The following are the requirements for the IBM i File System Agent 1-Touch disaster recovery by using Commvault VTL:
Operating System |
Architecture |
IBM i |
IBM i 7.5 |
Power PC |
IBM i 7.4 |
Power PC |
IBM i 7.3 |
Power PC |
IBM i 7.2 |
Power PC |
IBM i 7.1 |
Power PC |
IBM i 6.1 |
Power PC |
Disk Space
Client
There are no additional space requirements for the source client.
Target
The destination client must meet the following requirements:
The target system ASP must be the same size or larger than the source disk.
The target system must have the same IASP set and they must be the same size or larger than the source disk.
Proxy
There are no additional space requirements for the proxy computer.
VTL Configuration
Commvault virtual tape library should be configured and zoned to the source IBM i client and destination IBM i clients.
Miscellaneous
Network
TCP/IP services configured on the IBM i computer.
No firewall settings between the IBM i computer and the access node computer.
IPv6 is not supported.
User/SYSTEM Startup Script
Use the following guidelines and notes for the startup script that is specified in SYSTEM VALUE QSTRUPPGM:
The name is QGPL/<Program name>
The initial DR restore operation restores the *IBM provided libraries, QSYS2+QUSRSYS+QGPL libraries. If the IBM i client’s start-up program is located in user libraries, then you must configure the library paths under the Additional libraries option, available in additional subclient properties of the DR subclient. Otherwise, the destination IBM i client does not IPL properly during disaster recovery.
Disclaimer Third-party maintenance (minor) releases or service packs that are supported by the Commvault software may not be listed in our System Requirements. When possible, Commvault provides information on any known issues related to these minor releases or service packs. In some cases, these minor releases or service packs affect how the Commvault software works. Commvault software may experience changes in functionality as the result of the third-party minor release or service pack. These changes are beyond the control of Commvault. Platforms that are supported in the current version of Commvault software may not be supported in earlier versions of the software. Contact your software provider to ensure that third-party minor releases or service packs are compatible with the Commvault software. Additional considerations regarding minimum requirements and End-of-Life policies from third-party vendors also apply.
