] NDMP properties have been modified. |
| 85:1382 | NAS client [<String>] NDMP login and password have been modified. |
| 85:1383 | NAS client [<String>] NDMP login and password have been deleted. |
| 85:1384 | NAS client [<String>] NDMP login and password have been added. |
| 85:1385 | User [<String>] added command [<String>] for [<String>] with parameters [<String>] |
| 85:1386 | User [<String>] deleted command [<String>] for [<String>] with parameters [<String>] |
| 85:1387 | User [<String>] updated command [<String>] for [<String>]. Retention period changed from [<Number>] to [<Number>]. [<String>] |
| 85:1388 | Generate thumbnail images for mobile apps modified from [<String>] to [<String>]. |
| 85:1389 | Quota limit at Server group enabled |
| 85:1390 | Quota limit at Server group disabled |
| 85:1391 | Added MediaAgent [<String>] to MountPath [<String>] part of StoragePool [<String>] |
| 85:1392 | Entities: <String> Subclients: <String> Content Analyzer Client: <String> Storage Policy: <String> |
| 85:1393 | Rotated master key. |
| 85:1394 | Use VSS Enabled for DR subclient changed from [<Number>] to [<Number>]. |
| 85:1395 | Oracle Cloud Instance Credentials Updated |
| 85:1396 | Docker Instance Credentials Updated |
| 85:1397 | CVAccounts SSO URL changed. |
| 85:1398 | MTScanThreads was changed from [<Number>] to [<Number>]. |
| 85:1399 | nNumPipelineBuffers was changed from [<Number>] to [<Number>]. |
| 85:1400 | DataMoverUseLookAheadLinkReader was changed from [<Number>] to [<Number>]. |
| 85:1401 | Created storage policy [<String>] dependent of storage policy [<String>] |
| 85:1402 | The Access Path for MediaAgent [<String>] is Enabled. |
| 85:1403 | The Access Path for MediaAgent [<String>] is Disabled. |
| 85:1404 | Old Volume [<String>]. New Volume [<String>]. |
| 85:1405 | Old Snap [<String>]. New Snap [<String>]. |
| 85:1406 | Old Array [<String>]. New Array [<String>]. |
| 85:1407 | Array [<String>]. OldInterface[<String>] NewInterface[<String>]. |
| 85:1408 | NasClient [<String>] is associated to Array [<String>]. |
| 85:1409 | Updated [<Number>] SMSnap DB Entries. IDs [<String>]. |
| 85:1410 | Updated [<Number>] SMVolume DB Entries. IDs [<String>]. |
| 85:1411 | Updated [<Number>] SMMetaData DB Entries. |
| 85:1412 | Updated [<Number>] Snap Jobs. Job IDs [<String>]. |
| 85:1413 | Updated [<Number>] Snap Jobs. |
| 85:1414 | The property that allows jobs to complete past blackout windows has been changed by user [<String>]. |
| 85:1415 | Enable Option:Select mount path for MediaAgent according to the preferred setting. |
| 85:1416 | Disable Option:Select mount path for MediaAgent according to the preferred setting. |
| 85:1417 | The Move Partition operation on storage policy [<String>] copy [<String>] from MediaAgent [<String>], location [<String>] to MediaAgent [<String>], location [<String>] failed due to [<String>]. |
| 85:1418 | Prevent multiple copies of job across selective copies option is enabled |
| 85:1419 | Prevent multiple copies of job across selective copies option is disabled |
| 85:1420 | Storage Policy Copy type modified from [<Message>] to [<Message>] |
| 85:1421 | Container [<String>] is marked Onsite. |
| 85:1422 | Container [<String>] is marked Offsite. |
| 85:1423 | The password is changed. |
| 85:1424 | Command added [<String>] |
| 85:1425 | Command deleted [<String>] |
| 85:1426 | Command updated [<String>] |
| 85:1427 | Tape 2 Tape Copy job from source media [<String>] to target media [<String>] in library [<String>] completed successfully. |
| 85:1428 | Tape to Tape Copy job from source media [<String>] to target media [<String>] in library [<String>] failed with error [<String>]. |
| 85:1429 | Third party encryption key provider [<String>] was set. |
| 85:1430 | Third party encryption key provider was removed. |
| 85:1431 | Third party encryption key provider was changed to [<String>]. |
| 85:1432 | Key Provider: <String> |
| 85:1433 | Name changed from [<String>] to [<String>]. |
| 85:1434 | Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] Subclient : [<String>] |
| 85:1435 | Agent Type : [<String>] BackupSet: [<String>] Subclient : [<String>] |
| 85:1436 | Client Name : [<String>] |
| 85:1437 | Subclient(s) : <String> |
| 85:1438 | StoragePool [<String>] is associated with Server group [<String>] |
| 85:1439 | <String> |
| 85:1440 | Option to Select MediaAgents for pruning aged data based on the associated copy's datapaths is enabled on the MountPath [<String>]. |
| 85:1441 | Option to Select MediaAgents for pruning aged data based on the associated copy's datapaths is disabled on the MountPath [<String>]. |
| 85:1442 | Ransomware protection is disabled. |
| 85:1443 | Ransomware protection is enabled. |
| 85:1444 | Move Mount Path Job from source location [<String>, <String>] to target location [<String>, <String>] failed with error [<String>]. |
| 85:1445 | Move Mount Path Job from source location [<String>, <String>] to target location [<String>, <String>] succeeded. |
| 85:1446 | Disable Option:Hide Library. |
| 85:1447 | Enable Option:Hide Library. |
| 85:1448 | Show aged data during browse and recovery: Disabled |
| 85:1449 | Show aged data during browse and recovery: Enabled |
| 85:1450 | Allow Point-In-Time for SQL across cycles: Disabled |
| 85:1451 | Allow Point-In-Time for SQL across cycles: Enabled |
| 85:1452 | Automatically switch copy to read data from any copy: Disabled |
| 85:1453 | Automatically switch copy to read data from any copy: Enabled |
| 85:1454 | Set CommCell wide default page size to: [<Number>] |
| 85:1455 | Start Compliance restores in suspended state: Disabled |
| 85:1456 | Start Compliance restores in suspended state: Enabled |
| 85:1457 | Confirmation message for restore jobs: Disabled |
| 85:1458 | Confirmation message for restore jobs: Enabled |
| 85:1459 | Default Web Server for Search: [<String>] |
| 85:1460 | Start End User restores in suspended state: Disabled |
| 85:1461 | Start End User restores in suspended state: Enabled |
| 85:1462 | Recover Apple Resource Fork Data: Disabled |
| 85:1463 | Recover Apple Resource Fork Data: Enabled |
| 85:1464 | Configure Automatically : Set to [<String>] |
| 85:1465 | Default Outgoing Tunnel Protocol changed from [<String>] to [<String>] |
| 85:1466 | Use wildcardproxy : Set to [<String>] |
| 85:1467 | ClientId:[<Number>] association has been changed from PlanId:[<Number>] to PlanId[<Number>] |
| 85:1468 | SubClientId:[<Number>] association has been changed from PlanId:[<Number>] to PlanId[<Number>] |
| 85:1469 | Added SNMPV3 host: [<String>] |
| 85:1470 | Deleted SNMPV3 host: [<String>] |
| 85:1471 | Updated SNMPV3 host: [<String>] |
| 85:1472 | <String> : <String> |
| 85:1473 | Transferred ownership of the following entities to [<String>] |
| 85:1474 | Tape to Tape Copy job from source media [<String>] in library [<String>] to target media [<String>] in library [<String>] failed with error [<String>]. |
| 85:1475 | Tape to Tape Copy job from source media [<String>] in library [<String>] to target media [<String>] in library [<String>] completed successfully. |
| 85:1476 | Pick data from running backup jobs option was turned off. |
| 85:1477 | Pick data from running backup jobs option was turned on. |
| 85:1478 | Delete operation skipped, manual deletion of jobs from a WORM copy is not allowed. Job(s): [<String>], Storage Policy: [<String>], Copy: [<String>]. |
| 85:1479 | UserName [<String>] DatasourceName [<String>] Query [<String>] |
| 85:1480 | UserName [<String>] DatasourceName [<String>] CoreName [<String>] |
| 85:1481 | UserName [<String>] DatasourceName [<String>] FieldName [<String>] |
| 85:1482 | UserName [<String>] DatasourceName [<String>] HandlerName [<String>] |
| 85:1483 | UserName [<String>] CloudId [<String>] DatasourceType [<String>] <String> |
| 85:1484 | UserName [<String>] DatasourceName [<String>] DatasourceType [<String>] <String> |
| 85:1485 | UserName [<String>] DatasourceName [<String>] HandlerName [<String>] |
| 85:1486 | UserName [<String>] DatasourceName [<String>] <String> |
| 85:1487 | Library Controller was reset. |
| 85:1488 | Library Controller: <String> |
| 85:1489 | Library status check interval changed from : <Number> to : <Number>. |
| 85:1490 | Allocation Policy : [<String>] |
| 85:1491 | Plan : [<String>] |
| 85:1492 | Schedule : [<String>] |
| 85:1493 | Drive was reset. |
| 85:1494 | Exhaustive Detection. |
| 85:1495 | Without Exhaustive Detection. |
| 85:1496 | Source Library: <String> |
| 85:1497 | Keep resource reservations cached for jobs on this storage policy OFF. |
| 85:1498 | Keep resource reservations cached for jobs on this storage policy ON. |
| 85:1499 | Database changed from [<String>] to [<String>]. |
| 85:1500 | Preference Name: [<String>] |
| 85:1501 | Users/Groups: [<String>] |
| 85:1502 | Preference Value: [<String>] |
| 85:1503 | Data Interface Pair for clients [<String> - <String>] and [<String> - <String>] Active : [<Number>] |
| 85:1504 | Disabled Data Interface Pair for clients [<String> - <String>] and [<String> - <String>] |
| 85:1505 | Enabled Data Interface Pair for clients [<String> - <String>] and [<String> - <String>] |
| 85:1506 | Network Configuration is pushed on the client [<String>] |
| 85:1507 | Network Configuration is pushed on the Server group [<String>] |
| 85:1508 | Network Configuration is pushed on the Server group [<String>] in network topology [<String>] |
| 85:1509 | Network Configuration is pushed on the client [<String>] in network topology [<String>] |
| 85:1510 | Log monitoring dashboard name: [<String>] |
| 85:1511 | Dashboard name was changed from [<String>] to [<String>] |
| 85:1512 | Log monitoring search name: [<String>] |
| 85:1513 | Search name was changed from [<String>] to [<String>] |
| 85:1514 | Changed No. of Read, Write Sessions threshold from [<Number>] to [<Number>]. |
| 85:1515 | Removed association for Server group [<String>] and client [<String>] from schedule policy [<String>]. |
| 85:1516 | Failed to submit power off request. |
| 85:1517 | Successfully submitted power off request. |
| 85:1518 | Failed to submit power on request. |
| 85:1519 | Successfully submitted power on request. |
| 85:1520 | Power Management was disabled. |
| 85:1521 | Power Management was enabled. |
| 85:1522 | Cloud controller was changed from [<String>] to [<String>]. |
| 85:1523 | "Select MediaAgents for pruning aged data based on the associated copy's datapaths" is disabled. |
| 85:1524 | "Select MediaAgents for pruning aged data based on the associated copy's datapaths" is enabled. |
| 85:1525 | Software compression option was disabled on clients. |
| 85:1526 | Software compression option was enabled on clients. |
| 85:1527 | Software compression option was disabled on MediaAgent. |
| 85:1528 | Software compression option was enabled on MediaAgent. |
| 85:1529 | Deduplication - Optimize deduplication for Database agents was disabled. |
| 85:1530 | Deduplication - Optimize deduplication for Database agents was enabled. |
| 85:1531 | Google Cloud Instance Credentials Updated |
| 85:1532 | Auto Resume Interval in Minutes set to [<Number>]. |
| 85:1533 | <Message> got modified. |
| 85:1534 | Created Analytics cloud [<String>] with Cloud Mode [<String>], HAC Cluster [<String>] |
| 85:1535 | Deleted Analytics cloud [<String>] |
| 85:1536 | Modified Analytics cloud name from [<String>] to [<String>] |
| 85:1537 | Added Node [<String>] to Analytics cloud [<String>] with JVM [<String>], PortNo [<String>], Index Directory [<String>] |
| 85:1538 | Modified Node properties [<String>] for Analytics cloud [<String>] to JVM [<String>], PortNo [<String>], Index Directory [<String>] |
| 85:1539 | Removed Node [<String>] from Analytics cloud [<String>] with JVM [<String>], PortNo [<String>], Index Directory [<String>] |
| 85:1540 | Added Role [<String>] to Analytics cloud [<String>] |
| 85:1541 | Removed Role [<String>] from Analytics cloud [<String>] |
| 85:1542 | Path to save log files during sendlogfiles operation is changed from [<String>] to [<String>]. |
| 85:1543 | Password for path to save log files during sendlogfiles operation changed. |
| 85:1544 | User for path to save log files during sendlogfiles operation changed from [<String>] to [<String>]. |
| 85:1545 | Subclient(s) Associated to Backup Copy : <String> |
| 85:1546 | Subclient(s) Dissociated from Backup Copy : <String> |
| 85:1547 | Subclient(s) added for Deferred Catalog : <String> |
| 85:1548 | Subclient(s) removed for Deferred Catalog : <String> |
| 85:1549 | Subclient(s) Associated : <String> |
| 85:1550 | Subclients(s) Dissociated : <String> |
| 85:1551 | Auth Code Generated for Company : [<String>]. |
| 85:1552 | Changed key file path |
| 85:1553 | Moved key from file to DB |
| 85:1554 | Moved key from DB to file |
| 85:1555 | Reset configuration |
| 85:1556 | Generated saml token for user [<String>]. Token Validity time [<Number>] minutes |
| 85:1557 | Validated saml token for user [<String>]. Token Validity time [<Number>] minutes |
| 85:1558 | Job Suspend Reason set to [<String>]. |
| 85:1559 | Cloud Library: [<String>] |
| 85:1560 | Disk Library: [<String>] |
| 85:1561 | Disk library to cache Dedupe metadata option was disabled. |
| 85:1562 | Disk library to cache Dedupe metadata option was enabled. |
| 85:1563 | Disk library to cache Dedupe metadata option was modified. |
| 85:1564 | Old Disk Library: [<String>] |
| 85:1565 | UserName [<String>] DatasourceName [<String>] HandlerName [<String>] and HandlerInfo[<String>] |
| 85:1566 | HyperScale X Operation Type : ADD |
| 85:1567 | HyperScale X Configuration Type : <String> |
| 85:1568 | HyperScale X Operation Type : CREATE |
| 85:1569 | List Of Nodes : <String> |
| 85:1570 | HyperScale X Operation Type : RECONFIGURE |
| 85:1571 | HyperScale X Operation Type : REFRESH |
| 85:1572 | Monitoring Policy Template Name: <String> |
| 85:1573 | Alert [<String>] has been disabled. |
| 85:1574 | Alert [<String>] has been enabled. |
| 85:1575 | Filter [<String>] has been added. |
| 85:1576 | Filter [<String>] has been deleted. |
| 85:1577 | Filter [<String>] has been modified. |
| 85:1578 | Laptop Archiving has been : [<String>] |
| 85:1579 | Marked DDB Store [<String>] for validation and pruning for next DDB Resync |
| 85:1580 | Disabled Report Search Analytic Engine [<String>] |
| 85:1581 | Enabled Report Search Analytic Engine |
| 85:1582 | Changed Report Search Analytic Engine from [<String>] to [<String>] |
| 85:1583 | Sync Reports with Report Search Analytic Server [<String>] |
| 85:1584 | Cloned Subclient Policy: <String> |
| 85:1585 | Password changed. |
| 85:1586 | UserName changed from [<String>] to [<String>]. |
| 85:1587 | Key provider type was changed from [<String>] to [<String>]. |
| 85:1588 | Passphrase was rotated. |
| 85:1589 | Archiver data was deleted as part of this operation |
| 85:1590 | Power Management at Server group level settings enabled |
| 85:1591 | Power Management at MediaAgent level enabled |
| 85:1592 | "Start aging when data occupied on disk" set to [<Number>%] |
| 85:1593 | "Stop aging when data occupied on disk" set to [<Number>%] |
| 85:1594 | Media Password disabled |
| 85:1595 | Media Password enabled |
| 85:1596 | Device App key: [<String>] |
| 85:1597 | Device host name: [<String>] |
| 85:1598 | Device ID: [<String>] |
| 85:1599 | Device Name: [<String>] |
| 85:1600 | Operating system: [<String>] |
| 85:1601 | Owner userId: [<String>] |
| 85:1602 | Device App Key changed from: [<String>] to [<String>] |
| 85:1603 | Migration of laptop [<String>] from Plan:[<String>] to Plan:[<String>] failed. |
| 85:1604 | Migration of laptop [<String>] from Plan:[<String>] to Plan:[<String>] completed. |
| 85:1605 | Configuration policy [<String>], id:[<Number>] created |
| 85:1606 | Configuration policy [<String>], id:[<Number>] deleted |
| 85:1607 | Configuration policy [<String>], id:[<Number>] updated |
| 85:1608 | CommCell Registration |
| 85:1609 | CommCell Unregistration |
| 85:1610 | Remote CommCell: <String> |
| 85:1611 | Alibaba Cloud Instance Credentials Updated |
| 85:1612 | Id: [<String>] |
| 85:1613 | Name: [<String>] |
| 85:1614 | <String> |
| 85:1615 | Oracle Cloud Infrastructure Instance Credentials Updated |
| 85:1616 | Excluded Path for Restore: [<String>] |
| 85:1617 | Added Path for Restore: [<String>] |
| 85:1618 | Not set |
| 85:1619 | Password expiry date: <String> |
| 85:1620 | Replace disk submitted for HyperScale X StoragePool:[<String>], MediaAgent:[<String>] ,Disk Id:[<Number>] . |
| 85:1621 | Client: <String>. BackupSet: <String> |
| 85:1622 | Description: <String> |
| 85:1623 | Company [<String>] has been deleted. |
| 85:1624 | Created Index Server [<String>] with Cloud Mode [<String>], Index Server Pool [<String>] |
| 85:1625 | Deleted Index Server [<String>] |
| 85:1626 | Added Node [<String>] to Index Server [<String>] with JVM [<String>], PortNo [<String>], Index Directory [<String>] |
| 85:1627 | Modified Node properties [<String>] for Index Server [<String>] to JVM [<String>], PortNo [<String>], Index Directory [<String>] |
| 85:1628 | Removed Node [<String>] from Index Server [<String>] with JVM [<String>], PortNo [<String>], Index Directory [<String>] |
| 85:1629 | Created Index Server Pool [<String>] with HAC Cluster [<String>] |
| 85:1630 | Deleted Index Server Pool [<String>] |
| 85:1631 | Added Node [<String>] to Index Server Pool [<String>] with JVM [<String>], PortNo [<String>] |
| 85:1632 | Modified Node properties [<String>] for Index Server Pool [<String>] to JVM [<String>], PortNo [<String>] |
| 85:1633 | Removed Node [<String>] from Index Server Pool [<String>] with JVM [<String>], PortNo [<String>] |
| 85:1634 | Added Role [<String>] to Index Server [<String>] |
| 85:1635 | Removed Role [<String>] from Index Server [<String>] |
| 85:1636 | New plan created : '<String>' (<String>) |
| 85:1637 | Plan '<String>' set as default <String> |
| 85:1638 | Plan deleted : '<String>' |
| 85:1639 | Plan scheduled for deletion : '<String>' |
| 85:1640 | Plan '<String>' modified : <String> '<String>' (<Number>) associated with the plan |
| 85:1641 | Plan '<String>' modified : new inheritance rules applied |
| 85:1642 | Plan '<String>' renamed: new plan name is '<String>' |
| 85:1643 | <String> job ran for the library : <String> |
| 85:1644 | Disable Space Optimized AuxCopy |
| 85:1645 | Enable Space Optimized AuxCopy |
| 85:1646 | Logout : Login name: [<String>], Host: [<String>] |
| 85:1647 | Login failure: username:[<String>], host/ device:[<String>], login attempted from: [<String>] |
| 85:1648 | Login success: username:[<String>], host/ device:[<String>], logged in from: [<String>] |
| 85:1649 | Company theme modified for company <String> to <String> |
| 85:1650 | Domain name for client list [<String>] was changed from [<String>] to [<String>] |
| 85:1651 | Folder :[<String>] |
| 85:1652 | All client<String> |
| 85:1653 | Data Capturing Options |
| 85:1654 | Number of Associations<String> |
| 85:1655 | Company: <String> |
| 85:1656 | Company: <String> |
| 85:1657 | RServer Hostname : <String> |
| 85:1658 | SNMPV3 Hostname : <String> |
| 85:1659 | Plan '<String>' set as system default file server plan |
| 85:1660 | Plan '<String>' set as system default laptop plan |
| 85:1661 | Plan '<String>' set as system default server plan |
| 85:1662 | New access policies set '<String>'(<Number>) associated with the plan |
| 85:1663 | New set of alerts associated with the plan : '<String>' |
| 85:1664 | New analytic engine pseudo client '<String>'(<Number>) associated with the plan |
| 85:1665 | New data configuration policy '<String>'(<Number>) associated with the plan |
| 85:1666 | New content analyzer pseudo client '<String>'(<Number>) associated with the plan |
| 85:1667 | New edge drive pseudo client '<String>'(<Number>) associated with the plan |
| 85:1668 | New features set '<String>'(<Number>) associated with the plan |
| 85:1669 | Log schedule policy '<String>'(<Number>) associated with the plan |
| 85:1670 | Log storage policy '<String>'(<Number>) associated with the plan |
| 85:1671 | New log SLA value <Number> minutes set for the plan |
| 85:1672 | New archiving mailbox configuration policy '<String>'(<Number>) associated with the plan |
| 85:1673 | New clean-up mailbox configuration policy '<String>'(<Number>) associated with the plan |
| 85:1674 | New journal mailbox configuration policy '<String>'(<Number>) associated with the plan |
| 85:1675 | New retention mailbox configuration policy '<String>'(<Number>) associated with the plan |
| 85:1676 | New list of replication schedules associated with the plan : '<String>' |
| 85:1677 | New retention value '<Number>' set for the plan |
| 85:1678 | Schedule policy '<String>'(<Number>) associated with the plan |
| 85:1679 | New SLA value <Number> minutes set for the plan |
| 85:1680 | Storage policy '<String>'(<Number>) associated with the plan |
| 85:1681 | New linux subclient policy '<String>'(<Number>) associated with the plan |
| 85:1682 | New mac os subclient policy '<String>'(<Number>) associated with the plan |
| 85:1683 | New windows subclient policy '<String>'(<Number>) associated with the plan |
| 85:1684 | Password history count changed from [<Number>] to [<Number>]. |
| 85:1685 | Maximum days in event log changed from [<Number>] to [<Number>]. |
| 85:1686 | User [<String>] has deleted [<Number>] items for search criteria: [<String>] |
| 85:1687 | Encryption on primary was disabled. |
| 85:1688 | Encryption on primary was enabled. |
| 85:1689 | Override global encryption option was cleared. |
| 85:1690 | Override global encryption option was selected. |
| 85:1691 | Parameter [<String>] was changed from [<String>] to [<String>]. |
| 85:1692 | Red Hat OpenShift Instance credentials updated |
| 85:1693 | Jobs : [<String>] |
| 85:1694 | Prepare for retirement is disabled |
| 85:1695 | Prepare for retirement is enabled |
| 85:1696 | Subclient [<String>] cloned from Subclient [<String>] |
| 85:1697 | Name [<String>] |
| 85:1698 | Control Host modified from [<String>] to [<String>]. |
| 85:1699 | Use saved credential modified from [<String>] to [<String>]. |
| 85:1700 | Password has been changed. |
| 85:1701 | User Name modified from [<String>] to [<String>]. |
| 85:1702 | Library [<String>] - Operation Barcode Replace |
| 85:1703 | Barcode [<String>] was replaced with [<String>] |
| 85:1704 | Data aging on the client [<String>] has been disabled. |
| 85:1705 | Large amount of data deletion was detected during synthetic full job [<Number>]. Browse the client's data before re-enabling data aging. Contact your software provider for further questions. |
| 85:1706 | Client Owners for [<String>] is modified from Users [<String>] to [<String>]. |
| 85:1707 | Client Owners for [<String>] is modified from User Groups [<String>] to [<String>]. |
| 85:1708 | Created HAC Cluster [<String>] |
| 85:1709 | Deleted HAC Cluster [<String>] |
| 85:1710 | Added Node [<String>] to HAC Cluster [<String>] with Listener Port [<String>], Data Port [<String>], Election Port [<String>] |
| 85:1711 | Modified Node properties of client [<String>] for HAC Cluster [<String>] with Listener Port [<String>], Data Port [<String>], Election Port [<String>] |
| 85:1712 | Removed Node [<String>] from HAC Cluster [<String>] with Listener Port [<String>], Data Port [<String>], Election Port [<String>] |
| 85:1713 | Transferred ownership of <String> of Plan[<String>] to user[<String>]. |
| 85:1714 | Deduplication - Garbage Collection Disabled |
| 85:1715 | Deduplication - Garbage Collection Enabled |
| 85:1716 | Deduplication - Pruning log journaling Disabled |
| 85:1717 | Deduplication - Pruning log journaling Enabled |
| 85:1718 | [<String>] is deactivated. |
| 85:1719 | Client Owners for [<String>] is modified from Users [<String>] to [<String>]. |
| 85:1720 | Client Owners for [<String>] is modified from User Groups [<String>] to [<String>]. |
| 85:1721 | Content Index Policy: <String> |
| 85:1722 | Subclients Associated: |
| 85:1723 | Subclients dissociated: |
| 85:1724 | ResourcePool Name: [<String>] ID: [<Number>] |
| 85:1725 | [<String>] is activated. |
| 85:1726 | Disabled backup copy fallen behind alert. |
| 85:1727 | Enabled backup copy fallen behind alert. |
| 85:1728 | Backup Copy fallen behind alert jobs are not copied in days was changed from [<Number>] to [<Number>]. |
| 85:1729 | Backup Copy fallen behind alert jobs are not copied in hours was changed from [<Number>] to [<Number>]. |
| 85:1730 | Created 3dfs network share [<String>], backupset [<String>], 3dfs network server [<String>]. |
| 85:1731 | Deleted 3dfs network share [<String>], backupset [<String>], 3dfs network server [<String>]. |
| 85:1732 | Updated 3dfs network share [<String>], backupset [<String>], 3dfs network server [<String>]. |
| 85:1733 | Created 3dfs network share [<String>], subclient [<String>], 3dfs network server [<String>]. |
| 85:1734 | Deleted 3dfs network share [<String>], subclient [<String>], 3dfs network server [<String>]. |
| 85:1735 | Updated 3dfs network share [<String>], subclient [<String>], 3dfs network server [<String>]. |
| 85:1736 | Expire verification was changed from [<Number> (<String>)] to [<Number> (<String>)]. |
| 85:1737 | Weeks |
| 85:1738 | Years |
| 85:1739 | Region [<String>] is created. |
| 85:1740 | Region [<String>] has been deleted. |
| 85:1741 | Region: <String> |
| 85:1742 | Definition [<String>] of [<String>] created with options: [<String>] |
| 85:1743 | Definition [<String>] of [<String>] deleted with options: [<String>] |
| 85:1744 | Definition [<String>] of [<String>] updated with options: [<String>] |
| 85:1745 | Deleted: [<Number>] |
| 85:1746 | Definition: [<String>] |
| 85:1747 | Case: [<String>] |
| 85:1748 | Seal Deduplication Store Operation failed with reason [<String>]. |
| 85:1749 | Start Over Operation for storage policy [<String>] failed due to [<String>]. |
| 85:1750 | Start Over Operation for Storage Policy [<String>] completed successfully. |
| 85:1751 | The following subclients are marked for a full backup. |
| 85:1752 | Log Storage Policy: [<String>]. |
| 85:1753 | Log Storage Policy was changed from [<String>] to [<String>]. |
| 85:1754 | <String> |
| 85:1755 | Credential: <String> |
| 85:1756 | Domain: <String> |
| 85:1757 | SSO: <String> |
| 85:1758 | Enable Parallel Copy flag was turned off. |
| 85:1759 | Enable Parallel Copy flag was turned on. |
| 85:1760 | Data aging has been re-enabled by the system on affected clients to autocorrect an earlier issue. |
| 85:1761 | Client Display Name: <String> |
| 85:1762 | User has subscribed to alert SMS Notification. |
| 85:1763 | User has not subscribed to SMS Notification. |
| 85:1764 | Association between client ['<String>'] and plan ['<String>'] removed |
| 85:1765 | Association between company ['<String>'] and plan ['<String>'] removed |
| 85:1766 | Plan ['<String>'] is no longer the default plan for company ['<String>'] |
| 85:1767 | Association between email configuration policy ['<String>'] and plan ['<String>'] removed |
| 85:1768 | Association between subclient ['<String>'] and plan ['<String>'] removed |
| 85:1769 | Association between user ['<String>'] and plan ['<String>'] removed |
| 85:1770 | Libraries affected by MediaAgent[<String>] deletion:n<String> |
| 85:1771 | MountPaths affected by MediaAgent[<String>] deletion:n<String> |
| 85:1772 | Dedupe partitions affected by MediaAgent[<String>] deletion:n<String> |
| 85:1773 | Grace period for capacity license is set: [<String>] |
| 85:1774 | Grace period for usage license is set: [<String>] |
| 85:1775 | Passkey validation failed. |
| 85:1776 | Pruning on following deduplication stores have been disabled as part of MediaAgent deletion:<BR><String> |
| 85:1777 | Pruning have been enabled back on following deduplication stores as part of MediaAgent deletion:<BR><String> |
| 85:1778 | Subclient '<String>' content updated according '<String>' plan inheritance rules reflecting changes made on subclient policy '<String>' |
| 85:1779 | Subclient '<String>' retention values updated according '<String>' plan inheritance rules reflecting changes made on subclient policy '<String>' |
| 85:1780 | Auxiliary Copy end date was changed from [<String>] to [<String>]. |
| 85:1781 | Application [<String>] has been retired. |
| 85:1782 | Client [<String>] has been retired. |
| 85:1783 | Virtual Machine(s):[<String>] have been associated to Plan:[<String>]. |
| 85:1784 | Force Delete MountPath option selected. |
| 85:1785 | Jobs were killed to proceed MountPath deletion. JobIds [<String>]. |
| 85:1786 | Jobs were deleted to proceed MountPath deletion. |
| 85:1787 | Deleted the library [<String>], it does not have any MountPath. |
| 85:1788 | Deleted Replication Group [<String>] |
| 85:1789 | FBR [<String>] MediaAgent has changed from [<String>] to [<String>]. |
| 85:1790 | Replication group [<String>] has been created. |
| 85:1791 | Association between backupset ['<String>'] and plan ['<String>'] removed |
| 85:1792 | Exclude from SLA. |
| 85:1793 | SLA Exclude reason set to [<String>]. |
| 85:1794 | Include into SLA after delay set to [<String>]. |
| 85:1795 | SLA level set to: |
| 85:1796 | Last [<String>] days. |
| 85:1797 | CommCell level. |
| 85:1798 | WORM Copy flag was turned OFF |
| 85:1799 | WORM Copy flag was turned ON. |
| 85:1800 | Show Pseudo VM Jobs Option has been changed by user [<String>]. |
| 85:1801 | Company alias: <String> |
| 85:1802 | Associated SMTP: <String> |
| 85:1803 | Plan: <String> |
| 85:1804 | Primary site name: <String> |
| 85:1805 | Tenant Admin: <String> |
| 85:1806 | CommServe LiveSync automatic failover <String>. |
| 85:1807 | CommServe LiveSync <String>. |
| 85:1808 | Client(s) [<String>] have been retired. |
| 85:1809 | Pruning role disabled for Array Access Node [<String>]. |
| 85:1810 | Pruning role enabled for Array Access Node [<String>]. |
| 85:1811 | Removed Array Access Node [<String>]. |
| 85:1812 | Added Array Access Node [<String>] with Pruning role. |
| 85:1813 | Added Array Access Node [<String>] without Pruning role. |
| 85:1814 | Description : <String> |
| 85:1815 | Description was modified from [<String>] to [<String>]. |
| 85:1816 | Type changed from [File Server] to [File Server Primary]. |
| 85:1817 | Type changed from [File Server Primary] to [File Server]. |
| 85:1818 | Type [File Server] |
| 85:1819 | Type [OnCommand Unified Manager] |
| 85:1820 | Type [File Server Primary] |
| 85:1821 | Automatic cleanup (Snap pruning and unmounts) has been disabled. |
| 85:1822 | Automatic cleanup (Snap pruning and unmounts) has been enabled. |
| 85:1823 | Control Host [<String>] |
| 85:1824 | Use saved credential [<String>] |
| 85:1825 | User Name [<String>] |
| 85:1826 | Snap Vendor [<String>] |
| 85:1827 | Force Delete Library option selected. |
| 85:1828 | Jobs force killed by Library deletion. Job Ids [<String>] |
| 85:1829 | Deduplication DB Verification job submitted by Library deletion. Job Ids [<String>] |
| 85:1830 | Deleted company [<String>] |
| 85:1831 | Deleted app plans [<String>] of company [<String>] |
| 85:1832 | Deleted Server groups [<String>] of company [<String>] |
| 85:1833 | Deleted media agents [<String>] of company [<String>] |
| 85:1834 | Deleted non-data bearing entities of company [<String>] |
| 85:1835 | Retire client started for clients [<String>] of company [<String>] |
| 85:1836 | Deleted schedule policies [<String>] of company [<String>] |
| 85:1837 | Deleted storage policies [<String>] of company [<String>] |
| 85:1838 | Deleted storage pools [<String>] of company [<String>] |
| 85:1839 | Solutions added: [<String>] |
| 85:1840 | Solutions removed: [<String>] |
| 85:1841 | Mount path is disabled |
| 85:1842 | Mount path is enabled |
| 85:1843 | Storage policies added: [<String>] |
| 85:1844 | Storage policies removed: [<String>] |
| 85:1845 | CommServe LiveSync autoscale <String>. |
| 85:1846 | Replication pair: [<String>] : [<String>] is deleted. |
| 85:1847 | Replication pair: [<String>] : [<String>] of the replication group: [<String>] is deleted. |
| 85:1848 | Association between instance ['<String>'] and plan ['<String>'] removed |
| 85:1849 | [<String>] |
| 85:1850 | [<String>] |
| 85:1851 | [<String>] |
| 85:1852 | Accepted Metallic Recovery Reserve user agreement. |
| 85:1853 | User [<String>] did external pruning on instance [<String>] for <Number> pieces for backup taken between <String> and <String>. |
| 85:1854 | Service Commcell Role: <String> |
| 85:1855 | Auto select instance type set to true |
| 85:1856 | Create public IP set to [<String>] |
| 85:1857 | IAM Role changed from [<String>] to [<String>] |
| 85:1858 | Instance type changed from [<String>] to [<String>] |
| 85:1859 | Maximum number of access nodes changed from [<Number>] to [<Number>] |
| 85:1860 | Added Storage Accelerator Credential [<String>]. |
| 85:1861 | Changed Storage Accelerator Credential from [<String>] to [<String>]. |
| 85:1862 | Access nodes group changed from [<Number>] to [<Number>] |
| 85:1863 | Apptype changed from [<Number>] to [<Number>] |
| 85:1864 | Index server changed from [<Number>] to [<Number>] |
| 85:1865 | Name changed from [<String>] to [<String>] |
| 85:1866 | Storage pool changed from [<Number>] to [<Number>] |
| 85:1867 | Client is marked as Infrastructure machine by the user. |
| 85:1868 | Client is marked as non Infrastructure machine by the user. |
| 85:1869 | Commcell [<String>] has been linked to Company [<String>] with user [<String>]. |
| 85:1870 | Plan updated from [<String>] to [<String>] for Index Server [<String>]. |
| 85:1871 | Client(s) [<String>] are retired. |
| 85:1872 | Plan storage rule for region [<String>] is deleted successfully |
| 85:1873 | Storage Pool: <String> |
| 85:1874 | Log backup RPO of plan [<String>] modified from [<String>] to [<String>] minutes. |
| 85:1875 | Login attempts for user [<String>] exceeded limit. Account is locked for [<String>] |
| 85:1876 | Job Priority: <Number> |
| 85:1877 | New webhook [<String>] created. |
| 85:1878 | Replace all disks submitted for HyperScale X StoragePool:[<String>], MediaAgent:[<String>]. |
| 85:1879 | SQL authentication Credential Association changed by user [<String>]. |
| 85:1880 | Full database backup frequency of plan [<String>] modified from [<String>] to [<String>] days. |
| 85:1881 | Web authenticator added for User: [<String>] on Host: [<String>] |
| 85:1882 | Web authenticator removed for User: [<String>] |
| 85:1883 | Rule : [<String>] for plan -[<String>] deleted. |
| 85:1884 | [<String>] deleted [<Number>] export set(s). n<String> |
| 85:1885 | Deleted Storage Accelerator Credentials |
| 85:1886 | Company [<String>] on Commcell [<String>] has been linked to [<String>] with user [<String>]. |
| 85:1887 | Company [<String>] on Commcell [<String>] has been unlinked from [<String>] with user [<String>]. |
| 85:1888 | Commcell [<String>] has been unlinked from [<String>] with user [<String>]. |
| 85:1889 | UserName [<String>] DatasourceId [<String>] DatasourceName [<String>] CoreName [<String>] Reason [<String>] |
| 85:1890 | Added new category [<String>] in download center |
| 85:1891 | Added new package [<String>] in download center |
| 85:1892 | Added new repository [<String>] in download center |
| 85:1893 | Added new sub-category [<String>] in download center |
| 85:1894 | Deleted category [<String>] from download center |
| 85:1895 | Deleted package [<String>] from download center |
| 85:1896 | Deleted repository [<String>] from download center |
| 85:1897 | Deleted sub-category [<String>] from download center |
| 85:1898 | Edited category [<String>] in download center |
| 85:1899 | Edited package [<String>] in download center |
| 85:1900 | Edited repository [<String>] in download center |
| 85:1901 | Edited sub-category [<String>] in download center |
| 85:1902 | [<String>] records added. |
| 85:1903 | [<String>] records deleted. |
| 85:1904 | [<String>] records modified. |
| 85:1905 | User [<String>] is added as client owner for [<String>]. |
| 85:1906 | Job Status: [FAILED] |
| 85:1907 | Job Status: [PARTIAL SUCCESS] |
| 85:1908 | Job Status: [SUCCESS] |
| 85:1909 | Erase Operation Type: [FULL ERASE] |
| 85:1910 | Erase Media failed for: <String> |
| 85:1911 | Erase Media successful for: <String> |
| 85:1912 | Erase Operation Type: [QUICK ERASE] |
| 85:1913 | Inherit job retention from source copy was disabled |
| 85:1914 | Inherit job retention from source copy was enabled |
| 85:1915 | Inherit job retention on existing jobs was enabled |
| 85:1916 | Database |
| 85:1917 | Virtualization |
| 85:1918 | [<Message>] vendors added: [<String>] |
| 85:1919 | [<Message>] vendors removed: [<String>] |
| 85:1920 | Rule : [<String>] for plan -[<String>] marked as incomplete. |
| 85:1921 | Two factor authentication is disabled for company : [<String>]. |
| 85:1922 | Two factor authentication is enabled for company : [<String>]. |
| 85:1923 | <String> n <String> n Company : [<String>] |
| 85:1924 | Two factor authentication is enabled for user groups : |
| 85:1925 | Two factor authentication is disabled for user groups : |
| 85:1926 | The DDB Store [Id - <Number>, Name - <String>], Substore [Id - <Number>, Path - (<String>)<String>] does not have any data, hence converting Move partition job request to Config-Only move operation. |
| 85:1927 | Entity Name: [<String>] Type: [<String>] ID: [<Number>] |
| 85:1928 | [<String>] region updated from [<String>] to [<String>] |
| 85:1929 | NetApp Cloud Target copy has been enabled. |
| 85:1930 | User performed [<String>] operation for [<String>] : [<String>] |
| 85:1931 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet : [<String>] |
| 85:1932 | File name : [<String>] |
| 85:1933 | File path : [<String>] |
| 85:1934 | From : [<String>] |
| 85:1935 | Subject : [<String>] |
| 85:1936 | To : [<String>] |
| 85:1937 | Username : [<String>] |
| 85:1938 | Configure an RP Store. |
| 85:1939 | Deconfigure an RP Store. |
| 85:1940 | Update an RP Store. |
| 85:1941 | Account lock duration changed from [<String>] seconds to [<String>] seconds. |
| 85:1942 | Account lock duration increment changed from [<String>] seconds to [<String>] seconds. |
| 85:1943 | Failed login attempt limit changed from [<String>] attempts to [<String>] attempts. |
| 85:1944 | Failed login attempts within duration changed from [<String>] seconds to [<String>] seconds. |
| 85:1945 | Company [<String>] has been marked for delete. |
| 85:1946 | Deleted empty client groups list [<String>]. |
| 85:1947 | <laptopName:ownerName>: [<String>] |
| 85:1948 | [<String>] is assigned as owner to laptop [<String>]. |
| 85:1949 | Replication Group [<String>] site is updated to [<String>]. |
| 85:1950 | Execution mode set to [<String>] for [<String>] |
| 85:1951 | Workflow description is changed from [<String>] to [<String>]. |
| 85:1952 | Workflow name is changed from [<String>] to [<String>]. |
| 85:1953 | User performed [<String>] operation <String> |
| 85:1954 | Mailbox : [<String>] |
| 85:1955 | Syslog modified for <String> |
| 85:1956 | Hostname : <String> |
| 85:1957 | <String> : <String> |
| 85:1958 | Port : <String> |
| 85:1959 | Secure messaging : <String> |
| 85:1960 | Client : <String> |
| 85:1961 | [<String>] user group(s) added. |
| 85:1962 | [<String>] user(s) added. |
| 85:1963 | [<String>] user group(s) removed. |
| 85:1964 | [<String>] user(s) removed. |
| 85:1965 | Approval Request completed by user: [<String>] |
| 85:1966 | Approved : [<String>] |
| 85:1967 | Company : [<String>] |
| 85:1968 | Requested by : [<String>] |
| 85:1969 | Requested from : [<String>] |
| 85:1970 | Infrastructure Resource Name : [<String>] |
| 85:1971 | Custom REST API Token Type |
| 85:1972 | Access Token |
| 85:1973 | Renewed the REST Access Token. |
| 85:1974 | Added the Custom Token Type [<String>] |
| 85:1975 | Deleted the Custom Token Type [<String>] |
| 85:1976 | Updated the Custom Token Type [<String>] |
| 85:1977 | Added API Token [<String>] Type [^%2s] |
| 85:1978 | Deleted Access Token [<String>] |
| 85:1979 | for Group [<String>] |
| 85:1980 | Updated Access Token [<String>] |
| 85:1981 | Added Access Token [<String>] Scope [<String>] |
| 85:1982 | <String> |
| 85:1983 | HyperScale X Operation Type : MODIFY ROOT ACCESS |
| 85:1984 | All existing Laptop Admin(s) are removed. |
| 85:1985 | Associated Data Classification Plan changed from [<String>] for [<String>] |
| 85:1986 | webhook [<String>] deleted. |
| 85:1987 | webhook [<String>] modified |
| 85:1988 | SIEM connector [<String>] created |
| 85:1989 | SIEM connector [<String>] deleted. |
| 85:1990 | SIEM connector [<String>] modified |
| 85:1991 | Client group(s) [<String>] set as associated member servers |
| 85:1992 | Client(s) [<String>] set as associated member servers |
| 85:1993 | Client(s) [<String>] and client group(s) [<String>] set as associated member servers |
| 85:1994 | Access nodes associated with plan [<String>] ([<Number>]) are set as associated member servers. |
| 85:1995 | Access nodes associated with plan [<String>] ([<Number>]) (client group(s) [<String>]) are set as associated member servers |
| 85:1996 | Access nodes associated with plan [<String>] ([<Number>]) (client(s) [<String>]) are set as associated member servers |
| 85:1997 | Access nodes associated with plan [<String>] ([<Number>]) (client(s) [<String>], client group(s) [<String>]) are set as associated member servers |
| 85:1998 | Contains: [<String>] |
| 85:1999 | Accessing entities [<String>] in client [<String>] |
| 85:2000 | File extensions: [<String>] |
| 85:2001 | Keyword: [<String>] |
| 85:2002 | Modified time: [<String>] to [<String>] |
| 85:2003 | Size: [<String>] KB to [<String>] KB |
| 85:2004 | User name: [<String>] |
| 85:2005 | Access Token Expiration Date changed from [<String>] to [<String>] |
| 85:2006 | Access Token name changed from [<String>] to [<String>] |
| 85:2007 | Access Token allowed endpoints is set to [<String>] |
| 85:2008 | Company [<String>] subscribed to [<String>] subscription by [<String>] |
| 85:2009 | User [<String>] subscribed self to [<String>] subscription |
| 85:2010 | Company [<String>] unsubscribed from [<String>] subscription by [<String>] |
| 85:2011 | User [<String>] unsubscribed self from [<String>] subscription |
| 85:2012 | Company - Client(s) Information <String> |
| 85:2013 | <String> Removed |
| 85:2014 | <String>: Reverted back to original |
| 85:2015 | Hardware WORM flag was turned ON for storage pool. |
| 85:2016 | Change Fallen Behind Action from [<Number>] to [<Number>]. |
| 85:2017 | Change Fallen Behind Threshold from [<Number>] to [<Number>]. |
| 85:2018 | Object Type: [<String>] |
| 85:2019 | Applicable solutions changed from [<String>] to [<String>] for plan -[<String>] |
| 85:2020 | Client [<String>] excluded from SLA with exclusion type [<String>]. Include back in SLA after [<String>]. Exclusion Reason [<String>] |
| 85:2021 | Data Type: [<String>] |
| 85:2022 | Has Attachment: [<String>] |
| 85:2023 | Updated snapshot configuration [<String>] |
| 85:2024 | Updated snapshot configuration [<String>] from [<String>] to [<String>] |
| 85:2025 | Client Name : [<String>] Display Name : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet : [<String>] |
| 85:2026 | Storage WORM Lock Enabled |
| 85:2027 | Overriding Pool Retention Cycles [<String>] |
| 85:2028 | Overriding Pool Retention Days [<String>] |
| 85:2029 | Pool Retention Cycles [<String>] |
| 85:2030 | Pool Retention Days [<String>] |
| 85:2031 | Compliance WORM Lock Enabled |
| 85:2032 | Operation was approved by: [<String>] |
| 85:2033 | Automatic Access Node selection is disabled for the hypervisor(s): [<String>] |
| 85:2034 | Updated reseller [<String>] to company [<String>]. |
| 85:2035 | Tenant Admins of Company [<String>] subscribed to [<String>] subscription by [<String>] |
| 85:2036 | Tenant Operators of Company [<String>] subscribed to [<String>] subscription by [<String>] |
| 85:2037 | Tenant Admins of Company [<String>] unsubscribed from [<String>] subscription by [<String>] |
| 85:2038 | Tenant Operators of Company [<String>] unsubscribed from [<String>] subscription by [<String>] |
| 85:2039 | The password is set. |
| 85:2040 | Check CommservSurveyUtility log file for details |
| 85:2041 | Subclient will be excluded from SLA with exclusion type [<String>]. Include back in SLA after [<String>]. Exclusion Reason [<String>]. |
| 85:2042 | SAML Name: <String> |
| 85:2043 | Browse Type : [<String>] |
| 85:2044 | Edited Snapshot configurations at [<String>] [<String>] |
| 85:2045 | Edited Snapshot configurations at [array] |
| 85:2046 | Backups on Plans '<String>' have been : <String> |
| 85:2047 | Existing Status: [<String>] |
| 85:2048 | New Status: [<String>] |
| 85:2049 | Received time: [<String>] to [<String>] |
| 85:2050 | Local authentication was disabled for all users. |
| 85:2051 | Local authentication was enabled for all users. |
| 85:2052 | Local authentication was enabled for these new user groups : [<String>] |
| 85:2053 | Local authentication was disabled for these user groups : [<String>] |
| 85:2054 | API [<String>] failed with status code [<String>] |
| 85:2055 | <String> have been modified on Storage Pool <String>/<String>. n Data aging has been disabled for the below dependent copies, n <String>. |
| 85:2056 | Access node of [<String>] |
| 85:2057 | <String> backup codes generated for user [<String>] of [<String>]. |
| 85:2058 | User [<String>] of [<String>] utilized a backup code successfully. |
| 85:2059 | New Backup copy schedule: <String> |
| 85:2060 | New Deferred Snap Cataloging schedule: <String> |
| 85:2061 | Old Backup copy schedule: <String> |
| 85:2062 | Old Deferred Snap Cataloging schedule: <String> |
| 85:2063 | Operation [<String>] attempted on resource [<String>] by process [<String>] at timestamp [<String>] blocked |
| 85:2064 | Login failed due to incorrect password |
| 85:2065 | Login failed due to incorrect two-factor authentication pin |
| 85:2066 | Disable user operation failed due to insufficient permission |
| 85:2067 | Enable user operation failed due to insufficient permission |
| 85:2068 | An update user operation was attempted, but failed due to insufficient permission on the current user |
| 85:2069 | AuthCode generated for user group : [<String>]. |
| 85:2070 | AuthCode saved for user group : [<String>]. |
| 85:2071 | AuthCode updated for user group : [<String>]. |
| 85:2072 | More than 1 company associated to user. Please try onboarding with some unique user to company |
| 85:2073 | No company associated to user |
| 85:2074 | Deleted: [<Number>] items in [<String>] |
| 85:2075 | Delete Reason: [<String>] Deleted Items: [<String>] |
| 85:2076 | Failed to disable compliance lock. |
| 85:2077 | Added new DDB disk [<String>] on MediaAgent [<Number> : <String>] |
| 85:2078 | Moving DDB disk from source MediaAgent [<String>] and path [<String>] to target MediaAgent [<String>] and path [<String>] |
| 85:2079 | Config-only move partition completed for following partitions [<String>] |
| 85:2080 | Move partition failed for following partitions [<String>] |
| 85:2081 | Move partition job submitted for following partitions [<String>] |
| 85:2082 | DDB disk [<String>] on MediaAgent [<Number> : <String>] has been deleted |
| 85:2083 | All usage enforcements for tenant [<String>] were deleted. |
| 85:2084 | All usage enforcements for usagetype [<String>] for tenant [<String>] were deleted. |
| 85:2085 | Usage [<String>] [<String>] for usagetype [<String>] for tenant [<String>] was [<String>]. |
| 85:2086 | As this was the first successful test login, SAML app has now been auto enabled. |
| 85:2087 | SAML test login for app [<String>] of [<String>] failed. |
| 85:2088 | SAML test login for app [<String>] of [<String>] succeeded for user [<String>]. |
| 85:2089 | Reason: <String> |
| 85:2090 | User [<String>] with email [<String>] excluded from user group [<String>] as part of migration for company [<String>] |
| 85:2091 | Array has been marked for deletion. |
| 85:2092 | Associated [<String>] as a DDB MediaAgent with StoragePool [<String>] |
| 85:2093 | Associated [<String>] as a Storage MediaAgent with StoragePool [<String>] |
| 85:2094 | Removed [<String>] as a DDB MediaAgent from StoragePool [<String>] |
| 85:2095 | Removed [<String>] as a Storage MediaAgent from StoragePool [<String>] |
| 85:2096 | Threatwise Registration code Generated for Company : [<String>]. |
| 85:2097 | Basic retention rule for the copy: [Days - <Number>] [Cycles - <Number>]. |
| 85:2098 | Associated User Groups |
| 85:2099 | Failed to enable root access. |
| 85:2100 | Proxy Host modified from [<String>] to [<String>]. |
| 85:2101 | Proxy password modified. |
| 85:2102 | Proxy port modified from [<Number>] to [<Number>]. |
| 85:2103 | Proxy user modified from [<String>] to [<String>]. |
| 85:2104 | Service Host modified from [<String>] to [<String>]. |
| 85:2105 | Storage class modified from [<String>] to [<String>]. |
| 85:2106 | Disabled minimum allowed retention days on copy. |
| 85:2107 | Enabled minimum allowed retention days [<Number>] on copy. |
| 85:2108 | Failed to disable minimum allowed retention days on copy. |
| 85:2109 | Failed to enable minimum allowed retention days [<Number>] on copy. |
| 85:2110 | Delete operation skipped, manual deletion of jobs that have not met the minimum retention days configured on the copy is not allowed. Job(s): [<String>], Storage Policy: [<String>], Copy: [<String>]. |
| 85:2111 | New Storage Policy Primary Copy: <String> |
| 85:2112 | Old Storage Policy Primary Copy: <String> |
| 85:2113 | Snapshot properties modified for plan '<String>': Deferred catalog operation has been '<String>' |
| 85:2114 | Snapshot properties modified for plan '<String>': Backup copy operation has been '<String>' |
| 85:2115 | Overwrite media option was turned off. |
| 85:2116 | Immutable snapshot property has been enabled. |
| 85:2117 | Auto stamp option turned off |
| 85:2118 | Auto stamp option turned on |
| 85:2119 | Barcode pattern label [<String>] added |
| 85:2120 | Barcode pattern label [<String>] deleted |
| 85:2121 | Barcode pattern label updated from [<String>] to [<String>] |
| 85:2122 | Removed expired anomalies for clients [<String>] |
| 85:2123 | HyperScale X storage space usage extended past [<Number>]% by user. |
| 85:2124 | Snapshot properties modified for plan '<String>': Backup Copy properties has been modified. Type is ['<Number>'], Start time is ['<Number>'], Fallen behind alert is ['<String>'] after ['<Number>'] hours, and Action is ['<Number>'] for ['<Number>'] days. |
| 85:2125 | Mark Media Failed for: <String> |
| 85:2126 | Mark Media Successful for: <String> |
| 85:2127 | Array has been [<String>] for snap backups for all the companies in the CommCell. |
| 85:2128 | Array has been [<String>] for snap backups for all child companies of reseller company [<String>]. |
| 85:2129 | Drive [<String>] is shared with MediaAgent(s) [<String>] |
| 85:2130 | All associations removed from MediaAgent [<String>] |
| 85:2131 | Destination Client: [<String>] Destination Instance: [<String>] |
| 85:2132 | Clone Creation Time : <String> |
| 85:2133 | Clone Job ID: [<Number>] |
| 85:2134 | Snap Job ID: [<Number>] |
| 85:2135 | Status: Initialization pending |
| 85:2136 | Status: Airgap On |
| 85:2137 | Block size is set to [<Number>]KB. |
| 85:2138 | Hardware encryption is set to [<Number>] |
| 85:2139 | Library: <String> |
| 85:2140 | Kill request for V2 laptop backup jobs for plan [<String>] is submitted. |
| 85:2141 | Default media type of the spare group has been updated from [<String>] to [<String>]. |
| 85:2142 | Active management has been disabled for Commcell [<String>]. |
| 85:2143 | Active management has been disabled from global commcell. |
| 85:2144 | Active management has been enabled for Commcell [<String>]. |
| 85:2145 | Active management has been enabled with global commcell. |
| 85:2146 | Servers associated: <String> |
| 85:2147 | Servers associated changed from [<String>] to [<String>] |
| 85:2148 | Data folder: <String> |
| 85:2149 | Log folder: <String> |
| 85:2150 | Replica server: <String> |
| 85:2151 | Snapshot folder: <String> |
| 85:2152 | Recovery group [<String>] created successfully |
| 85:2153 | Copy Promotion request has been submitted. |
| 85:2154 | Recovery Entity [<String>] created for Recovery Group [<String>] |
| 85:2155 | Recovery Entity [<String>] deleted from Recovery Group [<String>] |
| 85:2156 | Recovery group [<String>] deleted successfully |
| 85:2157 | Recovery Entity description: <String> |
| 85:2158 | Recovery Group description: <String> |
| 85:2159 | Copy [<String>] Vendor [<String>] Source [<String>] Target [<String>] Type [<String>] |
| 85:2160 | Removed subclients [<String>] |
| 85:2161 | Associated subclients [<String>] |
GUI Messages
| Code | Description |
| 35:1 | Event Manager Server Service Stopping. |
| 35:2 | Internal error. |
| 35:3 | Client lock failed. |
| 35:4 | Archive group failed. |
| 35:5 | Filter lock failed. |
| 35:6 | Failed to connect to <String>. |
| 35:7 | Account is disabled. |
| 35:8 | Invalid login/password. |
| 35:9 | User <String> does not have <String> permission. |
| 35:10 | Operation is a success. |
| 35:11 | Operation is a success: <String>. |
| 35:12 | Operation failed. |
| 35:13 | Operation failed: <String>. |
| 35:14 | Operation is unknown. |
| 35:15 | No CommCell is specified. |
| 35:16 | No client is specified. |
| 35:17 | No application type is specified. |
| 35:18 | No instance is specified. |
| 35:19 | No Backup Set is specified. |
| 35:20 | No subclient is specified. |
| 35:21 | No data archive group is specified. |
| 35:22 | No index archive group is specified. |
| 35:23 | No object is found. |
| 35:24 | No copy header is specified. |
| 35:25 | No MediaAgent is specified. |
| 35:26 | No spare media group is specified. |
| 35:27 | No library is specified. |
| 35:28 | No archive group header is specified. |
| 35:29 | Successful! |
| 35:30 | Client [<String>] has been deleted. |
| 35:31 | Application Type [<String>] has been deleted. |
| 35:32 | Backup Set [<String>] has been deleted. |
| 35:33 | Instance [<String>] has been deleted. |
| 35:34 | Subclient [<String>] has been deleted. |
| 35:35 | Drive [<String>] is turned online. |
| 35:36 | Drive [<String>] is turned offline. |
| 35:37 | Library [<String>] is turned online. |
| 35:38 | Library [<String>] is turned offline. |
| 35:39 | Media Manager connection failed - [<String>]. |
| 35:40 | Cannot set data pipe interface for [<String>]. |
| 35:41 | Please specify media type to continue. |
| 35:42 | Failed to set Client properties. |
| 35:43 | Failed to set Application properties. |
| 35:44 | Failed to set Backup Set properties. |
| 35:45 | Failed to set Application properties for Exchange Mailbox. |
| 35:46 | Failed to set Application properties for Exchange Database. |
| 35:47 | Failed to set Backup Set properties for Exchange Mailbox. |
| 35:48 | Failed to move Job Results. Unable to initialize with Job Manager. |
| 35:49 | Failed to move Job Results. Jobs are still running. |
| 35:50 | Failed to move job results location. |
| 35:51 | Failed to decrypt password. |
| 35:52 | Failed to set password. |
| 35:53 | No CommCells loaded. |
| 35:54 | Client [<String>]: Job Results Directory may not be accurate due to problems accessing remote registry. |
| 35:55 | Client [<String>]: Version may not be accurate due to problems looking up client package information. |
| 35:56 | Failed to connect to Client Event Manager. |
| 35:57 | Failed to shut down services. |
| 35:58 | Failed to submit Forecast Request to Job Manager. |
| 35:59 | Failed To Generate Report. |
| 35:60 | OPERATION FAILED: No permission to update licensing on Server. |
| 35:61 | OPERATION FAILED: Memory allocation error. |
| 35:62 | OPERATION FAILED: Schedule has ended. |
| 35:63 | OPERATION FAILED: Valid date could not be computed. |
| 35:64 | OPERATION FAILED: Start time is after end time. |
| 35:65 | OPERATION FAILED: Schedule entry could not be written to the database. |
| 35:66 | OPERATION FAILED: AdminTask entry could not be written to the database. |
| 35:67 | OPERATION FAILED: BackupTask entry could not be written to the database. |
| 35:68 | OPERATION FAILED: RestoreTask entry could not be written to the database. |
| 35:69 | OPERATION FAILED: Could not commit schedule to the database. |
| 35:70 | OPERATION FAILED: Scheduled time has passed. |
| 35:71 | Add task failed to create schedule entry. |
| 35:72 | Admin task failed to create schedule entry. |
| 35:73 | Update task failed to update schedule entry. |
| 35:74 | Delete task failed to remove schedule entry. Entry cannot be deleted. |
| 35:75 | Delete task failed to remove schedule entry. Entry not found. |
| 35:76 | OPERATION FAILED: BackupTask entry not found. |
| 35:77 | OPERATION FAILED: RestoreTask entry not found. |
| 35:78 | OPERATION FAILED: User [<String>] does not have [Schedule Backup] permissions for [<String>]. |
| 35:79 | OPERATION FAILED: User [<String>] does not have [Schedule Restore] permissions. |
| 35:80 | OPERATION FAILED: User [<String>] does not have [Schedule Admin] permissions. |
| 35:81 | OPERATION FAILED: User [<String>] does not have [Administrative Management] permissions. |
| 35:82 | Delete failed. Entry is marked in-progress. |
| 35:83 | Update failed. Schedule entry not found. |
| 35:84 | Update failed. Entry is not editable. |
| 35:85 | Failed executing admin task. |
| 35:86 | OPERATION FAILED: Invalid AdminTask type. |
| 35:87 | Data Aging failed. Unable to initialize archive pruner. |
| 35:88 | Express Recovery failed. Unable to initialize express recovery. |
| 35:89 | Auxiliary copy failed. Unable to initialize Auxiliary Copy. |
| 35:90 | OPERATION FAILED: Unable to submit request to Job Manager. |
| 35:91 | Backup failed to submit to Job Manager. Incomplete data. |
| 35:92 | Backup failed to submit to Job Manager. Error [<Number>] getting subclient list for backup set [<Number>]. |
| 35:93 | Backup failed to submit to Job Manager. Subclient list for backup set [<Number>] is empty. |
| 35:94 | Backup failed to submit to Job Manager. Exception getting subclient list for backup set [<Number>]. |
| 35:95 | Failed to submit backup request. Error allocating memory or initializing CommCell or Client data. |
| 35:96 | Failed to submit backup request. Could not create a request to submit to the Job Manager. |
| 35:97 | Failed to submit backup request to Job Manager. |
| 35:98 | Failed to submit backup request. SubClient ID [<Number>] not found in database. |
| 35:99 | Failed to submit backup request. Error in accessing application [<Number>] for subclient [<String>]. |
| 35:100 | No permission to set activity control. |
| 35:101 | Failed to set backup activity on Server. |
| 35:102 | Failed to set restore activity on Server. |
| 35:103 | Failed to set Auxiliary Copy activity on Server. |
| 35:104 | Failed to set Disaster Recovery backup activity on Server. |
| 35:105 | Failed to set Data Aging activity on Server. |
| 35:106 | Failed to set media recycle activity on Server. |
| 35:107 | Failed to set synthetic full activity on Server. |
| 35:108 | Failed to set all activity on Server. |
| 35:109 | Failed to set activity control on Server. |
| 35:110 | Failed to set backup activity on Application Type. |
| 35:111 | Failed to set restore activity on Application Type. |
| 35:112 | Failed to set Auxiliary Copy activity on Application Type. |
| 35:113 | Failed to set Disaster Recovery backup activity on Application Type. |
| 35:114 | Failed to set Data Aging activity on Application Type. |
| 35:115 | Failed to set media recycle activity on Application Type. |
| 35:116 | Failed to set synthetic full activity on Application Type. |
| 35:117 | Failed to set all activity on Application Type. |
| 35:118 | Failed to set activity control on Application Type. |
| 35:119 | Failed to set backup activity on Client. |
| 35:120 | Failed to set restore activity on Client. |
| 35:121 | Failed to set Auxiliary Copy activity on Client. |
| 35:122 | Failed to set Disaster Recovery backup activity on Client. |
| 35:123 | Failed to set Data Aging activity on Client. |
| 35:124 | Failed to set media recycle activity on Client. |
| 35:125 | Failed to set synthetic full activity on Client. |
| 35:126 | Failed to set all activity on Client. |
| 35:127 | Failed to set activity control on Client. |
| 35:128 | Failed to set backup activity on Client Application Type. |
| 35:129 | Failed to set restore activity on Client Application Type. |
| 35:130 | Failed to set Auxiliary Copy activity on Client Application Type. |
| 35:131 | Failed to set Disaster Recovery backup activity on Client Application Type. |
| 35:132 | Failed to set Data Aging activity on Client Application Type. |
| 35:133 | Failed to set media recycle activity on Client Application Type. |
| 35:134 | Failed to set synthetic full activity on Client Application Type. |
| 35:135 | Failed to set all activity on Client Application Type. |
| 35:136 | Failed to set activity control on Client Application Type. |
| 35:137 | Failed to enable all activity on MediaAgent. |
| 35:138 | Failed to create new subclient. |
| 35:139 | A subclient by this name already exists as part of this backup set. |
| 35:140 | Failed to delete Subclient. User does not have permission. |
| 35:141 | Failed to delete Subclient. Unable to initialize with Job Manager. |
| 35:142 | Failed to delete Subclient. Jobs are still running. |
| 35:143 | Failed to delete Subclient. Unable to age subclient content. |
| 35:144 | Failed to delete Subclient. |
| 35:145 | Failed to delete Backup Set. User does not have permission. |
| 35:146 | Failed to delete Backup Set. Unable to initialize with Job Manager. |
| 35:147 | Failed to delete Backup Set. Jobs are still running. |
| 35:148 | Failed to delete Backup Set. |
| 35:149 | Failed to delete Instance. User does not have permission. |
| 35:150 | Failed to delete Instance. Unable to initialize with Job Manager. |
| 35:151 | Failed to delete Instance. Jobs are still running. |
| 35:152 | Failed to delete Instance. |
| 35:153 | Failed to delete Instance. Cannot be deleted unless already marked for deletion. |
| 35:154 | Failed to delete Application Type. User does not have permission. |
| 35:155 | Failed to delete Application Type. Unable to initialize with Job Manager. |
| 35:156 | Failed to delete Application Type. Jobs are still running. |
| 35:157 | Failed to delete Application Type. |
| 35:158 | Failed to delete Application Type. Cannot be deleted unless already marked for deletion. |
| 35:159 | Failed to delete Application Type. Failed JM clean activity control. |
| 35:160 | Failed to delete Client. User does not have permission. |
| 35:161 | Failed to delete Client. Unable to initialize with Job Manager. |
| 35:162 | Failed to delete Client. Jobs are still running. |
| 35:163 | Failed to delete Client. |
| 35:164 | Failed to delete Client. Cannot be deleted unless already marked for deletion. |
| 35:165 | Failed to delete Client. Failed JM clean activity control. |
| 35:166 | Unable to save any CommCell Properties at this time. |
| 35:167 | Failed to access Disaster Recovery destination. |
| 35:168 | Failed to create destination folder. |
| 35:169 | Failed to set Media Parameters. |
| 35:170 | Failed to set Drive Parameters. |
| 35:171 | Failed while moving the directory; MediaAgent services may be down or source file may be in use. |
| 35:172 | Failed to Initialize Events. |
| 35:173 | Invalid Number of arguments. |
| 35:174 | Unable to get current Job Results directory for iDataAgent. |
| 35:175 | Unable to get current Index Cache directory for MediaAgent. |
| 35:176 | Invalid Platform. |
| 35:177 | Unable to determine if jobs are running. |
| 35:178 | Error accessing directory information. |
| 35:179 | Source directory does not exist. |
| 35:180 | Destination directory cannot be created. |
| 35:181 | Failed to set new Job Results directory on Client. |
| 35:182 | Failed to set new Index Cache directory on MediaAgent. |
| 35:183 | Database transaction failed to start [<Number>/<String>]. |
| 35:184 | Failed to create storage policy [<String>]. |
| 35:185 | Failed to update storage policy [<String>]. |
| 35:186 | Failed to delete storage policy [<String>]. |
| 35:187 | The storage policy is associated with subclients. Please reassociate its subclients with another storage policy. |
| 35:188 | Failed to get applications for storage policy, delete aborted. |
| 35:189 | Failed to get drive pool for library [<String>]. |
| 35:190 | Failed to get media types for drive pool [<String>]. |
| 35:191 | Failed to get recording formats for drive pool [<String>]. |
| 35:192 | Failed to create copy [<String>] for storage policy [<String>], the same copy name may be used already. |
| 35:193 | Failed to update copy [<String>]. |
| 35:194 | Failed to delete copy [<String>]. |
| 35:195 | Failed to set copy [<Number>] <String>. |
| 35:196 | Failed to create aging rule for copy [<Number>]. |
| 35:197 | Failed to update aging rule for copy [<Number>]. |
| 35:198 | Failed to set hardware compression for copy [<Number>]. |
| 35:199 | Failed to set copy [<String>] to primary. |
| 35:200 | Failed to set precedence for copy [<Number>]. |
| 35:201 | Failed to update copy [<String>]: copies are not synchronized. |
| 35:202 | Operation failed: One copy in this storage policy is pointing to a library with fewer resources than number of streams desired. |
| 35:203 | Could not move Job Results; unable to init with Job Manager. |
| 35:204 | Could not move Job Results; jobs still running. |
| 35:205 | Failed to create new backup set. |
| 35:206 | A backup set by this name already exists. |
| 35:207 | Error getting the destination drive information. |
| 35:208 | Destination drive is a compressed drive. |
| 35:209 | Drive [<String>] in Library[<String>] is turned online. |
| 35:210 | Drive [<String>] in Library[<String>] is turned offline. |
| 35:211 | Failed to get library type and subtype. |
| 35:212 | Failed to mark active volume full for copy [<String>]. |
| 35:213 | Failed to set Application properties for SQL. <String> |
| 35:214 | Failed to set Instance properties for SQL. <String> |
| 35:215 | Failed to set Backup Set properties for SQL. <String> |
| 35:216 | Failed to set SubClient properties for SQL. <String> |
| 35:217 | Failed to set focus for [<String>]. |
| 35:218 | License Update Succeeded. Please write down Activation Key [<HexNumber>]. |
| 35:219 | License Update Succeeded. |
| 35:220 | License Update Failed. |
| 35:221 | Failed to get active volumes for copy [<String>]. |
| 35:222 | Active volumes for copy [<String>] in storage policy [<String>] are marked full. Active volumes/barcodes were <String>. |
| 35:223 | Failed to update user preferences. Incomplete data. |
| 35:224 | Failed to update user preferences. Item Sequence Error. |
| 35:225 | Failed to update user preferences. Database Error. |
| 35:226 | Failed to update user preferences. |
| 35:227 | Failed to migrate media for copy [<String>]. |
| 35:228 | The Storage Policy [<String>] has single stream applications associated with it. |
| 35:229 | Media with barcode: [<String>] have been migrated to library [<String>]. |
| 35:230 | The Mail Server is not configured to send E-mail. Please configure the Mail Server at the following location: From the CommCell Browser, right click the CommServe, select Control Panel, select E-Mail & IIS Configuration, and then select the E-Mail Server tab. |
| 35:231 | Mail Server [<String>] cannot be contacted to send email. |
| 35:232 | Alert notification has been set for user [<String>], but user has no email address specified. |
| 35:233 | Uninstalled |
| 35:234 | Unable to execute SrvOraAgent to populate CV tables for Oracle. |
| 35:235 | Database view cannot be displayed. Please check if database is mounted. |
| 35:236 | Failed to set Instance properties. |
| 35:237 | Unable to establish connectivity with these instance properties for [<String>]. Do you want to modify properties again? |
| 35:238 | Mail Report failed. Unable to initialize mail report. |
| 35:239 | The attempt to discover media on Library [<String>] has failed. Make sure the library is not performing an inventory and that the console is reporting the library as online, then retry the operation. |
| 35:240 | An instance by this name already exists. |
| 35:241 | Failed to create new instance. |
| 35:242 | OPERATION FAILED: Error reading file. |
| 35:243 | OPERATION FAILED: User [<String>] does not have [Schedule Admin or Manage Reports] permissions, or is not the owner of the scheduled report. |
| 35:244 | OPERATION FAILED: AdminTask entry not found. |
| 35:245 | OPERATION FAILED: No mail server set for scheduled reports. |
| 35:246 | Unable to move Job Results Directory. Failed to execute movedir. |
| 35:247 | Unable to move Index Cache Directory. Failed to execute movedir. |
| 35:248 | Failed to get Tablespaces. |
| 35:249 | MediaAgent [<String>] is turned <String>. |
| 35:250 | Deletion of storage policy [<String>] started. |
| 35:251 | Failed to delete storage policy [<String>] due to error: [<Message>]. |
| 35:252 | Storage policy [<String>] was deleted successfully. |
| 35:253 | Failed to create SQL Instance [<String>]. Verify that services are online and with the correct user name and password. Verify that User Account Configuration requirements from <String> are followed. If User Account Configuration is correct, then it is likely that a pending machine reboot is preventing the configuration from taking effect and rebooting the machine can help. |
| 35:254 | User [<String>] has logged on. |
| 35:255 | User [<String>] has logged off. |
| 35:256 | User [<String>] attempt to log on was denied. |
| 35:257 | Failed to set Media Manager timeouts. |
| 35:258 | Failed to update Holiday Schedule. |
| 35:259 | Skipping Task [<String>] on schedule [<String>] due to Holiday [<String>]. |
| 35:260 | Scheduled Task [<String>] could not be started within [<Number>] seconds of scheduled start time of [<String>] and was not run. |
| 35:261 | Job Priority for iDataAgent [<String>] has been changed to [<Number>]. |
| 35:262 | Job Priority Precedence has been changed to [<String>]. |
| 35:263 | Job Priority for Client [<String>] has been changed to [<Number>]. |
| 35:264 | This application ID does not exist so licenses must be freed too. |
| 35:265 | Skipping Scheduled Task [<String>] at [<String>] [<Number>] times. Previous task may have started or run late. |
| 35:266 | Deconfigure failed for the [<String>] iDataAgent from client [<String>]: job is running on [<String>]. |
| 35:267 | Deconfigure failed for the MediaAgent [<String>]: job is running on [<String>]. |
| 35:268 | Deconfigure failed for the [<String>] iDataAgent from client <String>. <Message>. |
| 35:269 | Deconfigure failed for the MediaAgent [<String>]. <Message>. |
| 35:270 | Failed to log on. |
| 35:271 | Failed to impersonate user. |
| 35:272 | Failed to access object. |
| 35:273 | Failed to perform network browse. |
| 35:274 | User [<String>] has deconfigured the [<String>] iDataAgent from the client [<String>]. |
| 35:275 | User [<String>] has failed to deconfigure the [<String>] iDataAgent from the client [<String>] due to error <Message>. |
| 35:276 | User [<String>] has deconfigured the MediaAgent [<String>]. |
| 35:277 | User [<String>] has failed to deconfigure the MediaAgent [<String>] due to error <Message>. |
| 35:278 | Clean drive [<String>] started. |
| 35:279 | Process to clean drive [<String>] has completed successfully. Please check the drive visually to see if its state becomes normal. |
| 35:280 | Clean drive [<String>] failed due to error: <String>. |
| 35:281 | Failed to save Disaster Recovery destination. Disaster Recovery destination must be a valid UNC network path. |
| 35:282 | Failed to save Disaster Recovery destination. Disaster Recovery destination cannot be local to CommServe. |
| 35:283 | Failed to create directories for send Log Files. |
| 35:284 | Failed to gather log files. |
| 35:285 | Failed to send log files to recipients. |
| 35:286 | Failed to delete copy [<String>]. Check Evmgrs.log for detailed information. |
| 35:287 | Copy [<String>] in the Storage Policy [<String>] was deleted successfully. |
| 35:288 | Failed to save Disaster Recovery destination. Destination is already being used for Express Recovery. |
| 35:289 | Failed to save Disaster Recovery destination. Unable to access Disaster Recovery destination with Disaster Recovery username and password. |
| 35:290 | Log Files of [<String>] were successfully sent to [<String>]. |
| 35:291 | Failed to get Time Zone information for <String>. The client may be uninstalled. |
| 35:292 | Failed to bundle log file folders. |
| 35:293 | Failed to save the new Media Password because the old Media Password is incorrect. |
| 35:294 | Unable to retrieve all client properties due to problems accessing remote machine.nPlease ensure that all iDataAgent software is properly installed.nAlso check network connectivity and if the product's services are running. |
| 35:295 | CommCell Console [<String>] is not compatible with CommServe [<String>]. CommCell Console will be closed. |
| 35:296 | No new media found in the library. |
| 35:297 | This is an old version of CommCell Console and not compatible with CommServe [<String>]. CommCell Console will be closed. |
| 35:298 | Unable to delete default subclient except from backup set level. |
| 35:299 | Problem encountered interfacing to SQL database. Consult EvMgrS log file for details. |
| 35:300 | Problems encountered adding Schedule Policy [<String>] to Scheduler. Consult EvmgrS log file for details. |
| 35:301 | Problems encountered modifying Schedule Policy [<String>] in Scheduler. Consult EvmgrS log file for details. |
| 35:302 | Problems encountered deleting Schedule Policy [<String>] from Scheduler. Consult EvmgrS log file for details. |
| 35:303 | Problems encountered decoupling schedule from Schedule Policy [<String>]. Consult EvmgrS log file for details. |
| 35:304 | Cannot decouple Schedules where either all instances or all backup sets are selected. Edit the Schedule Policy and remove the association. |
| 35:305 | Failed to save new Index Cache Directory. Index Cache Directory can reside only on a local fixed drive on the MediaAgent. |
| 35:306 | SmtpMail DataBase is full. SMTPCache = [<Number>]. First [<Number>] records will be deleted from SmtpMail DB. |
| 35:307 | Could not send alert to <<String>>. Reason: <String>. |
| 35:308 | Could not send log files to <<String>>. Reason: <String>. |
| 35:309 | Could not send scheduled report to <<String>>. Reason: <String>. |
| 35:310 | Connection to mail server [<String>] was refused. Check mail server settings. |
| 35:311 | Database |
| 35:312 | Backup Set |
| 35:313 | Unable to update subclient because it is already deleted. |
| 35:314 | Unable to update subclient because it is already uninstalled. |
| 35:315 | Unable to establish connectivity with these instance properties for [<String>]. [<String>] Do you want to modify properties again? |
| 35:316 | Deletion of storage policy is not allowed if there are running Auxiliary Copy, Content Indexing or Data Verification jobs n for this storage policy, or any running Restore or Data Aging jobs in the CommCell. |
| 35:317 | Abnormally Terminated Task [<String>] purged when Job Manager service restarted. |
| 35:318 | Media Export failed. Unable to initialize Media Export. |
| 35:319 | Failed to set parameters for media and drive, Media Manager process may be down. |
| 35:320 | Failed to contact Job Manager to determine if there are jobs running. The service may be down. |
| 35:321 | Unable to get dependent jobs for job [<Number>]. |
| 35:322 | Unable to complete Data Aging process for job [<Number>]. |
| 35:323 | Unable to complete 'mark bad' process for job [<Number>]. |
| 35:324 | Property Sheet was open for more than [<Number>] seconds and changes were not accepted. |
| 35:325 | Could not complete delete operation but some archive data have been deleted. Please resolve the error and retry the delete operation. |
| 35:326 | Could not complete delete operation but all the archive data have been deleted. Please resolve the error and retry the delete operation. |
| 35:327 | Unable to get Log File Path. Check that Communications Service is up and running on [<String>]. |
| 35:328 | Unable to delete subclient [<String>] because it no longer exists. CommCell Console may not have been refreshed. |
| 35:329 | Unable to delete backup set [<String>] because it no longer exists. CommCell Console may not have been refreshed. |
| 35:330 | Unable to delete iDataAgent [<String>] because it no longer exists. CommCell Console may not have been refreshed. |
| 35:331 | Unable to delete instance [<String>] because it no longer exists. CommCell Console may not have been refreshed. |
| 35:332 | Unable to delete client [<String>] because it no longer exists. CommCell Console may not have been refreshed. |
| 35:333 | Failed to delete storage policy copy [<String>] due to error: [<Message>]. |
| 35:334 | Deletion of storage policy is not allowed if there are running Auxiliary Copy jobs for n this storage policy, or any running restore or Data Aging jobs in the CommCell. |
| 35:335 | Please ignore this test event [<Number>]. |
| 35:336 | Failed to create copy [<String>] for storage policy [<String>], please see Evmgrs.log for details. |
| 35:337 | Failed to create copy [<String>] for storage policy [<String>], the effective date of a selective copy cannot be a past day. |
| 35:338 | Request to control Job [<Number>] by user [<String>] was denied becausen[<String>]. |
| 35:339 | Media Inventory failed. Unable to initialize Media Inventory. |
| 35:340 | On-demand failover for copy [<String>] of storage policy [<String>] is completed. |
| 35:341 | Failed to associate applications for storage policy [<String>]. |
| 35:342 | Unable to retrieve all MediaAgent properties due to problems accessing remote machine.nPlease ensure that all MediaAgent software is properly installed.nAlso check network connectivity and if this product's services are running. |
| 35:343 | Failed to set backup Task Options for taskId [<Number>], please see Evmgrs.log for details. |
| 35:344 | Unable to complete initial login message with [<String>] on [<String>]. Please make sure that this product is properly installed. |
| 35:345 | Storage policy [<String>] was deleted successfully, but failed to remove backup history. Check Evmgrs.log for detailed information. |
| 35:346 | Copy [<String>] is deleted successfully, but failed to remove backup history. Check Evmgrs.log for detailed information. |
| 35:347 | Media Manager returned the following error: Error retrieving number of drives for Drive Pool [<Number>]. |
| 35:348 | Database Transaction Error occurred while creating the storage policy copy[<String>]. |
| 35:349 | User [<String>] has deconfigured the [<String>] instance for [<String>] iDataAgent on client [<String>]. |
| 35:350 | User [<String>] has failed to deconfigure the [<String>] instance for [<String>] iDataAgent on client [<String>] due to error <Message>. |
| 35:351 | Deconfigure failed for the instance [<String>] for [<String>] iDataAgent on client <String>. <Message>. |
| 35:352 | Deconfigure failed of the instance [<String>] for [<String>] iDataAgent on client [<String>]n job is running on [<String>]. |
| 35:353 | Deconfigure failed of the partition [<String>] for [<String>] iDataAgent on client [<String>]n job is running on [<String>]. |
| 35:354 | User does not have sufficient credentials to control all jobs selected. |
| 35:355 | Job Priority for [<String>] has been changed to [<Number>]. |
| 35:356 | Reconfigure failed for the MediaAgent [<String>]: job is running on [<String>]. |
| 35:357 | Reconfigure failed for the partition [<String>] for [<String>] ion client [<String>]n job is running on [<String>]. |
| 35:358 | Reconfigure failed for the instance [<String>] for [<String>] iDataAgent on client [<String>]n job is running on [<String>]. |
| 35:359 | Reconfigure failed for the [<String>] iDataAgent from client [<String>]: job is running on [<String>]. |
| 35:360 | Reconfigure failed for the MediaAgent [<String>]. <Message>. |
| 35:361 | Reconfigure failed for the instance [<String>] for [<String>] iDataAgent on client <String>. <Message>. |
| 35:362 | Reconfigure failed for the [<String>] iDataAgent from client <String>. <Message>. |
| 35:363 | User [<String>] has failed to reconfigure the [<String>] instance for [<String>] iDataAgent on client [<String>] due to error <Message>. |
| 35:364 | User [<String>] has failed to reconfigure the [<String>] iDataAgent from the client [<String>] due to error <Message>. |
| 35:365 | User [<String>] has failed to reconfigure the MediaAgent [<String>] due to error <Message>. |
| 35:366 | User [<String>] has reconfigured the [<String>] iDataAgent from the client [<String>]. |
| 35:367 | User [<String>] has reconfigured the MediaAgent [<String>]. |
| 35:368 | Backup request for Client [<String>], Application Type [<String>], Backup Set [<String>], Subclient [<String>] converted to a full backup. |
| 35:369 | Failed to Get Replication Instances. |
| 35:370 | Operation failed: The Incremental Archive Group specified for this Storage Policy is Invalid. |
| 35:371 | Failed to set force the next backup to full[<Number>]. |
| 35:372 | Selected hardware compression setting for policy [<String>] was changed to [<String>]. Network Appliance hardware compression is set based on drive access path [<String>]. |
| 35:373 | I can see the new message after building ONLY EvMsgLoc.dll. |
| 35:374 | There are applications associated with this Storage Policy which require more streams than will remain after decrementing the number of streams. |
| 35:375 | This storage policy is already an incremental to another storage policy. |
| 35:376 | Error retrieving list of applications for this storage policy. |
| 35:377 | DataBase Error. |
| 35:378 | Skipping Task [<String>] on schedule [<String>]. Schedule is disabled. |
| 35:379 | User [<String>] has been <String> and cannot get scheduled reports. |
| 35:380 | Partition [<String>] has been deleted. |
| 35:381 | Skipping Task [<String>] on schedule [<String>]. Scheduler Activity at CommServe level has been disabled. |
| 35:382 | Unable to complete request. Check that Client Event Manager Service is up and running on [<String>]. |
| 35:383 | Failed to impersonate the user for the network shared index cache. Please verify thatn a) the username and password are correctn b) the specified user has local logon permissions to the MediaAgentn c) the user has both read/write access to both the index cache share and the MediaAgent's log file directory. |
| 35:384 | The path specified is invalid. |
| 35:385 | Could not move Index Cache Directory; jobs still running. |
| 35:386 | Feature [<String>] is not available for current CommServe license type. |
| 35:387 | Operations for iDataAgent [<String>] are not available for current CommServe license type. |
| 35:388 | Tracking Policy failed. Unable to initialize Tracking Policy. |
| 35:389 | Unable to complete 'pick for verification' process for job [<Number>]. |
| 35:390 | Unable to complete 'unpick for verification' process for job [<Number>]. |
| 35:391 | Unable to complete 'Select For Copy' process for job [<Number>]. |
| 35:392 | Unable to retain job [<Number>]. |
| 35:393 | Unable to change retention for job [<Number>]. |
| 35:394 | Failed to set activity on Subclient. |
| 35:395 | Failed to add subclients for the copy [<String>]. |
| 35:396 | Attempt denied. User [<String>] is a permanent user and may not be deleted. |
| 35:397 | Problem fetching information for user [<String>]. User has not been deleted. |
| 35:398 | Failed to add the barcode pattern [<String>], due to error [<String>]. |
| 35:399 | Failed to delete the barcode pattern [<String>], due to error [<String>]. |
| 35:400 | Failed to update the barcode pattern [<String>], due to error [<String>]. |
| 35:401 | Failed to reassociate the barcode patterns for the spareGroup [<Number>], due to error [<String>]. |
| 35:402 | Failed to change Storage Policy for subclient [<String>] because job [<Number>] is running. |
| 35:403 | Failed to delete the indicated snapshot [<Number>]. Please see EvMgrS.log for details. |
| 35:404 | An error occurred in CVSnapTool.exe [<Number>]. Please see CVSnapTool.log for details. |
| 35:405 | A required parameter for the OSSV Plug-in was not provided. |
| 35:406 | Failed to recover the indicated snapshot [<Number>]. Please see EvMgrS.log for details. |
| 35:407 | Unable to get volume list for client. |
| 35:408 | Failed to retrieve a list of installed OSSV Plug-ins [<Number>]. |
| 35:409 | Failed to set Subclient properties. |
| 35:410 | Failed to save Scheduler Enabled Property in CommServe database.n |
| 35:411 | Failed to save SNMP Traps Support Level in CommServe database.n |
| 35:412 | Failed to save Audit Trail Level in CommServe database.n |
| 35:413 | Failed to save Disaster Recovery Archive Group in CommServe database.n |
| 35:414 | Failed to save Disaster Recovery UserName in CommServe database.n |
| 35:415 | Failed to save Mail Server in CommServe database.n |
| 35:416 | Failed to save Sender's Address in CommServe database.n |
| 35:417 | Failed to save User Password in CommServe database.n |
| 35:418 | Failed to save Disaster Recovery Password in CommServe database.n |
| 35:419 | Failed to save Max Events in CommServe database.n |
| 35:420 | Failed to save Job Alive Check in CommServe database.n |
| 35:421 | Failed to save Job Precedence in CommServe database.n |
| 35:422 | Failed to save Enable/Disable Backup interrupt other Backups.n |
| 35:423 | Failed to save Enable/Disable Restore interrupt other Jobs.n |
| 35:424 | Failed to save Enable/Disable Other Jobs interrupt AuxCopy.n |
| 35:425 | Failed to save Job Priority for unsupported iDataAgent [<Number>] [<String>].n |
| 35:426 | Failed to save [<String>] Job Priority in CommServe database.n |
| 35:427 | Failed to save Disaster Recovery Destination in CommServe database.n |
| 35:428 | Failed to save Disaster Recovery Destination [<String>] in CommServe database because a folder name is required.n |
| 35:429 | Failed to save Disaster Recovery Destination in CommServe database because it is an invalid path.n |
| 35:430 | Failed to save Disaster Recovery Destination in CommServe database. Unable to get CommCell User Name.n |
| 35:431 | Failed to save Disaster Recovery Destination in CommServe database. Unable to get CommCell User Password.n |
| 35:432 | Failed to save Disaster Recovery Destination in CommServe database. Unable to decrypt Disaster Recovery user password.n |
| 35:433 | Failed to save Disaster Recovery Destination in CommServe database. Unable to Log on as Disaster Recovery user.n |
| 35:434 | Failed to save Disaster Recovery Destination in CommServe database. Unable to Impersonate Disaster Recovery user [<String>].n |
| 35:435 | Failed to save Disaster Recovery Destination in CommServe database because Disaster Recovery user [<String>] does not have permission to create folder [<String>].n |
| 35:436 | Failed to save Disaster Recovery Destination in CommServe database because folder [<String>] is already being used for Disaster Recovery.n |
| 35:437 | Failed to save Disaster Recovery Destination in CommServe database because Disaster Recovery user [<String>] does not have permission to access folder [<String>].n |
| 35:438 | Failed to save Disaster Recovery Number of Full Backups in CommServe database.n |
| 35:439 | Failed to save DB Space Check in CommServe database.n |
| 35:440 | Failed to save properties to CommCell table.n |
| 35:441 | Cannot update subclient's OSSV Policy because overlapping content was detected. |
| 35:442 | Unable to get subclient's OSSV policy. |
| 35:443 | Unable to check Content volume's snapshot engine. |
| 35:444 | Content volume's snapshot engine is different from subclient's snapshot engine. |
| 35:445 | Unable to remove snapshot parameters. |
| 35:446 | Unable to complete login attempt because encrypted session key cannot be set. |
| 35:447 | Lock failed. |
| 35:448 | SendLogs failed with an exception. |
| 35:449 | Problems encountered unlocking property sheet. |
| 35:450 | Incomplete (password) data received. |
| 35:451 | Invalid data received. |
| 35:452 | Account disabled. |
| 35:453 | Failed to update credentials in the database. |
| 35:454 | Login retry count exceeded. Please try later. |
| 35:455 | [<String>] operation failed. |
| 35:456 | Failed to submit restore request. |
| 35:457 | Failed to submit new Backup request. |
| 35:458 | Could not schedule UpdatePatches. |
| 35:459 | Unable to initialize with JM. Cannot proceed with request. |
| 35:460 | Unable to locate operation item. Cannot proceed with request. |
| 35:461 | [<String>] [<String>] with trailing whitespace is not allowed. |
| 35:462 | User [<String>] does not have required capability [<String>] for this <String> and this operation. |
| 35:463 | and this operation. |
| 35:464 | for this operation. |
| 35:465 | Undetermined User Response String |
| 35:466 | and association with [<String>] [<String>] |
| 35:467 | Undetermined Error String |
| 35:468 | CommCell |
| 35:469 | Client |
| 35:470 | MediaAgent |
| 35:471 | Library |
| 35:472 | Library[<Number>] |
| 35:473 | Storage Policy |
| 35:474 | User |
| 35:475 | Unknown Login, id = [<String>] |
| 35:476 | Group |
| 35:477 | Type [<Number>] |
| 35:478 | id = [<Number>] |
| 35:479 | , nor was this job initiated by this user. |
| 35:480 | Report Succeeded |
| 35:481 | Report Failed |
| 35:482 | No data was found for the selected criteria. |
| 35:483 | Database Error, could not access Database. |
| 35:484 | Could not get the CommCell ID. |
| 35:485 | Times selected are Invalid. |
| 35:486 | Could not create Reports Directory. |
| 35:487 | Could not create output file for report. |
| 35:488 | Could not get virtual web path. |
| 35:489 | Could not create IIS virtual web root. |
| 35:490 | Internet Information Server (IIS) is not installed on CommServe. |
| 35:491 | Could not get product's Base Directory. |
| 35:492 | MediaAgent is not installed. |
| 35:493 | Unable to write report to destination path. Please check permissions. |
| 35:494 | Could not get the user name. |
| 35:495 | Could not decrypt the password. |
| 35:496 | Could not log on user. |
| 35:497 | Could not impersonate user. |
| 35:498 | Could not get the report file name. |
| 35:499 | Could not open the report file |
| 35:500 | Failed to copy the report to the destination. The path, username and/or password may be invalid. |
| 35:501 | Failed to save FTP Site in CommServe database.n |
| 35:502 | Failed to save User Name for FTP Site in CommServe database.n |
| 35:503 | Failed to save Password for FTP Site in CommServe database.n |
| 35:504 | Failed to save CommServe Update Location in CommServe database.n |
| 35:505 | Failed to save User Name for CommServe Update Location in CommServe database.n |
| 35:506 | Failed to save Password for CommServe Update Location in CommServe database.n |
| 35:507 | Failed to save UNIX Update Location in CommServe database.n |
| 35:508 | Failed to add the switch [<String>], due to error [<String>]. |
| 35:509 | Failed to delete the switch [<String>], due to error [<String>]. |
| 35:510 | Failed to update the switch [<String>], due to error [<String>]. |
| 35:511 | Encryption Properties failed because all required data was not received. |
| 35:512 | Encryption Properties: Decryption failed because passphrase was invalid or empty. |
| 35:513 | Encryption Properties: Decryption failed because passphrase was not provided. |
| 35:514 | Encryption Properties: Failed to generate RSA pair. |
| 35:515 | Encryption Properties: Failed to decrypt RSA Primary Key. |
| 35:516 | Encryption Properties: Failed to encrypt RSA Primary Key. |
| 35:517 | Encryption Properties: Failed to decrypt passphrase received from GUI. |
| 35:518 | Encryption Properties: Old passphrase is invalid. Please try again. |
| 35:519 | Encryption Properties: Failed to save new property. See EvMgrS.log for details. |
| 35:520 | Encryption Properties: Failed to get network password for export. |
| 35:521 | Encryption Properties: Failed to encrypt passphrase for network transport. |
| 35:522 | Encryption Properties: Failed to send Export Request to EvMgrC on [<String>]. |
| 35:523 | Client Encryption Properties RSAPubKey and RSAPriKey are out of sync and need to be regenerated. Please call your vendor's support hotline for assistance. |
| 35:524 | Cannot enable encryption: there are no encryption licenses available. |
| 35:525 | Failed to get Licensing Information for CommServe. |
| 35:526 | Connection refused.nMaximum number of GUI connections for this CommServe license has been reached. |
| 35:527 | Command line interface is not supported for this CommServe license. |
| 35:528 | Failed to change Log Storage Policy for backup set [<String>] because jobs are running for that backup set. |
| 35:529 | Failed to change Log Storage Policy for instance [<String>] because jobs are running for that instance. |
| 35:530 | Log Files for job [<Number>] were successfully sent to [<String>]. |
| 35:531 | Unable to get product install directory. |
| 35:532 | Unable to create support directory. |
| 35:533 | Unable to create destination directory. |
| 35:534 | Unable to open information file. |
| 35:535 | Failed to gather log files. |
| 35:536 | No mail server is set. |
| 35:537 | Failed to bundle log files. |
| 35:538 | EvLogs: Unknown Error Code. |
| 35:539 | Applet interface is not supported for this CommServe license. |
| 35:540 | Failed to check EchoView Enabler install status [<Number>]. |
| 35:541 | Failed to save User Name for UNIX Update Location in CommServe database.n |
| 35:542 | Failed to save Client for UNIX Update Location in CommServe database.n |
| 35:543 | Failed to create the Storage Policy [<String>]. A Storage Policy with the same name already exists. |
| 35:544 | Failed to get MediaAgent for job [<Number>] |
| 35:545 | Cannot perform this operation: The evaluation license for VaultTracker feature is expired. Please call your vendor's support hotline for assistance. |
| 35:546 | Cannot perform this operation on the policy [<String>]: The policy is disabled. |
| 35:547 | User [<String>] has enabled the option to overwrite media at the library level on the library [<String>]. nPlease make sure that this option has not been selected erroneously. |
| 35:548 | Failed to save Download Flag for UNIX Update in CommServe database.n |
| 35:549 | Failed to move index cache. Jobs are still running. |
| 35:550 | Content Verification failed. Unable to initialize content verification copy. |
| 35:551 | User has enabled the option to overwrite media at the library level on the library. nPlease make sure that this option has not been selected erroneously. |
| 35:552 | Failed to get the subclient List for the backup set [<Number>]. |
| 35:553 | Failed to get the backup set List for the instance [<Number>]. |
| 35:554 | Failed to get the instance List for the Apptype [<Number>]. |
| 35:555 | Failed to get the application type List for the client [<Number>]. |
| 35:556 | Unable to prune job [<Number>] because there is an active job running for this subclient. |
| 35:557 | Unable to disable job [<Number>] because there is an active job running for this subclient. |
| 35:558 | Failed to display the report because Internet Information Server (IIS) is not installed on CommServe. |
| 35:559 | Failed to Configure Snap Volume Unit [<String>]. |
| 35:560 | Failed to Get Snap Volume Units. |
| 35:561 | Failed to Get Properties for Snap Volume Unit [<String>]. |
| 35:562 | Failed to create a new Server group by name [<String>] for CommCell [<Number>]. |
| 35:563 | Failed to rename the Server group with ID [<Number>] for CommCell [<Number>]. |
| 35:564 | Failed to delete the Server group with ID [<Number>] for CommCell [<Number>]. |
| 35:565 | Unable to access Index Cache Access Path. Please check the path and logon credentials. |
| 35:566 | No Index Cache Label was found in the specified location. Check failed. |
| 35:567 | The data in the Index Cache Label is an invalid format. |
| 35:568 | The data in the Index Cache Label does not match the expected values. Please check that the index cache access path is pointing to the correct index cache. |
| 35:569 | Writing to the ICL file failed. This is probably due to insufficient permissions. Please check the logon credentials and the file access rights to the index cache directory. |
| 35:570 | It was determined that the Index Cache Label file needed to be overwritten, but this is not possible because of the parameters supplied to the index cache controller. |
| 35:571 | There is not enough available disk space on the disk housing the specified target to copy the index cache. Please clear some disk space or specify another path. |
| 35:572 | Failed to query the amount of free disk space on the target directory. If using a UNC path, please make sure that the logon credentials are correct. |
| 35:573 | You have specified that you want to stop sharing the Index Cache. According to the database, the following MediaAgent is still using this cache: <String>. If you want to stop sharing this index cache directory, please provide another location. |
| 35:574 | You have specified that you want to stop sharing the Index Cache. According to the database, the following MediaAgent(s) are still using this cache: <String>. If you want to stop sharing this cache, please provide another location.. |
| 35:575 | Failed to execute Movedir on the MediaAgent. This may be due to services being down or due to an improper installation. |
| 35:576 | You have specified a directory [<String>], which already includes an index cache. Do you want to make the index [<String>] shared and also use it for this MediaAgent? |
| 35:577 | The directory you have specified [<String>] points to the shared index cache [<String>]. Would you like to use this shared index cache also for this MediaAgent? |
| 35:578 | The specified directory [<String>] contains an unshared index cache [<String>] not matching the shared index [<String>] you have specified. Please try making the settings again. |
| 35:579 | The specified directory [<String>] contains a shared index cache [<String>] not matching the shared index [<String>] you have specified. Please try making the settings again. |
| 35:580 | The specified target directory contains an invalid index. Please choose another directory. |
| 35:581 | The index cache directory you are currently using is shared by the following other MediaAgents: [<String>]. The directory you have specified already contains a different index cache: [<String>]. Would you like to use this other index cache for this MediaAgent? If you say yes, please remember that the old path still has to be accessible to the other MediaAgents. |
| 35:582 | Would you like to copy all the Index Cache data from the old directory [<String>] to the new directory [<String>] now? If you select No, then the next time you Browse Backup Data, there will be a slight delay while the required Index Cache data is restored from the backup media to the new location. |
| 35:583 | Cannot copy the index cache to the new location because the index cache is offline. |
| 35:584 | Error! Could not update indexing properties in the database. Please contact customer support if the problem persists. |
| 35:585 | Failed to <String> license for <String>. |
| 35:586 | Received invalid data from <String>. |
| 35:587 | Error! Could not retrieve information from the database for the Index Cache. Please contact customer support if the problem persists. |
| 35:588 | Error! Failed to update Index Cache information. Please contact customer support if the problem persists. |
| 35:589 | Failed to save Complete Running Jobs Option in CommServe database.n |
| 35:590 | Unable to initialize the storage validation schedule. |
| 35:591 | Unable to initialize the drive cleaning schedule. |
| 35:592 | Unable to initialize the stamp media schedule. |
| 35:593 | An attempt to verify write and read permissions in the index cache directory specified failed. Please verify that the location specified is correct. |
| 35:594 | Could not update index cache directory information in the CommServe Database. Please check network connections. If the problem persists, please contact your vendor's support hotline. |
| 35:595 | Failed to [<String>] Subclient Policy [<String>]. |
| 35:596 | You cannot copy a directory into one of its subdirectories. |
| 35:597 | Unable to connect to client [<String>] to execute [<String>].nPlease ensure that all iDataAgent software is properly installed.nAlso check network connectivity and if this product's services are running. |
| 35:598 | Could not create Report directory on IIS server. |
| 35:599 | This MediaAgent, together with others, is a failover candidate for storage policy copies of the following storage policies: [<String>]. While this is still the case, you cannot disassociate this MediaAgent from this shared index cache. |
| 35:600 | Failed to update backup sets associated with Subclient Policy [<String>]. |
| 35:601 | Failed to Configure Workflow [<String>]. |
| 35:602 | Failed to Get Workflows. |
| 35:603 | Failed to Get Properties for Workflow [<String>]. |
| 35:604 | Failed to create Disaster Recovery Destination [<String>] because Disaster Recovery user not specified.n |
| 35:605 | Failed to copy the files from the old index cache location to the new one. |
| 35:606 | No files were backed up. |
| 35:607 | Failed to get MediaAgent information. |
| 35:608 | Could not establish a lock on a test file in the index cache directory. Please check that no other processes are using the file. |
| 35:609 | File locking is not supported for files in the folder you have specified. Please choose another folder. |
| 35:610 | Failed to save Job Controller Job Retention Time in CommServe database.n |
| 35:611 | The index cache [<String>] was successfully copied to the new location [<String>] on MediaAgent [<String>] |
| 35:612 | You cannot set the path of the index cache to be the root directory. |
| 35:613 | The UNC path specified is invalid. It needs to be of the form \\Computername\Share\Directory. |
| 35:614 | The path specified needs to be a directory underneath a share, it cannot be the root of a share. |
| 35:615 | Failed to check if the CommServe was evaluated and failed to get the evaluation days left. |
| 35:616 | Failed to save Job Restart in CommServe database. |
| 35:617 | Failed to save Network Retry Period in CommServe database. |
| 35:618 | Failed to save Job Update Second in CommServe database. |
| 35:619 | Failed to save Job Update Mailbox in CommServe database. |
| 35:620 | Failed to calculate the amount of used disk space in the old index cache location. This may mean that the files are inaccessible or are in use. nnIf the problem persists, choose not to copy the index cache to the new location and then copy the files manually. NOTE: Do NOT copy the icl_label.txt file. |
| 35:621 | An index cache label file was read in the index cache directory, but the index cache it describes is unknown to the CommServe. Possible reasons might be because the MediaAgent was already force-deconfigured, the index cache is from an old installation, or the index cache is now used by another CommCell. |
| 35:622 | An index cache label file was read in the index cache directory, but the values it contains mismatch those in the CommServe database. This probably means that the cache is from an old installation, but it could also be that the index cache is from another CommCell. |
| 35:623 | The index cache is out of date. The index cache location was probably changed to a different directory, and this is the old directory.nNote that when changing the location of an index cache of a shared MediaAgent, all MediaAgents have to be changed to point to the new path.nIt could also be though (though less likely) that the index cache is from another CommCell. |
| 35:624 | No index cache access paths were returned for the cache. Please check that connectivity to the CommServe exists. If it does, please contact Customer Support. |
| 35:625 | Could not check for the existence of, or create an index cache directory in the specified location. Please check that the path is correct. |
| 35:626 | Deletion of inline copy is not allowed if there are running backup jobs for this storage policy. |
| 35:627 | Failed to save IIS Server Name in CommServe database.n |
| 35:628 | Failed to save IIS Server Install Location in CommServe database.n |
| 35:629 | Failed to save IIS Server User Name in CommServe database.n |
| 35:630 | Failed to save IIS Server User Password in CommServe database.n |
| 35:631 | Failed to save IIS Server Selection in CommServe database.n |
| 35:632 | Failed to save Chunk Size in CommServe database. |
| 35:633 | An invalid response was received from the MediaAgent while executing IdxLabelUtil. Please contact customer support. |
| 35:634 | Failed to save credentials for Exchange. |
| 35:635 | Failed to save credentials for SQL. |
| 35:636 | Failed to save credentials for UNC paths. |
| 35:637 | Failed to save credentials for Oracle. |
| 35:638 | Failed to save IIS Server Books Online Alias in CommServe database.n |
| 35:639 | Failed to save GUI Timeout settings in CommServe database.n |
| 35:640 | Only the subclient flagged as default can have its name changed to default. |
| 35:641 | Failed to Delete Workflow [<String>]. |
| 35:642 | Failed to Delete Schedules for Workflow [<String>]. |
| 35:643 | Client with the name you supplied already present. Duplicate client names are not allowed. |
| 35:644 | Unable to create subclient. A subclient already exists that is flagged as the default subclient. |
| 35:645 | Failed to perform any updates for the Server group with ID [<Number>] for CommCell [<Number>]. |
| 35:646 | Cannot perform CommCell Readiness Check: No license or the license has expired. |
| 35:647 | Failed to display [<String>] on GUI because Internet Information Server (IIS) is not installed on CommServe. |
| 35:648 | Unable to set the Number of Data Readers to a value greater than one.nThe license for <String> has expired. |
| 35:649 | Failed to save information on whether to use HTTP Proxy or not for Update downloading in CommServe database.n |
| 35:650 | Failed to save the HTTP Proxy information (server and port) for Update downloading in CommServe database.n |
| 35:651 | Failed to save the HTTP Proxy information (username) for Update downloading in CommServe database.n |
| 35:652 | Failed to save the HTTP Proxy information (password) for Update downloading in CommServe database.n |
| 35:653 | VaultTracker is currently enabled for one or more schedules. |
| 35:654 | Cannot perform On-Demand backup. The Advanced File System iDataAgent Options license has expired or is not installed. |
| 35:655 | Cannot perform this operation: The license for Encryption has expired or is not installed. |
| 35:656 | Cannot perform data protection operation for [<String>]. The license for Encryption has expired or is not installed. |
| 35:657 | Cannot perform this operation: The license for Content Indexing has expired or is not installed. |
| 35:658 | Cannot perform Restore By Job. The Advanced File System iDataAgent Options license has expired or is not installed. |
| 35:659 | Cannot perform a map file restore. The Advanced File System iDataAgent options license has expired or is not installed. |
| 35:660 | Cannot perform this operation: The license for Erase Data feature has expired or is not installed. |
| 35:661 | Cannot perform this operation: The license for Commcell Readiness Report has expired or is not installed. |
| 35:662 | Cannot perform this operation: The license for VaultTracker has expired or is not installed. |
| 35:663 | Cannot perform Automatic Multi-streaming backup operation: The Advanced File System iDataAgent Options license has expired or is not installed. |
| 35:664 | Unable to change the Media Password.nThe license for <String> has expired. |
| 35:665 | Failed to begin discovery process. Please see onMsgGetNewFound in EvMgrS.log for details. |
| 35:666 | Login attempt rejected because Application ID was not received. |
| 35:667 | Failed to get MediaAgent name. |
| 35:668 | Failed to get Archive information. |
| 35:669 | Failed to save Enable/Disable Queue Scheduled Jobs.n |
| 35:670 | Current user [<String>] is not the owner of Subclient Policy [<String>]. |
| 35:671 | Unable to process message because invalid data was received. Please see EvMgrS.log for more information. |
| 35:672 | The index cache location specified contains the correct index cache, but it is out of date.nDo you want to use it anyway? |
| 35:673 | The policy has been created but it was not possible to use the incremental storage policy specified because its data path configuration is incompatible with those of the newly created primary copy. nTo be compatible, one of the following must apply: All data paths use same index cache, both policies are configured to be LAN Free or the data paths have to match exactly.n |
| 35:674 | Schedule Policy [<String>] has been deleted by user [<String>]. |
| 35:675 | Cannot decouple Schedules from an [All Agent Types] Policy. Edit the Schedule Policy and remove the association. |
| 35:676 | Unable to get job details. Please see EvMgrS.log for more information. |
| 35:677 | Max Restart for [<String>] has been changed from [<Number>] to [<Number>]. |
| 35:678 | Restart Interval for [<String>] has been changed from [<Number>] Minutes to [<Number>] Minutes |
| 35:679 | Restartable for [<String>] has been enabled. |
| 35:680 | Restartable for [<String>] has been disabled. |
| 35:681 | Preemptable for [<String>] has been enabled. |
| 35:682 | Preemptable for [<String>] has been disabled. |
| 35:683 | Network retry period has been changed from [<Number>] Minutes to [<Number>] Minutes |
| 35:684 | Job Update Recovery Sec for [<String>] has been changed from [<Number>] Seconds to [<Number>] Seconds. |
| 35:685 | Job Update Interval for [<String>] has been changed from [<Number>] Minutes to [<Number>] Minutes. |
| 35:686 | Chunk Size for [<String>] has been changed from [<Number>] MB to [<Number>] MB. |
| 35:687 | The data paths of this primary copy are not compatible with those of the following storage policies which use this one as an incremental policy:n[<String>]nPlease make sure that either all policies involved use LAN free, share the same index or all have exactly the same data paths. |
| 35:688 | The data paths of this primary copy are not compatible with those of the primary of the configured incremental storage policy.nPlease make sure that either all policies involved use LAN free, share the same index or all have exactly the same data paths. |
| 35:689 | Out of place restore. User [<String>] must have [<String>] capability for the source and [<String>] capability at the destination. |
| 35:690 | User Group [<String>] has been disabled/deleted and cannot get scheduled reports. |
| 35:691 | User [<String>] belongs to a disabled/deleted user group and cannot get scheduled reports. |
| 35:692 | Failed to get logs for [<String>]. |
| 35:693 | Failed to add all media specified to shelf. Reason: There are duplicate barcodes present. |
| 35:694 | Commcell Console idle time has been exceeded for user [<String>]. |
| 35:695 | Snapshot [<Number>] was deleted successfully. |
| 35:696 | Failed to activate snapshot [<Number>]. |
| 35:697 | Snapshot [<Number>] was activated successfully. |
| 35:698 | Backup contents are not supported for backups done with earlier releases of this product. |
| 35:699 | License Activation Succeeded. |
| 35:700 | ..nNor is [<String>] the owner of Subclient Policy [<String>]. |
| 35:701 | Cannot add subclient [<String>] to backup set [<String>] because backup set is associated with Subclient Policy [<String>]. |
| 35:702 | There are too many data path changes to process. If this error persists, please contact customer support. |
| 35:703 | Ready |
| 35:704 | Failed to connect to client computer <Message>. |
| 35:705 | Unable to update Library attributes. Please contact customer support if the problem persists. |
| 35:706 | Failed to add Job Controller Filter <String> for User <String>. |
| 35:707 | Failed to modify Job Controller Filter <String> for User <String>. |
| 35:708 | Failed to delete Job Controller Filter <String> for User <String>. |
| 35:709 | There have been changes made to this subclient or backup set.nPlease Refresh CommCell Console and resubmit your changes. |
| 35:710 | Failed to save SMTP Port in CommServe registry.n |
| 35:711 | Failed to reconfigure. <Message> |
| 35:712 | Only NAS Clients are supported. |
| 35:713 | There was a problem initializing a database transaction. |
| 35:714 | The iDataAgent was already fully deleted. This may have been performed by another CommCell Console. |
| 35:715 | The iDataAgent was not marked deleted. |
| 35:716 | Could not get required information from the Database. If the problem persists, please contact your software vendor. |
| 35:717 | The NAS iDataAgent <String> was successfully reconfigured. |
| 35:718 | Troubleshooting log recipient has been set to [<String>]. |
| 35:719 | Troubleshooting notification Email has been set to [<String>]. |
| 35:720 | Troubleshooting FTP location has been set to [<String>]. |
| 35:721 | Troubleshooting FTP user has been set to [<String>]. |
| 35:722 | Troubleshooting FTP password has been modified. |
| 35:723 | Failed to save Troubleshooting log recipient in CommServe database. |
| 35:724 | Failed to save Troubleshooting notification Email in CommServe database. |
| 35:725 | Failed to save Troubleshooting FTP location in CommServe database. |
| 35:726 | Failed to save Troubleshooting FTP user in CommServe database. |
| 35:727 | Failed to save Troubleshooting FTP password in CommServe database. |
| 35:728 | Failed to get FTP parameters. |
| 35:729 | Failed to connect to FTP site [<String>]. |
| 35:730 | Failed to create directory [<String>] on FTP server [<String>]. |
| 35:731 | Failed to upload logs [<String>] to FTP server [<String>]. |
| 35:732 | Failed to save log files to the location [<String>]. |
| 35:733 | Failed to send log files to FTP site [<String>]. |
| 35:734 | System Created (All Agent Types) |
| 35:735 | System created schedule policy for All Agent Types |
| 35:736 | (ALL Agent Types) |
| 35:737 | Failed to Configure Calendar [<String>]. |
| 35:738 | Failed to Get Calendars. |
| 35:739 | Unable to find EZ Backup set. |
| 35:740 | Failed to get all the installed evaluation license details. |
| 35:741 | Unable to delete [<String>] because Schedules are associated with it. |
| 35:742 | Could not remove data path. Please try again, and if the problem persists, please contact your software vendor. |
| 35:743 | Job Results Folder Threshold for Client [<String>] has been changed to [<Number>]. |
| 35:744 | Failed to configure Replication Set. |
| 35:745 | The file system agent cannot be deconfigured because this is also a MediaAgent and NAS Client. [<String>] is using a storage policy [<String>] which the MediaAgent is associated with. |
| 35:746 | Failed to get the detailed license information needed to convert the installed eval licenses to permanent license. |
| 35:747 | Failed to convert the evaluation licenses to permanent licenses. |
| 35:748 | Some submitted pairs are in conflict with existing pairs. |
| 35:749 | Available & Retained |
| 35:750 | Available |
| 35:751 | Partial |
| 35:752 | Partial & Not Selected |
| 35:753 | To Be Copied & Deferred |
| 35:754 | To Be Copied |
| 35:755 | Running |
| 35:756 | Not Selected |
| 35:757 | Not Available |
| 35:758 | Not Applicable |
| 35:759 | Some directories could not be created during the copy process. Please check if there is enough disk space and retry the copy manually. |
| 35:760 | A directory listing could not be obtained. This might be due to the source directory not existing. Please check and attempt to copy the directory manually. |
| 35:761 | Could not copy all files and directories as some of these were in use. Please retry the copy manually. |
| 35:762 | Creating the new job results directory succeeded and will now be used, but the copy of the old folder [<String>] to the selected one did not succeed because of the following reason: <Message> |
| 35:763 | Some files that could not be overwritten. |
| 35:764 | There was a problem reading some source files. |
| 35:765 | There was a problem creating some destination files. |
| 35:766 | Unable to delete [<String>] because Storage Policy Copies are associated with it. |
| 35:767 | Media Bad |
| 35:768 | Yes |
| 35:769 | No |
| 35:770 | Killed |
| 35:771 | Failed |
| 35:772 | New Index |
| 35:773 | Full |
| 35:774 | Transaction Log |
| 35:775 | Incremental |
| 35:776 | ASR |
| 35:777 | Delta |
| 35:778 | Differential |
| 35:779 | Synthetic Full |
| 35:780 | Trans. Log No Truncation. |
| 35:781 | Offline Full |
| 35:782 | Online Full |
| 35:783 | Snapshot |
| 35:784 | Create Replica |
| 35:785 | Update Replica |
| 35:786 | Undiscovered |
| 35:787 | Failed to retrieve the non-copied Jobs for this Media. |
| 35:788 | Could not Set Schedule for the Full Inventory. |
| 35:789 | Could not add task. |
| 35:790 | Failed to get the Volume ID for the Media Side [<String>] |
| 35:791 | Failed to rename the barcode to [<String>]. |
| 35:792 | Unsupported operation type [<Number>] specified. |
| 35:793 | Could not schedule Media Export |
| 35:794 | Get volumes for job [<Number>] failed. |
| 35:795 | No Media found matching the criteria. |
| 35:796 | Failed to get media list |
| 35:797 | No Media found for this job |
| 35:798 | Unable to set Iron Mountain customer ID to [<String>] |
| 35:799 | Unable to delete Iron Mountain customer ID [<String>] |
| 35:800 | Unable to Create Iron Mountain customer ID [<String>] |
| 35:801 | Protocol Error, required information is missing. |
| 35:802 | Failed to get the policy status. |
| 35:803 | Could not update Rule. The error returned is: [<String>]. |
| 35:804 | Could not Set Schedule for the Tracking Policy. |
| 35:805 | Could not create Rule. The error returned is: [<String>]. |
| 35:806 | Could not clone Rule. The error returned is: [<String>]. |
| 35:807 | Invalid Destination Type |
| 35:808 | At VMS |
| 35:809 | In Transit |
| 35:810 | At Destination |
| 35:811 | At Source |
| 35:812 | Obsolete |
| 35:813 | Aborted |
| 35:814 | Rolled Back |
| 35:815 | Completed |
| 35:816 | Undefined Location Name [<Number>] |
| 35:817 | Inside Library |
| 35:818 | Has received an unprocessed element type [<Number>-<String>] |
| 35:819 | Cannot perform data protection operation for Client [<String>], Application Type [<String>], Backup Set [<String>], Subclient [<String>] because User [<String>] does not have required capability. |
| 35:820 | Failed to assign user for schedule. |
| 35:821 | Unable to find On Demand Backup set. |
| 35:822 | Maximum number of Outlook Add-In connections for this CommServe has been reached. Please try again later. |
| 35:823 | Not all the jobs were freed because some of them are still running. |
| 35:824 | Active |
| 35:825 | Inactive |
| 35:826 | Not Ready |
| 35:827 | Ready |
| 35:828 | Enabled |
| 35:829 | Disabled |
| 35:830 | Failed to configure the selected CommCell level features. |
| 35:831 | Yes (Media will not be used for Data Protection/Auxiliary Copy Jobs) |
| 35:832 | Unable to delete Replication Set because one or more pairs are replicated or suspended. |
| 35:833 | Failed to generate the fingerprint file. |
| 35:834 | Failed to email the generated fingerprint file to Software Provider. |
| 35:835 | Failed to generate the fingerprint file. Error : Failed to open the file [<String>] in write mode. |
| 35:836 | Failed to set the MediaAgent description field in the database. |
| 35:837 | Failed to set the maximum number reservations for the specified MediaAgent in the database. |
| 35:838 | Insufficient Parameters to fetch Active Directory Users. |
| 35:839 | One Time |
| 35:840 | Every <Number> Days |
| 35:841 | Every <Number> Weeks |
| 35:842 | Every Days |
| 35:843 | Every <Number> Months |
| 35:844 | Every Month |
| 35:845 | On Day <Number> |
| 35:846 | On |
| 35:847 | Every <Number> Years |
| 35:848 | At |
| 35:849 | Every |
| 35:850 | Until |
| 35:851 | For <Number> occurrence(s) |
| 35:852 | Starting |
| 35:853 | January |
| 35:854 | February |
| 35:855 | March |
| 35:856 | April |
| 35:857 | May |
| 35:858 | June |
| 35:859 | July |
| 35:860 | August |
| 35:861 | September |
| 35:862 | October |
| 35:863 | November |
| 35:864 | December |
| 35:865 | Sun |
| 35:866 | Mon |
| 35:867 | Tues |
| 35:868 | Wed |
| 35:869 | Thu |
| 35:870 | Fri |
| 35:871 | Sat |
| 35:872 | Weekday |
| 35:873 | Day |
| 35:874 | Weekend Day |
| 35:875 | Immediate |
| 35:876 | Single |
| 35:877 | Daily |
| 35:878 | Weekly |
| 35:879 | Monthly |
| 35:880 | Annually |
| 35:881 | By Count |
| 35:882 | By Date |
| 35:883 | Unknown |
| 35:884 | Backup |
| 35:885 | Restore |
| 35:886 | Admin |
| 35:887 | Full Backup |
| 35:888 | Differential Backup |
| 35:889 | ASR Backup |
| 35:890 | Incremental Backup |
| 35:891 | Any Level |
| 35:892 | Create new index |
| 35:893 | Start new media |
| 35:894 | Synthetic Full |
| 35:895 | Run Incremental |
| 35:896 | Back up all subclients |
| 35:897 | Truncation Log |
| 35:898 | Follow mount points. |
| 35:899 | Back up data in remote storage. |
| 35:900 | Back up files protected by system file protection. |
| 35:901 | Transaction Log Backup |
| 35:902 | Mark media full after successful operation. |
| 35:903 | Stop DHCP service when backing up system state data. |
| 35:904 | Stop WINS service when backing up system state data. |
| 35:905 | Run Incremental Backup Before Synthetic Full. |
| 35:906 | Preselected Backup Type |
| 35:907 | Create OSSV Volume |
| 35:908 | Start Media Export via VaultTracker. |
| 35:909 | Allow Full Content Indexing. |
| 35:910 | Schedule Policy |
| 35:911 | Except default subclients |
| 35:912 | Create an external snapshot. |
| 35:913 | Update OSSV Volume |
| 35:914 | File/File group subclient backup |
| 35:915 | Skip the collection of Metafiles during image level backup. |
| 35:916 | Start the job in suspended state. |
| 35:917 | Maximum number of subclients [<Number>] for this CommServe has been reached. |
| 35:918 | Approaching maximum number of subclients for this CommServe.n [<Number>] of [<Number>] subClients have been created. |
| 35:919 | Replication Set [<String>] has been deleted. |
| 35:920 | Replication Pair has been deleted. |
| 35:921 | Could not set the saved media group for any of the selected media. Probably the media type does not match or the media did not belong to an assigned media group. |
| 35:922 | Only [<Number>] out of the specified [<Number>] media had their saved media group set. For the others, please check if the media type is compatible and that the media was in an assigned media group. |
| 35:923 | Could not set the scratch pool for any of the selected media. Maybe the media pool is incompatible with the media. |
| 35:924 | Only [<Number>] out of the specified [<Number>] media had their scratch pool set into which these will go once a medium has been reused. For the others, please check if the media type is compatible with the selected scratch pool. |
| 35:925 | Failed to set new Job results minimum alert threshold in the registry. Aborting operation. |
| 35:926 | Email notification failed: <String>. |
| 35:927 | Failed to determine the schedule policy owner. |
| 35:928 | User does not have rights to edit schedule policy. |
| 35:929 | Maximum number of subclients for this CommServe has been reached. |
| 35:930 | Good |
| 35:931 | Bad |
| 35:932 | Deprecated |
| 35:933 | Invalid Volume Flag |
| 35:934 | Active |
| 35:935 | Full |
| 35:936 | Read Only |
| 35:937 | Bad |
| 35:938 | Idle |
| 35:939 | Recycle |
| 35:940 | Appendable |
| 35:941 | Failed to get storage policy and copy list. |
| 35:942 | Failed to set the max writers for the library: <Number> |
| 35:943 | Invalid or Missing Device ID. Cannot perform any device Operations. |
| 35:944 | Failed to get extended library attributes for Library ID <Number> |
| 35:945 | Failed to set extended library attributes for Library ID <Number> |
| 35:946 | Failed to set the Library description field in the DB for Library ID <Number> |
| 35:947 | Error retrieving Library info for Library <Number>, error = <String> |
| 35:948 | No Default |
| 35:949 | Properties were modified for this library |
| 35:950 | Unable to delete Replication Pair because it is in a replication or suspended state. |
| 35:951 | Deletion of the Replication Pair is not allowed because it is not in Aborted or New Pair state. |
| 35:952 | Deletion of the Replication Set is not allowed because one or more pairs are not in Aborted or New Pair state. |
| 35:953 | Snapshot cannot be deleted as this is not the oldest snapshot. |
| 35:954 | Unable to get Volumes and Mount Paths. |
| 35:955 | Index Cache retention time changed from [<Number>] to [<Number>] on Index Cache [<Number>] |
| 35:956 | MediaAgent switched offlinen |
| 35:957 | MediaAgent switched onlinen |
| 35:958 | Failed to set MediaAgent offline |
| 35:959 | Failed to set MediaAgent online |
| 35:960 | Failed to set the MediaAgent attributes |
| 35:961 | DB look up failure |
| 35:962 | Default Network Interface changed to [<String>]n |
| 35:963 | Multiple |
| 35:964 | Failed to rename barcode to: <String>. Reason: Duplicates found. |
| 35:965 | Failed to save Software Update Reboot Option in the CommServe database.n |
| 35:966 | Failed to configure Consistency Points Backups. |
| 35:967 | Job Management |
| 35:968 | MediaAgent Management |
| 35:969 | Administrative Management |
| 35:970 | Agent Management |
| 35:971 | Agent Scheduling |
| 35:972 | Storage Policy Management |
| 35:973 | Library Management |
| 35:974 | License Management |
| 35:975 | Data Protection/Management Operations |
| 35:976 | In Place Recover |
| 35:977 | Out-of-Place Recover |
| 35:978 | Browse |
| 35:979 | User Management |
| 35:980 | Report Management |
| 35:981 | Alert Management |
| 35:982 | The user [<String>] is a protected user and cannot be deleted. |
| 35:983 | The user [<String>] is a protected user and cannot be disabled or have its full name, description or aging rules changed. |
| 35:984 | The group [<String>] is a protected group and cannot be deleted. |
| 35:985 | The group [<String>] is a protected group. Changing the name or description of this group or disabling it is prohibited. |
| 35:986 | Failed to save Database Space Check Informational Percent Free in CommServe database.n |
| 35:987 | Failed to save Database Space Check Minor Percent Free in CommServe database.n |
| 35:988 | Failed to save Database Space Check Major Percent Free in CommServe database.n |
| 35:989 | Failed to save Database Space Check Critical Percent Free in CommServe database.n |
| 35:990 | A filter by that name already exists. |
| 35:991 | Snapshot Volume Unit [<String>] has been deleted. |
| 35:992 | Unable to change client name when jobs are running for client. |
| 35:993 | Failed to save Data Replicator Update Interval.n |
| 35:994 | Failed to delete Replication Set. Jobs are still running. |
| 35:995 | Failed to delete Replication Set. |
| 35:996 | Failed to delete Snapshot Volume Unit. Jobs are still running. |
| 35:997 | Failed to delete Replication Pair: Source [<String>] Destination [<String>]. Jobs are still running. |
| 35:998 | Failed to change Storage Policy for Consistency Points Backups because job [<Number>] is running. |
| 35:999 | Now |
| 35:1000 | Never |
| 35:1001 | This user action is restricted for regular VaultTracker license users. nPlease upgrade your VaultTracker license to enterprise license and try this again. nOr please call your vendor's support hotline for assistance. |
| 35:1002 | Failed to send the job control request to Job Manager. Please check that the Job Manager Service is running. |
| 35:1003 | Cannot perform name change on MediaAgent because there are still currently running jobs using this MediaAgent. |
| 35:1004 | iDataAgent |
| 35:1005 | storage policy |
| 35:1006 | backup set |
| 35:1007 | client |
| 35:1008 | CommCell |
| 35:1009 | drive |
| 35:1010 | instance |
| 35:1011 | library |
| 35:1012 | MediaAgent |
| 35:1013 | Server group |
| 35:1014 | subclient |
| 35:1015 | object |
| 35:1016 | Changes have been saved to the CommServe Database, but the Replication Service could not be reached for notification of changes. |
| 35:1017 | Failed to save Data Classification Update Interval.n |
| 35:1018 | Failed to get destination client |
| 35:1019 | Failed to save Maintenance Advantage User Name in CommServe database.n |
| 35:1020 | Failed to save Maintenance Advantage User Password in CommServe database.n |
| 35:1021 | Failed to receive response from client to verify Destination Path. Please check that Client Event Manager is running on client. |
| 35:1022 | The Index Cache free space warning threshold was changed from <Number> MB to <Number> MB. If the free space falls below this value, an alert will be sent but the index cache will stay online. |
| 35:1023 | The Index Cache free space threshold was changed from <Number> MB to <Number> MB. When the free space falls below this value, the index cache will be taken offline. |
| 35:1024 | Destination Path is not a fixed drive on the Destination Host. |
| 35:1025 | Unable to get GUID for Destination Path. Please make sure that mount path exists on Destination Host. |
| 35:1026 | No Rule Defined |
| 35:1027 | Unknown extended retention rule |
| 35:1028 | Retain ALL Full Jobs |
| 35:1029 | Retain One Full Every Week |
| 35:1030 | Retain One Full Every Month |
| 35:1031 | Retain One Full Every Quarter |
| 35:1032 | Retain One Full Every Half Year |
| 35:1033 | Retain One Full Every Year |
| 35:1034 | Cannot run VaultTracker Report: No license or the license has expired. |
| 35:1035 | Cannot run VaultTracker Report: Need Enterprise license to run the selected options. |
| 35:1036 | Failed to save SMTP maximum message size in CommServe database.n |
| 35:1037 | Failed to retrieve SMTP maximum message size from CommServe database.n |
| 35:1038 | Changing the SCSI reservation options is not allowed while there are reservations for this library. |
| 35:1039 | Could not open the [<String>] file <String>. Errno = [<Number>]. |
| 35:1040 | The <String> file [<String>] was too large to mail. |
| 35:1041 | Cannot Validate Password of logged in User. |
| 35:1042 | Failed to decrypt password for logged in User. |
| 35:1043 | Password Verification Failure for logged in User. |
| 35:1044 | Unable to compare passwords for logged in User. |
| 35:1045 | The user [<String>] is an administrative user and cannot be made part of the [<String>] group. |
| 35:1046 | Attempt to change user name and/or password for user [<String>] was denied. Only user [<String>] can make these changes. |
| 35:1047 | Cannot remove protected user [<String>] from group [<String>]. |
| 35:1048 | Group update failed for user. |
| 35:1049 | Clean drive [<String>] failed due to error: <Message>. |
| 35:1050 | Unable to Configure Subclients because Subclient [<Number>] [<String>] appears twice in request.nPlease contact Customer Support. |
| 35:1051 | The index cache directory you have selected already contains an index cache. The IDs match, but the timestamp of the last update mismatches - meaning that this could be an index cache from a previous install (possible a different CommCell) or an index cache that was left over from when it was moved elsewhere. |
| 35:1052 | The index cache directory you have selected already contains an index cache, but one which the CommServe does not have any information about - meaning that it could be from another CommCell or left over from a previous install. Please select another path. |
| 35:1053 | The index cache directory you have selected already contains an index cache, but one where the information mismatches to what is stored in the CommServe. This means it could be an index from a previous install, it could be left over of an index that was moved elsewhere, or it could be an index from another CommCell. |
| 35:1054 | Unable to configure Consistency Points Backup Set because there is no File System iDataAgent for client [<Number>] [<String>]. |
| 35:1055 | Not yet calculated |
| 35:1056 | There are Replication Pairs active on this client. These pairs need to be aborted before Job Results location can be changed. |
| 35:1057 | All subclients associated to a spool copy must be associated to at least one synchronous copy.Please check the subclient associations on this storage policy. |
| 35:1058 | Group update failed for user |
| 35:1059 | (Deleted,<Number>) |
| 35:1060 | Failed to decrypt password for User logging on |
| 35:1061 | User [<String>] already exists. |
| 35:1062 | User [<String>] insert failed. Consult the error log. |
| 35:1063 | Application |
| 35:1064 | Cannot change properties. A user with the name [<String>] already exists.n |
| 35:1065 | Could not update user[<String>].n |
| 35:1066 | Group addition Failed. Group [<String>] already exists.n |
| 35:1067 | Group addition Failed. Group [<String>] insert failed. Consult the error log.n |
| 35:1068 | Group has been added. |
| 35:1069 | Group [<String>] Update failed with error [<String>].n |
| 35:1070 | Attempt has been made to make the administrative user part of the group [<String>] which is not allowed. |
| 35:1071 | User [<String>] has been added. nn |
| 35:1072 | User [<String>] has been deleted. nn |
| 35:1073 | User [<String>] has been updated. nn |
| 35:1074 | Unknown operation [<Number>] has been attempted on User [<String>]. nn |
| 35:1075 | Username and Password were not saved because they do not authenticate with Active Directory Domain Controller [<String>]. Please change Username and Password and resubmit request. |
| 35:1076 | Failed to toggle 'Skip and Continue' setting for job [<Number>]. |
| 35:1077 | Username and Password were not saved because of failure to open session to Active Directory Domain Controller [<String>]. Please verify Active Directory Domain Controller and resubmit request if necessary. |
| 35:1078 | Primary Copy cannot be deleted. Must delete entire storage policy. |
| 35:1079 | Deletion of a source copy is not allowed. |
| 35:1080 | These pairs cannot be added because a child is already being monitored. Please change the child pair's source path to the current source path if desired. |
| 35:1081 | Child of [<String>] is already monitored in Replication Set [<String>] [<String>]. |
| 35:1082 | Child of Mount Path [<String>] is already monitored in Replication Set [<String>] [<String>]. |
| 35:1083 | These pairs were changed because a parent is already being monitored. |
| 35:1084 | [<String>] changed to [<String>] as in Replication Set [<String>]. |
| 35:1085 | [<String>] changed to Mount Path [<String>] as in Replication Set [<String>]. |
| 35:1086 | Replication Pair 'Source: [<String>] and Destination: [<String>]' has been deleted. |
| 35:1087 | These pairs cannot be added because of a destination path overlap. Please change to another destination path if desired. |
| 35:1088 | Submitted destination path [<String>] and destination path [<String>] in Replication Set [<String>] overlap each other. |
| 35:1089 | Unable to change Log Location because volume is already being used by one or more source paths on the client. |
| 35:1090 | Unable to connect to client to verify Log Location, so it cannot be saved. Please check that Client Event Manager is running on client. |
| 35:1091 | Maximum number of CommCell Console connections for this CommServe has been reached. Please try again later. |
| 35:1092 | Failed to receive response from client to verify Source Path. Please check that Client Event Manager is running on client. |
| 35:1093 | Unable to get GUID for Source Path. Please make sure that mount path exists on Source Host. |
| 35:1094 | Source Path is not a fixed drive on the Source Host. |
| 35:1095 | Failed to clean up Database records of old Cancelled CommCell Console Operations (details in EvMgrS.log). This may cause new CommCell Console Operations to be cancelled unexpectedly. Please call your vendor's support hotline for assistance. |
| 35:1096 | Failed to submit job for Content Indexing. |
| 35:1097 | Failed to create the log file for job [%d]. |
| 35:1098 | Failed to create the log file between time [%d] and [%d]. |
| 35:1099 | User cancelled the operation. |
| 35:1100 | Found more than one library as configured. Please check with your vendor. |
| 35:1101 | Failed to enable Content Indexing for selected job [<Number>]. |
| 35:1102 | Failed to disable Content Indexing for selected job [<Number>]. |
| 35:1103 | Failed to save high watermark in CommServe database.n |
| 35:1104 | Failed to save low watermark in CommServe database.n |
| 35:1105 | Failed to initialize Browse request. Please check EvMgrS.log for more information. |
| 35:1106 | XML Message unserialization failed. |
| 35:1107 | An exception occurred. Please check EvMgrS.log for detailed information. If the problem persists, please call your vendor's support hotline for assistance. |
| 35:1108 | Job [<Number>] is either prevented for copy or not available on source copy |
| 35:1109 | Failed to List Media for the restore job [<Number>]. The restore job may have completed. |
| 35:1110 | Failed to submit List Media from restore request. List media processing failed. |
| 35:1111 | Could not add User to the database. |
| 35:1112 | Failed to save Disaster Recovery Backup Pre/Post Commands in CommServe database.n |
| 35:1113 | Failed to cancel the operation. |
| 35:1114 | Failed to get Browse Recovery Options. |
| 35:1115 | Failed to save Browse Recovery Options. |
| 35:1116 | Failed to get Search Engines. |
| 35:1117 | Failed to save Search Engines. |
| 35:1118 | Failed to get Search Client. |
| 35:1119 | Failed to delete Search Engine. |
| 35:1120 | Failed to delete Search Engine Client. |
| 35:1121 | Failed to verify if anything has changed for the Copy [<String>]. |
| 35:1122 | Would you like to copy all the Deduplication Store data to the new location?nFrom: [<String>]nTo:t[<String>]nIf you select Yes, Deduplication data will be automatically copied to the new location.nIf you select No, only the Access path setting will be changed in the configuration, the data must be manually copied. |
| 35:1123 | Login Denied. User has no credentials on this CommServe. |
| 35:1124 | Failed to get Content Indexing Client Properties. |
| 35:1125 | Invalid User or Password for External User Login |
| 35:1126 | Failed to get properties for user [<String>]. |
| 35:1127 | Provider not added. A provider with this name already exists. |
| 35:1128 | The credentials you have entered could not be verified. The possible reasons could be:n1. The credentials you have entered are incorrect.n2. The provider could not be contacted for verification. |
| 35:1129 | Problem encountered interfacing to SQL database. Consult EvMgrS log file for details. |
| 35:1130 | Provider not added. Credentials provided do not have required Browse Privileges. |
| 35:1131 | Provider does not exist or has been disabled. |
| 35:1132 | Feature is not licensed, or trial license has expired. |
| 35:1133 | Request Handling Error. Consult EvmgrS log file for details. |
| 35:1134 | Failed to save Link to KB for JPR User Name in CommServe database.n |
| 35:1135 | Failed to save Link to KB for JPR User Password in CommServe database.n |
| 35:1136 | View |
| 35:1137 | End User Access |
| 35:1138 | Compliance Search |
| 35:1139 | Failed to initialize with Job Manager. |
| 35:1140 | Unable to delete the VaultTracker policy. There are jobs running for this policy. |
| 35:1141 | Failed to allocate license for Content Indexing. |
| 35:1142 | Failed to release license for Content Indexing. |
| 35:1143 | Failed to delete Search Engine <String> because it is in use by Storage Policies [<String>]. |
| 35:1144 | Failed to create instance because it already exists on another iDataAgent for this client. |
| 35:1145 | Deletion of the storage policy failed because some licenses could not be released. |
| 35:1146 | Failed to allocate Auxiliary Copy Encryption license when creating copy [<String>]. |
| 35:1147 | Failed to change Auxiliary Copy Encryption license based on data paths of current copy. |
| 35:1148 | Failed to allocate license when enabling the Auxiliary Copy Encryption option for copy [<String>]. |
| 35:1149 | Failed to release license when disabling the Auxiliary Copy Encryption option for copy [<String>]. |
| 35:1150 | A report with that name already exists. Please specify a different name. |
| 35:1151 | Unable to create storage policy copy [<String>] because the Deduplication license was not allocated successfully. |
| 35:1152 | Failed to release Deduplication license for copy [<String>]. |
| 35:1153 | Failed to allocate license when enabling the Deduplication option for copy [<String>]. |
| 35:1154 | Failed to release license when disabling the Deduplication option for copy [<String>]. |
| 35:1155 | No Error |
| 35:1156 | Failed to kill the running jobs for the VaultTracker policy. |
| 35:1157 | User [<String>] does not have required capability [Administrative Management] for this <String> and this operation. |
| 35:1158 | Unable to change client properties. There are still jobs running. |
| 35:1159 | User does not have sufficient rights to start the restore jobs. |
| 35:1160 | You cannot set the path to be the root directory. |
| 35:1161 | At Outside |
| 35:1162 | Failed to get client list that have backups on current storage policy. |
| 35:1163 | Failed to get client list that have backups on current copy. |
| 35:1164 | Skipping Task [<String>] on schedule [<String>] due to Holiday [<String>] set on client [<String>]. |
| 35:1165 | Skipping Task [<String>] on schedule [<String>] due to Holiday [<String>] set on Server group [<String>]. |
| 35:1166 | Unable to determine if Recovery Points are allowed for client [<String>]. |
| 35:1167 | Failed to save Auto Suppress Web Restores Option.n |
| 35:1168 | Deprecated message. |
| 35:1169 | Microsoft Windows File System |
| 35:1170 | Microsoft Exchange Server |
| 35:1171 | Network Attached Storage |
| 35:1172 | Microsoft SQL Server |
| 35:1173 | Cost Analysis |
| 35:1174 | UNIX File System |
| 35:1175 | Oracle |
| 35:1176 | Microsoft SharePoint |
| 35:1177 | NetWare File System |
| 35:1178 | VaultTracker Operations |
| 35:1179 | Container |
| 35:1180 | Shelf |
| 35:1181 | Policy |
| 35:1182 | Failed to save Secure Agent Install option in CommServe database.n |
| 35:1183 | Modifying data path for copy is not allowed since jobs are running for storage policy. Please wait for jobs to finish. |
| 35:1184 | Failed to save copy properties because of circular source copy dependency. |
| 35:1185 | Invalid report job ID |
| 35:1186 | Failed to initialize report |
| 35:1187 | unable to get report XML options from DB |
| 35:1188 | XML Message unserialization failed |
| 35:1189 | Cannot delete. Clients are still associated with this Search Engine. |
| 35:1190 | Could not add data path. Please try again, and if the problem persists, please contact your software vendor. |
| 35:1191 | Could not update data path. Please try again, and if the problem persists, please contact your software vendor. |
| 35:1192 | Update Cache Agent ID for Client [<String>] has been changed to [<Number>]. |
| 35:1193 | Failed to upload log files to web server [<String>]. |
| 35:1194 | Could not update property changes. Backup running for subclient. |
| 35:1195 | Could not update content changes. Backup running for default subclient. |
| 35:1196 | Cannot change subclient policy-backupset association. Jobs are running. |
| 35:1197 | Troubleshooting HTTP location has been set to [<String>]. |
| 35:1198 | Troubleshooting HTTP user has been set to [<String>]. |
| 35:1199 | Troubleshooting HTTP password has been modified. |
| 35:1200 | Failed to save Troubleshooting HTTP location in CommServe database. |
| 35:1201 | Failed to save Troubleshooting HTTP user in CommServe database. |
| 35:1202 | Failed to save Troubleshooting HTTP password in CommServe database. |
| 35:1203 | Failed to get HTTP parameters. |
| 35:1204 | Failed to add default preferences for user [<String>]. Please consult EvMgrS.log on the CommServe. |
| 35:1205 | Unable to initialize the Disk Library Maintenance. |
| 35:1206 | Failed to save the FTP Proxy information (server and port) for Update downloading in CommServe database.n |
| 35:1207 | Failed to save the FTP Proxy information (username) for Update downloading in CommServe database.n |
| 35:1208 | Failed to save the FTP Proxy information (password) for Update downloading in CommServe database.n |
| 35:1209 | Failed to save the FTP Proxy information (Location) for Update downloading in CommServe database.n |
| 35:1210 | Failed to save FTP Operation type for Update downloading in CommServe database.n |
| 35:1211 | Failed to save Use Passive FTP Option for Update downloading in CommServe database.n |
| 35:1212 | Failed to save the FTP Proxy information (Passive FTP) for Update downloading in CommServe database.n |
| 35:1213 | Failed to delete the pair. |
| 35:1214 | Failed to change SQL authentication settings at [<String>] level. |
| 35:1215 | Failed to get SQL authentication of Server group [<Number>]. |
| 35:1216 | Failed to create SQL Instance [<String>]. No authentication settings found at higher levels. Please choose Override Global settings. |
| 35:1217 | Server group [<String>] has been deleted. |
| 35:1218 | At Mail Slot |
| 35:1219 | Pickup from Slot |
| 35:1220 | Failed to save Network Error Retry Properties.n |
| 35:1221 | Multiplexing cannot be enabled for copy because Deduplication is used by copy in storage policy. |
| 35:1222 | Invalid report task ID |
| 35:1223 | External Group [<String>] has been <String> and cannot get scheduled reports. |
| 35:1224 | Failed to create/update the Server group. Please make sure a valid Server group license is installed. |
| 35:1225 | Changes not taken. Group was previously added to this domain. |
| 35:1226 | Group name could not be found in domain. Operation aborted. |
| 35:1227 | The correct NetBIOS name for the Directory Server you entered is [<String>]. Please select YES to continue with the system resolved name. Select NO to continue with the name you entered [<String>]. Selecting the name you entered may cause problems during Single Sign-On. |
| 35:1228 | The Directory Server name you have entered could not be contacted. If you intend to continue with the same name it may cause problems during log on. Do you want to change the name? |
| 35:1229 | Failed to create Replication Set [%s] from Policy. |
| 35:1230 | Failed to allocate license for Snap Backups. |
| 35:1231 | Failed to release license for Snap Backups. |
| 35:1232 | Notify GUI Server Developers: Item [<Number>] missing from cvEncode. |
| 35:1233 | Failed to Delete UpdateAgent [<String>]. |
| 35:1234 | UpdateAgent [<String>] deleted. |
| 35:1235 | New UpdateAgent [<String>] has been configured. |
| 35:1236 | UpdateAgent [<String>] has been modified. |
| 35:1237 | DnsRoot is not resolved. Ensure additional domain controllers are configured to work in failover situations. |
| 35:1238 | Failed to get storage policy properties. |
| 35:1239 | Failed to create Silo On Demand Backup Set for copy. |
| 35:1240 | Failed to check silo subclient for copy. |
| 35:1241 | Cannot delete copy with silo backup set. Please delete Silo backup set for the copy. |
| 35:1242 | Snap Copy to Tape failed. Unable to initialize Snap Copy To Tape. |
| 35:1243 | Deprecated message. |
| 35:1244 | Job is completed. Description cannot be saved. |
| 35:1245 | Failed to update job description. Database Error. |
| 35:1246 | Failed to create snapshot backup set for OSSV Volume [<Number>]. |
| 35:1247 | Compliance Director failed. Unable to initialize Compliance Director. |
| 35:1248 | This edition of the software does not support empty password. |
| 35:1249 | Association operation failed. Please try later. Check EvMgrS.log file for details. |
| 35:1250 | Failed to get subclient list. Please try later. |
| 35:1251 | Failed to return subclient for OSSV Volume [<Number>]. |
| 35:1252 | The operation cannot be completed at this time. Please try again later. |
| 35:1253 | Deprecated message [<String>]. |
| 35:1254 | Deprecated message [<String>]. |
| 35:1255 | A database error occurred while performing the operation. |
| 35:1256 | An unknown error occurred while retrieving the list of accounts from Microsoft Reporting Service. |
| 35:1257 | Please check for invalid or missing arguments. |
| 35:1258 | Error: Invalid account or password. Unable to log on to MS Reporting Services. |
| 35:1259 | Deprecated message [<String>]. |
| 35:1260 | Failed to Set RS Credentials. |
| 35:1261 | Library Administration |
| 35:1262 | Failed to pick snapshot job for moving to backup media. |
| 35:1263 | Failed to unpick snapshot job for moving to backup media. |
| 35:1264 | Analysis |
| 35:1265 | Discovery |
| 35:1266 | Workflow [<String>] cannot be deleted as the jobs are still running. |
| 35:1267 | SNMP traps for Alerts not sent. No license or license has expired. |
| 35:1268 | Cannot change index cache path. Disaster Recovery Backup running in the CommServe. Please try after the job completes. |
| 35:1269 | Failed to set the affinity. |
| 35:1270 | The Instance could not be reconfigured. Consult the EvmgrS log file for details. |
| 35:1271 | The Instance could not be deconfigured. Consult the EvmgrS log file for details. |
| 35:1272 | User [<String>] does not have required capability [<String>] or [<String>] for this <Message> and this operation. |
| 35:1273 | Failed to perform OS scan for new devices. Please check log file for details. |
| 35:1274 | Unable to create the storage policy or copy because the specified directory [<String>] already exists and is used by another Access Path or Deduplication Store. Please provide a different location for Deduplication Store and try again. |
| 35:1275 | Deletion of primary snapshot copy is not allowed when other snapshot copy exists. |
| 35:1276 | Unable to establish connectivity with these instance properties for [<String>].n[<String>].nFailed to create instance. |
| 35:1277 | Unable to establish connectivity with these instance properties for [<String>].nFailed to create instance. |
| 35:1278 | The credentials you have entered could not be verified. The possible reasons could be:n1. The Directory Server host name is not a fully qualified name.n2. The credentials you have entered are incorrect.n3. The provider could not be contacted for verification. |
| 35:1279 | Unable to create selective snapshot copy [<String>] for storage policy [<String>]; please create a primary snapshot copy first. |
| 35:1280 | Unable to create mirror snapshot copy [<String>] for storage policy [<String>]; please create a primary snapshot copy first. |
| 35:1281 | Unable to seal the active Deduplication store and create a new store for this copy because of an unspecified error. |
| 35:1282 | Failed to allocate license when enabling the Tape Deduplication option for copy [<String>]. |
| 35:1283 | Failed to release license when disabling the Tape Deduplication option for copy [<String>]. |
| 35:1284 | Failed to allocate Tape Deduplication license when creating SIDB Store for copy [<String>]. |
| 35:1285 | Failed to release Tape Deduplication license for copy [<String>]. |
| 35:1286 | Snapshots are still mounted. |
| 35:1287 | OPERATION FAILED: Please check logs for more details. |
| 35:1288 | Replication Policy [<String>] has been deleted. |
| 35:1289 | Invalid Silo data path configuration: data path using shared disk library is not allowed for copy with Silo enabled and default data path using an unshared disk library. |
| 35:1290 | <String> |
| 35:1291 | The Instance could not be deconfigured/deleted. Consult the EvmgrS log file for details. |
| 35:1292 | Cannot enable Office Communicator Server Backup: there are no Office Communicator Server Backup licenses available. |
| 35:1293 | Discovery Failed. Please see EvMgrS.log for additional details. |
| 35:1294 | Cannot modify backup set while jobs are running. |
| 35:1295 | Some users may not receive the email [subject : <String>...] as the number of recipients exceeded the maximum limit [<Number>]. |
| 35:1296 | Invalid browse time specified. Please be sure browse time is no earlier than Replication Set creation time. |
| 35:1297 | Unable to complete request for job [<Number>] while it is running. |
| 35:1298 | Error. Could not determine if a Local Migration Instance already exists. |
| 35:1299 | A local migration instance already exists for this iDataAgent. |
| 35:1300 | New name validation failed. |
| 35:1301 | Jobs are still running on CommServe. |
| 35:1302 | Failed to update CommServe Database. |
| 35:1303 | Failed to update CommServe registry. |
| 35:1304 | Source and Destination paths can only be changed when pair is in New state. |
| 35:1305 | The job doesn't have skipped restore files. |
| 35:1306 | Data multiplexing cannot be enabled for a storage policy copy because Deduplication is enabled for another copy. |
| 35:1307 | Deduplication cannot be enabled for a storage policy copy because data multiplexing is enabled for another copy. |
| 35:1308 | Failed to create Silo On Demand Backup Set for copy. Database error occurred. |
| 35:1309 | Failed to create Silo On Demand Backup Set for copy. There is no File System iDataAgent installed. |
| 35:1310 | Failed to create Silo On Demand Backup Set for copy. Error occurred. Please check log for more information. |
| 35:1311 | Data multiplexing cannot be enabled for a storage policy copy because Deduplication is enabled. |
| 35:1312 | Unable to seal the active Deduplication store and create a new store for this copy. Deduplication Store Access Path is on a MediaAgent older than 8.0. |
| 35:1313 | Unable to seal the active Deduplication store and create a new store for this copy. There are partially copied archive files. Please complete aux copy and retry. |
| 35:1314 | Cannot determine if Proxy has Agents pointing to it |
| 35:1315 | Deprecated message. |
| 35:1316 | Unable to seal the active Deduplication store and create a new store for this copy. Some jobs are using this DDB, please go to Job Controller and filter by this SP/Copy to view those jobs. |
| 35:1317 | Unable to complete 'Pick For Copy' process for job [<Number>] because some archive file has been partially copied to a sealed Deduplication store. Only 'Re-Copy' is allowed. |
| 35:1318 | User is deleted/disabled |
| 35:1319 | This replication pair is configured for out-of-band Sync. Cannot start Replication. Please enable incremental sync and try again. |
| 35:1320 | All replication pairs must be in New/ Stopped state to enable out-of-band sync. |
| 35:1321 | Report Selection FTP Location has been set to [<String>], [<String>]. |
| 35:1322 | Failed to save Report Settings FTP HTTP Credentials in CommServe database. |
| 35:1323 | No need to seal the active Deduplication store and create a new store for this copy. Probably there is no data in the current store. |
| 35:1324 | Failed to get FTP parameters. |
| 35:1325 | Failed to connect to FTP site [<String>]. |
| 35:1326 | Failed to create directory [<String>] on FTP server [<String>]. |
| 35:1327 | Failed to upload report [<String>] to FTP server [<String>]. |
| 35:1328 | uploadRpt: Unknown Error Code. |
| 35:1329 | Failed to send report files to FTP site [<String>]. |
| 35:1330 | Failed to upload report files to web server [<String>]. |
| 35:1331 | Failed to save Troubleshooting log HTTP Proxy Location in CommServe database. |
| 35:1332 | Failed to save Troubleshooting log HTTP Proxy Port in CommServe database. |
| 35:1333 | Troubleshooting log HTTP Proxy Location has been set to [<String>]. |
| 35:1334 | Troubleshooting log HTTP Proxy Port has been set to [<String>]. |
| 35:1335 | Tag Management |
| 35:1336 | Content Director Policy Management |
| 35:1337 | Legal Hold Management |
| 35:1338 | ERM Management |
| 35:1339 | Execute |
| 35:1340 | Add/Append |
| 35:1341 | Delete |
| 35:1342 | Unable to change Index Cache Server for MediaAgent. Jobs are running. |
| 35:1343 | Catalog profile cannot be removed if it is in use by more than one MediaAgent. Please unselect 'Catalog Profile' in properties of all such MediaAgents before removing the Catalog Profile. |
| 35:1344 | Failed to remove the Index Cache Server profile. |
| 35:1345 | Update Cache Agent for Client [<String>] has been changed to [<String>]. |
| 35:1346 | Unable to complete 'Mark Job Bad' process for job [<Number>]. |
| 35:1347 | Unable to complete 'Mark Job Good' process for job [<Number>]. |
| 35:1348 | Client [<String>] has been deleted/uninstalled. |
| 35:1349 | Client [<String>] is not reachable. The service may be down. |
| 35:1350 | Log Files for AppID [<Number>] were successfully sent to [<String>]. |
| 35:1351 | Log Files for job [<Number>] and AppID [<Number>] were successfully sent to [<String>]. |
| 35:1352 | Failed to find clients for AD Server Name [<String>], aborting discovery of Clients. |
| 35:1353 | Out-of-band sync failed. Check EvMgrS.log for details. |
| 35:1354 | Physical |
| 35:1355 | Virtual |
| 35:1356 | Successfully changed CommServe name from [<String>] to [<String>] on [<String>]. |
| 35:1357 | Failed to update CommServe name from [<String>] to [<String>] on [<String>]. |
| 35:1358 | Successfully changed client name from [<String>] to [<String>]. |
| 35:1359 | Failed to update client name from [<String>] to [<String>]. |
| 35:1360 | Successfully changed client host name from [<String>] to [<String>] on [<String>]. |
| 35:1361 | Failed to update client host name from [<String>] to [<String>] on [<String>]. |
| 35:1362 | Remote client could not be contacted to update registry entry.nDo you want to update Database anyway? |
| 35:1363 | Name change operation on remote client failed. |
| 35:1364 | Problem in discovering clients for Job id [<Number>]. |
| 35:1365 | Problem in updating the discovery status of clients for Job id [<Number>]. |
| 35:1366 | Annotation Management |
| 35:1367 | Failed to save user and user group mappings for the sites |
| 35:1368 | Report [<String>] is successfully uploaded to FTP site. |
| 35:1369 | Failed to save IIS Server Port in CommServe database.n |
| 35:1370 | Software Cache for Client [<String>] has been changed to [<String>]. |
| 35:1371 | Catalog profile with given name already exists. Please choose a different name. |
| 35:1372 | To Location : [<String>]. |
| 35:1373 | All Copies |
| 35:1374 | Data Recovery. |
| 35:1375 | Data Aging |
| 35:1376 | Erase backup/migrated data |
| 35:1377 | Data Aging Forecast |
| 35:1378 | Disaster Recovery |
| 35:1379 | Auxiliary Copy |
| 35:1380 | Data Verification |
| 35:1381 | Report |
| 35:1382 | Tracking Policy Schedule |
| 35:1383 | Media Inventory |
| 35:1384 | Media Export |
| 35:1385 | Tape Erase |
| 35:1386 | Media Prediction |
| 35:1387 | Storage Validation |
| 35:1388 | Drive Cleaning |
| 35:1389 | FTP Download |
| 35:1390 | Update Patches |
| 35:1391 | Primary Storage Report |
| 35:1392 | Offline Content Indexing |
| 35:1393 | Defrag Analysis |
| 35:1394 | Commcell Export |
| 35:1395 | Commcell Import |
| 35:1396 | Disk Library Volume Reconciliation |
| 35:1397 | External Data Connector |
| 35:1398 | Preparation |
| 35:1399 | Media Refresh |
| 35:1400 | External Data Processor |
| 35:1401 | Catalogue Media |
| 35:1402 | Information Management |
| 35:1403 | Backup Copy |
| 35:1404 | First |
| 35:1405 | Second |
| 35:1406 | Third |
| 35:1407 | Fourth |
| 35:1408 | Last |
| 35:1409 | Pattern : One time on : <String> |
| 35:1410 | Pattern : Daily |
| 35:1411 | Pattern : Weekly on days [<String>] |
| 35:1412 | Pattern : Monthly on day : <Number> |
| 35:1413 | Pattern : Monthly on the <String> <String> |
| 35:1414 | Pattern : Yearly on day <Number> of month <String> |
| 35:1415 | Pattern : Yearly on the <String> <String> of month <String> |
| 35:1416 | Until <String> |
| 35:1417 | Starting from <String> |
| 35:1418 | At : <String> |
| 35:1419 | Associations : |
| 35:1420 | Client : [<String>] |
| 35:1421 | Agent Type : [<String>] |
| 35:1422 | Instance : [<String>] |
| 35:1423 | BackupSet: [<String>] |
| 35:1424 | SubClient : [<String>] |
| 35:1425 | Storage Policy : [<String>] |
| 35:1426 | Storage Policy Copy: [<String>] |
| 35:1427 | Schedules : |
| 35:1428 | n t Name : [<String>]n |
| 35:1429 | Server group |
| 35:1430 | Index Cache Offline Reason: <String> |
| 35:1431 | Failed to perform operation on task. |
| 35:1432 | Failed to clone task. |
| 35:1433 | Failed to run task. |
| 35:1434 | Failed to delete task. |
| 35:1435 | Failed to enable the task. |
| 35:1436 | Failed to disable the task. |
| 35:1437 | Failed to decouple the task. |
| 35:1438 | Failed to get the job details. |
| 35:1439 | Failed to create task. Task information missing. |
| 35:1440 | Failed to create task. Task with same name already exists. |
| 35:1441 | Failed to create task. |
| 35:1442 | Failed to create task. Schedule with same name already exists. |
| 35:1443 | Server group : [<String>] |
| 35:1444 | Schedule Policy : [<String>]. |
| 35:1445 | Backup Task |
| 35:1446 | Restore Task |
| 35:1447 | Administrative Task |
| 35:1448 | Stamp Media |
| 35:1449 | Media Prediction |
| 35:1450 | Install Client |
| 35:1451 | Uninstall Client |
| 35:1452 | with |
| 35:1453 | Schedule Summary : |
| 35:1454 | Restore Destination : <String> |
| 35:1455 | Restore to same folder |
| 35:1456 | Recreate Mount Points |
| 35:1457 | Restore ACLS |
| 35:1458 | Restore Data |
| 35:1459 | Restore ACLS and Data |
| 35:1460 | XML Message serialization failed. |
| 35:1461 | Client look up failed. |
| 35:1462 | DAG Discover failed. |
| 35:1463 | Creation of DAG PseudoClient failed. |
| 35:1464 | Task is invalid. |
| 35:1465 | Task is disabled. |
| 35:1466 | Task is deleted. |
| 35:1467 | Invalid timezone. |
| 35:1468 | Could not schedule task. |
| 35:1469 | Schedule pattern not found. |
| 35:1470 | Invalid schedule pattern. |
| 35:1471 | Schedule pattern has expired. |
| 35:1472 | Failed to save the script. |
| 35:1473 | File already exists. |
| 35:1474 | Invalid path specified. |
| 35:1475 | Network Configuration successfully pushed for client [<String>]. |
| 35:1476 | Failed to push Network Configuration for client [<String>]. |
| 35:1477 | Network Configuration successfully pushed for Server group [<String>]. |
| 35:1478 | Failed to push Network Configuration for Server group [<String>]. |
| 35:1479 | Job preview Failed. |
| 35:1480 | Failed to get jobs for Calendar. |
| 35:1481 | Security check failed. |
| 35:1482 | License check failed. |
| 35:1483 | Security check failed. Invalid Task Type. |
| 35:1484 | Security check failed. Invalid SubTask Type. |
| 35:1485 | Security check failed. Invalid Policy Type. |
| 35:1486 | Invalid path specified. The path is a folder. |
| 35:1487 | Failed to create Task. Task does not have any subtask. |
| 35:1488 | Failed to modify task. |
| 35:1489 | Failed to run task. Task does not exist. |
| 35:1490 | Failed to run task. No associations exist. |
| 35:1491 | Schedule has exceeded maximum occurrence. |
| 35:1492 | Frequency type of schedule pattern is invalid. |
| 35:1493 | Failed to check holiday. |
| 35:1494 | Failed to create task. Report with same name already exists. |
| 35:1495 | Active for Refresh |
| 35:1496 | Disabled |
| 35:1497 | All subClients using encryption |
| 35:1498 | Disabled on some subclients |
| 35:1499 | No subClients using encryption |
| 35:1500 | Content Store Upload |
| 35:1501 | Content Store Download |
| 35:1502 | Failed to save Enable/Disable Do not start backups on disabled clients.n |
| 35:1503 | Every Day |
| 35:1504 | Every Week |
| 35:1505 | Every Month |
| 35:1506 | Every Year |
| 35:1507 | Of |
| 35:1508 | and |
| 35:1509 | repeats every |
| 35:1510 | hr(s) |
| 35:1511 | min(s) |
| 35:1512 | AM |
| 35:1513 | PM |
| 35:1514 | Unable to set prepare recovery point for off line mining for Exchange as QSnap is not installed on destination. |
| 35:1515 | Unable to set prepare recovery point for off line mining for Active Directory as QSnap is not installed on destination. |
| 35:1516 | Cannot enable client deduplication. There are no licenses available. |
| 35:1517 | Failed to release license when disabling client deduplication. |
| 35:1518 | Unable to establish connectivity with these instance properties for [<String>].n[<String>].nFailed to modify instance. |
| 35:1519 | Unable to establish connectivity with the instance properties for [<String>].nFailed to modify instance. |
| 35:1520 | Failed to retrieve list of blacklisted clients |
| 35:1521 | Failed to update the list of owners |
| 35:1522 | Failed to set the list of blacklisted clients |
| 35:1523 | Deprecated message[<String>], [<String>]. |
| 35:1524 | Cannot enable FSDM license for File system |
| 35:1525 | Failed to save Disaster Recovery wild card for client log backup in CommServe database.n |
| 35:1526 | Discovery job succeeded. Refresh CommCell console to see new entities. |
| 35:1527 | Failed to create share for software cache |
| 35:1528 | Failed to save share name in DB |
| 35:1529 | Error occurred while performing compliance delegation operation. |
| 35:1530 | Failed to discover Member Servers (Storage Areas) |
| 35:1531 | Creation of Object Server Pseudo Client failed. |
| 35:1532 | Unable to establish connectivity with these instance properties for [<String>] |
| 35:1533 | Unable to establish connectivity with these instance properties for [<String>]. Do you want to save the properties anyway? |
| 35:1534 | All Operations |
| 35:1535 | Online |
| 35:1536 | Offline |
| 35:1537 | Backup |
| 35:1538 | Restore |
| 35:1539 | Import |
| 35:1540 | Export |
| 35:1541 | Media Initialization |
| 35:1542 | Media Recycling |
| 35:1543 | Data Aging |
| 35:1544 | Disaster Recovery Backup |
| 35:1545 | Index Restore |
| 35:1546 | Auxiliary Copy |
| 35:1547 | Synthetic Full |
| 35:1548 | System State Restore |
| 35:1549 | Full Rebuild Restore |
| 35:1550 | Report |
| 35:1551 | Third Party Backup |
| 35:1552 | Full Rebuild Restore |
| 35:1553 | Media Export |
| 35:1554 | Media Inventory |
| 35:1555 | Create Snapshot |
| 35:1556 | Replicate create |
| 35:1557 | Replicate incremental update |
| 35:1558 | Restore |
| 35:1559 | List Media |
| 35:1560 | Recover |
| 35:1561 | Scheduler |
| 35:1562 | System State Backup |
| 35:1563 | Data Verification |
| 35:1564 | Erase Media |
| 35:1565 | Tracking Policy |
| 35:1566 | Copy Back |
| 35:1567 | Install Updates |
| 35:1568 | Download Software |
| 35:1569 | Roll Back |
| 35:1570 | Erase Data |
| 35:1571 | Workflow |
| 35:1572 | Restore By Job |
| 35:1573 | Storage Validation |
| 35:1574 | Drive Cleaning |
| 35:1575 | 1-Touch Backup |
| 35:1576 | Erase Data by Browsing |
| 35:1577 | Restore |
| 35:1578 | Stamp Media |
| 35:1579 | Catalogue Media |
| 35:1580 | 1-Touch Restore |
| 35:1581 | Find And Retrieve |
| 35:1582 | Create Consistency Recovery Point |
| 35:1583 | Create Quick Recovery Point |
| 35:1584 | Copy Back |
| 35:1585 | Offline Content Indexing |
| 35:1586 | Restore |
| 35:1587 | Power Find And Retrieve |
| 35:1588 | Continuous Data Replication |
| 35:1589 | Online Content Indexing |
| 35:1590 | Deprecated message |
| 35:1591 | Snap Backup |
| 35:1592 | Backup Copy |
| 35:1593 | Backup Copy Workflow |
| 35:1594 | Primary Storage Report |
| 35:1595 | Magnetic Library Maintenance |
| 35:1596 | Restore (Export) |
| 35:1597 | Third Party Snap Backup |
| 35:1598 | Restore |
| 35:1599 | Install Software |
| 35:1600 | Uninstall Software |
| 35:1601 | Foreign Data Workflow |
| 35:1602 | Mining Backup |
| 35:1603 | CommCell Export |
| 35:1604 | CommCell Import |
| 35:1605 | FDC Client |
| 35:1606 | Media Refresh |
| 35:1607 | Discover |
| 35:1608 | Archiving |
| 35:1609 | Mining Content Indexing |
| 35:1610 | Mining Preparation |
| 35:1611 | Deprecated message |
| 35:1612 | Dedup DB Reconstruction |
| 35:1613 | Tape Import |
| 35:1614 | Archiver |
| 35:1615 | Persistent Recovery |
| 35:1616 | Recovery |
| 35:1617 | Power Recovery |
| 35:1618 | Compliance Archive |
| 35:1619 | Retrieve |
| 35:1620 | Power Retrieve |
| 35:1621 | Silo Archive |
| 35:1622 | Silo Retrieval |
| 35:1623 | Upgrade Software |
| 35:1624 | Remove Updates |
| 35:1625 | Copy Software |
| 35:1626 | Failed to add user with MediaAgent management rights to storage policy [<String>]. |
| 35:1627 | Failed to add data path using MediaAgent [<String>] with error: [<String>] |
| 35:1628 | User has no MediaAgent management right to access this library. |
| 35:1629 | Library has no library controller. |
| 35:1630 | User has no MediaAgent management right to access any MediaAgent of this library. |
| 35:1631 | Failed to push Network Configuration for following Clients : [<String>]. |
| 35:1632 | Data Verification |
| 35:1633 | Other Admin Operation |
| 35:1634 | Manual deletion of jobs from a worm storage policy is not allowed. |
| 35:1635 | Reducing the basic or extended retention of a worm storage policy copy is not allowed. |
| 35:1636 | Removing any extended retention rule of a worm storage policy copy is not allowed because fewer jobs will be retained. |
| 35:1637 | Failed to delete Snap array information. |
| 35:1638 | Upgrade Client |
| 35:1639 | Failed to retrieve Network Configuration Summary. |
| 35:1640 | Unable to delete this Storage Pool since there are dependent storage policy copies that are still in use. |
| 35:1641 | An instance by this type already exists. |
| 35:1642 | Failed to save Enable/Disable for Oracle Multiplexing. |
| 35:1643 | Failed to set copy [<String>] to primary due to running jobs. |
| 35:1644 | Client reconfiguration failed. |
| 35:1645 | Client reconfiguration completed successfully. |
| 35:1646 | <html>Cannot remove Shared Catalog profile, profile is in use for these MediaAgent(s): <String> </html> |
| 35:1647 | Client reconfiguration failed because no agent needs to configure. |
| 35:1648 | Cannot create subclient for backupset [<String>] having wildcard content set for client [<String>]. |
| 35:1649 | Failed to add Snap array information. |
| 35:1650 | Failed to create client. |
| 35:1651 | Failed to export firewall certificate. |
| 35:1652 | Failed to push Network Configuration: [<String>]. |
| 35:1653 | Failed to save site information, please try again. |
| 35:1654 | Snap array information already present. |
| 35:1655 | Failed to send service control request to client [<String>]. |
| 35:1656 | Failed to send service control request to client. See Evmgrs.log for details. |
| 35:1657 | Service Control is not supported for the Client [%s] as it is older than version 9.0. |
| 35:1658 | Failed to get the SMTP username information. |
| 35:1659 | Failed to process the SMTP password. |
| 35:1660 | Failed to set SSL/TLS flag for SMTP. |
| 35:1661 | Failed to get the authentication flag for SMTP. |
| 35:1662 | Failed to create task. Missing or invalid Agentless policy information |
| 35:1663 | Failed to create task. Missing or invalid Application type information |
| 35:1664 | Failed to create task. Missing or invalid BackupSet information |
| 35:1665 | Failed to create task. Missing or invalid Server group information |
| 35:1666 | Failed to create task. Missing or invalid Client information |
| 35:1667 | Failed to create task. Missing or invalid Copy information |
| 35:1668 | Failed to create task. Missing or invalid Storage Policy information |
| 35:1669 | Failed to create task. Missing or invalid Instance information |
| 35:1670 | Failed to create task. Missing or invalid Subclient information |
| 35:1671 | Failed to create task. Missing or invalid Tracking Policy information |
| 35:1672 | Failed to create task. Missing or invalid MediaAgent information. |
| 35:1673 | Deprecated message |
| 35:1674 | Deprecated message |
| 35:1675 | Failed to modify Agentless policy. Jobs are still running. |
| 35:1676 | Failed to delete Agentless policy. Jobs are still running. |
| 35:1677 | The available datapath(s) cannot be used due to licensing reasons. |
| 35:1678 | No valid datapath found. |
| 35:1679 | Your file is currently being recalled from remote storage. |
| 35:1680 | Your file is currently being recalled from remote storage and the process may take several minutes to complete. Thank you for your patience. |
| 35:1681 | Your request has been cancelled because the file is currently stored in offline media. A restore request is pending, please check back in 24 hours. |
| 35:1682 | Unable to send test mail. Check your credentials. |
| 35:1683 | Mail sent successfully. |
| 35:1684 | This email was sent automatically by <String> while testing the settings of your account. |
| 35:1685 | Unable to resolve the SMTP host. Check your SMTP server name |
| 35:1686 | Unable to send mail. Check your username/password. |
| 35:1687 | Test Mail. |
| 35:1688 | Information Management |
| 35:1689 | Auxiliary Copy |
| 35:1690 | Media Refresh |
| 35:1691 | Persistent Recovery |
| 35:1692 | Site information is being modified by another user, try after some time. |
| 35:1693 | Error while sending site information to client. |
| 35:1694 | Error, Client not responding. |
| 35:1695 | Error while performing client side operation. |
| 35:1696 | Can not delete array information, it has associated snapshots. |
| 35:1697 | Total running Time for [<String>] has been enabled. |
| 35:1698 | Total running Time for [<String>] has been disabled. |
| 35:1699 | Kill job if total running time is expired for [<String>] has been enabled. |
| 35:1700 | Kill job if total running time is expired for [<String>] has been disabled. |
| 35:1701 | Total Running Time has been changed from [<Number>] Minutes to [<Number>] Minutes. |
| 35:1702 | Operation failed. Remove the association from DAG pseudo client to proceed. |
| 35:1703 | Data |
| 35:1704 | Log |
| 35:1705 | Config |
| 35:1706 | Control File |
| 35:1707 | Log Only |
| 35:1708 | Deprecated message |
| 35:1709 | Deprecated message |
| 35:1710 | N/A |
| 35:1711 | Recover and Download |
| 35:1712 | RAC Instance add operation successful. Unable to establish connectivity with the instance properties for [<String>]. [<String>]. Please use modify GUI option to modify instance properties. |
| 35:1713 | Datapath with the scratch pool already exists for Archive Group Copy. |
| 35:1714 | Could not connect to AD. Please check your username/password or Domain Controller name. |
| 35:1715 | Bad |
| 35:1716 | Bad & Retained |
| 35:1717 | Deletion of primary snapshot copy is not allowed when snapshot backups are running on it. |
| 35:1718 | Total Running Time for [<String>] has been changed from [<Number>] Minutes to [<Number>] Minutes. |
| 35:1719 | Reconstruction is not supported for Deduplication stores created in older releases. |
| 35:1720 | Unable to establish connectivity with these instance properties for [<String>]. [<String>]. |
| 35:1721 | RAC Instance add operation successful. Unable to establish connectivity with the instance properties for [<String>]. [<String>]. |
| 35:1722 | Failed to allocate license for NetApp Management. |
| 35:1723 | Failed to release license for NetApp Management. |
| 35:1724 | Failed to add Snap array information due to duplicate client name. |
| 35:1725 | Failed to add Snap array information due to duplicate host name. |
| 35:1726 | Failed to modify Snap array information due to duplicate client name. |
| 35:1727 | Failed to modify Snap array information due to duplicate host name. |
| 35:1728 | Failed to modify Snap array information. |
| 35:1729 | NetApp Snap Management license needs to be released from Array Management screen. |
| 35:1730 | Can not delete DataFabric Manager information, it is associated with Storage Policies. |
| 35:1731 | DataFabric Manager information already present. |
| 35:1732 | Failed to add DataFabric Manager information. |
| 35:1733 | Jobs in this storage policy [<String>] have been submitted for deletion. This policy now becomes hidden and will be deleted after all snapshots have been physically deleted. |
| 35:1734 | Jobs in this storage policy [<String>] copy [<String>] have been submitted for deletion. This copy now becomes inactive and will be deleted after all snapshots have been physically deleted. |
| 35:1735 | Deletion of a source copy for backup copy is not allowed. |
| 35:1736 | Unable to resubmit jobs older than 7 days. |
| 35:1737 | Unable to change source copy because partial jobs can't be copied with encryption setting 'Preserve encryption mode as in source' when source data are encrypted differently.nPlease first complete auxiliary copy or mark partial jobs for recopy or change encryption setting. |
| 35:1738 | Storage Pool has data from different CommCell than the current Storage Policy's CommCell. nStorage Pool can not be used for more than one CommCell data. nADVICE: Use a new Storage Pool for creating Storage Policy/Copy. |
| 35:1739 | Virtual Machine Management |
| 35:1740 | No instances are present, Please configure at least one instance. |
| 35:1741 | Discovery of templates is still in progress, Time out occurred while waiting for the response. |
| 35:1742 | <USER NAME> |
| 35:1743 | <SERIAL> |
| 35:1744 | <DATA CENTER> |
| 35:1745 | Create virtual machine [<String>]: Failed |
| 35:1746 | Create virtual machine [<String>]: Succeeded |
| 35:1747 | Virtual Machine creation failed. n Error: [<String>] |
| 35:1748 | Virtual machine name: <String> n Virtual machine hostname: <String> n <String> |
| 35:1749 | Virtual Machine Host/IP address not available yet. Wait for 5 minutes and try to do a synchronize operation in webconsole. If that does not work, please Contact administrator. |
| 35:1750 | Client creation failed. Client [<String>] already exists. |
| 35:1751 | The reservation period of Virtual Machine [<String>] is about to expire. Please renew it at: <String> |
| 35:1752 | The reservation period of the Virtual Machine mentioned below ends in [<Number>] days. Please renew it if you plan to use the virtual machine for some more time. nn Virtual machine Name: <String>n Virtual machine hostname: <String> n Reserved Until: <String> n URL: <String> |
| 35:1753 | Invalid input specified. |
| 35:1754 | vCenter [<String>] information is missing. Make sure virtual server instance is configured for this vCenter. |
| 35:1755 | vCenter [<String>] logon credentials are incorrect. Make sure virtual server instance is configured with correct username and password. |
| 35:1756 | Virtual machine provisioning operation failed with unknown error. Try this operation after some time. |
| 35:1757 | Virtual machine provisioning operation failed as no licenses are available. |
| 35:1758 | Snapshot deletion has failed. |
| 35:1759 | Unable to communicate with remote client |
| 35:1760 | Failed to Set Client Owner Capabilities |
| 35:1761 | Failed to Get Client Owner Capabilities |
| 35:1762 | Install Package/Update |
| 35:1763 | Error configuring plug-in information. Atleast one machine should be configured as web console for plug-in operations to work. |
| 35:1764 | Error retrieving vCenter host information. |
| 35:1765 | Another user is performing a plug-in operation on vCenter <String>. Please try after some time. |
| 35:1766 | Unexpected error while preparing to communicate with proxy client. |
| 35:1767 | Cannot communicate with proxy client. |
| 35:1768 | Did not get response from proxy client. |
| 35:1769 | Connection with vCenter failed. Please check vCenter state. |
| 35:1770 | Virtualize Machine |
| 35:1771 | XML error: please refer to logs for more details. |
| 35:1772 | DB error: please refer to logs for more details. |
| 35:1773 | Security error: please refer to logs for more details. |
| 35:1774 | Input XML has invalid subclient name in association. |
| 35:1775 | Unable to add content; duplicate content is available for the same client. |
| 35:1776 | Failed to create Instance. Backup server name is invalid. |
| 35:1777 | Following client owner entries could not be saved : |
| 35:1778 | [<String>] do not exist. |
| 35:1779 | [<String>] have invalid domain. |
| 35:1780 | User [<String>] can not manage user group [<String>]. |
| 35:1781 | Client |
| 35:1782 | Client Host |
| 35:1783 | Duplicate entry.<Message> [<String>] already exists. Try with different <Message> name. |
| 35:1784 | <Message> creation failed. Please refer to log files for more details. |
| 35:1785 | Hostname |
| 35:1786 | Failed to delete Application Type. Cannot be deleted unless NAS clients are dissociated |
| 35:1787 | Unable to delete job [<Number>] because offline content indexing, data analytics or media refresh jobs are running for the storage policy copy. |
| 35:1788 | Log Monitoring |
| 35:1789 | Deletion of Silo copy is not allowed when the source Dedup copy exists. |
| 35:1790 | Failed to configure client with CommServe. Please refer to log files for more details. |
| 35:1791 | Failed to configure client with CommServe. Please refer to log files for more details. |
| 35:1792 | Failed to get the list of consumed licenses for this client. |
| 35:1793 | Failed to release license. Please refer to CommServe logs for more details. |
| 35:1794 | Array name [<String>] is invalid. Please enter a valid array name. |
| 35:1795 | Could not complete update operation. Filer [<String>] not found. |
| 35:1796 | The UNC path cannot be modified as the Filer [<String>] is currently selected by one or more subClients. |
| 35:1797 | Filer [<String>] is still referenced by one or more subClients and cannot be deleted. |
| 35:1798 | Procedure [<String>]: Invalid operation [<String>] selected. |
| 35:1799 | No rows returned for selected query [<String>]. |
| 35:1800 | Invalid Client [<String>] specified. |
| 35:1801 | Failed to assign role of Index Cache Server to MediaAgent because it is already pointing to the Network Share Profile / Index Cache Server Profile. |
| 35:1802 | Turbo NAS |
| 35:1803 | CommCell Synchronisation |
| 35:1804 | PST Archiving |
| 35:1805 | Disk Library Maintenance |
| 35:1806 | Failed to get Response Files. |
| 35:1807 | Failed to get library host info. |
| 35:1808 | Prefetch operation failed. |
| 35:1809 | Recall Completed Successfully |
| 35:1810 | File is already recalled |
| 35:1811 | Recall ignored as the file has an alternative stream |
| 35:1812 | Recall cancelled because file is staging path |
| 35:1813 | Recall cancelled because the process is excluded at service level |
| 35:1814 | Recall cancelled because volume is going offline |
| 35:1815 | Recall cancelled because service is shutting down |
| 35:1816 | Recall cancelled because file path is invalid |
| 35:1817 | Recall cancelled as not able to get reparse data from file |
| 35:1818 | Recall cancelled as not able to get file attributes |
| 35:1819 | Recall cancelled as not able to get file time |
| 35:1820 | Copying the Stub file from cache is failed |
| 35:1821 | Copying the stub file to cache is failed |
| 35:1822 | Encrypted stub file cannot be recalled |
| 35:1823 | Service reached user defined high water mark for simultaneous recalls |
| 35:1824 | Recall failed because user defined minimum space limit is reached |
| 35:1825 | Volume does not have enough space to recall the file |
| 35:1826 | Recall cancelled as file path is too long |
| 35:1827 | Recall rejected because of invalid magic number |
| 35:1828 | Recall rejected as file path is empty |
| 35:1829 | Recall cancelled as DMNAS key not present in reparse data |
| 35:1830 | Recall cancelled as stub file metadata does not match MD5 |
| 35:1831 | Recall cancelled as file name is not found in metadata |
| 35:1832 | Recall cancelled as administrator disabled the recall |
| 35:1833 | Recalling file is failed |
| 35:1834 | Recall cancelled as tape containing archive is removed |
| 35:1835 | Recall job is killed as requested by DMR Service |
| 35:1836 | Recall job is killed as drive is going offline |
| 35:1837 | Recall cancelled as archive is erased by user |
| 35:1838 | The file trying to recall is not a valid stub |
| 35:1839 | Configuration of cluster group succeeded on the selected client(s) |
| 35:1840 | DeConfiguration of cluster group succeeded on the selected client(s) |
| 35:1841 | Configuration of cluster group failed on the selected client(s) |
| 35:1842 | DeConfiguration of cluster group failed on the selected client(s) |
| 35:1843 | Changing of the mode is not supported for files in the folder you have specified. Please choose another folder. |
| 35:1844 | Changing of the owner is not supported for files in the folder you have specified. Please choose another folder. |
| 35:1845 | Failed to upload the ZIP file to HTTP server |
| 35:1846 | Failed to run Disaster Recovery Backup to get the latest databases |
| 35:1847 | Failed to collect the database dump files |
| 35:1848 | Unable to collect SQL Logs |
| 35:1849 | Send Logs operation completed with errors |
| 35:1850 | IDataAgent Specified not supported |
| 35:1851 | Push Network Configuration submitted successfully for client [<String>]. |
| 35:1852 | Push Network Configuration submitted successfully for Server group [<String>]. |
| 35:1853 | Failed to save Troubleshooting log Network Timeout in CommServe database. |
| 35:1854 | Troubleshooting log Network Timeout has been set to [<Number>] seconds. |
| 35:1855 | Failed to delete monitoring policy. Jobs are still running. |
| 35:1856 | Failed to edit monitoring policy. Jobs are still running. |
| 35:1857 | User names/Passwords have been updated. Consult Audit Trail for details. |
| 35:1858 | No User names or passwords were found that matched the criteria specified. |
| 35:1859 | Invalid Backupset Name is specified. Please provide the correct Backupset name. |
| 35:1860 | Invalid Application type information '<String>' is specified. Please provide the correct Application name. |
| 35:1861 | Invalid Server group name '<String>' is specified. Please provide the correct Server group name. |
| 35:1862 | Invalid Client name '<String>' is specified. Please provide the correct Client name. |
| 35:1863 | Invalid Instance Name '<String>' is specified. Please provide the correct Instance name. |
| 35:1864 | Workflow Management |
| 35:1865 | User Credentials for CommCell were updated successfully by user [<String>]. Consult Audit Trail for details. |
| 35:1866 | Attempt by user [<String>] to update user credentials for CommCell failed due to insufficient security credentials. |
| 35:1867 | Attempt by user [<String>] to update user credentials for CommCell failed. Consult EvMgrs log for details. |
| 35:1868 | Failed to start synthetic full for subclients in archiving mode. See EvMgrs.log for more details. |
| 35:1869 | Schedule Policy |
| 35:1870 | Login Denied. End User is not allowed to log on to the Admin GUI. |
| 35:1871 | Client : [<String>] |
| 35:1872 | Client : [<String>] Agent Type : [<String>] |
| 35:1873 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] |
| 35:1874 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] |
| 35:1875 | Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] SubClient : [<String>] |
| 35:1876 | Storage Policy : [<String>] |
| 35:1877 | Storage Policy : [<String>] Storage Policy Copy : [<String>] |
| 35:1878 | OPERATION FAILED: User does not have permission. |
| 35:1879 | Server group created successfully |
| 35:1880 | Server group updated successfully |
| 35:1881 | Server group deleted successfully |
| 35:1882 | Clients associated successfully with Server group |
| 35:1883 | Clients removed successfully from Server group |
| 35:1884 | OPERATION FAILED: Invalid operation type |
| 35:1885 | Name |
| 35:1886 | Client |
| 35:1887 | Agents Installed |
| 35:1888 | Associated Server group |
| 35:1889 | OS Version |
| 35:1890 | Pinned job |
| 35:1891 | Installed |
| 35:1892 | Licensed |
| 35:1893 | VM (VSA Discovered) |
| 35:1894 | 1 Touch Enabled(UNIX only) |
| 35:1895 | MediaAgent |
| 35:1896 | Creation of OpenVMS Pseudo Client failed. |
| 35:1897 | The specified Path [<String>] is already in use. Please specify another path. |
| 35:1898 | ReInstall Client |
| 35:1899 | Upgrade Client [<String>] failed. |
| 35:1900 | Client [<String>] has been upgraded successfully. |
| 35:1901 | Timezone |
| 35:1902 | Can't delete the group, as it is associated to other Server group(s) |
| 35:1903 | Server group : [<String>] |
| 35:1904 | Excluded |
| 35:1905 | Unable to create dependent copy [<String>] for the Global Secondary Copy on storage policy [<String>] due to streams mismatch. Decreasing the streams on storage policy to match on Global Secondary copy would solve this issue. |
| 35:1906 | Data Verification |
| 35:1907 | Send Log Files |
| 35:1908 | Reference Copy Workflow |
| 35:1909 | Reference Copy |
| 35:1910 | Unable to execute SrvDb2Agent to populate CV tables for DB2 |
| 35:1911 | User [<String>] has logged on. Machine: [<String>]. Locale: [<String>]. |
| 35:1912 | User [<String>] has logged off. Machine: [<String>]. |
| 35:1913 | Message was not delivered to [<String>] because one or more recipients are offline or unable to chat. |
| 35:1914 | Unable to delete Global Secondary Copy Policy because there are dependent copies using this Global policy. |
| 35:1915 | Unable to verify write permissions on intermediate index cache directory. Please verify that the path specified is correct. |
| 35:1916 | Failed to contact the MediaAgent [<String>]. This may be due to services being down or due to an improper installation. |
| 35:1917 | The path [<String>] specified is invalid. |
| 35:1918 | Cannot delete default Backupset |
| 35:1919 | Job Results location cannot be changed now as Library Server is configured on this MediaAgent and services are still running. Please stop the MediaAgent service before changing the job results directory. |
| 35:1920 | All entities |
| 35:1921 | Server group : [<String>] Client : [<String>] |
| 35:1922 | Database dump files will not be collected because user does not have CommCell management capability. |
| 35:1923 | Logs from client [<String>] will not be collected because user does not have management capability on this client. |
| 35:1924 | Send Log Files job has been suspended. |
| 35:1925 | Send Log Files job has been killed. |
| 35:1926 | Client Version |
| 35:1927 | Virtual (Cluster Node) |
| 35:1928 | Unable to delete job [<Number>] because snap to tape jobs are running for the storage policy copy. |
| 35:1929 | Data Verification |
| 35:1930 | Catalog Snapshots Workflow |
| 35:1931 | Catalog Snapshots |
| 35:1932 | Server group creator[<String>] does not have Agent Management rights on one or more of the added clients. |
| 35:1933 | Cannot add new clients since the creator of Server group[<String>] has been deleted |
| 35:1934 | Discover Operation failed. Please check if services are running on the client. |
| 35:1935 | User [<String>] can not manage user [<String>]. |
| 35:1936 | User [<String>] does not have required capability [<String>] at any level. |
| 35:1937 | User [<String>] is not member of user group [<String>]. |
| 35:1938 | Users [<String>] and [<String>] are not member of same user group. |
| 35:1939 | Failed snap volumes will be handled later by the automatic clean up process. |
| 35:1940 | Catalog profile cannot be removed because it is used by the following MediaAgents: [<String>]. |
| 35:1941 | Failed to allocate license for FS iDaAgent on this client. Check Evmgrs.log for detailed information. |
| 35:1942 | Failed to create FS Agent on Client. Check Evmgrs.log for detailed information. |
| 35:1943 | Virtual Machine Plugin registered successfully. |
| 35:1944 | Failed to register Virtual Machine Plugin. URL used for registration is [<String>]. |
| 35:1945 | Manage Virtual Machine |
| 35:1946 | Virtual Machine management plugin. Registered to Web Console [<String>]. |
| 35:1947 | Catalog Profile [<String>] is created successfully on MediaAgent [<String>]. |
| 35:1948 | Catalog Profile [<String>] is deleted successfully. |
| 35:1949 | Catalog Profile [<String>] is assigned to MediaAgent [<String>]. |
| 35:1950 | Catalog Profile [<String>] is removed. |
| 35:1951 | MediaAgent [<String>] is removed from Catalog Profile. |
| 35:1952 | File already exists. Overwrite is not allowed. |
| 35:1953 | This MediaAgent [<String>] is required to act as a physical node for the cluster group. Do you still want to continue? |
| 35:1954 | Invalid user name or password. |
| 35:1955 | User [<String>] does not have required capabilities [<String>] and [<String>] on <Message>[<String>] for this operation. |
| 35:1956 | This is a DDB backup job[<Number>]. Deleting this job would result in inability to reconstruct the DDB. This job would not be deleted. |
| 35:1957 | OS Type |
| 35:1958 | Windows |
| 35:1959 | Unix |
| 35:1960 | No Users/User Groups is specified. |
| 35:1961 | User [<String>] is not member of the domain [<String>]. |
| 35:1962 | Current document count on Content Indexing engine [<String>] is [<Number>]. Maximum number of documents supported is [<Number>]. Please plan for additional capacity. |
| 35:1963 | Failed to update Web Server Name [<String>] in WebClient [<String>]. Possible reasons are 'Lack of network communication between CommServe and WebClient' or 'Commvault Services may not be running on the WebClient'. Please update registry and configuration file manually for the WebClient [<String>] to work properly. |
| 35:1964 | Reference Copy PST Archiving |
| 35:1965 | Failed to update configuration file [<String>] on client [<String>] due to communication failure or services may be not running on the client. |
| 35:1966 | Failed to update JVM memory in the registry for client [<String>] due to communication failure or services may be not running on the client. |
| 35:1967 | Archive |
| 35:1968 | This client is being used as proxy client for [<String>]. Please disassociate or deconfigure these clients before this operation |
| 35:1969 | Failed to delete Client. It is a part of Cloud [<String>]. |
| 35:1970 | Failed to delete MediaAgent. It is a part of search engine cloud [<String>]. |
| 35:1971 | Failed to delete Cloud. Please dissociate Cloud from each Storage Policies that are using it. |
| 35:1972 | Failed to modify Content Indexing for the job because Offline Content Indexing Job is running for the SP. |
| 35:1973 | Could not transfer Server group ownership. |
| 35:1974 | Association for specific Windows File System agent is not allowed. |
| 35:1975 | Database view cannot be displayed. Please check if database is accessible. |
| 35:1976 | Change CA certificate rotation period from [<Number>] to [<Number>] |
| 35:1977 | Failed to change CA certificate rotation period |
| 35:1978 | Change Client certificate rotation period from [<Number>] to [<Number>] |
| 35:1979 | Failed to change Client certificate rotation period |
| 35:1980 | Successfully renewed certificate [<Number>] |
| 35:1981 | Could not renew certificate [<Number>]. Check the logs for more details. |
| 35:1982 | Revoked Client certificate number [<Number>] |
| 35:1983 | Failed to revoke client certificate number [<Number>] |
| 35:1984 | In order to generate a temporary certificate for client [<String>] you must first revoke all of its outstanding certificates |
| 35:1985 | Successfully created temporary certificate for client [<String>] |
| 35:1986 | Could not create temporary certificate for client [<String>]. Check the logs for more details. |
| 35:1987 | Storage Policy [<String>] not found. |
| 35:1988 | Updated name server for DAG PseudoClient [<String>]. |
| 35:1989 | Failed to update DAG PseudoClient name server. |
| 35:1990 | Updated user name for DAG PseudoClient [<String>]. |
| 35:1991 | Failed to update DAG PseudoClient User Name. |
| 35:1992 | Updated user password for DAG PseudoClient [<String>]. |
| 35:1993 | Failed to update DAG PseudoClient User password. |
| 35:1994 | ARRAY |
| 35:1995 | Un-Age job operation failed. Please check Evmgrs.log for detailed information. |
| 35:1996 | Laptop Client |
| 35:1997 | Couldn't look up client [<String>]. |
| 35:1998 | Certificate revocation for client [<Number>] has failed. |
| 35:1999 | Failed to get snap information for volume [<Number>]. |
| 35:2000 | Failed to get associated application details. Check the logs for more details. |
| 35:2001 | Volume [<Number>, <String>] is mounted on another host [<Number>, <String>] and/or not in unmounted state. |
| 35:2002 | Volume [<Number>, <String>] is mounted and not in unmounted state. |
| 35:2003 | Selected Volume [<String>] Job [<Number>] is an external snap volume. Delete is not permitted. |
| 35:2004 | Request Handling Error. If accessing AD Server via Proxy, Push Network Configuration to the proxy and then try again. Consult EvmgrS log file for details. |
| 35:2005 | The credentials you have entered could not be verified. The possible reasons could be:n1. The credentials you have entered are incorrect.n2. The provider could not be contacted for verification.n3. If accessing AD Server via Proxy, Push Network Configuration to the proxy and then try again. |
| 35:2006 | Failed to get logs for [<String>]. Job will be retried automatically when the client comes online. |
| 35:2007 | Move Partition |
| 35:2008 | Backup running for subclient. Only content change is updated. |
| 35:2009 | Virtualize Me needs Operations Manager Package to be installed on CommServe in order to run. |
| 35:2010 | Failed to delete client. This client is an active library server. |
| 35:2011 | Failed to delete client. This CommServe has client(s) that are active library server. |
| 35:2012 | Package Installed |
| 35:2013 | Cannot modify backup copy or Catalog Snapshots options while snap backup or backup copy or Catalog Snapshots jobs are running |
| 35:2014 | Failed to check if there are any running jobs for snap or Catalog Snapshots. Please check EvMgrs.log for more details |
| 35:2015 | Invalid or unsupported data path selected for copy. Please check EvMgrs.log for more details. |
| 35:2016 | Storage policy association is not allowed because there are pending snap jobs for subclient [<String>] which need to be cataloged. Either run Catalog Snapshots workflow job on storage policy [<String>] or unpick corresponding jobs to continue. |
| 35:2017 | There are pending snap jobs for subclient [<String>] which need to be backup copied. Run backup copy workflow job on storage policy [<String>]. |
| 35:2018 | You need to first dissociate the nodes of the client. Go to client properties Advanced section. Visit the Cluster Configuration tab to complete those steps. |
| 35:2019 | Failed to create Subclient. DDB used by the storage policy has reached the threshold for QI Time. Please use a different Storage Policy. |
| 35:2020 | Alert name [<String>] is already in use. |
| 35:2021 | This storage policy is associated to DDB Backup subclient. Enabling Silo may cause reconstruction performance issues. |
| 35:2022 | No valid user exist in the give list |
| 35:2023 | Invalid user name [<String>] specified |
| 35:2024 | Domain user [<String>] has not yet logged in |
| 35:2025 | MediaAgent [<String>] is removed from Catalog Profile [<String>]. |
| 35:2026 | Application Command Line Backup |
| 35:2027 | Application Command Line Snap Backup |
| 35:2028 | Application Command Line Restore |
| 35:2029 | LOCATION |
| 35:2030 | Unable to change copy properties because auxiliary copy, data verification, offline content indexing, data analytics or media refresh jobs are running for the storage policy copy. |
| 35:2031 | Allow built-in certificates is enabled. |
| 35:2032 | Allow built-in certificates is disabled. |
| 35:2033 | Failed to change property for CommServe built-in certificates |
| 35:2034 | You do not have sufficient privileges for this operation |
| 35:2035 | Failed to move Index cache. Jobs are still running. Try again after suspending jobs. |
| 35:2036 | Would you like to copy all the Index Cache data from the old directory [<String>] to the new directory [<String>] now? If you select No, then the next time you Browse Backup Data, there will be a slight delay while the required Index Cache data is restored from the backup media to the new location and also suspended jobs will start from the beginning. |
| 35:2037 | Reconstruction job is in progress for this copy. Unable to seal store now. Please try after reconstruction completes or kill reconstruction job. |
| 35:2038 | Email address of the logged in user is not set. |
| 35:2039 | Could not find logged in user information. Please check evmgrs.log for more details. |
| 35:2040 | Sender email address is empty. Please enter valid email address. |
| 35:2041 | Port number for SMTP mail server is not provided, please provide SMTP port number |
| 35:2042 | CommCell hostname [<String>] is changed to [<String>] in CommCell [<String>] due to name resolution problem. |
| 35:2043 | Remote CommCell hostname [<String>] is not resolvable from Local host [<String>].nDo you want to change hostname to [<String>]? |
| 35:2044 | Failed to save Report Server Url in CommServe database.n |
| 35:2045 | The file already exists. Do you want to replace it? |
| 35:2046 | Unable to disable job [<Number>] because auxiliary copy, data verification, offline content indexing, data analytics or media refresh jobs are running for the storage policy copy. |
| 35:2047 | OPERATION FAILED: User does not have [Administrative Management] permissions. |
| 35:2048 | For a spooled snap copy, either Backup Copy has to be enabled to move all jobs or all subclients pointing to this Storage Policy must be selected to at least one of the synchronous vault copies. |
| 35:2049 | Spool Copy option cannot be enabled for secondary snap copy. |
| 35:2050 | Cannot resubmit job that was run by user with different credentials |
| 35:2051 | Administrator has disabled the option to run tools on CommCell Console. |
| 35:2052 | Administrator has disabled the option to run tools on CommServe. |
| 35:2053 | Administrator has disabled the option to run tools on Client. |
| 35:2054 | The tool is disabled. |
| 35:2055 | The username and/or password may be invalid. |
| 35:2056 | Invalid Backupset name '<String>' is specified. Please provide the correct Backupset name. |
| 35:2057 | Invalid SubClient name '<String>' is specified. Please provide the correct Subclient name. |
| 35:2058 | Cannot delete the Legal hold On Demand Backup Set. |
| 35:2059 | Managed Service Provider CommCell has been enabled. |
| 35:2060 | Managed Service Provider CommCell has been disabled. |
| 35:2061 | Failed to push Network Configuration for client [<String>], will try again. |
| 35:2062 | Could not set Enable for Archiving property for client [<String>]. |
| 35:2063 | Could not clear Enable for Archiving property for client [<String>]. |
| 35:2064 | Could not consume File Archiver license for client [<String>]. |
| 35:2065 | Could not release File Archiver license for client [<String>]. |
| 35:2066 | Create Replica |
| 35:2067 | Cannot perform name change on client because there are jobs running using this client as MediaAgent. |
| 35:2068 | Cannot perform name change on MediaAgent because there are jobs running for this client. |
| 35:2069 | Client Reconfigured. Please complete NAS configuration(NAS Properties -> NDMP Properties) for backups to run. |
| 35:2070 | Index Cache Server profile cannot be configured on selected MediaAgent as the index cache folder is shared. |
| 35:2071 | Sync Restore |
| 35:2072 | FTP Upload failed. Please check [schedulereport.log] for more details. |
| 35:2073 | Select a source copy that has a NAS attached Library as its data path. |
| 35:2074 | Failed to connect to the array[<String>]. |
| 35:2075 | Client:[<String>] already exists. Provide another name or to create a new instance on a V9 client go to [Client->Virtual Server->Create New Instance]. |
| 35:2076 | Total document count on Content Indexing engine [<String>] is <Number>. Maximum number of documents supported is [<Number>]. Please plan for additional capacity. |
| 35:2077 | The grace period of Virtual Machine [<String>] will expire in [<Number>] days. |
| 35:2078 | The grace period of the Virtual Machine mentioned below ends in [<Number>] days. If not renewed within the grace period, this VM will be permanently deleted. nn Virtual machine Name: <String>n Virtual machine hostname: <String> n Please note that this VM had actually expired on: <String>, and is currently in grace period. nn URL to renew: <String> |
| 35:2079 | t1. Name change failed. nt Error: [<String>] |
| 35:2080 | t1. Name change completed successfully.nt2. Configuring client failed.nt Error: [<String>]nt3. Operations on Source CommServe completed successfully. |
| 35:2081 | t1. Name change completed successfully.nt2. Configuring client completed successfully.nt3. Operations on Source CommServe failed.nt Error: [<String>] |
| 35:2082 | t1. Name change completed successfully.nt2. Configuring client failed.nt Error: [<String>]nt3. Operations on Source CommServe failed.nt Error: [<String>] |
| 35:2083 | Client [<String>] already pointing to this CommServe. |
| 35:2084 | Failed to update CommServe hostname on client. |
| 35:2085 | Failed to attach libraries to MediaAgent. |
| 35:2086 | Failed to consume DDO license for MediaAgent. |
| 35:2087 | Name change failed on remote commcells [<String>] with the error n [<String>].n Do you want to continue? |
| 35:2088 | We were unable to set the password for your machine. Please use the password [cvX1__<String>] for root user. (please note the two underscores before your vmname). If that does not work contact your Admin. |
| 35:2089 | Two-Factor Authentication is enabled on this CommServe. Please check your email for details to log on. |
| 35:2090 | Two-Factor Authentication is enabled on this CommServe. No email address was configured for your login to send the details. Please contact your administrator. |
| 35:2091 | CommServe Administrator just doubled your safety! |
| 35:2092 | Dear user, nnThe server you are trying to log on to has Two-Factor Authentication enabled. As a security step, this feature requires a 6-digit PIN to be provided along with your password during log on. You can use the One Time PIN provided in this email to log on to the server. However, to generate new PINs, you must download the Commvault PIN Generator and use the Secret Key provided in this email (or sent to you earlier). nnHOW TO USE THE PIN nSimply specify the 6-digit PIN after your regular password in the password field. nExample: RegularPassword123456 |
| 35:2093 | SECRET nDO NOT share the Secret Key provided in this email with anyone else. Also, make sure to save this email in your records. The Secret Key must be provided in the Commvault PIN Generator app to generate a new PIN for each login. Note that each generated PIN is valid for only 30 seconds. nnCOMMVAULT PIN GENERATOR nFind the details to download and use the App here: |
| 35:2094 | Login |
| 35:2095 | Secret Key (case-insensitive) |
| 35:2096 | One Time Pin (valid for next 30 minutes only) |
| 35:2097 | Thank you, nCommServe Administrator nnIf you did not attempt this login and received this email in error, please contact your administrator immediately. |
| 35:2098 | Failed to save EnableTwoFactorAuthentication setting in CommServe database.n |
| 35:2099 | Failed to Enable Archiving. No license available for File System Archiving. |
| 35:2100 | Failed to Disable Archiving. Could not release File System Archiving license. |
| 35:2101 | The smart Server group [<String>] creator has been deleted, removing all associated client |
| 35:2102 | Cannot add new clients since the creator of Server group[<String>] has been deleted and all associated clients has been removed. |
| 35:2103 | Failed to release cached resources. |
| 35:2104 | Monitoring Policy |
| 35:2105 | Schedule/Continuous Mode is not saved for [<String>] policy with the error:[<String>]. |
| 35:2106 | User [<String>] does not have required capability [<String>] or ([<String>] and [<String>]) for [<String>] <Message> and this operation |
| 35:2107 | User [<String>] does not have required capability [<String>] and [<String>] for this [<String>] <Message> and this operation |
| 35:2108 | Unable to mark job [<Number>] for recopy because auxiliary copy or media refresh jobs are running for the storage policy copy. |
| 35:2109 | Error while retrieving access path information for MediaAgent [<String>] and access path [<String>] |
| 35:2110 | Error while retrieving access path information for MediaAgent [<String>] and access path [<String>] |
| 35:2111 | Client offline (days) |
| 35:2112 | Please provide PostGres User Name. |
| 35:2113 | Please provide a Binary Directory. |
| 35:2114 | Please provide a Library Directory. |
| 35:2115 | Please provide an Archive Log Directory. |
| 35:2116 | Please provide a Log Backup Storage Policy. |
| 35:2117 | Please provide a Maintenance DataBase. |
| 35:2118 | Please provide a Port Number. |
| 35:2119 | Failed to check if Postgres Port in use. |
| 35:2120 | Provided Port Number [<String>] is already in use. Please provide another port. |
| 35:2121 | No user is associated with this email address. |
| 35:2122 | Multiple users are associated with this email address. Please use the username to log on. |
| 35:2123 | Failed to Enable Archiving. No Archive Enterprise license is available. |
| 35:2124 | Data Analytics Jobs are running on MediaAgent, so the Analytics option cannot be updated. |
| 35:2125 | Failed to start Data Analytics service on the MediaAgent. |
| 35:2126 | Failed to stop Data Analytics service on the MediaAgent. |
| 35:2127 | Please provide DB2 User Account. |
| 35:2128 | Please provide DB2 User Name. |
| 35:2129 | Please provide DB2 User Password. |
| 35:2130 | Please provide DB2 Home directory. |
| 35:2131 | Please provide DB2 Storage device information. |
| 35:2132 | Please provide DB2 Data Backup Storage Policy. |
| 35:2133 | Please provide DB2 Log Backup Storage Policy. |
| 35:2134 | Please provide DB2 Command Line Backup Storage Policy. |
| 35:2135 | Unable to establish connectivity with these instance properties for [<String>]. Please provide correct properties. |
| 35:2136 | Creation of iSeries Pseudo Client failed. |
| 35:2137 | Creation of Pseudo Client failed. |
| 35:2138 | Data Analytics |
| 35:2139 | Fail to populate DB for monitoring policy [<String>] and version [<Number>]. |
| 35:2140 | Failed to start Data Analytics service on the MediaAgent, Please install java and try again |
| 35:2141 | No clients found with the old host name provided.[<String>] |
| 35:2142 | Failed to perform Name change operation. Refer to EvMgrs.log for more details. |
| 35:2143 | Name change operation failed as jobs are running on the client. |
| 35:2144 | Domain/CommServe Name Change not allowed with this option. Use CS_HOST_NAME_CHANGE_ON_CS_REMOTECLIENTS to change CommServe host name. |
| 35:2145 | Login Retry Count Exceeded. Account is now disabled. |
| 35:2146 | Connection failed. Failed to update client registry. |
| 35:2147 | Validation succeeded for the input. |
| 35:2148 | Validation failed for the given input. |
| 35:2149 | Upload |
| 35:2150 | Download |
| 35:2151 | Live Browse |
| 35:2152 | In Place Full Machine Recovery |
| 35:2153 | Sharing |
| 35:2154 | Workflow Deployment |
| 35:2155 | User does not have Upload Capability |
| 35:2156 | User does not have Download Capability |
| 35:2157 | User does not have Live Browse Capability |
| 35:2158 | User does not have Full Machine Recovery Capability |
| 35:2159 | User does not have Sharing Capability |
| 35:2160 | User does not have Workflow Deployment Capability |
| 35:2161 | Block Level Snap |
| 35:2162 | DASH Copy |
| 35:2163 | Job will not be started. Auxcopy job does not need to Run. |
| 35:2164 | Job will not be started. Content Indexing job does not need to Run. |
| 35:2165 | Job will not be started. Snap Backup Copy job does not need to Run. |
| 35:2166 | Failed to delete the client. Delete the association of client [<String>] with Oracle RAC instance(s) [<String>] and retry. |
| 35:2167 | Failed to get Log Monitoring Analytics node. |
| 35:2168 | Failed to create Log Monitoring Analytics cloud. |
| 35:2169 | Analytics option is enabled on this MediaAgent. Please disable analytics option before deleting the MediaAgent. |
| 35:2170 | User cannot modify shared folder |
| 35:2171 | User cannot view shared folder |
| 35:2172 | Cannot complete the request please check with your administrator. |
| 35:2173 | Cloud Print is configured successfully. |
| 35:2174 | No username/password is provided. |
| 35:2175 | Failed to get the instance name. |
| 35:2176 | File [QinetixVM] not exists. |
| 35:2177 | Failed to initialize logger. |
| 35:2178 | IIS is not installed on the Web Server. |
| 35:2179 | Failed to get port number. |
| 35:2180 | Failed to get software Install path. |
| 35:2181 | Failed to get IIS version from registry. |
| 35:2182 | Invalid Path. |
| 35:2183 | User do not have administrative privileges. |
| 35:2184 | User is not logged in once on Web Server. Please log in once to the Web Server with this user. |
| 35:2185 | No default printer exists for this User. |
| 35:2186 | Application pool [PrintAppPool] already exists. |
| 35:2187 | Application [CvPrintSvc] already exist. |
| 35:2188 | Service is not accessible. |
| 35:2189 | Failed to reset IIS. |
| 35:2190 | Registry not exists in the system. |
| 35:2191 | Failed to get the host name. |
| 35:2192 | Host name does not exist. |
| 35:2193 | No physical path exists for virtual directory. |
| 35:2194 | Failed to update the [Web.Config] file. File not exists. |
| 35:2195 | Failed to change the [Web.config] file. |
| 35:2196 | Invalid username/password. Please use valid credentials to log in. |
| 35:2197 | Failed to read from the registry. |
| 35:2198 | Web Server is not installed on this machine. |
| 35:2199 | Cloud Print deconfigure failed. |
| 35:2200 | Cloud Print reconfigure failed. |
| 35:2201 | No Application exists to delete. |
| 35:2202 | No operation type is specified. |
| 35:2203 | No AppPool exists to delete. |
| 35:2204 | Failed to load user profile. |
| 35:2205 | Failed to unload user profile. |
| 35:2206 | Unknown error. |
| 35:2207 | Operation Manager Server is not reachable. Check [<String>] for more details. |
| 35:2208 | Failed to connect Operations Manager Server. Please check your username/password or Operations Manager hostname. |
| 35:2209 | Failed to import the required management packs to Operations Manager Server. Check [<String>] for more details. |
| 35:2210 | Multiple management pack with name [<String>] found. Delete all the management pack and retry. |
| 35:2211 | Operations Manager credentials test failed. Check [<String>] for more details. |
| 35:2212 | Connection to Operations Manager was successful. |
| 35:2213 | Imported management Pack [<String>] successfully. |
| 35:2214 | Failed to check if management pack was already imported. |
| 35:2215 | Already imported the management pack to Operation Manager. Do you really want to overwrite it? |
| 35:2216 | Successfully uninstalled the management pack. |
| 35:2217 | Management pack uninstallation failed. Check [<String>] for more details. |
| 35:2218 | Configured with management pack [<String>] version [<String>] on [<String>] |
| 35:2219 | Configured with management pack [<String>] version [<String>] on [<String>] ( the latest version: <String>) |
| 35:2220 | Not Configured |
| 35:2221 | Multiple management pack with name [<String>] found. |
| 35:2222 | Failed to save Operations Manager configuration. Check [<String>] for more details. |
| 35:2223 | HTTP request failed while generating web report. |
| 35:2224 | Unknown MediaAgent name. |
| 35:2225 | Unknown library name. |
| 35:2226 | Unknown mount path. |
| 35:2227 | Another instance of Library Configuration is being used. |
| 35:2228 | Failed to get library controller list for library. |
| 35:2229 | Failed to get mount path list for library. |
| 35:2230 | Cannot add shared mount path for library with an unshared mount path. Please use Expert Storage Configuration Wizard to add mount path for this library. |
| 35:2231 | Mount Path or Serial Number or Device Name are not given for creating library. |
| 35:2232 | Validation failed. Provide correct password to change password or enable/disable data security. |
| 35:2233 | Validation failed. Client is locked, password set to lock client data does not match with the current password. |
| 35:2234 | Client is locked. Authentication information to validate is missing in the input. |
| 35:2235 | Missing parameter. To enable data security, Provide data security password to be set. |
| 35:2236 | Download Center Management |
| 35:2237 | User does not have Manage Download Center Capability |
| 35:2238 | Commvault install directory is not specified. |
| 35:2239 | Failed to load the file[web.config]. |
| 35:2240 | Specified operation is not supported. |
| 35:2241 | Cloud Print configuration utility is already running on the webserver. |
| 35:2242 | Client name does not exist. |
| 35:2243 | Failed to get the client name. |
| 35:2244 | User [<String>] can't add the clients to Server group, user does not have [<String>] capability on [<String>] user group(s) |
| 35:2245 | The smart Server group [<String>] creator don't have User Management capability on [<String>] user groups, removing all associated clients |
| 35:2246 | User [<String>] does not have required capability [<String>] on <Message>[<String>] for this operation. |
| 35:2247 | Operation failed. Query with same name already exists. |
| 35:2248 | Operation failed. Please provide Query name |
| 35:2249 | Failed to modify Query. Please check EvMGrs.log for more details. |
| 35:2250 | Operation failed. Invalid client information specified for script |
| 35:2251 | Operation failed. Please provide either sql query text or path to input file |
| 35:2252 | No output columns retrieved |
| 35:2253 | Error in retrieving columns for query. Please check EvMGrs.log for more details. |
| 35:2254 | Operation failed. Multiple output columns of type [<String>] not supported |
| 35:2255 | Operation failed. Output column of type [<String>] missing from output columns list. |
| 35:2256 | Operation failed. Multiple input/output columns of same name [<String>] not supported |
| 35:2257 | Operation failed. Multiple output columns of same display name [<String>] not supported |
| 35:2258 | User as client owner |
| 35:2259 | Local user group as client owner |
| 35:2260 | External group as client owner |
| 35:2261 | Client has same feature release as CommServe |
| 35:2262 | Associate atleast an owner to lock the client. |
| 35:2263 | Access Denied. Client is Locked. |
| 35:2264 | You need to be an owner to lock/unlock the client. |
| 35:2265 | Insufficient Parameters to validate Virtual Server credentials. |
| 35:2266 | Failed to validate Virtual Server credentials. Please check input parameters and try again. |
| 35:2267 | User [<String>] does not have required capability [<String>] at required level to manage external group [<String>]. |
| 35:2268 | User authorization error. |
| 35:2269 | Invalid password. Please verify the password provided. |
| 35:2270 | User group [<String>] not found or does not exists |
| 35:2271 | Share Folder name already exists. |
| 35:2272 | Share Folder does not exist. |
| 35:2273 | User does not have rights to edit share folder |
| 35:2274 | Folder [<String>] has been shared by <String>. |
| 35:2275 | A folder [<String>] has been shared by <String>. |
| 35:2276 | Use the link below to view the share. |
| 35:2277 | Associated library name |
| 35:2278 | Virtual machine Hostname Intended: <String> n Hostname we have got: <String> n Virtual machine IP Address: <String> (Please perform synchronize operation after 15 mins or Use the IP to log on to the machine and change the Hostname manually) n <String> |
| 35:2279 | Your password is not ready --> Password generation can sometimes take more than 30 minutes, and we could not retrieve it in the initial 15 minutes. Please contact your administrator/retry the operation using synchronize operation after 15 mins. |
| 35:2280 | Virutal machine Password: <String> |
| 35:2281 | For more info on accessing using the attached pem, please visit : http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/ec2-connect-to-instance-linux.html#using-putty |
| 35:2282 | Successfully retrieved virtual machine password for vm: <String> |
| 35:2283 | Archive Restore |
| 35:2284 | Click <String> here <String> to view share |
| 35:2285 | Click <String> here <String> to register and view share |
| 35:2286 | Thank you. |
| 35:2287 | In case of any problems please contact the <String>Administrator |
| 35:2288 | Operation failed. Prevent admin access to user data cannot be unset. |
| 35:2289 | Prevent admin access to user data enabled. |
| 35:2290 | Operation failed.Administrator needs to enable privacy settings to enable/disable client lock. |
| 35:2291 | Invalid query name [<String>] provided. Please provide valid query name. |
| 35:2292 | Operation failed. Modification of Schedule information for custom query via Saved script execution is not supported. Please use CommCell Console to modify schedule information. |
| 35:2293 | Edge Drive |
| 35:2294 | Failed to discover Index Servers |
| 35:2295 | Cannot delete custom query for external entities |
| 35:2296 | User does not have capability on any On Demand Log Monitoring policy. |
| 35:2297 | Assocaited clients are offline. |
| 35:2298 | User[<String>] cannot manage owner[<String>] of locked clients. |
| 35:2299 | Lock client failed.Please check if all owners of the client are enabled and have an email id registered. |
| 35:2300 | Locking is restricted to user as client owner. Please remove the user group(s) from client owners. |
| 35:2301 | Cannot modify user group client owners on a locked client. |
| 35:2302 | Prevent admin access to user data disabled. |
| 35:2303 | Available w/ One or more Missing Snaps. |
| 35:2304 | The grace period of the Virtual Machine mentioned below ended and we are unable to delete it. Please verify the reasons for failure in deleting the VM[<String>] |
| 35:2305 | <String>Virtual machine Hostname: <String>n Virtual machine IP Address: <String>n Operating System: <String>n Memory(GB): <Number>n Number of CPUs: <Number>n Number of NICs: <Number>n Total Disk Size(GB): <Number>n <String> |
| 35:2306 | <String>Virtual machine Hostname: <String>n Virtual machine IP Address: <String>n Operating System: <String>n Instance Type: <String>n Total Disk Size(GB): <Number>n <String> |
| 35:2307 | File [<String>] has been shared by <String>. |
| 35:2308 | A file [<String>] has been shared by <String>. |
| 35:2309 | Replication |
| 35:2310 | Job will not be started. Replication job does not need to Run. |
| 35:2311 | Failed to add analytics roles. |
| 35:2312 | The reservation period of the virtual machine mentioned below ends in [<Number>] hours. Please renew it if you plan to use the virtual machine for some more time. n VM will be deleted immediately after expiration. nn Virtual machine Name: <String>n Virtual machine hostname: <String> n Reserved Until: <String> n URL: <String> |
| 35:2313 | Live Mount virtual machine [<String>]: Failed |
| 35:2314 | Live Mount virtual machine [<String>]: Succeeded |
| 35:2315 | Virtual Machine Live Mount failed. n Error: [<String>] |
| 35:2316 | <String>Live Mounted Virtual Machine Name: <String> n Virtual machine hostname: <String> n Virtual machine IP Address: <String> n vCenter Name: <String> n ESX Host: <String> |
| 35:2317 | Client is not visible to this user. |
| 35:2318 | This Availability Group is already configured. |
| 35:2319 | Error in processing message. Please check evmgrs.log for more details. |
| 35:2320 | Unable to resubmit job as job options have aged. |
| 35:2321 | Resubmit operation is not supported for jobs initiated from command line. |
| 35:2322 | Unable to resubmit job as job is older than [<Number>] days. |
| 35:2323 | Resubmit operation is not supported for Application Commandline jobs or jobs submitted from client. |
| 35:2324 | Out of Place Full Machine Recovery |
| 35:2325 | The specified index directory is not empty. Please provide empty directory and try again. |
| 35:2326 | Unknown device name. |
| 35:2327 | Received wrong mountPath usage option. |
| 35:2328 | MountPath or Device name not set. |
| 35:2329 | Failed to rename the device [<String>]. |
| 35:2330 | Library name and mediaAgent name and mountpath are empty. |
| 35:2331 | MediaAgent name and mountpath and device name are empty. |
| 35:2332 | invalid device type or device access type. |
| 35:2333 | Given MA has alreay access to this Device, please pass different MA. |
| 35:2334 | Failed to configure the device. |
| 35:2335 | No MediaAgent or Device Name is specified. |
| 35:2336 | Disk library has more than one master pool. |
| 35:2337 | Invalid property input for library. |
| 35:2338 | End users are not allowed to run any pre-post commands during restore. |
| 35:2339 | Edge Drive has been paused. |
| 35:2340 | Edge Drive has been unlinked. |
| 35:2341 | Unable to add new subclient content. New subclient path:[<String>] overlaps with subclient:[<String>] content:[<String>]. |
| 35:2342 | Unable to add new subclient content. New subclient path:[<String>] already exists in subclient:[<String>]. |
| 35:2343 | Shared by <String> |
| 35:2344 | Message |
| 35:2345 | Failed to get key from SafeNet server. |
| 35:2346 | The specified file or folder is already shared. |
| 35:2347 | Dear User,nnThis is an automated email from your administrator requesting that you enable your device for backup.nnUse the following steps to install the backup software package on your device:nn1. Download the installation package at <String>nn2. Install the package on your device.nDuring installation use the following backup CommServe name: <String>nnSincerely,nYour Administrator |
| 35:2348 | Dear User,nnThis is an automated email from your Commvault administrator requesting that you enable your device for backup.nnBelow are your login credentials:nnUser Name: <String>nnPassword: <String>nnUse the following steps to install the backup software package on your device:nn1. Download the installation package at <String>nn2. Install the package on your device.nDuring installation use the following backup CommServe name: <String>nnSincerely,nYour Administrator |
| 35:2349 | Dear User,nnUse following steps to install the proxy software package on your client:nn1. Download the installation package at <String>nn2. Install the package on your client.nDuring installation use the following setup information:nnclient name: <String>nhost name: <String>nCommServe name: <String>nnSincerely,nYour Administrator |
| 35:2350 | Use the following steps to install the gateway package on your client:nn1. Download the installation package at <String>nn2. Verify that tunnel port 443 is open. nn3. Install the package on your device.nDuring installation use the following setup information:nnclient name: <String>nhost name: <String>nCommServe name: <String> |
| 35:2351 | Prevent restore overwrite is enabled. Cannot restore to same folder on source. Please provide a different destination folder. |
| 35:2352 | <html>Failed to change CommServe name on one or more remote clients.<br>Use option: [Control Panel -> Name Mangement -><br> Update CommServe for Clients(use this option after DR restore)]<br> to update failed clients when they are reachable to CS.</html> |
| 35:2353 | Unable to complete request. Check that Communications Service is up and running on [<String>]. |
| 35:2354 | Deletion of a WORM copy is not allowed until all jobs on the copy are aged. |
| 35:2355 | Deletion of a source copy for Content Indexing is not allowed. |
| 35:2356 | Copy promotion to Primary is not allowed for migrated Storage policy. |
| 35:2357 | Invalid role name specified |
| 35:2358 | Invalid role operation type specified |
| 35:2359 | Failed to add remote CommCell client(s). Check Evmgrs.log for detailed information. |
| 35:2360 | Check streams information for more details |
| 35:2361 | Failed to get remote CommCell client(s). Check Evmgrs.log for detailed information. |
| 35:2362 | Can not delete system created DDB Schedule Policy |
| 35:2363 | Install Directory look up failed for given MediaAgent. |
| 35:2364 | Disk library mountpath cannot be configured in the installation directory |
| 35:2365 | Installation Directory look up failed for given MediaAgent |
| 35:2366 | Deduplication store cannot be configured in the installation directory |
| 35:2367 | This is the only device controller of the mount path. It cannot be deleted. |
| 35:2368 | Unable to create array replica copy [<String>] for storage policy [<String>]; array replica copy is already present. |
| 35:2369 | Unable to create array replica copy [<String>] for storage policy [<String>]; please create a primary snapshot copy first. |
| 35:2370 | Catalog Migration |
| 35:2371 | user |
| 35:2372 | user group |
| 35:2373 | external user group |
| 35:2374 | schedule policy |
| 35:2375 | tracking policy |
| 35:2376 | workflow |
| 35:2377 | domain |
| 35:2378 | Failed to pick snapshot job for Catalog. |
| 35:2379 | Failed to unpick snapshot job for Catalog. |
| 35:2380 | Deletion of a source copy for Snapshot Catalog is not allowed. |
| 35:2381 | Deletion of VM [<String>] did not happen after expiration and grace period elapsed |
| 35:2382 | <String>URL to manage the VM: <String> n |
| 35:2383 | User [<String>] running report [<String>] is deleted/disabled |
| 35:2384 | Device controller with the same media agent and mount path exists already. |
| 35:2385 | Deployed |
| 35:2386 | WorkFlow |
| 35:2387 | User as WorkFlow owner |
| 35:2388 | Unknown storage policy. |
| 35:2389 | Unknown storage policy copy. |
| 35:2390 | Unable to seal the active Deduplication store and create a new store for this copy because the store is under reconstruction. |
| 35:2391 | Unable to seal the active Deduplication store and create a new store for this copy because there is no valid reason to seal. |
| 35:2392 | Unable to seal the active Deduplication store and create a new store for this copy because move is in progress for the store. |
| 35:2393 | Unable to seal the active Deduplication store and create a new store for this copy because this is not a deduplication copy. |
| 35:2394 | Unable to seal the active Deduplication store and create a new store for this copy because this copy is using global deduplication storage policy. |
| 35:2395 | The specified index directory is a root directory. Please provide empty sub-directory and try again. |
| 35:2396 | Computer [<String>] is unreachable or the services are down. |
| 35:2397 | Pattern : Every week on days [<String>] |
| 35:2398 | Validate Custom Rule criteria |
| 35:2399 | Category |
| 35:2400 | Permission |
| 35:2401 | Capability |
| 35:2402 | User Management |
| 35:2403 | Add, delete and modify a user |
| 35:2404 | Add, delete and modify a user group |
| 35:2405 | Add, delete and modify a domain |
| 35:2406 | Change security settings |
| 35:2407 | Discover external server members |
| 35:2408 | User [<String>] doesn't have [<String>] permission on [<String>] entity(s) |
| 35:2409 | User [<String>] doesn't have [<String>] permission on [<String>] [<String>]. |
| 35:2410 | some |
| 35:2411 | User [<String>] doesn't have applicable permissions on an entity to perform this operation |
| 35:2412 | Role name cannot be empty |
| 35:2413 | Role name [<String>] is already in use. Please use a different name. |
| 35:2414 | Role properties do not have any category or permission associations |
| 35:2415 | Invalid category name specified |
| 35:2416 | Invalid permission name specified |
| 35:2417 | Category permission [<String>] combination specified multiple times. Please check the input |
| 35:2418 | Excluding all categories is not allowed |
| 35:2419 | Category [<String>] is excluded. Cannot include [<String>] - [<String>] beneath it |
| 35:2420 | Cannot exclude [<String>] - [<String>] since no category above it is included |
| 35:2421 | Invalid role name [<String>] given |
| 35:2422 | Role [<String>] is a system created protected role - cannot edit it |
| 35:2423 | Role [<String>] can be edited only by creator or master users |
| 35:2424 | Permission [<String>] is invalid |
| 35:2425 | Invalid roles [<String>] specified |
| 35:2426 | Invalid permissions [<String>] specified |
| 35:2427 | Invalid users [<String>] specified |
| 35:2428 | Invalid user groups [<String>] specified |
| 35:2429 | Invalid external groups [<String>] specifed |
| 35:2430 | Invalid include all associations set in the input XML |
| 35:2431 | Security association [<String>] is duplicated in the input request |
| 35:2432 | User does not have [<String>] rights on [<String>] to set security associations for it |
| 35:2433 | User does not have [<String>] rights on [<String>] himself. So cannot grant it to other users or groups |
| 35:2434 | Custom rule |
| 35:2435 | Custom report |
| 35:2436 | Failed to delete Search Engine.Preview/Tag engine [<String>] is associated with it. Please deselect Previw/Tag engine option from Search Engine [<String>] properties and try again. |
| 35:2437 | Failed to delete Search Engine.This is Preview/tag engine for Search engine [<String>]. Please modify or deselect Preview/Tag engine from Search Engine [<String>] properties and try again. |
| 35:2438 | Query Set |
| 35:2439 | Download Set |
| 35:2440 | Tag Set |
| 35:2441 | Legal Hold |
| 35:2442 | CD policy |
| 35:2443 | Unable to contact client for database discover operation. |
| 35:2444 | Unable to contact client for database browse/status operation |
| 35:2445 | Social Security number (SSN) |
| 35:2446 | Person |
| 35:2447 | Organization |
| 35:2448 | Location |
| 35:2449 | Date |
| 35:2450 | Time |
| 35:2451 | Money |
| 35:2452 | Percentage International Standard Book Number (ISBN) |
| 35:2453 | Credit Card |
| 35:2454 | |
| 35:2455 | Phone |
| 35:2456 | IP Address |
| 35:2457 | Edge drive associations for client are missing. Please provide valid edge drive associations. |
| 35:2458 | Storage policy associations for edge drive client are missing. Please select a valid storage policy to associate with the client. |
| 35:2459 | User Group associations for edge drive client are missing. Please select valid internal/external user group(s) to associate with the client. |
| 35:2460 | Please provide a valid operation type to perform on edge drive associations. The operation provided is invalid for edge drive associations. |
| 35:2461 | Unable to find client information to associate with edge drive associations. Please provide a valid client to associate with edge drive associations. |
| 35:2462 | and |
| 35:2463 | Delete operation skipped <String>. |
| 35:2464 | manually retained job(s) |
| 35:2465 | silo tape copy jobs |
| 35:2466 | DDB backup Job(s) |
| 35:2467 | mirror copy jobs |
| 35:2468 | jobs that are involved in Snap To Tape or Deferred Catalog job which are running for this storage policy copy |
| 35:2469 | some job(s) because offline content indexing, data analytics or media refresh job(s) are running for this storage policy copy |
| 35:2470 | Storage Management |
| 35:2471 | Client |
| 35:2472 | Commcell |
| 35:2473 | Content Director |
| 35:2474 | Global |
| 35:2475 | User is owner of locked clients. Please disassociate owner before deleting the user. |
| 35:2476 | Your username is now active |
| 35:2477 | <p>Hello,</p><p>Your account <String> has been created.</p>Thank you. |
| 35:2478 | Reset your password |
| 35:2479 | <p>Hello,</p><p>You have requested to reset your password. Your new password is <b><String></b>. We recommend that you change your password.</p>Thank you. |
| 35:2480 | Your password has been changed |
| 35:2481 | <p>Hello,</p><p>Your account password has been changed successfully.</p>Thank you. |
| 35:2482 | Monitoring Policy |
| 35:2483 | Workflow |
| 35:2484 | Edit Monitoring Policy |
| 35:2485 | Execute Monitoring Policy |
| 35:2486 | Delete Monitoring Policy |
| 35:2487 | Edit Workflow |
| 35:2488 | Execute Workflow |
| 35:2489 | Delete Workflow |
| 35:2490 | Shared Entity Info |
| 35:2491 | Install Client |
| 35:2492 | Install Package/Update |
| 35:2493 | User [<String>] does not have [<String>] permission. |
| 35:2494 | User [<String>] does not exists |
| 35:2495 | User [<String>] is a permanent user and may not be deleted |
| 35:2496 | User [<String>] already exists. |
| 35:2497 | OPERATION FAILED:User does not have [<String>] rights. |
| 35:2498 | NAS Client |
| 35:2499 | Sendlogs failed to get owner user. |
| 35:2500 | Sendlogs will not be able to notify owner <String> as E-Mail is not set for the user. |
| 35:2501 | Failed to save Job Throttle Option in CommServe database.n |
| 35:2502 | Please use password <String> to view share |
| 35:2503 | Password does not match old password |
| 35:2504 | User does not have rights to create share |
| 35:2505 | Your share link [<String>] has expired and it will be deleted in [<String>] days. |
| 35:2506 | Share [<String>] has expired and it will be deleted in [<String>] days. Click <String> here <String> to renew it if you want to continue sharing it.. |
| 35:2507 | Your share [<String>] expired and has been deleted. |
| 35:2508 | Your share link [<String>] is expired and has been deleted. |
| 35:2509 | Cannot toggle SILO option or create a new SILO copy as the volume has been initialized for the store. Please wait for the running jobs for the copy and seal the store. |
| 35:2510 | Email [<String>] is registered as username for another commcell user. Please proceed with another email address. |
| 35:2511 | Email [<String>] is registered as email ID for another commcell user. Please proceed with another email address. |
| 35:2512 | Failed to create the log file for job [<Number>]. |
| 35:2513 | Failed to create the log file between time [<Number>] and [<Number>]. |
| 35:2514 | <String> has shared files with you. |
| 35:2515 | Use the secure download link below to download. |
| 35:2516 | Click <String> here <String> to download: |
| 35:2517 | Secure File Downloads:<br/>Available until: <String><br/> <String> |
| 35:2518 | In case of any problems please contact the <String>Administrator |
| 35:2519 | Please find attached the shared files. |
| 35:2520 | New files have been shared By <String> |
| 35:2521 | <String>: Removed |
| 35:2522 | <String>: Excluded |
| 35:2523 | Cannot create a Silo copy if the source copy datapath has a Cloud Storage. |
| 35:2524 | Dataset |
| 35:2525 | Report |
| 35:2526 | Invalid login. |
| 35:2527 | Login name cannot contain [<String>] |
| 35:2528 | No account found with that email address. |
| 35:2529 | Cannot verify password |
| 35:2530 | The user [<String>] is a protected user and cannot be disabled or have its full name, description or aging rules changed. |
| 35:2531 | Cannot reset password for Domain user [<String>] |
| 35:2532 | Error in disabling/deleting alert for user |
| 35:2533 | User group [<String>] is a external group. Cannot modify users manually to it |
| 35:2534 | Cannot edit User Group [<String>], its a protected group. |
| 35:2535 | Cannot delete User group [<String>], its protected user group. |
| 35:2536 | User group [<String>] does not exist. |
| 35:2537 | Incorrect user given in the associations. |
| 35:2538 | Incorrect associations given. |
| 35:2539 | Cannot remove protected user [<String>]. |
| 35:2540 | User group [<String>] already exists. |
| 35:2541 | User[<String>] cannot be associated by this user |
| 35:2542 | External Group[<String>] cannot be associated by this user |
| 35:2543 | User name cannot be empty. |
| 35:2544 | User group [<String>] is a external group. Cannot add users manually to it |
| 35:2545 | Cannot verify password currently logged in user. |
| 35:2546 | user |
| 35:2547 | user group |
| 35:2548 | User group name cannot be empty |
| 35:2549 | MAs used for SnapBackups only |
| 35:2550 | Days since last backup |
| 35:2551 | Days since client created |
| 35:2552 | Client acts as proxy |
| 35:2553 | Backups enabled for client |
| 35:2554 | Restores enabled for client |
| 35:2555 | Days client online |
| 35:2556 | Inactive AD user as client owner |
| 35:2557 | Client excluded from SLA report |
| 35:2558 | Overwrite on Restore |
| 35:2559 | Prevent restore overwrite registry[bPreventOverwriteRestoreData] is set. Cannot restore to same folder on source. Please provide a different destination folder. |
| 35:2560 | Subclient Policy |
| 35:2561 | Use subclient policy |
| 35:2562 | Subclient Policy |
| 35:2563 | Operation failed. Job cannot be suspended/killed/resumed. |
| 35:2564 | Received invalid prevent datapath delete option, please pass either 0 or 1. |
| 35:2565 | Invalid parameters for - Threshold for managed disk space. |
| 35:2566 | Invalid input passed for enable pruning of aged data option. |
| 35:2567 | Invalid input passed for reserve space for silo restores. |
| 35:2568 | Received invalid use pnp when blank option. |
| 35:2569 | Dataset |
| 35:2570 | Datasource |
| 35:2571 | Reports |
| 35:2572 | Add Datasource |
| 35:2573 | Edit Datasource |
| 35:2574 | Delete Datasource |
| 35:2575 | Query Datasource |
| 35:2576 | Add DataSet |
| 35:2577 | Edit DataSet |
| 35:2578 | Delete DataSet |
| 35:2579 | Query DataSet |
| 35:2580 | Add Report |
| 35:2581 | Edit Report |
| 35:2582 | Delete Report |
| 35:2583 | Execute Report |
| 35:2584 | Create Workflow |
| 35:2585 | Datasource |
| 35:2586 | Data Pruning |
| 35:2587 | Analytics |
| 35:2588 | File Analytics |
| 35:2589 | Email Analytics |
| 35:2590 | Web Analytics |
| 35:2591 | Data Connectors |
| 35:2592 | Events Organizer |
| 35:2593 | User does not have agent management on any client to create a Server group |
| 35:2594 | Registry [EnforceUnixUserPermissionsOnRestore] is set. Please provide user impersonation to perform restores. |
| 35:2595 | Secure Erase |
| 35:2596 | Schedule Policy |
| 35:2597 | Create Schedule Policy |
| 35:2598 | Edit Schedule Policy |
| 35:2599 | Delete Schedule Policy |
| 35:2600 | Edit Schedule Policy Associations |
| 35:2601 | Amazon S3 |
| 35:2602 | Access Key ID |
| 35:2603 | Secret Access Key |
| 35:2604 | Verify Secret Access Key |
| 35:2605 | Bucket |
| 35:2606 | Verizon Cloud Storage |
| 35:2607 | Access Key ID |
| 35:2608 | Secret Access Key |
| 35:2609 | Verify Secret Access Key |
| 35:2610 | Bucket |
| 35:2611 | Google Cloud Storage |
| 35:2612 | Access Key ID |
| 35:2613 | Secret Access Key |
| 35:2614 | Verify Secret Access Key |
| 35:2615 | Bucket |
| 35:2616 | Microsoft Azure Storage |
| 35:2617 | Account Name |
| 35:2618 | Access Key |
| 35:2619 | Verify Access Key |
| 35:2620 | Container |
| 35:2621 | Nirvanix MFS |
| 35:2622 | Username |
| 35:2623 | Password |
| 35:2624 | Verify Password |
| 35:2625 | Application Key |
| 35:2626 | Rackspace Cloud Files |
| 35:2627 | Username |
| 35:2628 | API Key |
| 35:2629 | Verify API Key |
| 35:2630 | Container |
| 35:2631 | OpenStack Object Storage |
| 35:2632 | Username |
| 35:2633 | API Key |
| 35:2634 | Verify API Key |
| 35:2635 | Container |
| 35:2636 | Iron Mountain ASP |
| 35:2637 | Certificate Filename |
| 35:2638 | Passphrase |
| 35:2639 | Verify Passphrase |
| 35:2640 | Asset |
| 35:2641 | Sun Cloud Storage |
| 35:2642 | Username |
| 35:2643 | Password |
| 35:2644 | Verify Password |
| 35:2645 | Bucket |
| 35:2646 | i365 Cloud Storage |
| 35:2647 | Username |
| 35:2648 | Password |
| 35:2649 | Verify Password |
| 35:2650 | Root Folder |
| 35:2651 | EMC Atmos |
| 35:2652 | Token ID |
| 35:2653 | Shared Secret |
| 35:2654 | Verify Shared Secret |
| 35:2655 | Root Folder |
| 35:2656 | AT&T Synaptic Storage |
| 35:2657 | Token ID |
| 35:2658 | Shared Secret |
| 35:2659 | Verify Shared Secret |
| 35:2660 | Root Folder |
| 35:2661 | CV Object Server |
| 35:2662 | Username |
| 35:2663 | Password |
| 35:2664 | Verify Password |
| 35:2665 | Namespace |
| 35:2666 | HDS Hitachi Content Platform |
| 35:2667 | Username |
| 35:2668 | Password |
| 35:2669 | Verify Password |
| 35:2670 | Namespace |
| 35:2671 | Mezeo Cloud Storage |
| 35:2672 | Username |
| 35:2673 | Password |
| 35:2674 | Verify Password |
| 35:2675 | Root Folder |
| 35:2676 | Caringo CAStor |
| 35:2677 | Username |
| 35:2678 | Password |
| 35:2679 | Verify Password |
| 35:2680 | Root Folder |
| 35:2681 | Dell DX Object Storage Platform |
| 35:2682 | Username |
| 35:2683 | Password |
| 35:2684 | Verify Password |
| 35:2685 | Root Folder |
| 35:2686 | DDN WOS |
| 35:2687 | Username |
| 35:2688 | Password |
| 35:2689 | Verify Password |
| 35:2690 | Policy |
| 35:2691 | China Mobile oNest |
| 35:2692 | Access Key ID |
| 35:2693 | Secret Access Key |
| 35:2694 | Verify Secret Access Key |
| 35:2695 | Container |
| 35:2696 | DataDomain Boost |
| 35:2697 | Username |
| 35:2698 | Password |
| 35:2699 | Verify Password |
| 35:2700 | Root Folder |
| 35:2701 | Network Files |
| 35:2702 | Username |
| 35:2703 | Password |
| 35:2704 | Verify Password |
| 35:2705 | Bucket |
| 35:2706 | No results found |
| 35:2707 | User group [<String>] is not valid Commvault group. |
| 35:2708 | Storage Array |
| 35:2709 | BackupSet with user defined subclients is not allowd to update associated subclient policy. |
| 35:2710 | Developer Tools |
| 35:2711 | SnapBackup clients |
| 35:2712 | Clients with attached storages |
| 35:2713 | Case manager hold clients |
| 35:2714 | MediaAgents for clients in group |
| 35:2715 | Running |
| 35:2716 | Pending |
| 35:2717 | Waiting |
| 35:2718 | Suspended |
| 35:2719 | Kill Pending |
| 35:2720 | Suspend Pending |
| 35:2721 | Interrupt Pending |
| 35:2722 | Failed |
| 35:2723 | Killed |
| 35:2724 | Completed with one or more errors |
| 35:2725 | Queued |
| 35:2726 | Running(cannot be verified) |
| 35:2727 | Abnormal Termination Cleanup |
| 35:2728 | Completed with one or more warnings |
| 35:2729 | Committed |
| 35:2730 | Interrupted |
| 35:2731 | Skipped |
| 35:2732 | Failed to Start |
| 35:2733 | Started |
| 35:2734 | the job(s) in last cycle for the subclient(s) having active running job |
| 35:2735 | Received invalid prevent data delete option, please pass either 0 or 1. |
| 35:2736 | Invalid device accessType. |
| 35:2737 | Failed to fetch information from CommServ database. |
| 35:2738 | Invalid drive option. |
| 35:2739 | Failed to create Network Topology. Topology with same name already exists. |
| 35:2740 | User [<String>] doesn't have sufficient privilege to perform this operation. |
| 35:2741 | Invalid username. |
| 35:2742 | Invalid creator name specified. |
| 35:2743 | User exceeding policy quota. |
| 35:2744 | Failed to create task. Please specify a schedule name that is different than the saved report names. |
| 35:2745 | User is removed from the share. |
| 35:2746 | Share cannot be re-shared. |
| 35:2747 | Parent share folder does not exist. |
| 35:2748 | Parent share folder is expired. |
| 35:2749 | Only private re-shares can be created of private shares. |
| 35:2750 | MonitoringPolicy [<String>] does not exists. |
| 35:2751 | An error occured while deleting monitoring policy [<String>] |
| 35:2752 | Invalid monitoringPolicyId or Name |
| 35:2753 | User doesn't have required permissions on the client. Please contact your administrator. |
| 35:2754 | Please configure analytical engine. |
| 35:2755 | Failed to get sql instances |
| 35:2756 | Failed to get the source instance version |
| 35:2757 | Failed to get the source server type |
| 35:2758 | Failed to get the source instance Name |
| 35:2759 | Failed to Update Network Topology. Topology with same name already exists. |
| 35:2760 | Failed to complete operation. A delete operation is underway on the Library. |
| 35:2761 | Client uses storage policy |
| 35:2762 | Client is not ready |
| 35:2763 | Cannot run discovery for Organization members |
| 35:2764 | Cannot communicate to Active Directory for Organization |
| 35:2765 | You have shared the [<String>] <String> with additional users |
| 35:2766 | You have shared the [<String>] <String> with the following users: |
| 35:2767 | To view the shared <String>, click <String>. |
| 35:2768 | Message from <String>: |
| 35:2769 | folder |
| 35:2770 | file |
| 35:2771 | <String> re-shared the [<String>] <String> as [<String>] |
| 35:2772 | <String> renamed the [<String>] <String> to [<String>] and then re-shared the [<String>] <String> with additional users. |
| 35:2773 | Please contact your <String>administrator<String> if you need help or do not recognize<String>the sender of this email. |
| 35:2774 | Disabling delayed stubbing as no OnePass jobs found for Client [<String>] Agent [<String>]. |
| 35:2775 | Disabling delayed stubbing as 7 days have not passed after first OnePass job [<Number>] for Client [<String>] Agent [<String>]. |
| 35:2776 | Delayed stubbing is enabled with first OnePass job [<Number>]. Items will not be stubbed as a Disaster recovery backup job that is older than [<Number>] days and [<Number>] DR backups was not found. |
| 35:2777 | Delayed stubbing is enabled with first OnePass job [<Number>]. Items will be stubbed if the data is backed up before the start time of Disaster recovery backup job [<Number>] that is older than [<Number>] days and [<Number>] DR backups. |
| 35:2778 | User account is locked. Please contact administrator. |
| 35:2779 | Pattern : |
| 35:2780 | Cannot add or remove clients for smartclientgroup |
| 35:2781 | Data Cube Source |
| 35:2782 | Data Cube Search View |
| 35:2783 | Data Cube Search Handler |
| 35:2784 | Failed to configure Content Extractor Engine. |
| 35:2785 | Failed to start Content Extractor service on the MediaAgent, Please install java and try again |
| 35:2786 | Failed to start Content Extractor service on the MediaAgent. |
| 35:2787 | Failed to stop Content Extractor service on the MediaAgent. |
| 35:2788 | User does not have overwrite on restore capability, Map file restore is not supported. |
| 35:2789 | Subclient cannot be reassociated because the Dataset from subclient's previous storage policy association is marked for aging. Please retry in sometime (around 30 minutes). |
| 35:2790 | Can't delete the group, as it is associated to Server group(s) [<String>] |
| 35:2791 | Invalid cloud id passed |
| 35:2792 | Add, delete and modify folders |
| 35:2793 | Add, delete and modify content for DLP |
| 35:2794 | Change Content |
| 35:2795 | Allow privacy |
| 35:2796 | Allow change of client names |
| 35:2797 | Pause, Resume Backup |
| 35:2798 | Password Reset |
| 35:2799 | Dear User,<br/><br/>Reset your password by following these steps:<br/><br/>1. Click this link or copy and paste it into your web browser:<br/><a href=<String> style=color: #666666;><String></a><br/><br/>2. Follow the on-screen instructions to reset your password.<br/><br/>This link expires in 72 hours.<br/><br/>If you are unable to reset your password, contact your <a href=mailto:<String> style=color: #666666;>administrator</a>.<br/><br/>Sincerely,<br/><br/>Your Administrator |
| 35:2800 | Features |
| 35:2801 | Laptop |
| 35:2802 | Edge Drive |
| 35:2803 | eGovernance |
| 35:2804 | eDiscovery |
| 35:2805 | Mobile Backup |
| 35:2806 | Access Policies |
| 35:2807 | User does not have view rights on domain [<String>] |
| 35:2808 | Validate Mountpath. |
| 35:2809 | Invalid region(s) [<String>] specified. |
| 35:2810 | Failed to set region map for copy and subclient. |
| 35:2811 | Failed to remove subclients for the copy [<String>]. |
| 35:2812 | Alert |
| 35:2813 | Alert |
| 35:2814 | Create Alert |
| 35:2815 | Edit Alert |
| 35:2816 | Delete Alert |
| 35:2817 | Edit Alert Associations |
| 35:2818 | Add/Remove Recipients |
| 35:2819 | All Server groups |
| 35:2820 | All Clients |
| 35:2821 | All MediaAgents |
| 35:2822 | All Schedule Policies |
| 35:2823 | All Libraries |
| 35:2824 | All Storage Policies |
| 35:2825 | All Tracking Policies |
| 35:2826 | All Workflows |
| 35:2827 | All Log Monitoring Policies |
| 35:2828 | All Log Monitoring Criterias |
| 35:2829 | User [<String>] doesn't have applicable permissions on this [<String>] to perform this operation. |
| 35:2830 | All [<String>] entities |
| 35:2831 | A configuration policy by this name already exists. |
| 35:2832 | You cannot delete a configuration policy that is in use. |
| 35:2833 | Cleanup |
| 35:2834 | Plan |
| 35:2835 | Plan |
| 35:2836 | Create Plan |
| 35:2837 | Edit Plan |
| 35:2838 | Delete Plan |
| 35:2839 | Use Plan |
| 35:2840 | Invalid Request. New Owner is not present. |
| 35:2841 | Invalid Request. |
| 35:2842 | Unregister the laptop [<String>] associated to the user centric client to delete the client. |
| 35:2843 | Failed to activate laptop. User is not associated to any plan. |
| 35:2844 | Activation of laptop failed. Unable to associate data from the plan. |
| 35:2845 | User[<String>] is not the owner of the client[<String>]. |
| 35:2846 | Failed to unregister user. Registration information is not available. |
| 35:2847 | Laptop Registration. |
| 35:2848 | Activation of laptop [<String>] with user centric client:[<String>] for user[<String>] completed. |
| 35:2849 | Activation of laptop [<String>] with user centric client:[<String>] for user[<String>] failed. |
| 35:2850 | Deactivation of laptop [<String>] with user centric client:[<String>] for user[<String>] completed. |
| 35:2851 | Deactivation of laptop [<String>] with user centric client:[<String>] for user[<String>] successfull. |
| 35:2852 | Reassociation of laptop [<String>] with user centric client:[<String>] for user[<String>] completed. |
| 35:2853 | Reassociation of laptop [<String>] with user centric client:[<String>] for user[<String>] successfull. |
| 35:2854 | User is already associated to the list of user centric clients. Do you want to reassociate any of the existing ones? |
| 35:2855 | Locking is restricted on edge drive client. |
| 35:2856 | OS Name |
| 35:2857 | Associated Storage Policy |
| 35:2858 | MediaAgent has Lucene Index Roles |
| 35:2859 | Master key management is not enabled on copy, hence rotating key is not possible. |
| 35:2860 | Authentication code validation failed. Contact your software vendor for valid authentication code. |
| 35:2861 | Failed to create a Silo copy for the given copy as a Silo copy already exists |
| 35:2862 | Failed to save Disaster Recovery Backup Use VSS Enabled in CommServe database.n |
| 35:2863 | Bank Routing |
| 35:2864 | Individual Taxpayer Identification Number (ITIN) |
| 35:2865 | United States Driver's Licenses (USDL) |
| 35:2866 | CS Client |
| 35:2867 | Client associated with plan |
| 35:2868 | 3DFS Backup |
| 35:2869 | You have provided UNC path for Archive Log Directory. Please provide UNC Username and password. |
| 35:2870 | Root Application |
| 35:2871 | Laptop Backup |
| 35:2872 | Download |
| 35:2873 | VM Provisioning |
| 35:2874 | Push Installs |
| 35:2875 | VCenter |
| 35:2876 | Compliance Search |
| 35:2877 | Documentation |
| 35:2878 | CommCell Console |
| 35:2879 | Cloud Applications |
| 35:2880 | Custom Reports |
| 35:2881 | Client Registration |
| 35:2882 | External Data Connector |
| 35:2883 | Survey |
| 35:2884 | Configuration Request |
| 35:2885 | Sync Request |
| 35:2886 | Generate AuthCode |
| 35:2887 | Events |
| 35:2888 | Monitoring |
| 35:2889 | WorkFlow |
| 35:2890 | PSEECG |
| 35:2891 | Databases |
| 35:2892 | CVLocale |
| 35:2893 | CvLocale Admin |
| 35:2894 | Privacy Controls |
| 35:2895 | Mobile Device Management |
| 35:2896 | LG Individual License Visibility |
| 35:2897 | LG Modify Individual License Visibility |
| 35:2898 | Storage Provisioning |
| 35:2899 | Analytics |
| 35:2900 | LG Capacity License Visibility |
| 35:2901 | Records Management |
| 35:2902 | LM Cloud Applications |
| 35:2903 | Sys Monitoring Cloud Applications |
| 35:2904 | VM Labs |
| 35:2905 | Webconsole SSO |
| 35:2906 | Time Off |
| 35:2907 | LG New License Visibility |
| 35:2908 | LG Modify License Visibility |
| 35:2909 | LG Change License Visibility |
| 35:2910 | LG Staging License Visibility |
| 35:2911 | LG Delete License Visibility |
| 35:2912 | LG Transfer License Visibility |
| 35:2913 | LG View License Visibility |
| 35:2914 | VM Enabled |
| 35:2915 | EdgeDrive Enabled |
| 35:2916 | SharePoint Enabled |
| 35:2917 | Email Enabled |
| 35:2918 | Computers Enabled |
| 35:2919 | Shares Enabled |
| 35:2920 | Sync Allowed |
| 35:2921 | File Analytics |
| 35:2922 | Email Analytics |
| 35:2923 | Data Connector |
| 35:2924 | Web Analytics |
| 35:2925 | Event Organizer |
| 35:2926 | User Group Name cannot be empty |
| 35:2927 | Failed to save download protocol in CommServe database. |
| 35:2928 | XML error: Performance Parameters - Number of pipeline buffers is invalid. Value should be 0 or between 30-1024. |
| 35:2929 | XML error: Performance Parameters - Unable to set CRC details. For details see [EvMgrs.log] |
| 35:2930 | User with address <String> has already been configured on client: <String> |
| 35:2931 | Storage Policy Copy |
| 35:2932 | Library |
| 35:2933 | Resubmit operation is not supported for this job. |
| 35:2934 | User [<String>] doesn't have any one of [<String>] permissions on [<String>] [<String>]. |
| 35:2935 | Failed to update flag for container [<Number>] |
| 35:2936 | Failed to save CVAccounts SSO Url in CommServe database.GXGlobalParams |
| 35:2937 | Move Mount Path |
| 35:2938 | Failed to update the Lucene IndexServer registry value. |
| 35:2939 | Configuration Policy |
| 35:2940 | Exchange Policy |
| 35:2941 | Configuration Policy |
| 35:2942 | Exchange Policy |
| 35:2943 | Create Configuration Policy |
| 35:2944 | Edit Configuration Policy |
| 35:2945 | Delete Configuration Policy |
| 35:2946 | Add/Remove Associations |
| 35:2947 | Failed to change the mail server role on Client. |
| 35:2948 | Monthy Relative |
| 35:2949 | Annually Relative |
| 35:2950 | Client By Schedule Interval |
| 35:2951 | Client needs Updates |
| 35:2952 | Subclient name |
| 35:2953 | Failed to configure content extractor. Specified port is already in use, please try using different port number. |
| 35:2954 | Start Phase Retry Interval has been changed from [<Number>] Minutes to [<Number>] Minutes |
| 35:2955 | Commcell level SLA intervel changed from [<Number>] to [<Number>] |
| 35:2956 | Commcell level Exclude strikes older than interval changed from [<Number>] to [<Number>] |
| 35:2957 | VM Operations |
| 35:2958 | Create VM Snapshot |
| 35:2959 | Delete VM Snapshot |
| 35:2960 | Revert VM Snapshot |
| 35:2961 | Edit VM |
| 35:2962 | Delete VM |
| 35:2963 | Renew VM |
| 35:2964 | Clone VM |
| 35:2965 | Power ON VM |
| 35:2966 | Power OFF VM |
| 35:2967 | Refresh VM |
| 35:2968 | Tape to Tape Copy |
| 35:2969 | On Day |
| 35:2970 | On Days |
| 35:2971 | of each month |
| 35:2972 | of |
| 35:2973 | External Authentication failed. Error[<String>] |
| 35:2974 | Failed to verify the authentication token provided from IDP. |
| 35:2975 | Failed to create Live Sync schedule. Sync schedule exists for replicating [<String>] on [<String>] to [<String>] on [<String>]. Delete the existing schedule to configure Sync with same pair |
| 35:2976 | OPERATION FAILED: Failed to save Additional Settings. Please check logs for more details. |
| 35:2977 | Run Command with System Account |
| 35:2978 | Run Command with User Account |
| 35:2979 | Key Management Server can not be set on Storage Pool dependent copies.nADVICE: Set it on Storage Pool itself, it will get automatically added to all dependent copies. |
| 35:2980 | Master key rotation is not allowed from dependent copy of Storage Pool.nADVICE: Do it on Storage Pool default copy. |
| 35:2981 | Client description |
| 35:2982 | Configuring analytics role with Solr mixed version is not supported. |
| 35:2983 | Older version of analytics solr engine is already configured. Configuring role with Solr newer version is not supported. |
| 35:2984 | Newer version of analytics solr engine is already configured. Configuring role with Solr older version is not supported. |
| 35:2985 | User preference for activation of User Centric Clients is disabled. |
| 35:2986 | Cannot change Smart Server group query since the Create As credentials are incorrect |
| 35:2987 | Cannot change Smart Server group query since the logged in user is not part of Create As user group |
| 35:2988 | Create As credentials are incorrect for Create As user |
| 35:2989 | User is neither a member nor has rights to manage new owner user group. |
| 35:2990 | Billing |
| 35:2991 | Admins |
| 35:2992 | Operators |
| 35:2993 | Content Indexing |
| 35:2994 | Failure while trying to talk to IDP commcell |
| 35:2995 | Operation Failed on IDP commcell |
| 35:2996 | XML error: Performance Parameters - Unable to set registry key MTScanThreads. For details see [EvMgrs.log] |
| 35:2997 | XML error: Performance Parameters - Unable to set registry key nNumPipelineBuffers. For details see [EvMgrs.log] |
| 35:2998 | XML error: Performance Parameters - Unable to set registry key DataMoverUseLookAheadLinkReader. For details see [EvMgrs.log] |
| 35:2999 | Failed to prune indexing archive files. |
| 35:3000 | Import From Exchange Mailbox(Classic) |
| 35:3001 | Space Reclamation |
| 35:3002 | Clients discovered using VSA Subclient |
| 35:3003 | Dear User,<br/><br/>We have received a request to reset your password. Your user name and password cannot be managed inside Commvault software. Your credentials are managed by an external identity provider, such as LDAP or Active Directory. Please contact your <a href=mailto:<String> style=color: #666666;>administrator</a> for help.<br/><br/>Sincerely,<br/><br/>Your Administrator |
| 35:3004 | Dear User,<br/><br/>To reset your password, click this link or copy and paste it into your web browser:<br/><a href=<String> style=color: #666666;><String></a><br/><br/>This link expires in 72 hours.<br/><br/>If you are unable to reset your password, contact your <a href=mailto:<String> style=color: #666666;>administrator</a>.<br/><br/>Sincerely,<br/><br/>Your Administrator |
| 35:3005 | Your password has changed |
| 35:3006 | Your password changed |
| 35:3007 | Dear <String>,<br/><br/>Your password was reset on <String>.<br/>Operating system: <String><br/>Browser: <String><br/>IP address: <String><br/>Estimated location: <String><br/>If you did this, you can safely disregard this email.<br/>If you didn't do this, contact your <a href=mailto:<String> style=color: #666666;>administrator</a>.<br/><br/>Sincerely,<br/><br/>Your Administrator |
| 35:3008 | Contact Commvault Support regarding laptop: [<String>]. |
| 35:3009 | Contact Commvault Support |
| 35:3010 | A large number of files were marked for deletion from the Edge Drive folder on laptop [<String>], and user [<String>] has indicated that these files should <b>not</b> be deleted. Contact Commvault Support to resolve this issue.<br><br><b>Important:</b> This laptop will not sync with the Edge Drive on Web Console or other Edge Drive enabled devices until you contact Commvault Support to resolve this issue. |
| 35:3011 | Review Deleted files on laptop: [<String>]. |
| 35:3012 | Review Deleted Files |
| 35:3013 | A large number of files were marked for deletion from the Edge Drive folder on your laptop [<String>]. <br><br> To view a list of the deleted files, click <a href=<String>><String></a> and follow these instructions: <br> <ul><li>If you deleted the files from your laptop and no longer want them stored in your Edge Drive, click <font color=blue>Delete.</font></li> <li>If you did not delete the files, click <font color=red>Notify Admin.</font><ul><li>Your files will not be deleted and an email will be sent to your administrator. </ul></li></ul><br><br><b>Important: </b>Your laptop will not sync with your Edge Drive on Web and other Edge Drive enabled devices until you confirm the deletion of the files or until your administrator resolves the issue. |
| 35:3014 | User [<String>] does not have the required permissions [Administrative Management] for this operation. |
| 35:3015 | Failed to save dlpEnableAutomaticDecryption property for client : [<String>]. |
| 35:3016 | Failed to save Enable DLP property for client : [<String>]. |
| 35:3017 | Error [<String>] encountered while sending email for report [<String>] for job id [<Number>]. |
| 35:3018 | Edit Subclient Policy Associations |
| 35:3019 | Create Subclient Policy |
| 35:3020 | Delete Subclient Policy |
| 35:3021 | Edit Subclient Policy |
| 35:3022 | User account is disabled for CommCell Console login. Please contact administrator. |
| 35:3023 | Unable to change encryption setting to 'Preserve encryption mode as in source' because partial jobs can't be copied when source data are encrypted differently.nPlease first complete auxiliary copy or mark partial jobs for recopy. |
| 35:3024 | Failed to submit Job Control request for Client [<String>]. |
| 35:3025 | Laptop Backup (Stateless) |
| 35:3026 | System created schedules cannot be deleted |
| 35:3027 | Clients Meet SLA |
| 35:3028 | Clients with no Archive Data |
| 35:3029 | Storage Provisioning Administrator |
| 35:3030 | Storage Provisioning User |
| 35:3031 | Storage Provisioning |
| 35:3032 | Activity |
| 35:3033 | Agent Type |
| 35:3034 | App Group |
| 35:3035 | Calendar |
| 35:3036 | Component |
| 35:3037 | Drive |
| 35:3038 | Drive Pool |
| 35:3039 | License |
| 35:3040 | Locale |
| 35:3041 | Media |
| 35:3042 | Mount Path |
| 35:3043 | Release |
| 35:3044 | Role |
| 35:3045 | Schema |
| 35:3046 | Schema Location |
| 35:3047 | Scratch Pool |
| 35:3048 | SIDB Store |
| 35:3049 | Snapshot Engine |
| 35:3050 | Spare Media Group |
| 35:3051 | Subtask |
| 35:3052 | Sync Web Folder |
| 35:3053 | Task |
| 35:3054 | Timezone |
| 35:3055 | Virtual Machine |
| 35:3056 | VM Allocation Policy |
| 35:3057 | Failed to link CommvaultId |
| 35:3058 | Failed to unlink CommvaultId |
| 35:3059 | Failed to exchange certificate |
| 35:3060 | Connection to RADIUS server failed. |
| 35:3061 | Failed to resolve RADIUS server hostname [<String>]. |
| 35:3062 | Ctree Servers |
| 35:3063 | MongoDB Servers |
| 35:3064 | Index Servers |
| 35:3065 | Invalid SAML token or SAML token expired. |
| 35:3066 | One or more properties found with the same name. |
| 35:3067 | Custom property not found. |
| 35:3068 | PlanID-[<Number>] of PlanSubType-[<String>] is not compatible with the provided AppTypeId-[<Number>].No updates will be made for the entity based on plan. |
| 35:3069 | PlanID-[<Number>] is marked as incomplete. No entity can be associated to the plan. |
| 35:3070 | Application Command Line Backup |
| 35:3071 | Unsupported library for Deduplication copy. Only Magnetic libraries supported for deduplicated copies. |
| 35:3072 | Given cloud user is already linked to a local user |
| 35:3073 | Cloud user is not linked to any local user |
| 35:3074 | Failed to get linked user details |
| 35:3075 | Role |
| 35:3076 | We cannot have a selective copy in a CommServe DR Storage Policy. |
| 35:3077 | Media Refresh is not supported for Storage Policy Copy which uses Global AuxCopy Policy. |
| 35:3078 | A copy Dependent on a Global Secondary Copy Policy cannot be promoted to a Primary Copy. |
| 35:3079 | Unsupported library [<String>] for Global AuxCopy Policy. |
| 35:3080 | Invalid copy name [<String>]. |
| 35:3081 | Invalid DataPath. |
| 35:3082 | Invalid options for new DDB creation for copy [<String>] and storage policy [<String>]. |
| 35:3083 | Invalid dedup flags combination, cannot enable Client Side Dedup and network optimized dedup at the same time. |
| 35:3084 | Invalid Drive Pool Name:[<String>]. |
| 35:3085 | Invalid encType [<Number>] passed. |
| 35:3086 | Invalid combination of encType and encKeyLen passed [<Number> - <Number>]. |
| 35:3087 | Invalid extended retention rules are specified, please check the order of rules specified. |
| 35:3088 | Invalid library [<String>]. |
| 35:3089 | Invalid MediaAgent [<String>]. |
| 35:3090 | Invalid sidbBlockSizeKB [<Number>] passed. |
| 35:3091 | Invalid storage policy name [<String>]. |
| 35:3092 | Invalid spare group [<String>]. |
| 35:3093 | Encryption type and encryption key length passed without setting the flags to enable encryption. |
| 35:3094 | Encryption type and encryption key length are needed when enabling any kind of encryption. |
| 35:3095 | VPN Management |
| 35:3096 | Creating secondary copies on Storage Pool is not allowed. |
| 35:3097 | This is worm storage copy. Do you really want to reduce the retention? |
| 35:3098 | Cannot associate members of another domain to user groups of this domain |
| 35:3099 | Cannot change AD group names |
| 35:3100 | Local group(s) [<String>] cannot be associated by this user |
| 35:3101 | Onepass enabled |
| 35:3102 | Custom Property |
| 35:3103 | Custom Property |
| 35:3104 | Create Custom Property |
| 35:3105 | Delete Custom Property |
| 35:3106 | User does not have required permissions to perform the operation. |
| 35:3107 | Update Custom Property |
| 35:3108 | Live Browse Restore |
| 35:3109 | Server group |
| 35:3110 | Change Client Associations |
| 35:3111 | Create Server group |
| 35:3112 | Delete Server group |
| 35:3113 | User description contains |
| 35:3114 | User Group description contains |
| 35:3115 | New user [<String>] password is invalid. |
| 35:3116 | New user password is missing. |
| 35:3117 | Failed to save http site location in CommServe database. |
| 35:3118 | Failed to save Patch Config URL Prefix in CommServe database. |
| 35:3119 | Failed to save use token in CommServe database. |
| 35:3120 | Please set password for the user if you try to unlink commvaultId. |
| 35:3121 | User is linked to CommvaultId. Please use CommvaultId credentials to login. |
| 35:3122 | All User Groups |
| 35:3123 | All Users |
| 35:3124 | Mobile Policy |
| 35:3125 | Mobile Policy |
| 35:3126 | One or more policies found with the same name. |
| 35:3127 | Mobile Policy not found. |
| 35:3128 | Edit Mobile Policy Associations |
| 35:3129 | Create Mobile Policy |
| 35:3130 | Delete Mobile Policy |
| 35:3131 | Update Mobile Policy |
| 35:3132 | Failed to edit drive properties for the drive [<String>]. |
| 35:3133 | Failed to [<String>] status for the drive [<String>]. |
| 35:3134 | Failed to [<String>] maintenance mode for the library [<String>]. |
| 35:3135 | Failed to [<String>] status for the library [<String>]. |
| 35:3136 | The selected NAS client is already associated with another policy. |
| 35:3137 | Reassociated client [<String>] application [<String>] to storage policy [<String>] due to Server group change. |
| 35:3138 | Failed to create storage policy [<String>], No license or the license has expired on the MediaAgent [<String>]. |
| 35:3139 | Failed to create storage policy [<String>], The License is uninstalled on the MediaAgent[<String>]. |
| 35:3140 | Failed to push network configuration for one or more Server groups in the topology [<String>]. Please check logs for more details. |
| 35:3141 | Push Network Configuration submitted successfully for Network Topology [<String>]. |
| 35:3142 | Network Configuration successfully pushed for Network Topology [<String>]. |
| 35:3143 | User does not have permission to manage one/more Server groups in the topology [<String>]. Please check logs for more details. |
| 35:3144 | Commcell level RPO Minutes changed from [<Number>] to [<Number>] |
| 35:3145 | Commcell level RTO Minutes changed from [<Number>] to [<Number>] |
| 35:3146 | Commcell level SLA Copy Fallen Behind Days changed from [<Number>] to [<Number>] |
| 35:3147 | Commcell level SLA Copy Redundancy changed from [<Number>] to [<Number>] |
| 35:3148 | Commcell level SLA Count Snap Jobs changed from [<Number>] to [<Number>] |
| 35:3149 | Failed to submit power off request. |
| 35:3150 | Failed to submit power on request. |
| 35:3151 | User[<String>] does not have Media Agent Management permission to perform Power Management operation. |
| 35:3152 | Successfully submitted power off request. |
| 35:3153 | Successfully submitted power on request. |
| 35:3154 | Clients by Security Permission |
| 35:3155 | Clients by Security Role |
| 35:3156 | Company Client Provider Associations |
| 35:3157 | User Client Provider Associations |
| 35:3158 | User Group Client Provider Associations |
| 35:3159 | Laptop Activation |
| 35:3160 | Activation of laptop [<String>] failed. |
| 35:3161 | Activation of laptop [<String>] is successful. |
| 35:3162 | Deactivation of laptop [<String>] failed. |
| 35:3163 | Deactivation of laptop [<String>] is successful. |
| 35:3164 | Reassociation of laptop [<String>] with client:[<String>] failed. |
| 35:3165 | Reassociation of laptop [<String>] with client:[<String>] is successful. |
| 35:3166 | Archiving |
| 35:3167 | Failed to delete [<String>] for [<String>] with error [<String>]. |
| 35:3168 | Failed to get [<String>] for [<String>] with error [<String>]. |
| 35:3169 | Failed to set [<String>] for [<String>] with error [<String>]. |
| 35:3170 | EDC Clients |
| 35:3171 | Client Registry Key and Restart Flag |
| 35:3172 | Smart Server group Extra Clean Up |
| 35:3173 | Server Group |
| 35:3174 | Data Server FC |
| 35:3175 | Data Server IP |
| 35:3176 | Data Server ISCSI |
| 35:3177 | Dear User,nnUse following steps to install the proxy software package on your client:nn1. Download the installation package at <String>nn2. Verify that tunnel port 443 is open.nn3. Install the package on your client.nDuring installation use the following setup information:nnclient name: <String>nhost name: <String>nCommServe name: <String>nnSincerely,nYour Administrator |
| 35:3178 | Password provided does not meet complexity requirements. |
| 35:3179 | Subclient is associated with monitoring policy, Hence it cannot be deleted. |
| 35:3180 | Failed to associate archive subclient with Monitoring Policy. Please re-associate archive subclient through Monitoring Policy edit operation. reason : <String> |
| 35:3181 | Content Analyzer Cloud |
| 35:3182 | Physical Node of a Cluster |
| 35:3183 | Company Installed Client Associations |
| 35:3184 | View Reports |
| 35:3185 | Failed to connect to SQL Server. Please check if SQL Services are running or instance/database information is correct. |
| 35:3186 | Failed to get the database name. |
| 35:3187 | No database is specified. |
| 35:3188 | <String>Live Mounted Virtual Machine Name: <String> n Virtual machine hostname: <String> n Virtual machine IP Address: <String> |
| 35:3189 | Client Online in Last 30 Days |
| 35:3190 | Database(s) [<String>] does not exist. |
| 35:3191 | Database(s) [<String>] has multiple associations. |
| 35:3192 | File/FileGroup(s) [<String>] does not exist. |
| 35:3193 | File/FileGroup(s) [<String>] has multiple associations. |
| 35:3194 | FileGroup already associated, cannot associate file(s) [<String>] to another subclient. |
| 35:3195 | All contents will be removed from subclient(s) [<String>] after association. |
| 35:3196 | Subclient(s) [<String>] does not exist. |
| 35:3197 | Failed to power off the virtual machine. Reason : Jobs[<String>] are running. |
| 35:3198 | Unable to communicate with the client. Please make sure that client is accessible and then try again. |
| 35:3199 | Ownership transfer of schedules which are part of schedule policy is not allowed. |
| 35:3200 | Search Share |
| 35:3201 | Strikes count |
| 35:3202 | Failed to create an XML file for the given Storage Policy or Copy. |
| 35:3203 | Cannot create XML file as file path is not specified. |
| 35:3204 | Custom Calendar |
| 35:3205 | Client [<String>] cannot be deleted as it has valid data in worm storage. |
| 35:3206 | Subclient(s) [<String>] does not exist in the given instance. |
| 35:3207 | Search Engine node with URL [<String>] is not reachable. |
| 35:3208 | Error setting Alerts. |
| 35:3209 | Error setting company properties. |
| 35:3210 | Contact name not provided. |
| 35:3211 | Hello [<String>],<br/><br/>An account for [<String>] has been created for you. Go to the [<String>] and log on with the following credentials:<br/><br/>Username: [<String>]<br/><br/>Password: [<String>]<br/><br/>After you log on, you will be prompted to change your password.<br/><br/>If you need help, please send an email to [<String>].<br/><br/>Thank you,<br/><br/>Your Commvault Admin |
| 35:3212 | Your [<String>] Admin Console account is available |
| 35:3213 | Domain/subdomain name you supplied is already present. Duplicate domain/subdomain names are not allowed. |
| 35:3214 | Error sending email. |
| 35:3215 | Error setting Server group permissions. |
| 35:3216 | Company name is not provided. |
| 35:3217 | Plan not provided. |
| 35:3218 | Error setting Tenant Admin group permissions. |
| 35:3219 | Error setting Tenant Admin properties. |
| 35:3220 | Email is not provided for the user. |
| 35:3221 | Finance Tags |
| 35:3222 | Use Network Share |
| 35:3223 | Clients With Improperly Deconfigured Subclients |
| 35:3224 | Clients With Long Running Jobs |
| 35:3225 | Clients With Subclients Having Associated Storage Policy |
| 35:3226 | Clients With Backup Schedule |
| 35:3227 | Failed to delete monitoring policy [<String>]. Monitoring policy is associated with subclient [<String>]. |
| 35:3228 | Failed to associate monitoring policy [<String>] with subclient [<String>]. Content indexing should be enabled for storage policy [<String>]. |
| 35:3229 | Failed to associate monitoring policy [<String>] with subclient [<String>]. Client of storage policy [<String>] and monitoring policy [<String>] cloud are different. |
| 35:3230 | Invalid CommvaultId Credentials. |
| 35:3231 | User is created but linking to CommvaultId failed. Please retry by editing user. |
| 35:3232 | Clients With Synthetic Full Backup N Days |
| 35:3233 | Unable to delete Storage Pool because there are dependent copies using this Storage Pool. |
| 35:3234 | Commcell level property to exclude strikes is disabled. |
| 35:3235 | Healthcare Administrative Management |
| 35:3236 | File <String> has been uploaded by user <String> under share <String>. |
| 35:3237 | Folder <String> has been created by user <String> under share <String>. |
| 35:3238 | File <String> has been deleted by user <String> under share <String>. |
| 35:3239 | Folder <String> has been deleted by user <String> under share <String>. |
| 35:3240 | Share <String> has been deleted by user <String>. |
| 35:3241 | File <String> has been downloaded by user <String> under share <String>. |
| 35:3242 | Folder <String> has been downloaded by user <String> under share <String>. |
| 35:3243 | File <String> has been moved to <String> by user <String> under share <String>. |
| 35:3244 | Folder <String> has been moved to <String> by user <String> under share <String>. |
| 35:3245 | File <String> has been renamed to <String> by user <String> under share <String>. |
| 35:3246 | Folder <String> has been renamed to <String> by user <String> under share <String>. |
| 35:3247 | File <String> has been shared by user <String>. |
| 35:3248 | Folder <String> has been shared by user <String>. |
| 35:3249 | Share <String> has been updated by user <String>. |
| 35:3250 | Data Masking Policy |
| 35:3251 | Audit Trail |
| 35:3252 | Custom Calendar |
| 35:3253 | DR Backup |
| 35:3254 | Job Manager Settings |
| 35:3255 | Associated Server group List |
| 35:3256 | MediaAgents for clients in group list |
| 35:3257 | MediaAgent has Lucene Index Role List |
| 35:3258 | Associated Storage Policy List |
| 35:3259 | Timezone List |
| 35:3260 | This operation is not applicable for index backup job. |
| 35:3261 | Invalid Storage Policy or copy name is being passed. |
| 35:3262 | All properties |
| 35:3263 | Incorrect value set to Begin Date |
| 35:3264 | Incorrect value set to Begin Month |
| 35:3265 | Incorrect value set to Begin Year |
| 35:3266 | Calendar has association with one or more Storage Policy Copy(s) |
| 35:3267 | Calendar is default |
| 35:3268 | Calendar name already exists |
| 35:3269 | Calendar does not exist |
| 35:3270 | Incorrect value set to Number Of Year |
| 35:3271 | Calendar has association with one or more Schedule(s) |
| 35:3272 | Review Set |
| 35:3273 | Ownership transfer of an entity to a disabled user is not allowed. |
| 35:3274 | Shares |
| 35:3275 | Primary copy of a storage policy cannot be disabled. |
| 35:3276 | 'Pick data from running jobs' feature is not supported for selective copy or Inline copy. |
| 35:3277 | Create Recovery Point |
| 35:3278 | Incorrect name set to calendar name |
| 35:3279 | Incorrect value set to Number Of Days |
| 35:3280 | Create As(Owner) info is required for preview of clients in smart Server group. |
| 35:3281 | This user is associated with an Edge Drive/Object store. Please delete the associated backupset [<String>] under client [<String>] first before deleting the user. |
| 35:3282 | No Network Configuration Found |
| 35:3283 | DDB Verification |
| 35:3284 | Unable to identify backupset for input association. Please check clientName, appName, instanceName in the request xml. |
| 35:3285 | Unable to identify iDataAgent for input association. Please check clientName in the request xml. |
| 35:3286 | Unable to identify instance for input association. Please check clientName, appName in the request xml. |
| 35:3287 | User does not have permission on the entity. |
| 35:3288 | Caller do not have permission to get user information or he is not a peer user. |
| 35:3289 | Caller User do not have permissions on userGroup. |
| 35:3290 | User not found or does not exists. |
| 35:3291 | Failed to configure ObjectStore client. Please delete the client manually. |
| 35:3292 | Failed to configure ObjectStore client. Please check the log for more details. |
| 35:3293 | User/UserGroup [<String>] is not a member of the domain [<String>]. |
| 35:3294 | "Select MediaAgents for pruning aged data based on the associated copy's datapaths" cannot be changed when "Enable pruning of aged data option" is disabled. |
| 35:3295 | Invalid input passed for use datapath settings MA for pruning option. |
| 35:3296 | Timezone Region List |
| 35:3297 | Africa |
| 35:3298 | Antarctica |
| 35:3299 | Asia |
| 35:3300 | Atlantic Ocean |
| 35:3301 | Australia |
| 35:3302 | Europe |
| 35:3303 | Indian Ocean |
| 35:3304 | North America |
| 35:3305 | Other |
| 35:3306 | Pacific Ocean |
| 35:3307 | South America |
| 35:3308 | Unknown |
| 35:3309 | Unable to set Subclient data retention, please select Archiver mode or Backup mode. |
| 35:3310 | Unable to set OnePass feature on subclient, please select Archiver mode or Backup mode. |
| 35:3311 | Driver Install |
| 35:3312 | Driver Uninstall |
| 35:3313 | Driver Update |
| 35:3314 | RServer hostname already exist |
| 35:3315 | RServer Hostname |
| 35:3316 | Invalid id provided for RServer hostname |
| 35:3317 | Failed to configure index server |
| 35:3318 | Failed to configure index server due to db error |
| 35:3319 | Failed to create index server |
| 35:3320 | Failed to delete analytics cloud |
| 35:3321 | Invalid index server display name |
| 35:3322 | Invalid index server cloudId |
| 35:3323 | Index server cloud information is incomplete |
| 35:3324 | Failed to modify index server |
| 35:3325 | Index server name / client name already exists |
| 35:3326 | Index server does not exists |
| 35:3327 | Failed to perform index server operation. Please check logs for more details. |
| 35:3328 | Invalid operation type |
| 35:3329 | Invalid index server type |
| 35:3330 | Multiple Zookeeper information are found |
| 35:3331 | Index server node already exists |
| 35:3332 | Invalid index server node clientid |
| 35:3333 | Failed to perform index server node configuration |
| 35:3334 | Failed to modify node settings |
| 35:3335 | Failed to perform index server node operation |
| 35:3336 | Invalid index server node operation |
| 35:3337 | Invalid index server node properties |
| 35:3338 | Failed to deconfigure index server node |
| 35:3339 | Index server node information is not provided |
| 35:3340 | Invalid roleId |
| 35:3341 | Failed to perform role operation |
| 35:3342 | Invalid index server role operation |
| 35:3343 | Index server is not up and running |
| 35:3344 | Failed to get user session token |
| 35:3345 | Failed to get webservice URL. Index server / index server pool configuration requires at least one client with Webserver package installed. |
| 35:3346 | Invalid Zookeeper cloudId |
| 35:3347 | Zookeeper Information is not provided |
| 35:3348 | Filter name cannot be empty |
| 35:3349 | Table Filter |
| 35:3350 | Object store operation is in process. Property modification is not allowed at this time. |
| 35:3351 | Cannot delete storage policy [<String>]. The storage policy is associated to a plan [<String>]. |
| 35:3352 | Failed to delete task. The task is associated to a plan [<String>]. |
| 35:3353 | Path to save log files during sendlogfiles operation has been set to [<String>]. |
| 35:3354 | Failed to save path to save log files during sendlogfiles operation to [<String>] in CommServe database. |
| 35:3355 | Password for path to save log files during sendlogfiles operation changed. |
| 35:3356 | Failed to save password for path to save log files during sendlogfiles operation in CommServe database. |
| 35:3357 | User for path to save log files during sendlogfiles operation has been set to [<String>]. |
| 35:3358 | Failed to save User for path to save log files during sendlogfiles operation to [<String>] in CommServe database. |
| 35:3359 | Cannot delete entity as it has valid data in worm storage. |
| 35:3360 | Cannot create HyperScale X Storage pool with configuration [<String>], please select [<Number>] MediaAgent[s]. |
| 35:3361 | Cannot create HyperScale X Storage pool, please select a valid configuration type. |
| 35:3362 | <Number> files have been uploaded under share <String>. |
| 35:3363 | <Number> folders have been created under share <String>. |
| 35:3364 | <Number> files have been deleted under share <String>. |
| 35:3365 | <Number> folders have been deleted under share <String>. |
| 35:3366 | <Number> files have been downloaded under share <String>. |
| 35:3367 | <Number> folders have been downloaded under share <String>. |
| 35:3368 | <Number> files have been moved to share <String>. |
| 35:3369 | <Number> folders have been moved to share <String>. |
| 35:3370 | <Number> files have been renamed under share <String>. |
| 35:3371 | <Number> folders have been renamed under share <String>. |
| 35:3372 | Data Masking |
| 35:3373 | Selected Cloud Controller already has node(s) [<String>] which are power managed. |
| 35:3374 | Auth Code feature is not enabled |
| 35:3375 | Company provided does not exist |
| 35:3376 | Auth Code generation disabled for this company |
| 35:3377 | Multi Node Content Indexing |
| 35:3378 | <Message> at <String> |
| 35:3379 | Company alias name is not provided. |
| 35:3380 | Data Aging is disabled for client[<String>] on an account of anomaly detection. |
| 35:3381 | System created Edge drive Server group cannot be deleted. |
| 35:3382 | Finland HETU |
| 35:3383 | France INSEE |
| 35:3384 | Germany PK |
| 35:3385 | Germany Steuer ID |
| 35:3386 | Germany RVNR/VSNR |
| 35:3387 | Greece AFM |
| 35:3388 | Greece Tautotita |
| 35:3389 | United Kingdom Driving License |
| 35:3390 | United Kingdom National Health Service Number |
| 35:3391 | United Kingdom National Insurance Number |
| 35:3392 | Cannot delete the group [<String>], it is created by a company [<String>]. |
| 35:3393 | Cannot delete the group [<String>], it is created by a plan [<String>]. |
| 35:3394 | Cannot delete user group [<String>], it is created by a company [<String>]. |
| 35:3395 | Cannot delete user group [<String>], it is created by a plan [<String>]. |
| 35:3396 | Failed to delete <String> [<String>] with error [<String>]. |
| 35:3397 | Failed to set <String> [<String>] with error [<String>]. |
| 35:3398 | Failed to create Network Topology. A topology with same set of groups already exists. |
| 35:3399 | Failed to update Network Topology. A topology with same set of groups already exists. |
| 35:3400 | Beyond [X] Years |
| 35:3401 | Beyond 1 Year |
| 35:3402 | Last 1 Month |
| 35:3403 | Last [X] Days |
| 35:3404 | Last [X] Months |
| 35:3405 | Last [X] Years |
| 35:3406 | Last 1 Year |
| 35:3407 | Received invalid "Mark Library Offline for Maintenance" option, please pass either 0 or 1. |
| 35:3408 | Failed to mark the DDB for Archive File Validation and Pruning. DDB is Corrupt. |
| 35:3409 | Failed to mark the DDB for Archive File Validation and Pruning. DDB is aged. |
| 35:3410 | Failed to mark the DDB for Archive File Validation and Pruning. Data Verification operation is underway. |
| 35:3411 | Failed to mark the DDB for Archive File Validation and Pruning. DDB is not eligible for the operation. |
| 35:3412 | Failed to mark the DDB for Archive File Validation and Pruning. The DDB is in Maintenance mode. |
| 35:3413 | Failed to mark the DDB for Archive File Validation and Pruning. A DDB Synchronization Process is already in progress. |
| 35:3414 | Failed to mark the DDB for Archive File Validation and Pruning. DDB is uninitialized. |
| 35:3415 | Failed to delete MediaAgent. It is a part of index server [<String>].Please delete index server and try again |
| 35:3416 | All Shares |
| 35:3417 | File <String> has been uploaded. |
| 35:3418 | Folder <String> has been created. |
| 35:3419 | File <String> has been deleted. |
| 35:3420 | Folder <String> has been deleted. |
| 35:3421 | Share has been deleted. |
| 35:3422 | File <String> has been downloaded. |
| 35:3423 | Folder <String> has been downloaded. |
| 35:3424 | File <String> has been moved to <String>. |
| 35:3425 | Folder <String> has been moved to <String>. |
| 35:3426 | File <String> has been renamed to <String>. |
| 35:3427 | Folder <String> has been renamed to <String>. |
| 35:3428 | File has been shared. |
| 35:3429 | Folder has been shared. |
| 35:3430 | Share has been updated. |
| 35:3431 | Retention days are not in descending order with Critical Retention Days at the highest. |
| 35:3432 | Error connecting to workflow engine. |
| 35:3433 | Time out when receiving message from workflow engine. |
| 35:3434 | Failed to get response from workflow engine. |
| 35:3435 | Failed to send message to workflow engine. |
| 35:3436 | Backupset(s) [<String>] is(are) already associated to subclient policy [<String>] from Server group. |
| 35:3437 | Failed to activate laptop. Invalid auth code associated with client. |
| 35:3438 | Failed to create/edit Monitoring policy.Please associate archive subclient for mifid Monitoring policy type. |
| 35:3439 | Access denied. The user does not have required capabilities to create plan |
| 35:3440 | Access denied. The user does not have required capabilities to update plan |
| 35:3441 | Access denied. The user does not have required capabilities to view plan |
| 35:3442 | Plan not found |
| 35:3443 | Company with same name already exists. |
| 35:3444 | Client IPV4 CIDR Address Range |
| 35:3445 | Failed to set activity control. Time selected should be greater than current time. |
| 35:3446 | Clients With Encryption |
| 35:3447 | DR Orchestration |
| 35:3448 | Credential Management |
| 35:3449 | Invalid input specified. Please verify if all required parameters are passed in request. |
| 35:3450 | Invalid owner information specified in request. |
| 35:3451 | Invalid credential information in request. |
| 35:3452 | Either credentials are already associated with another entity or User does not have ownership to delete the credentials. |
| 35:3453 | Either credentialId OR credentialName OR recordType OR userName OR password is Invalid. |
| 35:3454 | User does not have ownership to update the credentials. |
| 35:3455 | Credential Entity. |
| 35:3456 | Use Credential |
| 35:3457 | Hello [<String>],<br/><br/>An account has been created for you. Go to the [<String>] and log on with the following credentials:<br/><br/>Username: [<String>]<br/><br/>Password: [<String>]<br/><br/>After you log on, you will be prompted to change your password.<br/><br/> |
| 35:3458 | Your account is available |
| 35:3459 | Your Account |
| 35:3460 | Hello [<String>],<br/><br/>The password of your account [<String>] was recently changed.<br/><br/> |
| 35:3461 | Job is not available on the given copy. |
| 35:3462 | Job not found on the given storage policy. |
| 35:3463 | Power management configuration at Server group level was not applied on certain Media Agents. Please check logs for further details. |
| 35:3464 | Power management re-configuration failed on associated media agents |
| 35:3465 | Company not found |
| 35:3466 | Invalid encryption algorithm provided |
| 35:3467 | SNMPV3 Hostname |
| 35:3468 | Invalid id provided for SNMPV3 hostname |
| 35:3469 | Failed to begin discovery. Could not connect to any of the given proxies. |
| 35:3470 | Delete Data |
| 35:3471 | Instant Clone |
| 35:3472 | EDiscoveryTask |
| 35:3473 | Create EDiscovery Task |
| 35:3474 | Delete EDiscovery Task |
| 35:3475 | Edit EDiscovery Task |
| 35:3476 | View EDiscovery Task |
| 35:3477 | Storage Policy Management |
| 35:3478 | Create Storage Policy \ Copy |
| 35:3479 | Delete Storage Policy \ Copy |
| 35:3480 | Edit Storage Policy \ Copy |
| 35:3481 | Operations on Storage Policy \ Copy |
| 35:3482 | Index server name / client name [<String>] already exists |
| 35:3483 | Port [<String>] is already in use by client [<String>]. Please try with different port. |
| 35:3484 | Drive [<String>] does not exists on client [<String>] |
| 35:3485 | Index directory path [<String>] does not exists on client [<String>] |
| 35:3486 | Credential Name is not available. Please use different credential Name. |
| 35:3487 | Server group selected for test failover contains Commserv client also. Please select another group |
| 35:3488 | Proxy Server group selected for test failover contains Commserv client also. Please select another group. |
| 35:3489 | Failed to set EdgeDrive audit property for client [<String>]. |
| 35:3490 | Exclude (Command Line) Subclients From SLA option is disabled at Commcell level. |
| 35:3491 | Exclude (Command Line) Subclients From SLA option is enabled at Commcell level. |
| 35:3492 | SLA Grace Period for new clients at Commcell level is changed from [<Number>] days to [<Number>] days. |
| 35:3493 | Maximum Offline Days for including long time offline laptops at Commcell level changed from [<Number>] days to [<Number>] days. |
| 35:3494 | Invalid old owner id is present. |
| 35:3495 | Invalid Request. Both new owner user and group are present in xml. |
| 35:3496 | New user/user group information for transfer of ownership is missing. Transfer of ownership is mandatory while deleting a user. |
| 35:3497 | New owner should not be a disabled user/user group. |
| 35:3498 | The value specified [<Number>] for 'Do not deduplicate against objects older than' property should be greater than 30. |
| 35:3499 | Modify Credential Account |
| 35:3500 | Server group is a proxy of a controller used for power management operations. |
| 35:3501 | Server group is a proxy of the selected controller. |
| 35:3502 | Media Agent is a proxy used for power management operations. |
| 35:3503 | Media Agent is a proxy of the selected controller. |
| 35:3504 | Invalid Drive ID : [<String>] |
| 35:3505 | Invalid Storage Pool [<String>] |
| 35:3506 | Restore Validate |
| 35:3507 | User password doesn't follow minimum complexity requirements. Minimum password length has to be 8 characters and it should have at least 1 lowercase letters, 1 uppercase letters, 1 numbers, 1 special characters. |
| 35:3508 | User password doesn't follow minimum complexity requirements. Minimum password length has to be 12 characters and it should have a combination of at least 2 lowercase letters, 2 uppercase letters, 2 numbers, and 2 special characters. |
| 35:3509 | Smart Folder |
| 35:3510 | Failed to delete the client. It is associated with Index Store Pools : [<String>] |
| 35:3511 | Cannot delete company. [<Number>] clients are still associated with this company. |
| 35:3512 | Please dissociate all plans from the company and try again. |
| 35:3513 | Exchange environment type cannot be updated from [<String>] to [<String>] |
| 35:3514 | Exchange DAG client [%s] is created in a de-configured state as there is no available license of type Application Class 1 |
| 35:3515 | Server group provided is not associated to a plan. |
| 35:3516 | Logged in user is not an admin to enable privacy on the Commcell. |
| 35:3517 | Logged in user is not a tenant admin to enable privacy for an Organization. |
| 35:3518 | HAC Cluster |
| 35:3519 | $EMAIL_HEADER$<br/>Hello $RECIPIENT_NAME$,<br/><br/>An account for $TENANT_COMPANY_NAME$ has been created for you. Click <a href="$CHANGE_PASSWORD_LINK$" style=color: #666666;>here</a> and enter the new credentials:<br/><br/>User name: $USERNAME$<br/><br/>This link expires in $CHANGE_PASSWORD_LINK_EXPIRATION$.<br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you,<br/><br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3520 | Your $TENANT_COMPANY_NAME$ account is available |
| 35:3521 | $EMAIL_HEADER$<br/>Hello $RECIPIENT_NAME$,<br/><br/>An account has been created for you. Click <a href="$CHANGE_PASSWORD_LINK$" style=color: #666666;>here</a> and enter the new credentials:<br/>User name: $USERNAME$<br/><br/>This link expires in $CHANGE_PASSWORD_LINK_EXPIRATION$.<br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you,<br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3522 | Your account is available |
| 35:3523 | $EMAIL_HEADER$<br/>Dear User,<br/><br/>To reset your password, click this link or copy and paste it into your web browser:<br/><a href="$CHANGE_PASSWORD_LINK$" style=color: #666666;>$CHANGE_PASSWORD_LINK$</a><br/><br/>This link expires in $CHANGE_PASSWORD_LINK_EXPIRATION$.<br/><br/>If you are unable to reset your password, contact your <a href="mailto:$ADMINISTRATOR_EMAIL$">administrator</a><br/><br/>Sincerely,<br/><br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3524 | Reset your password |
| 35:3525 | Add company |
| 35:3526 | Email sent to the tenant admin when a company is added |
| 35:3527 | Create local user |
| 35:3528 | Email sent to the local user when the user is created |
| 35:3529 | Reset password for a local user |
| 35:3530 | Email sent to the local user when the forgot password link is clicked |
| 35:3531 | Empty share path provided in the request. |
| 35:3532 | Failed to delete client [<String>]. It is associated to Index server pool [<String>]. Please delete index server pool and retry. |
| 35:3533 | CVApp |
| 35:3534 | CVApp |
| 35:3535 | Create CVApp |
| 35:3536 | Delete CVApp |
| 35:3537 | Edit CVApp |
| 35:3538 | Execute CVApp |
| 35:3539 | $EMAIL_HEADER$<br/>Dear User,<br/><br/>This is an automated email from your $COMPANY_NAME$ administrator requesting that you enable your device for backup.<br/><br/>Use the following steps to install the backup software package on your device:<br/><br/>1. Download the installation package at $WEBCONSOLE_URL$<br/><br/>2. Install the package on your device.<br/>During installation use the following backup CommServe name: $COMMSERVER_NAME$<br/><br/>Sincerely,<br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3540 | Invitation to use $COMPANY_NAME$ backup |
| 35:3541 | $EMAIL_HEADER$<br/>Dear User,<br/><br/>This is an automated email from your $COMPANY_NAME$ administrator requesting that you enable your device for backup. Click <a href="$CHANGE_PASSWORD_LINK$" style=color: #666666;>here</a> and enter the new credentials:<br/><br/>User Name: $USERNAME$<br/><br/>This link expires in $CHANGE_PASSWORD_LINK_EXPIRATION$.<br/><br/>Use the following steps to install the backup software package on your device:<br/><br/>1. Download the installation package at $WEBCONSOLE_URL$ <br/><br/>2. Install the package on your device.<br/><br/>During installation use the following backup CommServe name: $COMMSERVER_NAME$ <br/><br/>Sincerely,<br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3542 | Invitation to use $COMPANY_NAME$ backup |
| 35:3543 | Invite domain user |
| 35:3544 | Email sent to the domain user when the user is invited to install a package |
| 35:3545 | Invite local user |
| 35:3546 | Email sent to the local user when the user is invited to install a package |
| 35:3547 | Monitoring Policy Template |
| 35:3548 | Login denied to user [<String>] . User has no credentials on this CommServe. |
| 35:3549 | Unable to create mirror copy [<String>] for storage policy [<String>]. Default mirror copy is not present. |
| 35:3550 | Unable to create default mirror copy [<String>] for storage policy [<String>]. Default mirror copy is already present. |
| 35:3551 | Unable to create replica/vault copy [<String>] for storage policy [<String>]. Default replica/vault copy is not present. |
| 35:3552 | Unable to create default replica/vault copy [<String>] for storage policy [<String>]. Default replica/vault copy is already present. |
| 35:3553 | Online Crawl |
| 35:3554 | <Number> files have been brought back from trash to share <String>. |
| 35:3555 | <Number> folders have been brought back from trash to share <String>. |
| 35:3556 | File <String> has been brought back from trash by user <String> to share <String>. |
| 35:3557 | Folder <String> has been brought back from trash by user <String> to share <String>. |
| 35:3558 | Given User cannot be used as Primary Contact |
| 35:3559 | Error setting default plan as the plan has to be associated first |
| 35:3560 | At least one of the plans is in use |
| 35:3561 | Error setting plan |
| 35:3562 | Key Management Server |
| 35:3563 | Plan details cannot be retrieved. Please check logs for more details. |
| 35:3564 | User does not have rights on any plans. |
| 35:3565 | File <String> has been brought back from trash. |
| 35:3566 | Folder <String> has been brought back from trash. |
| 35:3567 | Promotion to default copy failed. Add at least one SVM mapping for the current default copy. |
| 35:3568 | Successfully connected to the server. The server doesn't require user authentication. |
| 35:3569 | Failed to connect to the server. |
| 35:3570 | Company |
| 35:3571 | Storage Policy Copy |
| 35:3572 | Unknown |
| 35:3573 | The link [<String>] which you have shared is expired and has been deleted.<String>Open<String> the file or folder. |
| 35:3574 | The link [<String>] which you have shared has expired and it will be deleted in [<String>] days. Click <String> here <String> to renew it if you want to continue sharing it.<String>Open<String> the file or folder. |
| 35:3575 | Failed to change the library name from [<String>] to [<String>]. . |
| 35:3576 | All folders |
| 35:3577 | Farm |
| 35:3578 | Cannot delete a configuration policy that is being used in Admin Console plan |
| 35:3579 | This client is associated to a case. Please delete the corresponding case from the Case Manager interface |
| 35:3580 | Drive [<String>] is a root directory on client [<String>]. Please provide empty sub-directory and try again. |
| 35:3581 | Insufficient memory [<String>] MB is specified for client [<String>]. Minimum required memory is [<String>] MB. |
| 35:3582 | Access Application |
| 35:3583 | Access Records |
| 35:3584 | Application |
| 35:3585 | AppStudio Application Form |
| 35:3586 | AppStudio Application Menu |
| 35:3587 | Change Application Schema |
| 35:3588 | Change Table Schema |
| 35:3589 | Create Application |
| 35:3590 | Create Table |
| 35:3591 | Table |
| 35:3592 | AppStudio Table Field |
| 35:3593 | $EMAIL_HEADER$<br/>Hello $RECIPIENT_NAME$,<br/><br/>An account has been created for you. Go to the $ADMINCONSOLE_URL$ and log on with the following credentials:<br/><br/> User Name: $USERNAME$<br/><br/> If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you,<br/><br/>$SIGNATURE$<br/>$EMAIL_FOOTER$ |
| 35:3594 | Your account is available |
| 35:3595 | Welcome,<br/><br/>$RECIPIENT_EMAIL$ has invited you to collaborate using Edge Drive.<br/><br/>Below are your log on credentials:<br/><br/>User Name: $USERNAME$<br />Password: $PASSWORD$<br/><br/>To get started with Edge Drive, visit <a href="Edge Drive">$WEBCONSOLE_URL$</a>. After you log on, we recommend changing your password by going to preferences. To learn more about <a href="Edge Drive">$WEBCONSOLE_URL$</a> click <a href="here">$EDGEDRIVE_HELP_URL$</a>.<br/><br/>Thank you,<br/>$RECIPIENT_NAME$ |
| 35:3596 | Welcome to Edge Drive: your credentials and next steps |
| 35:3597 | $EMAIL_HEADER$<br/>Hello $RECIPIENT_NAME$,<br/><br/>$RECIPIENT_EMAIL$ has been invited to use Edge Drive. A separate email with log on credentials to access Edge Drive has been sent to $RECIPIENT_EMAIL$.<br/><br/>Thank you,<br/>The Edge Drive Team |
| 35:3598 | $RECIPIENT_EMAIL$ has been invited to use Edge Drive |
| 35:3599 | $EMAIL_HEADER$<br/>Dear $RECIPIENT_NAME$,<br/><br/>Your password was reset on $PASSWORD_RESET_TIME$.<br/>Operating system: $OPERATING_SYSTEM$<br/>Browser: $BROWSER$<br/>IP address: $IP_ADDRESS$<br/>Estimated location: $LOCATION$<br/><br/>If you did this, you can safely disregard this email.<br/><br/>If you didn't do this, contact your <a href="mailto:$ADMINISTRATOR_EMAIL$">administrator</a>.<br/><br/>Sincerely,<br/><br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3600 | Your password has changed |
| 35:3601 | $EMAIL_HEADER$<br/>Dear User,<br/><br/>We have received a request to reset your password. Your user name and password cannot be managed inside Commvault software. Your credentials are managed by an external identity provider, such as LDAP or Active Directory. Please contact your <a href="mailto:$ADMINISTRATOR_EMAIL$">administrator</a> for help.<br/><br/>Sincerely,<br/><br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:3602 | Reset your password |
| 35:3603 | $EMAIL_HEADER$<br/>$CONTENT_TYPE$ [$CONTENT_NAME$] has been shared by $CONTENT_OWNER$.<br/><br/>To view the shared $CONTENT_TYPE$, click <a href="$CONTENT_LINK$">$CONTENT_NAME$</a><br/> $CONTENT_MESSAGE$<br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you |
| 35:3604 | $CONTENT_TYPE$ [$CONTENT_NAME$] has been shared by $CONTENT_OWNER$ |
| 35:3605 | Create domain user |
| 35:3606 | Email sent to the domain user when the user is created |
| 35:3607 | Invite user to Edge Drive |
| 35:3608 | Invite user and include Edge Drive credentials |
| 35:3609 | Email with credentials sent to the user when the user is new to Edge Drive |
| 35:3610 | Email sent to the share owner when the user being shared with is new to Edge Drive |
| 35:3611 | Reset password confirmation |
| 35:3612 | Confirmation email sent when a password is reset |
| 35:3613 | Reset password for a domain user |
| 35:3614 | Email sent to the domain user when the forgot password link is clicked |
| 35:3615 | Share content |
| 35:3616 | Email sent to users when content is shared with them using Edge Drive |
| 35:3617 | Queue jobs if conflicting jobs found setting at Server group level |
| 35:3618 | Failed to delete Storage Policy Copy [<String>] due to active job(s) [<String>]. Check Event Viewer for complete list of jobs. |
| 35:3619 | Failed to delete Storage Policy [<String>] due to active job(s) [<String>]. Check Event Viewer for complete list of jobs. |
| 35:3620 | Operation Priority |
| 35:3621 | Synth Full |
| 35:3622 | Failed to start Index server service on client [<String>]. Please check client logs for more details. |
| 35:3623 | Failed to stop Index server service on client [<String>]. Please check client logs for more details |
| 35:3624 | Client [<String>] is not reachable from Webserver [<String>]. Please check if all services are up and the network connection is working. |
| 35:3625 | Index server node [<String>] is not able to communicate with HAC cluster [<String>]. Please check if HAC cluster services are up and running. |
| 35:3626 | Index server url [<String>] is not up and running. Please check client [<String>] logs for more details. |
| 35:3627 | User [<String>] does not have Agent Management permission on client nodes. |
| 35:3628 | UNC path [<String>] is not supported. Please provide a local path. |
| 35:3629 | The specified memory [<String>] MB is more than the available memory on the client [<String>]. Please provide at least [<String>] MB memory and try again. |
| 35:3630 | Cannot remove user from Tenant Admin group. At least one user should be in this group. |
| 35:3631 | Public Link must be password protected. |
| 35:3632 | Please note that the share is password protected. You will receive a seperate email with the password. |
| 35:3633 | Password |
| 35:3634 | You have shared [<String>] <String>. |
| 35:3635 | Email template not found for the template type |
| 35:3636 | This Index server is associated to DC plans [<String>]. Please remove the association and try again. |
| 35:3637 | Download center is configured on Index server [<String>]. Please remove the association and try again |
| 35:3638 | This Index server is associated to edge clients [<String>]. Please remove the association and try again |
| 35:3639 | This Index server is associated to O365 clients [<String>]. Please remove the association and try again. |
| 35:3640 | This Index server is associated to data analytics schedules [<String>]. Please remove the association and try again. |
| 35:3641 | This Index server is associated to clients [<String>]. Please remove the association and try again |
| 35:3642 | This Index server is associated to log monitoring policies [<String>]. Please remove the association try again. |
| 35:3643 | This Index Server is associated with review sets [<String>] and cannot be deleted. Either delete the review sets or run the QS_ResetIndexServerForReviewSet qscript to disassociate the review sets. For details, go to the documentation website. |
| 35:3644 | Recipient(s) email address is not set, failed to send the email |
| 35:3645 | Recipient(s) email is not valid or SMTP mail server not able to send email to recipient(s) |
| 35:3646 | Failed to send email as no email is valid, please check recipient(s) emails |
| 35:3647 | Sender email information is not set, failed to send the email |
| 35:3648 | Failed to send email to SMTP Mail server, please check logs for more details |
| 35:3649 | Failed to send email as email size is greater than the maximum size allowed for SMTP Mail server |
| 35:3650 | SMTP Mail Server either not listening to given port number or port number is blocked. |
| 35:3651 | SMTP Mail Server rejected the socket connection |
| 35:3652 | SSL Encryption is enabled on SMTP mail server, failed to authenticate the connection |
| 35:3653 | Failed to send email, connection timed out. Try increasing the timeout for SMTP Mail Server |
| 35:3654 | TLS Encryption is enabled on SMTP mail server, failed to authenticate the connection |
| 35:3655 | Invalid Operation rule id-[<Number>] is specified. Please provide the correct Operation rule id. |
| 35:3656 | Operation failed. Tenant admin has not allowed client owners to enable privacy. |
| 35:3657 | Operation failed. Administrator needs to enable privacy settings to enable/disable privacy for company. |
| 35:3658 | Operation failed. Invalid organization information. |
| 35:3659 | Subclient Policy with [<String>] name already exists. |
| 35:3660 | Authorization code is not provided for Index server pool. Please contact your software provider to get authorization code. |
| 35:3661 | Invalid authorization code is provided for Index server pool. Please contact your software provider to get valid authorization code. |
| 35:3662 | Cannot run Synthetic Full Job on the subclient, since IBMi Save while active option is set to *SYNCLIB |
| 35:3663 | Clients by Index MA |
| 35:3664 | Exchange DAG |
| 35:3665 | MSSQL AG |
| 35:3666 | Oracle RAC |
| 35:3667 | Locale provided is not valid. |
| 35:3668 | Name change operation failed with a database error. Please refer to the EvMgrs.log for more details. |
| 35:3669 | Virtual lab operation failed with unknown error. Try this operation after some time. |
| 35:3670 | Activation failed. Please check if you have enabled settings to activate laptops with default plan. |
| 35:3671 | Activation failed. Local user is not allowed for activation. |
| 35:3672 | Activation failed. Need a valid user or an auth code to activate the laptop. |
| 35:3673 | Activation failed. An invalid auth code is associated with the laptop. |
| 35:3674 | Activation failed. User does not have rights to activate this laptop. |
| 35:3675 | Activation failed. An invalid auth code is associated with the laptop. |
| 35:3676 | Reactivation failed. Device is already activated with a user associated to a different plan. |
| 35:3677 | User is enabled as part of a laptop admin group and cannot be used to activate. |
| 35:3678 | Activation failed with a database error. Please try again later. |
| 35:3679 | Activation is not allowed for users in the restricted list. |
| 35:3680 | Device is already activated on the server. Completed updating laptop. |
| 35:3681 | Activation is not needed as no laptop plans are configured on CommServer. |
| 35:3682 | Activation failed with an error during creation of user centric client. |
| 35:3683 | Activation is attempted with auth code. Company settings requires valid user information to activate the laptop. |
| 35:3684 | Device is already activated. |
| 35:3685 | Device |
| 35:3686 | Device Controller |
| 35:3687 | Clients by OS Version |
| 35:3688 | Please use a different password as the previous [<Number>] passwords can't be reused. |
| 35:3689 | Failed to save Password History Count in CommServe database. |
| 35:3690 | Case Manager Index Copy |
| 35:3691 | Case Manager Reference Copy |
| 35:3692 | Index Extraction |
| 35:3693 | Block Level Operation |
| 35:3694 | Select VM Restore Destination Host |
| 35:3695 | PST Ingestion |
| 35:3696 | Exchange DAG client [<String>] is created in de-configured state as there is no available license of Class type [<Number>] |
| 35:3697 | Cannot delete Subclient policy [<String>], it is created by a plan [<String>]. |
| 35:3698 | Failed to set new Web Cache directory [<String>] on client [<String>] |
| 35:3699 | Email template with same name already exists. |
| 35:3700 | Email template type is not provided. |
| 35:3701 | An error occurred while performing the operation. |
| 35:3702 | Record was not found. |
| 35:3703 | None of job(s) picked are on magnetic media. |
| 35:3704 | The job(s) picked is/are bad. |
| 35:3705 | The given copy contains a tape datapath. |
| 35:3706 | Few of the jobs picked had data on tape media. |
| 35:3707 | One or more jobs could not be picked for refresh on Copy [<String>]. n Reason : <String> |
| 35:3708 | Create Role |
| 35:3709 | Delete Role |
| 35:3710 | Edit Role |
| 35:3711 | When users in this group install the laptop package, they cannot activate the laptop and they are not added as client owners. |
| 35:3712 | Access denied. The user does not have required capabilities to delete plan |
| 35:3713 | Plan is in use. Client '<String>' is associated with the plan |
| 35:3714 | Plan is in use. Clients '<String>' and '<String>' are associated with the plan |
| 35:3715 | Plan is in use. Clients '<String>', '<String>' and '<String>' are associated with the plan |
| 35:3716 | Plan is in use. Clients '<String>', '<String>', '<String>' and <Number> other clients are associated with the plan |
| 35:3717 | Plan is in use. Company '<String>' is associated with the plan |
| 35:3718 | Plan is in use. Companies '<String>' and '<String>' are associated with the plan |
| 35:3719 | Plan is in use. Companies '<String>', '<String>' and '<String>' are associated with the plan |
| 35:3720 | Plan is in use. Companies '<String>', '<String>', '<String>' and <Number> other companies are associated with the plan |
| 35:3721 | Plan is in use. Configuration policy '<String>' is associated with the plan |
| 35:3722 | Plan is in use. Configuration policies '<String>' and '<String>' are associated with the plan |
| 35:3723 | Plan is in use. Configuration policies '<String>', '<String>' and '<String>' are associated with the plan |
| 35:3724 | Plan is in use. Configuration policies '<String>', '<String>', '<String>' and <Number> other configuration policies are associated with the plan |
| 35:3725 | Plan is in use. Subclient '<String>' of client '<String>' is associated with the plan |
| 35:3726 | Plan is in use. Subclients '<String>' of client '<String>' and '<String>' of client '<String>' are associated with the plan |
| 35:3727 | Plan is in use. Subclients '<String>' of client '<String>', '<String>' of client '<String>' and '<String>' of client '<String>' are associated associated with the plan |
| 35:3728 | Plan is in use. Subclients '<String>' of client '<String>', '<String>' of client '<String>', '<String>' of client '<String>' and <Number> other subclients are associated with the plan |
| 35:3729 | Plan is in use. User '<String>' is associated with the plan |
| 35:3730 | Plan is in use. Users '<String>' and '<String>' are associated with the plan |
| 35:3731 | Plan is in use. Users '<String>', '<String>' and '<String>' are associated with the plan |
| 35:3732 | Plan is in use. Users '<String>', '<String>', '<String>' and <Number> other users are associated with the plan |
| 35:3733 | Plan serves as a base plan for derived plan '<String>' |
| 35:3734 | Plan serves as a base plan for derived plans '<String>' and '<String>' |
| 35:3735 | Plan serves as a base plan for derived plans '<String>', '<String>' and '<String>' |
| 35:3736 | Plan serves as a base plan for derived plans '<String>', '<String>', '<String>' and <Number> other plans |
| 35:3737 | Plan is default for company '<String>' |
| 35:3738 | Plan is default for companies '<String>' and '<String>' |
| 35:3739 | Plan is default for companies '<String>', <String>' and '<String>' |
| 35:3740 | Plan is default for companies '<String>', <String>', '<String>' and <Number> other companies |
| 35:3741 | MediaAgents with DDB Partitions |
| 35:3742 | The given copy does not have deduplication enabled. |
| 35:3743 | There are pending snap jobs for subclient [<String>] which need to be cataloged. Run Catalog Snapshots workflow job on storage policy [<String>] otherwise old jobs will not be cataloged. |
| 35:3744 | Two-Factor Authentication is enabled on this CommServe. Failed to email recipient [<String>]. |
| 35:3745 | Job is running for a longer time than expected. |
| 35:3746 | Job didn't get update from client for a very long time. |
| 35:3747 | Failed to delete client [<String>], it is created by a plan [<String>]. |
| 35:3748 | Cannot delete Role [<String>], it is created by a plan [<String>]. |
| 35:3749 | Array Administration |
| 35:3750 | Array Management |
| 35:3751 | Region Management |
| 35:3752 | Region |
| 35:3753 | Create Region |
| 35:3754 | Delete Region |
| 35:3755 | Edit Region |
| 35:3756 | One or more regions found with the same properties. |
| 35:3757 | Region not found. |
| 35:3758 | Unable to get network interfaces for array [<String>]. Not creating NAS client for this array. |
| 35:3759 | Company with same domain name already exists. |
| 35:3760 | Invalid role provided. |
| 35:3761 | Few of the jobs that were picked were on Active store. |
| 35:3762 | System created Tenant Operator role is missing in setup.System created Tenant Operator role is missing in setup. |
| 35:3763 | User [<String>] is not configured as operator for company [<String>]. |
| 35:3764 | "Prevent data block references for new backups" cannot be edited when BackSlasH"Disable mount path for new dataBackSlasH" is not selected. |
| 35:3765 | Invalid input passed for prevent data block references. |
| 35:3766 | Unable to clone the Subclient. Please retry in sometime. |
| 35:3767 | Add Domain |
| 35:3768 | Delete Domain |
| 35:3769 | Edit Domain |
| 35:3770 | Block level replication pair |
| 35:3771 | Hostname already exists |
| 35:3772 | Storage rule already present with the storage policy [<String>]. |
| 35:3773 | Storage Rule not found. |
| 35:3774 | Warning the DIAG_TableRowChangeTracking Table has exceeded 50,000 rows. |
| 35:3775 | Failed to delete storage policy copy [<String>]. Reason: [<String>]. |
| 35:3776 | Failed to delete storage policy [<String>]. Reason: [<String>]. |
| 35:3777 | Required packages are missing from Media Agent to complete configuration. |
| 35:3778 | Region with same name already exists. |
| 35:3779 | Name [<String>] already taken. Enter different name for credential. |
| 35:3780 | Exchange DAG client [<String>] is created in de-configured state as there is no available license of [Application Class 1] |
| 35:3781 | Failed to disable database addon for plan-[<String>] as some database subclients are associated with it. Please reassociate them to other plan and try again. |
| 35:3782 | Failed to disable snap addon for plan as some subclients with intellisnap enabled are associated with it. Please reassociate them to other plan and try again. |
| 35:3783 | Failover linked Commserv client |
| 35:3784 | Cannot delete region. Plan [<String>] is associated with this region. |
| 35:3785 | Two Factor Authentication |
| 35:3786 | Email sent to the user on login when two factor authentication is enabled |
| 35:3787 | Two Factor Authentication with secret key |
| 35:3788 | Email sent to the user on login with secret key when two factor authentication is enabled |
| 35:3789 | Login<br />$USERNAME_LOGIN$ or $USERNAME$<br /><br /> |
| 35:3790 | Dear user, <br/><br/>The server you are trying to log on to has Two-Factor Authentication enabled. As a security step, this feature requires a 6-digit PIN to be provided along with your password during log on. You can use the One Time PIN provided in this email to log on to the server. However, to generate new PINs, you must download the Commvault PIN Generator and use the Secret Key provided in this email (or sent to you earlier).<br/><br/>HOW TO USE THE PIN<br/>Simply specify the 6-digit PIN in the PIN field if available. If there is no dedicated PIN field, enter the 6-digit PIN immediately after your regular password in the password field.<br/><br/>Example with a dedicated PIN field:<br/>PIN Field: 123456<br/><br/>Example without a dedicated PIN field:<br/>Password Field: RegularPassword123456<br/><br/> |
| 35:3791 | One Time Pin (valid for next 30 minutes only)<br />$PIN$<br /><br /> |
| 35:3792 | Secret Key (case-insensitive)<br/>$SECRET_KEY$<br/><br/> |
| 35:3793 | SECRET <br />DO NOT share the Secret Key provided in this email with anyone else. Also, make sure to save this email in your records. The Secret Key must be provided in the Commvault PIN Generator app to generate a new PIN for each login. Note that each generated PIN is valid for only 30 seconds. <br /><br />COMMVAULT PIN GENERATOR <br />Find the details to download and use the App <a href="$PIN_GENERATOR_DOCUMENTATION_LINK$" style=color: #666666;>$PIN_GENERATOR_DOCUMENTATION_LINK$</a><br /><br /> |
| 35:3794 | Thank you, <br />CommServe Administrator<br /><br />If you did not attempt this login and received this email in error, please contact your administrator immediately. |
| 35:3795 | Cannot add associations between the subclient and selected DDB stores. |
| 35:3796 | Automatic pushing of packages on client failed as feature is disabled. Please enable the feature by changing DisableAutomaticPushInstall setting from additional settings. |
| 35:3797 | Automatic pushing of packages on client failed as feature is disabled. Please enable the feature by changing DisableLaptopAutomaticPushInstall setting from additional settings. |
| 35:3798 | Clients matching Region [<String>], AgentType [<String>] and ClientGroups [<String>] will be backed up on storage pool [<String>] for [<String>] days |
| 35:3799 | Proxy client selected for Network Share browse must be on 11.0 SP14 or higher. Please retry by selecting appropriate proxy client. |
| 35:3800 | Cannot remove user [<String>] from Tenant Admin group. At least one user should be in this group. |
| 35:3801 | MediaAgent associated to Storage Policy for log shipping Subclient |
| 35:3802 | No Server plan associated with any VM Group. Please assign server plan to VM group of this Hypervisor and try again. |
| 35:3803 | Failed to delete client [<String>]. It is associated to Content Analyzer cloud [<String>]. Please delete Content Analyzer cloud and try again. |
| 35:3804 | Invalid JobId. |
| 35:3805 | View RMAN logs operation failed. |
| 35:3806 | Error setting company Server group |
| 35:3807 | Failed to disable filesystem addon for plan-[<String>] as some filesystem subclients are associated with it. Please reassociate them to other plan and try again. |
| 35:3808 | Adding or deleting schedules is not allowed for this policy. |
| 35:3809 | Modification of associations to this policy is not allowed. |
| 35:3810 | Modification of pattern is not allowed for this policy. |
| 35:3811 | Access denied. User '<Number>' has no derivation capabilities on plan '<Number>'. |
| 35:3812 | Bad definition. Cross type inheritance is not allowed. |
| 35:3813 | Non-top level inheritance is not allowed. Plan '<Number>' is not top level plan. |
| 35:3814 | Base plan '<Number>' not found |
| 35:3815 | Bad definition. Base plan is sealed. |
| 35:3816 | Bad definition. Base plan type mismatch. Required type ' <Number> ', provided type '<Number>'. |
| 35:3817 | Incomplete plan definition. Base plan required |
| 35:3818 | Incomplete plan definition |
| 35:3819 | Plan '<String>' already exists |
| 35:3820 | "Backup on and After" date must be specified for selective copies. |
| 35:3821 | Deconfiguration of Instance [<String>] failed. |
| 35:3822 | Failed to deconfigure Instance. Jobs are still running. |
| 35:3823 | Deconfiguration of Instance [<String>] is successful. |
| 35:3824 | Invalid input provided. Please verify if the instance id is correct. |
| 35:3825 | Unknown Instance information. Please provide valid instance id to complete the operation. |
| 35:3826 | Unknown Instance information. Please provide valid instance name to complete the operation. |
| 35:3827 | Please consider running DDB backup for SIDB store <String> from <String>, during periods of low activity. |
| 35:3828 | DDB is being backed up for SIDB substore [<String>]. |
| 35:3829 | Possible causes :<ol> <String> </ol> |
| 35:3830 | DDB query and insert time exceeded threshold for SIDB substore [<String>]. |
| 35:3831 | Suggestions :<ol> <String> </ol> |
| 35:3832 | Web console report |
| 35:3833 | Default template for mailing webconsole reports |
| 35:3834 | $reportNotificationImage$<br><br> <p>$WEB_REPORT_FAILURE_STRING$</p> <a href="$WEB_REPORT_URL$" style="color:#2f4e66; font-family:Tahoma,verdana,arial,sans-serif; font-size: 24px;">$WEB_REPORT_TITLE$</a><br><br> <p>$WEB_REPORT_SCHEDULE_NAME$</p> <p style="font-size:90%;">$WEB_REPORT_UNSUBSCRIBE$ </p><br><p> $WEB_REPORT_CONTENT$</p> |
| 35:3835 | $WEB_REPORT_SUBJECT$ |
| 35:3836 | Invalid external user group information passed. |
| 35:3837 | Invalid provider information passed. |
| 35:3838 | Sync operation successfully completed. |
| 35:3839 | Failed to configure HAC Cluster |
| 35:3840 | Failed to configure HAC Cluster due to db error |
| 35:3841 | Failed to create HAC Cluster |
| 35:3842 | Failed to delete HAC Cluster |
| 35:3843 | Invalid HAC Cluster display name |
| 35:3844 | Failed to start HAC Cluster service on client [<String>]. Please check client logs for more details. |
| 35:3845 | Failed to stop HAC Cluster service on client [<String>]. Please check client logs for more details |
| 35:3846 | Invalid HAC Cluster cloudId |
| 35:3847 | HAC Cluster information is incomplete |
| 35:3848 | Invalid HAC Cluster type |
| 35:3849 | Failed to modify HAC Cluster |
| 35:3850 | HAC Cluster name / client name [<String>] already exists |
| 35:3851 | HAC Cluster node already exists |
| 35:3852 | Invalid HAC Cluster node clientid |
| 35:3853 | Failed to perform HAC Cluster node configuration |
| 35:3854 | Failed to modify HAC Cluster node settings |
| 35:3855 | Failed to perform HAC Cluster node operation |
| 35:3856 | Invalid HAC Cluster node operation |
| 35:3857 | Invalid HAC Cluster node properties |
| 35:3858 | Failed to deconfigure HAC Cluster node |
| 35:3859 | HAC Cluster node information is not provided |
| 35:3860 | HAC Cluster does not exists |
| 35:3861 | Failed to perform HAC Cluster operation. Please check logs for more details. |
| 35:3862 | Region is not tagged to the client. Please tag it. |
| 35:3863 | Clients owned by users in usergroup list |
| 35:3864 | One or more laptops are not associated with a region. Associate the laptop with a region and try again. |
| 35:3865 | Laptop activation is pending because the laptop is not associated with a region. Associate the laptop with a region and try again. |
| 35:3866 | Associating the subclient to the plan is pending because the server is not associated with a region. Associate the server with a region and try again. |
| 35:3867 | Clients owned by users in usergroup list |
| 35:3868 | Client IPV6 CIDR Address Range |
| 35:3869 | Reconfiguration of Instance [<String>] failed. |
| 35:3870 | Reconfiguration of Instance [<String>] is successful. |
| 35:3871 | Invalid or missing destination library |
| 35:3872 | Invalid or missing destination location |
| 35:3873 | Invalid or missing transit location |
| 35:3874 | Invalid or missing VaultTracker Policy |
| 35:3875 | Failed to set copy [<String>] to primary due to running jobs [<String>]. |
| 35:3876 | Unable to change copy properties because auxiliary copy, data verification, offline content indexing, data analytics or media refresh jobs are running for the storage policy copy. Running jobs [<String>]. |
| 35:3877 | The [<String>] plan is an Elastic Plan. To select this plan, associate the client to a region. |
| 35:3878 | Plan does not contain storage configuration for client's region. |
| 35:3879 | Cannot create/modify user properties of a deactivated company |
| 35:3880 | Default backup copy schedule creation failed for storage policy [<String>] |
| 35:3881 | Default backup copy schedule deletion failed for storage policy [<String>] |
| 35:3882 | Disabling default backup copy schedule failed for storage policy [<String>] |
| 35:3883 | Enabling default backup copy schedule failed for storage policy [<String>] |
| 35:3884 | This is a system created region and cannot be deleted. |
| 35:3885 | This is a system created region and cannot be modified. |
| 35:3886 | Incorrect location information. Location information should have country specified. |
| 35:3887 | There should be at least one location associated to the region. |
| 35:3888 | Storage Pool |
| 35:3889 | Error processing wildcard DIP with interfaces [<String>], [2^%s] |
| 35:3890 | Error update wildcard DIP with interfaces. Old source interface : [<String>], old destination interface : [2^%s]. New source interface : [<String>], new destination interface : [<String>]. |
| 35:3891 | Data Port [<String>] is already in use by client [<String>]. Please try with different port. |
| 35:3892 | Election port [<String>] is already in use by client [<String>]. Please try with different port. |
| 35:3893 | Listener Port [<String>] is already in use by client [<String>]. Please try with different port. |
| 35:3894 | File server interface [<String>] may be inaccessible or doesn't support browsing shares. |
| 35:3895 | File server interface [<String>] may be inaccessible or doesn't support browsing shares as user [<String>]. Please verify that the server interface is accessible, and the user credentials are correct. |
| 35:3896 | File server interface [<String>] may be inaccessible or doesn't support browsing shares. Please verify that the server interface is accessible, and the shares are exported. |
| 35:3897 | Client belongs to a deactivated company |
| 35:3898 | User creation not allowed for deactivated company. |
| 35:3899 | Cannot enable user of a deactivated company. |
| 35:3900 | Please deactivate company and then try again. |
| 35:3901 | Current version of the command line server is not supported. |
| 35:3902 | Failed to validate the challenge from RADIUS server. |
| 35:3903 | Failed to disable index copy addon for plan-[<String>] as some case manager subclients are associated with it. Please reassociate them to other plan and try again. |
| 35:3904 | Selected Cloud Controller should have at least one non power managed proxy. |
| 35:3905 | Server group [<String>] already exists. |
| 35:3906 | Invalid value set for DDB availability setting [Minimum number of partitions for jobs to run]. |
| 35:3907 | Cannot delete library as it is being used for dedup metadata caching by following libraries [<String>]. |
| 35:3908 | Users of a deactivated company cannot be activated. |
| 35:3909 | Delete Files |
| 35:3910 | Change Permission |
| 35:3911 | Cannot delete region. <String> [<String>] is associated with this region. |
| 35:3912 | client(s) |
| 35:3913 | plan(s) |
| 35:3914 | VM Group(s) |
| 35:3915 | DDB disk is not configured properly. |
| 35:3916 | Failed to start Monitoring service on client [<String>]. Please check client logs for more details. |
| 35:3917 | Failed to stop Monitoring service on client [<String>]. Please check client logs for more details |
| 35:3918 | If the infrastructure type is hybrid, then you cannot reset it to any other value. |
| 35:3919 | If the infrastructure type is own, then you can only reset it to hybrid. |
| 35:3920 | 'Pick data from running jobs' feature is not supported if source copy has tape data paths. |
| 35:3921 | Invalid encryption combination. Both encrypt on dependent primary and re-encrypt on auxcopy should be enabled/disabled for GDSP. |
| 35:3922 | File Archiver license is not available, unable to set retention mode. |
| 35:3923 | Commcell Group |
| 35:3924 | Server group Description |
| 35:3925 | Discover Rules |
| 35:3926 | DLP Properties |
| 35:3927 | Server group Name |
| 35:3928 | Region |
| 35:3929 | Storage Policy |
| 35:3930 | Failed to set [<String>] properties as user [<String>] does not have [<String>] rights on [<String>]:[<String>]. |
| 35:3931 | Error setting plan. Plan '<String>' is owned by another company. |
| 35:3932 | Error setting plans. Plans '<String>' are owned by other companies. |
| 35:3933 | Use Proxy |
| 35:3934 | Operation failed: The Log Storage Policy specified for this Storage Policy is Invalid. |
| 35:3935 | Secondary copy for an IBM i VTL storage policy should have an IBM VTL data path. |
| 35:3936 | Creating secondary copies with multiplexing is not allowed for IBM i VTL storage policy. |
| 35:3937 | Could not find any magnetic data path. |
| 35:3938 | Client is not ready. Reason: <Message> |
| 35:3939 | To disassociate a plan from the company, company client(s) has to be disassociated from the plan |
| 35:3940 | New plan not provided in the request |
| 35:3941 | Unsupported plan operation type |
| 35:3942 | Frequency type not supported for the system created schedule/schedule policy. |
| 35:3943 | No associated entities found for the plan. |
| 35:3944 | SMTP Server is not configured, Email notifications cannot be sent. |
| 35:3945 | Index Delete |
| 35:3946 | Unable to make Live Sync configuration changes on client [<String>]. Client may be offline. |
| 35:3947 | Reshare owner |
| 35:3948 | Email sent to immediate share owner when any user re-shares it |
| 35:3949 | $EMAIL_HEADER$<br/>$CONTENT_OWNER$ re-shared the [$CONTENT_NAME_PARENT$] $CONTENT_TYPE$ as [$CONTENT_NAME$].<br/><br/>To view the shared $CONTENT_TYPE$, click <a href="$CONTENT_LINK$">$CONTENT_NAME$</a><br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you |
| 35:3950 | $CONTENT_OWNER$ re-shared the [$CONTENT_NAME_PARENT$] $CONTENT_TYPE$ as [$CONTENT_NAME$] |
| 35:3951 | File |
| 35:3952 | Folder |
| 35:3953 | Share owner |
| 35:3954 | Email sent to the share owner when user is added or removed |
| 35:3955 | $EMAIL_HEADER$<br/>You have shared the [$CONTENT_NAME$] $CONTENT_TYPE$ with additional users<br/><br/>$SHARE_USERS$<br/><br/>To view the shared $CONTENT_TYPE$, click <a href="$CONTENT_LINK$">$CONTENT_NAME$</a><br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you |
| 35:3956 | Share password |
| 35:3957 | Email sent to users with share credentials for public link/share |
| 35:3958 | $EMAIL_HEADER$<br/>$CONTENT_TYPE$ [$CONTENT_NAME$] has been shared by $CONTENT_OWNER$.<br/><br/>Please use password $SHARE_PASSWORD$ to view the share.<br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you |
| 35:3959 | Failed to delete client [<String>]. It is associated to HAC Cluster [<String>]. Please delete HAC Cluster and retry. |
| 35:3960 | Delete Client |
| 35:3961 | Failed to get availability groups from primary replica. Verify that services are online and an availability group is configured on this SQL instance. |
| 35:3962 | Failed to get replica information of Availability group. |
| 35:3963 | Idle |
| 35:3964 | Inactive |
| 35:3965 | Network Topology |
| 35:3966 | Operation failed. User is not an owner of this client. |
| 35:3967 | Restore authorization is expired for client. Please provide passkey or authorize the client for restore. |
| 35:3968 | Passkey is incorrect. Please provide valid passkey to continue with the operation. |
| 35:3969 | User does not have delete client capability. |
| 35:3970 | Client is not ready. Physical Client [<Number>][<String>]. Reason: <Message> |
| 35:3971 | Tenant Operators are restricted from browsing the locked company data. |
| 35:3972 | Only tenant admins/users are allowed to browse the locked company data. |
| 35:3973 | Failed to delete the client. Delete the association of client [<String>] with VSA pseudo client(s) [<String>] and retry. |
| 35:3974 | Invalid authcode. |
| 35:3975 | Failed to create availability groups for instance [<String>]. Verify that services are online and with the correct user name and password. Verify that User Account Configuration requirements from <String> are followed. If User Account Configuration is correct, then it is likely that a pending machine reboot is preventing the configuration from taking effect and rebooting the machine can help. |
| 35:3976 | Backup type not supported for the system created schedule/schedule policy. |
| 35:3977 | Create Storage Policy Copy |
| 35:3978 | Create Storage Policy |
| 35:3979 | Backed up data is not aged. Unable to delete client:[<String>]. |
| 35:3980 | Successfully Retired client [<String>]. |
| 35:3981 | Client Name |
| 35:3982 | Client Display Name |
| 35:3983 | Pseudo Clients |
| 35:3984 | Change Ownership |
| 35:3985 | Operation is not supported on the System created backup schedule policy for failover. |
| 35:3986 | Operation is not supported on the System created Live Sync schedule for failover. |
| 35:3987 | Deleting System created transaction log schedule is not allowed for this schedule policy. |
| 35:3988 | CommCell Pseudo Client |
| 35:3989 | The path [<String>] specified is invalid - MediaAgent [<String>]. |
| 35:3990 | Failed to enable indexing as job [<Number>] has failed to install required packages. Please install Advanced Indexing Pack manually on Media agents and try again. |
| 35:3991 | The infrastructure for indexing is being set up. Please wait until job(s) [<String>] are finished. |
| 35:3992 | Manually install Advanced Indexing Pack on client(s) [<String>] and try again. |
| 35:3993 | Automatic installation of packages is disabled. Please install Advanced Indexing Pack manually on Media agents and try again. |
| 35:3994 | Company Name |
| 35:3995 | Africa |
| 35:3996 | ap-northeast-1 |
| 35:3997 | Asia Pacific (Tokyo) |
| 35:3998 | ap-northeast-2 |
| 35:3999 | Asia Pacific (Seoul) |
| 35:4000 | ap-northeast-3 |
| 35:4001 | Asia Pacific (Osaka) |
| 35:4002 | ap-south-1 |
| 35:4003 | Asia Pacific (Mumbai) |
| 35:4004 | ap-southeast-1 |
| 35:4005 | Asia Pacific (Singapore) |
| 35:4006 | ap-southeast-2 |
| 35:4007 | Asia Pacific (Sydney) |
| 35:4008 | Asia |
| 35:4009 | Australia |
| 35:4010 | australiacentral |
| 35:4011 | australiacentral2 |
| 35:4012 | Australia Central 2 |
| 35:4013 | Australia Central |
| 35:4014 | australiaeast |
| 35:4015 | Australia East |
| 35:4016 | australiasoutheast |
| 35:4017 | Australia Southeast |
| 35:4018 | brazilsouth |
| 35:4019 | Brazil South |
| 35:4020 | ca-central-1 |
| 35:4021 | Canada (Central) |
| 35:4022 | canadacentral |
| 35:4023 | Canada Central |
| 35:4024 | canadaeast |
| 35:4025 | Canada East |
| 35:4026 | centralindia |
| 35:4027 | Central India |
| 35:4028 | centralus |
| 35:4029 | Central US |
| 35:4030 | China East |
| 35:4031 | China East 2 |
| 35:4032 | China East 2 (Shanghai) |
| 35:4033 | China East (Shanghai) |
| 35:4034 | China North |
| 35:4035 | China North 2 |
| 35:4036 | China North 2 (Beijing) |
| 35:4037 | China North (Beijing) |
| 35:4038 | cn-north-1 |
| 35:4039 | China (Beijing) (cn-north-1) |
| 35:4040 | cn-northwest-1 |
| 35:4041 | China (Ningxia) (cn-northwest-1) |
| 35:4042 | Africa |
| 35:4043 | Asia |
| 35:4044 | Australia |
| 35:4045 | Europe |
| 35:4046 | North America |
| 35:4047 | eastasia |
| 35:4048 | East Asia |
| 35:4049 | eastus |
| 35:4050 | eastus2 |
| 35:4051 | East US 2 |
| 35:4052 | East US |
| 35:4053 | eu-central-1 |
| 35:4054 | Europe (Frankfurt) |
| 35:4055 | eu-west-1 |
| 35:4056 | Europe (Ireland) |
| 35:4057 | eu-west-2 |
| 35:4058 | Europe (London) |
| 35:4059 | eu-west-3 |
| 35:4060 | Europe (Paris) |
| 35:4061 | Europe |
| 35:4062 | francecentral |
| 35:4063 | France Central |
| 35:4064 | francesouth |
| 35:4065 | France South |
| 35:4066 | Germany Central |
| 35:4067 | Germany Central (Frankfurt) |
| 35:4068 | Germany Northeast |
| 35:4069 | Germany Northeast (Magdeburg) |
| 35:4070 | japaneast |
| 35:4071 | Japan East |
| 35:4072 | japanwest |
| 35:4073 | Japan West |
| 35:4074 | koreacentral |
| 35:4075 | Korea Central |
| 35:4076 | koreasouth |
| 35:4077 | Korea South |
| 35:4078 | North America |
| 35:4079 | northcentralus |
| 35:4080 | North Central US |
| 35:4081 | northeurope |
| 35:4082 | North Europe |
| 35:4083 | sa-east-1 |
| 35:4084 | South America (Sao Paulo) |
| 35:4085 | South America |
| 35:4086 | southcentralus |
| 35:4087 | South Central US |
| 35:4088 | southindia |
| 35:4089 | South India |
| 35:4090 | southeastasia |
| 35:4091 | Southeast Asia |
| 35:4092 | uksouth |
| 35:4093 | UK South |
| 35:4094 | ukwest |
| 35:4095 | UK West |
| 35:4096 | US DoD Central |
| 35:4097 | US DoD Central (Iowa) |
| 35:4098 | US DoD East |
| 35:4099 | US DoD East (Virginia) |
| 35:4100 | us-east-1 |
| 35:4101 | US East (N. Virginia) |
| 35:4102 | us-east-2 |
| 35:4103 | US East (Ohio) |
| 35:4104 | US Gov Arizona |
| 35:4105 | US Gov Iowa |
| 35:4106 | US Gov Texas |
| 35:4107 | US Gov Virginia |
| 35:4108 | us-west-1 |
| 35:4109 | US West (N. California) |
| 35:4110 | us-west-2 |
| 35:4111 | US West (Oregon) |
| 35:4112 | westcentralus |
| 35:4113 | West Central US |
| 35:4114 | westeurope |
| 35:4115 | West Europe |
| 35:4116 | westindia |
| 35:4117 | West India |
| 35:4118 | westus |
| 35:4119 | westus2 |
| 35:4120 | West US 2 |
| 35:4121 | West US |
| 35:4122 | Afghanistan |
| 35:4123 | Albania |
| 35:4124 | Algeria |
| 35:4125 | Andorra |
| 35:4126 | Angola |
| 35:4127 | Anguilla |
| 35:4128 | Antigua and Barbuda |
| 35:4129 | Argentina |
| 35:4130 | Arizona |
| 35:4131 | Armenia |
| 35:4132 | Australia |
| 35:4133 | Austria |
| 35:4134 | Azerbaijan |
| 35:4135 | Bahamas |
| 35:4136 | Bahrain |
| 35:4137 | Bangladesh |
| 35:4138 | Barbados |
| 35:4139 | Beijing |
| 35:4140 | Belarus |
| 35:4141 | Belgium |
| 35:4142 | Belize |
| 35:4143 | Benin |
| 35:4144 | Bermuda |
| 35:4145 | Bhutan |
| 35:4146 | Bolivia |
| 35:4147 | Bosnia and Herzegovina |
| 35:4148 | Botswana |
| 35:4149 | Brazil |
| 35:4150 | Brunei |
| 35:4151 | Bulgaria |
| 35:4152 | Burkina Faso |
| 35:4153 | Burundi |
| 35:4154 | Busan |
| 35:4155 | California |
| 35:4156 | Cambodia |
| 35:4157 | Cameroon |
| 35:4158 | Canada |
| 35:4159 | Canberra |
| 35:4160 | Cape Verde |
| 35:4161 | Cardiff |
| 35:4162 | Central African Republic |
| 35:4163 | Chad |
| 35:4164 | Chennai |
| 35:4165 | Chile |
| 35:4166 | China |
| 35:4167 | Colombia |
| 35:4168 | Comoros |
| 35:4169 | Costa Rica |
| 35:4170 | Croatia |
| 35:4171 | Cuba |
| 35:4172 | Cyprus |
| 35:4173 | Czech Republic |
| 35:4174 | Democratic Republic of the Congo |
| 35:4175 | Denmark |
| 35:4176 | Djibouti |
| 35:4177 | Dominica |
| 35:4178 | Dominican Republic |
| 35:4179 | East Timor |
| 35:4180 | Ecuador |
| 35:4181 | Egypt |
| 35:4182 | El Salvador |
| 35:4183 | Equatorial Guinea |
| 35:4184 | Eritrea |
| 35:4185 | Estonia |
| 35:4186 | Ethiopia |
| 35:4187 | Fiji |
| 35:4188 | Finland |
| 35:4189 | France |
| 35:4190 | Frankfurt |
| 35:4191 | Gabon |
| 35:4192 | Gambia |
| 35:4193 | Georgia |
| 35:4194 | Germany |
| 35:4195 | Ghana |
| 35:4196 | Greece |
| 35:4197 | Greenland |
| 35:4198 | Grenada |
| 35:4199 | Guadeloupe |
| 35:4200 | Guam |
| 35:4201 | Guatemala |
| 35:4202 | Guinea |
| 35:4203 | Guinea Bissau |
| 35:4204 | Guyana |
| 35:4205 | Haiti |
| 35:4206 | Honduras |
| 35:4207 | Hong Kong |
| 35:4208 | Hungary |
| 35:4209 | Iceland |
| 35:4210 | Illinois |
| 35:4211 | India |
| 35:4212 | Indonesia |
| 35:4213 | Iowa |
| 35:4214 | Iran |
| 35:4215 | Iraq |
| 35:4216 | Ireland |
| 35:4217 | Israel |
| 35:4218 | Italy |
| 35:4219 | Ivory Coast |
| 35:4220 | Jamaica |
| 35:4221 | Japan |
| 35:4222 | Jordan |
| 35:4223 | Kazakhstan |
| 35:4224 | Kenya |
| 35:4225 | Kiribati |
| 35:4226 | Kosovo |
| 35:4227 | Kuwait |
| 35:4228 | Kyrgyzstan |
| 35:4229 | Laos |
| 35:4230 | Latvia |
| 35:4231 | Lebanon |
| 35:4232 | Lesotho |
| 35:4233 | Liberia |
| 35:4234 | Libya |
| 35:4235 | Liechtenstein |
| 35:4236 | Lithuania |
| 35:4237 | London |
| 35:4238 | Luxembourg |
| 35:4239 | Macau |
| 35:4240 | Macedonia |
| 35:4241 | Madagascar |
| 35:4242 | Magdeburg |
| 35:4243 | Malawi |
| 35:4244 | Malaysia |
| 35:4245 | Maldives |
| 35:4246 | Mali |
| 35:4247 | Malta |
| 35:4248 | Marseille |
| 35:4249 | Marshall Islands |
| 35:4250 | Mauritania |
| 35:4251 | Mauritius |
| 35:4252 | Mexico |
| 35:4253 | Micronesia |
| 35:4254 | Moldova |
| 35:4255 | Monaco |
| 35:4256 | Mongolia |
| 35:4257 | Montenegro |
| 35:4258 | Montserrat |
| 35:4259 | Morocco |
| 35:4260 | Mozambique |
| 35:4261 | Mumbai |
| 35:4262 | Myanmar |
| 35:4263 | Namibia |
| 35:4264 | Nauru |
| 35:4265 | Nepal |
| 35:4266 | Netherlands |
| 35:4267 | New Caledonia |
| 35:4268 | New South Wales |
| 35:4269 | New Zealand |
| 35:4270 | Nicaragua |
| 35:4271 | Niger |
| 35:4272 | Nigeria |
| 35:4273 | Ningxia |
| 35:4274 | Niue |
| 35:4275 | Norfolk Island |
| 35:4276 | North Korea |
| 35:4277 | Norway |
| 35:4278 | Ohio |
| 35:4279 | Oman |
| 35:4280 | Oregon |
| 35:4281 | Osaka |
| 35:4282 | Pakistan |
| 35:4283 | Palau |
| 35:4284 | Palestine |
| 35:4285 | Panama |
| 35:4286 | Papua New Guinea |
| 35:4287 | Paraguay |
| 35:4288 | Paris |
| 35:4289 | Peru |
| 35:4290 | Philippines |
| 35:4291 | Poland |
| 35:4292 | Portugal |
| 35:4293 | Puerto Rico |
| 35:4294 | Pune |
| 35:4295 | Qatar |
| 35:4296 | Quebec City |
| 35:4297 | Republic of Congo |
| 35:4298 | Romania |
| 35:4299 | Russia |
| 35:4300 | Rwanda |
| 35:4301 | Saint Kitts and Nevis |
| 35:4302 | Saint Lucia |
| 35:4303 | Saint Vincent and the Grenadines |
| 35:4304 | Saitama |
| 35:4305 | Samoa |
| 35:4306 | San Marino |
| 35:4307 | Sao Paulo |
| 35:4308 | sao tome and principe |
| 35:4309 | Saudi Arabia |
| 35:4310 | Senegal |
| 35:4311 | Seoul |
| 35:4312 | Serbia |
| 35:4313 | Seychelles |
| 35:4314 | Shanghai |
| 35:4315 | Sierra Leone |
| 35:4316 | Singapore |
| 35:4317 | Slovakia |
| 35:4318 | Slovenia |
| 35:4319 | Solomon Islands |
| 35:4320 | Somalia |
| 35:4321 | South Africa |
| 35:4322 | South Korea |
| 35:4323 | South Sudan |
| 35:4324 | Spain |
| 35:4325 | Sri Lanka |
| 35:4326 | Arizona |
| 35:4327 | Bouches-du-Rhone |
| 35:4328 | Busan |
| 35:4329 | California |
| 35:4330 | England |
| 35:4331 | Illinois |
| 35:4332 | Iowa |
| 35:4333 | Maharashtra |
| 35:4334 | New South Wales |
| 35:4335 | Ohio |
| 35:4336 | Ontario |
| 35:4337 | Oregon |
| 35:4338 | Quebec |
| 35:4339 | Tamil Nadu |
| 35:4340 | Texas |
| 35:4341 | Victoria |
| 35:4342 | Virginia |
| 35:4343 | Wales |
| 35:4344 | Washington |
| 35:4345 | Wyoming |
| 35:4346 | Sudan |
| 35:4347 | Suriname |
| 35:4348 | Swaziland |
| 35:4349 | Sweden |
| 35:4350 | Switzerland |
| 35:4351 | Sydney |
| 35:4352 | Syria |
| 35:4353 | Taiwan |
| 35:4354 | Tajikistan |
| 35:4355 | Tanzania |
| 35:4356 | Texas |
| 35:4357 | Thailand |
| 35:4358 | Togo |
| 35:4359 | Tokelau |
| 35:4360 | Tokyo |
| 35:4361 | Tonga |
| 35:4362 | Toronto |
| 35:4363 | Trinidad and Tobago |
| 35:4364 | Tunisia |
| 35:4365 | Turkey |
| 35:4366 | Turkmenistan |
| 35:4367 | Tuvalu |
| 35:4368 | Uganda |
| 35:4369 | Ukraine |
| 35:4370 | United Arab Emirates |
| 35:4371 | United Kingdom |
| 35:4372 | United States |
| 35:4373 | Uruguay |
| 35:4374 | Uzbekistan |
| 35:4375 | Vanuatu |
| 35:4376 | Vatican City |
| 35:4377 | Venezuela |
| 35:4378 | Victoria |
| 35:4379 | Vietnam |
| 35:4380 | Virginia |
| 35:4381 | Washington |
| 35:4382 | Wyoming |
| 35:4383 | Yemen |
| 35:4384 | Zambia |
| 35:4385 | Zimbabwe |
| 35:4386 | An existing admin client cannot be marked as tenant. |
| 35:4387 | Invalid index server clientId |
| 35:4388 | Invalid role name is provided |
| 35:4389 | Invalid storage policy id is provided |
| 35:4390 | There is no mediaagent available to configure cloud index server. Please install a new mediaagent and add it to datapath of the associated storage policy primary copy |
| 35:4391 | Success |
| 35:4392 | File indexing is enabled on VM Group [<String>]. Please disable it and try again. |
| 35:4393 | User passkey doesn't follow minimum complexity requirements. Minimum passkey length has to be 8 characters and it should have at least 1 lowercase letters, 1 uppercase letters, 1 numbers, 1 special characters. |
| 35:4394 | User passkey doesn't follow minimum complexity requirements. Minimum passkey length has to be 8 characters and it should have at least 2 lowercase letters, 2 uppercase letters, 2 numbers, 2 special characters. |
| 35:4395 | Move directory is in progress. |
| 35:4396 | There are no MediaAgents available to configure for cloud index servers. Ensure that at least one MediaAgent is online, associated to the storage policy data path, and not already associated to a standalone index server. |
| 35:4397 | Client version v11 and feature release |
| 35:4398 | Failed to determine SQL instance on passive node [<String>]. Restart Services on the second instance of passive node and try again. |
| 35:4399 | Suspended as part of MediaAgent[<String>] deletion. |
| 35:4400 | The entity name contains unsupported control characters. |
| 35:4401 | Name change operation has been successfully submitted.nnIf client is offline, name change will be completed automatically once client comes online. |
| 35:4402 | Criteria matched for monitoring policy [<String>]. Description: [<String>] |
| 35:4403 | Cannot add a new client. The selected array already has a configured client [<String>]. |
| 35:4404 | Cannot add client for array [<String>]. The array vendor [<String>] does not match the selected client vendor [<String>]. |
| 35:4405 | Failed to configure the index server for file indexing. For more details, see the logs. |
| 35:4406 | File Indexing |
| 35:4407 | Creation of NFS ObjectStore failed. Please check logs for more details. |
| 35:4408 | Clients associated to AD User Group |
| 35:4409 | Clients with Agents associated to AD User Groups |
| 35:4410 | Failed to get database files information while retrieving the restore options for the database. |
| 35:4411 | Jobs in this storage policy [<String>] copy [<String>] have been submitted for deletion. This copy now becomes inactive and will be deleted after all snapshots and related OCUM entries have been physically deleted. Make sure that OCUM server is associated with at least one access node that has connectivity to the OCUM server. |
| 35:4412 | Jobs in this storage policy [<String>] have been submitted for deletion. This policy now becomes hidden and will be deleted after all snapshots and related OCUM entries have been physically deleted. Make sure that OCUM server is associated with at least one access node that has connectivity to the OCUM server. |
| 35:4413 | Failed to set member servers. Please ensure that the assigned member servers or groups have Virtual Server packages installed. |
| 35:4414 | DDB Space Reclamation |
| 35:4415 | Selected content [<String>] or part of it is already included in backup as part of the instance. Select different content for the subclient. |
| 35:4416 | Case Manager Client |
| 35:4417 | Create Company |
| 35:4418 | Application Command Line Restore |
| 35:4419 | Invalid input request. Specify valid client or Server group details. |
| 35:4420 | Client Online in Last N Days |
| 35:4421 | Access policies collection |
| 35:4422 | Database add-on |
| 35:4423 | File system add-on |
| 35:4424 | Snap add-on |
| 35:4425 | Alerts set |
| 35:4426 | Analytics engine |
| 35:4427 | Server group |
| 35:4428 | Content analyzer |
| 35:4429 | Content indexing policy |
| 35:4430 | Edge drive |
| 35:4431 | External user group(s) |
| 35:4432 | Entity extraction policy |
| 35:4433 | Features set |
| 35:4434 | Index copy schedule policy |
| 35:4435 | Internal user group(s) |
| 35:4436 | Mailbox archiving policy |
| 35:4437 | Mailbox cleanup policy |
| 35:4438 | Mailbox journaling policy |
| 35:4439 | Mailbox retention policy |
| 35:4440 | Office 365 backup policy |
| 35:4441 | Office 365 clean up policy |
| 35:4442 | Office 365 retention policy |
| 35:4443 | Options set |
| 35:4444 | Replication target |
| 35:4445 | Schedule policy |
| 35:4446 | Log schedule policy |
| 35:4447 | Storage policy |
| 35:4448 | Log storage policy |
| 35:4449 | Storage rules |
| 35:4450 | Linux subclient policy content definition |
| 35:4451 | Mac subclient policy content definition |
| 35:4452 | Windows subclient policy content definition |
| 35:4453 | Subclient policy |
| 35:4454 | Linux subclient policy |
| 35:4455 | Mac subclient policy |
| 35:4456 | Windows subclient policy |
| 35:4457 | Linux subclient policy retention definition |
| 35:4458 | Mac subclient policy retention definition |
| 35:4459 | Windows subclient policy retention definition |
| 35:4460 | Users and user group(s) |
| 35:4461 | Unable to activate laptop [<String>]. Contact your administrator to activate the laptop. |
| 35:4462 | NFS Server [<String>] is not reachable, cannot create NFS ObjectStore at this time. |
| 35:4463 | Linux subclient policy archival rules definition |
| 35:4464 | Windows subclient policy archival rules definition |
| 35:4465 | Failed to connect to the array[<String>]. Please make sure Array Access Node is configured and array is reachable from that node. |
| 35:4466 | License has been released for client [<String>]. |
| 35:4467 | MediaAgent is part of HyperScale storage pool. |
| 35:4468 | Please add the user manually before logging in when two-factor authentication is enabled. |
| 35:4469 | Two-factor authentication cannot be used along with Access challenge in Radius login |
| 35:4470 | At least one schedule is required to update schedule policy. |
| 35:4471 | You cannot delete this schedule as it is associated to a backup plan RPO. You must first delete the associated backup plan. |
| 35:4472 | Failed to send the request to the client. |
| 35:4473 | Operation not supported at the client feature release level, please update the client to the most recent feature release. |
| 35:4474 | Failed to decompress the log file. |
| 35:4475 | Failed to create temporary folder to decompress the log file. |
| 35:4476 | Failed to delete the temporary files and folders after decompressing the log file. Please clean the temporary files and folders manually. |
| 35:4477 | Invalid response received from the client. |
| 35:4478 | Failed to read the registry to get the log file path. |
| 35:4479 | Failed to open and read the log file. |
| 35:4480 | Client details are missing in the request. |
| 35:4481 | Log file details are missing in the request. |
| 35:4482 | Failed to receive response from the client. |
| 35:4483 | Unable to get the physical client details from Access Node. |
| 35:4484 | Failed to delete MediaAgent. It is a part of index server pool [<String>].Please delete index server pool and try again |
| 35:4485 | VM Admin Job(Backup) |
| 35:4486 | VM Admin Job(Backup Copy) |
| 35:4487 | VM Admin Job(Snap Backup) |
| 35:4488 | VM Admin Job(Synthetic Full) |
| 35:4489 | Server group : [<String>] Client : [<String>] Agent Type : [<String>] |
| 35:4490 | Server group : [<String>] Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] |
| 35:4491 | Server group : [<String>] Client : [<String>] Agent Type : [<String>] Instance : [<String>] |
| 35:4492 | Server group : [<String>] Client : [<String>] Agent Type : [<String>] Instance : [<String>] BackupSet: [<String>] SubClient : [<String>] |
| 35:4493 | [<String>] is not a valid virtual machine(s). |
| 35:4494 | [<String>] is not a valid plan(s). |
| 35:4495 | User does not have [<String>] rights on client(s)-[<String>]. |
| 35:4496 | User does not have [<String>] rights on plan(s)-[<String>]. |
| 35:4497 | Snap jobs pending catalog in previous storage policy were disabled as part of this reassociation. Check GUI audit trail for details. |
| 35:4498 | Snap jobs pending catalog for subclient [<String>] in storage policy [<String>] were disabled as part of this reassociation. Check GUI audit trail for details. |
| 35:4499 | $EMAIL_HEADER$<br/>Your request to export <b>[$CONTENT_NAME$]</b> has been completed.<br/><br/>Click <a href="$CONTENT_LINK$">here </a>to view or download the export.<br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you |
| 35:4500 | Export [$CONTENT_NAME$] Completed. |
| 35:4501 | $EMAIL_HEADER$<br/>Your request to export <b>[$CONTENT_NAME$]</b> has failed.<br/><br/>Click <a href="$CONTENT_LINK$">here </a>to view the export.<br/><br/>If you need help, please send an email to <a href="mailto:$ADMINISTRATOR_EMAIL$">$ADMINISTRATOR_NAME$</a>.<br/><br/>Thank you |
| 35:4502 | Export [$CONTENT_NAME$] Failed. |
| 35:4503 | Export Completed |
| 35:4504 | Email sent when the export initiated by user completed |
| 35:4505 | Export Failed |
| 35:4506 | Email sent when the export initiated by user failed |
| 35:4507 | Failed to connect to the domain server. Please contact Commcell administrator to check domain service credentials. |
| 35:4508 | Sync operation failed for external user group. |
| 35:4509 | Operation failed. Admin has not allowed users to set passkey. |
| 35:4510 | Operation failed. Passkey has not been set yet. |
| 35:4511 | Day and time specification missing in add Blackout Window rule request. |
| 35:4512 | Do-not-run interval days-of-week list missing in add Blackout Window rule request. |
| 35:4513 | Name missing in add Blackout Window rule request. |
| 35:4514 | Blackout Window missing in add Blackout Window rule request. |
| 35:4515 | Applicable do-not-run operations missing in add Blackout Window rule request. |
| 35:4516 | Start or end date missing in add Blackout Window rule request. |
| 35:4517 | Do-not-run interval start or end time missing in add Blackout Window rule request. |
| 35:4518 | Invalid day-of-week specified [<String>]. |
| 35:4519 | Backupset-level Blackout Window rule missing required parameter: BackupsetId. |
| 35:4520 | Client-level Blackout Window rule missing required parameter: ClientId. |
| 35:4521 | ClientGroup-level Blackout Window rule missing required parameter: ClientGroupId. |
| 35:4522 | CommServ-level Blackout Window rule missing required parameter: CommCellId. |
| 35:4523 | iDA-level Blackout Window rule missing required parameter: AppTypeId. |
| 35:4524 | Instance-level Blackout Window rule missing required parameter: InstanceId. |
| 35:4525 | Level specification missing in add/update Blackout Window rule request. |
| 35:4526 | SchedulePolicy-level Blackout Window rule missing required parameter: SchedulePolicyId. |
| 35:4527 | Subclient-level Blackout Window rule missing required parameter: SubclientId. |
| 35:4528 | Unsupported Blackout Window rule level [<Number>]. |
| 35:4529 | Cannot add or update Blackout Window rule with do-not-run interval start date greater than end date. |
| 35:4530 | Cannot add or update Blackout Window rule with do-not-run interval start time greater than or equal to end time. Start/End time is for the specified day. |
| 35:4531 | Failed to push network configuration for server group [<String>]. |
| 35:4532 | Push network configuration submitted successfully for server group [<String>]. |
| 35:4533 | Client is being used as index server for resource pool [<String>].Please delete resource pool and try again. |
| 35:4534 | Subclient '<String>' archival rules updated according to '<String>' plan inheritance rules reflecting changes made on subclient policy '<String>' |
| 35:4535 | User does not have permission to change the company alias. |
| 35:4536 | User does not have permission to change the company name. |
| 35:4537 | User does not have permission to change the Infrastructure Type |
| 35:4538 | User does not have permission to change the site name. |
| 35:4539 | User does not have permission to change the supported solutions |
| 35:4540 | Index Import |
| 35:4541 | Shared laptop is already activated for this user. |
| 35:4542 | Cannot activate the laptop as it is associated to invalid physical client. |
| 35:4543 | Cannot activate this laptop as [<String>] laptop is already activated for this user. |
| 35:4544 | Failed to find the associated physical client for the given client. |
| 35:4545 | Clients with associated regions |
| 35:4546 | Clients associated to Schedule Policy |
| 35:4547 | Move Partition job(s)[<String>] are running on MediaAgent[<String>] |
| 35:4548 | DDB Reconstruction job(s)[<String>] are running on MediaAgent[<String>] |
| 35:4549 | Move Mount Path job(s)[<String>] are running on MediaAgent[<String>] |
| 35:4550 | Clients with Indexing V1 |
| 35:4551 | Clients with Indexing V2 |
| 35:4552 | Failed to send log files by client gateway [<String>]. |
| 35:4553 | Deduplication cannot be enabled on dependent copy when disabled on Storage Pool. |
| 35:4554 | Invalid Agent [<Number>] specified. |
| 35:4555 | Failed to delete backupset. Data Aging is disabled. |
| 35:4556 | Destination Region |
| 35:4557 | Region Mappings |
| 35:4558 | Source Region |
| 35:4559 | Source SVM |
| 35:4560 | SVM Mappings |
| 35:4561 | Target SVM |
| 35:4562 | RP Store cannot be configured on an existing disk mount path |
| 35:4563 | Plan is in use. Backupset '<String>' is associated with the plan |
| 35:4564 | Plan is in use. Backupsets '<String>' and '<String>' are associated with the plan |
| 35:4565 | Plan is in use. Backupsets '<String>', '<String>' and '<String>' are associated with the plan |
| 35:4566 | Plan is in use. Backupsets '<String>', '<String>', '<String>' and <Number> other clients are associated with the plan |
| 35:4567 | Operation failed. Cannot delete a subclient associated to replication group [<String>]. |
| 35:4568 | Synthetic full is not allowed on deconfigured subclients. |
| 35:4569 | Synthetic full is not allowed on Virtual machine since there are no incrementals after last full or synthetic full. Run an incremental backup before running synthetic full. |
| 35:4570 | Synthetic full is not allowed since there are no Virtual machines with incremental backups after last full or synthetic full. |
| 35:4571 | Client is a Deleted VM |
| 35:4572 | hours |
| 35:4573 | minutes |
| 35:4574 | replication group |
| 35:4575 | Private Key Password |
| 35:4576 | Service Account ID |
| 35:4577 | API Token |
| 35:4578 | Frequency pattern is invalid for plan continuous RPO schedule. Valid values should be between 1 min to 1439 minutes. |
| 35:4579 | Frequency pattern is invalid for plan daily RPO schedule. Valid values should be between 1 day to 7 days. |
| 35:4580 | Frequency type of schedule pattern is invalid. Only continuous, daily and weekly frequency type are supported for plan RPO schedule. |
| 35:4581 | Failed to enable Use Native Snapshot property for Unix sub clients and Track Access Time for Windows agents associated to the plan. Please enable them manually. |
| 35:4582 | There are still snapshots associated with the array. Please delete all the snapshots associated with this array and then delete this array. |
| 35:4583 | Subscription ID |
| 35:4584 | Application Password |
| 35:4585 | Application ID |
| 35:4586 | Apache Tomcat is not running on CommServe. |
| 35:4587 | Failed to compute next schedule time for subclients. |
| 35:4588 | Live Update |
| 35:4589 | Failed to save Show Pseudo VM Jobs Option in CommServe database.n |
| 35:4590 | Cloud DB Migration |
| 35:4591 | Updated flag to scrub log files option from [<Number>] to [<Number>]. |
| 35:4592 | Scrub log files option has been set to [<Number>]. |
| 35:4593 | Failed to update flag scrub log files option to [<Number>]. |
| 35:4594 | Failed to set Backup Set properties. Backup Set is deconfigured. |
| 35:4595 | Subclient has object based retention set, so cannot associate an archival plan. |
| 35:4596 | Insufficient Parameters to validate SQL cloud credentials. |
| 35:4597 | Failed to validate SQL cloud credentials. Please check input parameters and try again. |
| 35:4598 | Unable to find the client with the given input. |
| 35:4599 | Detected multiple clients with the given input. |
| 35:4600 | AutoScale option disabled |
| 35:4601 | AutoScale option enabled |
| 35:4602 | Replication group [<String>] already exists. |
| 35:4603 | Tag |
| 35:4604 | Unable to activate laptop [<String>]. Laptop can only be activated by tenant associated to the laptop. |
| 35:4605 | Invalid input passed for enable mount path |
| 35:4606 | Autoscale Index Move |
| 35:4607 | Autoscale Index Prepare |
| 35:4608 | Delete Distributed Storage |
| 35:4609 | Superuser in Distributed Storage |
| 35:4610 | Update Distributed Storage |
| 35:4611 | View Distributed Storage |
| 35:4612 | Distributed Storage |
| 35:4613 | User does not have [<String>] rights on subclient(s)-[<String>]. |
| 35:4614 | Non archive plan cannot be associated to archive/onepass subclient. |
| 35:4615 | Unable to delete storage pools [<String>] of company since there are dependent storage policy copies that are still in use. |
| 35:4616 | MySQL Database username is modified, please provide a password for the user. |
| 35:4617 | Backup copy schedule policy |
| 35:4618 | Failed to start backups as no eligible subclients were found. |
| 35:4619 | Operation failed. Verify if distributed storage [<String>] is reachable. |
| 35:4620 | Failed to unregister distributed storage [<String>]. |
| 35:4621 | Failed to retrieve distributed storage info. |
| 35:4622 | Distributed storage with the same name already exists. |
| 35:4623 | Invalid request for distributed storage operation. |
| 35:4624 | Invalid distributed storage url. |
| 35:4625 | Invalid user specified for distributed storage operation. |
| 35:4626 | Missing required parameters in distributed storage operation request. |
| 35:4627 | Failed to register distributed storage [<String>]. |
| 35:4628 | Failed to update distributed storage [<String>] info. |
| 35:4629 | Failed to refresh the MountPath status. |
| 35:4630 | Enabled |
| 35:4631 | Using Storage Policy settings |
| 35:4632 | Manage Distributed Storage |
| 35:4633 | Register Distributed Storage |
| 35:4634 | Ignore higher-level Blackout Window rules request missing required parameter: ClientId. |
| 35:4635 | Distributed storage [<String>] is already registered. Verify if URL is correct. |
| 35:4636 | Distributed storage with the same name [<String>] already exists. |
| 35:4637 | Operation failed. Unable to fetch details from distributed storage [<String>]. |
| 35:4638 | Registration failed. Verify if distributed storage [<String>] is upgraded. |
| 35:4639 | Activation failed. Company [<String>] does not have rights on provided plan-[<String>]. |
| 35:4640 | Config 'Snap - Multi-tenant Site' cannot be disabled as there are conflicting arrays still present. Check the custom report [<String>] for more details. |
| 35:4641 | Use Distributed Storage |
| 35:4642 | Failed to authenticate to MongoDB instance. |
| 35:4643 | Configuration issues detected for MongoDB instance. |
| 35:4644 | Failed to connect to MongoDB instance. |
| 35:4645 | Connection timed out for MongoDB instance. |
| 35:4646 | Unable to delete media agents [<String>] of company of company since there are dependent storage policy copies that are still in use. |
| 35:4647 | Unable to delete plans [<String>] of company since they are being used by another company clients. |
| 35:4648 | Unable to delete storage policies [<String>] of company since they are being used by another company clients. |
| 35:4649 | Could not perform AD SSO. Please check the logs for more details. |
| 35:4650 | Could not perform AD SSO. Please ensure AD is trusted. Check the logs for more details. |
| 35:4651 | Failed to check if the given path is a logical volume with sufficient free extents. Please check IdxLabelUtil.log on the media agent for more details [For more information please refer to Deduplication Building Block Guide in the documentation] |
| 35:4652 | The path needs to be a logical volume (LVM) to perform DDB backups. |
| 35:4653 | User of company [<String>] cannot have security associations for [<String>] which belongs to company [<String>]. |
| 35:4654 | At least one Web Console should be enabled. |
| 35:4655 | [<String>] is a primary Web Console on the Master CommCell and cannot be disabled. |
| 35:4656 | This service CommCell needs to be upgraded for app to be created on universal Command Center. |
| 35:4657 | Client Backup Activity Enabled |
| 35:4658 | Clients with Enabled Backup Schedule |
| 35:4659 | Killed as part of company [<String>] deactivation. |
| 35:4660 | Unable to delete [<String>]. Clean up the datastores before deleting the distributed storage. |
| 35:4661 | Unable to delete [<String>] as there are backup targets associated to the distributed storage. |
| 35:4662 | Unable to delete [<String>]. Cleanup the snapshots before deleting the distributed storage. |
| 35:4663 | Unable to login to distributed storage [<String>]. Verify if the credentials to login to cluster are correct. |
| 35:4664 | Failed to display the report because Tomcat is not running on CommServe. |
| 35:4665 | Hedvig user [<String>] is not authorized to perform this operation on the cluster. |
| 35:4666 | Hedvig user [<String>] is not authorized to register the cluster. |
| 35:4667 | Live Mount |
| 35:4668 | Live Recovery |
| 35:4669 | Default Tagset |
| 35:4670 | One or more input params entity id, entity type or tag id are invalid with value NULL or 0. |
| 35:4671 | Invalid user id |
| 35:4672 | User does not have tag management permission on one or more entities |
| 35:4673 | User does not have view tag permission on one or more entities |
| 35:4674 | Successfully executed given operation |
| 35:4675 | Failed to setup index server for cloud mode as job[<Number>] has failed to install required packages. Either select index server while enabling cloud laptop mode or try again after installing Advanced Indexing Pack on media agents. |
| 35:4676 | Failed to create index server. Select index server while enabling cloud laptop mode. |
| 35:4677 | Cannot force add the array when MultiSite configuration is enabled. |
| 35:4678 | Cannot edit system created company Server group. |
| 35:4679 | Cloud Analytics |
| 35:4680 | Cannot edit system created plan Server group. |
| 35:4681 | Logged in user does not have rights to unlock this user account |
| 35:4682 | User account is not locked |
| 35:4683 | Unlock failed for user account |
| 35:4684 | Logged in user cannot unlock their own account |
| 35:4685 | Unlock successful for user account |
| 35:4686 | User account is locked for <String>. Please contact administrator. |
| 35:4687 | <Number> day(s) |
| 35:4688 | <Number> hour(s) |
| 35:4689 | <Number> minute(s) |
| 35:4690 | Cannot change distributed storage [<String>] login user to a user in different Hedvig tenant. |
| 35:4691 | Failed to sync distributed storage(s). |
| 35:4692 | Failed to sync distributed storage [<String>]. |
| 35:4693 | Could not perform SSO into Commcell Console. Please retry downloading new Commcell Console JNLP file or enter username and password to login manually. |
| 35:4694 | Remote Commcell Service Pack Version [<Number>] is less than required Service Pack Version [<Number>] |
| 35:4695 | Collect Diagnostics |
| 35:4696 | Failed to update timezone information. |
| 35:4697 | Entity rules |
| 35:4698 | Subclients matching regions [<String>] will be backed up using this plan. |
| 35:4699 | Subclients of clients matching clientGroups [<String>] agentType [<String>] will be backed up using this plan. |
| 35:4700 | Invalid clientgroup-[<Number>] specified. |
| 35:4701 | Server group is missing for the selected rule. |
| 35:4702 | Regions details are missing for the selected rule. |
| 35:4703 | Tags details are missing for the selected rule. |
| 35:4704 | Subclients matching tags [<String>] will be backed up using this plan. |
| 35:4705 | Invalid Rule type specified |
| 35:4706 | Failed to set Storage Accelerator Credential for mountpath. |
| 35:4707 | Detected Media Agent platform. Delete Media Agent before cleaning up the client. |
| 35:4708 | Plan association to subclient is not allowed. |
| 35:4709 | Server group belongs to a deactivated company. |
| 35:4710 | Cannot transfer ownership from [<String>] of [<String>] to [<String>] of [<String>], as they belong to different companies. |
| 35:4711 | The selected Plan does not have any UNIX MediaAgent required for NFS Network Share. Please check the Plan configuration or manually select the Access Nodes. |
| 35:4712 | The selected Plan does not have any Windows MediaAgent required for CIFS Network Share. Please check the Plan configuration or manually select the Access Nodes. |
| 35:4713 | Role of company [<String>] cannot have security associations for [<String>] which belongs to company [<String>]. |
| 35:4714 | Role of company [<String>] cannot have security associations for [<String>] which is MSP entity. |
| 35:4715 | Role of company [<String>] cannot have security associations for [<String>] which is MSP user/user group. |
| 35:4716 | Can't change index server as there is already an index migration running. |
| 35:4717 | Content Indexing is enabled for at least one of the subclient of client-[<String>]. Disable it from Commcell console and try again. |
| 35:4718 | NetApp Multisite configuration is supported for Feature Release 11.23 and later. Please make sure the access node for the array [<String>] meets the requirements. |
| 35:4719 | View failed items operation failed. |
| 35:4720 | Metallic recovery reserve copy is not allowed as source copy |
| 35:4721 | Custom Container |
| 35:4722 | Server group with scope as Commcell with no rules is not allowed. |
| 35:4723 | User does not have edit permission on one or more tags |
| 35:4724 | Failed to setup indexing as job-[<Number>] has failed to install required packages. Try again after manually creating resource pool or after installing Advanced Indexing Pack on applicable media agents. |
| 35:4725 | Failed to enable indexing. Try again after creating applicable resource pools. |
| 35:4726 | Content path [<String>] is invalid. |
| 35:4727 | There's no log related to the specified job id(s). |
| 35:4728 | Plan Rule cannot be deleted. One or more subclients of client [<String>] are associated with the rule. |
| 35:4729 | Plan Rule cannot be deleted. One or more subclients of client [<String>] and one or more subclients of client [<String>] are associated with the rule. |
| 35:4730 | Plan Rule cannot be deleted. One or more subclients of client [<String>], one or more subclients of client [<String>] and one or more subclients of client [<String>] are associated with the rule. |
| 35:4731 | Plan Rule cannot be deleted. One or more subclients of client [<String>], one or more subclients of client [<String>], one or more subclients of client [<String>] and [<Number>] other clients are associated with the rule. |
| 35:4732 | Failed to create Network Topology. Invalid Server group present. |
| 35:4733 | Failed to update Network Topology. Invalid Server group present. |
| 35:4734 | Failed to run check readiness, job is killed or failed. |
| 35:4735 | Failed to create result file for Job ID or Pair ID. |
| 35:4736 | Failed to create the log file for job. |
| 35:4737 | Failed to create the log file in time range. |
| 35:4738 | Failed to send logs. |
| 35:4739 | Failed to create directory on FTP server. |
| 35:4740 | Failed to connect to FTP site. |
| 35:4741 | Failed to upload logs to FTP server. |
| 35:4742 | Failed to get job options. |
| 35:4743 | No log is found for the Job ID. |
| 35:4744 | Log Files were successfully sent. |
| 35:4745 | Network Gateway used for client installation |
| 35:4746 | Cannot change the environment once it is enabled. |
| 35:4747 | The virtual machine can be backed up. |
| 35:4748 | Clients with License Consumed |
| 35:4749 | Another user with email [<String>] already exists. |
| 35:4750 | Cannot set [<String>] as Operators. Only Users and User groups belonging to [<String>] can be set as Operators on this company. |
| 35:4751 | Invalid job priority received, Valid job priority value should be between 0 and 9. |
| 35:4752 | Failed to establish connection to ActiveMQ(Message Queue) service. |
| 35:4753 | Clients associated to topology with region |
| 35:4754 | Edit operation failed, cutover workflow job [<Number>] is running |
| 35:4755 | There is no data that needs to be replicated. |
| 35:4756 | Webhook |
| 35:4757 | Webhook |
| 35:4758 | Create Webhook |
| 35:4759 | Delete Webhook |
| 35:4760 | Edit Webhook |
| 35:4761 | View Webhook |
| 35:4762 | Online Index Delete |
| 35:4763 | Multiple users are associated with email(s): [<String>] |
| 35:4764 | MediaAgent has no storage configured. Ransomware Protection will be enabled automatically when storage is configured |
| 35:4765 | Ransomware option is not supported for this MediaAgent |
| 35:4766 | Schedule cannot be run as it belongs to deactivated company [<String>] |
| 35:4767 | Clients with Tags |
| 35:4768 | Clients in Client Groups with Tags |
| 35:4769 | Plan entity rule |
| 35:4770 | No subclient(s) to process for the provided criteria. |
| 35:4771 | No plan rules defined |
| 35:4772 | User does not have rights on entity(s). |
| 35:4773 | User does not have rights on any plan(s). |
| 35:4774 | Failed to save cache location of active failover Remote Cache in CommServe database.n |
| 35:4775 | Failed to perform operation. Virtual machines [<String>] have the same GUID. Please retain only one of these virtual machines and try again. |
| 35:4776 | Hi,nnUser [<String>] cancelled filer migration from [<String>] to [<String>].nn No action is required on your part.nnThanks. |
| 35:4777 | Cancelled filer migration from [<String>] to [<String>] |
| 35:4778 | Failed to retire client(s). |
| 35:4779 | Failed to retire client(s). Missing or invalid Client information |
| 35:4780 | Fix Broken Permissions |
| 35:4781 | Oracle RDS Backup |
| 35:4782 | Oracle RDS Restore |
| 35:4783 | Error communicating to access node [<String>]. |
| 35:4784 | Failed to find access node. |
| 35:4785 | Unable to connect to access node [<String>]. Make sure services are running on the access node and try again. |
| 35:4786 | Tape library for IBM i needs a disk/cloud storage for storing index but MediaAgent [<String>] has no disk libraries. nConfigure disk storage on MediaAgent [<String>] and then try again. |
| 35:4787 | Failed to begin move job results directory. Could not connect to any of the given proxies. |
| 35:4788 | Organization ID |
| 35:4789 | Private Key |
| 35:4790 | Public Key |
| 35:4791 | Synthetic full is not allowed due to one of the DDB partition is currently unavailable. Check the corresponding Media Manager configuration of allowing synthetic full job in this case for more details. |
| 35:4792 | One of the backupsets is associated with another company. |
| 35:4793 | Either the server is an access node, or a Web Server, a Web Console, or a CommServe that is installed on the server. |
| 35:4794 | One of the instances is associated with another company. |
| 35:4795 | The server is locked. |
| 35:4796 | You are not the owner of the server. |
| 35:4797 | The storage on the MediaAgent is associated with another company. |
| 35:4798 | One of the subclients is associated with another company. |
| 35:4799 | One of the subclients is not associated with the same company as the server. |
| 35:4800 | Tenant admin does not have permission on the associated plan |
| 35:4801 | Either the parent or the child of the server is associated with another company. |
| 35:4802 | ResourcePool |
| 35:4803 | ResourcePool |
| 35:4804 | Create ResourcePool |
| 35:4805 | Delete ResourcePool |
| 35:4806 | Edit ResourcePool |
| 35:4807 | Content indexing plan is already associated to <String>, [<String>]. Enable Threat analysis on the existing Content indexing plan instead. |
| 35:4808 | Threat analysis plan is already associated to <String>, [<String>]. Select Content indexing plan with Threat analysis enabled. |
| 35:4809 | Threat analysis option is already enabled on Content indexing plan associated to <String>, [<String>]. |
| 35:4810 | OPERATION FAILED: Cannot edit system created rule [Company Installed Client Associations] for company smart client group. |
| 35:4811 | Failed to enable file search. |
| 35:4812 | Failed to process some of the storage pool(s). However, enabled file search on plan. |
| 35:4813 | Setting up file search. |
| 35:4814 | Validation failed for the infrastructure type. |
| 35:4815 | Cleanup Destination VM |
| 35:4816 | Custom DR |
| 35:4817 | Failback |
| 35:4818 | Planned Failover |
| 35:4819 | Point in Time Failover |
| 35:4820 | Reverse Replication |
| 35:4821 | Revert Failover |
| 35:4822 | Test Failover |
| 35:4823 | Test Boot |
| 35:4824 | Undo Failover |
| 35:4825 | Undo Test Failover |
| 35:4826 | Unplanned Failover |
| 35:4827 | Invalid device user mapping info. |
| 35:4828 | No permissions to manage device user mapping. |
| 35:4829 | Invalid input. Company [<String>] does not exist. |
| 35:4830 | Invalid input. User does not exist. |
| 35:4831 | Clients with Infrastructure Roles |
| 35:4832 | Hi,nn Source of migration : [<String>].nn Content paths selected for migration : [<String>]. nn Migration selected [<String>] configuration.nn Cutover approvers list : [<String>]. nn Cutover date and time in UTC : [<String>]. nnThanks. |
| 35:4833 | Filer migration from [<String>] to [<String>] configured |
| 35:4834 | The local metrics reporting is disabled. |
| 35:4835 | The local metrics reporting is enabled |
| 35:4836 | The local metrics reporting is changed. |
| 35:4837 | User [<String>] has been disconnected |
| 35:4838 | Incomplete definition. Please check access nodes are present and valid. |
| 35:4839 | Another resource pool already exist for this storage pool and solution. |
| 35:4840 | Incomplete definition. [<String>] not specified. |
| 35:4841 | Invalid input. Index server cannot be changed. |
| 35:4842 | Invalid solution specified |
| 35:4843 | Resource Pool not found. |
| 35:4844 | A resource pool with the same name already exist. |
| 35:4845 | Failed to get clients for the job(s). |
| 35:4846 | Failing the job as logs have not been gathered from any of the clients. |
| 35:4847 | User has insufficient permission. |
| 35:4848 | SendLogs job partially successful as not all of the data was successfully collected. |
| 35:4849 | Failed to inherit job retention for existing jobs |
| 35:4850 | Modifying system created company client group's rules is allowed only from Command Center |
| 35:4851 | Transfer ownership failed with following error: [<String>] for following servers: [<String>]. |
| 35:4852 | Failed to check if the path is a logical volume (LVM) for DDB backups. For details, check IdxLabelUtil.log on the Media Agent [<String>] |
| 35:4853 | Ignore Files |
| 35:4854 | Ignore Risks |
| 35:4855 | Set Retention |
| 35:4856 | Clients with Front End Terabyte Size <= 10GB |
| 35:4857 | Failed to get default datapath library of Storage Pool [<String>]. |
| 35:4858 | Operation failed because job [<Number>] is running. |
| 35:4859 | Cannot change company of system created company server group |
| 35:4860 | Failed to impersonate the user for the network shared job results path. Please verify thatn a) the username and password are correctn b) the specified user has local logon permissions to all the Access Nodesn c) the user has both read/write access to both the previous and current network shared job results path. |
| 35:4861 | Please contact the administrator for more details |
| 35:4862 | Instance [<String>] is a master. Master cannot be set as standby. |
| 35:4863 | Instance [<String>] is already a standby of another instance [<String>]. Standby cannot be set as master. |
| 35:4864 | Instance [<String>] is already a standby of another instance [<String>]. Same instance cannot be set as standby for multiple masters. |
| 35:4865 | Group [<String>] contains members from different companies. |
| 35:4866 | Subclient [<String>] already has block-level enabled, only one block-level subclient per instance is allowed. |
| 35:4867 | There are pending snap jobs for some subclients which need to be backup copied. Run backup copy workflow job on storage policy. |
| 35:4868 | Confirmation from user is not provided to perform the operation, cannot continue. |
| 35:4869 | Failed to mark SQL Database Backups as Unrestorable. |
| 35:4870 | Insufficient Parameters to mark SQL Database Backups as Unrestorable, cannot continue. |
| 35:4871 | Group [<String>] is associated to a different company entity |
| 35:4872 | Invalid company user |
| 35:4873 | Account lockout duration |
| 35:4874 | Audit trail |
| 35:4875 | Delete authorization |
| 35:4876 | External authentication |
| 35:4877 | Failed login lockout count |
| 35:4878 | Multi-factor authentication |
| 35:4879 | Restore authorization |
| 35:4880 | 30 minutes or more |
| 35:4881 | Retention for Critical audit trail: 1 yearnRetention for High audit trail: 1 yearnRetention for Medium audit trail: 8 monthsnRetention for Low audit trail: 4 months |
| 35:4882 | It is recommended to enable this feature so delete requests require additional authorization for approval. |
| 35:4883 | 5 or fewer failed log-ins |
| 35:4884 | Enable multi-factor authentication |
| 35:4885 | It is recommended to enable this feature so restore requests require additional authorization for approval. |
| 35:4886 | This setting is configured according to the recommendations published in AC-7 of the NIST 800-53 framework. |
| 35:4887 | It is recommended to enable multi-factor authentication with your external identity provider. |
| 35:4888 | Retention for Critical audit trail: <String> year<br>Retention for High audit trail: <String> year<br>Retention for Medium audit trail: <String> months<br>Retention for Low audit trail: <String> months |
| 35:4889 | <String> minutes |
| 35:4890 | <String> failed logins |
| 35:4891 | High CPU usage |
| 35:4892 | High memory usage |
| 35:4893 | Client is offline |
| 35:4894 | Similar location(s) defined in more than one region of the plan. |
| 35:4895 | Another resource pool already exist for this index server and solution. |
| 35:4896 | Company [<String>] already marked for delete |
| 35:4897 | Company does not exist. |
| 35:4898 | There is no user with name "<String>" in <String> domain |
| 35:4899 | Two-Factor Authentication is disabled for this user |
| 35:4900 | Linux content policy |
| 35:4901 | Mac content policy |
| 35:4902 | Windows content policy |
| 35:4903 | Key Management |
| 35:4904 | Storage with encryption |
| 35:4905 | AWS and Azure can be used to manage encryption keys outside of Metallic |
| 35:4906 | Encrypt storage |
| 35:4907 | This setting is managed by Metallic. <br><a href=<String> target="_blank">View full audit trail report</a> for export options |
| 35:4908 | When this setting is enabled, deletion requests will require approval from another administrator, protecting against accidental and malicious destructive tasks. This cannot be disabled once it is enabled. |
| 35:4909 | For more information on configuration, please refer to <a href=<String> target="_blank">Documentation</a> |
| 35:4910 | When this setting is enabled, restore requests will require approval from another administrator, providing extra privacy protection. This cannot be disabled once it is enabled. |
| 35:4911 | <a href=<String> target="_blank">Click here</a> to see storage encryption details |
| 35:4912 | <String> external key management system is being used |
| 35:4913 | <String> external key management system are being used |
| 35:4914 | <String>/<String> storage have encryption enabled |
| 35:4915 | You are restricted from logging on to this console. |
| 35:4916 | Replication Pair |
| 35:4917 | Clients backed up using VSA Subclient. |
| 35:4918 | Change App Certificate Duration from [<Number>] to [<Number>] |
| 35:4919 | Failed to change App Certificate Duration |
| 35:4920 | Successfully created app certificate for client [<String>] |
| 35:4921 | Could not create app certificate for client [<String>]. Check the logs for more details. |
| 35:4922 | External user group [<String>] cannot have direct security associations on company [<String>]. They can manage the company as Operators. |
| 35:4923 | External user [<String>] cannot have direct security associations on company [<String>]. They can manage the company as Operators. |
| 35:4924 | Move Files |
| 35:4925 | Operation failed. Replication plan [<String>] can be managed from replication group [<String>]. |
| 35:4926 | The request for log collection has been registered successfully. Logs will be collected automatically once the computer is powered on and connected to network. |
| 35:4927 | Login with Command Center is not supported |
| 35:4928 | Login with Command Center is not supported for Linux Commserv |
| 35:4929 | Retire operation is not supported for CommServer Client. |
| 35:4930 | Clone DR VM (Continuous) |
| 35:4931 | Copy DR FS Volumes (Continuous) |
| 35:4932 | FS Failback (Continuous) |
| 35:4933 | FS Planned Failover (Continuous) |
| 35:4934 | FS Test Failover (Continuous) |
| 35:4935 | FS Unplanned Failover (Continuous) |
| 35:4936 | VM Failback (Continuous) |
| 35:4937 | VM Planned Failover (Continuous) |
| 35:4938 | VM Test Failover (Continuous) |
| 35:4939 | VM Unplanned Failover (Continuous) |
| 35:4940 | Bulk File Migration |
| 35:4941 | Target SVM (Cloud) |
| 35:4942 | Retention cycle is not applicable for 'Database Dev/Test' plan or storage policy[<String>]. |
| 35:4943 | Failed to verify user [<String>] for instance [<String>]. Verify that services are online and with the correct user name and password. |
| 35:4944 | Data Migration |
| 35:4945 | Data Staging |
| 35:4946 | <String> SIEM unsent data records till id [<String>] are pruned for connector [<String>]. |
| 35:4947 | Cleanup failed for client [<String>]. Please delete snapshots related to the subclients manually from the fileserver. Error [<String>] |
| 35:4948 | User account [<String>] is locked for [<String>]. Please contact administrator. |
| 35:4949 | Metadata Restore |
| 35:4950 | Sandbox Seeding |
| 35:4951 | Clients associated to any company |
| 35:4952 | Syslog - <String> is <String> for <String> |
| 35:4953 | Cannot delete default subclient |
| 35:4954 | Database Restore |
| 35:4955 | Creating copy with metallic Library is not allowed. Try creating copy using Storage Pool. |
| 35:4956 | Data aging has been disabled for the <String>/<String> due to the changes in n<String>.nPlease review with customer and enable data aging. |
| 35:4957 | <String> modified for the <String>/<String>.nPlease review with customer. |
| 35:4958 | <String>: Review the <String> modification on <String>/<String> |
| 35:4959 | Data aging has been disabled due to <String> modification for the <String>/<String>. nPlease review with customer and enable data aging. |
| 35:4960 | nModified Time: <String> |
| 35:4961 | Retention rules |
| 35:4962 | Selective copy rules |
| 35:4963 | Cannot disable client owner assignment |
| 35:4964 | Default Server plan is configured for company-[<String>]. Unset default server plan and try again. |
| 35:4965 | Threat Analysis |
| 35:4966 | Not started |
| 35:4967 | Failed to set Send Log Files activity on Server. |
| 35:4968 | CommServe LiveSync needs at least one standby node and CommServe failover package should be installed on both active and standby nodes. Please check and install the required packages. |
| 35:4969 | A previous add node attempt has not completed, please try reconfigure operation. |
| 35:4970 | Changing content of log shipping subclient is not allowed from subclient properties. Please update it from CommServe LiveSync configuration. |
| 35:4971 | Bucket Name |
| 35:4972 | Server |
| 35:4973 | Cannot delete a read-only Client Group |
| 35:4974 | Cannot modify a read-only Client Group |
| 35:4975 | Data Migration |
| 35:4976 | Syslog |
| 35:4977 | Cannot delete Tenant Admin user group's security association on Company entity. |
| 35:4978 | User does not have in place and out of place permissions on source instance |
| 35:4979 | No special characters are allowed for tag name(s) or tag value(s) |
| 35:4980 | Lowering the reserve space of HyperScale mount path below recommended values is prevented |
| 35:4981 | Delete Company |
| 35:4982 | [<String>] is deactivated. |
| 35:4983 | Operation Failed. Only Tenant Admins are allowed to update user(s) and user group(s) when a company is locked. |
| 35:4984 | Operation Failed. Only Tenant Admins are allowed to create user(s) and user group(s) when a company is locked. |
| 35:4985 | Cannot retire [<String>]. Use Delete MediaAgent option if you want to retire [<String>] completely. |
| 35:4986 | Plan-[<String>] has restricted solutions. Not applicable for association to [<String>] |
| 35:4987 | Log Streaming Connector |
| 35:4988 | Compliance lock |
| 35:4989 | It is recommended to enable compliance lock for storage to restrict the ability to reduce retention on a plan, delete plans, plan copies, storage or servers associated with a plan. This option may not be turned off once enabled. |
| 35:4990 | <a href=<String> target="_blank">Click here</a> to view report and enable compliance lock on select storage. |
| 35:4991 | <String>/<String> storage has compliance lock enabled or is managed by Metallic |
| 35:4992 | af-south-1 |
| 35:4993 | Africa (Cape Town) |
| 35:4994 | ap-east-1 |
| 35:4995 | Asia Pacific (Hong Kong) |
| 35:4996 | ap-southeast-3 |
| 35:4997 | Asia Pacific (Jakarta) |
| 35:4998 | asiapacific |
| 35:4999 | Asia Pacific |
| 35:5000 | asia |
| 35:5001 | Asia |
| 35:5002 | australia |
| 35:5003 | Australia |
| 35:5004 | europe |
| 35:5005 | Europe |
| 35:5006 | brazil |
| 35:5007 | Brazil |
| 35:5008 | brazilsoutheast |
| 35:5009 | Brazil Southeast |
| 35:5010 | canada |
| 35:5011 | Canada |
| 35:5012 | centraluseuap |
| 35:5013 | Central US EUAP |
| 35:5014 | centralusstage |
| 35:5015 | Central US (Stage) |
| 35:5016 | eastasiastage |
| 35:5017 | East Asia (Stage) |
| 35:5018 | eastus2euap |
| 35:5019 | East US 2 EUAP |
| 35:5020 | eastus2stage |
| 35:5021 | East US 2 (Stage) |
| 35:5022 | eastusstage |
| 35:5023 | East US (Stage) |
| 35:5024 | eu-north-1 |
| 35:5025 | Europe (Stockholm) |
| 35:5026 | eu-south-1 |
| 35:5027 | Europe (Milan) |
| 35:5028 | france |
| 35:5029 | France |
| 35:5030 | germany |
| 35:5031 | Germany |
| 35:5032 | germanynorth |
| 35:5033 | Germany North |
| 35:5034 | germanywestcentral |
| 35:5035 | Germany West Central |
| 35:5036 | global |
| 35:5037 | Global |
| 35:5038 | india |
| 35:5039 | India |
| 35:5040 | japan |
| 35:5041 | Japan |
| 35:5042 | jioindiacentral |
| 35:5043 | Jio India Central |
| 35:5044 | jioindiawest |
| 35:5045 | Jio India West |
| 35:5046 | korea |
| 35:5047 | Korea |
| 35:5048 | me-south-1 |
| 35:5049 | Middle East (Bahrain) |
| 35:5050 | northcentralusstage |
| 35:5051 | North Central US (Stage) |
| 35:5052 | norway |
| 35:5053 | Norway |
| 35:5054 | norwayeast |
| 35:5055 | Norway East |
| 35:5056 | norwaywest |
| 35:5057 | Norway West |
| 35:5058 | southafrica |
| 35:5059 | South Africa |
| 35:5060 | southafricanorth |
| 35:5061 | South Africa North |
| 35:5062 | southafricawest |
| 35:5063 | South Africa West |
| 35:5064 | southcentralusstage |
| 35:5065 | South Central US (Stage) |
| 35:5066 | southeastasiastage |
| 35:5067 | Southeast Asia (Stage) |
| 35:5068 | swedencentral |
| 35:5069 | Sweden Central |
| 35:5070 | switzerland |
| 35:5071 | Switzerland |
| 35:5072 | switzerlandnorth |
| 35:5073 | Switzerland North |
| 35:5074 | switzerlandwest |
| 35:5075 | Switzerland West |
| 35:5076 | uae |
| 35:5077 | uaecentral |
| 35:5078 | UAE Central |
| 35:5079 | United Arab Emirates |
| 35:5080 | uaenorth |
| 35:5081 | UAE North |
| 35:5082 | uk |
| 35:5083 | United Kingdom |
| 35:5084 | unitedstates |
| 35:5085 | United States |
| 35:5086 | unitedstateseuap |
| 35:5087 | United States EUAP |
| 35:5088 | westus2stage |
| 35:5089 | West US 2 (Stage) |
| 35:5090 | westus3 |
| 35:5091 | West US 3 |
| 35:5092 | westusstage |
| 35:5093 | West US (Stage) |
| 35:5094 | Default |
| 35:5095 | OPERATION FAILED: Invalid Connector Id. |
| 35:5096 | OPERATION FAILED: Connector already exists for selected data type. |
| 35:5097 | Client certificate, Client key, and Certificate authority file must be specified for Google Cloud with SSL enabled. |
| 35:5098 | Failed to add array. Array name is empty. Provide a valid array name. |
| 35:5099 | Failed to add array [<String>]. Vendor name is empty. Provide a valid vendor name. |
| 35:5100 | Failed to edit array [<String>]. Name cannot be modified for an existing array. |
| 35:5101 | Failed to edit array [<String>]. Vendor cannot be modified for an existing array. |
| 35:5102 | Failed to add array [<String>]. Vendor [<String>] is not supported. Provide a valid vendor name. |
| 35:5103 | VMs not in any SubClient Content |
| 35:5104 | VMs where HyperVisor is part of Client Group |
| 35:5105 | Cannot create client group [<String>] as there is a system created entry with same name. |
| 35:5106 | Clients of Reseller |
| 35:5107 | Threat Scan |
| 35:5108 | The option to Prevent admin access to company data has been activated. Kindly deactivate this setting to proceed with the change company operation for following servers. |
| 35:5109 | Operation Failed. Only Tenant Admins are allowed to change company for resources of a locked company. |
| 35:5110 | Operation Failed. Only Tenant Admins are allowed to change ownership of company resources when a company is locked. |
| 35:5111 | Given tag does not exist |
| 35:5112 | Given tag has existing association |
| 35:5113 | af-johannesburg-1 |
| 35:5114 | South Africa Central (Johannesburg) |
| 35:5115 | ap-chuncheon-1 |
| 35:5116 | South Korea North (Chuncheon) |
| 35:5117 | ap-hyderabad-1 |
| 35:5118 | India South (Hyderabad) |
| 35:5119 | ap-melbourne-1 |
| 35:5120 | Australia Southeast (Melbourne) |
| 35:5121 | ap-mumbai-1 |
| 35:5122 | India West (Mumbai) |
| 35:5123 | ap-osaka-1 |
| 35:5124 | Japan Central (Osaka) |
| 35:5125 | ap-seoul-1 |
| 35:5126 | South Korea Central (Seoul) |
| 35:5127 | ap-singapore-1 |
| 35:5128 | Singapore (Singapore) |
| 35:5129 | ap-sydney-1 |
| 35:5130 | Australia East (Sydney) |
| 35:5131 | ap-tokyo-1 |
| 35:5132 | Japan East (Tokyo) |
| 35:5133 | ca-montreal-1 |
| 35:5134 | Canada Southeast (Montreal) |
| 35:5135 | ca-toronto-1 |
| 35:5136 | Canada Southeast (Toronto) |
| 35:5137 | eu-amsterdam-1 |
| 35:5138 | Netherlands Northwest (Amsterdam) |
| 35:5139 | eu-frankfurt-1 |
| 35:5140 | Germany Central (Frankfurt) |
| 35:5141 | eu-marseille-1 |
| 35:5142 | France South (Marseille) |
| 35:5143 | eu-milan-1 |
| 35:5144 | Italy Northwest (Milan) |
| 35:5145 | eu-stockholm-1 |
| 35:5146 | Sweden Central (Stockholm) |
| 35:5147 | eu-zurich-1 |
| 35:5148 | Switzerland North (Zurich) |
| 35:5149 | il-jerusalem-1 |
| 35:5150 | Israel Central (Jerusalem) |
| 35:5151 | me-abudhabi-1 |
| 35:5152 | UAE Central (Abu Dhabi) |
| 35:5153 | me-dubai-1 |
| 35:5154 | UAE East (Dubai) |
| 35:5155 | me-jeddah-1 |
| 35:5156 | Saudi Arabia West (Jeddah) |
| 35:5157 | sa-santiago-1 |
| 35:5158 | Chile (Santiago) |
| 35:5159 | sa-saopaulo-1 |
| 35:5160 | Brazil East (Sao Paulo) |
| 35:5161 | sa-vinhedo-1 |
| 35:5162 | Brazil Southeast (Vinhedo) |
| 35:5163 | uk-cardiff-1 |
| 35:5164 | UK West (Newport) |
| 35:5165 | uk-london-1 |
| 35:5166 | UK South (London) |
| 35:5167 | us-ashburn-1 |
| 35:5168 | US East (Ashburn) |
| 35:5169 | us-phoenix-1 |
| 35:5170 | US West (Phoenix) |
| 35:5171 | us-sanjose-1 |
| 35:5172 | US West (San Jose) |
| 35:5173 | Abu Dhabi |
| 35:5174 | Amsterdam |
| 35:5175 | Ashburn |
| 35:5176 | Chuncheon |
| 35:5177 | Dubai |
| 35:5178 | Hyderabad |
| 35:5179 | Jeddah |
| 35:5180 | Johannesburg |
| 35:5181 | Melbourne |
| 35:5182 | Milan |
| 35:5183 | Montreal |
| 35:5184 | Newport |
| 35:5185 | Phoenix |
| 35:5186 | San Jose |
| 35:5187 | Santiago |
| 35:5188 | Abu Dhabi |
| 35:5189 | Dubai |
| 35:5190 | Gangwon-do |
| 35:5191 | Gauteng |
| 35:5192 | Jerusalem |
| 35:5193 | Lombardy |
| 35:5194 | Makkah Province |
| 35:5195 | North Holland |
| 35:5196 | Santiago Metropolitan |
| 35:5197 | Sao Paulo |
| 35:5198 | Stockholm |
| 35:5199 | Telangana |
| 35:5200 | Zurich |
| 35:5201 | Stockholm |
| 35:5202 | Vinhedo |
| 35:5203 | Zurich |
| 35:5204 | User does not have Agent Management Capability |
| 35:5205 | Configuring Disaster Recovery destination using administrative or hidden shares is not allowed. |
| 35:5206 | Failed to validate Disaster Recovery path. |
| 35:5207 | HyperScale nodes of the storage pool |
| 35:5208 | Plan-[<String>] is using restricted storage pool. Association with this plan is not allowed. |
| 35:5209 | Plan-[<String>] is using Office 365 storage pool. Subclient-[<String>] association with this plan is not allowed. |
| 35:5210 | Plan-[<String>] is using Dynamic 365 storage pool. Subclient-[<String>] association with this plan is not allowed. |
| 35:5211 | Plan-[<String>] is using AD storage pool. Subclient-[<String>] association with this plan is not allowed. |
| 35:5212 | Plan-[<String>] is using Salesforce storage pool. Subclient-[<String>] association with this plan is not allowed. |
| 35:5213 | incompatible access nodes used to configure multi-node Object Storage. One or more access nodes are at a lower release level. |
| 35:5214 | Upgrade of single node Object Storage client to multiple node is not supported |
| 35:5215 | Generation of [<String>] Report failed for recipients - [<String>]. |
| 35:5216 | Report [<String>] sending failed as no recipients among [<String>] are not valid |
| 35:5217 | Error [<String>] encountered while sending email for report [<String>] for job id [<Number>] to recipients [<String>]. |
| 35:5218 | Failed to set WORM retention days[<String>] on library [<String>]. Please configure the WORM retention on storage using vendor portal. |
| 35:5219 | Automatic access nodes selection |
| 35:5220 | Automatic access node selection is disabled for hypervisor [<String>] due to AutoScale enabling |
| 35:5221 | DDB Data Verification |
| 35:5222 | DDB Space Reclamation |
| 35:5223 | Syslog connector for [<String>] already exists. |
| 35:5224 | asia-east1 |
| 35:5225 | asia-east2 |
| 35:5226 | asia-northeast1 |
| 35:5227 | asia-northeast2 |
| 35:5228 | asia-northeast3 |
| 35:5229 | asia-south1 |
| 35:5230 | asia-south2 |
| 35:5231 | asia-southeast1 |
| 35:5232 | asia-southeast2 |
| 35:5233 | australia-southeast1 |
| 35:5234 | australia-southeast2 |
| 35:5235 | europe-central2 |
| 35:5236 | europe-north1 |
| 35:5237 | europe-west1 |
| 35:5238 | europe-west2 |
| 35:5239 | europe-west3 |
| 35:5240 | europe-west4 |
| 35:5241 | europe-west6 |
| 35:5242 | europe-west8 |
| 35:5243 | northamerica-northeast1 |
| 35:5244 | northamerica-northeast2 |
| 35:5245 | southamerica-east1 |
| 35:5246 | southamerica-west1 |
| 35:5247 | us-central1 |
| 35:5248 | us-east1 |
| 35:5249 | us-east4 |
| 35:5250 | us-west1 |
| 35:5251 | us-west2 |
| 35:5252 | us-west3 |
| 35:5253 | us-west4 |
| 35:5254 | Changhua |
| 35:5255 | Council Bluffs |
| 35:5256 | Delhi |
| 35:5257 | Groningen |
| 35:5258 | Hamina |
| 35:5259 | Jakarta |
| 35:5260 | Jurong West New Town |
| 35:5261 | Kymenlaakso |
| 35:5262 | Las Vegas |
| 35:5263 | Los Angeles |
| 35:5264 | Mazovia |
| 35:5265 | Moncks Corner |
| 35:5266 | National Capital Territory of Delhi |
| 35:5267 | Nevada |
| 35:5268 | Osasco |
| 35:5269 | Salt Lake City |
| 35:5270 | South Carolina |
| 35:5271 | The Dalles |
| 35:5272 | Utah |
| 35:5273 | Wallonia |
| 35:5274 | Warsaw |
| 35:5275 | OPERATION FAILED : User does not have edit permission on [<String>] associated with webhook [<String>]. |
| 35:5276 | Tenant Admin/Tenant User can not change company to Commcell |
| 35:5277 | User does not have [<String>] permission on Connector entity associated with SIEM connector. |
| 35:5278 | FS Pair |
| 35:5279 | Container |
| 35:5280 | Bucket |
| 35:5281 | Service Host |
| 35:5282 | Configured Target Array |
| 35:5283 | Source Array |
| 35:5284 | Target Array |
| 35:5285 | Index Server associated to the client [<String>] has been changed; |
| 35:5286 | Backed up subclients [<String>] associated to the data source were deleted; |
| 35:5287 | Backup set with Globally Unique Identifier [<String>] associated to the data source was deleted; |
| 35:5288 | Client node [<String>], with index server cloud [<String>] was retired/deleted; |
| 35:5289 | Pseudo client with id [<String>] associated to the data source was deleted; |
| 35:5290 | Subclient with id [<String>] associated to the data source was deleted; |
| 35:5291 | The data source was marked for deletion; |
| 35:5292 | Setting two plans of same subtype as the default plans are not allowed |
| 35:5293 | Error setting default plan. Unsupported plan type/ Incorrect plan Id |
| 35:5294 | Tag value exists |
| 35:5295 | Marking or Unmarking MediaAgents in maintenance mode is supported only for Hyperscale storage |
| 35:5296 | Operation failed. Members from different companies are not allowed in [<String>] |
| 35:5297 | Failed to update properties because jobs are in progress for the Instance |
| 35:5298 | Users belonging to Super Admins group only can add or remove members from Super Admins and Compliance Officers. |
| 35:5299 | Failed to check mount status of DDB path [<String>], Reason [cannot open /etc/mtab file] |
| 35:5300 | DDB path [<String>] is not mounted |
| 35:5301 | No client is included in the job. Possible reasons: 1. No client is selected. 2. The user doesn't have permission to any of the selected clients or proxy clients. |
| 35:5302 | Cannot create Scale-out Storage pool, please select at least 3 MediaAgents. |
| 35:5303 | This Index server is associated to Inventory [<String>]. Please remove the association and try again. |
| 35:5304 | Invalid external credential information in request |
| 35:5305 | Plan Solution Association |
| 35:5306 | Setting applicable solutions is not allowed on derived plan-[<String>] |
| 35:5307 | Plan-[<String>] has restricted solutions. Not applicable for association to subclient-[<String>] for solution-[<String>] |
| 35:5308 | Cannot modify user group membership on service CommCell environment. |
| 35:5309 | Cannot set API as restricted console as Access token(s) exists.n<String>n<String> |
| 35:5310 | Reducing the store seal days of a worm storage policy copy is not allowed. |
| 35:5311 | Operation failed. Only tenant admin can modify/disable company passkey. |
| 35:5312 | Plan is in use. Datasource '<String>' is associated with the plan |
| 35:5313 | Plan is in use. Datasources '<String>' and '<String>' are associated with the plan |
| 35:5314 | Plan is in use. Datasources '<String>', '<String>' and '<String>' are associated with the plan |
| 35:5315 | Plan is in use. Datasources '<String>', '<String>', '<String>' and <Number> other datasources are associated with the plan |
| 35:5316 | Async ExportSet |
| 35:5317 | MSP Infra Machines |
| 35:5318 | Mount Path or Serial Number are not given for creating library |
| 35:5319 | Creating a disk library or adding a mount path using an existing device is not supported |
| 35:5320 | No path specified for creating mount path |
| 35:5321 | Deleting ArchiveLog subclient is not allowed. |
| 35:5322 | Operation Failed. Child company is a reseller company. |
| 35:5323 | Company is not associated with Commcell. Operation not supported. |
| 35:5324 | Reseller company is invalid. Please select a valid reseller company. |
| 35:5325 | Nesting of resellers is not allowed. |
| 35:5326 | Failed to get Tenant Admin group id for reseller company. |
| 35:5327 | User has permissions to change the additional settings only. Skipping other properties if present in input. |
| 35:5328 | Full (Data) |
| 35:5329 | Full (Data, Config) |
| 35:5330 | Incremental (Data) |
| 35:5331 | Incremental (Data, Config) |
| 35:5332 | Incremental (Log) |
| 35:5333 | Incremental (Log, Config) |
| 35:5334 | Plan-[<String>] is owned by another company. Cannot be associated with company-[<String>] entity |
| 35:5335 | Failed to get array details as the input array number is invalid. Provide a valid, non-zero array number. |
| 35:5336 | Failed to get array [<Number>] details as the array does not exist in the database. Provide array number of a successfully configured array. |
| 35:5337 | Failed to create the Storage Policy [<String>]. A Storage WORM lock enabled library cannot be reused to create another storage pool or storage policy. |
| 35:5338 | Failed to create the copy for storage policy [<String>]. Copy cannot be created with override retention using a storage pool with Storage WORM lock property set. |
| 35:5339 | Failed to update storage policy copy. Cannot update copy with override retention when storage pool is using Storage WORM lock property set. |
| 35:5340 | Storage WORM lock property cannot be set when one or more copies are overriding retention. |
| 35:5341 | Storage WORM lock cannot be enabled on Hyperscale storage. |
| 35:5342 | Storage WORM lock cannot be enabled on metallic storage. |
| 35:5343 | Agent(s) Configured |
| 35:5344 | Cloud Resource Discovery |
| 35:5345 | group with azure GUID [<String>] already exists |
| 35:5346 | Invalid operations in Blackout Window rule request. |
| 35:5347 | Cannot add or update Blackout Window with an invalid UTC end date. |
| 35:5348 | Cannot add or update Blackout Window with an invalid UTC start date. |
| 35:5349 | Failed to update storage policy copy. Cannot update copy with infinite retention when storage pool is using Storage WORM lock property set. |
| 35:5350 | Unable to configure service account for the reseller company. |
| 35:5351 | eu-paris-1 |
| 35:5352 | France Central (Paris) |
| 35:5353 | It is recommended to configure this setting according to the recommendations published in AC-7 of the NIST 800-53 framework. |
| 35:5354 | End User Restore |
| 35:5355 | Client Display Name List |
| 35:5356 | Client Hostname List |
| 35:5357 | Client Name List |
| 35:5358 | Please provide a GCP staging path for using GCP Export/Import APIs |
| 35:5359 | me-central-1 |
| 35:5360 | Middle East (UAE) |
| 35:5361 | Client has Backups |
| 35:5362 | Failed to delete Virtual Machine: [<String>] |
| 35:5363 | WorkloadId is not associated for subclient-[<String>] |
| 35:5364 | Invalid applicable solutions-[<String>] provided as input for plan-[<String>] |
| 35:5365 | & Deferred |
| 35:5366 | & Disabled |
| 35:5367 | Partially Available & Retained |
| 35:5368 | Partially Copied & Retained |
| 35:5369 | Partially Available |
| 35:5370 | Partially Copied |
| 35:5371 | Pruned |
| 35:5372 | with Missing Snaps |
| 35:5373 | Failed to delete array [<String>] as it is associated to VSA client [<String>]. Delete the client before deleting the array entry. |
| 35:5374 | Failed to edit credentials for array [<String>] as it is associated to VSA client [<String>]. Edit the credentials from the virtual server instance properties. |
| 35:5375 | Failed to delete array [<String>]. Cannot delete a system generated array entry. |
| 35:5376 | Node is overloaded. <String> |
| 35:5377 | Storage WORM lock property cannot be set when one or more copies have Compliance Lock already enabled. |
| 35:5378 | Storage WORM lock property cannot be set for pool when storage library is used by another pool enabled with WORM. |
| 35:5379 | Another user with User principal name [<String>] already exists. |
| 35:5380 | This Index server is associated to Resource Pool [<String>]. Please remove the association and try again. |
| 35:5381 | Log Set |
| 35:5382 | Report Set |
| 35:5383 | Restore Set |
| 35:5384 | Invalid or No SSL certificate passed. |
| 35:5385 | Cannot rename Tenant Admin group |
| 35:5386 | Invalid Request. Cannot use plan content with content defined in request. |
| 35:5387 | Invalid request. Local content flag need to be set as true. |
| 35:5388 | The snapshot backups for [<String>] instances were already configured under array [<String>]. This may happen if the [<String>] backups were configured for account previously and then manually [<String>] instance was deleted. Delete array [<String>] and try again. |
| 35:5389 | Automatic association of Access Nodes from the plan failed! Please associate a plan containing <String> storage. |
| 35:5390 | Job will not be started. Deferred catalog job does not need to run. |
| 35:5391 | Clients with Work Load Types |
| 35:5392 | Device controllers with data server transport type cannot be set as preferred controller. |
| 35:5393 | The [<String>] plan is an Elastic Plan. To select this plan, associate the hypervisor to a region. |
| 35:5394 | Elastic Plan - [<String>] does not contain storage configuration for hypervisor's region. |
| 35:5395 | $EMAIL_HEADER$<br/>Dear User,<br/><br/>We have received a request to reset your password. Request to reset your password cannot be completed as multiple accounts have been found. Use login name or UPN to request reset password. Please contact your <a href="mailto:$ADMINISTRATOR_EMAIL$">administrator</a> for help.<br/><br/>Sincerely,<br/><br/>Your Administrator<br/>$EMAIL_FOOTER$ |
| 35:5396 | Reset password for a user having multiple accounts |
| 35:5397 | Email sent to the user when the forgot password link is clicked and multiple accounts are found |
| 35:5398 | User doesn't have Operations or Data management capability on storage policy. |
| 35:5399 | User doesn't have Operations or Data management capability on storage policy [<String>]. |
| 35:5400 | Data Management |
| 35:5401 | Failed to push Network Configuration for client group [<String>] with error [<String>]. |
| 35:5402 | Storage policy [<String>] contains a NetApp Cloud Target copy [<String>].nWhen there is a NetApp Cloud Target copy, deferred catalog cannot be disabled on the storage policynand the deferred catalog source copy must match the NetApp Cloud Target source copy. |
| 35:5403 | When adding a NetApp Cloud Target copy, deferred cataloging must be enabled on the storage policynand must have the same source copy as the NetApp Cloud Target copy.nPlease check the deferred catalog settings on storage policy [<String>] to enable deferred catalogingnand set the source copy to match the new NetApp Cloud Target copy and retry adding the new NetApp Cloud Target copy. |
| 35:5404 | When adding a NetApp Cloud Target copy, deferred cataloging must be enabled on the storage policynand must have the same source copy as the NetApp Cloud Target copy.nPlease manually enable deferred cataloging on storage policy [<String>] and set the source copy to match the new NetApp Cloud Target copynon this storage policy and retry adding the new NetApp Cloud Target copy. |
| 35:5405 | When adding a NetApp Cloud Target copy, deferred cataloging must be enabled on the storage policynand must have the same source copy as the NetApp Cloud Target copy.nAutomatically adding the deferred catalog settings to storage policy [<String>] failed.nPlease manually enable deferred cataloging and set the source copy to match the new NetApp Cloud Target copynon this storage policy and retry adding the new NetApp Cloud Target copy. |
| 35:5406 | When adding a NetApp Cloud Target copy, deferred cataloging must be scheduled on storage policy [<String>].nAutomatically associating to schedule policy [<String>] failed.nPlease check that this schedule policy exists and retry adding the new NetApp Cloud Target copy. |
| 35:5407 | Workload |
| 35:5408 | <String> have been modified on Storage Pool <String>/<String>. n Data aging has been disabled for the below dependent copies, n <String> n Please review with customer and enable data aging. |
| 35:5409 | Invalid Backupset Name is specified. Length of backupset name provided cannot exceed 100 characters. |
| 35:5410 | Operation failed. Company user trying to run pre post command on a client marked as infrastructure and owned by Commcell. |
| 35:5411 | Dear User,<br/><br/>Your $COMPANY_NAME$ administrator has allowed using backup codes to login.<br/>Each backup code can be be used only once. DO NOT share these codes with anyone and record them for future use.<br/><br/>Login<br />$USERNAME_LOGIN$ or $USERNAME$<br/><br/>Backup Codes<br/>$BACKUP_CODES$<br/><br/>If you need help, contact your <a href="mailto:$ADMINISTRATOR_EMAIL$">administrator</a>.<br/><br/>Thank you,<br/><br/>CommServe Administrator |
| 35:5412 | Backup codes to login |
| 35:5413 | Backup codes for a user |
| 35:5414 | Email sent to the user when backup codes are configured |
| 35:5415 | Client is Remote Client Type |
| 35:5416 | Invalid input specified. Please specify credential name. |
| 35:5417 | ap-south-2 |
| 35:5418 | Asia Pacific (Hyderabad) |
| 35:5419 | ap-southeast-4 |
| 35:5420 | Asia Pacific (Melbourne) |
| 35:5421 | eu-central-2 |
| 35:5422 | Europe (Zurich) |
| 35:5423 | eu-south-2 |
| 35:5424 | Europe (Spain) |
| 35:5425 | The target company does not have permission on the plan associated with the server or its backupset/subclient. |
| 35:5426 | Resubmit operation is not supported for workflow jobs. |
| 35:5427 | Configure a third-party encryption key management server as required by your organization |
| 35:5428 | <a href=<String> target="_blank">View full audit trail report</a> for export options |
| 35:5429 | This setting is following recommendations in accordance to AC-7 NIST 800-53 publication |
| 35:5430 | This setting is not following recommendations in accordance to AC-7 NIST 800-53 publication |
| 35:5431 | For more information on configuration, please refer to <a href=<String> target="_blank">Documentation</a> |
| 35:5432 | <String>/<String> storage has compliance lock enabled |
| 35:5433 | Clients with Action Pending |
| 35:5434 | Failed to add data path with error: [<String>] |
| 35:5435 | Deleted |
| 35:5436 | Command Center timeout period |
| 35:5437 | Commcell Console timeout period |
| 35:5438 | Disaster Recovery Backup |
| 35:5439 | File Activity Anomaly alert |
| 35:5440 | Key Management Server for Password Encryption |
| 35:5441 | Passkey for restore feature |
| 35:5442 | Password complexity level |
| 35:5443 | Privacy feature |
| 35:5444 | Ransomware protection |
| 35:5445 | Requires user authentication for installing agents |
| 35:5446 | Cleanup of unused entities |
| 35:5447 | Single sign-on |
| 35:5448 | User and user group permissions |
| 35:5449 | Commvault recommends that you enable this feature |
| 35:5450 | Enable this alert to receive anomaly alerts |
| 35:5451 | It is recommended to enable multi-factor authentication to secure login accounts managed by Commvault. |
| 35:5452 | Longer passwords are recommended. Enforce passwords to be twelve characters or more with a combination of at least two uppercase letters, two lowercase letters, two numbers and two special characters. |
| 35:5453 | Enable this option to enforce authentication for installations |
| 35:5454 | GUI timeout should be 30 minutes or less |
| 35:5455 | This setting is following recommendations in accordance to AC-7 NIST 800-53 publication |
| 35:5456 | This setting is not following recommendations in accordance to AC-7 NIST 800-53 publication |
| 35:5457 | <a href=<String> target="_blank">Click here</a> to configure this alert. |
| 35:5458 | Password complexity complies with NIST 800-53 |
| 35:5459 | Enable High Password Complexity |
| 35:5460 | <a href=<String> target="_blank">How to change this setting</a> |
| 35:5461 | Review user security configurations to identify and mitigate potential user access risks.<br><a href=<String> target="_blank">Click here</a> to view. |
| 35:5462 | <a href=<String> target="_blank">Click here</a> to view details. |
| 35:5463 | Review and mitigate users that have privileged master access to help reduce user access risks.<br><a href=<String> target="_blank">Click here</a> to view. |
| 35:5464 | Command Center will timeout after <Number> minutes |
| 35:5465 | Command Center will timeout after 30 minutes |
| 35:5466 | Commcell Console will timeout after <Number> minutes. |
| 35:5467 | DR backup is not configured to cloud or UNC path |
| 35:5468 | DR backup is configured |
| 35:5469 | <String> key management service is used. |
| 35:5470 | <Number> client computer owner(s) have enabled the passkey for restore operations |
| 35:5471 | No client computer owners have enabled the passkey for restore operations |
| 35:5472 | Some media agents are not secured against ransomware. |
| 35:5473 | All media agents are secured against ransomware. |
| 35:5474 | Authentication is not required |
| 35:5475 | Authentication is required |
| 35:5476 | <Number> user groups without users<br><Number> users without security associations<br><Number> users not logged-in in 30 days |
| 35:5477 | <Number> Single sign-on Provider(s) are configured. |
| 35:5478 | No Single sign-on Providers are configured. |
| 35:5479 | View users in master group |
| 35:5480 | High |
| 35:5481 | Medium |
| 35:5482 | Windows MediaAgents with admin shares |
| 35:5483 | <String> MediaAgents have admin shares enabled putting mount paths at risk |
| 35:5484 | No MediaAgents have admin shares enabled |
| 35:5485 | All Client Groups In Company |
| 35:5486 | All Clients In Company |
| 35:5487 | Failed to change recovery options. Please Check Logs for more information. |
| 35:5488 | Failed to get destination access node details. Please Check Logs for more information. |
| 35:5489 | RP Store is not shared with the destination access nodes. Please make sure that the RP Store is shared with destination access nodes. |
| 35:5490 | Empty mount path info for RP store |
| 35:5491 | Invalid RP store id provided |
| 35:5492 | User is managing more than one company. Specific company info cannot be returned. |
| 35:5493 | This setting is not following recommendations in accordance to AC-7 NIST 800-53 publication.<br><a href=<String> target="_blank">Click here</a> to configure by going to <b>settings</b> section on the page. |
| 35:5494 | <a href=<String> target="_blank">Click here</a> to enable high password complexity by going to <b>settings</b> section on the page. |
| 35:5495 | Cannot configure Identity Server, Company IdP already configured. |
| 35:5496 | AuthCode-[<String>] provided does not match with user group authcode. Cannot allow company creation without matching authcode. |
| 35:5497 | Existing user not present for email-: [<String>]. Cannot allow company creation without user present. |
| 35:5498 | User is missing admin permission to manage company |
| 35:5499 | The client's workload region differs from Plan's storage pool workload region. |
| 35:5500 | It's recommended that you protect your DR backup in the Metallic cloud or your own cloud for air gap protection |
| 35:5501 | Use a third-party key management server to encrypt account passwords used for login as required by your organization |
| 35:5502 | Enable this option to allow password-protected restores only for company tenants |
| 35:5503 | Enable this option to allow restrictions for browse and restores only for company tenants |
| 35:5504 | Review and remove unused CommCell management entities |
| 35:5505 | Configure SSO as required by your organization |
| 35:5506 | Review and remove privileged access accounts that are no longer needed |
| 35:5507 | <a href=<String> target="_blank">Click here</a> to configure a third-party key management server |
| 35:5508 | Failed to move some partitions hosted on the DDB disk |
| 35:5509 | Successfully launched move operation for all the partitions hosted on the DDB disk |
| 35:5510 | DDB cannot be configured in MediaAgent [<Number> : <String>] installation directory [<String>] |
| 35:5511 | Network paths [<String>] are not allowed for hosting DDB |
| 35:5512 | Disk [<String>] is not associated with the MediaAgent [<Number> : <String>] |
| 35:5513 | An icl_label file already exists on the path [<String>] on MediaAgent [<Number> : <String>] |
| 35:5514 | No DDB disk configured on MediaAgent [<Number> : <String>] |
| 35:5515 | No DDB partition hosted on this disk [<String> : <String>] |
| 35:5516 | Dear user, <br/><br/> Use the below OTP as your password to change password for user $USERNAME_LOGIN$ or $USERNAME$<br/><br/>One Time Pin (valid for next 30 minutes only)<br/>$PIN$<br/><br/>Thank you, <br/>CommServe Administrator<br/><br/>If you did not attempt this operation and received this email in error, please contact your administrator immediately. |
| 35:5517 | Pin to change password |
| 35:5518 | Pin for password change |
| 35:5519 | Email sent to the user when user requests OTP to change password for other user |
| 35:5520 | Restore (Export) |
| 35:5521 | SAML app cannot be enabled as test login not completed yet. |
| 35:5522 | Usergroup - [<String>] is already migrated. |
| 35:5523 | Usergroup - [<String>] is already migrated. Cannot allow company creation. |
| 35:5524 | Reseller Accounts are not eligible for trial. Please contact administrator. |
| 35:5525 | Client Name [<String>] contains invalid characters |
| 35:5526 | Archive plan cannot be associated to non-archive subclient. |
| 35:5527 | Enabling Allow multiple company members is not allowed. Group [<String>] is associated to the group [<String>] on which the flag is disabled. |
| 35:5528 | This setting is managed by Metallic. |
| 35:5529 | Extend failed for Company [<String>] , ErrorMessage : [<String>] |
| 35:5530 | Incomplete request : [<String>] |
| 35:5531 | Invalid syslog hostname [<String>] format. |
| 35:5532 | Invalid/Empty Secret provided for webhook |
| 35:5533 | MongoDB Disaster Recovery Backup |
| 35:5534 | An application group by this name already exists as part of this cluster. |
| 35:5535 | One Time Pin (valid for next $VALIDITY$ minutes only)<br />$PIN$<br /><br /> |
| 35:5536 | One Time Pin (valid for next <String> minutes only) |
| 35:5537 | Cannot dissociate plan '<String>' as it is owned by this company. Try deleting it as Tenant Operator instead. |
| 35:5538 | Cannot dissociate plans '<String>' as they are owned by this company. Try deleting them as Tenant Operator instead. |
| 35:5539 | Cannot remove DDB role association of MediaAgent [<String>] with StoragePool [<String>]. Please move the DDB partitions of this StoragePool that are hosted on the MediaAgent before removing the association |
| 35:5540 | Cannot remove Storage role association of MediaAgent [<String>] from StoragePool [<String>] as it is the only regular shared controller on the MountPath [<String>] |
| 35:5541 | Authentication code expired. |
| 35:5542 | The last full job for de-configured subclient already ran. |
| 35:5543 | Clients associated to Oracle RAC Clusters |
| 35:5544 | Region based storage is not configured in the Elastic Plan for the access node's workload region[<String>]. |
| 35:5545 | Service mesh client is already configured for this Commcell |
| 35:5546 | Create/Update [<String>] failed. [<String>] is invalid. |
| 35:5547 | Auxiliary Copy (Dash) |
| 35:5548 | Media Refreshing |
| 35:5549 | Unable to determine if the Plan MAs are online and accessible. Please check the MAs associated to the selected plan. |
| 35:5550 | The selected Plan has UNIX MediaAgents required for NFS Network Share, but the connectivity check from the MA to the client failed. Please check whether the UNIX MAs can connect to the client. |
| 35:5551 | The selected Plan has UNIX MediaAgents required for NFS Network Share, but none are online. Please check the status of the UNIX MAs. |
| 35:5552 | The selected Plan has Windows MediaAgents required for CIFS Network Share, but the connectivity check from the MA to the client failed. Please check whether the Windows MAs can connect to the client. |
| 35:5553 | The selected Plan has Windows MediaAgents required for CIFS Network Share, but none are online. Please check the status of the Windows MAs. |
| 35:5554 | Plan should have at least one Backup Destination defined. |
| 35:5555 | Renaming restricted for User Group. |
| 35:5556 | User is not managing any specific company. Company specific info cannot be returned. |
| 35:5557 | Authentication code validation failed. Verify that the PIN matches with the one provided in authentication code request form.nIf issue persists contact your software vendor for valid authentication code. |
| 35:5558 | DDB disk cannot be configured inside MediaAgent [<String>] installation directory [<String>] |
| 35:5559 | Standard MediaAgent(s) |
| 35:5560 | europe-west12 |
| 35:5561 | Piedmont |
| 35:5562 | Turin |
| 35:5563 | Archiving Service policy |
| 35:5564 | Failed to delete storage policy as there are jobs that have not met the minimum retention configured on the copy. |
| 35:5565 | Manual deletion of jobs that have not met the minimum retention days configured on the copy is not allowed. |
| 35:5566 | Reducing the basic or extended retention of copy lower than the minimum retention days [<Number>] is not allowed. |
| 35:5567 | jobs that have not met the minimum retention days configured on the copy |
| 35:5568 | Client [<String>] cannot be deleted as it has valid data that has not met the minimum retention days configured on the copy. |
| 35:5569 | Cannot delete entity as it has valid data that has not met the minimum retention configured on the copy. |
| 35:5570 | Active Directory Comparison |
| 35:5571 | Login auth code has expired. |
| 35:5572 | <html>Use of CommCell Console requires authorization for new deployments starting from Platform release 2024. For more information <a href="https://kb.commvault.com/article/82051">https://kb.commvault.com/article/82051</a></html> |
| 35:5573 | Invalid recopy job [<Number>] on primary |
| 35:5574 | Storage Accelerator Disabled Clients |
| 35:5575 | <html>Possible anomaly detected on client [<String>] by [<String>] at [<String>]. Check Unusual File Activity report for more detail.<span style="display: none"><String></span></html> |
| 35:5576 | il-central-1 |
| 35:5577 | Israel (Tel Aviv) |
| 35:5578 | Tel Aviv |
| 35:5579 | Snap Catalog |
| 35:5580 | Azure Function API to fetch regions failed. |
| 35:5581 | Invalid commcell GUID provided |
| 35:5582 | Failed to update copy. Toggling between job/days based retention is not allowed on worm enabled copy. |
| 35:5583 | User [<String>] has disabled the option to overwrite media at the library level on the library [<String>]. nPlease make sure that this option has not been selected erroneously. |
| 35:5584 | User has disabled the option to overwrite media at the library level on the library. nPlease make sure that this option has not been selected erroneously. |
| 35:5585 | Restore for Comparison |
| 35:5586 | Cannot delete company. Plan [<String>] is being used as Base Plan for company [<String>]. |
| 35:5587 | Failed to enable Immutable snapshot for the dependent copy [<String>] of source copy [<String>]. |
| 35:5588 | BackupSet Name |
| 35:5589 | Instance Name |
| 35:5590 | The primary contact for user <String> within company <String> cannot be deleted. Please assign another user as the primary contact and try the operation again |
| 35:5591 | Download |
| 35:5592 | Recovery Group |
| 35:5593 | Create Recovery Group |
| 35:5594 | Delete Recovery Group |
| 35:5595 | Edit Recovery Group |
| 35:5596 | View Recovery Group |
| 35:5597 | Automatic Client Group Refresh operation failed. |
| 35:5598 | User [<String>] violated Automatic Client Group Scope Level, check security permissions. |
| 35:5599 | DM Outlook Restore |
| 35:5600 | Quick DM Restore |
| 35:5601 | There is no change in the Barcode pattern label |
| 35:5602 | Failed to edit auto discover media for Tape storage [<String>] |
| 35:5603 | Failed to edit auto stamp media for Tape storage [<String>] |
| 35:5604 | Failed to get supported media types for Tape storage [<String>] |
| 35:5605 | Failed to edit overwrite media for Tape storage [<String>] |
| 35:5606 | Failed to edit Barcode pattern label for Tape storage [<String>] |
| 35:5607 | MediaAgents associated with storage pool list |
| 35:5608 | Alert cannot be associated to jobs. It should be associated to servers/server groups. |
| 35:5609 | Alert cannot be created on jobID [<Number>] since it has another alert [<String>] created. |
| 35:5610 | Alert cannot be created on jobID [<Number>] since alert type specified is not valid. |
| 35:5611 | Alert cannot be created on jobID [<Number>] since user doesn't have sufficient privileges. |
| 35:5612 | Alert cannot be created on jobID [<Number>] since it is not running. |
| 35:5613 | Failed to create credential associating external credential. User does not have permission for external credential [<String>]. |
| 35:5614 | Failed to update credential. User does not have permission for external credential [<String>]. |
| 35:5615 | The storage array entry associated to the hypervisor client still has snaps associated to it. Please delete the snaps to proceed with company migration. |
| 35:5616 | The storage array entry associated to the NAS client still has snaps associated to it. Please delete the snaps to proceed with company migration. |
| 35:5617 | The job couldn't start as the connected storage policies were linked to companies that are currently deactivated. |
| 35:5618 | Failed to get security associations of Credential [<String>]. |
| 35:5619 | Failed to get associated Credential information |
| 35:5620 | User doesn't have "Use Credential" rights to use the Credential [<String>] |
| 35:5621 | Recovery |
| 35:5622 | Partially enabled |
| 35:5623 | Compliance Manager |
| 35:5624 | <a href=<String> target="_blank">Click here</a> to configure a third-party key management server by going to <b>password encryption</b> section on the page. |
| 35:5625 | <a href=<String> target="_blank">Click here</a> to configure by going to <b>general</b> section on the page. |
| 35:5626 | <a href=<String> target="_blank">Click here</a> to configure by going to <b>passkey</b> section on the page. |
| 35:5627 | <a href=<String> target="_blank">Click here</a> to configure by going to <b>privacy</b> section on the page. |
| 35:5628 | Log backup is not applicable as Optimized log backup is enabled for this instance |
| 35:5629 | Invalid company association for Identity Server app |
| 35:5630 | Invalid domain association for Identity Server app |
| 35:5631 | Invalid user association for Identity Server app |
| 35:5632 | Invalid user group association for Identity Server app |
| 35:5633 | Recovery Status is not ready because: |
| 35:5634 | The storage copy and recovery point combination cannot be used for recovery. Make sure that full/synthetic full backups are present in the AirGap copy for the provided recovery point time. |
| 35:5635 | Destination entity name is invalid. Check the destination name and override it to a valid azure VM name. |
| 35:5636 | [<String>] critical, [<String>] high, [<String>] moderate risk files detected, data source [<String>], project [<String>]. |
| 35:5637 | Storage Policy common properties |
| 35:5638 | Projected to run every [<String>] days based on configuration [<String>] on backup destination [<String>]. |
| 35:5639 | Automatically created based on configuration [<String>] to include [<String>] [<String>] on backup destination [<String>] under region [<String>] to run on supported workloads. |
| 35:5640 | Log Commit |
| 35:5641 | Unable to establish connectivity with these instance properties for [<String>]. [<String>]. For more information: https://documentation.commvault.com/v11/expert/creating_sap_hana_hdbuserstore_key.html |
| 35:5642 | Hypervisor Clients |
| 35:5643 | Failed to delete storage policy as there are jobs that are associated with the client, client group, instance or the copy on which Data Aging activity is disabled. |
| 35:5644 | Manual deletion of jobs associated with the client, client group, instance or the copy on which Data Aging activity is disabled is not allowed. |
| 35:5645 | jobs that are associated with the client, client group, instance or the copy on which Data Aging activity is disabled |
| 35:5646 | Client [<String>] cannot be deleted as Data Aging activity is disabled on the client, client group, instance or the copy associated with the backups. |
| 35:5647 | Cannot delete entity as it has valid data associated with the client, client group, instance or the copy on which Data Aging activity is disabled. |
| 35:5648 | ca-west-1 |
| 35:5649 | Canada West (Calgary) |
| 35:5650 | me-west1 |
| 35:5651 | Calgary |
| 35:5652 | Alberta |
| 35:5653 | Plan cannot be deleted. Backup destination '<String>' has compliance lock enabled. |
| 35:5654 | Plan cannot be deleted. Backup destinations '<String>' and '<String>' have compliance lock enabled. |
| 35:5655 | Plan cannot be deleted. Backup destinations '<String>', '<String>' and '<String>' have compliance lock enabled. |
| 35:5656 | Plan cannot be deleted. Backup destinations '<String>', '<String>', '<String>' and <Number> other backup destinations have compliance lock enabled. |
| 35:5657 | Plan cannot be deleted. At least one backup destination in the region '<String>' has compliance lock enabled. |
| 35:5658 | Plan cannot be deleted. At least one backup destination in the regions '<String>' and '<String>' has compliance lock enabled. |
| 35:5659 | Plan cannot be deleted. At least one backup destination in the regions '<String>', '<String>' and '<String>' has compliance lock enabled. |
| 35:5660 | Plan cannot be deleted. At least one backup destination in the regions '<String>', '<String>', '<String>' and <Number> other regions has compliance lock enabled. |
| 35:5661 | File server interface [<String>] can't be accessed. Error [^%s] |
| 35:5662 | [<String>] entities detected in risk analysis job, job id [<String>], data source [<String>], project [<String>]. |
| 35:5663 | Failed to set the block size for the specified MediaAgent in the database. |
| 35:5664 | Valid backup copy not found in the destination region: %1s, valid copies are present in [%2s]. Set destination region to a region where valid copies are present or add a AirGap copy in the plan and make sure that a full or synthetic full backup job is present in the new copy. |
| 35:5665 | NetApp SnapMirror Cloud Target copy creation failed because the source copy '<String>' is enabled with immutable snapshot but NetApp SnapMirror Cloud Target does not support immutable snapshot. |
| 35:5666 | Copy '<String>' cannot support immutable snapshot because there is a dependent NetApp SnapMirror Cloud Target copy '<String>' which does not support immutable snapshot. |
| 35:5667 | Deleting client [<String>] is not possible as it is linked with array [<String>]. Please make sure to remove the array from Storage Provisioning and Array Management before attempting to delete the client. |
| 35:5668 | Recovery job is not allowed to run with current license |
| 35:5669 | License usage limit exceeded. Please contact customer executive for further assistance |
| 35:5670 | No License issued. Please contact customer executive for further assistance |
| 35:5671 | System Identification Number |
| 35:5672 | Management Interface |
| 35:5673 | System Name |
| 35:5674 | Management Interface |
| 35:5675 | Management Interface |
| 35:5676 | iSCSI Discovery IP |
| 35:5677 | Management Interface |
| 35:5678 | Control Host |
| 35:5679 | Company [<String>] with AuthCode [<String>] already exists on Cloud. |
| 35:5680 | Clients with Tag name and value |
| 35:5681 | Clients in Client Groups with Tag name and value |
| 35:5682 | User has marked the entity as failed |
| 35:5683 | Recovery group [<String>] created successfully |
| 35:5684 | Forest Restore |
| 35:5685 | Network Topology creation was unsuccessful. |
| 35:5686 | Invalid proactive reach out email recipients. |
| 35:5687 | No Access Node found in destination region [<String>] for smart folder [<String>] |
| 35:5688 | The given storage policy and copy are unrelated, please verify the input parameters and try again. |
| 35:5689 | Laptop V2 is not enabled for the specified plan. |
| 35:5690 | The plan specified is not a laptop plan. |
| 35:5691 | Cleanup Recovered Entity |
| 35:5692 | Immutable snap copy does not support extended retention. It supports only days-based retention. |
| 35:5693 | Immutable snap copy does not support cycle-based retention. It supports only days-based retention. |
| 35:5694 | Immutable snap copy does not support infinite retention. It supports only days-based retention. |
| 35:5695 | Immutable snap copy does not support snapshot recovery-point-based retention. It supports only days-based retention. |
| 35:5696 | Retention details are missing in the request. |
| 35:5697 | Immutable snap copy does not support spool (0 days) retention. It supports only days-based retention. Set minimum retention to at least 1 day. |
| 35:5698 | The selected retention period of [<Number>] day(s) is not within the acceptable range for an Immutable snap copy. The valid retention period is between [<Number>] and [<Number>] days. |
| 35:5699 | Immutable snap copy supports only days-based retention. |
| 35:5700 | User does not have permissions over the credentials. |
| 35:5701 | Azure Active Directory Comparison |
| 35:5702 | Commcell Policy |
| 35:5703 | MongoDB service is currently down. |
| 35:5704 | Tool Run as Workflow : <String> |
| 35:5705 | File server interface [<String>] can't be accessed. Error [<String>] |
| 35:5706 | Linux MediaAgents in the selected plans will be used as access nodes for CIFS share backup and restore. None of these Linux MediaAgents have connectivity to the file share, please check network connectivity. |
Index Manager
| Code | Description |
| 14:1 | Winsock initialization error [<Number>] in [<String>]. |
| 14:2 | Invalid CommCell number in [<String>]. |
| 14:3 | Invalid application number in [<String>]. |
| 14:4 | Invalid backup type [<Number>] in [<String>]. Bad CreateIndex/UpdateIndex command line arguments. |
| 14:5 | Invalid job id in [<String>]. |
| 14:6 | Invalid find time in CreateIndex - Bad command line arguments for CreateIndex received. |
| 14:7 | Invalid callback address in [<String>]. |
| 14:8 | Out of memory in [<String>]. |
| 14:9 | Cannot access cache directory for [<String>] in [<String>]. |
| 14:10 | Ack write failed (code [<Number>]) in [<String>]. |
| 14:11 | CreateIndex ifind handshake failed for [<String>]. |
| 14:12 | CreateIndex initialization failed for [<String>]. |
| 14:13 | Index update failed. creating new index for [<String>]. |
| 14:14 | Indexing failure causes full backup for [<String>]. |
| 14:15 | CreateIndex processing failed for [<String>]. |
| 14:16 | Cannot suspend cache dir for [<String>] in [<String>]. |
| 14:17 | Cannot resume cache dir for [<String>] in [<String>]. |
| 14:18 | Bad argument count [<Number>] in UpdateIndex. |
| 14:19 | UpdateIndex dsBackup handshake failed for [<String>]. |
| 14:20 | UpdateIndex initialization failed for [<String>]. |
| 14:21 | UpdateIndex index processing failed for [<String>]. |
| 14:22 | Unknown completion code [<Number>] in UpdateIndex for [<String>]. |
| 14:23 | Cache close failed in UpdateIndex for [<String>]. |
| 14:24 | Connection died in UpdateIndex for [<String>]. |
| 14:25 | Backup suspended in UpdateIndex for [<String>]. |
| 14:26 | No valid delimiter in path [<String>] for [<String>]. |
| 14:27 | Cannot open index for [<String>] at time [<String>]. |
| 14:28 | Cannot open latest index for [<String>]. |
| 14:29 | Cannot create temp index for [<String>]. |
| 14:30 | Non-root restore not supported for [<String>]. |
| 14:31 | Non-root restore failed for [<String>]. |
| 14:32 | Restore cannot initialize index for [<String>] at time [<String>]. |
| 14:33 | Synthetic full cannot retrieve file list for [<String>]. |
| 14:34 | Synthetic full cannot save file list for [<String>]. |
| 14:35 | Restore cannot initialize latest index for [<String>]. |
| 14:36 | Cannot restore [<String>] in subclient [<String>] - not found at time [<String>]. |
| 14:37 | Nothing to browse under [<String>] for [<String>] at time [<String>]. |
| 14:38 | Unable to restore under [<String>] for [<String>] at time [<String>]. |
| 14:39 | Unable to browse under [<String>] for [<String>] at time [<String>]. |
| 14:40 | Data extracting for browse failed for [<String>]. |
| 14:41 | Data extracting for restore failed for [<String>]. |
| 14:42 | Source path [<String>] ([<Number>] of [<Number>]). |
| 14:43 | Browse initialization failed for [<String>]. |
| 14:44 | Restore initialization failed for [<String>]. |
| 14:45 | Restore failed for [<String>]. |
| 14:46 | Unable to browse using subclient configuration for [<String>] at time [<String>]. |
| 14:47 | Cache uncompress failed (path [<String>]). |
| 14:48 | Cache compress failed (path [<String>]). |
| 14:49 | Cannot get cache directory state (path [<String>]). |
| 14:50 | Cannot set cache directory state (path [<String>]). |
| 14:51 | Cannot get cache directory access time (path [<String>]). |
| 14:52 | Cannot make cache directory (path [<String>]). |
| 14:53 | Cannot search for index for [<String>] at time [<String>]. |
| 14:54 | Cannot search for latest index for [<String>]. |
| 14:55 | Index cache directory is not accessible. |
| 14:56 | Job results directory is not accessible. |
| 14:57 | Cannot create cache directory for [<String>] at time [<String>]. |
| 14:58 | Cannot create results directory for job id [<Number>]. |
| 14:59 | Cannot update cache directory for [<String>]. |
| 14:60 | Cannot suspend cache directory for [<String>]. |
| 14:61 | Cannot resume cache directory for [<String>]. |
| 14:62 | Cannot close cache directory for [<String>]. |
| 14:63 | Cannot close results directory for job id [<Number>]. |
| 14:64 | Cannot remove cache directory (path [<String>]). |
| 14:65 | Cannot remove job results directory (path [<String>]). |
| 14:66 | Removing cache directory [<String>] during cleanup. |
| 14:67 | Removing job results directory [<String>] during cleanup. |
| 14:68 | Error during uncache operation (path [<String>]). |
| 14:69 | Attempting to free [<Number>] blocks in cache area [<String>]. |
| 14:70 | Cleaning up job results in cache area [<String>]. |
| 14:71 | Error while trying to free [<Number>] blocks in cache area [<String>]. |
| 14:72 | Out of cache space after trying to free [<Number>] blocks in cache area [<String>]. |
| 14:73 | Cache area [<String>] is more than [<Number>] percent full. |
| 14:74 | Compressing cache directories during cleanup. |
| 14:75 | Removing recently accessed directories in cache [<String>]. |
| 14:76 | Error while releasing space in cache. |
| 14:77 | Error while trying to reserve [<Number>] blocks in cache area [<String>]. |
| 14:78 | Cannot open index cache directory for [<String>] at time [<String>]. |
| 14:79 | Cannot open job results directory for job id [<Number>]. |
| 14:80 | Cannot process filter [<String>] for [<String>] at time [<String>]. |
| 14:81 | Cannot restore [<String>] in subclient [<String>] - no backup at time [<String>]. |
| 14:82 | At least one Microsoft Exchange link not found in subclient [<String>] - possibly an imported message from remote Palm or laptop. Backup continues. |
| 14:83 | CommServe clock has gone backwards - unable to create a new index version. |
| 14:84 | Please wait. Restoring Index files to the cache [<String>]. |
| 14:85 | Cannot contact client [<String>]. Please check that network connectivity and services are running on client. |
| 14:86 | Protocol error with client [<String>]. Please check that network connectivity and services are running on client. |
| 14:87 | Cannot find this product's list of existing files on client [<String>]. Please see CVRenameDirchange.log log file on client for more information. |
| 14:88 | Cannot copy this product's list of existing files on client [<String>]. Please see CVRenameDirchange.log log file on client for more information. |
| 14:89 | Cannot restore [<String>] - no backup at time [<String>]. |
| 14:90 | Ignoring duplicate subclient content [<String>] in backup set containing subclient [<String>]. |
| 14:91 | Backup data browse in subclient [<String>] not completed due to failed index cache restore. |
| 14:92 | The backup proceeds despite an error while updating the content index. |
| 14:93 | A previous version of this product reported the following pending reason: <String> |
| 14:94 | Indexing reservation mechanism failed on MediaAgent. After making sure no jobs are running on MediaAgent, please send [<String>] to your software vendor. Then delete this reserveFile completely to resume your backups. |
| 14:95 | Failed to start CreateIndex on MediaAgent [<String>] (timeout). Either improper host name resolution, or wrong host name, or that the MediaAgent you're trying to contact is not executing. Please verify software configurations, including name resolution, on both the client and MediaAgent and check the network connectivity between the client and the MediaAgent. |
| 14:96 | Failed to start CreateIndex on MediaAgent [<String>]. Please check the following: network connectivity between client and MediaAgent, MediaAgent's name can be resolved, and this product's services are running on the MediaAgent. |
| 14:97 | The index processing on MediaAgent [<String>] was cancelled by Job Manager. |
| 14:98 | Index processing on MediaAgent [<String>] failed because of a protocol error. |
| 14:99 | Index processing on MediaAgent [<String>] failed due to a CreateIndex processing error. |
| 14:100 | Index processing on MediaAgent [<String>] failed because it was unable to copy an optional file to CreateIndex. |
| 14:101 | Index processing on MediaAgent [<String>] was interrupted by Job Manager. |
| 14:102 | Unable to copy DIR_CHANGE to the CreateIndex process on MediaAgent [<String>]. Index processing failed. |
| 14:103 | UpdateIndex index processing failed - index files are missing, possibly due to a failover. Backup will restart from the beginning. If the problem persists, please call your vendor's support hotline. |
| 14:104 | CreateIndex has no virtual machine name. |
| 14:105 | CreateIndex index processing failed - no index archive files. |
| 14:106 | CreateIndex index processing failed - index files are missing, possibly due to a failover. |
| 14:107 | CreateIndex cannot obtain app type properties. |
| 14:108 | CreateIndex unable to read valid information from iDataAgent. |
| 14:109 | Index processing failed on MediaAgent. This may be due to the index cache being full or because of a corrupt index. |
| 14:110 | Invalid information from iDataAgent. |
| 14:111 | Invalid path sent by iDataAgent to CreateIndex. |
| 14:112 | UpdateIndex detected an abnormally large archive file offset. |
| 14:113 | Index cache restore failed. <Message> |
| 14:114 | Cannot access content index cache. |
| 14:115 | Cannot access index cache. |
| 14:116 | Cannot access Job Results cache. |
| 14:117 | Cannot determine Job Results cache base. |
| 14:118 | Cannot determine index cache base. |
| 14:119 | Please check if index cache directory is present and accessible on the MediaAgent. |
| 14:120 | The MediaAgent was unable to connect back to the client [<String>] to receive the index data. |
| 14:121 | Failed to retrieve data path information. Please ensure that the Storage Policy copy is pointing to a valid data path. |
| 14:122 | Unable to search for [<String>] in subclient [<String>] at time [<String>]. |
| 14:123 | There is insufficient space in the index cache. Please either expand the size of the cache or remove non-index data from the file system. |
| 14:124 | List Media operation is not supported on MediaAgent [<String>]. The MediaAgent version is lower than [<String>] |
| 14:125 | Invalid parameters for the browse operation. |
| 14:126 | Failed to process contents of subclient. |
| 14:127 | Access denied. The user does not have required capabilities to perform List Media operation. |
| 14:128 | There is no data to show in this view. |
| 14:129 | Connection to MediaAgent [<String>] was lost. |
| 14:130 | Failed to connect to MediaAgent [<String>]. |
| 14:131 | Failed to send browse parameters to MediaAgent [<String>]. |
| 14:132 | Invalid time range [<String>] to [<String>] for Browse. |
| 14:133 | Unable to find/get index in the cache for [<String>] at time [<String>]. |
| 14:134 | Cannot open index for [<String>] at time [<String>]. |
| 14:135 | Failed to set number of wildcard browse paths to [<Number>], for [<String>] at time [<String>]. |
| 14:136 | Failed to set browse path[<Number>]: [<String>], for [<String>] at time [<String>]. |
| 14:137 | Browse is not possible. Path [<String>] is too long [<Number>]. |
| 14:138 | Unable to Browse path [<String>], for [<String>] at time [<String>]. This folder may not have been backed up. |
| 14:139 | Browse failed during searching for results in the index. |
| 14:140 | Browse failed for item [<String>], node [<Number>]. [<Number>] nodes were found. [<Number>] nodes were filtered. |
| 14:141 | Browse iterator failed for item [<String>], node [<Number>], parent node [<Number>]. |
| 14:142 | Browse was unable to get FRN for Image Level browse path [<String>]. |
| 14:143 | Browse was unable to get volume name. |
| 14:144 | Browse failed to open metadata file(s) for volume [<String>] in the Index Cache [<String>]. |
| 14:145 | Browse failed to find root node for volume [<String>] in the Index Cache [<String>]. |
| 14:146 | For [<String>] the subclient content was changed from [<String>] to [<String>]. Please use time range before changing subclient content or perform the backup. |
| 14:147 | No results were found in the index [<String>]. |
| 14:148 | Browse was unable to define the type of the browse item. |
| 14:149 | Browse code on the MediaAgent failed to send result(s) back. |
| 14:150 | Browse found no attributes for the node [<Number>] in the index [<String>]. |
| 14:151 | Browse was unable to get AD metadata table in the cache [<String>]. |
| 14:152 | Failed to access Index Cache for [<String>] at time [<String>] with error [<Number>]. |
| 14:153 | COM initialization failed. Please check the installation and Search.log for details. |
| 14:154 | Not enough RAM to perform this operation. |
| 14:155 | Unable to initialize XML support. Please verify version of your GUI and CommServe. |
| 14:156 | Unable to unserialize XML message. Please verify version of your GUI and CommServe. |
| 14:157 | No data was found. FAST COM Layer failed with exception. |
| 14:158 | No data was found. Search failed in the COM layer. Please verify your installation. |
| 14:159 | Start search sequence failed on the CommServe. |
| 14:160 | Search initialization failed. Check your GUI version. |
| 14:161 | Wrong search parameter was detected. Check your GUI version. |
| 14:162 | No results were found. GUI requested non existing results. Check your GUI version. |
| 14:163 | No results were found. FAST COM Layer failed with exception. |
| 14:164 | No results were found. Please verify your installation. |
| 14:165 | Unexpected message was detected. Check your GUI version. |
| 14:166 | Error parsing malformed exception |
| 14:167 | Error retrieving clustered results |
| 14:168 | Error creating Search Engine factory, please check the URL of the search engine |
| 14:169 | Error retrieving Navigated results |
| 14:170 | Error retrieving Navigated results |
| 14:171 | Requested query parameter not found |
| 14:172 | Wrong query parameter specified |
| 14:173 | Requested query parameter not found |
| 14:174 | Error parsing the query result |
| 14:175 | Error while submitting the query |
| 14:176 | Error processing search results |
| 14:177 | Search engine error while submitting the query |
| 14:178 | Error while communicating with the configuration server, please check network connectivity. |
| 14:179 | Generic search error. Please check the log files for more information |
| 14:180 | Stale objects found. Please recycle the search application |
| 14:181 | Search application error. Please check the log files for more information |
| 14:182 | No error reported |
| 14:183 | No data can be found because Subclient Name was changed. Please try browse again in a few minutes. |
| 14:184 | Failed to do search. Please check Search.log for more details. |
| 14:185 | User does not have required capabilities to do the search. |
| 14:186 | Failed to find available FAST server. Please check Search.log for details. |
| 14:187 | Connection to UpdateIndex failed, possibly due to a failover. If the problem persists, please call your vendor's support hotline. |
| 14:188 | Cannot access snapshot metadata cache. |
| 14:189 | Access denied. The user does not have required capabilities to perform restore operation. |
| 14:190 | Synthetic full job for subclient [<String>] failed while processing component index. |
| 14:191 | Failed to clean up metadata files under component index for subclient [<String>] at time [<String>]. |
| 14:192 | Failed to restore component indices under index of subclient [<String>] at time [<String>]. |
| 14:193 | Failed to archive component indices. |
| 14:194 | Unable to access Index Cache for [<String>] at time [<String>]. Please select correct media to restore the index. |
| 14:195 | Index files required for CreateIndex are not present in Index cache. CreateIndex cannot continue. |
| 14:196 | Index cache [<String>] free space on MediaAgent [<String>] is [<Number>] MB. It is considered critically low. Backups will start failing if the cache runs out of space. Take one of the following actions: 1. Increase the index cache total disk space. 2. Reduce the retention setting on the index cache. |
| 14:197 | Volume browse from File backup is not supported. |
| 14:198 | Container browse from File backup is not supported. |
| 14:199 | Container browse from Volume backup is not supported. |
| 14:200 | UpdateIndex failed on MediaAgent [<String>] - Index files are missing. Job could have earlier run on a different MediaAgent possibly due to a failover. |
| 14:201 | Index from previous job was not found on MediaAgent [<String>].The job will resume after restoring the index. |
| 14:202 | CreateIndex failed to connect to Client [<String>]. Please check the following: network connectivity between client and MediaAgent, Client's name can be resolved, and this product's services are running on the MediaAgent/Client. |
| 14:203 | Unable to find/get filter index for the clientId [<Number>], appType [<Number>]. |
| 14:204 | Browse failed due to incompatible erase data on MediaAgent [<String>]. The MediaAgent version is lower than [<String>], please upgrade the MediaAgent. |
| 14:205 | ArchiveIndex failed to process arguments |
| 14:206 | ArchiveIndex initialization failed |
| 14:207 | ArchiveIndex failed to generate collect file for index files |
| 14:208 | ArchiveIndex failed to back up index files |
| 14:209 | Failed to fetch data interface pair configuration for MediaAgent [<String>] from CommServe |
| 14:210 | Search string cannot be empty, please enter a valid input. |
| 14:211 | Free space on deduplication database path [<String>] on MediaAgent [<String>] is [<Number>] MB. It is considered critically low. Backups will start failing if the deduplication database path runs out of space. Increase the deduplication path total disk space. |
| 14:212 | Client [<String>] failed to connect to the Index on MediaAgent [<String>]. Error [<Message>]. |
| 14:213 | Invalid index detected on MediaAgent [<String>]. Please contact administrator. |
| 14:214 | The browse request could take a while for processing. |
| 14:215 | Browse failed due to error occurred during snapshot mount. |
| 14:216 | Failed to create intermediate index while consolidating results from multiple subclients/cycles. Please check Browse.log on MediaAgent [<String>] or contact administrator. |
| 14:217 | Failed to open intermediate index while consolidating results from multiple subclients/cycles. Please check Browse.log on MediaAgent [<String>] or contact administrator. |
| 14:218 | Failed to populate intermediate index while consolidating results from multiple subclients/cycles. Please check Browse.log on MediaAgent [<String>] or contact administrator. |
| 14:219 | A timeout has occurred in populating intermediate index while consolidating results from multiple subclients/cycles. Please check Browse.log on MediaAgent [<String>] or contact administrator. |
| 14:220 | Restore cannot initialize index for [<String>] at time [<String>] (path [<String>]). |
| 14:221 | Browse failed due to error occurred during Virtual Machine registration or Virtual Machine mount. |
| 14:222 | Restore job aborted because of illegal parameters |
| 14:223 | Please check StartSynthFull.log and FsIndexedRestore.log for more details. |
| 14:224 | Browse could not find snap information. If there are no snap jobs for the chosen time range, please do a normal browse. |
| 14:225 | No backups found for the chosen time range. |
| 14:226 | Results could be incomplete because intermediate index could not be populated with results from one or more subclients/cycles. Please check Browse.log on [<String>] or contact administrator. |
| 14:227 | Sufficient space is available in index cache directory [<String>] |
| 14:228 | Prediction conversion failed at CommServe. |
| 14:229 | Unable to connect to CVMA on [<String>]. Please make sure the service is running and retry the job. |
| 14:230 | Restore job could not restore all the items selected. Total items [<String>], Restored items [<String>], Skipped items [<String>], Failed items [<String>]. |
| 14:231 | Refining search results. Please wait... |
| 14:232 | Refining browse results. Please wait... |
| 14:233 | Failed to retrieve NDMP credentials for filer [<String>]. Please add NAS client for filer [<String>] or if NAS client is in de-configured state, reconfigure it. |
| 14:234 | Failed to close intermediate index while consolidating results from multiple subclients/cycles. Please check Browse.log on MediaAgent [<String>] or contact administrator. |
| 14:235 | Failed to obtain lock for consolidating results from multiple subclients/cycles. Please retry the operation after some time. |
| 14:236 | An internal software error has occurred while consolidating results from multiple subclients/cycles. Please check Browse.log on MediaAgent [<String>] or contact administrator. |
| 14:237 | Please contact the administrator to upgrade the MediaAgent. This operation is not supported with older MediaAgents. |
| 14:238 | Exchange Mailbox browse/find cannot span across client upgrade time:[<String>]. Please select the time range before or after the upgrade time. |
| 14:239 | Failed to send/receive information about Indexing Service to/from MediaAgent [<String>]. Retry the operation. |
| 14:240 | Failed to launch Indexing Service on MediaAgent [<String>]. Retry the operation. |
| 14:241 | Protocol error. Unexpected message received from MediaAgent [<String>]. Retry the operation. |
| 14:242 | Failed to receive browse response from MediaAgent [<String>]. Please check Browse.log on MediaAgent. |
| 14:243 | Failed to connect to CommServe. Make sure the CommServe services are running and retry the operation. |
| 14:244 | Failed to initialize browse request. Check Browse.log on CommServe for more details. |
| 14:245 | Protocol error. Unexpected message received from CommServe. Retry the operation. |
| 14:246 | This backupset contains one or more snapshot backups, please browse from subclient level. |
| 14:247 | This backupset contains one or more snapshot backups, please find from subclient level. |
| 14:248 | Low space warning is now resolved and index cache [<String>] now has sufficient free space [<Number>] MB |
| 14:249 | Index is in use by a running job. |
| 14:250 | Index was accessed recently. |
| 14:251 | Index is in use. |
| 14:252 | Failed to open index, check IndexCacheCleanup.log for more details. |
| 14:253 | Failed to delete index, check IndexCacheCleanup.log for more details. |
| 14:254 | Failed to verify state of index. |
| 14:255 | Browse failed due to error occurred during file system mount. |
| 14:256 | Failed to update the CommServe database with usage information of backed up mailboxes. |
| 14:257 | Browse/Restore is not supported from BlockLevel Snap backup with metadata collection disabled. |
| 14:258 | Volume level browse/restore is not supported from snap copy. |
| 14:259 | The existing index format has been updated, please install the latest updates on the client. |
| 14:260 | Failed to update the CommServe database with media usage information of subclient. |
| 14:261 | Browse failed due to error while mounting virtual machine: <String>. |
| 14:262 | Browse failed due to error while mounting backup. |
| 14:263 | Browse failed because a proxy ESX server was not specified. Please select a proxy ESX server on the subclient or instance properties and retry the browse operation. |
| 14:264 | Browse failed because a MediaAgent that supports mounting a virtual machine from media could not be identified. Please select a 'File Recovery Enabler for Linux' on the Virtual Server instance properties. |
| 14:265 | The File Recovery Enabler for Linux reported a problem while browsing the file system of the virtual machine. |
| 14:266 | Setting job to pending due to excessive data drop detected ([<Number>] items) for this subclient (subclient ID [<Number>]). This is [<Number>] percent of the total number of items in the job. Please refer to following kb article [http://kb.commvault.com/#!/WFS0006]. |
| 14:267 | To enable file-level recovery for UNIX MediaAgent [<String>], set the "Allow restore jobs to use alternative MediaAgent and Drive Pool to access required media" parameter in Control Panel Media Management Configuration, and use a Windows MediaAgent for the browse and restore operation. |
| 14:268 | Index Reconstruction is in progress, please wait |
| 14:269 | Browse failed due to internal server error. Please check EvMgrS.log and Browse.log for more details. |
| 14:270 | Unsupported time range chosen for browse. Client upgrade was done at time [<String>]. Please choose a time range either before the upgrade time or after the upgrade time. |
| 14:271 | Object/Version Guid is missing for object [<String>]. Please contact administrator. |
| 14:272 | File/Folder level Browse is not supported because Granular recovery was turned off during backup. |
| 14:273 | No backup copy job could be found. Please check Browse.log for more details. |
| 14:274 | Failed to archive the Index, unable to collect Index Logs from all Backup MediaAgents. Please check ArchiveIndex.log on the MediaAgent [<String>]. |
| 14:275 | No data backed up in this attempt since Index validation could not complete. Job will automatically restart. Please check archiveIndex.log on the MediaAgent [<String>] for further details |
| 14:276 | Previous version was dropped. |
| 14:277 | System deleted retention was met. |
| 14:278 | User deleted retention was met. |
| 14:279 | Invalid reason was marked for dropped file. |
| 14:280 | Unable to continue. Number of the source sub-clients is greater than the 150. Please decrease number of associations in this job. |
| 14:281 | Index server for Client [<String>] -> Application [<String>] -> Backupset [<String>] has been changed from [<String>] to [<String>] |
| 14:282 | Indexing V2 has been enabled due to mismatch in revision. Job will resume after sometime. |
| 14:283 | No Data to Synthesize. |
| 14:284 | Cannot submit exchange retention request to web server[<String>] for user [<String>]. |
| 14:285 | Please note that this is a live browse operation. Live browse operations can take some time before the results appear in the browse window. Viewing older versions and deleted items will not be supported during live browse. |
| 14:286 | Index reconstruction failed. Reason [<String>]. |
| 14:287 | Restore of Index logs failed from media [<String>]. Please check whether media is in library and retry. |
| 14:288 | Index playback failed for job [<String>]. Please check IndexServer.log on MediaAgent [<String>]. |
| 14:289 | Synthetic Full data loss detected since items read during archive index is not equal to items backed up |
| 14:290 | Dangling inode count [<Number>] is high. Please check [<String>] for more details. |
| 14:291 | Browsing files and folders from snap copy is not supported. |
| 14:292 | Updating index, please wait. |
| 14:293 | Updating index is taking longer than expected. Job will resume after some time. |
| 14:294 | MediaAgent [<String>] is offline as it has power management enabled. It might take some time to power on and show browse results |
| 14:295 | Failed to write to Index logs on Media agent [<String>], Reason [<String>]. |
| 14:296 | Following Paths have been deleted: |
| 14:297 | <String> |
| 14:298 | Detected unusual drop in number of protected objects [<Number>]% in Synthetic full job [<Number>]. Previous number of objects [<Number>] and current [<Number>]. |
| 14:299 | Index server changed from [<String>] to [<String>] for index [<String>]. |
| 14:300 | An unusual job activity was detected in Job [<Number>], type [<String>]. Details: <String> |
| 14:301 | Failed to power on Media agent [<String>] |
| 14:302 | Index server [<String>] is in [<String>] state with load [<Number>]% |
| 14:303 | Mismatch detected in number of blocks backed up in synthetic full. Please contact customer support. |
| 14:304 | The index cannot be accessed. Try again later. If the issue persists, contact support. |
| 14:305 | Could not perform the operation as [<String>]. Please check Index Server log for more details. |
| 14:306 | [<Number>] dangling stubs detected in synthetic full job [<Number>]. Please check report [<String>] on Media Agent [<String>] for further details. |
| 14:307 | Number of items qualified for System State are lesser than expected. |
| 14:308 | Job metadata files uploaded could not be backed up. |
| 14:309 | Index could not be backed up. Please check ArchiveIndex.log on the MediaAgent [<String>]. |
| 14:310 | Access denied. The user does not have required capabilities to perform delete data operation. |
| 14:311 | Mismatch detected in blocks being backed up for certain volumes or disks. Next incremental will resolve the situation automatically. |
| 14:312 | Not Supported. Please select HyperV node as MA in Advanced options to browse Windows VM form Linux MA. |
| 14:313 | Unable to upload job metadata to the remote file cache. Please ensure the Media Agent Remote File Cache server [<String>] is online and operational before the job is automatically resumed. |
| 14:314 | Index copy to PNP library failed with error [<String>] |
| 14:315 | Index server change is disabled by GxGlobamParam.EnableIdxSrvrSwitch. Remove or disable the configuration if server change is required. |
| 14:316 | Index server change is not possible as source Media Agent is running Catalog Migration. |
| 14:317 | Index server change is not possible as index size is bigger than Index Cache free space. Please, add more space to Index Cache and retry operation. |
| 14:318 | Index server is disabled on the Media agent [<String>]. |
| 14:319 | Synthetic Full job cannot proceed since zero items were qualified. |
| 14:320 | An anomaly in MIME type classification was detected in job [<Number>], a total of [<Number>] files were affected. |
| 14:321 | Destination file system is not big enough to copy the index cache |
| 14:322 | Folder size shown is approximate. Please select Compute folder size option from browse options for accurate size. |
| 14:323 | Detected MIME classification anomaly in job [<Number>] for client [<String>]. Number of files affected [<Number>]. |
| 14:324 | Could not reach Media Agent [<String>] with hostname [<String>] |
| 14:325 | <html>Detected file type classification anomaly in job [<Number>] for client [<String>]. Number of files affected [<Number>]. Please click <a href="<String>"> here</a> for more details.</html> |
| 14:326 | Log restore failed for job [<Number>] |
| 14:327 | Index reconstruction failed on media agent [<String>] . |
| 14:328 | Access denied. The user [<String>] does not have required capabilities to perform [<Message>] operation. |
| 14:329 | Free disk space is [<Number>] GB is lower than defined threshold of [<Number>] GB. [<Number>] GB is being consumed by index cache data and [<Number>] GB by non-index related data. |
| 14:330 | The index cannot be accessed, please check index server logs. |
| 14:331 | Invalid destination path provided [<String>]. The destination path can't be disk root or the same path with different case (Windows only). |
| 14:332 | Detected an anomaly in [<String>] for process [<String>] PID: [<Number>] |
| 14:333 | Invalid destination path provided [<String>]. The destination path is not empty. |
| 14:334 | UpdateIndex failed on MediaAgent [<String>] - IndexCache is offline. |
| 14:335 | Index restore for backup job [<Number>] requires recall from cold storage. A cloud recall workflow has been initiated with job id [<Number>]. Please retry browse after workflow job is completed. |
| 14:336 | Index server changed from [<String>] to [<String>] for index [<String>], reason: [<String>]. |
| 14:337 | <html>Detected file type classification anomaly in job [<Number>] for client [<String>]. Number of files affected [<Number>]. Please click <a href="<String>"> here</a> for more details.<span style="display: none"><String></span></html> |
| 14:338 | <html>An unusual job activity was detected in Job [<Number>], type [<String>]. Details: <String><span style="display: none"><String></span></html> |
| 14:339 | <String> |
| 14:340 | No results were found. This could be because a 'Delete data by browse' operation was performed on this client. |
| 14:341 | Please wait for the Media Agent [<String>] associated with the Air Gap copy to become accessible and try again. |
| 14:342 | Browse failed because the guest VM OS is not supported. |
Scan Module
| 17:1 | File system scan started. |
| 17:2 | File system scan failed. |
| 17:3 | File system scan and index creation completed. |
| 17:4 | Error during index creation. |
| 17:5 | No space available on disk [<String>]. |
| 17:6 | Error reading directory contents [<String>]. |
| 17:7 | Incremental backup could not find previous image. |
| 17:8 | Filter file not found [<String>]. |
| 17:9 | File system scan failed, error code [<Number>]. |
| 17:10 | Cannot scan [<String>] |
| 17:11 | Configured content does not exist. |
| 17:12 | Backup job is aborted due to file scan failure. |
| 17:13 | Path [<String>] is a symbolic link to [<String>]. |
| 17:14 | Symbolic link detected in subclient content or filter - backup fails. |
| 17:15 | Ancestor/descendant relationship found in subclient content - backup fails. |
| 17:16 | Duplicate subclient content detected - backup fails. |
| 17:17 | Error while automatically changing subclient content or filter - backup fails. |
| 17:18 | Error while obtaining feedback from IFind on symbolic links. |
| 17:19 | Path length exceeds 260 Characters. FindFirstFile limitation reached; cannot process directory [<String>]. |
| 17:20 | Length exceeds [<Number>] characters. This is too long for this product to process; cannot process directory [<String>]. The application may have trouble with this directory. |
| 17:21 | Cannot scan [<String>]. Cause: [<String>] |
| 17:22 | Program Operating System mismatch [<String>] |
| 17:23 | (obsolete) Failed to connect to client [<String>] to begin the scan phase. Please ensure the following: Network connectivity between the CommServe and Client is available; the CommServe is capable of resolving the client machine's IP Address; and this product's Communications Service is running on the client. |
| 17:24 | (obsolete) Failed to send execute request to client [<String>] to begin the scan phase. Please ensure the following: Network connectivity between the CommServe and Client is available; the CommServe is capable of resolving the client machine's IP Address; and this product's Communications Service is running on the client. |
| 17:25 | Failed to execute scan process [<String>] on client [<String>]. Check the following: Network connectivity between CommServe and Client is available. CommServe can resolve Client's IP Address. Also check to see if this product's services are running on the Client. |
| 17:26 | Failed to execute CreateIndex process on MediaAgent [<String>]. Check the following: Network connectivity between Client and MediaAgent is available. Client can resolve MediaAgent's IP Address. Also check if this product's services are running on the MediaAgent. |
| 17:27 | Failed to open backup results file for job [<Number>]. |
| 17:28 | Failed to load the subclient configuration on the client. |
| 17:29 | File scan client timed out and failed to connect to the server. Please Check the [file scan.log] on the client. |
| 17:30 | Cannot create VSS snapshot. Possible reasons: System installed on FAT file system, VSS service is down. Will use legacy methods for system state backup. |
| 17:31 | Skipping backup of path [<String>] because components of the path [<String>] and [<String>] point to the same drive. |
| 17:32 | File scan initialization failure. Possible causes: Services down on Client and/or CommServe, lost network connectivity to CommServe, out of process memory, handles or corrupted install. |
| 17:33 | File Scan could not identify base directory for subclient [%s]. Possibly insufficient permissions or corrupted install |
| 17:34 | Insufficient information to start the job. Possibly mismatched version with CommServe or corrupted install. |
| 17:35 | Failed to open filter file [<String>]. Possible reasons include nonexistent path/file, hardware problems or full disk. |
| 17:36 | Failed to write to filter file [<String>]. Possible reasons include a nonexistent path/file, hardware problems or full disk. |
| 17:37 | Failed to close filter file [<String>]. Possible reasons include nonexistent path/file, hardware problems or full disk. |
| 17:38 | Failed scan as scanning one or more files failed. File scan errors are not tolerated for proxy host backups. |
| 17:39 | File scan failed to write to collect file [<String>]. Possible reasons include nonexistent path/file, hardware problems or full disk. |
| 17:40 | File scan failed to write to dirchange file [<String>]. Possible reasons include nonexistent path/file, hardware problems or insufficient disk space. |
| 17:41 | Invalid path in the subclient content [<String>]. Could not scan this directory. |
| 17:42 | <Message><Message><Message><Message><Message> |
| 17:43 | 0 |
| 17:44 | Some paths are UNC paths.n |
| 17:45 | Some paths do not support Change Journal.n |
| 17:46 | Some paths have mount points.n |
| 17:47 | File Archiver installed.n |
| 17:48 | Failed to complete the scan. Possible causes: the Optimized Scan service is either not ready or is busy creating the database. |
| 17:49 | Failed to further divide the collect files. Possible reasons: nonexistent path/file, hardware problems or full disk. |
| 17:50 | Optimized Scan could not process the request for [<String>]. Falling back to regular scan for this volume/path. Possible causes: Optimized Scan Service is down, Optimized Scan does not monitor this volume/path, or the database is inconsistent. |
| 17:51 | Skipped [<String>] while exploring directory [<String>] as it is among filtered directories. |
| 17:52 | Found [<String>] in list of directories to be filtered. |
| 17:53 | Found [<String>] among exceptions to the list of directories to be filtered. |
| 17:54 | Skipped [<String>] while exploring directory [<String>] as it is under skipped filesystem [<String>]. |
| 17:55 | Failed to create a VSS snapshot required to run a system state backup; marking the backup job failed. |
| 17:56 | Failed to impersonate the specified user; marking the backup job failed. Please check [FileScan.log] on the client. |
| 17:57 | No SILO volumes found on the mount path [<String>]; marking the backup job failed. Please check [FileScan.log] on the client. |
| 17:58 | No SILO volumes found to backup. |
| 17:59 | (Not used) |
| 17:60 | (Not used) |
| 17:61 | (Not used) |
| 17:62 | (Not used) |
| 17:63 | The snapshot generated from the file scan database is not consistent; the database on this volume should be rebuilt, VolumeGuid=[<String>] |
| 17:64 | There are no files that need to be backed up. Finishing the job in the file scan phase. |
| 17:65 | Backup job is in pending state while the index cache folder is being restored. |
| 17:66 | Failed to open file [<String>] for output. Check that the file is not in use by another program. The open attempt returned error [<String>]. |
| 17:67 | Failed to delete [<String>], error reported [<String>]. Please ensure that Antivirus exclusions are in place for Commvault files and folders and check that the items are not in use by another program. |
| 17:68 | Client content [<String>] not found. |
| 17:69 | Client content root path [<String>] of filter [<String>] not found. |
| 17:70 | Subclient content overlaps; [<String>] of subclient [<String>] overlaps [<String>] of subclient [<String>]. |
| 17:71 | [<String>] filters both subclient [<Number>] and subclient [<Number>] (wildcard [<String>]). |
| 17:72 | Failed to process failed items from index. |
| 17:73 | Subclient content overlaps of subclient [<String>]. |
| 17:74 | Extended Attribute is not supported or not enabled in mount point(s) [<String>]. Archiving will not be done for files in this mount point. |
| 17:75 | Failed to suspend/resume device [<String>]. |
| 17:76 | Either GPFS scan or Incremental Image mode is enabled. Previous dirchange version is incompatible. Please run Full job to proceed further. |
| 17:77 | Collect files sort failed. Possible reasons include nonexistent path/file, hardware problems or full disk. |
| 17:78 | Unable to locate GPFS binary path at [<String>]. Please add the path of GPFS binary in 'sGpfsBin' variable in Additional Settings of GUI and resubmit the Job. |
| 17:79 | No jobs ran on catalog configured NAS subclient. |
| 17:80 | 'Track Access Time' is disabled in the Filesystem properties. Hence ignoring the rule 'archive files with access time older than [<Number>] days'. |
| 17:81 | Previous job was committed and it cannot be handled. |
| 17:82 | Commit is not supported. Not backing up files from previous committed job. |
| 17:83 | File system scan failed - there is no GPFS content to back up. |
| 17:84 | Token [<String>] is not a recognized content or filter token. |
| 17:85 | Unable to retrieve records manager content from the CommServe. Please verify if the records are present/configured correctly. |
| 17:86 | All scanned volumes [<String>] are dirty. Please run chkdsk to fix the volume errors. |
| 17:87 | Encountered dirty volume with recursive scan [<String>]. Please run chkdsk to fix the volume errors. |
| 17:88 | The volume(s) [<String>] have dirty bit set. This indicates that the file system may be in an inconsistent state. Data may not get properly protected due to this. Please run chkdsk to check and fix any logical or physical errors on the file system or with file system metadata. |
| 17:89 | User profile [<String>] is not enrolled to use Document Library Services (QDLS). QDLS data is not protected. |
| 17:90 | The following subclient content [<String>] could not be scanned. If content under these paths was backed up at some point in the past, it might not get deleted from media as this could be a temporary issue. Please review and if these paths are no longer eligible for backup, remove them from subclient content so that their content gets marked deleted on the media too. |
| 17:91 | The following subclient content [<String>] are on dirty volume(s) and have not been scanned. Please run chkdsk on corresponding volume(s) to fix errors. |
| 17:92 | [<String>] is a Stale mount point. It will be skipped from Scan and Backup. |
| 17:93 | User settings data is being collected as part of this job for Migration Assistant |
| 17:94 | There are some stale mount points which will be skipped |
| 17:95 | Failed to sync contents of Edge Drive. Pausing the Edge Drive |
| 17:96 | Optimized Scan could not proceed with scanning volume [<String>] as change journal deletion is being observed for the last [<Number>] minutes. This may occur if the file system has many items and the performance is low, or file system is inconsistent which may need to be addressed via chkdsk. The volume may still get processed by other scan methods. |
| 17:97 | Optimized scan could not complete scan on volume [<String>] as the database processing reported disk full error. This volume has [<Number>] bytes of free space available. SQLite is using [<String>] as the path for its temporary usage, and this volume has [<Number>] bytes of free space available. |
| 17:98 | Resetting the file extent backup configuration parameters to FileSize=[<Number> MB], ExtentSize=[<Number> MB], supplied values was FileSize=[<Number> MB], ExtentSize=[<Number> MB]. |
| 17:99 | Unable to initialize NutanixAFS native snap. Failed to load native snap library. |
| 17:100 | Failed to create and mount Nutanix snap. |
| 17:101 | Extent backup will not be performed. Files will be backed up as regular files. [<String>] |
| 17:102 | glusterfind command could not be executed on host : [<String>] volume : [<String>] due to error : [<String>]. |
| 17:103 | glusterfind command could not be executed on host : [<String>] volume : [<String>] due to error : [<String>]. Please check whether keyless ssh is enabled between the gluster server [<String>] and the data access node [<String>]. |
| 17:104 | Cannot check if the gluster server [<String>] and the gluster client [<String>] are time-synced. |
| 17:105 | Time is not synced between gluster server [<String>] and the data access node [<String>]. Delta = [<Number>] ms. Bring Delta < [<Number>] ms. |
| 17:106 | Could not locate directive file [<String>] |
| 17:107 | Backup copy job failed to initialize job results. |
| 17:108 | Found some job(s) that have been aged/deleted in the current cycle, job will behave as Full backup |
| 17:109 | Failed to create collect files for bitmap |
| 17:110 | Failed to load Block Level Backup Library |
| 17:111 | File scan initialization failed to download bitmaps. |
| 17:112 | Failed to process commit job candidates. |
| 17:113 | Failed to create commit collect file. Forcing reference time to 0 to do a full scan. |
| 17:114 | Failed to evaluate edge drive item [<String>]. |
| 17:115 | Missing Edge Drive configuration. |
| 17:116 | Post scan processing failed for edge drive sync job, error : [<String>]. |
| 17:117 | Failed to complete edge drive sync job in scan phase. |
| 17:118 | Failed to load task options. |
| 17:119 | GPFS Scan using mmapplypolicy failed, falling back to regular scan. |
| 17:120 | Failed to find GPFS fileset for path [<String>]. |
| 17:121 | GPFS Scan using mmapplypolicy failed. |
| 17:122 | Filescan initialization failed. Please check FileScan.log for details. |
| 17:123 | Hadoop archiving cannot create stubs, please change the disk cleanup settings accordingly. |
| 17:124 | OnePass driver could not be loaded, it is required for OnePass archiving job on this platform. |
| 17:125 | OnePass is not currently supported on this platform. |
| 17:126 | Unable to initialize Native Snap. Error : [<String>] |
| 17:127 | Cannot open lustre changelog reader information file [<String>] |
| 17:128 | Cannot register changelog reader with the MDT [<String>]. Please check whether keyless ssh is enabled between MDT and the Data Access Node. Unable to De-register already registered changelogs from other MDTs. Please manually delete them and proceed. |
| 17:129 | Cannot register changelog reader with the MDT [<String>]. Please check whether keyless ssh is enabled between MDT and the Data Access Node. |
| 17:130 | Cannot retrieve changelog reader information from MDT [<String>]. Please check whether keyless ssh is enabled between MDT and the Data Access Node. |
| 17:131 | Prepare for snapshot failed. Reason : [<String>]. Please check FileScan.log for details. |
| 17:132 | Access time rule is enabled without enabling 'use Native Snap to preserve file access time option'. This may lead to access time of files being changed and thereby delaying access time rule. |
| 17:133 | Failed to Cleanup and ReSnap mount points that have ReStubbing candidates. |
| 17:134 | Errors encountered while scanning the subclient content. |
| 17:135 | Errors encountered while scanning the subclient content. A possible cause is that some of the subclient content does not exist. |
| 17:136 | Failed to send some items to solr. |
| 17:137 | This job will be forced to run as a full job to address an issue where renaming folder to an already existing folder in previous job can result in not backing up files in the renamed folder. |
| 17:138 | There are no files that need to be backed up. Finishing the job in the file scan phase. One or more subclient contents failed - Marking phase as completed with error. |
| 17:139 | Too many open files, please adjust open file limit. |
| 17:140 | Automatic mount of shares is not supported on UNIX archiving jobs |
| 17:141 | Automatic mount of shares is supported only via multinode backups |
| 17:142 | Failed to process the WorkUnit with error [<String>] |
| 17:143 | Failed to get items using criteria with error [<String>] |
| 17:144 | Failed to count items. Error [<String>] |
| 17:145 | Failed to fetch items. Error [<String>] |
| 17:146 | Failed to initialize failure file. Error [<String>] |
| 17:147 | Snap Shot [<String>] creation failed for path [<String>]. Error [<String>] |
| 17:148 | Comparison of the snapshot [<String>] and [<String>] failed. Error [<String>] |
| 17:149 | API [<String>] failed with error [<String>]. |
| 17:150 | Unable to fetch file server host and login info, error [<String>] |
| 17:151 | Failed to initialize and load NAS snap scan library. |
| 17:152 | Failed to create snapshot or build snapshot information. Please check if supplied user credentials are correct and the user has sufficient REST API permissions. |
| 17:153 | Reboot is pending on host [<String>] due to Windows updates. System State backup may be inconsistent, leading to issues when recovering the system via 1Touch or Full System Restores. Please consider rebooting the host system. |
| 17:154 | GPFS optimized scan is not supported on remote cluster device [<String>] |
| 17:155 | There was insufficient physical space to create the shadow copy which is required for a system state backup. Please try increasing the maximum size limit used to store shadow copies of the according volume. If the error remains, extend the physical volume or switch to a larger volume to store the shadow copies. Please refer to the following KB article [http://kb.commvault.com/article/WFS0010]. |
| 17:156 | Essential System State filters [<String>] will be ignored for this backup job else it renders System State backup unusable for recovery. |
| 17:157 | Unable to fetch file server host and login info from MediaManager. |
| 17:158 | Configured content does not exist [<String>]. |
| 17:159 | Differential Job not supported for <String> |
| 17:160 | The command file [<String>] changed since the last Full Backup Job. Please run a new Full Backup Job. |
| 17:161 | Unable to parse command file [<String>]. Please correct the file format and run a new Full Backup Job. |
| 17:162 | The command file [<String>] or Dir Change file [<String>] not found. Please run a new Full Backup Job. |
| 17:163 | The subclient with command file supports only a Full Backup job. The job will behave as Full backup. |
| 17:164 | [%llu] incomplete items backed up in extents reported from Index |
| 17:165 | Error accessing snapshot [<String>] on volume/path [<String>] error [<String>]. Please check if snapshot access is enabled. |
| 17:166 | Some Scan content is part of NTFS Deduplicated volume |
| 17:167 | Could not determine if volume [%s] is an NTFS Deduplicated volume. Please check if WMI service is in a healthy state. |
| 17:168 | FileScan failed with error [<String>] |
| 17:169 | *SYNCLIB option must be used with custom subclient content only. |
| 17:170 | *SYNCLIB option must be used only with libraries. <String> |
| 17:171 | Job failed because client group capacity quota is exceeded. |
| 17:172 | Unable to mount volumes [<String>] for cataloging. |
| 17:173 | Backup job failed because the option CFT_BACKUP is not enabled for the share [<String>]. |
| 17:174 | Found some job(s) have been aged/deleted in the current cycle. Job will behave as Full Job. |
| 17:175 | Failed to process system state component. System state backup is skipped. Please see the log file for more details. |
| 17:176 | Failed to create VSS snapshot required to run system state backup. System state backup is skipped. VSS error [<String>]. Please refer VSS Event logs for more details. |
| 17:177 | <String> Job not supported for <String> |
| 17:178 | Create snapshot failed on [<String>]. Error [<String>]. |
| 17:179 | Following errors occurred while scanning: [<String>] |
| 17:180 | VSS operation failed even after restarting the VSS services. Please reboot the system and resubmit the job to proceed further. |
| 17:181 | TrueUp Processing has been disabled for this job because of browse failure |
| 17:182 | TrueUp Processing has been disabled for this job because TrueUp state file could not be processed |
| 17:183 | Failed to register with the configured NetAPP client [<String>]. Please check the client configuration |
| 17:184 | Failed to monitor the volume [<String>] and will not be archived. |
| 17:185 | Failed to load the block level metadata files from index cache. Please Check the [file scan.log] on the client. |
| 17:186 | Impersonating user is not supported. |
| 17:187 | FileScan failed to write to job results directory due to insufficient space. |
| 17:188 | The user has reached the trial period data size limit for analytics services. |
| 17:189 | Failed to unmount volumes under [<String>] during restarted scan attempt. Please check if the mount points are busy/stale. |
| 17:190 | None of the configured subclient contents could be backed up. |
| 17:191 | 4 or more subclient contents failed to back up. Please check the logs for more details. |
| 17:192 | Failed to backup some of the subclient contents [<String>] |
| 17:193 | Threat analysis completed with some failures for client [<String>]. Found [<String>] threats. Report link [<String>]. Full threat information is present in file [<String>] in client [<String>]. |
| 17:194 | Threat analysis completed with failures for client [<String>] and found no threats |
| 17:195 | Threat analysis completed successfully for client [<String>] with [<String>] threats. Report link [<String>]. Full threat information is present in file [<String>] in client [<String>] |
| 17:196 | Threat analysis completed successfully for client [<String>] without threats. |
| 17:197 | Previous snapshot backed up is same as current snapshot [<String>] for path [<String>] on file server [<String>]. No data will be backed up in current job. |
| 17:198 | No snaps found on the volume [<String>] with prefix [<String>] on file server [<String>]. Continue backup from live filesystem. |
Informix iDataAgent
| 45:1 | Informix not relinked for Informix Home [<String>] on client [<String>]. Please relink Informix on the client and then backup/restore. |
| 45:2 | Failed to get Informix information from client; database may not be opened. |
| 45:3 | Informix iDataAgent not installed properly. |
| 45:4 | Version of Informix libraries does not match the version this product expects. Please relink or reinstall the Informix iDataAgent. |
| 45:5 | Not a valid Informix Home Directory - Please Re-enter. |
| 45:6 | Not a valid Informix onconfig filename - Please Re-enter. |
| 45:7 | Not a valid Informix Instance - Please Re-enter. |
| 45:8 | Not a valid Informix user name - Please Re-enter. |
| 45:9 | INFORMIXSERVER not defined in the Informix environment on the client. |
| 45:10 | Failed to communicate to the client services on host [<String>]. A network error occurred or the product's services are not running. |
| 45:11 | Informix Server [~<String>~] is in an incorrect state for this backup or restore request. Check the error message in the ON-Bar activity log. |
| 45:12 | Failed to edit the onconfig file to add XBSA library path. Please check the logs for more details. |
| 45:13 | Failed to create the sm_versions file under INFORMIXHOME/etc directory. Please check the logs for more details. |
| 45:14 | Failed to logon with the given user details. Please Re-enter.Browse Failed. |
| 45:15 | Failed to impersonate the given user. Browse Failed. |
| 45:16 | Storage Policy has less streams [<Number>] than BAR_MAX in onconfig [<Number>] - Backup failed |
| 45:17 | Not a valid Sqlhosts file path - Please Re-enter. |
| 45:18 | DBSpace has been modified. The backup job will continue as a full job. |
| 45:19 | Please check if the Informix Server [<String>] is online. |
| 45:20 | Database Server [<String>] is not responding. Please check the ON-Bar activity log for the exact error. |
| 45:21 | Failed to Open File - [<String>]. Error No - [<Number>]. Error Message - [<String>]. |
Image Level iDataAgent
| 70:1 | Exiting because event initialization failed. |
| 70:2 | Error notifying Job Manager of successful completion. |
| 70:3 | Error notifying Job Manager of failure. |
| 70:4 | Started |
| 70:5 | Exiting... |
| 70:6 | Failed to freeze [<String>]. Please ensure that all files are closed. |
| 70:7 | Failed to thaw [<String>]. |
| 70:8 | Failed to get extent list for [<String>]. |
| 70:9 | Failed to create archive file. |
| 70:10 | Failed to close archive file. |
| 70:11 | Failed to create index. |
| 70:12 | Failed to enumerate subclient content. |
| 70:13 | Failed to back up [<String>]. |
| 70:14 | Failed to get volume information. |
| 70:15 | Failed to get bitmap information. |
| 70:16 | Failed to clear bitmap information. |
| 70:17 | Failed to reset bitmap information. |
| 70:18 | Failed to open collect file. |
| 70:19 | Failed to write into collect file. |
| 70:20 | Failed to read from collect file. |
| 70:21 | Failed to seek into collect file. |
| 70:22 | Failed to create collect file. |
| 70:23 | Failed to create volume object. |
| 70:24 | Backup job [<Number>] has been converted to a full backup because last shutdown was not proper or complete volume needs to be backed up. |
| 70:25 | Successfully backed up volume(s) [<String>]. |
| 70:26 | Backup failed for volume(s) [<String>]. |
| 70:27 | Backup is partially successful. |
| 70:28 | Volume synchronization failed for snapshot driver. |
| 70:29 | Error while getting changed block offsets from snapshot driver. |
| 70:30 | Extent backup failed. Possible causes: corruption on source, snapshot failed or failed to communicate with MediaAgent [<String>]. |
| 70:31 | The destination volume is smaller than source. Please pick right size Destination volume. |
| 70:32 | ImgFileLvlIndexRestore error when launching restore process to get Indexing files. Please check if the product's services are running. |
| 70:33 | ImgFileLvlIndexRestore portion of required MFT information cannot be recovered; restore failed. |
| 70:34 | ImgFileLvlIndexRestore processing failed - cannot open ImgFRN information files. |
| 70:35 | ImgFileLvlIndexRestore processing failed - Error retrieving information from the restored MFT file. |
| 70:36 | Failed to restart job. Invalid restart string. |
| 70:37 | Failed to enumerate subclient content. Please check if the device is mounted to the given mount point as subclient content. |
| 70:38 | Failed to prepare bitmap file name. |
| 70:39 | Failed to read bitmap from bitmap file. |
| 70:40 | Failed to get and clear bitmap. |
| 70:41 | Failed to merge bitmap. |
| 70:42 | Failed to save bitmap on disk. |
| 70:43 | Failed to get bitmap from driver. |
| 70:44 | Failed to save Collect File Map on disk. |
| 70:45 | Failed to save SnapMap on disk. |
| 70:46 | Failed to read SnapMap from disk. |
| 70:47 | Failed to read CollectMap from disk. |
| 70:48 | Failed to read from snapshot. |
| 70:49 | Failed to read from Collect file. The Collect file may be corrupted. |
| 70:50 | Failed to open volume [<String>]. |
| 70:51 | For volume [<String>] DATABLOCK map is not ready; going to do full copy. |
| 70:52 | For volume [<String>] DATABLOCK map is ready; going to do DATABLOCK ONLY copy. |
| 70:53 | Restart string sent by Job Manager cannot be used. Start a new job. |
| 70:54 | Setting snapshot driver cache configuration failed. Please check that the driver is loaded; try rebooting and ensure that cache is located on NTFS partition. |
| 70:55 | Failed to get bitmap from production host. |
| 70:56 | Failed to read bitmap on disk. Extent size must have changed. |
| 70:57 | Error updating ShadowID to Job Manager. |
| 70:58 | Failed to get Disk Volume Extents, error [<Number>]. |
| 70:59 | Backup will copy All Blocks. |
| 70:60 | Read from snapshot failed; Please check your cache settings. Snapshot possibly was deleted due to cache overflow. |
| 70:61 | Creation of snapshot failed. Please check if there was written activity on volume [<String>]. Also check if minimum cache space is available on the cache partition. Then Schedule the backup at off-peak hour. |
| 70:62 | Unable to get volume information for [<String>]. Please check access rights on this volume. |
| 70:63 | Extent size on volume [<String>] changed, forcing full backup. |
| 70:64 | Image Level block filter not activated. Possible causes: driver not loaded, block filter not activated. |
| 70:65 | Failed to mount back restore volume. User intervention required to mount it manually. |
| 70:66 | Failed to lock destination volume. [<String>]. |
| 70:67 | The destination volume is not a mount point or device |
| 70:68 | Forcing Full backup for volume(s) - [<String>] |
Job Manager Service
| 19:1 | Out of Memory. |
| 19:2 | Failed to establish a connection to Job Manager Service. Server=[<String>], session error=[<Number>]. |
| 19:3 | Failed to disconnect from Job Manager Service. Server=[<String>], session error=[<Number>]. |
| 19:4 | Failed to send message to Job Manager Service. Server=[<String>], session error=[<Number>]. |
| 19:5 | Failed to receive message from Job Manager Service. Server=[<String>], session error=[<Number>]. |
| 19:6 | No response from the Job Manager. Server=[<String>]. |
| 19:7 | Received invalid message from the Job Manager. Server=[<String>]. |
| 19:8 | Job Manager received invalid message. Remote host=[<String>]. |
| 19:9 | Error in submitting backup request to the Job Manager. Server=[<String>]. |
| 19:10 | Error in submitting restore request to the Job Manager. Server=[<String>]. |
| 19:11 | Error in submitting administration request to the Job Manager. Server=[<String>]. |
| 19:12 | Error in receiving Job ID from the Job Manager service. Server=[<String>]. |
| 19:13 | Error in receiving go-ahead from the Job Manager service. Server=[<String>]. |
| 19:14 | Job Manager service requested exit. Server=[<String>]; |
| 19:15 | [<Number>]: Invalid Job ID received from Job Manager Service. |
| 19:16 | Phase parameter can be no longer than [<Number>]. |
| 19:17 | Restart string can be no longer than [<Number>]. |
| 19:18 | Number of bytes cannot be negative. |
| 19:19 | Number of files cannot be negative. |
| 19:20 | Reference time cannot be negative. |
| 19:21 | Null string passed for phase parameters. |
| 19:22 | Null string passed for application arguments. |
| 19:23 | Null string passed for MediaAgent name. |
| 19:24 | Null string passed for the compression scheme. |
| 19:25 | Null string passed for the machine name. |
| 19:26 | Null string passed for the entity that is being operated on. |
| 19:27 | Null string passed for the name of an entity. |
| 19:28 | Null string passed for the criteria. |
| 19:29 | Null string passed for the client. |
| 19:30 | Library ID cannot be negative. |
| 19:31 | Error in setting the application arguments. |
| 19:32 | Error in constructing the session message for the subclient object. |
| 19:33 | Error in accessing target copy list from the backup request object. |
| 19:34 | Invalid control flag is specified. |
| 19:35 | Failed to fetch the local machine host name from the registry. Cannot run job. |
| 19:36 | Still waiting for go ahead from the JobManager.server=[<String>]. |
| 19:37 | Error in constructing the user ID object. |
| 19:38 | Application construction failed. Your configuration might be inconsistent. Please try opening your CommCell Console again. |
| 19:39 | Error in constructing the client priority object. |
| 19:40 | Error in constructing the application priority object. |
| 19:41 | Error in constructing the operation priority object. |
| 19:42 | Error in setting the machines. |
| 19:43 | Error in setting the operation on entity. |
| 19:44 | Error in setting the list of entities. |
| 19:45 | Error in setting the criteria. |
| 19:46 | The name of source storage policy cannot be longer than [<Number>]. |
| 19:47 | The name of backpack cannot be longer than [<Number>]. |
| 19:48 | Copy ID has to be positive. |
| 19:49 | Error in constructing the object. |
| 19:50 | Priority value cannot be negative. |
| 19:51 | Priority value cannot be more than [<Number>]. |
| 19:52 | Failed to successfully read the configuration. |
| 19:53 | Failed to read the service configuration. |
| 19:54 | Failed to set up the initial values before starting. |
| 19:55 | Failed to read the application type configuration. |
| 19:56 | Failed to read the activity configuration. |
| 19:57 | Restore job [<Number>] was not found. |
| 19:58 | Backup job [<Number>] was not found in pending queue. |
| 19:59 | Restore job [<Number>] was not found in pending queue. |
| 19:60 | Null passed in for the executable name. |
| 19:61 | Executable name cannot be longer than [<Number>]. |
| 19:62 | Invalid type [<Number>] of job in job queue. |
| 19:63 | Invalid operation type [<Number>]. |
| 19:64 | Invalid application type [<Number>]. |
| 19:65 | Failed to get the application details. |
| 19:66 | Failed to get the application number. |
| 19:67 | Failed to get the target storage policy ID for application number [<String>]. |
| 19:68 | Failed to get priorities from the backup job information object. |
| 19:69 | Failed to get the configuration for application type [<Number>]. |
| 19:70 | Failed to get the configuration for application type [<Number>], operation type [<Number>]. |
| 19:71 | Failed to get the configuration for application type [<Number>], operation type [<Number>], phase [<String>]. |
| 19:72 | Failed to initialize stats object. |
| 19:73 | Failed to add stats record to the database. |
| 19:74 | Failed to add an attempt status record to the database. |
| 19:75 | Failed to start a database transaction [<String>]. |
| 19:76 | Failed to insert a database row in table [<String>], Error [<String>]. |
| 19:77 | Failed to update phase parameters for job [<Number>]. |
| 19:78 | Failed to update restart string for job [<Number>]. |
| 19:79 | Failed to update reference time for job [<Number>]. |
| 19:80 | Failed to get reference time for job [<Number>]. |
| 19:81 | Application Manager Exception for class [<String>]. |
| 19:82 | Failed to get the instance ID for CommCell [<String>], client [<String>], application type [<Number>], instance [<String>]. |
| 19:83 | Failed to get the Backup Set ID for CommCell [<String>], client [<String>], application type [<Number>], Backup Set [<String>]. |
| 19:84 | Failed to get the Backup Set ID for CommCell [<String>], client [<String>], application type [<Number>], instance [<String>], Backup Set [<String>]. |
| 19:85 | Failed to get the Subclient ID for CommCell [<String>], client [<String>], application type [<Number>], Backup Set [<String>], Subclient [<String>]. |
| 19:86 | Failed to get the Subclient ID for CommCell [<String>], client [<String>], application type [<Number>], instance [<String>] Backup Set [<String>], Subclient [<String>]. |
| 19:87 | Failed to look up application ID for CommCell [<String>], client [<String>], application type [<Number>], Backup Set [<String>], Subclient [<String>]. |
| 19:88 | Failed to look up application ID for application id [<String>]. |
| 19:89 | Failed to get the application id for CommCell [<String>], client [<String>], application type [<Number>], Backup Set [<String>], Subclient [<String>]. |
| 19:90 | Failed to get the application id for CommCell [<String>], client [<String>], application type [<Number>], instance [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:91 | Failed to get the data target storage policy ID. |
| 19:92 | Failed to construct CommCell Console message for Backup Job. Please call your vendor's support hotline. |
| 19:93 | Failed to construct CommCell Console message for Restore Job. Please call your vendor's support hotline. |
| 19:94 | Failed to send the information for a backup job. |
| 19:95 | Failed to send the information for a restore job. |
| 19:96 | Failed to send the information for a CommServe Disaster Recovery backup job. |
| 19:97 | Failed to send the information for a Data Aging job. |
| 19:98 | Failed to get command line arguments for File System job [<Number>]. |
| 19:99 | Failed to get command line arguments for Lotus Notes Document job [<Number>]. |
| 19:100 | Failed to get command line arguments for Exchange Database job [<Number>]. |
| 19:101 | Failed to get command line arguments for Exchange Mailbox job [<Number>]. |
| 19:102 | Failed to get command line arguments for test job [<Number>]. |
| 19:103 | Failed to get start-up information for the job [<Number>]. |
| 19:104 | Failed to get the target MediaAgent name for job [<Number>]. |
| 19:105 | Invalid start-up information for job [<Number>]. |
| 19:106 | Failed to start phase [<String>] for job [<Number>] due to network error[<Number>]. Will attempt to restart. |
| 19:107 | Phase [<String>] for job [<Number>] has started. |
| 19:108 | Null client name is encountered in the subclient object for job ID [<Number>]. |
| 19:109 | Invalid phase [<Number>] for File System job [<Number>]. |
| 19:110 | Invalid phase [<Number>] for Lotus Notes Document job [<Number>]. |
| 19:111 | Invalid phase [<Number>] for Exchange Database job [<Number>]. |
| 19:112 | Invalid phase [<Number>] for Exchange Mailbox job [<Number>]. |
| 19:113 | Invalid phase [<Number>] for test job [<Number>]. |
| 19:114 | Received update message for backup job [<Number>], but the job is not running. |
| 19:115 | Received update message for restore job [<Number>], but the job is not running. |
| 19:116 | Backup job [<Number>] failed; client [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:117 | Restore job [<Number>] failed. |
| 19:118 | Backup job [<Number>] completed. |
| 19:119 | Restore job [<Number>] completed. |
| 19:120 | Phase [<String>] for job [<Number>] completed. |
| 19:121 | Received completed message for restore job [<Number>]. |
| 19:122 | Received failed message for job [<Number>], phase [<String>]. |
| 19:123 | Phase [<String>], for job [<Number>] will be restarted. |
| 19:124 | Phase [<String>], for job [<Number>] has failed too many times. |
| 19:125 | Failed to initialize backup request. |
| 19:126 | Failed to get the Job ID due to a database error. Try resubmitting the job again after some time. |
| 19:127 | Failed to send job ID to a client. |
| 19:128 | Failed to send approval message to a client. |
| 19:129 | Client disconnected while sending Job ID. |
| 19:130 | New backup request received for client [<String>], application type [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:131 | The resources required for phase [<String>] of job [<Number>] are not available. |
| 19:132 | Received job completed for restore job [<Number>], but the job is not running. |
| 19:133 | New restore request received for client [<String>], application type [<String>]. |
| 19:134 | Failed to update information for the restore job [<Number>]. |
| 19:135 | Failed to disable activity for the client [<String>]. |
| 19:136 | Failed to enable activity for the client [<String>]. |
| 19:137 | Failed to disable activity for the application type [<Number>]. |
| 19:138 | Failed to enable activity for the application type [<Number>]. |
| 19:139 | Failed to disable activity for CommServe. |
| 19:140 | Failed to enable activity for CommServe. |
| 19:141 | Application number string is longer than 25 characters. |
| 19:142 | Null string passed for the CommCell name. |
| 19:143 | Null string passed for the subclient name. |
| 19:144 | Null string passed for the backup set name. |
| 19:145 | Null string passed for the instance name. |
| 19:146 | Subclient name cannot be longer than [<Number>]. |
| 19:147 | Backup Set name cannot be longer than [<Number>]. |
| 19:148 | Invalid backup history query submitted. |
| 19:149 | Failed to construct the backup history object from session message. |
| 19:150 | Failed to get the application number list for the backup history query. |
| 19:151 | No backup history for the job [<Number>]. |
| 19:152 | Database error encountered. Table = [<String>], Error = [<String>]. |
| 19:153 | Failed to create the backup statistics information object from a database record. |
| 19:154 | Failed to get the attempt information for job [<Number>] from database. |
| 19:155 | Entry exists in the database, but no information in database for the job [<Number>]. |
| 19:156 | Failed to create the attempts statistics information object from a database record. |
| 19:157 | Failed to construct a session message backup statistics information object. |
| 19:158 | Encountered an invalid application type in the backup stats record. |
| 19:159 | Encountered an invalid backup level in the backup stats record. |
| 19:160 | Encountered an invalid status in the backup stats record. |
| 19:161 | Entry for the client [<Number>] missing from the job Action table. |
| 19:162 | Entry for the application type [<Number>] missing from the job Action table. |
| 19:163 | Entry for the CommServe is missing from the job Action table. |
| 19:164 | Entry for the CommCell is missing from CommCell table. |
| 19:165 | Failed to get the current activity configuration to report to CommCell Console. |
| 19:166 | Failed to get the CommCell ID. |
| 19:167 | The semaphore used by scheduler thread already exists. |
| 19:168 | License [<String>] is not active at this time. |
| 19:169 | The license for client [<String>] and application type [<String>] will expire in [<Number>] days. |
| 19:170 | Failed to get the application list from the Application Manager for domain ID [<Number>], client ID [<Number>]. |
| 19:171 | No applications found for CommCell ID [<Number>], client ID [<Number>]. |
| 19:172 | Invalid application number [<String>] returned by the Application Manager. |
| 19:173 | Failed to get the application list from the Application Manager for domain ID [<Number>], client ID [<Number>], application type [<Number>]. |
| 19:174 | No applications found for CommCell ID [<Number>], client ID [<Number>], application type [<Number>]. |
| 19:175 | Failed to get the application list from the Application Manager for domain ID [<Number>], client ID [<Number>], application type [<Number>], instance ID [<Number>], backup set ID [<Number>]. |
| 19:176 | No applications found for CommCell ID [<Number>], client ID [<Number>], application type [<Number>], instance ID [<Number>], Backup Set ID [<Number>]. |
| 19:177 | Dependency check failed for the restore and the job cannot run. |
| 19:178 | Queue operation [<String>] failed with an exception. |
| 19:179 | Job [<Number>] has been killed. |
| 19:180 | Job [<Number>] has been suspended by user's request. |
| 19:181 | Job Manager received an invalid control operation [<Number>] for job [<Number>]. |
| 19:182 | Kill request pending for job [<Number>]. |
| 19:183 | Stop request pending for job [<Number>]. |
| 19:184 | Cannot get control information for job [<Number>]. |
| 19:185 | Failed to kill the job [<Number>]. |
| 19:186 | Failed to stop the job [<Number>]. |
| 19:187 | Processes for Job [<Number>] were forcefully terminated as they did not respond to control messages. |
| 19:188 | Cannot locate job [<Number>]. |
| 19:189 | Another backup is running for client [<String>], application type [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:190 | Failed to get maximum instance criteria for the application type [<Number>]. |
| 19:191 | Failed to look up the Backup Set for application number [<String>]. |
| 19:192 | Failed to construct a restore job server object for restore task ID [<Number>]. |
| 19:193 | Failed to construct a restore information object for the task ID [<Number>]. |
| 19:194 | Failed to get the client name for CommCell ID [<Number>] and client ID [<Number>]. |
| 19:195 | Failed to create shared memory region [<Number>]. |
| 19:196 | Failed to create semaphore [<Number>]. |
| 19:197 | Failed to write response to shared memory [<Number>]. |
| 19:198 | Failed to release resource [<Number>]. |
| 19:199 | Failed to start a session to send control. |
| 19:200 | Failed to open shared memory to read [<Number>]. |
| 19:201 | Failed to map shared memory [<Number>]. |
| 19:202 | Failed to open shared memory to write [<Number>]. |
| 19:203 | Failed to read response from shared memory. |
| 19:204 | Failed to wait for control response. |
| 19:205 | Received an unexpected message. |
| 19:206 | Failed to get registration. |
| 19:207 | Failed to send control message to this product's Communications Service (CVD) on client [<String>]. Check the Services on the client machine and the network connectivity. |
| 19:208 | Failed to write register message to shared memory. |
| 19:209 | Failed to create control thread. |
| 19:210 | Error registering job with the Communications Service. |
| 19:211 | Control semaphore failed. |
| 19:212 | Semaphore was released. |
| 19:213 | The Communications Service released semaphore. |
| 19:214 | Failed waiting for worker to quit, [<Number>]. |
| 19:215 | Failed to release wait semaphore. |
| 19:216 | Failed to unregister job with the Communications Service. |
| 19:217 | Error in starting a thread. |
| 19:218 | Error failed to grab resource, [<Number>]. |
| 19:219 | Control thread finished. |
| 19:220 | No restore history for the job. |
| 19:221 | Failed to construct a session message for restore statistics information object. |
| 19:222 | Failed to update job info for job [<Number>] in table [<String>] for field [<String>] with error [<String>]. |
| 19:223 | Failed to delete rows for job [<Number>] from table [<String>] with error [<String>]. |
| 19:224 | Entries for job [<Number>] are inconsistent in different tables. |
| 19:225 | Failed to initialize backup job [<Number>] from database. |
| 19:226 | Failed to initialize restore job [<Number>] from database. |
| 19:227 | Failed to clean up all jobs from the database. |
| 19:228 | Process for current phase is not running. No Control Registration Received in timeout period. Please check the logs for the current phase on the client machine. |
| 19:229 | Failed to receive control request response from the Communications Service in timeout period. |
| 19:230 | Failed to set up control semaphore. |
| 19:231 | Index failure during job [<Number>] has triggered a full backup job [<Number>]. |
| 19:232 | Backup job [<Number>] has been converted to a full backup because a full backup has not been run. |
| 19:233 | Job [<Number>] cannot be suspended. |
| 19:234 | Job [<Number>] resumed by user's request. |
| 19:235 | Abnormally terminated backup job [<Number>] detected and has been terminated without user intervention. |
| 19:236 | Abnormally terminated restore job [<Number>] detected and has been terminated without user intervention. |
| 19:237 | Abnormally terminated Data Aging job [<Number>] detected and has been terminated without user intervention. |
| 19:238 | Abnormally terminated CommServe Disaster Recovery backup job [<Number>] detected and has been terminated without user intervention. |
| 19:239 | Request to stop job [<Number>] timed out. Phase will be terminated. |
| 19:240 | Request to kill job [<Number>] timed out. Phase will be terminated. |
| 19:241 | Request to terminate job [<Number>] failed. |
| 19:242 | Failed to send control request for job [<Number>] to the Communications Service. |
| 19:243 | A control request is already pending for job [<Number>]. |
| 19:244 | Data Aging operation is already running. |
| 19:245 | Error in submitting Data Aging request to the JobManager. Server=[<String>]. |
| 19:246 | Error in submitting CommServe Disaster Recovery Backup request to the JobManager. Server=[<String>]. |
| 19:247 | Failed to construct CommServe Disaster Recovery Backup job server object. |
| 19:248 | Failed to construct backup job object from the session message. |
| 19:249 | Failed to get the CommServe host name from the platform information. |
| 19:250 | Duplicate process registration for job [<Number>]. |
| 19:251 | Failed to terminate all process for job [<Number>]. |
| 19:252 | Invalid control mechanism sent to the job control server. |
| 19:253 | No control mechanism has been defined for this phase for job [<Number>]. |
| 19:254 | List operation [<String>] failed with an exception. |
| 19:255 | Wrong backup level for the CommServe Disaster Recovery backup [<Number>]. |
| 19:256 | Destination directory is not specified for the CommServe Disaster Recovery backup [<Number>]. |
| 19:257 | No database name is specified for the CommServe Disaster Recovery backup [<Number>]. |
| 19:258 | Failed to submit index restore registration to the CommServe [<String>]. |
| 19:259 | Failed to send index restore completion to the CommServe [<String>]. |
| 19:260 | Application ID for job [<Number>] has been deleted. |
| 19:261 | Data Aging operation has been disabled. |
| 19:262 | Data Aging operation has been enabled. |
| 19:263 | Backups on the server have been disabled. |
| 19:264 | Backups on the server have been enabled. |
| 19:265 | Restores on the server have been disabled. |
| 19:266 | Restores on the server have been enabled. |
| 19:267 | Both backups and restores have been disabled on the server. |
| 19:268 | Both backups and restores have been enabled on the server. |
| 19:269 | File System backups have been disabled on the server. |
| 19:270 | File System backups have been enabled on the server. |
| 19:271 | File System restores have been disabled on the server. |
| 19:272 | File System restores have been enabled on the server. |
| 19:273 | File System backups and restores have been disabled on the server. |
| 19:274 | File System backups and restores have been enabled on the server. |
| 19:275 | Exchange Mailbox backups have been disabled on the server. |
| 19:276 | Exchange Mailbox backups have been enabled on the server. |
| 19:277 | Exchange Mailbox restores have been disabled on the server. |
| 19:278 | Exchange Mailbox restores have been enabled on the server. |
| 19:279 | Exchange Mailbox backups and restores have been disabled on the server. |
| 19:280 | Exchange Mailbox backups and restores have been enabled on the server. |
| 19:281 | Exchange Database backups have been disabled on the server. |
| 19:282 | Exchange Database backups have been enabled on the server. |
| 19:283 | Exchange Database restores have been disabled on the server. |
| 19:284 | Exchange Database restores have been enabled on the server. |
| 19:285 | Exchange Database backups and restores have been disabled on the server. |
| 19:286 | Exchange Database backups and restores have been enabled on the server. |
| 19:287 | Backups on the client [<String>] have been disabled. |
| 19:288 | Backups on the client [<String>] have been enabled. |
| 19:289 | Restores on the client [<String>] have been disabled. |
| 19:290 | Restores on the client [<String>] have been enabled. |
| 19:291 | Both backups and restores have been disabled on the client [<String>]. |
| 19:292 | Both backups and restores have been enabled on the client [<String>]. |
| 19:293 | File System backups have been disabled on the client [<String>]. |
| 19:294 | File System backups have been enabled on the client [<String>]. |
| 19:295 | File System restores have been disabled on the client [<String>]. |
| 19:296 | File System restores have been enabled on the client [<String>]. |
| 19:297 | File System backups and restores have been disabled on the client [<String>]. |
| 19:298 | File System backups and restores have been enabled on the client [<String>]. |
| 19:299 | Exchange Mailbox backups have been disabled on the client [<String>]. |
| 19:300 | Exchange Mailbox backups have been enabled on the client [<String>]. |
| 19:301 | Exchange Mailbox restores have been disabled on the client [<String>]. |
| 19:302 | Exchange Mailbox restores have been enabled on the client [<String>]. |
| 19:303 | Exchange Mailbox backups and restores have been disabled on the client [<String>]. |
| 19:304 | Exchange Mailbox backups and restores have been enabled on the client [<String>]. |
| 19:305 | Exchange Database backups have been disabled on the client [<String>]. |
| 19:306 | Exchange Database backups have been enabled on the client [<String>]. |
| 19:307 | Exchange Database restores have been disabled on the client [<String>]. |
| 19:308 | Exchange Database restores have been enabled on the client [<String>]. |
| 19:309 | Exchange Database backups and restores have been disabled on the client [<String>]. |
| 19:310 | Exchange Database backups and restores have been enabled on the client [<String>]. |
| 19:311 | MediaAgent [<String>] has been put offline. |
| 19:312 | MediaAgent [<String>] has been put online. |
| 19:313 | The restore activity is disabled. The restore will not run. |
| 19:314 | The backup activity is disabled. The backup will not run. |
| 19:315 | Interrupt request pending for job [<Number>]. |
| 19:316 | Job [<Number>] has been interrupted. |
| 19:317 | Request to interrupt job [<Number>] timed out. Phase will be terminated. |
| 19:318 | The Blackout Window does not allow the job [<Number>] to run at this time. |
| 19:319 | Error in submitting Auxiliary Copy request to the JobManager. Server=[<String>]. |
| 19:320 | Failed to send the information for an Auxiliary Copy job. |
| 19:321 | Auxiliary Copy operation running for Storage Policy [<String>]. |
| 19:322 | Data Aging operation has started; job ID [<Number>]. |
| 19:323 | Data Aging operation has completed; job ID [<Number>]. |
| 19:324 | CommServe DR operation has started; job ID [<Number>]. |
| 19:325 | CommServe DR operation has completed; job ID [<Number>]. |
| 19:326 | CommServe DR operation is already running. |
| 19:327 | Abnormally terminated synthetic full backup job [<Number>] detected and has been terminated without user intervention. |
| 19:328 | Another Backup is already running. |
| 19:329 | Error in submitting a synthetic full request to the Job Manager. Server=[<String>]. |
| 19:330 | Failed to initialize a Synthetic Full job. |
| 19:331 | New synthetic full request received for the client [<String>], application type [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:332 | Synthetic Full job [<Number>] not found in pending queue. |
| 19:333 | Received update message for synthetic full job [<Number>], but the job is not running. |
| 19:334 | Failed to create an incremental backup from a synthetic full backup; job ID [<Number>]. |
| 19:335 | Failed to initialize synthetic full job [<Number>] from the database. |
| 19:336 | Synthetic Full job [<Number>] failed. |
| 19:337 | Synthetic Full job [<Number>] completed. |
| 19:338 | No incremental or differential run after full; Synthetic Full will not run; job ID [<Number>]. |
| 19:339 | No information for job [<Number>] on job information table. |
| 19:340 | Failed to delete rows for archive group ID [<Number>] from table with error [<String>]. |
| 19:341 | Physical Resources needed for job [<Number>] are not available, there may not be enough online drives in Library [<String>]. Job will not be retried. |
| 19:342 | Job [<Number>] resumed by Blackout Window. |
| 19:343 | Data Aging operation is running. Cannot run job. |
| 19:344 | Data Aging cannot run because there is either a Restore, Synthetic Full or Auxiliary Copy running. |
| 19:345 | Failed to get the data target Storage Policy Name. |
| 19:346 | Failed to get the data target Storage Policy Copy Name. |
| 19:347 | No drive is available for job [<Number>], all drives are offline in Library [<String>], DrivePool [<String>]. |
| 19:348 | Failed to get command line arguments for Novell File System job [<Number>]. |
| 19:349 | Failed to get command line arguments for Novell Directory Service job [<Number>]. |
| 19:350 | Failed to get command line arguments for Windows 2000 File System job [<Number>]. |
| 19:351 | Failed to get command line arguments for SQL Server database job [<Number>]. |
| 19:352 | Invalid phase [<Number>] for Novell File System job [<Number>]. |
| 19:353 | Invalid phase [<Number>] for Novell Directory Service job [<Number>]. |
| 19:354 | Invalid phase [<Number>] for Windows 2000 File System job [<Number>]. |
| 19:355 | Invalid phase [<Number>] for SQL Server database job [<Number>]. |
| 19:356 | NetWare File System backups have been disabled on the server. |
| 19:357 | NetWare File System backups have been enabled on the server. |
| 19:358 | NetWare File System restores have been disabled on the server. |
| 19:359 | NetWare File System restores have been enabled on the server. |
| 19:360 | NetWare File System backups and restores have been disabled on the server. |
| 19:361 | NetWare File System backups and restores have been enabled on the server. |
| 19:362 | Novell Directory Services backups have been disabled on the server. |
| 19:363 | Novell Directory Services backups have been enabled on the server. |
| 19:364 | Novell Directory Services restores have been disabled on the server. |
| 19:365 | Novell Directory Services restores have been enabled on the server. |
| 19:366 | Novell Directory Services backups and restores have been disabled on the server. |
| 19:367 | Novell Directory Services backups and restores have been enabled on the server. |
| 19:368 | Windows 2000 File System backups have been disabled on the server. |
| 19:369 | Windows 2000 File System backups have been enabled on the server. |
| 19:370 | Windows 2000 File System restores have been disabled on the server. |
| 19:371 | Windows 2000 File System restores have been enabled on the server. |
| 19:372 | Windows 2000 File System backups and restores have been disabled on the server. |
| 19:373 | Windows 2000 File System backups and restores have been enabled on the server. |
| 19:374 | SQL Server backups have been disabled on the server. |
| 19:375 | SQL Server backups have been enabled on the server. |
| 19:376 | SQL Server restores have been disabled on the server. |
| 19:377 | SQL Server restores have been enabled on the server. |
| 19:378 | SQL Server backups and restores have been disabled on the server. |
| 19:379 | SQL Server backups and restores have been enabled on the server. |
| 19:380 | NetWare File System backups have been disabled on the client [<String>]. |
| 19:381 | NetWare File System backups have been enabled on the client [<String>]. |
| 19:382 | NetWare File System restores have been disabled on the client [<String>]. |
| 19:383 | NetWare File System restores have been enabled on the client [<String>]. |
| 19:384 | NetWare File System backups and restores have been disabled on the client [<String>]. |
| 19:385 | NetWare File System backups and restores have been enabled on the client [<String>]. |
| 19:386 | Novell Directory Services backups have been disabled on the client [<String>]. |
| 19:387 | Novell Directory Services backups have been enabled on the client [<String>]. |
| 19:388 | Novell Directory Services restores have been disabled on the client [<String>]. |
| 19:389 | Novell Directory Services restores have been enabled on the client [<String>]. |
| 19:390 | Novell Directory Services backups and restores have been disabled on the client [<String>]. |
| 19:391 | Novell Directory Services backups and restores have been enabled on the client [<String>]. |
| 19:392 | Windows 2000 File System backups have been disabled on the client [<String>]. |
| 19:393 | Windows 2000 File System backups have been enabled on the client [<String>]. |
| 19:394 | Windows 2000 File System restores have been disabled on the client [<String>]. |
| 19:395 | Windows 2000 File System restores have been enabled on the client [<String>]. |
| 19:396 | Windows 2000 File System backups and restores have been disabled on the client [<String>]. |
| 19:397 | Windows 2000 File System backups and restores have been enabled on the client [<String>]. |
| 19:398 | SQL Server backups have been disabled on the client [<String>]. |
| 19:399 | SQL Server backups have been enabled on the client [<String>]. |
| 19:400 | SQL Server restores have been disabled on the client [<String>]. |
| 19:401 | SQL Server restores have been enabled on the client [<String>]. |
| 19:402 | SQL Server backups and restores have been disabled on the client [<String>]. |
| 19:403 | SQL Server backups and restores have been enabled on the client [<String>]. |
| 19:404 | Wrong Backup Level [<Number>] for SQL Server Database backup job [<Number>]. |
| 19:405 | There are jobs running for client [<String>], application type [<Number>], instance [<String>]. Microsoft SQL Restore Job will not run. |
| 19:406 | MS SQL Exclusive Restore is running. Cannot run job for client [<String>], application type [<Number>], instance [<String>]. |
| 19:407 | NAS backups have been disabled on the server. |
| 19:408 | NAS backups have been enabled on the server. |
| 19:409 | NAS restores have been disabled on the server. |
| 19:410 | NAS restores have been enabled on the server. |
| 19:411 | NAS backups and restores have been disabled on the server. |
| 19:412 | NAS backups and restores have been enabled on the server. |
| 19:413 | NAS backups have been disabled on the client [<String>]. |
| 19:414 | NAS backups have been enabled on the client [<String>]. |
| 19:415 | NAS restores have been disabled on the client [<String>]. |
| 19:416 | NAS restores have been enabled on the client [<String>]. |
| 19:417 | NAS backups and restores have been disabled on the client [<String>]. |
| 19:418 | NAS backups and restores have been enabled on the client [<String>]. |
| 19:419 | Failed to get number of streams for CommCell ID [<Number>], client [<String>], instance [<String>]. |
| 19:420 | Failed to get command line arguments for NAS File system job [<Number>]. |
| 19:421 | Lotus Notes Document backups have been disabled on the server. |
| 19:422 | Lotus Notes Document backups have been enabled on the server. |
| 19:423 | Lotus Notes Document restores have been disabled on the server. |
| 19:424 | Lotus Notes Document restores have been enabled on the server. |
| 19:425 | Lotus Notes Document backups and restores have been disabled on the server. |
| 19:426 | Lotus Notes Document backups and restores have been enabled on the server. |
| 19:427 | Lotus Notes Document backups have been disabled on the client [<String>]. |
| 19:428 | Lotus Notes Document backups have been enabled on the client [<String>]. |
| 19:429 | Lotus Notes Document restores have been disabled on the client [<String>]. |
| 19:430 | Lotus Notes Document restores have been enabled on the client [<String>]. |
| 19:431 | Lotus Notes Document backups and restores have been disabled on the client [<String>]. |
| 19:432 | Lotus Notes Document backups and restores have been enabled on the client [<String>]. |
| 19:433 | Invalid phase [<Number>] for NAS job [<Number>]. |
| 19:434 | Invalid phase [<Number>] for Lotus Database job [<Number>]. |
| 19:435 | Failed to get command line arguments for Lotus Database job [<Number>]. |
| 19:436 | Lotus Notes Database backups have been disabled on the server. |
| 19:437 | Lotus Notes Database backups have been enabled on the server. |
| 19:438 | Lotus Notes Database restores have been disabled on the server. |
| 19:439 | Lotus Notes Database restores have been enabled on the server. |
| 19:440 | Lotus Notes Database backups and restores have been disabled on the server. |
| 19:441 | Lotus Notes Database backups and restores have been enabled on the server. |
| 19:442 | Lotus Notes Database backups have been disabled on the client [<String>]. |
| 19:443 | Lotus Notes Database backups have been enabled on the client [<String>]. |
| 19:444 | Lotus Notes Database restores have been disabled on the client [<String>]. |
| 19:445 | Lotus Notes Database restores have been enabled on the client [<String>]. |
| 19:446 | Lotus Notes Database backups and restores have been disabled on the client [<String>]. |
| 19:447 | Lotus Notes Database backups and restores have been enabled on the client [<String>]. |
| 19:448 | Exchange 2000 Mailbox backups have been disabled on the server. |
| 19:449 | Exchange 2000 Mailbox backups have been enabled on the server. |
| 19:450 | Exchange 2000 Mailbox restores have been disabled on the server. |
| 19:451 | Exchange 2000 Mailbox restores have been enabled on the server. |
| 19:452 | Exchange 2000 Mailbox backups and restores have been disabled on the server. |
| 19:453 | Exchange 2000 Mailbox backups and restores have been enabled on the server. |
| 19:454 | Exchange 2000 Database backups have been disabled on the server. |
| 19:455 | Exchange 2000 Database backups have been enabled on the server. |
| 19:456 | Exchange 2000 Database restores have been disabled on the server. |
| 19:457 | Exchange 2000 Database restores have been enabled on the server. |
| 19:458 | Exchange 2000 Database backups and restores have been disabled on the server. |
| 19:459 | Exchange 2000 Database backups and restores have been enabled on the server. |
| 19:460 | Exchange 2000 Mailbox backups have been disabled on the client [<String>]. |
| 19:461 | Exchange 2000 Mailbox backups have been enabled on the client [<String>]. |
| 19:462 | Exchange 2000 Mailbox restores have been disabled on the client [<String>]. |
| 19:463 | Exchange 2000 Mailbox restores have been enabled on the client [<String>]. |
| 19:464 | Exchange 2000 Mailbox backups and restores have been disabled on the client [<String>]. |
| 19:465 | Exchange 2000 Mailbox backups and restores have been enabled on the client [<String>]. |
| 19:466 | Exchange 2000 Database backups have been disabled on the client [<String>]. |
| 19:467 | Exchange 2000 Database backups have been enabled on the client [<String>]. |
| 19:468 | Exchange 2000 Database restores have been disabled on the client [<String>]. |
| 19:469 | Exchange 2000 Database restores have been enabled on the client [<String>]. |
| 19:470 | Exchange 2000 Database backups and restores have been disabled on the client [<String>]. |
| 19:471 | Exchange 2000 Database backups and restores have been enabled on the client [<String>]. |
| 19:472 | Null Database name string passed for Current Database. |
| 19:473 | Current Database cannot be longer than [<Number>]. |
| 19:474 | Restore job [<Number>] completed with one or more errors. |
| 19:475 | Received invalid Restore Task ID [<Number>]. |
| 19:476 | Number of restarts for job [<Number>] have exceeded the maximum number allowed. |
| 19:477 | Failed to send to client [<String>] the job ID [<Number>]. |
| 19:478 | Client [<String>] disconnected while sending job ID [<Number>]. Job will not run. |
| 19:479 | Failed to get session object lock within session server; socket ID [<Number>] and job ID [<Number>]. |
| 19:480 | Failed to get registration for job ID [<Number>]. |
| 19:481 | The job [<Number>] is in an uninterruptible state and the control request will be ignored. |
| 19:482 | The job [<Number>] entered an uninterruptible state and the control request will be ignored. |
| 19:483 | Server Event Manager timed out waiting for job ID [<Number>] or is disconnected. Job will not run. |
| 19:484 | Failed to get command line arguments for <String> job [<Number>]. |
| 19:485 | Invalid phase [<Number>] for <String> job [<Number>]. |
| 19:486 | <String> backups have been disabled on the server. |
| 19:487 | <String> backups have been enabled on the server. |
| 19:488 | <String> restores have been disabled on the server. |
| 19:489 | <String> restores have been enabled on the server. |
| 19:490 | <String> backups and restores have been disabled on the server. |
| 19:491 | <String> backups and restores have been enabled on the server. |
| 19:492 | <String> backups have been disabled on the client [<String>]. |
| 19:493 | <String> backups have been enabled on the client [<String>]. |
| 19:494 | <String> restores have been disabled on the client [<String>]. |
| 19:495 | <String> restores have been enabled on the client [<String>]. |
| 19:496 | <String> backups and restores have been disabled on the client [<String>]. |
| 19:497 | <String> backups and restores have been enabled on the client [<String>]. |
| 19:498 | Job [<Number>] has been automatically resumed. |
| 19:499 | Failed to get the number of streams needed for Storage Policy ID [<Number>]. |
| 19:500 | New backup request received for Client [<String>], Application Type [<String>], Backup Set [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:501 | Failed to get the Target Storage Policy Name for application id [<String>]; Check the Storage Policy under the subclient properties; |
| 19:502 | Job [<Number>] did not contact Job Manager back. Please check the services and network connectivity with the client machine. Check Job Manager Log on the CommServe to determine on which machine the executable was started. |
| 19:503 | The Blackout Window does not allow the third party request to run. Client [<String>], Application Type [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:504 | Backup job failed; Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:505 | Third party job timed out waiting for job ID [<Number>] or is disconnected. Job will not run. |
| 19:506 | Cannot stop/kill third party job [<Number>] while it is waiting for resources. |
| 19:507 | Failed to send Scheduled Report completion message to the CommServe [<String>]. |
| 19:508 | Failed to start Scheduled Report job on CommServe Machine. Admin task ID[<Number>]; Report type [<Number>]. |
| 19:509 | Abnormally terminated Auxiliary Copy job [<Number>] detected and has been terminated without user intervention. |
| 19:510 | Auxiliary Copy operation already running for Storage Policy ID [<Number>]. |
| 19:511 | New third party restore request received for client [<String>], application type [<String>]. |
| 19:512 | Job [<Number>] has been automatically resumed according to the Blackout Window times. |
| 19:513 | Space on the disk where this product was installed is below the threshold value of <Number> MB. New jobs or phases will not run. |
| 19:514 | Space on the disk where this product has been installed has reached the critical threshold value of <Number> MB. All jobs with RUNNING status will be killed. |
| 19:515 | Failed to get ProxyHost name for Subclient [<String>]; job [<Number>]. |
| 19:516 | Failed to initialize Backup request. <String> |
| 19:517 | Failed to initialize Synthetic Full request due to [<String>]. |
| 19:518 | Failed to communicate with the Job Manager service on CommServe Machine. Make sure that both this product's Communications service and Job Manager service on [<String>] is up and running. Also, ensure the network resolution of [<String>] is proper from this machine. |
| 19:519 | Job Manager Failed to Start on computer [<String>]; Server Event Manager may not be running or not in a healthy state. |
| 19:520 | CommServe Disaster Recovery PATH is pointing to a local drive and therefore is invalid. |
| 19:521 | Data Aging operation has <String> for job ID [<Number>]. |
| 19:522 | Auxiliary Copy operation has <String> for job ID [<Number>]. |
| 19:523 | Disaster Recovery operation has <String>. Media Used [<String>]. Job ID [<Number>]. |
| 19:524 | CommServe DR Phase [<String>] has started. |
| 19:525 | Failed to initialize Administration Job [<Number>] from Database. |
| 19:526 | [<String>] does not have a Storage Policy associated with it. |
| 19:527 | Backup job completed. Media Used [<String>]. Job ID [<Number>]. |
| 19:528 | Failed to terminate all pipelines for job [<Number>]. |
| 19:529 | Invalid type [<Number>] of job in job queue. Function [<String>]. |
| 19:530 | Abnormally terminated job detected. Phase [<String>] will be restarted. |
| 19:531 | Failed to start phase [<String>] on [<String>] due to network error [<Number>]. Will attempt to restart. Please check if this product's services are running on the remote host. |
| 19:532 | Failed to initialize a Restore request. Restore Task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:533 | Synthetic Full cannot run because no FULL backup was run for that subclient. Client [<String>], AppType [<String>], Backup Set [<String>], Subclient [<String>] |
| 19:534 | Synthetic Full cannot run because no INCREMENTAL or DIFFERENTIAL backup was run after last FULL backup for that subclient. Client [<String>], AppType [<String>], Backup Set [<String>], Subclient [<String>] |
| 19:535 | SubClient[<String>] for Client [<String>], Application Type [<String>], Backup Set[<String>] was deleted. Request for running Job was dropped. This might happen if the user interface has not been refreshed. |
| 19:536 | Job Manager Service failed to start on computer [<String>]; CommServe License has expired. |
| 19:537 | The restore activity is disabled. <String> The restore will not run. |
| 19:538 | The backup activity is disabled. <String> The backup will not run. |
| 19:539 | Job [<Number>] has been killed since it was running when this product's services were stopped. |
| 19:540 | <String> Job [<Number>] has been suspended by user's request. |
| 19:541 | <String> Job [<Number>] has been interrupted. |
| 19:542 | <String> Job [<Number>] has been killed. |
| 19:543 | Application requested [<Number>] streams for Backup; reserved [<Number>] streams due to lack of available resources. |
| 19:544 | Database operation did not succeed. Please check Job Manager.log on the CommServe for detailed explanation. |
| 19:545 | Error in submitting Scheduled Export request to the Job Manager. Server=[<String>]. |
| 19:546 | Scheduled Export operation has <String> for job ID [<Number>]. |
| 19:547 | Scheduled Export operation has started; job ID [<Number>]. |
| 19:548 | Abnormally terminated scheduled export job [<Number>] detected and has been terminated without user intervention. |
| 19:549 | Failed to get export media list for job ID [<Number>]. |
| 19:550 | There are no media to be exported for job ID [<Number>]. |
| 19:551 | Failed to update job info in table [<String>], for field [<String>] with error [<String>] for job [<Number>]. |
| 19:552 | Abnormally terminated <String> job [<Number>] detected and has been terminated. |
| 19:553 | Abnormally terminated job detected. Phase [<String>] cannot be restarted. Starting next phase [<String>]. |
| 19:554 | Phase [<String>] cannot be restarted. Starting next phase [<String>]. |
| 19:555 | Failed to get the log storage policy ID for application number [<String>]. |
| 19:556 | Resources needed for job [<Number>] are not available. There are not enough streams on the Storage Policy [<String>]. Check Storage Policy properties to make sure it has at least [<Number>] active streams. The job will not be retried. |
| 19:557 | CommServe DR Phase [<String>] has started for Job [<Number>]. |
| 19:558 | [<String>] for Job [<Number>] does not have a Storage Policy associated with it. |
| 19:559 | Synthetic Full job failed. Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:560 | Job Manager received an invalid control operation [<Number>] for jobs [<String>]. |
| 19:561 | <String> operation has started for library [<String>]. |
| 19:562 | Media Inventory operation has <String> for job ID [<Number>]. |
| 19:563 | Failed to initialize a Media Inventory Task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:564 | Another inventory is running for library [<String>]. |
| 19:565 | Failed to get maximum instance criteria for the application number [<String>]. |
| 19:566 | Error in submitting <String> request to the Job Manager. |
| 19:567 | Failed to check if SQL Logs Backup should be converted to Full. Error [<String>]. |
| 19:568 | SQL Backup job [<Number>] has been converted to a <String> backup. |
| 19:569 | Failed to get the Primary Copy for Storage Policy [<Number>]. |
| 19:570 | The job cannot run at this time. |
| 19:571 | Error in receiving a response from Job Manager. |
| 19:572 | <String> activity on CommServe is disabled. |
| 19:573 | <String> activity for <String> on CommServe is disabled. |
| 19:574 | <String> activity on Client [<String>] is disabled. |
| 19:575 | <String> activity for [<String>] on Client [<String>] is disabled. |
| 19:576 | <String> The <String> job will not run. |
| 19:577 | Failed to send the information for a Media Export job. |
| 19:578 | Failed to send the information for a Media Inventory job. |
| 19:579 | An Auxiliary Copy operation is already running for Storage Policy [<String>]. |
| 19:580 | New media prediction request received for client [<String>], application type [<String>]. |
| 19:581 | Synthetic Full cannot run because a full backup has not been run for the subclient. Client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:582 | Synthetic Full cannot run because no Incremental or Differential backup was run after the last Full backup for the subclient. Client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:583 | Another backup is running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:584 | MS SQL Exclusive Restore is running. Cannot run job for client [<String>], iDataAgent [<Number>], instance [<String>]. |
| 19:585 | The Synthetic Full cannot run because a full backup for this subclient does not exist on the source Copy nn If the Synthetic Full is running from a Primary Copy, please run a Full backup for the subclient first. nn If the source is a snap copy, then please run a Backup Copy to copy all jobs for this subclient's cycle. nn Resubmit the Synthetic Full. |
| 19:586 | Synthetic Full cannot run because no Incremental or Differential backup was run after last Full backup for the subclient. |
| 19:587 | Failed to get the data types created for job [<Number>]. |
| 19:588 | Failed to check the license for CommServe. <String> |
| 19:589 | The license for the CommServe has expired. |
| 19:590 | No Storage Policy has been set for the subclient. |
| 19:591 | Failed to get number of streams for SQL Transaction Log Backup for client [<String>], instance [<String>], database [<String>]. |
| 19:592 | Inventory operation cannot run at this time because an Export operation is running for library [<String>]. |
| 19:593 | Another export is already running for library [<String>]. |
| 19:594 | Export operation cannot run at this time because an Inventory operation is running for library [<String>]. |
| 19:595 | Failed to establish a connection to Job Manager Service. |
| 19:596 | Failed to get a valid session to Job Manager Service. |
| 19:597 | Blackout Window for <String> prevents the <String> from running right now. |
| 19:598 | <String> Blackout Window for <String> prevents the <String> from running right now. |
| 19:599 | Loss of control process <String>. Possible causes: 1. The control process has unexpectedly died. Check crash dump or core file. 2. The communication to the control process machine <String> might have gone down due to network errors. 3. If the machine <String> is a cluster, it may have failed over. 4. The machine <String> may have rebooted. 5. Antivirus/Malware software may be blocking the process. Please ensure that all exclusions are in place: nn http://documentation.commvault.com/commvault/v11/article?p=8665.htm |
| 19:600 | New recovery request received for client [<String>]. |
| 19:601 | The Job Manager service was restarted. |
| 19:602 | Export operation has <String> for job ID [<Number>]. |
| 19:603 | Export operation has <String> for library [<String>]. |
| 19:604 | The number of <String> operations for client [<String>] exceeds the maximum number allowed. |
| 19:605 | New OSSV Replica Creation request received for Client [<String>], Subclient [<String>]. |
| 19:606 | New archiver request received for Client [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:607 | Another OSSV Replica Creation operation is running for client [<String>], Subclient [<String>]. |
| 19:608 | An archive operation is running for client [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:609 | New recovery request received for client [<String>]. |
| 19:610 | Error in submitting request to the Job Manager. |
| 19:611 | OSSV Replica Creation job [<String>] for Client [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:612 | Archiver job <String> for Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:613 | <String> job [<Number>] failed. |
| 19:614 | <String> job [<Number>] completed. |
| 19:615 | Data Management activity on the server has been disabled. |
| 19:616 | Data Management activity on the server has been enabled. |
| 19:617 | Data Recovery activity on the server has been disabled. |
| 19:618 | Data Recovery activity on the server has been enabled. |
| 19:619 | Both Data Management and Data Recovery activities have been disabled on the server. |
| 19:620 | Both Data Management and Data Recovery activities have been enabled on the server. |
| 19:621 | <String> Data Management activity has been disabled on the server. |
| 19:622 | <String> Data Management activity has been enabled on the server. |
| 19:623 | <String> Data Recovery activity has been disabled on the server. |
| 19:624 | <String> Data Recovery activity has been enabled on the server. |
| 19:625 | <String> Data Management and Data Recovery activities have been disabled on the server. |
| 19:626 | <String> Data Management and Data Recovery activities have been enabled on the server. |
| 19:627 | Data Management activity on the client [<String>] has been disabled. |
| 19:628 | Data Management activity on the client [<String>] has been enabled. |
| 19:629 | Data Recovery activity on the client [<String>] has been disabled. |
| 19:630 | Data Recovery activity on the client [<String>] has been enabled. |
| 19:631 | Both Data Management and Data Recovery activities have been disabled on the client [<String>]. |
| 19:632 | Both Data Management and Data Recovery activities have been enabled on the client [<String>]. |
| 19:633 | <String> for <String> have been disabled on the client [<String>]. |
| 19:634 | <String> for <String> have been enabled on the client [<String>]. |
| 19:635 | <String> for <String> have been disabled on the client [<String>]. |
| 19:636 | <String> for <String> have been enabled on the client [<String>]. |
| 19:637 | <String> and <String> for <String> have been disabled on the client [<String>]. |
| 19:638 | <String> and <String> for <String> have been enabled on the client [<String>]. |
| 19:639 | The restore activity is currently disabled. Please try again later. |
| 19:640 | Phase [<String>] failed for Disaster Recovery backup [<Number>]. |
| 19:641 | Phase [<String>] failed for backup job [<Number>]. |
| 19:642 | Phase [<String>] failed for Synthetic Full Backup job [<Number>]. |
| 19:643 | <String> job [<Number>] completed. |
| 19:644 | Phase [<String>] failed for Auxiliary Copy job [<Number>]. |
| 19:645 | All Activity on the CommServe has been disabled. |
| 19:646 | All Activity on the CommServe has been enabled. |
| 19:647 | Failed to initialize Synthetic Full Backup Job. <String> |
| 19:648 | File/File Group backups cannot run at this time since the Volume Shadow Service property has been enabled for the SQL instance. |
| 19:649 | Failed on a SELECT for job [<Number>], in table [<String>], with error [<String>]. |
| 19:650 | Auxiliary Copy operation has been disabled. |
| 19:651 | Auxiliary Copy operation has been enabled. |
| 19:652 | A OSSV Replicate Creation operation for a subclient with content overlapping with subclient [<String>] is already running for client [<String>]. This operation cannot run. |
| 19:653 | An Update Replica cannot run since Incremental Updates have been disabled for this subclient. |
| 19:654 | Error in submitting report request to the Job Manager. |
| 19:655 | Scheduler operations have been disabled. |
| 19:656 | Scheduler operations have been enabled. |
| 19:657 | Releasing resources allocated for the previous attempt. |
| 19:658 | Cleaning up snapshots for previous attempts. |
| 19:659 | <String> The scheduled report will not run. |
| 19:660 | The Backup job is not running. |
| 19:661 | Cannot attach to Job Manager without initializing the job client. |
| 19:662 | Failed to establish a connection to Job Manager Service on [<String>]. |
| 19:663 | Differential/Transaction Log backups cannot run at this time since the Volume Shadow Service property has been enabled for the SQL instance. |
| 19:664 | Terminating processes from the previous Job Manager run. |
| 19:665 | Waiting for job(s) [<String>] to release the resources. |
| 19:666 | Waiting for job(s) [<String>] to complete. |
| 19:667 | <String> activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>] is disabled. |
| 19:668 | A Selective Online Full backup is running for instance [<String>] on client [<String>] and iDataAgent [<String>]. |
| 19:669 | A Selective Online Full backup is running for instance [<String>] on client [<String>] and iDataAgent [<String>]. This job cannot run this time. |
| 19:670 | Failed to initialize Data Verification job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:671 | A Data Verification operation is already running for Storage Policy [<String>]. |
| 19:672 | <String> operation has <String> for job ID [<Number>]. |
| 19:673 | Failed to initialize Erase Media job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:674 | Failed to initialize VaultTracker job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:675 | Data Aging operation has completed; Job ID [<Number>]. |
| 19:676 | Data Aging operation has failed; Job ID [<Number>]. |
| 19:677 | Auxiliary Copy operation has completed; Job ID [<Number>]. |
| 19:678 | Auxiliary Copy operation has failed; Job ID [<Number>]. |
| 19:679 | Disaster Recovery operation has completed. Media Used [<String>]. |
| 19:680 | Disaster Recovery operation has completed with one or more errors. Media Used [<String>]. |
| 19:681 | Disaster Recovery operation has completed. |
| 19:682 | Disaster Recovery operation has failed. |
| 19:683 | CommServe DR does not have a Storage Policy associated with it. |
| 19:684 | Archiver job has been suspended by user's request. |
| 19:685 | OSSV Replica Creation job has been suspended on user's request. |
| 19:686 | Backup job has been suspended by user's request. |
| 19:687 | Synthetic Full job has been suspended by user's request. |
| 19:688 | Media Prediction job has been suspended by user's request. |
| 19:689 | Recovery job has been suspended by user's request. |
| 19:690 | OSSV Recovery job has been suspended by user's request. |
| 19:691 | Restore job has been suspended by user's request. |
| 19:692 | Data Aging job has been suspended by user's request. |
| 19:693 | Auxiliary Copy job has been suspended by user's request. |
| 19:694 | DR Backup job has been suspended by user's request. |
| 19:695 | Scheduled Export job has been suspended by user's request. |
| 19:696 | Media Inventory job has been suspended by user's request. |
| 19:697 | Data Verification job has been suspended by user's request. |
| 19:698 | Erase Media job has been suspended by user's request. |
| 19:699 | Job has been suspended by user's request. |
| 19:700 | Archiver job has been interrupted. |
| 19:701 | OSSV Replicate Creation job has been interrupted. |
| 19:702 | Backup job has been interrupted. |
| 19:703 | Synthetic Full job has been interrupted. |
| 19:704 | Restore job has been interrupted. |
| 19:705 | Auxiliary Copy job has been interrupted. |
| 19:706 | DR Backup job has been interrupted. |
| 19:707 | Data Verification job has been interrupted. |
| 19:708 | Erase Media job has been interrupted. |
| 19:709 | Job has been interrupted. |
| 19:710 | Archiver job has been killed. |
| 19:711 | OSSV Replicate Creation job has been killed. |
| 19:712 | Backup job has been killed. |
| 19:713 | Synthetic Full job has been killed. |
| 19:714 | Media Prediction job has been killed. |
| 19:715 | Recovery job has been killed. |
| 19:716 | OSSV Recovery job has been killed. |
| 19:717 | Restore job has been killed. |
| 19:718 | Data Aging job has been killed. |
| 19:719 | Auxiliary Copy job has been killed. |
| 19:720 | DR Backup job has been killed. |
| 19:721 | Scheduled Export job has been killed. |
| 19:722 | Media Inventory job has been killed. |
| 19:723 | Data Verification job has been killed. |
| 19:724 | Erase Media job has been killed. |
| 19:725 | Index Restore job has been killed. |
| 19:726 | Job has been killed. |
| 19:727 | Scheduled Export operation has completed. |
| 19:728 | Scheduled Export operation has failed. |
| 19:729 | Full Inventory operation has started for library [<String>]. |
| 19:730 | Quick Inventory operation has started for library [<String>]. |
| 19:731 | Search Inventory operation has started for library [<String>]. |
| 19:732 | Export Inventory operation has started for library [<String>]. |
| 19:733 | Verify Media operation has started for library [<String>]. |
| 19:734 | Discover Media operation has started for library [<String>]. |
| 19:735 | Inventory operation has started for library [<String>]. |
| 19:736 | Media Inventory operation has completed. |
| 19:737 | Media Inventory operation has failed. |
| 19:738 | SQL Backup job has been converted to a full backup. |
| 19:739 | SQL Backup job has been converted to a differential backup. |
| 19:740 | All activity on CommServe is disabled. |
| 19:741 | Data Management activity on CommServe is disabled. |
| 19:742 | Data Recovery activity on CommServe is disabled. |
| 19:743 | Auxiliary Copy activity on CommServe is disabled. |
| 19:744 | Data Aging activity on CommServe is disabled. |
| 19:745 | Data Management activity for <String> on CommServe is disabled. |
| 19:746 | Data Recovery activity for <String> on CommServe is disabled. |
| 19:747 | Data Management activity on Client [<String>] is disabled. |
| 19:748 | Data Recovery activity on Client [<String>] is disabled. |
| 19:749 | Data Protection activity for [<String>] on Client [<String>] is disabled. |
| 19:750 | Data Recovery activity for [<String>] on Client [<String>] is disabled. |
| 19:751 | Backup activity for [<String>] on Client [<String>] is disabled. |
| 19:752 | Restore activity for [<String>] on Client [<String>] is disabled. |
| 19:753 | Data Protection activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>] is disabled. |
| 19:754 | Backup activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>] is disabled. |
| 19:755 | <Message> The Archiver job will not run. |
| 19:756 | <Message> The OSSV Replicate Creation job will not run. |
| 19:757 | <Message> The job will not run because activity is disabled. Please enable activity at the respective level to continue. |
| 19:758 | <Message> The Recovery job will not run. |
| 19:759 | <Message> The OSSV Recovery job will not run. |
| 19:760 | <Message> The Restore job will not run. |
| 19:761 | <Message> The Auxiliary Copy job will not run. |
| 19:762 | <Message> The Disaster Recovery Backup job will not run. |
| 19:763 | <Message> The Data Aging job will not run. |
| 19:764 | <Message> The Media Export job will not run. |
| 19:765 | <Message> The Media Inventory job will not run. |
| 19:766 | <Message> The Data Verification job will not run. |
| 19:767 | <Message> The Erase Media job will not run. |
| 19:768 | <Message> The VaultTracker job will not run. |
| 19:769 | Blackout Window for CommServe prevents the Backup job from running right now. |
| 19:770 | Blackout Window for CommServe prevents the archive job from running right now. |
| 19:771 | Blackout Window for CommServe prevents the OSSV Replicate Creation job from running right now. |
| 19:772 | Blackout Window for CommServe prevents the Restore job from running right now. |
| 19:773 | Blackout Window for CommServe prevents the Recovery job from running right now. |
| 19:774 | Blackout Window for CommServe prevents the OSSV Recovery job from running right now. |
| 19:775 | Blackout Window for iDataAgent prevents the Backup job from running right now. |
| 19:776 | Blackout Window for iDataAgent prevents the Archiver job from running right now. |
| 19:777 | Blackout Window for iDataAgent prevents the OSSV Replicate Creation job from running right now. |
| 19:778 | Blackout Window for iDataAgent prevents the Restore job from running right now. |
| 19:779 | Blackout Window for iDataAgent prevents the Recovery job from running right now. |
| 19:780 | Blackout Window for iDataAgent prevents the OSSV Recovery job from running right now. |
| 19:781 | Blackout Window for CommServe prevents the Disaster Recovery Backup job from running right now. |
| 19:782 | Blackout Window for CommServe prevents the Auxiliary Copy job from running right now. |
| 19:783 | Blackout Window for CommServe prevents the Data Aging job from running right now. |
| 19:784 | Blackout Window for CommServe prevents the Media Export job from running right now. |
| 19:785 | Blackout Window for CommServe prevents the Media Inventory job from running right now. |
| 19:786 | Blackout Window for CommServe prevents the Data Verification job from running right now. |
| 19:787 | Blackout Window for CommServe prevents the Erase Media job from running right now. |
| 19:788 | Blackout Window for CommServe prevents the VaultTracker job from running right now. |
| 19:789 | Full Blackout Window for CommServe prevents the backup from running right now. |
| 19:790 | Full Blackout Window for CommServe prevents the archive job from running right now. |
| 19:791 | Full Blackout Window for CommServe prevents the OSSV Replica Creation from running right now. |
| 19:792 | Synthetic Full Blackout Window for CommServe prevents the synthetic backup from running right now. |
| 19:793 | Full Blackout Window for iDataAgent prevents the Backup from running right now. |
| 19:794 | Full Blackout Window for iDataAgent prevents the archive job from running right now. |
| 19:795 | Full Blackout Window for iDataAgent prevents the OSSV Replica Creation from running right now. |
| 19:796 | Export operation has started for library [<String>]. |
| 19:797 | The number of Restore operations for client [<String>] exceeds the maximum number allowed. |
| 19:798 | The number of Recovery operations for client [<String>] exceeds the maximum number allowed. |
| 19:799 | The number of OSSV Recovery operations for client [<String>] exceeds the maximum number allowed. |
| 19:800 | OSSV Replica Creation job failed for Client [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:801 | Archive job failed for Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:802 | Media prediction job [<Number>] failed. |
| 19:803 | Restore job [<Number>] failed. |
| 19:804 | Recovery job [<Number>] failed. |
| 19:805 | OSSV Recovery job [<Number>] failed. |
| 19:806 | Media prediction job [<Number>] completed. |
| 19:807 | Restore job [<Number>] completed. |
| 19:808 | Recovery job [<Number>] completed. |
| 19:809 | OSSV Recovery job [<Number>] completed. |
| 19:810 | Backups for <String> have been disabled on the client [<String>]. |
| 19:811 | Archiving for <String> has been disabled on the client [<String>]. |
| 19:812 | OSSV Replica Creation for <String> has been disabled on the client [<String>]. |
| 19:813 | Backups for <String> have been enabled on the client [<String>]. |
| 19:814 | Archiving for <String> has been enabled on the client [<String>]. |
| 19:815 | OSSV Replica Creation for <String> has been enabled on the client [<String>]. |
| 19:816 | Restores for <String> have been disabled on the client [<String>]. |
| 19:817 | Recovery for <String> has been disabled on the client [<String>]. |
| 19:818 | OSSV Recovery for <String> has been disabled on the client [<String>]. |
| 19:819 | Restores for <String> have been enabled on the client [<String>]. |
| 19:820 | Recovery for <String> has been enabled on the client [<String>]. |
| 19:821 | OSSV Recovery for <String> has been enabled on the client [<String>]. |
| 19:822 | Backups and Restores for <String> have been disabled on the client [<String>]. |
| 19:823 | Archiving and Recovery for <String> have been disabled on the client [<String>]. |
| 19:824 | OSSV Replica Creation and Recovery for <String> have been disabled on the client [<String>]. |
| 19:825 | Backups and Restores for <String> have been enabled on the client [<String>]. |
| 19:826 | Archiving and Recovery for <String> have been enabled on the client [<String>]. |
| 19:827 | OSSV Replica Creation and Recovery for <String> have been enabled on the client [<String>]. |
| 19:828 | Backup activity has been disabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:829 | Archive activity has been disabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:830 | Data Protection activity has been disabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:831 | Backup activity has been enabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:832 | Archive activity has been enabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:833 | Data Protection activity has been enabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:834 | Failed to disable activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:835 | Failed to enable activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>] has been disabled. |
| 19:836 | Backup job [<Number>] completed. |
| 19:837 | Archive job [<Number>] completed. |
| 19:838 | OSSV Replicate Creation job [<Number>] completed. |
| 19:839 | Administration operation has completed. |
| 19:840 | Data Aging operation has completed. |
| 19:841 | Auxiliary Copy operation has completed. |
| 19:842 | Disaster Recovery Backup operation has completed. |
| 19:843 | Media Export operation has completed. |
| 19:844 | Media Inventory operation has completed. |
| 19:845 | Data Verification operation has completed. |
| 19:846 | Erase Media operation has completed. |
| 19:847 | VaultTracker operation has completed. |
| 19:848 | Administration operation has failed. |
| 19:849 | Data Aging operation has failed. |
| 19:850 | Auxiliary Copy operation has failed. |
| 19:851 | Disaster Recovery operation has failed. |
| 19:852 | Media Export operation has failed. |
| 19:853 | Media Inventory operation has failed. |
| 19:854 | Data Verification operation has failed. |
| 19:855 | Erase Media operation has failed. |
| 19:856 | VaultTracker operation has failed. |
| 19:857 | <String> |
| 19:858 | Data Verification operation has been disabled. |
| 19:859 | Data Verification operation has been enabled. |
| 19:860 | Data Verification activity on CommServe is disabled. |
| 19:861 | Killed by <String>. |
| 19:862 | Suspended by <String>. |
| 19:863 | Erase Media operation has been disabled. |
| 19:864 | Erase Media operation has been enabled. |
| 19:865 | Erase Media activity on CommServe is disabled. |
| 19:866 | Failed to get information for the index archive file. |
| 19:867 | Failed to get volume ID for archive file [<Number>] on copy [<Number>]. |
| 19:868 | Failed to get MediaAgent and Drive Pool for volume. |
| 19:869 | Erase Media operation has started for library [<String>]. |
| 19:870 | Failed to start Install Update job on CommServe Machine. Task ID = [<Number>]. |
| 19:871 | <Message> The Install Update job will not run. |
| 19:872 | Export operation cannot run at this time because an Erase Media operation is running for library [<String>]. |
| 19:873 | Inventory operation cannot run at this time because an Erase Media operation is running for library [<String>]. |
| 19:874 | Erase Media operation cannot run as an Export operation is running for library [<String>]. |
| 19:875 | Another Erase Media operation is already running for library [<String>]. |
| 19:876 | Erase Media operation cannot run at this time because an Inventory operation is running for library [<String>]. |
| 19:877 | Cannot perform Data Verification. No license or the license has expired. |
| 19:878 | License for Data Verification will expire in [<Number>] days. |
| 19:879 | Another Download/Copy Update operation is already running. |
| 19:880 | Download/Copy Update operation cannot run at this time because one or more Install Update operations are running. |
| 19:881 | Install Update operation cannot run at this time because a Download/Copy Update operation is running. |
| 19:882 | Maximum concurrent Install Update operations are already running. |
| 19:883 | Failed to send the information for job [<Number>]. |
| 19:884 | Data Archiver iDataAgent is not installed. |
| 19:885 | Failed to get client ID for host name <String>. |
| 19:886 | Blackout Window for CommServe prevents the Compliance Archive job from running right now. |
| 19:887 | Blackout Window for CommServe prevents the Retrieve job from running right now. |
| 19:888 | Blackout Window for iDataAgent prevents the Retrieve job from running right now. |
| 19:889 | Full Blackout Window for iDataAgent prevents the Compliance Archive job from running right now. |
| 19:890 | Blackout Window for iDataAgent prevents the Compliance Archive job from running right now. |
| 19:891 | Compliance archive job failed for Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:892 | New compliance archive request received for Client [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:893 | Another compliance archive operation is running for client [<String>], Backup set [<String>], Subclient [<String>]. |
| 19:894 | New retrieve request received for client [<String>]. |
| 19:895 | Compliance archive job has been suspended by user's request. |
| 19:896 | Compliance archive job has been interrupted. |
| 19:897 | Compliance archive job has been killed. |
| 19:898 | Compliance archive job [<Number>] completed. |
| 19:899 | Retrieve job has been suspended by user's request. |
| 19:900 | Retrieve job has been killed. |
| 19:901 | Retrieve job [<Number>] failed. |
| 19:902 | Retrieve job [<Number>] completed. |
| 19:903 | Compliance archiving activity has been enabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:904 | Compliance archiving activity has been disabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:905 | Compliance archiving for <String> have been disabled on the client [<String>]. |
| 19:906 | Retrieve for <String> has been disabled on the client [<String>]. |
| 19:907 | Compliance Archiving and Retrieve for <String> have been disabled on the client [<String>]. |
| 19:908 | Compliance Archiving for <String> has been enabled on the client [<String>]. |
| 19:909 | Retrieve for <String> has been enabled on the client [<String>]. |
| 19:910 | Compliance Archiving and Retrieve for <String> have been enabled on the client [<String>]. |
| 19:911 | Auxiliary Copy operation has completed with one or more errors for job ID [<Number>]. |
| 19:912 | Data Verification operation has completed with one or more errors. |
| 19:913 | Erase Media operation has completed with one or more errors. |
| 19:914 | Media Inventory operation has completed with one or more errors. |
| 19:915 | Media Export operation has completed with one or more errors. |
| 19:916 | Download/Copy Updates operation has been killed. |
| 19:917 | Install Update job has been killed. |
| 19:918 | New backup request received for Client [<String>], iDataAgent [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:919 | There are no Content Indexing files to copy for job [<Number>]. |
| 19:920 | Job Manager received invalid message [<Number>]. Remote host=[<String>]. |
| 19:921 | Loss of control process detected for phase [<String>]. |
| 19:922 | Erase Backup Data job has been suspended by user <String>. |
| 19:923 | Erase Migrated Data job has been suspended by user <String>. |
| 19:924 | Erase Backup Data job has been killed by <String>. |
| 19:925 | Erase Migrated Data job has been killed by <String>. |
| 19:926 | Erase Backup Data job has been interrupted. |
| 19:927 | Erase Migrated Data job has been interrupted. |
| 19:928 | <Message> The Erase Data job will not run. |
| 19:929 | Erase Data operation has been disabled. |
| 19:930 | Erase Data operation has been enabled. |
| 19:931 | Failed to initialize Erase Data request. <String> |
| 19:932 | New Erase Migrated Data request received for Client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:933 | An Erase Migrated Data operation is running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:934 | An Erase Migrated Data operation is already running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:935 | Other Erase Migrated Data operations are running for client [<String>], iDataAgent [<String>], Backup Set [<String>]. |
| 19:936 | A mismatch in the database library has been detected. This may occur if some updates have not been applied correctly. Please check the JobManager.log file under the [<String>] folder of the CommServe machine for more information. You may need to uninstall the recently installed updates on the CommServe machine [<String>] and reinstall them with sufficient user privileges to make modifications to the CommServe SQL Database. |
| 19:937 | Failed to initialize Workflow request. [<String>] |
| 19:938 | Starting Workflow [<String>]. |
| 19:939 | A Workflow operation is already running for client [<String>]. |
| 19:940 | The Workflow has been terminated because Job [<Number>] has failed. |
| 19:941 | The Workflow has been terminated because Job [<Number>] has been killed. |
| 19:942 | Data Verification job has been killed by <String>. |
| 19:943 | Data Aging job has been killed by <String>. |
| 19:944 | Auxiliary Copy job has been killed by <String>. |
| 19:945 | Archive job has been killed by <String>. |
| 19:946 | Compliance archive job has been killed by <String>. |
| 19:947 | OSSV Replicate Creation job has been killed by <String>. |
| 19:948 | Backup job has been killed by <String>. |
| 19:949 | DR Backup job has been killed by <String>. |
| 19:950 | Index Restore job has been killed by <String>. |
| 19:951 | Media Inventory job has been killed by <String>. |
| 19:952 | Install Update job has been killed by <String>. |
| 19:953 | Download/Copy Updates operation has been killed by <String>. |
| 19:954 | Media Prediction job has been killed by <String>. |
| 19:955 | Recovery job has been killed by <String>. |
| 19:956 | Retrieve job has been killed by <String>. |
| 19:957 | OSSV Recovery job has been killed by <String>. |
| 19:958 | Restore job has been killed by <String>. |
| 19:959 | Scheduled Export job has been killed by <String>. |
| 19:960 | Synthetic Full job has been killed by <String>. |
| 19:961 | Erase Media job has been killed by <String>. |
| 19:962 | Data Verification job has been suspended by user <String>. |
| 19:963 | Data Aging job has been suspended by user <String>. |
| 19:964 | Auxiliary Copy job has been suspended by user <String>. |
| 19:965 | Archive job has been suspended by user <String>. |
| 19:966 | Compliance archive job has been suspended by user <String>. |
| 19:967 | OSSV Replicate Creation job has been suspended by user <String>. |
| 19:968 | Backup job has been suspended by user <String>. |
| 19:969 | DR Backup job has been suspended by user <String>. |
| 19:970 | Media Inventory job has been suspended by user <String>. |
| 19:971 | Media Prediction job has been suspended by user <String>. |
| 19:972 | Recovery job has been suspended by user <String>. |
| 19:973 | Retrieve job has been suspended by user <String>. |
| 19:974 | OSSV Recovery job has been suspended by user <String>. |
| 19:975 | Restore job has been suspended by user <String>. |
| 19:976 | Scheduled Export job has been suspended by user <String>. |
| 19:977 | Synthetic Full job has been suspended by user <String>. |
| 19:978 | Erase Media job has been suspended by user <String>. |
| 19:979 | Job [<Number>] resumed by user <String>. |
| 19:980 | Erase Backup Data operation has completed. |
| 19:981 | Erase Migrated Data operation has completed. |
| 19:982 | Erase Backup Data operation has failed. |
| 19:983 | Erase Migrated Data operation has failed. |
| 19:984 | The job was started in a suspended state. The job can be started by resuming the job. |
| 19:985 | Failed to get the Target Storage Policy for subclient [<String>]. Check the Storage Policy under the subclient properties. |
| 19:986 | <Message> The Storage Validation job will not run. |
| 19:987 | <Message> The Drive Cleaning job will not run. |
| 19:988 | <Message> The Stamp Media job will not run. |
| 19:989 | The job cannot run at this time as it is waiting for some jobs to complete. |
| 19:990 | New compliance archive request received for Client [<String>], Subclient [<String>]. |
| 19:991 | Storage Validation operation has completed. |
| 19:992 | Storage Validation operation has failed. |
| 19:993 | Drive Cleaning operation has completed. |
| 19:994 | Drive Cleaning operation has failed. |
| 19:995 | Stamp Media operation has completed. |
| 19:996 | Stamp Media operation has failed. |
| 19:997 | Catalogue Media operation has completed. |
| 19:998 | Catalogue Media operation has failed. |
| 19:999 | New Erase Backup Data request received for Client [<String>], iDataAgent [<String>]. |
| 19:1000 | New Consistency Point creation request received for Client [<String>], Subclient [<String>]. |
| 19:1001 | Consistency Point creation job [<Number>] completed. |
| 19:1002 | Consistency Point creation job has been killed by <String>. |
| 19:1003 | Consistency Point creation job has been suspended by user <String>. |
| 19:1004 | Consistency Point creation job has been interrupted. |
| 19:1005 | New Snapshot request received for Client [<String>], Subclient [<String>]. |
| 19:1006 | Snapshot job [<Number>] completed. |
| 19:1007 | Snapshot job has been killed by <String>. |
| 19:1008 | Snapshot job has been suspended by user <String>. |
| 19:1009 | Snapshot job has been interrupted. |
| 19:1010 | Data Management activity for Server group [<String>] has been enabled. |
| 19:1011 | Data Management activity for Server group [<String>] has been disabled. |
| 19:1012 | Data Recovery activity for Server group [<String>] has been enabled. |
| 19:1013 | Data Recovery activity for Server group [<String>] has been disabled. |
| 19:1014 | Data Management activity for Server group(s) [<String>] is disabled. |
| 19:1015 | Data Recovery activity for Server group(s) [<String>] is disabled. |
| 19:1016 | Failed to get a lock for job [<Number>]. |
| 19:1017 | Failed to initialize Auxiliary Copy job. |
| 19:1018 | Host [<String>] may have been uninstalled. Phase <String> cannot run. |
| 19:1019 | Failed to check for Erase Data license. |
| 19:1020 | No Erase Data License found. The evaluation license may have expired. |
| 19:1021 | An Erase Backup Data operation is already running for client [<String>], iDataAgent [<String>]. |
| 19:1022 | Failed to get the Job ID of the OSSV job. |
| 19:1023 | Blackout Window for CommServe prevents Erase Backup/Migrated Data job from running right now. |
| 19:1024 | No Filter Storage Policy has been defined for client [<String>] and iDataAgent [<String>]. |
| 19:1025 | The scheduled job is queued because the Queue Scheduled Jobs option is on. The job can be started by resuming the job or by deselecting the Queue Scheduled Job option. |
| 19:1026 | New copy back request received for client [<String>]. |
| 19:1027 | Copy Backup operation has been suspended by user <String>. |
| 19:1028 | Copy Backup operation has been killed by <String>. |
| 19:1029 | Copy Backup job [<Number>] failed. |
| 19:1030 | Copy Backup job [<Number>] completed. |
| 19:1031 | Another backup is running for client [<String>], iDataAgent [<String>], Subclient [<String>]. |
| 19:1032 | Another compliance archive operation is running for client [<String>], Subclient [<String>]. |
| 19:1033 | Failed to get the host name. |
| 19:1034 | Backup job failed. |
| 19:1035 | Delete Snapshot started on Client [<String>] for Workflow [<String>]. |
| 19:1036 | Snapshot on Client [<String>] for Workflow [<String>] was deleted successfully. |
| 19:1037 | Failed to delete snapshot on Client [<String>] for Workflow [<String>]. <String> |
| 19:1038 | Synthetic Full cannot run because no Incremental or Differential backup was run after the last Full backup for the Subclient. Client [<String>], iDataAgent [<String>], Subclient [<String>]. |
| 19:1039 | Backup activity is disabled on subclient [<String>] for Client [<String>], iDataAgent [<String>], Instance [<String>] and Database [<String>]. |
| 19:1040 | New synthetic full request received for the client [<String>], iDataAgent [<String>] and Subclient [<String>]. |
| 19:1041 | Processes for job [<Number>] were forcefully terminated. |
| 19:1042 | Snap activate can run only as part of a workflow. |
| 19:1043 | Restore has completed with more than one attempt. Please review the restore file list for partially restored files. The file immediately following a 'BEGIN RESTORE' statement with a failure reason of 'OLDER' is possibly a partially restored file. |
| 19:1044 | Another drive cleaning operation is already running for [<String>]. |
| 19:1045 | A library configuration update is in progress. |
| 19:1046 | Failed to unmount snapshot for Workflow [<String>]. <String> |
| 19:1047 | Checking if the index is in cache. |
| 19:1048 | Archive job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Archived [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1049 | Compliance archive job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Archived [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1050 | Snapshot job [<Number>] completed. Client [<String>], Duration [<String>]. |
| 19:1051 | Consistency Point creation job [<Number>] completed. Client [<String>], Duration [<String>]. |
| 19:1052 | OSSV Replicate Creation job [<Number>] completed. Client [<String>], Duration [<String>]. |
| 19:1053 | Backup job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Objects [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1054 | Job [<Number>] resumed by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1055 | Job [<Number>] has been automatically resumed according to the Blackout Window times. Client [<String>], Agent Type [<String>]. |
| 19:1056 | Job [<Number>] has been automatically resumed. Client [<String>], Agent Type [<String>]. |
| 19:1057 | Archive job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1058 | Compliance archive job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1059 | Consistency Point creation job [<Number>] has been killed by <String>. Client [<String>], Duration [<String>]. |
| 19:1060 | Snapshot job [<Number>] has been killed by <String>. Client [<String>], Duration [<String>]. |
| 19:1061 | OSSV Replicate Creation job [<Number>] has been killed by <String>. Client [<String>], Duration [<String>]. |
| 19:1062 | Backup job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Duration [<String>]. |
| 19:1063 | Archive job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:1064 | Compliance archive job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:1065 | Consistency Point creation job [<Number>] has been suspended by user <String>. Client [<String>]. |
| 19:1066 | Snapshot job [<Number>] has been suspended by user <String>. Client [<String>]. |
| 19:1067 | OSSV Replicate Creation job [<Number>] has been suspended by user <String>. Client [<String>]. |
| 19:1068 | Backup job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1069 | Synthetic Full job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1070 | Synthetic Full job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1071 | Synthetic Full job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:1072 | Recovery job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1073 | Retrieve job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1074 | Copy Backup job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1075 | OSSV Recovery job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1076 | Restore job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1077 | Recovery job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1078 | Retrieve job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1079 | Copy Backup operation job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1080 | OSSV Recovery job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1081 | Restore job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1082 | Recovery job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1083 | Retrieve job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1084 | Copy Backup operation [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1085 | OSSV Recovery job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1086 | Restore job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1087 | Restore job [<Number>] completed with one or more errors. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1088 | Recovery job [<Number>] failed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1089 | Retrieve job [<Number>] failed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1090 | Copy Backup job [<Number>] failed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1091 | OSSV Recovery job [<Number>] failed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1092 | Restore job [<Number>] failed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1093 | Backup job [<Number>] failed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1094 | Synthetic Full job [<Number>] failed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1095 | Install Update job has been suspended by user <String>. |
| 19:1096 | Download/Copy Updates operation has been suspended by user <String>. |
| 19:1097 | Failed to initialize job [<Number>] on service start-up. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:1098 | Install Update operation has completed with one or more errors for job ID [<Number>]. |
| 19:1099 | Download/Copy Updates operation has completed with one or more errors for job ID [<Number>]. |
| 19:1100 | Install Update operation has failed. |
| 19:1101 | Download/Copy Updates operation has failed. |
| 19:1102 | Failed to get the MediaAgent name. Please verify that the MediaAgent version is compatible with the client version. |
| 19:1103 | All jobs are in the process of being terminated. |
| 19:1104 | No clients were selected for installing updates. It is possible that there is no software installed on these clients. |
| 19:1105 | No Resources Available. Please check the Streams tab for details. |
| 19:1106 | Required resources are not available. |
| 19:1107 | A dependent job has not completed. |
| 19:1108 | The job was started in a suspended state. |
| 19:1109 | Please check the log files for this job for more details. |
| 19:1110 | The job will be retried after the restart interval. |
| 19:1111 | The job has exceeded the total running time. |
| 19:1112 | No resources were allocated for this copy |
| 19:1113 | Database operation did not succeed. Please check JobManager.log on the CommServe for detailed explanation. Error [<String>]. |
| 19:1114 | File System and Indexing Based (Data Protection) |
| 19:1115 | File System and Indexing Based (Data Recovery) |
| 19:1116 | Exchange DB (Data Protection) |
| 19:1117 | Informix DB (Data Protection) |
| 19:1118 | Lotus Notes DB (Data Protection) |
| 19:1119 | Oracle DB (Data Protection) |
| 19:1120 | SQL DB (Data Protection) |
| 19:1121 | Sybase DB (Data Protection) |
| 19:1122 | DB2 (Data Protection) |
| 19:1123 | Other (Data Protection) |
| 19:1124 | Disaster Recovery backup |
| 19:1125 | Auxiliary Copy |
| 19:1126 | Data Aging |
| 19:1127 | Install Updates |
| 19:1128 | Download/Copy Updates |
| 19:1129 | A Download or Copy Update operation can be started only after 10 minutes of the completion of the previous Install Update operation. |
| 19:1130 | Failed to create job history for job [<Number>]. A recycle of CommServe services may be required. |
| 19:1131 | Unable to reach Client/Access Node [<String>]. Please check Client and Access node configuration, confirm Access Node and Client are up and running then check network connectivity between Commserve and Access Node, and Access Node and Client. |
| 19:1132 | Another backup is running for client [<String>], iDataAgent [<String>], Instance [<String>], Subclient [<String>]. |
| 19:1133 | New Consistent Recovery Point creation operation received for Client [<String>], Replication Set [<String>]. |
| 19:1134 | New Recovery Point creation operation received for Client [<String>], Replication Set [<String>]. |
| 19:1135 | Recovery Point creation job [<Number>] completed. Client [<String>], Replication Set [<String>], Duration [<String>]. |
| 19:1136 | Recovery Point creation job [<Number>] has been killed by <String>. Client [<String>], Replication Set [<String>], Duration [<String>]. |
| 19:1137 | New backup request received for Client [<String>], iDataAgent [<String>], Instance [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1138 | New Index |
| 19:1139 | Full |
| 19:1140 | Offline Full |
| 19:1141 | Online Full |
| 19:1142 | Transaction Log |
| 19:1143 | Incremental |
| 19:1144 | Delta |
| 19:1145 | Differential |
| 19:1146 | Synthetic Full |
| 19:1147 | Transaction Log No Truncation |
| 19:1148 | ASR |
| 19:1149 | Snapshot |
| 19:1150 | Create Replica |
| 19:1151 | Update Replica |
| 19:1152 | A Recovery Point creation operation is already running for client [<String>] and Replication Set [<String>]. |
| 19:1153 | Pipelines from the previous phase have not unregistered yet from the machines [<String>]. |
| 19:1154 | <Message> The Download/Copy Updates job will not run. |
| 19:1155 | Failed to get the Backup set for Replication Set [<String>] for Client [<String>]. The Recovery Point will not be backed up. |
| 19:1156 | Failed to get the host name to back up recovery point. |
| 19:1157 | Failed to get the command line arguments. Please check JobManager.log on the CommServe for additional information. |
| 19:1158 | <Message> The List Media job will not run. |
| 19:1159 | No pairs have been defined for Replication Set [<String>] for Client [<String>]. |
| 19:1160 | Data Aging operation has completed with one or more errors. |
| 19:1161 | The number of running jobs has exceeded the limit on the maximum number [<Number>] allowed. |
| 19:1162 | Cannot create recovery point for Replication Set [<String>] on Client [<String>]. No license or the license has expired. |
| 19:1163 | Cannot back up recovery point for Replication Set [<String>] on Client [<String>]. No license or the license has expired. |
| 19:1164 | <String> cannot be performed on Client [<String>]. No license or the license has expired. |
| 19:1165 | Backup activity has been disabled for subclient [<String>] on Client [<String>], iDataAgent [<String>] and instance [<String>]. |
| 19:1166 | Backup activity has been enabled for subclient [<String>] on Client [<String>], iDataAgent [<String>] and instance [<String>]. |
| 19:1167 | Loss of Oracle process on the client machine. Possible causes: 1. The control process has unexpectedly died. 2. The communication to the machine <String> might have gone down due to network errors. 3. If the machine <String> is a cluster, it may have failed over. 4. The machine <String> may have rebooted. |
| 19:1168 | Failed to receive acknowledgement from Job Manager for the process registration. |
| 19:1169 | Failed to receive acknowledgement from Job Manager for the process registration within the timeout period. |
| 19:1170 | Job [<Number>] was killed by the system because a new job [<Number>] of a similar type was started |
| 19:1171 | Failed to start Erase Data job. Check that the Filter Storage Policy has been defined for this agent. |
| 19:1172 | Blackout Window for CommServe prevents the Content Indexing job from running right now. |
| 19:1173 | New Online Content Indexing request received for Client [<String>], Application Type [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1174 | Online Content Indexing job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Objects [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1175 | Online Content Indexing job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Duration [<String>]. |
| 19:1176 | Online Content Indexing job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1177 | Online Content Indexing job [<Number>] failed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1178 | Online Content Indexing job [<Number>] completed. |
| 19:1179 | Online Content Indexing job [<Number>] has been converted to full because a full Content Indexing job has not been run. |
| 19:1180 | Content Indexing operation has completed. |
| 19:1181 | Content Indexing operation has completed with one or more errors. |
| 19:1182 | Content Indexing operation has failed. |
| 19:1183 | Content Indexing job has been killed by <String>. |
| 19:1184 | Content Indexing job has been suspended by user <String>. |
| 19:1185 | Backup job [<Number>] has been converted to a full backup because of a storage policy association change. |
| 19:1186 | Backup job [<Number>] has been converted to a full backup because of a storage policy change. |
| 19:1187 | Backup job [<Number>] has been converted to a full backup because of a subclient association change. |
| 19:1188 | Backup job [<Number>] has been converted to a full backup because of a client reinstallation. |
| 19:1189 | Backup job [<Number>] has been converted to a full backup because the backup properties have changed. |
| 19:1190 | Backup job [<Number>] has been converted to a full backup because the user has changed the storage policy. |
| 19:1191 | Backup job [<Number>] has been converted to a full backup because the new storage policy copy was set to be the primary copy. |
| 19:1192 | Backup job [<Number>] has been converted to a full backup because a job in the current full cycle has been manually pruned or disabled for copy. |
| 19:1193 | Backup job [<Number>] has been converted to a full backup because the data or log ID has been changed due to a reassociation of subclient properties. |
| 19:1194 | Backup job [<Number>] has been converted to a full backup because of Active Directory during a client upgrade. |
| 19:1195 | Backup job [<Number>] has been converted to a full backup because Data Aging did not find a full backup. |
| 19:1196 | Online Content Indexing job [<Number>] has been converted to full because of a storage policy association change. |
| 19:1197 | Online Content Indexing job [<Number>] has been converted to full because of a storage policy change. |
| 19:1198 | Online Content Indexing job [<Number>] has been converted to full because of a subclient association change. |
| 19:1199 | Online Content Indexing job [<Number>] has been converted to full because of a client reinstallation. |
| 19:1200 | Online Content Indexing job [<Number>] has been converted to a full backup because the backup properties have changed. |
| 19:1201 | Online Content Indexing job [<Number>] has been converted to a full because the user has changed the storage policy. |
| 19:1202 | Online Content Indexing job [<Number>] has been converted to a full backup because the new storage policy copy was set to be the primary copy. |
| 19:1203 | Online Content Indexing job [<Number>] has been converted to a full backup because a job in the current full cycle has been manually pruned or disabled for copy. |
| 19:1204 | Online Content Indexing job [<Number>] has been converted to a full backup because the data or log ID has been changed due to a re-association of subclient properties. |
| 19:1205 | Online Content Indexing job [<Number>] has been converted to a full backup because of Active Directory during a client upgrade. |
| 19:1206 | Online Content Indexing job [<Number>] has been converted to a full backup because Data Aging did not find a full backup. |
| 19:1207 | Command line arguments for <String> job [<Number>] exceeded maximum length. |
| 19:1208 | Could not attach to shared memory to receive message [<Number>] |
| 19:1209 | Could not detach from shared memory to receive message [<Number>] |
| 19:1210 | Could not open communication semaphore [<Number>] |
| 19:1211 | Could not release communication semaphore [<Number>] |
| 19:1212 | Create Content Indexing job option is no longer supported. |
| 19:1213 | Content Indexing activity on the client [<String>] has been disabled. |
| 19:1214 | Content index activity on the client [<String>] has been enabled. |
| 19:1215 | Content Indexing activity for <String> has been disabled on the client [<String>]. |
| 19:1216 | Content Indexing activity for <String> has been enabled on the client [<String>]. |
| 19:1217 | Content Indexing activity has been disabled on the server. |
| 19:1218 | Content Indexing activity has been enabled on the server. |
| 19:1219 | Content Indexing activity on the server has been disabled. |
| 19:1220 | Content Indexing activity on the server has been enabled. |
| 19:1221 | Content Indexing activity on CommServe is disabled. |
| 19:1222 | Content Indexing activity for <String> on CommServe is disabled. |
| 19:1223 | Content Indexing activity for Server group(s) [<String>] is disabled. |
| 19:1224 | Content Indexing activity on Client [<String>] is disabled. |
| 19:1225 | Content Indexing activity for [<String>] on Client [<String>] is disabled. |
| 19:1226 | Content Indexing activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>] is disabled. |
| 19:1227 | Content Indexing operation has been disabled. |
| 19:1228 | Content Indexing operation has been enabled. |
| 19:1229 | Content Indexing activity on CommServe is disabled. |
| 19:1230 | <Message> The Content Indexing job will not run. |
| 19:1231 | Failed to get the configuration for application type [<Number>], operation type [<Number>], phase [<Number>]. |
| 19:1232 | Data Management, Data Recovery, and Content Index activities have been disabled on the client [<String>]. |
| 19:1233 | Data Management, Data Recovery, and Content Index activities have been enabled on the client [<String>]. |
| 19:1234 | Online Content Indexing job has been suspended by user <String>. |
| 19:1235 | Online Content Indexing job has been killed by <String>. |
| 19:1236 | Backup activity for subclient [<String>] on Client [<String>], iDataAgent [<String>] and Instance [<String>] is disabled. |
| 19:1237 | Content Indexing activity has been enabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:1238 | Content Indexing activity has been disabled for subclient [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:1239 | Auxiliary Copy attempt started. To copy : <String> (out of <String>). |
| 19:1240 | Auxiliary Copy operation has completed. Copied : <String>. |
| 19:1241 | A Content Indexing operation is already running for Storage Policy [<String>]. |
| 19:1242 | A Content Indexing Blackout Window for CommServe prevents the Content Indexing job from running right now. |
| 19:1243 | Blackout Window for iDataAgent prevents the Content Indexing job from running right now. |
| 19:1244 | Offline Content Indexing |
| 19:1245 | Online Content Indexing |
| 19:1246 | <Message> The Content Indexing job will not run. |
| 19:1247 | Synthetic Full cannot run because no Incremental backup was run after last Full backup for the subclient. |
| 19:1248 | MediaAgent already set without an update. |
| 19:1249 | The MediaAgent must be the same version as the CommServe for a CommServe Disaster Recovery Backup to fully complete successfully. |
| 19:1250 | Recovery point could not be created since <Allow Recovery Points> option is disabled for Replication Set [<String>] for Client [<String>]. |
| 19:1251 | Insufficient user rights for job to continue. |
| 19:1252 | Failed to remove information for CDR job (Pair ID [<Number>]. Job ID [<Number>]) from table [<String>] with error [<String>]. |
| 19:1253 | Number of restarts has exceeded the maximum number allowed [<Number>]. |
| 19:1254 | <String> job [<Number>] has been reindexed because of a storage policy association change. |
| 19:1255 | <String> job [<Number>] has been re-indexed because of a storage policy change. |
| 19:1256 | <String> job [<Number>] has been reindexed because of a subclient association change. |
| 19:1257 | <String> job [<Number>] has been reindexed because of a client reinstallation. |
| 19:1258 | <String> job [<Number>] has been reindexed because the properties have changed. |
| 19:1259 | <String> job [<Number>] has been reindexed because the user has changed the storage policy. |
| 19:1260 | <String> job [<Number>] has been reindexed because the new storage policy copy was set to be the primary copy. |
| 19:1261 | <String> job [<Number>] has been reindexed because a job in the current full cycle has been manually pruned or disabled for copy. |
| 19:1262 | <String> job [<Number>] has been reindexed because the data or log ID has been changed due to a re-association of subclient properties. |
| 19:1263 | <String> job [<Number>] has been reindexed because of Active Directory during a client upgrade. |
| 19:1264 | <String> job [<Number>] has been reindexed because Data Aging did not find a full backup. |
| 19:1265 | <String> job [<Number>] has been reindexed. |
| 19:1266 | Full Blackout Window for Client prevents the Backup from running right now. |
| 19:1267 | Full Blackout Window for Server group prevents the Backup from running right now. |
| 19:1268 | Blackout Window for Client prevents the Backup job from running right now. |
| 19:1269 | Blackout Window for Server group prevents the Backup job from running right now. |
| 19:1270 | Full Blackout Window for Client prevents the Archiver job from running right now. |
| 19:1271 | Full Blackout Window for Server group prevents the Archiver job from running right now. |
| 19:1272 | Blackout Window for Client prevents the Archiver job from running right now. |
| 19:1273 | Blackout Window for Server group prevents the Archiver job from running right now. |
| 19:1274 | Blackout Window for Client prevents the Compliance Archive job from running right now. |
| 19:1275 | Blackout Window for Server group prevents the Compliance Archive job from running right now. |
| 19:1276 | Full Blackout Window for Client prevents the OSSV Replicate Creation from running right now. |
| 19:1277 | Full Blackout Window for Server group prevents the OSSV Replicate Creation from running right now. |
| 19:1278 | Blackout Window for Client prevents the OSSV Replicate Creation job from running right now. |
| 19:1279 | Blackout Window for Server group prevents the OSSV Replicate Creation job from running right now. |
| 19:1280 | Blackout Window for Client prevents the Restore job from running right now. |
| 19:1281 | Blackout Window for Server group prevents the Restore job from running right now. |
| 19:1282 | Blackout Window for Client prevents the Recovery job from running right now. |
| 19:1283 | Blackout Window for Server group prevents the Recovery job from running right now. |
| 19:1284 | Blackout Window for Client prevents the Retrieve job from running right now. |
| 19:1285 | Blackout Window for Server group prevents the Retrieve job from running right now. |
| 19:1286 | Blackout Window for Client prevents the OSSV Recovery job from running right now. |
| 19:1287 | Blackout Window for Server group prevents the OSSV Recovery job from running right now. |
| 19:1288 | Blackout Window for Client prevents the Content Indexing job from running right now. |
| 19:1289 | Blackout Window for Server group prevents the Content Indexing job from running right now. |
| 19:1290 | Interrupting job due to cluster group failover. |
| 19:1291 | New retrieve request received for client [<String>], application type [<String>]. |
| 19:1292 | Failed to read row for job [<Number>] from table [<String>] with error [<String>]. |
| 19:1293 | New restore request received. |
| 19:1294 | New search and retrieve request received. |
| 19:1295 | Content Indexing job cannot run because no Search engine has been set. |
| 19:1296 | Could not open shared memory. Please check the minimum and maximum shared memory segment sizes of the kernel. |
| 19:1297 | Could not open shared memory. Please check the minimum and maximum shared memory segment sizes of the kernel on [<String>]. |
| 19:1298 | <String> |
| 19:1299 | No streams were allocated for the backup. |
| 19:1300 | Failed to set the task state active. |
| 19:1301 | Failed to add attempt to the database. |
| 19:1302 | Failed to get the default replication pair ID for the recovery point job. |
| 19:1303 | Failed to get either the Replication Set ID or the consistency point job ID for this job. |
| 19:1304 | Failed to connect to Communications Service to register the process. |
| 19:1305 | Failed to send process registration to Communications Service. |
| 19:1306 | Failed to get a response from Communications Service for process registration. |
| 19:1307 | Failed to get a response in the timeout period from Communications Service for process registration. |
| 19:1308 | Register job failure: [<String>]. Click http://kb.commvault.com/article/JM0004 for additional information. |
| 19:1309 | Unexpected message received for job registration acknowledgement. |
| 19:1310 | Blackout Window |
| 19:1311 | Interrupted |
| 19:1312 | Activity Disabled |
| 19:1313 | Network Problem |
| 19:1314 | Failed to add CommCell client to the table. |
| 19:1315 | <String> |
| 19:1316 | The job will be converted to a differential backup. |
| 19:1317 | The incremental backup job will be converted to a differential backup. |
| 19:1318 | [<String>] |
| 19:1319 | Job start: [<String>] |
| 19:1320 | Resources: [<String>] |
| 19:1321 | Archive File: [<String>] |
| 19:1322 | Scalability: [<String>] |
| 19:1323 | Get media info: [<String>] |
| 19:1324 | Reserve volume/drive info: [<String>] |
| 19:1325 | Failed to lock new job request. |
| 19:1326 | Dependency: [<String>] |
| 19:1327 | Attempt start error: [<String>] |
| 19:1328 | <String> |
| 19:1329 | Stub recall history: [<String>] |
| 19:1330 | <String> |
| 19:1331 | CLBACKUP Send end of file [<String>] |
| 19:1332 | CLBACKUP [<String>] |
| 19:1333 | DB2 Backup [<String>] |
| 19:1334 | DB2 Restore [<String>] |
| 19:1335 | Oracle Backup [<String>] |
| 19:1336 | Oracle Restore [<String>] |
| 19:1337 | Deprecated message[<String>], [<String>], [<String>]. |
| 19:1338 | Deprecated message[<String>], [<String>], [<String>]. |
| 19:1339 | Deprecated message[<String>], [<Number>], [<String>]. |
| 19:1340 | Deprecated message[<String>], [<String>], [<String>]. |
| 19:1341 | Deprecated message[<Number>] [<String>],[<String>] [<String>]. |
| 19:1342 | Deprecated message[<Number>] <String>, [<String>], [<String>], [<String>]. |
| 19:1343 | Deprecated message[<Number>] <String>, [<String>], [<String>], [<String>]. |
| 19:1344 | Deprecated message[<Number>] <String>, [<String>], [<String>]. |
| 19:1345 | Deprecated message[<Number>]. |
| 19:1346 | Deprecated message <String>. |
| 19:1347 | Deprecated message |
| 19:1348 | Deprecated message <String>. |
| 19:1349 | Online Content Indexing job has been interrupted. |
| 19:1350 | <String> job [<Number>] has been reindexed (code <Number>). |
| 19:1351 | Online Content Indexing job [<Number>] has been converted to full (code <Number>). |
| 19:1352 | Backup job [<Number>] has been converted to a full (code <Number>). |
| 19:1353 | Online Content Indexing activity for Server group [<String>] has been enabled. |
| 19:1354 | Online Content Indexing activity for Server group [<String>] has been disabled. |
| 19:1355 | Full Blackout Window for Instance prevents the Backup from running right now. |
| 19:1356 | Full Blackout Window for Backup Set prevents the Backup from running right now. |
| 19:1357 | Full Blackout Window for Subclient prevents the Backup from running right now. |
| 19:1358 | Full Blackout Window for Instance prevents the Archiver job from running right now. |
| 19:1359 | Full Blackout Window for Backup Set prevents the Archiver job from running right now. |
| 19:1360 | Full Blackout Window for Subclient prevents the Archiver job from running right now. |
| 19:1361 | Blackout Window for Instance prevents the Compliance Archive job from running right now. |
| 19:1362 | Blackout Window for Backup Set prevents the Compliance Archive job from running right now. |
| 19:1363 | Blackout Window for Subclient prevents the Compliance Archive job from running right now. |
| 19:1364 | Full Blackout Window for Instance prevents the OSSV Replicate Creation from running right now. |
| 19:1365 | Full Blackout Window for Backup Set prevents the OSSV Replicate Creation from running right now. |
| 19:1366 | Full Blackout Window for Subclient prevents the OSSV Replicate Creation from running right now. |
| 19:1367 | Blackout Window for Instance prevents the Backup job from running right now. |
| 19:1368 | Blackout Window for Backup Set prevents the Backup job from running right now. |
| 19:1369 | Blackout Window for Subclient prevents the Backup job from running right now. |
| 19:1370 | Blackout Window for Instance prevents the Archiver job from running right now. |
| 19:1371 | Blackout Window for Backup Set prevents the Archiver job from running right now. |
| 19:1372 | Blackout Window for Subclient prevents the Archiver job from running right now. |
| 19:1373 | Blackout Window for Instance prevents the OSSV Replicate Creation job from running right now. |
| 19:1374 | Blackout Window for Backup Set prevents the OSSV Replicate Creation job from running right now. |
| 19:1375 | Blackout Window for Subclient prevents the OSSV Replicate Creation job from running right now. |
| 19:1376 | Blackout Window for Instance prevents the Content Indexing job from running right now. |
| 19:1377 | Blackout Window for Backup Set prevents the Content Indexing job from running right now. |
| 19:1378 | Blackout Window for Subclient prevents the Content Indexing job from running right now. |
| 19:1379 | Job Manager Internal error:< <Number> >. |
| 19:1380 | The job will be converted to a differential backup. |
| 19:1381 | The incremental backup job will be converted to a differential backup. |
| 19:1382 | Failed to set the task state active. |
| 19:1383 | Failed to add CommCell client to the table. |
| 19:1384 | Failed to add attempt to the database. |
| 19:1385 | Failed to lock new job request. |
| 19:1386 | Failed to get the default replication pair ID for the recovery point job. |
| 19:1387 | Failed to get either the Replication Set ID or the consistency point job ID for this job. |
| 19:1388 | An exception occurred while allocating resources. |
| 19:1389 | Skipping resource manager calls [<String>]. |
| 19:1390 | Error in adding task entry in database. |
| 19:1391 | System Internal Error. |
| 19:1392 | There are no jobs in the time range specified |
| 19:1393 | Admin job request initialization failed. |
| 19:1394 | Admin job request failed in finding CommServe host name. |
| 19:1395 | Erase media failed in finding CommServe host name. |
| 19:1396 | Erase media initialization failed. |
| 19:1397 | Library operations request failed. |
| 19:1398 | Library operations request failed in finding CommServe host name. |
| 19:1399 | Archive prune request failed in finding CommServe host name. |
| 19:1400 | Archive prune request initialization failed. |
| 19:1401 | Could not start job within [<Number>] seconds of scheduled start time of [<String>] |
| 19:1402 | Checking if the BCD index is in cache. |
| 19:1403 | Failed to get information for the BCD index archive file. |
| 19:1404 | A Backup Copy Workflow operation is already running for Storage Policy [<String>]. |
| 19:1405 | Failed to initialize Backup Copy Workflow request. [<String>] |
| 19:1406 | Starting Backup Copy Workflow [<String>]. |
| 19:1407 | Disk Library Maintenance operation has completed. |
| 19:1408 | Disk Library Maintenance operation has failed. |
| 19:1409 | Failed to create a new job from the original job; job ID [<Number>]. |
| 19:1410 | Failed to create a log backup job from the original SQL job; job ID [<Number>]. |
| 19:1411 | Failed to create a backup job from the original consistency point job; job ID [<Number>]. |
| 19:1412 | Failed to create a legal hold backup job from the original job; job ID [<Number>]. |
| 19:1413 | The job was started in a suspended state by the end user. The job can be started by resuming the job. |
| 19:1414 | The job was started in a suspended state by Compliance user. The job can be started by resuming the job. |
| 19:1415 | <Message> The Backup Copy job will not run. |
| 19:1416 | Create Backup Copy option will not be performed because there is an earlier dependent job [<Number>] that must be backed up to tape first. |
| 19:1417 | Job [<Number>] has been converted to a full backup because Lotus Notes data migrator is configured to operate in backup mode. |
| 19:1418 | Backup Copy job failed because dependent job [<Number>] failed to start. |
| 19:1419 | Snap Backup failed to start because license is not configured for client [<String>]. |
| 19:1420 | Failed to get the command line arguments. Please check JobManager.log on the CommServe for additional information. |
| 19:1421 | OCS activity for [<String>] on Client [<String>] is disabled. |
| 19:1422 | Analysis |
| 19:1423 | Discovery |
| 19:1424 | Restore (Export) job has been interrupted. |
| 19:1425 | Restore (Export) job has failed. |
| 19:1426 | Deprecated message. |
| 19:1427 | Deprecated message [<Number>]. |
| 19:1428 | Deprecated message. |
| 19:1429 | <String> job [<Number>] has been reindexed because the last backup was done in a different operation type. |
| 19:1430 | Online Content Indexing job [<Number>] has been converted to a full backup because the last backup was done in a different operation type. |
| 19:1431 | Backup job [<Number>] has been converted to a full backup because the last backup was done in a different operation type. |
| 19:1432 | Restore (Export) Job operation is already running. |
| 19:1433 | Snap Backup cannot run because there is no snapshot copy on the storage policy. |
| 19:1434 | Create Backup Copy option will not be performed because the storage policy has Enable Backup Copy disabled. |
| 19:1435 | <String> job [<Number>] has been reindexed because the last snap backup did not successfully complete archive index after completing snap phase. |
| 19:1436 | Online Content Indexing job [<Number>] has been converted to a full backup because the last snap backup did not successfully complete archive index after completing snap phase. |
| 19:1437 | Backup job [<Number>] has been converted to a full backup because the last snap backup did not successfully complete archive index after completing snap phase. |
| 19:1438 | Deprecated message [<String>] [<String>] [<String>]. |
| 19:1439 | Deprecated message [<String>] [<String>] [<String>]. |
| 19:1440 | Deprecated message [<String>] [<String>] [<String>]. |
| 19:1441 | Create Backup Copy option for the snap backup job will not be performed because a conflicting offline Backup Copy job is currently running. |
| 19:1442 | Deprecated message |
| 19:1443 | Job [<Number>] cannot be committed. |
| 19:1444 | Commit request pending for job [<Number>]. Request converted to INTERRUPT and jobs context is set to COMMIT |
| 19:1445 | Blackout Window for CommServe prevents Restore (Export) job from running right now. |
| 19:1446 | Deprecated message [<Number>]. |
| 19:1447 | Failed to construct Restore (Export) job server object. |
| 19:1448 | Multiple instances [<Number>] for Oracle job are not allowed. |
| 19:1449 | Snap backup job completed with errors. Please check Events and logs for further details. |
| 19:1450 | Erase Data job will not run because Erase Data is not enabled for client [<String>]. |
| 19:1451 | Backup job [<Number>] has been converted to a full. |
| 19:1452 | <String> job [<Number>] has been reindexed. |
| 19:1453 | Online Content Indexing job [<Number>] has been converted to full. |
| 19:1454 | Erase Data job could not be started since <Allow Erase Data> option is disabled for one or more storage policies. |
| 19:1455 | Erase Data job could not be started since <Allow Erase Data> option is disabled for storage policy. |
| 19:1456 | There are no jobs that need to be backup copied. |
| 19:1457 | Could not get the list of jobs to back up copy. |
| 19:1458 | <String> job [<Number>] has been reindexed because the backup level set is not supported for this operation. |
| 19:1459 | Online Content Indexing job [<Number>] has been converted to a full backup because the level set is not supported for this operation. |
| 19:1460 | Backup job [<Number>] has been converted to a full backup because the backup level set is not supported for this operation. |
| 19:1461 | MYSQL (Data Protection) |
| 19:1462 | SQL server differential snap backup is not supported on this SQL version. |
| 19:1463 | Unable to calculate percentage change because previous job size is zero. |
| 19:1464 | Snap backup is not supported for SQL Server transaction log backups. The job will run as traditional log backup. |
| 19:1465 | Create Backup Copy option for the snap backup job will not be performed because of the storage policy settings. |
| 19:1466 | Restore (Export) job has started for Automated Content Classification Policy [<String>]. |
| 19:1467 | Restore (Export) job has completed. |
| 19:1468 | Restore (Export) job has completed with one or more errors. |
| 19:1469 | Restore (Export) job has been killed by [<String>]. |
| 19:1470 | Restore (Export) job has been suspended by user [<String>]. |
| 19:1471 | Too many scripts [<Number>] given for Oracle job and are not allowed. |
| 19:1472 | Could not verify [<Number>] instances for Oracle job. |
| 19:1473 | Deprecated message. |
| 19:1474 | Restore (Export) |
| 19:1475 | Restore (Export) Job operation is already running for the compliance policy [<String>]. |
| 19:1476 | Data Management activity for [<String>] have been disabled on the client [<String>]. |
| 19:1477 | Data Management activity for [<String>] have been enabled on the client [<String>]. |
| 19:1478 | Data Management activity for [<String>] on Client [<String>] is disabled. |
| 19:1479 | Job [<Number>] has been converted to a full backup because option Use direct database access is modified |
| 19:1480 | Deprecated message [<Number>] [<String>], [<String>], [<String>]. |
| 19:1481 | Deprecated message [<Number>] <String>, [<String>], [<String>], [<String>]. |
| 19:1482 | Deprecated message [<Number>] <String>, [<String>], [<String>], [<String>]. |
| 19:1483 | Deprecated message [<Number>] [<String>], [<String>], [<String>]. |
| 19:1484 | Deprecated message [<Number>]. |
| 19:1485 | Deprecated message <String>. |
| 19:1486 | Deprecated message. |
| 19:1487 | Deprecated message <String>. |
| 19:1488 | Deprecated message [<Number>] [<String>], [<String>], [<String>]. |
| 19:1489 | Deprecated message [<Number>] <String>, [<String>], [<String>], [<String>]. |
| 19:1490 | Deprecated message [<Number>] <String>, [<String>], [<String>], [<String>]. |
| 19:1491 | Deprecated message [<Number>] [<String>], [<String>], [<String>]. |
| 19:1492 | Deprecated message [<Number>]. |
| 19:1493 | Deprecated message <String>. |
| 19:1494 | Deprecated message. |
| 19:1495 | Deprecated message <String>. |
| 19:1496 | Install Client job has completed with one or more errors. |
| 19:1497 | Install Client job has failed. |
| 19:1498 | Install Client job has been killed by [<String>]. |
| 19:1499 | Install Client job has been suspended by user [<String>]. |
| 19:1500 | Uninstall Client job has completed with one or more errors. |
| 19:1501 | Uninstall Client job has failed. |
| 19:1502 | Uninstall Client job has been killed by [<String>]. |
| 19:1503 | Uninstall Client job has been suspended by user [<String>]. |
| 19:1504 | Sybase IQ Backup [<String>] |
| 19:1505 | Sybase IQ Restore [<String>] |
| 19:1506 | Failed to initialize External Data Connector Workflow request. [<String>] |
| 19:1507 | Starting External Data Connector Workflow. |
| 19:1508 | An External Data Connector Workflow operation is already running. |
| 19:1509 | External Data Workflow job failed because dependent job [<Number>] failed to start. |
| 19:1510 | Blackout Window for CommServe prevents the Media Refresh job from running right now. |
| 19:1511 | Media Refresh operation has completed. |
| 19:1512 | Media Refresh operation has completed with one or more errors for job ID [<Number>]. |
| 19:1513 | Media Refresh operation has failed. |
| 19:1514 | Media Refresh job has been killed by <String>. |
| 19:1515 | Media Refresh job has been suspended by user <String>. |
| 19:1516 | Media Refresh operation has completed. Copied : <String>. |
| 19:1517 | Failed to send the information for the Media Refresh job. |
| 19:1518 | Media Refresh operation has failed; Job ID [<Number>]. |
| 19:1519 | Media Refresh job has been interrupted. |
| 19:1520 | Failed to initialize Media Refresh job. |
| 19:1521 | Media Refresh operation has been disabled. |
| 19:1522 | Media Refresh operation has been enabled. |
| 19:1523 | Media Refresh activity on CommServe is disabled. |
| 19:1524 | Failed to get the Subclient Property of PostgreSQL for job [<Number>]. |
| 19:1525 | There are no jobs that need to be operated on. |
| 19:1526 | Could not get the list of jobs to operate on. |
| 19:1527 | CDR (Data Management) |
| 19:1528 | WBA and CDR (Data Recovery) |
| 19:1529 | <String> job [<Number>] has been reindexed because the image file has changed. |
| 19:1530 | Online Content Indexing job [<Number>] has been converted to full because the image file has changed. |
| 19:1531 | Backup job [<Number>] has been converted to a full backup because the image file has changed. |
| 19:1532 | This job has been converted to full on user request. Qscript PromoteToFullById was used on subclient. |
| 19:1533 | <Message> The Media Refresh job will not run. |
| 19:1534 | Another CCM job is already running. |
| 19:1535 | <String> activity for the Commcell has been re-enabled based on scheduled time. |
| 19:1536 | <String> activity for client [<String>] has been re-enabled based on scheduled time. |
| 19:1537 | <String> activity for client [<String>], iDataAgent [<String>] has been re-enabled based on scheduled time. |
| 19:1538 | <String> activity for Server group [<String>] has been re-enabled based on scheduled time. |
| 19:1539 | Media Refresh attempt started. To refresh : <String> (out of <String>). |
| 19:1540 | Media Refresh |
| 19:1541 | New discovery request received for Client [<String>], Application Type [<String>], Instance [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1542 | A Media Refresh operation is already running for Storage Policy [<String>]. |
| 19:1543 | All phases were skipped for backup job [<Number>]. Please check if proper content is configured for backup. |
| 19:1544 | Recovery Point creation job [<Number>] failed. Client [<String>], Replication Set [<String>], Duration [<String>]. |
| 19:1545 | Backup job [<Number>] has been converted to a full backup because the CXBF Incremental Support is used. |
| 19:1546 | Deprecated message. |
| 19:1547 | Deprecated message. |
| 19:1548 | Deprecated message [<String>]. |
| 19:1549 | Deprecated message [<String>]. |
| 19:1550 | The number of running [<String>] jobs has exceeded the limit on the maximum number [<Number>] allowed. |
| 19:1551 | Failed to get the Destination Client ID for Replication Set [<String>]. |
| 19:1552 | Failed to get number of streams for CommCell ID [<Number>], client [<String>], instance [<String>]. Check the value of BAR_MAX_BACKUP in Informix Server configuration file (onconfig). Please check the log on the client machine for more information. |
| 19:1553 | Deduplication DB Reconstruction operation has started; job ID [<Number>]. |
| 19:1554 | Failed to initialize Deduplication DB Reconstruction job for task [<Number>]. Please check Job Manager log files and/or call your vendor's support hotline. |
| 19:1555 | A Deduplication DB Reconstruction operation is already running for Storage Policy [<String>]. |
| 19:1556 | <Message> The Deduplication DB Reconstruction job will not run. |
| 19:1557 | Deduplication DB Reconstruction operation has completed. |
| 19:1558 | Deduplication DB Reconstruction operation has completed with one or more errors. |
| 19:1559 | Deduplication DB Reconstruction operation has failed. |
| 19:1560 | Deduplication DB Reconstruction job has been killed by <String>. |
| 19:1561 | Deduplication DB Reconstruction job has been suspended by user <String>. |
| 19:1562 | Deduplication DB Reconstruction job has been interrupted. |
| 19:1563 | Tape Import operation has started; job ID [<Number>]. |
| 19:1564 | Tape Import operation has completed. |
| 19:1565 | Tape Import operation has failed. |
| 19:1566 | Tape Import operation has completed with one or more errors. |
| 19:1567 | Tape Import job has been killed by <String>. |
| 19:1568 | Tape Import job has been suspended by user <String>. |
| 19:1569 | <Message> The Tape Import job will not run. |
| 19:1570 | CCM Export operation has started; job ID [<Number>]. |
| 19:1571 | CCM Export operation has completed. |
| 19:1572 | CCM Export operation has completed with one or more errors. |
| 19:1573 | CCM Export operation has failed. |
| 19:1574 | CCM Export job has been killed by <String>. |
| 19:1575 | CCM Export job has been suspended by user <String>. |
| 19:1576 | <Message> The CCM job will not run. |
| 19:1577 | CCM Import operation has started; job ID [<Number>]. |
| 19:1578 | CCM Import operation has completed. |
| 19:1579 | CCM Import operation has completed with one or more errors. |
| 19:1580 | CCM Import operation has failed. |
| 19:1581 | CCM Import job has been killed by <String>. |
| 19:1582 | CCM Import job has been suspended by user <String>. |
| 19:1583 | Documentum (Data Protection) |
| 19:1584 | This action is not permitted as this is a managed client (without software installed). Please refer to documentation about running data collection on managed clients. |
| 19:1585 | The job cannot run at this time as another agentless job for the policy is already running. |
| 19:1586 | Deprecated message [<Number>]. |
| 19:1587 | Deprecated message. |
| 19:1588 | None of the proxy clients configured are available. |
| 19:1589 | <String> job [<Number>] has been converted to full as previous extended retention job has failed. |
| 19:1590 | Deduplication DB Reconstruction operation has started for copy [<String>] and DeDuplication Store [<String>]; job ID [<Number>]. |
| 19:1591 | No need to run reconstruction as the DeDuplication Store [<String>] for the copy [<String>] is not offline. |
| 19:1592 | Auxiliary Copy attempt started for storage policy <String> copy Name <String>. To copy : <String> (out of <String>). |
| 19:1593 | <String> job [<Number>] has been converted to full as previous job failed or killed in the archived index phase. |
| 19:1594 | Backup job [<Number>] has been converted to incremental for File System Archiver in Turbo mode. |
| 19:1595 | Killed and marked as failed by System. |
| 19:1596 | File System agent should be installed on the CommServe to run a SILO Archive job |
| 19:1597 | Failed to start phase [<String>] on [<String>] due to network error [<String>]. Will attempt to restart. Please check if this product's services are running on the remote host. |
| 19:1598 | <Message> The Remove Update job will not run. |
| 19:1599 | <Message> The Upgrade Client job will not run. |
| 19:1600 | <Message> The Install Client job will not run. |
| 19:1601 | EDC Discovery job [<Number>] has been converted to a full. |
| 19:1602 | Job [<String>] converted to full as new Replication Set has been created. |
| 19:1603 | Job [<String>] has been converted to full as destination client has changed. |
| 19:1604 | Job [<String>] has been converted to full as common base folder has changed. |
| 19:1605 | Please have at least one data path in storage policy which can match the following criteria: 1) same OS type as client 2) magnetic 3) CDR is installed on the datapath |
| 19:1606 | Data Verification |
| 19:1607 | Virtual Machine Management job has failed. |
| 19:1608 | Virtual Machine Management job has been interrupted. |
| 19:1609 | Virtual Machine Management job has started; job ID [<Number>]. |
| 19:1610 | Virtual Machine Management job has completed. |
| 19:1611 | Virtual Machine Management job has completed with one or more errors. |
| 19:1612 | Virtual Machine Management job has been killed by user: [<String>]. |
| 19:1613 | Virtual Machine Management job has been suspended by user: [<String>]. |
| 19:1614 | Virtual Machine Management job has failed because of unknown reason. Please try resubmitting the job. |
| 19:1615 | Virtual Machine Management job has failed because of invalid input in XML. Please try resubmitting the job with correct parameters. |
| 19:1616 | Virtual Machine Management job has failed because Refresh is not done for Virtualization client :[<String>]. Please do refresh operation for this virtualization client. |
| 19:1617 | Virtual Machine Management job has failed because incorrect credentials are configured on instance for virtualization client:[^1%ls] |
| 19:1618 | Virtual Machine Management job has failed. Failure Reason:[<String>] |
| 19:1619 | Data Verification job has been suspended by System. |
| 19:1620 | Data Aging job has been suspended by System. |
| 19:1621 | Auxiliary Copy job has been suspended by System. |
| 19:1622 | Archive job has been suspended by System. |
| 19:1623 | Compliance archive job has been suspended by System. |
| 19:1624 | OSSV Replicate Creation job has been suspended by System. |
| 19:1625 | Backup job has been suspended by System. |
| 19:1626 | DR Backup job has been suspended by System. |
| 19:1627 | Media Inventory job has been suspended by System. |
| 19:1628 | Media Prediction job has been suspended by System. |
| 19:1629 | Recovery job has been suspended by System. |
| 19:1630 | Retrieve job has been suspended by System. |
| 19:1631 | OSSV Recovery job has been suspended by System. |
| 19:1632 | Restore job has been suspended by System. |
| 19:1633 | Scheduled Export job has been suspended by System. |
| 19:1634 | Synthetic Full job has been suspended by System. |
| 19:1635 | Erase Media job has been suspended by System. |
| 19:1636 | Install Client job has been suspended by System. |
| 19:1637 | Uninstall Client job has been suspended by System. |
| 19:1638 | Install Update job has been suspended by System. |
| 19:1639 | Download/Copy Updates operation has been suspended by System. |
| 19:1640 | Synthetic Full job [<Number>] has been suspended by System. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:1641 | Backup job [<Number>] has been suspended by System. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1642 | Recovery job [<Number>] has been suspended by System. Client [<String>], Agent Type [<String>]. |
| 19:1643 | Retrieve job [<Number>] has been suspended by System. Client [<String>], Agent Type [<String>]. |
| 19:1644 | Restore job [<Number>] has been suspended by System. Client [<String>], Agent Type [<String>]. |
| 19:1645 | Reason |
| 19:1646 | Another Virtualize Machine job is already running for the client [<String>]. |
| 19:1647 | The Virtualize Machine job has started for client [<String>] on host [<String>]; job ID [<Number>]. |
| 19:1648 | The Virtualize Machine job has completed for client [<String>] on host [<String>]. |
| 19:1649 | The Virtualize Machine job has failed. |
| 19:1650 | The Virtualize Machine job has been killed by <String>. |
| 19:1651 | The Virtualize Machine job has been suspended by user <String>. |
| 19:1652 | <Message> The Virtualize Machine job will not run. |
| 19:1653 | Virtualize Machine job has completed with one or more errors. |
| 19:1654 | Waiting for Configuration Restore to start. |
| 19:1655 | Waiting for Full Machine Restore to start. |
| 19:1656 | Waiting for Configuration Restore job [<Number>] to complete. |
| 19:1657 | Waiting for Full Machine Restore job [<Number>] to complete. |
| 19:1658 | Details : n |
| 19:1659 | Job ID: [<Number>] n |
| 19:1660 | t Virtualization Client: [<String>] n |
| 19:1661 | t Host: [<String>] n |
| 19:1662 | t data store: [<String>] n |
| 19:1663 | t Virtual Machine Name: [<String>] n |
| 19:1664 | t Virtual Machine IP: [<String>] n |
| 19:1665 | The child restore job [<Number>] has failed. |
| 19:1666 | The child restore job [<Number>] has been killed. |
| 19:1667 | The child restore job [<Number>] is pending. |
| 19:1668 | Waiting for child restore job [<Number>] to be killed. |
| 19:1669 | t Virtual Machine Host Name : [<String>] n |
| 19:1670 | Maximum number of jobs allowed to run has been reached for this client. |
| 19:1671 | Failed to read throttle settings from DB. Please check the logs for more details. |
| 19:1672 | Job [<Number>] cannot be started now as the maximum number of jobs allowed for the client [<String>] has been reached. |
| 19:1673 | Maximum number of data jobs allowed to run has been reached for this client. |
| 19:1674 | Maximum number of log jobs allowed to run has been reached for this client. |
| 19:1675 | Differential backup level is not supported for archival subclient. |
| 19:1676 | Job completed immediately as none of the stores are eligible for backup. |
| 19:1677 | Backup job [<Number>] has been converted to incremental followed by Synthetic FULL because subclient is in Archiving mode. |
| 19:1678 | Client [<String>] has deduplication enabled but Storage Policy Copy [<String>] for Storage Policy [<String>] has De-duplication Disabled |
| 19:1679 | File System agent should be installed on the source MediaAgent [<String>] to run a SILO Archive job. |
| 19:1680 | Discovery job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1681 | Discovery job [<Number>] completed. |
| 19:1682 | Discovery job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Duration [<String>]. |
| 19:1683 | Failed to create job history for job [<Number>]. The operation will be retried. |
| 19:1684 | Backup job [<Number>] has been converted to incremental because File System subclient is in Archiving mode. |
| 19:1685 | Backup job [<Number>] has been converted to incremental. |
| 19:1686 | Another Log Monitoring job is already running. |
| 19:1687 | Log Monitoring operation has started; job ID [<Number>]. |
| 19:1688 | Log monitoring job has completed. |
| 19:1689 | Log monitoring job has failed. |
| 19:1690 | Log monitoring job has been killed by <String>. |
| 19:1691 | Log monitoring job has been suspended by user <String>. |
| 19:1692 | <Message> The log monitoring job will not run. |
| 19:1693 | CommCell Synchronization job has started; job ID [<Number>]. |
| 19:1694 | CommCell Synchronization job has completed. |
| 19:1695 | CommCell Synchronization job has completed with one or more errors. |
| 19:1696 | CommCell Synchronization job has failed. |
| 19:1697 | CommCell Synchronization job has been killed by <String>. |
| 19:1698 | CommCell Synchronization job has been suspended by user <String>. |
| 19:1699 | <Message> The CommCell Synchronization job will not run. |
| 19:1700 | Battery mode has been detected. |
| 19:1701 | Erase Data job could not be started since <Allow Erase Data> option is disabled for one or more storage policies : Storage Policy [^1%ls] for Subclient [<String>]. |
| 19:1702 | SRM is not installed, log monitoring job can not run without SRM. |
| 19:1703 | Discovery job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Objects [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1704 | Exchange DB (Data Recovery) |
| 19:1705 | Informix DB (Data Recovery) |
| 19:1706 | Lotus Notes DB (Data Recovery) |
| 19:1707 | Oracle DB (Data Recovery) |
| 19:1708 | SQL DB (Data Recovery) |
| 19:1709 | Sybase DB (Data Recovery) |
| 19:1710 | DB2 (Data Recovery) |
| 19:1711 | Documentum (Data Recovery) |
| 19:1712 | MYSQL (Data Recovery) |
| 19:1713 | Other (Data Recovery) |
| 19:1714 | Auxiliary Copy operation has completed with one or more errors. |
| 19:1715 | Media Refresh operation has completed with one or more errors. |
| 19:1716 | Install Update operation has completed with one or more errors. |
| 19:1717 | Download/Copy Updates operation has completed with one or more errors. |
| 19:1718 | Synthetic FULL job is not allowed because the last job [<Number>] in the cycle was committed. |
| 19:1719 | Send Log File job has failed. |
| 19:1720 | Send Log File job has been interrupted. |
| 19:1721 | Send Log File has started; job ID [<Number>]. |
| 19:1722 | Send Log File job has completed. |
| 19:1723 | Send Log File job has completed with one or more errors. |
| 19:1724 | Send Log File job has been killed by user: [<String>]. |
| 19:1725 | Send Log File job has been suspended by user: [<String>]. |
| 19:1726 | Send Log File job has failed because of unknown reason. Try resubmitting the job. |
| 19:1727 | Job [<String>] has been converted to full as 'Enable SnapProtect' client property has changed. |
| 19:1728 | New backup performance request received for Client [<String>], Application Type [<String>], Backup Set [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1729 | New restore performance request received for client [<String>], application type [<String>]. |
| 19:1730 | Backup performance job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Objects [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1731 | Restore performance job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1732 | Backup performance job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:1733 | Restore performance job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:1734 | Backup performance job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Duration [<String>]. |
| 19:1735 | Restore performance job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:1736 | Starting reference copy Workflow [<String>]. |
| 19:1737 | Failed to initialize reference copy Workflow request. [<String>] |
| 19:1738 | A reference copy Workflow operation is already running for Storage Policy [<String>]. |
| 19:1739 | There are no jobs that need to be Reference copied. |
| 19:1740 | Could not get the list of jobs to Reference copy. |
| 19:1741 | Workflow |
| 19:1742 | Failed to kill workflow job [<Number>]. |
| 19:1743 | Failed to suspend workflow job [<Number>]. |
| 19:1744 | Failed to resume workflow job [<Number>]. |
| 19:1745 | Failed to start workflow [<String>]. |
| 19:1746 | Failed to deploy workflow [<String>]. |
| 19:1747 | Failed to import package [<String>]. |
| 19:1748 | Workflow [<String>] started. |
| 19:1749 | Workflow [<String>] completed. |
| 19:1750 | Workflow [<String>] failed. |
| 19:1751 | Workflow [<String>] has been suspended by user <String>. |
| 19:1752 | Workflow [<String>] has been killed by user <String>. |
| 19:1753 | Workflow [<String>] resumed by user <String>. |
| 19:1754 | Activity [<String>] for workflow [<String>] failed, reason: [<String>]. |
| 19:1755 | SAP for Oracle (Data Protection) |
| 19:1756 | SAP for Oracle (Data Recovery) |
| 19:1757 | PostgreSQL (Data Protection) |
| 19:1758 | PostgreSQL (Data Recovery) |
| 19:1759 | <String> job [<Number>] has been converted to full as previous job failed or killed in the archived index phase. |
| 19:1760 | Thread for activity [<String>] was terminated. |
| 19:1761 | Duplicate unique name found [<String>] in definition. |
| 19:1762 | Failed to build response message. |
| 19:1763 | Workflow marked failed by activity [<String>]. |
| 19:1764 | Failed to configure bean shell. |
| 19:1765 | Failed to create deployment. |
| 19:1766 | Failed to import package. |
| 19:1767 | Failed to create workflow job. |
| 19:1768 | Failed to create schema for [<String>]. |
| 19:1769 | Failed to determine transition. |
| 19:1770 | Failed to encode xml. |
| 19:1771 | Failed to evaluate beanshell expression [<String>]. |
| 19:1772 | Failed to initialize request message. |
| 19:1773 | Failed to instantiate class [<String>]. |
| 19:1774 | Failed to load current activities. |
| 19:1775 | Failed to load activity [<String>]. |
| 19:1776 | Failed to load inputs for activity [<String>]. |
| 19:1777 | Failed to load workflow definition. |
| 19:1778 | Failed to load workflow execution process. |
| 19:1779 | Failed to load global schema system. |
| 19:1780 | Failed to load job id [<Number>]. |
| 19:1781 | Failed to load job inputs. |
| 19:1782 | Failed to load package [<String>]. |
| 19:1783 | Failed to load post operations. |
| 19:1784 | Failed to load schema for [<String>]. |
| 19:1785 | Failed to load WSDL definition. |
| 19:1786 | Failed to retrieve activity outputs. |
| 19:1787 | Failed to retrieve workflow deployment. |
| 19:1788 | Failed to retrieve value from field [<String>], class [<String>]. |
| 19:1789 | Failed to retrieve next job id. |
| 19:1790 | Failed to retrieve start activity. |
| 19:1791 | Failed to retrieve user information. |
| 19:1792 | Error setting field [<String>] in class [<String>] with value [<String>]. |
| 19:1793 | Failed to execute XPath statement [<String>]. |
| 19:1794 | Inconsistent state. |
| 19:1795 | Invalid activity definition in package. |
| 19:1796 | Invalid import in definition. |
| 19:1797 | Invalid schema in workflow definition. |
| 19:1798 | Invalid transition from source activity [<String>]. |
| 19:1799 | Invalid unique name for activity [<String>]. |
| 19:1800 | Invalid expression [<String>] in activity [<String>]. |
| 19:1801 | Maximum number of restarts [<String>] reached. |
| 19:1802 | Cannot marshal multi-dimensional array [<String>]. |
| 19:1803 | Timeout executing script [<String>]. |
| 19:1804 | Waiting on inbound activities <String>. |
| 19:1805 | Waiting on jobs <Number>. |
| 19:1806 | Failed to build python script. |
| 19:1807 | Failed during execution of python script [<String>]. |
| 19:1808 | Failed to retrieve results from python script [<String>]. |
| 19:1809 | Failed to parse xml file [<String>]. |
| 19:1810 | Workflow engine [<String>] started. |
| 19:1811 | Workflow engine [<String>] stopped. |
| 19:1812 | Activity [<String>] for workflow [<String>] killed by [<String>]. |
| 19:1813 | Activity [<String>] for workflow [<String>] suspended by [<String>]. |
| 19:1814 | Activity [<String>] for workflow [<String>] was interrupted. |
| 19:1815 | Failed to copy package to local class path. |
| 19:1816 | Failed to add package to local class path. |
| 19:1817 | Package already imported on workflow engine. |
| 19:1818 | Failed to remove import. |
| 19:1819 | Failed to refresh import. |
| 19:1820 | Package [<String>] does not exist on workflow engine. |
| 19:1821 | Could not find location for activity [<String>]. |
| 19:1822 | Internal SOAP failure. |
| 19:1823 | Failed to send SOAP message to endpoint [<String>]. |
| 19:1824 | Failed to build outputs for activity [<String>]. |
| 19:1825 | Failed to execute command [<String>]. |
| 19:1826 | Failed to parse results from command [<String>]. |
| 19:1827 | Failed to configure email message. |
| 19:1828 | Failed to send email message. |
| 19:1829 | Failed to retrieve activity transitions. |
| 19:1830 | Remove Update job has been killed by <String>. |
| 19:1831 | Remove Update operation has failed. |
| 19:1832 | Remove Update job has been suspended by System. |
| 19:1833 | Remove Update job has been suspended by user <String>. |
| 19:1834 | Remove Update operation has completed with one or more errors. |
| 19:1835 | Upgrade Client job has been killed by <String>. |
| 19:1836 | Upgrade Client job has failed. |
| 19:1837 | Upgrade Client job has been suspended by System. |
| 19:1838 | Upgrade Client job has been suspended by user <String>. |
| 19:1839 | Upgrade Client operation has completed with one or more errors. |
| 19:1840 | Backup job [<Number>] has been converted to incremental because subclient is in Archiving mode. |
| 19:1841 | Failed to submit new child job request with Task Manager. Please check TaskManager.log for more details. |
| 19:1842 | A Catalog Snapshots Workflow operation is already running for Storage Policy [<String>]. |
| 19:1843 | Failed to initialize Catalog Snapshots Workflow request. [<String>] |
| 19:1844 | Starting Catalog Snapshots Workflow [<String>]. |
| 19:1845 | <Message> The Catalog Snapshots job will not run. |
| 19:1846 | Create Catalog Snapshots option will not be performed because there is an earlier dependent job [<Number>] that must be backed up to tape first. |
| 19:1847 | Create Catalog Snapshots option for the snap backup job will not be performed because a conflicting offline Backup Copy job is currently running. |
| 19:1848 | Create Catalog Snapshots option for the snap backup job will not be performed because of the storage policy settings. |
| 19:1849 | Failed to get the Target Storage Policy for Client [<String>] Subclient [<String>]. Check the Storage Policy under the subclient properties. |
| 19:1850 | Log Storage Policy not assigned for subclient [<String>]. Please assign and try again. |
| 19:1851 | There are no jobs that need to be cataloged. |
| 19:1852 | Catalog Snapshots job has been failed because MediaAgent [<String>] release is older than 10.0. Please perform release upgrade for this MediaAgent. |
| 19:1853 | Failed to get the clients configured for Oracle RAC Instance [<String>]. |
| 19:1854 | Expired license for application of type [<String>] for member client [<String>]. Please obtain a permanent license. |
| 19:1855 | DeDup DB Reconstruction |
| 19:1856 | Another Virtualize Machine job is already running for the client [<String>]. |
| 19:1857 | Clone job has started for client [<String>] on host [<String>]; job ID [<Number>]. |
| 19:1858 | Client [<String>] has been cloned on host [<String>] to [<String>]. |
| 19:1859 | Clone job has failed. |
| 19:1860 | Clone job has been killed by <String>. |
| 19:1861 | Clone job has been suspended by user <String>. |
| 19:1862 | <Message> The Clone job will not run. |
| 19:1863 | Client [<String>] has been cloned on host [<String>] with one or more errors. |
| 19:1864 | Client [<String>] has been virtualized on host [<String>]. |
| 19:1865 | Client [<String>] has been virtualized on host [<String>] with one or more errors. |
| 19:1866 | t Clone Host Name : [<String>] n |
| 19:1867 | Error threshold rule at <String> level marked the job as failed based on <String> failed files count criteria. |
| 19:1868 | ErrorThreshold rule at <String> level marked the job as partial success based on <String> failed files count criteria. |
| 19:1869 | CommCell Migration Export |
| 19:1870 | CommCell Migration Import |
| 19:1871 | Install Software |
| 19:1872 | Uninstall Software |
| 19:1873 | Unable to view logs at this time as job is not in running state. |
| 19:1874 | Unable view RMAN logs at this time as the job control process is not available. |
| 19:1875 | Catalog Snapshots Workflow job failed because dependent job [<Number>] failed to start. |
| 19:1876 | t New Virtual Machine Name : [<String>] n |
| 19:1877 | t New Virtual Machine IP : [<String>] n |
| 19:1878 | t New Virtual Machine Host Name : [<String>] n |
| 19:1879 | t Clone Client Name : [<String>] n |
| 19:1880 | Snap backup job [<Number>] is skipped for backup copy as it is not valid. |
| 19:1881 | Restore (Export) job has started. |
| 19:1882 | Failed to get a valid proxy client to run the job. Please check the proxy configuration. |
| 19:1883 | Failed to initialize storage policy information for job. Storage policy may be invalid. |
| 19:1884 | Failed to initialize SIDB store information for Dedupe DB Reconstruction. |
| 19:1885 | Error threshold rule at <String> level marked the job as failed based on <String> failed files criteria. |
| 19:1886 | Error threshold rule at <String> level marked the job as partial success based on <String> failed files criteria. |
| 19:1887 | Reference copy job failed. Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:1888 | Reference copy job has been killed by <String>. |
| 19:1889 | Reference copy job has been suspended by user <String>. |
| 19:1890 | New Reference copy request received for the client [<String>], application type [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:1891 | Reference copy job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1892 | Reference copy job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1893 | Reference copy job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:1894 | Reference copy job [<Number>] failed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1895 | Reference copy job is not allowed because the last job [<Number>] in the cycle was committed. |
| 19:1896 | t Client : [<String>] n |
| 19:1897 | t Datastore : [<String>] n |
| 19:1898 | <Message> The Report job will not run. |
| 19:1899 | <Message> The SRM Report job will not run. |
| 19:1900 | Backup Copy operation will not be performed for job [<Number>] of Subclient [<String>] on Storage Policy [<String>] because there is an earlier dependent job [<Number>] that must be backed up to tape first on Storage Policy [<String>]. |
| 19:1901 | <Message> The DDB Move job will not run. |
| 19:1902 | Backup copy workflow job has been suspended by user <String>. |
| 19:1903 | Activity [<String>] has exceeded the timeout period of [<String>] minutes. |
| 19:1904 | Workflow engine on client [<String>] has failed to properly shutdown. |
| 19:1905 | The vm was unable to get the hostname/IP. Customization Failed. |
| 19:1906 | LM data queue is full. |
| 19:1907 | Failed to get the configured member server list for Virtual Server. Please verify if the nodes of the Virtualization client have licenses. |
| 19:1908 | Expired license for application of type [<String>] for all configured member servers. Please obtain a permanent license or modify your member server configuration. |
| 19:1909 | Expired license for application of type [<String>] for the member server(s) [<String>]. Please obtain a permanent license. |
| 19:1910 | [<String>] Job [<Number>] has been converted to full as 'Enable Metadata Collection' Subclient property has changed. |
| 19:1911 | Job cannot be started as continuous mode is set for this monitoring policy |
| 19:1912 | Percentage change is not applicable for this job type. |
| 19:1913 | Failed to initialize Data Analytics job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:1914 | Blackout Window for CommServe prevents the Data Analytics job from running right now. |
| 19:1915 | Data Analytics operation has completed. |
| 19:1916 | Data Analytics operation has completed with one or more errors. |
| 19:1917 | Data Analytics operation has failed. |
| 19:1918 | Data Analytics job has been killed by <String>. |
| 19:1919 | Data Analytics job has been suspended by user <String>. |
| 19:1920 | <Message> The Data Analytics job will not run. |
| 19:1921 | A Data Analytics operation is already running for Storage Policy [<String>]. |
| 19:1922 | [<String>] Job [<Number>] has been converted to full as 'Block Level Snap' subclient option has changed. |
| 19:1923 | A Disaster Recovery backup was not run in the last 72 hours. Please run a Disaster Recovery backup as soon as possible. |
| 19:1924 | The job will be killed as the client has been continuously unreachable for maximum allowed offline time of [<Number>] minutes. |
| 19:1925 | Storage policy [<String>] has non-dedupe copies. Use Scalable Resource Allocation is supported only for dedupe copies. To use Scalable Resource Allocation for dedupe copies please create schedules for individual copies. |
| 19:1926 | Some jobs were skipped due to read errors. Will retry after some time. |
| 19:1927 | Synthetic full backup job is not supported for subclient with archiver agent retention. |
| 19:1928 | Post request failed while sending documents to analytics indexing engine. |
| 19:1929 | Browse initialization request to indexing subsystem failed. |
| 19:1930 | Browse request to indexing subsystem failed. |
| 19:1931 | Commit request to analytics indexing engine failed. |
| 19:1932 | CVCIAnalytics.exe encountered an unknown error. |
| 19:1933 | No Resources Available. Please check the Streams tab for details. Analytics error code: [<Number>] [<Number>] virtual-machines of [<Number>] were processed successfully. |
| 19:1934 | Job [<Number>] has been automatically resumed as per the AutoResume Configuration [<String>]. Client [<String>], Agent Type [<String>]. |
| 19:1935 | Block Level Backup cannot run because there is no spool snapshot copy on the storage policy for the native snapshot engine. |
| 19:1936 | Backup job [<Number>] has been committed. Client [<String>], Agent Type [<String>], Subclient [<String>], Backup Level [<String>], Objects [<String>], Failed [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1937 | Synthetic full backup job is not supported with sibling archiver agent retention subclient. Please enable Archiver agent retention. |
| 19:1938 | Failed to get the clients configured for SAP HANA Instance [<String>]. |
| 19:1939 | Exceeded the limit of maximum allowed number of consecutive incremental jobs. Job [<Number>] has triggered a [<String>] backup job [<Number>]. |
| 19:1940 | There are pending snaps that needs to be moved to tape. Please try again after running WorkFlow job. |
| 19:1941 | Failed to run Data Analytics job. Data Analytics Role may not be configured on associated MediaAgent. |
| 19:1942 | The RBS Store Client option is not selected. Please configure it and resubmit the job. |
| 19:1943 | No successful backup exists for the selected VM at selected time. |
| 19:1944 | VM name not found for selected client. |
| 19:1945 | VM GUID not found for selected client. |
| 19:1946 | VM details not found in database for selected client. |
| 19:1947 | 3DFS MediaAgent for Live Mount is not found. |
| 19:1948 | Failed to create temporary staging directory. |
| 19:1949 | Live Mount is supported for VMware VMs only. |
| 19:1950 | Unable to mount the media as a datastore. Please check the communication between the 3dfs server and the host. |
| 19:1951 | The virtual machine could not be mounted from the media. Please check the MediaAgent for additional details. |
| 19:1952 | Failed to power on the mounted VM. |
| 19:1953 | Failed to complete Live Mount operation. Please check log files for more details. |
| 19:1954 | Discover Live Mounted VM failed. |
| 19:1955 | Failed to get VM info from Database |
| 19:1956 | Backup job [<Number>] failed to start on client computer [<String>] since client owner(s) have exceeded their quota. |
| 19:1957 | Another replication job is running for this schedule. |
| 19:1958 | No backup has run for subclients associated to schedule (nothing to replicate). |
| 19:1959 | Cannot start job because replication status is 'Failed to Sync' or 'Sync Disabled'. |
| 19:1960 | After the most recent backup job, a replication job completed or is still running for this schedule. |
| 19:1961 | This job (being committed) is failed because of Indexing errors. Please check the log files for details. |
| 19:1962 | Redirecting to the data storage policy[<String>] of the online full backup[<Number>]. |
| 19:1963 | Synthetic full job is not supported for IntelliSnap enabled subclients. |
| 19:1964 | Job has been converted to Incremental as Synthetic full job is not supported for IntelliSnap enabled subclients. |
| 19:1965 | Restore to disk operation is not supported for Agent Type [<String>]. |
| 19:1966 | Restore to disk operation is not supported on job [<Number>]. Please ensure a valid backup job is specified. |
| 19:1967 | Atleast one of the backup copy jobs associated with this workflow has failed or failed to start. |
| 19:1968 | All of the backup copy jobs associated with this workflow has failed or failed to start. |
| 19:1969 | Backup job [<Number>] has been converted to a full backup because of a client reconfiguration. |
| 19:1970 | Backup copy workflow job has completed with one or more errors. |
| 19:1971 | Log monitoring job has completed with one or more errors. |
| 19:1972 | Snap backup is not supported for [<String>] transaction log backups. The job will run as traditional log backup. |
| 19:1973 | Catalog migration job has completed with one or more errors. |
| 19:1974 | Catalog migration job has completed. |
| 19:1975 | Catalog migration job has failed. |
| 19:1976 | Catalog migration job has been killed by <String>. |
| 19:1977 | Catalog migration job has been suspended by user <String>. |
| 19:1978 | <Message> The Catalog migration job will not run. |
| 19:1979 | Catalog migration job has started; job ID [<Number>]. |
| 19:1980 | Unable to start the 3dfs server. Please check the communication between the MediaAgent and the 3dfs server. |
| 19:1981 | There are too many virtual machines exported. Please wait for some virtual machines to be migrated or unregistered. |
| 19:1982 | Unable to export the backup from the media to mount it as a datastore. Please check the communication between the MediaAgent and the 3dfs server. |
| 19:1983 | Could not open config file for VM |
| 19:1984 | Could not create config file for VM |
| 19:1985 | VM already exists. Please delete this VM manually and resubmit job. |
| 19:1986 | Host version is not supported for Live Mount. |
| 19:1987 | Failed to register Virtual Machine |
| 19:1988 | [<String>] Job [<Number>] has been converted to full as it is the first job after upgrade. |
| 19:1989 | Job is not resumed because some data were skipped due to read errors. System resume will retry after some time. |
| 19:1990 | PST Archiving job failed. Client [<String>], Backup Set [<String>], Subclient [<String>]; Job ID [<Number>]. |
| 19:1991 | PST Archiving job has been killed by <String>. |
| 19:1992 | PST Archiving job has been suspended by user <String>. |
| 19:1993 | New PST Archiving request received for the client [<String>], application type [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:1994 | PST Archiving job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>], Total Size [<String>], Media or Mount Path Used [<String>]. |
| 19:1995 | PST Archiving job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1996 | PST Archiving job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:1997 | PST Archiving job [<Number>] failed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:1998 | Invalid expression [<String>] in transition from activity [<String>]. |
| 19:1999 | Backup job [<Number>] on client computer [<String>] cannot be run as Incremental and will be converted to Synthetic Full since client owner(s) have exceeded their quota. |
| 19:2000 | Download Software operation has started; job ID [<Number>]. |
| 19:2001 | The Deduplication DB Reconstruction operation has been killed. |
| 19:2002 | Third Party job cannot be run, Token validation failed. |
| 19:2003 | Storage policy [<String>] has snap copies or copies with NAS Attached Libraries. Use Scalable Resource Allocation is not supported for NAS Attached Libraries or snap copies. To use Scalable Resource Allocation for other copies please create schedules for individual copies. |
| 19:2004 | Auxiliary Copy operation has completed with one or more errors. Copied : <String>. |
| 19:2005 | Block Level Backup cannot run because there is an earlier dependent job [<Number>] that must be backed up to tape first. |
| 19:2006 | After upgrading to version 11, you can use this agent to restore data, but you cannot use it to back up data. To perform backups with similar functionality, configure the appropriate File System agent to perform block-level backups. For more information about block-level backup, refer to the Documentation site. |
| 19:2007 | After upgrading to version 11, you can use this agent to recover data, but you cannot use it to archive data. To archive data, use the appropriate OnePass agent. For more information about OnePass agents, refer to the Documentation site. |
| 19:2008 | A DR CommServe with hostname [<String>] has been detected. |
| 19:2009 | A Data Verification job is running for the DDB Store [<String>]. |
| 19:2010 | Conflicting job(s) are currently running for the DDB Store [<String>]. |
| 19:2011 | Loss of Communications Service. Possible causes: 1. The control process has unexpectedly died. Check crash dump or core file. 2. The communication to the control process machine <String> might have gone down due to network errors. 3. If the machine <String> is a cluster, it may have failed over. 4. The machine <String> may have rebooted. |
| 19:2012 | Transaction Logs backup cannot be run now as backups have not been run on all Database subclients after upgrade. |
| 19:2013 | Snap Backup cannot run because there is no spool snapshot copy on the storage policy for the native snapshot engine. |
| 19:2014 | Blackout Window for Source MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2015 | Blackout Window for Destination MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2016 | Blackout Window for Server group having Source MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2017 | Blackout Window for Server group having Destination MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2018 | Workflow [<String>] completed with one or more errors. |
| 19:2019 | Backup job [<Number>] has been converted to a full backup because backup device of SAP for Oracle is changed. |
| 19:2020 | A Data Verification job is already running for the DDB Store [<String>]. |
| 19:2021 | Data verification job cannot run as a Move Partition job is running for the DDB Store [<String>]. |
| 19:2022 | Backup job [<Number>] has been converted to a full backup because backup files qualified for archive is unchecked. |
| 19:2023 | Data verification job cannot run as a Deduplication DB Reconstruction operation is running for the DDB Store [<String>]. |
| 19:2024 | Data verification job cannot run as a Deduplication DB Reconstruction operation is running for the storage policy[<String>]. |
| 19:2025 | Backup job cannot run. Please verify that all DAG members are upgraded. |
| 19:2026 | <Message> The Library Maintenance job will not run. |
| 19:2027 | Secure Erase job has failed. |
| 19:2028 | Secure Erase has been started for client [<String>]; job ID [<Number>]. |
| 19:2029 | Secure Erase job has completed. |
| 19:2030 | Secure Erase job has been killed by user: [<String>]. |
| 19:2031 | Secure Erase job has been suspended by user: [<String>]. |
| 19:2032 | <Message> The Secure Erase job will not run. |
| 19:2033 | A Secure Erase job is already running for the client [<String>]. |
| 19:2034 | Blackout Window for Server group prevents the Backup Copy job from running right now. |
| 19:2035 | Blackout Window for iDataAgent prevents the Backup Copy job from running right now. |
| 19:2036 | Blackout Window for Client prevents the Backup Copy job from running right now. |
| 19:2037 | Blackout Window for Instance prevents the Backup Copy job from running right now. |
| 19:2038 | Blackout Window for Backup Set prevents the Backup Copy job from running right now. |
| 19:2039 | Blackout Window for Subclient prevents the Backup Copy job from running right now. |
| 19:2040 | Blackout Window for CommServe prevents the Backup Copy job from running right now. |
| 19:2041 | Backup job [<Number>] will continue on client computer [<String>] since one or more client owner(s) do not have quota set. |
| 19:2042 | Failed to get the list of member servers to launch the job. Please check the logs for more details. |
| 19:2043 | Failed to get the configured member server list for Virtual Server. Please check the access nodes listed in the Virtualization client properties are online, have licenses, and are on the same version as the pseudo client. Click <https://documentation.commvault.com/commvault/v11/article?p=32191.htm> on how to configure. |
| 19:2044 | Another Catalog Migration job is already running for Media Agent [<String>]. |
| 19:2045 | Created snap primary with spool copy retention. |
| 19:2046 | Content Indexing job is not supported for release version 9. |
| 19:2047 | Search engine clients not at the same version. |
| 19:2048 | Erase Data job could not be started since <Allow Erase Data> option is disabled for one or more storage policies : Storage Policy [<String>] for Subclient [<String>]. |
| 19:2049 | Index Backup job cannot run. Catalog Migration job is running on the Media agent [<String>]. |
| 19:2050 | Failed to get the cloud Application instance type for instance name [<String>]. |
| 19:2051 | Exchange Database backup job [<Number>] has been converted to a full backup because previous full backup job was killed before backing up all databases. |
| 19:2052 | Mountpath Validation operation has completed. |
| 19:2053 | Mountpath Validation operation has failed. |
| 19:2054 | Unable to allocate resources. Please check the Progress tab for more details. |
| 19:2055 | Data Verification |
| 19:2056 | Distributed App (Data Protection) |
| 19:2057 | Distributed App (Data Recovery) |
| 19:2058 | Cleanup |
| 19:2059 | Backup job [<Number>] has been converted to a full backup because Sybase version is less than 15.7. |
| 19:2060 | CommServe database is at [<Number>] percent of [<Number>] GB Threshold. Please call your vendor's support hotline. |
| 19:2061 | CommServe database is at [<Number>] percent of [<Number>] GB Threshold. All jobs will be suspended. Please call your vendor's support hotline. |
| 19:2062 | Waiting for job(s) [<String>] to complete Archive Index phase. |
| 19:2063 | Blackout Window for Schedule Policy prevents the Backup job from running right now. |
| 19:2064 | Blackout Window for Schedule Policy prevents the Archiver job from running right now. |
| 19:2065 | Blackout Window for Schedule Policy prevents the Compliance Archive job from running right now. |
| 19:2066 | Blackout Window for Schedule Policy prevents the OSSV Replicate Creation job from running right now. |
| 19:2067 | Blackout Window for Schedule Policy prevents the Restore job from running right now. |
| 19:2068 | Blackout Window for Schedule Policy prevents the Recovery job from running right now. |
| 19:2069 | Blackout Window for Schedule Policy prevents the Retrieve job from running right now. |
| 19:2070 | Blackout Window for Schedule Policy prevents the OSSV Recovery job from running right now. |
| 19:2071 | Blackout Window for Schedule Policy prevents the synthetic backup from running right now. |
| 19:2072 | Blackout Window for Schedule Policy prevents the Content Indexing job from running right now. |
| 19:2073 | Blackout Window for Schedule Policy prevents the Backup Copy job from running right now. |
| 19:2074 | Blackout Window for Schedule Policy prevents the Auxiliary Copy job from running right now. |
| 19:2075 | Blackout Window for Schedule Policy prevents the Content Indexing job from running right now. |
| 19:2076 | Blackout Window for Schedule Policy prevents the full Backup job from running right now. |
| 19:2077 | Blackout Window for Schedule Policy prevents the full Archiver job from running right now. |
| 19:2078 | Blackout Window for Schedule Policy prevents the full OSSV Replicate Creation job from running right now. |
| 19:2079 | [<String>] Job [<Number>] has been converted to full as Block-Level Backup optimize option has changed. |
| 19:2080 | Move Mount Path operation has completed. |
| 19:2081 | Move Mount Path operation has failed. |
| 19:2082 | Storage policy [<String>] has snap copies. Use Scalable Resource Allocation is not supported for snap copies. To use it for other copies please create schedules for individual copies. |
| 19:2083 | Few jobs were skipped from the Multi-job Control operation. Please check JobManager.log for more details. |
| 19:2084 | Content Indexing activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2085 | Content Indexing activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2086 | Data Protection activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2087 | Data Protection activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2088 | Archive activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2089 | Archive activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2090 | SRM activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2091 | SRM activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2092 | Data Protection activity has been disabled for Instance [<String>] on Client [<String>], iDataAgent [<String>]. |
| 19:2093 | Data Protection activity has been enabled for Instance [<String>] on Client [<String>], iDataAgent [<String>]. |
| 19:2094 | Data Protection activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2095 | Data Protection activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2096 | Failed to disable activity for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2097 | Failed to enable activity for Instance [<String>] on Client [<String>] and iDataAgent [<String>] has been disabled. |
| 19:2098 | Compliance archiving activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2099 | Compliance archiving activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2100 | Data Recovery activity has been enabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2101 | Data Recovery activity has been disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2102 | Data Protection activity is disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2103 | Data Recovery activity is disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2104 | Content Indexing activity is disabled for Instance [<String>] on Client [<String>] and iDataAgent [<String>]. |
| 19:2105 | <String> activity for Instance [<String>] on Client [<String>] and iDataAgent [<String>] is disabled. |
| 19:2106 | <String> activity for client [<String>], iDataAgent [<String>] and instance [<String>] has been re-enabled based on scheduled time. |
| 19:2107 | <String> activity for client [<String>], iDataAgent [<String>], instance [<String>] and Subclient [<String>] has been re-enabled based on scheduled time. |
| 19:2108 | <String> activity for client [<String>], iDataAgent [<String>], Backup Set [<String>] and Subclient [<String>] has been re-enabled based on scheduled time. |
| 19:2109 | <String> activity for client [<String>], iDataAgent [<String>], instance [<String>], Backup Set [<String>] and Subclient [<String>] has been re-enabled based on scheduled time. |
| 19:2110 | Tape to Tape copy operation has started; job ID [<Number>]. |
| 19:2111 | Tape to Tape copy operation has completed. |
| 19:2112 | Tape to Tape copy operation has failed. |
| 19:2113 | Tape to Tape copy operation has completed with one or more errors. |
| 19:2114 | Tape to Tape copy job has been killed by <String>. |
| 19:2115 | Tape to Tape copy job has been suspended by user <String>. |
| 19:2116 | <Message> The Tape to Tape copy job will not run. |
| 19:2117 | Data Analytics job is already running. |
| 19:2118 | Live Mount job failed with error:[<String>]. |
| 19:2119 | Backup job failed since client owner(s) have exceeded their quota limit. |
| 19:2120 | Backup job [<Number>] failed on client computer [<String>] since client owner(s) have exceeded their quota. |
| 19:2121 | <String> activity for Instance [<String>] on Client [<String>] and iDataAgent [<String>] is disabled. |
| 19:2122 | DDB activity on CommServe is disabled. |
| 19:2123 | <Message> The Content Indexing job will not run. |
| 19:2124 | The number of running streams has exceeded the limit on the maximum number [<Number>] allowed. |
| 19:2125 | There is no log backup ran after last snap backup job. Please try again after running log backup. |
| 19:2126 | Edge drive backup cannot run as it is in paused state. |
| 19:2127 | Cloud Apps (Data Protection) |
| 19:2128 | Cloud Apps (Data Recovery) |
| 19:2129 | Blackout Window for Schedule Policy prevents the job from running right now. |
| 19:2130 | Catalog Snapshots operation cannot run because Deferred Catalog option is not enabled on the storage policy [<String>]. |
| 19:2131 | Job [<Number>] has been converted to full as Salesforce backup client has changed. |
| 19:2132 | Job [<Number>] has been converted to full as Salesforce Sync Database options have changed. |
| 19:2133 | Backup job [<Number>] has been converted to Synthetic FULL because subclient is in Archiving mode and last cycle is deleted. |
| 19:2134 | Job [<Number>] cannot be started now. Job will be resumed when number of Backup operation is less than [<Number>]. |
| 19:2135 | Edge drive backup cannot run as the system is unable to determine the quota associated to the user. |
| 19:2136 | Edge drive backup cannot run as the user exceeded the allowed quota limit . |
| 19:2137 | System failed to determine the node where job should run. This could be because of one of the following reasons nn 1. You have not defined Data Access nodes at Client/Agent/Instance/Subclient Level nn 2. The software version installed on the Data Access node is not updated to the right level nn Please run check readiness on the client and see if your machine is ready for these operations. |
| 19:2138 | Virtual Server (Data Protection) |
| 19:2139 | Virtual Server (Data Recovery) |
| 19:2140 | Job [<Number>] cannot be started now as it is scheduled to run at later point of time after [<Number>] seconds. |
| 19:2141 | Failed to initialize job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:2142 | Data Aging operation has been disabled on the client [<String>]. |
| 19:2143 | Data Aging operation has been enabled on the client [<String>]. |
| 19:2144 | Data Aging operation has been disabled on the Server group [<String>]. |
| 19:2145 | Data Aging operation has been enabled on the Server group [<String>]. |
| 19:2146 | Backup activity has been [<String>] for client [<String>], iDataAgent [<String>], instance [<String>] and Subclient [<String>] |
| 19:2147 | Backup activity has been [<String>] for client [<String>], iDataAgent [<String>], Backup Set [<String>] and Subclient [<String>] |
| 19:2148 | Backup activity has been [<String>] for client [<String>], iDataAgent [<String>], instance [<String>], Backup Set [<String>] and Subclient [<String>] |
| 19:2149 | License [<String>] is not active due to IP address mismatch. |
| 19:2150 | Waiting for new data. Backup will resume automatically when there is new data to sync. |
| 19:2151 | Failed to save job retention options. Please check the logs for more details. |
| 19:2152 | No copy list selected to apply job retention options. |
| 19:2153 | Skipping reservation because number of backup jobs waiting are more than configured value, please check AuxCopyMgr.log for more information. |
| 19:2154 | VM appears to be in failed over state. Backup skipped for now. User can configure reverse replication from Replication monitor or perform failback |
| 19:2155 | Atleast one of the Snapshot catalog jobs associated with this workflow has failed or failed to start. |
| 19:2156 | Backup job has been converted to a full backup because the client is reconfigured and the latest cycle is partially aged. |
| 19:2157 | Allow jobs to run past Blackout Window has been disabled for clientGroup [<String>] |
| 19:2158 | Allow jobs to run past Blackout Window has been enabled for clientGroup [<String>] |
| 19:2159 | Waiting on Synthetic Full jobs on Virtual Machines to complete. |
| 19:2160 | DDB operation has been disabled. |
| 19:2161 | DDB operation has been enabled. |
| 19:2162 | All of the Snapshot Catalog jobs associated with this workflow has failed or failed to start. |
| 19:2163 | New Cleanup request received for Client [<String>], Application Type [<String>], Backup Set [<String>], Subclient [<String>], Backup Level [<String>]. |
| 19:2164 | Data Verification (Scalable Resource Allocation) |
| 19:2165 | Operation failed. Job is not in suspended state. |
| 19:2166 | This job was initiated by an Automatic schedule. It is ready to be resumed by the client. |
| 19:2167 | A Content Indexing operation is already running for subclient [<String>]. |
| 19:2168 | Cleanup Blackout Window for Backup Set prevents the Cleanup job from running right now. |
| 19:2169 | Cleanup Blackout Window for Server group prevents the Cleanup job from running right now. |
| 19:2170 | Cleanup Blackout Window for Client prevents the Cleanup job from running right now. |
| 19:2171 | Cleanup Blackout Window for CommServe prevents the Cleanup job from running right now. |
| 19:2172 | Cleanup Blackout Window for iDataAgent prevents the Cleanup job from running right now. |
| 19:2173 | Cleanup Blackout Window for Instance prevents the Cleanup job from running right now. |
| 19:2174 | Cleanup Blackout Window for Subclient prevents the Cleanup job from running right now. |
| 19:2175 | Blackout Window for Schedule Policy prevents the Cleanup job from running right now. |
| 19:2176 | Another Archive Job is running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:2177 | Another Cleanup Job is running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:2178 | Content Indexing job has completed. |
| 19:2179 | Content Indexing job has failed. |
| 19:2180 | Content Indexing job has been killed by <String>. |
| 19:2181 | Content Indexing job has completed with one or more errors. |
| 19:2182 | Content Indexing job has been suspended by user <String>. |
| 19:2183 | <Message> The Content Indexing job will not run. |
| 19:2184 | Another Content Indexing job is already running. |
| 19:2185 | Content Indexing job has started; job ID [<Number>]. |
| 19:2186 | Waiting for job(s) [<String>] to complete Backup To Disk phase. |
| 19:2187 | <Message> The VSA Block Replication job will not run. |
| 19:2188 | DR Orchestration job has completed. |
| 19:2189 | DR Orchestration job has failed. |
| 19:2190 | DR Orchestration job has been interrupted. |
| 19:2191 | DR Orchestration job has been killed by user: [<String>]. |
| 19:2192 | DR Orchestration job has completed with one or more errors. |
| 19:2193 | DR Orchestration job has been suspended by user: [<String>]. |
| 19:2194 | DR Orchestration has started; job ID [<Number>]. |
| 19:2195 | SAP for Hana (Data Protection) |
| 19:2196 | SAP for Hana (Data Recovery) |
| 19:2197 | <String> job [<Number>] has been converted to full as previous default backupset has changed. |
| 19:2198 | Copying of Disaster recovery files to staging location is in progress. |
| 19:2199 | Blackout Window for Backup Set prevents the Data Analytics job from running right now. |
| 19:2200 | Blackout Window for Server group prevents the Data Analytics job from running right now. |
| 19:2201 | Blackout Window for Client prevents the Data Analytics job from running right now. |
| 19:2202 | Blackout Window for iDataAgent prevents the Data Analytics job from running right now. |
| 19:2203 | Blackout Window for instance prevents the Data Analytics job from running right now. |
| 19:2204 | Blackout Window for Subclient prevents the Data Analytics job from running right now. |
| 19:2205 | Blackout Window for Schedule Policy prevents the Data Analytics job from running right now. |
| 19:2206 | Online Crawl job is already running. |
| 19:2207 | Phase has reached max restarts. Job will be committed. |
| 19:2208 | Adhoc job is not supported for Indexing V1 Clients. |
| 19:2209 | Adhoc job is not supported for V10 Clients. |
| 19:2210 | Job is marked failed because Log Monitoring policy is deleted. |
| 19:2211 | Download Software operation has completed; job ID [<Number>]. |
| 19:2212 | Blackout Window for CommServe prevents the Backup Copy Workflow job from running right now. |
| 19:2213 | Job is running as AdHoc Job |
| 19:2214 | No jobs available for content indexing. Marking the job as Completed. |
| 19:2215 | Queue jobs if conflicting jobs found setting has been disabled for Server group [<String>] |
| 19:2216 | Queue jobs if conflicting jobs found setting has been enabled for Server group [<String>] |
| 19:2217 | 3dfs Prefetch Failure. 3dfs share not found |
| 19:2218 | 3dfs Prefetch Failure. Failed to browse VM files from indexing |
| 19:2219 | 3dfs Prefetch Failure. 3dfs Disk Cache Error |
| 19:2220 | 3dfs Prefetch Failure |
| 19:2221 | 3dfs Prefetch Failure. Failed to generate VM files |
| 19:2222 | 3dfs Prefetch Failure. VM [<String>] not found in backup for selected point in time [<String>] |
| 19:2223 | Data Protection activity for subclient [<String>] on Client [<String>] and iDataAgent [<String>] is disabled from subclient policy. |
| 19:2224 | No backup has run for subclient. |
| 19:2225 | Big Data Apps (Data Protection) |
| 19:2226 | Big Data Apps (Data Recovery) |
| 19:2227 | Could not get the list of jobs to catalog. |
| 19:2228 | There are jobs selected for backup copy but not yet available on the source copy. Please run auxiliary copy to copy the jobs to the secondary snap copy and then run backup copy. |
| 19:2229 | Client version cannot be older than 11.0 |
| 19:2230 | Index Copy job has completed. |
| 19:2231 | Index Copy job has failed. |
| 19:2232 | Index Copy job has completed with one or more errors. |
| 19:2233 | Index Copy job has been suspended by user <String>. |
| 19:2234 | <Message> The Index Copy job will not run. |
| 19:2235 | Index Copy job has been killed by <String>. |
| 19:2236 | Another Index Copy job is already running. |
| 19:2237 | Index Copy job has started; job ID [<Number>]. |
| 19:2238 | An entity extraction operation is already running for the data source. |
| 19:2239 | Block Level Operation job has failed because of unknown reason. Please try resubmitting the job. |
| 19:2240 | Block Level Operation job has completed. |
| 19:2241 | Block Level Operation job has failed |
| 19:2242 | Block Level Operation job has been interrupted. |
| 19:2243 | Block Level Operation job has been killed by user: [<String>]. |
| 19:2244 | Block Level Operation job has completed with one or more errors. |
| 19:2245 | Block Level Operation job has been suspended by user: [<String>]. |
| 19:2246 | Block Level Operation job has started; job ID [<Number>]. |
| 19:2247 | Failed to cleanup backup context from client [<String>] for job [<Number>]. Please check whether the file server is reachable from the detect MA (if configured) or the CS and also manually cleanup the backup contexts that are not active. |
| 19:2248 | License is not consumed by agent [<String>] on client [<String>]. |
| 19:2249 | Synthetic Full job for the Block Level Subclient [<String>] is not yet run. Failing this job. |
| 19:2250 | Maximum number of data jobs allowed to run has been reached for Server group [<String>]. |
| 19:2251 | Maximum number of log jobs allowed to run has been reached for Server group [<String>]. |
| 19:2252 | Large amount of data deletion was detected during synthetic full. Data aging on the client [<String>] has been disabled. Browse the client's data before re-enabling data aging. Contact your software provider for further questions. |
| 19:2253 | Failed to start backup copy job [<Number>] because no child VM jobs are available to run. |
| 19:2254 | In-place restore for Unix subclients with NFS auto mount contents is not yet supported. Please use out-of-place restore. |
| 19:2255 | VM [<String>] appears to be in failed over state. We will start synthetic full with incremental |
| 19:2256 | Synthetic Full cannot run because the previous job for the subclient is committed. Client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:2257 | Synthetic Full cannot run because the previous job for the subclient is committed. |
| 19:2258 | Job [<Number>] cannot be started now as the maximum number of jobs allowed for the Server group [<String>] has been reached. |
| 19:2259 | One or more partitions on the Media agent are not available to use. |
| 19:2260 | One or more partitions on the Media agent are skipped for backup. |
| 19:2261 | Blackout Window for Schedule prevents the Compliance Archive job from running right now. |
| 19:2262 | Blackout Window for Schedule prevents the Auxiliary Copy job from running right now. |
| 19:2263 | Blackout Window for Schedule prevents the Backup Copy job from running right now. |
| 19:2264 | Blackout Window for Schedule prevents the Backup job from running right now. |
| 19:2265 | Blackout Window for Schedule prevents the OSSV Replicate Creation job from running right now. |
| 19:2266 | Blackout Window for Schedule prevents the Cleanup job from running right now. |
| 19:2267 | Blackout Window for Schedule prevents the Data Analytics job from running right now. |
| 19:2268 | Blackout Window for Schedule prevents the full Backup job from running right now. |
| 19:2269 | Blackout Window for Schedule prevents the full OSSV Replicate Creation job from running right now. |
| 19:2270 | Blackout Window for Schedule prevents the full Archiver job from running right now. |
| 19:2271 | Blackout Window for Schedule prevents the job from running right now. |
| 19:2272 | Blackout Window for Schedule prevents the Archiver job from running right now. |
| 19:2273 | Blackout Window for Schedule prevents the Content Indexing job from running right now. |
| 19:2274 | Blackout Window for Schedule prevents the Content Indexing job from running right now. |
| 19:2275 | Blackout Window for Schedule prevents the OSSV Recovery job from running right now. |
| 19:2276 | Blackout Window for Schedule prevents the Recovery job from running right now. |
| 19:2277 | Blackout Window for Schedule prevents the Restore job from running right now. |
| 19:2278 | Blackout Window for Schedule prevents the Retrieve job from running right now. |
| 19:2279 | Blackout Window for Schedule prevents the synthetic backup from running right now. |
| 19:2280 | Failed to start job. Please check JobManager.log on the CommServe for more details. |
| 19:2281 | MongoDB Backup cannot run because there is an earlier dependent job [<Number>] that must be backed up to tape first. |
| 19:2282 | Backup job [^1lld] has been converted to a full backup because new AppAware Backup for Selective Copy support. |
| 19:2283 | Cleanup job [<Number>] failed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:2284 | Cleanup job [<Number>] has been killed. Client [<String>], Agent Type [<String>], Subclient [<String>], Duration [<String>]. |
| 19:2285 | Cleanup job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>], Subclient [<String>]. |
| 19:2286 | Cleanup job [<Number>] completed. Client [<String>], Agent Type [<String>], Subclient [<String>], Successful [<Number>], Failed [<Number>], Skipped [<Number>] Messages, Successful [<Number>], Failed [<Number>], Skipped [<Number>] Mailboxes, Duration [<String>], Saved space [<String>]. |
| 19:2287 | Instant Clone job [<Number>] failed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:2288 | Instant Clone job [<Number>] has been killed by <String>. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:2289 | Instant Clone job has been killed by <String>. |
| 19:2290 | Instant Clone job [<Number>] completed with one or more errors. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:2291 | Instant Clone job [<Number>] has been suspended by user <String>. Client [<String>], Agent Type [<String>]. |
| 19:2292 | Instant Clone job has been suspended by user <String>. |
| 19:2293 | Instant Clone job [<Number>] completed. Client [<String>], Agent Type [<String>], Duration [<String>]. |
| 19:2294 | Please upgrade MediaAgent [<String>] to [<String>] for operations to continue. |
| 19:2295 | A Data Verification operation is already running for Storage Policy [<String>]. Conflicting job(s) [<String>]. |
| 19:2296 | Data verification job cannot run as a Deduplication DB Reconstruction operation is running for the DDB Store [<String>]. Conflicting job(s) [<String>]. |
| 19:2297 | Data verification job cannot run as a Deduplication DB Reconstruction operation is running for the storage policy[<String>]. Conflicting job(s) [<String>]. |
| 19:2298 | A store level job is already running for the DDB Store [<String>]. Conflicting job(s) [<String>]. |
| 19:2299 | An entity extraction operation is already running for the data source. Conflicting job(s) [<String>]. |
| 19:2300 | A Data Analytics operation is already running for Storage Policy [<String>]. Conflicting job(s) [<String>]. |
| 19:2301 | Data Analytics job is already running. Conflicting job(s) [<String>]. |
| 19:2302 | Data verification job cannot run as a Move Partition job is running for the DDB Store [<String>]. Conflicting job(s) [<String>]. |
| 19:2303 | A Content Indexing operation is already running for Storage Policy [<String>]. Conflicting job(s) [<String>]. |
| 19:2304 | Online Crawl job is already running. Conflicting job(s) [<String>]. |
| 19:2305 | A Content Indexing operation is already running for subclient [<String>]. Conflicting job(s) [<String>]. |
| 19:2306 | Backups cannot start. Ensure that you have a valid configuration with access nodes (VSA proxies) that use the latest service pack, are online, and are not in maintenance mode, and then retry backups. |
| 19:2307 | Synthetic Full cannot run because the full backup job of the latest cycle is aged. |
| 19:2308 | Synthetic Full cannot run because the full snap backup job of the latest cycle has been aged in the backup copy. |
| 19:2309 | Synthetic Full cannot run because the full snap backup job of the latest cycle has not been backup copied. |
| 19:2310 | Failing the job as incremental data backups are not supported for MongoDB. |
| 19:2311 | Client [<String>] must be upgraded to Indexing Version 2. Please run the workflow [Upgrade To indexing V2] for the Oracle Agent on this client. The workflow can be downloaded from the Commvault Store. |
| 19:2312 | VM client is already being backed up by another job currently. Backup of VM client [<String>] being skipped. |
| 19:2313 | VM client activity is disabled at VM client or subclient level. Backup of VM client [<String>] being skipped. |
| 19:2314 | Running Orphan Chunk Listing as part of this Space Reclamation job [<Number>] as full Reconstruction job ran on same Deduplication Database. |
| 19:2315 | MS SQL instance is not yet validated, the job will be resumed when it is validated. |
| 19:2316 | Live Update job has completed. |
| 19:2317 | Live Update job has failed. |
| 19:2318 | Live Update job has been killed by user: [<String>]. |
| 19:2319 | Live Update job has completed with one or more errors. |
| 19:2320 | Live Update job has started; job ID [<Number>]. |
| 19:2321 | Live Update job has been suspended by user: [<String>]. |
| 19:2322 | Jobs available for processing are deferred due to storage policy configuration. Please check storage policy properties, snapshot tab. |
| 19:2323 | SharePoint (Data Protection) |
| 19:2324 | SharePoint (Data Recovery) |
| 19:2325 | NumberOfFilesProcessedInStubbingPhase = [<String>], NumberOfFilesArchivedInStubbingPhase = [<String>], NumberOfFilesSkippedForRedundancyCheckInStubbingPhase = [<String>]. TotalNumberOfFilesSkippedInStubbingPhase[<String>]. |
| 19:2326 | Backup job [^1lld] has been converted to a full backup because Start Over Operation was performed for Storage Policy |
| 19:2327 | Backup job [<Number>] has been converted to a full backup because the backup level set is not supported for IBM iSeries. |
| 19:2328 | SynthFULL with Indexing V2 is not supported |
| 19:2329 | Auto Scaling Index job has completed. |
| 19:2330 | Failed to initialize Auto Scaling Index job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:2331 | Auto Scaling Index job has failed. |
| 19:2332 | Auto Scaling Index job has been killed. |
| 19:2333 | Auto Scaling Index job has completed with one or more errors. |
| 19:2334 | Auto Scaling Index job has been stopped. |
| 19:2335 | <Message> The Auto Scaling Index job will not run. |
| 19:2336 | Space reclamation job has been killed by <String>. |
| 19:2337 | Failing this job as user selected dependent job [<Number>] was invalid or not successful. |
| 19:2338 | This job will start after user selected dependent job [<Number>] complete successfully. |
| 19:2339 | Backup job [^lld] has been converted to full backup because Laptop mode switched to classic |
| 19:2340 | Another snap backup is running for VSA parent client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. Parallel backup for same subclient is not supported for Intellisnap backups. |
| 19:2341 | Error in getting copy ID for single instance SILO job. |
| 19:2342 | Failed to get backup cycle number for subclient [<String>]. |
| 19:2343 | Failed to get the first job Id for turbo subclient [<String>]. |
| 19:2344 | Failed to get job option [<Number>]. |
| 19:2345 | Failed to get Turbo refTime for turbo subclient [<String>] for backup level [<Number>]. |
| 19:2346 | Failed to update Turbo refTime for turbo subclient [<String>] for backup level [<Number>]. |
| 19:2347 | Failed to check if subclient [<String>] is in Turbo Mode. |
| 19:2348 | Invalid App Id [<Number>]. |
| 19:2349 | Invalid backup level [<Number>]. |
| 19:2350 | Invalid Incremental Level [<Number>]. |
| 19:2351 | Quota check failed. |
| 19:2352 | Synthetic full job is not supported for this client [<String>]. |
| 19:2353 | Computer <<String>> is not able to connect back to Commserver. Login to remote machine <<String>> and see if it can resolve commserver hostname, create network topology between commserver and remote machine. |
| 19:2354 | Blackout Window for Server group prevents the synthetic backup from running right now. |
| 19:2355 | Blackout Window for Client prevents the synthetic backup from running right now. |
| 19:2356 | Backup job [<Number>] has been converted to a full backup because the backup level set is not supported for Meditech backups. |
| 19:2357 | Failed to start 3dfs service as other nfs service running on 3dfs server. |
| 19:2358 | Failed to start 3dfs service as no RPC service found on 3dfs server. |
| 19:2359 | Failed to export spanner database [<String>]. |
| 19:2360 | Failed to import spanner database [<String>]. |
| 19:2361 | Job initialization failed. Please check if Snapshot/IntelliSnap property is enabled at client/subclient level. |
| 19:2362 | Previous job on this subclient used SnapDiff scan on FlexGroup volume - this feature is supported on FR23 and higher. Please verify the subclient/agent configuration, it is recommended to use the Access Nodes with FR23 and higher. |
| 19:2363 | Failed to start the controller |
| 19:2364 | Blackout Window[<String>] for CommServe prevents the Data Verification job from running right now. |
| 19:2365 | Blackout Window[<String>] for Backup Set prevents the Compliance Archive job from running right now. |
| 19:2366 | Blackout Window[<String>] for Server group[<String>] prevents the Compliance Archive job from running right now. |
| 19:2367 | Blackout Window[<String>] for Client prevents the Compliance Archive job from running right now. |
| 19:2368 | Blackout Window[<String>] for CommServe prevents the Compliance Archive job from running right now. |
| 19:2369 | Blackout Window[<String>] for iDataAgent prevents the Compliance Archive job from running right now. |
| 19:2370 | Blackout Window[<String>] for Instance prevents the Compliance Archive job from running right now. |
| 19:2371 | Blackout Window[<String>] for Subclient prevents the Compliance Archive job from running right now. |
| 19:2372 | Blackout Window[<String>] for Schedule prevents the Compliance Archive job from running right now. |
| 19:2373 | Blackout Window[<String>] for Schedule Policy prevents the Compliance Archive job from running right now. |
| 19:2374 | Blackout Window[<String>] for CommServe prevents the Data Aging job from running right now. |
| 19:2375 | Blackout Window[<String>] for CommServe prevents the Auxiliary Copy job from running right now. |
| 19:2376 | Blackout Window[<String>] for Destination MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2377 | Blackout Window[<String>] for Server group[<String>] having Destination MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2378 | Blackout Window[<String>] for Schedule prevents the Auxiliary Copy job from running right now. |
| 19:2379 | Blackout Window[<String>] for Schedule Policy prevents the Auxiliary Copy job from running right now. |
| 19:2380 | Blackout Window[<String>] for Source MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2381 | Blackout Window[<String>] for Server group[<String>] having Source MediaAgent prevents the Auxiliary Copy job from running right now. |
| 19:2382 | Blackout Window[<String>] for Backup Set prevents the Backup Copy job from running right now. |
| 19:2383 | Blackout Window[<String>] for Server group[<String>] prevents the Backup Copy job from running right now. |
| 19:2384 | Blackout Window[<String>] for Client prevents the Backup Copy job from running right now. |
| 19:2385 | Blackout Window[<String>] for CommServe prevents the Backup Copy job from running right now. |
| 19:2386 | Blackout Window[<String>] for iDataAgent prevents the Backup Copy job from running right now. |
| 19:2387 | Blackout Window[<String>] for Instance prevents the Backup Copy job from running right now. |
| 19:2388 | Blackout Window[<String>] for Subclient prevents the Backup Copy job from running right now. |
| 19:2389 | Blackout Window[<String>] for Schedule prevents the Backup Copy job from running right now. |
| 19:2390 | Blackout Window[<String>] for Schedule Policy prevents the Backup Copy job from running right now. |
| 19:2391 | Blackout Window[<String>] for CommServe prevents the Backup Copy Workflow job from running right now. |
| 19:2392 | Blackout Window[<String>] for Backup Set prevents the Backup job from running right now. |
| 19:2393 | Blackout Window[<String>] for Server group[<String>] prevents the Backup job from running right now. |
| 19:2394 | Blackout Window[<String>] for Client prevents the Backup job from running right now. |
| 19:2395 | Blackout Window[<String>] for CommServe prevents the Backup job from running right now. |
| 19:2396 | Blackout Window[<String>] for iDataAgent prevents the Backup job from running right now. |
| 19:2397 | Blackout Window[<String>] for Instance prevents the Backup job from running right now. |
| 19:2398 | Blackout Window[<String>] for Subclient prevents the Backup job from running right now. |
| 19:2399 | Blackout Window[<String>] for Schedule prevents the Backup job from running right now. |
| 19:2400 | Blackout Window[<String>] for Schedule Policy prevents the Backup job from running right now. |
| 19:2401 | Blackout Window[<String>] for Backup Set prevents the OSSV Replicate Creation job from running right now. |
| 19:2402 | Blackout Window[<String>] for Server group[<String>] prevents the OSSV Replicate Creation job from running right now. |
| 19:2403 | Blackout Window[<String>] for Client prevents the OSSV Replicate Creation job from running right now. |
| 19:2404 | Blackout Window[<String>] for CommServe prevents the OSSV Replicate Creation job from running right now. |
| 19:2405 | Blackout Window[<String>] for iDataAgent prevents the OSSV Replicate Creation job from running right now. |
| 19:2406 | Blackout Window[<String>] for Instance prevents the OSSV Replicate Creation job from running right now. |
| 19:2407 | Blackout Window[<String>] for Subclient prevents the OSSV Replicate Creation job from running right now. |
| 19:2408 | Blackout Window[<String>] for Schedule prevents the OSSV Replicate Creation job from running right now. |
| 19:2409 | Blackout Window[<String>] for Schedule Policy prevents the OSSV Replicate Creation job from running right now. |
| 19:2410 | Blackout Window[<String>] for CommServe prevents the Disaster Recovery Backup job from running right now. |
| 19:2411 | Cleanup Blackout Window[<String>] for Backup Set prevents the Cleanup job from running right now. |
| 19:2412 | Cleanup Blackout Window[<String>] for Server group[<String>] prevents the Cleanup job from running right now. |
| 19:2413 | Cleanup Blackout Window[<String>] for Client prevents the Cleanup job from running right now. |
| 19:2414 | Cleanup Blackout Window[<String>] for CommServe prevents the Cleanup job from running right now. |
| 19:2415 | Cleanup Blackout Window[<String>] for iDataAgent prevents the Cleanup job from running right now. |
| 19:2416 | Cleanup Blackout Window[<String>] for Instance prevents the Cleanup job from running right now. |
| 19:2417 | Cleanup Blackout Window[<String>] for Subclient prevents the Cleanup job from running right now. |
| 19:2418 | Blackout Window[<String>] for Schedule prevents the Cleanup job from running right now. |
| 19:2419 | Blackout Window[<String>] for Schedule Policy prevents the Cleanup job from running right now. |
| 19:2420 | Blackout Window[<String>] for CommServe prevents the Media Export job from running right now. |
| 19:2421 | Blackout Window[<String>] for Backup Set prevents the Data Analytics job from running right now. |
| 19:2422 | Blackout Window[<String>] for Server group[<String>] prevents the Data Analytics job from running right now. |
| 19:2423 | Blackout Window[<String>] for Client prevents the Data Analytics job from running right now. |
| 19:2424 | Blackout Window[<String>] for CommServe prevents the Data Analytics job from running right now. |
| 19:2425 | Blackout Window[<String>] for iDataAgent prevents the Data Analytics job from running right now. |
| 19:2426 | Blackout Window[<String>] for instance prevents the Data Analytics job from running right now. |
| 19:2427 | Blackout Window[<String>] for Subclient prevents the Data Analytics job from running right now. |
| 19:2428 | Blackout Window[<String>] for Schedule prevents the Data Analytics job from running right now. |
| 19:2429 | Blackout Window[<String>] for Schedule Policy prevents the Data Analytics job from running right now. |
| 19:2430 | Full Blackout Window[<String>] for iDataAgent prevents the Compliance Archive job from running right now. |
| 19:2431 | Full Blackout Window[<String>] for Backup Set prevents the Backup from running right now. |
| 19:2432 | Full Blackout Window[<String>] for Server group[<String>] prevents the Backup from running right now. |
| 19:2433 | Full Blackout Window[<String>] for Client prevents the Backup from running right now. |
| 19:2434 | Full Blackout Window[<String>] for CommServe prevents the backup from running right now. |
| 19:2435 | Full Blackout Window[<String>] for iDataAgent prevents the Backup from running right now. |
| 19:2436 | Full Blackout Window[<String>] for Instance prevents the Backup from running right now. |
| 19:2437 | Full Blackout Window[<String>] for Subclient prevents the Backup from running right now. |
| 19:2438 | Blackout Window[<String>] for Schedule prevents the full Backup job from running right now. |
| 19:2439 | Blackout Window[<String>] for Schedule Policy prevents the full Backup job from running right now. |
| 19:2440 | Full Blackout Window[<String>] for Backup Set prevents the OSSV Replicate Creation from running right now. |
| 19:2441 | Full Blackout Window[<String>] for Server group[<String>] prevents the OSSV Replicate Creation from running right now. |
| 19:2442 | Full Blackout Window[<String>] for Client prevents the OSSV Replicate Creation from running right now. |
| 19:2443 | Full Blackout Window[<String>] for CommServe prevents the OSSV Replica Creation from running right now. |
| 19:2444 | Full Blackout Window[<String>] for iDataAgent prevents the OSSV Replica Creation from running right now. |
| 19:2445 | Full Blackout Window[<String>] for Instance prevents the OSSV Replicate Creation from running right now. |
| 19:2446 | Full Blackout Window[<String>] for Subclient prevents the OSSV Replicate Creation from running right now. |
| 19:2447 | Blackout Window[<String>] for Schedule prevents the full OSSV Replicate Creation job from running right now. |
| 19:2448 | Blackout Window[<String>] for Schedule Policy prevents the full OSSV Replicate Creation job from running right now. |
| 19:2449 | Full Blackout Window[<String>] for Backup Set prevents the Archiver job from running right now. |
| 19:2450 | Full Blackout Window[<String>] for Server group[<String>] prevents the Archiver job from running right now. |
| 19:2451 | Full Blackout Window[<String>] for Client prevents the Archiver job from running right now. |
| 19:2452 | Full Blackout Window[<String>] for CommServe prevents the archive job from running right now. |
| 19:2453 | Full Blackout Window[<String>] for iDataAgent prevents the archive job from running right now. |
| 19:2454 | Full Blackout Window[<String>] for Instance prevents the Archiver job from running right now. |
| 19:2455 | Full Blackout Window[<String>] for Subclient prevents the Archiver job from running right now. |
| 19:2456 | Blackout Window[<String>] for Schedule prevents the full Archiver job from running right now. |
| 19:2457 | Blackout Window[<String>] for Schedule Policy prevents the full Archiver job from running right now. |
| 19:2458 | Blackout Window[<String>] for Schedule prevents the job from running right now. |
| 19:2459 | Blackout Window[<String>] for Schedule Policy prevents the job from running right now. |
| 19:2460 | Blackout Window[<String>] for CommServe prevents Restore (Export) job from running right now. |
| 19:2461 | Blackout Window[<String>] for CommServe prevents the Media Inventory job from running right now. |
| 19:2462 | Blackout Window[<String>] for CommServe prevents the Media Refresh job from running right now. |
| 19:2463 | Blackout Window[<String>] for Backup Set prevents the Archiver job from running right now. |
| 19:2464 | Blackout Window[<String>] for Server group[<String>] prevents the Archiver job from running right now. |
| 19:2465 | Blackout Window[<String>] for Client prevents the Archiver job from running right now. |
| 19:2466 | Blackout Window[<String>] for CommServe prevents the archive job from running right now. |
| 19:2467 | Blackout Window[<String>] for iDataAgent prevents the Archiver job from running right now. |
| 19:2468 | Blackout Window[<String>] for Instance prevents the Archiver job from running right now. |
| 19:2469 | Blackout Window[<String>] for Subclient prevents the Archiver job from running right now. |
| 19:2470 | Blackout Window[<String>] for Schedule prevents the Archiver job from running right now. |
| 19:2471 | Blackout Window[<String>] for Schedule Policy prevents the Archiver job from running right now. |
| 19:2472 | Blackout Window[<String>] for CommServe prevents the Content Indexing job from running right now. |
| 19:2473 | Blackout Window[<String>] for Schedule prevents the Content Indexing job from running right now. |
| 19:2474 | Blackout Window[<String>] for Schedule Policy prevents the Content Indexing job from running right now. |
| 19:2475 | Blackout Window[<String>] for Backup Set prevents the Content Indexing job from running right now. |
| 19:2476 | Blackout Window[<String>] for Server group[<String>] prevents the Content Indexing job from running right now. |
| 19:2477 | Blackout Window[<String>] for Client prevents the Content Indexing job from running right now. |
| 19:2478 | A Content Indexing Blackout Window[<String>] for CommServe prevents the Content Indexing job from running right now. |
| 19:2479 | Blackout Window[<String>] for iDataAgent prevents the Content Indexing job from running right now. |
| 19:2480 | Blackout Window[<String>] for Instance prevents the Content Indexing job from running right now. |
| 19:2481 | Blackout Window[<String>] for Subclient prevents the Content Indexing job from running right now. |
| 19:2482 | Blackout Window[<String>] for Schedule prevents the Content Indexing job from running right now. |
| 19:2483 | Blackout Window[<String>] for Schedule Policy prevents the Content Indexing job from running right now. |
| 19:2484 | Blackout Window[<String>] for Server group[<String>] prevents the OSSV Recovery job from running right now. |
| 19:2485 | Blackout Window[<String>] for Client prevents the OSSV Recovery job from running right now. |
| 19:2486 | Blackout Window[<String>] for CommServe prevents the OSSV Recovery job from running right now. |
| 19:2487 | Blackout Window[<String>] for iDataAgent prevents the OSSV Recovery job from running right now. |
| 19:2488 | Blackout Window[<String>] for Schedule prevents the OSSV Recovery job from running right now. |
| 19:2489 | Blackout Window[<String>] for Schedule Policy prevents the OSSV Recovery job from running right now. |
| 19:2490 | Blackout Window[<String>] for Server group[<String>] prevents the Recovery job from running right now. |
| 19:2491 | Blackout Window[<String>] for Client prevents the Recovery job from running right now. |
| 19:2492 | Blackout Window[<String>] for CommServe prevents the Recovery job from running right now. |
| 19:2493 | Blackout Window[<String>] for iDataAgent prevents the Recovery job from running right now. |
| 19:2494 | Blackout Window[<String>] for Schedule prevents the Recovery job from running right now. |
| 19:2495 | Blackout Window[<String>] for Schedule Policy prevents the Recovery job from running right now. |
| 19:2496 | Blackout Window[<String>] for Server group[<String>] prevents the Restore job from running right now. |
| 19:2497 | Blackout Window[<String>] for Client prevents the Restore job from running right now. |
| 19:2498 | Blackout Window[<String>] for CommServe prevents the Restore job from running right now. |
| 19:2499 | Blackout Window[<String>] for iDataAgent prevents the Restore job from running right now. |
| 19:2500 | Blackout Window[<String>] for Schedule prevents the Restore job from running right now. |
| 19:2501 | Blackout Window[<String>] for Schedule Policy prevents the Restore job from running right now. |
| 19:2502 | Blackout Window[<String>] for Server group[<String>] prevents the Retrieve job from running right now. |
| 19:2503 | Blackout Window[<String>] for Client prevents the Retrieve job from running right now. |
| 19:2504 | Blackout Window[<String>] for CommServe prevents the Retrieve job from running right now. |
| 19:2505 | Blackout Window[<String>] for iDataAgent prevents the Retrieve job from running right now. |
| 19:2506 | Blackout Window[<String>] for Schedule prevents the Retrieve job from running right now. |
| 19:2507 | Blackout Window[<String>] for Schedule Policy prevents the Retrieve job from running right now. |
| 19:2508 | Blackout Window[<String>] for CommServe prevents Erase Backup/Migrated Data job from running right now. |
| 19:2509 | Blackout Window[<String>] for CommServe prevents the VaultTracker job from running right now. |
| 19:2510 | Blackout Window[<String>] for Server group[<String>] prevents the synthetic backup from running right now. |
| 19:2511 | Blackout Window[<String>] for Client prevents the synthetic backup from running right now. |
| 19:2512 | Synthetic Full Blackout Window[<String>] for CommServe prevents the synthetic backup from running right now. |
| 19:2513 | Blackout Window[<String>] for Schedule prevents the synthetic backup from running right now. |
| 19:2514 | Blackout Window[<String>] for Schedule Policy prevents the synthetic backup from running right now. |
| 19:2515 | Blackout Window[<String>] for CommServe prevents the Erase Media job from running right now. |
| 19:2516 | The license of agent [<String>] has expired. |
| 19:2517 | There is no license available. |
| 19:2518 | The license of agent [<String>] was released. |
| 19:2519 | Error: not all collections were tried to backup, failing job |
| 19:2520 | Failed to initialize solr API, failing job |
| 19:2521 | Failed to open results file. Failed files information for this job will not be available |
| 19:2522 | Failed to unquiesce solr DB restore |
| 19:2523 | Solr DB core status check failed, failing job |
| 19:2524 | Failed to release solr DB commit point, failing job |
| 19:2525 | Status check failed for role [<String>] |
| 19:2526 | Maximum number of data jobs allowed to run has been reached for client [<String>]. |
| 19:2527 | All available proxy clients are being used by other VMe to cloud jobs, please wait for a job to complete or add a new proxy client. |
| 19:2528 | Maximum number of log jobs allowed to run has been reached for client [<String>]. |
| 19:2529 | Another backup [<Number>] started running in parallel before this synthetic full could start to run, failing this job. |
| 19:2530 | Backup job [<Number>] has been converted to a full backup because Data Verification detected errors. |
| 19:2531 | Spanner database [<String>] not present on google cloud. Removed it from backup content. |
| 19:2532 | Unable to mount the media as a datastore. Please check the communication between the 3dfs server [<String>] and the host[<String>]. |
| 19:2533 | The job failed because of a database error while checking if conflicting job is running. Please try running the job after sometime. |
| 19:2534 | The job has exceeded the configured maximum allowed time without transferring any data so it is going to be interrupted and resumed by system automatically. |
| 19:2535 | Recovery target not found. Live Mount operation skipped. |
| 19:2536 | Waiting for job(s) [<String>] to be completed/suspended which are using cloud library. |
| 19:2537 | Failing the job as incremental backups are not supported for Splunk. |
| 19:2538 | Index Delete |
| 19:2539 | A VM selective backup job is running. |
| 19:2540 | A VM selective backup job is running. Backup of VM client [<String>] being skipped. |
| 19:2541 | New snap backup jobs are stopped because pending backup copy jobs threshold reached on this subclient. Please resolve any issue with backup copy to reduce pending backup copy count or modify threshold to enable new snap backup jobs. For <String> (pending/threshold) |
| 19:2542 | Commvault tools are being pushed to assist faster restore via install software job [<Number>]. |
| 19:2543 | Operation window for client prevents the Install Update job from running right now. |
| 19:2544 | Synthetic Full backup job for cloud laptop client failed because of errors detected in Data Verification |
| 19:2545 | Failed to initialize Data Remediation job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:2546 | The number of jobs currently running for this client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>] has already reached max instances [<Number>]. |
| 19:2547 | The subclient is associated to storage policy with Optimized for instant clone. Cannot run regular log backups. Please configure this instance to a schedule or plan that supports disk cache for log backups feature or use different plan or storage policy |
| 19:2548 | Sub-client is not eligible to run instant clone optimized backups. Please assign a different storage policy or plan. |
| 19:2549 | Marking this job as partial success because all jobs in the current cycle were marked committed. |
| 19:2550 | No Media Agent found to run backup copy of snapshot job. Please check Media Agent(s) configured |
| 19:2551 | Exchange package is not installed on [%s], index copy job can not run without Exchange package. |
| 19:2552 | Client is not eligible to run instant clone optimized backups. Please install Media Agent package on client. |
| 19:2553 | Backup copy job reattempted to backup the skipped Virtual Machines. |
| 19:2554 | Subclient [<String>] contains application data that is already defined in a VSA App Aware subclient, Client [<String>], subclient[<String>]. Please run a Full from this VSA subclient instead. If this job was initiated via a schedule, please ensure the schedule is disabled for this subclient. |
| 19:2555 | Bulk file migration job has completed. |
| 19:2556 | Bulk file migration job has failed because of unknown reason. Please try resubmitting the job. |
| 19:2557 | Bulk file migration job has failed. |
| 19:2558 | Bulk file migration job has been interrupted. |
| 19:2559 | Bulk file migration job has been killed by user: [<String>]. |
| 19:2560 | Bulk file migration job has completed with one or more errors. |
| 19:2561 | Bulk file migration job has been suspended by user: [<String>]. |
| 19:2562 | Unable to process jobs as there are existing active workflow jobs processing same subclients. |
| 19:2563 | Backup Window[<String>] for Plan prevents the Backup job from running right now. |
| 19:2564 | Operation window[<String>] for client prevents the Install Update job from running right now. |
| 19:2565 | <Message> The Send Log File job will not run. |
| 19:2566 | Computer [<String>] is currently under maintenance. Job will automatically resume in few minutes when maintenance is complete. |
| 19:2567 | Failed to get the configured access nodes list for Virtual Server. Please verify if the access nodes of the Virtualization client [<String> ] or subclient [<String>] have licenses or if they are of the same version as of the pseudo client. Click <https://documentation.commvault.com/commvault/v11/article?p=32191.htm> on how to configure. |
| 19:2568 | Node [<String>] either failed to start or stopped without completing it's tasks |
| 19:2569 | Synthetic full job is not supported for this subclient if snap copy is with cycle based retention. |
| 19:2570 | Job has been killed and cleaned up. |
| 19:2571 | Failed to run Data Aging job due to change in system time. |
| 19:2572 | Old style content indexing job is not supported. |
| 19:2573 | Failed to initialize Content Indexing job for task [<Number>]. Check Job Manager log files and/or call your vendor's support hotline. |
| 19:2574 | Exchange package is not installed on [<String>], index copy job can not run without Exchange package. |
| 19:2575 | Backup activity for [<String>] on Server [<String>] is disabled. |
| 19:2576 | Backup activity for Instance [<String>] on Server [<String>] is disabled. |
| 19:2577 | Backup activity on Server [<String>] is disabled. |
| 19:2578 | Backup activity on Server group(s) [<String>] is disabled. |
| 19:2579 | Backup activity for Subclient [<String>] on Server [<String>] is disabled. |
| 19:2580 | Backup activity for VM group [<String>] on Server [<String>] is disabled. |
| 19:2581 | Installs are not allowed on deactivated company clients. |
| 19:2582 | Number of available streams [<Number>] is either less than the number of nodes [<Number>] or less than the recommended minimum number [<Number>]. This can impact performance of the backup. |
| 19:2583 | Client is already being backed up by job [<Number>] from parent job [<Number>]. |
| 19:2584 | A Catalog Snapshots Workflow operation is already running for Subclient [<String>]. |
| 19:2585 | A Backup Copy Workflow operation is already running for Subclient [<String>]. |
| 19:2586 | Another backup job [<Number>] is running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:2587 | Another backup job [<Number>] from parent job [<Number>] is running for client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. |
| 19:2588 | Another snap backup job [<Number>] is running for VSA parent client [<String>], iDataAgent [<String>], Backup Set [<String>], Subclient [<String>]. Parallel backup for same subclient is not supported for Intellisnap backups. |
| 19:2589 | Backup activity for VM group [<String>] on Server [<String>] and iDataAgent [<String>] is disabled. |
| 19:2590 | Maximum number of sweep jobs allowed to run have been reached for Media Agent [<String>]. |
| 19:2591 | Failing the job since all cluster nodes are either down or not reachable. |
| 19:2592 | Job [<Number>] cannot be started now as it is staggered due to job staggering option selected in the schedule policy. |
| 19:2593 | Failed to get proxy clients associated with the instance, check if the node is primary and cluster nodes are configured. |
| 19:2594 | NumberOfFilesProcessedInStubbingPhase = [<String>], NumberOfFilesDeleted = [<String>], NumberOfFilesSkippedForRedundancyCheckInStubbingPhase = [<String>]. TotalNumberOfFilesSkippedInStubbingPhase[<String>]. |
| 19:2595 | Waiting for job(s) [<String>] to complete Transaction Log backup phase. |
| 19:2596 | Unable to fetch IndexServer name for index database of client [<String>]. |
| 19:2597 | Configuration restore has not yet started on the destination Virtual Machine. Check the VM console to rule out any boot or network connectivity issues. |
| 19:2598 | Full Blackout Window[<String>] for Client[<String>] prevents the Backup from running right now. |
| 19:2599 | Infrastructure software update<String> in progress. Job will be retried. |
| 19:2600 | Incremental snap backup job [<Number>] has been converted to a full backup during backup copy as last full snap backup job [<Number>] was marked as bad because of missing snapshot. |
| 19:2601 | The job is pending because all access nodes to launch the job are overloaded. |
| 19:2602 | The job is pending because client to launch the job is overloaded. |
| 19:2603 | DDB Space Reclamation job has been suspended by user <String> |
| 19:2604 | VM level Synthetic Full backup job failed because of errors detected in Data Verification. The next incremental for the VM will be converted to full. |
| 19:2605 | Index Restore job has been suspended by user <String>. |
| 19:2606 | Index Restore job has been suspended by System <String> |
| 19:2607 | Incremental snap backup job [<Number>] has been converted to a full backup during backup copy as last full snap backup job [<Number>] was disabled for backup copy. |
| 19:2608 | Incremental snap backup job [<Number>] has been converted to a full backup during backup copy as last full snap backup job [<Number>] was marked as bad because of missing snapshot. |
| 19:2609 | Exchange package is not installed on [<String>], reference copy job can not run without Exchange package. |
| 19:2610 | Exchange package is not installed on any of the member servers, reference copy job can not run without Exchange package. |
| 19:2611 | Failing the job as a Full backup has not yet been run on the subclient. |
| 19:2612 | Reducing the job activity high water mark to [<Number>] because SQL server health is not good. |
| 19:2613 | SQL Server health is better now. Using the regular high water mark [<Number>] |
| 19:2614 | Workflow [<String>] has failed for operation [<String>]. Error [<String>] |
| 19:2615 | <Message> The Install job will not run. |
| 19:2616 | <Message> The Uninstall job will not run. |
| 19:2617 | License is not consumed by agent [<String>] on client [<String>]. Try Release/Reconfigure agent [<String>] license on client [<String>] and then run the job again. |
| 19:2618 | File Indexing |
| 19:2619 | DDB Data Verification |
| 19:2620 | Space reclamation |
| 19:2621 | Restore (export) |
| 19:2622 | MongoDB Disaster Recovery Backup operation is already running. |
| 19:2623 | Cloud Resource Discovery job is already running. Conflicting job(s) [<String>]. |
| 19:2624 | Job [<Number>] is queued as the maximum number of move partition jobs allowed per Commcell has been reached |
| 19:2625 | Job [<Number>] is queued as the maximum number of move partition jobs allowed for the MediaAgent [<String>] has been reached |
| 19:2626 | NDMP Client (Data Protection) |
| 19:2627 | Blackout Window[<String>] for Client [<String>] prevents the Compliance Archive job from running right now. |
| 19:2628 | Blackout Window[<String>] for Client [<String>] prevents the Backup Copy job from running right now. |
| 19:2629 | Blackout Window[<String>] for Client [<String>] prevents the Backup job from running right now. |
| 19:2630 | Blackout Window[<String>] for Client [<String>] prevents the OSSV Replicate Creation job from running right now. |
| 19:2631 | Cleanup Blackout Window[<String>] for Client [<String>] prevents the Cleanup job from running right now. |
| 19:2632 | Blackout Window[<String>] for Client [<String>] prevents the Data Analytics job from running right now. |
| 19:2633 | Full Blackout Window[<String>] for Client [<String>] prevents the OSSV Replicate Creation from running right now. |
| 19:2634 | Full Blackout Window[<String>] for Client [<String>] prevents the Archiver job from running right now. |
| 19:2635 | Blackout Window[<String>] for Client [<String>] prevents the Archiver job from running right now. |
| 19:2636 | Blackout Window[<String>] for Client [<String>] prevents the Content Indexing job from running right now. |
| 19:2637 | Blackout Window[<String>] for Client [<String>] prevents the OSSV Recovery job from running right now. |
| 19:2638 | Blackout Window[<String>] for Client [<String>] prevents the Recovery job from running right now. |
| 19:2639 | Blackout Window[<String>] for Client [<String>] prevents the Restore job from running right now. |
| 19:2640 | Blackout Window[<String>] for Client [<String>] prevents the Retrieve job from running right now. |
| 19:2641 | Blackout Window[<String>] for Client [<String>] prevents the synthetic backup from running right now. |
| 19:2642 | Archiver full Job [<Number>] has been converted to INCR with ref time as 0. |
| 19:2643 | License capacity/usage has exceeded. Please check licensing summary report. |
| 19:2644 | Job is in waiting state and will resume shortly. If the problem persists for a long time, please contact your provider. |
| 19:2645 | Backups cannot start. Please ensure that you have a valid configuration with access nodes (VSA proxies) that use the latest feature release, are online, have a valid license, are not in maintenance mode, and then retry backups. |
| 19:2646 | Incremental snap backup job [<Number>] has been converted to a full backup during backup copy as last full snap backup job was not available anymore. |
| 19:2647 | The backup copy job of the PostgreSQL full snap had failed or was killed. Will not spawn off a new full snap backup when the incremental backup fails because failover was detected. |
| 19:2648 | Waiting for Download Job [<Number>] to complete. |
| 19:2649 | The Critical System State Component of [One Touch Files] failed to be protected due to an issue querying the operating system for disk information. Please review this https://kb.commvault.com/article/54405 as the system's VDS service could be the cause of failure. |
| 19:2650 | Failed to start phase [<String>] on [<String>] due to software being prepared for first time use. |
| 19:2651 | Job is waiting for Airgap to be lifted. |
| 19:2652 | Operations on recovery group has been disabled. You may be over your subscription or license expired. Advice : Please contact customer success manager for additional license or renewal. |
| 19:2653 | Operations on replication group has been disabled. You may be over your subscription or license expired. Advice : Please contact customer success manager for additional license or renewal. |
| 19:2654 | The space reclamation job cannot be run at the moment as a Deduplication DB Reconstruction operation is running for the DDB Store [<String>]. There are conflicting job(s) [<String>]. |
| 19:2655 | The data verification job cannot be run for the uninitialized DDB Store [<String>]. |
| 19:2656 | The space reclamation job cannot be run at the moment as a Move Partition job is currently running for the DDB Store [<String>]. There are conflicting job(s) [<String>]. |
| 19:2657 | The space reclamation job cannot be run for the uninitialized DDB Store [<String>]. |
Lotus Notes
| Code | Description |
| 42:1 | Notes.ini file not found. Notes initialization will fail. |
| 42:2 | Cannot get log information of database <String> (<String>) - <String>. |
| 42:3 | Database <String> not logged. |
| 42:4 | <Number> databases found in Notes directory <String>. |
| 42:5 | Transactional logging is set to circular. It must be set to archive. |
| 42:6 | Error recovering <String> (<Number>) (<String> - <Number>). |
| 42:7 | Cannot bring database <String> online (<String> - <Number>). |
| 42:8 | Transaction logging not turned on. |
| 42:9 | Cannot back up database <String> - <String>. |
| 42:10 | Cannot open database <String> - <String>. |
| 42:11 | Disaster recovery not ready. Please prepare for disaster recovery. |
| 42:12 | Cannot restore latest archived log. Disaster recovery will fail. |
| 42:13 | It seems you are going to do disaster recovery. Please make sure to check the correct option. |
| 42:14 | Restoring from selective copy, only databases will be restored. |
| 42:15 | Recovery Error: <String>. |
| 42:16 | Error initializing CVSession with w2StartRestore. (error <Number>). |
| 42:17 | Error receiving initialization data from w2StartRestore. |
| 42:18 | Current operation is uninterruptible, stop/kill request ignored. Please try again later. |
| 42:19 | Cannot find version of Lotus Domino server from registry. |
| 42:20 | Cannot start process [<String>]. (error <Number>). |
| 42:21 | Transaction logging is not in ARCHIVE mode. Please do not use Disaster Recovery/Media Recovery option. |
| 42:22 | Transaction logging is not in ARCHIVE mode. Please do not use TRANSLOG_RECREATE_LOGCTRL in notes.ini. |
| 42:23 | Transaction logging is not in ARCHIVE mode. Recovery phase will be skipped. Databases restored are usable in the state of last backup. |
| 42:24 | Transaction log backup will fail because the logging setting is not in ARCHIVE mode. |
| 42:25 | Cannot initialize Notes API. Please check if Domino Server status and settings are OK. |
| 42:26 | Invalid Lotus Domino Server version. The version should be <String>. |
| 42:27 | Use Alternate Path for Restored Log Extents' option is used, but 'Translog_Recover_Path' is not set in notes.ini. |
| 42:28 | Unable to open restore list file <String>. |
| 42:29 | A transaction log file required for recovery was not found. Please make sure that transaction log subclient was successfully backed up. |
| 42:30 | Error happened while restoring a transaction log. Please check the media, library, network connection and the product's services status on all involved machine. |
| 42:31 | Restore job was killed. Database(s) being recovered could be corrupt. |
| 42:32 | Unknown error (<Number>) happened when restoring a transaction log file. Please see lndbClRestoreLogs.log for details. |
| 42:33 | Database [<String>] was accessed either by user or server task after restore but before recovery. Recovery cannot continue. Databases restored are usable in the state of last backup. |
| 42:34 | Recovery for database [<String>] failed - It is from another Domino Server or the logging system on this server has been changed since it was backed up. Databases restored are usable in the state of last backup. |
| 42:35 | Incorrect parameters were used for recovery. Recovery phase will be skipped. Databases restored are usable in the state of last backup. |
| 42:36 | Recovery Error: <String> - (<Number>), database: [<String>]. |
| 42:37 | Cannot open image file [<String>]. Please check free space and permission. |
| 42:38 | Cannot open transaction log file [<String>] - error [<Number>]. |
| 42:39 | An error occurred while reading the transaction log file [<String>]. |
| 42:40 | Cannot get size of transaction log file [<String>] - error [<Number>]. |
| 42:41 | Cannot initiate archiving transaction logs. Please make sure there is no other process locking the logs. |
| 42:42 | Querying Domino Server for next log failed. |
| 42:43 | Unable to locate one or more required DLLs. |
| 42:44 | Unable to locate a required entry point function. Please ensure that the proper DLLs are being used. |
| 42:45 | A run time failure has occurred. |
| 42:46 | Unable to initialize Lotus Notes/Domino API. |
| 42:47 | At least one document failed to be archived/backed up. |
| 42:48 | At least one database failed to back up. |
| 42:49 | SubClients contents are empty.There is nothing to backup. |
| 42:50 | Insufficient disk space on client [<String>].nPlease make sure there is enough disk space on transaction log directory and job results directory. |
| 42:51 | Backup for database [<String>] overlaps with its maintenance task(s) on domino server [<String>]. Please reschedule. |
Media Library Manager
| 31:1 | Could not determine device type for vendor:[<String>] model:[<String>]. |
| 31:2 | Could not determine device type for vendor:[<String>] model:[<String>]. |
| 31:3 | Could not complete function:[<String>] - missing parameter:[<String>]. |
| 31:4 | Could not access file:[<String>][<String>]. |
| 31:5 | Could not remove service:[<String>]. |
| 31:6 | Could not create service named:[<String>] - service path is too long. |
| 31:7 | Could not create configuration for LMS or DMS:[<String>] - configuration path is too long |
| 31:8 | Could not allocate space when attempting:[<String>]. |
| 31:9 | Could not retrieve existing service configuration for service:[<String>]. |
| 31:10 | Could not install service:[<String>] on Host [<String>]. |
| 31:11 | Could not stop service:[<String>]. |
| 31:12 | Could not start service:[<String>]. |
| 31:13 | Cannot configure DRIVE:[<String>] - required data has not been entered. |
| 31:14 | Cannot configure DRIVE:[<String>] - No Access Path, please detect devices again. |
| 31:15 | Cannot configure drive pool:[<String>] - required data has not been entered. |
| 31:16 | Cannot deconfigure drive pool:[<String>] - required data has not been entered. |
| 31:17 | Cannot configure LIBRARY:[<String>] - required data has not been entered. |
| 31:18 | Cannot configure HOST:[<String>] - required data has not been entered. |
| 31:19 | Cannot configure HOST:[<String>] - server required data has not been entered. |
| 31:20 | Cannot configure DRIVE:[<String>] - drive pool is required. |
| 31:21 | Cannot configure DRIVE:[<String>] - master drive pool is required. |
| 31:22 | Cannot configure drive pool:[<String>] when configuring DMS:[<String>]. |
| 31:23 | Cannot configure master drive pool:[<String>] when configuring DMS:[<String>]. |
| 31:24 | Configure DMS:[<String>] encountered MLM interface error:[<String>]. |
| 31:25 | Configure drive pool:[<String>] encountered MLM interface error:[<String>]. |
| 31:26 | Configure LMS:[<String>] encountered MLM interface error:[<String>]. |
| 31:27 | Attempting to read DRIVES for server host:[<String>] encountered MLM interface error:[<String>]. |
| 31:28 | Attempting to read LIBRARIES for server host:[<String>] encountered MLM interface error:[<String>]. |
| 31:29 | Attempting to read DRIVEPOOLS for server host:[<String>] encountered MLM interface error:[<String>]. |
| 31:30 | Installing DRIVE:[<String>] failed with error [<String>]. |
| 31:31 | Installing LIBRARY:[<String>] failed with error [<String>]. |
| 31:32 | Uninstalling DRIVE:[<String>] failed with error [<String>]. |
| 31:33 | Uninstalling LIBRARY:[<String>] failed with error [<String>]. |
| 31:34 | Deleting DRIVE:[<String>], data object:[<String>] encountered MLM interface error:[<String>]. |
| 31:35 | Deleting drive pool:[<String>], data object:[<String>] encountered MLM interface error:[<String>]. |
| 31:36 | Deleting LIBRARY:[<String>], data object:[<String>] encountered MLM interface error:[<String>]. |
| 31:37 | Could not add DRIVE:[<String>] to library:[<String>] - drive number:[<String>] is not in the range 1-[<String>]. |
| 31:38 | Could not add DRIVE:[<String>] to Library [<String>] - All drives for this library have been assigned. For DDS, there is a different drive occupied the drive slot from other MediaAgent(s). |
| 31:39 | Could not find DRIVE:[<String>] in the drive list for Library [<String>]. |
| 31:40 | Could not create directory:[<String>]. |
| 31:41 | Could not write to file:[<String>]. |
| 31:42 | Could not read from file:[<String>]. |
| 31:43 | Could not open file:[<String>]. |
| 31:44 | Could not access file:[<String>]. |
| 31:45 | Received unexpected message type:[<String>] when configuring Library [<String>]. |
| 31:46 | Could not create link named:[<String>] to point to:[<String>]. |
| 31:47 | Could not read [<String>] from the platform information for host:[<String>]. |
| 31:48 | Could not find DRIVE:[<String>] in the drive list for HOST:[<String>]. |
| 31:49 | Could not find LIBRARY:[<String>] in the library list for HOST:[<String>]. |
| 31:50 | Could not find drive pool:[<String>] in the drive pool list for server host:[<String>]. |
| 31:51 | Could not find DRIVE:[<String>] in any host in server:[<String>]. |
| 31:52 | Could not find LIBRARY:[<String>] in any host in server:[<String>]. |
| 31:53 | Could not remove DRIVE:[<String>] from HOST:[<String>] - drive must be deconfigured. |
| 31:54 | Could not remove LIBRARY:[<String>] from HOST:[<String>] - library must be deconfigured. |
| 31:55 | Could not remove HOST:[<String>] from server host:[<String>] - host must be deconfigured. |
| 31:56 | Could not assign DRIVE:[<String>] to LIBRARY:[<String>] - drive is already assigned to LIBRARY:[<String>]. |
| 31:57 | Could not read the platform information for server host:[<String>] - cannot find installation directory. |
| 31:58 | Cannot remove drive pool:[<String>] from server host:[<String>] - the default drive pool cannot be removed. |
| 31:59 | Cannot remove drive pool:[<String>] from server host:[<String>] - drive pool must not have any drives assigned to it and must be deconfigured. |
| 31:60 | Could not get a license for Library [<String>]. |
| 31:61 | Could not free the license for Library [<String>]. |
| 31:62 | Attempt to get unique ID for library encountered error:[<String>]. |
| 31:63 | Attempt to get unique ID for drive encountered error:[<String>]. |
| 31:64 | Attempt to get unique ID for master drive pool encountered error:[<String>]. |
| 31:65 | Attempt to get unique ID for drive pool encountered error:[<String>]. |
| 31:66 | Could not mount volume:[<String>] in DRIVE:[<String>] encountered error:[<String>]. |
| 31:67 | Could not unmount volume:[<String>] encountered error:[<String>]. |
| 31:68 | Could not read drives for host:[<String>] - drive:[<String>] is contained in a library:[<String>] which is not on this host. |
| 31:69 | Could not read platform information. |
| 31:70 | Could not read device name for drive:[<String>]. Drivers may not be loaded or drive is in use. |
| 31:71 | Could not create archive group for library:[<String>]. Could not load Archive Manager library:[<String>]. |
| 31:72 | Could not create archive group for library:[<String>]. Could not find Archive Manager routine:[<String>]. |
| 31:73 | Could not create archive group for library:[<String>]. Received error [<String>=<String>]. |
| 31:74 | Library [<String>] cannot be deleted. [<String>] |
| 31:75 | Library [<String>][<String>,<String>][<String>,<String>,<String>] is not online. Could not determine drive count and base address. |
| 31:76 | Operation failed on library [<String>]. Not enough information to perform action. |
| 31:77 | Operation failed on drive [<String>]. Not enough information to perform action. |
| 31:78 | Could not find drive pool:[<String>] in HOST:[<String>]. |
| 31:79 | Could not remove drive pool:[<String>] from HOST:[<String>] - Drive pool is not in a removable state. |
| 31:80 | Could not find drive pool:[<String>] in the drive pool list for Library [<String>]. |
| 31:81 | Could not disable RSM on host:[<String>]. Access denied. |
| 31:82 | Could not disable RSM on host:[<String>]. Received unexpected error code:[<String>]. |
| 31:83 | Could not deconfigure drive [<String>] - number of configured drives cannot be less than maximum concurrent streams allocated in drive pool [<String>]. Please check to see if the storage policy copies for drive pool were properly deleted or reduce the streams for the storage policy. |
| 31:84 | Could not deconfigure drive [<String>] - failed to retrieve maximum concurrent steams for drive pool [<String>]. |
| 31:85 | Could not execute request. Remote host [<String>] must be upgraded to a more recent software version. |
| 31:86 | Cannot configure MASTERDRIVEPOOL:[<String>] - required data has not been entered. |
| 31:87 | Cannot deconfigure MASTERDRIVEPOOL:[<String>] - required data has not been entered. |
| 31:88 | Could not share the drive pool:[<String>] - drive pool must be deconfigured. |
| 31:89 | Could not find MASTERDRIVEPOOL:[<String>] in the master drive pool list for Library [<String>]. |
| 31:90 | Could not configure Library [<String>] with RSM disabled. |
| 31:91 | Could not deconfigure drive [<String>] - check to see if the storage policy copies for drive pool [<String>] were properly deleted. |
| 31:92 | Could not complete Drag & Drop action. The Drag object type is wrong for the Drop target. |
| 31:93 | Could not complete Drag & Drop action. The Drag object is configured. |
| 31:94 | Could not complete Drag & Drop action. The target drive is configured. |
| 31:95 | Library [<String>] is not configured yet, please configure library first. |
| 31:96 | Could not merge two Drive Pools with different MediaAgents. |
| 31:97 | Could not merge two Master Drive Pools. The Master Drive Pool already contains a Drive Pool with same MediaAgent for a Drive Pool in another Master Drive Pool. |
| 31:98 | Could not add the drive to the Master Drive Pool. The other Master Drive Pool already contains a Drive Pool with same MediaAgent for the drive. |
| 31:99 | There is no empty drive slot available to add the drive to library. Either the drive does not belong to this library or there is some drive misplaced to the library. Please run Exhaustive Detection to correct the problem. |
| 31:100 | There are not enough drive slots to add all drives to library. The source Drive Pool may contain wrong drives for the library or there is some drive misplaced to the library. Please run Exhaustive Detection to correct the problem. |
| 31:101 | Could not add the same drive to library without creating SAN DDS Drive Pool first. |
| 31:102 | Drag & Drop is not supported for RSM-enabled library. |
| 31:103 | Could not delete the configured object [<String>]. |
| 31:104 | Missing information for the installation directory for MediaAgent[<String>]. |
| 31:105 | Missing parameter for the service. |
| 31:106 | Missing MediaAgent information. |
| 31:107 | Receive wrong message from MediaAgent [<String>]. |
| 31:108 | Unmount medium for Library [<String>] on MediaAgent [<String>] failed. |
| 31:109 | Mount medium for Library [<String>] on MediaAgent [<String>] failed. |
| 31:110 | Unload medium for Drive [<String>] on MediaAgent [<String>] failed, the medium may be stuck in the drive. |
| 31:111 | Failed to detect the medium for Drive [<String>] on MediaAgent [<String>]. |
| 31:112 | Base Address for Library [<String>] is not detected, please detect the Library again. |
| 31:113 | Cannot create the API object for Library [<String>]. |
| 31:114 | Cannot create work pool for Library [<String>]. |
| 31:115 | Cannot remove work pool for Library [<String>]. |
| 31:116 | Could not install service [<String>] on Host [<String>]. |
| 31:117 | Could not remove service [<String>] on Host [<String>]. |
| 31:118 | Could not add service [<String>] to cluster resources. |
| 31:119 | Could not remove service [<String>] from cluster resources. |
| 31:120 | User aborted. |
| 31:121 | Auto-updated the SCSI address for device [<String>] from <String> to <String>. |
| 31:122 | Failed to create the media pool for RSM-enabled library on host:[<String>]. |
| 31:123 | Failed to delete the media pool for RSM-enabled library on host:[<String>]. |
| 31:124 | Could not Impersonate user [<String>] on host:[<String>]. |
| 31:125 | Cannot get NDMP host Info. |
| 31:126 | Unable to open connection to NDMP library device. |
| 31:127 | Unable to determine device vendor and model. |
| 31:128 | Unable to determine number of drives and their base address. |
| 31:129 | Cannot configure Copy Manager [<String>] - No Concurrency limit, please detect devices again. |
| 31:130 | Cannot configure Drive [<String>] - No Drive ID for the IP Library selected. Please select the IP Library Drive ID first in Properties page. |
| 31:131 | Could not remove service [<String>] on Host [<String>]. The machine may be offline or not enough access privilege. |
| 31:132 | Drag & Drop is not supported for Fastrax library. |
| 31:133 | Could not determine Copy Manager type for vendor:[<String>] model:[<String>] |
| 31:134 | Could not log in to server [<String>]. |
| 31:135 | The server [<String>] NDMP version does not support this operation. |
| 31:136 | Serial number not available for drive [<String>]. |
| 31:137 | Mount Error: passing the invalid drive slot address. |
| 31:138 | Library is not initialized yet. |
| 31:139 | No medium transport element available. |
| 31:140 | No media available. |
| 31:141 | No empty slot available. |
| 31:142 | Moving medium failed. |
| 31:143 | Failed to initialize the CVSCSISPITarget object. |
| 31:144 | Failed to initialize element status. |
| 31:145 | Failed to read element status. |
| 31:146 | Failed to Load/Unload tape. |
| 31:147 | Failed to call TestUnitReady(). |
| 31:148 | Unknown SCSI error. |
| 31:149 | At least one Storage Policy/Copy Name [<String>/<String>] still exists. |
| 31:150 | Cannot deconfigure Copy Manager [<String>] because Drive Pool [<String>] is still associated to it. |
| 31:151 | Failed to Get EMC Fastrax information from MediaAgent [<String>]. |
| 31:152 | Failed to create failover Library Controllers, the library connection type is different from the target library. |
| 31:153 | Failed to create failover Library Controllers, the library is different from the target library. |
| 31:154 | Failed to create failover Library Controllers, the Library Controller on MediaAgent [<String>] is existed for the target library. |
| 31:155 | Failed to create failover Library Controllers, cannot use the standalone library for failover Library Controller. |
| 31:156 | Failed to detect Centera Cluster using Access Node [<String>] on MediaAgent [<String>]. |
| 31:157 | Failed to add new Drive Pool to MasterDrivePool [<String>] which contains Drive Pool [<String>] for the same MediaAgent [<String>]. |
| 31:158 | Cannot deconfigure DiskDevice [<String>] because Disk Library [<String>] is still associated with it. |
| 31:159 | Cannot deconfigure Centera Cluster [<String>] because Disk Library [<String>] is still associated with it. |
| 31:160 | Unknown Event. |
| 31:161 | Moving the shared drive to different Master Drive Pool within the library is not allowed. |
| 31:162 | NDMP detect in <String> has completed. |
| 31:163 | NDMP exhaustive detection in <String> has completed. |
| 31:164 | NDMP exhaustive detection in <String> not possible. No Library present in <String>. |
| 31:165 | NDMP detect in <String> failed: Internal error. |
| 31:166 | NDMP detect in <String> failed: Wrong NDMP version. |
| 31:167 | NDMP detect in <String> failed. |
| 31:168 | NDMP detect in <String> failed: No memory. |
| 31:169 | NDMP detect in <String> failed: Cannot access arm changer. |
| 31:170 | NDMP detect in <String> failed: Cannot access tape drive. |
| 31:171 | NDMP detect in <String> failed: Arm changer error. |
| 31:172 | NDMP detect in <String> failed: Tape drive error. |
| 31:173 | NDMP detect in <String> failed: Cannot move the medium. |
| 31:174 | NDMP detect in <String> failed: Tape drive is not responding. |
| 31:175 | NDMP detect in <String> failed: Cannot unload the medium from the drive. |
| 31:176 | The server type for <String> is not supported for NDMP device auto detection. |
| 31:177 | NDMP detect in <String> failed: Cannot log in to server. |
| 31:178 | NDMP exhaust detect in <String> failed. Normal detection was performed. |
| 31:179 | A Library in server <String> has no more tapes available. |
| 31:180 | NDMP detect: Unknown Error. |
| 31:181 | Drive exhaustive detection failed. |
| 31:182 | Creating service <String>... |
| 31:183 | Creating service <String> failed. |
| 31:184 | Service <String> is created. |
| 31:185 | Removing service <String>... |
| 31:186 | Removing service <String> failed. |
| 31:187 | Service <String> is removed. |
| 31:188 | Removing service <String> failed: <String>. |
| 31:189 | Starting service <String>... |
| 31:190 | Starting service <String> failed. |
| 31:191 | Service <String> is started. |
| 31:192 | Stopping service <String>... |
| 31:193 | Stopping service <String> failed. |
| 31:194 | Service <String> is Stopped. |
| 31:195 | Resetting MediaAgent [<String>]... |
| 31:196 | Resetting MediaAgent [<String>] failed. <String> |
| 31:197 | MediaAgent [<String>] is Reset. |
| 31:198 | Configuring MediaAgent [<String>]... |
| 31:199 | Configuring MediaAgent [<String>] failed. |
| 31:200 | MediaAgent [<String>] is configured. |
| 31:201 | Deconfiguring MediaAgent [<String>]... |
| 31:202 | Deconfiguring MediaAgent [<String>] failed. |
| 31:203 | MediaAgent [<String>] is deconfigured. |
| 31:204 | Detection failed on MediaAgent [<String>], error: <String>. |
| 31:205 | Warning - The Drive [<String>] is not ready, error: <String>. |
| 31:206 | Unloading media from Drive [<String>] on MediaAgent [<String>]... |
| 31:207 | Warning - Drive [<String>] has no media or may have a stuck tape, error: <String>. |
| 31:208 | Unloaded media from Drive [<String>] on MediaAgent [<String>]. |
| 31:209 | Unmounting all media on MediaAgent [<String>]... |
| 31:210 | Unmounted all media on MediaAgent [<String>]. |
| 31:211 | Failed to remove the Library service for Library [<String>], error: <String>. |
| 31:212 | Mounting medium for Drive [<String>] on MediaAgent [<String>]... |
| 31:213 | Mounting medium for Drive [<String>] on MediaAgent [<String>] failed. |
| 31:214 | Mounted medium for Drive [<String>] on MediaAgent [<String>]. |
| 31:215 | Unmounting medium for Drive [<String>] on MediaAgent [<String>]... |
| 31:216 | Unmounting medium for Drive [<String>] on MediaAgent [<String>] failed. |
| 31:217 | Unmounted medium for Drive [<String>] on MediaAgent [<String>]. |
| 31:218 | Internal error - application threw the exception. |
| 31:219 | Stopping device services on MediaAgent [<String>]... |
| 31:220 | ***** Start Exhaustive Detection ***** |
| 31:221 | Initialize all libraries... |
| 31:222 | Initialize the library... |
| 31:223 | Start to detect devices on MediaAgent [<String>]... |
| 31:224 | Warning - Cannot get the drive slot base address from Library [<String>], will skip this library. |
| 31:225 | Start to detect drives on Library [<String>]... |
| 31:226 | Mounting a medium to drive slot (<String>) in Library [<String>]... |
| 31:227 | Warning - Mount error on Library [<String>], error: <String>. |
| 31:228 | Mounted a medium to drive slot (<String>) in Library [<String>]. |
| 31:229 | -> Detected the media in Drive [<String>]. |
| 31:230 | -> Detected Drive [<String>] is the same drive of Drive [<String>]. |
| 31:231 | Warning - Sense the mounted medium in multiple drives: Drive [<String>] and Drive [<String>]. |
| 31:232 | Warning - Cannot determine the medium in any drive. The medium may get stuck in drive slot (<String>) in Library [<String>]. |
| 31:233 | Unloading the media from drive slot (<String>) in Library [<String>]... |
| 31:234 | Warning - Failed to unload the media from drive slot (<String>) in Library [<String>], error: <String>. |
| 31:235 | Unloaded the media from drive slot (<String>) in Library [<String>]... |
| 31:236 | Unmounting the media from drive slot (<String>) in Library [<String>]... |
| 31:237 | Warning - Failed to unmount the media from drive slot (<String>) in Library [<String>], error: <String>. |
| 31:238 | Unmounted the media from drive slot (<String>) in Library [<String>]... |
| 31:239 | Finished detection on Library [<String>]. |
| 31:240 | Finished detection on MediaAgent [<String>]. |
| 31:241 | Starting device services on MediaAgent [<String>]... |
| 31:242 | -> Detected Library [<String>] is the same library of Library [<String>]. |
| 31:243 | Warning - Detection conflict: Library [<String>] and Library [<String>] are different libraries but both contain the drives with mounted medium. |
| 31:244 | ***** End Exhaustive Detection ***** |
| 31:245 | -> Drive [<String>] is already assigned to Library [<String>]. |
| 31:246 | -> Drive [<String>] is assigned the new drive number (<String>) to replace the old drive number (<String>) in Library [<String>]. |
| 31:247 | Warning - Failed to swap drive number on Drive [<String>], error: <String>. |
| 31:248 | Warning - Failed to set drive number (<String>) on Drive [<String>] in Library [<String>], error: <String>. |
| 31:249 | Update Drive [<String>] information... |
| 31:250 | Warning - Failed to update database on Drive [<String>], error: <String>. |
| 31:251 | -> Update Drive [<String>] SCSI address (<String>) to (<String>). |
| 31:252 | Warning - Drive [<String>] is misplaced into Library [<String>]. |
| 31:253 | Warning - Failed to deconfigure Drive [<String>], error: <String> |
| 31:254 | Warning - Failed to remove Drive [<String>] from Library [<String>], error: <String>. |
| 31:255 | -> Removed Drive [<String>] from Library [<String>]. |
| 31:256 | -> Drive [<String>] is assigned to the new drive number (<String>) in Library [<String>]. |
| 31:257 | Warning - Failed to assign Drive [<String>] the new drive number (<String>) in Library [<String>] : cannot find the MediaAgent for the drive. |
| 31:258 | -> Drive [<String>] is already configured in the Library [<String>]. |
| 31:259 | Warning - Drive [<String>] is configured in the wrong Library [<String>], please deconfigure this drive. |
| 31:260 | Warning - Internal error for assigning Drive [<String>] the new drive number (<String>) in Library [<String>]. |
| 31:261 | ***** Exhaustive Detection Report ***** |
| 31:262 | Devices on MediaAgent [<String>]: |
| 31:263 | Serial Number: |
| 31:264 | Drive Count: |
| 31:265 | Drive |
| 31:266 | -> Possible same libraries on other MediaAgents for Library [<String>]: |
| 31:267 | -> Possible same drives on other MediaAgents for Drive [<String>]: |
| 31:268 | ***** End Report ***** |
| 31:269 | Warning - Internal error for generating Exhaustive Detection report. |
| 31:270 | Stopping Library service for Library [<String>]... |
| 31:271 | Warning - Failed to get the current drive information. |
| 31:272 | Aborting... |
| 31:273 | -> Detected the medium in the drive, Fastrax Device ID = [<String>]. |
| 31:274 | Warning - Cannot assign Device ID [<String>] to Drive [<String>], error: <String>. |
| 31:275 | Warning - Failed to get the drive information for Device ID [<String>], error: <String>. |
| 31:276 | -> Assigned Device ID [<String>] to Drive [<String>]. |
| 31:277 | Fastrax ID [<String>] |
| 31:278 | Fastrax Drive ID [<String>] |
| 31:279 | Starting Library service for Library [<String>]... |
| 31:280 | Unknown message. |
| 31:281 | Failed to deconfigure Copy Manager [<String>]. There may be some Storage Policy or OSSV Policy still associated to this Copy Manager, error: <String> |
| 31:282 | This product no longer supports RSM-enabled libraries. Please disable RSM service before configuring the library. |
| 31:283 | The device is not connected through SAN switch at all. |
| 31:284 | Failed to discover the SAN path, error: <String>. |
| 31:285 | Communication with MediaAgent[<String>] failed. Please check that the product services on MediaAgent are running[<String>]. |
| 31:286 | Failed to get the library information, STK ACSLS libAttach service may not be running. |
| 31:287 | Device [<String>] has not been supported. Please call your vendor's support hotline for assistance. |
| 31:288 | -> Set Drive [<String>] Drive ID to [<String>]. |
| 31:289 | -> Drive [<String>] Drive ID [<String>] is correct. |
| 31:290 | Could not complete Drag & Drop action, the drive type [<String>] is different from the library drive type [<String>]. |
| 31:291 | The current library view is not up-to-date, please press 'F5' key to refresh the view. |
| 31:292 | The operation is not supported on this platform. |
| 31:293 | Configured |
| 31:294 | Not configured |
| 31:295 | Detected |
| 31:296 | Not detected - connection error |
| 31:297 | Not detected - device not found |
| 31:298 | Shared |
| 31:299 | No mount path |
| 31:300 | There is a drive with the same serial number already configured. |
| 31:301 | Cannot configure Drive [<String>] - No Drive ID is detected; try to detect the device again. |
| 31:302 | There is a library with the same serial number already configured. |
| 31:303 | Cannot change the Drive ID for Drive [<String>] to (<String>), it should be (<String>) according to the IP library server. |
| 31:304 | Cannot deconfigure DRU Host [<String>] because Disk Device [<String>] is still associated to it. |
| 31:305 | Folder |
| 31:306 | Volume |
| 31:307 | Network Sharing Disk Device |
| 31:308 | Cannot update the drive [<String>] information with the replaced drive [<String>] because the current drive type [<String>] is different from the new drive type [<String>]. |
| 31:309 | Updated the drive [<String>] information with the replaced drive [<String>] according to the drive identifiers from the library [<String>]. |
| 31:310 | Changed the Drive ID to [<String>] for the drive [<String>]. |
| 31:311 | Cannot change the host from [<String>] to [<String>] which is used from another library. |
| 31:312 | Cannot drag and drop the PnP Disk. |
| 31:313 | Please restart the MediaAgent [<String>] to disable the Windows TUR polling for tape drives/libraries. See Microsoft KB:842411 for more information. |
| 31:314 | Unknown |
| 31:315 | Generic |
| 31:316 | NetApp NearStore |
| 31:317 | Failed to create Disk Volume on MediaAgent [<String>]. |
| 31:318 | There is not enough space to create the drive. The minimum space to create the drive is [<String>] GB and the current available space is only [<String>] GB. |
| 31:319 | Creating Disk Volumes on MediaAgent [<String>]... |
| 31:320 | Disk Volume is created as drive [<String>] on MediaAgent [<String>]. |
| 31:321 | Failed to initialize VDS service. |
| 31:322 | Failed to query the hardware providers. |
| 31:323 | Failed to query the software providers. |
| 31:324 | Failed to find the provider. |
| 31:325 | Failed to query the provider properties. |
| 31:326 | Failed to query the Disk subsystem interface. |
| 31:327 | Failed to query disk subsystem. |
| 31:328 | Failed to query the maximum size for creating the LUN. |
| 31:329 | Failed to get asynchronous output. |
| 31:330 | Failed to create LUN during disk group configuration. |
| 31:331 | Failed to query the disk properties. |
| 31:332 | Failed to create the disk pack during disk group configuration. |
| 31:333 | Failed to add the disk during disk group configuration. |
| 31:334 | Failed to create the partition during disk group configuration. |
| 31:335 | Failed to access disk object during disk group configuration. |
| 31:336 | Failed to add the access path during disk group configuration. |
| 31:337 | Failed to format the disk during disk group configuration. |
| 31:338 | There is no enclosure found during disk group configuration. |
| 31:339 | There is more than one enclosure found during disk group configuration. |
| 31:340 | No device is configured. |
| 31:341 | Failed to re-enumerate the subsystem during disk group configuration. |
| 31:342 | Failed to query the drives for the subsystem during disk group configuration. |
| 31:343 | Failed to query the LUNs for the subsystem during disk group configuration. |
| 31:344 | Failed to set hot spare for the drive during disk group configuration. |
| 31:345 | failed to read virtual disk info file. |
| 31:346 | failed to write virtual disk info file. |
| 31:347 | Failed to query the volumes for the subsystem during disk group configuration. |
| 31:348 | Failed to create the directory for the mount point. |
| 31:349 | A volume was deleted or it disappeared. |
| 31:350 | A disk was unplugged, or a RAID controller unbound a LUN that was local to the host. |
| 31:351 | A partition was deleted. |
| 31:352 | A subsystem was disconnected. |
| 31:353 | A controller goes offline. |
| 31:354 | A drive behind a RAID controller was unplugged. |
| 31:355 | An external LUN was deleted. |
| 31:356 | Failed to load the library for SMCLI. |
| 31:357 | SMCLI not found(registry access error). |
| 31:358 | SMCLI error (popen error). |
| 31:359 | SMCLI error (Incorrect SMCLI command). |
| 31:360 | <String> mount path(s) configured on the disk library [<String>]. |
| 31:361 | There are some missing disk drives in disk array [<String>]. |
| 31:362 | Found some foreign volumes in disk array [<String>]. |
| 31:363 | Failed to load the Disk Type library for disk array. |
| 31:364 | Error reported by the Disk Type library: Storlib error. |
| 31:365 | Cannot communicate with CommServe [<String>], CommServe services may not be running. |
| 31:366 | Error reported by the Disk Type library: Registry key error. |
| 31:367 | Error reported by the Disk Type library: Pipe error. |
| 31:368 | Error reported by the Disk Type library: Internal error. |
| 31:369 | Remote Host Disk Device |
| 31:370 | The mount path folder cannot contain the reserved word [<String>]. |
| 31:371 | Path |
| 31:372 | Found a disk in foreign state at bus number [<Number>], slot number [<Number>] from disk array [<String>], please use Dell OpenManage Server Administrator to import or clear the foreign disk. |
| 31:373 | A drive was plugged in behind a RAID controller. |
| 31:374 | Failed to process the Disk Array Configuration file. Please check if the Disk Configuration Specifications are correct. |
| 31:375 | Found an unsupported <String> disk at bus number [<Number>], slot number [<Number>] from disk array [<String>]. |
| 31:376 | Failed to set the slot range. Please check if the MediaAgent services are running on the Library Server host. |
| 31:377 | Failed to get library information from the Library Server. Please check if the MediaAgent services are running on the Library Server host. |
| 31:378 | DD Boost |
| 31:379 | Data Server |
| 31:380 | Cannot deconfigure DiskDevice [<String>] for the primary MediaAgent because at least one MediaAgent is still associated with it. |
| 31:381 | Configured Device [<String>][<String>] is not detected on MediaAgent [<String>]. |
| 31:382 | Configured Device [<String>][<String>] is not detected for NDMP server [<String>] on MediaAgent [<String>]. |
| 31:383 | Fujitsu ETERNUS CS High End |
| 31:384 | A volume [<String>] was deleted or it was disappeared. |
| 31:385 | A disk [<String>] was unplugged, or a RAID controller unbound a LUN that was local to the host. |
| 31:386 | A subsystem [<String>] was disconnected. |
| 31:387 | A controller [<String>] goes offline. |
| 31:388 | A drive [<String>] behind a RAID controller was unplugged. |
| 31:389 | An external LUN [<String>] was deleted. |
| 31:390 | A drive [<String>] was plugged-in behind a RAID controller. |
| 31:391 | A disk [<String>] was inserted, or a RAID controller surfaced a LUN that is local to the host. |
| 31:392 | A new LUN [<String>] has been created. |
| 31:393 | Status of LUN [<String>] changed to available. |
| 31:394 | Status of LUN [<String>] changed to busy. |
| 31:395 | Status of LUN [<String>] changed to unavailable. |
| 31:396 | Status of LUN [<String>] changed to failed. |
| 31:397 | Health status of LUN [<String>] changed to healthy. |
| 31:398 | Health status of LUN [<String>] changed to rebuilding. |
| 31:399 | Health status of LUN [<String>] changed to failing. |
| 31:400 | Health status of LUN [<String>] changed to failing redundancy. |
| 31:401 | Health status of LUN [<String>] changed to Failed Redundancy. |
| 31:402 | Health status of LUN [<String>] changed to Failed Redundancy Failing. |
| 31:403 | Health status of LUN [<String>] changed to failed. |
| 31:404 | The status of drive [<String>] has changed to available and in-use. |
| 31:405 | The status of drive [<String>] changed to busy. |
| 31:406 | The status of drive [<String>] changed to physically present but has been removed from its RAID group or storage pool. |
| 31:407 | The status of drive [<String>] changed to failed. |
| 31:408 | The status of drive [<String>] changed to physically unplugged from the subsystem. |
| 31:409 | The health status of drive [<String>] changed to healthy. |
| 31:410 | The health status of drive [<String>] changed to failed. |
| 31:411 | The health status of drive [<String>] changed to replaced. |
| 31:412 | The health status of drive [<String>] changed to pending failure. |
| 31:413 | Configured new mount path folder [<String>] for library [<String>] on MediaAgent[<String>]. |
| 31:414 | LUN [<String>] is mounted to [<String>]. |
| 31:415 | Folder [<String>] is not available to mount the new LUN. Please check the folder and run the Disk Group Configuration again. |
| 31:416 | Failed to execute the command, error [<String>]. |
| 31:417 | Not enough free space available for the new volume from the disk array. |
| 31:418 | Failed to send the command to the disk array. |
| 31:419 | Failed to get the local host node from the disk array. |
| 31:420 | Failed to create the volume for the disk array. |
| 31:421 | IPv6 is not supported for Auto Discovery. |
| 31:422 | Failed to find the port for the local host from the disk array. |
| 31:423 | Failed to find the IP address for the disk array. |
| 31:424 | Failed to find enough drives for the volume pool in the disk array. |
| 31:425 | Wrong parameters for the command to execute. |
| 31:426 | Failed to find a valid volume group with enough free space, the number of drives for the volume group must be exact 6 or 12 in the disk array. |
| 31:427 | Failed to rename the volume in the disk array. |
| 31:428 | The device cannot be verified with MediaAgent [<String>], the device label is not matched. |
| 31:429 | Failed to logon as user [<String>] with error [<String>]. |
| 31:430 | Failed to logon as user [<String>] to access folder [<String>]. |
| 31:431 | Failed to logon as user [<String>] to write file [<String>]. |
| 31:432 | Failed to logon as user [<String>] to read file [<String>]. |
| 31:433 | [<String>] is not found. |
| 31:434 | Failed to check cloud server status, please make sure the provided service host URL, credential and bucket/container name are correct and with proper permissions. Also check the network connection to the cloud server is not blocked. Error = [<String>] |
| 31:435 | Failed to verify the device from MediaAgent [<String>] with the error [<String>]. |
| 31:436 | Commvault IBM i VTL |
| 31:437 | Could not complete function:[<String>] - invalid value for parameter:[<String>]. |
Media Manager Messages
| 63:1 | Please check following:n1. MediaAgent is Online;n2. Cable connection to MediaAgent is OK.n |
| 63:2 | Please close some programs or reboot your machine.n |
| 63:3 | Please check the following:n1. Communication Service is running on both CommServe and MediaAgentn2. Media & Library Manager is running on CommServe.n |
| 63:4 | Please check if drive is working properly. You may reset this drive to recover.n |
| 63:5 | Please wait until drive is ready or reset this drive.n |
| 63:6 | Please make sure that the optical disk used is compatible with the drive.n |
| 63:7 | Please check to see if the Library Arm Changer is functioning correctly.n |
| 63:8 | Please check to see if the Library Arm Changer and Drive is functioning correctly.n |
| 63:9 | Please import some spares to the library.n |
| 63:10 | Please check the GUI to turn drive pool online.n |
| 63:11 | Please check to see if library is still initializing.n |
| 63:12 | Please check to see if the library is ready.n |
| 63:13 | Please check the GUI to turn master drive pool online.n |
| 63:14 | Please import the media into library and try again.n |
| 63:15 | Please move the media back into regular slots in the library.n |
| 63:16 | Please import media into library and continue.n |
| 63:17 | Please check if the mount path is online and accessible. The offline reason shown on mount path properties will indicate why it's unavailable. |
| 63:18 | Please check if drives are installed for this library.n |
| 63:19 | Please check the following:n1. There are drives with compatible recording format to the media being read.n2. There are resources (Drives, Libraries, MediaAgents, etc.) that are online and ready to be used.nIf you still have an issue, please contact customer support. |
| 63:20 | Please define a failover candidate for allowing LAN-free backups.n |
| 63:21 | Please mark all the media in exported library and retry operation.n |
| 63:22 | Please check the following:n1. Media Mount Manager is still running on MediaAgent;n2. Connection between MediaAgent and CommServe is in good condition.n |
| 63:23 | Schedule a full inventory for this library from the CommCell Console.n |
| 63:24 | Please set the default media type for this library and enable the auto discover option. |
| 63:25 | Please wait for inventory to complete. |
| 63:26 | Please check to see if inventory is done. |
| 63:27 | Please enable auto cleaning for library. |
| 63:28 | The Request will be retried automatically. |
| 63:29 | Please wait until the device becomes idle. |
| 63:30 | Please enable the device from the Console. |
| 63:31 | Please mark the device as fixed. |
| 63:32 | Please check the following and retry the operation:n1. The Disk is visible from the MediaAgent.n2. This product's services are running on the MediaAgent.n |
| 63:33 | Make sure that the Device or Device Controller does not have any mount Paths or storage policies associated.n |
| 63:34 | Please make sure the requested media is in the library.n |
| 63:35 | There is no need to erase this media as it does not contain any recoverable data written by this product. |
| 63:36 | Make sure the Concurrency Limit is not zero or wait until other jobs are done using the Drive Pool. |
| 63:37 | Make sure no jobs are running for the Copy Manager. |
| 63:38 | Please retry the operation later.n |
| 63:39 | Please retry your operation later.n |
| 63:40 | Please check the Job Controller window or job reports to check the job status.n |
| 63:41 | This could be because of the job being timed out waiting for the mount request to complete. Or, the job was interrupted by another job or by user request. |
| 63:42 | Please check the following:n1. Media Mount Manager is still running on MediaAgent;n2. Connection between MediaAgent and CommServe is in good condition.n |
| 63:43 | Please check the library status on the Console.n |
| 63:44 | Please check the library and GUI to see the failure reason.n |
| 63:45 | Please check the drive status on the Console.n |
| 63:46 | Please check the drive and GUI to see the failure reason.n |
| 63:47 | Please check the following:n1. Media Mount Manager is still running on MediaAgent;n2. Connection between MediaAgent and CommServe is in good condition.n |
| 63:48 | Please check the following:n1. Media Mount Manager is still running on MediaAgent;n2. Connection between MediaAgent and CommServe is in good condition.n |
| 63:49 | Please check if there are any connection errors between CommServe and MediaAgent.n |
| 63:50 | Please check if the MediaAgent services are running on the drive controlling MediaAgent.n |
| 63:51 | Please check if the MediaAgent is online.n |
| 63:52 | Please check the following:n1. Media Mount Manager is still running on MediaAgent;n2. Connection between MediaAgent and CommServe is in good condition.n |
| 63:53 | The Library or Drive may have been reset or Drive is the process of unmounting.n |
| 63:54 | Please check the following:n1. Library and drive is functioning correctly.n2. Library and Drive management services are running.n3. All other MediaAgent services are running.n4. The time out period on the Expert Storage Configuration Properties Window in the CommCell Console.n5. Cleaning media in Assigned Media Group.n |
| 63:55 | Please import the media into the library and continue. If the media is still in the library, please perform a full scan on the library.n |
| 63:56 | Please retry the operation later.n |
| 63:57 | Please retry this job.n |
| 63:58 | Please retry this job.n |
| 63:59 | Please suspend all jobs, manually unload media from the drive and reset the library to continue.n |
| 63:60 | Please reset library to update library inventory.n |
| 63:61 | Please reset the drive to recover this media. |
| 63:62 | Please import this media into the library. |
| 63:63 | Please check the following:n1. MediaAgent is online.n2. All drives are online in the library.n3. Reset drives that are not online.n4. An Unmount required to free up the drive may have failed. |
| 63:64 | Please check the following:n1. MediaAgent is online.n2. Check if the library is online.n |
| 63:65 | Please check to see if the shared disk device is properly configured.n |
| 63:66 | Please check the following:n1. MediaAgent is online.n2. Drive is online.n |
| 63:67 | Check if the requested resource is still available.n |
| 63:68 | Please check the following:n1. Media Mount Manager is running on MediaAgent.n2. Connection between MediaAgent and Library Arm Changer or Drive are in good condition.n3. Library and Drive are working properly.n |
| 63:69 | Please retry your operation later. If the drive has a stuck volume, reset the drive to recover the media.n |
| 63:70 | Please import cleaning media into the library and perform discover cleaning media from the console.n |
| 63:71 | Please check the following:n1. If discovered media is not available in the library, please import new media.n2. All media inside library are probably in use, try again later.n |
| 63:72 | Please check the following to clean the drive:n1. If discovered cleaning media is not available in the library, please import cleaning media.n2. All cleaning media inside library are probably in use, try again later.n |
| 63:73 | All cleaning media for the library is exported. Please import a cleaning media.n |
| 63:74 | There are no cleaning media groups in the library. Please create a cleaning group and import cleaning media.n |
| 63:75 | There are no discovered cleaning media in the library. Please import cleaning media.n |
| 63:76 | All cleaning media inside the library are probably in use. Try again later.n |
| 63:77 | Please make sure that the device is seen by the Operating System.n |
| 63:78 | Please check to see if the Library configuration is correct. Verify the drive ordering in the library matches that in the Software.nMake sure that you have not switched barcodes on media.nIf problem persists, please call your vendor's support hotline. |
| 63:79 | Please check to see if the Library configuration is correct. Make sure that you have not accidentally moved media from a different CommCellnIf problem persists, please call your vendor's support hotline. |
| 63:80 | Make sure that no jobs that are using the drive pool are running.n |
| 63:81 | Do not kill the inventory process while it is searching for media. |
| 63:82 | Please execute a full inventory on this library.n |
| 63:83 | Please make sure there are enough resources available for this application restore.n |
| 63:84 | Please wait until the Blind Library Inventory completes. |
| 63:85 | Make sure that at least one free mount point is available on the MediaAgent. |
| 63:86 | Make sure that the directory is accessible. |
| 63:87 | Please make sure that no other device explorer applications like SAN Explorer are running on the machine.n |
| 63:88 | Please clean the drive. For libraries with a medium changer, system will automatically clean the drive if the cleaning options are enabled. For standalone drives, please clean the drive by inserting a cleaning media into the drive. |
| 63:89 | Please enter a different mount path. |
| 63:90 | Please check if Job Manager Service is running.n |
| 63:91 | Please make sure that the proper media has been inserted into the drive and restart the current job or create a new job.n |
| 63:92 | Please check the following:n1. The media in the drive may be full and you need to insert a spare media.n2. You have a wrong media in the drive and the job needs a different media.n |
| 63:93 | The Library may be starting up or in the process of doing an inventory. Please wait until inventory is complete.n |
| 63:94 | Please make sure the door is closed and locked, the arm changer is not stuck, and there are no media stuck halfway in slots and drives.n |
| 63:95 | Please make sure there are no errors on the Front Panel. Try running library diagnostics to make sure that the library is functioning correctly.n |
| 63:96 | Please make sure the SCSI IDs for the Library are correct.n |
| 63:97 | Please wait until the Library has finished doing the inventory and come back online.n |
| 63:98 | Please remove all media from mail slots and update their export location.n |
| 63:99 | Please check the following:n1. If destination is a drive, remove the media manually from the drive and reset the drive.n2. If destination is a slot, remove the media to a different slot and reset library.n3. Make sure SCSI IDs for drives are correct. Use Expert Storage Configuration to check them.n4. Validate all drives after checking SCSI IDs.n |
| 63:100 | Please check the following:n1. Try resetting the library.n2. Make sure SCSI IDs are correct. Use Expert Storage Configuration program to check them. Please validate drives after checking the SCSI IDs.n |
| 63:101 | Cleaning media has been identified in a regular media group. This media will be moved to the cleaning media pool.n |
| 63:102 | The drive may not be accessible from the MediaAgent.n |
| 63:103 | Make sure the arm changer can move freely and is not blocked by media stuck halfway in slots or drives.n |
| 63:104 | Please try resetting the drive.n |
| 63:105 | Please make sure that the MediaAgent services are running. n |
| 63:106 | Please make sure that barcode on the media has not been switched with any other media. n |
| 63:107 | Please make sure that all the media in the library have valid readable barcodes. n |
| 63:108 | Please make sure that there are free slots in the library. In case there are no free slots, please export some media. n |
| 63:109 | Please wait until the Removable Storage Management (RSM) service completes inventory of the library. n |
| 63:110 | Please re-initialize the device, before attempting any operation. n |
| 63:111 | Please close the door of the library. n |
| 63:112 | Please make sure the media is compatible with this hardware configuration. n |
| 63:113 | Please ensure that the file is present in the given path and is accessible. n |
| 63:114 | Please ensure that the path is correct and accessible. n |
| 63:115 | Please ensure that the device is accessible. n |
| 63:116 | Please ensure that the device is accessible. n |
| 63:117 | Please ensure that the length of the path is not more than the length supported by the Operating System. n |
| 63:118 | Please configure at least one access Node for the Centera Cluster. n |
| 63:119 | Unexpected application logic error occurred. Please call your vendor's support hotline. |
| 63:120 | Unexpected Centera hardware or API error generated. lease try again. If the problem persists, please call your vendor's support hotline. |
| 63:121 | Communication to the configured. Centera Access node failed.nPlease verify the LAN connection and try again. |
| 63:122 | Reached the maximum capacity of the configured Centera Cluster. Please either delete or prune some blobs, orncontact hardware vendor for any further resolution. |
| 63:123 | Please make sure that the media selected is a spare media. |
| 63:124 | Please stop all applications which access or monitor tape drives that do not belong to the product suite. |
| 63:125 | There is a drive access path change. Please run SCSI Detection on the MediaAgents. |
| 63:126 | Make sure that there is at least enough space on the Mount Path as set on the Library Property. |
| 63:127 | Check the mount path level property to make sure that the right value is set for Maximum Data to Write. |
| 63:128 | Make sure that there is at least enough free space to satisfy the reserve space value set on the Library Property. |
| 63:129 | Please retry operation and select correct data path. |
| 63:130 | Please check to see that all Storage Policy Copies have at least one data path defined. |
| 63:131 | Please move this media into regular scratch pool to use. |
| 63:132 | Please move this media into regular scratch pool to use. |
| 63:133 | Please Unpin the media. |
| 63:134 | Please check if device is being used by another process. |
| 63:135 | Please check if the MediaAgent is online. |
| 63:136 | Please contact your vendor's support hotline to purchase this license. |
| 63:137 | Please contact your vendor's support hotline to purchase this license. |
| 63:138 | Please contact your vendor's support hotline to purchase this license. |
| 63:139 | Please contact your vendor's support hotline to purchase this license. |
| 63:140 | Please contact your vendor's support hotline to purchase this license. |
| 63:141 | Please contact your vendor's support hotline to purchase this license. |
| 63:142 | Please retry the operation. |
| 63:143 | Please retry the operation. |
| 63:144 | Please rescan the disks using this product's Volume Explorer on the MediaAgent and retry the operation. |
| 63:145 | Please contact your vendor's support hotline to purchase this license. |
| 63:146 | Please stop all applications accessing the disks on this machine including Windows Explorer. |
| 63:147 | Please verify the media to make sure that the data is readable. |
| 63:148 | Please verify the media to make sure that the data is readable. |
| 63:149 | Data on media may be unreadable. Media will be marked bad. |
| 63:150 | Data on media may be unreadable. Media will be marked bad. |
| 63:151 | Data on media may be unreadable. Media will be marked bad. |
| 63:152 | To overwrite this tape, disable the 'prevent use of tapes from a different backup vendor' option from library properties. |
| 63:153 | Data on media may be unreadable. Media will be marked bad. |
| 63:154 | Data on media may be unreadable. Media will be marked bad. |
| 63:155 | Data on media may be unreadable. Media will be marked bad. |
| 63:156 | Data on media may be unreadable. Media will be marked bad. |
| 63:157 | Data on media may be unreadable. Media will be marked bad. |
| 63:158 | Data on media may be unreadable. Media will be marked bad. |
| 63:159 | Please verify that the Media and Library Manager service is running on the CommServe. |
| 63:160 | Please verify that the Media and Library Manager service is running on the CommServe. |
| 63:161 | Please verify that the Media and Library Manager service is running on the CommServe. |
| 63:162 | Please verify that the Media and Library Manager service is running on the CommServe. |
| 63:163 | Please wait until this operation has been completed. |
| 63:164 | Check to see that the CommServe name in the database and registry match. |
| 63:165 | Please ensure there is a drive controller for this drive which is online and supports SCSI2 Reserve/Release. |
| 63:166 | Please ensure that this drive can perform operations from other MediaAgents. |
| 63:167 | Please verify by checking the library and console to see the failure reason and mark the library as fixed. |
| 63:168 | Please restart services on this MediaAgent. |
| 63:169 | Please wait either until the reservation is released for that drive or issue a release SCSI-2 Reservation request from the Console. |
| 63:170 | Please wait until the operation completes. Otherwise, reset the drive and try again. |
| 63:171 | Please enable write access for the Media Agent. |
| 63:172 | Please use the following troubleshooting utilities n1.TapeTool for Tape device-related problems.n2.LibraryTool for Library related problems n provided in the MediaAgent's installation folder to perform diagnostics on this device. |
| 63:173 | Please contact your vendor's support hotline. |
| 63:174 | Please contact your vendor's support hotline. |
| 63:175 | Please contact your vendor's support hotline. |
| 63:176 | Please check the MediaAgent level option to ensure that the correct value is set. |
| 63:177 | This cleaning media cannot be used for any more drive cleaning operations. Please export and remove this media from the library. |
| 63:178 | Please delete the Storage or OSSV Policy that is using this Copy Manager and retry the operation. |
| 63:179 | Please use the troubleshooting utility provided in the software's installation folder to perform diagnostics on this device. |
| 63:180 | Please check if the media has a valid barcode. |
| 63:181 | Please make sure that drive supports SCSI-2 Reserve/Release Commands and that its not reserved by any third-party application. |
| 63:182 | Please make sure that HDS HiCommand Device Manager is running properly and it can see Disk Array Subsystem. Also make sure that MediaAgent has networked connectivity to the Host where HiCommand Device Manager is running. If Hitachi SVP or Hitachi Storage Navigator software is running in Modify mode, please change the mode back to View Mode so that DRU API works next time. If you have made any Configuration changes on array subsystem without using HiCommand Device Manager Server, please use refresh subsystem option from HDvM for the array subsystem so that DRU API works next time. Always use HDvM to make configuration changes on your array subsystem. |
| 63:183 | Please contact your vendor's support hotline. |
| 63:184 | Please contact your vendor's support hotline. |
| 63:185 | Please contact your vendor's support hotline. |
| 63:186 | Please contact your vendor's support hotline. |
| 63:187 | Please contact your vendor's support hotline. |
| 63:188 | Please contact your vendor's support hotline. |
| 63:189 | Please contact your vendor's support hotline. |
| 63:190 | Please make sure that drive supports SCSI-2 Reserve/Release Commands and that its not reserved by any third-party application. |
| 63:191 | Please retry this job. |
| 63:192 | Please check if device supports SCSI-3 protocol. |
| 63:193 | Please select the option to use media from different scratch pool. |
| 63:194 | If the issue persists, please upload log files from CommServe, MediaAgent and Client and contact your vendor's support hotline with the job ID of the failed job. |
| 63:195 | Please see if the Drivers/HBA needs an upgrade. If the hardware does not support the current block size, change Block size on the current data path to a lower value and perform the operation on a new media. |
| 63:196 | If this error is to be ignored, check the option: - Overwrite Media when content verification fails - on the library properties. CAUTION: Checking this option may cause data loss if the media has valid data. |
| 63:197 | Please do a reset library operation if this condition persists. |
| 63:198 | If the job is performed on a tape drive, check if the drive needs cleaning. |
| 63:199 | Try unmounting the media in the drive from the front panel of the library. |
| 63:200 | Please check if the SIDB process is running on the MediaAgent. |
| 63:201 | Please check if the CVD log on the MediaAgent is running. |
| 63:202 | Please contact your vendor's support hotline. |
| 63:203 | Please check if the SIDB.exe and its dependencies are present on the target MediaAgent. |
| 63:204 | Please contact your vendor's support hotline. |
| 63:205 | Please check whether there are any network errors in the Windows event log. |
| 63:206 | Please restart the services on the target MediaAgent. |
| 63:207 | Please contact your vendor's support hotline. |
| 63:208 | Please contact your vendor's support hotline. |
| 63:209 | Please contact your vendor's support hotline. |
| 63:210 | Please contact your vendor's support hotline. |
| 63:211 | Please contact your vendor's support hotline. |
| 63:212 | Please check the following:n1)if the SIDB process on the target MediaAgent is still running.n2)Whether there are any network errors in the Windows event log. |
| 63:213 | Please check whether the user name/password provided for the DDB path is correct. |
| 63:214 | Please contact your vendor's support hotline. |
| 63:215 | Please contact your vendor's support hotline. |
| 63:216 | Please check whether the SIDB index path is accessible and the index files have not been deleted. |
| 63:217 | Please check whether the SIDB index path is accessible. |
| 63:218 | Please contact your vendor's support hotline. |
| 63:219 | Please deconfigure the drive pool associated with this NDMP Host and try again. |
| 63:220 | Please free up the disk space on the SIDB index. |
| 63:221 | Please check if current spare group is using a data path. |
| 63:222 | Please do the following: 1) Remove the media from the mail slots if the slots are occupied. 2) Check the mail slots physically and try the operation again. |
| 63:223 | Please check its visibility from the MediaAgents and run storage validation to verify that its functional. |
| 63:224 | Please check to see if the Operating System can see the devices correctly. |
| 63:225 | The data on this mount path used by the deduplication DB could be referenced by other backup jobs. The mount path can be deleted only when all associated storage policies/copies with deduplication enabled are deleted. See Deduplication DBs tab on the property dialog of this mount path to view the list of DDBs and storage policies/copies. |
| 63:226 | SCSI command failed as the device is SCSI reserved from another system. |
| 63:227 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:228 | Please mark this medium full and retry the operation. |
| 63:229 | Please mark this medium full and retry the operation. |
| 63:230 | Please mark this medium full and retry the operation. |
| 63:231 | Please mark this medium full and retry the operation. |
| 63:232 | There is no more data found on this medium. Please check if this is the correct medium for the intended operation. |
| 63:233 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:234 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:235 | Please clean the drive and retry this operation. |
| 63:236 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:237 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:238 | Please mark the medium bad and retry the operation. |
| 63:239 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:240 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:241 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:242 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:243 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:244 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:245 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:246 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:247 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:248 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:249 | Please close the I/E port and retry the operation. |
| 63:250 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:251 | Please close the I/E port and retry the operation. |
| 63:252 | Please change the mode and retry the operation. |
| 63:253 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:254 | Please change the mode and retry the operation. |
| 63:255 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:256 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:257 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:258 | Please check the connections and try the operations again. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:259 | Please check the connections and try the operations again. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:260 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:261 | See if the recording format on the media is compatible with the Drive. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:262 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:263 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:264 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:265 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:266 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:267 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:268 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:269 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:270 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:271 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:272 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:273 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:274 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:275 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:276 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:277 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:278 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:279 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:280 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:281 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:282 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:283 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:284 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:285 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:286 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:287 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:288 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:289 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:290 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:291 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:292 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:293 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:294 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:295 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:296 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:297 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:298 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:299 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:300 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:301 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:302 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:303 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:304 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:305 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:306 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:307 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:308 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:309 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:310 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:311 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:312 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:313 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:314 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:315 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:316 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:317 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:318 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:319 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:320 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:321 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:322 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:323 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:324 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:325 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:326 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:327 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:328 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:329 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:330 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:331 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:332 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:333 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:334 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:335 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:336 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:337 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:338 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:339 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:340 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:341 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:342 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:343 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:344 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:345 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:346 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:347 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:348 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:349 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:350 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:351 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:352 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:353 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:354 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:355 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:356 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:357 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:358 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:359 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:360 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:361 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:362 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:363 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:364 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:365 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:366 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:367 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:368 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:369 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:370 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:371 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:372 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:373 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:374 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:375 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:376 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:377 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:378 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:379 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:380 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:381 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:382 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:383 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:384 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:385 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:386 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:387 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:388 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:389 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:390 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:391 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:392 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:393 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:394 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:395 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:396 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:397 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:398 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:399 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:400 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:401 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:402 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:403 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:404 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:405 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:406 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:407 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:408 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:409 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:410 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:411 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:412 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:413 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:414 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:415 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:416 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:417 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:418 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:419 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:420 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:421 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:422 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:423 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:424 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:425 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:426 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:427 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:428 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:429 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:430 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:431 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:432 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:433 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:434 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:435 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:436 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:437 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:438 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:439 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:440 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:441 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:442 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:443 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:444 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:445 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:446 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:447 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:448 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:449 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:450 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:451 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:452 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:453 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:454 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:455 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:456 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:457 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:458 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:459 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:460 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:461 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:462 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:463 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:464 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:465 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:466 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:467 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:468 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:469 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:470 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:471 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:472 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:473 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:474 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:475 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:476 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:477 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:478 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:479 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:480 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:481 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:482 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:483 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:484 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:485 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:486 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:487 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:488 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:489 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:490 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:491 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:492 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:493 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:494 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:495 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:496 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:497 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:498 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:499 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:500 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:501 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:502 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:503 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:504 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:505 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:506 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:507 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:508 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:509 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:510 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:511 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:512 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:513 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:514 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:515 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:516 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:517 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:518 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:519 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:520 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:521 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:522 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:523 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:524 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:525 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:526 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:527 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:528 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:529 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:530 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:531 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:532 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:533 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:534 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:535 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:536 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:537 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:538 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:539 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:540 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:541 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:542 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:543 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:544 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:545 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:546 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:547 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:548 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:549 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:550 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:551 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:552 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:553 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:554 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:555 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:556 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:557 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:558 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:559 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:560 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:561 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:562 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:563 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:564 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:565 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:566 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:567 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:568 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:569 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:570 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:571 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:572 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:573 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:574 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:575 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:576 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:577 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:578 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:579 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:580 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:581 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:582 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:583 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:584 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:585 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:586 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:587 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:588 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:589 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:590 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:591 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:592 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:593 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:594 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:595 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:596 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:597 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:598 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:599 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:600 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:601 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:602 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:603 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:604 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:605 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:606 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:607 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:608 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:609 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:610 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:611 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:612 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:613 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:614 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:615 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:616 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:617 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:618 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:619 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:620 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:621 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:622 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:623 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:624 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:625 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:626 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:627 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:628 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:629 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:630 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:631 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:632 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:633 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:634 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:635 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:636 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:637 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:638 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:639 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:640 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:641 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:642 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:643 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:644 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:645 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:646 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:647 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:648 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:649 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:650 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:651 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:652 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:653 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:654 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:655 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:656 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:657 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:658 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:659 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:660 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:661 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:662 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:663 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:664 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:665 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:666 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:667 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:668 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:669 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:670 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:671 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:672 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:673 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:674 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:675 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:676 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:677 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:678 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:679 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:680 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:681 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:682 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:683 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:684 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:685 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:686 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:687 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:688 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:689 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:690 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:691 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:692 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:693 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:694 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:695 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:696 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:697 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:698 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:699 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:700 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:701 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:702 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:703 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:704 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:705 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:706 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:707 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:708 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:709 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:710 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:711 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:712 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:713 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:714 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:715 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:716 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:717 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:718 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:719 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:720 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:721 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:722 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:723 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:724 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:725 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:726 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:727 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:728 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:729 | Please retry this operation. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:730 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:731 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:732 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:733 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:734 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:735 | Please use another media. If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:736 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:737 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:738 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:739 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:740 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:741 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:742 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:743 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:744 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:745 | Please verify there are no VaultTracker actions running and retry the operation. |
| 63:746 | Please verify with your hardware vendor. If device does not support hardware encryption, turn off the hardware encryption feature from GUI Console and retry the operation. |
| 63:747 | Please make sure that your device supports hardware encryption and its functioning correctly. |
| 63:748 | Please make sure that your device supports hardware encryption and its functioning correctly. |
| 63:749 | For an inline copy, it must have a datapath using the same MediaAgent as is being used for the primary copy. |
| 63:750 | Please make sure that Mount Path is configured correctly. |
| 63:751 | Check the storage connectivity from the MediaAgent. If this issue persists even after rebooting the MediaAgent, please contact customer support. |
| 63:752 | Import this media into the correct library and retry the operation. |
| 63:753 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:754 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:755 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:756 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:757 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:758 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:759 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:760 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:761 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:762 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:763 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:764 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:765 | If this error is persistent, check if there are any visible hardware errors reported by the device or Operating System logs. Please contact your hardware vendor. |
| 63:766 | Please unmount the snapshot and retry the operation. |
| 63:767 | Please change the host for the Deduplication store and retry the operation. |
| 63:768 | Please contact your vendor's support hotline to purchase this license. |
| 63:769 | Review the Library's Mount Path Allocation Policy. |
| 63:770 | Please check the following and retry the operation:n1. This product's services are running on the MediaAgent.n2. Enable the device from the Console.n |
| 63:771 | Please use another media. |
| 63:772 | Please check the following:n1. MediaAgent is online.n2. Check if the library is online.n |
| 63:773 | Please check the drive status on the Console.n |
| 63:774 | Please wait ?n(1) Library Server is yet to process the reservation request for this job.n(2) Drives requested may currently be in use by other CommCell(s).nIf there are drives available but not yet allocated for this job for a long period, please contact customer support |
| 63:775 | Please check all the DeDuplication store partitions and make sure they are not in offline state. |
| 63:776 | Possible causes: MediaAgent or Access Path for some DeDuplication store partitions may be offline. Or some of the partitions may be in an offline state. |
| 63:777 | Please contact your Account Team to obtain additional licenses. |
| 63:778 | Please disable client side deduplication on client or storage policy copy properties, or upgrade client to proper release, or use different storage policy copy for backup. |
| 63:779 | Please upgrade the source MediaAgent or use different copy for Auxiliary copy. |
| 63:780 | Please contact your vendor's support hotline to purchase this license. |
| 63:781 | Please wait for the other job to complete and retry this operation. |
| 63:782 | Job is waiting for failover to a new deduplication store. |
| 63:783 | Please launch the DeDuplication DB Reconstruction job. |
| 63:784 | Please wait till the DeDuplication DB Reconstruction job reconstructs the partitions. |
| 63:785 | Please verify the permissions on the mount path and retry the operation. |
| 63:786 | Please disable the inline copy feature on the destination copy and retry the operation. |
| 63:787 | Please upgrade the MediaAgent such that the DDB and datapath MediaAgents are on the same version. |
| 63:788 | Please check schedule and schedule policy for current job and make sure the selected job data path option is also part of the Storage Policy copy data paths. |
| 63:789 | Please upgrade the MediaAgent to the current version. |
| 63:790 | Please check the Drive properties on the console and verify if it is marked offline for maintenance. |
| 63:791 | Please check the MediaAgent properties on the console and verify if it is marked offline for maintenance. |
| 63:792 | Please check the Library properties on the console and verify if it is marked offline for maintenance. |
| 63:793 | Please check the library, MediaAgent and drive pool of LAN-free data paths are online and available for write. |
| 63:794 | Please check device stream configuration to this Storage Policy. |
| 63:795 | Please check the jobs currently running to this Storage Policy. Current job will run once a stream becomes available. |
| 63:796 | Please check the higher priority job currently running to this Storage Policy. Current job will run once running job finish. |
| 63:797 | Please check jobs from other schedule(s) running to this Storage Policy. Current job will run once more resources become available or running jobs finish. |
| 63:798 | Please check jobs using current Data Path of this Storage Policy. Current job will run once more resources become available or running jobs finish. |
| 63:799 | Please check stream usage of current job and jobs running to this Storage Policy. Waiting streams of current job will run once more stream becomes available. |
| 63:800 | Please check stream usage of current SILO job. Increase number of Combined Source Data Streams option on the SILO copy will allow more streams to run concurrently. |
| 63:801 | Please check the following:n1. There are drives with compatible recording format to the media being written.n2. There are enough available drives in the drive pool for this job. n If the issue persists, please contact customer support. |
| 63:802 | Please enable the desired data path from the Data Paths tab of the Storage Policy Copy properties. |
| 63:803 | Please check to see if the mount path is online and configured properly. Also verify if the mount path is accessible from the desired MediaAgents by reviewing the Sharing tab of mount path properties. |
| 63:804 | Please review the drive allocation settings for the Master Drive Pool and Drive Pool. |
| 63:805 | Please check MediaAgent property and make sure it has installed properly with valid MediaAgent license. |
| 63:806 | Please check storage policy property for Content Indexing information. |
| 63:807 | Please check the status of Search Engines in current cloud and verify if there is available one to use. n If the issue persists, please contact customer support. |
| 63:808 | Please check the library, MediaAgent and drivepool of default data paths are online and available for write. |
| 63:809 | The requested drives could be in use for other operations by another CommCell. Please check the drive status on the console. |
| 63:810 | Please check the library, MediaAgent and drivepool of subclient data paths are online and available for write. |
| 63:811 | Please review the Maximum Number of Parallel Data Transfer operations setting for the MediaAgent. |
| 63:812 | Please upgrade the source MediaAgent or use different copy for Auxiliary copy. |
| 63:813 | Please upgrade the MediaAgent such that the source and destination MediaAgents are on the same version. |
| 63:814 | Please check to see if the mount path is online and accessible from the desired MediaAgents. |
| 63:815 | Please upgrade the MediaAgent or Search Engine and make sure they are on the same version. |
| 63:816 | Please upgrade the Search Engines from current cloud to the same version. |
| 63:817 | Please check the library for details. |
| 63:818 | Please upgrade the MediaAgent and make sure source and destination MediaAgent for synthetic full job are on the same version. |
| 63:819 | Please review the Maximum Number of Parallel Data Transfer operations setting for deduplication database under Resource Manager tab in the Media Manager configuration. |
| 63:820 | Please upload log files from CommServe, DDB MediaAgent and contact your vendor's support hotline with the DDB reconstruction job ID. |
| 63:821 | Please review the deduplication database configuration. |
| 63:822 | Please check deduplication database validation job progress for current storage policy and wait for it to finish. |
| 63:823 | Please wait for job to retry. |
| 63:824 | Please check the following:n1. There are drives with compatible recording format to the media being read.n2. There are resources (Drives, Libraries, MediaAgents, etc.) that are online and ready to be used.n3. If you want to use alternative MediaAgent then set 'Allow restore jobs to use alternative MediaAgent and Drive Pool to access required media' to 1 in Control Panel/MediaManagement Configuration/Resource Manager Configuration.nIf you still have an issue, please contact customer support. |
| 63:825 | Please check the desired data path from the Data Paths tab of the Storage Policy Copy properties. |
| 63:826 | Please wait until Blackout Window completes on MediaAgent. |
| 63:827 | If you want to use older version MediaAgents then uncheck 'Use Scalable Resource Allocation' in job options. |
| 63:828 | Take VG out of cluster and make it active again. Retry hardware revert. |
| 63:829 | Please check the Resource Manager configuration on concurrent job limit on one physical node (client). |
| 63:830 | Please use 'zfs list -o name,zoned,mountpoint -r <datasetpath>' to check if ZFS Dataset is marked zoned. For more information check Oracle documentation 'Understanding the zoned Property'. |
| 63:831 | Please check Server group capacity quota settings. |
| 63:832 | Please turn off inline backup on storage policy copy and then continue the backup operation. |
| 63:833 | Please enter a unique Drive Pool Name. |
| 63:834 | The virtual machine is getting powered on, it may take few minutes. |
| 63:835 | Please turn off inline backup on storage policy copy and then continue the backup operation. |
| 63:836 | The index cache may be low on space or disabled. Please check the offline reason in Catalog tab of MediaAgent properties. |
| 63:837 | Make sure no jobs are using the drives in this master pool. |
| 63:838 | Please check the following:n1. Specified drive is online and ready to be used.n2. Specified drive recording format is compatible and has access to the media being read.nIf you still have an issue, please contact customer support. |
| 63:839 | Please check the following:n1. Specified drive is online and ready to be used.n2. Specified drive recording format is compatible and has access to the media being read.n3. If you want to use alternative MediaAgent then set 'Allow restore jobs to use alternative MediaAgent and Drive Pool to access required media' to 1 in Control Panel/MediaManagement Configuration/Resource Manager Configuration.nIf you still have an issue, please contact customer support. |
| 63:840 | Please check the following:n1. Specified drive pool is online and ready to be used.n2. Specified drive pool has drives with compatible recording format and has access to the media being read.nIf you still have an issue, please contact customer support. |
| 63:841 | Please check the following:n1. Specified drive pool is online and ready to be used.n2. Specified drive pool has drives with compatible recording format and has access to the media being read.n3. If you want to use alternative MediaAgent then set 'Allow restore jobs to use alternative MediaAgent and Drive Pool to access required media' to 1 in Control Panel/MediaManagement Configuration/Resource Manager Configuration.nIf you still have an issue, please contact customer support. |
| 63:842 | Please check the following:n1. Specified MediaAgent is online and ready to be used.n2. Specified MediaAgent has drives with compatible recording format and has access to the media being read.nIf you still have an issue, please contact customer support. |
| 63:843 | Please check the following:n1. Specified MediaAgent is online and ready to be used.n2. Specified MediaAgent has drives with compatible recording format and has access to the media being read.n3. If you want to use alternative MediaAgent then set 'Allow restore jobs to use alternative MediaAgent and Drive Pool to access required media' to 1 in Control Panel/MediaManagement Configuration/Resource Manager Configuration.nIf you still have an issue, please contact customer support. |
| 63:844 | Make sure that there is at least enough free space to satisfy the low watermark set on the Library Property. |
| 63:845 | Please review the Maximum Number of Parallel Data Transfer operations setting for the client. |
| 63:846 | Please review the configuration on the maximum number of running streams from Commserver. Reservation will be put on hold temporarily until current active streams are released. |
| 63:847 | Disable and stop lvmetad: 'systemctl stop lvm2-lvmetad.service' 'systemctl disable lvm2-lvmetad.service' 'systemctl stop lvm2-lvmetad.socket' 'systemctl disable lvm2-lvmetad.socket' 'edit and update /etc/lvm/lvm.conf to set use_lvmetad = 0' |
| 63:848 | Please ensure that the device for DDB path is mounted. |
| 63:849 | Please check the properties of disk library for current hybrid cloud library and make sure it is available to use. |
| 63:850 | Please review the associated Schedule or Schedule Policy and migrate to an Automatic Schedule to better balance the load against your data path. If this is not an option, you can leverage the 'JMSynthFullJobHighWaterMark' to increase the limit until you are able to transition to an Automatic Schedule. |
| 63:851 | Please provide Library Management (or) Library Administration permission at Library level to the user. |
| 63:852 | Please wait until blackout window completes. |
| 63:853 | Check data access node(s) set on client |
| 63:854 | Please check subclient properties and make sure correct storage policy is assigned for backup. |
| 63:855 | Apply license again and accept terms and conditions. |
| 63:856 | N/A |
| 63:857 | Check the manually retained jobs and change retention if required. |
| 63:858 | Verify retention criteria and if the clients are running new full jobs. |
| 63:859 | Older snaps could be retained if new snap jobs are not running. Please check snap job schedule. |
| 63:860 | Please check the retention criteria of database backups. |
| 63:861 | Run backup copy job or disable these jobs for backup copy operation. |
| 63:862 | N/A |
| 63:863 | There could be newer jobs that require older jobs due to SQL chaining. Needs analysis of the jobs that are holding these. |
| 63:864 | Please check the retention criteria of database backups. |
| 63:865 | Check if there are running catalog jobs. |
| 63:866 | Check if DDB backups are running on the store. |
| 63:867 | N/A |
| 63:868 | N/A |
| 63:869 | Please check jobs pending auxiliary copy and either run auxiliary copy jobs or manually disable these jobs. |
| 63:870 | Please check the dependent data jobs retention criteria. |
| 63:871 | Please check backup schedules and verify full/synthetic full jobs are scheduled and running successfully as applicable. |
| 63:872 | SILO pruning needs to be checked. |
| 63:873 | Snap mirror jobs are pruned along with the source snap copy jobs. Check retention of source snap jobs. |
| 63:874 | Verify that subclients run a full job in the new storage policy to clear the jobs in old storage policy. |
| 63:875 | There could be newer jobs that require older jobs due to SQL chaining. Needs analysis of the jobs that are holding these. |
| 63:876 | Verify that the client is active and true up jobs are running. |
| 63:877 | Verify retention criteria on VM jobs. |
| 63:878 | Please check the Data Aging schedule and verify a full Data Aging job is run at regular intervals. |
| 63:879 | Please check backup schedules and verify full/incremental/synthetic full jobs are scheduled and running successfully as applicable. |
| 63:880 | Check retention criteria of jobs in the associated tapes. |
| 63:881 | Please check Mount Path properties and make sure there is at least one device controller with r/w access. |
| 63:882 | Media Manager has auto-correction logic to set this. Verify Media Manager process is running properly. If your previous pruner MediaAgent went offline, it might take some time for the Media Manager to reset a new pruner. |
| 63:883 | Media Manager has auto-correction logic to set this. Verify Media Manager process is running properly. If your previous pruner device controller went offline, it might take some time for the Media Manager to reset a new pruner. |
| 63:884 | Media Manager has auto-correction logic to set this. Verify Media Manager process is running properly. If your previous pruner data path went offline, it might take some time for the Media Manager to reset a new pruner. |
| 63:885 | This Mount Path has no online device controller that is enabled. Please check the Mount Path properties and status of the MediaAgents that can access this Mount Path. |
| 63:886 | Please check Data Pruning Blackout window on associated MediaAgents and see if you need a reconfiguration. |
| 63:887 | Please check the status of this Mount Path and verify if the MediaAgents are online and the physical storage is accessible. |
| 63:888 | Please enable the Mount Path for pruning to continue. |
| 63:889 | Please check the status of this Mount Path and verify if the MediaAgents are online and the physical storage is accessible. |
| 63:890 | If micro pruning is disabled for cloud Mount Path, pruning of dedup volumes will not happen until the store is sealed and all jobs in the store get aged. Please enable micro pruning. |
| 63:891 | Please check the status of this Mount Path and verify if the MediaAgents are online and the physical storage is accessible. |
| 63:892 | Please check the Mount Path property and enable pruning of aged data. |
| 63:893 | Check the datapaths on associated storage policy copy and make sure they are enabled and the Media Agents have device controllers with r/w access to the Mount Path. |
| 63:894 | Backup activity is disabled on this subclient which can cause older data to be retained under cycles criteria. Please evaluate activity control on the subclient/client. |
| 63:895 | Please check if there are scheduled backups for this subclient and if the schedules are running as expected. |
| 63:896 | Media management configuration parameter to 'ignore cycle retention on backup activity disabled subclients' is not enabled. Enabling this config param may help clean up older jobs on this subclient. |
| 63:897 | Media management configuration parameter to 'ignore cycle retention on deconfigured subclients' is not enabled. Enabling this config param may help clean up older jobs on this subclient. |
| 63:898 | Subclient is deconfigured which can cause older data to be retained under cycles criteria. |
| 63:899 | Please check the associated entities on which Data Aging is disabled and consider enabling Data Aging. |
| 63:900 | Please check DataAging.log in the Commcell for possible errors. |
| 63:901 | Please check the Data Aging job advanced options and consider running Data Aging job on the missing entities. |
| 63:902 | Please check and address other potential concerns in this report related to physical pruning. If no other error, Media Agent might be slow in processing the physical pruning requests. |
| 63:903 | Space reclamation job is recommended to reclaim space on mount paths without sparse file support. Please check if there are space reclamation jobs scheduled on the associated deduplication stores. |
| 63:904 | Job will skip current chunks and continue. Please check database and logs for more details. |
| 63:905 | Job will skip current segment. Please check logs for details. |
| 63:906 | Please review DDB property and move DDB to a valid MediaAgent. |
| 63:907 | Check profile name and access keys are entered correctly in AWS credential file set in environment variable AWS_SHARED_CREDENTIALS_FILE. |
| 63:908 | Check if environment variable is set with correct file path. |
| 63:909 | Check certificate file given in KMS properties is available on access node(s). |
| 63:910 | Review bring your own key option in KMS properties and add a new key to use. |
| 63:911 | Please review the maximum concurrent number of active DDB in MediaAgent additional setting. |
| 63:912 | Please check the trial limit configurations. |
| 63:913 | Please review the configuration on maximum number of allowed Data Verification jobs to run simultaneously. |
| 63:914 | Set advance setting 'AllowCrossRegionBackups' on the access node(s)/client with value 'TRUE' To allow cross region backup. |
| 63:915 | Please Upgrade DDB MediaAgent to 11.30 or higher. |
| 63:916 | Please review the job option for MediaAgent and Client Group selections. |
| 63:917 | Please review the configuration on maximum number of allowed Aux Copy jobs to run simultaneously. |
| 63:918 | Please review the configuration on maximum number of allowed File Indexing jobs to run simultaneously. |
| 63:919 | Data will not be pruned until the associated disk storage reaches its threshold space for pruning. If data needs to be pruned immediately, consider disabling the option on the copy. |
| 63:920 | Check service account file is available. |
Media Manager Errors
| Code | Description |
| 62:1 | Undefined software error occurred. |
| 62:2 | Failed to contact MediaAgent Service. |
| 62:3 | Object has not been initialized before use. |
| 62:4 | Invalid argument passed to a function. |
| 62:5 | Memory allocation failed, no more memory. |
| 62:6 | Memory allocation failed, no more memory. |
| 62:7 | Failure during database operation on CommServe Database. |
| 62:8 | Init method called with a null connection pointer. |
| 62:9 | Invalid argument passed to a function. |
| 62:10 | A semaphore error occurred. |
| 62:11 | Invalid argument passed to a function. |
| 62:12 | Invalid argument passed to a function. |
| 62:13 | The specified export location is invalid. |
| 62:14 | The specified export location is already used. |
| 62:15 | Failed to delete export location: it may be associated with Tracking Policies or pending actions, or there are media currently at this location. |
| 62:16 | The specified barcode does not match the media in the slot. |
| 62:17 | The attribute cannot be changed. |
| 62:18 | The command to the LMS did not complete. Check if the Door and I/E port are closed. |
| 62:19 | The destination slot/drive is full. |
| 62:20 | Drive is empty. |
| 62:21 | Cleaning media loaded in drive. |
| 62:22 | Unmount failed as drive is not unloaded. |
| 62:23 | The operation encountered a drive/SCSI failure. |
| 62:24 | Drive is not ready. |
| 62:25 | Optical Disk Drive is not ready even after the timeout period. |
| 62:26 | The specified bay does not exist. |
| 62:27 | The command passed to LMS is not supported. |
| 62:28 | The drive specified does not exist. |
| 62:29 | The drive handle specified does not exist. |
| 62:30 | The mode specified for attach is not supported. |
| 62:31 | The slot specified does not exist. |
| 62:32 | The operation encountered a mechanical movement failure with library arm changer. |
| 62:33 | Library is not ready. Check if the library is online. |
| 62:34 | The command cannot be processed as there are pending ejects. |
| 62:35 | Operation failed as the source is empty. |
| 62:36 | The source/destination slot is marked inaccessible. |
| 62:37 | A task clause was not specified for the cancel command. |
| 62:38 | The specified attribute does not exist. |
| 62:39 | The move operation encountered an unknown error. |
| 62:40 | The specified attribute is not known to LMS. |
| 62:41 | The value specified for the attribute is out of range. |
| 62:42 | The LMS returned the following error: |
| 62:43 | Require manual intervention to get the library ready. |
| 62:44 | The operation cannot be completed as an invalid element address was accessed. |
| 62:45 | The operation failed as the library was either reset or turned off and on. |
| 62:46 | Media is not present to complete the operation. |
| 62:47 | The operation cannot be completed as removal of media is prevented either from front panel or by a program. |
| 62:48 | Load operation on the drive resulted in a failure. |
| 62:49 | Response from LMS could not be parsed. |
| 62:50 | An unknown command type was received. |
| 62:51 | An unknown response was received. |
| 62:52 | A wrong string was received. |
| 62:53 | A wrong token was received. |
| 62:54 | All spares are outside the library. |
| 62:55 | The media record has an invalid field. |
| 62:56 | The barcode is not present in the list of RSM media. |
| 62:57 | Failure while committing the database transaction. |
| 62:58 | There are drive pools still configured for this library. |
| 62:59 | The operation could not be completed as the drive pool is offline. |
| 62:60 | There are drives still configured for this library. |
| 62:61 | The operation cannot be completed as the drive is reserved. |
| 62:62 | Failure to fetch information from CommServe Database. |
| 62:63 | The recording format of the drive is not compatible with the recording format of the drive pool. |
| 62:64 | Failure to fetch information from CommServe Database. |
| 62:65 | Failure to fetch information from CommServe Database. |
| 62:66 | The operation cannot be completed as the MediaAgent is offline. |
| 62:67 | Insert failed since there is already a row with the same name. |
| 62:68 | The library type ID is invalid. |
| 62:69 | The media ID specified is invalid. |
| 62:70 | The operation specified is invalid for the spare group type. |
| 62:71 | The volume ID is invalid. |
| 62:72 | The operation could not be completed as the library controller is offline. |
| 62:73 | The operation cannot be completed as the library is offline. |
| 62:74 | The operation cannot be completed as the master drive pool is offline. |
| 62:75 | The operation cannot be completed as the media is outside the library. |
| 62:76 | The operation cannot be completed as the media is in the mail slot. |
| 62:77 | The operation cannot be completed as the mount path is reserved. |
| 62:78 | The operation could not be completed as there is not enough media that can be used. |
| 62:79 | The operation could not be completed as there are not enough drives that are unreserved and online with an active controller. |
| 62:80 | There is no active controller for this drive. |
| 62:81 | Insufficient disk space. Available mount paths are not enabled for write or have met reserved space limit. Enable/add more mount paths or add more disk space to existing mount paths. |
| 62:82 | There are not enough drives in the drive pool. This could be due to drive limit set on master pool if this failure is for magnetic library. |
| 62:83 | There are no more scratch media in the library. |
| 62:84 | There are no recording formats available for this library. |
| 62:85 | Reservation was not found in the database table. |
| 62:86 | Failure during open cursor database call. |
| 62:87 | The operation cannot be completed as the opposite side for this media is already reserved. |
| 62:88 | The number of readers would exceed the maximum allowed limit. |
| 62:89 | The recording format is not supported by the drive pool. |
| 62:90 | Failure during delete operation on CommServe Database. |
| 62:91 | Failure during insert operation on CommServe Database. |
| 62:92 | Failure during update operation on CommServe Database. |
| 62:93 | Failure while trying to enable database transaction. |
| 62:94 | The volume is contained on more than one medium. |
| 62:95 | There is more than one row in the Mount Path table for this media side. |
| 62:96 | The media side contains more than one partition. |
| 62:97 | The specified volume is reserved more than once for the same job ID. |
| 62:98 | The volume is contained on more than one media side. |
| 62:99 | The operation cannot be completed as the number of drive reservations exceeds the number of allowed drives. |
| 62:100 | The number of writers would exceed the maximum allowed limit. |
| 62:101 | The operation cannot be completed as the media group is reserved. |
| 62:102 | The operation cannot be completed as the copy is reserved. |
| 62:103 | The operation cannot be completed as the drive pool is used by storage policy copy. |
| 62:104 | Media residing in library has valid data for storage policy. |
| 62:105 | There is another media container with the same name. |
| 62:106 | There are no cleaning media types for this library. |
| 62:107 | Could not obtain exclusive database lock. |
| 62:108 | Could not release exclusive database lock. |
| 62:109 | Concurrency Count exceeds the total Concurrency Paths for the Copy Manager. |
| 62:110 | The Current Concurrency count is not zero. Some jobs are running for the Copy Manager. |
| 62:111 | The file marker on this volume mismatched between volume table and archChunk table. |
| 62:112 | The medium is located in the drive. |
| 62:113 | Media has either duplicate barcode, unrecognized barcode or is in the wrong library. |
| 62:114 | There is no active controller for this library. |
| 62:115 | The number of library controller does not match the number in both tables. |
| 62:116 | Cannot disable an active controller. |
| 62:117 | Mount path is offline. |
| 62:118 | Export media operation failed. |
| 62:119 | Initialization of MediaAgent failed. |
| 62:120 | LMS license check failed. |
| 62:121 | MediaAgent is offline. |
| 62:122 | Invalid job type. |
| 62:123 | Unknown MediaAgent name. |
| 62:124 | MediaAgent is offline. |
| 62:125 | Software Copy Manager License not available. |
| 62:126 | More than one Library Controller Configured for a Library on given MediaAgent. |
| 62:127 | Library sharing not supported under RSM. |
| 62:128 | Library controller is actively controlling a library that has pending reservations. |
| 62:129 | Library controller service is down. |
| 62:130 | Failed to schedule full inventory for library. |
| 62:131 | Failed to get the default media type for library. |
| 62:132 | Library inventory is in progress. |
| 62:133 | Media in slot is being identified. |
| 62:134 | Media has not yet been located in the library. |
| 62:135 | Auto cleaning has not been enabled on the library. |
| 62:136 | Request is moved to pending queue as it is waiting for another action to complete. |
| 62:137 | Volume is already mounted on the requested MediaAgent. |
| 62:138 | Volume is being used by other MediaAgents. |
| 62:139 | Volume is not mounted on any MediaAgent. |
| 62:140 | The device is not in use. |
| 62:141 | The device is not enabled. |
| 62:142 | The device is broken. |
| 62:143 | The mount request for disk timed out. |
| 62:144 | Device Controller or Device has Mount Path Configured. |
| 62:145 | Media location is unknown and cannot be moved. |
| 62:146 | Media does not have a valid on media identifier. |
| 62:147 | At least one failover candidate is defined for the entity being deleted. |
| 62:148 | Requested volume is being mounted/unmounted. |
| 62:149 | The state of the requested volume could not be determined. |
| 62:150 | The volume is currently in use. |
| 62:151 | Media is stuck in a drive and recovery is in progress. |
| 62:152 | The medium is in use or in drive. |
| 62:153 | The job request this operation has been killed. |
| 62:154 | The mount failed for an unknown reason. |
| 62:155 | The mount request cannot be completed as the job is not running. |
| 62:156 | Maximum share limit is reached on requested volume. |
| 62:157 | Request failed. |
| 62:158 | MediaAgent is not ready. |
| 62:159 | Library is disabled. |
| 62:160 | Library is broken. |
| 62:161 | Library is not ready. |
| 62:162 | Drive is disabled. |
| 62:163 | Drive is broken. |
| 62:164 | Drive is not ready. |
| 62:165 | Library controller is not active. |
| 62:166 | The Library controller is offline. |
| 62:167 | The drive controller is offline, MediaAgent services may not be started. |
| 62:168 | The requested drive is not found in the MediaAgent Drive List. Resync of Media Manager and MediaAgent may not be done properly. |
| 62:169 | Library controller is not ready. |
| 62:170 | Drive controller is not active. |
| 62:171 | Drive controller is not ready. |
| 62:172 | MediaAgent is not active. |
| 62:173 | MediaAgent is not ready. |
| 62:174 | There are no free drives in the drive pool for the mount. |
| 62:175 | Failed to process client request. |
| 62:176 | The request ID was not found in any of the MLM list/queues. |
| 62:177 | A cache mount for unmount was not found in any of the cache mount lists. |
| 62:178 | Invalid Drive Pool Type. |
| 62:179 | Cannot export from specified library. |
| 62:180 | Some media were exported successfully. |
| 62:181 | Request partially completed. |
| 62:182 | Operation could not be completed in timeout interval. |
| 62:183 | Volume has more than one partition. Media Manager does not support media with more than one partition. |
| 62:184 | Wrong or unsupported library type. |
| 62:185 | Media Type not supported. |
| 62:186 | Recording format not supported. |
| 62:187 | Message not supported by new Media Manager. |
| 62:188 | No Volumes in library. |
| 62:189 | Unmount failed after maximum number of retries. |
| 62:190 | Mount path is disabled. |
| 62:191 | Mount path already exists in library on same drive. |
| 62:192 | Disk library cannot have more than one drive pool. |
| 62:193 | No drive pools found for library. |
| 62:194 | Cannot mount to a pre-selected drive using RSM. |
| 62:195 | The medium is not in library. |
| 62:196 | No media found for the volume. |
| 62:197 | Source spare group is not regular or unidentified spare. |
| 62:198 | Source Spare group does not have enough media. |
| 62:199 | Destination Spare group is not Regular spare. |
| 62:200 | No drive controller found for the drive. |
| 62:201 | More than one drive controller found for the drive. |
| 62:202 | Undefined error. |
| 62:203 | Media belongs to undefined spare group. |
| 62:204 | Duplicate barcode detected. |
| 62:205 | Media is not a spare media. |
| 62:206 | There are no media groups. |
| 62:207 | Storage policy still exists for Library. |
| 62:208 | Media is being used and is reserved. |
| 62:209 | Media specified is not in the slot. |
| 62:210 | A database error has occurred. |
| 62:211 | Volume is no longer reserved. |
| 62:212 | There are no free slots in the library. |
| 62:213 | The operation cannot be completed as the library is reserved. |
| 62:214 | Mount path is associated with one or more storage policies. |
| 62:215 | Mount path is not UNC path. |
| 62:216 | Scratch pool may be used by one or more storage policies. |
| 62:217 | Failed search cache mount. |
| 62:218 | Job does not have reservation on the drive. |
| 62:219 | The other side of media is in use. |
| 62:220 | Failed to unmount the other side of media. |
| 62:221 | The requested media is not in any slot of the library. |
| 62:222 | The requested media is stuck in the drive. |
| 62:223 | The requested media is exported. |
| 62:224 | Failed to get media information for the volume. |
| 62:225 | Failed to access drive that was reserved. |
| 62:226 | Failed to access library information for mount. |
| 62:227 | Failed to activate device controller for disk device. |
| 62:228 | The job requesting this mount is no longer running. |
| 62:229 | Failed to activate drive controller. |
| 62:230 | Failed to deactivate drive controller. |
| 62:231 | Failed to set sub request for this mount. |
| 62:232 | Failed to find active drive controller. |
| 62:233 | Failed to get the resources for this mount operation. |
| 62:234 | Failed to submit LCP mount request to MediaAgent. |
| 62:235 | Failed to deactivate drive controller for this drive. |
| 62:236 | Failed to submit drive attach request to MediaAgent. |
| 62:237 | Failed to set cache mount point in request. |
| 62:238 | Failed to update cache mount list. |
| 62:239 | Failed to submit verify OML to MediaAgent. |
| 62:240 | Failed to submit write OML to MediaAgent. |
| 62:241 | Failed to submit read OML to MediaAgent. |
| 62:242 | Failed to submit drive load to MediaAgent. |
| 62:243 | Failed to update side table to mark OML valid. |
| 62:244 | Failed to increment active file counter for this volume. |
| 62:245 | Failed to update cache mount. |
| 62:246 | Failed to set drive info for this media. |
| 62:247 | Failed to submit activate drive controller to MediaAgent. |
| 62:248 | Failed to submit deactivate drive controller to MediaAgent. |
| 62:249 | Failed to get activate drive controller. |
| 62:250 | Failed to submit standalone mount to MediaAgent. |
| 62:251 | Failed to retrieve client information. |
| 62:252 | Failed to retrieve volume information. |
| 62:253 | Failed to submit initialization volume to MediaAgent. |
| 62:254 | Failed to set volume state to initialized. |
| 62:255 | Failed to submit RSM mount request. |
| 62:256 | Failed to set media location. |
| 62:257 | Failed to set media ID in drive table. |
| 62:258 | Failed to submit drive detach to MediaAgent. |
| 62:259 | Failed to submit drive unload to MediaAgent. |
| 62:260 | Failed to unmount drive. |
| 62:261 | Volume is not reserved for this job. |
| 62:262 | Drive cannot be cleaned. |
| 62:263 | Failed to retrieve media group info. |
| 62:264 | Failed to retrieve drive pool information. |
| 62:265 | Failed to retrieve drive controller information. Check if the MediaAgent is Online. |
| 62:266 | Failed to retrieve MediaAgent information. |
| 62:267 | Failed to retrieve master drive pool information. |
| 62:268 | Drive is in use or drive is loaded. |
| 62:269 | Failed to retrieve drive type information. |
| 62:270 | Failed to retrieve cleaning media list. |
| 62:271 | There is no discovered cleaning media in the library. |
| 62:272 | Failed to retrieve volume list. |
| 62:273 | There is no discovered media in the slot. |
| 62:274 | There is no cleaning media in the slot. |
| 62:275 | All the cleaning media has been exported. |
| 62:276 | Failed to identify media for standalone library. |
| 62:277 | There is no cleaning media group. |
| 62:278 | There is no cleaning media in the cleaning media group. |
| 62:279 | The cleaning media is currently cleaning the drive. |
| 62:280 | The media in the drive already has a valid On Media Label and is not a spare. |
| 62:281 | The media in the drive already has a valid On Media Label and is from a different CommCell. |
| 62:282 | The Drive Pool is being used by Job %%d. |
| 62:283 | The Inventory Process was killed before it could complete the search. |
| 62:284 | Failed to search the required media for mount in library. |
| 62:285 | Timed out waiting for resources to be available for application-based restore. |
| 62:286 | The Slot contains a media other than the expected one. |
| 62:287 | Failed to set drive dirty to start drive cleaning process. |
| 62:288 | Failed to check status of parent directory, media agent cannot access the storage. |
| 62:289 | No free drive mount point found to mount disk volume. |
| 62:290 | Failed to update database with unmount disk volume information. |
| 62:291 | Failed to update database with mount disk volume information. |
| 62:292 | Failed to mount disk volume. Please check permissions. |
| 62:293 | Failed to unmount disk volume. |
| 62:294 | Cannot impersonate user. User credentials provided for disk mount path access may be incorrect. |
| 62:295 | Create directory failed. |
| 62:296 | Delete file failed. |
| 62:297 | Delete directory failed. |
| 62:298 | Failed to get Disk Space Information. |
| 62:299 | Open and Prepare Tape failed. |
| 62:300 | Read OML failed. |
| 62:301 | Verify OML failed. Media mismatch. |
| 62:302 | Write OML failed. |
| 62:303 | Device is not ready. |
| 62:304 | Data error (cyclic redundancy check). If the job is performed on a tape drive, check if the drive needs cleaning. |
| 62:305 | Tape volume block size selected is not supported by the underlying HBA card. Change Block size on data path to a lower level and start a new media. |
| 62:306 | The request could not be performed because of an I/O device error. |
| 62:307 | Device did not respond to the command in a timely manner. |
| 62:308 | The media side mounted is write-protected. |
| 62:309 | There is not enough space on the disk. |
| 62:310 | The disk structure or file system is either corrupted or unreadable. |
| 62:311 | Access to the file/media denied. |
| 62:312 | The device is not connected. |
| 62:313 | I/O operation is not completed. |
| 62:314 | The media that was in the drive has been replaced or removed. |
| 62:315 | There is no medium in the drive. |
| 62:316 | A reset condition was detected on the bus. |
| 62:317 | The current block size on the tape is incorrect. |
| 62:318 | No more data is on the tape. |
| 62:319 | The path is being accessed by another application |
| 62:320 | The drive needs cleaning. |
| 62:321 | The number of lifetime hard errors has exceeded its threshold. |
| 62:322 | Drive error occurred. |
| 62:323 | Media error occurred. |
| 62:324 | Magic Number of the OML does not match. |
| 62:325 | Version Number of the OML does not match. |
| 62:326 | Label Type of the OML does not match. |
| 62:327 | Media is from a different backup software vendor and will be marked bad to prevent overwrite. |
| 62:328 | Application name of the OML does not match. |
| 62:329 | Media ID of the OML does not match. |
| 62:330 | Media side name of the OML does not match. |
| 62:331 | Media creation time on the OML does not match. |
| 62:332 | Attempt to read back the OML just written to the media failed. nCheck if the media is compatible for the drive. |
| 62:333 | Volume ID of the OML does not match. |
| 62:334 | An attempt to access data before the beginning-of-media marker failed. |
| 62:335 | The end-of-media marker was reached during read/write on media. |
| 62:336 | A filemark was reached during read/write on tape. |
| 62:337 | A setmark was reached during read/write on tape. |
| 62:338 | Formatting of the Disk Failed. |
| 62:339 | Opening of the OML file on the Disk Failed. |
| 62:340 | The tape could not be partitioned. |
| 62:341 | The request is not supported. |
| 62:342 | Encountered an I/O error while performing the operation. |
| 62:343 | A mount path already exists at the given location. |
| 62:344 | Transmission error over socket. |
| 62:345 | Transmission error over socket. No connection. |
| 62:346 | Invalid Volume ID. Volume ID must be a positive number. |
| 62:347 | The medium is cannot be interrupted. The Media should be pre-emptible and Interrupt Job ID should be 0. |
| 62:348 | The medium is already reserved by some other job[s]. |
| 62:349 | Unable to get CommServe Name. |
| 62:350 | Unable to connect to Job Manager. |
| 62:351 | The medium is not available. The Job currently using the medium was interrupted. |
| 62:352 | No drives available for reservation. |
| 62:353 | Not enough good drives available for reservation. |
| 62:354 | Cannot release Media reservation. |
| 62:355 | Cannot release Drive. |
| 62:356 | Two drives needed by job are not available in Source and Destination Drive Pool. |
| 62:357 | The interrupted job has not released the drives yet. |
| 62:358 | The interrupted job has not released the Media yet. |
| 62:359 | The job has already been interrupted by another job. |
| 62:360 | Drive reservation not found for the job. |
| 62:361 | Drive reservation not found for the job. |
| 62:362 | No license available for Gridstore. |
| 62:363 | No license available for Data Multiplexing. |
| 62:364 | Media reservation not found for the job. |
| 62:365 | The job has reserved too many extra drives. |
| 62:366 | Media in drive is from a previous Installation of this product. |
| 62:367 | Media in the drive is already assigned. Replace this media. |
| 62:368 | Media in the drive is retired. Replace this media. |
| 62:369 | Import request has been cancelled by the operator. |
| 62:370 | Mount request has reached its maximum threshold. |
| 62:371 | Not enough drives available for reservation. Interrupting another job. |
| 62:372 | RSM returned error. |
| 62:373 | RSM request timed out. |
| 62:374 | RSM server unavailable. See if the service is running or it was restarted. |
| 62:375 | Media cannot be reserved as it is stuck in a drive. |
| 62:376 | Media cannot be reserved. Copy Manager Exceeds Maximum Concurrent Paths. |
| 62:377 | Media cannot be reserved. It needs to be recycled. Marking Media Full. |
| 62:378 | The FastraxId already exists. |
| 62:379 | The alias name is already used by another drive. |
| 62:380 | Cannot reset media ID for a disk drive. |
| 62:381 | More than one volume found for a given media. |
| 62:382 | The name is already used by another device. |
| 62:383 | The device is offline and not available to use. |
| 62:384 | There are no devices configured to be used as mount paths. |
| 62:385 | There are no devices configured for this MediaAgent. |
| 62:386 | Failed to get job type from Job Manager. |
| 62:387 | Failed to fetch information from Application Manager. |
| 62:388 | Read operation cannot be completed as none of the resources available can be used. |
| 62:389 | Failover candidate not defined for this MediaAgent. |
| 62:390 | Media Manager is not able to talk to MediaAgent. Check whether the MediaAgent services are running. |
| 62:391 | The barcode reader of the library is not able to read the barcode on the media. Please make sure a valid barcode is present. |
| 62:392 | End of media was reached while writing data. |
| 62:393 | RSM inventory is in progress. This prevents this product from accessing the library. |
| 62:394 | A file with the same name already exists. Cannot create a new file. |
| 62:395 | Failed to open the file. |
| 62:396 | Error writing to the media. |
| 62:397 | Backup file does not exist in the given path. Please make sure that the path is correct. |
| 62:398 | Error reading from media. |
| 62:399 | Failed to communicate with the device. Re-initialization of the device required. |
| 62:400 | Failed to communicate with the library. The library door may be open. |
| 62:401 | Device is not partitioned. |
| 62:402 | Failed to flush the contents of the volume to the disk during an I/O operation. |
| 62:403 | Failed to unload the media. |
| 62:404 | Failed to seek the required data on the media. |
| 62:405 | Unable to recognize the media. Please make sure that the media is compatible with this hardware. |
| 62:406 | Media Offline. |
| 62:407 | Media not available. |
| 62:408 | Unable to load the media. |
| 62:409 | Unable to inventory drive. |
| 62:410 | Unable to eject the mounted media. |
| 62:411 | Operating System could not find the path specified. |
| 62:412 | Operating System failed to get a valid handle to the device. |
| 62:413 | Failed to get the logical drive path. |
| 62:414 | Failed to create the directory. |
| 62:415 | Path is too long and is not accessible. |
| 62:416 | File size is too big. |
| 62:417 | Write size is too big and cannot be performed. |
| 62:418 | Operating System could not find the device file specified. The device may be unreachable from the MediaAgent. |
| 62:419 | SCSI command failed as the device is reporting busy status. |
| 62:420 | There is no Access Node configured for Centera Cluster. |
| 62:421 | Unexpected Centera application logic error occurred. |
| 62:422 | Centera hardware or API internal logic error occurred. |
| 62:423 | Error in sending or receiving a request to Centera Access Node. |
| 62:424 | All possible capacity in the configured Centera cluster has been used. |
| 62:425 | Shared Disk is not available for Mount. It may be mounted by another device or may be disabled. |
| 62:426 | Exception..... |
| 62:427 | Failed to run Tracking Policy. |
| 62:428 | Failed to retrieve information for Tracking Policy. |
| 62:429 | Failed to run command for action. |
| 62:430 | Failed to run command for history. |
| 62:431 | Failed to run Tracking Policy for job. |
| 62:432 | Failed to update Tracking Policy after lcp pushes slot map. |
| 62:433 | Failed to retrieve media that need import, export or reshuffle. |
| 62:434 | Failed to run the Tracking Policy rule. |
| 62:435 | Another Tracking Policy with same name already exists. |
| 62:436 | Another Tracking Policy rule with same name already exists. |
| 62:437 | Rule is used by Tracking Policy. |
| 62:438 | Tracking Policy is referenced by pending movement. |
| 62:439 | The schema type has more than one related schema defined. |
| 62:440 | Failed to create Tracking Policy for media. |
| 62:441 | Internal software error occurred. |
| 62:442 | Unable to move media to a slot that is not empty. |
| 62:443 | Media is in pending movement. |
| 62:444 | Failed to remove library references from VaultTracker tables. |
| 62:445 | Failed to remove schedule for Tracking Policy. |
| 62:446 | Cannot erase media that is not spare. |
| 62:447 | Job[s] interrupted by this Job have not released resources yet. |
| 62:448 | Cannot mark Active Volume for Arch Group [<String>] as Full. The Active Volume is already being used by other job[s]. |
| 62:449 | Not enough streams available for Storage Policy [<String>]. Need <Number> streams and <Number> stream(s) are available. |
| 62:450 | Library [<String>], MediaAgent [<String>], Drive Pool [<String>], Media[<String>]: <Message> |
| 62:451 | Library [<String>], MediaAgent [<String>], Drive Pool [<String>], MountPath[<String>]: <Message> |
| 62:452 | Interrupted Job has not yet released resources required. |
| 62:453 | This job type cannot multiplex its data streams on the same media. |
| 62:454 | All unreserved drives are not ready to use. |
| 62:455 | Drive in which Media is mounted is not ready to use. |
| 62:456 | Drive in which Media is mounted is offline. |
| 62:457 | Physical End of Media Encountered. |
| 62:458 | Media is marked Exportable. |
| 62:459 | During a write operation, the position on the tape is found to be incorrect. |
| 62:460 | While accessing a drive, the Serial Number obtained is different from expected Serial Number. |
| 62:461 | There are media inside this container. Please change the container for those media. |
| 62:462 | Mount Path does not have minimum required free space. |
| 62:463 | Amount of data on Mount Path has reached the maximum threshold set. |
| 62:464 | Mount Path does not have enough space. |
| 62:465 | The storage policy selected for the backup is not valid. |
| 62:466 | The Data mover module is being loaded in an unsupported platform. |
| 62:467 | The Data mover module received an invalid MediaAgent host name. |
| 62:468 | Failed to establish connection with the CommServe to get the required parameters. |
| 62:469 | Data read from media appears to be invalid. |
| 62:470 | Pipeline module specified data whose size is greater than the supported size. |
| 62:471 | Data mover module received data from a client that is not currently backed up by this module. |
| 62:472 | Data mover module failed to create or update the chunk information. |
| 62:473 | Failed to seek to the correct location on the media to start the data restore. |
| 62:474 | Failed to parse the metadata read from the media. |
| 62:475 | Failed to generate the metadata that needs to be written on the tape. |
| 62:476 | Invalid media type has been passed as a parameter for the job. |
| 62:477 | Failed to get the free space on the media. |
| 62:478 | The NetWare Volume Name is invalid. |
| 62:479 | Invalid read request issued to the media. |
| 62:480 | Failed to create disk mount path. |
| 62:481 | The multiplexing properties on the copy are invalid. |
| 62:482 | Failed to update container due to error: existing number of media in container exceeds new capacity. |
| 62:483 | Failed to move media to container due to error: the container is already full. Increase the capacity and try again. |
| 62:484 | Copy [<Number>] of Storage Policy [<Number>] does not have a data path containing MediaAgent [<String>]. |
| 62:485 | Failed to create the Library Handler for the library. |
| 62:486 | Failed to add elements to the element map for the library. |
| 62:487 | The current library controller MediaAgent is not actively controlling the library anymore. |
| 62:488 | The operation is interrupted because the Library Handler is stopping. |
| 62:489 | The operation failed because the IP Library Server returns error. |
| 62:490 | The operation is not supported for this library. |
| 62:491 | The previous import operation is still in progress. |
| 62:492 | The export operation is in progress. |
| 62:493 | Tape volume block size selected is unsupported by the OS tape drivers. |
| 62:494 | Attempt to send a SCSI-3 Persistent Reserve command to the disk device failed. This device may be unsupported for Dynamic Mount Path Sharing. |
| 62:495 | SCSI command failed as the device is SCSI reserved from another system. |
| 62:496 | Waiting for Job Manager to clean up before releasing resource. |
| 62:497 | Resource is in use by a running job. |
| 62:498 | The mount path has valid backup data. |
| 62:499 | Secondary Copy [<Number>] does not have an active stream corresponding to stream [<Number>] of the Primary Copy for Storage Policy [<String>]. |
| 62:500 | Media is not accessible from data path selected. |
| 62:501 | Storage Policy Copy does not have any data path defined. |
| 62:502 | The drive is over-subscribed. |
| 62:503 | Initializing device failed. |
| 62:504 | The device is busy. |
| 62:505 | The target device is invalid. |
| 62:506 | Unknown platform error. |
| 62:507 | Failed to open the device. |
| 62:508 | The library is offline. |
| 62:509 | The door is opened. |
| 62:510 | The device is becoming ready. |
| 62:511 | The mailbox is opened. |
| 62:512 | All slots are full. |
| 62:513 | Auto Import failed. |
| 62:514 | No configured mailbox. |
| 62:515 | Failed to export media to the mail slot as all mail slots are full. Please remove media from the mail slots and try again. |
| 62:516 | Mailbox is inaccessible now. |
| 62:517 | Error recovered. |
| 62:518 | Medium error. |
| 62:519 | Positioning error. |
| 62:520 | Internal target failure. |
| 62:521 | Mode parameters changed. |
| 62:522 | Firmware updated. |
| 62:523 | The door has been accessed. |
| 62:524 | The mailbox has been accessed |
| 62:525 | Reset occurred. |
| 62:526 | Unit attention occurred. |
| 62:527 | Command aborted. |
| 62:528 | Hardware error. |
| 62:529 | Incompatible medium installed. |
| 62:530 | The CAP is not available; there may be pending import/export operations. |
| 62:531 | Library Management service reset by user. |
| 62:532 | Library has been marked as Disabled. |
| 62:533 | Repeated errors during mounts and unmounts have now exceeded a threshold. The library has been marked as broken. Please check your hardware, firmware versions as well as cables/terminators/bent pins. Then mark the library as fixed by right-clicking the library. |
| 62:534 | N/A |
| 62:535 | Library Management service is ready. |
| 62:536 | Library Management service is offline. |
| 62:537 | Media in saved pool cannot be overwritten. |
| 62:538 | Media in foreign pool cannot be overwritten. |
| 62:539 | Media is prevented from exports. |
| 62:540 | The device is busy. |
| 62:541 | The device is not accessible to the MediaAgent. |
| 62:542 | The Index cache Path for the MediaAgent is disabled. |
| 62:543 | There is no accessible controller for this device. |
| 62:544 | The device is being used by a different MediaAgent. |
| 62:545 | License for Advanced Media Management features to support this configuration is not available. |
| 62:546 | License for Dynamic Mount Path Sharing feature to support this configuration is not available. |
| 62:547 | License for DDO is not available. |
| 62:548 | License to share a Library/Drive is not available. |
| 62:549 | License to use Centera Library is not available. |
| 62:550 | Failed to release license. |
| 62:551 | Failed to verify presence of license. |
| 62:552 | No Additional SCSI Information regarding the error. SCSI Error - ASC[0x00], ASCQ[0x00] |
| 62:553 | FileMark detected during the operation on the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x01] |
| 62:554 | End-of-partition/medium detected during an operation on the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x02] |
| 62:555 | Setmark detected during an operation on the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x03] |
| 62:556 | Beginning-of-partition/medium detected during an operation on the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x04] |
| 62:557 | End-of-data detected during an operation on the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x05] |
| 62:558 | The I/O operation was terminated by the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x06] |
| 62:559 | An I/O operation is in progress on the SCSI device. SCSI Error - ASC[0x00], ASCQ[0x16] |
| 62:560 | SCSI device reported that the drive needs to be cleaned. SCSI Error - ASC[0x00], ASCQ[0x17] |
| 62:561 | NO SEEK COMPLETE. SCSI Error - ASC[0x02], ASCQ[0x00] |
| 62:562 | Error reported by the SCSI device when writing. SCSI Error - ASC[0x03], ASCQ[0x00] |
| 62:563 | SCSI returned too many write errors on the device. SCSI Error - ASC[0x03], ASCQ[0x02] |
| 62:564 | The SCSI device is not ready. SCSI Error - ASC[0x04], ASCQ[0x00] |
| 62:565 | The SCSI device is in the process of becoming ready. SCSI Error - ASC[0x04], ASCQ[0x01] |
| 62:566 | The SCSI device is not ready. It needs to be initialized. SCSI Error - ASC[0x04], ASCQ[0x02] |
| 62:567 | The SCSI device is not ready. Manual intervention is required. SCSI Error - ASC[0x04], ASCQ[0x03] |
| 62:568 | The SCSI device is not ready, Format in progress. SCSI Error - ASC[0x04], ASCQ[0x04] |
| 62:569 | The SCSI device is not ready, Rebuild in progress. SCSI Error - ASC[0x04], ASCQ[0x05] |
| 62:570 | The SCSI device is not ready, Recalculation in progress. SCSI Error - ASC[0x04], ASCQ[0x06] |
| 62:571 | The SCSI device is not ready, Operation in progress. SCSI Error - ASC[0x04], ASCQ[0x07] |
| 62:572 | The SCSI device is not ready, Long write in progress. SCSI Error - ASC[0x04], ASCQ[0x08] |
| 62:573 | The SCSI device is not ready, Self-test in progress. SCSI Error - ASC[0x04], ASCQ[0x09] |
| 62:574 | The import/export port is open. Cannot execute the SCSI command. SCSI Error - ASC[0x04], ASCQ[0x82] |
| 62:575 | Aisle power is disabled. A door could be open. Cannot execute the SCSI command. SCSI Error - ASC[0x04], ASCQ[0x83] |
| 62:576 | Door is open. Cannot execute the SCSI command. SCSI Error - ASC[0x04], ASCQ[0x85] |
| 62:577 | The library is in console mode. Cannot execute the SCSI command. SCSI Error - ASC[0x04], ASCQ[0x89] |
| 62:578 | The SCSI device is offline. Cannot execute the SCSI command. SCSI Error - ASC[0x04], ASCQ[0x8D] |
| 62:579 | The library is in LCD mode. Cannot execute the SCSI command. SCSI Error - ASC[0x04], ASCQ[0x8D] |
| 62:580 | The SCSI device is not responding. SCSI Error - ASC[0x05], ASCQ[0x00] |
| 62:581 | NO REFERENCE POSITION FOUND. SCSI Error - ASC[0x06], ASCQ[0x00] |
| 62:582 | MULTIPLE PERIPHERAL DEVICES SELECTED. SCSI Error - ASC[0x07], ASCQ[0x00] |
| 62:583 | Failed to communicate with the SCSI device. SCSI Error - ASC[0x08], ASCQ[0x00] |
| 62:584 | Communication with the SCSI device timed out. SCSI Error - ASC[0x08], ASCQ[0x01] |
| 62:585 | Parity error occurred when communicating with the SCSI device. SCSI Error - ASC[0x08], ASCQ[0x02] |
| 62:586 | CRC Error occurred when communicating with the SCSI device. SCSI Error - ASC[0x08], ASCQ[0x03] |
| 62:587 | UNREACHABLE COPY TARGET. SCSI Error - ASC[0x08], ASCQ[0x04] |
| 62:588 | TRACK FOLLOWING ERROR. SCSI Error - ASC[0x09], ASCQ[0x00] |
| 62:589 | TRACKING SERVO FAILURE. SCSI Error - ASC[0x09], ASCQ[0x01] |
| 62:590 | FOCUS SERVO FAILURE. SCSI Error - ASC[0x09], ASCQ[0x02] |
| 62:591 | SPINDLE SERVO FAILURE. SCSI Error - ASC[0x09], ASCQ[0x03] |
| 62:592 | HEAD SELECT FAULT. SCSI Error - ASC[0x09], ASCQ[0x04] |
| 62:593 | Error log of the SCSI device overflowed. SCSI Error - ASC[0x0A], ASCQ[0x00] |
| 62:594 | SCSI device reported error while writing. SCSI Error - ASC[0x0C], ASCQ[0x00] |
| 62:595 | SCSI device reported error while writing - RECOVERED WITH AUTO REALLOCATION. SCSI Error - ASC[0x0C], ASCQ[0x01] |
| 62:596 | SCSI device reported error while writing - AUTO REALLOCATION FAILED. SCSI Error - ASC[0x0C], ASCQ[0x02] |
| 62:597 | SCSI device reported error while writing - RECOMMEND REASSIGNMENT. SCSI Error - ASC[0x0C], ASCQ[0x03] |
| 62:598 | SCSI device reported error while compressing or uncompressing data. SCSI Error - ASC[0x0C], ASCQ[0x04] |
| 62:599 | SCSI device reported error while compressing or uncompressing data. SCSI Error - ASC[0x0C], ASCQ[0x05] |
| 62:600 | BLOCK NOT COMPRESSIBLE. SCSI Error - ASC[0x0C], ASCQ[0x06] |
| 62:601 | SCSI device reported error while writing - RECOVERY NEEDED. SCSI Error - ASC[0x0C], ASCQ[0x07] |
| 62:602 | SCSI device reported error while writing - RECOVERY FAILED. SCSI Error - ASC[0x0C], ASCQ[0x08] |
| 62:603 | SCSI device reported error while writing - LOSS OF STREAMING. SCSI Error - ASC[0x0C], ASCQ[0x09] |
| 62:604 | SCSI device reported error while writing - PADDING BLOCKS ADDED. SCSI Error - ASC[0x0C], ASCQ[0x0A] |
| 62:605 | SCSI device reported CRC or ECC error. SCSI Error - ASC[0x10], ASCQ[0x00] |
| 62:606 | SCSI device reported unrecovered read error. SCSI Error - ASC[0x11], ASCQ[0x00] |
| 62:607 | SCSI device reported read error after retries. SCSI Error - ASC[0x11], ASCQ[0x01] |
| 62:608 | ERROR TOO LONG TO CORRECT. SCSI Error - ASC[0x11], ASCQ[0x02] |
| 62:609 | SCSI device reported multiple read errors. SCSI Error - ASC[0x11], ASCQ[0x03] |
| 62:610 | SCSI device reported unrecovered read error - AUTO REALLOCATE FAILED. SCSI Error - ASC[0x11], ASCQ[0x04] |
| 62:611 | SCSI device reported an unresolvable error. SCSI Error - ASC[0x11], ASCQ[0x05] |
| 62:612 | SCSI device reported error and cannot recover from it. SCSI Error - ASC[0x11], ASCQ[0x06] |
| 62:613 | SCSI device reported data re-synchronization error. SCSI Error - ASC[0x11], ASCQ[0x07] |
| 62:614 | SCSI device failed to read complete block of data. SCSI Error - ASC[0x11], ASCQ[0x08] |
| 62:615 | MISCORRECTED ERROR. SCSI Error - ASC[0x11], ASCQ[0x0A] |
| 62:616 | SCSI device reported unrecovered read error - RECOMMEND REASSIGNMENT. SCSI Error - ASC[0x11], ASCQ[0x0B] |
| 62:617 | SCSI device reported unrecovered read error - RECOMMEND REWRITE THE DATA. SCSI Error - ASC[0x11], ASCQ[0x0C] |
| 62:618 | SCSI device reported CRC error during decompression. SCSI Error - ASC[0x11], ASCQ[0x0D] |
| 62:619 | CANNOT DECOMPRESS USING DECLARED ALGORITHM. SCSI Error - ASC[0x11], ASCQ[0x0E] |
| 62:620 | SCSI device reported read error - LOSS OF STREAMING. SCSI Error - ASC[0x11], ASCQ[0x11] |
| 62:621 | Filemark or Setmark not found on the media. SCSI Error - ASC[0x14], ASCQ[0x02] |
| 62:622 | End-of-data not found on the media. SCSI Error - ASC[0x14], ASCQ[0x03] |
| 62:623 | BLOCK SEQUENCE ERROR. SCSI Error - ASC[0x14], ASCQ[0x04] |
| 62:624 | The SCSI device reported a random positioning error. SCSI Error - ASC[0x15], ASCQ[0x00] |
| 62:625 | The SCSI device reported a mechanical positioning error. SCSI Error - ASC[0x15], ASCQ[0x01] |
| 62:626 | The SCSI device reported a positioning error detected by read of medium. SCSI Error - ASC[0x15], ASCQ[0x02] |
| 62:627 | The SCSI device dropped a cartridge. SCSI Error - ASC[0x15], ASCQ[0x80] |
| 62:628 | The SCSI device could not pick a cartridge. SCSI Error - ASC[0x15], ASCQ[0x81] |
| 62:629 | The SCSI device could not put a cartridge. SCSI Error - ASC[0x15], ASCQ[0x83] |
| 62:630 | The SCSI device could not load the drive. SCSI Error - ASC[0x15], ASCQ[0x83] |
| 62:631 | The SCSI could not pick from a full cartridge slot. SCSI Error - ASC[0x15], ASCQ[0x86] |
| 62:632 | The SCSI device reported data synchronization mark error. SCSI Error - ASC[0x16], ASCQ[0x00] |
| 62:633 | The SCSI device reported data synchronization error - data rewritten. SCSI Error - ASC[0x16], ASCQ[0x01] |
| 62:634 | The SCSI device reported data synchronization error - rewrite data. SCSI Error - ASC[0x16], ASCQ[0x02] |
| 62:635 | The SCSI device reported data synchronization error - data auto-relocated. SCSI Error - ASC[0x16], ASCQ[0x03] |
| 62:636 | The SCSI device reported data synchronization error - reassign data. SCSI Error - ASC[0x16], ASCQ[0x04] |
| 62:637 | The SCSI device recovered data with no error correction applied. SCSI Error - ASC[0x17], ASCQ[0x00] |
| 62:638 | The SCSI device recovered data with retries. SCSI Error - ASC[0x17], ASCQ[0x01] |
| 62:639 | The SCSI device recovered data with positive head offset. SCSI Error - ASC[0x17], ASCQ[0x02] |
| 62:640 | The SCSI device recovered data with negative head offset. SCSI Error - ASC[0x17], ASCQ[0x03] |
| 62:641 | The SCSI device recovered data with retries and/or CIRC applied. SCSI Error - ASC[0x17], ASCQ[0x04] |
| 62:642 | The SCSI device recovered data using previous sector ID. SCSI Error - ASC[0x17], ASCQ[0x05] |
| 62:643 | The SCSI device recovered data without ECC - data auto-reallocated. SCSI Error - ASC[0x17], ASCQ[0x06] |
| 62:644 | The SCSI device recovered data without ECC - reassign data. SCSI Error - ASC[0x17], ASCQ[0x07] |
| 62:645 | The SCSI device recovered data without ECC - rewrite data. SCSI Error - ASC[0x17], ASCQ[0x08] |
| 62:646 | The SCSI device recovered data without ECC - data rewritten. SCSI Error - ASC[0x17], ASCQ[0x09] |
| 62:647 | The SCSI device recovered data with error correction applied. SCSI Error - ASC[0x18], ASCQ[0x00] |
| 62:648 | The SCSI device recovered data with error correction and retries applied. SCSI Error - ASC[0x18], ASCQ[0x01] |
| 62:649 | The SCSI device recovered data - data auto-relocated. SCSI Error - ASC[0x18], ASCQ[0x02] |
| 62:650 | The SCSI device recovered data with CIRC. SCSI Error - ASC[0x18], ASCQ[0x03] |
| 62:651 | The SCSI device recovered data with L-EC. SCSI Error - ASC[0x18], ASCQ[0x04] |
| 62:652 | The SCSI device recovered data - reassign data. SCSI Error - ASC[0x18], ASCQ[0x05] |
| 62:653 | The SCSI device recovered data - rewrite data. SCSI Error - ASC[0x18], ASCQ[0x06] |
| 62:654 | The SCSI device recovered data with ECC - data rewritten. SCSI Error - ASC[0x18], ASCQ[0x07] |
| 62:655 | Error in the number of parameters passed to the SCSI device. SCSI Error - ASC[0x1A], ASCQ[0x00] |
| 62:656 | The SCSI device reported an error in synchronous data transfer. SCSI Error - ASC[0x1B], ASCQ[0x00] |
| 62:657 | The SCSI device reported a mismatch during a verify operation. SCSI Error - ASC[0x1D], ASCQ[0x00] |
| 62:658 | The SCSI device reported that an invalid operation is being attempted. SCSI Error - ASC[0x20], ASCQ[0x00] |
| 62:659 | LOGICAL BLOCK ADDRESS OUT OF RANGE. SCSI Error - ASC[0x21], ASCQ[0x00] |
| 62:660 | The SCSI device reported an invalid element address in a SCSI command. SCSI Error - ASC[0x21], ASCQ[0x01] |
| 62:661 | The SCSI device reported that an illegal operation is being attempted. SCSI Error - ASC[0x22], ASCQ[0x00] |
| 62:662 | The SCSI device reported an invalid field in a SCSI command. SCSI Error - ASC[0x24], ASCQ[0x00] |
| 62:663 | The SCSI device reported an error while decrypting the SCSI command. SCSI Error - ASC[0x24], ASCQ[0x01] |
| 62:664 | The SCSI device reported that an attempt is being made to write on a read-only data. SCSI Error - ASC[0x24], ASCQ[0x80] |
| 62:665 | The SCSI device reported an illegal logical unit number. SCSI Error - ASC[0x25], ASCQ[0x00] |
| 62:666 | The SCSI device reported an invalid field in the parameter list for the SCSI command. SCSI Error - ASC[0x26], ASCQ[0x00] |
| 62:667 | The SCSI device reported that parameter is not supported for the SCSI command. SCSI Error - ASC[0x26], ASCQ[0x01] |
| 62:668 | The SCSI device reported that parameter in the parameter list for the SCSI command is not valid. SCSI Error - ASC[0x26], ASCQ[0x02] |
| 62:669 | THRESHOLD PARAMETERS NOT SUPPORTED. SCSI Error - ASC[0x26], ASCQ[0x03] |
| 62:670 | INVALID RELEASE OF PERSISTENT RESERVATION. SCSI Error - ASC[0x26], ASCQ[0x04] |
| 62:671 | The SCSI device reported data decryption error. SCSI Error - ASC[0x26], ASCQ[0x05] |
| 62:672 | The SCSI device reported that too many target devices have been specified in the SCSI command. SCSI Error - ASC[0x26], ASCQ[0x06] |
| 62:673 | The SCSI device reported that an unsupported target device has been specified in the SCSI command. SCSI Error - ASC[0x26], ASCQ[0x07] |
| 62:674 | TOO MANY SEGMENT DESCRIPTORS. SCSI Error - ASC[0x26], ASCQ[0x08] |
| 62:675 | UNSUPPORTED SEGMENT DESCRIPTOR TYPE CODE. SCSI Error - ASC[0x26], ASCQ[0x09] |
| 62:676 | UNEXPECTED INEXACT SEGMENT. SCSI Error - ASC[0x26], ASCQ[0x0A] |
| 62:677 | INLINE DATA LENGTH EXCEEDED. SCSI Error - ASC[0x26], ASCQ[0x0B] |
| 62:678 | The SCSI device reported an invalid operation for copy source or destination. SCSI Error - ASC[0x26], ASCQ[0x0C] |
| 62:679 | COPY SEGMENT GRANULARITY VIOLATION. SCSI Error - ASC[0x26], ASCQ[0x0D] |
| 62:680 | The SCSI device reported data checksum failure in the parameters of the SCSI command. SCSI Error - ASC[0x26], ASCQ[0x80] |
| 62:681 | The SCSI device reported that the media is write-protected. SCSI Error - ASC[0x27], ASCQ[0x00] |
| 62:682 | The SCSI device reported that the media is hardware write-protected. SCSI Error - ASC[0x27], ASCQ[0x01] |
| 62:683 | The SCSI device reported that the media is software write-protected. SCSI Error - ASC[0x27], ASCQ[0x02] |
| 62:684 | ASSOCIATED WRITE PROTECT. SCSI Error - ASC[0x27], ASCQ[0x03] |
| 62:685 | PERSISTENT WRITE PROTECT. SCSI Error - ASC[0x27], ASCQ[0x04] |
| 62:686 | PERMANENT WRITE PROTECT. SCSI Error - ASC[0x27], ASCQ[0x05] |
| 62:687 | The SCSI device reported that the medium may have changed. Doors opened or closed. SCSI Error - ASC[0x28], ASCQ[0x00] |
| 62:688 | The SCSI device reported that the import or export slot may have been opened. SCSI Error - ASC[0x28], ASCQ[0x01] |
| 62:689 | The SCSI device reported that power on reset, or bus device reset occurred. SCSI Error - ASC[0x29], ASCQ[0x00] |
| 62:690 | POWER ON OCCURRED. SCSI Error - ASC[0x29], ASCQ[0x01] |
| 62:691 | The SCSI device reported that SCSI bus reset occurred. SCSI Error - ASC[0x29], ASCQ[0x02] |
| 62:692 | The SCSI device reported that SCSI bus device reset occurred. SCSI Error - ASC[0x29], ASCQ[0x03] |
| 62:693 | The SCSI device reported that the device internal reset occurred. SCSI Error - ASC[0x29], ASCQ[0x04] |
| 62:694 | The SCSI device transceiver mode changed to single-ended. SCSI Error - ASC[0x29], ASCQ[0x05] |
| 62:695 | The SCSI device transceiver mode changed to LVD. SCSI Error - ASC[0x29], ASCQ[0x06] |
| 62:696 | Reset SCSI device for permanent error occurred. SCSI Error - ASC[0x29], ASCQ[0x80] |
| 62:697 | Reset SCSI device into degraded mode of operation. SCSI Error - ASC[0x29], ASCQ[0x81] |
| 62:698 | PARAMETERS CHANGED. SCSI Error - ASC[0x2A], ASCQ[0x00] |
| 62:699 | MODE PARAMETERS CHANGED. SCSI Error - ASC[0x2A], ASCQ[0x01] |
| 62:700 | LOG PARAMETERS CHANGED. SCSI Error - ASC[0x2A], ASCQ[0x02] |
| 62:701 | RESERVATIONS PREEMPTED. SCSI Error - ASC[0x2A], ASCQ[0x03] |
| 62:702 | RESERVATIONS RELEASED. SCSI Error - ASC[0x2A], ASCQ[0x04] |
| 62:703 | REGISTRATIONS PREEMPTED. SCSI Error - ASC[0x2A], ASCQ[0x05] |
| 62:704 | COPY CANNOT EXECUTE SINCE HOST CANNOT DISCONNECT. SCSI Error - ASC[0x2B], ASCQ[0x00] |
| 62:705 | The SCSI device reported that a wrong sequence of commands has been issued to the device. SCSI Error - ASC[0x2C], ASCQ[0x00] |
| 62:706 | ILLEGAL POWER CONDITION REQUEST. SCSI Error - ASC[0x2C], ASCQ[0x05] |
| 62:707 | OVERWRITE ERROR ON UPDATE IN PLACE. SCSI Error - ASC[0x2D], ASCQ[0x00] |
| 62:708 | ERROR DETECTED BY THIRD PARTY TEMPORARY INITIATOR. SCSI Error - ASC[0x2E], ASCQ[0x00] |
| 62:709 | THIRD PARTY DEVICE FAILURE. SCSI Error - ASC[0x2E], ASCQ[0x01] |
| 62:710 | COPY TARGET DEVICE NOT REACHABLE. SCSI Error - ASC[0x2E], ASCQ[0x02] |
| 62:711 | INCORRECT COPY TARGET DEVICE TYPE. SCSI Error - ASC[0x2E], ASCQ[0x03] |
| 62:712 | COPY TARGET DEVICE DATA UNDERRUN. SCSI Error - ASC[0x2E], ASCQ[0x04] |
| 62:713 | COPY TARGET DEVICE DATA OVERRUN. SCSI Error - ASC[0x2E], ASCQ[0x05] |
| 62:714 | COMMANDS CLEARED BY ANOTHER INITIATOR. SCSI Error - ASC[0x2F], ASCQ[0x00] |
| 62:715 | Incompatible Medium Installed. SCSI Error - ASC[0x30], ASCQ[0x00] |
| 62:716 | The SCSI device reported that the application cannot read the medium as the format is unknown. SCSI Error - ASC[0x30], ASCQ[0x01] |
| 62:717 | The SCSI device reported that the application cannot read the medium as the format is incompatible. SCSI Error - ASC[0x30], ASCQ[0x02] |
| 62:718 | The SCSI device reported that cleaning cartridge has been installed. SCSI Error - ASC[0x30], ASCQ[0x03] |
| 62:719 | The SCSI device reported that the application cannot write into medium as the format is unknown. SCSI Error - ASC[0x30], ASCQ[0x04] |
| 62:720 | The SCSI device reported that the application cannot write into medium as the format is incompatible. SCSI Error - ASC[0x30], ASCQ[0x05] |
| 62:721 | The SCSI device reported that format medium failed as the medium is incompatible. SCSI Error - ASC[0x30], ASCQ[0x06] |
| 62:722 | The SCSI device reported that there was a cleaning failure. SCSI Error - ASC[0x30], ASCQ[0x07] |
| 62:723 | The SCSI device reported that write failed as there was an application code mismatch. SCSI Error - ASC[0x30], ASCQ[0x08] |
| 62:724 | CURRENT SESSION NOT FIXATED FOR APPEND. SCSI Error - ASC[0x30], ASCQ[0x09] |
| 62:725 | The SCSI device reported that medium format is corrupted. SCSI Error - ASC[0x31], ASCQ[0x00] |
| 62:726 | The SCSI device reported that format failed. SCSI Error - ASC[0x31], ASCQ[0x01] |
| 62:727 | NO DEFECT SPARE LOCATION AVAILABLE. SCSI Error - ASC[0x32], ASCQ[0x00] |
| 62:728 | TAPE LENGTH ERROR. SCSI Error - ASC[0x33], ASCQ[0x00] |
| 62:729 | ENCLOSURE FAILURE. SCSI Error - ASC[0x34], ASCQ[0x00] |
| 62:730 | ENCLOSURE SERVICES FAILURE. SCSI Error - ASC[0x35], ASCQ[0x00] |
| 62:731 | UNSUPPORTED ENCLOSURE FUNCTION. SCSI Error - ASC[0x35], ASCQ[0x01] |
| 62:732 | ENCLOSURE SERVICES UNAVAILABLE. SCSI Error - ASC[0x35], ASCQ[0x02] |
| 62:733 | ENCLOSURE SERVICES TRANSFER FAILURE. SCSI Error - ASC[0x35], ASCQ[0x03] |
| 62:734 | ENCLOSURE SERVICES TRANSFER REFUSED. SCSI Error - ASC[0x35], ASCQ[0x04] |
| 62:735 | ROUNDED PARAMETER. SCSI Error - ASC[0x37], ASCQ[0x00] |
| 62:736 | SAVING PARAMETERS NOT SUPPORTED. SCSI Error - ASC[0x39], ASCQ[0x00] |
| 62:737 | The SCSI device reported that the source or target medium is not present. SCSI Error - ASC[0x3A], ASCQ[0x00] |
| 62:738 | The SCSI device reported that the source or target medium is not present - TRAY CLOSED. SCSI Error - ASC[0x3A], ASCQ[0x01] |
| 62:739 | The SCSI device reported that the source or target medium is not present - TRAY OPEN. SCSI Error - ASC[0x3A], ASCQ[0x02] |
| 62:740 | The SCSI device reported that the source or target medium is not present - LOADABLE. SCSI Error - ASC[0x3A], ASCQ[0x03] |
| 62:741 | The SCSI device reported that the source or target medium is not present - MEDIUM AUXILIARY MEMORY ACCESSIBLE. SCSI Error - ASC[0x3A], ASCQ[0x04] |
| 62:742 | The SCSI device reported sequential positioning error. SCSI Error - ASC[0x3B], ASCQ[0x00] |
| 62:743 | The SCSI device reported error when positioning to the beginning of medium. SCSI Error - ASC[0x3B], ASCQ[0x01] |
| 62:744 | The SCSI device reported error when positioning to the end of medium. SCSI Error - ASC[0x3B], ASCQ[0x02] |
| 62:745 | The SCSI device reported repositioning error. SCSI Error - ASC[0x3B], ASCQ[0x08] |
| 62:746 | The SCSI device read past end of medium. SCSI Error - ASC[0x3B], ASCQ[0x09] |
| 62:747 | The SCSI device read past beginning of medium. SCSI Error - ASC[0x3B], ASCQ[0x0A] |
| 62:748 | The SCSI device positioned past the end of medium. SCSI Error - ASC[0x3B], ASCQ[0x0B] |
| 62:749 | The SCSI device positioned past the beginning of medium. SCSI Error - ASC[0x3B], ASCQ[0x0C] |
| 62:750 | The SCSI device reported destination element is full. SCSI Error - ASC[0x3B], ASCQ[0x0D] |
| 62:751 | The SCSI device reported source element is empty. SCSI Error - ASC[0x3B], ASCQ[0x0E] |
| 62:752 | The SCSI device reported that the end of medium has been reached. SCSI Error - ASC[0x3B], ASCQ[0x0F] |
| 62:753 | The SCSI device reported that medium magazine is not accessible. SCSI Error - ASC[0x3B], ASCQ[0x11] |
| 62:754 | The SCSI device reported that medium magazine is removed. SCSI Error - ASC[0x3B], ASCQ[0x12] |
| 62:755 | The SCSI device reported that medium magazine is inserted. SCSI Error - ASC[0x3B], ASCQ[0x13] |
| 62:756 | The SCSI device reported that medium magazine is locked. SCSI Error - ASC[0x3B], ASCQ[0x14] |
| 62:757 | The SCSI device reported that medium magazine is unlocked. SCSI Error - ASC[0x3B], ASCQ[0x15] |
| 62:758 | The SCSI device reported mechanical positioning or changer error. SCSI Error - ASC[0x3B], ASCQ[0x16] |
| 62:759 | The SCSI device reported that the arm changer is full before command. SCSI Error - ASC[0x3B], ASCQ[0x80] |
| 62:760 | The SCSI device reported firmware Error. SCSI Error - ASC[0x3B], ASCQ[0x81] |
| 62:761 | The SCSI device reported that the element is not accessible, cartridge present was exported by another logical library. SCSI Error - ASC[0x3B], ASCQ[0x81] |
| 62:762 | The SCSI device reported that the element not accessible. Drive is not present. SCSI Error - ASC[0x3B], ASCQ[0x82] |
| 62:763 | The SCSI device reported the arm changer is unable to pick the cartridge from the tape drive. SCSI Error - ASC[0x3B], ASCQ[0x83] |
| 62:764 | The SCSI device reported that the destination of move medium operation cannot be accessor. SCSI Error - ASC[0x3B], ASCQ[0x85] |
| 62:765 | The SCSI device reported that the source of move medium operation cannot be accessor. SCSI Error - ASC[0x3B], ASCQ[0x86] |
| 62:766 | The SCSI device reported that the cartridge stuck in tape drive. SCSI Error - ASC[0x3B], ASCQ[0x87] |
| 62:767 | The SCSI device reported that the drive cannot be loaded. SCSI Error - ASC[0x3B], ASCQ[0x89] |
| 62:768 | The SCSI device reported that the source cartridge is loaded into tape drive and is not accessible. SCSI Error - ASC[0x3B], ASCQ[0x90] |
| 62:769 | The SCSI device reported that the arm changer movement has been interrupted. SCSI Error - ASC[0x3B], ASCQ[0x91] |
| 62:770 | The SCSI device reported that the media type does not match destination media type. SCSI Error - ASC[0x3B], ASCQ[0xA0] |
| 62:771 | INVALID BITS IN IDENTIFY MESSAGE. SCSI Error - ASC[0x3D], ASCQ[0x00] |
| 62:772 | The SCSI device reported that the host must allow SCSI disconnects for the operation to be complete. SCSI Error - ASC[0x3D], ASCQ[0x80] |
| 62:773 | The SCSI device reported that the logical unit has not self-configured yet. SCSI Error - ASC[0x3E], ASCQ[0x00] |
| 62:774 | The SCSI device reported a logical unit failure. SCSI Error - ASC[0x3E], ASCQ[0x01] |
| 62:775 | The SCSI device reported a SCSI timeout on the logical unit. SCSI Error - ASC[0x3E], ASCQ[0x02] |
| 62:776 | The SCSI device reported that the logical unit failed self test. SCSI Error - ASC[0x3E], ASCQ[0x03] |
| 62:777 | The SCSI device reported that the logical unit failed to update self test log. SCSI Error - ASC[0x3E], ASCQ[0x04] |
| 62:778 | The SCSI device reported that the operating conditions of the SCSI target device have changed. SCSI Error - ASC[0x3F], ASCQ[0x00] |
| 62:779 | The SCSI device reported that the microcode has been changed. SCSI Error - ASC[0x3F], ASCQ[0x01] |
| 62:780 | The SCSI device reported that the SCSI device operating definitions have changed. SCSI Error - ASC[0x3F], ASCQ[0x02] |
| 62:781 | The SCSI device reported that the inquiry data has changed. SCSI Error - ASC[0x3F], ASCQ[0x03] |
| 62:782 | The SCSI device reported that a component device has been attached. SCSI Error - ASC[0x3F], ASCQ[0x04] |
| 62:783 | The SCSI device reported that the SCSI device identifier changed. SCSI Error - ASC[0x3F], ASCQ[0x05] |
| 62:784 | REDUNDANCY GROUP CREATED OR MODIFIED. SCSI Error - ASC[0x3F], ASCQ[0x06] |
| 62:785 | REDUNDANCY GROUP DELETED. SCSI Error - ASC[0x3F], ASCQ[0x07] |
| 62:786 | SPARE CREATED OR MODIFIED. SCSI Error - ASC[0x3F], ASCQ[0x08] |
| 62:787 | SPARE DELETED. SCSI Error - ASC[0x3F], ASCQ[0x09] |
| 62:788 | VOLUME SET CREATED OR MODIFIED. SCSI Error - ASC[0x3F], ASCQ[0x0A] |
| 62:789 | VOLUME SET DELETED. SCSI Error - ASC[0x3F], ASCQ[0x0B] |
| 62:790 | VOLUME SET DEASSIGNED. SCSI Error - ASC[0x3F], ASCQ[0x0C] |
| 62:791 | VOLUME SET REASSIGNED. SCSI Error - ASC[0x3F], ASCQ[0x0D] |
| 62:792 | The SCSI device reported that the LUNS data has changed. SCSI Error - ASC[0x3F], ASCQ[0x0E] |
| 62:793 | ECHO BUFFER OVERWRITTEN. SCSI Error - ASC[0x3F], ASCQ[0x0F] |
| 62:794 | The SCSI device reported that the medium is loadable. SCSI Error - ASC[0x3F], ASCQ[0x10] |
| 62:795 | The SCSI device reported that the medium auxiliary memory is accessible. SCSI Error - ASC[0x3F], ASCQ[0x11] |
| 62:796 | The SCSI device reported that it could not erase EEPROM. SCSI Error - ASC[0x3F], ASCQ[0x80] |
| 62:797 | The SCSI device reported that it could not program EEPROM. SCSI Error - ASC[0x3F], ASCQ[0x84] |
| 62:798 | The SCSI device reported that it cannot execute a WRITE BUFFER command. The console write firmware operation is in progress. SCSI Error - ASC[0x3F], ASCQ[0x87] |
| 62:799 | The SCSI device reported that it cannot execute a WRITE BUFFER command. The console read firmware operation is in progress. SCSI Error - ASC[0x3F], ASCQ[0x88] |
| 62:800 | The SCSI device reported a RAM failure. SCSI Error - ASC[0x40], ASCQ[0x00] |
| 62:801 | The SCSI device reported that a cartridge is in the gripper at power on. SCSI Error - ASC[0x40], ASCQ[0x01] |
| 62:802 | The SCSI device reported a component failure. SCSI Error - ASC[0x40], ASCQ[0x80] |
| 62:803 | The SCSI device reported a gripper error. SCSI Error - ASC[0x40], ASCQ[0x91] |
| 62:804 | The SCSI device reported that the accessor could not move on vertical axis. SCSI Error - ASC[0x40], ASCQ[0xA0] |
| 62:805 | The SCSI device reported that the accessor could not home the vertical axis. SCSI Error - ASC[0x40], ASCQ[0xA1] |
| 62:806 | The SCSI device reported that the accessor could not move the horizontal axis. SCSI Error - ASC[0x40], ASCQ[0xB0] |
| 62:807 | The SCSI device reported that the accessor could not home the horizontal axis (Scalar 1000). SCSI Error - ASC[0x40], ASCQ[0xB1] |
| 62:808 | The SCSI device reported that the accessor lost power. SCSI Error - ASC[0x40], ASCQ[0xE0] |
| 62:809 | The SCSI device reported that the accessor could not move. SCSI Error - ASC[0x40], ASCQ[0xC0] |
| 62:810 | The SCSI device reported that the front door is open. SCSI Error - ASC[0x40], ASCQ[0x88] |
| 62:811 | DATA PATH FAILURE (SHOULD USE 40 NN). SCSI Error - ASC[0x41], ASCQ[0x00] |
| 62:812 | The SCSI device reported that power-on or self-test failed. SCSI Error - ASC[0x42], ASCQ[0x00] |
| 62:813 | MESSAGE ERROR. Message received at inappropriate time. SCSI Error - ASC[0x43], ASCQ[0x00] |
| 62:814 | The SCSI device reported an internal SCSI target failure. SCSI Error - ASC[0x44], ASCQ[0x00] |
| 62:815 | SELECT OR RESELECT FAILURE. Host rejected Identify message sent for reselection. SCSI Error - ASC[0x45], ASCQ[0x00] |
| 62:816 | The SCSI device reported an unsuccessful soft reset. SCSI Error - ASC[0x46], ASCQ[0x00] |
| 62:817 | The SCSI device reported a SCSI parity error. SCSI Error - ASC[0x47], ASCQ[0x00] |
| 62:818 | The SCSI device reported a CRC error in data phase. SCSI Error - ASC[0x47], ASCQ[0x01] |
| 62:819 | The SCSI device reported a SCSI parity error in data phase. SCSI Error - ASC[0x47], ASCQ[0x02] |
| 62:820 | The SCSI device reported a CRC error in information unit. SCSI Error - ASC[0x47], ASCQ[0x03] |
| 62:821 | ASYNCHRONOUS INFORMATION PROTECTION ERROR DETECTED. SCSI Error - ASC[0x47], ASCQ[0x04] |
| 62:822 | INITIATOR DETECTED ERROR MESSAGE RECEIVED. SCSI Error - ASC[0x48], ASCQ[0x00] |
| 62:823 | The SCSI device reported that invalid messages were transferred between the SCSI devices. SCSI Error - ASC[0x49], ASCQ[0x00] |
| 62:824 | The SCSI device reported an error in the command phase of the SCSI device. SCSI Error - ASC[0x4A], ASCQ[0x00] |
| 62:825 | The SCSI device reported an error in the data phase of the SCSI device. SCSI Error - ASC[0x4B], ASCQ[0x00] |
| 62:826 | The SCSI device reported that the logical unit failed self-reconfiguration. SCSI Error - ASC[0x4C], ASCQ[0x00] |
| 62:827 | TAGGED OVERLAPPED COMMANDS (NN = QUEUE TAG). SCSI Error - ASC[0x4D], ASCQ[0x00] |
| 62:828 | OVERLAPPED COMMANDS ATTEMPTED. Disconnect during command processing. SCSI Error - ASC[0x4E], ASCQ[0x00] |
| 62:829 | WRITE APPEND ERROR. SCSI Error - ASC[0x50], ASCQ[0x00] |
| 62:830 | WRITE APPEND POSITION ERROR. SCSI Error - ASC[0x50], ASCQ[0x01] |
| 62:831 | POSITION ERROR RELATED TO TIMING. SCSI Error - ASC[0x50], ASCQ[0x02] |
| 62:832 | ERASE FAILURE. SCSI Error - ASC[0x51], ASCQ[0x00] |
| 62:833 | The SCSI device reported a cartridge fault. SCSI Error - ASC[0x52], ASCQ[0x00] |
| 62:834 | The SCSI device reported that the media load or eject failed. SCSI Error - ASC[0x53], ASCQ[0x00] |
| 62:835 | The SCSI device reported that the medium unload failed. SCSI Error - ASC[0x53], ASCQ[0x01] |
| 62:836 | The SCSI device prevented the removal of medium. SCSI Error - ASC[0x53], ASCQ[0x02] |
| 62:837 | The SCSI device reported that the cartridge was rejected in the Import/Export slot as it was not properly loaded. SCSI Error - ASC[0x53], ASCQ[0x80] |
| 62:838 | The SCSI device reported that the cartridge is jammed. SCSI Error - ASC[0x53], ASCQ[0x80] |
| 62:839 | The SCSI device reported import/export slot door is open. SCSI Error - ASC[0x53], ASCQ[0x81] |
| 62:840 | The SCSI device reported that it cannot lock the Import/Export slot. SCSI Error - ASC[0x53], ASCQ[0x82] |
| 62:841 | The SCSI device reported that it cannot unlock the Import/Export slot. SCSI Error - ASC[0x53], ASCQ[0x83] |
| 62:842 | The SCSI device reported a failure in the interface of the SCSI device and the host system. SCSI Error - ASC[0x54], ASCQ[0x00] |
| 62:843 | SYSTEM RESOURCE FAILURE. SCSI Error - ASC[0x55], ASCQ[0x00] |
| 62:844 | SYSTEM BUFFER FULL. SCSI Error - ASC[0x55], ASCQ[0x01] |
| 62:845 | INSUFFICIENT RESERVATION RESOURCES. SCSI Error - ASC[0x55], ASCQ[0x02] |
| 62:846 | INSUFFICIENT RESOURCES. SCSI Error - ASC[0x55], ASCQ[0x03] |
| 62:847 | INSUFFICIENT REGISTRATION RESOURCES. SCSI Error - ASC[0x55], ASCQ[0x04] |
| 62:848 | UNABLE TO RECOVER TABLE-OF-CONTENTS. SCSI Error - ASC[0x57], ASCQ[0x00] |
| 62:849 | GENERATION DOES NOT EXIST. SCSI Error - ASC[0x58], ASCQ[0x00] |
| 62:850 | UPDATED BLOCK READ. SCSI Error - ASC[0x59], ASCQ[0x00] |
| 62:851 | OPERATOR REQUEST OR STATE CHANGE INPUT. Drive offline. SCSI Error - ASC[0x5A], ASCQ[0x00] |
| 62:852 | OPERATOR MEDIUM REMOVAL REQUEST. SCSI Error - ASC[0x5A], ASCQ[0x01] |
| 62:853 | OPERATOR SELECTED WRITE PROTECT. SCSI Error - ASC[0x5A], ASCQ[0x02] |
| 62:854 | OPERATOR SELECTED WRITE PERMIT. SCSI Error - ASC[0x5A], ASCQ[0x03] |
| 62:855 | LOG EXCEPTION. SCSI Error - ASC[0x5B], ASCQ[0x00] |
| 62:856 | THRESHOLD CONDITION MET. SCSI Error - ASC[0x5B], ASCQ[0x01] |
| 62:857 | LOG COUNTER AT MAXIMUM. SCSI Error - ASC[0x5B], ASCQ[0x02] |
| 62:858 | LOG LIST CODES EXHAUSTED. SCSI Error - ASC[0x5B], ASCQ[0x03] |
| 62:859 | RPL STATUS CHANGE. SCSI Error - ASC[0x5C], ASCQ[0x00] |
| 62:860 | SPINDLES SYNCHRONIZED. SCSI Error - ASC[0x5C], ASCQ[0x01] |
| 62:861 | SPINDLES NOT SYNCHRONIZED. SCSI Error - ASC[0x5C], ASCQ[0x02] |
| 62:862 | FAILURE PREDICTION THRESHOLD EXCEEDED. SCSI Error - ASC[0x5D], ASCQ[0x00] |
| 62:863 | MEDIA FAILURE PREDICTION THRESHOLD EXCEEDED. SCSI Error - ASC[0x5D], ASCQ[0x01] |
| 62:864 | LOGICAL UNIT FAILURE PREDICTION THRESHOLD EXCEEDED. SCSI Error - ASC[0x5D], ASCQ[0x02] |
| 62:865 | HARDWARE IMPENDING FAILURE GENERAL HARD DRIVE FAILURE. SCSI Error - ASC[0x5D], ASCQ[0x10] |
| 62:866 | HARDWARE IMPENDING FAILURE DRIVE ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x11] |
| 62:867 | HARDWARE IMPENDING FAILURE DATA ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x12] |
| 62:868 | HARDWARE IMPENDING FAILURE SEEK ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x13] |
| 62:869 | HARDWARE IMPENDING FAILURE TOO MANY BLOCK REASSIGNS. SCSI Error - ASC[0x5D], ASCQ[0x14] |
| 62:870 | HARDWARE IMPENDING FAILURE ACCESS TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x15] |
| 62:871 | HARDWARE IMPENDING FAILURE START UNIT TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x16] |
| 62:872 | HARDWARE IMPENDING FAILURE CHANNEL PARAMETRICS. SCSI Error - ASC[0x5D], ASCQ[0x17] |
| 62:873 | HARDWARE IMPENDING FAILURE CONTROLLER DETECTED. SCSI Error - ASC[0x5D], ASCQ[0x18] |
| 62:874 | HARDWARE IMPENDING FAILURE THROUGHPUT PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x19] |
| 62:875 | HARDWARE IMPENDING FAILURE SEEK TIME PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x1A] |
| 62:876 | HARDWARE IMPENDING FAILURE SPIN-UP RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x1B] |
| 62:877 | HARDWARE IMPENDING FAILURE DRIVE CALIBRATION RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x1C] |
| 62:878 | CONTROLLER IMPENDING FAILURE GENERAL HARD DRIVE FAILURE. SCSI Error - ASC[0x5D], ASCQ[0x20] |
| 62:879 | CONTROLLER IMPENDING FAILURE DRIVE ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x21] |
| 62:880 | CONTROLLER IMPENDING FAILURE DATA ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x22] |
| 62:881 | CONTROLLER IMPENDING FAILURE SEEK ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x23] |
| 62:882 | CONTROLLER IMPENDING FAILURE TOO MANY BLOCK REASSIGNS. SCSI Error - ASC[0x5D], ASCQ[0x24] |
| 62:883 | CONTROLLER IMPENDING FAILURE ACCESS TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x25] |
| 62:884 | CONTROLLER IMPENDING FAILURE START UNIT TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x26] |
| 62:885 | CONTROLLER IMPENDING FAILURE CHANNEL PARAMETRICS. SCSI Error - ASC[0x5D], ASCQ[0x27] |
| 62:886 | CONTROLLER IMPENDING FAILURE CONTROLLER DETECTED. SCSI Error - ASC[0x5D], ASCQ[0x28] |
| 62:887 | CONTROLLER IMPENDING FAILURE THROUGHPUT PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x29] |
| 62:888 | CONTROLLER IMPENDING FAILURE SEEK TIME PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x2A] |
| 62:889 | CONTROLLER IMPENDING FAILURE SPIN-UP RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x2B] |
| 62:890 | CONTROLLER IMPENDING FAILURE DRIVE CALIBRATION RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x2C] |
| 62:891 | DATA CHANNEL IMPENDING FAILURE GENERAL HARD DRIVE FAILURE. SCSI Error - ASC[0x5D], ASCQ[0x30] |
| 62:892 | DATA CHANNEL IMPENDING FAILURE DRIVE ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x31] |
| 62:893 | DATA CHANNEL IMPENDING FAILURE DATA ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x32] |
| 62:894 | DATA CHANNEL IMPENDING FAILURE SEEK ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x33] |
| 62:895 | DATA CHANNEL IMPENDING FAILURE TOO MANY BLOCK REASSIGNS. SCSI Error - ASC[0x5D], ASCQ[0x34] |
| 62:896 | DATA CHANNEL IMPENDING FAILURE ACCESS TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x35] |
| 62:897 | DATA CHANNEL IMPENDING FAILURE START UNIT TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x36] |
| 62:898 | DATA CHANNEL IMPENDING FAILURE CHANNEL PARAMETRICS. SCSI Error - ASC[0x5D], ASCQ[0x37] |
| 62:899 | DATA CHANNEL IMPENDING FAILURE CONTROLLER DETECTED. SCSI Error - ASC[0x5D], ASCQ[0x38] |
| 62:900 | DATA CHANNEL IMPENDING FAILURE THROUGHPUT PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x39] |
| 62:901 | DATA CHANNEL IMPENDING FAILURE SEEK TIME PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x3A] |
| 62:902 | DATA CHANNEL IMPENDING FAILURE SPIN-UP RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x3B] |
| 62:903 | DATA CHANNEL IMPENDING FAILURE DRIVE CALIBRATION RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x3C] |
| 62:904 | SERVO IMPENDING FAILURE GENERAL HARD DRIVE FAILURE. SCSI Error - ASC[0x5D], ASCQ[0x40] |
| 62:905 | SERVO IMPENDING FAILURE DRIVE ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x41] |
| 62:906 | SERVO IMPENDING FAILURE DATA ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x42] |
| 62:907 | SERVO IMPENDING FAILURE SEEK ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x43] |
| 62:908 | SERVO IMPENDING FAILURE TOO MANY BLOCK REASSIGNS. SCSI Error - ASC[0x5D], ASCQ[0x44] |
| 62:909 | SERVO IMPENDING FAILURE ACCESS TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x45] |
| 62:910 | SERVO IMPENDING FAILURE START UNIT TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x46] |
| 62:911 | SERVO IMPENDING FAILURE CHANNEL PARAMETRICS. SCSI Error - ASC[0x5D], ASCQ[0x47] |
| 62:912 | SERVO IMPENDING FAILURE CONTROLLER DETECTED. SCSI Error - ASC[0x5D], ASCQ[0x48] |
| 62:913 | SERVO IMPENDING FAILURE THROUGHPUT PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x49] |
| 62:914 | SERVO IMPENDING FAILURE SEEK TIME PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x4A] |
| 62:915 | SERVO IMPENDING FAILURE SPIN-UP RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x4B] |
| 62:916 | SERVO IMPENDING FAILURE DRIVE CALIBRATION RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x4C] |
| 62:917 | SPINDLE IMPENDING FAILURE GENERAL HARD DRIVE FAILURE. SCSI Error - ASC[0x5D], ASCQ[0x50] |
| 62:918 | SPINDLE IMPENDING FAILURE DRIVE ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x51] |
| 62:919 | SPINDLE IMPENDING FAILURE DATA ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x52] |
| 62:920 | SPINDLE IMPENDING FAILURE SEEK ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x53] |
| 62:921 | SPINDLE IMPENDING FAILURE TOO MANY BLOCK REASSIGNS. SCSI Error - ASC[0x5D], ASCQ[0x54] |
| 62:922 | SPINDLE IMPENDING FAILURE ACCESS TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x55] |
| 62:923 | SPINDLE IMPENDING FAILURE START UNIT TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x56] |
| 62:924 | SPINDLE IMPENDING FAILURE CHANNEL PARAMETRICS. SCSI Error - ASC[0x5D], ASCQ[0x57] |
| 62:925 | SPINDLE IMPENDING FAILURE CONTROLLER DETECTED. SCSI Error - ASC[0x5D], ASCQ[0x58] |
| 62:926 | SPINDLE IMPENDING FAILURE THROUGHPUT PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x59] |
| 62:927 | SPINDLE IMPENDING FAILURE SEEK TIME PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x5A] |
| 62:928 | SPINDLE IMPENDING FAILURE SPIN-UP RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x5B] |
| 62:929 | SPINDLE IMPENDING FAILURE DRIVE CALIBRATION RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x5C] |
| 62:930 | FIRMWARE IMPENDING FAILURE GENERAL HARD DRIVE FAILURE. SCSI Error - ASC[0x5D], ASCQ[0x60] |
| 62:931 | FIRMWARE IMPENDING FAILURE DRIVE ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x61] |
| 62:932 | FIRMWARE IMPENDING FAILURE DATA ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x62] |
| 62:933 | FIRMWARE IMPENDING FAILURE SEEK ERROR RATE TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x63] |
| 62:934 | FIRMWARE IMPENDING FAILURE TOO MANY BLOCK REASSIGNS. SCSI Error - ASC[0x5D], ASCQ[0x64] |
| 62:935 | FIRMWARE IMPENDING FAILURE ACCESS TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x65] |
| 62:936 | FIRMWARE IMPENDING FAILURE START UNIT TIMES TOO HIGH. SCSI Error - ASC[0x5D], ASCQ[0x66] |
| 62:937 | FIRMWARE IMPENDING FAILURE CHANNEL PARAMETRICS. SCSI Error - ASC[0x5D], ASCQ[0x67] |
| 62:938 | FIRMWARE IMPENDING FAILURE CONTROLLER DETECTED. SCSI Error - ASC[0x5D], ASCQ[0x68] |
| 62:939 | FIRMWARE IMPENDING FAILURE THROUGHPUT PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x69] |
| 62:940 | FIRMWARE IMPENDING FAILURE SEEK TIME PERFORMANCE. SCSI Error - ASC[0x5D], ASCQ[0x6A] |
| 62:941 | FIRMWARE IMPENDING FAILURE SPIN-UP RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x6B] |
| 62:942 | FIRMWARE IMPENDING FAILURE DRIVE CALIBRATION RETRY COUNT. SCSI Error - ASC[0x5D], ASCQ[0x6C] |
| 62:943 | FAILURE PREDICTION THRESHOLD EXCEEDED (FALSE). SCSI Error - ASC[0x5D], ASCQ[0xFF] |
| 62:944 | LOW POWER CONDITION ON. SCSI Error - ASC[0x5E], ASCQ[0x00] |
| 62:945 | IDLE CONDITION ACTIVATED BY TIMER. SCSI Error - ASC[0x5E], ASCQ[0x01] |
| 62:946 | STANDBY CONDITION ACTIVATED BY TIMER. SCSI Error - ASC[0x5E], ASCQ[0x02] |
| 62:947 | IDLE CONDITION ACTIVATED BY COMMAND. SCSI Error - ASC[0x5E], ASCQ[0x03] |
| 62:948 | STANDBY CONDITION ACTIVATED BY COMMAND. SCSI Error - ASC[0x5E], ASCQ[0x04] |
| 62:949 | POWER STATE CHANGE TO ACTIVE. SCSI Error - ASC[0x5E], ASCQ[0x41] |
| 62:950 | POWER STATE CHANGE TO IDLE. SCSI Error - ASC[0x5E], ASCQ[0x42] |
| 62:951 | POWER STATE CHANGE TO STANDBY. SCSI Error - ASC[0x5E], ASCQ[0x43] |
| 62:952 | POWER STATE CHANGE TO SLEEP. SCSI Error - ASC[0x5E], ASCQ[0x45] |
| 62:953 | POWER STATE CHANGE TO DEVICE CONTROL. SCSI Error - ASC[0x5E], ASCQ[0x47] |
| 62:954 | PACKET DOES NOT FIT IN AVAILABLE SPACE. SCSI Error - ASC[0x63], ASCQ[0x01] |
| 62:955 | INVALID PACKET SIZE. SCSI Error - ASC[0x64], ASCQ[0x01] |
| 62:956 | VOLTAGE FAULT. SCSI Error - ASC[0x65], ASCQ[0x00] |
| 62:957 | CONFIGURATION FAILURE. SCSI Error - ASC[0x67], ASCQ[0x00] |
| 62:958 | CONFIGURATION OF INCAPABLE LOGICAL UNITS FAILED. SCSI Error - ASC[0x67], ASCQ[0x01] |
| 62:959 | ADD LOGICAL UNIT FAILED. SCSI Error - ASC[0x67], ASCQ[0x02] |
| 62:960 | MODIFICATION OF LOGICAL UNIT FAILED. SCSI Error - ASC[0x67], ASCQ[0x03] |
| 62:961 | EXCHANGE OF LOGICAL UNIT FAILED. SCSI Error - ASC[0x67], ASCQ[0x04] |
| 62:962 | REMOVAL OF LOGICAL UNIT FAILED. SCSI Error - ASC[0x67], ASCQ[0x05] |
| 62:963 | ATTACHMENT OF LOGICAL UNIT FAILED. SCSI Error - ASC[0x67], ASCQ[0x06] |
| 62:964 | CREATION OF LOGICAL UNIT FAILED. SCSI Error - ASC[0x67], ASCQ[0x07] |
| 62:965 | ASSIGN FAILURE OCCURRED. SCSI Error - ASC[0x67], ASCQ[0x08] |
| 62:966 | MULTIPLY ASSIGNED LOGICAL UNIT. SCSI Error - ASC[0x67], ASCQ[0x09] |
| 62:967 | LOGICAL UNIT NOT CONFIGURED. SCSI Error - ASC[0x68], ASCQ[0x00] |
| 62:968 | DATA LOSS ON LOGICAL UNIT. SCSI Error - ASC[0x69], ASCQ[0x00] |
| 62:969 | MULTIPLE LOGICAL UNIT FAILURES. SCSI Error - ASC[0x69], ASCQ[0x01] |
| 62:970 | PARITY/DATA MISMATCH. SCSI Error - ASC[0x69], ASCQ[0x02] |
| 62:971 | INFORMATIONAL, REFER TO LOG. SCSI Error - ASC[0x6A], ASCQ[0x00] |
| 62:972 | STATE CHANGE HAS OCCURRED. SCSI Error - ASC[0x6B], ASCQ[0x00] |
| 62:973 | REDUNDANCY LEVEL GOT BETTER. SCSI Error - ASC[0x6B], ASCQ[0x01] |
| 62:974 | REDUNDANCY LEVEL GOT WORSE. SCSI Error - ASC[0x6B], ASCQ[0x02] |
| 62:975 | REBUILD FAILURE OCCURRED. SCSI Error - ASC[0x6C], ASCQ[0x00] |
| 62:976 | RECALCULATE FAILURE OCCURRED. SCSI Error - ASC[0x6D], ASCQ[0x00] |
| 62:977 | COMMAND TO LOGICAL UNIT FAILED. SCSI Error - ASC[0x6E], ASCQ[0x00] |
| 62:978 | COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE. SCSI Error - ASC[0x6F], ASCQ[0x00] |
| 62:979 | COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT. SCSI Error - ASC[0x6F], ASCQ[0x01] |
| 62:980 | COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED. SCSI Error - ASC[0x6F], ASCQ[0x02] |
| 62:981 | READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION. SCSI Error - ASC[0x6F], ASCQ[0x03] |
| 62:982 | MEDIA REGION CODE IS MISMATCHED TO LOGICAL UNIT REGION. SCSI Error - ASC[0x6F], ASCQ[0x04] |
| 62:983 | DRIVE REGION MUST BE PERMANENT/REGION RESET COUNT ERROR. SCSI Error - ASC[0x6F], ASCQ[0x05] |
| 62:984 | DECOMPRESSION EXCEPTION SHORT ALGORITHM ID OF NN - special case. SCSI Error - ASC[0x70], ASCQ[0x00] |
| 62:985 | DECOMPRESSION EXCEPTION LONG ALGORITHM ID. SCSI Error - ASC[0x71], ASCQ[0x00] |
| 62:986 | SESSION FIXATION ERROR. SCSI Error - ASC[0x72], ASCQ[0x00] |
| 62:987 | SESSION FIXATION ERROR WRITING LEAD-IN. SCSI Error - ASC[0x72], ASCQ[0x01] |
| 62:988 | SESSION FIXATION ERROR WRITING LEAD-OUT. SCSI Error - ASC[0x72], ASCQ[0x02] |
| 62:989 | SESSION FIXATION ERROR - INCOMPLETE TRACK IN SESSION. SCSI Error - ASC[0x72], ASCQ[0x03] |
| 62:990 | EMPTY OR PARTIALLY WRITTEN RESERVED TRACK. SCSI Error - ASC[0x72], ASCQ[0x04] |
| 62:991 | NO MORE TRACK RESERVATIONS ALLOWED. SCSI Error - ASC[0x72], ASCQ[0x05] |
| 62:992 | POWER CALIBRATION AREA ALMOST FULL. SCSI Error - ASC[0x73], ASCQ[0x01] |
| 62:993 | POWER CALIBRATION AREA IS FULL. SCSI Error - ASC[0x73], ASCQ[0x02] |
| 62:994 | POWER CALIBRATION AREA ERROR. SCSI Error - ASC[0x73], ASCQ[0x03] |
| 62:995 | PROGRAM MEMORY AREA UPDATE FAILURE. SCSI Error - ASC[0x73], ASCQ[0x04] |
| 62:996 | PROGRAM MEMORY AREA IS FULL. SCSI Error - ASC[0x73], ASCQ[0x05] |
| 62:997 | RMA/PMA IS FULL. SCSI Error - ASC[0x73], ASCQ[0x06] |
| 62:998 | The library reported that the picker is not empty. SCSI Error - ASC[0x80], ASCQ[0x01] |
| 62:999 | The SCSI device reported that it cannot execute a command because the entry/exit port is unlocked. SCSI Error - ASC[0x80], ASCQ[0x02] |
| 62:1000 | The library reported that there is no Source element. SCSI Error - ASC[0x80], ASCQ[0x03] |
| 62:1001 | The library reported that there is no Destination element. SCSI Error - ASC[0x80], ASCQ[0x04] |
| 62:1002 | The library reported drive is not present. SCSI Error - ASC[0x80], ASCQ[0x05] |
| 62:1003 | The library reported drive is not present. SCSI Error - ASC[0x80], ASCQ[0x06] |
| 62:1004 | The library reported drive is in wrong slot. Single drive units must have the drive installed in Slot 1 next to the cartridge magazine. SCSI Error - ASC[0x80], ASCQ[0x07] |
| 62:1005 | The library reported that all slots are full. SCSI Error - ASC[0x80], ASCQ[0x0D] |
| 62:1006 | The SCSI device reported that the drive is occupied. The tape drive could not be calibrated. SCSI Error - ASC[0x80], ASCQ[0x0D] |
| 62:1007 | The SCSI device reported that a drive has been removed. SCSI Error - ASC[0x80], ASCQ[0x0E] |
| 62:1008 | The SCSI device reported that a drive has been added. SCSI Error - ASC[0x80], ASCQ[0x0F] |
| 62:1009 | The SCSI device reported that conflict element is reserved. SCSI Error - ASC[0x80], ASCQ[0x18] |
| 62:1010 | Mode mismatch. Fixes/variable (EXABYTE Mammoth 1). SCSI Error - ASC[0x81], ASCQ[0x00] |
| 62:1011 | The SCSI device reported that the drive failed to come ready. SCSI Error - ASC[0x81], ASCQ[0x04] |
| 62:1012 | The SCSI device reported that the drive requires cleaning. SCSI Error - ASC[0x82], ASCQ[0x82] |
| 62:1013 | The SCSI device reported problem reading the barcode. SCSI Error - ASC[0x83], ASCQ[0x00] |
| 62:1014 | The SCSI device cannot read a barcode label due to scan problem. SCSI Error - ASC[0x83], ASCQ[0x01] |
| 62:1015 | The SCSI device reported that no drive is installed indicating that the element is in a magazine that is not fitted. SCSI Error - ASC[0x83], ASCQ[0x02] |
| 62:1016 | The SCSI device reported that no drive is installed indicating that the element is in a tape drive that is not fitted. SCSI Error - ASC[0x83], ASCQ[0x04] |
| 62:1017 | The SCSI device reported that there is no label. SCSI Error - ASC[0x83], ASCQ[0x09] |
| 62:1018 | The SCSI device reported that the request is illegal. Bad element address. SCSI Error - ASC[0x83], ASCQ[0x10] |
| 62:1019 | The SCSI device reported that X axis calibration failed. SCSI Error - ASC[0x83], ASCQ[0x10] |
| 62:1020 | Library is full or overfull. Remove tapes. SCSI Error - ASC[0x83], ASCQ[0x12] |
| 62:1021 | The SCSI device reported a firmware error.//duplicates. SCSI Error - ASC[0x84], ASCQ[0x00] |
| 62:1022 | The SCSI device reported that the SCSI operation is not supported. SCSI Error - ASC[0x84], ASCQ[0x00] |
| 62:1023 | The SCSI device received no response from SCSI target. SCSI Error - ASC[0x84], ASCQ[0x01] |
| 62:1024 | The SCSI device reported check condition from SCSI target. SCSI Error - ASC[0x84], ASCQ[0x02] |
| 62:1025 | The SCSI device reported that the SCSI ID is the same as the library ID. SCSI Error - ASC[0x84], ASCQ[0x03] |
| 62:1026 | The SCSI device reported that two or more of the library's SCSI IDs are the same. SCSI Error - ASC[0x84], ASCQ[0x04] |
| 62:1027 | The SCSI device reported that the SCSI target reported a busy condition. SCSI Error - ASC[0x84], ASCQ[0x08] |
| 62:1028 | OS failure.(EXABYTE 430). SCSI Error - ASC[0x84], ASCQ[0x10] |
| 62:1029 | Could not set alarm.(EXABYTE 430). SCSI Error - ASC[0x84], ASCQ[0x11] |
| 62:1030 | OS message failure.(EXABYTE 430). SCSI Error - ASC[0x84], ASCQ[0x12] |
| 62:1031 | The SCSI device reported a SCSI reservation conflict. SCSI Error - ASC[0x84], ASCQ[0x18] |
| 62:1032 | The SCSI device reported drive Hardware error. SCSI Error - ASC[0x84], ASCQ[0x20] |
| 62:1033 | The SCSI device reported that the drive is not talking. Unable to communicate with tape drive. SCSI Error - ASC[0x84], ASCQ[0x21] |
| 62:1034 | The SCSI device reported that the arm changer is not initialized/The SCSI device reported a configuration problem. No barcode scanner installed. SCSI Error - ASC[0x85], ASCQ[0x01] |
| 62:1035 | The SCSI device reported an error in the arm changer or the drive bay is unoccupied. SCSI Error - ASC[0x85], ASCQ[0x02] |
| 62:1036 | The SCSI device reported an error in the arm changer. SCSI Error - ASC[0x85], ASCQ[0x03] |
| 62:1037 | The SCSI device detected ambient light. SCSI Error - ASC[0x85], ASCQ[0x04] |
| 62:1038 | The SCSI device reported that the calibration came up with a bad value. SCSI Error - ASC[0x85], ASCQ[0x10] |
| 62:1039 | The SCSI device reported that it was unable to retrieve arm changer calibration data. SCSI Error - ASC[0x85], ASCQ[0x11] |
| 62:1040 | The SCSI device reported an error in the arm changer. SCSI Error - ASC[0x85], ASCQ[0x99] |
| 62:1041 | The SCSI device reported that the drive needs cleaning. SCSI Error - ASC[0x86], ASCQ[0x01] |
| 62:1042 | The SCSI device reported that the drive needs cleaning. SCSI Error - ASC[0x86], ASCQ[0x02] |
| 62:1043 | The SCSI device reported that the drive needs cleaning. SCSI Error - ASC[0x86], ASCQ[0x03] |
| 62:1044 | The SCSI device reported that the drive needs cleaning. SCSI Error - ASC[0x86], ASCQ[0x04] |
| 62:1045 | The SCSI device reported that the cleaning tape has been loaded into drives too many times. SCSI Error - ASC[0x86], ASCQ[0x05] |
| 62:1046 | The SCSI device reported that communication with the drive failed. SCSI Error - ASC[0x87], ASCQ[0x21] |
| 62:1047 | The SCSI device reported that the communication with the drive timed out. SCSI Error - ASC[0x87], ASCQ[0x23] |
| 62:1048 | The SCSI device reported that the drive load command failed. SCSI Error - ASC[0x87], ASCQ[0x24] |
| 62:1049 | The SCSI device reported that the drive is not ready. SCSI Error - ASC[0x87], ASCQ[0x25] |
| 62:1050 | The SCSI device reported an error in the command issued to the drive. SCSI Error - ASC[0x87], ASCQ[0x26] |
| 62:1051 | The SCSI device reported an error while executing the SCSI operation. |
| 62:1052 | The SCSI device reported an unrecognized SCSI error while executing the SCSI operation. |
| 62:1053 | An incorrect Disk is accessed while reading or writing to the disk. |
| 62:1054 | Inline Auxiliary Copy license not available. |
| 62:1055 | Magic Number of the Mount Path Label does not match. |
| 62:1056 | CommCell ID of the Mount Path Label does not match the current Commcell ID. |
| 62:1057 | Library ID of the Mount Path Label does not match the current Library ID. |
| 62:1058 | Mount Path ID of the Mount Path Label does not match the current Mount Path ID. |
| 62:1059 | The result of a database query indicated that either a non-existent storage policy copy ID was passed or that required index cache entries do not exist in the database. |
| 62:1060 | The Index Cache for the MediaAgent is offline. |
| 62:1061 | License to use DVD Media is not available. |
| 62:1062 | License to use UDO Media is not available. |
| 62:1063 | License for Content Addressed Storage is not available. |
| 62:1064 | License to use WORM Media is not available. |
| 62:1065 | No SCSI Unit found for MediaAgent. Device may not be configured for the MediaAgent. |
| 62:1066 | Error reading SCSI Unit for the MediaAgent. |
| 62:1067 | No SCSI Device found for the device. |
| 62:1068 | Error reading SCSI Device for the device. |
| 62:1069 | Error reading Library specific information. |
| 62:1070 | Cannot parse the XML document. |
| 62:1071 | Error Initializing the XML Parser. |
| 62:1072 | Error reading data from XML document. File may be in use by another process. |
| 62:1073 | No library information found in the XML document. |
| 62:1074 | Cannot find the specified element in the library. |
| 62:1075 | Previous attempt for the job has not released the resources yet. The MediaAgent may still be mounting the media or be stuck in a system call. |
| 62:1076 | Cannot access tape via native tape driver device node [<String>]. Please make sure that native tape driver is attached to all SCSI/FC devices. |
| 62:1077 | User imported the media back into the library that was moved to the mail slot for export. |
| 62:1078 | Drive is stuck. |
| 62:1079 | Writes on Mount Path are disabled. |
| 62:1080 | Error sending message to Media and Library Manager service. |
| 62:1081 | Error receiving message from Media and Library Manager service. |
| 62:1082 | Receiving message from Media and Library Manager service timed out. |
| 62:1083 | Wrong message received from Media and Library Manager service. |
| 62:1084 | Library is marked offline as it is being used for an administrative activity such as Exhaustive Detection. |
| 62:1085 | Failed to query CommCell information. |
| 62:1086 | There are no MediaAgents available to send the SCSI2 Release message for this drive. |
| 62:1087 | There is no SCSI2 reservation on this drive. |
| 62:1088 | The operation cannot be completed as the library is marked broken. |
| 62:1089 | A SCSI command to the drive is stuck on the active drive controlling MediaAgent. |
| 62:1090 | Client cannot use a MediaAgent with older version. |
| 62:1091 | Resources in all data paths are offline or busy. |
| 62:1092 | Drive is SCSI-2 Reserved on another MediaAgent. |
| 62:1093 | Drive is already in the process of being mounted or unmounted. |
| 62:1094 | MediaAgent does not have write access enabled for the mount path to this device. |
| 62:1095 | Duplicate drive ID found in the library. |
| 62:1096 | Total number of slots in the CommCell exceeds the total allowed. |
| 62:1097 | Total number of libraries in the CommCell exceeds the total allowed. |
| 62:1098 | Total number of drives in the CommCell exceeds the total allowed. |
| 62:1099 | Total number of data transfer operations on the MediaAgent exceeds the maximum allowed value. |
| 62:1100 | The cleaning media has retired. |
| 62:1101 | Inline copy cannot start in the same library as the primary copy. |
| 62:1102 | The current job may have been suspended or killed. |
| 62:1103 | Source MediaAgent cannot copy data to the destination MediaAgent with later version. |
| 62:1104 | All spares are from different CommCell. |
| 62:1105 | There are no media for schedule use. |
| 62:1106 | No (subclient) data paths were found for the copy. Probably a library has been deconfigured. |
| 62:1107 | No default data path was found for the copy, but other data paths were found. One data path has to be default. |
| 62:1108 | Cleaning operation detected that a data Cartridge is loaded in the drive instead of Cleaning Media. |
| 62:1109 | Data Mover is in an invalid state and will be destroyed and recreated. This could be due to a mount failure. |
| 62:1110 | Centera Library is either not installed or the installed version is not correct. |
| 62:1111 | MediaAgent version is older than the supported version. |
| 62:1112 | Drive has been marked as inaccessible on this MediaAgent. |
| 62:1113 | A Copy Manager associated with this MediaAgent is used in a Storage and/or OSSV Policy. |
| 62:1114 | Failed to get the license type for the MediaAgent. |
| 62:1115 | MediaAgent license is expired. |
| 62:1116 | Failed to do a SCSI-3 reserve on the device. |
| 62:1117 | No such MediaAgent. |
| 62:1118 | Failed to start thread. |
| 62:1119 | Volume has not been specified. |
| 62:1120 | CommServe Media Manager service error has occurred. |
| 62:1121 | Drive information not specified. |
| 62:1122 | Could not open handle to device. |
| 62:1123 | Media information not specified. |
| 62:1124 | Too many symbolic links in the path. |
| 62:1125 | Error creating link. |
| 62:1126 | Too many open handles. |
| 62:1127 | System tables are full. |
| 62:1128 | Centera error occurred. |
| 62:1129 | Access node for Centera does not have an IP Address. |
| 62:1130 | There are no media that can be discovered. |
| 62:1131 | Failed to initialize ScheduleExport Client. |
| 62:1132 | Failed to get CommServe host name. |
| 62:1133 | Drive resources not available as all drives are either in use or not ready. |
| 62:1134 | SCSI-2 Reservation Command to the Drive failed. |
| 62:1135 | Failed to Query Device ID for DRU Device using SCSI Inquiry. |
| 62:1136 | Failed to Lock HDS DRU Mount Path. HiCommand Device Manager returned error. |
| 62:1137 | Failed to Unlock HDS DRU Mount Path. HiCommand Device Manager returned error. |
| 62:1138 | Failed to retrieve Archive metadata for this job from the CommServe Database. Please contact your vendor's customer support. |
| 62:1139 | SCSI-2 Release Command to the Drive failed. |
| 62:1140 | Media is from a different scratch pool than expected. |
| 62:1141 | Media not available for operation to continue as it is being used by other operations or is exported. Please make sure that the media is available for use. |
| 62:1142 | Storage Policy Copy does not have any data path defined, or all its data paths are disabled. |
| 62:1143 | All data paths for the subclient are offline or busy. |
| 62:1144 | LAN-free data path is offline or busy. |
| 62:1145 | Preferred data path is offline or busy. |
| 62:1146 | The network path was not found. |
| 62:1147 | All device streams configured to this Storage Policy including their multiplexing factor are in use. |
| 62:1148 | The specified network resource or device is no longer available. |
| 62:1149 | Insufficient system resources exist to complete the requested service. See Microsoft Knowledge Base Article: 304101 for more information. |
| 62:1150 | The file or directory is corrupted and non-readable. |
| 62:1151 | The requested resource is in use. This resource may be reserved by another MediaAgent. |
| 62:1152 | The parameter used for the current operation is not supported by the Operating System, OS Drivers or the underlying Hardware. |
| 62:1153 | The tape block size used is not supported by the Operating System, Device Drivers, HBA or the underlying Hardware. |
| 62:1154 | While trying to read the media label on tape, the tape block size encountered is unrecognizable and unsupported by the application. |
| 62:1155 | There are no drives available currently. A few of the drives need cleaning. Please clean these drives. |
| 62:1156 | There are no drives available currently as they are all in use. |
| 62:1157 | There are not enough drives to run this multistream job. |
| 62:1158 | There are not enough streams to run this multistream job. |
| 62:1159 | There are no active streams for the job. |
| 62:1160 | All device streams configured to this Storage Policy including their multiplexing factor are in use. |
| 62:1161 | Multiplexing to some streams for the Storage Policy Copy are not allowed temporarily. |
| 62:1162 | Streams are in use by other job(s) that do not allow this job to multiplex with. |
| 62:1163 | There are not enough streams for this multistream job. |
| 62:1164 | There are no usable media inside the library. All media are probably full, outside library or marked bad. |
| 62:1165 | There are media inside library with duplicate barcode. |
| 62:1166 | There are no spare media inside library, and library does not allow using appendable media for the job. |
| 62:1167 | There are no spare media inside library, and all appendable media are not usable as their last write time is outside of specified time range. |
| 62:1168 | Preferred data path specified on subclient is offline or busy. |
| 62:1169 | The device did not report any specific sense key information for the current failure. |
| 62:1170 | The last command completed successfully with some recovery action by the device. |
| 62:1171 | The device is not ready. |
| 62:1172 | The device reported a Medium Error during the current operation. |
| 62:1173 | The device reported a Hardware failure while performing the current operation. |
| 62:1174 | The device reported an illegal request error during the execution of the command. |
| 62:1175 | The device reported a unit attention condition during the execution of the command. |
| 62:1176 | The device reported that the Media used for the current operation is write-protected. |
| 62:1177 | The device reported that an end-of-data indication is encountered for the Media during the current operation. |
| 62:1178 | The device reported a vendor specific error. |
| 62:1179 | The device reported that a copy operation is aborted. |
| 62:1180 | The device aborted the command. |
| 62:1181 | The device indicated that the search data command has satisfied an equal comparison. |
| 62:1182 | The device indicated a physical end of medium encountered during the current operation. |
| 62:1183 | The device indicated that the source data did not match the data read from the medium. |
| 62:1184 | Retired media cannot be moved to scratch and will remain in retired pool. |
| 62:1185 | Data error (cyclic redundancy check). |
| 62:1186 | User marked full. |
| 62:1187 | Physical end of Media. |
| 62:1188 | Hardware error. |
| 62:1189 | Media was found exported when required by a backup or copy job. |
| 62:1190 | Media stuck in drive. |
| 62:1191 | Recycled Media. |
| 62:1192 | Mount path was disabled when the backup or copy job ran. |
| 62:1193 | As part of start new media option on the backup or copy job. |
| 62:1194 | Media Write-Protected. |
| 62:1195 | Inconsistent file count between media and the database. |
| 62:1196 | Mount path not accessible. |
| 62:1197 | Number of Streams reduced on the storage policy. |
| 62:1198 | Marked full in a previous release of this product. |
| 62:1199 | Media Marked full after successful operation. |
| 62:1200 | Marked full to create Synthetic Full. |
| 62:1201 | Marked full to allow for LAN-free backup. |
| 62:1202 | User marked appendable. |
| 62:1203 | Marked full as the archiving data path has switched. |
| 62:1204 | Media was found exportable when required by a backup or copy job. |
| 62:1205 | Marked full as the Media was inherited from a Foreign CommCell during CommCell Migration Merge operation. |
| 62:1206 | Media recycled as part of option to overwrite media. |
| 62:1207 | Media marked full as the flush block size has changed for upgrade. |
| 62:1208 | Media Marked full after successful copy operation. |
| 62:1209 | Mount Path is disabled for new data. |
| 62:1210 | Marked full to allow round-robin between mount paths. |
| 62:1211 | Marked full/appendable due to media group switching to a different data path. |
| 62:1212 | Marked full as cleaning media was mounted for backup. |
| 62:1213 | Marked full due to option to start new media set. |
| 62:1214 | Marked full as the number of chunks in the volume exceeds the maximum number of chunks. |
| 62:1215 | Marked full as duplicate barcode was detected. |
| 62:1216 | Marked full as the media is marked bad. |
| 62:1217 | Marked full as validation of the position on the tape failed. |
| 62:1218 | Marked full as positioning of the tape at a file mark failed. |
| 62:1219 | Marked full as reaching the defined interval hour limits since last marking full operation. |
| 62:1220 | The specified network name is no longer available. Check if the disk library mount paths are still accessible from MediaAgent. |
| 62:1221 | Job had reserved a stream, but no remaining streams are available for the job anymore. |
| 62:1222 | A media stuck in the medium changer. |
| 62:1223 | The VaultTracker export failed to due to error: the VaultTracker license is either not installed or has expired. |
| 62:1224 | The VaultTracker export failed to due to error: Failed to read the schedule parameters. |
| 62:1225 | Actual size of chunk on the disk does not match size of chunk stored in CommServe Database. |
| 62:1226 | Failed to get the policy ID or media list. |
| 62:1227 | SCSI Command failed. Error returned from adapter driver: Queue is full. |
| 62:1228 | SCSI Command failed. Error returned from adapter driver: SCSI command was terminated by the target. |
| 62:1229 | Drive is marked for maintenance. |
| 62:1230 | MediaAgent is marked for maintenance. |
| 62:1231 | Library is marked for maintenance. |
| 62:1232 | Failed to unmount media in drive. |
| 62:1233 | Cannot remove the encryption keys for some deduplicated archive files as they are still referenced. |
| 62:1234 | Failed to delete the encryption keys for deduplicated archive files. |
| 62:1235 | Auxiliary Copy Data writer cannot multiplex with any other Job. |
| 62:1236 | Drive in which Media is mounted is inaccessible from its drive controller. |
| 62:1237 | Copy Thread is hanging. |
| 62:1238 | Wrong mode of execution detected. |
| 62:1239 | Failed to set up the copy pipeline. |
| 62:1240 | Error signalling start of data transfer over the pipeline. |
| 62:1241 | Error signalling stop of data transfer over the pipeline. |
| 62:1242 | Could not connect to the DDB process on the target MediaAgent. |
| 62:1243 | Could not connect to the CVD on the target MediaAgent to launch the DDB engine. |
| 62:1244 | Internal Error. Cannot acquire the DDB lock. |
| 62:1245 | Could not launch the DDB engine on the target MediaAgent. |
| 62:1246 | Not connected to any SIDB engine. |
| 62:1247 | Encountered network error while connecting to the DDB engine process. |
| 62:1248 | DDB Engine is in the process of going down. Probably the MediaAgent is going down. |
| 62:1249 | Configuration Error. SIDB Engine with wrong copy ID is being contacted. |
| 62:1250 | Configuration Error. SIDB Engine with wrong Job ID is being contacted. |
| 62:1251 | Configuration Error. SIDB Engine with wrong signature type is being contacted. |
| 62:1252 | Internal Error. Cannot insert into the SIDB database. |
| 62:1253 | Internal Error. Please contact support. |
| 62:1254 | Network timeout. DDB Engine did not respond within the timeout period. |
| 62:1255 | A part of the operation completed successfully. |
| 62:1256 | Impersonation failed. Probably the username or password is incorrect. |
| 62:1257 | Internal Error. Incorrect parameter passed to the SIDB engine. |
| 62:1258 | Internal Error. This function is not yet implemented. |
| 62:1259 | The DDB index files are missing. |
| 62:1260 | Could not create the DDB data files. |
| 62:1261 | Internal Error. Could not get the port on which SIDB is listening. |
| 62:1262 | While accessing a drive, the Serial Number obtained is different from expected SCSI Identifier supplied by the Medium Changer. |
| 62:1263 | Cannot remove this NDMP Host since it is referenced by a drive pool. |
| 62:1264 | There is insufficient free disk space on the DDB path location. |
| 62:1265 | Insufficient memory available to perform the current operation. |
| 62:1266 | The Media currently used is physically bad and unusable. |
| 62:1267 | Failed to delete Spare Group due to error: the Spare Group is used by a data path. |
| 62:1268 | Marked full during media recycling. |
| 62:1269 | Marked full by the utility that marks all active media full for a user specified Storage Policy Copy. |
| 62:1270 | All mail slots are either occupied or inaccessible. |
| 62:1271 | Clients with versions prior to 7.0 cannot backup using the MediaAgent property: [Optimize for concurrent LAN backups]. Please upgrade the client or change this option on the MediaAgent. |
| 62:1272 | There are no drives that are active and ready to be used. |
| 62:1273 | Mount path is used by a Deduplication database. |
| 62:1274 | Object Level Deduplication license for MediaAgent has expired. |
| 62:1275 | Encryption license for MediaAgent has expired. |
| 62:1276 | Failed to abort the running actions. |
| 62:1277 | Hardware Encryption is not supported by hardware device. |
| 62:1278 | Failed to enable hardware encryption on the hardware device. |
| 62:1279 | Failed to disable hardware encryption on the hardware device. |
| 62:1280 | Internal error. One of the path passed to the pruning logic belongs to a Deduplicated backup and cannot be deleted through regular pruning logic. Please contact your vendor's customer support. |
| 62:1281 | No license available for Object Level Deduplication. |
| 62:1282 | No license available for Encryption. |
| 62:1283 | During a backup, MediaAgent received invalid data sequence from the client. Please run diagnostics on the Network for the data integrity of the data transferred between the client and MediaAgent. |
| 62:1284 | Invalid inputs for VaultTracker command. |
| 62:1285 | Invalid VaultTracker command. |
| 62:1286 | Invalid container given for media in VaultTracker action. |
| 62:1287 | Failed to set container for media in action due to limited capacity. |
| 62:1288 | Failed to return media to source library. Operation requires media import. |
| 62:1289 | Failed to return one or more media to source location. Operation requires media export. |
| 62:1290 | Failed to pick up one or more media from media location. Operation requires media export. |
| 62:1291 | Failed to pick up one media in standalone library that is cache-mounted. |
| 62:1292 | Failed to reach destination for one or more media. Operation requires media import. |
| 62:1293 | Failed to reach destination for one or more media. Operation requires media export. |
| 62:1294 | Failed to reach destination for one media in standalone library that is cache-mounted. |
| 62:1295 | Failed to reach destination for one or more media. Media type has no matching scratch pool. |
| 62:1296 | Failed to complete recall action for one or more media that are not yet at destination. |
| 62:1297 | Media export cannot be suspended at this point. |
| 62:1298 | Media is marked pinned for recall action. |
| 62:1299 | Media was found as pinned by a recall action when required by a backup or copy job. |
| 62:1300 | The Drive Pool is being used by another job |
| 62:1301 | Cannot mark Active Media for Storage Policy as Full as it is being used by other job[s]. |
| 62:1302 | Storage Policy Copy does not have a data path using the required MediaAgent. |
| 62:1303 | Secondary Copy does not have an active stream corresponding to streams of the Primary Copy for Storage Policy. |
| 62:1304 | Cannot access tape via native tape driver device node. Please make sure that native tape driver is attached to all SCSI/FC devices. |
| 62:1305 | There are some media that still have valid data and cannot be pruned at this time. |
| 62:1306 | Unformatted media |
| 62:1307 | Drive not fully configured for all MediaAgents |
| 62:1308 | Centera invalid name |
| 62:1309 | Centera unknown option |
| 62:1310 | Centera not send request error |
| 62:1311 | Not receive reply error |
| 62:1312 | Centera server error |
| 62:1313 | Centera param error |
| 62:1314 | Centera path not found error |
| 62:1315 | Centera controlfield error |
| 62:1316 | Centera Segdata error |
| 62:1317 | Centera duplicate file error |
| 62:1318 | Centera offset field error |
| 62:1319 | Centera operation not supported |
| 62:1320 | Centera acknowledgement not received error |
| 62:1321 | Centera file not stored error |
| 62:1322 | Centera numloc field error |
| 62:1323 | Centera section not found error |
| 62:1324 | Centera tag not found error |
| 62:1325 | Centera attr not found error |
| 62:1326 | Centera wrong reference error |
| 62:1327 | Centera no pool error |
| 62:1328 | Centera clip not found error |
| 62:1329 | Centera tagtree error |
| 62:1330 | Centera is not directory error |
| 62:1331 | Centera unexpected tag error |
| 62:1332 | Centera tag read-only error |
| 62:1333 | Centera out-of-bounds error |
| 62:1334 | Centera filesystem error |
| 62:1335 | Centera stack depth error |
| 62:1336 | Centera tag has no data error |
| 62:1337 | Centera version error |
| 62:1338 | Centera multi blob error |
| 62:1339 | Centera protocol error |
| 62:1340 | Centera no socket avail error |
| 62:1341 | Centera blob ID field error |
| 62:1342 | Centera blob ID mismatch error |
| 62:1343 | Centera probe packet error |
| 62:1344 | Centera clip closed error |
| 62:1345 | Centera pool closed error |
| 62:1346 | Centera blob busy error |
| 62:1347 | Centera server not ready error |
| 62:1348 | Invalid media group ID |
| 62:1349 | Invalid platform |
| 62:1350 | Invalid MediaAgent host name |
| 62:1351 | Cvmm init failed |
| 62:1352 | Invalid operation |
| 62:1353 | Not initialized |
| 62:1354 | Afile lookup failed |
| 62:1355 | Appid lookup failed |
| 62:1356 | Apptype lookup failed |
| 62:1357 | Client lookup failed |
| 62:1358 | Client name lookup failed |
| 62:1359 | Media object null |
| 62:1360 | Chunk size lookup failed |
| 62:1361 | Cs version lookup failed |
| 62:1362 | Get chunk ID failed |
| 62:1363 | Convert network to host byte transaction failed |
| 62:1364 | Invalid data size |
| 62:1365 | Wrong archive file ID |
| 62:1366 | Get chunk closed state failed |
| 62:1367 | Reset chunk closed state failed |
| 62:1368 | Create afile failed |
| 62:1369 | Archive file add failed |
| 62:1370 | Archive file not present in map |
| 62:1371 | Seek failed |
| 62:1372 | Set close pending failed |
| 62:1373 | Invalid multiplexing setting |
| 62:1374 | Create new chunk failed |
| 62:1375 | Get file marker count failed |
| 62:1376 | Chunk get info failed |
| 62:1377 | Invalid volume ID |
| 62:1378 | Parse chunk header failed |
| 62:1379 | Prepare chunk map trailer failed |
| 62:1380 | Failed to fill chunk information details |
| 62:1381 | Close chunk failed |
| 62:1382 | Set chunk closed failed |
| 62:1383 | Archive file close failed |
| 62:1384 | Invalid file mark for update |
| 62:1385 | Failed to reset closed state |
| 62:1386 | Update chunk information failed |
| 62:1387 | Invalid media type |
| 62:1388 | Volume already initialized |
| 62:1389 | Invalid volume block size |
| 62:1390 | Invalid media initialization |
| 62:1391 | Increment volume counters failed |
| 62:1392 | Volume was never initialized |
| 62:1393 | Invalid archive file component |
| 62:1394 | Get free space failed |
| 62:1395 | Invalid NetWare volume name |
| 62:1396 | Write zero bytes request failed |
| 62:1397 | Remote mount path creation failed |
| 62:1398 | Get logical drive failed |
| 62:1399 | Invalid chunk collect file handle |
| 62:1400 | Chunk collect file read failed |
| 62:1401 | End-of-chunk collect file |
| 62:1402 | Chunk collect file create failed |
| 62:1403 | Chunk collect file open failed |
| 62:1404 | Mount path traverse failed |
| 62:1405 | Get maximum chunk map trailer failed |
| 62:1406 | Unknown header type encountered |
| 62:1407 | Parse header failed |
| 62:1408 | Chunk set volume ID failed |
| 62:1409 | Multiplexing not supported for Deduplication |
| 62:1410 | Failed to query afile offset |
| 62:1411 | Wrong tag header seq number read |
| 62:1412 | Failed to retrieve Mount Path information using Mount Path ID. |
| 62:1413 | There is already an active write session for the destination Dedup stream; the new write request will be prevented. Possible causes include a stuck system/network call on the MediaAgent. |
| 62:1414 | Deduplication Store already exists for a given copy. |
| 62:1415 | Source MediaAgent cannot copy data to the destination MediaAgent with a different version. |
| 62:1416 | MediaAgent is docked. |
| 62:1417 | Drives are reserved for restore only. |
| 62:1418 | Maximum file size limit for the filesystem has been reached. |
| 62:1419 | The required media is currently in a different library. |
| 62:1420 | This container is associated with a Tracking Policy and cannot be deleted. Remove association and try deleting container again. |
| 62:1421 | Data Integrity validation failed for the data read from media. |
| 62:1422 | The total number of media in drives and mail slots exceeds the number of the free slots in Library [<String>]. Please remove some media from the library. |
| 62:1423 | Data Decryption Key Fail Limit |
| 62:1424 | Data Encryption Key Instance Counter has changed |
| 62:1425 | Drive rejected a Write operation because the current cartridge is a suspicious WORM cartridge |
| 62:1426 | Drive rejected a Write operation because the rules for allowing WORM writes have not been met |
| 62:1427 | Security Error |
| 62:1428 | Encryption - Unable to Decrypt Data |
| 62:1429 | Encryption - Unencrypted Data encountered while decrypting |
| 62:1430 | Encryption - Incorrect Data Encryption Key |
| 62:1431 | Encryption - Cryptographic Integrity Validation failed. |
| 62:1432 | Encryption - Error Decrypting Data |
| 62:1433 | All the drives are offline for the Storage Policy |
| 62:1434 | All the drives are busy for the Storage Policy |
| 62:1435 | All reservable drives are marked offline for maintenance. |
| 62:1436 | User specified a data path which is not part of the data paths in the storage policy copy. |
| 62:1437 | This medium contains valid data of a running job. |
| 62:1438 | Failed to pick up one or more media from media location. Transit location is not selected for action. |
| 62:1439 | Encryption - Key Service Timeout |
| 62:1440 | Encryption - Key Service Failure |
| 62:1441 | Encryption - Key Required |
| 62:1442 | Failed to reach destination for one or more media. Media is not in destination library yet. |
| 62:1443 | Total number of data transfer operations on the Snap Shot exceeds the maximum allowed value. |
| 62:1444 | Current Snap Shot has already been reserved by a different mount Host. |
| 62:1445 | Marked full to allow for SILO backup. |
| 62:1446 | Failed to Mount. Either media format is not supported or the mount path is busy. |
| 62:1447 | The Deduplication database and the CommServe are out of sync. |
| 62:1448 | Marked full as starting to use a new deduplication DB. |
| 62:1449 | Failed to reserve for SILO backup because no SILO data path is defined for this copy. Please check copy properties. |
| 62:1450 | This medium contains valid data of SILO jobs. |
| 62:1451 | Snapshot is currently mounted on a different host. |
| 62:1452 | The operation cannot be completed as the snapshot is currently in use. |
| 62:1453 | Tape DeDuplication license for MediaAgent has expired. |
| 62:1454 | Volume is associated to a storage policy copy that has option to back up deduplication database to Tape turned on. |
| 62:1455 | Invalid Barcode. |
| 62:1456 | Pruning request rejected as the number of connections to the SIDB Engine is greater than the set threshold. |
| 62:1457 | Invalid parameters passed to disk library maintenance. |
| 62:1458 | The mount path is not present on MediaAgent. |
| 62:1459 | A Windows file system-level API failed. Please check the logs on the MediaAgent. |
| 62:1460 | Marked full due to current volume's physical size reaching the high watermark. |
| 62:1461 | Disk Volume reaches the maximum allowed physical space. |
| 62:1462 | Cannot delete SnapShot on Mirror Copy. |
| 62:1463 | Snap is not moved to media. Cannot delete the SnapShot. |
| 62:1464 | Failed to delete the SnapShot. |
| 62:1465 | Check the UNC path type. It may not be supported. |
| 62:1466 | Failed to create the snapshot. |
| 62:1467 | Failed to mount the snapshot. |
| 62:1468 | Failed to unmount the snapshot. |
| 62:1469 | Failed to delete the snapshot. |
| 62:1470 | Failed to revert the snapshot. |
| 62:1471 | Snapshot is currently mounted. |
| 62:1472 | Failed to create the snapshot. Volume contains busy snapshots. Please unmount any snapshots on the volume. |
| 62:1473 | Failed to create the snapshot. The volume is out of space. |
| 62:1474 | Failed to create the snapshot. No more snapshots are available on the volume. |
| 62:1475 | Failed to delete the snapshot. The snapshot is currently busy. Please check if the snapshot is mounted. |
| 62:1476 | Failed to access mount point. Please check connectivity with the mount point. |
| 62:1477 | Failed to mount the snapshot. The snapshot is either in Mounting or Expired or Unmounting State. Please try later. |
| 62:1478 | Failed to unmount the snapshot. The snapshot is in Unmounted State. |
| 62:1479 | An active deduplication database is hosted by this MediaAgent. |
| 62:1480 | Snapshot is currently mounting on a different host. |
| 62:1481 | Snapshot is currently mounting on a different path on the same host. |
| 62:1482 | Snapshot is already Unmounted. |
| 62:1483 | Invalid Snapshot Host ID. |
| 62:1484 | Failed to create Instance of Snap Engine. |
| 62:1485 | Invalid Archive File ID. |
| 62:1486 | Invalid Copy ID. |
| 62:1487 | Invalid Job ID. |
| 62:1488 | Invalid Copy Precedence. |
| 62:1489 | Failed to create Protection for Snapshot. |
| 62:1490 | Failed to revert Protection for Snapshot. |
| 62:1491 | Failed to create Mount Point Folder. |
| 62:1492 | Failed to remove Mount Point Folder. |
| 62:1493 | Failed to get Client ID. |
| 62:1494 | No Mount Point Given. |
| 62:1495 | Invalid Mount Status. |
| 62:1496 | Invalid Parameters. |
| 62:1497 | No Snapshots Specified. |
| 62:1498 | The number of readers for this job is limited. |
| 62:1499 | The source media are in use by another stream. |
| 62:1500 | Block level Deduplication license for MediaAgent has expired. |
| 62:1501 | No license available for Block Level Deduplication. |
| 62:1502 | No license available for Tape DeDuplication. |
| 62:1503 | Number of reserved drives exceeded for EMC filer. |
| 62:1504 | [Cloud] The operation is interrupted. |
| 62:1505 | [Cloud] Invalid Amazon S3 bucket name. |
| 62:1506 | [Cloud] The query parameters are too long. |
| 62:1507 | [Cloud] Failed to initialize the request. |
| 62:1508 | [Cloud] The metadata headers are too long. |
| 62:1509 | [Cloud] The metadata is bad. |
| 62:1510 | [Cloud] The content type is bad. |
| 62:1511 | [Cloud] The content type is too long. |
| 62:1512 | [Cloud] The MD5 is not matched. |
| 62:1513 | [Cloud] The MD5 is too long. |
| 62:1514 | [Cloud] The Cache control is bad. |
| 62:1515 | [Cloud] The cache control is too long. |
| 62:1516 | [Cloud] The content disposition filename is bad. |
| 62:1517 | [Cloud] The content disposition filename is too long. |
| 62:1518 | [Cloud] The content encoding is bad. |
| 62:1519 | [Cloud] The content encoding is too long. |
| 62:1520 | [Cloud] The IF MATCH ETAG is bad. |
| 62:1521 | [Cloud] The IF MATCH ETAG is too long. |
| 62:1522 | [Cloud] The IF NOT MATCH ETAG is bad. |
| 62:1523 | [Cloud] The IF NOT MATCH ETAG is too long. |
| 62:1524 | [Cloud] The headers are too long. |
| 62:1525 | [Cloud] The key is too long. |
| 62:1526 | [Cloud] The URI is too long. |
| 62:1527 | [Cloud] There is an XML parse failure. |
| 62:1528 | [Cloud] The email address is too long. |
| 62:1529 | [Cloud] the user ID is too long. |
| 62:1530 | [Cloud] The user display name is too long. |
| 62:1531 | [Cloud] The group URI is too long. |
| 62:1532 | [Cloud] The permission string is too long. |
| 62:1533 | [Cloud] The target bucket name is too long. |
| 62:1534 | [Cloud] The target prefix is too long. |
| 62:1535 | [Cloud] There are too many grants. |
| 62:1536 | [Cloud] The grantee is bad. |
| 62:1537 | [Cloud] The permission is bad. |
| 62:1538 | [Cloud] The XML document is too large. |
| 62:1539 | [Cloud] There is a name lookup error. |
| 62:1540 | [Cloud] Failed to connect. |
| 62:1541 | Failed to validate the cloud server certificate authenticity, either the cloud server presented an invalid certificate or a self-signed certificate. If the cloud server using self-signed certificate, please set additional setting MediaAgent/nCloudServerCertificateNameCheck with value 2 to skip peer certificate verification. |
| 62:1542 | [Cloud] The connection failed. |
| 62:1543 | [Cloud] The operation is aborted by the callback function. |
| 62:1544 | [Cloud] Access denied. |
| 62:1545 | [Cloud] There is an account problem. |
| 62:1546 | [Cloud] There is an ambiguous grant by the email address. |
| 62:1547 | [Cloud] There is a bad digest. |
| 62:1548 | [Cloud] The bucket already exists. |
| 62:1549 | [Cloud] The bucket already exists and owned by you. |
| 62:1550 | [Cloud] The bucket is not empty. |
| 62:1551 | [Cloud] The credentials are not supported. |
| 62:1552 | [Cloud] The cross location logging is prohibited. |
| 62:1553 | [Cloud] The entity is too small. |
| 62:1554 | [Cloud] The entity is too large. |
| 62:1555 | [Cloud] The Token expired. |
| 62:1556 | [Cloud] The body is incomplete. |
| 62:1557 | [Cloud] The number of files in post request is incorrect. |
| 62:1558 | [Cloud] The inline data is too large. |
| 62:1559 | [Cloud] There is an internal error. |
| 62:1560 | [Cloud] The access key ID is invalid. |
| 62:1561 | [Cloud] The addressing header is invalid. |
| 62:1562 | [Cloud] The argument is invalid. |
| 62:1563 | [Cloud] The bucket name is invalid. |
| 62:1564 | [Cloud] The digest is invalid. |
| 62:1565 | [Cloud] The location constraint is invalid. |
| 62:1566 | [Cloud] The payer is invalid. |
| 62:1567 | [Cloud] The policy document is invalid. |
| 62:1568 | [Cloud] The range is invalid. |
| 62:1569 | [Cloud] The security is invalid. |
| 62:1570 | [Cloud] The SOA prequest is invalid. |
| 62:1571 | [Cloud] The storage class is invalid. |
| 62:1572 | [Cloud] The target bucket for logging is invalid. |
| 62:1573 | [Cloud] The token is invalid. |
| 62:1574 | [Cloud] The requested URI does not represent any resource on the server. |
| 62:1575 | [Cloud] The key is too long. |
| 62:1576 | [Cloud] The ACL is malformed. |
| 62:1577 | [Cloud] The XML is malformed. |
| 62:1578 | [Cloud] The max message length exceeded. |
| 62:1579 | [Cloud] The max post or pre data length exceeded |
| 62:1580 | [Cloud] The metadata is too large. |
| 62:1581 | [Cloud] The method is not allowed |
| 62:1582 | [Cloud] The attachment is missing. |
| 62:1583 | [Cloud] The content length is missing. |
| 62:1584 | [Cloud] The security element is missing. |
| 62:1585 | [Cloud] The security header is missing. |
| 62:1586 | [Cloud] There is no logging status for the key. |
| 62:1587 | [Cloud] There is no such bucket. |
| 62:1588 | [Cloud] There no such key. |
| 62:1589 | [Cloud] The method is not implemented. |
| 62:1590 | [Cloud] The user is not signed up. |
| 62:1591 | [Cloud] The operation is aborted. |
| 62:1592 | [Cloud] There is an error for the permanent redirect. The bucket may be in different region and not matched with the provided host URL. |
| 62:1593 | [Cloud] The precondition failed. |
| 62:1594 | [Cloud] There is an error for the redirect. |
| 62:1595 | [Cloud] The request is not multi-part content. |
| 62:1596 | [Cloud] There is a request timeout. |
| 62:1597 | [Cloud] The request time is too skewed. |
| 62:1598 | [Cloud] There is a request torrent of bucket error. |
| 62:1599 | [Cloud] The signature does not match. |
| 62:1600 | [Cloud] There is a slow down error. |
| 62:1601 | [Cloud] There is an error for the temporary redirect. |
| 62:1602 | [Cloud] Token refresh is required. |
| 62:1603 | [Cloud] There are too many buckets. |
| 62:1604 | [Cloud] There is an unexpected content. |
| 62:1605 | [Cloud] There is an unresolvable grant by the email address. |
| 62:1606 | [Cloud] The user key must be specified. |
| 62:1607 | [Cloud] Unknown error. |
| 62:1608 | [Cloud] HTTP Error - moved temporarily. |
| 62:1609 | [Cloud] HTTP Error - bad request. |
| 62:1610 | [Cloud] HTTP Error - forbidden. |
| 62:1611 | [Cloud] HTTP Error - not found. |
| 62:1612 | [Cloud] HTTP Error - conflict. |
| 62:1613 | [Cloud] Unknown HTTP error. |
| 62:1614 | [Cloud] There is an internal error. |
| 62:1615 | [Cloud] The filename is invalid. |
| 62:1616 | [Cloud] Failed to access the temporary file. |
| 62:1617 | [Cloud] Failed to send the file to the storage server. |
| 62:1618 | [Cloud] Failed to get the subfile size. |
| 62:1619 | [Cloud] MediaAgent is preconfigured. |
| 62:1620 | [Cloud] A required HTTP header was not specified. |
| 62:1621 | [Cloud] A required XML node was not specified in the request body. |
| 62:1622 | [Cloud] One of the HTTP headers specified in the request is not supported. |
| 62:1623 | [Cloud] One of the XML nodes specified in the request body is not supported. |
| 62:1624 | [Cloud] The value provided for one of the HTTP headers was not in the correct format. |
| 62:1625 | [Cloud] The value provided for one of the XML nodes in the request body was not in the correct format. |
| 62:1626 | [Cloud] A required query parameter was not specified for this request. |
| 62:1627 | [Cloud] One of the query parameters specified in the request URI is not supported. |
| 62:1628 | [Cloud] An invalid value was specified for one of the query parameters in the request URI. |
| 62:1629 | [Cloud] A query parameter specified in the request URI is outside the permissible range. |
| 62:1630 | [Cloud] The HTTP verb specified was not recognized by the server. |
| 62:1631 | [Cloud] The key for one of the metadata key-value pairs is empty. |
| 62:1632 | [Cloud] The specified XML is not syntactically valid. |
| 62:1633 | [Cloud] The MD5 value specified in the request did not match the MD5 value calculated by the server. |
| 62:1634 | [Cloud] The MD5 value specified in the request is invalid. The MD5 value must be 128 bits and Base64-encoded. |
| 62:1635 | [Cloud] One of the request inputs is out of range. |
| 62:1636 | [Cloud] The authentication information may be incorrect, please check the provided credential. |
| 62:1637 | [Cloud] One of the request inputs is not valid. |
| 62:1638 | [Cloud] The specified metadata is invalid. It includes characters that are not permitted. |
| 62:1639 | [Cloud] The size of the specified metadata exceeds the maximum size permitted. |
| 62:1640 | [Cloud] The server failed to authenticate the request. Verify that the value of Authorization header is formed correctly and includes the signature. |
| 62:1641 | [Cloud] The specified resource does not exist. |
| 62:1642 | [Cloud] The specified account does not exist. |
| 62:1643 | [Cloud] The resource doesn't support the specified HTTP verb. |
| 62:1644 | [Cloud] The specified account already exists. |
| 62:1645 | [Cloud] The specified account is in the process of being deleted but still exists. |
| 62:1646 | [Cloud] The specified account is in the process of being created. |
| 62:1647 | [Cloud] The Content-Length header was not specified. |
| 62:1648 | [Cloud] The condition specified in the conditional header(s) was not met. |
| 62:1649 | [Cloud] The size of the request body exceeds the maximum size permitted. |
| 62:1650 | [Cloud] The range specified is invalid for the current size of the resource. |
| 62:1651 | [Cloud] The server encountered an internal error. Please retry the request. |
| 62:1652 | [Cloud] The operation could not be completed within the permitted time. |
| 62:1653 | [Cloud] The server is currently unable to receive requests. Please retry your request. |
| 62:1654 | [Cloud] The specified blob or block content is invalid. |
| 62:1655 | [Cloud] The specified block ID is invalid. The block ID must be Base64-encoded. |
| 62:1656 | [Cloud] The specified block list is invalid. |
| 62:1657 | [Cloud] The specified container does not exist. |
| 62:1658 | [Cloud] The specified blob does not exist. |
| 62:1659 | [Cloud] The specified container already exists. |
| 62:1660 | [Cloud] The specified container has been disabled by the administrator. |
| 62:1661 | [Cloud] The specified container is being deleted. |
| 62:1662 | [Cloud] The specified blob already exists. |
| 62:1663 | [Cloud] Missing required parameters. |
| 62:1664 | [Cloud] Unsupported operation. |
| 62:1665 | [Cloud] Invalid payment. |
| 62:1666 | [Cloud] The credit card charge failed. |
| 62:1667 | [Cloud] Failed to create the account. |
| 62:1668 | [Cloud] Failed to create the account contact. |
| 62:1669 | [Cloud] Invalid SLA error. |
| 62:1670 | [Cloud] Invalid application key. |
| 62:1671 | [Cloud] Invalid account type. |
| 62:1672 | [Cloud] There is a duplicate username under the application key. |
| 62:1673 | [Cloud] There is a duplicate username under the application name. |
| 62:1674 | [Cloud] The page size exceeds the limit. |
| 62:1675 | [Cloud] The account has been deleted. |
| 62:1676 | [Cloud] Invalid status. |
| 62:1677 | [Cloud] Invalid security response. |
| 62:1678 | [Cloud] Invalid username or password. |
| 62:1679 | [Cloud] There is a duplicate master account username |
| 62:1680 | [Cloud] Invalid contact parameter. |
| 62:1681 | [Cloud] Cannot find the application name. |
| 62:1682 | [Cloud] Cannot find the username. |
| 62:1683 | [Cloud] The metadata does not exist. |
| 62:1684 | [Cloud] The file path is too long. |
| 62:1685 | [Cloud] The file folder name is too long. |
| 62:1686 | [Cloud] Cannot override the metadata. |
| 62:1687 | [Cloud] The file is locked. |
| 62:1688 | [Cloud] The folder is locked. |
| 62:1689 | [Cloud] Failed to lock the file folder. |
| 62:1690 | [Cloud] Failed to unlock the file folder. |
| 62:1691 | [Cloud] The file path is empty. |
| 62:1692 | [Cloud] Invalid path character. |
| 62:1693 | [Cloud] Invalid absolute path. |
| 62:1694 | [Cloud] Invalid relative path. |
| 62:1695 | [Cloud] There is an error for file integrity. |
| 62:1696 | [Cloud] The file path is too short. |
| 62:1697 | [Cloud] The file is offline. |
| 62:1698 | [Cloud] Invalid image dimensions. |
| 62:1699 | [Cloud] Failed to login the server. |
| 62:1700 | [Cloud] Invalid master account ID. |
| 62:1701 | [Cloud] Invalid billable account ID. |
| 62:1702 | [Cloud] The session is not found. |
| 62:1703 | [Cloud] Account expired. |
| 62:1704 | [Cloud] There is an out of bytes error. |
| 62:1705 | [Cloud] There is an out of bytes of non-owner error. |
| 62:1706 | [Cloud] The download file size limit exceeded. |
| 62:1707 | [Cloud] The upload bandwidth limit exceeded. |
| 62:1708 | [Cloud] The storage limit exceeded. |
| 62:1709 | [Cloud] The limit already exceeded. |
| 62:1710 | [Cloud] Invalid access token. |
| 62:1711 | [Cloud] Invalid session token. |
| 62:1712 | [Cloud] The access token expired. |
| 62:1713 | [Cloud] Invalid download token. |
| 62:1714 | [Cloud] There is a restricted IP address. |
| 62:1715 | [Cloud] These is a configuration error. |
| 62:1716 | [Cloud] These is an SSL required. |
| 62:1717 | [Cloud] These is a database error. |
| 62:1718 | [Cloud] The server encountered an internal error. Please try again. |
| 62:1719 | [Cloud] One or more arguments in the request were invalid. |
| 62:1720 | [Cloud] The requested object was not found. |
| 62:1721 | [Cloud] The specified range cannot be satisfied. |
| 62:1722 | [Cloud] One or more metadata tags were not found for the requested object. |
| 62:1723 | [Cloud] Operation aborted because of a conflicting operation in process against the resource. |
| 62:1724 | [Cloud] The server is out of memory. |
| 62:1725 | [Cloud] The requested resource was not found on the server. |
| 62:1726 | [Cloud] The method specified in the request is not allowed for the resource identified. |
| 62:1727 | [Cloud] The requested object size exceeds the maximum allowed upload/download size. |
| 62:1728 | [Cloud] The specified object length does not match the actual length of the attached object. |
| 62:1729 | [Cloud] The requested update size was greater than the size of the attached object. |
| 62:1730 | [Cloud] The server is out of disk space. |
| 62:1731 | [Cloud] The maximum allowed metadata entries per object has been exceeded. |
| 62:1732 | [Cloud] The request could not be finished due to insufficient access privileges. |
| 62:1733 | [Cloud] The resource you are trying to create already exists. |
| 62:1734 | [Cloud] The server encountered an I/O error. Please try again. |
| 62:1735 | [Cloud] A requested resource is missing or could not be found. |
| 62:1736 | [Cloud] A requested resource is not a directory. |
| 62:1737 | [Cloud] A requested resource is a directory. |
| 62:1738 | [Cloud] A requested directory is not empty. |
| 62:1739 | [Cloud] A requested resource is in an unstable state. |
| 62:1740 | [Cloud] A network resource is disconnected or could not be reached. |
| 62:1741 | [Cloud] A cross device link was attempted to be created. |
| 62:1742 | [Cloud] The client was uninitialized before the request was submitted. |
| 62:1743 | [Cloud] The client was already initialized before the request was submitted. |
| 62:1744 | [Cloud] The client could not be initialized. |
| 62:1745 | [Cloud] The request timestamp was outside the valid time window. |
| 62:1746 | [Cloud] There was a mismatch between the signature in the request and the signature as computed by the server. |
| 62:1747 | [Cloud] Unable to retrieve the secret key for the specified principal. |
| 62:1748 | [Cloud] Unable to read the contents of the HTTP body.400 Bad Request |
| 62:1749 | [Cloud] The specified offset was invalid. |
| 62:1750 | Operation to update DDB access path is not allowed while the DDB is in use. |
| 62:1751 | License to use Cloud Storage is not available. |
| 62:1752 | Reservation Request has been submitted successfully. |
| 62:1753 | Resource Manager timeout. Reservation request has not be processed within the timeout period. |
| 62:1754 | Error occurred in Snap Client |
| 62:1755 | Failed to create MM Snap API Object |
| 62:1756 | Discovering Volume Details failed |
| 62:1757 | Invalid Job ID |
| 62:1758 | Invalid CommCell ID |
| 62:1759 | Invalid Archive File ID |
| 62:1760 | Invalid Source Client ID |
| 62:1761 | Invalid Copy ID |
| 62:1762 | Invalid Copy Precedence |
| 62:1763 | Invalid Copy Parameter Type |
| 62:1764 | Invalid Operation Source |
| 62:1765 | Invalid Operation Mode |
| 62:1766 | Invalid Snap Operation Type |
| 62:1767 | Invalid Application Type |
| 62:1768 | Volume List is empty |
| 62:1769 | Volume ID is Set during Prepare Volume Snaps |
| 62:1770 | Volume Source Path is empty during Prepare Volume Snaps |
| 62:1771 | Invalid Snap Engine ID |
| 62:1772 | Invalid Application Type ID |
| 62:1773 | Source Path is empty |
| 62:1774 | Snap List is empty |
| 62:1775 | Metadata List is empty |
| 62:1776 | Volume Snap Map List is empty |
| 62:1777 | Controlhost List is empty |
| 62:1778 | Snap Engine List is empty |
| 62:1779 | Invalid Volume ID |
| 62:1780 | Invalid Mount Host ID |
| 62:1781 | Volume Mount Path is empty |
| 62:1782 | Multiple Source Client ID specified |
| 62:1783 | Both Mount host name and ID given |
| 62:1784 | Failed to get Client ID |
| 62:1785 | Error occurred in Media Manager |
| 62:1786 | Inconsistent Data |
| 62:1787 | Invalid Prune Flags |
| 62:1788 | Volume Mount Job not running |
| 62:1789 | Unknown Volume Mount Host |
| 62:1790 | Volume is mounted in different host |
| 62:1791 | Snap is mapped to different host |
| 62:1792 | Volume Operation in Progress |
| 62:1793 | Snap Operation in Progress |
| 62:1794 | Volume is partially mounted |
| 62:1795 | Volume does not exist |
| 62:1796 | Volume Mount Failed |
| 62:1797 | Volume Operation is in Progress |
| 62:1798 | Host is different for Delete Operation |
| 62:1799 | Volume is Reserved |
| 62:1800 | Volume is Deleted |
| 62:1801 | Invalid Archive File ID |
| 62:1802 | Volume not Deleted |
| 62:1803 | Invalid Source Client ID |
| 62:1804 | Invalid CommCell ID |
| 62:1805 | Invalid Job ID |
| 62:1806 | Invalid Archive File ID |
| 62:1807 | Invalid Application Type ID |
| 62:1808 | Invalid Source Path |
| 62:1809 | Invalid Source GUID |
| 62:1810 | Invalid Snap Engine ID |
| 62:1811 | Invalid Snap Source Device |
| 62:1812 | Invalid Reference ID |
| 62:1813 | Invalid Reference Type |
| 62:1814 | Source Path is empty |
| 62:1815 | Source GUID is empty |
| 62:1816 | Snap Source Device is empty |
| 62:1817 | Source Path is too big |
| 62:1818 | Source GUI is too big |
| 62:1819 | Volume List is empty |
| 62:1820 | Snap List is empty |
| 62:1821 | MetaData List is empty |
| 62:1822 | Invalid Volume ID |
| 62:1823 | Invalid Snap ID |
| 62:1824 | Invalid MetaData ID |
| 62:1825 | Invalid VolSnapMap ID |
| 62:1826 | Duplicate Volume ID |
| 62:1827 | Duplicate Snap ID |
| 62:1828 | Duplicate MetaData ID |
| 62:1829 | Duplicate VolSnapMap ID |
| 62:1830 | Reference Volume not found |
| 62:1831 | Reference Snap not found |
| 62:1832 | Mapped Volume not found |
| 62:1833 | Mapped Snap not found |
| 62:1834 | Mapped MetaData not found |
| 62:1835 | Volume not found in Map |
| 62:1836 | Snap not found in Map |
| 62:1837 | MetaData not found in Map |
| 62:1838 | VolSnapInfo update failed |
| 62:1839 | Getting Control Host Info failed |
| 62:1840 | Getting Snap Engine Info failed |
| 62:1841 | Snap Operation failed |
| 62:1842 | Update VolSnapInfo failed |
| 62:1843 | Getting VolSnapInfo failed |
| 62:1844 | Failed to get control host list |
| 62:1845 | Failed to get snap engine list |
| 62:1846 | Wrong metadata reference |
| 62:1847 | Error occurred in MediaAgent |
| 62:1848 | Error occurred in MediaAgent - CVSnapHandler |
| 62:1849 | Initialization failed |
| 62:1850 | Invalid Job ID |
| 62:1851 | Get Snap Engine List failed |
| 62:1852 | Invalid Snap Engine ID |
| 62:1853 | Failed to get Snap Engine Instance |
| 62:1854 | Prepare Volume Snaps failed |
| 62:1855 | Create Volume Snaps failed |
| 62:1856 | Mount Volumes failed |
| 62:1857 | Unmount Volumes failed |
| 62:1858 | Delete Volume Snaps failed |
| 62:1859 | Revert Volume Snaps failed |
| 62:1860 | Failed to create Snap OS Utility object |
| 62:1861 | Failed to get MediaAgent Base folder |
| 62:1862 | Failed to create base folder for Volume Mount Point |
| 62:1863 | Failed to create Volume Mount Point |
| 62:1864 | Failed to delete Volume Mount Point |
| 62:1865 | Error occurred in Snap Engine |
| 62:1866 | Snap operation partially successful |
| 62:1867 | Error occurred in OS Snap utility |
| 62:1868 | Error in mounting as device is busy |
| 62:1869 | Media not found |
| 62:1870 | Mountpath Media Mismatch |
| 62:1871 | Device not found |
| 62:1872 | Device busy |
| 62:1873 | Invalid Argument |
| 62:1874 | Unmatched Data |
| 62:1875 | Device error |
| 62:1876 | Device is not ready |
| 62:1877 | VG create failed |
| 62:1878 | OS mount failed |
| 62:1879 | Not a mount path |
| 62:1880 | Mount device not found |
| 62:1881 | OS mount failed |
| 62:1882 | OS unmount failed, device is busy. |
| 62:1883 | OS unmount failed |
| 62:1884 | VG removal failed |
| 62:1885 | Unsupported Snap message - probably from older MediaAgent |
| 62:1886 | Media is required for Synthetic Full operation. |
| 62:1887 | Inline backup is not allowed when the primary copy has client side Deduplication enabled. |
| 62:1888 | OS failed to Revert the volume. |
| 62:1889 | OS failed to Revert the volume. |
| 62:1890 | Snap delete operation failed partially. |
| 62:1891 | Snap delete operation failed. |
| 62:1892 | Vol has been aged. |
| 62:1893 | Failed to add volume records to DB. |
| 62:1894 | Failed to delete volume records from DB. |
| 62:1895 | Error passed to MM from MediaAgent. |
| 62:1896 | Unknown snap operation. |
| 62:1897 | Failed to update volume prune flags. |
| 62:1898 | Failed to age volume. |
| 62:1899 | No volume is aged. |
| 62:1900 | Failed to prune volume. |
| 62:1901 | Failed to add action to DB. |
| 62:1902 | Failed to delete action from DB. |
| 62:1903 | Failed to add resource to DB. |
| 62:1904 | Failed to delete resource from DB. |
| 62:1905 | Mount validation failed. |
| 62:1906 | Unmount validation failed. |
| 62:1907 | Revert validation failed. |
| 62:1908 | Delete validation failed. |
| 62:1909 | Failed to populate control host and snapshot engine info. |
| 62:1910 | Prepare operation failed before sending request to MediaAgent. |
| 62:1911 | Prepare operation failed after getting response from MediaAgent. |
| 62:1912 | Mount operation failed before sending request to MediaAgent. |
| 62:1913 | Mount operation failed after getting response from MediaAgent. |
| 62:1914 | Unmount operation failed before sending request to MediaAgent. |
| 62:1915 | Unmount operation failed after getting response from MediaAgent. |
| 62:1916 | Revert operation failed before sending request to MediaAgent. |
| 62:1917 | Revert operation failed after getting response from MediaAgent. |
| 62:1918 | Delete operation failed before sending request to MediaAgent. |
| 62:1919 | Delete operation failed after getting response from MediaAgent. |
| 62:1920 | Failed to increase retry count for volume. |
| 62:1921 | Data Paths are not usable because Catalogue Server is offline. |
| 62:1922 | Unable to create snap due to busy snaps on volume. Please unmount any snapshots on this volume or turn on the snapshot_clone_dependency volume option and try the snap operation again. Please consult NetApp documentation for details of the snapshot_clone_dependency volume option. |
| 62:1923 | Snapshot creation failed due to out of space on volume. Please delete some snapshots or free some space on the volume and try the operation again. |
| 62:1924 | Reached the maximum snap limit on the volume, no more snaps can be created. Please delete some snapshots and try the operation again. |
| 62:1925 | Snap creation failed. |
| 62:1926 | Unable to clone LUN from snap. |
| 62:1927 | Unable to assign LUN to initiator group. |
| 62:1928 | Unable to get LUN serial number. |
| 62:1929 | Unable to find OS device(s) corresponding to clone(s). Possible reasons could be 1) Improper FC/iSCSI H/W connection between the host and the array 2) The OS didn't find the device corresponding to the clone. |
| 62:1930 | Unable to delete snap because snap is busy. Please unmount the snapshot and try the delete again. |
| 62:1931 | Unable to mark LUN offline on file server. |
| 62:1932 | Unable to mark LUN online on file server. |
| 62:1933 | Unable to restore LUN from snap on file server. |
| 62:1934 | Device passed in for operation is not a NetApp device OR the NetApp filer credentials haven't been entered OR the NetApp filer credential have been entered incorrectly. Please check if the subclient content is on a NetApp volume/the NetApp filer credentials. |
| 62:1935 | IBM XIV Engine invoked for non IBM XIV array. |
| 62:1936 | Cannot find source device for the given volume. |
| 62:1937 | Cannot set disk array login credentials in the DB. |
| 62:1938 | Cannot get Snap Unique ID. |
| 62:1939 | Unable to get client's hostname. |
| 62:1940 | Unable to detect client's initiator info. |
| 62:1941 | Unable to volume Info. |
| 62:1942 | Unable to set duplicate to read-write mode. |
| 62:1943 | Cannot find free LUN to map volume to client. |
| 62:1944 | Cannot map duplicate of a snapshot to client. |
| 62:1945 | Cannot get list of devices on the client. |
| 62:1946 | Volume with given ID is not present on the array. |
| 62:1947 | Duplicate is not present or not mapped to client. |
| 62:1948 | Duplicate is not present. |
| 62:1949 | Snapshot is not present. |
| 62:1950 | Unable to revert to the given snapshot. |
| 62:1951 | Given volume name does not exist. |
| 62:1952 | Maximum number of volumes already defined. |
| 62:1953 | Snapshot deletion priority value is illegal. |
| 62:1954 | Operation is not permitted on snapshots. |
| 62:1955 | Already existing volume name is used. |
| 62:1956 | Volume name has a reserved prefix. |
| 62:1957 | Data Migration has not completed to this volume. |
| 62:1958 | Given snapshot name does not exist. |
| 62:1959 | Cannot override Master Volume. |
| 62:1960 | Specified snapshot is not a snapshot of the specified volume. |
| 62:1961 | Snapshot is part of a Snapshot Group. |
| 62:1962 | Internal snapshots cannot be mapped, modified or deleted. |
| 62:1963 | Storage Pool snapshot usage has reached its limit. |
| 62:1964 | Cannot create a snapshot of a slave volume that is not consistent. |
| 62:1965 | Operation is permitted only on snapshots. |
| 62:1966 | Data Migration is defined for this volume. |
| 62:1967 | No space to allocate volume. |
| 62:1968 | Mirror is defined for this volume. |
| 62:1969 | Volume is locked. |
| 62:1970 | Target snapshot and source snapshot should be snapshots of the same volume. |
| 62:1971 | Target snapshot name does not exist. |
| 62:1972 | Target snapshot is part of a Snapshot Group. |
| 62:1973 | Target snapshot is a master volume. |
| 62:1974 | Source snapshot cannot be the target snapshot. |
| 62:1975 | Snapshot that is mapped to a host cannot be deleted. |
| 62:1976 | Volume is defined as a slave. |
| 62:1977 | Volume with requested SCSI serial number does not exist. |
| 62:1978 | Host name does not exist on array. Cannot map. |
| 62:1979 | Cluster name does not exist. |
| 62:1980 | Host is part of a cluster. |
| 62:1981 | Mapping conflict. Volume already mapped to this host. |
| 62:1982 | Mapping conflict. LUN is in use. |
| 62:1983 | LUN is out of range or does not exist. |
| 62:1984 | XCLI command not found or not installed. Please add XCLI location to environment variable PATH. |
| 62:1985 | Invalid Parameter for SMIS method. |
| 62:1986 | SMIS Provider connection timeout. Please make sure 1) SMIS provider software has been installed. 2) Correct SMIS provider name has been entered using Array Management. |
| 62:1987 | Source volume not found in SMIS provider. |
| 62:1988 | Failed to create snapshot, maximum number of snapshots reached. |
| 62:1989 | Failed to create snapshot, snapshot name already in use. |
| 62:1990 | Cannot create snapshot using snapshot disk. |
| 62:1991 | Failed to create clone, previous clone operation in progress or Snapshot may exist for the source LUN. |
| 62:1992 | Mapping failed, invalid logical unit ID. |
| 62:1993 | Mapping failed, invalid initiator port ID. |
| 62:1994 | Mapping failed, max map count exceeded for the host group. |
| 62:1995 | Mapping failed, target initiator combination already exposed |
| 62:1996 | Failed. Host mappings found |
| 62:1997 | Failed. Device group not found for snap operation. |
| 62:1998 | Failed to create clone volume. |
| 62:1999 | Failed to attach the volume for clone operation. |
| 62:2000 | Authentication failure, wrong CIMOM login credentials. Please check the array management login and password settings. |
| 62:2001 | Device passed in for operation is not a HPEVA device. Please check if the subclient content is an HPEVA device. |
| 62:2002 | Device passed in for operation is not a LSI device. Please check if the subclient content is an LSI device. |
| 62:2003 | Snap device not found, removed externally from the storage array. |
| 62:2004 | Failed to get source device. |
| 62:2005 | Failed to get host identifier. |
| 62:2006 | Failed to get host initiator port. |
| 62:2007 | Failed to get device array info from device path. |
| 62:2008 | Failed to get array info. Please enter array info from Array Management. |
| 62:2009 | Failed to get device list from host. |
| 62:2010 | Invalid engine id received. |
| 62:2011 | Failed to prepare snapshot. |
| 62:2012 | Failed to map snapshot to host. |
| 62:2013 | Failed to unmap snapshot from host. |
| 62:2014 | SYMAPI Initialization failed. |
| 62:2015 | Failed to reload SYMAPI database. |
| 62:2016 | Failed to parse snapshot info from unique identifier. |
| 62:2017 | Device path is still not seen on the host. |
| 62:2018 | Failed to convert block to row device path. |
| 62:2019 | Failed to synchronize the snapshot. |
| 62:2020 | The feature being requested is not licensed. |
| 62:2021 | The maximum number of Concurrent Copy sessions for the specified device, has been exceeded. Therefore a new session cannot be created until a session is stopped. |
| 62:2022 | Failed to get the initiator group. |
| 62:2023 | Failed to set snapshot online. |
| 62:2024 | Failed to set snapshot offline. |
| 62:2025 | Unable to refresh device list. |
| 62:2026 | Unable to Log on to snapshot target. |
| 62:2027 | Unable to Log off from snapshot target. |
| 62:2028 | Failed to set volume offline. |
| 62:2029 | Failed to set volume online. |
| 62:2030 | Failed to create volume clone. |
| 62:2031 | Unable to get array information. Please make sure array information has been entered in the DB using Array Management. |
| 62:2032 | No suitable device found to be used as snap or clone. |
| 62:2033 | SYMAPI DB is locked by another process. Please try after some time. |
| 62:2034 | Please specify SYMAPI installation home directory path using Array Management. |
| 62:2035 | One or more partitions of the active DDB for the storage policy copy is not available to use. |
| 62:2036 | Empty Parameters are passed. |
| 62:2037 | Invalid Parameters are passed. |
| 62:2038 | Invalid Copy Details are given. |
| 62:2039 | Invalid Control Host ID given. |
| 62:2040 | SIDB Reconstruct Job Failed. |
| 62:2041 | Invalid SIDB Store ID. |
| 62:2042 | Replay of pruned DeletedAF entries failed. |
| 62:2043 | Failed to add Access Control Record to Volume for local host. |
| 62:2044 | Global zone host name missing under client's advanced properties. |
| 62:2045 | Archive file has been queued for pruning from the DDB. |
| 62:2046 | This medium contains valid data in worm storage. |
| 62:2047 | Unable to load library into memory, or not found. |
| 62:2048 | Library does not confirm to API specification (missing API function). |
| 62:2049 | Unsupported Platform or Unsupported Library version. |
| 62:2050 | Failed to mark the snap job as bad. |
| 62:2051 | The requested feature is not supported by the SYMAPI for this Symmetrix/Clariion microcode level. |
| 62:2052 | Operation could not complete because the Symmetrix/Clariion unit is busy or out of resources. |
| 62:2053 | SYMAPI detected an illegal Gatekeeper configuration. Action: This is most likely due to a change in the host configuration. Try to run symcfg discover. |
| 62:2054 | The operation cannot proceed because the local Symmetrix unit is holding a configuration change Symmetrix lock. |
| 62:2055 | An active gatekeeper has become busy and the requested operation could not complete. Please retry. |
| 62:2056 | Load of information from Clariion failed. Check the EMC log files for details. |
| 62:2057 | The specified Clariion ID is not found. Please enter the right array id using Array Management. |
| 62:2058 | The host is not connected to any storage group. Please connect the host to a storage group. |
| 62:2059 | The feature is not supported on this OS. |
| 62:2060 | The operation cannot be completed because there are no available, unallocated SnapView save area LUNs. |
| 62:2061 | The NaviCLI version installed is invalid. Please check the supported NaviCLI version. |
| 62:2062 | Please add Clone Private LUNs for each storage processor. |
| 62:2063 | The device already has the maximum number of clone supported. |
| 62:2064 | The operation cannot be completed as the hardware returned an error. Error Code [<Number>], Error String [<String>]. |
| 62:2065 | [Cloud] An error occurred on the Archive Services Platform server. |
| 62:2066 | [Cloud] The client application cannot access the Archive Services Platform. |
| 62:2067 | [Cloud] The client ID does not exist on the Archive Services Platform. |
| 62:2068 | [Cloud] The request contains an invalid argument. |
| 62:2069 | [Cloud] A required argument is missing. |
| 62:2070 | [Cloud] The asset part content is missing from the Archive Services Platform. |
| 62:2071 | [Cloud] The asset content is not staged correctly. |
| 62:2072 | [Cloud] The asset ID is missing or invalid. |
| 62:2073 | [Cloud] Error parsing query statement. |
| 62:2074 | [Cloud] This query is not supported by storage provider. |
| 62:2075 | [Cloud] The Archive Services Platform could not find the requested asset. For retrieval or destruction using a temporary asset ID, this error can occur if the Archive Services Platform moved the stored asset. |
| 62:2076 | [Cloud] Invalid asset: cannot convert provided asset to storage asset. |
| 62:2077 | [Cloud] Asset contains duplicate properties. |
| 62:2078 | [Cloud] The request includes a reserved property name (prefix = meta:) that the Archive Services Platform either does not recognize or that is supported only for specific client applications. |
| 62:2079 | [Cloud] The folder ID in the request uses an invalid format or is missing. |
| 62:2080 | [Cloud] A request argument exceeds the maximum size or value allowed. |
| 62:2081 | [Cloud] The folder does not exist on the Archive Services Platform. |
| 62:2082 | [Cloud] The asset cannot be destroyed because it is protected by a retention policy that is not yet expired. |
| 62:2083 | [Cloud] The folder ID to which you are adding assets or from which you are removing assets cannot be the same as the folder ID you use in the request query. |
| 62:2084 | [Cloud] A request to submit a staged asset exceeds the maximum size of 250KB. |
| 62:2085 | [Cloud] The asset part ID in the request is invalid. |
| 62:2086 | [Cloud] The request to store an asset with a reserved property value includes the option parameter, which should not be provided for reserved properties. |
| 62:2087 | [Cloud] The requested information is not available on the Archive Services Platform. Contact Customer Support for more information. |
| 62:2088 | [Cloud] The client application provided an unsupported value for the meta:assetType reserved property. |
| 62:2089 | [Cloud] This asset type has one or more required standard properties, and the client application did not provide values for those properties. |
| 62:2090 | [Cloud] The query includes too many terms or criteria. |
| 62:2091 | [Cloud] The wildcard search format is invalid or the search includes too many wildcards. |
| 62:2092 | [Cloud] A reserved property is used incorrectly in the query. |
| 62:2093 | [Cloud] The query includes a comparison condition that is not supported. |
| 62:2094 | [Cloud] The query includes an invalid property. |
| 62:2095 | [Cloud] The proximity search query uses incorrect syntax. |
| 62:2096 | [Cloud] A client certificate was already generated for this customer and client application. |
| 62:2097 | [Cloud] A condition exists that prevents the Archive Services Platform from on boarding the customer and client application, and generating the client certificate and client key. |
| 62:2098 | [Cloud] The request is for a disabled client. Contact Customer Support if this information is incorrect. |
| 62:2099 | [Cloud] The request is for a disabled customer. Contact Customer Support if this information is incorrect. |
| 62:2100 | [Cloud] The Archive Services Platform is unavailable. Contact Customer Support. |
| 62:2101 | [Cloud] The search cannot be completed because the service is unavailable. Contact Customer Support. |
| 62:2102 | Total number of data deduplication operations on the MediaAgent exceeds the maximum allowed value. |
| 62:2103 | Backup operation is not allowed for this global deduplication storage policy. |
| 62:2104 | The maximum number of writeable checkpoints supported for a file system has been reached, no more writable checkpoints can be created. |
| 62:2105 | Unable to create NFS share on primary file system or checkpoint. |
| 62:2106 | Unable to delete share. |
| 62:2107 | Cannot get list of IBM XIV arrays from database. |
| 62:2108 | Cannot find the IBM XIV array in database |
| 62:2109 | Failed to set Equallogic snapshot online. |
| 62:2110 | Failed to set Equallogic snapshot offline. |
| 62:2111 | Unable to refresh device list. |
| 62:2112 | Unable to Log ON to iSCSI target. |
| 62:2113 | Unable to Log OFF from iSCSI target. |
| 62:2114 | Failed to set Equallogic volume online. |
| 62:2115 | Failed to set Equallogic volume offline. |
| 62:2116 | Failed to add Access Control Record to Volume for local host. |
| 62:2117 | Failed to create snapshot on Equallogic disk array. |
| 62:2118 | Failed to create clone on Equallogic disk array. |
| 62:2119 | Failed to delete the snapshot on Equallogic disk array. |
| 62:2120 | Failed to revert the snapshot. |
| 62:2121 | Failed to get array info for Equallogic disk array. Please enter array info from Array Management. |
| 62:2122 | Failed to delete the clone on Equallogic disk array. |
| 62:2123 | Invalid Datametrics parameter - not a MediaId or MediaSideId or VolumeId |
| 62:2124 | Device file for revert not found or failed with system error. See CVMA.log file for more details. |
| 62:2125 | The volume path not found or volume is not mounted. See CVMA.log file for more details. |
| 62:2126 | The Volume Group information not found in database. See CVMA.log file for more details. |
| 62:2127 | Unable to find logical volume information in database. See CVMA.log file for more details. |
| 62:2128 | The number of LUNs required for revert does not match the Volume Group information in database. See CVMA.log file for more details. |
| 62:2129 | The Volume Group cannot be reverted. See CVMA.log file for more details. |
| 62:2130 | Unable to unmount one or more file system for revert because it is in use. See CVMA.log file for more details. |
| 62:2131 | Unable to unmount one or more file system for revert. See CVMA.log file for more details. |
| 62:2132 | Unable to unmount one or more loopback file system for revert because it is in use. See CVMA.log file for more details. |
| 62:2133 | Unable to unmount one or more loopback file system for revert. See CVMA.log file for more details. |
| 62:2134 | Failure while preparing Volume Group to revert. See CVMA.log file for more details. |
| 62:2135 | Inconsistent revert information. See CVMA.log file for more details. |
| 62:2136 | Revert information is missing. See CVMA.log file for more details. |
| 62:2137 | Invalid revert information. See CVMA.log file for more details. |
| 62:2138 | Volume Group recreate fail during revert. See CVMA.log file for more details. |
| 62:2139 | Volume Group failure during revert rollback. See CVMA.log file for more details. |
| 62:2140 | Mount Path is empty. |
| 62:2141 | Invalid Mount Path. |
| 62:2142 | Mount path given is a relative path and not an absolute path. |
| 62:2143 | Mount path given is one of System paths. |
| 62:2144 | Mount path not found. |
| 62:2145 | The client machine initiator address is not visible on the file server. Please check the SAN or iSCSI connectivity between the file server and the client. |
| 62:2146 | VSS protection snap not supported for native snap engines. |
| 62:2147 | VSS protection snap failed. |
| 62:2148 | Shadow Copy ID is empty. |
| 62:2149 | MediaAgent with older version cannot access current data. Please upgrade it to the latest version. |
| 62:2150 | Unable to create clone from snap due to no more space on volume. Please free some space on the volume and try the mount again. |
| 62:2151 | Failure authenticating with file server. Please check the array management login and password settings. |
| 62:2152 | Failure connecting to file server. Please check that the file server can be reached and check the file server configuration for accepting incoming HTTP or HTTPS connections. |
| 62:2153 | Failure connecting to file server. Please check the connectivity to the file server. |
| 62:2154 | Failed to create catalog metadata directory to write metadata files. |
| 62:2155 | The media type is currently not supported for Tape Catalog job. |
| 62:2156 | Failed to create metadata files from catalog database. |
| 62:2157 | Failed to send metadata files to CommServe. |
| 62:2158 | Failed to initialize catalog operation for media. |
| 62:2159 | Failed to catalog the media. |
| 62:2160 | Failed to convert metadata files into SQL database. |
| 62:2161 | Failed to merge the metadata into CommServe Database. |
| 62:2162 | Failed to traverse the mount path. |
| 62:2163 | No media specified for catalog job. |
| 62:2164 | Failed to move media to catalog media spare group. |
| 62:2165 | Failed to check whether the path is Single Instanced or not. |
| 62:2166 | Missing or mismatching zone information found. Please check client log. |
| 62:2167 | Invalid remote operation. |
| 62:2168 | Invalid remote operation status. |
| 62:2169 | Empty remote operation. |
| 62:2170 | Empty remote operation status. |
| 62:2171 | Mismatching zone information found. Please check client log. |
| 62:2172 | Missing zone information found. Please check client log. |
| 62:2173 | Getting next remote operation failed. |
| 62:2174 | Invalid next remote operation received. |
| 62:2175 | Valid flags found empty. |
| 62:2176 | Invalid Snap Protect Job ID. |
| 62:2177 | Invalid copy param - either copy id or copy precedence. |
| 62:2178 | Invalid copy param type. |
| 62:2179 | Invalid Criteria flags given. |
| 62:2180 | Invalid Recovery Point ID. |
| 62:2181 | Given Host is different from Source host. |
| 62:2182 | Dependent volumes are not selected. |
| 62:2183 | Dependent volumes are in use. |
| 62:2184 | Operation failed before sending to MediaAgent. |
| 62:2185 | Operation failed at MediaAgent. |
| 62:2186 | Reconciliation failed. |
| 62:2187 | Reconciliation failed at MediaAgent. |
| 62:2188 | Next remote operation returned error. |
| 62:2189 | Invalid next remote operation. |
| 62:2190 | Reconciliation failed. |
| 62:2191 | Unsupported operation. |
| 62:2192 | Unsupported Snap Engine. |
| 62:2193 | Prepared failed as the device is not a Celerra device. Please check if the subclient content is a Celerra volume. |
| 62:2194 | Get OS host id failed. |
| 62:2195 | Mismatching remote operation. |
| 62:2196 | Discover failed. |
| 62:2197 | Raw device not supported. |
| 62:2198 | Zone path is empty. |
| 62:2199 | Failed to get CommCell info by CommServe hostname. Please check if CommServe hostname in registry and database match. |
| 62:2200 | Job Manager service temporarily blocks any new stream reservation coming from Auxiliary Copy Manager service based on the number of waiting job in Scheduler. |
| 62:2201 | The active DDB of current storage policy copy is not available to use. |
| 62:2202 | The active DDB of current storage policy copy is not available to use. |
| 62:2203 | Marked full as tape import merge was run on the media. |
| 62:2204 | Inline backup is not allowed when the client has client side Deduplication enabled. |
| 62:2205 | Inline backup is not allowed when it points to a global deduplication policy whose primary copy has client side Deduplication enabled. |
| 62:2206 | Device passed in for operation is not an Equallogic device. Please check if the subclient content is on an Equallogic volume. |
| 62:2207 | Device is not supported by any Snap Engine. |
| 62:2208 | Backup to current deduplication storage policy copy is not allowed. |
| 62:2209 | Backup to current deduplication storage policy copy is not allowed because current MediaAgent has different version compared to other MediaAgents from Data Path list. Please upgrade the MediaAgent first. |
| 62:2210 | Dynamic disks are not supported for snapping by this snap engine. |
| 62:2211 | MediaAgent of current active deduplication database is offline. |
| 62:2212 | Access path of current active deduplication database is offline. |
| 62:2213 | Access path of the current active deduplication database is offline. |
| 62:2214 | Recopy operation for media of a primary copy is not allowed. |
| 62:2215 | Recopy operation for media of a snap copy is not allowed. |
| 62:2216 | Recopy operation for media of a silo enabled copy is not allowed. |
| 62:2217 | Recopy operation for media of a hidden transition copy is not allowed. |
| 62:2218 | Mount path is defined to be used for SILO Archive Job restore only. |
| 62:2219 | The usage for enterprise archiver agents has exceeded the licensed capacity. Please purchase additional capacity licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2220 | The usage for core archiver agents has exceeded the licensed capacity. Please purchase additional capacity licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2221 | The usage for enterprise backup agents has exceeded the licensed capacity. Please purchase additional capacity licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2222 | The usage for core backup agents has exceeded the licensed capacity. Please purchase additional capacity licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2223 | Snapshot creation failed because new snapshots are not currently allowed on the volume. Please check if there is a LUN clone split operation in progress - please wait for the split to complete then attempt the snapshot creation again. |
| 62:2224 | No suitable MediaAgent available for volume reconciliation. |
| 62:2225 | Backup to current deduplication storage policy copy is not allowed because current MediaAgent has different version compared to MediaAgent hosting the deduplication database. |
| 62:2226 | Backup to current deduplication storage policy copy is not allowed because MediaAgent hosting the deduplication database is of a different version compared to MediaAgents from Data Path list. Please upgrade the MediaAgent first. |
| 62:2227 | The active deduplication database of current storage policy copy is not available to use. |
| 62:2228 | Failure connecting to array. Please check that the array can be reached using TCP/IP. |
| 62:2229 | Authentication with disk array failed. Invalid credentials. Please check the array management login and password settings. |
| 62:2230 | Wrong control host given. Given control host information does not belong to the selected array. Please check the array management configuration. |
| 62:2231 | Device Manager service connection is timeout. Please make sure 1) Device Manager software has been installed. 2) Correct Device Manager server host name/IP has been entered using Array Management. |
| 62:2232 | Authentication failed with Device Manager server. Invalid credentials. Please check the array management login and password settings |
| 62:2233 | HORCM CLI path not found. |
| 62:2234 | Prepare failed as device is not a HDS device. Please check if the subclient content is an HDS device. |
| 62:2235 | No HDS device visible from the host. |
| 62:2236 | Failed to submit the XML request to device manager server. |
| 62:2237 | Failed to process the XML response from device manager. |
| 62:2238 | Failed to get array properties from device manager. |
| 62:2239 | Failed to get the host information from device manager. |
| 62:2240 | Failed to get the configured host paths from device manager. |
| 62:2241 | Failed to get the replication pairs information from device manager. |
| 62:2242 | Failed to get Logical Unit information from device manager. |
| 62:2243 | Failed to get Free Logical Units available for mapping. |
| 62:2244 | Failed to get available paths' information from device manager. |
| 62:2245 | Replication pair information not found in device manager response. |
| 62:2246 | Resync of the snapshot/clone failed. |
| 62:2247 | Splitting of the snapshot/clone failed. |
| 62:2248 | No free LU available for mapping operation. Please remove paths for some luns to go ahead. |
| 62:2249 | Failed to add replication pair. |
| 62:2250 | Failed to delete the path, device manager failed to perform the operation. |
| 62:2251 | Failed to map the device, device manager failed to perform the operation. |
| 62:2252 | Failed to unmap the device, device manager failed to perform the operation. |
| 62:2253 | Failed to detect devices on the host after host refresh, could be failure with host refresh. |
| 62:2254 | Failed to perform host refresh for HDS devices. |
| 62:2255 | Failed to get the path information from device manager. |
| 62:2256 | Failed to create the replication pair. |
| 62:2257 | [Data Protection Core infrastructure] license has been expired. |
| 62:2258 | [Data Protection Enterprise infrastructure] license has expired. |
| 62:2259 | [Data Archive Enterprise infrastructure] license has expired. |
| 62:2260 | [Data Archive Core infrastructure] license has expired. |
| 62:2261 | Please make sure the client OR control host array has valid license. |
| 62:2262 | Failed to make the SnapVault qtree on the snapshot writable. |
| 62:2263 | Revert is not supported for this array/filer or engine. |
| 62:2264 | Auxiliary copy cannot write to the same library as the source copy. |
| 62:2265 | At least one of the paths used by the partitions of current active deduplication database is offline. |
| 62:2266 | At least one of the paths used by the partitions of current active deduplication database is offline. |
| 62:2267 | Device passed in for operation is not a IBMSVC device. Please check if the subclient content is an IBMSVC device. |
| 62:2268 | No space left on the DiskGroup to create a new volume/snapshot. |
| 62:2269 | Mount request failed because a full slot config was received from the library. |
| 62:2270 | There are more than one drive type in the given drive pool. Please check the Expert Storage Configuration. |
| 62:2271 | Failed to obtain lock to the metadata database. Possible reason: Another job might be accessing the database. Please run the job later. |
| 62:2272 | The media being cataloged has an invalid OML. |
| 62:2273 | Failed to read from or write to the metadata DB. Please rediscover the media and run catalog again. |
| 62:2274 | User requested to stop the tape catalog operation. |
| 62:2275 | Failed to read metadata from the chunk. Please check the log files. |
| 62:2276 | Data Path is disabled. |
| 62:2277 | LAN-free data path is disabled. |
| 62:2278 | Preferred data path is disabled. |
| 62:2279 | The source volume used is not a symmetrix device. Please check vendor and model of the source volume. |
| 62:2280 | Failed to remove pseudo device paths from host. |
| 62:2281 | Managed snap-protect check failed. |
| 62:2282 | Managed snap-protect - limit exceeded. |
| 62:2283 | Check and make sure that configuration is supported for the version of MediaAgent. |
| 62:2284 | Waiting for library server to lease drive resources for this job |
| 62:2285 | The library server host for this library is offline. |
| 62:2286 | Library not detected or could still be initializing on Library Server. 1)Check network connectivity between the library controller MediaAgent and Library Server. 2) Check if library is accessible on Library Server. |
| 62:2287 | The drive is not configured or is offline on library server. |
| 62:2288 | The Slot/Drive on which the operation was requested is not allotted to this CommCell. |
| 62:2289 | An invalid operation was attempted on library server. |
| 62:2290 | A library server operation failed. |
| 62:2291 | No iSCSI or FC initiators have been setup on this machine. Please configure either iSCSI or FC on the host and retry the operation. |
| 62:2292 | A database operation on library server failed. |
| 62:2293 | Library server operation failed. |
| 62:2294 | A database query on library server failed. Please check the library server logs for more details. |
| 62:2295 | Library server database path is not found or could not be created. |
| 62:2296 | Library server database already exists. |
| 62:2297 | Drive is configured on this CommServe. |
| 62:2298 | The drive is currently occupied. |
| 62:2299 | There are not enough free drives to proceed with the task. The drives could be in use by another CommCell. |
| 62:2300 | Request performed on a wrong library. |
| 62:2301 | Deprecated message. |
| 62:2302 | An import or export operation is currently in progress on the library server. |
| 62:2303 | Failed to connect to library server. 1. Check services are running on Library Server. 2. Check Network connectivity between CommServe and Library Server. |
| 62:2304 | There are media in the slot(s). |
| 62:2305 | No Snaps or Snap-Protect Jobs found for the search criteria. |
| 62:2306 | Enterprise archiver capacity license is required to run jobs. |
| 62:2307 | Core archiver capacity license is required to run jobs. |
| 62:2308 | Enterprise backup capacity license is required to run jobs. |
| 62:2309 | Core backup capacity license is required to run jobs. |
| 62:2310 | Source element is not occupied. |
| 62:2311 | Unable to perform DB transaction on Library Server. Please check if DB file exist and has write permission. |
| 62:2312 | Failed to initialize library. |
| 62:2313 | Failed to mount media. |
| 62:2314 | Failed to unmount media. |
| 62:2315 | Failed to move media. |
| 62:2316 | Failed to import media. |
| 62:2317 | Failed to export media. |
| 62:2318 | Failed to scan library. |
| 62:2319 | Failed to get CommCell information. |
| 62:2320 | Failed to get CommCell GUID. |
| 62:2321 | Library is being initialized on library server. Please try the operation later. |
| 62:2322 | Media is mounted on a drive that is not allotted to any CommCell. Please unmount the media manually from the drive. |
| 62:2323 | Please check if all the disk library mount paths in the dedup storage policy copy are properly configured to read from the MediaAgent [<String>] |
| 62:2324 | Failed to reserve drive from library server for this operation. |
| 62:2325 | Inline copy failed to reserve the MediaAgent used by primary copy. Please make sure Inline copy and primary copy can share the same MediaAgent for backup. |
| 62:2326 | The usage for protected mailboxes has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2327 | The usage for archive mailboxes has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2328 | The usage for content indexing objects has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2329 | Protected mailbox license is required to run jobs. |
| 62:2330 | Archive mailbox license is required to run jobs. |
| 62:2331 | Content indexing object license is required to run jobs. |
| 62:2332 | [Protected Mailbox] license has expired. |
| 62:2333 | [Archive Mailbox] license has expired. |
| 62:2334 | [Content Indexed Object] license has been expired. |
| 62:2335 | Media was not mounted by this CommCell. |
| 62:2336 | None of the partitions of the deduplication database are online. Please check if MediaAgent/Access Path are online for the partitions. |
| 62:2337 | All the Deduplication databases of current storage policy copy are not available to use. |
| 62:2338 | There is no usable DeDuplication database for current storage policy copy. |
| 62:2339 | Error with SI Volume DB. Make sure SQLite DB is not corrupted. |
| 62:2340 | This MediaAgent is an active library server. |
| 62:2341 | Failed to get spare media during write. Please verify if mount paths have enough space. |
| 62:2342 | Backups of older release clients with client side deduplication enabled cannot run to storage policies using multi-partitioned DDB. |
| 62:2343 | Auxiliary copy cannot use deduplication database with partitions if the source MediaAgent is of a previous release version. |
| 62:2344 | This is not an Isilon Disk. |
| 62:2345 | Isilon Snap Engine does not support revert operation. |
| 62:2346 | Failed to send SCSI inquiry to isilon lun. |
| 62:2347 | Isilon Filer's Control Host or Username or Password are missing. |
| 62:2348 | Failed to ssh session to Isilon filer. |
| 62:2349 | Failed to read from ssh session. |
| 62:2350 | Failed to write to SSH session. |
| 62:2351 | Failed to execute command on Isilon filer. |
| 62:2352 | Given volume does exist on Isilon filer. |
| 62:2353 | Failed to check whether lun is still present on the Isilon filer. |
| 62:2354 | Failed to check whether clone is present on the Isilon Filer. |
| 62:2355 | Unknown error from Isilon filer. Please check log files for more details. |
| 62:2356 | Cannot find snapshot on Isilon filer. |
| 62:2357 | Cannot fine the clone on Isilon filer. |
| 62:2358 | Failed to make the clone writeable. |
| 62:2359 | Failed to get initiators that are allowed to access the target on Isilon filer. |
| 62:2360 | Cannot delete snapshot. |
| 62:2361 | Failed to resolve filer hostname to IP address. |
| 62:2362 | Failed to connect to filer. |
| 62:2363 | Authentication failed while connecting to filer. Invalid credentials. |
| 62:2364 | This library is migrated for monitoring purpose, data is not accessible |
| 62:2365 | No targets on filer contain this client's IQN/HBA. |
| 62:2366 | Failed to check if this client is connected to the filer. |
| 62:2367 | Permission denied while running snap commands. |
| 62:2368 | Failed to create clone of a snapshot. |
| 62:2369 | SILO Job had reserved a stream, but no remaining streams are available for the job anymore. |
| 62:2370 | This medium is part of current active Auxiliary Copy or Media Refresh job. |
| 62:2371 | A Move Partition job is currently in progress for this deduplication database. |
| 62:2372 | Request for SIDB Reconstruction is already in progress for copy. |
| 62:2373 | No preferred device controller found |
| 62:2374 | Aged data on this mountpath cannot be pruned because mountpath is disabled. |
| 62:2375 | Aged data on this mountpath cannot be pruned. Please check if its device paths and MediaAgents are online. |
| 62:2376 | Aged data on this mountpath cannot be pruned because mountpath is not accessible. |
| 62:2377 | Aged data on this mountpath cannot be pruned because mountpath is offline. |
| 62:2378 | Volume cannot be pruned because mountpath is marked dirty. |
| 62:2379 | Volume from a foreign CommCell cannot be pruned. |
| 62:2380 | Volume cannot be pruned because the Deduplication database is offline. |
| 62:2381 | SILO enabled volume cannot be pruned. |
| 62:2382 | SILO volume not found. |
| 62:2383 | SILO copy not found. |
| 62:2384 | Check if MediaAgent Services are down or Device is offline. |
| 62:2385 | Archive file of SILO volume not found. |
| 62:2386 | Archive file is not valid on any copy. |
| 62:2387 | Archive file is Aged. |
| 62:2388 | Archive file is not valid for copy. |
| 62:2389 | Archive file aged for copy. |
| 62:2390 | A duplicate client entry was found. |
| 62:2391 | MediaAgent is not installed. |
| 62:2392 | Failed to perform operation. Library or Mount Path may have been deleted. |
| 62:2393 | Failed to perform operation. The MediaAgent may have been deleted. |
| 62:2394 | The Deduplication database for this copy has not had any deduped backups run to it. Skipping reconstruction. |
| 62:2395 | MediaAgent is uninstalled. |
| 62:2396 | Cannot find the cloud information for current storage policy. |
| 62:2397 | Search Engine resources are not available because either the amount of available disk space is low, the maximum number of content indexed documents has been reached, or the Search Engine is configured in Search Only mode. Please add a new node or use other Search Engine to content index data. |
| 62:2398 | No more luns available on Isilon filer to create a snapshot or clone. |
| 62:2399 | Job contains no valid snap volumes. |
| 62:2400 | Snap volume size details for the job is not found. |
| 62:2401 | Move Partition Failed, another move job is running on the same partition. |
| 62:2402 | Move Partition Initialization Phase Failed. |
| 62:2403 | Move Partition Failed. MediaAgent is offline. |
| 62:2404 | Move Partition Failed. MediaAgents should be offline for Move Partition [Change Path Only] operation. Please stop source and destination MediaAgent services and retry. |
| 62:2405 | Move Partition Failed. Given target path already hosts another partition, please kill the job and give a new target location. |
| 62:2406 | Move Partition Failed. A DDB Backup job is running on the DDB. |
| 62:2407 | Move Partition Failed. Failed to Stop SIDB Engines. |
| 62:2408 | Move Partition Failed. ICL label file creation failed. |
| 62:2409 | Move Partition physical move phase failed. |
| 62:2410 | There is no enough free space available in the mount path selected on the destination MediaAgent. Please select the mount path which has enough free space available. |
| 62:2411 | There is a mismatch between source DDB and the destination DDB, this could be due to manual change of files on the destination MediaAgent or DDB engine process started manually on the destination MediaAgent. |
| 62:2412 | File Read error happened on source MediaAgent, this could be due to some other process is accessing the file. Please resume the job after some time. |
| 62:2413 | File write error happened on destination MediaAgent, please make sure destination MediaAgent is up and running and there is no network connectivity issue between source and destination MediaAgent. |
| 62:2414 | Error encountered with the Dataserver, please make sure destination MediaAgent is up and running and there is no network connectivity issue between source and destination MediaAgent. |
| 62:2415 | Error while processing offset file, this could be due to some other process accessing the file or someone manually removed the file. |
| 62:2416 | Error while processing collect file, this could be due to some other process accessing the file or someone manually removed the file. |
| 62:2417 | There is checksum difference between the source file and source file copy on destination, this could be due to source or destination file is accessing by some other processes. Resume operation may solve the issue. |
| 62:2418 | Cannot Decrypt/Decompress data read from media. |
| 62:2419 | The deduplication partition is still uninitialized. Not marking the partition for recovery. |
| 62:2420 | Successfully set the Store Partition for copy[<String>] for recovery by user. |
| 62:2421 | Failed to find a suitable target device for source lun. Please make sure usable luns of same size as source created in the array. |
| 62:2422 | MediaAgent cannot do offline content indexing job to an engine with a different version. |
| 62:2423 | Search Engines from current cloud have different versions. |
| 62:2424 | Some deduplication partitions of this Storage Policy Copy are skipped due to reconstruction threshold. Skipping reconstruction. Please check event viewer for details. |
| 62:2425 | Source and destination MediaAgent with different versions cannot be used for one synthetic full job. |
| 62:2426 | Cannot read chunk metadata file. This could be due to missing or corrupted metadata file. |
| 62:2427 | Total number of data transfer operations on current deduplication database exceeds the maximum allowed value. |
| 62:2428 | Not all volumes are valid. |
| 62:2429 | Invalid Backup Set ID |
| 62:2430 | Invalid Parameters to get Clone Envs |
| 62:2431 | No Cloned Volumes found |
| 62:2432 | Aged data on this mountpath cannot be pruned because DDB partition MediaAgent is offline. |
| 62:2433 | Aged data on this mountpath cannot be pruned because DDB partition is offline. |
| 62:2434 | SILO volume cannot be accessed. Username or password could be incorrect or volume is inaccessible from MediaAgent. |
| 62:2435 | Test Clones exist in the database. |
| 62:2436 | Cannot delete Volume details from database. |
| 62:2437 | Cannot delete Snap details from database. |
| 62:2438 | Cannot delete Snap Volume Map details from database. |
| 62:2439 | Cannot delete Snap Volume Metadata details from database. |
| 62:2440 | Cannot delete Snap Job details from database. |
| 62:2441 | Failed to execute [<String>]-snap command [<String>] on [<String>] client. Error [^4%S]. Please check if 1) The specified batch file exists. 2) Access credentials are valid. |
| 62:2442 | Command [<String>] executed for [<String>]-snap on [<String>] client returned failure error code[<Number>]. |
| 62:2443 | No nodes will accept Put or Reserve operations for this policy. |
| 62:2444 | No nodes have a copy of the requested object. |
| 62:2445 | Policy name or id is not currently supported by the cluster. |
| 62:2446 | Unknown internal Error. |
| 62:2447 | An invalid OID was specified. |
| 62:2448 | The cluster is full. |
| 62:2449 | Object does not match its checksum. |
| 62:2450 | Filesystem internal structures are corrupted. |
| 62:2451 | Insufficient cluster resources to service Put or Reserve request for this policy. |
| 62:2452 | Unrecoverable drive error. |
| 62:2453 | Object size > 5 TB. |
| 62:2454 | Operation should be retried momentarily. |
| 62:2455 | Reservation not found for specified OID. |
| 62:2456 | Attempt to store object of length zero. |
| 62:2457 | Invalid metadata key specified. |
| 62:2458 | Attempted Get of an unused reservation. |
| 62:2459 | Unresolvable network corruption of the object. |
| 62:2460 | Command did not complete in a timely manner. |
| 62:2461 | Illegal combination of buffered=true, integrity=false. |
| 62:2462 | The operation is not valid for the object's storage class. The object might be archived and the Cloud Recall workflow might have been initiated. After the recall operation is complete, the job will resume and the recalled data will be restored. |
| 62:2463 | Archived object restore is already in progress. |
| 62:2464 | Some deduplication partitions of this Storage Policy Copy are skipped due to reconstruction threshold or currently DDB validation is failed. Skipping reconstruction. Please check event viewer for details. |
| 62:2465 | Failed to initialize communication with array. |
| 62:2466 | HORCM command failed. |
| 62:2467 | Failed to authenticate with array. |
| 62:2468 | Revert from VNX Snapshot is not supported for the device which has existing Snapview session(s) or clone(s) in non-fractured state. |
| 62:2469 | Please set the EMC Navisphere secure CLI home directory path using Array Management. It is either empty or wrong path is set. |
| 62:2470 | Security file does not exist. Please consult VNX documentation for details on adding Navisphere secure CLI user security. |
| 62:2471 | The CLARiiON device is not eligible for VNX Snapshot |
| 62:2472 | Can not perform operations on deduplication store because DDB activity on CommServe is disabled. |
| 62:2473 | Backup/Auxiliary Copy operations are not allowed for this migrated storage policy. |
| 62:2474 | The active deduplication store of current storage policy copy was found to be inconsistent during the last reconstruction job. |
| 62:2475 | Unknown chunk status. |
| 62:2476 | AvgQITime for DDB has exceeded the threshold. |
| 62:2477 | Snapshot creation failed because the volume is offline. Please make sure the volume is online. |
| 62:2478 | System has detected that a DR backup was restored. Job ID will be restarted at a higher number to facilitate DDB resync. |
| 62:2479 | Deduplication Database is currently under maintenance. |
| 62:2480 | Please complete the maintenance operation (DDB Resynchronization, Conversion to Transactional DDB, etc.) to bring the Deduplication Database back online. |
| 62:2481 | Media Password verification failed. |
| 62:2482 | Initialization of Deduplication Validation Phase Failed. Check the log files for details. |
| 62:2483 | Unable to run Data Verification job because One or more partitions of the deduplication store is corrupted. |
| 62:2484 | Unable to run Data Verification job because Deduplication Database Move operation is in progress. |
| 62:2485 | Unable to run Data Verification job because Deduplication Database is currently under maintenance. |
| 62:2486 | Unable to run Data Verification job because Deduplication Database is currently in use by other jobs like Backup, Auxiliary Copy etc. |
| 62:2487 | Reservation cannot continue because current deduplication database is under maintenance. |
| 62:2488 | Unable to run Data Verification job because Deduplication Database [<String>] stop request failed. Error: [<String>] |
| 62:2489 | Sfile index file is missing or found corrupt during data verification job. |
| 62:2490 | Chunk folder is missing during data verification job. |
| 62:2491 | Chunk with bad checksum found during data verification job. |
| 62:2492 | Required chunk record not found with SIDB during data verification job. |
| 62:2493 | Invalid Sfile no. present in chunk metadata. |
| 62:2494 | Invalid volume Id present in chunk metadata. |
| 62:2495 | Invalid mount path Id present in chunk metadata. |
| 62:2496 | Invalid Sfile offset present in chunk metadata. |
| 62:2497 | Sfile container file is missing or found corrupt during data verification job. |
| 62:2498 | Failed to retrieve data. |
| 62:2499 | Navisphere CLI error. |
| 62:2500 | Marked [<Number>] Deduplication Engines for resync. Note that engines hosted by MediaAgents lower than 10.0 SP6A are not eligible for resync. |
| 62:2501 | Failed to mark Deduplication Engines for resync. Please check EvMgrS service log for detailed information. |
| 62:2502 | Cannot mark Deduplication Engines for resync because restored DR backup is older than the allowed [<Number>] days. |
| 62:2503 | Deduplication Engine [<String>] successfully validated/resync-ed. |
| 62:2504 | Validation/Resync of Deduplication Engine [<String>] failed. The operation will be attempted again. Please check MediaManager service log for detailed information. |
| 62:2505 | Mapping between given host and volume does not exist. |
| 62:2506 | The account was out of service. |
| 62:2507 | The Content-MD5 in message header did not match the content received. |
| 62:2508 | The container was disabled. |
| 62:2509 | The length of content body mismatch the number specified by the Content-Length HTTP header. |
| 62:2510 | No sufficient capacity to process the request. |
| 62:2511 | The specified metadata does not exist. |
| 62:2512 | Acl exceeds the maximum allowed size. |
| 62:2513 | The request attempts to create more container than allowed. |
| 62:2514 | POST requires exactly one object upload per request. |
| 62:2515 | The Move Partition job cannot be run because the chosen partition is empty and has no data in it, hence failing the job. |
| 62:2516 | The blob type is invalid for this operation. |
| 62:2517 | All operations on page blobs require at least version 2009-09-19. |
| 62:2518 | The page range specified is invalid. |
| 62:2519 | The sequence number condition specified was not met. |
| 62:2520 | The sequence number increment cannot be performed because it would result in overflow of the sequence number. |
| 62:2521 | The source condition specified using HTTP conditional header(s) is not met. |
| 62:2522 | The target condition specified using HTTP conditional header(s) is not met. |
| 62:2523 | Prepare operation failed after getting response from MediaAgent as there are LUNs from multiple arrays. This configuration is not supported. |
| 62:2524 | Operation failed as there are LUNs from multiple arrays. This configuration is not supported. |
| 62:2525 | Validation/Resync of Deduplication Engine [<String>] cannot proceed. Reason [<String>]. |
| 62:2526 | [<Number>] Deduplication Engine(s) have been put in maintenance mode. Reason [<String>]. Please resync these Engines to make them accessible. |
| 62:2527 | Move Mount Path Job Failed, Reason : Source and target locations given for the job are the same. |
| 62:2528 | Move Mount Path Job Failed, Reason : Failure in initialization of the job. |
| 62:2529 | Move Mount Path Job Failed, Reason : Failure in physical move of the mount path. |
| 62:2530 | Move Mount Path Job Failed, Reason : The mount path is under maintenance and hence cannot proceed with the move operation. |
| 62:2531 | Move Mount Path Job Failed, Reason : There are jobs running to the mount paths. |
| 62:2532 | Move Mount Path Job Failed, Reason : The media agent controlling the mount path is offline. |
| 62:2533 | Cannot mark partition for recovery as one or more partitions of this Deduplication Engine are being resync-ed. Please try after sometime. |
| 62:2534 | Initiating validation/resync on [<Number>] Deduplication Engines. |
| 62:2535 | Move Mount Path Job Failed, Reason : Cannot move mount path to a UNC location. |
| 62:2536 | Move Mount Path Job Failed, Reason : Cannot move network or UNC mount path. |
| 62:2537 | Move Mount Path Job Failed, Reason : The target location already hosts another mount path. |
| 62:2538 | Move Mount Path Job Failed, Reason : Moving a device with more than one mount path is not supported. |
| 62:2539 | There is no more data to process currently. Rest of the unprocessed data are either being sent to MediaAgent or skipped due to failures. |
| 62:2540 | Failed to update the array configurations |
| 62:2541 | Failed to process the alternate media agent for Snap |
| 62:2542 | Error in stored procedure MM_SMProcessSnapPrune |
| 62:2543 | The number of Snap Prune requests per Media Agent is set to 0. Snap Pruning will not take place. |
| 62:2544 | Failed to add DFM Dataset Members to CommServe database. |
| 62:2545 | Failed to add SMSnap to DFM Dataset Member Map to CommServe database. |
| 62:2546 | AvgQITime for DDB of Copy [<String>] Storage Policy [<String>] has exceeded the threshold. |
| 62:2547 | Mountpath already exists |
| 62:2548 | Marked appendable during media refresh. |
| 62:2549 | Jobs on this media were unaged by user. |
| 62:2550 | SMActiveSnap Operation failed |
| 62:2551 | Failed to retrieve data. |
| 62:2552 | Failed get SProvInfo. |
| 62:2553 | Failed to manage host for Storage Provisioning. |
| 62:2554 | Failed to manage LUN operation for Storage Provisioning. |
| 62:2555 | Empty LUN list. |
| 62:2556 | Unknown Operation Type. |
| 62:2557 | Failed to provision new LUN(s) before sending request to MediaAgent. |
| 62:2558 | Failed to provision new LUN(s) after getting response from MediaAgent. |
| 62:2559 | Failed to map LUN(s) before sending request to MediaAgent. |
| 62:2560 | Failed to map LUN(s) after getting response from MediaAgent. |
| 62:2561 | Failed to unmap LUN(s) before sending request to MediaAgent. |
| 62:2562 | Failed to unmap LUN(s) after getting response from MediaAgent. |
| 62:2563 | Failed to delete LUN(s) before sending request to MediaAgent. |
| 62:2564 | Failed to delete LUN(s) after getting response from MediaAgent. |
| 62:2565 | Failed to provision new LUN(s). |
| 62:2566 | Failed to map LUN(s). |
| 62:2567 | Failed to mount LUN(s). |
| 62:2568 | Failed to unmap LUN(s). |
| 62:2569 | Failed to delete LUN(s). |
| 62:2570 | Failed to update SProvInfo to CommServ DB. |
| 62:2571 | Failed to resize LUN(s). |
| 62:2572 | Failed to resize LUN(s) before sending request to MediaAgent. |
| 62:2573 | Failed to resize LUN(s) after getting response from MediaAgent. |
| 62:2574 | Failed to find MediaAgent to send request fro Storage Provisioning. |
| 62:2575 | VSA AppAware revert operation failed for iDA Snap because VSA Snap is either not mounted or mounted to a different host. |
| 62:2576 | VSA AppAware. check to detach VM disk Failed. |
| 62:2577 | VSA AppAware. Mount VM GUID is empty. |
| 62:2578 | Destination mail slots for export are unavailable or invalid for the library. |
| 62:2579 | Physical pruning on mount path is disabled. |
| 62:2580 | Failed to set or remove pruning control information into registry on the media agent. |
| 62:2581 | Input mail slots for import are unavailable or invalid for the library. |
| 62:2582 | Input destination slots for import are unavailable or invalid for the library. |
| 62:2583 | Physical pruning on SIDB store is disabled. |
| 62:2584 | Data Path with the closest geometric location to current client is not available. |
| 62:2585 | Move Partition job failed because the source Media Agent is unresponsive for more than 20 mins. Please check the media agent services. |
| 62:2586 | Aged data on this mountpath cannot be pruned because mountpath is read-only. |
| 62:2587 | Aged data on this mountpath cannot be pruned because micro pruning is disabled on the mountpath. |
| 62:2588 | Mount Path Label file not found. |
| 62:2589 | Failed to get array controller(s). |
| 62:2590 | Aged data on this mountpath cannot be pruned because none of the device controllers are marked for pruning. |
| 62:2591 | The Blackout Window for data pruning on the DDB Media Agent prevents the pruning operation from running right now. |
| 62:2592 | Move Mount Path Job Failed, Reason : Unsupported OS configuration - move is allowed only between windows-windows or unix-unix media agents. |
| 62:2593 | Move Mount Path Job Failed, Reason : Unsupported Commvault configuration - move is allowed only between V10-V10 or V11-V11 media agents. |
| 62:2594 | Move Mount Path Job Failed, Reason : Failure in building the list of volumes to be moved. |
| 62:2595 | Move Mount Path Job Failed, Reason : Unsupported library configuration - move not allowed on storage device that is shared between different mount paths. |
| 62:2596 | Move Mount Path Job Failed, Reason : Jobs are running to the mount path being moved. Please suspend the backup job and resume move mount path job or let backup finish and resume move mount path job. |
| 62:2597 | Move Mount Path Job Failed, Reason : Moving a UNC mount path is supported only on Media Agents with versions v11 or higher. |
| 62:2598 | Data Verification job is in progress on the deduplication store. |
| 62:2599 | The Blackout Window on MediaAgent prevents the job from running right now. |
| 62:2600 | Failed to compute destination encryption key based on copy RSA encryption. |
| 62:2601 | Validation failed for Test Clones |
| 62:2602 | One or more volume(s) have been already created by a previous attempt for this Test Clone job. |
| 62:2603 | ChunkId greater than the one verified was requested. |
| 62:2604 | The destination mount path is invalid, please enter a valid path. |
| 62:2605 | There is no data to move at the source location. |
| 62:2606 | Scalable resource allocation option can not be used for this job. |
| 62:2607 | Pruning is prevented on the mount path due to Data Pruning Blackout Window set on all its associated MediaAgents. |
| 62:2608 | There is a mismatch between source path and the destination path, this could be due to manual change of files on the destination MediaAgent. |
| 62:2609 | VM Sockets license is required to run jobs. |
| 62:2610 | Protected Virtual Machines license is required to run jobs. |
| 62:2611 | Application Class Virtual license is required to run jobs. |
| 62:2612 | VM Sockets license has expired. |
| 62:2613 | Protected Virtual Machines license has expired. |
| 62:2614 | Application Class Virtual license has expired. |
| 62:2615 | The usage for [VM Sockets] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2616 | The usage for [Protected Virtual Machines] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2617 | The usage for [Application Class Virtual] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2618 | In-use chunkId requested by data verification job. |
| 62:2619 | Block Level Snap Can not be deleted. |
| 62:2620 | Search Engine resources are not available because the amount of available disk space is low, the maximum number of content indexed documents has been reached, and the Search Engine is configured in Search Only mode. Please add a new node or use other Search Engine to content index data. |
| 62:2621 | Search Engine resources are not available because the amount of available disk space is low and the Search Engine is configured in Search Only mode. Please add a new node or use other Search Engine to content index data. |
| 62:2622 | Search Engine resources are not available because the maximum number of content indexed documents has been reached and the Search Engine is configured in Search Only mode. Please add a new node or use other Search Engine to content index data. |
| 62:2623 | Search Engine resources are not available because the amount of available disk space is low and the maximum number of content indexed documents has been reached. Please add a new node or use other Search Engine to content index data. |
| 62:2624 | Search Engine resources are not available because the Search Engine is configured in Search Only mode. Please add a new node or use other Search Engine to content index data. |
| 62:2625 | Search Engine resources are not available because the amount of available disk space is low. Please add a new node or use other Search Engine to content index data. |
| 62:2626 | Search Engine resources are not available because the maximum number of content indexed documents has been reached. Please add a new node or use other Search Engine to content index data. |
| 62:2627 | Library status offline due to incomplete storage pool configuration. Please wait for other media agents to join this storage pool library configuration. |
| 62:2628 | Snap operation request timed out as response was not received from Media Agent. |
| 62:2629 | There is an issue with HyperScale X storage configuration. |
| 62:2630 | HyperScale cluster does not exist |
| 62:2631 | Failed to add drives to the HyperScale cluster |
| 62:2632 | Failed to create HyperScale cluster |
| 62:2633 | Failed to mount HyperScale cluster |
| 62:2634 | Encountered error while processing HyperScale mount path |
| 62:2635 | Failed to resolve any of the provided hosts to loopback address 127.0.0.1. |
| 62:2636 | DDB is currently in a suspended state due to a maintenance operation. |
| 62:2637 | The DDB is not in valid state. |
| 62:2638 | The DDB is in quiesced state. |
| 62:2639 | DDB move partition is not allowed from this higher feature release MediaAgent to lower feature release MediaAgent when In-memory deduplication database option is disabled. |
| 62:2640 | One or more dataset members have been aged but not yet removed from the dataset. |
| 62:2641 | A Partition requires upgrade or is currently being upgraded for this deduplication database. |
| 62:2642 | Failed to resume writes on GPFS volume. |
| 62:2643 | Failed to suspend writes on GPFS volume. |
| 62:2644 | Volume group can't be reverted while it is part of a cluster. |
| 62:2645 | Concurrent jobs running on current physical node (client) reach the limit. |
| 62:2646 | ZFS volume [<String>] is not marked zoned. |
| 62:2647 | The Move Partition job cannot proceed because the selected target location hosts a partition from a different copy. |
| 62:2648 | Failed to get device details through xiv_devlist. Please ensure that the IBM XIV HAK is installed and the path is set correctly in the reg key iDataAgent/sXivDevListPath. |
| 62:2649 | Mailbox archive solution license is required to run jobs. |
| 62:2650 | Mailbox archive solution license has expired. |
| 62:2651 | The usage for [Mailbox archive solution] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2652 | Please check if all the disk library mount paths in the dedup storage policy copy are properly configured to read from the MediaAgent. |
| 62:2653 | Server group capacity quota is exceeded. |
| 62:2654 | An obsolete file is created at the source location, please delete the file manually before resuming the move mount path job. |
| 62:2655 | Inline backup currently is not supported when using regional Server group backup feature for this client. |
| 62:2656 | Cannot connect to Data Server, please make sure destination MediaAgent is up and running and there is no network / connectivity issue between source and destination MediaAgent. |
| 62:2657 | Connection to Data Server is lost, please make sure destination MediaAgent is up and running and there is no network / connectivity issue between source and destination MediaAgent. |
| 62:2658 | Export failed for mount path, please check if the mount path is accessible on Data Server. Check the Media Agent logs for detailed error. |
| 62:2659 | Mount failed for mount path, please check if the mount path is accessible on Data Server. Check the Media Agent logs for detailed error. |
| 62:2660 | The source media for Tape to Tape Copy job should not be aged. |
| 62:2661 | The source media for Tape to Tape Copy job do not have valid data. |
| 62:2662 | The destination media for Tape to Tape Copy job is not a spare media. |
| 62:2663 | The media selected for Tape to Tape Copy job is currently reserved. |
| 62:2664 | The chosen tape library is offline. |
| 62:2665 | The library has insufficient drives to run Tape to Tape Copy job. |
| 62:2666 | Another Tape to Tape Copy job is running on the same media. |
| 62:2667 | Failed to mount spare media for Tape to Tape Copy job. |
| 62:2668 | Failed to mount active media for Tape to Tape Copy job. |
| 62:2669 | Tape to Tape Copy job failed in physical copy phase. |
| 62:2670 | The library does not have a version 11 media agent. |
| 62:2671 | The destination media is smaller than the source media. |
| 62:2672 | The destination media is write protected. |
| 62:2673 | Failure in unreserving the media after tape copy operation. |
| 62:2674 | Mount path has Defragmented Data, Media Agent is below the required feature release level to read Defragment Data on mount paths. Please install the latest feature release. |
| 62:2675 | A Drive Pool with this name already exists for the Library under the same MediaAgent. |
| 62:2676 | Incompatible Datamover and DDB MediaAgents. Please verify that Datamover and DDB MediaAgent versions are matching. |
| 62:2677 | Suspending running jobs. |
| 62:2678 | Job is killed because the media agent is unresponsive for the past 15 minutes. If job resources are still reserved, please release it from the GUI. |
| 62:2679 | Snapshot creation failed because the volume is read-only. Please make sure the volume is read-writable. |
| 62:2680 | Media Management configuration setting 'Allow load-balance on multiple data paths within one backup job' is enabled |
| 62:2681 | Media Marked Full by Tape to Tape Copy Job. |
| 62:2682 | The Move Partition job cannot proceed as the source and destination location of the move are same. |
| 62:2683 | The usage for [Appliance Store Usage] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2684 | Appliance Store Usage license has expired. |
| 62:2685 | Appliance Store Usage license is required to run jobs. |
| 62:2686 | Connection to Data Server [<String>] failed, please make sure Data Server MediaAgent is up and running and there is no network / connectivity issue with Data Server MediaAgent. |
| 62:2687 | Export / Mount failed for mount path [<String>], please check if the mount path is accessible on Data Server [<String>]. Check the logs for detailed error. |
| 62:2688 | Another Tape to Tape Copy job is running on the spare media selected. |
| 62:2689 | Another Tape to Tape Copy job is running on the source media selected. |
| 62:2690 | The selected destination tape library is offline. |
| 62:2691 | The spare media selected for this Tape to Tape Copy job is currently reserved. |
| 62:2692 | No drives in destination drive pool. |
| 62:2693 | No drives in source drive pool. |
| 62:2694 | The Media Agent selected is not a library controller of destination library. |
| 62:2695 | The Media Agent selected is not a library controller of source library. |
| 62:2696 | The selected source tape library is offline. |
| 62:2697 | The source media selected for this Tape to Tape Copy job is currently reserved. |
| 62:2698 | The target drive does not support hardware encryption. |
| 62:2699 | The source drive does not support hardware encryption. |
| 62:2700 | Jobs[<String>] are running to this MediaAgent. |
| 62:2701 | The deduplication partition is already marked for recovery. |
| 62:2702 | The operation with this blob type is not supported for the account type. |
| 62:2703 | Power Management is enabled on this Virtual Machine. Waiting on the Virtual Machine to power on. |
| 62:2704 | Array Controller(s) not configured for array. |
| 62:2705 | Inline backup currently is not supported when using feature 'Allow load-balance on multiple data paths within one backup job'. |
| 62:2706 | Move Mount Path Job Failed, Reason : Mount Path is shared over Data Server IP and hence cannot be moved to UNC Path. |
| 62:2707 | Move Mount Path Job Failed, Reason : Mount Path is shared over iSCSI and hence cannot be moved to UNC Path. |
| 62:2708 | Move Mount Path Job Failed, Reason : Mount Path is shared over SAN and hence cannot be moved to UNC Path. |
| 62:2709 | Drive(s) in this master pool are being used by a job. |
| 62:2710 | The device does not recognize the command while reading. |
| 62:2711 | An unexpected network error occurred. |
| 62:2712 | Read operation cannot be completed using the specified drive. |
| 62:2713 | Read operation cannot be completed using the specified drive pool. |
| 62:2714 | Read operation cannot be completed using the specified MediaAgent. |
| 62:2715 | Provided library is not a cloud library [<String>] |
| 62:2716 | Provided library is not a disk library [<String>] |
| 62:2717 | MediaAgent(s) [<String>] were powered off by Cloud VM Power Management. Please power on manually from MediaAgent properties. |
| 62:2718 | Free space on library reached low watermark. |
| 62:2719 | Data Aging activity on the commcell is disabled. |
| 62:2720 | Deduplication Engine [<String>] has invalid archive files. Please mark it for archive file validation and pruning. |
| 62:2721 | IBM i VTL Storage Policy does not have a secondary data path. |
| 62:2722 | Media [<String>] is outside the Library, Chunks on this Media skipped for AuxCopy. |
| 62:2723 | Total number of data transfer operations on the client exceeds the maximum allowed value. |
| 62:2724 | Holding streams for doing index operations. |
| 62:2725 | Number of active streams for running jobs reaches the limit. |
| 62:2726 | The certificate file is not found. |
| 62:2727 | Adding partitions is not supported for MediaAgents older than version 10. |
| 62:2728 | Failed to perform <String> operation for Cloud Virtual Machine [<String>]. Reason - <String>. |
| 62:2729 | Move Mount Path Job Failed, Reason : Another Move Mount Path job [<Number>] is running to same target location [<String>], Please provide different target location. |
| 62:2730 | The RPStore is currently in use. |
| 62:2731 | -3109 OSCLT_CLTERR_ABANDONED_ACTIVE_TRANSACTIONS |
| 62:2732 | -1200 OSCLT_CLTERR_ALREADY_IN_BLACKOUT |
| 62:2733 | -3103 OSCLT_CLTERR_CHUNK_MANIFEST_ARRAY_SIZE_MISMATCH |
| 62:2734 | -3104 OSCLT_CLTERR_CHUNK_MANIFEST_ARRAY_TOO_SMALL |
| 62:2735 | -3999 OSCLT_CLTERR_DATA_SESSION_IN_ERROR_STATE |
| 62:2736 | -3111 OSCLT_CLTERR_DATA_SESSION_IN_IDLE_STATE |
| 62:2737 | -3000 OSCLT_CLTERR_FIRST_SOFT_DATA_SESSION_ERROR |
| 62:2738 | -3105 OSCLT_CLTERR_INSUFFICIENT_BUFFER_SPACE |
| 62:2739 | -1951 OSCLT_CLTERR_INSUFFICIENT_REDUNDANCY |
| 62:2740 | -3101 OSCLT_CLTERR_INVALID_CHUNK_SIZE |
| 62:2741 | -3102 OSCLT_CLTERR_INVALID_COMPRESSION_ALGORITHM |
| 62:2742 | -1303 OSCLT_CLTERR_INVALID_LOG_FILE_SIZE |
| 62:2743 | -1302 OSCLT_CLTERR_INVALID_LOG_LEVEL |
| 62:2744 | -3107 OSCLT_CLTERR_INVALID_OVERLAPPING_SECTIONS_VALUE |
| 62:2745 | -1304 OSCLT_CLTERR_INVALID_PATHNAME |
| 62:2746 | -3100 OSCLT_CLTERR_INVALID_SECTION_SIZE |
| 62:2747 | -1300 OSCLT_CLTERR_INVALID_SESSION_HANDLE |
| 62:2748 | -1301 OSCLT_CLTERR_INVALID_SESSION_LOG_ID |
| 62:2749 | -1305 OSCLT_CLTERR_INVALID_SESSION_OPTIONS |
| 62:2750 | -3300 OSCLT_CLTERR_LAST_SOFT_DATA_SESSION_ERROR |
| 62:2751 | -1201 OSCLT_CLTERR_NOT_IN_BLACKOUT |
| 62:2752 | -1307 OSCLT_CLTERR_OPERATION_NOT_SUPPORTED_IN_TEAMING_BOOTSTRAP_MODE |
| 62:2753 | -1309 OSCLT_CLTERR_OPERATION_NOT_SUPPORTED_IN_TEAMING_DEGRADED_MODE |
| 62:2754 | -1306 OSCLT_CLTERR_OPERATION_SUPPORTED_ONLY_IN_TEAMING_BOOTSTRAP_MODE |
| 62:2755 | -3112 OSCLT_CLTERR_READ_HOLE |
| 62:2756 | -1950 OSCLT_CLTERR_RESTRICTION_REMOVES_ALL_TEAM_MEMBERS |
| 62:2757 | -1963 OSCLT_CLTERR_TEAMED_DATAJOB_BITMASK_INCONSISTENCY |
| 62:2758 | -1962 OSCLT_CLTERR_TEAMED_DATAJOB_JOB_BITMASK_INCONSISTENCY |
| 62:2759 | -1961 OSCLT_CLTERR_TEAMED_DATAJOB_JOB_UUID_INCONSISTENCY |
| 62:2760 | -1960 OSCLT_CLTERR_TEAMED_OBJECT_BITMASK_INCONSISTENCY |
| 62:2761 | -1955 OSCLT_CLTERR_TEAMED_OBJECT_CREATION_BITMASK_INCONSISTENCY |
| 62:2762 | -1959 OSCLT_CLTERR_TEAMED_OBJECT_DATA_LAST_MODIFIED_BITMASK_INCONSISTENCY |
| 62:2763 | -1958 OSCLT_CLTERR_TEAMED_OBJECT_DATA_LAST_MODIFIED_UUID_INCONSISTENCY |
| 62:2764 | -1953 OSCLT_CLTERR_TEAMED_OBJECT_KEY_INCONSISTENCY |
| 62:2765 | -1966 OSCLT_CLTERR_TEAMED_OBJECT_META_INCONSISTENCY |
| 62:2766 | -1957 OSCLT_CLTERR_TEAMED_OBJECT_META_LAST_MODIFIED_BITMASK_INCONSISTENCY |
| 62:2767 | -1956 OSCLT_CLTERR_TEAMED_OBJECT_META_LAST_MODIFIED_UUID_INCONSISTENCY |
| 62:2768 | -1952 OSCLT_CLTERR_TEAMED_OBJECT_NOT_CREATED_ON_TEAM_MEMBER |
| 62:2769 | -1964 OSCLT_CLTERR_TEAMED_OBJECT_STORAGEMODE_INCONSISTENCY |
| 62:2770 | -1965 OSCLT_CLTERR_TEAMED_OBJECT_TAGLIST_INCONSISTENCY |
| 62:2771 | -1954 OSCLT_CLTERR_TEAMED_OBJECT_UUID_INCONSISTENCY |
| 62:2772 | -1854 OSCLT_CLTERR_TEAMED_OBJECTSTORE_BITMASK_INCONSISTENCY |
| 62:2773 | -1851 OSCLT_CLTERR_TEAMED_OBJECTSTORE_CREATION_BITMASK_INCONSISTENCY |
| 62:2774 | -1855 OSCLT_CLTERR_TEAMED_OBJECTSTORE_DESCRIPTION_INCONSISTENCY |
| 62:2775 | -1858 OSCLT_CLTERR_TEAMED_OBJECTSTORE_JOB_RETENTION_POLICY_INCONSISTENCY |
| 62:2776 | -1853 OSCLT_CLTERR_TEAMED_OBJECTSTORE_LAST_MODIFIED_BITMASK_INCONSISTENCY |
| 62:2777 | -1852 OSCLT_CLTERR_TEAMED_OBJECTSTORE_LAST_MODIFIED_UUID_INCONSISTENCY |
| 62:2778 | -1857 OSCLT_CLTERR_TEAMED_OBJECTSTORE_QUOTA_POLICY_INCONSISTENCY |
| 62:2779 | -1860 OSCLT_CLTERR_TEAMED_OBJECTSTORE_SECURE_ERASE_OVERWRITE_COUNT_INCONSISTENCY |
| 62:2780 | -1859 OSCLT_CLTERR_TEAMED_OBJECTSTORE_TEAMING_POLICY_INCONSISTENCY |
| 62:2781 | -1850 OSCLT_CLTERR_TEAMED_OBJECTSTORE_UUID_INCONSISTENCY |
| 62:2782 | -1856 OSCLT_CLTERR_TEAMED_OBJECTSTORE_WRITE_POLICY_INCONSISTENCY |
| 62:2783 | -1308 OSCLT_CLTERR_TEAMING_BOOTSTRAP_MODE_IN_ERROR_STATE |
| 62:2784 | -3110 OSCLT_CLTERR_THROUGHPUT_STATISTICS_CALLBACK_ERROR |
| 62:2785 | -3108 OSCLT_CLTERR_TOO_MANY_ACTIVE_TRANSACTIONS |
| 62:2786 | -3106 OSCLT_CLTERR_TOO_MANY_CHUNKS_IN_SECTION |
| 62:2787 | -3113 OSCLT_CLTERR_VARFIX_WRITE_SIZE_NOT_MULTIPLE_OF_CHUNK_SIZE |
| 62:2788 | -1408 OSCLT_ERR_ACCOUNT_DENIED |
| 62:2789 | -3222 OSCLT_ERR_DATA_SESSION_MODE_NOT_SUPPORTED_FOR_OBJECT_STORAGE_MODE |
| 62:2790 | -3400 OSCLT_ERR_DEDUPE_ERROR |
| 62:2791 | -3401 OSCLT_ERR_DEDUPE_OPEN_ERROR |
| 62:2792 | -3402 OSCLT_ERR_DEDUPE_TIMEOUT_ERROR |
| 62:2793 | -1606 OSCLT_ERR_DUPLICATE_CLIENT_IDENTIFIER |
| 62:2794 | -1901 OSCLT_ERR_DUPLICATE_OBJECT_KEY |
| 62:2795 | -1801 OSCLT_ERR_DUPLICATE_OBJECTSTORE_KEY |
| 62:2796 | -2215 OSCLT_ERR_FC_COPYJOB_MAXIMUM_DEVICE_LOCKS |
| 62:2797 | -2213 OSCLT_ERR_FC_COPYJOB_NOT_SUPPORTED_ON_DESTINATION |
| 62:2798 | -2212 OSCLT_ERR_FC_COPYJOB_NOT_SUPPORTED_ON_ORIGIN |
| 62:2799 | -2214 OSCLT_ERR_FC_COPYJOB_RECIPROCAL_CONNECTION_FAILED_TO_ESTABLISH |
| 62:2800 | -2211 OSCLT_ERR_FC_DESTINATION_NOT_AVAILABLE |
| 62:2801 | -3223 OSCLT_ERR_FIXED_BLOCK_STORAGE_MODE_REQUIRES_BLOCK_ALIGNED_ACCESS |
| 62:2802 | -3209 OSCLT_ERR_INSUFFICIENT_SPACE |
| 62:2803 | -1401 OSCLT_ERR_INTERNAL_ERROR_ON_SERVER |
| 62:2804 | -1403 OSCLT_ERR_INVALID_ADDRESS |
| 62:2805 | -1702 OSCLT_ERR_INVALID_ADDRESS_FILTER |
| 62:2806 | -3203 OSCLT_ERR_INVALID_BANDWIDTH_MODE |
| 62:2807 | -1500 OSCLT_ERR_INVALID_BLACKOUT_POLICY |
| 62:2808 | -3204 OSCLT_ERR_INVALID_BUFFER_SIZE |
| 62:2809 | -2216 OSCLT_ERR_INVALID_CHECKSUM_ALGORITHM |
| 62:2810 | -1603 OSCLT_ERR_INVALID_CLIENT_IDENTIFIER |
| 62:2811 | -1604 OSCLT_ERR_INVALID_CLIENT_PASSWORD |
| 62:2812 | -1605 OSCLT_ERR_INVALID_CLIENT_PERMISSIONS |
| 62:2813 | -3213 OSCLT_ERR_INVALID_CLONE_CACHE_SIZE |
| 62:2814 | -1420 OSCLT_ERR_INVALID_CREDENTIALS |
| 62:2815 | -1703 OSCLT_ERR_INVALID_CREDENTIALS_FILTER |
| 62:2816 | -1503 OSCLT_ERR_INVALID_DATA_SESSIONS_LIMIT |
| 62:2817 | -1701 OSCLT_ERR_INVALID_DATEPERIOD_FILTER |
| 62:2818 | -1807 OSCLT_ERR_INVALID_DEDUPE_STORE_NAME |
| 62:2819 | -1803 OSCLT_ERR_INVALID_DESCRIPTION |
| 62:2820 | -2000 OSCLT_ERR_INVALID_JOB_ID_FILTER |
| 62:2821 | -2004 OSCLT_ERR_INVALID_JOB_REFERENCE |
| 62:2822 | -1806 OSCLT_ERR_INVALID_JOB_RETENTION_POLICY |
| 62:2823 | -2001 OSCLT_ERR_INVALID_JOB_STATUS_FILTER |
| 62:2824 | -2100 OSCLT_ERR_INVALID_JOB_UUID_FILTER |
| 62:2825 | -1700 OSCLT_ERR_INVALID_LIST_HANDLE |
| 62:2826 | -1705 OSCLT_ERR_INVALID_LIST_INCREASING_ORDER |
| 62:2827 | -1906 OSCLT_ERR_INVALID_META |
| 62:2828 | -1907 OSCLT_ERR_INVALID_META_BUFFER |
| 62:2829 | -2200 OSCLT_ERR_INVALID_OBJECT_COPYJOB_EXTENT |
| 62:2830 | -2202 OSCLT_ERR_INVALID_OBJECT_COPYJOB_ID |
| 62:2831 | -2201 OSCLT_ERR_INVALID_OBJECT_COPYJOB_OFFSET |
| 62:2832 | -2101 OSCLT_ERR_INVALID_OBJECT_DATAJOB_TEAMING |
| 62:2833 | -1900 OSCLT_ERR_INVALID_OBJECT_KEY |
| 62:2834 | -1902 OSCLT_ERR_INVALID_OBJECT_KEY_FILTER |
| 62:2835 | -1911 OSCLT_ERR_INVALID_OBJECT_TEAMING |
| 62:2836 | -1800 OSCLT_ERR_INVALID_OBJECTSTORE_KEY |
| 62:2837 | -1802 OSCLT_ERR_INVALID_OBJECTSTORE_KEY_FILTER |
| 62:2838 | -1813 OSCLT_ERR_INVALID_OBJECTSTORE_TEAMING |
| 62:2839 | -1502 OSCLT_ERR_INVALID_ORIGIN_COPY_SESSIONS_LIMIT |
| 62:2840 | -1805 OSCLT_ERR_INVALID_QUOTA_POLICY |
| 62:2841 | -1815 OSCLT_ERR_INVALID_SECURE_ERASE_OVERWRITE_COUNT |
| 62:2842 | -1811 OSCLT_ERR_INVALID_STORAGE_ENCRYPTION_POLICY |
| 62:2843 | -1903 OSCLT_ERR_INVALID_STORAGEMODE |
| 62:2844 | -1904 OSCLT_ERR_INVALID_TAGLIST |
| 62:2845 | -1905 OSCLT_ERR_INVALID_TAGLIST_FILTER |
| 62:2846 | -1812 OSCLT_ERR_INVALID_TEAMING_POLICY |
| 62:2847 | -1501 OSCLT_ERR_INVALID_THROTTLE_POLICY |
| 62:2848 | -1804 OSCLT_ERR_INVALID_WRITE_POLICY |
| 62:2849 | -2003 OSCLT_ERR_JOB_CANCELLED |
| 62:2850 | -2210 OSCLT_ERR_JOB_CANCELLED_BY_USER |
| 62:2851 | -2002 OSCLT_ERR_JOB_PAUSED |
| 62:2852 | -2209 OSCLT_ERR_JOB_SEQUENCING_ERROR |
| 62:2853 | -1704 OSCLT_ERR_LIST_ARRAY_BUFFER_TOO_SMALL |
| 62:2854 | -1602 OSCLT_ERR_MAXIMUM_CLIENT_PERMISSIONS_CONFIGURED |
| 62:2855 | -1451 OSCLT_ERR_MAXIMUM_DEVICE_LOCKS |
| 62:2856 | -1421 OSCLT_ERR_MAXIMUM_LOCKS |
| 62:2857 | -1808 OSCLT_ERR_MAXIMUM_OBJECTSTORES |
| 62:2858 | -3221 OSCLT_ERR_MAXIMUM_OPEN_PARENTS |
| 62:2859 | -1407 OSCLT_ERR_MAXIMUM_SESSIONS |
| 62:2860 | -1450 OSCLT_ERR_NO_DEVICE_FILE_PRIVILEGE |
| 62:2861 | -3212 OSCLT_ERR_NOT_IN_CLONE_MODE |
| 62:2862 | -3206 OSCLT_ERR_NOT_IN_READ_MODE |
| 62:2863 | -3224 OSCLT_ERR_NOT_IN_READ_PARENT_MODE |
| 62:2864 | -3211 OSCLT_ERR_NOT_IN_READ_SECTIONS_MODE |
| 62:2865 | -3205 OSCLT_ERR_NOT_IN_WRITE_MODE |
| 62:2866 | -3210 OSCLT_ERR_NOT_IN_WRITE_SECTIONS_MODE |
| 62:2867 | -1409 OSCLT_ERR_NOT_LICENSED |
| 62:2868 | -2208 OSCLT_ERR_OBJECT_CHANGED_WHILST_PAUSED_OR_QUEUED |
| 62:2869 | -2204 OSCLT_ERR_OBJECT_COPYJOB_ALREADY_TERMINATED |
| 62:2870 | -2203 OSCLT_ERR_OBJECT_COPYJOB_ID_NOT_FOUND |
| 62:2871 | -1910 OSCLT_ERR_OBJECT_KEY_NOT_FOUND |
| 62:2872 | -1909 OSCLT_ERR_OBJECT_LOCK_FAILED |
| 62:2873 | -3600 OSCLT_ERR_OBJECT_LOCK_RELEASE_REQUEST |
| 62:2874 | -1908 OSCLT_ERR_OBJECT_NOT_OPERATIONAL |
| 62:2875 | -3225 OSCLT_ERR_OBJECT_READ_ONLY |
| 62:2876 | -2207 OSCLT_ERR_OBJECT_STORAGE_MODE_MISMATCH |
| 62:2877 | -3200 OSCLT_ERR_OBJECT_WRITE_LOCK_FAILED |
| 62:2878 | -1814 OSCLT_ERR_OBJECTS_WITH_ZERO_UUID_ENCOUNTERED |
| 62:2879 | -1810 OSCLT_ERR_OBJECTSTORE_KEY_NOT_FOUND |
| 62:2880 | -1809 OSCLT_ERR_OBJECTSTORE_NOT_OPERATIONAL |
| 62:2881 | -1423 OSCLT_ERR_OBJECTSTORE_NOT_TEAMED |
| 62:2882 | -2205 OSCLT_ERR_OBJECTSTORE_ORIGIN_SAME_AS_DESTINATION |
| 62:2883 | -1422 OSCLT_ERR_OBJECTSTORE_TEAMED |
| 62:2884 | -1402 OSCLT_ERR_OPERATION_NOT_SUPPORTED |
| 62:2885 | -1426 OSCLT_ERR_OPERATION_NOT_SUPPORTED_IN_TEAMING_MODE |
| 62:2886 | -1425 OSCLT_ERR_OPERATION_SUPPORTED_ONLY_IN_TEAMING_MODE |
| 62:2887 | -3215 OSCLT_ERR_PARENT_ALREADY_OPEN |
| 62:2888 | -3216 OSCLT_ERR_PARENT_NOT_OPEN |
| 62:2889 | -3219 OSCLT_ERR_PARENT_OBJECT_KEY_INVALID |
| 62:2890 | -3220 OSCLT_ERR_PARENT_OBJECT_KEY_NOT_FOUND |
| 62:2891 | -3218 OSCLT_ERR_PARENT_OBJECT_LOCK_FAILED |
| 62:2892 | -3217 OSCLT_ERR_PARENT_OBJECT_NOT_OPERATIONAL |
| 62:2893 | -3214 OSCLT_ERR_PARENT_SAME_AS_CHILD |
| 62:2894 | -3207 OSCLT_ERR_PARTIAL_DATA |
| 62:2895 | -3208 OSCLT_ERR_PAST_EXTENT |
| 62:2896 | -1410 OSCLT_ERR_PERMISSION_DENIED |
| 62:2897 | -1601 OSCLT_ERR_PERMISSIONS_CHECKING_DISABLED |
| 62:2898 | -1600 OSCLT_ERR_PERMISSIONS_CHECKING_ENABLED |
| 62:2899 | -3505 OSCLT_ERR_PIPELINE_CHUNK_DATA_PAYLOAD_INCONSISTENCY |
| 62:2900 | -3501 OSCLT_ERR_PIPELINE_EXTENT_MISMATCH |
| 62:2901 | -3504 OSCLT_ERR_PIPELINE_MANIFEST_PAYLOAD_INCONSISTENCY |
| 62:2902 | -3502 OSCLT_ERR_PIPELINE_OFFSET_MISMATCH |
| 62:2903 | -3503 OSCLT_ERR_PIPELINE_TRANSACTION_INCONSISTENCY |
| 62:2904 | -1405 OSCLT_ERR_PROTOCOL_NOT_SUPPORTED_ON_PORT |
| 62:2905 | -1406 OSCLT_ERR_PROTOCOL_VERSION_NEGOTIATION_FAILURE |
| 62:2906 | -3702 OSCLT_ERR_SCRATCHPAD_ERROR |
| 62:2907 | -3700 OSCLT_ERR_SCRATCHPAD_INVALID_NUMBER_OF_PARTITIONS |
| 62:2908 | -3701 OSCLT_ERR_SCRATCHPAD_INVALID_PARTITION_ID |
| 62:2909 | -3703 OSCLT_ERR_SCRATCHPAD_RECORD_SIZES_MISMATCH |
| 62:2910 | -1404 OSCLT_ERR_SERVER_OFFLINE |
| 62:2911 | -2206 OSCLT_ERR_SERVER_SERIAL_NUMBER_CHANGED |
| 62:2912 | -3202 OSCLT_ERR_SPARSE_WRITE_NOT_SUPPORTED |
| 62:2913 | -1424 OSCLT_ERR_TEAMING_MODE_NOT_SUPPORTED |
| 62:2914 | -1400 OSCLT_ERR_UNKNOWN_SERVER_ERROR |
| 62:2915 | -3201 OSCLT_ERR_WRITE_IN_PLACE_NOT_SUPPORTED |
| 62:2916 | -1101 OSCLT_CLTERR_MALLOC_FAILURE |
| 62:2917 | -1100 OSCLT_CLTERR_NULL_PARAMETER |
| 62:2918 | -1102 OSCLT_CLTERR_NULL_PARAMETER_EXPECTED |
| 62:2919 | -1000 OSCLT_ERR_INTERNAL_ERROR |
| 62:2920 | Failed to check whether replica group is present in the CommServe database. |
| 62:2921 | Replica group is not present in the request. Failing the snap operation. |
| 62:2922 | Failed to extend the reservation for mounted snap(s). |
| 62:2923 | Failure during snap operation. |
| 62:2924 | Multi-Storage feature is disabled or not supported. |
| 62:2925 | No data returned for request - Ignoring, as this is Offline Replication. |
| 62:2926 | Volume is unmounted. |
| 62:2927 | The snap engine selected does not support dedicated clone creation for mount operation. |
| 62:2928 | Replica entity has invalid array number. |
| 62:2929 | Replica group is reserved by another storage policy. Please run the NetApp Open Replication report to get the reservation details. |
| 62:2930 | One or more volumes(s) are not in mounted state. |
| 62:2931 | Failed to update replica group details in the CommServe database. |
| 62:2932 | Failed to update Snap index MediaAgent in database. |
| 62:2933 | A DDB move job is running on one or more substores of this DDB subclient. |
| 62:2934 | Could not find OS type for the given application, check if the application has same appType for more than one operating system. If yes, then this feature is not supported for this application. |
| 62:2935 | There are no media agents found with same OS type of the given client. |
| 62:2936 | Multi-node mounts exist in database. |
| 62:2937 | Add Nodes Failed[Reason:<String>] |
| 62:2938 | Create Storage Pool Failed[Reason:<String>] |
| 62:2939 | Replace is not allowed because another replace operation is in progress on the disk |
| 62:2940 | Unable to run Data Verification job because Deduplication Database validation/resync in progress. |
| 62:2941 | Mount path is marked offline by user. |
| 62:2942 | IntelliSnap package is not installed on this host. |
| 62:2943 | Killed by User. |
| 62:2944 | Suspended by User. |
| 62:2945 | The lvmetad service is running, it must be disabled and stopped. |
| 62:2946 | Unable to find device mounted for DDB Path. |
| 62:2947 | Power Management is enabled on this Virtual Machine(s)[<String>]. Waiting on the Virtual Machine(s) to power on. |
| 62:2948 | The usage for [Office 365 Sharepoint] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2949 | Office 365 Sharepoint license has been expired. |
| 62:2950 | Office 365 Sharepoint license is required to run jobs. |
| 62:2951 | The Move Partition job cannot proceed because another move partition job is running to same target location. |
| 62:2952 | The Move Partition job cannot proceed because the selected target location already hosts a partition. |
| 62:2953 | Sharing a storage device with a target MediaAgent of a running Move Mount Path job is not allowed. |
| 62:2954 | DDB move partition is not allowed from this higher feature release MediaAgent to this lower feature release MediaAgent |
| 62:2955 | Disk library not available for hybrid cloud library backup. |
| 62:2956 | Unable to associate subclient to DDB |
| 62:2957 | A device controller for the same MediaAgent and device combination already exists |
| 62:2958 | Failed to suspend the jobs using the store. Please suspend the jobs manually and resume Move Partition job. |
| 62:2959 | Services going down on the node or the process received a stop request. |
| 62:2960 | Disk library not available for hybrid cloud library backup due to MediaAgent is not ready. |
| 62:2961 | Disk library not available for hybrid cloud library backup due to device is not accessible to the selected MediaAgent. |
| 62:2962 | Disk library not available for hybrid cloud library backup due to the selected MediaAgent does not have write access enabled for the mount path to this device. |
| 62:2963 | Disk library not available for hybrid cloud library backup due to Library Drive Pool is offline. |
| 62:2964 | Disk library not available for hybrid cloud library backup due to Library is not ready. |
| 62:2965 | Disk library not available for hybrid cloud library backup due to Library Master Pool is offline. |
| 62:2966 | Disk library not available for hybrid cloud library backup due to amount of data on mount path has reached the maximum threshold set. |
| 62:2967 | Disk library not available for hybrid cloud library backup due to mount path does not have enough space. |
| 62:2968 | Disk library not available for hybrid cloud library backup due to mount path is offline. |
| 62:2969 | Disk library not available for hybrid cloud library backup due to writes on mount path are disabled. |
| 62:2970 | Disk library not available for hybrid cloud library backup due to mount path device is offline and not available to use. |
| 62:2971 | Disk library not available for hybrid cloud library backup due to there are no devices configured to be used as mount paths. |
| 62:2972 | Disk library not available for hybrid cloud library backup due to the number of writers of the mount path exceeds the maximum allowed limit. |
| 62:2973 | Marked full due to Hybrid Cloud library volume's cache mount path offline. |
| 62:2974 | Marked full due to Hybrid Cloud library volume's cache mount path is currently out of space. |
| 62:2975 | The usage for [Operating Instances] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2976 | Operating Instances license has expired. |
| 62:2977 | Operating Instances license is required to run jobs. |
| 62:2978 | The usage for [Virtual Operating Instances] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:2979 | Virtual Operating Instances license has expired. |
| 62:2980 | Virtual Operating Instances license is required to run jobs. |
| 62:2981 | Deduplication database reconstruction job [<Number>] has found DDB Store [<String>] out of sync with Commserv database. |
| 62:2982 | The number of running Synthetic Full jobs has exceeded the limit. |
| 62:2983 | Disk library not available for hybrid cloud library backup due to device is broken. |
| 62:2984 | Disk library not available for hybrid cloud library backup due to device is disabled. |
| 62:2985 | Aged data on this cloud mountpath cannot be pruned because associated cache disk mountpath is offline. |
| 62:2986 | Unable to connect to deduplication engine [<String>] for validation/resync. The operation will be attempted again. Please check MediaManager.log for more information. |
| 62:2987 | Validation/resync is still pending for [<Number>] deduplication engines. The operation will be attempted again. Please check MediaManager.log for more information. |
| 62:2988 | Failed to bind port [<Number>] on [<String>], another NFS service may be running. Please stop that service and retry. |
| 62:2989 | SUN RPC Service not running on [<String>]. Please start [rpcbind] service. |
| 62:2990 | Drive pool deletion prevented to avoid dangling drive configuration(drive without drive controller) |
| 62:2991 | Associated MediaAgent deleted by user |
| 62:2992 | The Media Agent selected is not a library controller of the given library. |
| 62:2993 | No MediaAgent is configured to read data from media. |
| 62:2994 | The mount path does not have a device controller, please share the mount path with a media agent. |
| 62:2995 | -2217 OSCLT_ERR_INVALID_COPYJOB_SECURITY_MODE_PAIRING |
| 62:2996 | -1816 OSCLT_ERR_INVALID_OBJECTSTORE_SECURITY_MODE |
| 62:2997 | -1452 OSCLT_ERR_NO_DEVICES_DISCOVERED |
| 62:2998 | User [<String>] doesn't have permission to delete Library. |
| 62:2999 | User [<String>] doesn't have permission to delete MountPath. |
| 62:3000 | The usage for [Activate E-Discovery For Email/Cloud Apps] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3001 | The license [Activate E-Discovery For Email/Cloud Apps] has been expired. |
| 62:3002 | The license [Activate E-Discovery For Email/Cloud Apps] is required to run jobs. |
| 62:3003 | The usage for [Activate E-Discovery For Files] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3004 | The license [Activate E-Discovery For Files] has been expired. |
| 62:3005 | The license [Activate E-Discovery For Files] is required to run jobs. |
| 62:3006 | The usage for [Activate Sensitive Data For Email/Cloud Apps] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3007 | The license [Activate Sensitive Data For Email/Cloud Apps] has been expired. |
| 62:3008 | The license [Activate Sensitive Data For Email/Cloud Apps] is required to run jobs. |
| 62:3009 | The usage for [Activate Sensitive Data For Files] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3010 | The license [Activate Sensitive Data For Files] has been expired. |
| 62:3011 | The license [Activate Sensitive Data For Files] is required to run jobs. |
| 62:3012 | The usage for [Activate Suite] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3013 | The license [Activate Suite] has been expired. |
| 62:3014 | The license [Activate Suite] is required to run jobs. |
| 62:3015 | The usage for [File Storage Optimization] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3016 | The license [File Storage Optimization] has been expired. |
| 62:3017 | The license [File Storage Optimization] is required to run jobs. |
| 62:3018 | Replace operation failed in mounting the new disk |
| 62:3019 | Replace operation failed as there are no eligible disks attached to the media agent |
| 62:3020 | Replace operation failed in executing the disk reset command |
| 62:3021 | Physical deletion of data is not possible, Force delete operation will do DB cleanup only. |
| 62:3022 | Physical cleanup failed for the path [<String>]. |
| 62:3023 | Physical cleanup succeed for the path [<String>]. |
| 62:3024 | Storage has valid data, deleting it will cause data loss. |
| 62:3025 | The blackout window on backupset prevents the job from running right now |
| 62:3026 | The blackout window on MediaAgent prevents the job from running right now |
| 62:3027 | The blackout window on Server group prevents the job from running right now |
| 62:3028 | The blackout window on CommServe prevents the job from running right now |
| 62:3029 | The blackout window on iDataAgent prevents the job from running right now |
| 62:3030 | The blackout window on instance prevents the job from running right now |
| 62:3031 | The blackout window on schedule policy prevents the job from running right now |
| 62:3032 | The blackout window on schedule prevents the job from running right now |
| 62:3033 | The blackout window on subclient prevents the job from running right now |
| 62:3034 | The target media agent already hosts maximum allowed number of partitions, pick a different media agent and retry. |
| 62:3035 | The operation contains snapshots created using multiple IntelliSnap snapshot engines. Please make sure that the selected snapshots belong to one particular IntelliSnap snapshot engine. |
| 62:3036 | Failed to check free space on the target path. Check if selected path have enough free space available. |
| 62:3037 | The Deduplication Database is marked for pending bad chunk review. Bad chunk processing is suspended. |
| 62:3038 | The usage for [Auto Recovery] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3039 | Auto Recovery license has expired. |
| 62:3040 | Auto Recovery license is required to run jobs. |
| 62:3041 | Space Reclamation operation cannot be completed as cloud pruner media agent not found. |
| 62:3042 | Deduplication database reconstruction job [<Number>] has found DDB Store [<String>] out of sync with Commserv database on following jobs [<String>]. Marking these jobs as Data Verification failed and recommended delete these jobs from respective copies. |
| 62:3043 | Instant clone creation is not possible as the snap is created without required mode |
| 62:3044 | Deletion is not possible. Reason - <String> |
| 62:3045 | Storage has WORM data. |
| 62:3046 | The usage for [Metallic Recovery Reserve] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve] licenses. |
| 62:3047 | The license [Metallic Recovery Reserve] has expired. |
| 62:3048 | The license [Metallic Recovery Reserve] is required to use Metallic recovery reserve. Contact customer support to purchase license. |
| 62:3049 | There is no valid storage policy associated with current subclient. |
| 62:3050 | Failed to mount snapshot using pRDM |
| 62:3051 | The license [Metallic Recovery Reserve] user agreement was not accepted during applying license. Apply license again and accept the user agreement. |
| 62:3052 | The usage for [Metallic Recovery Reserve T10] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T10] licenses. |
| 62:3053 | The license [Metallic Recovery Reserve T10] has expired. |
| 62:3054 | The license [Metallic Recovery Reserve T10] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3055 | The usage for [Metallic Recovery Reserve T2] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T2] licenses. |
| 62:3056 | The license [Metallic Recovery Reserve T2] has expired. |
| 62:3057 | The license [Metallic Recovery Reserve T2] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3058 | The usage for [Metallic Recovery Reserve T3] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T3] licenses. |
| 62:3059 | The license [Metallic Recovery Reserve T3] has expired. |
| 62:3060 | The license [Metallic Recovery Reserve T3] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3061 | The usage for [Metallic Recovery Reserve T4] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T4] licenses. |
| 62:3062 | The license [Metallic Recovery Reserve T4] has expired. |
| 62:3063 | The license [Metallic Recovery Reserve T4] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3064 | The usage for [Metallic Recovery Reserve T5] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T5] licenses. |
| 62:3065 | The license [Metallic Recovery Reserve T5] has expired. |
| 62:3066 | The license [Metallic Recovery Reserve T5] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3067 | The usage for [Metallic Recovery Reserve T6] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T6] licenses. |
| 62:3068 | The license [Metallic Recovery Reserve T6] has expired. |
| 62:3069 | The license [Metallic Recovery Reserve T6] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3070 | The usage for [Metallic Recovery Reserve T7] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T7] licenses. |
| 62:3071 | The license [Metallic Recovery Reserve T7] has expired. |
| 62:3072 | The license [Metallic Recovery Reserve T7] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3073 | The usage for [Metallic Recovery Reserve T8] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T8] licenses. |
| 62:3074 | The license [Metallic Recovery Reserve T8] has expired. |
| 62:3075 | The license [Metallic Recovery Reserve T8] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3076 | The usage for [Metallic Recovery Reserve T9] has exceeded the licensed usage. Purchase additional [Metallic Recovery Reserve T9] licenses. |
| 62:3077 | The license [Metallic Recovery Reserve T9] has expired. |
| 62:3078 | The license [Metallic Recovery Reserve T9] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3079 | Cannot connect to Data Server, failed to resolve Client / Data Server host IP address. Please make sure Client / Data Server host name resolvable to IP address |
| 62:3080 | Active clone running on these snap jobs. |
| 62:3081 | Jobs are held due to manually extended retention. |
| 62:3082 | Jobs are retained under cycles criteria. |
| 62:3083 | Snap jobs retained by count based retention. |
| 62:3084 | Database log backups are retained if there are older database backups retained that need this. |
| 62:3085 | Snaps retained are pending backup copy. |
| 62:3086 | Jobs retained due to pending reference copy. |
| 62:3087 | Jobs are retained due to SQL chaining. |
| 62:3088 | SQL log backups are retained if there are older database backups retained that need this. |
| 62:3089 | Snaps are retained as they are being processed by current running catalog jobs. |
| 62:3090 | DDB backups retained. |
| 62:3091 | Migrated jobs from a different Commcell remain. |
| 62:3092 | Indexing subclient backups. |
| 62:3093 | There are older jobs pending auxcopy. |
| 62:3094 | Database log backups linked with data jobs are retained. |
| 62:3095 | Jobs retained due to cycle dependency. |
| 62:3096 | Older SILO jobs are still retained. |
| 62:3097 | Jobs of snap mirror copy. |
| 62:3098 | Jobs retained in old storage policy due to storage policy change. |
| 62:3099 | Jobs are retained due to SQL chaining. |
| 62:3100 | Jobs retained as True up job is pending after latest synthetic full. |
| 62:3101 | VSA V2 parent jobs are retained. |
| 62:3102 | Some of the data backed up in this library is not being processed by Data Aging job. |
| 62:3103 | There are clients that are not running jobs actively. Older cycles might be retained beyond their expected retention if the clients are not running regular backup jobs. |
| 62:3104 | There are tapes held beyond their expected retention period. |
| 62:3105 | Cloud Mount Path has a dedicated pruner MediaAgent set but the Mount Path data is not accessible from the Media Agent. |
| 62:3106 | Cloud Mount Path does not have dedicated pruner Media Agent set in device controller for dedup data pruning. |
| 62:3107 | Cloud Mount Path is configured to use datapath Media Agents for pruning but does not have dedicated pruner Media Agent set in datapath for dedup data pruning. |
| 62:3108 | Physical pruning on mount path is disabled. |
| 62:3109 | Mount Path is configured to use datapath Media Agents for pruning, but there are no available datapath Media Agents that can prune this mount path. |
| 62:3110 | Volume reconciliation job completed with errors, please check media agent logs for details. |
| 62:3111 | Unable to start volume reconciliation as there is another reconciliation job running on the same mount path |
| 62:3112 | Cannot run move mount path job when space reclamation job is running on the mount path. |
| 62:3113 | Target location is same as mediaagent installation directory. |
| 62:3114 | Failed to determine the version of the MediaAgent. |
| 62:3115 | The data access node is not associated to any region. Please associate the data access node to a region and then proceed. |
| 62:3116 | The array and data access node belong to different regions. Please ensure that both the array and access node belong to the same region and then proceed. |
| 62:3117 | Unable to find an array that belongs to the same region as that of the data access node. |
| 62:3118 | Multiple arrays with conflicting IPs belong to the same region as that of the data access node. |
| 62:3119 | The Multisite configuration is enabled and the data access node does not meet the requirements to run Multisite related operations. |
| 62:3120 | Data Aging operation is disabled on some of the entities causing jobs to not be processed for retention computation. |
| 62:3121 | Data Aging job encountered error while processing some of the entities. |
| 62:3122 | Data Aging job is being run at granular level causing jobs to not be processed for retention computation. |
| 62:3123 | There are jobs that are retained beyond their expected basic retention days which might need attention. |
| 62:3124 | Physical pruning is backlogged in this mount path. |
| 62:3125 | Mount path file system does not have sparse file support required for micro pruning of deduplicated data. No recent space reclamation job run on the deduplication store. |
| 62:3126 | Unable to mount the snaps on given host using LVM as the host is source client for one or more snaps present in current operation. |
| 62:3127 | Volume information is unknown for current chunk. |
| 62:3128 | Media Agent is not specified for current snap copy data. |
| 62:3129 | No (subclient) data paths were found for the Storage Policy: [<String>] / Copy: [<String>]. Probably a library has been deconfigured. |
| 62:3130 | WARNING: The range header in cloud download requests might have been deliberately removed by security components in your network and it might result in additional costs from your cloud service provider due to larger amount of data download. Please check your proxy server configuration. |
| 62:3131 | WARNING: Cannot delete the versioned object in S3 bucket [<String>] which is versioning enabled. The object may be still locked with retention or the current credential may not have s3:DeleteObjectVersion permission. |
| 62:3132 | WARNING: The S3 bucket [<String>] is versioning enabled, but the current credential may not have s3:ListBucketVersions permission to list versioned objects for deletion. |
| 62:3133 | WARNING: The Azure storage account [<String>] is versioning enabled, but the current credential may not have [Microsoft.Storage/storageAccounts/blobServices/containers/blobs/deleteBlobVersion/action] permission or [Storage Blob Data Owner] role to delete versioned objects. |
| 62:3134 | Available space in pool [<String>] is less than <String>%. Configured size: <String>, free: <String>. |
| 62:3135 | Drive [<String>] in VTL [<String>] unmounted. Mount statistics: Bytes written [<String>], compressed [<String>], deduplicated [<String>], Bytes read [<String>], uncompressed [<String>] |
| 62:3136 | Write to [<String>] failed due to an out of space condition. Pool configured size: <String>, free: <String> |
| 62:3137 | Target MediaAgent [<String>] and path [<String>] cannot be same as the source MediaAgent [<String>] and path [<String>] |
| 62:3138 | The comaptible parameters for provisioned ASM DiskGroup are not valid. RDBMS Compatibility [<String>] ASM Compatibility [<String>] |
| 62:3139 | The disk [<String>] provisioned for backup has different ASM diskgroup signature [<String>] than expected [<String>]. Please retry the job or contact your vendors customer support. |
| 62:3140 | The ASM diskgroup provisioning for backup not found all disks. Expected [<Number>] Found [<Number>]. please retry the operation and contact your vendors customer support. |
| 62:3141 | The storage provisioning for backup as ASM diskgroup failed during ASM connection initialize. Please check if ASM instance is configured in Commvault for this client |
| 62:3142 | This Operating System is not supported for OptimizeForInstantClone Plan |
| 62:3143 | The client does not have iscsiadm command. Please install iscsi-initiator-utils. |
| 62:3144 | The usage for [Commvault Backup & Recovery for Unstructured data] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3145 | The license [Commvault Backup & Recovery for Unstructured data] has expired. |
| 62:3146 | The license [Commvault Backup & Recovery for Unstructured data] is required to run jobs. |
| 62:3147 | Failed to delete unmounted clones from database. |
| 62:3148 | MediaAgent for current DDB is invalid. |
| 62:3149 | Invalid AWS credential file. |
| 62:3150 | AWS credential file environment variable AWS_SHARED_CREDENTIALS_FILE not found. |
| 62:3151 | Azure certificate file not found. |
| 62:3152 | Bring your own key option is selected for KMS but no valid and unused key found. |
| 62:3153 | Total number of active DDB on current MediaAgent exceeds the maximum allowed value. |
| 62:3154 | Max data to write should be greater than or equal to used space. |
| 62:3155 | Max data to write should be less than or equal to capacity. |
| 62:3156 | Limiting capacity on offline and uninitialized mount path is not allowed. Wait for mount path to initialize. |
| 62:3157 | Metallic cloud storage copy is not allowed as source copy. |
| 62:3158 | Only Metallic cloud storage hot tier is allowed for primary copy. |
| 62:3159 | Metallic cloud storage is not allowed for secondary copy when both source and destination storage are in different regions. |
| 62:3160 | Trial Limit for the total data protection has reached. |
| 62:3161 | The usage for [HyperScale Storage] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3162 | The license [HyperScale Storage] has been expired. |
| 62:3163 | The license [HyperScale Storage] is required to run jobs. |
| 62:3164 | Remote snap MA execution failed |
| 62:3165 | Only Metallic cloud storage hot tier is allowed as source copy |
| 62:3166 | The number of running Data Verification jobs has exceeded the limit. |
| 62:3167 | The usage for [Metallic Cloud Storage Service T11] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T11] licenses. |
| 62:3168 | The license [Metallic Cloud Storage Service T11] has expired. |
| 62:3169 | The license [Metallic Cloud Storage Service T11] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3170 | The usage for [Metallic Cloud Storage Service T12] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T12] licenses. |
| 62:3171 | The license [Metallic Cloud Storage Service T12] has expired. |
| 62:3172 | The license [Metallic Cloud Storage Service T12] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3173 | The usage for [Metallic Cloud Storage Service T13] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T13] licenses. |
| 62:3174 | The license [Metallic Cloud Storage Service T13] has expired. |
| 62:3175 | The license [Metallic Cloud Storage Service T13] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3176 | The usage for [Metallic Cloud Storage Service T14] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T14] licenses. |
| 62:3177 | The license [Metallic Cloud Storage Service T14] has expired. |
| 62:3178 | The license [Metallic Cloud Storage Service T14] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3179 | The usage for [Metallic Cloud Storage Service T15] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T15] licenses. |
| 62:3180 | The license [Metallic Cloud Storage Service T15] has expired. |
| 62:3181 | The license [Metallic Cloud Storage Service T15] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3182 | The usage for [Metallic Cloud Storage Service T16] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T16] licenses. |
| 62:3183 | The license [Metallic Cloud Storage Service T16] has expired. |
| 62:3184 | The license [Metallic Cloud Storage Service T16] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3185 | The usage for [Metallic Cloud Storage Service T17] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T17] licenses. |
| 62:3186 | The license [Metallic Cloud Storage Service T17] has expired. |
| 62:3187 | The license [Metallic Cloud Storage Service T17] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3188 | The usage for [Metallic Cloud Storage Service T18] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T18] licenses. |
| 62:3189 | The license [Metallic Cloud Storage Service T18] has expired. |
| 62:3190 | The license [Metallic Cloud Storage Service T18] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3191 | The usage for [Metallic Cloud Storage Service T19] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T19] licenses. |
| 62:3192 | The license [Metallic Cloud Storage Service T19] has expired. |
| 62:3193 | The license [Metallic Cloud Storage Service T19] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3194 | The usage for [Metallic Cloud Storage Service T20] has exceeded the licensed usage. Purchase additional [Metallic Cloud Storage Service T20] licenses. |
| 62:3195 | The license [Metallic Cloud Storage Service T20] has expired. |
| 62:3196 | The license [Metallic Cloud Storage Service T20] is required to use Metallic cloud storage. Contact customer support to purchase license. |
| 62:3197 | One or more volumes are not valid or aged |
| 62:3198 | An error occurred when trying to unpack metadata. |
| 62:3199 | Configuring mountpath using administrative shares is not allowed. |
| 62:3200 | Maximum ISV controlled data immutability retention configured on Storeonce is lower than the copy retention. Failed to set retention lock on the object. Please review and configure data immutability retention on Storeonce and copy retention correctly. |
| 62:3201 | Parsing error in admin share access check |
| 62:3202 | Move mount path operation is not supported for Hyperscale storage. |
| 62:3203 | Mountpath creation failed as the location is in use for another mountpath |
| 62:3204 | The usage for [Activate Sensitive Data For Endpoints] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3205 | The license [Activate Sensitive Data For Endpoints] has expired. |
| 62:3206 | The license [Activate Sensitive Data For Endpoints] is required to run jobs. |
| 62:3207 | The usage for [Activate Sensitive Data For Virtual Machines] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3208 | The license [Activate Sensitive Data For Virtual Machines] has expired. |
| 62:3209 | The license [Activate Sensitive Data For Virtual Machines] is required to run jobs. |
| 62:3210 | The usage for [Activate E-Discovery For Endpoints] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3211 | The license [Activate E-Discovery For Endpoints] has expired. |
| 62:3212 | The license [Activate E-Discovery For Endpoints] is required to run jobs. |
| 62:3213 | The usage for [Activate E-Discovery For Virtual Machines] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3214 | The license [Activate E-Discovery For Virtual Machines] has expired. |
| 62:3215 | The license [Activate E-Discovery For Virtual Machines] is required to run jobs. |
| 62:3216 | The usage for [File Storage Optimization For Endpoints] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3217 | The license [File Storage Optimization For Endpoints] has expired. |
| 62:3218 | The license [File Storage Optimization For Endpoints] is required to run jobs. |
| 62:3219 | The usage for [File Storage Optimization for Virtual Machines] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3220 | The license [File Storage Optimization for Virtual Machines] has expired. |
| 62:3221 | The license [File Storage Optimization for Virtual Machines] is required to run jobs. |
| 62:3222 | Only Metallic cloud storage with same cloud type allowed for secondary copy. |
| 62:3223 | There is no storage found for the region. |
| 62:3224 | Moving mountpath to administrative shares is not allowed |
| 62:3225 | Only regular access MediaAgents are allowed as source/Destination. |
| 62:3226 | Source and target device should be in the same library |
| 62:3227 | Failed to submit Move Job, Reason : Target location [<String>] is being moved by another Move Job [<Number>] |
| 62:3228 | Failed to submit Move Job, Reason : Source location [<String>] is being moved by another Move Job [<Number>] |
| 62:3229 | Failed to submit Move Job, Reason : Source location [<String>] is being used as a destination for another Move Job [<Number>] |
| 62:3230 | Move job failed because the source MediaAgent is unresponsive for more than 20 minutes. Please check the MediaAgent services. |
| 62:3231 | Storage Policy [<String>] Copy [<String>] is using storage pool compliance lock setting. Please disable compliance lock from storage pool copy. |
| 62:3232 | Invalid storage policy [<String>] passed to disable compliance lock. |
| 62:3233 | Invalid storage policy [<String>] copy [<String>] passed to disable compliance lock. |
| 62:3234 | Storage policy [<String>] and copy [<String>] is not compliance lock enabled copy. |
| 62:3235 | Unsupported DDB MediaAgent version. nADVICE: Upgrade MediaAgent [<String>] to 11.30 or higher. |
| 62:3236 | Unsupported DDB MediaAgent version. |
| 62:3237 | Failed to fetch credentials from credential vault. |
| 62:3238 | Invalid response received from credential vault. |
| 62:3239 | The Cloud upload/download throttling is set to [<String>/<String>] MiB/hour. |
| 62:3240 | Live recovery not possible as the snapshot is created without required mode |
| 62:3241 | Live recovery is not supported by the snapshot engine |
| 62:3242 | MediaAgents from job option have no storage access. |
| 62:3243 | Snapshot is not available for mount as it needs to be unmounted after being used by Live Recovery job. Retry the current operation once the unmount completes successfully. |
| 62:3244 | Storage library is used by DR backup, deletion will cause data loss |
| 62:3245 | Workload has been disabled. You may be over your subscription usage. |
| 62:3246 | WORM locking not supported when mount path is shared using DataServer-IP with the MediaAgent. |
| 62:3247 | The storage-unit is not retention-lock enabled |
| 62:3248 | The retention time is outside the configured retention period. |
| 62:3249 | The usage for [Risk Analysis For Email/Cloud Apps] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3250 | The license [Risk Analysis For Email/Cloud Apps] has expired. |
| 62:3251 | The license [Risk Analysis For Email/Cloud Apps] is required to run jobs. |
| 62:3252 | The usage for [Risk Analysis For Files] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3253 | The license [Risk Analysis For Files] has expired. |
| 62:3254 | The license [Risk Analysis For Files] is required to run jobs. |
| 62:3255 | The usage for [Risk Analysis For VMs] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3256 | The license [Risk Analysis For VMs] has expired. |
| 62:3257 | The license [Risk Analysis For VMs] is required to run jobs. |
| 62:3258 | The usage for [Threat Scan For Files] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3259 | The license [Threat Scan For Files] has expired. |
| 62:3260 | The license [Threat Scan For Files] is required to run jobs. |
| 62:3261 | The usage for [Threat Scan For VMs] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button under Manage->License to temporarily allow jobs. |
| 62:3262 | The license [Threat Scan For VMs] has expired. |
| 62:3263 | The license [Threat Scan For VMs] is required to run jobs. |
| 62:3264 | The number of running Aux Copy jobs has exceeded the limit. |
| 62:3265 | The number of running File Indexing jobs has exceeded the limit. |
| 62:3266 | Passphrase is not found in input. Please provide valid passphrase to disable compliance lock. |
| 62:3267 | Pure protection group snap is still being replicated to the target site, Timeout has been reached while monitoring the status of the snap at the replication target in current run of auxcopy job. Commvault will re-check the status on next run of auxcopy job. |
| 62:3268 | MediaAgent of current active deduplication database is under maintenance. |
| 62:3269 | MediaAgents not available in the selected region. |
| 62:3270 | Move Mount Path Operation cannot be performed on CCM libraries/mount paths. |
| 62:3271 | PIN is not found in request. Please provide valid PIN in request. |
| 62:3272 | Cannot create DDB disk [<String>] as MediaAgent [<String>] already hosts a DDB disk on path [<String>] |
| 62:3273 | MediaAgent(s) [<String>] are offline, both source and target MediaAgents must be online for move partition job |
| 62:3274 | Cannot delete DDB disk [<String>] as it is in use |
| 62:3275 | Missing input to enable minimum allowed retention days on the copy. |
| 62:3276 | Insufficient input parameters to configure minimum allowed retention days on the copy. Missing input parameter - 'enable'. |
| 62:3277 | Failed to associate copy with the storage pool while configuring minimum allowed retention days. Please check the logs for details. |
| 62:3278 | Failed to associate copy with the storage pool as the retention days is lower than the minimum retention days [<Number>] configured on the storage pool. |
| 62:3279 | Invalid storage policy [<String>] passed to configure minimum allowed retention days. |
| 62:3280 | Invalid storage policy [<String>] copy [<String>] passed to configure minimum allowed retention days. |
| 62:3281 | PIN not found in input. Please provide valid PIN to configure minimum allowed retention days. |
| 62:3282 | This medium contains valid data that has not met the minimum retention days configured on the copy. |
| 62:3283 | Metallic Infrastructure is not available in the selected region. |
| 62:3284 | Media [<String>] in library [<String>] is already reserved by job [<Number>] from MediaAgent [<String>]. |
| 62:3285 | Failing the snap operation as there are no online remote snap MA to process the request. There are one or more remote snap MA configured for the array but none of them are online. Check the list of remote snap MA configured in Array Management for array and make sure at least one of them is online. |
| 62:3286 | Managed disk space enabled on the copy. |
| 62:3287 | The copy is currently under maintenance as the copy promotion request is in progress. |
| 62:3288 | Failed remote execution on multiple snap MAs. |
| 62:3289 | Power managed infrastructure resources are being powered on |
| 62:3290 | GCP service account credentials not found. |
| 62:3291 | Lowering the reserve space of Data Domain library mount path below recommended values is prevented. |
| 62:3292 | The usage for [Cleanroom Recovery] has exceeded the licensed usage. Please purchase additional usage licenses. |
| 62:3293 | The license [Cleanroom Recovery] has expired. |
| 62:3294 | The license [Cleanroom Recovery] is required to run jobs. |
| 62:3295 | CS and DDB are out of sync for more than 5 days. Can't mark partition for recovery. |
| 62:3296 | Storage space utilization of HyperScale X storage pool has reached critical threshold and data protection operations to this storage pool are suspended. |
| 62:3297 | There are no valid jobs for the store. The store will automatically get sealed. |
| 62:3298 | This medium contains valid data associated with the client, client group, instance or the copy on which Data Aging activity is disabled. |
| 62:3299 | The usage for [Active Directory - Enterprise] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button in control panel license administration window to temporarily allow jobs. |
| 62:3300 | The license [Active Directory - Enterprise] has expired. |
| 62:3301 | The license [Active Directory - Enterprise] is required to run jobs. |
| 62:3302 | The usage for [Active Directory - Standard] has exceeded the licensed usage. Please purchase additional usage licenses. Until the new license is applied, click on the RESET button in control panel license administration window to temporarily allow jobs. |
| 62:3303 | The license [Active Directory - Standard] has expired. |
| 62:3304 | The license [Active Directory - Standard] is required to run jobs. |
| 62:3305 | Storage [<String>] is air-gapped, job will automatically resume once the storage is out of air-gap |
| 62:3306 | Storage is air-gapped, job will automatically resume once the storage is out of airgap |
| 62:3307 | Immutable snapshots are not supported in this version of the array. |
| 62:3308 | The creation of immutable snapshots is not supported by this version of the Media Agent. |
Media Manager
| Code | Description |
| 32:1 | Out of Memory. |
| 32:2 | Error in disconnecting connection from Media Manager service. Server=[<String>], SessionError=[<Number>], SessionErrorText=[<String>]. |
| 32:3 | Received invalid Media Manager message [<String>] ID = [0x<HexNumber>]. |
| 32:4 | No client name specified in the message to Media Manager service. |
| 32:5 | Invalid session object. Media Manager will not reply back. |
| 32:6 | Missing mount object in the Media Manager mount cache list. |
| 32:7 | Error in sending message [0x<HexNumber>] to Media Manager service. Server=[<String>], SessionError=[<Number>] [<String>]. |
| 32:8 | Error in receiving message [0x<HexNumber>] from Media Manager service. Server=[<String>], SessionError=[<Number>] [<String>]. |
| 32:9 | Error in sending message [0x<HexNumber>] from Media Manager service. SessionError=[<Number>] [<String>]. |
| 32:10 | No response from Media Manager service. Server=[<String>]. |
| 32:11 | Media Manager could not set up initial values. |
| 32:12 | Attempting to interrupt job [<Number>]. |
| 32:13 | Could not free the reservation for job [<Number>]. |
| 32:14 | Unexpected magic number. Client sent [<HexNumber>], server expected [<HexNumber>]. |
| 32:15 | Unsupported client version [<String>]. Server version [<String>]. |
| 32:16 | Replacing the active media for job [<Number>] from Media with Barcode [<String>] to [<String>]. |
| 32:17 | Out of spare media in scratch pool [<String>] in Library [<String>]. |
| 32:18 | All spare media for scratch pool [<String>] are outside the Library [<String>]. |
| 32:19 | Media with barcode [<String>], side [<String>], mounted on library [<String>] and drive [<String>] on MediaAgent [<String>]. Mountpoint [<String>] for job [<Number>]. Media block size is [<Number> KB]. Mount finished in [<Number>] seconds. |
| 32:20 | Media with barcode [<String>] mounted in library [<String>] and drive [<String>] on MediaAgent [<String>]. Mount finished in [<Number>] seconds. |
| 32:21 | Media with identifier [<String>] mounted in library [<String>] and drive [<String>] on MediaAgent [<String>] has been stamped. Mount finished in [<Number>] seconds. |
| 32:22 | Failed to stamp media. <String><String> |
| 32:23 | Failed to mount media with barcode [<String>], side [<String>], into drive [<String>], in library [<String>] on MediaAgent [<String>]. |
| 32:24 | Failed to mount media with Unique ID [<String>], side [<String>], into drive [<String>], in library [<String>] on MediaAgent [<String>]. |
| 32:25 | Failed to mount medium from Slot [<String>]. |
| 32:26 | Failed to mount medium. |
| 32:27 | Failed to mount media with barcode [<String>]. |
| 32:28 | Failed to mount media with Unique ID [<String>]. |
| 32:29 | Media with barcode [<String>] unmounted from library [<String>] and drive [<String>]. Unmount finished in [<Number>] seconds. |
| 32:30 | Media with barcode [<String>] unmounted from library [<String>] and drive [<String>]. Mount Point [<String>]. Unmount finished in [<Number>] seconds. |
| 32:31 | Failed to unmount medium in drive [<String>], library [<String>]. <String> <String> |
| 32:32 | Media with barcode [<String>], Unique ID [<String>] is outside Library [<String>]. Please import this media. |
| 32:33 | Initialize media to group [<Number>] failed with error '<String>', Moving media with barcode [<String>], Unique ID [<String>] to the retired group [<String>]. |
| 32:34 | Out of disk space or disk usage exceeded on disk library [<String>]. Make sure that there is at least one mount path which is online and which meets the space allocation criteria specified on the mount path properties. |
| 32:35 | Duplicate barcode [<String>] was detected in Library [<String>] in CommCell. Remove these media from the library manually and then reset the libraries. |
| 32:36 | Failed to delete directory [<String>]. Please delete this directory manually. |
| 32:37 | Media with barcode [<String>] could not be reserved for job [<Number>]. The media may be in use. System will retry until successful. |
| 32:38 | Could not reserve a drive for job [<Number>]. All the drives may be in use. System will retry until successful. |
| 32:39 | Could not reserve a drive for job [<Number>]. All the drives may be in use. |
| 32:40 | Media with barcode [<String>] is being exported from Library [<String>]. |
| 32:41 | Media with barcode [<String>], Unique ID [<String>] has been moved to the retired group [<String>], check media property for reason. |
| 32:42 | Number of media in the scratch pool [<String>] inside the library [<String>] is less than the minimum required number, [<Number>]. |
| 32:43 | MediaAgent [<String>] is ready. |
| 32:44 | MediaAgent [<String>] is offline. |
| 32:45 | Library [<String>] on MediaAgent [<String>] is ready. |
| 32:46 | Library [<String>] on MediaAgent [<String>] is offline. |
| 32:47 | Drive [<String>] in library [<String>] is ready. |
| 32:48 | Drive [<String>] in library [<String>] is offline. |
| 32:49 | Device [<String>] is now ready. |
| 32:50 | Device [<String>] is now offline. |
| 32:51 | Drive [<String>] in library [<String>] may need cleaning. |
| 32:52 | Process to clean Drive [<String>] in library [<String>] has finished successfully. Please check the drive visually to see if its state becomes normal. |
| 32:53 | Media with Unique ID [<String>], side [<String>], mounted on library [<String>] and drive [<String>] on MediaAgent [<String>]. Mountpoint [<String>] for job [<Number>]. Mount finished in [<Number>] seconds. |
| 32:54 | Media with Unique ID [<String>] unmounted from library [<String>] and drive [<String>]. Mountpoint [<String>]. Mount finished in [<Number>] seconds. |
| 32:55 | Medium with barcode [<String>] is in the wrong library. Please move media from slot [<String>] in library [<String>] to library [<String>]. |
| 32:56 | The total remaining free space [<Number>] MB for all the mount paths that are online for the disk Library [<String>] on MediaAgent [<String>] is less than the low watermark [<Number>] MB. |
| 32:57 | Media in library [<String>], drive [<String>] recovered. |
| 32:58 | Media with barcode [<String>], Unique ID [<String>] is now marked full. <String> |
| 32:59 | Volume [<String>] on mount path [<String>] in the library [<String>] is now marked full. |
| 32:60 | Volume on Centera mount path [<String>] in the library [<String>] is now marked full. |
| 32:61 | Media with barcode [<String>], Unique ID [<String>] is now marked bad. |
| 32:62 | Volume [<String>] on mount path [<String>] in the library [<String>] is now marked bad. |
| 32:63 | Volume on Centera mount path [<String>] in the library [<String>] is now marked bad. |
| 32:64 | Media with barcode [<String>], Unique ID [<String>] is now marked Read-Only. |
| 32:65 | Volume [<String>] on mount path [<String>] in the library [<String>] is now marked Read-Only. |
| 32:66 | Volume on Centera mount path [<String>] in the library [<String>] is now marked Read-Only. |
| 32:67 | There are no mount paths that are online for the disk library [<String>]. Make sure that there is at least one mount path which is online and which meets the space allocation criteria specified on the mount path properties. |
| 32:68 | There are no mount paths that are online for the disk library [<String>]. Make sure that there is at least one mount path which is online. |
| 32:69 | Drive pool [<String>] is offline. |
| 32:70 | Drive pool [<String>] is ready. |
| 32:71 | Master Drive pool [<String>] is offline. |
| 32:72 | Master Drive pool [<String>] is ready. |
| 32:73 | Media Manager request failed to mount/unmount a medium in drive [<String>], library [<String>] in the specified timeout period. <String> |
| 32:74 | Media Manager request [<String>] timed out. |
| 32:75 | Mount path [<String>] in the disk library [<String>] is now marked offline. |
| 32:76 | Mount path [<String>] in the disk library [<String>] is now marked ready. |
| 32:77 | Reservation for job [<Number>] could not be completed as the library controller [<String>] for the library [<String>] on MediaAgent [<String>] is not online. |
| 32:78 | Reservation for job [<Number>] could not be completed as the library [<String>] on MediaAgent [<String>] is not online. |
| 32:79 | Reset library [<String>] started. |
| 32:80 | Reset library [<String>] finished. Library may be in the process of inventory. |
| 32:81 | Reset library [<String>] failed with error <String> |
| 32:82 | Library controller on MediaAgent [<String>] for library [<String>] has been reset. |
| 32:83 | Media in drive [<String>] in library [<String>] was not recovered. Try resetting the drive or the library again. |
| 32:84 | Reservation for job [<Number>] could not be completed as the drive pool [<String>] is not online. |
| 32:85 | Reservation for job [<Number>] could not be completed as the master drive pool [<String>] is not online. |
| 32:86 | Reservation for job [<Number>] could not be completed as the MediaAgent services on the MediaAgent [<String>] are not online. |
| 32:87 | Scratch pool [<String>] deleted successfully. |
| 32:88 | Process to reset drive [<String>] finished successfully. The reset is complete when the drive is turned back online. |
| 32:89 | Media & Library Manager service failed to start: [<String>]. |
| 32:90 | The number of read and write errors <String> for drive [<String>] in library [<String>] has exceeded its threshold. |
| 32:91 | The number of mount and unmount errors <String> for drive [<String>] in library [<String>] has exceeded its threshold. Drive will be marked as broken. |
| 32:92 | The number of hours used <String> for drive [<String>] in library [<String>] has exceeded its threshold. |
| 32:93 | The number of reuses for media [<String>] in library [<String>] has reached its threshold. |
| 32:94 | The number of restores and backups for the media [<String>] in the library [<String>] has exceeded the Short-Length durability threshold. |
| 32:95 | The number of read and write errors for media [<String>] in library [<String>] has exceeded its threshold. |
| 32:96 | The number of media label errors for media [<String>] in library [<String>] has exceeded its threshold. |
| 32:97 | The media with barcode [<String>] cannot be reserved because it is stuck in drive [<String>] in library [<String>]. Please reset the drive. |
| 32:98 | Drive [<String>] in library [<String>] is being cleaned. |
| 32:99 | Cannot migrate library [<String>] on MediaAgent [<String>] as jobs are running for the library. |
| 32:100 | Drive [<String>] in library [<String>] needs cleaning. Automatic cleaning for this library is disabled, please clean this drive manually and mark drive clean from the Console. |
| 32:101 | Drive [<String>] in library [<String>] needs cleaning, but there are currently no cleaning media available inside this library. Please import and identify cleaning media or retry when cleaning media become available. |
| 32:102 | Failed to clean drive [<String>] in library [<String>]. |
| 32:103 | Library controller [<String>] for library [<String>] on MediaAgent [<String>] has logged the following message. [<String>]. |
| 32:104 | Invalid barcode detected in slot [<String>], in library [<String>]. Please replace the barcode for this medium in the library. |
| 32:105 | <String> |
| 32:106 | Job [<Number>] waiting for a drive [<String>] in library [<String>] to be unmounted in order to mount media with Barcode [<String>]. |
| 32:107 | Job [<Number>] waiting for media with Barcode [<String>], which is in motion, to be mounted. |
| 32:108 | Media with Barcode [<String>] is already mounted in drive [<String>] in library [<String>] and will be used for the job. |
| 32:109 | Media in drive [<String>] in library [<String>] is being unmounted. |
| 32:110 | Failed to export media with barcode [<String>] from library [<String>] due to error: <Message> |
| 32:111 | Media [<String>] is deleted from Library [<String>]. |
| 32:112 | The file marker on media with Barcode [<String>] is [<Number>], smaller than the highest file marker [<Number>] recorded in archChunk table. Data loss may occur on this media. |
| 32:113 | Media with barcode: [<String>] have been migrated to library [<String>]. |
| 32:114 | The number of years for media [<String>] in library [<String>] has exceeded its threshold. |
| 32:115 | Unable to allocate spare media with Barcode [<String>], Unique ID [<String>] from Scratch Pool [<String>] in Library [<String>] because it is stuck in the drive. |
| 32:116 | Media with barcode [<String>], Unique ID [<String>] for Job [<Number>] is outside Library [<String>]. |
| 32:117 | A scan operation on library [<String>] on MediaAgent [<String>] has started. |
| 32:118 | Deleted Storage Policy [<String>] for deconfiguring Drive Pool [<Number>]. |
| 32:119 | There are <Number> media recycled asynchronously by Media Manager. |
| 32:120 | Deleted Storage Policy/Copy Name [<String>] for deconfiguring Drive Pool [<Number>]. |
| 32:121 | Resetting MediaAgent [<String>]... |
| 32:122 | Reset MediaAgent [<String>] failed due to error: <String> |
| 32:123 | Media in slot [<String>] is being exported from Library [<String>]. |
| 32:124 | Failed to export media in slot [<String>] from library [<String>] due to error: <String> |
| 32:125 | Failed to mount media with barcode [<String>] in library [<String>]. |
| 32:126 | Media with Unique ID [<String>] is not found in expected slot [<String>] of Library [<String>]. Library will be inventoried to search for media. |
| 32:127 | Wrong media [<String>] is mounted in the Drive [<String>] of Library [<String>]. |
| 32:128 | Media in library [<String>], slot [<String>] does not have a valid media label which means that it was not written to by this product. |
| 32:129 | Media in library [<String>], slot [<String>] has Unique ID [<String>], creation time [<String>], CommCell Number [<Number>] and does not belong to this instance of the CommCell. |
| 32:130 | Media in library [<String>], slot [<String>] has Unique ID [<String>], creation time [<String>], CommCell Number [<Number>] and belongs to this instance of the CommCell. |
| 32:131 | Media in library [<String>], slot [<String>] has Unique ID [<String>], creation time [<String>] was migrated from CommCell Number [<Number>]. |
| 32:132 | Media in library [<String>], slot [<String>] has Unique ID [<String>], creation time [<String>]. This medium is in the wrong library and should be moved to library [<String>]. |
| 32:133 | Media in library [<String>], slot [<String>] is a cleaning media. |
| 32:134 | The number of connectivity errors for library [<String>] has exceeded its threshold. The library is marked offline. |
| 32:135 | The number of mount and unmount errors for library [<String>] has exceeded its threshold. The library is marked offline. |
| 32:136 | Media with barcode [<String>], Unique ID [<String>] is now marked retired. |
| 32:137 | Scheduled export job [<Number>] has started. Please check if there are media moved to mail slots. |
| 32:138 | Failed to mount the disk media in library [<String>] with mount path [<String>] on MediaAgent [<String>]. <String> <String> |
| 32:139 | Drives in library [<String>] needs cleaning. This product's Automatic cleaning functionality for this library is disabled. |
| 32:140 | Drives in library [<String>] need cleaning but all cleaning media is in use or exported. |
| 32:141 | Drives in library [<String>] need cleaning but there is no cleaning media in library. |
| 32:142 | The policy [<String>] has run successfully to create [<Number>] media movement actions for total of [<Number>] media. |
| 32:143 | The policy [<String>] has failed to run due to error: <String>. |
| 32:144 | The job [<Number>] has run successfully to create [<Number>] media movement actions for total of [<Number>] media. |
| 32:145 | The job [<Number>] has failed to run due to error: <String>. |
| 32:146 | VaultTracker requires import of following media. Please move these media to their desired libraries. <String> |
| 32:147 | The [<Number>] media movement actions for total of [<Number>] media has been created successfully for <String>. |
| 32:148 | Failed to create media movement actions for <String>, <String>. |
| 32:149 | There are some Tracking Policies disabled because <String>. |
| 32:150 | VaultTracker has created [<Number>] pending media movement actions for <String>. Please check VaultTracker for details. |
| 32:151 | VaultTracker has completed [<Number>] pending action(s) for <String>. Please check VaultTracker history for details. |
| 32:152 | VaultTracker has detected that [<Number>] pending action(s) for <String> are failed or aborted. Please check VaultTracker history for details. |
| 32:153 | VaultTracker has detected that [<Number>] media for <String> are exported, they will be moved to in transit automatically. Please check VaultTracker for details. |
| 32:154 | VaultTracker requires import of [<Number>] media for <String>, please check pending actions for the destination library for import. |
| 32:155 | VaultTracker has moved [<Number>] media to virtual mail slots for <String>, please check pending action(s) for library to pick up. |
| 32:156 | VaultTracker has detected that [<Number>] media have been picked up for <String>. Please check VaultTracker for details. |
| 32:157 | VaultTracker has detected that [<Number>] media have reached their destination for <String>. Please check VaultTracker for details. |
| 32:158 | VaultTracker has detected that [<Number>] media have been returned to their source for <String>. Please check VaultTracker for details. |
| 32:159 | VaultTracker has rolled back [<Number>] media movement history for <String>, media location is reset to their source location. Please check VaultTracker for details. |
| 32:160 | Slot [<String>] for Media [<String>] in library [<String>] is being inventoried. |
| 32:161 | Media with barcode [<String>] in slot [<String>] in library [<String>] has a duplicate barcode. |
| 32:162 | Replacing the active media for job [<Number>] from Mount Path [<String>] to [<String>]. |
| 32:163 | There are media inside this container. Please change the container for those media. |
| 32:164 | Media with barcode [<String>], side [<String>], in library [<String>] and drive [<String>] on MediaAgent [<String>] has been erased. Mount finished in [<Number>] seconds. |
| 32:165 | Media with barcode [<String>], side [<String>], mounted on library [<String>] and drive [<String>] on filer [<String>]. Mountpoint [<String>] for job [<Number>]. Mount finished in [<Number>] seconds. |
| 32:166 | Failed to verify media. <String><String> |
| 32:167 | Media with identifier [<String>], Unique ID [<String>] mounted in library [<String>] and drive [<String>] on MediaAgent [<String>]. Mount finished in [<Number>] seconds. |
| 32:168 | Media in library [<String>] drive [<String>] does not have a valid media label, which means that it was not written to by this product. |
| 32:169 | Media in library [<String>] drive [<String>] has Identifier [<String>] Unique ID [<String>], creation time [<String>], CommCellId [<Number>] and does not belong to this instance of the CommCell. |
| 32:170 | Media in library [<String>] drive [<String>] has Identifier [<String>] Unique ID [<String>], creation time [<String>] and belongs to this instance of the CommCell. |
| 32:171 | Media in library [<String>] drive [<String>] has Identifier [<String>] Unique ID [<String>], creation time [<String>]. This medium is in the wrong library and should be moved to library [<String>]. |
| 32:172 | Media in library [<String>] drive [<String>] is a cleaning media. |
| 32:173 | VaultTracker failed to export media for <String> due to error: <String>. Please check VaultTracker for details. |
| 32:174 | VaultTracker failed to move media to virtual mail slot for <String> due to error: <String>. Please check VaultTracker for details. |
| 32:175 | VaultTracker failed to start media movement process due to error: the VaultTracker license is either not installed or has expired. |
| 32:176 | Media [<String>] in library [<String>] has been pruned because of option to overwrite media and was written to on [<String>]. Please make sure that this option has not been selected erroneously. |
| 32:177 | Waiting for the Library to come online after a full scan. |
| 32:178 | Read operation from media [<String>] could not be completed as there are no ready resources that can read from this media. |
| 32:179 | The required media [<String>] for the job [<Number>] is not in the Library [<String>]. Please use the import functionality to import the media from the location [<String>] into the library [<String>]. |
| 32:180 | Export Bulk Media failed due to the following reason: <Message> |
| 32:181 | Failed to mount medium. Reason given: <Message> Advice: <Message> |
| 32:182 | Failed to mount medium. Reason given: <Message> |
| 32:183 | Read operation from media [<String>] could not be completed. The reason given was: <Message> |
| 32:184 | Media with barcode [<String>] has On Media Label of [<String>] Unique ID [<String>]. Please update the barcode from [<String>] to [<String>]. |
| 32:185 | Media [<String>] has been moved to mail slot [<String>] in Library [<String>] for export. Please remove this media from the mail slot. |
| 32:186 | There are no available mail slots for exporting media in Library [<String>]. Please remove all media from mail slots. |
| 32:187 | Export completed for the selected media from Library [<String>]. |
| 32:188 | Failed to export media from library [<String>] due to error: <Message>. |
| 32:189 | Media [<String>] has been successfully exported from Library [<String>]. |
| 32:190 | Export completed for the selected media from Library [<String>]. Please open the library door and remove media from the library. |
| 32:191 | Following media have been moved to the mail slots in Library [<String>] for export. n <String> n Please remove these media from the mail slots. |
| 32:192 | [<Number>] media have been moved to the mail slot in Library [<String>]. The mail slot is now full. Please remove these media to export the rest of the [<Number>] media. |
| 32:193 | <Message> Reason: <Message> Advice: <Message> |
| 32:194 | <Message> Reason: <Message> |
| 32:195 | The index cache access path [<String>] for MediaAgent [<String>] is ready. |
| 32:196 | The index cache access path [<String>] for MediaAgent [<String>] is offline. Reason: <Message> |
| 32:197 | Drive [<String>] in Library [<String>] cleaned with media, barcode [<String>]. Cleaning finished in [<Number>] seconds. |
| 32:198 | Drive [<String>] in Library [<String>] validated on MediaAgent [<String>] with media [<String>], block size [<Number>]KB with data of size [<Number>]MB, chunk size [<Number>]MB. Write/Read throughput [<Number>/<Number>]MB/sec. |
| 32:199 | Drive lifetime read and write error count at [<Number>], threshold [<Number>] |
| 32:200 | Drive since clean read and write error count at [<Number>], threshold [<Number>] |
| 32:201 | Drive lifetime mount and unmount error count at [<Number>], threshold [<Number>] |
| 32:202 | Drive since clean read and write error count at [<Number>], threshold [<Number>] |
| 32:203 | Drive lifetime hours used count at [<Number>], threshold [<Number>] |
| 32:204 | Drive since clean hours used count at [<Number>], threshold [<Number>] |
| 32:205 | Library connectivity error count at [<Number>], threshold [<Number>] |
| 32:206 | Library mount and unmount error count at [<Number>], threshold [<Number>] |
| 32:207 | Media reuses count at [<Number>], threshold [<Number>] |
| 32:208 | Media months used count at [<Number>], threshold [<Number>] |
| 32:209 | Media backups/restores count at [<Number>], threshold [<Number>] |
| 32:210 | Media read and write error count at [<Number>], threshold [<Number>] |
| 32:211 | Media label error count at [<Number>], threshold [<Number>] |
| 32:212 | The Drive <String> in Library <String> on MediaAgent <String> may not be released. MediaAgent may not have unmounted media due to a possible hung system call. Please check the firmware revisions and hardware status of all the components in the data path. This includes HBA cards, switches, routers, cables and drives. |
| 32:213 | Mount request cannot be processed as job is no longer in running state. |
| 32:214 | The required media [<String>] for the job [<Number>] is not in the Library [<String>]. Please use the import functionality to import the media from the location [<String>] container [<String>] into the library [<String>]. |
| 32:215 | A database error occurred while looking up the data path candidates. Please try again and if the problem persists, contact your software vendor. |
| 32:216 | The operation failed because a NAS client is using the storage policy and MediaAgent [<String>] does not have a file system agent installed on it. |
| 32:217 | The operation failed because a NAS client is using the storage policy and MediaAgent [<String>] has had its files system agent uninstalled. |
| 32:218 | Index Cache [<String>] was taken offline because the free space [<Number> MB] is less than the threshold [<Number> MB]. Reporting MediaAgent: [<String>] |
| 32:219 | The Index Cache [<String>] is back online after being taken offline due to lack of space. Free space now [<Number> MB], threshold [<Number> MB]. |
| 32:220 | MediaAgent [<String>] has been at a lower version for [<Number>] days since the CommServe has been upgraded. Please upgrade the MediaAgent to the same version as the CommServe as soon as possible. |
| 32:221 | Failed to verify media in the slot [<String>]. Media in this slot will not be exported |
| 32:222 | Failed to reserve drive(s) to perform inventory on the Library [<String>]. Inventory will be retried |
| 32:223 | Inventory for slot [<String>] in the library [<String>] failed due to mount failure. |
| 32:224 | Failed to get information on the slot [<String>]. Media verification in slot [<String>] failed. |
| 32:225 | Either the library [<String>] is offline or the drives in this library cannot be reserved. Therefore, the inventory job is being killed. |
| 32:226 | The MediaAgent [<String>] needs to have the CBRM module installed in order for this storage policy to be usable for this client. |
| 32:227 | Adding the data path didn't work as there are one (or) more Centera iDataAgents using this storage policy. This requires that the MediaAgent [<String>] needs to have the CBRM module installed. |
| 32:228 | Failed to reserve a drive to do discover media in the slot [<String>] |
| 32:229 | Failed to verify media in the slot [<String>] |
| 32:230 | Failed to discover media in the slot [<String>] |
| 32:231 | Successfully verified media in the slot [<String>] |
| 32:232 | Successfully discovered media in the slot [<String>] |
| 32:233 | The MediaAgent [<String>] needs to have the NDMP remote server module installed in order for this storage policy to be usable for this client. |
| 32:234 | Adding the data path didn't work as there are one (or) more NAS iDataAgents or one or more Centera iDataAgents using this storage policy. This requires that the MediaAgent [<String>] has the NDMP remote server module installed. |
| 32:235 | Validate Storage |
| 32:236 | Failed to validate drive because of the error [<Message>] |
| 32:237 | Successfully validated the drive. Achieved a write throughput of [<Number>] MB/Sec and a read throughput of [<Number>] MB/Sec for a data size of [<Number>] MB. |
| 32:238 | Stamp Media |
| 32:239 | Failed to stamp the media because of the error [<Message>] |
| 32:240 | Successfully stamped the media |
| 32:241 | Clean Drive |
| 32:242 | Failed to clean the drive because of the error [<Message>] |
| 32:243 | Successfully cleaned the drive |
| 32:244 | Failed to communicate with MediaAgent %s. Please check to see if the MediaAgent services are online and the network connectivity is OK. |
| 32:245 | There are some Tracking Policies disabled because destination has changed as result of library uninstallation. |
| 32:246 | Media & Library Manager service failed to start: [<String>]. |
| 32:247 | Failed to stamp media. |
| 32:248 | Failed to unmount medium in drive [<String>], library [<String>]. |
| 32:249 | Failed to export media with barcode [<String>] from library [<String>] due to error: <Message> |
| 32:250 | Reset MediaAgent [<String>] failed due to error: <Message> |
| 32:251 | Failed to export media in slot [<String>] from library [<String>] due to error: <Message> |
| 32:252 | Library is not ready. |
| 32:253 | Failed to verify media. |
| 32:254 | Read operation from media [<String>] could not be completed. The reason: <Message> <Message> |
| 32:255 | Library [<String>] has been deconfigured. |
| 32:256 | Drive [<String>] in library [<String>] has been deconfigured. |
| 32:257 | MediaAgent [<String>] has been uninstalled. |
| 32:258 | Failed to verify media. <Message>. <Message> |
| 32:259 | Failed to reserve a drive to verify media in the slot [<String>]. |
| 32:260 | <Message> SCSI Operation: <Message>. Reason: <Message> Advice: <Message> |
| 32:261 | Media Type of Media [<String>] has been changed to [<String>] from [<String>]. The media will remain in [<String>] since there are no scratch pools configured for the new media type. |
| 32:262 | Media Type of medium [<String>] has been changed to [<String>] from [<String>]. The medium is now in Scratch Pool [<String>]. |
| 32:263 | Failed to communicate with MediaAgent [<String>]. Please check to see if the MediaAgent services are online and the network connectivity is OK. |
| 32:264 | The required media [<String>] for the job [<Number>] is not in the Library [<String>]. Please use the import functionality to import the media from the location [<String>] container [<String>] into the library [<String>]. |
| 32:265 | <String> |
| 32:266 | Data path for Library [<String>], DrivePool [<String>], MediaAgent [<String>], Spare Group [<String>] has been removed for Storage Policy [<String>], Storage Policy Copy [<String>]. |
| 32:267 | Data path for Library [<String>], DrivePool [<String>], MediaAgent [<String>], Spare Group [<String>] has been removed for Storage Policy [<String>], Storage Policy Copy [<String>]. This Storage Policy does not have any more data paths. Please make sure that this copy has at least one data path associated to it. |
| 32:268 | Data path for Library [<String>], MediaAgent [<String>] has been removed for Storage Policy [<String>], Storage Policy Copy [<String>]. |
| 32:269 | Data path for Library [<String>], MediaAgent [<String>] has been removed for Storage Policy [<String>], Storage Policy Copy [<String>]. This Storage Policy does not have any more data paths. Please make sure that this copy has at least one data path associated to it. |
| 32:270 | Invalid |
| 32:271 | Uninitialized |
| 32:272 | Mounting media |
| 32:273 | Mounting media |
| 32:274 | Initialized |
| 32:275 | Seeking on media |
| 32:276 | Writing on media |
| 32:277 | Reading on media |
| 32:278 | Waiting for network message |
| 32:279 | Preparing media |
| 32:280 | Preparing media |
| 32:281 | Committing data |
| 32:282 | Unknown |
| 32:283 | The data transfer for the following jobs [<String>] is not progressing. The state of the data transfer on the MediaAgent is: <Message> |
| 32:284 | Export for Action [<Number>] of VaultTracker Policy [<String>] started for moving [<Number>] media to location [<String>]. |
| 32:285 | The following media are being exported as part of Action [<Number>] for Vault Tracker Policy [<String>]: n <String> n. |
| 32:286 | Media in library [<String>], slot [<String>] which has UniqueId [<String>], creation time [<String>] was mounted but OML found on the media is that of another media with Unique Id [<String>]. |
| 32:287 | Internal error. The path [<String>] belongs to a deduplicated backup and cannot be deleted through regular pruning logic. Please contact your vendor's customer support. |
| 32:288 | Cannot mark Active Volume for Arch Group [<String>] as Full. The Active Volume is already being used by other job[s]. |
| 32:289 | Library [<String>], MediaAgent [<String>], Drive Pool [<String>], Media[<String>]: <Message> |
| 32:290 | Library [<String>], MediaAgent [<String>], Drive Pool [<String>], MountPath[<String>]: <Message> |
| 32:291 | Copy [<Number>] of Storage Policy [<String>] does not have a data path containing MediaAgent [<String>]. |
| 32:292 | Cannot access tape via native tape driver device node [<String>]. Please make sure that native tape driver is attached to all SCSI/FC devices. |
| 32:293 | VaultTracker Action [<Number>] of Policy [<String>] has moved following media to the mail slots in Library [<String>] for export. n <String> n Please remove these media from the mail slots. |
| 32:294 | MediaAgent [<String>] is at a lower version than the CommServe. Please upgrade the MediaAgent to the same version as the CommServe as soon as possible. |
| 32:295 | The scan operation on library [<String>] on MediaAgent [<String>] finished. |
| 32:296 | Disk Library Maintenance |
| 32:297 | Failed to perform Disk Library Maintenance because of the error [<Message>] |
| 32:298 | Successfully performed Disk Library Maintenance. |
| 32:299 | Skipped Disk Library Maintenance due to unsupported parameters or platform. |
| 32:300 | Disk Library Maintenance Job Partially Completed. |
| 32:301 | Failed to reset manual retention end time on jobs. |
| 32:302 | Failed to clear extended retention flags for jobs on copies with no extended retention criteria. |
| 32:303 | Failed to prune successful jobs with no archive files. |
| 32:304 | Failed to prune failed and killed backups. |
| 32:305 | Failed to prune older CDR attempts. |
| 32:306 | Failed to prune Data Aging Logging Tables. |
| 32:307 | Failed to prune SQL Lock Detection Tables. |
| 32:308 | Failed to prune Media Mount and Error Tracker History. |
| 32:309 | Failed to Prune Selective Deletion Jobs. |
| 32:310 | Failed to Prune Jobs. |
| 32:311 | Failed to Prune disk Chunks. |
| 32:312 | Failed to Prune DB2 Logs Table. |
| 32:313 | Failed to Prune Job Histories. |
| 32:314 | Failed to Prune Unused Subclient Properties. |
| 32:315 | Failed to reset Reference Time for Subclients. |
| 32:316 | Failed to Prune Audit Trail Records. |
| 32:317 | Failed to Prune SQL Backup Sets from SQL Clients created before 6.1. |
| 32:318 | Failed to Prune SQL Backup Sets from SQL Clients. |
| 32:319 | Failed to get Archive Files for Oracle Cross-Check. |
| 32:320 | Failed to Cross-Check Oracle Clients. One or more Oracle instances are not reachable. Please view Events of this Job for list of clients, instances that failed. |
| 32:321 | Failed to clean up database after Oracle Cross-Check. |
| 32:322 | Failed to Prune OSSV Volumes. |
| 32:323 | Failed to check for running QRA Jobs. |
| 32:324 | Failed to set flag for pre-7.0 System State Archive Files. |
| 32:325 | Deprecated message. |
| 32:326 | Deprecated message. |
| 32:327 | Deprecated message. |
| 32:328 | Deprecated message. |
| 32:329 | Failed to get prunable data. |
| 32:330 | Failed to Prune Spool Copy Data. |
| 32:331 | Failed to Prune ASR Jobs. |
| 32:332 | Failed to get SQL Chaining Information. |
| 32:333 | Failed to Prune SQL Jobs. |
| 32:334 | Failed to get Log Pruning time. |
| 32:335 | Failed to Prune Log Jobs. |
| 32:336 | Failed to Prune Dangling SILO. |
| 32:337 | Failed to get Archive Files for SAP Cross-Check. |
| 32:338 | Failed to Cross-Check SAP Clients. |
| 32:339 | Failed to clean up database after SAP Cross-Check. |
| 32:340 | Disk Library Volume Reconciliation |
| 32:341 | Failed to perform Disk Library Volume Reconciliation because of the error [<Message>] |
| 32:342 | Successfully performed Disk Library Volume Reconciliation |
| 32:343 | Skipped Disk Library Volume Reconciliation due to unsupported parameters or platform. |
| 32:344 | Disk Library Volume Reconciliation Partially Completed |
| 32:345 | Media with the following barcode(s) [<String>] in library [<Number>] has mismatching Spare Group. Please check them. |
| 32:346 | In invalid state. |
| 32:347 | In uninitialized state. |
| 32:348 | Waiting for mounting of media to complete. |
| 32:349 | Waiting for mounting of media to complete. |
| 32:350 | Initialized and waiting to receive data from client. |
| 32:351 | Performing the seek operation to the given offset. |
| 32:352 | Performing the write operation to the media. |
| 32:353 | Performing the read operation from the media. |
| 32:354 | Waiting to receive data from the client. |
| 32:355 | Waiting for media initialization to complete during a write session. |
| 32:356 | Waiting for media initialization to complete during a read session. |
| 32:357 | Waiting for flushing of data on media and for committing data to CommServe to complete. |
| 32:358 | In unknown state. |
| 32:359 | The data transfer for the following jobs [<String>] is not progressing. MediaAgent module is <Message> |
| 32:360 | SDR Replication is suspended by user. Mount Paths on this host will not be replicated. |
| 32:361 | Abnormal termination of DeDuplication services detected on MediaAgent [<String>] on Storage Policy [<String>] / Copy [<String>]. <Message>. |
| 32:362 | Access Path [<String>] on MediaAgent [<String>] for MountPath [<String>] in library [<String>] is offline. |
| 32:363 | Library [<String>] either does not exist or is a magnetic library. |
| 32:364 | Snap prepared for volume [<String>] with id [<Number>] on client [<String>] using filer array [<String>] by [<String>]. |
| 32:365 | Snap created of volume [<String>] with id [<Number>] on client [<String>] using filer array [<String>] by [<String>]. |
| 32:366 | Snapped volume [<String>] with id [<Number>] of job [<Number>] mounted on client [<String>] at mount point [<String>] by [<String>]. |
| 32:367 | Mounted volume [<String>] with id [<Number>] of job [<Number>] on client [<String>] unmounted from mount point [<String>] by [<String>]. |
| 32:368 | Snap of volume [<String>] with id [<Number>] of job [<Number>] on client [<String>] deleted from the filer array [<String>] by [<String>]. |
| 32:369 | The required media [<String>] for the job [<Number>] is not in the Library [<String>]. n Please use the import functionality to import the media from n the location [<String>] container [<String>] into the library [<String>]. |
| 32:370 | Deduplication DB [<String>] has been sealed. Sealed Reason: <Message> |
| 32:371 | Deduplication DB [<String>] has been sealed after partially copied archive files have been set for recopy. Sealed Reason: <Message> |
| 32:372 | Failed to Prune Documentum Data. |
| 32:373 | Snap created for volume [<String>] - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>]. |
| 32:374 | Failed to create snap for volume [<String>] - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>]. |
| 32:375 | Snap of source volume [<String>] mounted successfully - id [<Number>] backup job [<Number>] mount client [<String>] mount point [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:376 | Failed to mount snap of source volume [<String>] - id [<Number>] backup job [<Number>] mount client [<String>] mount point [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:377 | Failed to mount snap of source volume [<String>] - id [<Number>] backup job [<Number>] mount client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:378 | Snap of source volume [<String>] unmounted successfully - id [<Number>] backup job [<Number>] mount client [<String>] mount point [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:379 | Failed to unmount snap of source volume [<String>] - id [<Number>] backup job [<Number>] mount client [<String>] mount point [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:380 | Volume [<String>] reverted successfully - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:381 | Failed to revert volume [<String>] - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:382 | Snap of source volume [<String>] deleted successfully - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:383 | Failed to delete snapshot of volume [<String>] - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:384 | Snap of source volume [<String>] missing or externally pruned - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:385 | <String> : [<Message>] |
| 32:386 | Please run a DDB recovery job to correct this |
| 32:387 | The DDB will be recovered automatically |
| 32:388 | Failing over to a new DDB |
| 32:389 | Reaching low disk space on the SIDB index [copy - <String>]. |
| 32:390 | Low disk space on the SIDB index [copy - <String>]. |
| 32:391 | Failed to Prune Failed and Killed Job Info. |
| 32:392 | <Message> : [<String>] |
| 32:393 | Data transfer will be performed over LAN based on the resource availability. Destination Client [<String>], MediaAgent/NAS Filer [<String>]. |
| 32:394 | Inventory operation was terminated because a slot config update was received from the library. |
| 32:395 | Media [<String>] required for Stub recovery job is exported and currently at [<String>]. |
| 32:396 | The deduplication database path [<String>] for MediaAgent [<String>] is ready. |
| 32:397 | The deduplication database path [<String>] for MediaAgent [<String>] is offline. Reason: <Message> |
| 32:398 | Failed to delete deconfigured clients with no protected data. |
| 32:399 | Deduplication Database (DDB) access path [<String>] on MediaAgent [<String>] is offline for Storage Policy Copy [<String> / <String> ]. Offline Reason: <String> <Message> |
| 32:400 | Failed to clean up database after Oracle Cross-Check due to Oracle Cross-Check timeout. |
| 32:401 | Failed to clean drive [<String>] because of error [<String>] |
| 32:402 | Successfully cleaned drive [<String>] |
| 32:403 | Found Mount path(s) offline [copy - <String>]. So, Cache DB lookup is skipped. |
| 32:404 | Deduplication database [<String>] has been sealed. Sealed Reason: <Message>. Sealed by User: [<String>] |
| 32:405 | Deduplication database [<String>] has been sealed after partially copied archive files have been set for recopy. Sealed Reason: <Message>. Sealed by User: [<String>] |
| 32:406 | Library [<String>], MediaAgent [<String>], Drive Pool [<String>], Media[<String>]: <Message> Advice: <Message> |
| 32:407 | Library [<String>], MediaAgent [<String>], Drive Pool [<String>], MountPath[<String>]: <Message> Advice: <Message> |
| 32:408 | <Message> Advice: <Message> |
| 32:409 | Warning: Total available space for jobs [<Number>] MB on all the mount paths that are online for the disk Library [<String>] on MediaAgent [<String>] is less than [<Number>] MB. |
| 32:410 | Abnormal termination of DeDuplication services detected on MediaAgent [<String>] on Storage Policy [<String>] / Copy [<String>]. |
| 32:411 | Reaching low disk space on the Cache DB [client - <String>] [Path - <String>] [Free <Number> MB]. |
| 32:412 | Read operation from Library [<String>], MediaAgent [<String>], Media [<String>] could not be completed. The reason: <Message> Advice: <Message> |
| 32:413 | Failed to prune CCR. |
| 32:414 | No device detected for snap job [<Number>] mount point [<String>]. |
| 32:415 | Some Deduplication databases may not be protected using DDB Backup subclient on these MediaAgents: [<String>]. |
| 32:416 | Deduplication databases for these Storage Policies/ Copies [<String>] are not backed up the in last [<Number>] hours on this MediaAgent: [<String>]. |
| 32:417 | Deduplication database on MediaAgent [<String>] Path [<String>] is found offline within last [<Number>] hours. Backups/Auxcopy may not be running to this partition. Space for prunable data managed by the DDB will not be freed until the DDB is fully online. |
| 32:418 | DDB access path [<String>] on MediaAgent [<String>] is offline for Storage Policy Copy [<String> / <String>]. Offline Reason: <String> |
| 32:419 | Successfully collected reporting information for array [<String>]. |
| 32:420 | Failed to collect reporting information for array [<String>]. |
| 32:421 | File-level revert finished successfully - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:422 | File-level revert failed - id [<Number>] backup job [<Number>] client [<String>] array [<String>] snap engine [<String>] by [<String>]. |
| 32:423 | Reconstruction of a deduplication partition on MediaAgent [<String>] at path [<String>] of Storage Policy [<String>] Copy [<String>] has been skipped due to exceeding threshold of [<Number>] reconstructions within [<Number>]hrs. Please start full reconstruction of this partition from GUI. |
| 32:424 | Media[<String>]: <Message> |
| 32:425 | Media[<String>]: <Message> Advice: <Message> |
| 32:426 | Failed to clean drive [<String>] in Library [<String>], MediaAgent [<String>] because of error [<String>]. |
| 32:427 | Successfully cleaned drive [<String>] in Library [<String>], MediaAgent [<String>]. |
| 32:428 | Failed to execute [<String>]-snap command [<String>] on [<String>] client for backup job [<Number>]. Error [<String>] |
| 32:429 | Command [<String>] executed for [<String>]-snap on [<String>] client for backup job [<Number>] returned failure error code[<Number>]. |
| 32:430 | Reconstruction of a deduplication partition on MediaAgent [<String>] at path [<String>] of Storage Policy [<String>] Copy [<String>] has been skipped due to DDB validation failed status. |
| 32:431 | Deduplication database on MediaAgent [<String>] Path [<String>] is found offline due to DDB validation failed after reconstruction within last [<Number>] hours. Backups/Auxcopy may not be running to this partition. |
| 32:432 | Deduplication database(s) reaching QI time threshold. [<String>]. Please review the deduplication database configuration. |
| 32:433 | StoreName[<String>] StoragePolicy[<String>] Copy[<String>] MediaAgent[<String>] Path[<String>] PrimaryRecords[<Number>] AvgQITime[<Number>] |
| 32:434 | Deduplication database(s) reaching threshold for Pending Logical Pruning [<String>]. |
| 32:435 | StoreName[<String>] StoragePolicy[<String>] Copy[<String>] Pending Logical Pruning Records[<Number>] |
| 32:436 | Failed to prune DASH Copy job information. |
| 32:437 | Deduplication database(s) reaching QI time threshold for adding new Subclient [<String>]. Please review the deduplication database configuration. |
| 32:438 | Deduplication database(s) crossed QI time threshold for adding new Subclient [<String>]. Please review the deduplication database configuration. |
| 32:439 | Deduplication database(s) reaching primary records threshold. [<String>]. Please review the deduplication database configuration. |
| 32:440 | Deduplication database(s) crossed QI time threshold. Jobs will stop running [<String>]. Please review the deduplication database configuration. |
| 32:441 | Deduplication database(s) in grace period. Jobs will run till extension date [<String>]. Please review the deduplication database configuration. |
| 32:442 | StoreName[<String>] StoragePolicy[<String>] Copy[<String>] MediaAgent[<String>] Path[<String>] PrimaryRecords[<Number>] AvgQITime[<Number>] ExtensionDate[<String>] |
| 32:443 | Failed to delete virtual machine clients with no protected data. |
| 32:444 | Failed to Prune Datasets and Dataset Members. |
| 32:445 | Failed to clean drive [<String>] in Library [<String>] because of error [<String>]. |
| 32:446 | Successfully cleaned drive [<String>] in Library [<String>]. |
| 32:447 | Failed to Prune VSA Data. |
| 32:448 | Some archive files will be asynchronously content indexed by tagger thread. |
| 32:449 | Import Media Operation Started for Library [<String>]. |
| 32:450 | Import Media Operation Completed for Library [<String>]. |
| 32:451 | Failed to start Import Media Operation for Library [<String>]. |
| 32:452 | Failed to Complete Import Media Operation for Library [<String>]. |
| 32:453 | Destination mail slots for export are unavailable or invalid for the library [<String>]. |
| 32:454 | Input mail slots for import are unavailable or invalid for the library [<String>]. |
| 32:455 | Input destination slots for import are unavailable or invalid for the library [<String>]. |
| 32:456 | Mountpath [<String>] in Library [<String>] validated on MediaAgent [<String>] with Block Size [<Number>] bytes, Block Count [<Number>], File Count [<Number>]. Write/Read throughput [<Number>/<Number>]MB/sec. |
| 32:457 | Successfully validated the mount path. Achieved a write throughput of [<Number>] MB/Sec and a read throughput of [<Number>] MB/Sec for a data size of [<Number>] MB. |
| 32:458 | Failed to validate mount path because of the error [<Message>]. |
| 32:459 | Mountpath validation job(<Number>) is already running for the same mount path[<String>, <String>]. |
| 32:460 | Requested Space is not available on the mount path[<String>, <String>] for validation. |
| 32:461 | Mountpath validation job is not allowed because Media Agent [<String>] has lower version than required. Media Agent version should be at least 11.0. |
| 32:462 | Error in cleaning up Edge Drive data. |
| 32:463 | <Number> of <Number> Online |
| 32:464 | Snap operation request [<Number>] of type [<String>] for job [<Number>] timed out after [<Number>] minutes as response was not received from Media Agent [<Number>] |
| 32:465 | No clients, copies or libraries are selected for pruning. Please check the required capabilities/associations for clients/copies/libraries OR there is no data available on the associated clients/copies/libraries. |
| 32:466 | <Number> of <Number> nodes offline |
| 32:467 | Online |
| 32:468 | Infinite |
| 32:469 | <Number> day(s), <Number> cycle(s) |
| 32:470 | Failed to get information for storage pool [<String>] |
| 32:471 | Disabled for write |
| 32:472 | Failed to resume suspended job(s) by the move partition job [<Number>]. Please resume the job(s) [<String>] manually. |
| 32:473 | The job(s) [<String>] are resumed by the move partition job [<Number>]. |
| 32:474 | Failed to resume suspended job(s) by the Config only move partition operation to the storage policy [<String>]. Please resume the job(s) [<String>] manually. |
| 32:475 | The job(s) [<String>] to the storage policy[<String>] are resumed by the config only move partition operation. |
| 32:476 | <Number> of <Number> drives offline |
| 32:477 | Storage Policy [<String>], Copy [<String>]: <Message> |
| 32:478 | Storage Policy [<String>], Copy [<String>]: <Message> Advice: <Message> |
| 32:479 | The virtual machine[<String>] is powered off by Power Management. |
| 32:480 | The virtual machine[<String>] is powered on by Power Management. |
| 32:481 | Failed to mark clients with no protected data. |
| 32:482 | The required media [<String>] for the job [<Number>] is not in the Library [<Stri
