Creating Multiple Mount Paths in the Same Volume
For UNC mount paths, avoid adding mount paths that utilize the same disk as separate volumes as this can lead to incorrect storage calculations.
For example, \\Computer_name\share1 and \\Computer_name2\share2 are UNC mount paths that are using the same volume and both the mount paths will report having X amount as the total capacity leading to an incorrect 2X calculation. For example if the volume size is 4 TB, both the mount paths will report 4 TB as total capacity, leading to an incorrect calculation of 8 TB as total capacity.
