You can share a mount path with multiple Media Agents for Air Gap Protect.
From the CommCell Browser, expand to Storage Resources | Libraries | <Library>.
Right-click the mount path that you want to share with another MediaAgent, and click Share Mount Path.
Select the mount path and click Share.
From the Share Mount Path dialog box, perform the following:
Select the MediaAgents that you want to share the mount path.
Click Ok to confirm your selection.
The mount path will be shared and the selected MediaAgents will have read-write access to the mount path.
