Setting Options for a Subclient with Auto-mount Contents
You can set options for the auto-mount process that runs when an auto-mounted NFS export subclient is backed up. The -o flag options are supported.
  1. From the CommCell Browser, go to Client Computers > client > Linux File System > backup_set.
  2. Double-click the subclient.
  3. Click Advanced.
  4. On the Auto Mount Options tab, in the Mount Options box, enter your -o flag option.
    For example, if the auto-mount process should mount the NFS export as read-only, enter ro.
    If you have multiple options, enter the options as a comma-separated list.
  5. Click OK.
