Before you configure the storage array, verify that your environment meets the system requirements.
Licenses
Install the following licenses.
Array |
Snapshot Type |
License |
Hitachi Vantara VSP using CCI Engine |
ShadowImage |
ShadowImage |
Thin Image |
Thin Image |
Hitachi Targetless Snap (CCI) (Deprecated) Engine |
Thin Image |
Thin Image |
Version and Firmware
Use the following version and firmware.
Array |
Version and Firmware |
*Supported through Field Certification. Contact your Software Provider or Professional Services to see if the specific FCoE can be supported.
Support for HTI and HTIA Snapshots
Array |
VSP 5000 |
VSP E Series |
VSP F/G Series |
VSP One Block |
HTI |
Yes |
Yes |
Yes |
No |
HTIA |
Yes |
No |
No |
Yes |
Protocols
Use one of the following protocols.
Array |
Protocol |
Software
Install the following software.
Array |
Required Software |
Hitachi Vantara VSM or GAD |
Remote Snap MediaAgent |
Ports
You do not need to open any specific port.
