Enabling Autodiscovery of Users for OneDrive for Business
All users that belong to the user groups that you add (including users that are automatically added to the user groups) are included in backups of the app.
  1. From the Command Center navigation pane, go to Protect > Microsoft 365.
    The Microsoft 365 Overview page appears.
  2. On the Apps tab, click the app to add the user group to.
    The app page appears.
  3. On the Content tab, click Add, and then click Add user group.
    The Add user group dialog box appears.
  4. In the User group name box, type a name for the user group.
  5. Complete one of the following steps to add users to the user group:
    • On the Users tab, click Add user. Select the users you want to add, and then click Add.
    • On the (.*) Regex patterns tab, click Add pattern. In the Regular expression box, type a regular expression or wildcard pattern, and then click Add.
      You can enter multiple regular expressions or wildcard patterns.
  6. Click Save.
To automatically discover new users, back up the OneDrive for Business app.
