System Requirements for the HPE Nimble Storage / Nimble dHCI / HPE Alletra 6000 Series / HPE Alletra 5000 Series Storage Array
Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
Array
Snapshot Type
License
HPE Nimble Storage/ Nimble dHCI/ HPE Alletra 6000 Series/ HPE Alletra 5000 Series
Snapshot
None
Version and Firmware
Use the following version and firmware.
Important
  • Before you upgrade the HPE Nimble Storage firmware, move all snapshots to a secondary storage using the backup copy operation because array nodes will no longer be accessible using old interfaces.
  • Before you merge HPE Nimble Storage arrays to one group, move all snapshots to a secondary storage using the backup copy operation.
Array
HPE Nimble Storage/Nimble dHCI
  • 6.1.x, 6.0.x, 5.2.x, 5.1.x, 5.0.x, 4.x, 3.x
    5.0.2.x, 5.0.1.x and 4.4.1.x are not supported.
  • AF-Series, CS-Series, HF-Series, and Nimble dHCI
  • 6.1.x, 6.0.x
  • 6.1.x
Protocols
Use one of the following protocols.
Array
Protocol
HPE Nimble Storage/Nimble dHCI/HPE Alletra 6000 Series/ HPE Alletra 5000 Series
Fibre Channel
iSCSI
Software
Install the following software.
Array
Required Software
None
Ports
Open the following ports between the Backup Gateway and the storage array:
  • REST - 5392
  • SOAP - 5391
