Verify that your environment meets the system requirements for the Exchange Public Folder Agent.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Operating system |
Processor architecture |
Microsoft Windows Server 2016 Editions |
All Windows-compatible processors are supported. |
Hard Drive
Component |
Space required |
Software |
1 GB |
Job results folder |
256 MB |
Log folder |
256 MB |
Application
Microsoft Exchange 2013 Server 64-bit, up to the most recent service pack
See the installation prerequisites for Exchange Server 2013.
Microsoft Exchange 2010 Server 64-bit, up to the most recent service pack
Microsoft Exchange 2007 Server 64-bit, up to the most recent service pack
Software That Is Automatically Installed
File System Agent
If not already installed, the Windows File System Agent or Linux File System Agent is installed. For more information, see the following:
On Windows computers, to successfully restore NAS data and Domino emails on the web, install a 32-bit file system proxy instance on a 64-bit computer.
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++
The following Redistributable Packages are installed automatically. Note that the Redistributable Package can co-exist with other versions of this software.
Microsoft Visual C++ 2013 Redistributable Package
Microsoft Visual C++ 2010 Redistributable Package
DISCLAIMER
