You can enable power management for a server group. The power management feature is automatically enabled for the cloud MediaAgent associated with the server group.
Verify that the cloud MediaAgent uses a fully qualified domain name (FQDN) or a static publicly accessible IP address.
Select the Auto-start services when OS starts checkbox for the cloud MediaAgent. For more information, see Viewing Services.
For the cloud MediaAgent in a Linux environment, verify that the dmidecode tool is available. For more information about the tool, see dmidecode.
From the navigation pane, go to Manage > Server groups. The Server groups page appears.
Click the server group. The server group page appears.
Click the Configuration tab.
in the Power management area, click Edit. The Edit power management dialog box appears.
Select Enable power management, and then select the Cloud account.
Click Save.
