Schedule or immediately run an archive job.
Select Archive Type
Incremental
Specifies the job as an Incremental archive, which backs up only that portion of the data that is new or has changed since the last full archive.
Archive Preview
Select Script to view the criteria and order for selecting archived data.
Select Data to view the data that the Commvault software will archive. Type the Oracle user credentials to view the data.
Click the Preview button to view the script or data.
Job Initiation
Immediate
Specifies that this job will run immediately.
Schedule
Specifies that this job will be scheduled. Click Configure to specify the schedule details.
Advanced
Click to select advanced backup/archive options, such as create a new index, start new media, and mark media as full.
Save As Script
Click to open the Save As Script dialog, which allows you to save this operation and the selected options as a script file (in XML format). The script can later be executed from the Command Line Interface using qoperation execute command.
When you save an operation as a script, each option in the dialog will have a corresponding XML parameter in the script file. When executing the script, you can modify the value for any of these XML parameters.
