System Requirements for Azure SQL Database Backups Using a Backup Gateway
Verify that your environment meets the system requirements to configure Azure SQL database backups using a backup gateway.
Commvault Software
  • Verify that the SQL Server Agent is installed on the backup gateway.
Network Requirements
  • Verify that the following ports are open on the backup gateway that has access to the Azure cloud:
    • 443 to management.azure.com
    • 1433 to *.database.windows.net
Access Node Operating System Requirements
For restoring an on-premises backup to the Azure cloud, install the SQL Server on the access node.
The operating system of the access node can be either Red Hat Enterprise Linux or Windows.
Important
Use the most recent version of the operating system that is listed. The Commvault Cloud software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault Cloud software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Linux
For information about SQL Server on Linux, see Microsoft guidelines for SQL Server on Linux on the Microsoft website.
Important
The following operating systems are supported only for the following versions of Microsoft SQL Server. Microsoft has a known issue on Microsoft SQL server 2017 cumulative updates 19 and 20.
  • Microsoft SQL Server 2017 cumulative update 18 or lower
  • Microsoft SQL Server 2017 cumulative update 21 and higher
  • Microsoft SQL Server 2019 cumulative update 5 and higher
  • Microsoft SQL Server 2022
Operating System
Applies to SQL Server Version
Red Hat Enterprise Linux 8.0 to 8.6
SQL Server 2022, SQL Server 2019, SQL Server 2017
Red Hat Enterprise Linux 7.7 to 7.9
SUSE Enterprise Linux Server v15 SP1 - SP4
SUSE Enterprise Linux Server v12 SP3 - SP5
Ubuntu 20.04 LTS
Ubuntu 18.04
Ubuntu 16.04
Windows
Operating system
Processor architecture
Microsoft Windows Server 2025 Editions
All Windows-compatible processors are supported
Microsoft Windows Server 2022 Editions
Microsoft Windows Server 2019 Editions
Microsoft Windows Server 2016 Editions
Microsoft Windows Server 2012 Editions
Microsoft Windows Server 2012 R2 Editions
Microsoft Windows 10
Microsoft Windows 7 Editions
Microsoft Windows Server 2008 R2 Editions
SQL Server User Accounts and Authentication
This section describes the supported user accounts and authentication methods for Azure SQL Database.
Azure SQL Database supports the following types of user accounts for data protection:
  • Azure SQL Server Admin account: Serves as the server administrator for the Azure SQL instance.
  • Microsoft Entra Password: Manages user accounts, security settings, and permissions for users who access the Azure SQL Database.
    • Ensure that login names for user accounts are in UPN (User Principal Name) format.
      Multifactor authentication is not supported.
    • Install the Microsoft Active Directory Authentication Library (ADAL) for Microsoft SQL Server or SQL Server Management Studio (SSMS) on the access node.
  • Database user: A database-level account used to configure minimal permissions for data protection operations. This authentication type requires the following minimum permissions:
    Server-Level Roles
    Database-Level Roles
    None
    • db_owner on the database being backed up
    • dbmanager on the master database
      This role is required to delete the temporary transactionally consistent database copy during the backup operation and is required for the restore operation to create the database.
The following authentication methods are supported:
  • Microsoft Entra Managed Identity: Provides a secure, credential-less method for Azure resources to authenticate and authorize with other services that support Microsoft Entra authentication.
    Both system-assigned and user-assigned managed identities are supported.
    For more information, see Enabling Microsoft Entra Managed Identity Authentication.
  • Microsoft Entra Service Principal: Provides a secure method to authenticate and access Azure SQL resources without using individual user credentials.
    For more information, see Enabling Microsoft Entra Service Principal Authentication.
Supported TLS Version
The software supports database protection operations on TLS version 1.2.
