Verify that your environment meets the system requirements for the S3 Vault.
| Component | Requirements |
| Supported only on deduplication-enabled plans | The primary copy must have dedupe enabled. |
| S3 endpoint (MediaAgent) | Red Hat Enterprise Linux (RHEL) 8.3 to 9.5 Rocky Linux 8.3 to 9.5 *At least one Linux MediaAgent is required on the plan. |
Network Requirements
The S3 Vault service uses the following ports for CVDotNetContainer service:
| Port | Protocol |
| 5005 | HTTP |
| 5006 | HTTPS |
License Requirements
S3 Vault is metered using standard capacity licenses based on the cumulative front-end capacity of the ingested data.
Installed Package Requirements
The following packages are installed on the Linux S3 endpoints:
- S3 Vault Service (CVS3Service)
- DotNet Container Service (CVGxDotNetContainer)
- StorageAccelerator
- File System
