Determining the Network Topology for HyperScale Edge
Determining the network topology is a crucial first step that can affect nearly every part of the HyperScale Edge deployment in your environment.
HyperScale Edge software leverages several technologies that are critically dependent on a fast and stable network connection. Due to that, there are guidelines on how the network should be configured to ensure that the appliance is stable and meets the performance expectations.
Important
Several pre-defined topologies have been validated and built into the software. These validated topologies are explained below.
If the network topology in your environment is not listed here, or if you are not sure of the topology that is required for your environment, contact your Commvault Cloud representative for assistance.
Answering the following questions will help to determine a recommended topology:
  • Do you require network redundancy?
  • Do you have a dedicated non-routable backup network?
  • Do you require the appliance to be connected to multiple vLANs?
Use the following selection guide to determine the topology required for your environment:
Require Network Redundancy
Have dedicated non-routable backup network
Require multiple VLANs connected to the appliance
Recommended Topology
No
No
No
Basic topology
Yes
No
No
Bonded topology
No
No
Yes
VLAN topology
Yes
No
Yes
Bonded VLAN topology
Considerations
For proper operations, the HyperScale Edge node require connectivity to the following networks:
  • Data protection network, which transfers data to and from the clients being protected and connect to the CommServe server. This will require a minimum of at least one dedicated 10 GbE network connection.
  • Optional Management network which is used only when the data protection interfaces are non-routable, and an alternative interface must be used for management.
Consider the following while determining your network topology:
  • All HyperScale Edge nodes in a single storage pool, must reside in the same location. Spanning multiple locations over a WAN is not supported.
  • Commvault HyperScale X node within a single pool are not required to be connected to the same switch. However, steps should be taken to minimize latency and ensure sufficient bandwidth is available for uplinks. Additional latency or bandwidth restriction can result in reduced performance, and in extreme cases, instability.
Consider the following when planning for large-scale deployments:
  • When sizing inter-switch links, assume that HyperScale Edge node will require a minimum of 20 GBPS bandwidth.
