HyperScale X nodes can be deployed using a basic topology with a dedicated management network.
In this topology:
- One interface is configured for CommServe Registration, which is used for data protection traffic and communication with the CommServe server.
- One interface is configured for the Storage Pool network, which is used exclusively for communication and replication between HyperScale X nodes.
- One dedicated 1 GbE interface is configured for the Management network, which is used for management communication, such as accessing DNS services and communicating with the CommServe server.
Use this deployment method when the data protection network is non-routable or isolated, and a separate management interface is required for administrative communication.
Use this procedure to deploy the HyperScale X software using the Hyperscale ISO 3.2312 or higher version.
During the setup process, ensure that the following passwords do not contain the special characters
',",/,~, or\:- Root password
- Restricted shell user (
cvbackupadmin) password - CommServe connection password
When deployment is complete:
- Password-based root access is disabled.
- Firewall protection is enabled.
- Ransomware protection is enabled automatically.
If you plan to connect to an existing CommServe server, gather the following information before you begin:
- The fully qualified domain name (FQDN) of the CommServe server.
- The credentials of an administrative user.
- Confirmation that TCP ports 8400 and 443 are open between the nodes and the CommServe server.
Verify the requirements needed for setting up the Basic Topology With Management Network.
Keep the network names and IP addresses listed in the Network Requirements section of Basic Topology With Management Network handy before you start the configuration. This will help you to accurately add the details during the deployment.
The Managed Service Provider (MSP) administrator or the tenant administrator performing the installation must obtain the authorization code.
For instructions on activating the authorization code, see User Administration and Security.
Verify that DNS records have been created and validated for all nodes, as described in DNS Requirements and Validation for HyperScale X.
Verify that the management network is routable and can communicate with the required infrastructure services, including DNS and the CommServe server.
Verify that all nodes can communicate with each other on the storage pool network.
Log on to one of the nodes using the system console as described in Setting up a Static IP For IPMI. (Do not use PuTTy / SSH to setup the nodes.)
Launch the network configuration interface using the following command:
# hsxsetupThe Network Configuration page appears.
Configure the data protection interface as follows:
Click Configure interface.
From the Interfaces list, select one of the data protection interfaces. (For example, enpsf3 or enpsf5.)
Click CREATE.
From the Network Type list, select CommServe Registration.
Add the IP Address and Netmask in the respective boxes.
Configure the storage pool interface as follows:
From the Interfaces list, select one of the storage pool interfaces. (For example, enpsf4 or enpsf6.)
Click CREATE.
From the Network Type list, select Storage Pool. This interface will be used exclusively for communication and replication between the HyperScale nodes.
Configure the management interface as follows:
From the Interfaces list, select one of the management interfaces. (For example, enpsf1 or enpsf2.)
Click CREATE.
From the Network Type list, select Management. This interface will be used for all management related communication, such as connecting to the CommServe server, accessing the DNS server, etc.
Configure the DNS server(s) as follows:
In the Default Gateway box, add the IP address associated with the default gateway.
In the DNS Servers box, add the IP address associated with the DNS Server.
Click CONFIGURE.
Verify the network configuration and then click CONTINUE.
IP address and netmask for the data protection interface accurate.
IP address and netmask for the storage pool interface is accurate.
IP address and netmask for the management interface is accurate.
Hostname and serial number associated with the node is accurate.
Default gateway and DNS servers are accurately configured.
Click one of the following:
Click NO, EXIT to configure another node in the storage pool.
Click YES, CONTINUE if this is the last node in the storage pool.
The Setup Type page appears.
Click New storage pool setup and then click NEXT.
Select the nodes as follows:
Click the down arrow
at the top right area of the page to view a list of available nodes. -
Click and select the nodes that must be included in the storage pool.
Click NEXT.
Click NEXT.
Verify the summary for each node by clicking the tabs associated with each node. Ensure that the nodes are accurately configured and then click NEXT.
All nodes have identical information for the default gateway and DNS servers.
Add the following information:
In the Root password and Confirm password boxes, type a secure password for the nodes.
In the Storage pool name box, type a name for the storage pool associated with the cluster.
From the Time zone list, select the time zone in which the nodes are located.
In the Password for Restricted shell user - cvbackupadmin and Confirm cvbckupadmin password boxes, type a secure password for the cvbackupadmin user.
Click NEXT.
Check the status to ensure that all the nodes have a green status to indicate that the network settings is validated and accurate. Click NEXT.
Click Connect to existing CommServe, and then click NEXT.
The CommServe Credentials page appears.
In the CommServe hostname (FQDN) box, enter a fully qualified host name of the existing CommServe server that you are connecting to.
In the Auth-code box, enter the authorization code to connect to the CommServe server.
Click NEXT.
Click CLOSE.
