Using Region-Based Backups for SAP HANA System Replication
In an SAP HANA system replication setup, if the primary and secondary nodes are located in different workload regions, you can configure the backups to use the storage which is local to the current primary (source) node workload region. Using a region-based backup plan avoids data transfer over a WAN and enables faster backups and restores.
When the backup job starts from an SAP HANA client, it uses the storage belonging to the workload region defined for the SAP HANA client. If the primary node fails, the secondary node replication client becomes the primary node and takes over the backup operation. In this case, the backup job automatically considers the storage that is defined in the backup plan based on the workload region.
When a multi-region backup plan is assigned to an SAP HANA non-replication instance, the backup job will automatically select the storage based on the workload region defined for the server.
Create a multi-region backup plan.
  1. Assign workload region to both the SAP HANA Clients.
  2. Create a Pseudo Client and assign the backup plan to it.
