Cross-Hypervisor Restores (Virtual Machine Conversion)
From backups performed with the Virtual Server Agent, you can perform a full VM restore and convert the source virtual machine to be used with a different hypervisor.
You can perform conversions from streaming backups, from secondary copies, or, for hypervisors that support IntelliSnap, from IntelliSnap backup copies. You can--t perform a conversion from a Snap copy.
The following table shows the cross-hypervisor restores that are supported by Commvault.
DESTINATION
Alibaba Cloud ECS
Amazon EC2
Azure
Azure Stack Hub
Azure Local
Google Cloud
Hyper-V
Nutanix AHV
OpenStack
Oracle VM
Oracle Cloud Infrastructure
Red Hat Virtualization
VMware
SOURCE
Amazon EC2
Yes
Yes
Yes
Azure
Yes
Yes
Yes
Yes
Yes
Yes
Azure Classic
Yes
Azure Stack Hub
Yes
Azure Local
Yes
Yes
Yes
Yes
Yes
Google Cloud
Yes
Hyper-V
Yes
Yes
Yes
Yes
Yes
Nutanix AHV
Yes
Yes
Oracle VM
Yes
Yes
VMware
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
