Can we protect data on non-global zones if the File System iDataAgent is installed only on the global zone?
Yes. We can protect file system data on non-global zones if the File System iDataAgent is installed only on the global zone. However, in order to enable consistent backups of application specific data on the non-global zones, you will need to install the corresponding application specific iDataAgent on the non-global zone.
How do we protect Sybase data on a non-global zone?
In order to enable consistent backups of Sybase data on a non-global zone, you need to install the Sybase agent on the non-global zone.
What folders, files and changes are created and performed when I install the agent?
Platforms |
Folders Created |
Files Created |
Other Changes |
AIX |
None |
None |
Create a link to libSybGalaxy.so under $SYBASE/$SYBASE_ASE/lib folder |
HP-UX |
None |
None |
Linux |
None |
None |
Solaris |
None |
None |
Windows |
None |
None |
Creates a link to the libSysGalaxy.dll file that is in the $SYBASE/$SYBASE_ASE/lib folder |
When does a non-full backup automatically get converted to a full backup?
A non-full backup is automatically converted to a full backup in the following situations:
First backup of the subclient.
Re-associating a subclient to another storage policy.
Promote a secondary storage policy copy that is not synchronized with a primary copy (for all the subclients of a storage policy).
If a backup job within the most recent backup cycle is pruned or disabled from a primary copy.
CommCell Console Migration operation.
When a Sybase database create time is changed since the last backup.
Are remote backup servers supported?
No. Remote Backup Servers are not supported. You can only change the backup server that is associated to a Sybase server instance from the available backup servers with in the Sybase server environment.
How are Transaction Logs truncated?
Truncation of transaction logs use the following rules:
The software truncates the transaction logs when a transaction log backup completes.
Transaction logs will be truncated every time a checkpoint is processed, if the database is in truncate mode.
If the log segments of a database are on a separate device from the data segments, then the transaction log backup automatically truncates the in-active part of the transaction log.
If the log segments of the database are on the same device as the data segments, the full backup automatically truncates the in-active part of the transaction log.
The physical size of the database device will not shrink. Logs are only logically truncated from the device.
Can we perform a table level restore?
Currently, table level restore for Sybase database is not supported. However, you can create a new database and restore your backup to this new database (target database). After the restore, you can truncate original table in the source database and replace this table with the table in the target database using bcp export/import commands.
Ensure that you have the latest full backup i.e., the backup prior to the corruption or loss of a table that you want to restore.
Use the following steps to restore a table:
From the CommCell Browser, navigate to Client Computers| <Client> | Sybase.
Right-click the <Instance>, point to All Tasks and then click Browse and Restore.
Click View Content in the Restore Options dialog box.
In the right pane of the window, select one or more databases that you wish to restore. Click Recover All Selected.
Select the Rename Databases check box and click Advanced.
Click the Options tab.
Click the Target Database column and type the new database name.
When you rename a database, make sure that the tables in the database are not referencing to or referenced by tables in any other databases.
Click OK in the Sybase Restore dialog box. A new database (target database) is created and restored with the latest backup.
Truncate the table that is corrupted in source database.
Example:
use db1 truncate table_abc -
Run the following command from the target database:
bcp db_name.owner.table_name out file_name -Y -U user_name -P password -S server_nameExample:
use db2 bcp db2.owner.table_abc out file1 -y -sa -pwd -SYB1 -
Run the following command from the source database:
bcpdb_name.owner.table_name in file_name -Y -U user_name -P password -S server_nameExample:
use db1 bcp db2.owner.table_abc in file1 -y -sa -pwd -SYBX -
Execute the query in source database to confirm that the table is successfully restored.
Can you backup Sybase IQ Data?
Yes. You can use File System Agent with Pre/Post Scripts to quiesce/shutdown and backup Sybase IQ data. You cannot use Commvault's Sybase iDataAgent to backup Sybase IQ data as the backup commands used for IQ are different from the commands used for Adaptive Server Enterprise (ASE) data backup.
You need to install the Commvault File System Data Agent for Unix and Windows before you backup Sybase IQ data.
Backup:
Use the following steps to backup Sybase IQ data:
Create a directory to store all your Sybase IQ backup data.
Example: /backup_Commvault -
Create scripts to backup Sybase IQ databases. Use the following commands to backup the Sybase IQ data:
BACKUP DATABASE backup-option... TO archive_device archive-option COMMENT stringExamples:
BACKUP DATABASE FULL TO '/backup_Commvault' SIZE 15000000 BACKUP DATABASE INCREMENTAL SINCE FULL TO '/backup_Commvault' SIZE 15000000 -
Create a subclient for Commvault's File System iDataAgent and add the content from /backup_Commvault directory.
Perform or Schedule regular backups for this subclient (which includes the Sybase IQ data from /backup_Commvault directory).
Restore:
You can restore the backup files from /backup_Commvault directory.
Use the following command to restore the Sybase IQ data:
RESTORE DATABASE 'database-name'
restore-option
FROM 'archive_device'Examples:
RESTORE DATABASE 'iqdemo'
FROM '/backup_Commvault'Can we load a master database while performing a Cross-Platform restore?
No. Sybase do not support loading a master database while performing a cross-platform restore.
Is cross-platform loading available for transaction dumps?
No. Cross-platform loading is only available for database dumps and not to the transaction dumps.
Can we restore from the transaction log backups?
Yes. You can restore the transaction logs along with the database to a specific point in time. The point in time should be in between the start and end point of a transaction log. Point in Time restore will restore the database followed by transaction logs restored until the point of time. The nearest database backup job before the point-in time will be picked up followed by one or more transaction log backups. The immediate transaction log backup after a Point in Time will be restored.
For example:
Let us assume that you have performed a Full backup (F1) and transaction log backup (L1) for the first time at 1 P.M. Subsequently you have performed L2 at 3 P.M. Later, you have performed L3, F2, L4,L5 etc at subsequent intervals. If you perform a point in time restore for the transaction log backups at 2 P.M, the Full backup (F1) along with the log backups of L1 and L2 (transaction log after point in time) will be restored.
We do not support the restores from the transaction log backups that are not truncated. Transaction log jobs picked for Point in Time restore should fall with in one backup cycle and not across job cycles.
You can perform a point of time restore of transaction logs for clients and CommServe on different time zones.
Can I schedule step-by-step restores?
No. You cannot schedule step-by-step restores.
Can we perform SQL Anywhere Backups and Restores using Sybase iDataAgent?
No. We currently support Sybase ASE for backups and restores. However, we can perform SQL Anywhere backups and restores using Commvault's file system iDataAgent with pre-post scripts. See Configuring Sybase SQL Anywhere, Performing SQL Anywhere Backups and Restoring SQL Anywhere Backups for more information on how to configure and perform SQL Anywhere backups and restores.
How do I get the size of the master database in the event of a disaster recovery?
In the case of a disaster recovery, use the QS_GetSybaseJobList QScript command to view and alter the size of the master database.
Usage:
qoperation execscript -sn QS_GetSybaseJobList -si "@i_clientName = 'clientname'" -si "@i_instanceName='instanceName'" -si "@i_startTime = 'starttime'" -si "@i_endTime = 'endtime'" -si "@i_databaseName = 'dbname'" si "@i_noTimeRestriction = '0 or 1'" si "@i_enableDateTimeFormat = '0 or 1'"|
Input Parameter |
Description of Parameter Values |
i_clientName |
The client name |
i_instanceName |
The instance name |
i_startTime |
The start time |
i_endTime |
The end time |
i_databaseName |
The database name |
i_noTimeRestriction |
By default only a 14 day difference between the Start and End date is allowed. Optionally set this to 1 to bypass this constraint. |
i_enableDateTimeFormat |
By default the time will be shown in EPOCH time format. To enable date-time format, set this value to 1. |
Output Parameter |
jobID |
The Job ID |
DatabaseID |
The database ID |
DatabaseName |
The database name |
BackupLevel |
The backup level |
backup_creation_time |
The time the backup was created |
logicalDeviceName |
The logical device name. |
physicalDevicePath |
The phsical device path |
DBSize_in_MB |
The size of the database in Big integer |
Master Database Example
F:\Program Files\CommVault\ContentStore\Base>qoperation execscript -sn QS_GetSybaseJobList -si "@i_clientName='sybserver4'" -si "@i_instanceName='S155syb4'" -si "@i_ startTime='07-21-2014 01:00:00'" -si "@i_endTime='07-21-2014 15:00:00'" -si "@i_databaseName = 'master'" -si "@i_noTimeRestriction = '0'" -si "@i_enableDateTimeFormat = '1'"QScript[QS_GetSybaseJobList] CS[leonard64] DB[CommServ] SP[QS_GetSybaseJobList]
Qscript Output:
jobid DatabaseId DatabaseName BackupLevel backup_start_time backup_end_time logicalDeviceName physicalDevicePath DBSize_in_MB
112404 1 master FULL 2014-07-21 13:41:24.000 2014-07-21 13:56:26.000 master /sybase/syb155/data/master.dat 100
Qscript Execution Succeeded!
Database Example
F:\Program Files\CommVault\ContentStore\Base>qoperation execscript -sn QS_GetSybaseJobList -si "@i_clientName='sybserver4'" -si "@i_instanceName='S155syb4'" -si "@i_ startTime='07-21-2014 01:00:00'" -si "@i_endTime='07-21-2014 15:00:00'" -si "@i_databaseName = 'db4'" -si "@i_noTimeRestriction = '0'" -si "@i_enableDateTimeFormat = '1'"Database Output
Qscript Output:
112404 13 db4 FULL 2014-07-21 13:41:24.000 2014-07-21 13:56:26.000 db4 /sybase/syb155/data/db4.dat 1400
112404 13 db4 FULL 2014-07-21 13:41:24.000 2014-07-21 13:56:26.000 db4_log /sybase/syb155/db_log/db4_log.dat 80
112407 13 db4 INCR 2014-07-21 13:57:05.000 2014-07-21 13:57:39.000 N/A N/A N/A
112408 13 db4 INCR 2014-07-21 13:58:19.000 2014-07-21 13:58:49.000 N/A N/A N/A
How do I separate the data device and log device for a Sybase database?
it is required to have data and log existing on separate devices to attain transaction log backups. A user cannot run a transaction log backup if data and log are on a same device for a particular database. Either create a new database having a data and a log device or alter existing database to have the data and the log device separate. Create a database command to have separate data and log device during database creation. If a database already has data and log on the same device, separate the data and log device using the step below.:
use master
Go
alter database dbname log on logdevice
GO
sp_dboption dbname , ‘single user’, True
Go
sp_logdevice dbname,logdevice
Go
dump tran dbname with truncate_only
go
create table dummy (a char(1800)) go insert into dummy values (“aaa”)
go 50
drop table dummy
go
dbcc traceon (3604)
go
dbcc findstranded (dbname)
go
dump tran DB-NAME with truncate_only
go
sp_helpdb dbname --- Verify data and log is separate
go
sp_dboption dbname,single,false
goExample:
The database “mix” has data on logs initially on same device
Change log device and separate it from data device.
1> alter database mix log on dev2="10M"
2> go
Extending database by 2560 pages (10.0 megabytes) on disk dev2
Warning: Using ALTER DATABASE to extend the log segment will cause user thresholds on the log segment within 128 pages of the last chance threshold to be disabled.
1> sp_logdevice mix,dev2
2> go
DBCC execution completed. If the DBCC printed error messages, contact a user with a System Administrator (SA) role.
DBCC execution completed. If DBCC printed error messages, contact a user with a System Administrator (SA) role.
syslogs moved.
The last-chance threshold for database mix is now 16 pages.
(return status = 0)
1> dump tran mix with truncate_only
2> go
1>use mix
2>go
Create a temporary table and drop it.
1>create table dummytab (a char(1800))
2>go
1>insert into dummytab values ('aaa')
2>go 50
(1 row affected)
50 xacts:
1> drop table dummytab
2> go
1> use mix
2> go
1> dbcc traceon(3604)
2> go
DBCC execution completed. If DBCC printed error messages, contact a user with System Administrator (SA) role.
1> dbcc findstranded (mix)
2> go
Found 1 stranded extent(s) in database 8.
2> go
2> go
There are no stranded extents in database 8.
1> sp_helpdb mix ->Check if mix data and log status is removed
2> go
name db_size
owner dbid
created
durability
lobcomplvl
inrowlen
status
mix 30.0 MB
sa 8
Mar 13, 2014
full
0
NULL single user
(1 row affected)
device_fragments size usage
created free kbytes
dev1 20.0 MB data only
Mar 13 2014 4:07PM 17056
dev2 10.0 MB log only
Mar 20 2014 11:11AM not applicable
__
log only free kbytes =
10168
(return status = 0)
SP_dboption mix , “single user”, false
Are there additional steps to take when the Sybase Agent is installed on an existing client?
If you install the agent on an existing client, you must run the cvpkgchg command to update the group permissions after you install the agent. You can use this command to set the group permissions to the correct level, which prevents the backup job from failing. For information on how to change the group permissions, see Changing UNIX Groups and Permissions on UNIX Clients.
Is there a way to back up transaction logs with a separate storage policy?
Yes. You can associate an incremental storage policy with the data storage policy. After you make the storage policy association, the transaction log backups use the incremental storage policy.
How can you place a Sybase server offline?
Follow these steps to place a Sybase server offline:
To connect to the Sybase server using ISQL, execute the following command with suitable parameters:
isql -Uusername -Ppassword -Sserver name -
Execute the following command to shut down the Sybase server:
shutdown
Alternatively, for Windows, you can also shut down the Sybase server by stopping the dataserver service SAP SQLSERVER_<sybase_servername>.
For example, if ASE server name is "winsybase", then stop the service SAP SQLSERVER_WINSYBASE.
Can I use the Commvault software to protect SAP Advantage Databases?
You can use the File System Agent to protect SAP Advantage Databases. Perform the following operations to protect SAP Advantage Databases:
Configure pre- scripts and post-scripts that use the SAP Advantage native database commands (Subclient Properties dialog box, Pre/Post Process tab, Pre-Backup Process box, Post-Backup box).
Perform backup operations on the subclient.
How is the number of streams used for a Sybase snapshot, backup copy, or auxiliary copy restore determined?
Snapshot restores of the database may run with fewer streams than the number of streams you choose. This is because the number of streams for a snapshot restore is determined by the number of files to be restored. The snapshot restore procedure makes the best effort to increase the number of streams used for the restore and to therefore reduce the restore time. However, it is limited by the number of files to be restored. A restore of a log file snapshot is limited to one stream, since log files are relatively small.
The number of streams used for a restore from a backup copy or auxiliary copy is the lesser of the following criteria:
The number of streams used to make the backup copy or auxiliary copy
The number of streams you specify in the GUI used to start the restore
