Credential owners can delete a credential from Credential Manager.
If a credential entity is active in your CommCell environment, you cannot delete it.
Only the owner of an account can perform this procedure.
If you need to change a credential owner, see Changing Ownership of a Credential in Credential Vault.
In the CommCell Console, open Credential Vault.
In the Manage credentials dialog box, select the credential that you want to remove from the list, and then click Delete.
To confirm deleting the credential, click OK.
