System Requirements for SAP for Oracle
Verify that your environment meets the system requirements for SAP Oracle.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault Cloud software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault Cloud software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
SAP BR*Tools 7.40 and Higher Versions for Oracle 12c (V12.2), Oracle 18c, Oracle 19c
  • For Oracle 12.2, you must install BR*Tools 7.40 patch level 32 or a more recent version. For information about additional SAP requirements with Oracle 12.2, see SAP Note 2470660.
  • For Oracle 18c, you must install BR*Tools 7.40 patch level 37 or a more recent version. For information about additional SAP requirements with Oracle 18c, see SAP Notes 2705272, 2763733, and 2660020.
  • For Oracle 19c, you must install BR*Tools 7.40 patch level 40 or a more recent version. For information about additional SAP requirements with Oracle 19c, see SAP Notes 2799900, 2817074, and 2763733.
AIX
Data protection on Logical Partitioning (LPAR) and Workload Partitioning (WPAR) is supported.
Operating system
Processor architecture
AIX 7.3 64-bit
TL 00 SP1
PowerPC
AIX 7.2 64-bit
TL 09 SP 1, TL05
PowerPC
AIX 7.1 64-bit
TL03 SP4
PowerPC
HP-UX
Operating system
HP-UX 11i v3 (11.31)
Itanium
Linux
Important
If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
Operating system
Oracle Linux 9.x with glibc 2.34.x or a more recent version
  • x86
  • x64
  • Compatible processors
Oracle Linux 8.x with glibc 2.17.x or a more recent version
  • x86
  • x64
Oracle Linux 7.x with glibc 2.17.x or a more recent version
  • x86
  • x64
Red Hat Enterprise Linux 9.x with glibc 2.34.x
  • x86
  • x64
Red Hat Enterprise Linux 8.x with glibc 2.28.x
  • x86
  • x64
Red Hat Enterprise Linux 7.x
  • x86
  • x64
SuSE Linux 12 SP1 Enterprise Server
  • x86
  • x64
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x and higher
  • x86
  • x64
  • PowerPC
Oracle Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system
Oracle Solaris 11.2 SRU 5.5
  • x64
  • Sparc T/M series
Oracle Solaris 10 Update 11
  • x64
  • Sparc T/M series
Windows
Operating system
Microsoft Windows Server 2022 Editions
All Windows-compatible processors are supported
Microsoft Windows Server 2019 Editions
Microsoft Windows Server 2016 x64 Editions
Microsoft Windows Server 2012 R2 Editions
Microsoft Windows Server 2012 x64 Edition
SAP BR*Tools 7.20 (42), 7.20 (40), 7.40(46), 7.40 (14) for Oracle 12c (V12.1), 11g (R1, R2, or a More Recent Version)
AIX
Operating system
AIX 7.2 64-bit
PowerPC
AIX 7.1 64-bit
PowerPC
HP-UX
Operating system
Itanium
HP-UX 11i v1 (11.23)
Itanium
Linux
Important
Operating system
  • x86
  • x64
  • x86
  • x64
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x or a more recent version
You must have Oracle v11.2.0.4 or a more recent version, with BR*Tools v7.20 (40) or v7.40 (14).
  • x86
  • x64
  • PowerPC
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) with glibc 2.19.x
  • x86
  • x64
  • PowerPC
Solaris
Operating system
Solaris 11.x
  • x64
  • Sparc T/M series
Solaris 10 Update 6 or equivalent
Sparc T/M series
x64
Windows
Operating system
Microsoft Windows Server 2016 Editions
Microsoft Windows Server 2012 Editions
Server Core installations are not supported.
SAP BR*Tools 7.20(42) or Higher for Oracle 10g (R1, R2 or a More Recent Version)
AIX
Operating system
AIX 7.2 64-bit
PowerPC
AIX 7.1 64-bit
PowerPC
HP-UX
Operating system
Itanium
Itanium
Linux
Important
Operating system
  • x86
  • x64
  • x86
  • x64
  • x86
  • x64
  • PowerPC
Solaris
Operating system
Solaris 11.x
  • x64
  • Sparc T/M series
x64
Sparc T/M series
Windows
Operating system
Nano Servers are not supported.
Hard Drive
Component
Space required
Software
2 GB
Job results folder
256 MB
Log folder
256 MB
Memory (RAM)
2 GB or more
Clustering
If clustering is supported by the operating system, you can install the software on a cluster.
Software That Is Automatically Installed
File System Agent
  • The following file system agents are automatically installed during the installation of this software:
    • Windows file system
    • AIX file system
    • HP-UX file system
    • Linux file system
    • Solaris file system
  • The operating system must have been installed with at least the user level software option selected.
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Microsoft Windows 10 and Microsoft Windows Server 2016, because these versions have the Universal C Runtime already installed.
  • KB2919355
  • KB2939087
  • KB2975061
  • KB2999226
DISCLAIMER
Certain third-party software and service releases (together, "Releases") may not be supported by Commvault. You are solely responsible for ensuring Commvault products and services are compatible with any such Releases.
