Setting Up Alerts for Jobs Using a Schedule Policy
You can configure alerts to generate automatic notifications when the properties of the associated schedule policy are modified.
Use the following steps to create a schedule policy and configure its alert:
  1. From the CommCell Browser, navigate to Policies.
  2. Right-click Schedule Policies and click New Schedule Policy.
  3. Type a name for the schedule policy in the Name box.
  4. Select the type of schedule policy from the Type list.
  5. Click the Associations tab and select the entities that you want to associate with the schedule policy.
  6. Click the Alert tab and click Add Alert.
  7. From the Add Alert Wizard dialog box, select the required threshold and notification criteria and click Next.
  8. Select the way in which the alert is to be sent to its intended recipient and click Next. For example, you can click Select [Email] for notification to send the alert as an email.
  9. Select the CommCell users and/or user groups that will receive the alert and then click Next.
  10. Review the options that you selected in the Summary tab and click Finish.
You must configure new alerts after cloning a schedule policy. The associated alerts are not replicated during the cloning process.
