Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses:
Snapshot Type |
License |
Snapshot |
None |
Version and Firmware
Ensure that you are using compatible versions and firmware:
Array |
Version and Firmware |
Pure |
*To avoid snapshot creation on the temporary volumes that gets created as part of Commvault snap operations, disable the snapshot schedule on the pgroup-auto protection group.
Protocols
Ensure that at least one of the following protocols is available:
Array |
Protocol |
Pure |
Fibre Channel iSCSI |
Software
Install the following software components:
Array |
Required Software |
Pure |
None |
Ports
For the REST API, the source clients, proxy computer, and the Remote Snapshot MediaAgent access the management IP of the array using port 443 (HTTPS).
