Deprecated
This engine is deprecated from the Commvault software in Commvault Platform Release 2023 (11.30).
See End-of-Life, Deprecated and Extended Support - Features for information about deprecated features.
Before you configure your storage array, verify that your environment the following requirements.
Licenses
Install the following licenses.
Snapshot Type |
License |
Snapshot (NEC DynamicSnapVolume) |
Replication (NEC DynamicDataReplication) |
Version and Firmware
Use the following versions and firmware.
Array |
Version and Firmware |
NEC |
NEC M-Series with Storage Control Software version 087C |
Protocols
Use one of the following protocols.
Array |
Protocol |
NEC |
Fibre Channel |
Software
Install the following software.
Arraye |
Required Software |
NEC |
ControlCommand version 9.3.006 on the client computer |
Ports
You do not need to open any specific port.
