Modify the encryption settings for Air Gap Protect
You can modify the cipher or the key management server for Air Gap Protect storage. You can also disable encryption. By default, Air Gap Protect is encrypted with the AES-256 cipher.
To modify encryption settings, follow these steps:
  1. From the Command Center navigation pane, go to Storage > Air Gap Protect.
  2. Click the storage.
  3. On the Configuration tab, in the Encryption tile, specify the encryption settings.
