Verify that your environment meets the system requirements for Oracle RAC.
Important
Before configuring the Oracle RAC agent, you must install and configure the Oracle agent. For more information, see System Requirements for Oracle.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Oracle Exadata Database Machine is supported on the following Oracle Database versions:
Oracle 21c (21.x)
Oracle 19c (19.x)
Oracle 18c (18.x)
Oracle 12c (12.0.1.0 or more recent)
Oracle 11g R2 (11.2.0.1 or more recent)
Oracle 11g (11.1.0.7)
Oracle 21c and Oracle 23ai
Linux
Operating system |
Processor architecture |
Oracle Linux 9.x with glibc 2.34.x or a more recent version |
Oracle Linux 8.x with glibc 2.28.x or a more recent version |
Red Hat Enterprise Linux 9.x |
Red Hat Enterprise Linux 8.x |
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x and higher |
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) with glibc 2.19.x |
Oracle 19c (19.2, 19.3, 19.4, or More Recent), Oracle 18c (18.3)
AIX
Data protection on Logical Partitioning (LPAR) and Workload Partitioning (WPAR) is supported.
Operating system |
AIX 7.2 64-bit |
PowerPC |
Linux
Important
If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
Operating system |
Oracle Linux 7.x with glibc 2.17.x or a more recent version |
Red Hat Enterprise Linux 7.x |
SuSE Linux 12 SP3 Enterprise Server |
Z-Linux
Operating system |
s390x 64-bit |
s390x 64-bit |
Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system |
Oracle Solaris (64-bit) |
Windows
Operating system |
Windows Server 2022 Editions – applies only to Oracle 19c |
All Windows-compatible processors are supported |
Windows Server 2019 Editions – applies only to Oracle 19c |
Windows Server 2016 Editions |
Oracle 12c (R1, R2), 11g, 10.2.x (R2 or More Recent) Databases (Enterprise or Standard Edition)
AIX
Operating system |
AIX 7.3 64-bit |
PowerPC |
AIX 7.2 64-bit |
PowerPC |
AIX 7.1 64-bit |
PowerPC |
AIX 6.1 TL 02 SP00 or higher, 64-bit |
PowerPC |
HP-UX
Operating system |
HP-UX 11i v3 (11.31) |
Itanium |
HP-UX 11i v1 (11.23) |
Itanium |
Linux
Important
Operating system |
Oracle Linux 6.x with glibc 2.12.x or a more recent version |
Oracle Linux 5.x with glibc 2.5.x |
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x or a more recent version |
SuSE Linux 12 (Initial Release/SP1 and later SPs) with glibc 2.19.x or a more recent version |
SuSE Linux 11 (Initial Release/SP1 and later SPs) with glibc 2.9.x and higher |
Z-Linux
Operating system |
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) Enterprise Server |
s390x 64-bit |
Solaris
Operating system |
Solaris 11.x |
Solaris 10 Update 6 or equivalent |
Windows
Operating system |
Windows Server 2012 R2 Editions |
Windows Server 2012 Editions Supported on Oracle version 11.2.0.4 and more recent versions. |
Windows Server 2008 R2 Editions Server Core installations are not supported. |
Hard Drive
See Oracle: System Requirements.
Memory (RAM)
2 GB or more
Network
For Commvault communication between the RAC nodes, the nodes added to the RAC client in the CommCell Console must be able to communicate with each other over Commvault networking. For example, if direct connect is not possible, set up network tunnels.
Commvault Release Levels
All the clients in an Oracle RAC environment should be at the same Commvault release level for the best operation of the Oracle RAC configuration.
Software That Is Automatically Installed
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Windows 10 and Windows Server 2016, because these versions have the Universal C Runtime already installed.
KB2919355
KB2939087
KB2975061
KB2999226
DISCLAIMER
