Job Management (General)
Use this dialog box to set the job alive check interval and to establish the priorities of individual jobs.
General
Job Alive Check Interval (Mins)
Allows you to specify the time interval (in minutes) by which active jobs are monitored. By default, the time interval is 5 minutes.
Job Stream High Watermark Level
The total number of jobs (total streams) allowed in the CommServe.
Note: This setting does not affect reports. (The maximum number of reports that can run at one time is 50.)
Queue Jobs if other conflicting jobs are active
The option to start jobs in a Queued state if they conflict with other running jobs. After the conflicting jobs are completed, the queued jobs resume automatically. Jobs conflict with other jobs if the operation is performed on the same CommCell object, such as a subclient, CommServe database, or storage policy. This option also can be set at the client level. For information on setting this option at the client level, see Queuing Jobs. Note: On Demand Data Protection jobs are always queued because the directive and content files can change with every run.
The Queue jobs if other conflicting jobs are active option is not compatible with Indexing Version 2.
Queue Jobs if activity is disabled
Specifies that jobs will go into the Queued state if activity control for these jobs is disabled. Once activity control for these jobs is enabled again, the queued jobs will resume automatically.
Allow running jobs to complete past the operation window
Specifies that jobs that run past the operation window rule set for these jobs are allowed to run until completion. Without this option selected, the jobs will go into a Pending/Queued state.
Queue Scheduled Jobs
Specifies that all scheduled jobs will go into the Queued state. These jobs can be resumed manually using the Resume option, or by disabling this option.
Do not start backups on disabled client
When selected, backups will not be performed for clients that are disabled.
Enable Multiplexing for Oracle
When selected, Oracle backup streams can multiplex and write to fewer tapes instead of requiring a tape per stream of backup.
Enable Multiplexing for database agents (non-Oracle/RAC)
When selected, backup streams of database agents other than Oracle/RAC can multiplex and write to fewer tapes instead of requiring a tape per stream of backup.
Enable Job Throttling at Client Level
When selected, the Enable Job Throttle check box on the Job Configuration tab of the Advanced Client Properties dialog box is available. For information on client-level job throttling, see Throttling Backup Jobs.
Show individual virtual machine jobs in job controller
Select this option to display child jobs for VMs that are part of a hypervisor that uses Indexing Version 2 for VM-centric operations. By default, only parent jobs for the subclient or backup set appear in the job controller.
Job Pre-Emption Control
If you select default values for all the options, then the options do not appear on the interface going forward. To bring the options back, run the following qoperation execscript qcommand: qoperation execscript -sn SetKeyIntoGlobalParamTbl.sql -si RMRestoreInterruptOtherJobs -si n
Restore Preempts Other Jobs
This option is selected by default. Do not clear this option unless specifically instructed to do so.
Select this check box to have restore jobs preempt other jobs.
Backup Preempts Other Backups
Select this check box to have backup jobs preempt other jobs.
Backup Preempts Auxiliary copy
Select this check box to have backup jobs preempt auxiliary copy jobs.
Job Management (Job Updates)
Use this dialog box to view or to modify how often information must be updated for data protection, data recovery or data collection operations in the Job Details dialog box.
Agent Type
Lists the agent types that are available.
Protection (Mins)
Specifies the time interval in minutes by which data protection/data collection operation details of an Agent are updated in the Job Details dialog box. Click the integer in the column to change the time interval.
Recovery (Mins)
Specifies the time interval in minutes by which an agent type's data recovery operation details are updated in the Job Details dialog box. Click the integer in the column to change the time interval.
Changes made to the protection time interval or recovery time interval will not affect job updates.
State update interval for ContinuousDataReplicator
Specifies the time interval (in minutes) at which ContinuousDataReplicator will transfer Replication Logs from the source computer to the destination computer. This will happen when there has not been sufficient change activity to fill the log and cause automatic transfer.
Administration Job Details (General)
Use this dialog box to view the job details of this administration operation. Not all fields are applicable to all types of administration operations.
Job ID
A unique number allocated by the Job Manager that identifies this operation.
Operation
The type of administration operation.
Storage Policy
The storage policy to which this operation is directed.
Storage Policy Copy
For an Auxiliary Copy operation, the secondary copy for which the data from the source copy is being copied to. For a Data Verification operation, the primary or secondary copy whose data is being verified.
MediaAgent/Source MediaAgent
Displays the MediaAgent name from which this operation originated.
Destination MediaAgent
Displays the MediaAgent name of the destination copy for Auxiliary Copy operation.
Total Data Processed
Displays the total amount of that has been copied at this time.
Data Transferred/Data Transferred on Network
Displays the amount of data transferred through the network. This amount of data is calculated by adding all the data written attempts by this job. Enabling data deduplication or compression on the source reduces the amount of data transferred over the network.
If the job completed with multiple attempts or if the data included sparse files, metadata, etc, the data transferred may be larger than the application size.
Total Data to Process
Displays the total amount of that must be copied during this operation. This amount is calculated by adding application size of all jobs ran to the source storage policy copy.
Percent complete
The percentage completion status of this operation at the present time.
Note: When you run a DDB verification with Verification of Existing Jobs on Disk and Deduplication Database or Reclaim idle space on Mount Pathsoption, the Percent Complete is per phase. Both the phases are 50% each.
Average Throughput
This information is available for auxiliary copy job. The average data transfer rate (in GB of data per hour) based on all data transfer attempts that have taken place.
It is calculated as:
Total of all data copied for all the storage policy copies / The total time taken in copying the data.
Start Time/Started Time
The date and time of the CommServe when this operation started.
Estimated Completion Time
The time the Job Manager has estimated that this operation will be completed.
Notes:
For auxiliary copy operation, this estimated completion time is based on the Average Throughput.
When you run a DDB verification with Verification of Existing Jobs on Disk and Deduplication Database or Reclaim idle space on Mount Paths option, the Estimated Completion Time is per phase of the DDB verification job.
Priority
The job priority that is assigned to this operation.
Status
Displays the job status of this operation. For descriptions of job statuses, see Job Status Descriptions.
Last Job Update Time
The last time the Job Manager updated this operation.
Job Started By/User Name
The name of the CommCell user who initiated this operation.
Job Started From
Indicates where this operation has started from, either from a CommCell Console, Web Start application, or from a scheduled job.
Use Scalable Resource Allocation
Displays the status of the selection of Use Scalable Resource Allocation option.
If status is Yes, then Use Scalable Resource Allocation option is enabled during data verification or auxiliary copy operation, and the scalability of the auxiliary copy/data verification operation is enhanced and the CommServe resources are optimally utilized.
If status is No, then this option is disabled during data verification or auxiliary copy operations.
DDB Name
Displays the name and ID of the DDB for which the deduplicated data verification job is run.
Verification Type
The type of deduplicated data verification operation that was conducted, either full or incremental.
Data Verification Type
Displays the data verification option name that was used to run the deduplication data verification job.
Reason for Job delay
Includes a detailed description of the reason why this operation may be pending, waiting or failing. Reasons may include resource contention, media issues, application specific errors, or operation control issues. Click on the Error Code to review the troubleshooting articles available from the customer support website.
Library
Displays the name of the library for which:
An inventory operation is being performed
Media is being erased during this erase media operation
Media is being exported during this scheduled export media operation.
A drive cleaning operation is being performed.
Use this field to enter a description about the entity. This description can include information about the entity's content, cautionary notes, etc.
Disaster Recovery Backup Operations
Backup Type
The type of Disaster Recovery Backup operation that is being conducted, either full or differential.
Database
The database containing the metadata to be backed up during this operation.
Export Media Operations
Media Count
The number of media that has been exported.
Successfully Exported
The number of media that the scheduled export media operation has successfully exported at this time.
Failed to Export
The number of media that the scheduled export media operation has failed to export at this time.
Total
The total number of media that is required to be exported by the operation.
Erase Spare Media Operations
Media Count
The number of media that has been erased.
Successfully Erased
The number of media that an erase media operation has successfully erased at this time.
Failed to Erase
The number of media that an erase media operation has failed to erase at this time
Total
The total number of media that is required to be erased by the operation.
Inventory Operations
Inventory Type
The type of inventory operation (i.e. Search, Full, Quick, Verify, or Discover) that is being conducted.
Source Job ID
The job ID associated with this operation (i.e. data protection or data recovery operation) that initiated an inventory operation.
DrivePool
The name of the drive pool that initiated this operation.
Media Barcode
The user configurable identifier provided for the media.
Media Unique ID
A unique ID generated by the software for the media, when the media was discovered.
Drive Operations
Drive Name
The name of the drive for which a drive cleaning operation is being performed.
Administration Job Details (Attempts)
Use this dialog box to view the phase attempts of an administration operation. Not all fields are applicable to all types of administration operations.
Phase
Identifies the phase of this operation.
Start Time
The date and time on the CommServe when that attempt of the operation started.
End Time
The date and time on the CommServe when that attempt of the operation ended.
Elapsed Time
The duration of time consumed by that phase of the operation (hh:mm:ss).
Transfer Time
The time taken for the data to be transferred.
Data Transferred
The amount of data that has been transferred.
Throughput
The data transfer rate.
Status
Displays the job status for that phase of the operation. For descriptions of job statuses, see Job Status Descriptions.
Administration Job Details (Progress)
Use this dialog box to view the progress of an administration operation. Not all fields are applicable to all types of administration operations.
Note: If there are any stream reservation failures for an auxiliary copy operation, the description box will display the reasons for such failures. In case there are multiple destination copies, you must click on individual copy to view the related stream reservation failure message.
Source Copy or Copy Name
For an auxiliary copy operation, displays the name of the copy from which the data is being copied. For a data verification operation, the copy that is being verified.
Destination Copy
Displays the name of the copy to which data is being written.
Current Phase
Identifies the current phase of the operation.
Percent Complete
A percentage completion status of the operation.
Data Copied
Amount of data (in GB) copied at this time during the auxiliary copy operation.
Data Size
Displays the amount of that has been transferred.
Data TO Be Copied
Total Amount of data that has to be copied (in GB) during the auxiliary copy operation.
Overall Throughput (GB/hr)
The data transfer rate (in GB of data per hour) based on all data transfer attempts that have taken place. It is the sum of throughput from all the current active streams.
Number of Running Streams
Displays the current number of active streams that are being used for the auxiliary copy operation.
Multiplexing Factor
Displays the multiplexing factor that is configured for the secondary copy.
Number of Combine Streams
Displays the number of combine streams enabled on secondary copy.
Throughput Unit (GB/Hr)
Displays the transfer rate of all active streams.
Elapsed Time
The duration of time consumed by this phase. (hh:mm:ss).
The last time the Job Manager received job updates for the operation.
Status
Inventory Operations Only:
Number of slots already scanned
Identifies the number of slots that have been scanned for media. This information is displayed only for Full or Quick Inventory.
Number of slots remaining to be scanned
Identifies the number of slots that have not been scanned for media. This information is displayed only for Full or Quick Inventory.
Download Updates Only:
Total Files to Download
The total number of updates that will be downloaded during this operation.
Files Downloaded
The total number of updates that have been downloaded up to the present time.
Size of Files Downloaded
The total size (in bytes) of the files that were downloaded up to the present time.
Current Throughput (GB/Hr)
Displays the current rate of transfer. The rate is adjusted as the throughput changes (for example, when the transferred data undergoes an update).
Estimated Completion Time Based on Current Throughput
Displays the time it will take to copy the data based on the Current Throughput.
Check Readiness:
Checks the readiness of a client.
Network
Runs a network check between the client, CommCell, and MediaAgents.
Resource/Capacity
Runs a check on the resources and capacity of the client.
Include disabled entities
Runs a check on disabled entities.
Application Check
Runs a check on the database applications on the client.
Additional Resources
Runs a check on the following:
Connection between client and remote software cache pair client.
Connection between laptop client and Edge Index Server client.
Connection between client and log monitoring index client.
Administration Job Details (Streams)
Use this dialog box to determine the number of streams that are running for this auxiliary copy operation. Read and write streams are combined on the same row.
No
The stream number.
Status
Displays the Job Status for the particular data stream of this operation. For descriptions of job statuses, see Job Status Descriptions.
Native Data
The amount of data (in uncompressed bytes) that has been transferred to the copy.
MediaAgent
The MediaAgent from which data is content indexed.
Compressed Data
The amount of data (in compressed bytes) that was included during that attempt of this operation.
Source MediaAgent
The MediaAgent of the drive/mount path that is reading data from the source copy.
Drive/Mount Path
The drive or mount path that is reading the data for content indexing.
Source Drive/Mount Path
The drive or mount path that is reading data from the source copy.
The MediaAgent of the drive/mount path that is writing data to the destination copy.
Destination Drive/Mount Path
The destination drive or mount path that is writing data to the destination copy.
Storage Policy
The storage policy of the copy to which data is being copied to.
Source Copy
Displays the name of the copy from which the data is being read.
Source Stream No
Displays the number of source stream.
Destination Copy
Displays the name of the destination copy to which data is being written.
Destination Stream No
Displays the stream number that is used during copy operation. This number will be same as source stream number if you don't have Combine Source Data Stream option enabled on secondary copy and Distribute data evenly among multiple streams for offline read operations enabled on the Storage Policy Properties dialog box.
Total Data to Copy
Displays the amount of application data to be copied by this stream.
Data Copied
Displays the amount of application data copied by this stream at this time.
Displays the current throughput of each active stream.
Displays the amount of data transferred through the network by this stream.
Overall Throughput
The overall data transfer rate of the job (GB/hr).
Total Bytes to Copy
The total number of bytes remaining to be copied.
Maximum Number of Readers
Displays the number of streams selected to copy in parallel when the auxiliary copy job was initiated.
Number of Readers in Use
Displays the number of readers currently in use for the auxiliary copy job.
Media Prediction Job Details (General)
Use this dialog box to view the job details of a list media operation.
Job ID
Start time
The date and time on the CommServe when this operation started.
Client Computer
The client computer from which the this operation is initiated.
DataAgent
The agent on the client computer from which the this operation is initiated.
Backup Set
The backup set from which this operation is initiated..
User Name
The user name associated with the user initiating the job.
Job Started From
Indicates how this operation originated - e.g., schedule, interactive, etc
Backup/Information Management Job Details (General)
Use this dialog box to view the job details of a data protection, Offline Content Indexing, or Information Management operation. Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent for which the information is being displayed.
Job ID
Policy Name
Specifies the Automated Content Classification Policy name for the Information Management job.
Backup/Content Index Type
The type of operation that is being conducted.
Index
Indicates whether this migration operation is creating a new index (displays New Index) or not (displays a blank value).
Priority
The priority that is assigned to this operation.
Total number of files (databases or mailboxes)
The number of items that are included in this operation such as files, mailboxes, or databases.
Number of Files (mailboxes or databases) transferred
The number of files and directories (mailboxes or databases) that this operation has transferred at this time.
Start time
Status
The current status of the job. For descriptions of job statuses, see Job Status Descriptions.
The time at which the last job update was obtained.
Percent Complete
The percentage of the job that has completed.
User Name
The name of the user from which the job was initiated.
Client Name
The client computer to which the subclient belongs.
DataAgent (Agent Type)
The agent on the client computer that is performing this data protection operation.
Instance/Partition
The application instance/partition on the client computer for which this operation is taking place.
Database/Backup Set
The database or backup set to which the subclient belongs.
Subclient
The subclient that is being included in this operation.
Storage Policy
MediaAgent
The MediaAgent to which this operation is directed.
Backup Level
The backup level that was specified in the Subclient Properties dialog for database agents that support multi-level incremental backups.
Job Started By
Job Started From
Indicates where this operation originated from, either from the CommCell Console, from a schedule, or a third party interface.
Database Size
The size of the index for the content indexing operation.
Scan Type
Displays the type of scan used for this operation.
Scan Change Reason
Displays the reason for a scan change, if during the operation a change of scan type occurred.
Software Compression
Indicates the level of software compression (e.g., client, MediaAgent) used during the operation.
System State
Indicates if system state was backed up during the operation.
Use this field to enter a description about the entity. This description can include information about the entity's content, cautionary notes, etc. View RMAN Log
Click to display the RMAN log for the selected Oracle backup or restore job.View BR Tools Log
Click to display the BRTools log for the selected SAP for Oracle backup or restore job.View Media
Click to view the information about the media used by the backup job.
(The detail information below are displayed only for Content Indexing operations)
Files Indexed
The number of files indexed.
Files Failed to Index
The number of files that failed to be indexed.
Files Skipped for Index
The number of files skipped during the content indexing operation.
Backup/Information Management Job Details (Attempts)
Use this dialog box to view the phase attempts of this data protection, Offline Content Indexing, or Information Management operation. Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent for which the information is being displayed
Phase
Start Time
The date and time on the CommServe when that attempt of this job started.
End Time
The date and time on the CommServe when that attempt of this job ended.
Elapsed Time
The duration of time consumed by that phase of this operation (hh:mm:ss).
Transfer Time
Size on Media
The amount of data that was transferred to the media.
Note:When viewing the jobs from the client level, the amount displayed is an uncompressed size and includes valid and invalid attempts of the backup jobs, and thus, may be larger than the size displayed when viewing the jobs from any other level.
Throughput (GB/hr)
The data transferred rate.
Status
Displays the Job Status for that phase of this operation. For descriptions of job statuses, see Job Status Descriptions.
Library
The name of the library in which this operation was conducted.
MediaAgent
The name of the MediaAgent through which the job is occurring.
DrivePool
The name of the drive pool that initiated the operation.
Storage Policy
Copy
For a stream that writes the data, the copy to which data is being copied to. For a stream that reads data, the copy to which data is being copied from.
Streams
The number of data streams that is being used for that phase of the operation.
View RMAN Log
View BR Tools Log
View Media
Backup/Information Management Job Details (Progress)
Use this dialog box to view the progress of the data protection, or Information Management operation. Not all fields are applicable to all agents.
Current Phase
Identifies the current phase of this operation. The number of backup phases varies depending on the agent.
State
The status of this operation up to the present time.
Attempt start time
The time of the latest attempt of this operation started.
Elapsed Time
Number of files transferred
The current number of files that are being transferred.
Skipped Files
The current number of files that are being skipped.
Failures
Includes the number of files and folders that failed to be included in this operation.
Size of Application
The amount of application data that has been protected (actual size of the backed up data).
The amount of data transferred through the network calculated by adding all the data written attempts by this job. Enabling data deduplication or compression on the source reduces the amount of data transferred over the network.
Compression
The percentage of compressed data during this operation.
Transfer Time
The time taken thus far for the data to be transferred.
The time that the system estimates for this job to be completed.
The last time the Job Manager received job updates for this operation.
Percent Complete
A percentage completion status of this operation.
Current Throughput
The data transferred rate for the current operation. The rate is adjusted as the throughput changes (for example, when the transferred data undergoes an update).
Average Throughput
The average data transfer rate (in GB of data per hour) based on all data transfer attempts that have taken place, and the percentage of time spent in the following activities: read, write, network, and DDB lookup.
Currently Backing Up
The drive or mount path of the data being protected.
Reason for Job Delay
Includes a detailed description of the reason why this operation may be pending, waiting, or failing. Reasons may include resource contention, media issues, application specific errors, or job control issues.
View RMAN Log
View BR Tools Log
View Media
Backup/Information Management Job Details (Streams)
Use this dialog box to determine the number of streams that are running for this data protection, Offline Content Indexing, or Information Management operation. The information in this dialog box is only available during those job phases that actually transfer data. Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent for which the information is being displayed
No.
The stream number.
Status
Native Data/Size of Application
The amount of data (in uncompressed bytes) that has been transferred. Note that the number of bytes backed up for a Unix raw partition job displays as '0' on the CommCell Console even for a successful data protection operation. However, the correct number of bytes is displayed in the Job History.
Compressed Data
The amount of data (in compressed bytes) that has been transferred.
Transfer Time
MediaAgent
Drive/Mount Path
The drive or mount path that is being used to write the data.
Storage Policy
Copy
For a stream that writes the data, it displays the type of storage policy copy to which data is being copied to. For a stream that reads data, it displays the type of storage policy copy to which data is being copied from.
Type
The type of data transfer during the stream, either read or write.
Throughput (GB/Hr)
The amount of data (in GB) that is transferring through the stream per hour.
The maximum number of data readers that can be used by the data protection operation.
The number of readers currently being used for the data protection operation.
View RMAN Log
View BR Tools Log
View Media
Information Management Job Details (Phase Details)
Use this dialog box to view the details of each phase of the Information Management operation.
Phase: Search
Displays the details for the Search phase of the Information Management operation.
Phase: Legal Hold
Displays the details for the Legal Hold phase of the Information Management operation.
Phase: Restore to Review
Displays the details for the Restore to Review phase of the Information Management operation.
Phase: Tagging
Displays the details for the Tagging phase of the Information Management operation.
Media Used By Job ID
Use this dialog box to view information about the media used by backup job.
Status
Indicates the current status of the media. (See Identifying Media Icons for more information.)
Barcode
The barcode label for the media. For disk libraries, this is displayed as Disk.
Library
f the media is available in a library, the name of the library in which it currently resides.
If the media is exported, the name of the library in which the last data protection job was conducted.
Location
The location of the media.
If the media is inside the library, this field displays the storage slot or the Drive Name in which the media resides.
If the media is outside the library and you entered a location when you exported it (e.g., Shelf 4 in Storage Room), that location is displayed here. Note that the MediaAgent has no control over media once they leave the library; it is your responsibility to ensure that exported media are stored in the location entered.
For disk libraries the mount path is displayed
Storage Policy
The storage policy used to write to the media.
Copy
The storage policy copy used to write to the media.
Stream No.
The stream number used to write to the media.
Click to print the details displayed in the dialog box.
Save to File
Click to save the details displayed in the dialog box either as a tab (.xls) or comma (.csv) separated file.
Report Job Details (General)
Use this dialog box to view the job details of a report operation.
Job ID
Start Time
User Name
Job Started From
Indicates where this operation has started from, either from a CommCell Console (stand-alone or remote web-based application) or from a scheduled job.
Report Type
The name of the report that initiated this operation.
Use this dialog box to view the general details of the operation. Note that all the fields described in this help may not be available and only those fields displayed in the dialog box are applicable to the operation for which the information is being displayed.
Job ID
Priority
Start Time
User Name
Job Started From
Client Name
Displays the client whose data was included in the operation.
Agent Type
The agent that performed the operation.
Use this dialog box to view the progress of the operation. Note that all the fields described in this help may not be available and only those fields displayed in the dialog box are applicable to the operation for which the information is being displayed.
Current Phase
State
Displays the status for that phase of the operation.
Attempt Start Time
The date and time on the CommServe when the attempt of the phase started.
Elapsed Time
The number of files that will be downloaded during the update process.
Files Downloaded
The number of files downloaded.
The total size of the downloaded files.
Percent Complete
The percentage of the update process completed.
Client Status
Displays the clients' update status. This field can be filtered or sorted by update status.
Reason for job delay
Includes a detailed description of the reason why the operation may be pending, waiting or failing. Reasons may include resource contention, cache corruption, media issues, application specific errors, or operation control issues. If cache corruption is found, information pertaining to the missing update or service pack will be provided.
Use this dialog box to view the phase attempts of the operation. Note that all the fields described in this help may not be available and only those fields displayed in the dialog box are applicable to the operation for which the information is being displayed.
Phase
Start Time
End Time
Elapsed Time
Status
Job Details (Client Status)
Use this dialog box to view the update status of clients.
Client
Lists the clients that have been updated within the time range specified.
Status
Displays the current update status for the specific client.
Reason
Displays the reason for the current status for the specific client.
Installed Updates
Lists the updates that are installed on the client.
Total Clients
The total number of clients that have been updated.
Clients Already Up-To-Date
The total number of clients that have been up-to-date before the update operation.
Successful Clients
The total number of clients that have been successfully updated.
Pending Clients
The total number of clients that are waiting to be updated.
Failed Clients
The total number of clients that failed to be updated.
Clients Partially Successful
The total number of clients that have been partially updated.
Clients In Progress
The total number of clients that have not completed the update operation (still running).
Restore Job Details (General)
Use this dialog box to view the job details of this data recovery operation. Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent for which the information is being displayed.
Note that for DataArchiver agents, some active data recovery jobs are combined into one job in the Job Controller dialog box.
Job ID
A unique number allocated by the Job Manager for this data recovery operation.
Priority
The priority that is assigned to this data recovery operation.
Start time
The date and time on the CommServe when this data recovery operation started.
Total number of files (mailboxes, databases) to be Restored
The number of items that are restored/recovered in this data recovery operation.
Source Client Computer
The client computer from which the data originated.
The agent that conducted this data recovery operation.
Instance/Partition
The application instance/partition on the client computer for which this data recovery operation is taking place.
Database/Backup Set
The database or backup set on the source client computer from which this restore/recovery operation originated.
Destination Client Computer
The client computer to which the data is being restored/recovered.
MediaAgent
The MediaAgent to which this data recovery operation is directed.
User Name
The name of the user initiating the job.
Job Started By
The name of the CommCell user who initiated this data recovery operation. For DataArchiver stub recoveries from Outlook, the Exchange Mailbox Alias Name will be displayed.
Job Started From
Indicates where this data recovery operation originated from, either from the CommCell Console, a schedule, or a third party interface.
View RMAN Log
View BR Tools Log
Restore Job Details (Progress)
Use this dialog box to view the job details of this data recovery operation. Not all fields are applicable to all agents.
Current Phase
Identifies the current phase of this data recovery operation.
State
Displays the status of the job.
Attempt Start Time
Displays the start time of the job.
Elapsed time
The duration of time consumed by that phase of this data recovery operation (hh:mm:ss).
Number of Files Restored
The number of files and directories (or mailboxes, databases, or archive files) that this data recovery operation has transferred at this time.
Failed Count
The number of files and directories (or mailboxes, databases, or archive files) that this data recovery operation has failed to restore at this time.
Skipped Count
The number of files and directories (or mailboxes, databases, or archive files) that this data recovery operation has skipped at this time.
Data Transferred
The amount of data that has been restored/recovered. (In the case of a File Level restore using the Image Level iDataAgent, this is the size of the extents involved in the restore.)
Current Database Being Restored
The database being restored for this data recovery operation.
The last time the Job Manager received job updates for this data recovery operation.
Skip Errors and Continue
When selected, all media errors will be ignored and the operation will continue.
Toggle
Click this button to select/deselect the Skip Errors and continue option.
Includes a detailed description of the reason why this data recovery operation may be pending, waiting, or failing. Reasons may include resource contention, media issues, application specific errors, or job control issues.
View RMAN Log
View BR Tools Log
Restore Job Details (Streams)
Use this dialog box to view the streams of this data recovery operation. Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent for which the information is being displayed
No
The stream number.
Status
The status of the data recovery stream. For descriptions of job statuses, see Job Status Descriptions.
Native Data
The amount of data (in uncompressed bytes) that has been recovered for the stream.
Compressed Data
The amount of data (in compressed bytes) that was included during the stream.
Files Transferred
The number of files that have been recovered for a stream up to the present time.
Files Failed
The number of files that failed to recover during the stream.
MediaAgent
The MediaAgent of the data recovery stream.
Drive/Mount Path
The drive/mount path of the data recovery stream.
Storage Policy
The storage policy of the copy to which data is being recovered.
Copy
The copy from which the data is being recovered.
Currently Restoring
The file that is currently being recovered.
View RMAN Log
View BR Tools Log
Restore Job Details (Attempts)
Use this dialog box to view the phase attempts of this data recovery operation. Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent for which the information is being displayed
Phase
Identifies the phase of this data recovery operation.
Attempt Number
The number of times the phase of the job phase was attempted.
Files Restored
The number of files and directories that have been restored/recovered at this time.
Failed
The number of files and directories that have failed to be restored/recovered at this time.
Skipped
The number of files and directories that have been skipped at this time.
Start Time
The date and time on the CommServe when that attempt of this data recovery job started.
End Time
The date and time on the CommServe when that attempt of this data recovery job ended.
Elapsed Time
Status
Displays the Job Status for that phase of this data recovery operation. For descriptions of job statuses, see Job Status Descriptions.
View RMAN Log
View BR Tools Log
Index Restore Job Details
Use this dialog box to obtain job details for an index restore job.
Job ID
The job ID of this index restore job.
Operation
The type of job.
Client
Backup Set
The backup set associated with the operation.
MediaAgent
The MediaAgent performing the index restore job.
Started Time
The date and time that the index restore job started.
User Name
The name of the user that initiated this index restore job.
Workflow Process Details (General)
Use this dialog box to view the job details for a workflow job.
Job ID
A unique number allocated by the Job Manager that identifies the job.
Operation
The name of the workflow.
Client Name
The client the workflow is running on.
Started Time
Status
Displays the job status for that phase of the operation, for example, Suspended. For descriptions of job statuses, see Job Status Descriptions.
Phase
Identifies the phase of this job, for example, Get Administrator Approval.
The last time the Job Manager received job updates for the job.
Percent Complete
The percentage of the job that is complete.
User Name
Job Started From
Indicates how this operation started, for example, Interactive.
Includes a detailed description of the reason why the job may be pending, waiting or failing. For example, a workflow job could be waiting for user input.
Use this field to enter a description for the workflow job.
Workflow Process Details (Attempts)
Use this dialog box to view the phase attempts for the workflow job.
Phase
Identifies the phase of this job.
Start Time
The date and time on the CommServe when the phase started.
End Time
The date and time on the CommServe when the phase ended.
Elapsed Time
The duration of time consumed by the phase (hh:mm:ss).
Status
Displays the job status for that phase, for example, Suspended. For descriptions of job statuses, see Job Status Descriptions.
Workflow Process Details (Properties)
Use this dialog box to view and edit workflow inputs and variables.
Inputs
The name and value of the inputs entered to execute the workflow.
Variables
The name and value of the variables used to execute the workflow.
Change Resume Interval
Use this dialog box to change the amount of time that the Commvault software waits before resuming a suspended job. By default, the time is 30 minutes.
hr(s)
Specify the time in hours.
min(s)
Specify the time in minutes.
Multi-Job Control Dialog
Use this dialog box to suspend, resume, or kill groups of jobs in the Job Controller window. The selection of jobs listed in the Job Controller is done from the Job Controller prior to opening this dialog box.
Action
Select an action.
Suspend
Temporarily stops a job. A suspended job is not terminated, it can be restarted at a later time. Only preemptible jobs can be suspended.
Resume
Resumes a job and returns the status to Waiting, Pending, or Running depending on the availability of resources or the state of operation windows and activity control settings.
Kill
Terminates a job.
Selection
Select one group of jobs on which the selected action will take place.
All Jobs
Only the current running jobs in the Job Controller are suspended, resumed, or killed.
All Selected Jobs
From the Job Controller, highlight any or all of the jobs currently present in the Job Controller.
All Jobs For This Client
Select a client computer from the list so that only the data protection and data recovery operations for the selected client are either suspended, resumed, or killed.
Only Jobs For This Agent Type
Select this check box and choose an agent so that only the jobs for the selected agent on this client are either suspended, resumed, or killed.
All Jobs On This MediaAgent
Select a MediaAgent from the list so that only the data protection operations for the selected MediaAgent are either suspended, resumed, or killed.
All Jobs for this job Type
Select an operation type from the list so that only the jobs for that operation are either suspended, resumed, or killed.
Enter Option
Use this dialog box to start this job in a suspended state.
Start job in suspended state
Specifies that this job will start in the Job Controller in a suspended state and cannot run until the job is manually resumed using the Resume option.
Filter Definition
Use this dialog box to create or edit a filter for the jobs or scheduled jobs you would like to view in the Job Controller or Scheduled Jobs window.
Name
Type the name of the filter.
Filter By Operation
Data Protection
Displays all types of data protection operations. You can also select to filter the following types of data protection operations:
Backup
Archive/Compliance Archive
QR Volume
Data Recovery
Displays all type of data recovery operations. You can also select to filter the following types of data recovery operations:
Restore
Recovery
Admin Jobs
Displays all type of administration operations. You can also select to filter the following types of administration operations:
Auxiliary Copy
Data Aging
Data Verification
Report and others
Filter Operation
Use this dialog box to apply an existing filter or to create a new filter for the jobs or scheduled jobs you would like to view in the Job Controller or Scheduled Jobs window.
Filters
Select the filter you wish to apply from the drop-down list.
Displays the details of the filter selected in the Filters drop-down list.
Initiates the Filter Definition window to create a new filter.
Apply
Applies the filter that is selected in the Filters drop-down list to the jobs or scheduled jobs in the Job Controller or Scheduled Jobs window.
Deletes the filter selected in the Filters drop-down list.
Note: If the filter is currently active in the Job Controller or Scheduled Jobs window, it cannot be deleted.
Alert
Use this dialog box to configure and email the alerts associated with Content Indexing operation.
Configure Alert
Provides the necessary options to configure the alerts associated with this operation. Use this option to email the results of the operation as an alert.
Add/Modify Alert
Click to access the Alert Wizard to configure necessary alerts for this operation.
Delete Alert
Click to delete any existing alerts that are already configured.
Job Initiation
Select from the following options. Note that all the options described in this help might not be available and only the options displayed in the dialog box are applicable to the operation for which the information is being displayed.
Immediate
Run This Job Now
Specifies this job will run immediately.
Schedule
Specifies this job will be scheduled. When you click Configure, the Schedule Details dialog box will open and allow you to configure the schedule pattern.
Result file location on CommServe
This option is only applicable for List Media operations. Specifies the name of the file in which the results of the scheduled list media job must be saved. Click Browse to access to the Directory Browse dialog box which allows you to select the folder / file in the CommServe computer.
Automatic Content Indexing
Interval n min
You can create a schedule to run content indexing jobs automatically after a set interval of time (in minutes).
Before a job is initiated by an Automatic Content Indexing schedule, the status of the data to be content indexed is checked. The Automatic Content Indexing schedule job will not run if:
The data is currently in the process of being indexed by a different job.
There is no data to be content indexed.
No additional data has been backed up since the previous content indexing job.
If an Automatic Content Indexing scheduled job is skipped, the job will try to run again after the set interval of time has passed.
Automatic Copy
Specifies that an auxiliary copy operation will be performed at the interval specified. This operation will occur when new data that must be copied is found on the primary copy.
Interval
The time interval in which the Automatic Copy will be performed. The default interval is 30 minutes.
Automatic Verification
Specifies that a deduplication database (ddb) data verification operation will be performed at the interval specified. The data verification job runs only if new data is available on the ddb.
Interval
The time interval in which the Automatic Verification will be performed. The default interval is 30 minutes.
Save As Script
Click to open the Save As Script dialog, which allows you to save this operation and the selected options as a script file (in XML format). The script can later be executed from the Command Line Interface using qoperation execute command.
When you save an operation as a script, each option in the dialog will have a corresponding XML parameter in the script file. When executing the script, you can modify the value for any of these XML parameters as per need.
To view the command line XML values for the operations supporting save as script option, refer to Command Line documentation.
Configure Alert
Add/Modify Alert
When clicked, opens the Alert Wizard to configure necessary alerts for this operation.
Delete Alert
When clicked, deletes any existing alerts that are already configured.
Advanced
Click to select additional options.
Script Preview
Click to display the restore script, based on the selected restore options, that will be submitted to RMAN when restores are performed for the selected Oracle client.
Job Retry
Note that all the options described in this help may not be available and only the options displayed in the dialog box are applicable to the agent or operation for which the information is being displayed.
Enable Total Running Time
The maximum elapsed time, in hours and minutes, from the time that the job is created. When the specified maximum elapsed time is reached, as long as the job is in the "Running" state, it will continue; if the job is not in the "Running" state when the specified time is reached, Job Manager will kill the job.
Kill Running Jobs When Total Running Time Expires
Option to kill the job when the specified Total Running Time has elapsed, even if its state is "Running". This option is available only if you have specified a Total Running Time.
Number of resubmits on Job Failure
The number of times the Job Manager will attempt to resubmit a failed job. When the job fails, the Job Manager resubmits the job with a new Job ID. After the maximum number of resubmit attempts has been reached, if the job still fails, the Job Manager will stop resubmitting the job.
Enable Number of Retries
The number of times that Job Manager will attempt to restart the job. Once the maximum number of retry attempts has been reached, if the job has still not restarted successfully, Job Manager will kill the job. Note that this job-based setting will not be valid if restartability has been turned off in the Job Management Control Panel.
Search by Job ID
Use this dialog box to search for a job by using a job ID. To access this dialog box, right-click the CommServe, point to All Tasks, and then select Search by Job ID.
Job ID
Enter the job ID for the following types of jobs:
A job that a user runs, such as a backup job
A job that the Commvault automatically runs, such as an auxiliary copy job
