HPE 3PAR StoreServ for snapshot storage
Commvault Cloud supports HPE 3PAR StoreServ for snapshot storage.
The following requirements and support apply to the following array types:
  • HPE 3PAR StoreServ
  • Primera
  • HPE Alletra 9000 series
  • HPE GreenLake for block storage array
Support
Workloads
The following workloads are supported:
  • Db2
  • Db2 MultiNode
  • Exchange Database
  • Microsoft Hyper-V
  • Microsoft SQL Server
  • MySQL
  • Notes Database
  • Oracle
  • Oracle RAC
  • PostgreSQL
  • SAP for Oracle
  • SAP HANA
  • Sybase
  • Linux file system
  • VMware
  • Windows file system
Version/firmware
HPE 3PAR StoreServ
For 3.3.1 GA and more recent versions, because of a 3par limitation, aged snapshots with child snapshots might not be deleted on the array.
  • 3.3.2.159 (MU1)
  • 3.3.1.648 (MU5)
  • 3.3.1.410 (MU2) + P30, P32
  • 3.3.1.269 (MU1) + P08, P14, P17
  • 3.2.2.709 (MU6)
  • 3.2.2.390 (EMU2)
  • 3.2.2 (MU4)
  • 3.2.2
  • 3.2.1 (MU3)
  • 3.2.1 (MU2)
  • 3.1.2 (MU3)
  • 2.3.1 (MU4)
HPE Primera
  • 4.6.1: Set the SMIS server port to 5989 and enable the Use secure connection to SMIS Server option.
  • 4.5.15.9
  • 4.5.7.8
  • 4.4.1.7
  • 4.3.3.2
  • 4.2.1
  • 4.0.1.3+1 (snapshot only)
HPE Alletra 9000 Series
  • 9.6.1: Set the SMIS server port to 5989 and enable the Use secure connection to SMIS Server option.
  • 9.5.21
  • 9.5.18
  • 9.5.15
  • 9.5.7
  • 9.3.3
  • 10.4.0: Replication for this array version is not supported by Commvault Cloud due to the behavioral changes done by HPE in virtual volume sets and RCG.
  • 10.3.0
  • 10.2.0: iSCSI supported only on Linux and VMware.
Protocols
  • Fibre channel
  • iSCSI: For HPE Alletra 9000 series, only supported for firmware versions 9.5.15 and more recent.
Requirements
Licenses
  • For all array and snapshot types: Virtual copy
  • For Thin provisioning a snapshot clone on HPE 3PAR StoreServ: Thin Provisioning (4096G)
Ports
Open port 5989 for HTTPS and port 5988 for HTTP between the Commvault Cloud control plane and the storage array and between the Backup Gateway and the storage array.
Snapshot names
HPE 3PAR StoreServ/Primera/HPE Alletra 9000 series/HPE Greenlake for block
  • Configuration: Default
  • Naming convention: SP_2_JobID_SnapID
    • SP_2: Constant value
    • Job ID: A unique ID assigned to each snapshot backup by the Commvault Cloud software.
    • SnapID: The snapshot ID created by the Commvault Cloud software.
  • Example: SP_2_1508_925
