System Requirements for the Pure Storage FlashArray Array
Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses:
Snapshot Type
License
Snapshot
None
Version and Firmware
Ensure that you are using compatible versions and firmware:
Array
Pure
  • Product
    • Pure Storage FlashArray
    • Cloud Block Store
  • Purity version 6.9.2, 6.8.9, 6.7.2, 6.5.2, 6.4.3, 6.3.6, 6.2.14, 6.1.10, 6.1.3, 5.3.10, 5.3.8, 5.3.6, 5.3.2, 5.2.3, 5.1.6, 5.1.1, 5.0.1, 4.10.9, 4.10.7, 4.9.6, 4.8.10, 4.8.7, 4.7.5, 4.6.11, 4.5.5, 4.1.1
  • REST API version 2.16, 1.4
Protocols
Ensure that at least one of the following protocols is available:
Array
Protocol
Pure
Fibre Channel
iSCSI
Software
Install the following software components:
Array
Required Software
Pure
None
Ports
For the REST API, the source clients, proxy computer, and the Remote Snapshot MediaAgent access the management IP of the array using port 443 (HTTPS).
