Setting the Java Path for Oracle Data Masking
Before you can manage your data masking policies, you need to specify the Java home path on the client that contains the instance that you want to mask.
  • On the Oracle source and destination client computers, add the sCV_JAVA_HOME additional setting for data masking as shown in the following table.
    For instructions about adding additional settings from the CommCell Console, see Adding an Additional Setting from the CommCell Console.
    Property
    Value
    Name
    sCV_JAVA_HOME
    Category
    OracleAgent
    Type
    String
    Value
    The Java home path where you installed Java. Include the directory path to the folder that is before "bin".
