Two-Way Sync Using the UNIX File System Agent File System Agent
Two-way sync feature can be implemented by using the UNIX File System Agent.
Install Requirements
Install the File System Agent on the source and destination computers.
High-Level Process Flow
  • Data from the source client is backed up to the destination client by the File System Agent using scheduled backups.
  • Data on the destination client is backed up by using the File System Agent. The data modified on the destination client is included in the scheduled backups.
  • Modified data on the destination client is restored to the source client. The data is only restored if the data on the source client is older than the data on the destination client.
