Verify that your environment meets the system requirements for the Exchange Mailbox Agent.
For information about hardware recommendations for the index server and access nodes that are used for the Exchange Mailbox Agent operations, see Hardware Recommendations for the Exchange Mailbox Agent.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Operating system |
Processor architecture |
Microsoft Windows Server 2025 Editions |
All Windows-compatible processors are supported |
Microsoft Windows Server 2022 Editions |
Microsoft Windows Server 2019 Editions |
All Windows-compatible processors are supported. |
Microsoft Windows Server 2016 Editions |
Microsoft Windows Server 2012 Editions Server Core installations are not supported. |
Microsoft Windows Server 2012 R2 Editions Server Core installations are not supported. |
Hard Drive
Component |
Space required |
Job results folder |
256 MB |
Application
Microsoft Office 365 with Exchange Server
Microsoft Exchange Server Subscription Edition (Exchange Server SE)
Microsoft Exchange 2019 Server 64-bit, up to the most recent service pack
Microsoft Exchange 2016 Server 64-bit, up to the most recent service pack
Microsoft Exchange 2013 Server 64-bit, up to the most recent service pack
Software That Is Automatically Installed
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++
The following Redistributable Packages are installed automatically. Note that the Redistributable Package can co-exist with other versions of this software.
Microsoft Visual C++ 2013 Redistributable Package
Microsoft Visual C++ 2010 Redistributable Package
DISCLAIMER
