Verify that your environment meets the system requirements for Oracle.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
Oracle Exadata Database Machine is supported on the following Oracle Database versions:
Oracle 21c (21.x)
Oracle 19c (19.x)
Oracle 18c (18.x)
Oracle 12c (12.0.1.0 or more recent)
Oracle 11g R2 (11.2.0.1 or more recent)
Oracle 11g (11.1.0.7)
Oracle 21c
Support of the Express Edition is included for all operating systems that are supported by the Oracle application server.
Linux
Important
If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
Operating system |
Processor architecture |
Oracle Linux 9.x with glibc 2.34.x or a more recent version |
Oracle Linux 8.x with glibc 2.28.x or a more recent version |
Oracle Linux 7.x with glibc 2.17.x or a more recent version |
Red Hat Enterprise Linux 9.x |
Red Hat Enterprise Linux 8.x |
Red Hat Enterprise Linux 7.x |
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x or a more recent version |
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x and higher |
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) with glibc 2.19.x |
SuSE Linux 12 SP3 Enterprise Server |
Windows
Operating system |
Windows Server 2022 Editions |
All Windows-compatible processors are supported |
Windows Server 2019 Editions |
Windows Server 2016 Editions |
Oracle 19c (19.2, 19.3, 19.4, or More Recent), Oracle 18c (18.3, 18.4, 18.5, or More Recent)
AIX
Operating system |
AIX 7.3 64-bit |
PowerPC |
AIX 7.2 64-bit |
PowerPC |
AIX 7.1 64-bit |
PowerPC |
AIX 6.1 TL 02 SP00 or higher, 64-bit |
PowerPC |
HP-UX
Operating system |
HP-UX 11i v3 (11.31) |
Itanium |
Linux
Important
Operating system |
Oracle Linux 6.x with glibc 2.12.x or a more recent version |
Oracle Linux 5.x with glibc 2.5.x |
Z-Linux
Operating system |
s390x 64-bit |
s390x 64-bit |
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) Enterprise Server |
s390x 64-bit |
SuSE Linux Enterprise Server 15.5 |
s390x 64-bit |
Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system |
Oracle Solaris (64-bit) |
Windows
Operating system |
Windows Server 2022 Editions – applies only to Oracle 19c |
Oracle 12c (R1, R2), 11g, 10.2.x (R2 or More Recent) Databases (Enterprise or Standard Edition)
Express Editions of Oracle 10g and 11g (R2) Databases are supported on all operating systems that are supported by the Oracle application server.
AIX
Data protection on Logical Partitioning (LPAR) and Workload Partitioning (WPAR) is supported.
Operating system |
AIX 7.3 64-bit |
PowerPC |
AIX 7.2 64-bit |
PowerPC |
AIX 7.1 64-bit |
PowerPC |
PowerPC |
HP-UX
Operating system |
Itanium |
HP-UX 11i v1 (11.23) |
Itanium |
Linux
Important
Operating system |
NeoKylin Linux 7.4 |
x64 |
NeoKylin Linux 6 |
x64 |
SuSE Linux 11 (Initial Release/SP1 and later SPs) with glibc 2.9.x and higher |
SuSE Linux 11 (Initial Release/SP1/SP2/SP3/SP4) Enterprise Server |
s390x 64-bit |
Z-Linux
Operating system |
s390x 64-bit |
s390x 64-bit |
Solaris
Operating system |
Solaris 11.x |
Sparc T/M series |
Solaris 10 Update 6 or equivalent |
Windows
Operating system |
Hard Drive
Component |
Space required |
Software |
2 GB |
Job results folder |
256 MB |
Log folder |
256 MB |
Memory (RAM)
2 GB or more
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Software That Is Automatically Installed
File System Agent
The file system agent is automatically installed during the installation of this software, if it is not already installed. For file system system requirements, see the following:
The operating system must have been installed with at least the user level software option selected.
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Windows 10 and Windows Server 2016, because these versions have the Universal C Runtime already installed.
KB2919355
KB2939087
KB2975061
KB2999226
DISCLAIMER
