A mount path can be added to a Commvault HPE Catalyst Library, once it is created.
Create a Commvault HPE Catalyst Library as described in XML Files - Creating a Commvault HPE Catalyst Library.
Download the Add_HPECatalystDevice.xml file and save it on the computer where the command is run.
Open the XML file.
Change the XML parameters.
Attribute
mediaAgentName
The name of the MediaAgent.
DeviceType
Must be set to 59.
baseFolder
This is an optional attribute. You can specify the name of the base folder or else standard naming convention will be used to name the base folder.
deviceAccessType
Read 4
Read and Write 6
Read and Write, Preferred Access 14
Run the following command from the <software installation directory>\Base folder to execute the xml.
qoperation execute –af Add_HPECatalystDevice.xml
