Users and user groups must be assigned permission before they can use a credential for CommCell configurations. Credential owners can give users permissions to use the credential.
This procedure assumes that you have already added a credential to Credential Vault.
For information about creating a new credential, see Adding a Credential to a Built-in Credential Vault and Adding a Credential to a CyberArk Credential Vault.
Only the owner of an account can perform this procedure.
If you need to change a credential owner, see Changing Ownership of a Credential in Credential Vault.
In the CommCell Console, open Credential Vault.
In the Manage Credentials dialog box, select the credential that you want to change from the list, and then click Edit.
In the Modify credential dialog box, click the Security tab, and then click Add.
In the Add Users and Groups dialog box, select a user or user group from the list.
Tips
Use the Domain list to filter the users by domain.
Use the Find feature to locate specific users and user groups by keywords.
Click Add.
The user or user group name appears in the box at the bottom of the dialog box.
From the Please select Role list, select custom role and then select the Use Credential permission under Credential Manager.
