Adding Additional Mount Paths to an Existing Air Gap Protect Library
You can add an additional mount paths to an existing Air Gap Protect library.
  1. From the CommCell Browser, expand Storage Resources > Libraries.
  2. Right-click the appropriate library, and then click Add Mount Path.
    The Add Mount Path dialog box appears.
  3. In the General tab, select the following:
    1. From the MediaAgent list, select the MediaAgent that must be used to access the library.
    2. From the Location list, select a Air Gap Protect location.
      Recommended: Choose a location nearest to the MediaAgent.
  4. Click OK.
The new mount path is added to the Air Gap Protect library.
