Modifying the Web Console URL for Edge Monitor for Laptop Backup
By default, when the Web Console is installed on multiple computers, the URL link provided in the Edge Monitor points to the computer where the Web Console was installed first.
When upgrading multiple Web Console computers to the current release, the URL link in the Edge Monitor will be updated to point to the computer that was upgraded first. This could mean that the new URL may not be from the original Web Console computer (which got installed first).
You can change the default Web Console URL that will be used with Edge Monitor and Explorer Plug-In.
  • To the client computer or client computer group, add the sCustomWebConsoleUrl additional setting as shown in the following table.
    For instructions about adding the additional setting from the CommCell Console, see Add or Modify an Additional Setting.
    Property
    Value
    Name
    Category
    JobInfo
    Type
    String
    Value
    Add the Web Console URL in the following format:
    http://<fully qualified name of the Web Console>/webconsole/clientDetails/fsDetails.do?clientName=CLIENTNAME
    For example, http://testwebconsole.company.com/webconsole/clientDetails/fsDetails.do?clientName=CLIENTNAME
