Disabling the Double-Click Message Recall from a Stub
By default, users can recall a message when they double-click a stub. However, you can disable this option.
  1. On the client where the agent is located, disable user impersonation by adding the DisableDoubleclickRecall additional setting as shown in the following table.
    For instructions about adding the additional setting from the CommCell Console, see Adding or Modifying Additional Settings from the CommCell Console.
    Property
    Value
    Name
    Category
    iDataAgent\CVExMetadata
    Type
    Integer
    Value
    1
  2. Run an archiving job.
    Recalling messages by double-clicking the stub is disabled.
