You can enable power management for a server group that the cloud MediaAgents are associated to or for a specific cloud MediaAgent.
After you enable power management for a cloud MediaAgent, do not turn on or turn off the MediaAgent from the console that is provided by the cloud service provider.
Related Topics
Configure an alert that will notify you when the cloud MediaAgent is offline. For instructions, see Predefined Alert Criteria – Configuration – MediaAgents.
You can change the idle time after which the power management feature can turn off the cloud MediaAgent by using the Idle time (Minutes) for power managed cloud VMs parameter. For more information, see Media Management Configuration: Service Configuration.
