System Requirements for Amazon FSx for NetApp ONTAP
Before you configure your storage virtual machine, verify that your system meets the following requirements.
Version and Firmware
Use the following version and firmware.
Product
ONTAP 9.16.1, 9.15.1, 9.14.1, 9.13.1, 9.12.1, 9.11.1
Open Replication
Protocols
Use one of the following protocols.
Array
Protocol
NetApp
  • iSCSI
  • CIFS, NFS
NetApp with Open Replication
  • iSCSI
  • CIFS, NFS
Ports
For snap-based operations, open port 443 (HTTPS) for communication between the NetApp server and CommServe computer, MediaAgent, access node or Remote Snap MediaAgent in your CommCell environment.
