Commvault Cloud supports key workloads and features for Air Gap Protect.
Supported Azure features
| Feature | Supported |
| Azure ExpressRoute | Yes, with no additional configuration in Commvault Cloud |
| Azure Private Link | Yes, with additional configuration in Commvault |
Supported Commvault features
| Feature | Frequent access storage | Infrequent access storage | Archive |
| Archive storage | No | No | No |
| Auto recovery | Yes | Yes | No |
| Auxiliary copy source | Yes | No | No |
| Cleanroom recovery | Yes | Yes | No |
| Disaster recovery | Yes | Yes | No |
| Primary copy | Yes | Yes (can't be a source for auxiliary copies) | Yes (can't be a source for auxiliary copies) |
| Secondary copy | Yes | Yes | Yes |
| Threat Scan | Yes | Yes | No |
| Threatwise | N/A | N/A | No |
| Space reclamation | Yes | Yes | No |
| Data verification | Yes | Yes | No |
Space reclamation is supported for Air Gap Protect storage on Azure, AWS, OCI, and Google Cloud Storage when fragmentation exceeds 30%.
For Air Gap Protect on Azure, you can run a space reclamation job using either an on-premises Backup Gateway or a Backup Gateway deployed in the same cloud region.
For Air Gap Protect on AWS, OCI or Google Cloud Storage, the space reclamation job requires a Backup Gateway deployed in the cloud and located in the same region as the configured storage.
Not supported
- CommCell migration
