Before you configure your storage array, verify that your system meets the following requirements.
Commvault tests major versions and some minor versions of firmware, so the best practice is to use the supported versions listed in this topic. If you encounter a problem with a minor version during an IntelliSnap operation, contact Commvault.
Licenses
Install the following licenses:
Snapshot Type |
License |
Snapshot |
SnapshotIQ License |
Protocols
Ensure that at least one of the following protocols is available:
Array |
Protocol |
Dell EMC Isilon/PowerScale |
CIFS, NFS, and NAS. Support for the CIFS protocol and the NFS protocol is for network share backups only. |
Version and Firmware
Ensure that you are using compatible versions and firmware:
Array |
Version and Firmware |
Support for OneFS 9.8 through 7.0 |
Software
Install the following software components:
Array |
Required Software |
None |
Ports
You do not need to open any port.
